楼主 #1 2017-11-08 10:47:28
daydayup
已发帖子: 343
AllWinner全志V3s荔枝派zero板子用W25Q256,发现我烧文件系统之后,串口无输出, 直接进入芯片内部的fel
发现我烧文件系统之后,串口无输出,
直接进入芯片内部的fel,
感觉spi flash被擦掉了, 这是什么情况?
新鲜出炉 windows 版本 32M spi nor flash 版本烧录软件: sunxi-tools-win32-support_f1c100s_32M.7z
测试OK!
#2 2017-11-08 10:55:25
沉鱼
已发帖子: 161
Re: AllWinner全志V3s荔枝派zero板子用W25Q256,发现我烧文件系统之后,串口无输出, 直接进入芯片内部的fel
转载看云的文章: sunxi-fel增加对16M以上Flash的支持
由于SPI flash 的地址是24bit,也就是最大16M 地址空间,所以对于32M flash,需要增加bank切换支持。
uboot中有CONFIG_SPI_FLASH_BAR选项可以使能bank切换。
但是sunxi-fel中尚未支持,所以下载的时候超出16M会循环覆盖掉。
这里介绍对sunxi-fel增加16M以上flash支持的方法。
u-boot的支持
drivers/mtd/spi/spi_flash.c
static int write_bar(struct spi_flash *flash, u32 offset)
	u8 cmd, bank_sel;
	int ret;
	bank_sel = offset / (SPI_FLASH_16MB_BOUN << flash->shift);
	if (bank_sel == flash->bank_curr)
		goto bar_end;
	cmd = flash->bank_write_cmd;
	ret = spi_flash_write_common(flash, &cmd, 1, &bank_sel, 1);
	if (ret < 0) {
		debug("SF: fail to write bank register\n");
		return ret;
bar_end:
	flash->bank_curr = bank_sel;
	return flash->bank_curr;
sunxi-fel的支持
fel-spiflash.c
#define CMD_WRITE_ENABLE 0x06
#define SPI_FLASH_16MB_BOUN  0x1000000
# define CMD_BANKADDR_BRWR              0x17	//only SPANSION flash use it
# define CMD_BANKADDR_BRRD              0x16
# define CMD_EXTNADDR_WREAR             0xC5
# define CMD_EXTNADDR_RDEAR             0xC8
size_t bank_curr = 0;
void aw_fel_spiflash_write_helper(feldev_handle *dev,
				  uint32_t offset, void *buf, size_t len,
				  size_t erase_size, uint8_t erase_cmd,
				  size_t program_size, uint8_t program_cmd)
	uint8_t *buf8 = (uint8_t *)buf;
	size_t max_chunk_size = dev->soc_info->scratch_addr - dev->soc_info->spl_addr;
	size_t cmd_idx, bank_sel;
	if (max_chunk_size > 0x1000)
		max_chunk_size = 0x1000;
	uint8_t *cmdbuf = malloc(max_chunk_size);
	cmd_idx = 0;
	prepare_spi_batch_data_transfer(dev, dev->soc_info->spl_addr);
	//add bank support
	cmd_idx = 0;
	bank_sel = offset /SPI_FLASH_16MB_BOUN;
	if (bank_sel == bank_curr)
		goto bar_end;
	/* Emit write enable command */
	cmdbuf[cmd_idx++] = 0;
	cmdbuf[cmd_idx++] = 1;
	cmdbuf[cmd_idx++] = CMD_WRITE_ENABLE;
	/* Emit write bank */
	cmdbuf[cmd_idx++] = 2;
	cmdbuf[cmd_idx++] = CMD_EXTNADDR_WREAR;
	cmdbuf[cmd_idx++] = offset >> 24;
	/* Emit wait for completion */
	cmdbuf[cmd_idx++] = 0xFF;
	/* Emit the end marker */
	aw_fel_write(dev, cmdbuf, dev->soc_info->spl_addr, cmd_idx);
	aw_fel_remotefunc_execute(dev, NULL);
	bar_end:
	cmd_idx = 0;
重新编译sunxi-fel后就可以烧录32M flash了~
#3 2017-11-08 10:58:01
沉鱼
已发帖子: 161
看看对你有没有帮助,
我估计你写到后面的16MiB位置了,
而没有切换bank,
所以绕回头擦除了 uboot,
导致系统无法启动进入了fel
楼主 #4 2017-11-08 11:43:33
daydayup
已发帖子: 343
太好了,谢谢。
按上面的代码改了 aw_fel_spiflash_write_helper( ) 之后果然可以烧录32MiB flash了.
#5 2017-12-23 22:07:54
qianhao
已发帖子: 135
呼叫沉鱼大神 能不能让sunxi-fel支持a33
#6 2018-03-15 14:30:47
所在地: 微信 whycan_cn
已发帖子: 9,252
按这个修改, 可以通过编译。
#7 2018-04-26 10:10:50
已发帖子: 1,135
奇怪我按照这样改动,还是无法烧写32MB 文件,但烧写16MB文件正常。不知道哪里出问题了
#8 2018-04-26 10:13:36
所在地: 微信 whycan_cn
已发帖子: 9,252
正在准备找这个帖子,
改一下 sunxi-fel的f1c100s版本,
因为刚刚写W25Q256超过16M,绕回去把前面的也擦写了。
正好被你顶上来了,
我现在就改改试一试。
#9 2018-04-26 10:36:01
所在地: 微信 whycan_cn
已发帖子: 9,252
编译出来了, 正在测试,看能不能烧录32M的W25Q256.
#10 2018-04-26 10:46:58
已发帖子: 1,135
我是V3S。我刷新了一下磁盘cache重新编译然后似乎是烧成功了,uboot跑起来了说明没有绕回去把头擦了。但是后来linux加载jffs时候全是错误,跑不起来。我烧写的是网盘V3s_W25Q256_Qt5.9.1.bin和V3s_W25Q256_mplayer.bin, 同样的问题
#11 2018-04-26 10:52:02
所在地: 微信 whycan_cn
已发帖子: 9,252
你flash是 W25Q256 ?
#12 2018-04-26 11:21:30
所在地: 微信 whycan_cn
已发帖子: 9,252
测试OK!
#13 2018-04-26 12:02:51
已发帖子: 1,135
你flash是 W25Q256 ?
是的,就怕不兼容,专门去买的W25Q256
#14 2018-04-26 13:44:19
所在地: 微信 whycan_cn
已发帖子: 9,252
你执行spiflash-write之后,马上执行spiflash-read读出,
再用beyond compare或者ultra compare比较, 看烧进去的是否是读出来的。
#15 2018-04-26 14:28:40
所在地: 微信 whycan_cn
已发帖子: 9,252
正好有个W25Q256开发板,我来试一试:
hexing@ubuntu:/tmp/ccc$ sudo sunxi-fel spiflash-info
Manufacturer: Winbond (EFh), model: 40h, size: 33554432 bytes.
hexing@ubuntu:/tmp/ccc$ sudo sunxi-fel -p spiflash-write 0 /mnt/hgfs/E/V3s_W25Q256_Qt5.9.1.bin
  2% [                                                ]  49.8 kB/s, ETA 11:03
#16 2018-04-26 14:50:07
所在地: 微信 whycan_cn
已发帖子: 9,252
一切正常!
#17 2018-04-26 18:07:07
已发帖子: 1,135
能发下改过的c文件吗?
改动很简单,我实在想不出为什么会出错,我都检查了几遍了
另外,问一下QT在V3S上跑的速度如何?
#18 2018-04-26 18:37:12
所在地: 微信 whycan_cn
已发帖子: 9,252
当时没有备份,也忘记改了什么,关键你现在读出来的和写入的是否一致?
#19 2018-04-27 11:06:31
已发帖子: 1,135
sudo ./sunxi-fel -p spiflash-read 0 33554432 ./dump.bin
读出来和原文件对比很大差异,第一个字节就错位相差一个00,过了uboot后差得更多
#20 2018-04-27 11:14:42
所在地: 微信 whycan_cn
已发帖子: 9,252
那要么写有问题,要么读有问题。
看有没有带校验的编程器,可以试一试。
或者 jlink v9,本站有贴。
https://whycan.cn/t_745.html
#21 2018-04-30 16:35:34
kgp0213
已发帖子: 149
这是一个关于sunxi fel 无法烧录16m spi flash的故事
#22 2019-04-13 18:01:51
无情一刀
已发帖子: 704
沉鱼 说:
u-boot的支持
	u8 cmd, bank_sel;
	int ret;
		goto bar_end;
	if (ret < 0) {
		return ret;
bar_end:
sunxi-fel的支持
fel-spiflash.c
	cmd_idx = 0;
	//add bank support
	cmd_idx = 0;
		goto bar_end;
	bar_end:
	cmd_idx = 0;
你这里是修改了深哦哦就32M的可以了哦哦
#23 2019-11-26 21:24:32
okshall
zero flash使用w25q256fv,刚开始偶尔能烧写固件,串口无输出直接进入fel,对比写入数据发现写入无效。解决方法:每次烧写或重新上电前对zero进行短接放点即可。
#24 2020-05-11 15:42:17
lhb882
多谢分享,搞半天一直32M有问题
#25 2020-05-11 15:44:22
lhb882
感谢分享,感觉这个工具很麻烦
#26 2020-11-23 09:12:17
frog007
按照这个方法修改了Sunxi tools, 晚上试试, 谢谢分享!
#27 2021-01-11 04:12:53
yabiv58242
Can someone please post the first file(sunxi-tools-win32-support_f1c100s_32M.7z), so I can download it? Thank you.
#28 2021-01-11 10:51:18
vip888888
已发帖子: 141
yabiv58242 说:
You can recharge your account and then you can download it Ha Ha.
This is a tutorial to become a VIP.
https://whycan.com/t_5042.html
#29 2023-05-10 14:27:21
CHSHIQING
已发帖子: 46
GD25Q256能不能用呢?站内下了好几个都不行
#30 2023-05-11 19:28:00
CHSHIQING
已发帖子: 46
用工具烧录进去,再读出来数据都不对了
#31 2023-11-03 16:08:10
DowJhob
https://whycan.cn/files/members/3/QQ20180315142018.png
按这个修改, 可以通过编译。
Why don't you commit to the main repository?
#32 2024-05-12 10:23:14
hdlazyhy
已发帖子: 20
FW1330的spiflash芯片能用这个工具吗?
#33 2024-05-12 13:59:02
hdlazyhy
已发帖子: 20
 * Write data to the SPI flash. Use the first 4KiB of SRAM as the data buffer.
    soc_info_t *soc_info = dev->soc_info;
    size_t max_chunk_size = soc_info->scratch_addr - soc_info->spl_addr;
    size_t cmd_idx,bank_sel;
    //补丁代码
    //add bank support
        cmd_idx = 0;
            goto bar_end;
    bar_end:
    cmd_idx = 0;
    prepare_spi_batch_data_transfer(dev, soc_info->spl_addr);
    while (len > 0) {
        while (len > 0 && max_chunk_size - cmd_idx > program_size + 64) {
            if (offset % erase_size == 0) {
                /* Emit erase command */
                cmdbuf[cmd_idx++] = 4;
                cmdbuf[cmd_idx++] = erase_cmd;
                cmdbuf[cmd_idx++] = offset >> 16;
                cmdbuf[cmd_idx++] = offset >> 8;
                cmdbuf[cmd_idx++] = offset;
            /* Emit page program command */
            size_t write_count = program_size;
            if (write_count > len)
                write_count = len;
            cmdbuf[cmd_idx++] = (4 + write_count) >> 8;
            cmdbuf[cmd_idx++] = 4 + write_count;
            cmdbuf[cmd_idx++] = program_cmd;
            memcpy(cmdbuf + cmd_idx, buf8, write_count);
            cmd_idx += write_count;
            buf8    += write_count;
            len     -= write_count;
            offset  += write_count;
        /* Flush */
        aw_fel_write(dev, cmdbuf, soc_info->spl_addr, cmd_idx);
        cmd_idx = 0;
    free(cmdbuf);
参照代码改了后,与原来的结果一样, 不知道是不是我改的有问题。
