楼主 #1 2019-10-15 18:06:45
baird
insmod 触摸屏出错,求助....
出错的日志:
[root@/opt]# insmod goodix.ko
[  159.017199] Goodix-TS 0-0014: 0-0014 supply AVDD28 not found, using dummy regulator
[  159.024991] Goodix-TS 0-0014: 0-0014 supply VDDIO not found, using dummy regulator
[  161.125906] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[  161.132453] Goodix-TS 0-0014: i2c test failed attempt 1: -110
[  163.285865] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[  163.292411] Goodix-TS 0-0014: i2c test failed attempt 2: -110
[  163.335878] Goodix-TS 0-0014: I2C communication failure: -110
[  163.341854] Goodix-TS: probe of 0-0014 failed with error -110
#2 2019-10-15 18:50:58
所在地: 微信 whycan_cn
已发帖子: 9,250
Re: insmod 触摸屏出错,求助....
应该是硬件有问题, 可能你的 i2c 引脚没有上拉
楼主 #3 2019-10-16 14:14:02
baird
感谢晕哥,我搞个上拉试试
