楼主 # 2024-09-13 17:01:15
JiangLin
已发帖子: 19
A33在Uboot中无法使用mmc和sd卡
Uboot来自于 https://github.com/linux-sunxi/u-boot-sunxi的mirror/next分支
配置文件使用 Sinlinx_SinA33_defconfig
在Uboot中使用mmc相关命令均不能得到响应(已经开启mmc_debug):
=> mmc list
mmc@1c0f000: 0
mmc@1c11000: 1
=> mmc dev 1
CMD_SEND:0
                ARG                      0x00000000
                MMC_RSP_NONE
CMD_SEND:8
                ARG                      0x000001AA
                RET                      -110
CMD_SEND:55
                ARG                      0x00000000
                RET                      -110
CMD_SEND:0
                ARG                      0x00000000
                MMC_RSP_NONE
CMD_SEND:1
                ARG                      0x00000000
                RET                      -110
=> mmc dev 0
CMD_SEND:0
                ARG                      0x00000000
                MMC_RSP_NONE
CMD_SEND:8
                ARG                      0x000001AA
                RET                      -110
CMD_SEND:55
                ARG                      0x00000000
                RET                      -110
CMD_SEND:0
                ARG                      0x00000000
                MMC_RSP_NONE
CMD_SEND:1
                ARG                      0x00000000
                RET                      -110
设备树如下:
		mmc0: mmc@1c0f000 {
			compatible = "allwinner,sun7i-a20-mmc";
			reg = <0x01c0f000 0x1000>;
			clocks = <&ccu CLK_BUS_MMC0>,
				 <&ccu CLK_MMC0>,
				 <&ccu CLK_MMC0_OUTPUT>,
				 <&ccu CLK_MMC0_SAMPLE>;
			clock-names = "ahb",
				      "mmc",
				      "output",
				      "sample";
			resets = <&ccu RST_BUS_MMC0>;
			reset-names = "ahb";
			interrupts = <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>;
			status = "disabled";
			#address-cells = <1>;
			#size-cells = <0>;
		mmc2: mmc@1c11000 {
			reg = <0x01c11000 0x1000>;
			clocks = <&ccu CLK_BUS_MMC2>,
				 <&ccu CLK_MMC2>,
				 <&ccu CLK_MMC2_OUTPUT>,
				 <&ccu CLK_MMC2_SAMPLE>;
				      "mmc",
				      "output",
				      "sample";
			resets = <&ccu RST_BUS_MMC2>;
			interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>;
			#size-cells = <0>;
			mmc2_8bit_pins: mmc2_8bit {
				pins = "PC5", "PC6", "PC8",
				       "PC9", "PC10", "PC11",
				       "PC12", "PC13", "PC14",
				       "PC15", "PC16";
				function = "mmc2";
				drive-strength = <30>;
				bias-pull-up;
&mmc0 {
	pinctrl-names = "default";
	pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin_sina33>;
	vmmc-supply = <&reg_dcdc1>;
	bus-width = <4>;
	cd-gpios = <&pio 1 4 GPIO_ACTIVE_LOW>; /* PB4 */
&mmc2 {
	pinctrl-0 = <&mmc2_8bit_pins>;
	bus-width = <8>;
	non-removable;
	cap-mmc-hw-reset;
&mmc2_8bit_pins {
	/* Increase drive strength for DDR modes */
	drive-strength = <40>;
	/* eMMC is missing pull-ups */
	bias-pull-up;
对照原理图感觉没什么问题阿:
sche
#1 2024-09-13 18:20:06
microxp
已发帖子: 76
Re: A33在Uboot中无法使用mmc和sd卡
silinx的配置文件一般水土不服呀,换orangepi的a33试试看
最近编辑记录 microxp (2024-09-13 19:51:35)
楼主 #2 2024-09-14 09:20:41
JiangLin
已发帖子: 19
microxp 说:
./A33-OLinuXino_defconfig也试过了...
我试试orangepi的
楼主 #3 2024-09-14 10:49:29
JiangLin
已发帖子: 19
microxp 说:
请问一下orangepi的仓库在哪里?没找到orangepi的a33开发板阿
#4 2024-09-14 11:48:03
microxp
已发帖子: 76
A33-OLinuXino_defconfig那个我试过是没问题的啦,mmc dev 1是板子上的emmc呀,先确认下你的板子有emmc吗,dev 0是外挂的tf卡,你可以插个tf卡试试mmc dev 0 有没有反应
最近编辑记录 microxp (2024-09-14 11:48:22)
楼主 #5 2024-09-14 12:48:47
JiangLin
已发帖子: 19
microxp 说:
OlinuXino config在这个分支也一样。
估计是这个仓库的这个分支不行吧,他那个分支太多,命名也不全。
我直接使用mainline的Uboot的SinLinx config就能用,mmc和sd卡都能检测到,昨天尝试mainline起不来是因为sd卡和uart0复用,导致uboot在初始化sd卡之前会切到uart2去输出,所以连uart0只能看到一部分log然后就没有反映了。
另外mainline的uboot的OLinuXino_defconfig配置文件在我这个板子上只能看到sd卡,不能看到mmc。
Board: vstar A33
最近编辑记录 JiangLin (2024-09-14 12:49:14)
#6 2024-09-14 15:35:14
microxp
已发帖子: 76
设备树里还得加上mmc2吧,我记得设备树里没开mmc2
#7 昨天 03:45:03
人才就是我
@JiangLin
您好,编译好的可以使用mmc正常,带ums命令的uboot可以方便分享一下吗,万分感谢
