楼主 # 2024-09-19 13:50:27
LiuZiqian
D133EBS使用
各位大佬,有D133EBS的img文件吗?我这边编译之后出现以下问题(AiBurn 日志):
[debug] WinEvent: Some devnode changed
[info ] Set upg work mode: 1
[debug] Blocksize 1 , chunk 1048576 * 0 , rest 2048
[debug] Offset: 0 Size: 2048
[debug]  Dev "1:1-4-2" Send the rest data 2048
[error] Dev "1:1-4-2" Failed to send data 2048
[error]  Dev "1:1-4-2" Failed to send 2048
[warn ] Try to resend firmware component image.info , try count: 1
[warn ] Try to recovery the connection
[error] Connection recovery failed!
串口输出:
Pre-Boot Program ... (24-05-30 17:09 569b02e)
USB/UART
cs=0, phase=3
cs=1, phase=2
Psram_init done.
goto run SPL
tinySPL [Built on Sep 19 2024 13:31:10]
[W] usbh_get_connect_id()107 usb 0 port change wait failed.
[E] main()172 Not find udisk.
Startup reason: Power-On-Reset
Firmware Component:
    partition:
    attr:      required
    Media:     RAM(0)
qspi0 freq (input): 99000000Hz
qspi0 freq ( bus ): 49500000Hz
[E] sfud_probe()475 sfud_device_init failed: ret 4
Failed to probe spinor flash.
[E] image_info_proc()117 NOR prepare failed
刚入门,我们这边是自己画的板子,因此想试试是硬件问题还是软件问题。
希望有大佬能提供编译好的D133EBS镜像文件。提前感谢各位大佬!
#1 2024-09-19 15:57:33
AICxia
已发帖子: 68
Re: D133EBS使用
您可以直接从gitee 官网上 ( https://gitee.com/keqian/luban-lite )将我们的SDK下载下来进行编译,选择 d13x_demo88-nor_v1.0.0 ,不需要做其他更改,就可以获取到D133EBS镜像文件
#2 2024-09-20 09:09:52
已发帖子: 1,409
Re: D133EBS使用
据说100脚的封装管脚特别密,不好画板还是不好加工来着。
#3 2024-09-20 11:56:19
海石生风
已发帖子: 765
Re: D133EBS使用
Gentlepig 说:
88脚、100脚、128脚封装的引脚间距分别为:0.4mm、0.4mm、0.35mm
#4 2024-09-20 15:43:55
LB_YJY
Re: D133EBS使用
128脚的焊接让你口吐白沫!哈哈
