楼主 # 2024-09-24 06:50:04
dtsayhi
已发帖子: 27
关于全志H6 的RGB666 DPI接口问题求助
各位大牛,我发现各类H6的主板都是引出HDMI接口。没有使用RGB接口的板子,google也找不到相关信息。看手册呢又是支持的,有没有哪位大哥适配过?是不是和HDMI冲突,共用一个tcon ?
楼主 #1 2024-09-24 06:56:41
dtsayhi
已发帖子: 27
Re: 关于全志H6 的RGB666 DPI接口问题求助
设备树什么的也没有相关信息
这是自己改的
	hdmi: hdmi@6000000 {
			#sound-dai-cells = <0>;
			compatible = "allwinner,sun50i-h6-dw-hdmi";
			reg = <0x06000000 0x10000>;
			reg-io-width = <1>;
			interrupts = <GIC_SPI 64 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&ccu CLK_BUS_HDMI>, <&ccu CLK_HDMI_SLOW>,
				 <&ccu CLK_HDMI>, <&ccu CLK_HDMI_CEC>,
				 <&ccu CLK_HDCP>, <&ccu CLK_BUS_HDCP>;
			clock-names = "iahb", "isfr", "tmds", "cec", "hdcp",
				      "hdcp-bus";
			resets = <&ccu RST_BUS_HDMI_SUB>, <&ccu RST_BUS_HDCP>;
			reset-names = "ctrl", "hdcp";
			phys = <&hdmi_phy>;
			phy-names = "phy";
			pinctrl-names = "default";
			pinctrl-0 = <&hdmi_pins>;
			status = "disabled";
			ports {
				#address-cells = <1>;
				#size-cells = <0>;
				hdmi_in: port@0 {
					reg = <0>;
					hdmi_in_tcon_top: endpoint {
						remote-endpoint = <&tcon_top_hdmi_out_hdmi>;
				hdmi_out: port@1 {
					reg = <1>;
		hdmi_phy: hdmi-phy@6010000 {
			compatible = "allwinner,sun50i-h6-hdmi-phy";
			reg = <0x06010000 0x10000>;
			clocks = <&ccu CLK_BUS_HDMI>, <&ccu CLK_HDMI_SLOW>;
			clock-names = "bus", "mod";
			resets = <&ccu RST_BUS_HDMI>;
			reset-names = "phy";
			#phy-cells = <0>;
		tcon_top: tcon-top@6510000 {
			compatible = "allwinner,sun50i-h6-tcon-top";
			reg = <0x06510000 0x1000>;
			clocks = <&ccu CLK_BUS_TCON_TOP>,
				 <&ccu CLK_TCON_TV0>;
				      "tcon-tv0";
			clock-output-names = "tcon-top-tv0";
			resets = <&ccu RST_BUS_TCON_TOP>;
			#clock-cells = <1>;
			ports {
				#size-cells = <0>;
				tcon_top_mixer0_in: port@0 {
					#size-cells = <0>;
					reg = <0>;
					tcon_top_mixer0_in_mixer0: endpoint@0 {
						reg = <0>;
						remote-endpoint = <&mixer0_out_tcon_top_mixer0>;
				tcon_top_mixer0_out: port@1 {
					#size-cells = <0>;
					reg = <1>;
					// tcon_top_mixer0_out_tcon_lcd: endpoint@0{
					// 	reg = <0>;
					// 	remote-endpoint = <&tcon_lcd_in_tcon_top_mixer0>;
					tcon_top_mixer0_out_tcon_tv: endpoint@2 {
						reg = <2>;
						remote-endpoint = <&tcon_tv_in_tcon_top_mixer0>;
				tcon_top_mixer0_out1: port@2 {
					#size-cells = <0>;
					reg = <2>;
					tcon_top_mixer0_out_tcon_lcd: endpoint@2{
						reg = <2>;
				tcon_top_hdmi_in: port@4 {
					#size-cells = <0>;
					reg = <4>;
					tcon_top_hdmi_in_tcon_tv: endpoint@0 {
						reg = <0>;
						remote-endpoint = <&tcon_tv_out_tcon_top>;
				tcon_top_hdmi_out: port@5 {
					reg = <5>;
					tcon_top_hdmi_out_hdmi: endpoint {
						remote-endpoint = <&hdmi_in_tcon_top>;
		tcon_lcd: lcd-controller@6511000 {
			compatible = "allwinner,sun50i-h6-tcon-lcd",
				     "allwinner,sun8i-r40-tcon-lcd";
			reg = <0x06511000 0x1000>;
			interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&ccu CLK_BUS_TCON_LCD0>, <&ccu CLK_TCON_LCD0>;
			clock-names = "ahb",
				      "tcon-ch0";
			clock-output-names = "tcon-data-clock";
			#clock-cells = <0>;
			resets = <&ccu RST_BUS_TCON_LCD0>;
			reset-names = "lcd";
			#size-cells = <0>;
			 ports {
			 	#size-cells = <0>;
				tcon_lcd_in: port@0 {
					reg = <0>;
					tcon_lcd_in_tcon_top_mixer0: endpoint {
						remote-endpoint = <&tcon_top_mixer0_out_tcon_lcd>;
				tcon_lcd_out_rgb: port@1 {
					#size-cells = <0>;
					reg = <1>;
					lcd_out_rgb: endpoint@0 {
						reg = <0>;
						remote-endpoint = <&panel_in>;
		tcon_tv: lcd-controller@6515000 {
			compatible = "allwinner,sun50i-h6-tcon-tv",
				     "allwinner,sun8i-r40-tcon-tv";
			reg = <0x06515000 0x1000>;
			interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&ccu CLK_BUS_TCON_TV0>,
				 <&tcon_top CLK_TCON_TOP_TV0>;
				      "tcon-ch1";
			resets = <&ccu RST_BUS_TCON_TV0>;
			ports {
				#size-cells = <0>;
				tcon_tv_in: port@0 {
					reg = <0>;
					tcon_tv_in_tcon_top_mixer0: endpoint {
						remote-endpoint = <&tcon_top_mixer0_out_tcon_tv>;
				tcon_tv_out: port@2 {
					#size-cells = <0>;
					reg = <2>;
					tcon_tv_out_tcon_top: endpoint@1 {
						reg = <1>;
						remote-endpoint = <&tcon_top_hdmi_in_tcon_tv>;
楼主 #2 2024-09-24 07:02:33
dtsayhi
已发帖子: 27
