楼主 # 2024-10-08 13:23:54
michou2022
全志T113-S3启动优化
咨询各位大佬,我在使用官方的Tina5.0的openwrt启动时间很长,网上找到了一些优化方法,优化后效果不明显,现在系统启动后控制台到可输入的状态就已经15秒了,自启动的应用启动已经20秒了,看日志
[ 9.901821] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
[ 12.926843] block: attempting to load /etc/config/fstab
这部分有3秒的等待其他部分没有等待,哪位大佬给指点下提升一下开机速度,感谢了!!!
楼主 #1 2024-10-08 16:13:39
michou2022
Re: 全志T113-S3启动优化
[27]HELLO! BOOT0 is starting!
[30]BOOT0 commit : 1417090655
[43]dram size =128
M/TC: OP-TEE version: 8b49ce62-dirty (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Fri Aug 12 08:24:15 UTC 2022 arm
E/TC:0 tee_read_fdt:433 fine node /firmware/optee failed with FDT_ERR_NOTFOUND
[00.254]smc_tee_inform_fdt failed with: ffff0000
[00.804]set disp.dev2_output_type fail. using defval=0
[00.810]set disp.fb0_width fail. using defval=0
[00.814]set disp.fb0_height fail. using defval=0
[00.819]set disp.fb0_rot_used fail. using defval=0
[00.823]set disp.fb0_rot_degree fail. using defval=0
[00.990]Item0 (Map) magic is bad
[00.992]out of usb burn from boot: not need burn key
[01.066]mac format illegal
[02.172]no vendor_boot partition is found
[02.205]Starting kernel ...
[ 0.000000] Linux version 5.4.61 (michou@ubuntu) (arm-linux-gnueabi-gcc (Linaro GCC 5.3-2016.05) 5.3.1 20160412, GNU ld (Linaro_Binutils-2016.05) 2.25.0 Linaro 2016_02) #16 SMP PREEMPT Tue Oct 8 09:54:08 +08 2024
[ 0.000000] OF: fdt: Machine model: sun8iw20
[ 0.000000] printk: bootconsole [earlycon0] enabled
[ 0.000000] cma: Reserved 4 MiB at 0x47c00000
[ 0.000000] On node 0 totalpages: 32768
[ 0.000000] Normal zone: 256 pages used for memmap
[ 0.000000] Normal zone: 32768 pages, LIFO batch:7
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.0
[ 0.000000] percpu: Embedded 15 pages/cpu s30912 r8192 d22336 u61440
[ 0.000000] pcpu-alloc: s30912 r8192 d22336 u61440 alloc=15*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 32512
[ 0.000000] Kernel command line: ubi.mtd=sys ubi.block=0,rootfs earlyprintk=sunxi-uart,0x02500C00 clk_ignore_unused initcall_debug=0 console=ttyS3,115200 loglevel=8 root=/dev/ubiblock0_5 rootfstype=squashfs init=/sbin/init partitions=mbr@ubi0_0:boot-resource@ubi0_1:env@ubi0_2:env-redund@ubi0_3:boot@ubi0_4:rootfs@ubi0_5:private@ubi0_6:rootfs_data@ubi0_7:UDISK@ubi0_8: cma=4M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun8iw20p1 boot_type=5 androidboot.boot_type=5 gpt=1 uboot_message=2018.07(10/07/2024-07:51:52) disp_reserve=1536000,0x4490c000 aw-ubi-spinand.ubootblks=24 androidboot.dramsize=128
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.000000] Memory: 111024K/131072K available (7168K kernel code, 427K rwdata, 2580K rodata, 1024K init, 174K bss, 15952K reserved, 4096K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] random: get_random_bytes called from start_kernel+0x24c/0x42c with crng_init=0
[ 0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.008017] Switching to timer-based delay loop, resolution 41ns
[ 0.014192] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.023922] Console: colour dummy device 80x30
[ 0.028390] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.038758] pid_max: default: 32768 minimum: 301
[ 0.043525] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.050847] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.059196] CPU: Testing write buffer coherency: ok
[ 0.064439] /cpus/cpu@0 missing clock-frequency property
[ 0.069758] /cpus/cpu@1 missing clock-frequency property
[ 0.075103] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.081348] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.088032] rcu: Hierarchical SRCU implementation.
[ 0.093127] BOOTEVENT: 93.117623: ON
[ 0.097489] smp: Bringing up secondary CPUs ...
[ 0.103245] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.103398] smp: Brought up 1 node, 2 CPUs
[ 0.113195] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[ 0.119374] CPU: All CPU(s) started in SVC mode.
[ 0.124500] devtmpfs: initialized
[ 0.140713] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.148887] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.158743] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.165848] pinctrl core: initialized pinctrl subsystem
[ 0.171791] reg-dummy reg-dummy: no of_node; not parsing pinctrl DT
[ 0.178704] NET: Registered protocol family 16
[ 0.185053] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.227846] rtc_ccu: sunxi ccu init OK
[ 0.233997] ccu: sunxi ccu init OK
[ 0.238085] r_ccu: sunxi ccu init OK
[ 0.281149] sun6i-dma 3002000.dma-controller: sunxi dma probed
[ 0.289688] reg-fixed-voltage pio-18: GPIO lookup for consumer (null)
[ 0.296137] reg-fixed-voltage pio-18: using device tree for GPIO lookup
[ 0.302864] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/pio-18[0]'
[ 0.310893] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/pio-18[0]'
[ 0.318839] reg-fixed-voltage pio-18: using lookup tables for GPIO lookup
[ 0.325620] reg-fixed-voltage pio-18: No GPIO consumer (null) found
[ 0.332333] reg-fixed-voltage pio-33: GPIO lookup for consumer (null)
[ 0.338780] reg-fixed-voltage pio-33: using device tree for GPIO lookup
[ 0.345443] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/pio-33[0]'
[ 0.353462] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/pio-33[0]'
[ 0.361385] reg-fixed-voltage pio-33: using lookup tables for GPIO lookup
[ 0.368184] reg-fixed-voltage pio-33: No GPIO consumer (null) found
[ 0.375069] reg-fixed-voltage usb1-vbus: GPIO lookup for consumer (null)
[ 0.381784] reg-fixed-voltage usb1-vbus: using device tree for GPIO lookup
[ 0.388708] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/usb1-vbus[0]'
[ 0.396998] reg-fixed-voltage usb1-vbus: No GPIO consumer (null) found
[ 0.403736] iommu: Default domain type: Translated
[ 0.408811] sunxi iommu: irq = 24
[ 0.413380] SCSI subsystem initialized
[ 0.417666] usbcore: registered new interface driver usbfs
[ 0.423253] usbcore: registered new interface driver hub
[ 0.428729] usbcore: registered new device driver usb
[ 0.434013] mc: Linux media interface: v0.10
[ 0.438352] videodev: Linux video capture interface: v2.00
[ 0.444906] Advanced Linux Sound Architecture Driver Initialized.
[ 0.451703] Bluetooth: Core ver 2.22
[ 0.455473] NET: Registered protocol family 31
[ 0.459931] Bluetooth: HCI device and connection manager initialized
[ 0.466323] Bluetooth: HCI socket layer initialized
[ 0.471216] Bluetooth: L2CAP socket layer initialized
[ 0.476293] Bluetooth: SCO socket layer initialized
[ 0.481460] pwm module init!
[ 0.485046] sunxi_pwm_probe: can't parse "sunxi-pwms" property
[ 0.492121] g2d 5410000.g2d: Adding to iommu group 0
[ 0.497481] G2D: rcq version initialized.major:250
[ 0.503765] clocksource: Switched to clocksource arch_sys_counter
[ 0.511622] sun8iw20-pinctrl pio: try to register 88 pins ...
[ 0.517480] pinctrl core: registered pin 32 (PB0) on pio
[ 0.522787] pinctrl core: registered pin 33 (PB1) on pio
[ 0.528119] pinctrl core: registered pin 34 (PB2) on pio
[ 0.533441] pinctrl core: registered pin 35 (PB3) on pio
[ 0.538778] pinctrl core: registered pin 36 (PB4) on pio
[ 0.544123] pinctrl core: registered pin 37 (PB5) on pio
[ 0.549436] pinctrl core: registered pin 38 (PB6) on pio
[ 0.554771] pinctrl core: registered pin 39 (PB7) on pio
[ 0.560076] pinctrl core: registered pin 40 (PB8) on pio
[ 0.565402] pinctrl core: registered pin 41 (PB9) on pio
[ 0.570724] pinctrl core: registered pin 42 (PB10) on pio
[ 0.576128] pinctrl core: registered pin 43 (PB11) on pio
[ 0.581520] pinctrl core: registered pin 44 (PB12) on pio
[ 0.586934] pinctrl core: registered pin 64 (PC0) on pio
[ 0.592256] pinctrl core: registered pin 65 (PC1) on pio
[ 0.597583] pinctrl core: registered pin 66 (PC2) on pio
[ 0.602888] pinctrl core: registered pin 67 (PC3) on pio
[ 0.608212] pinctrl core: registered pin 68 (PC4) on pio
[ 0.613526] pinctrl core: registered pin 69 (PC5) on pio
[ 0.618856] pinctrl core: registered pin 70 (PC6) on pio
[ 0.624203] pinctrl core: registered pin 71 (PC7) on pio
[ 0.629526] pinctrl core: registered pin 96 (PD0) on pio
[ 0.634851] pinctrl core: registered pin 97 (PD1) on pio
[ 0.640157] pinctrl core: registered pin 98 (PD2) on pio
[ 0.645477] pinctrl core: registered pin 99 (PD3) on pio
[ 0.650799] pinctrl core: registered pin 100 (PD4) on pio
[ 0.656213] pinctrl core: registered pin 101 (PD5) on pio
[ 0.661604] pinctrl core: registered pin 102 (PD6) on pio
[ 0.667026] pinctrl core: registered pin 103 (PD7) on pio
[ 0.672417] pinctrl core: registered pin 104 (PD8) on pio
[ 0.677830] pinctrl core: registered pin 105 (PD9) on pio
[ 0.683239] pinctrl core: registered pin 106 (PD10) on pio
[ 0.688747] pinctrl core: registered pin 107 (PD11) on pio
[ 0.694247] pinctrl core: registered pin 108 (PD12) on pio
[ 0.699743] pinctrl core: registered pin 109 (PD13) on pio
[ 0.705240] pinctrl core: registered pin 110 (PD14) on pio
[ 0.710728] pinctrl core: registered pin 111 (PD15) on pio
[ 0.716236] pinctrl core: registered pin 112 (PD16) on pio
[ 0.721726] pinctrl core: registered pin 113 (PD17) on pio
[ 0.727229] pinctrl core: registered pin 114 (PD18) on pio
[ 0.732716] pinctrl core: registered pin 115 (PD19) on pio
[ 0.738218] pinctrl core: registered pin 116 (PD20) on pio
[ 0.743696] pinctrl core: registered pin 117 (PD21) on pio
[ 0.749206] pinctrl core: registered pin 118 (PD22) on pio
[ 0.754710] pinctrl core: registered pin 128 (PE0) on pio
[ 0.760101] pinctrl core: registered pin 129 (PE1) on pio
[ 0.765533] pinctrl core: registered pin 130 (PE2) on pio
[ 0.770942] pinctrl core: registered pin 131 (PE3) on pio
[ 0.776380] pinctrl core: registered pin 132 (PE4) on pio
[ 0.781772] pinctrl core: registered pin 133 (PE5) on pio
[ 0.787179] pinctrl core: registered pin 134 (PE6) on pio
[ 0.792588] pinctrl core: registered pin 135 (PE7) on pio
[ 0.797993] pinctrl core: registered pin 136 (PE8) on pio
[ 0.803392] pinctrl core: registered pin 137 (PE9) on pio
[ 0.808812] pinctrl core: registered pin 138 (PE10) on pio
[ 0.814322] pinctrl core: registered pin 139 (PE11) on pio
[ 0.819808] pinctrl core: registered pin 140 (PE12) on pio
[ 0.825308] pinctrl core: registered pin 141 (PE13) on pio
[ 0.830803] pinctrl core: registered pin 142 (PE14) on pio
[ 0.836294] pinctrl core: registered pin 143 (PE15) on pio
[ 0.841789] pinctrl core: registered pin 144 (PE16) on pio
[ 0.847298] pinctrl core: registered pin 145 (PE17) on pio
[ 0.852784] pinctrl core: registered pin 160 (PF0) on pio
[ 0.858197] pinctrl core: registered pin 161 (PF1) on pio
[ 0.863606] pinctrl core: registered pin 162 (PF2) on pio
[ 0.869028] pinctrl core: registered pin 163 (PF3) on pio
[ 0.874449] pinctrl core: registered pin 164 (PF4) on pio
[ 0.879849] pinctrl core: registered pin 165 (PF5) on pio
[ 0.885271] pinctrl core: registered pin 166 (PF6) on pio
[ 0.890680] pinctrl core: registered pin 192 (PG0) on pio
[ 0.896096] pinctrl core: registered pin 193 (PG1) on pio
[ 0.901505] pinctrl core: registered pin 194 (PG2) on pio
[ 0.906941] pinctrl core: registered pin 195 (PG3) on pio
[ 0.912350] pinctrl core: registered pin 196 (PG4) on pio
[ 0.917767] pinctrl core: registered pin 197 (PG5) on pio
[ 0.923167] pinctrl core: registered pin 198 (PG6) on pio
[ 0.928599] pinctrl core: registered pin 199 (PG7) on pio
[ 0.934012] pinctrl core: registered pin 200 (PG8) on pio
[ 0.939403] pinctrl core: registered pin 201 (PG9) on pio
[ 0.944825] pinctrl core: registered pin 202 (PG10) on pio
[ 0.950311] pinctrl core: registered pin 203 (PG11) on pio
[ 0.955829] pinctrl core: registered pin 204 (PG12) on pio
[ 0.961324] pinctrl core: registered pin 205 (PG13) on pio
[ 0.966823] pinctrl core: registered pin 206 (PG14) on pio
[ 0.972301] pinctrl core: registered pin 207 (PG15) on pio
[ 0.977827] pinctrl core: registered pin 208 (PG16) on pio
[ 0.983323] pinctrl core: registered pin 209 (PG17) on pio
[ 0.988839] pinctrl core: registered pin 210 (PG18) on pio
[ 0.994360] sun8iw20-pinctrl pio: no hogs found
[ 0.999440] gpio gpiochip0: (pio): added GPIO chardev (254:0)
[ 1.005383] gpiochip_setup_dev: registered GPIOs 0 to 223 on device: gpiochip0 (pio)
[ 1.013146] gpio gpiochip0: (pio): created GPIO range 32->32 ==> pio PIN 32->32
[ 1.020487] gpio gpiochip0: (pio): created GPIO range 33->33 ==> pio PIN 33->33
[ 1.027825] gpio gpiochip0: (pio): created GPIO range 34->34 ==> pio PIN 34->34
[ 1.035169] gpio gpiochip0: (pio): created GPIO range 35->35 ==> pio PIN 35->35
[ 1.042473] gpio gpiochip0: (pio): created GPIO range 36->36 ==> pio PIN 36->36
[ 1.049817] gpio gpiochip0: (pio): created GPIO range 37->37 ==> pio PIN 37->37
[ 1.057151] gpio gpiochip0: (pio): created GPIO range 38->38 ==> pio PIN 38->38
[ 1.064489] gpio gpiochip0: (pio): created GPIO range 39->39 ==> pio PIN 39->39
[ 1.071800] gpio gpiochip0: (pio): created GPIO range 40->40 ==> pio PIN 40->40
[ 1.079145] gpio gpiochip0: (pio): created GPIO range 41->41 ==> pio PIN 41->41
[ 1.086480] gpio gpiochip0: (pio): created GPIO range 42->42 ==> pio PIN 42->42
[ 1.093799] gpio gpiochip0: (pio): created GPIO range 43->43 ==> pio PIN 43->43
[ 1.101110] gpio gpiochip0: (pio): created GPIO range 44->44 ==> pio PIN 44->44
[ 1.108443] gpio gpiochip0: (pio): created GPIO range 64->64 ==> pio PIN 64->64
[ 1.115761] gpio gpiochip0: (pio): created GPIO range 65->65 ==> pio PIN 65->65
[ 1.123081] gpio gpiochip0: (pio): created GPIO range 66->66 ==> pio PIN 66->66
[ 1.130416] gpio gpiochip0: (pio): created GPIO range 67->67 ==> pio PIN 67->67
[ 1.137754] gpio gpiochip0: (pio): created GPIO range 68->68 ==> pio PIN 68->68
[ 1.145081] gpio gpiochip0: (pio): created GPIO range 69->69 ==> pio PIN 69->69
[ 1.152385] gpio gpiochip0: (pio): created GPIO range 70->70 ==> pio PIN 70->70
[ 1.159732] gpio gpiochip0: (pio): created GPIO range 71->71 ==> pio PIN 71->71
[ 1.167059] gpio gpiochip0: (pio): created GPIO range 96->96 ==> pio PIN 96->96
[ 1.174385] gpio gpiochip0: (pio): created GPIO range 97->97 ==> pio PIN 97->97
[ 1.181697] gpio gpiochip0: (pio): created GPIO range 98->98 ==> pio PIN 98->98
[ 1.189014] gpio gpiochip0: (pio): created GPIO range 99->99 ==> pio PIN 99->99
[ 1.196331] gpio gpiochip0: (pio): created GPIO range 100->100 ==> pio PIN 100->100
[ 1.204046] gpio gpiochip0: (pio): created GPIO range 101->101 ==> pio PIN 101->101
[ 1.211697] gpio gpiochip0: (pio): created GPIO range 102->102 ==> pio PIN 102->102
[ 1.219390] gpio gpiochip0: (pio): created GPIO range 103->103 ==> pio PIN 103->103
[ 1.227057] gpio gpiochip0: (pio): created GPIO range 104->104 ==> pio PIN 104->104
[ 1.234730] gpio gpiochip0: (pio): created GPIO range 105->105 ==> pio PIN 105->105
[ 1.242388] gpio gpiochip0: (pio): created GPIO range 106->106 ==> pio PIN 106->106
[ 1.250060] gpio gpiochip0: (pio): created GPIO range 107->107 ==> pio PIN 107->107
[ 1.257724] gpio gpiochip0: (pio): created GPIO range 108->108 ==> pio PIN 108->108
[ 1.265387] gpio gpiochip0: (pio): created GPIO range 109->109 ==> pio PIN 109->109
[ 1.273036] gpio gpiochip0: (pio): created GPIO range 110->110 ==> pio PIN 110->110
[ 1.280717] gpio gpiochip0: (pio): created GPIO range 111->111 ==> pio PIN 111->111
[ 1.288390] gpio gpiochip0: (pio): created GPIO range 112->112 ==> pio PIN 112->112
[ 1.296070] gpio gpiochip0: (pio): created GPIO range 113->113 ==> pio PIN 113->113
[ 1.303738] gpio gpiochip0: (pio): created GPIO range 114->114 ==> pio PIN 114->114
[ 1.311426] gpio gpiochip0: (pio): created GPIO range 115->115 ==> pio PIN 115->115
[ 1.319099] gpio gpiochip0: (pio): created GPIO range 116->116 ==> pio PIN 116->116
[ 1.326763] gpio gpiochip0: (pio): created GPIO range 117->117 ==> pio PIN 117->117
[ 1.334444] gpio gpiochip0: (pio): created GPIO range 118->118 ==> pio PIN 118->118
[ 1.342103] gpio gpiochip0: (pio): created GPIO range 128->128 ==> pio PIN 128->128
[ 1.349770] gpio gpiochip0: (pio): created GPIO range 129->129 ==> pio PIN 129->129
[ 1.357442] gpio gpiochip0: (pio): created GPIO range 130->130 ==> pio PIN 130->130
[ 1.365117] gpio gpiochip0: (pio): created GPIO range 131->131 ==> pio PIN 131->131
[ 1.372784] gpio gpiochip0: (pio): created GPIO range 132->132 ==> pio PIN 132->132
[ 1.380456] gpio gpiochip0: (pio): created GPIO range 133->133 ==> pio PIN 133->133
[ 1.388137] gpio gpiochip0: (pio): created GPIO range 134->134 ==> pio PIN 134->134
[ 1.395827] gpio gpiochip0: (pio): created GPIO range 135->135 ==> pio PIN 135->135
[ 1.403486] gpio gpiochip0: (pio): created GPIO range 136->136 ==> pio PIN 136->136
[ 1.411166] gpio gpiochip0: (pio): created GPIO range 137->137 ==> pio PIN 137->137
[ 1.418857] gpio gpiochip0: (pio): created GPIO range 138->138 ==> pio PIN 138->138
[ 1.426538] gpio gpiochip0: (pio): created GPIO range 139->139 ==> pio PIN 139->139
[ 1.434201] gpio gpiochip0: (pio): created GPIO range 140->140 ==> pio PIN 140->140
[ 1.441869] gpio gpiochip0: (pio): created GPIO range 141->141 ==> pio PIN 141->141
[ 1.449541] gpio gpiochip0: (pio): created GPIO range 142->142 ==> pio PIN 142->142
[ 1.457205] gpio gpiochip0: (pio): created GPIO range 143->143 ==> pio PIN 143->143
[ 1.464877] gpio gpiochip0: (pio): created GPIO range 144->144 ==> pio PIN 144->144
[ 1.472527] gpio gpiochip0: (pio): created GPIO range 145->145 ==> pio PIN 145->145
[ 1.480200] gpio gpiochip0: (pio): created GPIO range 160->160 ==> pio PIN 160->160
[ 1.487867] gpio gpiochip0: (pio): created GPIO range 161->161 ==> pio PIN 161->161
[ 1.495564] gpio gpiochip0: (pio): created GPIO range 162->162 ==> pio PIN 162->162
[ 1.503223] gpio gpiochip0: (pio): created GPIO range 163->163 ==> pio PIN 163->163
[ 1.510915] gpio gpiochip0: (pio): created GPIO range 164->164 ==> pio PIN 164->164
[ 1.518586] gpio gpiochip0: (pio): created GPIO range 165->165 ==> pio PIN 165->165
[ 1.526268] gpio gpiochip0: (pio): created GPIO range 166->166 ==> pio PIN 166->166
[ 1.533930] gpio gpiochip0: (pio): created GPIO range 192->192 ==> pio PIN 192->192
[ 1.541589] gpio gpiochip0: (pio): created GPIO range 193->193 ==> pio PIN 193->193
[ 1.549272] gpio gpiochip0: (pio): created GPIO range 194->194 ==> pio PIN 194->194
[ 1.556952] gpio gpiochip0: (pio): created GPIO range 195->195 ==> pio PIN 195->195
[ 1.564635] gpio gpiochip0: (pio): created GPIO range 196->196 ==> pio PIN 196->196
[ 1.572302] gpio gpiochip0: (pio): created GPIO range 197->197 ==> pio PIN 197->197
[ 1.579972] gpio gpiochip0: (pio): created GPIO range 198->198 ==> pio PIN 198->198
[ 1.587653] gpio gpiochip0: (pio): created GPIO range 199->199 ==> pio PIN 199->199
[ 1.595332] gpio gpiochip0: (pio): created GPIO range 200->200 ==> pio PIN 200->200
[ 1.603000] gpio gpiochip0: (pio): created GPIO range 201->201 ==> pio PIN 201->201
[ 1.610670] gpio gpiochip0: (pio): created GPIO range 202->202 ==> pio PIN 202->202
[ 1.618354] gpio gpiochip0: (pio): created GPIO range 203->203 ==> pio PIN 203->203
[ 1.626045] gpio gpiochip0: (pio): created GPIO range 204->204 ==> pio PIN 204->204
[ 1.633704] gpio gpiochip0: (pio): created GPIO range 205->205 ==> pio PIN 205->205
[ 1.641387] gpio gpiochip0: (pio): created GPIO range 206->206 ==> pio PIN 206->206
[ 1.649069] gpio gpiochip0: (pio): created GPIO range 207->207 ==> pio PIN 207->207
[ 1.656742] gpio gpiochip0: (pio): created GPIO range 208->208 ==> pio PIN 208->208
[ 1.664423] gpio gpiochip0: (pio): created GPIO range 209->209 ==> pio PIN 209->209
[ 1.672090] gpio gpiochip0: (pio): created GPIO range 210->210 ==> pio PIN 210->210
[ 1.686658] sun8iw20-pinctrl pio: initialized sunXi PIO driver
[ 1.707019] thermal_sys: Registered thermal governor 'step_wise'
[ 1.707027] thermal_sys: Registered thermal governor 'user_space'
[ 1.713041] thermal_sys: Registered thermal governor 'power_allocator'
[ 1.719736] NET: Registered protocol family 2
[ 1.731363] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 1.739778] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 1.747483] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 1.754554] TCP: Hash tables configured (established 1024 bind 1024)
[ 1.761032] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 1.767595] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 1.774767] NET: Registered protocol family 1
[ 1.779386] pinctrl core: add 6 pinctrl maps
[ 1.783690] pinctrl core: add 6 pinctrl maps
[ 1.788031] pinctrl core: add 12 pinctrl maps
[ 1.792417] sun8iw20-pinctrl pio: found group selector 15 for PC2
[ 1.798532] sun8iw20-pinctrl pio: found group selector 15 for PC2
[ 1.804645] sun8iw20-pinctrl pio: found group selector 17 for PC4
[ 1.810735] sun8iw20-pinctrl pio: found group selector 17 for PC4
[ 1.816839] sun8iw20-pinctrl pio: found group selector 18 for PC5
[ 1.822928] sun8iw20-pinctrl pio: found group selector 18 for PC5
[ 1.829049] sun8iw20-pinctrl pio: found group selector 16 for PC3
[ 1.835158] sun8iw20-pinctrl pio: found group selector 16 for PC3
[ 1.841267] sun8iw20-pinctrl pio: found group selector 20 for PC7
[ 1.847377] sun8iw20-pinctrl pio: found group selector 20 for PC7
[ 1.853486] sun8iw20-pinctrl pio: found group selector 19 for PC6
[ 1.859607] sun8iw20-pinctrl pio: found group selector 19 for PC6
[ 1.865733] sun8iw20-pinctrl pio: found group selector 15 for PC2
[ 1.871831] sun8iw20-pinctrl pio: found group selector 15 for PC2
[ 1.877959] sun8iw20-pinctrl pio: found group selector 16 for PC3
[ 1.884078] sun8iw20-pinctrl pio: found group selector 16 for PC3
[ 1.890185] sun8iw20-pinctrl pio: found group selector 17 for PC4
[ 1.896303] sun8iw20-pinctrl pio: found group selector 17 for PC4
[ 1.902393] sun8iw20-pinctrl pio: found group selector 18 for PC5
[ 1.908519] sun8iw20-pinctrl pio: found group selector 18 for PC5
[ 1.914647] sun8iw20-pinctrl pio: found group selector 19 for PC6
[ 1.920736] sun8iw20-pinctrl pio: found group selector 19 for PC6
[ 1.926847] sun8iw20-pinctrl pio: found group selector 20 for PC7
[ 1.932936] sun8iw20-pinctrl pio: found group selector 20 for PC7
[ 1.939058] sun8iw20-pinctrl pio: request pin 66 (PC2) for 4025000.spi
[ 1.945743] sun8iw20-pinctrl pio: pio supply vcc-pc not found, using dummy regulator
[ 1.953819] sun8iw20-pinctrl pio: request pin 68 (PC4) for 4025000.spi
[ 1.960363] sun8iw20-pinctrl pio: bank PC regulator has been opened
[ 1.966665] sun8iw20-pinctrl pio: request pin 69 (PC5) for 4025000.spi
[ 1.973194] sun8iw20-pinctrl pio: bank PC regulator has been opened
[ 1.979491] sun8iw20-pinctrl pio: request pin 67 (PC3) for 4025000.spi
[ 1.986040] sun8iw20-pinctrl pio: bank PC regulator has been opened
[ 1.992324] sun8iw20-pinctrl pio: request pin 71 (PC7) for 4025000.spi
[ 1.998873] sun8iw20-pinctrl pio: bank PC regulator has been opened
[ 2.005165] sun8iw20-pinctrl pio: request pin 70 (PC6) for 4025000.spi
[ 2.011694] sun8iw20-pinctrl pio: bank PC regulator has been opened
[ 2.018192] spi spi0: spi0 supply spi not found, using dummy regulator
[ 2.024933] sunxi_spi_resource_get()2259 - [spi0] SPI MASTER MODE
[ 2.031026] spi spi0: obtain a copy of previously claimed pinctrl
[ 2.037202] sunxi_spi_resource_get()2297 - Failed to get sample mode
[ 2.043548] sunxi_spi_resource_get()2302 - Failed to get sample delay
[ 2.049994] sunxi_spi_resource_get()2306 - sample_mode:-1431633921 sample_delay:-1431633921
[ 2.058386] sunxi_spi_request_dma()988 - [spi0] Request DMA channel dma0chan0 (tx) and dma0chan1 (rx) for DMA transfers
[ 2.069220] sunxi_spi_clk_init()2356 - [spi0] mclk 100000000
[ 2.075642] sunxi_spi_probe()2809 - [spi0]: driver probe succeed, base c881f000, irq 41
[ 2.085897] Initialise system trusted keyrings
[ 2.090490] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[ 2.109172] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.115386] ntfs: driver 2.1.32 [Flags: R/W].
[ 2.120180] fuse: init (API version 7.31)
[ 2.154402] NET: Registered protocol family 38
[ 2.158856] Key type asymmetric registered
[ 2.162965] Asymmetric key parser 'x509' registered
[ 2.167977] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 2.175422] io scheduler mq-deadline registered
[ 2.179956] io scheduler kyber registered
[ 2.184081] atomic64_test: passed
[ 2.189616] pinctrl core: add 4 pinctrl maps
[ 2.193976] pinctrl core: add 4 pinctrl maps
[ 2.198273] sun8iw20-pinctrl pio: found group selector 0 for PB0
[ 2.204314] sun8iw20-pinctrl pio: found group selector 0 for PB0
[ 2.210335] sun8iw20-pinctrl pio: found group selector 1 for PB1
[ 2.216351] sun8iw20-pinctrl pio: found group selector 1 for PB1
[ 2.222354] sun8iw20-pinctrl pio: found group selector 0 for PB0
[ 2.228368] sun8iw20-pinctrl pio: found group selector 0 for PB0
[ 2.234408] sun8iw20-pinctrl pio: found group selector 1 for PB1
[ 2.240426] sun8iw20-pinctrl pio: found group selector 1 for PB1
[ 2.246443] sun8iw20-pinctrl pio: request pin 32 (PB0) for 0.pinctrl_test
[ 2.253377] sun8iw20-pinctrl pio: pio supply vcc-pb not found, using dummy regulator
[ 2.261280] sun8iw20-pinctrl pio: request pin 33 (PB1) for 0.pinctrl_test
[ 2.268098] sun8iw20-pinctrl pio: bank PB regulator has been opened
[ 2.274488] of_get_named_gpiod_flags: parsed 'test-gpios' property of node '/soc@3000000/pinctrl_test@0[0]' - status (0)
[ 2.285404] of_get_named_gpiod_flags: can't parse 'suspend-gpios' property of node '/soc@3000000/pinctrl_test@0[0]'
[ 2.295851] Fail to get dts property 'suspend-gpios'. err=32
[ 2.301627] sunxi_pctrltest_probe(): gpio=32, config=1, irq=62
[ 2.308281] [DISP]disp_module_init
[ 2.312244] disp 5000000.disp: Adding to iommu group 0
[ 2.318061] [DISP] disp_init,line:2331:
[ 2.318067] smooth display screen:0 type:1 mode:4
[ 2.326980] of_get_named_gpiod_flags: can't parse 'lcd_bl_en' property of node '/soc@3000000/lcd0@5461000[0]'
[ 2.337505] of_get_named_gpiod_flags: parsed 'lcd_gpio_0' property of node '/soc@3000000/lcd0@5461000[0]' - status (0)
[ 2.348334] of_get_named_gpiod_flags: can't parse 'lcd_gpio_1' property of node '/soc@3000000/lcd0@5461000[0]'
[ 2.358451] of_get_named_gpiod_flags: can't parse 'lcd_gpio_2' property of node '/soc@3000000/lcd0@5461000[0]'
[ 2.368561] of_get_named_gpiod_flags: can't parse 'lcd_gpio_3' property of node '/soc@3000000/lcd0@5461000[0]'
[ 2.378662] of_get_named_gpiod_flags: can't parse 'lcd_gpio_4' property of node '/soc@3000000/lcd0@5461000[0]'
[ 2.388779] of_get_named_gpiod_flags: can't parse 'lcd_gpio_5' property of node '/soc@3000000/lcd0@5461000[0]'
[ 2.398901] of_get_named_gpiod_flags: can't parse 'lcd_gpio_scl' property of node '/soc@3000000/lcd0@5461000[0]'
[ 2.409189] of_get_named_gpiod_flags: can't parse 'lcd_gpio_sda' property of node '/soc@3000000/lcd0@5461000[0]'
[ 2.433962] display_fb_request,fb_id:0
[ 2.441869] disp_al_manager_apply ouput_type:1
[ 2.444454] [DISP]disp_module_init finish
[ 2.446525] [DISP] lcd_clk_config,line:777:
[ 2.446537] disp 0, clk: pll(198000000),clk(198000000),dclk(33000000) dsi_rate(198000000)
[ 2.446537] clk real:pll(288000000),clk(288000000),dclk(48000000) dsi_rate(0)
[ 2.451933] sunxi_sid_init()783 - insmod ok
[ 2.462353] Freeing logo buffer memory: 1500K
[ 2.471282] pwm-regulator vdd-cpu: Failed to get PWM: -517
[ 2.485592] pinctrl core: add 4 pinctrl maps
[ 2.489899] pinctrl core: add 2 pinctrl maps
[ 2.494328] sun8iw20-pinctrl pio: found group selector 6 for PB6
[ 2.500333] sun8iw20-pinctrl pio: found group selector 6 for PB6
[ 2.506393] sun8iw20-pinctrl pio: found group selector 7 for PB7
[ 2.512420] sun8iw20-pinctrl pio: found group selector 7 for PB7
[ 2.518458] sun8iw20-pinctrl pio: found group selector 6 for PB6
[ 2.524496] sun8iw20-pinctrl pio: found group selector 7 for PB7
[ 2.530502] sun8iw20-pinctrl pio: request pin 38 (PB6) for 2500c00.uart
[ 2.537136] sun8iw20-pinctrl pio: bank PB regulator has been opened
[ 2.543407] sun8iw20-pinctrl pio: request pin 39 (PB7) for 2500c00.uart
[ 2.550037] sun8iw20-pinctrl pio: bank PB regulator has been opened
[ 2.556567] uart uart3: uart3 supply uart not found, using dummy regulator
[ 2.563832] uart uart3: obtain a copy of previously claimed pinctrl
[ 2.570111] uart3: ttyS3 at MMIO 0x2500c00 (irq = 34, base_baud = 1500000) is a SUNXI
[ 2.577995] sw_console_setup()1831 - console setup baud 115200 parity n bits 8, flow n
▒[ 2.585995] printk: console [ttyS3] enabled
[ 2.594910] printk: bootconsole [earlycon0] disabled
[ 2.606008] pinctrl core: add 4 pinctrl maps
[ 2.610793] pinctrl core: add 2 pinctrl maps
[ 2.615631] sun8iw20-pinctrl pio: found group selector 2 for PB2
[ 2.622332] sun8iw20-pinctrl pio: found group selector 2 for PB2
[ 2.629061] sun8iw20-pinctrl pio: found group selector 3 for PB3
[ 2.635780] sun8iw20-pinctrl pio: found group selector 3 for PB3
[ 2.642481] sun8iw20-pinctrl pio: found group selector 2 for PB2
[ 2.649198] sun8iw20-pinctrl pio: found group selector 3 for PB3
[ 2.655918] sun8iw20-pinctrl pio: request pin 34 (PB2) for 2501000.uart
[ 2.663296] sun8iw20-pinctrl pio: bank PB regulator has been opened
[ 2.670310] sun8iw20-pinctrl pio: request pin 35 (PB3) for 2501000.uart
[ 2.677701] sun8iw20-pinctrl pio: bank PB regulator has been opened
[ 2.684926] uart uart4: uart4 supply uart not found, using dummy regulator
[ 2.692940] uart uart4: obtain a copy of previously claimed pinctrl
[ 2.699970] uart4: ttyS4 at MMIO 0x2501000 (irq = 35, base_baud = 1500000) is a SUNXI
[ 2.709952] misc dump reg init
[ 2.713969] deinterlace 5400000.deinterlace: Adding to iommu group 0
[ 2.721574] deinterlace 5400000.deinterlace: version[1.0.0], ip=0x110
[ 2.730648] [ADDR_MGT] addr_mgt_probe: module version: v1.0.11
[ 2.737889] [ADDR_MGT] addr_mgt_probe: success.
[ 2.744162] sunxi-spinand: AW SPINand MTD Layer Version: 2.3 20211223
[ 2.751355] sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.10 20200306
[ 2.759237] sunxi-spinand-phy: not detect any munufacture from id table
[ 2.766641] sunxi-spinand-phy: get spi-nand Model from fdt fail
[ 2.773240] sunxi-spinand-phy: get phy info from fdt fail
[ 2.779269] sunxi-spinand-phy: not detect munufacture from fdt
[ 2.785902] sunxi-spinand-phy: detect munufacture from id table: Winbond
[ 2.793376] sunxi-spinand-phy: detect spinand id: ff21aaef ffffffff
[ 2.800380] sunxi-spinand-phy: ========== arch info ==========
[ 2.806894] sunxi-spinand-phy: Model: W25N01GVZEIG
[ 2.813590] sunxi-spinand-phy: Munufacture: Winbond
[ 2.819812] sunxi-spinand-phy: DieCntPerChip: 1
[ 2.825451] sunxi-spinand-phy: BlkCntPerDie: 1024
[ 2.831370] sunxi-spinand-phy: PageCntPerBlk: 64
[ 2.837107] sunxi-spinand-phy: SectCntPerPage: 4
[ 2.842736] sunxi-spinand-phy: OobSizePerPage: 64
[ 2.848472] sunxi-spinand-phy: BadBlockFlag: 0x0
[ 2.854305] sunxi-spinand-phy: OperationOpt: 0x7
[ 2.860128] sunxi-spinand-phy: MaxEraseTimes: 65000
[ 2.866154] sunxi-spinand-phy: EccFlag: 0x0
[ 2.871977] sunxi-spinand-phy: EccType: 2
[ 2.877616] sunxi-spinand-phy: EccProtectedType: 3
[ 2.883245] sunxi-spinand-phy: ========================================
[ 2.890633] sunxi-spinand-phy:
[ 2.894142] sunxi-spinand-phy: ========== physical info ==========
[ 2.901031] sunxi-spinand-phy: TotalSize: 128 M
[ 2.906380] sunxi-spinand-phy: SectorSize: 512 B
[ 2.911718] sunxi-spinand-phy: PageSize: 2 K
[ 2.916877] sunxi-spinand-phy: BlockSize: 128 K
[ 2.922215] sunxi-spinand-phy: OOBSize: 64 B
[ 2.927474] sunxi-spinand-phy: ========================================
[ 2.934859] sunxi-spinand-phy:
[ 2.938356] sunxi-spinand-phy: ========== logical info ==========
[ 2.945159] sunxi-spinand-phy: TotalSize: 128 M
[ 2.950497] sunxi-spinand-phy: SectorSize: 512 B
[ 2.955846] sunxi-spinand-phy: PageSize: 4 K
[ 2.960990] sunxi-spinand-phy: BlockSize: 256 K
[ 2.966339] sunxi-spinand-phy: OOBSize: 128 B
[ 2.971677] sunxi-spinand-phy: ========================================
[ 2.979063] sunxi-spinand-phy: W25N01GVZEIG reset rx bit width to 1
[ 2.986068] sunxi-spinand-phy: W25N01GVZEIG reset tx bit width to 1
[ 2.993138] sunxi-spinand-phy: block lock register: 0x00
[ 2.999185] sunxi-spinand-phy: feature register: 0x19
[ 3.004841] sunxi-spinand-phy: sunxi physic nand init end
[ 3.011332] Creating 4 MTD partitions on "sunxi_mtd_nand":
[ 3.017488] 0x000000000000-0x000000100000 : "boot0"
[ 3.034844] 0x000000100000-0x000000400000 : "uboot"
[ 3.054819] 0x000000400000-0x000000500000 : "secure_storage"
[ 3.062110] random: fast init done
[ 3.074876] 0x000000500000-0x000008000000 : "sys"
[ 3.215459] mdio_bus fixed-0: GPIO lookup for consumer reset
[ 3.221780] mdio_bus fixed-0: using lookup tables for GPIO lookup
[ 3.228622] mdio_bus fixed-0: No GPIO consumer reset found
[ 3.234779] libphy: Fixed MDIO Bus: probed
[ 3.239361] CAN device driver interface
[ 3.244123] sunxi-can can@0x0 (unnamed net_device) (uninitialized): request pinctrl handle fail!
[ 3.254590] sunxi-can can@0x0: can driver probe ok ...
[ 3.260637] sunxi-can can@0x1 (unnamed net_device) (uninitialized): request pinctrl handle fail!
[ 3.271110] sunxi-can can@0x1: can driver probe ok ...
[ 3.277260] pinctrl core: add 22 pinctrl maps
[ 3.282220] pinctrl core: add 22 pinctrl maps
[ 3.287136] sun8iw20-pinctrl pio: found group selector 69 for PG0
[ 3.293954] sun8iw20-pinctrl pio: found group selector 69 for PG0
[ 3.300759] sun8iw20-pinctrl pio: found group selector 70 for PG1
[ 3.307581] sun8iw20-pinctrl pio: found group selector 70 for PG1
[ 3.314397] sun8iw20-pinctrl pio: found group selector 71 for PG2
[ 3.321198] sun8iw20-pinctrl pio: found group selector 71 for PG2
[ 3.328014] sun8iw20-pinctrl pio: found group selector 72 for PG3
[ 3.334826] sun8iw20-pinctrl pio: found group selector 72 for PG3
[ 3.341629] sun8iw20-pinctrl pio: found group selector 73 for PG4
[ 3.348445] sun8iw20-pinctrl pio: found group selector 73 for PG4
[ 3.355275] sun8iw20-pinctrl pio: found group selector 74 for PG5
[ 3.362076] sun8iw20-pinctrl pio: found group selector 74 for PG5
[ 3.368907] sun8iw20-pinctrl pio: found group selector 80 for PG11
[ 3.375820] sun8iw20-pinctrl pio: found group selector 80 for PG11
[ 3.382722] sun8iw20-pinctrl pio: found group selector 81 for PG12
[ 3.389631] sun8iw20-pinctrl pio: found group selector 81 for PG12
[ 3.396545] sun8iw20-pinctrl pio: found group selector 82 for PG13
[ 3.403443] sun8iw20-pinctrl pio: found group selector 82 for PG13
[ 3.410363] sun8iw20-pinctrl pio: found group selector 83 for PG14
[ 3.417273] sun8iw20-pinctrl pio: found group selector 83 for PG14
[ 3.424186] sun8iw20-pinctrl pio: found group selector 84 for PG15
[ 3.431084] sun8iw20-pinctrl pio: found group selector 84 for PG15
[ 3.437996] sun8iw20-pinctrl pio: found group selector 69 for PG0
[ 3.444808] sun8iw20-pinctrl pio: found group selector 69 for PG0
[ 3.451610] sun8iw20-pinctrl pio: found group selector 70 for PG1
[ 3.458422] sun8iw20-pinctrl pio: found group selector 70 for PG1
[ 3.465236] sun8iw20-pinctrl pio: found group selector 71 for PG2
[ 3.472036] sun8iw20-pinctrl pio: found group selector 71 for PG2
[ 3.478854] sun8iw20-pinctrl pio: found group selector 72 for PG3
[ 3.485675] sun8iw20-pinctrl pio: found group selector 72 for PG3
[ 3.492478] sun8iw20-pinctrl pio: found group selector 73 for PG4
[ 3.499294] sun8iw20-pinctrl pio: found group selector 73 for PG4
[ 3.506116] sun8iw20-pinctrl pio: found group selector 74 for PG5
[ 3.512917] sun8iw20-pinctrl pio: found group selector 74 for PG5
[ 3.519732] sun8iw20-pinctrl pio: found group selector 80 for PG11
[ 3.526643] sun8iw20-pinctrl pio: found group selector 80 for PG11
[ 3.533543] sun8iw20-pinctrl pio: found group selector 81 for PG12
[ 3.540453] sun8iw20-pinctrl pio: found group selector 81 for PG12
[ 3.547366] sun8iw20-pinctrl pio: found group selector 82 for PG13
[ 3.554276] sun8iw20-pinctrl pio: found group selector 82 for PG13
[ 3.561176] sun8iw20-pinctrl pio: found group selector 83 for PG14
[ 3.568086] sun8iw20-pinctrl pio: found group selector 83 for PG14
[ 3.574999] sun8iw20-pinctrl pio: found group selector 84 for PG15
[ 3.581897] sun8iw20-pinctrl pio: found group selector 84 for PG15
[ 3.588808] sun8iw20-pinctrl pio: request pin 192 (PG0) for 4500000.eth
[ 3.596333] sun8iw20-pinctrl pio: pio supply vcc-pg not found, using dummy regulator
[ 3.605189] sun8iw20-pinctrl pio: request pin 193 (PG1) for 4500000.eth
[ 3.612570] sun8iw20-pinctrl pio: bank PG regulator has been opened
[ 3.619601] sun8iw20-pinctrl pio: request pin 194 (PG2) for 4500000.eth
[ 3.626994] sun8iw20-pinctrl pio: bank PG regulator has been opened
[ 3.634003] sun8iw20-pinctrl pio: request pin 195 (PG3) for 4500000.eth
[ 3.641380] sun8iw20-pinctrl pio: bank PG regulator has been opened
[ 3.648387] sun8iw20-pinctrl pio: request pin 196 (PG4) for 4500000.eth
[ 3.655767] sun8iw20-pinctrl pio: bank PG regulator has been opened
[ 3.662764] sun8iw20-pinctrl pio: request pin 197 (PG5) for 4500000.eth
[ 3.670151] sun8iw20-pinctrl pio: bank PG regulator has been opened
[ 3.677159] sun8iw20-pinctrl pio: request pin 203 (PG11) for 4500000.eth
[ 3.684644] sun8iw20-pinctrl pio: bank PG regulator has been opened
[ 3.691642] sun8iw20-pinctrl pio: request pin 204 (PG12) for 4500000.eth
[ 3.699127] sun8iw20-pinctrl pio: bank PG regulator has been opened
[ 3.706142] sun8iw20-pinctrl pio: request pin 205 (PG13) for 4500000.eth
[ 3.713616] sun8iw20-pinctrl pio: bank PG regulator has been opened
[ 3.720624] sun8iw20-pinctrl pio: request pin 206 (PG14) for 4500000.eth
[ 3.728109] sun8iw20-pinctrl pio: bank PG regulator has been opened
[ 3.735122] sun8iw20-pinctrl pio: request pin 207 (PG15) for 4500000.eth
[ 3.742595] sun8iw20-pinctrl pio: bank PG regulator has been opened
[ 3.749850] gmac-power0: NULL
[ 3.753160] gmac-power1: NULL
[ 3.756486] gmac-power2: NULL
[ 3.759831] of_get_named_gpiod_flags: parsed 'phy-rst' property of node '/soc@3000000/eth@4500000[0]' - status (0)
[ 3.771409] sun8iw20-pinctrl pio: request pin 198 (PG6) for pio:198
[ 3.778416] sun8iw20-pinctrl pio: bank PG regulator has been opened
[ 3.785422] sunxi-gmac 4500000.eth: obtain a copy of previously claimed pinctrl
[ 3.793573] rtl8363nb_vb_init->692 rtk8363 init=====
[ 3.799133] rtk_switch_probe->1011 flyranchao data = 0x0 regValue = 0x0===
[ 3.806816] rtk switch init failed!
[ 3.811761] Failed to alloc md5
[ 3.815303] eth0: Use random mac address
[ 3.820118] usbcore: registered new interface driver asix
[ 3.826313] usbcore: registered new interface driver ax88179_178a
[ 3.833190] usbcore: registered new interface driver cdc_ether
[ 3.839787] usbcore: registered new interface driver net1080
[ 3.846200] usbcore: registered new interface driver cdc_subset
[ 3.852891] usbcore: registered new interface driver zaurus
[ 3.859211] usbcore: registered new interface driver cdc_ncm
[ 3.865555] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.872842] sunxi-ehci: EHCI SUNXI driver
[ 3.877817] get drvvbus-en is fail, 22
[ 3.882001] get ehci1-controller wakeup-source is fail.
[ 3.887979] sunxi ehci1-controller don't init wakeup source
[ 3.894229] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0c8d1d8, 0x:c883d000, irq_no:39
[ 3.906203] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply drvvbus not found, using dummy regulator
[ 3.918685] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
[ 3.930846] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
[ 3.938100] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
[ 3.948066] sunxi-ehci 4200000.ehci1-controller: irq 57, io mem 0x04200000
[ 3.993783] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
[ 4.001564] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
[ 4.011150] hub 1-0:1.0: USB hub found
[ 4.015435] hub 1-0:1.0: 1 port detected
[ 4.020597] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 4.027565] sunxi-ohci: OHCI SUNXI driver
[ 4.032527] get drvvbus-en is fail, 22
[ 4.036754] get ohci1-controller wakeup-source is fail.
[ 4.042704] sunxi ohci1-controller don't init wakeup source
[ 4.048950] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0c8d488
[ 4.058619] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply drvvbus not found, using dummy regulator
[ 4.071095] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
[ 4.083283] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
[ 4.090538] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
[ 4.100406] sunxi-ohci 4200400.ohci1-controller: irq 58, io mem 0x04200400
[ 4.178786] hub 2-0:1.0: USB hub found
[ 4.183017] hub 2-0:1.0: 1 port detected
[ 4.188449] usbcore: registered new interface driver uas
[ 4.194538] usbcore: registered new interface driver usb-storage
[ 4.201336] usbcore: registered new interface driver ums-alauda
[ 4.208044] usbcore: registered new interface driver ums-cypress
[ 4.214839] usbcore: registered new interface driver ums-datafab
[ 4.221617] usbcore: registered new interface driver ums_eneub6250
[ 4.228601] usbcore: registered new interface driver ums-freecom
[ 4.235543] usbcore: registered new interface driver ums-isd200
[ 4.242229] usbcore: registered new interface driver ums-jumpshot
[ 4.249144] usbcore: registered new interface driver ums-karma
[ 4.255737] usbcore: registered new interface driver ums-onetouch
[ 4.262634] usbcore: registered new interface driver ums-realtek
[ 4.269427] usbcore: registered new interface driver ums-sddr09
[ 4.276120] usbcore: registered new interface driver ums-sddr55
[ 4.282803] usbcore: registered new interface driver ums-usbat
[ 4.289483] usbcore: registered new interface driver option
[ 4.295919] usbserial: USB Serial support registered for GSM modem (1-port)
[ 4.304635] input: sunxi-ts as /devices/platform/soc@3000000/2009c00.rtp/input/input0
[ 4.314344] sunxi_gpadc_init,2151, success
[ 4.319959] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
[ 4.330677] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
[ 4.341882] alarmtimer alarmtimer.0.auto: no of_node; not parsing pinctrl DT
[ 4.349933] sunxi-rtc 7090000.rtc: registered as rtc0
[ 4.355618] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
[ 4.366232] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T05:40:10 UTC (20410)
[ 4.375501] sunxi-rtc 7090000.rtc: sunxi rtc probed
[ 4.381429] i2c /dev entries driver
[ 4.385365] usb 1-1: new high-speed USB device number 2 using sunxi-ehci
[ 4.393157] IR NEC protocol handler initialized
[ 4.398243] IR RC5(x/sz) protocol handler initialized
[ 4.404839] of_get_named_gpiod_flags: can't parse 'tvd_gpio0' property of node '/soc@3000000/tvd@05c00000[0]'
[ 4.415981] of_get_named_gpiod_flags: can't parse 'tvd_gpio1' property of node '/soc@3000000/tvd@05c00000[0]'
[ 4.428416] usbcore: registered new interface driver uvcvideo
[ 4.434891] USB Video Class driver (1.1.1)
[ 4.439459] gspca_main: v2.14.0 registered
[ 4.444055] sunxi cedar version 1.1
[ 4.449393] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 4.458558] Bluetooth: HCI UART driver ver 2.3
[ 4.463539] Bluetooth: HCI UART protocol H4 registered
[ 4.470168] sun50i-cpufreq-nvmem sun50i-cpufreq-nvmem: no of_node; not parsing pinctrl DT
[ 4.480385] pinctrl core: add 12 pinctrl maps
[ 4.485511] pinctrl core: add 12 pinctrl maps
[ 4.490410] pinctrl core: add 6 pinctrl maps
[ 4.495256] pinctrl core: add 4 pinctrl maps
[ 4.500046] pinctrl core: add 8 pinctrl maps
[ 4.504879] sun8iw20-pinctrl pio: found group selector 62 for PF0
[ 4.511712] sun8iw20-pinctrl pio: found group selector 62 for PF0
[ 4.518543] sun8iw20-pinctrl pio: found group selector 63 for PF1
[ 4.525367] sun8iw20-pinctrl pio: found group selector 63 for PF1
[ 4.532187] sun8iw20-pinctrl pio: found group selector 64 for PF2
[ 4.539002] sun8iw20-pinctrl pio: found group selector 64 for PF2
[ 4.545825] sun8iw20-pinctrl pio: found group selector 65 for PF3
[ 4.552640] sun8iw20-pinctrl pio: found group selector 65 for PF3
[ 4.559511] sun8iw20-pinctrl pio: found group selector 66 for PF4
[ 4.566391] sun8iw20-pinctrl pio: found group selector 66 for PF4
[ 4.573217] sun8iw20-pinctrl pio: found group selector 67 for PF5
[ 4.580046] sun8iw20-pinctrl pio: found group selector 67 for PF5
[ 4.586908] sun8iw20-pinctrl pio: found group selector 62 for PF0
[ 4.593718] sun8iw20-pinctrl pio: found group selector 62 for PF0
[ 4.600548] sun8iw20-pinctrl pio: found group selector 63 for PF1
[ 4.607371] sun8iw20-pinctrl pio: found group selector 63 for PF1
[ 4.614248] sun8iw20-pinctrl pio: found group selector 64 for PF2
[ 4.621126] sun8iw20-pinctrl pio: found group selector 64 for PF2
[ 4.628010] sun8iw20-pinctrl pio: found group selector 65 for PF3
[ 4.634909] sun8iw20-pinctrl pio: found group selector 65 for PF3
[ 4.641763] sun8iw20-pinctrl pio: found group selector 66 for PF4
[ 4.648843] sun8iw20-pinctrl pio: found group selector 66 for PF4
[ 4.655796] usb 1-1: no of_node; not parsing pinctrl DT
[ 4.661686] sun8iw20-pinctrl pio: found group selector 67 for PF5
[ 4.668534] sun8iw20-pinctrl pio: found group selector 67 for PF5
[ 4.675363] sun8iw20-pinctrl pio: found group selector 62 for PF0
[ 4.682172] sun8iw20-pinctrl pio: found group selector 63 for PF1
[ 4.689000] sun8iw20-pinctrl pio: found group selector 64 for PF2
[ 4.695823] sun8iw20-pinctrl pio: found group selector 65 for PF3
[ 4.702626] sun8iw20-pinctrl pio: found group selector 66 for PF4
[ 4.709451] sun8iw20-pinctrl pio: found group selector 67 for PF5
[ 4.716284] sun8iw20-pinctrl pio: found group selector 64 for PF2
[ 4.723085] sun8iw20-pinctrl pio: found group selector 64 for PF2
[ 4.729909] sun8iw20-pinctrl pio: found group selector 66 for PF4
[ 4.736733] sun8iw20-pinctrl pio: found group selector 66 for PF4
[ 4.743537] sun8iw20-pinctrl pio: found group selector 62 for PF0
[ 4.750360] sun8iw20-pinctrl pio: found group selector 62 for PF0
[ 4.757186] sun8iw20-pinctrl pio: found group selector 63 for PF1
[ 4.764014] sun8iw20-pinctrl pio: found group selector 63 for PF1
[ 4.770827] sun8iw20-pinctrl pio: found group selector 65 for PF3
[ 4.777651] sun8iw20-pinctrl pio: found group selector 65 for PF3
[ 4.784473] sun8iw20-pinctrl pio: found group selector 67 for PF5
[ 4.791282] sun8iw20-pinctrl pio: found group selector 67 for PF5
[ 4.798241] sun8iw20-pinctrl pio: request pin 160 (PF0) for 4020000.sdmmc
[ 4.806087] hub 1-1:1.0: no of_node; not parsing pinctrl DT
[ 4.812373] hub 1-1:1.0: USB hub found
[ 4.814570] sun8iw20-pinctrl pio: request pin 161 (PF1) for 4020000.sdmmc
[ 4.816982] hub 1-1:1.0: 4 ports detected
[ 4.824196] sun8iw20-pinctrl pio: bank PF regulator has been opened
[ 4.835655] sun8iw20-pinctrl pio: request pin 162 (PF2) for 4020000.sdmmc
[ 4.843240] sun8iw20-pinctrl pio: bank PF regulator has been opened
[ 4.850282] sun8iw20-pinctrl pio: request pin 163 (PF3) for 4020000.sdmmc
[ 4.857870] sun8iw20-pinctrl pio: bank PF regulator has been opened
[ 4.864887] sun8iw20-pinctrl pio: request pin 164 (PF4) for 4020000.sdmmc
[ 4.872458] sun8iw20-pinctrl pio: bank PF regulator has been opened
[ 4.879479] sun8iw20-pinctrl pio: request pin 165 (PF5) for 4020000.sdmmc
[ 4.887064] sun8iw20-pinctrl pio: bank PF regulator has been opened
[ 4.894126] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40)
[ 4.903952] sunxi-mmc 4020000.sdmmc: ctl-spec-caps 8
[ 4.910124] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
[ 4.916453] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
[ 4.922860] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
[ 4.929279] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
[ 4.935797] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
[ 4.942302] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
[ 4.948818] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
[ 4.955352] of_get_named_gpiod_flags: can't parse 'card-pwr-gpios' property of node '/soc@3000000/sdmmc@4020000[0]'
[ 4.967013] sunxi-mmc 4020000.sdmmc: obtain a copy of previously claimed pinctrl
[ 4.975662] sunxi-mmc 4020000.sdmmc: GPIO lookup for consumer cd
[ 4.982366] sunxi-mmc 4020000.sdmmc: using device tree for GPIO lookup
[ 4.989713] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/soc@3000000/sdmmc@4020000[0]' - status (0)
[ 5.001580] sun8iw20-pinctrl pio: request pin 166 (PF6) for pio:166
[ 5.008584] sun8iw20-pinctrl pio: bank PF regulator has been opened
[ 5.015595] gpio gpiochip0: Persistence not supported for GPIO 166
[ 5.022504] sunxi-mmc 4020000.sdmmc: Got CD GPIO
[ 5.027667] sunxi-mmc 4020000.sdmmc: GPIO lookup for consumer wp
[ 5.034377] sunxi-mmc 4020000.sdmmc: using device tree for GPIO lookup
[ 5.041670] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/soc@3000000/sdmmc@4020000[0]'
[ 5.052751] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/soc@3000000/sdmmc@4020000[0]'
[ 5.063728] sunxi-mmc 4020000.sdmmc: using lookup tables for GPIO lookup
[ 5.071214] sunxi-mmc 4020000.sdmmc: No GPIO consumer wp found
[ 5.078124] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 5.089253] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
[ 5.109368] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 5.133552] sun8iw20-pinctrl pio: pio: request IRQ for GPIO 166, return 134
[ 5.141554] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
[ 5.147245] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 5.155160] usbcore: registered new interface driver usbhid
[ 5.165073] usbhid: USB HID core driver
[ 5.166320] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 5.169352] exFAT: Version 1.3.0
[ 5.184526] sunxi-mmc 4020000.sdmmc: smc 0 p0 err, cmd 8, RTO !!
[ 5.191253] sunxi-mmc 4020000.sdmmc: smc 0 p0 err, cmd 55, RTO !!
[ 5.198078] sunxi-mmc 4020000.sdmmc: smc 0 p0 err, cmd 55, RTO !!
[ 5.204907] sunxi-mmc 4020000.sdmmc: smc 0 p0 err, cmd 55, RTO !!
[ 5.211738] sunxi-mmc 4020000.sdmmc: smc 0 p0 err, cmd 55, RTO !!
[ 5.211763] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 5.219167] sunxi-msgbox 3003000.msgbox: sunxi msgbox driver probe ...
[ 5.229818] sun8iw20-pinctrl pio: request pin 160 (PF0) for 4020000.sdmmc
[ 5.237340] sunxi-msgbox 3003000.msgbox: sunxi msgbox driver init ok...
[ 5.244644] sun8iw20-pinctrl pio: bank PF regulator has been opened
[ 5.252359] rpmsg_tty_init: Sunxi rpmsg tty driver will init
[ 5.259094] sun8iw20-pinctrl pio: request pin 161 (PF1) for 4020000.sdmmc
[ 5.265587] rpmsg_tty_init: Sunxi rpmsg tty driver init ok
[ 5.272894] sun8iw20-pinctrl pio: bank PF regulator has been opened
[ 5.281546] snd-soc-dummy snd-soc-dummy: no of_node; not parsing pinctrl DT
[ 5.286331] sun8iw20-pinctrl pio: request pin 162 (PF2) for 4020000.sdmmc
[ 5.295883] [AUDIOCODEC][sunxi_codec_parse_params][2437]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
[ 5.295883]
[ 5.301688] sun8iw20-pinctrl pio: bank PF regulator has been opened
[ 5.318917] [AUDIOCODEC][sunxi_codec_parse_params][2473]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
[ 5.325814] sun8iw20-pinctrl pio: request pin 163 (PF3) for 4020000.sdmmc
[ 5.336570] of_get_named_gpiod_flags: can't parse 'gpio-spk' property of node '/soc@3000000/codec@2030000[0]'
[ 5.344174] sun8iw20-pinctrl pio: bank PF regulator has been opened
[ 5.355258] of_get_named_gpiod_flags: can't parse 'gpio-spk-pwr' property of node '/soc@3000000/codec@2030000[0]'
[ 5.362225] sun8iw20-pinctrl pio: request pin 164 (PF4) for 4020000.sdmmc
[ 5.374185] [AUDIOCODEC][sunxi_internal_codec_probe][2634]:codec probe finished
[ 5.381324] sun8iw20-pinctrl pio: bank PF regulator has been opened
[ 5.390815] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
[ 5.396613] sun8iw20-pinctrl pio: request pin 165 (PF5) for 4020000.sdmmc
[ 5.406347] [SNDCODEC][sunxi_card_init][583]:card init finished
[ 5.413825] sun8iw20-pinctrl pio: bank PF regulator has been opened
[ 5.427787] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
[ 5.438882] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input1
[ 5.450953] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
[ 5.459931] NET: Registered protocol family 10
[ 5.464959] [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
[ 5.473339] Segment Routing with IPv6
[ 5.477603] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 5.485848] NET: Registered protocol family 17
[ 5.490867] NET: Registered protocol family 15
[ 5.495870] can: controller area network core (rev 20170425 abi 9)
[ 5.502880] NET: Registered protocol family 29
[ 5.507883] can: raw protocol (rev 20170425)
[ 5.512645] can: broadcast manager protocol (rev 20170425 t)
[ 5.518990] can: netlink gateway (rev 20190810) max_hops=1
[ 5.525477] Bluetooth: RFCOMM TTY layer initialized
[ 5.530966] Bluetooth: RFCOMM socket layer initialized
[ 5.536764] Bluetooth: RFCOMM ver 1.11
[ 5.541690] Registering SWP/SWPB emulation handler
[ 5.547481] Loading compiled-in X.509 certificates
[ 5.572862] sunxi-thermal 2009400.ths: sun8iw20 cp version:17
[ 5.580082] reg-fixed-voltage usb1-vbus: GPIO lookup for consumer (null)
[ 5.587651] reg-fixed-voltage usb1-vbus: using device tree for GPIO lookup
[ 5.595365] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/usb1-vbus[0]'
[ 5.604638] of_get_named_gpiod_flags: parsed 'gpio' property of node '/usb1-vbus[0]' - status (0)
[ 5.614576] sun8iw20-pinctrl pio: request pin 42 (PB10) for pio:42
[ 5.621478] sun8iw20-pinctrl pio: bank PB regulator has been opened
[ 5.628509] gpio gpiochip0: Persistence not supported for GPIO 42
[ 5.636570] pwm-regulator vdd-cpu: Failed to get PWM: -517
[ 5.642854] sun50i-cpufreq-nvmem sun50i-cpufreq-nvmem: no of_node; not parsing pinctrl DT
[ 5.652373] cpufreq-dt cpufreq-dt: no of_node; not parsing pinctrl DT
[ 5.660375] get drvvbus-en is fail, 22
[ 5.664583] get ehci0-controller wakeup-source is fail.
[ 5.670542] sunxi ehci0-controller don't init wakeup source
[ 5.676786] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0c8cc78, 0x:c88cb000, irq_no:37
[ 5.688740] [sunxi-ehci0]: Not init ehci0
[ 5.693649] get drvvbus-en is fail, 22
[ 5.697871] get ohci0-controller wakeup-source is fail.
[ 5.703852] sunxi ohci0-controller don't init wakeup source
[ 5.710084] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0c8cf28
[ 5.719755] [sunxi-ohci0]: Not init ohci0
[ 5.724567] pwm-regulator vdd-cpu: Failed to get PWM: -517
[ 5.730875] cpufreq-dt cpufreq-dt: no of_node; not parsing pinctrl DT
[ 5.738548] pwm-regulator vdd-cpu: Failed to get PWM: -517
[ 5.744858] cpufreq-dt cpufreq-dt: no of_node; not parsing pinctrl DT
[ 5.752649] ubi0: attaching mtd3
[ 6.086432] ubi0: scanning is finished
[ 6.102366] ubi0: attached mtd3 (name "sys", size 123 MiB)
[ 6.108550] ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
[ 6.116241] ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
[ 6.123824] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 6.131596] ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
[ 6.138312] ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128
[ 6.146386] ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
[ 6.155703] ubi0: available PEBs: 0, total reserved PEBs: 492, PEBs reserved for bad PEB handling: 20
[ 6.166064] ubi0: background thread "ubi_bgt0d" started, PID 1068
[ 6.174287] block ubiblock0_5: created from ubi0:5(rootfs)
[ 6.180934] get usb_detect_mode is fail, -22
[ 6.185744] get det_vbus is fail, -84
[ 6.189876] otg manager soc@3000000:usbc0@0: soc@3000000:usbc0@0 supply usbc not found, using dummy regulator
[ 6.201586] pwm-regulator vdd-cpu: Failed to get PWM: -517
[ 6.205724] clk: Not disabling unused clocks
[ 6.208015] cpufreq-dt cpufreq-dt: no of_node; not parsing pinctrl DT
[ 6.212608] ALSA device list:
[ 6.223110] #0: audiocodec
[ 6.226383] alloc_fd: slot 0 not NULL!
[ 6.235238] VFS: Mounted root (squashfs filesystem) readonly on device 254:0.
[ 6.245270] Freeing unused kernel memory: 1024K
[ 6.263968] Kernel init done
[ 6.267180] Run /sbin/init as init process
[ 6.888451] init: Console is alive
[ 6.892510] init: - watchdog -
[ 6.896752] init: - preinit -
[ 7.231661] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 7.258864] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 7.283825]
[ 7.283825] insmod_device_driver
[ 7.283825]
[ 7.291036] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
[ 7.304928] device_chose finished 142!
[ 7.485732] random: crng init done
/etc/preinit: line 5: strings: not found
[ 8.194005] mdio_bus 4500000.eth-0: GPIO lookup for consumer reset
[ 8.200932] mdio_bus 4500000.eth-0: using lookup tables for GPIO lookup
[ 8.208354] mdio_bus 4500000.eth-0: No GPIO consumer reset found
[ 8.223857] mdio_bus 4500000.eth-0:00: GPIO lookup for consumer reset
[ 8.231072] mdio_bus 4500000.eth-0:00: using lookup tables for GPIO lookup
[ 8.238775] mdio_bus 4500000.eth-0:00: No GPIO consumer reset found
[ 8.250360] mdio_bus 4500000.eth-0:01: GPIO lookup for consumer reset
[ 8.257619] mdio_bus 4500000.eth-0:01: using lookup tables for GPIO lookup
[ 8.265337] mdio_bus 4500000.eth-0:01: No GPIO consumer reset found
[ 8.277039] mdio_bus 4500000.eth-0:02: GPIO lookup for consumer reset
[ 8.284364] mdio_bus 4500000.eth-0:02: using lookup tables for GPIO lookup
[ 8.292048] mdio_bus 4500000.eth-0:02: No GPIO consumer reset found
[ 8.303597] mdio_bus 4500000.eth-0:03: GPIO lookup for consumer reset
[ 8.310876] mdio_bus 4500000.eth-0:03: using lookup tables for GPIO lookup
[ 8.318575] mdio_bus 4500000.eth-0:03: No GPIO consumer reset found
[ 8.330217] mdio_bus 4500000.eth-0:04: GPIO lookup for consumer reset
[ 8.337530] mdio_bus 4500000.eth-0:04: using lookup tables for GPIO lookup
[ 8.345242] mdio_bus 4500000.eth-0:04: No GPIO consumer reset found
[ 8.356895] mdio_bus 4500000.eth-0:05: GPIO lookup for consumer reset
[ 8.364142] mdio_bus 4500000.eth-0:05: using lookup tables for GPIO lookup
[ 8.371814] mdio_bus 4500000.eth-0:05: No GPIO consumer reset found
[ 8.383269] mdio_bus 4500000.eth-0:06: GPIO lookup for consumer reset
[ 8.390549] mdio_bus 4500000.eth-0:06: using lookup tables for GPIO lookup
[ 8.398239] mdio_bus 4500000.eth-0:06: No GPIO consumer reset found
[ 8.409797] mdio_bus 4500000.eth-0:07: GPIO lookup for consumer reset
[ 8.417079] mdio_bus 4500000.eth-0:07: using lookup tables for GPIO lookup
[ 8.424767] mdio_bus 4500000.eth-0:07: No GPIO consumer reset found
[ 8.436381] mdio_bus 4500000.eth-0:08: GPIO lookup for consumer reset
[ 8.443604] mdio_bus 4500000.eth-0:08: using lookup tables for GPIO lookup
[ 8.451384] mdio_bus 4500000.eth-0:08: No GPIO consumer reset found
[ 8.463076] mdio_bus 4500000.eth-0:09: GPIO lookup for consumer reset
[ 8.470363] mdio_bus 4500000.eth-0:09: using lookup tables for GPIO lookup
[ 8.478056] mdio_bus 4500000.eth-0:09: No GPIO consumer reset found
[ 8.489666] mdio_bus 4500000.eth-0:0a: GPIO lookup for consumer reset
[ 8.496938] mdio_bus 4500000.eth-0:0a: using lookup tables for GPIO lookup
[ 8.504700] mdio_bus 4500000.eth-0:0a: No GPIO consumer reset found
[ 8.516369] mdio_bus 4500000.eth-0:0b: GPIO lookup for consumer reset
[ 8.523562] mdio_bus 4500000.eth-0:0b: using lookup tables for GPIO lookup
[ 8.531287] mdio_bus 4500000.eth-0:0b: No GPIO consumer reset found
[ 8.542900] mdio_bus 4500000.eth-0:0c: GPIO lookup for consumer reset
[ 8.550155] mdio_bus 4500000.eth-0:0c: using lookup tables for GPIO lookup
[ 8.557867] mdio_bus 4500000.eth-0:0c: No GPIO consumer reset found
[ 8.569341] mdio_bus 4500000.eth-0:0d: GPIO lookup for consumer reset
[ 8.576626] mdio_bus 4500000.eth-0:0d: using lookup tables for GPIO lookup
[ 8.584312] mdio_bus 4500000.eth-0:0d: No GPIO consumer reset found
[ 8.595981] mdio_bus 4500000.eth-0:0e: GPIO lookup for consumer reset
[ 8.603204] mdio_bus 4500000.eth-0:0e: using lookup tables for GPIO lookup
[ 8.610970] mdio_bus 4500000.eth-0:0e: No GPIO consumer reset found
[ 8.622561] mdio_bus 4500000.eth-0:0f: GPIO lookup for consumer reset
[ 8.629836] mdio_bus 4500000.eth-0:0f: using lookup tables for GPIO lookup
[ 8.637522] mdio_bus 4500000.eth-0:0f: No GPIO consumer reset found
[ 8.649028] mdio_bus 4500000.eth-0:10: GPIO lookup for consumer reset
[ 8.656345] mdio_bus 4500000.eth-0:10: using lookup tables for GPIO lookup
[ 8.664042] mdio_bus 4500000.eth-0:10: No GPIO consumer reset found
[ 8.675704] mdio_bus 4500000.eth-0:11: GPIO lookup for consumer reset
[ 8.682897] mdio_bus 4500000.eth-0:11: using lookup tables for GPIO lookup
[ 8.690652] mdio_bus 4500000.eth-0:11: No GPIO consumer reset found
[ 8.702181] mdio_bus 4500000.eth-0:12: GPIO lookup for consumer reset
[ 8.709491] mdio_bus 4500000.eth-0:12: using lookup tables for GPIO lookup
[ 8.717191] mdio_bus 4500000.eth-0:12: No GPIO consumer reset found
[ 8.728806] mdio_bus 4500000.eth-0:13: GPIO lookup for consumer reset
[ 8.736094] mdio_bus 4500000.eth-0:13: using lookup tables for GPIO lookup
[ 8.743781] mdio_bus 4500000.eth-0:13: No GPIO consumer reset found
[ 8.755482] mdio_bus 4500000.eth-0:14: GPIO lookup for consumer reset
[ 8.762676] mdio_bus 4500000.eth-0:14: using lookup tables for GPIO lookup
[ 8.770463] mdio_bus 4500000.eth-0:14: No GPIO consumer reset found
[ 8.782039] mdio_bus 4500000.eth-0:15: GPIO lookup for consumer reset
[ 8.789308] mdio_bus 4500000.eth-0:15: using lookup tables for GPIO lookup
[ 8.797009] mdio_bus 4500000.eth-0:15: No GPIO consumer reset found
[ 8.808521] mdio_bus 4500000.eth-0:16: GPIO lookup for consumer reset
[ 8.815786] mdio_bus 4500000.eth-0:16: using lookup tables for GPIO lookup
[ 8.823458] mdio_bus 4500000.eth-0:16: No GPIO consumer reset found
[ 8.835087] mdio_bus 4500000.eth-0:17: GPIO lookup for consumer reset
[ 8.842311] mdio_bus 4500000.eth-0:17: using lookup tables for GPIO lookup
[ 8.850056] mdio_bus 4500000.eth-0:17: No GPIO consumer reset found
[ 8.861592] mdio_bus 4500000.eth-0:18: GPIO lookup for consumer reset
[ 8.868871] mdio_bus 4500000.eth-0:18: using lookup tables for GPIO lookup
[ 8.876558] mdio_bus 4500000.eth-0:18: No GPIO consumer reset found
[ 8.888192] mdio_bus 4500000.eth-0:19: GPIO lookup for consumer reset
[ 8.895479] mdio_bus 4500000.eth-0:19: using lookup tables for GPIO lookup
[ 8.903176] mdio_bus 4500000.eth-0:19: No GPIO consumer reset found
[ 8.914837] mdio_bus 4500000.eth-0:1a: GPIO lookup for consumer reset
[ 8.922031] mdio_bus 4500000.eth-0:1a: using lookup tables for GPIO lookup
[ 8.929763] mdio_bus 4500000.eth-0:1a: No GPIO consumer reset found
[ 8.941321] mdio_bus 4500000.eth-0:1b: GPIO lookup for consumer reset
[ 8.948558] mdio_bus 4500000.eth-0:1b: using lookup tables for GPIO lookup
[ 8.956285] mdio_bus 4500000.eth-0:1b: No GPIO consumer reset found
[ 8.967882] mdio_bus 4500000.eth-0:1c: GPIO lookup for consumer reset
[ 8.975155] mdio_bus 4500000.eth-0:1c: using lookup tables for GPIO lookup
[ 8.982845] mdio_bus 4500000.eth-0:1c: No GPIO consumer reset found
[ 8.994445] mdio_bus 4500000.eth-0:1d: GPIO lookup for consumer reset
[ 9.001638] mdio_bus 4500000.eth-0:1d: using lookup tables for GPIO lookup
[ 9.009356] mdio_bus 4500000.eth-0:1d: No GPIO consumer reset found
[ 9.020926] mdio_bus 4500000.eth-0:1e: GPIO lookup for consumer reset
[ 9.028211] mdio_bus 4500000.eth-0:1e: using lookup tables for GPIO lookup
[ 9.035920] mdio_bus 4500000.eth-0:1e: No GPIO consumer reset found
[ 9.047529] mdio_bus 4500000.eth-0:1f: GPIO lookup for consumer reset
[ 9.054808] mdio_bus 4500000.eth-0:1f: using lookup tables for GPIO lookup
[ 9.062479] mdio_bus 4500000.eth-0:1f: No GPIO consumer reset found
[ 9.069683] libphy: 4500000.eth: probed
[ 9.074257] pwm-regulator vdd-cpu: Failed to get PWM: -517
[ 9.080550] cpufreq-dt cpufreq-dt: no of_node; not parsing pinctrl DT
[ 9.084130] sunxi-gmac 4500000.eth eth0: eth0: Type(7) PHY ID 00070007 at 0 IRQ poll (4500000.eth-0:00)
[ 9.109893] sunxi-gmac 4500000.eth eth0: Link is Up - 10Mbps/Half - flow control off
Error: inet prefix is expected rather than "/".
/dev/by-name/UDISK already format by ubifs
/dev/by-name/rootfs_data already format by ubifs
[ 9.614355] mount_root: loading kmods from internal overlay
[ 9.629896] kmodloader: loading kernel modules from //etc/modules-boot.d/*
[ 9.637971] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
[ 12.672443] block: attempting to load /etc/config/fstab
[ 12.715980] UBIFS (ubi0:8): Mounting in unauthenticated mode
[ 12.722461] UBIFS (ubi0:8): background thread "ubifs_bgt0_8" started, PID 1213
[ 12.819055] UBIFS (ubi0:8): recovery needed
[ 13.074494] UBIFS (ubi0:8): recovery completed
[ 13.079564] UBIFS (ubi0:8): UBIFS: mounted UBI device 0, volume 8, name "UDISK"
[ 13.087769] UBIFS (ubi0:8): LEB size: 258048 bytes (252 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
[ 13.098843] UBIFS (ubi0:8): FS size: 6193152 bytes (5 MiB, 24 LEBs), journal size 2322433 bytes (2 MiB, 8 LEBs)
[ 13.110106] UBIFS (ubi0:8): reserved for root: 0 bytes (0 KiB)
[ 13.116627] UBIFS (ubi0:8): media format: w4/r0 (latest is w5/r0), UUID 89A700E0-058F-464D-89AD-C2407DC9E127, small LPT model
[ 13.142619] mount_root: switched to extroot
[ 13.170756] sunxi-gmac 4500000.eth eth0: Link is Down
[ 14.392181] procd: - early -
[ 14.395643] procd: - watchdog -
[ 14.672095] procd: - watchdog -
[ 14.687446] procd: - ubus -
[ 14.885697] procd: - init -
BusyBox v1.33.2 (2024-09-03 08:04:14 UTC) built-in shell (ash)
_____ _ __ _
|_ _||_| ___ _ _ | | |_| ___ _ _ _ _
| | _ | || | | |__ | || || | ||_'_|
| | | || | || _ | |_____||_||_|_||___||_,_|
|_| |_||_|_||_|_| Tina is Based on OpenWrt!
Tina 5.0, OpenWrt 21.02-SNAPSHOT r0-7a9e5fa3d8
[ 15.199230] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
root@(none):/# [ 15.921983] udevd[1517]: starting version 3.2.9
[ 16.009538] kmodloader: loading kernel modules from /etc/modules.d/*
[ 16.156882] udevd[1517]: specified group 'tty' unknown
[ 16.163019] udevd[1517]: specified group 'kmem' unknown
[ 16.169245] udevd[1517]: specified group 'input' unknown
[ 16.175498] udevd[1517]: specified group 'video' unknown
[ 16.181948] udevd[1517]: specified group 'lp' unknown
[ 16.187956] udevd[1517]: specified group 'disk' unknown
[ 16.214188] udevd[1517]: specified group 'cdrom' unknown
[ 16.220422] udevd[1517]: specified group 'tape' unknown
[ 16.226929] udevd[1517]: specified group 'kvm' unknown
[ 16.455261] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 16.478539] udevd[1661]: starting eudev-3.2.9
[ 16.483701] printk: udevd: 2 output lines suppressed due to ratelimiting
[ 16.547369] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 16.567711] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 16.584528] kmodloader: done loading kernel modules from /etc/modules.d/*
kmodloader done
[ 16.621161] cfg80211: failed to load regulatory.db
[ 17.019447] file system registered
[ 17.323284] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[ 17.630728] read descriptors
[ 17.647237] read strings
[ 17.842104] sunxi_set_cur_vol_work()424 WARN: get power supply failed
[ 17.891002] android_work: sent uevent USB_STATE=CONNECTED
[ 18.031215] sunxi_set_cur_vol_work()424 WARN: get power supply failed
[ 18.094644] configfs-gadget gadget: high-speed config #1: c
[ 18.101152] android_work: sent uevent USB_STATE=CONFIGURED
[ 18.835257] IPv6: ADDRCONF(NETDEV_CHANGE): can1: link becomes ready
[ 18.901382] sun8iw20-pinctrl pio: request pin 200 (PG8) for pio:200
[ 18.924680] sun8iw20-pinctrl pio: bank PG regulator has been opened
[ 18.931772] sun8iw20-pinctrl pio: request pin 199 (PG7) for pio:199
[ 18.943831] sun8iw20-pinctrl pio: bank PG regulator has been opened
[ 18.954530] gpio gpiochip0: Persistence not supported for GPIO 200
[ 18.961541] sun8iw20-pinctrl pio: pio: request IRQ for GPIO 200, return 168
[ 18.970174] gpio gpiochip0: Persistence not supported for GPIO 199
[ 18.991394] sun8iw20-pinctrl pio: pio: request IRQ for GPIO 199, return 167
附上启动log,另外loglevel的级别设置为8和设置为0,启动时间没有变化
#2 2024-10-08 17:07:31
shaoxi2010
已发帖子: 399
Re: 全志T113-S3启动优化
loglevel没改对吧,你这一条日志几个ms,怎么看都是没关闭打印的状态
#3 2024-10-08 17:11:21
shaoxi2010
已发帖子: 399
Re: 全志T113-S3启动优化
还有你的只读文件系统内脚本是不有等待,你先整个空的进去看看堵塞3秒的问题还在不
#4 2024-10-08 17:36:38
jkl
已发帖子: 269
Re: 全志T113-S3启动优化
不要走procd-init初始化,这个启动流程确实长,自己改成busybox-init就快很多了
楼主 #5 2024-10-08 19:48:59
michou2022
Re: 全志T113-S3启动优化
log时我打开的,关闭之后启动的时间用秒表测过相差不到1秒,这个时方便观察打开的,这个也是很奇怪的日志关闭对启动时间没有影响
楼主 #6 2024-10-08 19:50:01
michou2022
Re: 全志T113-S3启动优化
我尝试改一下试试:)
楼主 #7 2024-10-08 19:50:53
michou2022
Re: 全志T113-S3启动优化
这涛SDK是官方的只修改了NAND启动其他没改
#8 2026-05-11 17:30:58
dlskm
Re: 全志T113-S3启动优化
你好,我看RGMII需要 RGMII-CLKIN外部phy提供125M时钟输入作为参考,但是rtl8363没有看到有时钟输出引脚,可以问一下硬件是怎么设计的吗
