楼主 #1 2019-05-28 22:38:01
OggyJFX
已发帖子: 110
FreeRTOS----heap_4.c增加realloc和calloc
NUC972上面跑的FreeRTOS, 堆管理程序,都没有realloc和calloc,但是freetype要用
freetype默认用的gnu tool的标准库里面的malloc, free, realloc, calloc,这几个函数,配合FreeRTOS使用,如果不好好处理,是有严重问题的,谁用谁知道。
提供一个heap_4.c,增加realloc和calloc,freetype直接使用FreeRTOS的堆管理函数,解决一切烦恼。
heap_4.7z
#2 2019-05-28 22:44:09
firstman
已发帖子: 279
Re: FreeRTOS----heap_4.c增加realloc和calloc
    FreeRTOS V8.2.3 - Copyright (C) 2015 Real Time Engineers Ltd.
    All rights reserved
    VISIT http://www.FreeRTOS.org TO ENSURE YOU ARE USING THE LATEST VERSION.
    This file is part of the FreeRTOS distribution.
    FreeRTOS is free software; you can redistribute it and/or modify it under
    the terms of the GNU General Public License (version 2) as published by the
    Free Software Foundation >>>> AND MODIFIED BY <<<< the FreeRTOS exception.
    >>!   NOTE: The modification to the GPL is included to allow you to     !<<
    >>!   distribute a combined work that includes FreeRTOS without being   !<<
    >>!   obliged to provide the source code for proprietary components     !<<
    >>!   outside of the FreeRTOS kernel.                                   !<<
    FreeRTOS is distributed in the hope that it will be useful, but WITHOUT ANY
    WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
    FOR A PARTICULAR PURPOSE.  Full license text is available on the following
    link: http://www.freertos.org/a00114.html
     *    FreeRTOS provides completely free yet professionally developed,    *
     *    robust, strictly quality controlled, supported, and cross          *
     *    platform software that is more than just the market leader, it     *
     *    is the industry's de facto standard.                               *
     *    Help yourself get started quickly while simultaneously helping     *
     *    to support the FreeRTOS project by purchasing a FreeRTOS           *
     *    tutorial book, reference manual, or both:                          *
     *    http://www.FreeRTOS.org/Documentation                              *
    http://www.FreeRTOS.org/FAQHelp.html - Having a problem?  Start by reading
    the FAQ page "My application does not run, what could be wrong?".  Have you
    defined configASSERT()?
    http://www.FreeRTOS.org/support - In return for receiving this top quality
    embedded software for free we request you assist our global community by
    participating in the support forum.
    http://www.FreeRTOS.org/training - Investing in training allows your team to
    be as productive as possible as early as possible.  Now you can receive
    FreeRTOS training directly from Richard Barry, CEO of Real Time Engineers
    Ltd, and the world's leading authority on the world's leading RTOS.
    http://www.FreeRTOS.org/plus - A selection of FreeRTOS ecosystem products,
    including FreeRTOS+Trace - an indispensable productivity tool, a DOS
    compatible FAT file system, and our tiny thread aware UDP/IP stack.
    http://www.FreeRTOS.org/labs - Where new FreeRTOS products go to incubate.
    Come and try FreeRTOS+TCP, our new open source TCP/IP stack for FreeRTOS.
    http://www.OpenRTOS.com - Real Time Engineers ltd. license FreeRTOS to High
    Integrity Systems ltd. to sell under the OpenRTOS brand.  Low cost OpenRTOS
    licenses offer ticketed support, indemnification and commercial middleware.
    http://www.SafeRTOS.com - High Integrity Systems also provide a safety
    engineered and independently SIL3 certified version for use in safety and
    mission critical applications that require provable dependability.
    1 tab == 4 spaces!
 * A sample implementation of pvPortMalloc() and vPortFree() that combines
 * (coalescences) adjacent memory blocks as they are freed, and in so doing
 * limits memory fragmentation.
 * See heap_1.c, heap_2.c and heap_3.c for alternative implementations, and the
 * memory management pages of http://www.FreeRTOS.org for more information.
#include <stdlib.h>
#include <string.h>
/* Defining MPU_WRAPPERS_INCLUDED_FROM_API_FILE prevents task.h from redefining
all the API functions to use the MPU wrappers.  That should only be done when
task.h is included from an application file. */
#define MPU_WRAPPERS_INCLUDED_FROM_API_FILE
#include "FreeRTOS.h"
#include "task.h"
#undef MPU_WRAPPERS_INCLUDED_FROM_API_FILE
/* Block sizes must not get too small. */
#define heapMINIMUM_BLOCK_SIZE	( ( size_t ) ( xHeapStructSize << 1 ) )
/* Assumes 8bit bytes! */
#define heapBITS_PER_BYTE		( ( size_t ) 8 )
/* Allocate the memory for the heap. */
#if( configAPPLICATION_ALLOCATED_HEAP == 1 )
	/* The application writer has already defined the array used for the RTOS
	heap - probably so it can be placed in a special segment or address. */
	extern uint8_t ucHeap[ configTOTAL_HEAP_SIZE ];
#else
	static uint8_t ucHeap[ configTOTAL_HEAP_SIZE ];
#endif /* configAPPLICATION_ALLOCATED_HEAP */
/* Define the linked list structure.  This is used to link free blocks in order
of their memory address. */
typedef struct A_BLOCK_LINK
	struct A_BLOCK_LINK *pxNextFreeBlock;	/*<< The next free block in the list. */
	size_t xBlockSize;						/*<< The size of the free block. */
} BlockLink_t;
 * Inserts a block of memory that is being freed into the correct position in
 * the list of free memory blocks.  The block being freed will be merged with
 * the block in front it and/or the block behind it if the memory blocks are
 * adjacent to each other.
static void prvInsertBlockIntoFreeList( BlockLink_t *pxBlockToInsert );
 * Called automatically to setup the required heap structures the first time
 * pvPortMalloc() is called.
static void prvHeapInit( void );
/* The size of the structure placed at the beginning of each allocated memory
block must by correctly byte aligned. */
static const size_t xHeapStructSize	= ( sizeof( BlockLink_t ) + ( ( size_t ) ( portBYTE_ALIGNMENT - 1 ) ) ) & ~( ( size_t ) portBYTE_ALIGNMENT_MASK );
/* Create a couple of list links to mark the start and end of the list. */
static BlockLink_t xStart, *pxEnd = NULL;
/* Keeps track of the number of free bytes remaining, but says nothing about
fragmentation. */
static size_t xFreeBytesRemaining = 0U;
static size_t xMinimumEverFreeBytesRemaining = 0U;
/* Gets set to the top bit of an size_t type.  When this bit in the xBlockSize
member of an BlockLink_t structure is set then the block belongs to the
application.  When the bit is free the block is still part of the free heap
space. */
static size_t xBlockAllocatedBit = 0;
void *pvPortMalloc( size_t xWantedSize )
BlockLink_t *pxBlock, *pxPreviousBlock, *pxNewBlockLink;
void *pvReturn = NULL;
	vTaskSuspendAll();
		/* If this is the first call to malloc then the heap will require
		initialisation to setup the list of free blocks. */
		if( pxEnd == NULL )
			prvHeapInit();
			mtCOVERAGE_TEST_MARKER();
		/* Check the requested block size is not so large that the top bit is
		set.  The top bit of the block size member of the BlockLink_t structure
		is used to determine who owns the block - the application or the
		kernel, so it must be free. */
		if( ( xWantedSize & xBlockAllocatedBit ) == 0 )
			/* The wanted size is increased so it can contain a BlockLink_t
			structure in addition to the requested amount of bytes. */
			if( xWantedSize > 0 )
				xWantedSize += xHeapStructSize;
				/* Ensure that blocks are always aligned to the required number
				of bytes. */
				if( ( xWantedSize & portBYTE_ALIGNMENT_MASK ) != 0x00 )
					/* Byte alignment required. */
					xWantedSize += ( portBYTE_ALIGNMENT - ( xWantedSize & portBYTE_ALIGNMENT_MASK ) );
					configASSERT( ( xWantedSize & portBYTE_ALIGNMENT_MASK ) == 0 );
			if( ( xWantedSize > 0 ) && ( xWantedSize <= xFreeBytesRemaining ) )
				/* Traverse the list from the start	(lowest address) block until
				one	of adequate size is found. */
				pxPreviousBlock = &xStart;
				pxBlock = xStart.pxNextFreeBlock;
				while( ( pxBlock->xBlockSize < xWantedSize ) && ( pxBlock->pxNextFreeBlock != NULL ) )
					pxPreviousBlock = pxBlock;
					pxBlock = pxBlock->pxNextFreeBlock;
				/* If the end marker was reached then a block of adequate size
				was	not found. */
				if( pxBlock != pxEnd )
					/* Return the memory space pointed to - jumping over the
					BlockLink_t structure at its start. */
					pvReturn = ( void * ) ( ( ( uint8_t * ) pxPreviousBlock->pxNextFreeBlock ) + xHeapStructSize );
					/* This block is being returned for use so must be taken out
					of the list of free blocks. */
					pxPreviousBlock->pxNextFreeBlock = pxBlock->pxNextFreeBlock;
					/* If the block is larger than required it can be split into
					two. */
					if( ( pxBlock->xBlockSize - xWantedSize ) > heapMINIMUM_BLOCK_SIZE )
						/* This block is to be split into two.  Create a new
						block following the number of bytes requested. The void
						cast is used to prevent byte alignment warnings from the
						compiler. */
						pxNewBlockLink = ( void * ) ( ( ( uint8_t * ) pxBlock ) + xWantedSize );
						configASSERT( ( ( ( size_t ) pxNewBlockLink ) & portBYTE_ALIGNMENT_MASK ) == 0 );
						/* Calculate the sizes of two blocks split from the
						single block. */
						pxNewBlockLink->xBlockSize = pxBlock->xBlockSize - xWantedSize;
						pxBlock->xBlockSize = xWantedSize;
						/* Insert the new block into the list of free blocks. */
						prvInsertBlockIntoFreeList( pxNewBlockLink );
					xFreeBytesRemaining -= pxBlock->xBlockSize;
					if( xFreeBytesRemaining < xMinimumEverFreeBytesRemaining )
						xMinimumEverFreeBytesRemaining = xFreeBytesRemaining;
					/* The block is being returned - it is allocated and owned
					by the application and has no "next" block. */
					pxBlock->xBlockSize |= xBlockAllocatedBit;
					pxBlock->pxNextFreeBlock = NULL;
		traceMALLOC( pvReturn, xWantedSize );
	( void ) xTaskResumeAll();
	#if( configUSE_MALLOC_FAILED_HOOK == 1 )
		if( pvReturn == NULL )
			extern void vApplicationMallocFailedHook( void );
			vApplicationMallocFailedHook();
	configASSERT( ( ( ( uint32_t ) pvReturn ) & portBYTE_ALIGNMENT_MASK ) == 0 );
	return pvReturn;
void vPortFree( void *pv )
uint8_t *puc = ( uint8_t * ) pv;
BlockLink_t *pxLink;
	if( pv != NULL )
		/* The memory being freed will have an BlockLink_t structure immediately
		before it. */
		puc -= xHeapStructSize;
		/* This casting is to keep the compiler from issuing warnings. */
		pxLink = ( void * ) puc;
		/* Check the block is actually allocated. */
		configASSERT( ( pxLink->xBlockSize & xBlockAllocatedBit ) != 0 );
		configASSERT( pxLink->pxNextFreeBlock == NULL );
		if( ( pxLink->xBlockSize & xBlockAllocatedBit ) != 0 )
			if( pxLink->pxNextFreeBlock == NULL )
				/* The block is being returned to the heap - it is no longer
				allocated. */
				pxLink->xBlockSize &= ~xBlockAllocatedBit;
				vTaskSuspendAll();
					/* Add this block to the list of free blocks. */
					xFreeBytesRemaining += pxLink->xBlockSize;
					traceFREE( pv, pxLink->xBlockSize );
					prvInsertBlockIntoFreeList( ( ( BlockLink_t * ) pxLink ) );
void *pvPortRealloc( void *SrcAddr, size_t NewSize)
	size_t xWantedSize;
    BlockLink_t *pxBlockold, *pxBlockjudge, *pxIterator;
    size_t cnt;
    if(SrcAddr == NULL)
        /* 直接malloc */
        pvReturn = pvPortMalloc(NewSize);
        return pvReturn;
    if(NewSize <= 0)
        vPortFree(SrcAddr);
        return NULL;
    vTaskSuspendAll();
        if( pxEnd == NULL )
            prvHeapInit();
        if( ( NewSize & xBlockAllocatedBit ) == 0 )
			/* xWantedSize中包含BlockLink_t结构体的尺寸 */
			xWantedSize = NewSize + xHeapStructSize;
			/* 块结束边界对齐处理 */
			if ((xWantedSize & portBYTE_ALIGNMENT_MASK) != 0x00)
				xWantedSize += (portBYTE_ALIGNMENT - (xWantedSize & portBYTE_ALIGNMENT_MASK));
				configASSERT((xWantedSize & portBYTE_ALIGNMENT_MASK) == 0);
			/* 找到源地址对应的BlockLink_t结构体,提取其中的xBlockSize信息 */
			pxBlockold = (BlockLink_t *)(((uint8_t *)SrcAddr) - xHeapStructSize);
            if ((pxBlockold->xBlockSize & (~xBlockAllocatedBit)) >= xWantedSize)
				/* 原来的内存足够覆盖新申请的内存,什么也不做,直接返回 */
				pvReturn = SrcAddr;
				/* 判断源地址块后的下一块是否可以合并使用 */
				for (pxIterator = &xStart;
					 pxIterator->pxNextFreeBlock < pxBlockold;
					 pxIterator = pxIterator->pxNextFreeBlock)
					/* 什么也不做,只是为了找到比原内存块更靠后的空内存块 */
				pxPreviousBlock = pxIterator;
				pxBlock = pxIterator->pxNextFreeBlock;
				/* 计算源地址后面的内存块 */
                pxBlockjudge = (BlockLink_t *)(((uint8_t *)pxBlockold) + (pxBlockold->xBlockSize & (~xBlockAllocatedBit)));
                if (pxBlock != pxBlockjudge ||
                    ((pxBlockold->xBlockSize & (~xBlockAllocatedBit)) + pxBlockjudge->xBlockSize) < xWantedSize)
					/* 源地址块后面没有空闲地址块了或者空闲空间也不够 */
					if (pvReturn)
                        cnt = (pxBlockold->xBlockSize & (~xBlockAllocatedBit)) - xHeapStructSize;
						cnt = cnt > NewSize ? NewSize : cnt;
						memcpy((uint8_t *)pvReturn, SrcAddr, cnt);
						vPortFree(SrcAddr);
					/* 直接使用后面的地址空间 */
					pvReturn = SrcAddr;
                    /* cnt表示从后面的内存块中取走多少个Byte */
                    cnt = xWantedSize - (pxBlockold->xBlockSize & (~xBlockAllocatedBit));
                    if ((pxBlock->xBlockSize - cnt) > heapMINIMUM_BLOCK_SIZE)
						/* 分裂后面的内存块 */
                        /* 创建新的空闲内存块 */
						pxNewBlockLink = (BlockLink_t *)(((uint8_t *)pxBlockold) + xWantedSize);
                        pxNewBlockLink->pxNextFreeBlock = NULL;
                        pxNewBlockLink->xBlockSize = pxBlock->xBlockSize - cnt;
                        /* 内存池中剩余的内存数量 */
                        xFreeBytesRemaining -= cnt;
                        /* realloc以后的新内存块大小 */
                        pxBlockold->xBlockSize = xWantedSize | xBlockAllocatedBit;
                        /* 重新链接空闲内存表 */
						prvInsertBlockIntoFreeList(pxNewBlockLink);
						/* 直接将后面的整个块都合并到原地址块 */
                        pxBlockold->xBlockSize += pxBlock->xBlockSize;
					if(xMinimumEverFreeBytesRemaining > xFreeBytesRemaining)
    configASSERT( ( ( ( size_t ) pvReturn ) & ( size_t ) portBYTE_ALIGNMENT_MASK ) == 0 );
    return pvReturn;
void *pvPortCalloc(size_t n, size_t size)
	void *pvReturn;
	pvReturn = pvPortMalloc(n * size);
    if(pvReturn)
        memset(pvReturn, 0, n * size);
	return pvReturn;
size_t xPortGetFreeHeapSize( void )
	return xFreeBytesRemaining;
size_t xPortGetMinimumEverFreeHeapSize( void )
	return xMinimumEverFreeBytesRemaining;
void vPortInitialiseBlocks( void )
	/* This just exists to keep the linker quiet. */
BlockLink_t *pxFirstFreeBlock;
uint8_t *pucAlignedHeap;
size_t uxAddress;
size_t xTotalHeapSize = configTOTAL_HEAP_SIZE;
	/* Ensure the heap starts on a correctly aligned boundary. */
	uxAddress = ( size_t ) ucHeap;
	if( ( uxAddress & portBYTE_ALIGNMENT_MASK ) != 0 )
		uxAddress += ( portBYTE_ALIGNMENT - 1 );
		uxAddress &= ~( ( size_t ) portBYTE_ALIGNMENT_MASK );
		xTotalHeapSize -= uxAddress - ( size_t ) ucHeap;
	pucAlignedHeap = ( uint8_t * ) uxAddress;
	/* xStart is used to hold a pointer to the first item in the list of free
	blocks.  The void cast is used to prevent compiler warnings. */
	xStart.pxNextFreeBlock = ( void * ) pucAlignedHeap;
	xStart.xBlockSize = ( size_t ) 0;
	/* pxEnd is used to mark the end of the list of free blocks and is inserted
	at the end of the heap space. */
	uxAddress = ( ( size_t ) pucAlignedHeap ) + xTotalHeapSize;
	uxAddress -= xHeapStructSize;
	pxEnd = ( void * ) uxAddress;
	pxEnd->xBlockSize = 0;
	pxEnd->pxNextFreeBlock = NULL;
	/* To start with there is a single free block that is sized to take up the
	entire heap space, minus the space taken by pxEnd. */
	pxFirstFreeBlock = ( void * ) pucAlignedHeap;
	pxFirstFreeBlock->xBlockSize = uxAddress - ( size_t ) pxFirstFreeBlock;
	pxFirstFreeBlock->pxNextFreeBlock = pxEnd;
	/* Only one block exists - and it covers the entire usable heap space. */
	xMinimumEverFreeBytesRemaining = pxFirstFreeBlock->xBlockSize;
	xFreeBytesRemaining = pxFirstFreeBlock->xBlockSize;
	/* Work out the position of the top bit in a size_t variable. */
	xBlockAllocatedBit = ( ( size_t ) 1 ) << ( ( sizeof( size_t ) * heapBITS_PER_BYTE ) - 1 );
BlockLink_t *pxIterator;
uint8_t *puc;
	/* Iterate through the list until a block is found that has a higher address
	than the block being inserted. */
	for( pxIterator = &xStart; pxIterator->pxNextFreeBlock < pxBlockToInsert; pxIterator = pxIterator->pxNextFreeBlock )
		/* Nothing to do here, just iterate to the right position. */
	/* Do the block being inserted, and the block it is being inserted after
	make a contiguous block of memory? */
	puc = ( uint8_t * ) pxIterator;
	if( ( puc + pxIterator->xBlockSize ) == ( uint8_t * ) pxBlockToInsert )
		pxIterator->xBlockSize += pxBlockToInsert->xBlockSize;
		pxBlockToInsert = pxIterator;
	/* Do the block being inserted, and the block it is being inserted before
	puc = ( uint8_t * ) pxBlockToInsert;
	if( ( puc + pxBlockToInsert->xBlockSize ) == ( uint8_t * ) pxIterator->pxNextFreeBlock )
		if( pxIterator->pxNextFreeBlock != pxEnd )
			/* Form one big block from the two blocks. */
			pxBlockToInsert->xBlockSize += pxIterator->pxNextFreeBlock->xBlockSize;
			pxBlockToInsert->pxNextFreeBlock = pxIterator->pxNextFreeBlock->pxNextFreeBlock;
			pxBlockToInsert->pxNextFreeBlock = pxEnd;
		pxBlockToInsert->pxNextFreeBlock = pxIterator->pxNextFreeBlock;
	/* If the block being inserted plugged a gab, so was merged with the block
	before and the block after, then it's pxNextFreeBlock pointer will have
	already been set, and should not be set here as that would make it point
	to itself. */
	if( pxIterator != pxBlockToInsert )
		pxIterator->pxNextFreeBlock = pxBlockToInsert;
我比较了一下, 好像就是添加了两个函数: pvPortCalloc pvPortRealloc
请问下, 这两个函数干嘛用的呢?
#3 2019-05-28 22:46:23
firstman
已发帖子: 279
楼主 #4 2019-05-28 23:04:10
OggyJFX
已发帖子: 110
我看见你说的这个了,这个pvPortRealloc的实现,太简单粗暴了,而且把别人的heap_4.c进行了魔改,改得面目全非了。
realloc和calloc是干啥的,你自己看资料吧^_^ 。
最近编辑记录 OggyJFX (2019-05-28 23:04:48)
#5 2019-05-28 23:12:42
真的是很烦
已发帖子: 162
还有个 bget, 挺好使的
http://www.fourmilab.ch/bget/
#6 2019-05-29 09:06:50
firstman
已发帖子: 279
真的是很烦 wrote:
还有个 bget, 挺好使的
翻译简介看了一下, 真不错。
#8 2024-10-28 22:12:57
GGDuck
你好楼主,我也准备自实现一个realloc函数,积分不太够下载文件,请问你能简单的说一下思路吗?谢谢
#10 2026-01-09 13:46:55
Mondayice
你好,博主,请问这个实现经过实际验证了吗?
