上传到这里做个笔记^^
重新编辑原因:原来的LVGL刷屏速度太慢了,下午调试发现把lv_tick_inc(5)新开一线程更新,速度上来了,重新上传修改后的代码
源码是:lvgl7110_f1c_demo.7z,自己下载解压
1. 改lvgl及makefile
(1)lvgl
东西都是现成了,下了当前最新的lvgl 7.11.0版本,
主要改了lv_conf.h,lv_drv_conf.h,lv_ex_conf.h三个配置文件,以及main函数修改了一下。
具体忘记改哪些了,都是make的时候,哪里报错就改哪里的,直接看我的例程源文件
(2)
参考网上把makefile文件改了一下,主要是把交叉编译链的目录改成自己的目录就可以了,比如我的是
CC = /home/myway/f1c200/buildroot-tiny200/output/host/bin/arm-buildroot-linux-gnueabi-gcc-8.4.0
然后就可以make 生成执行文件 lvgl_7110_demo
2. 运行
将编译出来的lvgl_7110_demo放在tiny200-r3的文件系统,比如我的放在root文件夹下,运行如下
# pwd
/root
# ls
lvgl_7110_demo
# chmod 777 lvgl_7110_demo
# ./lvgl_7110_demo 3
lvgl version:7.11.0
demo num:3
The framebuffer device was opened successfully.
800x480, 32bpp
The framebuffer device was mapped to memory successfully.
总共51个demo,运行第几个demo就加相应的数字,如运行第3个就是
./lvgl_7110_demo 3
demo数字对应的数字如下,参考main函数:
switch(demo_num)
case 0:
case 1: lv_demo_widgets(); break;
case 2: lv_demo_music(); break;
case 3: lv_demo_printer(); break;
case 4: lv_demo_keypad_encoder(); break;
case 5: lv_demo_benchmark(); break;
case 6: lv_ex_get_started_1(); break;
case 7: lv_ex_get_started_2(); break;
case 8: lv_ex_get_started_3(); break;
case 9: lv_ex_style_1(); break;
case 10: lv_ex_style_2(); break;
case 11: lv_ex_style_3(); break;
case 12: lv_ex_style_4(); break;
case 13: lv_ex_style_5(); break;
case 14: lv_ex_style_6(); break;
case 15: lv_ex_style_7(); break;
case 16: lv_ex_style_8(); break;
case 17: lv_ex_style_10(); break;
case 18: lv_ex_style_11(); break;
case 19: lv_ex_arc_1(); break;
case 20: lv_ex_tileview_1(); break;
case 21: lv_ex_spinner_1(); break;
case 22: lv_ex_spinbox_1(); break;
case 23: lv_ex_slider_1(); break;
case 24: lv_ex_roller_1(); break;
case 25: lv_ex_page_1(); break;
case 26: lv_ex_objmask_1(); break;
case 27: lv_ex_objmask_2(); break;
case 28: lv_ex_msgbox_2(); break;
case 29: lv_ex_list_1(); break;
case 30: lv_ex_linemeter_1(); break;
case 31: lv_ex_line_1(); break;
case 32: lv_ex_imgbtn_1(); break;
case 33: lv_ex_img_1(); break;
case 34: lv_ex_gauge_1(); break;
case 35: lv_ex_gauge_2(); break;
case 36: lv_ex_dropdown_1(); break;
case 37: lv_ex_dropdown_2(); break;
case 38: lv_ex_cpicker_1(); break;
case 39: lv_ex_cpicker_2(); break;
case 40: lv_ex_cont_1(); break;
case 41: lv_ex_checkbox_1(); break;
case 42: lv_ex_chart_1(); break;
case 43: lv_ex_chart_2(); break;
case 44: lv_ex_canvas_1(); break;
case 45: lv_ex_canvas_2(); break;
case 46: lv_ex_calendar_1(); break;
case 47: lv_ex_btnmatrix_1(); break;
case 48: lv_ex_btn_1(); break;
case 49: lv_ex_btn_2(); break;
case 50: lv_ex_bar_1(); break;
case 51: lv_ex_arc_1(); break;
case 52: lv_ex_arc_2(); break;[video]https://whycan.com/files/members/6042/printf1.mp4[/video]
default:
最近编辑记录 xiaohua4758 (2021-03-09 16:48:27)
谢谢分享。
用楼主的demo不知道为什么触屏不能用,用ts_test已经能正常测试触屏了。
that is ok..
+1......触摸只有一小块能用
buliaoqq 说:用楼主的demo不知道为什么触屏不能用,用ts_test已经能正常测试触屏了。
+1......触摸只有一小块能用
是不是GT911触屏重新配置了数据,不同厂家的的屏配置数据不一样,尽量不要动配置,动之前先备份。
@lg676041036
这么一说 厂家提供了一组gt911的初始化数组 应该是这样原因
有没有整个含板子驱动的代码?
lv_conf.h
lv_drv_conf.h
lv_ex_conf.h
需要修改的这三个文件还有main.c,放在什么目录下,单独创建个文件夹吗?和之前的lvgl,lv_drivers,examples目录同级的吗
tina是哪个系统内核
你好,我自己做的板子 也是Tina系统,编译出了出来的LVGL 运行不起来,提示我
root@TinaLinux:~# ls
demo
root@TinaLinux:~# ./demo 1
-/bin/sh: ./demo: not found
