楼主 # 2024-12-04 17:30:52
memory
已发帖子: 487
A133 AW869C 蓝牙开启失败,请问是什么原因呢?
12-04 16:39:58.393  2451  2661 E[  877.899234] AICWFDBG(LOGTRACE)       rwnx_send_msg (118)MM_GET_STA_INFO_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
 WifiVendorHal: getWifiLinkLayer[  877.912624] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
Stats_1_3_Internal(l.926) failed[  877.924856] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x76
 {.code = ERROR_NOT_AVAILABLE, .[  877.933604] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
description = }
[  877.944334] AICWFDBG(LOGDEBUG)       rwnx_fill_station_info ModTx(0):4 TxIndex:6 ModRx(0):0 RxHTIndex:0 RxVHTIndex:0 RxHEIndex:0 RSSI:-35
12-04 16:40:00.003  2768  2768 D KeyguardClockSwitch: Updating clock: 440
12-04 16:40:00.931  2451  2638 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 16:40:01.025  2451  7203 I ActivityTaskManager: START u0 {act=android.intent.action.MAIN cmp=com.android.settings/.SubSettings (has extras)} from uid 1000
12-04 16:40:01.016  2451  2638 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 16:40:01.029  2140  2140 I AW_PowerHAL_Platform: ==LAUNCH_MODE==
12-04 16:40:01.030  2130  4727 D audio_hw_primary: start_output_stream
12-04 16:40:01.030  2130  4727 V audio_platform: disable backend pcm(direction:PCM_OUT)
12-04 16:40:01.030  2130  4727 D audio_route: Apply path: out-reset
12-04 16:40:01.030  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.030  2130  4727 D audio_route: Apply path: media-speaker
12-04 16:40:01.030  2130  4727 D audio_hw_primary: select device(out):pdev:OUT_DULSPK, path:media-speaker
12-04 16:40:01.030  2130  4727 D audio_hw_primary: +++++++++++++++ start_output_stream: pcm sample_rate: 48000,pcm fmt: 0x00000000,pcm channels: 2
12-04 16:40:01.031  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.052  2140  2140 D AW_PowerHAL: c-s = 8
12-04 16:40:01.068  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.079  2130  4727 I chatty  : uid=1041(audioserver) writer identical 1 line
12-04 16:40:01.091  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.096  3026  3026 W ActivityThread: handleWindowVisibility: no activity for token android.os.BinderProxy@ba65f49
12-04 16:40:01.109  2146  2227 D AudioFlinger: mixer(0x77d6647f80) throttle end: throttle time(11)
12-04 16:40:01.112  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.118  3026  3026 D SettingsActivity: Starting onCreate
12-04 16:40:01.131  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.142  3026  3026 D SettingsActivity: Starting to set activity title
12-04 16:40:01.143  3026  3026 D SettingsActivity: Done setting title
12-04 16:40:01.143  3026  3026 D SettingsActivity: Switching to fragment com.android.settings.bluetooth.BluetoothPairingDetail
12-04 16:40:01.143  3026  3026 D SubSettings: Launching fragment com.android.settings.bluetooth.BluetoothPairingDetail
12-04 16:40:01.147  3026  3026 D PrefCtrlListHelper: Could not find Context-only controller for pref: com.android.settings.bluetooth.BluetoothDeviceRenamePreferenceController
12-04 16:40:01.153  3026  3026 D BluetoothPairingDetail: NO dashboard tiles for BluetoothPairingDetail
12-04 16:40:01.153  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.153  3026  3026 D BluetoothPairingDetail: All preferences added, reporting fully drawn
12-04 16:40:01.158  2451  2499 I ActivityTaskManager: Fully drawn com.android.settings/.SubSettings: +131ms
12-04 16:40:01.162  3026  3026 D SettingsActivity: Executed frag manager pendingTransactions
12-04 16:40:01.174  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.181  3026  3026 D LocalBluetoothManager: setting foreground activity to non-null context
12-04 16:40:01.182  2451  7203 D BluetoothManagerService: enable(com.android.settings):  mBluetooth =null mBinding = false mState = OFF
12-04 16:40:01.182  2451  7203 D BluetoothManagerService: enable returning
12-04 16:40:01.182  2451  2492 D BluetoothManagerService: MESSAGE_ENABLE(0): mBluetooth = null
12-04 16:40:01.194  3026  6738 W TileUtils: Found com.android.settings.Settings$DataUsageSummaryActivity for intent Intent { act=com.android.settings.action.SETTINGS pkg=com.android.settings } missing metadata com.android.settings.category
12-04 16:40:01.195  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.211  2124  2124 D Zygote  : Forked child process 8620
12-04 16:40:01.217  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.217  2451  2501 I ActivityManager: app.processName = com.android.bluetooth
12-04 16:40:01.217  2451  2501 I ActivityManager: Start proc 8620:com.android.bluetooth/1002 for service {com.android.bluetooth/com.android.bluetooth.btservice.AdapterService}
12-04 16:40:01.218  8620  8620 I Zygote  : seccomp disabled by setenforce 0
12-04 16:40:01.243  2451  3243 D PackageManager: Instant App installer not found with android.intent.action.INSTALL_INSTANT_APP_PACKAGE
12-04 16:40:01.244  2451  3243 D PackageManager: Clear ephemeral installer activity
12-04 16:40:01.250  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.267  3026  8619 D SettingsActivity: Enabled state changed for some tiles, reloading all categories {com.android.settings/com.android.settings.Settings$PowerUsageSummaryActivity},
12-04 16:40:01.273  2130  4727 V audio_platfor[  880.972191] AICWFDBG(LOGTRACE) rwnx_send_msg (118)MM_GET_STA_INFO_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
12-04 16:40:01.295  2130  4727 V audio_platform: mode(0),devices(0x2):p[  880.996240] AICWFDBG(LOGTRACE)        rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[  881.005789] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x76
12-04 16:40:01.296  3026  6738 W TileUtils: Found com.android.se[  881.017080] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
ttings.Settings$DataUsageSummaryActivity for intent Intent { act[  881.031524] AICWFDBG(LOGDEBUG)       rwnx_fill_station_info ModTx(0):4 TxIndex:6 ModRx(0):0 RxHTIndex:0 RxVHTIndex:0 RxHEIndex:0 RSSI:-34
12-04 16:40:01.305  8620  8620 I droid.bluetoot: The ClassLoaderContext is a special shared library.
12-04 16:40:01.313  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.369  2451  7111 D PackageManager: Instant App installer not found with android.intent.action.INSTALL_INSTANT_APP_PACKAGE
12-04 16:40:01.369  2451  7111 D PackageManager: Clear ephemeral installer activity
12-04 16:40:01.376  2130  4727 I chatty  : uid=1041(audioserver) writer identical 3 lines
12-04 16:40:01.397  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.399  8620  8620 D BluetoothOppFileProvider: Initialized
12-04 16:40:01.418  3026  8619 D SettingsActivity: Enabled state changed for some tiles, reloading all categories {com.android.settings/com.android.settings.Settings$PowerUsageSummaryActivity},
12-04 16:40:01.422  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.430  3026  6738 W TileUtils: Found com.android.settings.Settings$DataUsageSummaryActivity for intent Intent { act=com.android.settings.action.SETTINGS pkg=com.android.settings } missing metadata com.android.settings.category
12-04 16:40:01.432  2140  2140 I AW_PowerHAL_Platform: ==NORMAL MODE==
12-04 16:40:01.436  2140  2140 D AW_PowerHAL: c-s = 18
12-04 16:40:01.442  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.462  2130  4727 V audio_platform: mode(0)[  881.186922] bluetooth_set_power: start_block=1
,devices(0x2):platform device:OU[  881.193501] aicbsp: aicbsp_set_subsys, subsys: AIC_BLUETOOTH, state to: 0
T_DULSPK(0x4)
12-04 16:40:01.46[  881.203569] aicbsp: aicbsp_set_subsys, power state no need to change, current: 1
5  2451  2661 E WifiVendorHal: g[  881.214784] bluetooth_set_power: end_block=1
etWifiLinkLayerStats_1_3_Interna[  881.222610] bluetooth_set_power: start_block=0
l(l.926) failed {.code = ERROR_N[  881.230064] aicbsp: aicbsp_set_subsys, subsys: AIC_BLUETOOTH, state to: 1
OT_AVAILABLE, .description = }
[  881.240387] aicbsp: aicbsp_set_subsys, power state no need to change, current: 1
12-04 16:40:01.480  8620  8620 V[  881.251412] bluetooth_set_power: end_block=0
 AdapterServiceConfig: Adding HeadsetService
12-04 16:40:01.482[  881.262458] [BT_LPM] bluesleep_outgoing_data: tx was sleeping, wakeup it
  8620  8620 V AdapterServiceCon[  881.272082] [BT_LPM] hsuart_power: bsi->uport = NULL, has_lpm_enabled = 0
fig: Adding A2dpService
12-04 16:40:01.482  8620  8620 V AdapterServiceConfig: Adding HidHostService
12-04 16:40:01.482  8620  8620 V AdapterServiceConfig: Adding PanService
12-04 16:40:01.482  8620  8620 V AdapterServiceConfig: Adding GattService
12-04 16:40:01.482  8620  8620 V AdapterServiceConfig: Adding BluetoothMapService
12-04 16:40:01.482  8620  8620 V AdapterServiceConfig: Adding AvrcpTargetService
12-04 16:40:01.482  8620  8620 V AdapterServiceConfig: Adding HidDeviceService
12-04 16:40:01.482  8620  8620 V AdapterServiceConfig: Adding BluetoothOppService
12-04 16:40:01.482  8620  8620 V AdapterServiceConfig: Adding BluetoothPbapService
12-04 16:40:01.483  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.485  3026  3041 I ndroid.setting: Background concurrent copying GC freed 67525(3451KB) AllocSpace objects, 28(616KB) LOS objects, 49% free, 4827KB/9654KB, paused 102us total 243.028ms
12-04 16:40:01.507  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.520  8620  8620 I         : [1204/164001.520505:INFO:com_android_bluetooth_btservice_AdapterService.cpp(628)] hal_util_load_bt_library loaded HAL: btinterface=0x79b8b64440, handle=0x2ad82ce9145ff26d
12-04 16:40:01.521  8620  8620 D BluetoothAdapterService: onCreate()
12-04 16:40:01.526  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.528  8620  8620 D AdapterState: make() - Creating AdapterState
12-04 16:40:01.528  2230  2230 D omx_venc: <__AwOmxVencFillThisBuffer:2082>: vencOutPort: fill_this_buffer 50 times
12-04 16:40:01.531  8620  8660 I AdapterState: OFF : entered
12-04 16:40:01.531  8620  8660 D AdapterProperties: Setting state to OFF
12-04 16:40:01.532  8620  8620 I bt_btif : init: start restricted = 0 ; single user = 0
12-04 16:40:01.532  8620  8620 D bt_osi_allocation_tracker: canary initialized
12-04 16:40:01.533  8620  8661 I         : [1204/164001.533189:INFO:message_loop_thread.cc(175)] Run: message loop starting for thread bt_stack_manager_thread
12-04 16:40:01.533  8620  8661 I bt_stack_manager: event_init_stack is initializing the stack
12-04 16:40:01.536  8620  8661 I         : [1204/164001.536857:INFO:btif_config.cc(647)] hash_file: Disabled for multi-user
12-04 16:40:01.536  8620  8661 I         : [1204/164001.536961:INFO:btif_config.cc(675)] read_checksum_file: Disabled for multi-user
12-04 16:40:01.537  8620  8661 E bt_btif_config: Config is missing adapter section
12-04 16:40:01.537  8620  8661 W bt_btif_config: init unable to load config file: /data/misc/bluedroid/bt_config.conf; using backup.
12-04 16:40:01.537  8620  8661 I         : [1204/164001.537382:INFO:btif_config.cc(647)] hash_file: Disabled for multi-user
12-04 16:40:01.537  8620  8661 I         : [1204/164001.537440:INFO:btif_config.cc(675)] read_checksum_file: Disabled for multi-user
12-04 16:40:01.537  8620  8661 W bt_btif_config: init unable to load backup; attempting to transcode legacy file.
12-04 16:40:01.538  8620  8661 E bt_btif_config_transcode: btif_config_transcode unable to load XML file '/data/misc/bluedroid/bt_config.xml': 3
12-04 16:40:01.538  8620  8661 E bt_btif_config: init unable to transcode legacy file; creating empty config.
12-04 16:40:01.538  8620  8661 W         : [1204/164001.538167:WARNING:btif_config.cc(151)] read_or_set_metrics_salt: Failed to read metrics salt from config
12-04 16:40:01.538  8620  8661 I         : [1204/164001.538239:INFO:btif_config.cc(162)] read_or_set_metrics_salt: Metrics salt is not invalid, creating new one
12-04 16:40:01.539  8620  8661 E bt_osi_alarm: timer_create_internal unable to create timer with clock 9: Unknown error 524
12-04 16:40:01.539  8620  8661 E bt_osi_alarm: The kernel might not have support for timer_create(CLOCK_BOOTTIME_ALARM): https://lwn.net/Articles/429925/
12-04 16:40:01.539  8620  8661 E bt_osi_alarm: See following patches: https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/log/?qt=grep&q=CLOCK_BOOTTIME_ALARM
12-04 16:40:01.540  8620  8665 I bt_osi_thread: run_thread: thread id 8665, thread name alarm_default_ca started
12-04 16:40:01.541  8620  8666 I bt_osi_thread: run_thread: thread id 8666, thread name alarm_dispatcher started
12-04 16:40:01.543  8620  8661 I bt_btif_core: btif_init_bluetooth entered
12-04 16:40:01.544  8620  8661 I bt_stack_config: init attempt to load stack conf from /etc/bluetooth/bt_stack.conf
12-04 16:40:01.545  8620  8667 I         : [1204/164001.545291:INFO:message_loop_thread.cc(175)] Run: message loop starting for thread bt_jni_thread
12-04 16:40:01.545  8620  8661 I bt_btif_core: btif_init_bluetooth finished
12-04 16:40:01.545  8620  8661 I bt_stack_manager: event_init_stack finished
12-04 16:40:01.545  8620  8620 I bt_osi_wakelock: wakelock_set_os_callouts set to non-native
12-04 16:40:01.545  8620  8620 I bt_btif : get_profile_interface: id = socket
12-04 16:40:01.546  8620  8667 E bt_btif_storage: btif_storage_get_adapter_property: Controller not ready! Unable to return Bluetooth Address
12-04 16:40:01.546  8620  8667 E BluetoothServiceJni: adapter_properties_callback: Status 1 is incorrect
12-04 16:40:01.547  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.548  8620  8620 I bt_btif : get_profile_interface: id = sdp
12-04 16:40:01.548  8620  8667 D AdapterProperties: Name is: QUAD-CORE A133 c3
12-04 16:40:01.548  8620  8667 D AdapterProperties: BT Class:1a011c
12-04 16:40:01.549  2451  2451 D BluetoothManagerService: Bluetooth Adapter name changed to QUAD-CORE A133 c3
12-04 16:40:01.549  2451  2451 D BluetoothManagerService: Stored Bluetooth name: QUAD-CORE A133 c3
12-04 16:40:01.551  8620  8620 I BluetoothAdapterService: Phone policy enabled
12-04 16:40:01.553  2768  2768 W StatusBarIconController: setIconVisibility index: 27
12-04 16:40:01.556  8620  8620 D BluetoothActiveDeviceManager: start()
12-04 16:40:01.568  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.569  8620  8670 D BluetoothActiveDeviceManager: onAudioDevicesAdded
12-04 16:40:01.571  8620  8670 D BluetoothActiveDeviceManager: Audio device added: QUAD-CORE A133 c3 type: 2
12-04 16:40:01.571  8620  8670 D BluetoothActiveDeviceManager: Audio device added: QUAD-CORE A133 c3 type: 15
12-04 16:40:01.580  3026  3026 D LocalBluetoothManager: setting foreground activity to null
12-04 16:40:01.583  8620  8620 D BluetoothDatabase: start()
12-04 16:40:01.585  8620  8620 D BluetoothDatabase: Load Database
12-04 16:40:01.589  8620  8620 D BluetoothAdapterService: setAdapterService() - trying to set service to com.android.bluetooth.btservice.AdapterService@3d23669
12-04 16:40:01.589  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.598  8620  8620 D BluetoothAdapterService: onBind()
12-04 16:40:01.599  2451  2451 D BluetoothManagerService: BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
12-04 16:40:01.599  2451  2492 D BluetoothManagerService: MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
12-04 16:40:01.601  2451  2492 D BluetoothManagerService: Broadcasting onBluetoothServiceUp() to 5 receivers.
12-04 16:40:01.601  2451  2492 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@b27333
12-04 16:40:01.602  3026  3045 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@bf2291e
12-04 16:40:01.602  2768  2786 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@407851d
12-04 16:40:01.602  2894  3435 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@c170371
12-04 16:40:01.603  8620  8640 D BluetoothAdapter: onBluetoothServiceUp: com.android.bluetooth.btservice.AdapterService$AdapterServiceBinder@f0d0c95
12-04 16:40:01.605  8620  8643 D BluetoothAdapterService: enable() - Enable called with quiet mode status =  false
12-04 16:40:01.606  8620  8660 I AdapterState: BLE_TURNING_ON : entered
12-04 16:40:01.606  8620  8660 D AdapterProperties: Setting state to BLE_TURNING_ON
12-04 16:40:01.606  8620  8660 D BluetoothAdapterService: updateAdapterState() - Broadcasting state BLE_TURNING_ON to 1 receivers.
12-04 16:40:01.607  2451  2492 D BluetoothManagerService: MESSAGE_GET_NAME_AND_ADDRESS
12-04 16:40:01.612  2230  2940 D omx_venc: <__AwOmxVencEmptyThisBuffer:2043>: vencInPort: , empty_this_buffer 50 times
12-04 16:40:01.613  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.614  2451  2492 D BluetoothManagerService: Stored Bluetooth name: QUAD-CORE A133 c3
12-04 16:40:01.615  2451  2492 D BluetoothManagerService: MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
12-04 16:40:01.615  2451  2492 D BluetoothManagerService: Sending BLE State Change: OFF > BLE_TURNING_ON
12-04 16:40:01.626  8620  8660 D BluetoothAdapterService: bleOnProcessStart()
12-04 16:40:01.627  8620  8660 I AdapterProperties: init(), maxConnectedAudioDevices, default=5, propertyOverlayed=5, finalValue=5
12-04 16:40:01.628  8620  8672 I BluetoothDatabase: cacheMetadata
12-04 16:40:01.630  8620  8660 D BluetoothAdapterService: bleOnProcessStart() - Make Bond State Machine
12-04 16:40:01.630  8620  8660 D BluetoothBondStateMachine: make
12-04 16:40:01.632  8620  8681 I BluetoothBondStateMachine: StableState(): Entering Off State
12-04 16:40:01.632  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.638  8620  8620 I BtGatt.JNI: classInitNative(L876): classInitNative: Success!
12-04 16:40:01.642  8620  8620 D BtGatt.DebugUtils: handleDebugAction() action=null
12-04 16:40:01.644  8620  8620 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@3d23669
12-04 16:40:01.647  8620  8620 I bt_btif : get_profile_interface: id = gatt
12-04 16:40:01.647  8620  8620 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@3d23669
12-04 16:40:01.654  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.669  8620  8620 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@3d23669
12-04 16:40:01.675  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.675  8620  8661 I bt_stack_manager: event_start_up_stack is bringing up the stack
12-04 16:40:01.675  8620  8661 I bt_core_module: module_start_up Starting module "btif_config_module"
12-04 16:40:01.676  8620  8661 I bt_core_module: module_start_up Started module "btif_config_module"
12-04 16:40:01.676  8620  8661 I bt_core_module: module_start_up Starting module "btsnoop_module"
12-04 16:40:01.677  8620  8661 I         : [1204/164001.676979:INFO:btsnoop.cc(207)] start_up: Snoop Logs disabled
12-04 16:40:01.677  8620  8661 I         : [1204/164001.677131:INFO:btsnoop.cc(338)] delete_btsnoop_files: Deleting snoop logs if they exist. filtered = 1
12-04 16:40:01.677  8620  8661 I         : [1204/164001.677400:INFO:btsnoop.cc(338)] delete_btsnoop_files: Deleting snoop logs if they exist. filtered = 0
12-04 16:40:01.677  8620  8661 I bt_core_module: module_start_up Started module "btsnoop_module"
12-04 16:40:01.677  8620  8661 I bt_core_module: module_start_up Starting module "hci_module"
12-04 16:40:01.677  8620  8661 I bt_hci  : hci_module_start_up
12-04 16:40:01.678  8620  8688 I         : [1204/164001.678402:INFO:message_loop_thread.cc(175)] Run: message loop starting for thread bt_hci_thread
12-04 16:40:01.678  8620  8661 D bt_hci  : hci_module_start_up starting async portion
12-04 16:40:01.678  8620  8688 I bt_hci  : hci_initialize
12-04 16:40:01.681  8620  8688 I bt_hci  : hci_initialize: IBluetoothHci::getService() returned 0x7a0b7d8220 (remote)
12-04 16:40:01.681  5034  5040 I android.hardware.bluetooth@1.0-impl: BluetoothHci::initialize()
12-04 16:40:01.682  5034  5040 D         : get_local_address: Trying /sys/class/addr_mgt/addr_bt
12-04 16:40:01.682  5034  5040 D         : get_local_address: Got Factory BDA 52:24:EB:E7:63:5D
12-04 16:40:01.682  5034  5040 I bt_vendor: init
12-04 16:40:01.682  5034  5040 W bt_vendor: *****************************************************************
12-04 16:40:01.682  5034  5040 W bt_vendor: ** Warning - BT Vendor Lib is loaded in debug tuning mode!
12-04 16:40:01.682  5034  5040 W bt_vendor: ** If this is not intentional, rebuild libbt-vendor.so
12-04 16:40:01.682  5034  5040 W bt_vendor: ** with VENDOR_LIB_RUNTIME_TUNING_ENABLED=FALSE and
12-04 16:40:01.682  5034  5040 W bt_vendor: ** check if any run-time tuning parameters needed to be
12-04 16:40:01.682  5034  5040 W bt_vendor: ** carried to the build-time configuration accordingly.
12-04 16:40:01.683  5034  5040 I bt_vnd_conf: Attempt to load conf from /etc/bluetooth/bt_vendor.conf
12-04 16:40:01.683  5034  5040 I bt_vnd_conf: vnd_load_conf file >/etc/bluetooth/bt_vendor.conf< not found
12-04 16:40:01.683  5034  5040 D android.hardware.bluetooth@1.0-impl: Open vendor library loaded
12-04 16:40:01.683  5034  5040 D bt_vendor: op for 0
12-04 16:40:01.683  5034  5040 D bt_upio : init_rfkill: rfkill path /sys/devices/platform/aic-bt/rfkill/rfkill1
12-04 16:40:01.700  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.718  5034  5040 W bt_vendor: NOTE: BT_VND_PWR_ON now forces power-off first
12-04 16:40:01.718  5034  5040 D bt_upio : init_rfkill: rfkill path /sys/devices/platform/aic-bt/rfkill/rfkill1
12-04 16:40:01.726  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.742  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.756  5034  5040 D bt_vendor: op for 3
12-04 16:40:01.757  5034  5040 I bt_userial_vendor: userial vendor open: opening /dev/ttyS1
12-04 16:40:01.757  5034  5040 I bt_userial_vendor: device fd = 6 open
12-04 16:40:01.757  5034  5040 D bt_vendor: op for 1
12-04 16:40:01.757  5034  5040 E bt_hwcfg: hw_config_start
12-04 16:40:01.758  5034  5040 D bt_vendor: op for 7
12-04 16:40:01.758  5034  5040 E bt_hwcfg: set_wake_stat 1
12-04 16:40:01.758  5034  5040 D bt_upio : upio_set : pio 0 action 2, polarity 1
12-04 16:40:01.766  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.779  5034  5040 D bt_upio : upio_set: proc btwrite assertion, buffer: 1, timer_armed 1 0
12-04 16:40:01.790  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:02.272  2130  4727 I chatty  : uid=1041(audioserver) writer identical 23 lines
12-04 16:40:02.294  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:02.302  2451  2499 E system_server: No package ID 7f found for ID 0x7f08024a.
12-04 16:40:02.302  2451  2499 E system_server: No package ID 7f found for ID 0x7f1211a1.
12-04 16:40:02.302  2451  2499 E system_server: No package ID 7f found for ID 0x7f080249.
12-04 16:40:02.303  2451  2499 E system_server: No package ID 7f found for ID 0x7f1204e0.
12-04 16:40:02.303  2451  2499 E system_server: No package ID 7f found for ID 0x7f080248.
12-04 16:40:02.303  2451  2499 E system_server: No package ID 7f found for ID 0x7f120afa.
12-04 16:40:02.309  2894  2894 E PhoneInterfaceManager: [PhoneIntfMgr] getCarrierPackageNamesForIntent: No UICC
12-04 16:40:02.309  2894  2894 D CarrierSvcBindHelper: No carrier app for: 0
12-04 16:40:02.310  2451  2451 D DeviceIdleController: find package null
12-04 16:40:02.314  2451  2639 I InputReader: Reconfiguring input devices.  changes=0x00000010
12-04 16:40:02.316  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:02.320  2451  2451 I Telecom : DefaultDialerCache: Refreshing default dialer for user 0: now null: DDC.oR@ABE
12-04 16:40:02.325  3026  6738 W TileUtils: Found com.android.settings.Settings$DataUsageSummaryActivity for intent Intent { act=com.android.settings.action.SETTINGS pkg=com.android.settings } missing metadata com.android.settings.category
12-04 16:40:02.326  2451  2499 W VoiceInteractionManagerService: no available voice interaction services found for user 0
12-04 16:40:02.336  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:03.106  2130  4727 I chatty  : uid=1041(audioserver) writer identical 36 lines
12-04 16:40:03.126  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:03.146  2230  2276 D omx_venc: <__AwOmxVencFillThisBuffer:2082>: vencOutPort: fill_this_buffer 50 times
12-04 16:40:03.147  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:03.168  2130  4727 I chatty  : uid=1041(audioserver) writer identical 1 line
12-04 16:40:03.190  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:03.210  2230  2276 D omx_venc: <__AwOmxVencEmptyThisBuffer:2043>: vencInPort: , empty_this_buffer 50 times
12-04 16:40:03.211  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.149  2130  4727 I chatty  : uid=1041(audioserver) writer identical 44 lines
12-04 16:40:04.171  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.177  2451  2638 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 16:40:04.188  2768  2768 W KeyButtonRipple: mSupportHardware: true mDark: true mLastDark: false pressed: true
12-04 16:40:04.189  2768  2768 W KeyButtonRipple: mDelayTouchFeedback: false
12-04 16:40:04.189  2768  2768 W KeyButtonRipple: enterHardware cancelAnimations
12-04 16:40:04.189  2768  2768 W KeyButtonRipple: enterHardware isHorizontal is true!
12-04 16:40:04.191  2768  2768 W KeyButtonRipple: enterHardware mDelayTouchFeedback: false mPressed: false
12-04 16:40:04.191  2768  2768 W KeyButtonView: mCode: 4
12-04 16:40:04.192  2768  2768 I KeyButtonView: Back button event: ACTION_DOWN
12-04 16:40:04.192  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.195  2451  2638 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 16:40:04.205  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.225  2130  4727 I chatty  : uid=1041(audioserver) writer identical 1 line
12-04 16:40:04.247  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.261  2451  2638 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 16:40:04.262  2768  2768 W KeyButtonRipple: mSupportHardware: true mDark: true mLastDark: true pressed: false
12-04 16:40:04.264  2768  2768 I KeyButtonView: Back button event: ACTION_UP
12-04 16:40:04.267  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.268  2451  2638 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 16:40:04.268  2451  2491 D AutofillManagerService: onBackKeyPressed()
12-04 16:40:04.268  2451  2491 D AutofillManagerServiceImpl: Reset component for user 0:
12-04 16:40:04.269  2451  2491 D AutofillUI: destroySaveUiUiThread(): already destroyed
12-04 16:40:04.291  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.304  3026  3026 E ActivityThread: Failed to find provider info for com.google.android.gms.nearby.fastpair
12-04 16:40:04.306  3026  6738 E ActivityThread: Failed to find provider info for com.google.android.gms.nearby.fastpair
12-04 16:40:04.306  3026  3026 D LocalBluetoothManager: setting foreground activity to non-null context
12-04 16:40:04.306  3026  6738 W SliceManager: Unknown URI: content://com.google.android.gms.nearby.fastpair/device_status_list_item
12-04 16:40:04.308  3026  3026 D LocalBluetoothManager: setting foreground activity to non-null context
12-04 16:40:04.311  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.317  3026  3026 D LocalBluetoothManager: setting foreground activity to non-null context
12-04 16:40:04.331  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.337  3026  6738 W TileUtils: Found com.android.settings.Settings$DataUsageSummaryActivity for intent Intent { act=com.android.settings.action.SETTINGS pkg=com.android.settings } missing metadata com.android.settings.category
12-04 16:40:04.352  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.366  3026  8619 D SettingsActivity: No enabled state changed, skipping updateCategory call
12-04 16:40:04.374  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
[  884.064240] AICWFDBG(LOGTRACE)       rwnx_send_msg (118)MM_GET_STA_INFO_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[  884.075822] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
12-04 16:40:04.512  2130  4727 I[  884.084809] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x76
 chatty  : uid=1041(audioserver)[  884.095772] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
 writer identical 6 lines
12-04[  884.104606] AICWFDBG(LOGDEBUG)  rwnx_fill_station_info ModTx(0):4 TxIndex:6 ModRx(0):0 RxHTIndex:0 RxVHTIndex:0 RxHEIndex:0 RSSI:-35
 16:40:04.533  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.557  2451  2661 E WifiVendorHal: getWifiLinkLayerStats_1_3_Internal(l.926) failed {.code = ERROR_NOT_AVAILABLE, .description = }
12-04 16:40:04.558  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.603  2130  4727 I chatty  : uid=1041(audioserver) writer identical 2 lines
12-04 16:40:04.619  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.622  2768  2768 W StatusBarIconController: setIconVisibility index: 27
12-04 16:40:04.637  3026  3026 D LocalBluetoothManager: setting foreground activity to null
12-04 16:40:04.640  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.651  2451  3438 E TaskPersister: File error accessing recents directory (directory doesn't exist?).
12-04 16:40:04.790  2130  4727 I chatty  : uid=1041(audioserver) writer identical 7 lines
12-04 16:40:04.811  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.812  2451  2638 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 16:40:04.813  2768  2768 W KeyButtonRipple: mSupportHardware: true mDark: true mLastDark: true pressed: true
12-04 16:40:04.813  2768  2768 W KeyButtonRipple: mDelayTouchFeedback: false
12-04 16:40:04.813  2768  2768 W KeyButtonRipple: enterHardware cancelAnimations
12-04 16:40:04.813  2768  2768 W KeyButtonRipple: enterHardware isHorizontal is true!
12-04 16:40:04.815  2768  2768 W KeyButtonRipple: enterHardware mDelayTouchFeedback: false mPressed: false
12-04 16:40:04.815  2768  2768 W KeyButtonView: mCode: 4
12-04 16:40:04.816  2768  2768 I KeyButtonView: Back button event: ACTION_DOWN
12-04 16:40:04.821  2451  2638 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 16:40:04.830  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.865  2130  4727 I chatty  : uid=1041(audioserver) writer identical 2 lines
12-04 16:40:04.886  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.896  2451  2638 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 16:40:04.897  2768  2768 W KeyButtonRipple: mSupportHardware: true mDark: true mLastDark: true pressed: false
12-04 16:40:04.898  2768  2768 I KeyButtonView: Back button event: ACTION_UP
12-04 16:40:04.899  2230  2276 D omx_venc: <__AwOmxVencFillThisBuffer:2082>: vencOutPort: fill_this_buffer 50 times
12-04 16:40:04.899  2451  2491 D AutofillManagerService: onBackKeyPressed()
12-04 16:40:04.900  2451  2638 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 16:40:04.907  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.929  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.936  2451  7203 E TAG     : Exception = android.content.pm.PackageManager$NameNotFoundException: com.google.android.simappdialog.gts
12-04 16:40:04.936  2451  3243 E TAG     : Exception = android.content.pm.PackageManager$NameNotFoundException: com.google.android.simappdialog.gts
12-04 16:40:04.936  2451  3243 E TAG     : Exception = android.content.pm.PackageManager$NameNotFoundException: android.net.cts
12-04 16:40:04.936  2451  7203 E TAG     : Exception = android.content.pm.PackageManager$NameNotFoundException: android.net.cts
12-04 16:40:04.945  2451  2507 E BatteryExternalStatsWorker: no controller energy info supplied for bluetooth
12-04 16:40:04.946  3026  3026 D AvatarViewMixin: Feature disabled by config. Skipping
12-04 16:40:04.950  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.961  2230  2940 D omx_venc: <__AwOmxVencEmptyThisBuffer:2043>: vencInPort: , empty_this_buffer 50 times
12-04 16:40:04.964  2451  2507 E KernelCpuSpeedReader: Failed to read cpu-freq: /sys/devices/system/cpu/cpu0/cpufreq/stats/time_in_state: open failed: ENOENT (No such file or directory)
12-04 16:40:04.965  2451  7111 E TAG     : Exception = android.content.pm.PackageManager$NameNotFoundException: com.google.android.simappdialog.gts
12-04 16:40:04.965  2451  7111 E TAG     : Exception = android.content.pm.PackageManager$NameNotFoundException: android.net.cts
12-04 16:40:04.967  2451  2507 W BatteryExternalStatsWorker: modem info is invalid: ModemActivityInfo{ mTimestamp=0 mSleepTimeMs=0 mIdleTimeMs=0 mTxTimeMs[]=[0, 0, 0, 0, 0] mRxTimeMs=0 mEnergyUsed=0}
12-04 16:40:04.967  2451  2507 D KernelCpuUidUserSysTimeReader: Removing uids 1037-1037
12-04 16:40:04.971  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.996  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.998  3026  8619 D BatteryInfo: time for getStats: 63ms
12-04 16:40:04.999  3026  4758 D BatteryTipLoader: BatteryInfoLoader post query: 1ms
12-04 16:40:04.999  3026  4758 D BatteryInfo: time for getBatteryInfo: 0ms
12-04 16:40:04.999  3026  4758 D BatteryTipLoader: BatteryInfoLoader.loadInBackground: 1ms
12-04 16:40:05.001  3026  8619 D BatteryInfo: time for regular BatteryInfo: 3ms
12-04 16:40:05.001  3026  8619 D BatteryInfo: time for getBatteryInfo: 0ms
12-04 16:40:05.014  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:05.046  2130  4727 I chatty  : uid=1041(audioserver) writer identical 1 line
12-04 16:40:05.067  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:05.089  2451  6775 E TAG     : Exception = android.content.pm.PackageManager$NameNotFoundException: com.google.android.simappdialog.gts
12-04 16:40:05.089  2451  6775 E TAG     : Exception = android.content.pm.PackageManager$NameNotFoundException: android.net.cts
12-04 16:40:05.091  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.969  2451  2507 D KernelCpuUidUserSysTimeReader: Removing uids 1037-1037
12-04 16:40:05.101  2451  2507 E BatteryExternalStatsWorker: no controller energy info supplied for bluetooth
12-04 16:40:05.112  2451  2507 E KernelCpuSpeedReader: Failed to read cpu-freq: /sys/devices/system/cpu/cpu0/cpufreq/stats/time_in_state: open failed: ENOENT (No such file or directory)
12-04 16:40:05.110  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:05.117  3026  3026 D BatteryInfo: time for callback: 0ms
12-04 16:40:05.119  2451  2507 W BatteryExternalStatsWorker: modem info is invalid: ModemActivityInfo{ mTimestamp=0 mSleepTimeMs=0 mIdleTimeMs=0 mTxTimeMs[]=[0, 0, 0, 0, 0] mRxTimeMs=0 mEnergyUsed=0}
12-04 16:40:05.132  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:05.153  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:05.156  3026  4758 D BatteryTipLoader: BatteryInfoLoader post query: 1ms
12-04 16:40:05.157  3026  4758 D BatteryInfo: time for getBatteryInfo: 1ms
12-04 16:40:05.157  3026  4758 D BatteryTipLoader: BatteryInfoLoader.loadInBackground: 3ms
12-04 16:40:05.174  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:05.211  2451  3438 E TaskPersister: File error accessing recents directory (directory doesn't exist?).
12-04 16:40:05.600  2130  4727 I chatty  : uid=1041(audioserver) writer identical 20 lines
12-04 16:40:05.621  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:05.630  8620  8660 E AdapterState: BLE_TURNING_ON : BLE_START_TIMEOUT
12-04 16:40:05.630  8620  8660 I AdapterState: BLE_TURNING_OFF : entered
12-04 16:40:05.630  8620  8660 D AdapterProperties: Setting state to BLE_TURNING_OFF
12-04 16:40:05.630  8620  8660 D BluetoothAdapterService: updateAdapterState() - Broadcasting state BLE_TURNING_OFF to 1 receivers.
12-04 16:40:05.631  2451  2492 D BluetoothManagerService: MESSAGE_BLUETOOTH_STATE_CHANGE: BLE_TURNING_ON > BLE_TURNING_OFF
12-04 16:40:05.631  2451  2492 D BluetoothManagerService: Sending BLE State Change: BLE_TURNING_ON > BLE_TURNING_OFF
12-04 16:40:05.631  8620  8660 D AdapterProperties: onBleDisable
12-04 16:40:05.633  8620  8620 D BtGatt.DebugUtils: handleDebugAction() action=null
12-04 16:40:05.638  8620  8620 W         : [1204/164005.637971:WARNING:bta_gattc_api.cc(61)] GATTC Module not enabled/already disabled
12-04 16:40:05.638  8620  8620 W         : [1204/164005.638173:WARNING:bta_gatts_api.cc(56)] GATTS Module not enabled/already disabled
12-04 16:40:05.639  8620  8620 W BtGatt.ScanManager: exception when invoking removeOnUidImportanceListener
12-04 16:40:05.639  8620  8620 W BtGatt.ScanManager: java.lang.IllegalArgumentException: Listener not registered: com.android.bluetooth.gatt.ScanManager$2@7371d49
12-04 16:40:05.639  8620  8620 W BtGatt.ScanManager:    at android.app.ActivityManager.removeOnUidImportanceListener(ActivityManager.java:3382)
12-04 16:40:05.639  8620  8620 W BtGatt.ScanManager:    at com.android.bluetooth.gatt.ScanManager.cleanup(ScanManager.java:157)
12-04 16:40:05.639  8620  8620 W BtGatt.ScanManager:    at com.android.bluetooth.gatt.GattService.cleanup(GattService.java:254)
12-04 16:40:05.639  8620  8620 W BtGatt.ScanManager:    at com.android.bluetooth.btservice.ProfileService.onDestroy(ProfileService.java:211)
12-04 16:40:05.639  8620  8620 W BtGatt.ScanManager:    at android.app.ActivityThread.handleStopService(ActivityThread.java:4140)
12-04 16:40:05.639  8620  8620 W BtGatt.ScanManager:    at android.app.ActivityThread.access$1900(ActivityThread.java:219)
12-04 16:40:05.639  8620  8620 W BtGatt.ScanManager:    at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1905)
12-04 16:40:05.639  8620  8620 W BtGatt.ScanManager:    at android.os.Handler.dispatchMessage(Handler.java:107)
12-04 16:40:05.639  8620  8620 W BtGatt.ScanManager:    at android.os.Looper.loop(Looper.java:214)
12-04 16:40:05.639  8620  8620 W BtGatt.ScanManager:    at android.app.ActivityThread.main(ActivityThread.java:7386)
12-04 16:40:05.639  8620  8620 W BtGatt.ScanManager:    at java.lang.reflect.Method.invoke(Native Method)
12-04 16:40:05.639  8620  8620 W BtGatt.ScanManager:    at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:492)
12-04 16:40:05.639  8620  8620 W BtGatt.ScanManager:    at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1072)
12-04 16:40:05.640  8620  8620 W BtGatt.ScanManager: exception when invoking unregisterReceiver(mLocationReceiver)
12-04 16:40:05.640  8620  8620 W BtGatt.ScanManager: java.lang.IllegalArgumentException: Receiver not registered: com.android.bluetooth.gatt.ScanManager$3@cd9e64e
12-04 16:40:05.640  8620  8620 W BtGatt.ScanManager:    at android.app.LoadedApk.forgetReceiverDispatcher(LoadedApk.java:1429)
12-04 16:40:05.640  8620  8620 W BtGatt.ScanManager:    at android.app.ContextImpl.unregisterReceiver(ContextImpl.java:1543)
12-04 16:40:05.640  8620  8620 W BtGatt.ScanManager:    at android.content.ContextWrapper.unregisterReceiver(ContextWrapper.java:664)
12-04 16:40:05.640  8620  8620 W BtGatt.ScanManager:    at com.android.bluetooth.gatt.ScanManager.cleanup(ScanManager.java:178)
12-04 16:40:05.640  8620  8620 W BtGatt.ScanManager:    at com.android.bluetooth.gatt.GattService.cleanup(GattService.java:254)
12-04 16:40:05.640  8620  8620 W BtGatt.ScanManager:    at com.android.bluetooth.btservice.ProfileService.onDestroy(ProfileService.java:211)
12-04 16:40:05.640  8620  8620 W BtGatt.ScanManager:    at android.app.ActivityThread.handleStopService(ActivityThread.java:4140)
12-04 16:40:05.640  8620  8620 W BtGatt.ScanManager:    at android.app.ActivityThread.access$1900(ActivityThread.java:219)
12-04 16:40:05.640  8620  8620 W BtGatt.ScanManager:    at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1905)
12-04 16:40:05.640  8620  8620 W BtGatt.ScanManager:    at android.os.Handler.dispatchMessage(Handler.java:107)
12-04 16:40:05.640  8620  8620 W BtGatt.ScanManager:    at android.os.Looper.loop(Looper.java:214)
12-04 16:40:05.640  8620  8620 W BtGatt.ScanManager:    at android.app.ActivityThread.main(ActivityThread.java:7386)
12-04 16:40:05.640  8620  8620 W BtGatt.ScanManager:    at java.lang.reflect.Method.invoke(Native Method)
12-04 16:40:05.640  8620  8620 W BtGatt.ScanManager:    at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:492)
12-04 16:40:05.640  8620  8620 W BtGatt.ScanManager:    at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1072)
12-04 16:40:05.643  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:06.475  2130  4727 I chatty  : uid=1041(audioserver) writer identical 39 lines
12-04 16:40:06.496  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:06.505  2451  2638 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 16:40:06.506  2768  2768 W KeyButtonRipple: mSupportHardware: true mDark: true mLastDark: true pressed: true
12-04 16:40:06.506  2768  2768 W KeyButtonRipple: mDelayTouchFeedback: false
12-04 16:40:06.506  2768  2768 W KeyButtonRipple: enterHardware cancelAnimations
12-04 16:40:06.507  2768  2768 W KeyButtonRipple: enterHardware isHorizontal is true!
12-04 16:40:06.509  2768  2768 W KeyButtonRipple: enterHardware mDelayTouchFeedback: false mPressed: false
12-04 16:40:06.509  2768  2768 W KeyButtonView: mCode: 4
12-04 16:40:06.509  2768  2768 I KeyButtonView: Back button event: ACTION_DOWN
12-04 16:40:06.514  2451  2638 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 16:40:06.518  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:06.551  2130  4727 I chatty  : uid=1041(audioserver) writer identical 2 lines
12-04 16:40:06.572  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:06.582  2451  2638 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 16:40:06.584  2768  2768 W KeyButtonRipple: mSupportHardware: true mDark: true mLastDark: true pressed: false
12-04 16:40:06.586  2768  2768 I KeyButtonView: Back button event: ACTION_UP
12-04 16:40:06.588  2451  2491 D AutofillManagerService: onBackKeyPressed()
12-04 16:40:06.588  2451  2638 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 16:40:06.593  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:06.614  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:06.633  8620  8660 E AdapterState: BLE_TURNING_OFF : BLE_STOP_TIMEOUT
12-04 16:40:06.633  8620  8660 I AdapterState: OFF : entered
12-04 16:40:06.633  8620  8660 D AdapterProperties: Setting state to OFF
12-04 16:40:06.634  8620  8660 D BluetoothAdapterService: updateAdapterState() - Broadcasting state OFF to 1 receivers.
12-04 16:40:06.634  2451  2492 D BluetoothManagerService: MESSAGE_BLUETOOTH_STATE_CHANGE: BLE_TURNING_OFF > OFF
12-04 16:40:06.634  2451  2492 D BluetoothManagerService: Bluetooth is complete send Service Down
12-04 16:40:06.634  2451  2492 D BluetoothManagerService: Broadcasting onBluetoothServiceDown() to 5 receivers.
12-04 16:40:06.635  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:06.635  2451  2492 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@b27333
12-04 16:40:06.635  3026  3045 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@bf2291e
12-04 16:40:06.636  2768  2786 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@407851d
12-04 16:40:06.636  2451  2492 D BluetoothManagerService: unbindAndFinish(): android.bluetooth.IBluetooth$Stub$Proxy@b27333 mBinding = false mUnbinding = false
12-04 16:40:06.636  8620  8676 D BluetoothAdapter: onBluetoothServiceDown: com.android.bluetooth.btservice.AdapterService$AdapterServiceBinder@f0d0c95
12-04 16:40:06.636  2894  3435 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@c170371
12-04 16:40:06.657  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:06.662  8620  8620 D BluetoothAdapterService: onUnbind() - calling cleanup
12-04 16:40:06.662  8620  8620 D BluetoothAdapterService: cleanup()
12-04 16:40:06.672  2451  2492 D BluetoothManagerService: Sending BLE State Change: BLE_TURNING_OFF > OFF
12-04 16:40:06.678  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:06.681  2451  2492 D BluetoothManagerService: Entering STATE_OFF but mEnabled is true; restarting.
12-04 16:40:06.681  8620  8620 W BluetoothSdpJni: Cleaning up Bluetooth SDP Interface...
12-04 16:40:06.681  2451  2492 E BluetoothManagerService: waitForState [10] time out
12-04 16:40:06.681  8620  8620 W BluetoothSdpJni: Cleaning up Bluetooth SDP object
12-04 16:40:06.681  8620  8620 D BluetoothAdapterService: cleanup() - Cleaning up adapter native
12-04 16:40:06.699  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:06.720  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:06.729  3194  3194 I Launcher: Launcher:onResume start
12-04 16:40:06.731  3194  3194 I Launcher: Launcher:onResume end
12-04 16:40:06.733  2230  2230 D omx_venc: <__AwOmxVencFillThisBuffer:2082>: vencOutPort: fill_this_buffer 50 times
12-04 16:40:06.753  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:06.774  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:06.797  2230  2940 D omx_venc: <__AwOmxVencEmptyThisBuffer:2043>: vencInPort: , empty_this_buffer 50 times
12-04 16:40:06.798  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:06.816  2130  4727 I chatty  : uid=1041(audioserver) writer identical 1 line
12-04 16:40:06.839  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:06.860  2149  2525 D PermissionCache: checking android.permission.READ_FRAME_BUFFER for uid=1000 => granted (274 us)
12-04 16:40:06.861  2135  2340 E IMGSRV  : :0: OSMMapPMR: SVM mmap not supported on architecture.
12-04 16:40:06.863  2135  2340 I chatty  : uid=1000(system) HwBinder:2135_1 identical 36 lines
12-04 16:40:06.863  2135  2340 E IMGSRV  : :0: OSMMapPMR: SVM mmap not supported on architecture.
12-04 16:40:06.866  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_
楼主 #1 2024-12-04 17:37:36
memory
已发帖子: 487
Re: A133 AW869C 蓝牙开启失败,请问是什么原因呢?
开机日志:
[40]HELLO! BOOT0 is starting!
[43]BOOT0 commit : f10e8c3
[46]set pll start
[48]periph0 has been enabled
[51]set pll end
[53][pmu]: bus read error
[56]PMU: AXP803
[75]vaild para:1  select dram para0
[79]board init ok
[80]rtc[3] value = 0xb00f
[103]DRAM BOOT DRIVE INFO: V0.67
[106]the chip id is 0x1400
[109]the chip id is 0x1400
[112]the chip id is 0x1400
[114]the chip id is 0x1400
[117]the chip id is 0x1400
[120]chip id check OK
[122]DRAM_VCC set to 1500 mv
[125]DRAM CLK =648 MHZ
[127]DRAM Type =3 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4)
[136]DRAM SIZE =2048 MBytes, para1 = 310a, para2 = 8000000, tpr13 = 6001
[148]DRAM simple test OK.
[150]dram size =2048
[153]chipid = 54401400
[155]nsi init ok 2020-4-7
[158]card no is 2
[160]sdcard 2 line count 8
[163][mmc]: mmc driver ver 2020-05-25 09:40-202007019516
[174][mmc]: Wrong media type 0x0
[177][mmc]: ***Try SD card 2***
[181][mmc]: mmc 2 cmd 8 timeout, err 100
[185][mmc]: mmc 2 cmd 8 err 100
[188][mmc]: mmc 2 send if cond failed
[192][mmc]: mmc 2 cmd 55 timeout, err 100
[196][mmc]: mmc 2 cmd 55 err 100
[200][mmc]: mmc 2 send app cmd failed
[203][mmc]: ***Try MMC card 2***
[229][mmc]: RMCA OK!
[232][mmc]: bias 4
[233][mmc]: mmc 2 bias 4
[237][mmc]: MMC 5.1
[239][mmc]: HSSDR52/SDR25 8 bit
[242][mmc]: 50000000 Hz
[244][mmc]: 7400 MB
[246][mmc]: ***SD/MMC 2 init OK!!!***
[306]Loading boot-pkg Succeed(index=0).
[310]Entry_name        = u-boot
[317]Entry_name        = monitor
[321]Entry_name        = scp
[324]set arisc reset to assert state
[333]set arisc reset to de-assert state
[337]Entry_name        = dtb
[340]tunning data addr:0x4a0003e8
[344]Jump to second Boot.
NOTICE:  BL3-1: v1.0(debug):e138ea9
NOTICE:  BL3-1: Built : 09:21:33, 2020-11-18
NOTICE:  BL3-1 commit: 8
NOTICE:  cpuidle init version V2.0
ERROR:   Error initializing runtime service tspd_fast
NOTICE:  BL3-1: Preparing for EL3 exit to normal world
NOTICE:  BL3-1: Next image address = 0x4a000000
NOTICE:  BL3-1: Next image spsr = 0x1d3
U-Boot 2018.05 (Jun 01 2023 - 05:30:25 +0000) Allwinner Technology
[00.427]CPU:   Allwinner Family
[00.430]Model: sun50iw10
I2C:   smallwit i2c init begin ...
smallwit i2c init end ...
ready
[00.706]DRAM:  2 GiB
[00.709]Relocation Offset is: 75f00000
[00.743]secure enable bit: 0
read 0x05 register result : 0
i2c write 0x01 register ok
read 0x01 register result : 0
[00.765]PMU: AXP803
[00.767]PMU: pmu_axp81X found
FDT ERROR:fdt_get_regulator_name:get property handle twi-supply error:FDT_ERR_INTERNAL
[00.785]gpio_bias, pc_bias: 1800, pc_supply: not set
[00.790]gpio_bias, pl_bias:   -1, pl_supply: not set
[00.797]dcdc1_vol = 3300, onoff=1
[00.801]aldo1_vol = 1800, onoff=1
[00.806]aldo2_vol = 1800, onoff=1
[00.810]aldo3_vol = 3300, onoff=1
[00.814]dldo1_vol = 0, onoff=0
[00.819]dldo2_vol = 1800, onoff=1
[00.823]dldo3_vol = 1800, onoff=1
[00.828]dldo4_vol = 1800, onoff=1
[00.832]eldo1_vol = 1800, onoff=1
[00.837]eldo2_vol = 1800, onoff=1
[00.842]eldo3_vol = 1800, onoff=1
[00.846]fldo1_vol = 900, onoff=1
[00.850]dc1sw_vol = 0, onoff=1
bias_name:pc_bias        bias_vol:1800
[00.858]SMALLWIT CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=400Mhz
[00.865]not need merged sunxi overlay
[00.868]gic: sec monitor mode
[00.871]sunxi flash type@2 not support fast burn key
[00.875]flash init start
[00.878]workmode = 0,storage type = 2
[00.881][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
[00.887][mmc]: get sdc_type fail and use default host:tm4.
[00.899][mmc]: SUNXI SDMMC Controller Version:0x50300
[00.927][mmc]: Best spd md: 4-HS400, freq: 3-100000000, Bus width: 8
[00.933]sunxi flash init ok
[00.935]non secure, do not need update backup boot0 to toc0
[00.941]init_clocks:finish
[00.943]drv_disp_init
[00.976]get flash lcd idx 0
request pwm success, pwm2:pwm2:0x300a000.
[00.988]drv_disp_init finish
[00.997]Loading Environment from SUNXI_FLASH... OK
[01.006]boot_gui_init:start
[01.010]set disp.dev2_output_type fail. using defval=0
[01.014]disp 0, clk: pll(364000000),clk(364000000),dclk(52000000) dsi_rate(364000000)
     clk real:pll(360000000),clk(360000000),dclk(51428571) dsi_rate(0)
[01.028]enable power dc1sw, ret=0
[01.031]enable power dcdc1, ret=0
[01.034]enable power eldo3, ret=0
[01.037]enable power dldo2, ret=0
[01.044]switch device: sel=0, type=1, mode=4, format=0, bits=0, eotf=4, cs=260
[01.052]boot_gui_init:finish
54 bytes read in 1 ms (52.7 KiB/s)
[01.059]bmp_name=bootlogo.bmp size 793494
793494 bytes read in 8 ms (94.6 MiB/s)
[01.079]no secure os for keybox operation
[01.082]try to burn key
[01.085]out of usb burn from boot: not need burn key
[01.090][ARISC] :arisc initialize
[01.095][ARISC ERROR] :get [allwinner,sunxi-hwspinlock] device node error
CACHE: Misaligned operation at range [bffa0ae0, bffa0df8]
[01.106][ARISC] :arisc para ok
[SCP] :sunxi-arisc driver begin startup 2
[SCP] :0x1
[SCP] :arisc version: [66fd4f97463a87fc2a2bcebebcee26f774992e52rid-]
[SCP] :arisc startup ready
[SCP] :arisc startup notify message feedback
[SCP] :send hard sync feedback message: 0x900200
[SCP] :sunxi-arisc driver v1.10 is starting
[01.136]soc ic_ver:0x6, qa_val:0x0, markid:0x1400 dclk[0-200] display_cfg_flag:0
[01.143][ARISC] :sunxi-arisc driver startup succeeded
[01.148]read item0 copy0
[01.161]Item0 (Map) magic is bad
[01.164]the secure storage item0 copy0 magic is bad
[01.179]Item0 (Map) magic is bad
[01.182]the secure storage item0 copy1 magic is bad
[01.186]Item0 (Map) magic is bad
[01.189]the secure storage map is empty
[01.193]no item name device_unlock in the map
[01.197]no item name fastboot_status_flag in the map
[01.202]sunxi secure storage has no flag
List file under ULI/factory
** Unrecognized filesystem type **
[01.211]no item name snum in the map
[01.214]no item name mac in the map
[01.217]no item name wifi_mac in the map
[01.221]no item name bt_mac in the map
[01.225]no item name specialstr in the map
[01.229]update part info
[01.231]key 0
[01.232]misc partition found
pin_name = pwm2
compat=/soc/pwm2
[01.250]LCD open finish
[01.264]update bootcmd
[01.266]serial num is: 8c000c5dd642884235d
disable nand error: FDT_ERR_BADPATH
[01.278](weak)update dtb dram start
[01.298]update dtb dram  end
[01.305]update dts
[01.315]partinfo: name boot, start 0x3a000, size 0x10000
[01.466]read data in addr ret = 1
[01.469]magic = AVB0
[01.471]major version = 1  minor version = 0
[01.475]authentication_data_block_size = 240
[01.479]auxiliary_data_block_size = d40
[01.483]vbmeta_size = 4224
[01.485]algorithm_type = 0
[01.488]flag = 0
[01.490]release tool = avbtool 1.1.0
[01.504]read data in addr ret = 1
[01.507]magic = AVB0
[01.509]major version = 1  minor version = 0
[01.513]authentication_data_block_size = 140
[01.517]auxiliary_data_block_size = 3c0
[01.520]vbmeta_size = 1536
[01.523]algorithm_type = 0
[01.525]flag = 0
[01.527]release tool = avbtool 1.1.0
[01.541]read data in addr ret = 1
[01.544]magic = AVB0
[01.546]major version = 1  minor version = 0
[01.550]authentication_data_block_size = 140
[01.554]auxiliary_data_block_size = 340
[01.558]vbmeta_size = 1408
[01.560]algorithm_type = 0
[01.563]flag = 0
[01.564]release tool = avbtool 1.1.0
[01.568]total_size = 7168
[01.570]alloc block = 17
[01.604]vbmeta hash is a32ee9eb894a2f7a2eb86a847bbba8c767586f8ea3d0680b3f2eb37f88ce77ad
[01.615]no vendor_boot partition is found
[01.618]in boot normal mode,pass normal para to cmdline
[01.625]android.hardware = sun50iw10p1
[01.629]line:110 dtbo_idx= 0
[01.631]line:110 dtbo_idx= 1
[01.634]dtbo_idx= 118
[01.715]partinfo: name dtbo, start 0x61a000, size 0x1000
[01.779]Starting kernel ...
[01.782][mmc]: mmc exit start
[01.800][mmc]: mmc 2 exit ok
[    0.000000] Linux version 4.9.170 (ubuntu@ubuntu) (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05) ) #1 SMP PREEMPT Wed Dec 4 11:27:00 CST 2024
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] disp reserve base 0xbbf4f000 ,size 0x258000
[    0.000000] cma: Reserved 8 MiB at 0x00000000bf800000
[    0.000000] On node 0 totalpages: 524288
[    0.000000]   DMA zone: 8192 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 524288 pages, LIFO batch:31
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.0
[    0.000000] percpu: Embedded 23 pages/cpu @ffffffc07f6e9000 s53376 r8192 d32640 u94208
[    0.000000] pcpu-alloc: s53376 r8192 d32640 u94208 alloc=23*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 516096
[    0.000000] Kernel command line: earlyprintk=sunxi-uart,0x05000000 initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mmcblk0p4 init=/init partitions=bootloader@mmcblk0p1:env@mmcblk0p2:boot@mmcblk0p3:super@mmcblk0p4:misc@mmcblk0p5:recovery@mmcblk0p6:cache@mmcblk0p7:vbmeta@mmcblk0p8:vbmeta_system@mmcblk0p9:vbmeta_vendor@mmcblk0p10:metadata@mmcblk0p11:private@mmcblk0p12:frp@mmcblk0p13:empty@mmcblk0p14:dtbo@mmcblk0p15:media_data@mmcblk0p16:UDISK@mmcblk0p17 cma=8M snum=8c000c5dd642884235d mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.vbmeta.avb_version=2.0 androidboot.vbmeta.hash_alg=sha256 androidboot.vbmeta.size=7168 androidboot.vbmeta.digest=a32ee9eb894a2f7a2eb86a847bbba8c767586f8ea3d0680b3f2eb37f88ce77ad androidboot.vbmeta.device_state=locked androidboot.veritymode=enforcing androidboot.mode=normal androidboot.serialno=8c000c5dd642884235d androidboot.hardware=sun50iw10p1 boot_type=2 androidboot.boot_type=2 androidboot.secure_os_exist=0 androidboot.trustchain=false an[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Memory: 2011348K/2097152K available (10878K kernel code, 1852K rwdata, 3800K rodata, 3712K init, 599K bss, 77612K reserved, 8192K cma-reserved)
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008b20000   ( 10880 KB)
[    0.000000]     .rodata : 0xffffff8008b20000 - 0xffffff8008ee0000   (  3840 KB)
[    0.000000]       .init : 0xffffff8008ee0000 - 0xffffff8009280000   (  3712 KB)
[    0.000000]       .data : 0xffffff8009280000 - 0xffffff800944f008   (  1853 KB)
[    0.000000]        .bss : 0xffffff800944f008 - 0xffffff80094e4ef8   (   600 KB)
[    0.000000]     fixed   : 0xffffffbefe7fb000 - 0xffffffbefec00000   (  4116 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf02000000   (    32 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc080000000   (  2048 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000]  Build-time adjustment of leaf fanout to 64.
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (virt).
[    0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.008163] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[    0.018200] pid_max: default: 32768 minimum: 301
[    0.023020] Security Framework initialized
[    0.026880] SELinux:  Initializing.
[    0.030470] SELinux:  Starting in permissive mode
[    0.035131] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.041699] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.049547] ftrace: allocating 34120 entries in 134 pages
[    0.131536] sched-energy: CPU device node has no sched-energy-costs
[    0.132177] Invalid sched_group_energy for CPU0
[    0.136714] CPU0: update cpu_capacity 1024
[    0.150820] ASID allocator initialised with 32768 entries
[    0.168247] nsi: no limit for F version(except 1080P-LP4)
[    0.168478] BOOTEVENT:       168.474165: ON
[    0.202427] Detected VIPT I-cache on CPU1
[    0.202476] Invalid sched_group_energy for CPU1
[    0.202479] CPU1: update cpu_capacity 1024
[    0.202482] CPU1: Booted secondary processor [410fd034]
[    0.225812] Detected VIPT I-cache on CPU2
[    0.225840] Invalid sched_group_energy for CPU2
[    0.225842] CPU2: update cpu_capacity 1024
[    0.225845] CPU2: Booted secondary processor [410fd034]
[    0.249219] Detected VIPT I-cache on CPU3
[    0.249245] Invalid sched_group_energy for CPU3
[    0.249247] CPU3: update cpu_capacity 1024
[    0.249250] CPU3: Booted secondary processor [410fd034]
[    0.249329] Brought up 4 CPUs
[    0.299963] SMP: Total of 4 processors activated.
[    0.304655] CPU features: detected feature: 32-bit EL0 Support
[    0.310459] CPU features: detected feature: Kernel page table isolation (KPTI)
[    0.321382] CPU: All CPU(s) started at EL1
[    0.321731] alternatives: patching kernel code
[    0.326335] Invalid sched_group_energy for CPU3
[    0.330657] CPU3: update max cpu_capacity 1024
[    0.335073] Invalid sched_group_energy for Cluster3
[    0.339925] Invalid sched_group_energy for CPU2
[    0.344432] Invalid sched_group_energy for Cluster2
[    0.349285] Invalid sched_group_energy for CPU1
[    0.353793] Invalid sched_group_energy for Cluster1
[    0.358645] Invalid sched_group_energy for CPU0
[    0.363152] Invalid sched_group_energy for Cluster0
[    0.368657] CPU1: update max cpu_capacity 1024
[    0.373157] devtmpfs: initialized
[    0.412765] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.416892] futex hash table entries: 1024 (order: 5, 131072 bytes)
[    0.423670] atomic64_test: passed
[    0.426397] pinctrl core: initialized pinctrl subsystem
[    0.433712] NET: Registered protocol family 16
[    0.437451] dump_class_init,861, success
[    0.453328] cpuidle: using governor menu
[    0.454761] sunxi iommu: irq = 9
[    0.455684] vdso: 2 pages (1 code @ ffffff8008b28000, 1 data @ ffffff8009284000)
[    0.462242] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.470356] DMA: preallocated 256 KiB pool for atomic allocations
[    0.478056] sun50iw10p1-r-pinctrl r_pio: initialized sunXi PIO driver
[    0.496591] sun50iw10p1-pinctrl pio: initialized sunXi PIO driver
[    0.500924] iommu: Adding device 1c0e000.ve to group 0
[    0.511049] iommu: Adding device soc@03000000:disp1@1 to group 0
[    0.512237] iommu: Adding device 6000000.disp to group 0
[    0.517236] iommu: Adding device 6400000.eink to group 0
[    0.523065] iommu: Adding device 6480000.g2d to group 0
[    0.565392] pwm module init!
[    0.570760] sunxi-pm debug v3.10
[    0.572193] SCSI subsystem initialized
[    0.573150] usbcore: registered new interface driver usbfs
[    0.577632] usbcore: registered new interface driver hub
[    0.582955] usbcore: registered new device driver usb
[    0.588050] sunxi_i2c_adap_init()2541 - init
[    0.592639] sunxi_i2c_probe()2289 - [i2c6] twi_drv_used = 1
[    0.597668] sunxi_i2c_probe()2293 - [i2c6] twi_pkt_interval = 0
[    0.603572] twi6 supply twi not found, using dummy regulator
[    0.609265] twi_request_gpio()453 - [i2c6] init name: twi6
[    0.615229] axp20x-i2c 6-0034: AXP20x variant AXP803 found
[    0.626393] axp2101-regulator axp2101-regulator.0: Setting DCDC frequency for unsupported AXP variant
[    0.629991] axp2101-regulator axp2101-regulator.0: Error setting dcdc frequency: -22
[    0.668880] axp803-dldo1: Bringing 3300000uV into 1900000-1900000uV
[    0.696562] axp20x-i2c 6-0034: AXP20X driver loaded
[    0.696669] sunxi_i2c_dma_request()1123 - [i2c6] using dma0chan0 (tx) and dma0chan1 (rx)for DMA transfers
[    0.705872] sunxi_i2c_probe()2289 - [i2c0] twi_drv_used = 0
[    0.710911] sunxi_i2c_probe()2293 - [i2c0] twi_pkt_interval = 0
[    0.716835] twi0 supply twi not found, using dummy regulator
[    0.722519] twi_request_gpio()453 - [i2c0] init name: twi0
[    0.728809] sunxi_i2c_probe()2289 - [i2c1] twi_drv_used = 0
[    0.733451] sunxi_i2c_probe()2293 - [i2c1] twi_pkt_interval = 0
[    0.739381] twi1 supply twi not found, using dummy regulator
[    0.745036] twi_request_gpio()453 - [i2c1] init name: twi1
[    0.751007] sunxi_i2c_probe()2289 - [i2c2] twi_drv_used = 0
[    0.755974] sunxi_i2c_probe()2293 - [i2c2] twi_pkt_interval = 0
[    0.762246] twi_request_gpio()453 - [i2c2] init name: twi2
[    0.768025] sunxi_i2c_probe()2289 - [i2c3] twi_drv_used = 0
[    0.772876] sunxi_i2c_probe()2293 - [i2c3] twi_pkt_interval = 0
[    0.778811] twi3 supply twi not found, using dummy regulator
[    0.784491] twi_request_gpio()453 - [i2c3] init name: twi3
[    0.790737] media: Linux media interface: v0.10
[    0.794425] Linux video capture interface: v2.00
[    0.799914] ion_parse_dt_heap_common: id 0 type 0 name sys_user align 1000
[    0.806017] ion_parse_dt_heap_common: id 4 type 4 name cma align 1000
[    0.812379] ion_parse_dt_heap_common: id 6 type 6 name secure align 1000
[    0.819190] drm config service not available: FFFFFFFF
[    0.824427] Advanced Linux Sound Architecture Driver Initialized.
[    0.830711] Bluetooth: Core ver 2.22
[    0.833674] NET: Registered protocol family 31
[    0.838040] Bluetooth: HCI device and connection manager initialized
[    0.844380] Bluetooth: HCI socket layer initialized
[    0.849225] Bluetooth: L2CAP socket layer initialized
[    0.854294] Bluetooth: SCO socket layer initialized
[    0.860547] clocksource: Switched to clocksource arch_sys_counter
[    0.932592] VFS: Disk quotas dquot_6.6.0
[    0.932735] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.940353] udc_init,0
[    0.941520] NET: Registered protocol family 2
[    0.970741] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    0.972436] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[    0.979190] TCP: Hash tables configured (established 16384 bind 16384)
[    0.985492] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[    0.991444] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[    0.998166] NET: Registered protocol family 1
[    1.002438] Trying to unpack rootfs image as initramfs...
[    1.041914] Freeing initrd memory: 776K
[    1.043542] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    1.050458] audit: initializing netlink subsys (disabled)
[    1.053302] audit: type=2000 audit(0.863:1): initialized
[    1.059529] workingset: timestamp_bits=45 max_order=19 bucket_order=0
[    1.075115] Registering sdcardfs 0.1
[    1.075624] ntfs: driver 2.1.32 [Flags: R/W].
[    1.077912] fuse init (API version 7.26)
[    1.083289] SELinux:  Registering netfilter hooks
[    1.090414] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    1.093552] io scheduler noop registered
[    1.097361] io scheduler deadline registered
[    1.101754] io scheduler cfq registered (default)
[    1.108158] [DISP]disp_module_init
[    1.109946] disp soc@03000000:disp1@1: unable to map de registers
[    1.115673] disp: probe of soc@03000000:disp1@1 failed with error -22
[    1.122863] [DISP] disp_init,line:2345:
[    1.125699] smooth display screen:0 type:1 mode:4
[    1.172306] [DISP] lcd_clk_config,line:675:
[    1.172353] disp 0, clk: pll(364000000),clk(364000000),dclk(52000000) dsi_rate(364000000)
[    1.172353]      clk real:pll(360000000),clk(360000000),dclk(51428571) dsi_rate(0)
[    1.174524] [DISP]disp_module_init finish
[    1.198440] uart uart0: get regulator failed
[    1.199046] uart0: ttyS0 at MMIO 0x5000000 (irq = 349, base_baud = 1500000) is a SUNXI
[    1.205027] sw_console_▒[    1.212943] console [ttyS0] enabled
[    1.216950] bootconsole [earlycon0] disabled
[    1.225926] uart uart1: get regulator failed
[    1.234239] uart1 supply uart not found, using dummy regulator
[    1.241064] uart1: ttyS1 at MMIO 0x5000400 (irq = 350, base_baud = 1500000) is a SUNXI
[    1.250513] uart uart2: get regulator failed
[    1.255374] uart2 supply uart not found, using dummy regulator
[    1.262169] uart2: ttyS2 at MMIO 0x5000800 (irq = 351, base_baud = 1500000) is a SUNXI
[    1.271448] sun50iw10p1-pinctrl pio: missing pins property in node uart3
[    1.279010] uart: probe of uart3 failed with error -22
[    1.284840] sun50iw10p1-pinctrl pio: missing pins property in node uart4
[    1.292394] uart: probe of uart4 failed with error -22
[    1.298920] misc dump reg init
[    1.303531] G2D: Module initialized.major:245
[    1.309281] [drm] Initialized
[    1.312783] Unable to detect cache hierarchy for CPU 0
[    1.330937] brd: module loaded
[    1.348172] loop: module loaded
[    1.352656] zram: Added device: zram0
[    1.357028] [NAND][NE] Not found valid nand node on dts
[    1.363627] Boot type 2
[    1.366870] sunxi-bt soc@03000000:bt@0: bt_power_name (axp803-dldo1)
[    1.374081] sunxi-bt soc@03000000:bt@0: Missing bt_io_regulator.
[    1.380859] sunxi-bt soc@03000000:bt@0: io_regulator_name ((null))
[    1.387884] sunxi-bt soc@03000000:bt@0: get gpio bt_rst failed
[    1.394515] sunxi-bt soc@03000000:bt@0: devm_pinctrl_get() failed!
[    1.402162] sunxi-wlan soc@03000000:wlan@0: wlan_busnum (1)
[    1.408464] sunxi-wlan soc@03000000:wlan@0: wlan_power_name (axp803-dldo1)
[    1.416213] sunxi-wlan soc@03000000:wlan@0: Missing wlan_io_regulator.
[    1.423575] sunxi-wlan soc@03000000:wlan@0: io_regulator_name ((null))
[    1.430959] sunxi-wlan soc@03000000:wlan@0: wlan_regon gpio=202  mul-sel=1  pull=-1  drv_level=-1  data=1
[    1.441778] sunxi-wlan soc@03000000:wlan@0: get gpio chip_en failed
[    1.448843] sunxi-wlan soc@03000000:wlan@0: get gpio power_en failed
[    1.456022] sunxi-wlan soc@03000000:wlan@0: wlan_hostwake gpio=205  mul-sel=6  pull=-1  drv_level=-1  data=0
[    1.467159] sunxi-wlan soc@03000000:wlan@0: clk not config
[    1.473357] sunxi-wlan soc@03000000:wlan@0: dcxo not config
[    1.479660] sunxi-wlan soc@03000000:wlan@0: pinctrl_lookup_state(default) failed! return ffffffffffffffed
[    1.491683] [ADDR_MGT] addr_mgt_probe: success.
[    1.499896] libphy: Fixed MDIO Bus: probed
[    1.504563] tun: Universal TUN/TAP device driver, 1.6
[    1.510261] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.518962] deviceless supply  not found, using dummy regulator
[    1.525713] deviceless supply  not found, using dummy regulator
[    1.532411] deviceless supply  not found, using dummy regulator
[    1.540022] PPP generic driver version 2.4.2
[    1.545086] PPP BSD Compression module registered
[    1.550398] PPP Deflate Compression module registered
[    1.556119] PPP MPPE Compression module registered
[    1.561527] NET: Registered protocol family 24
[    1.566534] PPTP driver version 0.8.5
[    1.571032] usbcore: registered new interface driver rtl8150
[    1.577480] usbcore: registered new interface driver r8152
[    1.583729] usbcore: registered new interface driver asix
[    1.589878] usbcore: registered new interface driver ax88179_178a
[    1.596799] usbcore: registered new interface driver cdc_ether
[    1.603478] usbcore: registered new interface driver smsc75xx
[    1.610025] usbcore: registered new interface driver smsc95xx
[    1.616551] usbcore: registered new interface driver net1080
[    1.622993] usbcore: registered new interface driver cdc_subset
[    1.629716] usbcore: registered new interface driver zaurus
[    1.636057] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[    1.644471] usbcore: registered new interface driver cdc_ncm
[    1.650854] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.658581] get ehci0-controller, regulator_io is no nocare
[    1.664868] get ehci0-controller wakeup-source is fail.
[    1.670996] sunxi ehci0-controller don't init wakeup source
[    1.677286] [sunxi-ehci0]: probe, pdev->name: 5101000.ehci0-controller, sunxi_ehci: 0xffffff80094d08b0, 0x:ffffff8009c56000, irq_no:168
[    1.690998] [sunxi-ehci0]: Not init ehci0
[    1.695641] get ehci1-controller, regulator_io is no nocare
[    1.701921] get ehci1-controller wakeup-source is fail.
[    1.707945] sunxi ehci1-controller don't init wakeup source
[    1.714229] [sunxi-ehci1]: probe, pdev->name: 5200000.ehci1-controller, sunxi_ehci: 0xffffff80094d0c38, 0x:ffffff8009cf2000, irq_no:16a
[    1.729237] sunxi-ehci 5200000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.739466] sunxi-ehci 5200000.ehci1-controller: new USB bus registered, assigned bus number 1
[    1.749644] sunxi-ehci 5200000.ehci1-controller: irq 362, io mem 0xffffffc07c70a010
[    1.770566] sunxi-ehci 5200000.ehci1-controller: USB 0.0 started, EHCI 1.00
[    1.778413] sunxi-ehci 5200000.ehci1-controller: ehci_irq: highspeed device connect
[    1.788013] hub 1-0:1.0: USB hub found
[    1.792276] hub 1-0:1.0: 1 port detected
[    1.797624] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.804980] get ohci0-controller, regulator_io is no nocare
[    1.811268] get ohci0-controller wakeup-source is fail.
[    1.817387] sunxi ohci0-controller don't init wakeup source
[    1.823787] [sunxi-ohci0]: probe, pdev->name: 5101000.ohci0-controller, sunxi_ohci: 0xffffff80094d1348
[    1.834274] [sunxi-ohci0]: Not init ohci0
[    1.838917] get ohci1-controller, regulator_io is no nocare
[    1.845203] get ohci1-controller wakeup-source is fail.
[    1.851218] sunxi ohci1-controller don't init wakeup source
[    1.857596] [sunxi-ohci1]: probe, pdev->name: 5200000.ohci1-controller, sunxi_ohci: 0xffffff80094d16d0
[    1.868227] sunxi-ohci 5200000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.878050] sunxi-ohci 5200000.ohci1-controller: new USB bus registered, assigned bus number 2
[    1.887826] sunxi-ohci 5200000.ohci1-controller: irq 363, io mem 0xffffffc07c70a400
[    1.955506] hub 2-0:1.0: USB hub found
[    1.959772] hub 2-0:1.0: 1 port detected
[    1.965359] usbcore: registered new interface driver uas
[    1.971471] usbcore: registered new interface driver usb-storage
[    1.978303] usbcore: registered new interface driver ums-alauda
[    1.985029] usbcore: registered new interface driver ums-cypress
[    1.991854] usbcore: registered new interface driver ums-datafab
[    1.998672] usbcore: registered new interface driver ums_eneub6250
[    2.005696] usbcore: registered new interface driver ums-freecom
[    2.012515] usbcore: registered new interface driver ums-isd200
[    2.019241] usbcore: registered new interface driver ums-jumpshot
[    2.026157] usbcore: registered new interface driver ums-karma
[    2.032786] usbcore: registered new interface driver ums-onetouch
[    2.039721] usbcore: registered new interface driver ums-realtek
[    2.046547] usbcore: registered new interface driver ums-sddr09
[    2.053268] usbcore: registered new interface driver ums-sddr55
[    2.059997] usbcore: registered new interface driver ums-usbat
[    2.066693] usbcore: registered new interface driver usbserial
[    2.073455] usbcore: registered new interface driver option
[    2.079784] usbserial: USB Serial support registered for GSM modem (1-port)
[    2.087816] usbcore: registered new interface driver cdc_xr_usb_serial
[    2.095171] xr_usb_serial_common: Exar USB UART (serial port) driver
[    2.102499] usb_serial_number:20080411
[    2.107504] sunxikbd_key_init: key0 vol= 590 code= 0
[    2.113104] sunxikbd_key_init: key1 vol= 646 code= 115
[    2.113896] usb 1-1: new high-speed USB device number 2 using sunxi-ehci
[    2.126445] sunxikbd_key_init: key2 vol= 897 code= 114
[    2.132532] input: sunxi-keyboard as /devices/virtual/input/input0
[    2.148098] input: axp803-pek as /devices/platform/soc/7081400.s_twi/i2c-6/6-0034/axp2101-pek.0/input/input1
[    2.163014] random: fast init done
[    2.169477] rtc-hym8563 3-0051: rtc core: registered hym8563 as rtc0
[    2.177632] i2c /dev entries driver
[    2.182701] lirc_dev: IR Remote Control driver registered, major 244
[    2.189895] IR NEC protocol handler initialized
[    2.195001] IR RC5(x/sz) protocol handler initialized
[    2.200697] IR RC6 protocol handler initialized
[    2.205809] IR JVC protocol handler initialized
[    2.210918] IR Sony protocol handler initialized
[    2.216120] IR SANYO protocol handler initialized
[    2.221431] IR Sharp protocol handler initialized
[    2.226730] IR MCE Keyboard/mouse protocol handler initialized
[    2.233357] IR LIRC bridge handler initialized
[    2.238413] IR XMP protocol handler initialized
[    2.244020] sunxi_ir_startup: get ir protocol failed
[    2.249481] 7040000.s_cir supply ir0 not found, using dummy regulator
[    2.257113] Registered IR keymap rc_map_sunxi
[    2.262485] input: sunxi-ir as /devices/platform/soc/7040000.s_cir/rc/rc0/input2
[    2.271093] rc rc0: sunxi-ir as /devices/platform/soc/7040000.s_cir/rc/rc0
[    2.279369] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input3
[    2.289348] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
[    2.289518] hub 1-1:1.0: USB hub found
[    2.289936] hub 1-1:1.0: 4 ports detected
[    2.308060] sunxi cedar version 0.1
[    2.312147] VE: install start!!!
[    2.312147]
[    2.317612] cedar_ve: cedar-ve the get irq is 347
[    2.323334] VE: get debugfs_mpp_root is NULL, please check mpp
[    2.323334]
[    2.331580] VE: sunxi ve debug register driver failed!
[    2.331580]
[    2.351960] axp803_battery: axp803_bat_power_dt_parse: failed
[    2.351960]
[    2.360107] axp803_battery: axp803_bat_power_probe parse device tree err
[    2.360107]
[    2.369350] axp803-battery-power-supply: probe of axp803-battery-power-supply.0 failed with error -22
[    2.381148] device-mapper: uevent: version 1.0.3
[    2.386840] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[    2.396512] device-mapper: verity-avb: AVB error handler initialized with vbmeta device:
[    2.405735] Bluetooth: HCI UART driver ver 2.3
[    2.410754] Bluetooth: HCI UART protocol H4 registered
[    2.416548] Bluetooth: HCI UART protocol LL registered
[    2.422337] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    2.433975] sunxi-mmc sdc2: SD/MMC/SDIO Host Controller Driver(v3.46 2020-6-1 11:33-202006021635)
[    2.444056] sunxi-mmc sdc2: ***ctl-spec-caps*** 308
[    2.450204] sunxi-mmc sdc2: No vdmmc regulator found
[    2.455805] sunxi-mmc sdc2: No vd33sw regulator found
[    2.461504] sunxi-mmc sdc2: No vd18sw regulator found
[    2.467197] sunxi-mmc sdc2: No vq33sw regulator found
[    2.472899] sunxi-mmc sdc2: No vq18sw regulator found
[    2.479266] sunxi-mmc sdc2: set host busy
[    2.483878] mmc:failed to get gpios
[    2.488070] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm UP vdd 22 width 1 timing LEGACY(SDR12) dt B
[    2.513962] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[    2.540806] sunxi-mmc sdc2: detmode:alway in(non removable)
[    2.540840] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[    2.549301] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[    2.550369] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[    2.561223] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[    2.561287] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[    2.574133] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[    2.618630] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
[    2.628043] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
[    2.637474] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
[    2.646897] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
[    2.656310] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
[    2.665737] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
[    2.675480] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.46 2020-6-1 11:33-202006021635)
[    2.685559] sunxi-mmc sdc0: ***ctl-spec-caps*** 8
[    2.692569] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[    2.692957] sunxi-mmc sdc0: No vqmmc regulator found
[    2.692962] sunxi-mmc sdc0: No vdmmc regulator found
[    2.703450] sunxi-mmc sdc0: set host busy
[    2.703513] sunxi-mmc sdc0: Got CD GPIO
[    2.703842] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 22 width 1 timing LEGACY(SDR12) dt B
[    2.703887] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
[    2.720576] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[    2.737469] sunxi-mmc sdc0: detmode:gpio irq
[    2.737984] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.46 2020-6-1 11:33-202006021635)
[    2.738053] sunxi-mmc sdc1: ***ctl-spec-caps*** 1
[    2.738238] sunxi-mmc sdc1: No vmmc regulator found
[    2.738242] sunxi-mmc sdc1: No vqmmc regulator found
[    2.738247] sunxi-mmc sdc1: No vdmmc regulator found
[    2.738251] sunxi-mmc sdc1: No vd33sw regulator found
[    2.738255] sunxi-mmc sdc1: No vd18sw regulator found
[    2.738259] sunxi-mmc sdc1: No vq33sw regulator found
[    2.738264] sunxi-mmc sdc1: No vq18sw regulator found
[    2.738858] sunxi-mmc sdc1: set host busy
[    2.738936] mmc:failed to get gpios
[    2.738972] sunxi-mmc sdc1: min-frequency:150000
[    2.739187] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.753912] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.770588] sunxi-mmc sdc1: detmode:manually by software
[    2.771429] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[    2.772267] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[    2.772293] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.774774] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.776667] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    2.777542] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    2.778411] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    2.779278] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    2.779306] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[    2.780392] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.782407] ledtrig-cpu: registered to indicate activity on CPUs
[    2.782833] hidraw: raw HID events driver (C) Jiri Kosina
[    2.785401] usbcore: registered new interface driver usbhid
[    2.785405] usbhid: USB HID core driver
[    2.785811] ashmem: initialized
[    2.787669] optee: probing for conduit method from DT.
[    2.787679] optee: api uid mismatch
[    2.788098] usbcore: registered new interface driver snd-usb-audio
[    2.789428] sun50iw10p1-pinctrl pio: pin PB4 already requested by twi1; cannot claim for daudio0
[    2.789434] sun50iw10p1-pinctrl pio: pin-36 (daudio0) status -22
[    2.789441] sun50iw10p1-pinctrl pio: could not request pin 36 (PB4) from group PB4  on device pio
[    2.789446] sunxi-daudio daudio0: Error applying setting, reverse things back
[    2.789467] sunxi-daudio: probe of daudio0 failed with error -22
[    2.789945] sun50iw10p1-pinctrl pio: missing pins property in node spdif
[    2.789953] sunxi-spdif: probe of spdif failed with error -22
[    2.793195] sunxi-internal-codec codec: pa_power_always_on get failed and set it off.
[    2.793202] digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:0, pa_power_always_on:0
[    2.793211] adcdrc_cfg:2, adchpf_cfg:1, dacdrc_cfg:2, dachpf:0
[    2.793271] sunxi-internal-codec codec: [sunxi_internal_codec_probe] codec probe finished.
[    2.793930] sunxi-mmc sdc1: sdc set ios:clk 300000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.794341] [sunxi_card_init] card init finished.
[    2.794432] Audio: [soc_new_pcm] -> 2699
[    2.794437] Audio: [soc_new_pcm] -> 2718
[    2.794545] Audio: [soc_new_pcm] -> 2746
[    2.795910] sunxi-codec-machine sndcodec: sun50iw10codec <-> codec mapping ok
[    2.797154] input: sun50iw10-codec sunxi Audio Jack as /devices/platform/soc/sndcodec/sound/card0/input4
[    2.797545] [audio] hp_detect_case: 1
[    2.797550] [audio] noheadphonemic missing or it has headphonemic.
[    2.797812] sunxi-codec-machine sndcodec: [sunxi_card_dev_probe] register card finished.
[    2.798773] sndspdif sndspdif: ASoC: CPU DAI (null) not registered
[    2.798781] sndspdif sndspdif: snd_soc_register_card failed: -517
[    2.798892] sndspdif: probe of sndspdif failed with error -16
[    2.799685] u32 classifier
[    2.799687]     Actions configured
[    2.799697] Netfilter messages via NETLINK v0.30.
[    2.799714] nfnl_acct: registering with nfnetlink.
[    2.800046] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    2.800271] ctnetlink v0.93: registering with nfnetlink.
[    2.800821] xt_time: kernel timezone is -0000
[    2.800920] ipip: IPv4 and MPLS over IPv4 tunneling driver
[    2.801527] gre: GRE over IPv4 demultiplexor driver
[    2.801531] ip_gre: GRE over IPv4 tunneling driver
[    2.802643] IPv4 over IPsec tunneling driver
[    2.805093] ip_tables: (C) 2000-2006 Netfilter Core Team
[    2.805340] arp_tables: arp_tables: (C) 2002 David S. Miller
[    2.811836] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[    2.815263] Initializing XFRM netlink socket
[    2.815299] IPsec XFRM device driver
[    2.816053] NET: Registered protocol family 10
[    2.816328] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[    2.816358] sunxi-mmc sdc1: sdc set ios:clk 300000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.818998] sunxi-mmc sdc1: sdc set ios:clk 300000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.821157] mip6: Mobile IPv6
[    2.821191] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    2.821193] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    2.822294] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    2.823391] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    2.824487] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    2.824510] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[    2.825602] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.843886] sunxi-mmc sdc1: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.846475] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    2.847797] NET: Registered protocol family 17
[    2.847828] NET: Registered protocol family 15
[    2.847859] l2tp_core: L2TP core driver, V2.0
[    2.847875] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[    2.851417] Registered cp15_barrier emulation handler
[    2.851431] Registered setend emulation handler
[    2.852253] registered taskstats version 1
[    2.865567] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[    2.867234] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[    2.867275] sunxi-mmc sdc1: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.868366] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[    2.868373] cpu cpu0: _opp_add: OPP not supported by regulators (1464000000)
[    2.868685] cpu cpu1: opp_list_debug_create_link: Failed to create link
[    2.868691] cpu cpu1: _add_opp_dev: Failed to register opp debugfs (-12)
[    2.868726] cpu cpu2: opp_list_debug_create_link: Failed to create link
[    2.868732] cpu cpu2: _add_opp_dev: Failed to register opp debugfs (-12)
[    2.868767] cpu cpu3: opp_list_debug_create_link: Failed to create link
[    2.868772] cpu cpu3: _add_opp_dev: Failed to register opp debugfs (-12)
[    2.870148] sunxi-mmc sdc1: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.871015] get usb_detect_mode is fail, 22
[    2.871532] sunxi_ctp_startup: ctp_power_io is invalid.
[    2.871557] get ctp_gesture_wakeup fail, no gesture wakeup
[    2.871595] 0-005d supply ctp not found, using dummy regulator
[    2.871696] get ctp_screen_max_x is fail, -22
[    2.872971] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    2.874601] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    2.876221] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    2.877841] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    2.877856] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[    2.878936] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.897212] sunxi-mmc sdc1: sdc set ios:clk 150000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.919368] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[    2.921527] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[    2.921540] sunxi-mmc sdc1: sdc set ios:clk 150000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.924600] sunxi-mmc sdc1: sdc set ios:clk 150000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.927843] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    2.930003] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    2.932162] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    2.934309] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    2.934321] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[    2.940558] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[    2.967553] GTP I2C Address:0x5d
[    2.967805] sunxi_i2c_do_xfer()1946 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x5d)
[    2.968008] sunxi_i2c_do_xfer()1946 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x5d)
[    2.984133] gtp_i2c_read:I2C retry timeout, reset chip.GTP i2c test failed time 1.
[    2.984133] sunxi_i2c_do_xfer()1946 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x5d)
[    2.984336] sunxi_i2c_do_xfer()1946 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x5d)
[    3.000599] gtp_i2c_read:I2C retry timeout, reset chip.GTP i2c test failed time 2.I2C communication ERROR!
[    3.000630] gt9xx_ts: probe of 0-005d failed with error -70
[    3.000752] sunxi_i2c_drv_core_process()1007 - [i2c6] Timeout when sending 9th SCL clk
[    3.000770] i2c_sunxi_drv_complete()1181 - [i2c6] incomplete xfer(status: 0x1, dev addr: 0x14)
[    3.000777] 0x07081600: 01011001 00000001 00002800 0001ffff
[    3.000781] 0x07081610: 00008040 00010004 00010010 00000000
[    3.000853] sunxi_i2c_drv_core_process()1007 - [i2c6] Timeout when sending 9th SCL clk
[    3.000865] i2c_sunxi_drv_complete()1181 - [i2c6] incomplete xfer(status: 0x1, dev addr: 0x5d)
[    3.000869] 0x07081600: 11011001 00000001 0000bb00 00000001
[    3.000874] 0x07081610: 00008040 00010004 00010010 00000000
[    3.001035] sunxi_i2c_do_xfer()1946 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x14)
[    3.001254] sunxi_i2c_do_xfer()1946 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x14)
[    3.001440] sunxi_i2c_do_xfer()1946 - [i2c1] incomplete xfer (status: 0x48, dev addr: 0x5d)
[    3.001650] sunxi_i2c_do_xfer()1946 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
[    3.001834] sunxi_i2c_do_xfer()1946 - [i2c2] incomplete xfer (status: 0x48, dev addr: 0x5d)
[    3.002022] sunxi_i2c_do_xfer()1946 - [i2c3] incomplete xfer (status: 0x20, dev addr: 0x14)
[    3.002206] sunxi_i2c_do_xfer()1946 - [i2c3] incomplete xfer (status: 0x48, dev addr: 0x5d)
[    3.002549] ERROR! get hall_para failed, func:switch_init, line:269
[    3.006879] rtc-hym8563 3-0051: setting system clock to 2024-12-04 09:36:38 UTC (1733304998)
[    3.007435] snddaudio snddaudio0: codec: snd-soc-dummy, codec_dai: snd-soc-dummy-dai.
[    3.007447] snddaudio snddaudio0: ASoC: CPU DAI (null) not registered
[    3.007451] snddaudio snddaudio0: snd_soc_register_card failed
[    3.008882] axp803-dcdc6: disabling
[    3.009727] axp803-dldo3: disabling
[    3.010341] axp803-dldo4: disabling
[    3.010958] axp803-eldo2: disabling
[    3.012020] ALSA device list:
[    3.012023]   #0: sun50iw10-codec
[    3.889700] Freeing unused kernel memory: 3712K
[    3.894851] Kernel init done
[    3.901859] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 8 timing LEGACY(SDR12) dt B
[    3.912991] init: init first stage started!
[    3.918346] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 8 timing MMC-HS200 dt B
[    3.918652] init: [libfs_mgr]ReadFstabFromDt(): failed to read fstab from dt
[    3.920216] init: Using Android DT directory /proc/device-tree/firmware/android/
[    3.945304] sunxi-mmc sdc2: sdc set ios:clk 100000000Hz bm PP pm ON vdd 22 width 8 timing MMC-HS200 dt B
[    3.956313] sunxi-mmc sdc2: sdc set ios:clk 100000000Hz bm PP pm ON vdd 22 width 8 timing MMC-HS(SDR20) dt B
[    3.967526] sunxi-mmc sdc2: sdc set ios:clk 52000000Hz bm PP pm ON vdd 22 width 8 timing MMC-HS(SDR20) dt B
[    3.978934] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 22 width 8 timing MMC-HS400 dt B
[    3.989681] sunxi_mmc_get_hs400_cmd_dly,222
[    3.994391] sunxi-mmc sdc2: failed to get HS400_cmd used default
[    4.001235] sunxi-mmc sdc2: sdc set ios:clk 100000000Hz bm PP pm ON vdd 22 width 8 timing MMC-HS400 dt B
[    4.010622] init: bool android::init::FirstStageMount::InitRequiredDevices(): partition(s) not found in /sys, waiting for their uevent(s): metadata, super
[    4.027449] sunxi_mmc_get_hs400_cmd_dly,222
[    4.032135] sunxi-mmc sdc2: failed to get HS400_cmd used default
[    4.039249] mmc0: new HS400 MMC card at address 0001
[    4.048743] mmcblk0: mmc0:0001 AT2S38 7.23 GiB
[    4.057452] mmcblk0boot0: mmc0:0001 AT2S38 partition 1 4.00 MiB
[    4.067719] mmcblk0boot1: mmc0:0001 AT2S38 partition 2 4.00 MiB
[    4.077858] mmcblk0rpmb: mmc0:0001 AT2S38 partition 3 4.00 MiB
[    4.086282]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
[    4.099552] snddaudio snddaudio0: codec: snd-soc-dummy, codec_dai: snd-soc-dummy-dai.
[    4.100852] init: Wait for partitions returned after 90ms
[    4.103732] init: [libfs_mgr]Created logical partition system on device /dev/block/dm-0
[    4.105125] init: [libfs_mgr]Created logical partition vendor on device /dev/block/dm-1
[    4.106420] init: [libfs_mgr]Created logical partition product on device /dev/block/dm-2
[    4.107193] init: [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/by-name/metadata
[    4.107355] init: [libfs_mgr]Filesystem on /dev/block/by-name/metadata was not cleanly shutdown; state flags: 0x1, incompat feature flags: 0x46
[    4.113099] EXT4-fs (mmcblk0p11): recovery complete
[    4.113229] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: errors=panic
[    4.119279] EXT4-fs (dm-0): mounted filesystem without journal. Opts: barrier=1
[    4.131097] EXT4-fs (dm-1): mounted filesystem without journal. Opts: barrier=1
[    4.134142] EXT4-fs (dm-2): mounted filesystem without journal. Opts: barrier=1
[    4.147553] init: 14 output lines suppressed due to ratelimiting
[    4.157439] random: init: uninitialized urandom read (40 bytes read)
[    4.218444] snddaudio snddaudio0: ASoC: CPU DAI (null) not registered
[    4.225660] snddaudio snddaudio0: snd_soc_register_card failed
[    4.286478] random: init: uninitialized urandom read (40 bytes read)
[    4.312951] init: Loading SELinux policy
[    4.331466] SELinux: 8192 avtab hash slots, 22279 rules.
[    4.348949] SELinux: 8192 avtab hash slots, 22279 rules.
[    4.354953] SELinux:  1 users, 4 roles, 1373 types, 0 bools, 1 sens, 1024 cats
[    4.363036] SELinux:  97 classes, 22279 rules
[    4.371478] SELinux:  Completing initialization.
[    4.376652] SELinux:  Setting up existing superblocks.
[    4.490126] audit: type=1403 audit(1733304999.983:2): policy loaded auid=4294967295 ses=4294967295
[    4.500422] selinux: SELinux: Loaded policy from /vendor/etc/selinux/precompiled_sepolicy
[    4.500422]
[    4.516822] selinux: SELinux:  Skipping /product/etc/selinux/product_file_contexts:  empty file
[    4.516822]
[    4.531988] selinux: SELinux: Loaded file_contexts
[    4.531988]
[    4.545439] random: init: uninitialized urandom read (40 bytes read)
[    4.589052] init: init second stage started!
[    4.623935] init: Using Android DT directory /proc/device-tree/firmware/android/
[    4.637517] selinux: SELinux:  Skipping /product/etc/selinux/product_file_contexts:  empty file
[    4.637517]
[    4.649088] selinux: SELinux: Loaded file_contexts
[    4.649088]
[    4.656150] init: Running restorecon...
[    4.673426] init: Overriding previous 'ro.' property 'pm.dexopt.shared':'speed' with new value 'quicken'
[    4.686764] selinux: avc:  denied  { set } for  scontext=u:r:vendor_init:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=1
[    4.686764]
[    4.703398] init: Overriding previous 'ro.' property 'ro.zygote':'zygote32' with new value 'zygote64_32'
[    4.714654] selinux: avc:  denied  { set } for  scontext=u:r:vendor_init:s0 tcontext=u:object_r:dalvik_prop:s0 tclass=property_service permissive=1
[    4.714654]
[    4.731171] init: Overriding previous 'ro.' property 'pm.dexopt.boot':'verify' with new value 'extract'
[    4.989761] ueventd: ueventd started!
[    4.997663] selinux: SELinux:  Skipping /product/etc/selinux/product_file_contexts:  empty file
[    4.997663]
[    5.009450] selinux: SELinux: Loaded file_contexts
[    5.009450]
[    5.016801] ueventd: Parsing file /ueventd.rc...
[    5.023404] ueventd: Parsing file /vendor/ueventd.rc...
[    5.030182] ueventd: Parsing file /odm/ueventd.rc...
[    5.035820] ueventd: Unable to read config file '/odm/ueventd.rc': open() failed: No such file or directory
[    5.046810] ueventd: Parsing file /ueventd.sun50iw10p1.rc...
[    5.053208] ueventd: Unable to read config file '/ueventd.sun50iw10p1.rc': open() failed: No such file or directory
[    5.073112] apexd: Bootstrap subcommand detected
[    5.089139] apexd: Scanning /system/apex for embedded keys
[    5.096982] apexd: Scanning /product/apex for embedded keys
[    5.103534] apexd: ... does not exist. Skipping
[    5.108953] apexd: Scanning /system/apex looking for APEX packages.
[    5.116447] apexd: Found /system/apex/com.android.tzdata
[    5.123253] apexd: Successfully bind-mounted flattened package /system/apex/com.android.tzdata on /apex/com.android.tzdata@290000000
[    5.137099] apexd: Found /system/apex/com.android.runtime.release
[    5.144853] apexd: Successfully bind-mounted flattened package /system/apex/com.android.runtime.release on /apex/com.android.runtime@1
[    5.158864] apexd: Found /system/apex/com.android.media.swcodec
[    5.171452] apexd: 9 output lines suppressed due to ratelimiting
[    5.203001] audit: type=1400 audit(1733305000.696:3): avc:  denied  { read } for  pid=1577 comm="ueventd" name="/" dev="debugfs" ino=1 scontext=u:r:ueventd:s0 tcontext=u:object_r:debugfs:s0 tclass=dir permissive=1
[    5.224418] audit: type=1400 audit(1733305000.720:4): avc:  denied  { open } for  pid=1577 comm="ueventd" path="/sys/kernel/debug" dev="debugfs" ino=1 scontext=u:r:ueventd:s0 tcontext=u:object_r:debugfs:s0 tclass=dir permissive=1
[    5.247439] audit: type=1400 audit(1733305000.743:5): avc:  denied  { getattr } for  pid=1577 comm="ueventd" path="/sys/kernel/debug/fault_around_bytes" dev="debugfs" ino=1199 scontext=u:r:ueventd:s0 tcontext=u:object_r:debugfs:s0 tclass=file permissive=1
[    5.272991] audit: type=1400 audit(1733305000.766:6): avc:  denied  { getattr } for  pid=1577 comm="ueventd" path="/sys/kernel/debug/wakeup_sources" dev="debugfs" ino=18 scontext=u:r:ueventd:s0 tcontext=u:object_r:debugfs_wakeup_sources:s0 tclass=file permissive=1
[    5.364202] ueventd: Coldboot took 0.297 seconds
[    5.430928] Registered swp emulation handler
[    5.489611] init: wait for '/dev/block/by-name/media_data' took 0ms
[    5.499379] FAT-fs (mmcblk0p16): bogus number of reserved sectors
[    5.506255] FAT-fs (mmcblk0p16): Can't find a valid FAT filesystem
[    5.589798] fsck.f2fs: Info: Fix the reported corruption.
[    5.589798]
[    5.591081] logd.auditd: start
[    5.601074] fsck.f2fs:       Info: No support kernel version!
[    5.601074]
[    5.608726] fsck.f2fs: Info: Segments per section = 1
[    5.608726]
[    5.616161] fsck.f2fs: Info: Sections per zone = 1
[    5.616161]
[    5.623239] fsck.f2fs: Info: sector size = 512
[    5.623239]
[    5.629916] fsck.f2fs: Info: total sectors = 8720351 (4257 MB)
[    5.629916]
[    5.638134] fsck.f2fs: Info: MKFS version
[    5.638134]
[    5.644300] fsck.f2fs:   "4.9.170 #1 SMP PREEMPT Wed Dec 4 11:27:00 CST 2024"
[    5.644300]
[    5.653983] fsck.f2fs: Info: FSCK version
[    5.653983]
[    5.660143] fsck.f2fs:   from "4.9.170 #1 SMP PREEMPT Wed Dec 4 11:27:00 CST 2024"
[    5.660143]
[    5.758931] F2FS-fs (mmcblk0p17): recover_inode: ino = 7fd, name = external.db, inline = 1
[    5.768206] F2FS-fs (mmcblk0p17): recover_data: ino = 7fd (i_size: recover) recovered = 0, err = 0
[    5.778213] F2FS-fs (mmcblk0p17): recover_inode: ino = 13af, name = persistent_properties.tmp, inline = b
[    5.789500] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13af, name = persistent_properties.tmp, dir = 47, err = 0
[    5.800975] F2FS-fs (mmcblk0p17): recover_data: ino = 13af (i_size: recover) recovered = 0, err = 0
[    5.811061] F2FS-fs (mmcblk0p17): recover_inode: ino = 13b1, name = drop34.tmp, inline = b
[    5.824026] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13b1, name = drop34.tmp, dir = 58, err = 0
[    5.834095] F2FS-fs (mmcblk0p17): recover_data: ino = 13b1 (i_size: recover) recovered = 0, err = 0
[    5.844211] F2FS-fs (mmcblk0p17): recover_inode: ino = 13b2, name = log-files.xml, inline = 1
[    5.854301] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13b2, name = log-files.xml, dir = 57, err = 0
[    5.864704] F2FS-fs (mmcblk0p17): recover_data: ino = 13b2 (i_size: recover) recovered = 1, err = 0
[    5.874810] F2FS-fs (mmcblk0p17): recover_inode: ino = 13b4, name = drop177.tmp, inline = 3
[    5.884699] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13b4, name = drop177.tmp, dir = 58, err = 0
[    5.894812] F2FS-fs (mmcblk0p17): recover_data: ino = 13b4 (i_size: recover) recovered = 0, err = 0
[    5.904945] F2FS-fs (mmcblk0p17): recover_inode: ino = 13b5, name = drop34.tmp, inline = b
[    5.914198] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13b5, name = drop34.tmp, dir = 58, err = 0
[    5.924276] F2FS-fs (mmcblk0p17): recover_data: ino = 13b5 (i_size: recover) recovered = 0, err = 0
[    5.934419] F2FS-fs (mmcblk0p17): recover_inode: ino = 13b6, name = log-files.xml, inline = 1
[    5.943990] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13b6, name = log-files.xml, dir = 57, err = 0
[    5.954342] F2FS-fs (mmcblk0p17): recover_data: ino = 13b6 (i_size: recover) recovered = 1, err = 0
[    5.964439] F2FS-fs (mmcblk0p17): recover_inode: ino = 13b9, name = persistent_properties.tmp, inline = b
[    5.975139] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13b9, name = persistent_properties.tmp, dir = 47, err = 0
[    5.986606] F2FS-fs (mmcblk0p17): recover_data: ino = 13b9 (i_size: recover) recovered = 0, err = 0
[    5.996773] F2FS-fs (mmcblk0p17): recover_inode: ino = 5fd, name = primary.prof, inline = 3
[    6.006110] F2FS-fs (mmcblk0p17): recover_data: ino = 5fd (i_size: recover) recovered = 0, err = 0
[    6.016116] F2FS-fs (mmcblk0p17): recover_inode: ino = 13bb, name = drop180.tmp, inline = 3
[    6.038429] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13bb, name = drop180.tmp, dir = 58, err = 0
[    6.048535] F2FS-fs (mmcblk0p17): recover_data: ino = 13bb (i_size: recover) recovered = 0, err = 0
[    6.058638] F2FS-fs (mmcblk0p17): recover_inode: ino = 13bc, name = drop34.tmp, inline = b
[    6.067905] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13bc, name = drop34.tmp, dir = 58, err = 0
[    6.077919] F2FS-fs (mmcblk0p17): recover_data: ino = 13bc (i_size: recover) recovered = 0, err = 0
[    6.088020] F2FS-fs (mmcblk0p17): recover_inode: ino = 13bd, name = log-files.xml, inline = 1
[    6.097541] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13bd, name = log-files.xml, dir = 57, err = 0
[    6.107864] F2FS-fs (mmcblk0p17): recover_data: ino = 13bd (i_size: recover) recovered = 1, err = 0
[    6.117963] F2FS-fs (mmcblk0p17): recover_inode: ino = 13be, name = persistent_properties.tmp, inline = b
[    6.128656] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13be, name = persistent_properties.tmp, dir = 47, err = 0
[    6.140112] F2FS-fs (mmcblk0p17): recover_data: ino = 13be (i_size: recover) recovered = 0, err = 0
[    6.150205] F2FS-fs (mmcblk0p17): recover_inode: ino = 5fd, name = primary.prof, inline = 3
[    6.159537] F2FS-fs (mmcblk0p17): recover_data: ino = 5fd (i_size: recover) recovered = 0, err = 0
[    6.169536] F2FS-fs (mmcblk0p17): recover_inode: ino = 13c0, name = drop183.tmp, inline = 3
[    6.191852] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13c0, name = drop183.tmp, dir = 58, err = 0
[    6.201952] F2FS-fs (mmcblk0p17): recover_data: ino = 13c0 (i_size: recover) recovered = 0, err = 0
[    6.212042] F2FS-fs (mmcblk0p17): recover_inode: ino = 13c1, name = drop34.tmp, inline = b
[    6.221288] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13c1, name = drop34.tmp, dir = 58, err = 0
[    6.231296] F2FS-fs (mmcblk0p17): recover_data: ino = 13c1 (i_size: recover) recovered = 0, err = 0
[    6.241398] F2FS-fs (mmcblk0p17): recover_inode: ino = 13c2, name = log-files.xml, inline = 1
[    6.250927] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13c2, name = log-files.xml, dir = 57, err = 0
[    6.261240] F2FS-fs (mmcblk0p17): recover_data: ino = 13c2 (i_size: recover) recovered = 1, err = 0
[    6.271328] F2FS-fs (mmcblk0p17): recover_inode: ino = 13c3, name = persistent_properties.tmp, inline = b
[    6.282017] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13c3, name = persistent_properties.tmp, dir = 47, err = 0
[    6.293495] F2FS-fs (mmcblk0p17): recover_data: ino = 13c3 (i_size: recover) recovered = 0, err = 0
[    6.303590] F2FS-fs (mmcblk0p17): recover_inode: ino = 5fd, name = primary.prof, inline = 3
[    6.312916] F2FS-fs (mmcblk0p17): recover_data: ino = 5fd (i_size: recover) recovered = 0, err = 0
[    6.322904] F2FS-fs (mmcblk0p17): recover_inode: ino = 13c5, name = drop185.tmp, inline = 3
[    6.332232] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13c5, name = drop185.tmp, dir = 58, err = 0
[    6.342348] F2FS-fs (mmcblk0p17): recover_data: ino = 13c5 (i_size: recover) recovered = 0, err = 0
[    6.352438] F2FS-fs (mmcblk0p17): recover_inode: ino = 13c6, name = drop34.tmp, inline = b
[    6.361672] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13c6, name = drop34.tmp, dir = 58, err = 0
[    6.371676] F2FS-fs (mmcblk0p17): recover_data: ino = 13c6 (i_size: recover) recovered = 0, err = 0
[    6.381771] F2FS-fs (mmcblk0p17): recover_inode: ino = 13c7, name = log-files.xml, inline = 1
[    6.391299] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13c7, name = log-files.xml, dir = 57, err = 0
[    6.401608] F2FS-fs (mmcblk0p17): recover_data: ino = 13c7 (i_size: recover) recovered = 1, err = 0
[    6.411703] F2FS-fs (mmcblk0p17): recover_inode: ino = 13c8, name = persistent_properties.tmp, inline = b
[    6.422392] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13c8, name = persistent_properties.tmp, dir = 47, err = 0
[    6.433852] F2FS-fs (mmcblk0p17): recover_data: ino = 13c8 (i_size: recover) recovered = 0, err = 0
[    6.443954] F2FS-fs (mmcblk0p17): recover_inode: ino = 5fd, name = primary.prof, inline = 3
[    6.453275] F2FS-fs (mmcblk0p17): recover_data: ino = 5fd (i_size: recover) recovered = 0, err = 0
[    6.463269] F2FS-fs (mmcblk0p17): recover_inode: ino = 13ca, name = drop187.tmp, inline = 3
[    6.472604] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13ca, name = drop187.tmp, dir = 58, err = 0
[    6.482711] F2FS-fs (mmcblk0p17): recover_data: ino = 13ca (i_size: recover) recovered = 0, err = 0
[    6.492813] F2FS-fs (mmcblk0p17): recover_inode: ino = 13cb, name = drop34.tmp, inline = b
[    6.502054] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13cb, name = drop34.tmp, dir = 58, err = 0
[    6.512059] F2FS-fs (mmcblk0p17): recover_data: ino = 13cb (i_size: recover) recovered = 0, err = 0
[    6.522169] F2FS-fs (mmcblk0p17): recover_inode: ino = 13cc, name = log-files.xml, inline = 1
[    6.531682] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13cc, name = log-files.xml, dir = 57, err = 0
[    6.541997] F2FS-fs (mmcblk0p17): recover_data: ino = 13cc (i_size: recover) recovered = 1, err = 0
[    6.552104] F2FS-fs (mmcblk0p17): recover_inode: ino = 13cd, name = persistent_properties.tmp, inline = b
[    6.562793] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13cd, name = persistent_properties.tmp, dir = 47, err = 0
[    6.574252] F2FS-fs (mmcblk0p17): recover_data: ino = 13cd (i_size: recover) recovered = 0, err = 0
[    6.584344] F2FS-fs (mmcblk0p17): recover_inode: ino = 5fd, name = primary.prof, inline = 3
[    6.593672] F2FS-fs (mmcblk0p17): recover_data: ino = 5fd (i_size: recover) recovered = 0, err = 0
[    6.603670] F2FS-fs (mmcblk0p17): recover_inode: ino = 13cf, name = drop189.tmp, inline = 3
[    6.613003] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13cf, name = drop189.tmp, dir = 58, err = 0
[    6.623104] F2FS-fs (mmcblk0p17): recover_data: ino = 13cf (i_size: recover) recovered = 0, err = 0
[    6.633216] F2FS-fs (mmcblk0p17): recover_inode: ino = 13d0, name = drop34.tmp, inline = b
[    6.642435] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13d0, name = drop34.tmp, dir = 58, err = 0
[    6.652439] F2FS-fs (mmcblk0p17): recover_data: ino = 13d0 (i_size: recover) recovered = 0, err = 0
[    6.662532] F2FS-fs (mmcblk0p17): recover_inode: ino = 13d1, name = log-files.xml, inline = 1
[    6.672045] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13d1, name = log-files.xml, dir = 57, err = 0
[    6.682363] F2FS-fs (mmcblk0p17): recover_data: ino = 13d1 (i_size: recover) recovered = 1, err = 0
[    6.692465] F2FS-fs (mmcblk0p17): recover_inode: ino = 13d2, name = persistent_properties.tmp, inline = b
[    6.703145] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13d2, name = persistent_properties.tmp, dir = 47, err = 0
[    6.714616] F2FS-fs (mmcblk0p17): recover_data: ino = 13d2 (i_size: recover) recovered = 0, err = 0
[    6.724711] F2FS-fs (mmcblk0p17): recover_inode: ino = 5fd, name = primary.prof, inline = 3
[    6.734037] F2FS-fs (mmcblk0p17): recover_data: ino = 5fd (i_size: recover) recovered = 0, err = 0
[    6.744045] F2FS-fs (mmcblk0p17): recover_inode: ino = 13d5, name = drop192.tmp, inline = 3
[    6.753377] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13d5, name = drop192.tmp, dir = 58, err = 0
[    6.763482] F2FS-fs (mmcblk0p17): recover_data: ino = 13d5 (i_size: recover) recovered = 0, err = 0
[    6.773574] F2FS-fs (mmcblk0p17): recover_inode: ino = 13d4, name = drop34.tmp, inline = b
[    6.782809] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13d4, name = drop34.tmp, dir = 58, err = 0
[    6.792815] F2FS-fs (mmcblk0p17): recover_data: ino = 13d4 (i_size: recover) recovered = 0, err = 0
[    6.802914] F2FS-fs (mmcblk0p17): recover_inode: ino = 13d6, name = log-files.xml, inline = 1
[    6.812449] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13d6, name = log-files.xml, dir = 57, err = 0
[    6.822751] F2FS-fs (mmcblk0p17): recover_data: ino = 13d6 (i_size: recover) recovered = 1, err = 0
[    6.832853] F2FS-fs (mmcblk0p17): recover_inode: ino = 13d7, name = persistent_properties.tmp, inline = b
[    6.843533] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13d7, name = persistent_properties.tmp, dir = 47, err = 0
[    6.854993] F2FS-fs (mmcblk0p17): recover_data: ino = 13d7 (i_size: recover) recovered = 0, err = 0
[    6.865087] F2FS-fs (mmcblk0p17): recover_inode: ino = 5fd, name = primary.prof, inline = 3
[    6.874399] F2FS-fs (mmcblk0p17): recover_data: ino = 5fd (i_size: recover) recovered = 0, err = 0
[    6.884400] F2FS-fs (mmcblk0p17): recover_inode: ino = 13d9, name = drop194.tmp, inline = 3
[    6.893730] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13d9, name = drop194.tmp, dir = 58, err = 0
[    6.903833] F2FS-fs (mmcblk0p17): recover_data: ino = 13d9 (i_size: recover) recovered = 0, err = 0
[    6.913941] F2FS-fs (mmcblk0p17): recover_inode: ino = 13da, name = drop34.tmp, inline = b
[    6.923179] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13da, name = drop34.tmp, dir = 58, err = 0
[    6.933321] F2FS-fs (mmcblk0p17): recover_data: ino = 13da (i_size: recover) recovered = 0, err = 0
[    6.943468] F2FS-fs (mmcblk0p17): recover_inode: ino = 13db, name = log-files.xml, inline = 1
[    6.953041] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13db, name = log-files.xml, dir = 57, err = 0
[    6.976237] F2FS-fs (mmcblk0p17): recover_data: ino = 13db (i_size: recover) recovered = 1, err = 0
[    6.986352] F2FS-fs (mmcblk0p17): recover_inode: ino = 13dc, name = persistent_properties.tmp, inline = b
[    6.997057] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13dc, name = persistent_properties.tmp, dir = 47, err = 0
[    7.008524] F2FS-fs (mmcblk0p17): recover_data: ino = 13dc (i_size: recover) recovered = 0, err = 0
[    7.010608]
[    7.010608] insmod_device_driver
[    7.010608]
[    7.010846] device_chose finished 137!
[    7.029684] F2FS-fs (mmcblk0p17): recover_inode: ino = 5fd, name = primary.prof, inline = 3
[    7.038996] F2FS-fs (mmcblk0p17): recover_data: ino = 5fd (i_size: recover) recovered = 0, err = 0
[    7.048992] F2FS-fs (mmcblk0p17): recover_inode: ino = 13de, name = drop34.tmp, inline = b
[    7.058253] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13de, name = drop34.tmp, dir = 58, err = 0
[    7.068258] F2FS-fs (mmcblk0p17): recover_data: ino = 13de (i_size: recover) recovered = 0, err = 0
[    7.078362] F2FS-fs (mmcblk0p17): recover_inode: ino = 13df, name = log-files.xml, inline = 1
[    7.087890] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13df, name = log-files.xml, dir = 57, err = 0
[    7.098220] F2FS-fs (mmcblk0p17): recover_data: ino = 13df (i_size: recover) recovered = 1, err = 0
[    7.108309] F2FS-fs (mmcblk0p17): recover_inode: ino = 13e0, name = drop196.tmp, inline = 3
[    7.117647] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13e0, name = drop196.tmp, dir = 58, err = 0
[    7.127742] F2FS-fs (mmcblk0p17): recover_data: ino = 13e0 (i_size: recover) recovered = 0, err = 0
[    7.137829] F2FS-fs (mmcblk0p17): recover_inode: ino = 13e1, name = persistent_properties.tmp, inline = b
[    7.148526] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13e1, name = persistent_properties.tmp, dir = 47, err = 0
[    7.159994] F2FS-fs (mmcblk0p17): recover_data: ino = 13e1 (i_size: recover) recovered = 0, err = 0
[    7.170103] F2FS-fs (mmcblk0p17): recover_inode: ino = 5fd, name = primary.prof, inline = 3
[    7.179422] F2FS-fs (mmcblk0p17): recover_data: ino = 5fd (i_size: recover) recovered = 0, err = 0
[    7.189413] F2FS-fs (mmcblk0p17): recover_inode: ino = 13e3, name = drop198.tmp, inline = 3
[    7.198748] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13e3, name = drop198.tmp, dir = 58, err = 0
[    7.208869] F2FS-fs (mmcblk0p17): recover_data: ino = 13e3 (i_size: recover) recovered = 0, err = 0
[    7.218958] F2FS-fs (mmcblk0p17): recover_inode: ino = 13e4, name = drop34.tmp, inline = b
[    7.228209] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13e4, name = drop34.tmp, dir = 58, err = 0
[    7.238226] F2FS-fs (mmcblk0p17): recover_data: ino = 13e4 (i_size: recover) recovered = 0, err = 0
[    7.248320] F2FS-fs (mmcblk0p17): recover_inode: ino = 13e5, name = log-files.xml, inline = 1
[    7.257858] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13e5, name = log-files.xml, dir = 57, err = 0
[    7.268179] F2FS-fs (mmcblk0p17): recover_data: ino = 13e5 (i_size: recover) recovered = 1, err = 0
[    7.278395] F2FS-fs (mmcblk0p17): recover_inode: ino = 13e6, name = persistent_properties.tmp, inline = b
[    7.289129] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13e6, name = persistent_properties.tmp, dir = 47, err = 0
[    7.300624] F2FS-fs (mmcblk0p17): recover_data: ino = 13e6 (i_size: recover) recovered = 0, err = 0
[    7.310722] F2FS-fs (mmcblk0p17): recover_inode: ino = 5fd, name = primary.prof, inline = 3
[    7.320054] F2FS-fs (mmcblk0p17): recover_data: ino = 5fd (i_size: recover) recovered = 0, err = 0
[    7.330055] F2FS-fs (mmcblk0p17): recover_inode: ino = 13e8, name = drop201.tmp, inline = 3
[    7.339403] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13e8, name = drop201.tmp, dir = 58, err = 0
[    7.349502] F2FS-fs (mmcblk0p17): recover_data: ino = 13e8 (i_size: recover) recovered = 0, err = 0
[    7.359609] F2FS-fs (mmcblk0p17): recover_inode: ino = 13e9, name = drop34.tmp, inline = b
[    7.368863] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13e9, name = drop34.tmp, dir = 58, err = 0
[    7.378875] F2FS-fs (mmcblk0p17): recover_data: ino = 13e9 (i_size: recover) recovered = 0, err = 0
[    7.388969] F2FS-fs (mmcblk0p17): recover_inode: ino = 13ea, name = log-files.xml, inline = 1
[    7.398486] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13ea, name = log-files.xml, dir = 57, err = 0
[    7.408807] F2FS-fs (mmcblk0p17): recover_data: ino = 13ea (i_size: recover) recovered = 1, err = 0
[    7.418898] F2FS-fs (mmcblk0p17): recover_inode: ino = 13eb, name = persistent_properties.tmp, inline = b
[    7.429583] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13eb, name = persistent_properties.tmp, dir = 47, err = 0
[    7.441061] F2FS-fs (mmcblk0p17): recover_data: ino = 13eb (i_size: recover) recovered = 0, err = 0
[    7.451145] F2FS-fs (mmcblk0p17): recover_inode: ino = 5fd, name = primary.prof, inline = 3
[    7.460464] F2FS-fs (mmcblk0p17): recover_data: ino = 5fd (i_size: recover) recovered = 0, err = 0
[    7.470464] F2FS-fs (mmcblk0p17): recover_inode: ino = 13ed, name = drop203.tmp, inline = 3
[    7.479797] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13ed, name = drop203.tmp, dir = 58, err = 0
[    7.489908] F2FS-fs (mmcblk0p17): recover_data: ino = 13ed (i_size: recover) recovered = 0, err = 0
[    7.500011] F2FS-fs (mmcblk0p17): recover_inode: ino = 13ee, name = drop34.tmp, inline = b
[    7.509245] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13ee, name = drop34.tmp, dir = 58, err = 0
[    7.519246] F2FS-fs (mmcblk0p17): recover_data: ino = 13ee (i_size: recover) recovered = 0, err = 0
[    7.529337] F2FS-fs (mmcblk0p17): recover_inode: ino = 13ef, name = log-files.xml, inline = 1
[    7.538856] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13ef, name = log-files.xml, dir = 57, err = 0
[    7.549181] F2FS-fs (mmcblk0p17): recover_data: ino = 13ef (i_size: recover) recovered = 1, err = 0
[    7.559275] F2FS-fs (mmcblk0p17): recover_inode: ino = 13f0, name = persistent_properties.tmp, inline = b
[    7.569959] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13f0, name = persistent_properties.tmp, dir = 47, err = 0
[    7.581419] F2FS-fs (mmcblk0p17): recover_data: ino = 13f0 (i_size: recover) recovered = 0, err = 0
[    7.591505] F2FS-fs (mmcblk0p17): recover_inode: ino = 5fd, name = primary.prof, inline = 3
[    7.600831] F2FS-fs (mmcblk0p17): recover_data: ino = 5fd (i_size: recover) recovered = 0, err = 0
[    7.610837] F2FS-fs (mmcblk0p17): recover_inode: ino = 13f2, name = drop205.tmp, inline = 3
[    7.620174] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13f2, name = drop205.tmp, dir = 58, err = 0
[    7.630283] F2FS-fs (mmcblk0p17): recover_data: ino = 13f2 (i_size: recover) recovered = 0, err = 0
[    7.640389] F2FS-fs (mmcblk0p17): recover_inode: ino = 13f3, name = drop34.tmp, inline = b
[    7.649623] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13f3, name = drop34.tmp, dir = 58, err = 0
[    7.659630] F2FS-fs (mmcblk0p17): recover_data: ino = 13f3 (i_size: recover) recovered = 0, err = 0
[    7.669716] F2FS-fs (mmcblk0p17): recover_inode: ino = 13f4, name = log-files.xml, inline = 1
[    7.679236] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13f4, name = log-files.xml, dir = 57, err = 0
[    7.689541] F2FS-fs (mmcblk0p17): recover_data: ino = 13f4 (i_size: recover) recovered = 1, err = 0
[    7.718953] F2FS-fs (mmcblk0p17): checkpoint: version = 32a82eda
[    7.725807] F2FS-fs (mmcblk0p17): Mounted with checkpoint version = 32a82eda
[    7.736384] EXT4-fs (mmcblk0p7): Ignoring removed nomblk_io_submit option
[    7.749080] EXT4-fs (mmcblk0p7): recovery complete
[    7.754569] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[    7.853130] EXT4-fs (mmcblk0p7): Ignoring removed nomblk_io_submit option
[    7.862097] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: barrier=1,data=ordered,nomblk_io_submit,noauto_da_alloc,errors=panic
[    7.897470] init: 14 output lines suppressed due to ratelimiting
[    7.911165] zram0: detected capacity change from 0 to 1554452480
[    7.942835] mkswap: Swapspace size: 1518016k, UUID=3ad44fa5-0cf8-48a1-9075-ee5cd99d996a
[    7.952867] Adding 1518016k swap on /dev/block/zram0.  Priority:-1 extents:1 across:1518016k SS
console:/ $ [    8.092506] videobuf2_vmalloc: disagrees about version of symbol module_layout
[    8.351103] apexd: Marking APEXd as starting
[    8.357006] apexd: Scanning /system/apex for embedded keys
[    8.365123] apexd: Scanning /product/apex for embedded keys
[    8.371698] apexd: ... does not exist. Skipping
[    8.376990] apexd: Populating APEX database from mounts...
[    8.383758] apexd: Failed to walk /product/apex : Can't open /product/apex for reading : No such file or directory
[    8.396167] apexd: Found "/apex/com.android.tzdata@290000000"
[    8.402931] apexd: Found "/apex/com.android.runtime@1"
[    8.408892] apexd: 2 packages restored.
[    8.413299] apexd: Scanning /data/apex/sessions looking for sessions to be activated.
[    8.455252] vdc: Waited 0ms for vold
[    8.528921] type=1400 audit(1733305004.023:7): avc: denied { setattr } for comm="init" name="audio_d" dev="mmcblk0p17" ino=118 scontext=u:r:vendor_init:s0 tcontext=u:object_r:audio_rw_data_file:s0 tclass=dir permissive=1
[    8.689335] logd.daemon: reinit
[    9.220026] file system registered
[    9.232822] type=1400 audit(1733305004.023:7): avc: denied { setattr } for comm="init" name="audio_d" dev="mmcblk0p17" ino=118 scontext=u:r:vendor_init:s0 tcontext=u:object_r:audio_rw_data_file:s0 tclass=dir permissive=1
[    9.254898] type=1400 audit(1733305004.726:8): avc: denied { create } for comm="audio@2.0-servi" scontext=u:r:hal_audio_default:s0 tcontext=u:r:hal_audio_default:s0 tclass=tcp_socket permissive=1
[    9.257919] using random self ethernet address
[    9.257924] using random host ethernet address
[    9.288994] healthd: No battery devices found
[    9.303052] sunxi-bt soc@03000000:bt@0: block state already is 1
[    9.314480] healthd: battery none chg=au
[    9.327591] type=1400 audit(1733305004.726:8): avc: denied { create } for comm="audio@2.0-servi" scontext=u:r:hal_audio_default:s0 tcontext=u:r:hal_audio_default:s0 tclass=tcp_socket permissive=1
[    9.351715] type=1400 audit(1733305004.726:9): avc: denied { setopt } for comm="audio@2.0-servi" scontext=u:r:hal_audio_default:s0 tcontext=u:r:hal_audio_default:s0 tclass=tcp_socket permissive=1
[    9.372060] type=1400 audit(1733305004.726:9): avc: denied { setopt } for comm="audio@2.0-servi" scontext=u:r:hal_audio_default:s0 tcontext=u:r:hal_audio_default:s0 tclass=tcp_socket permissive=1
[    9.391627] type=1400 audit(1733305004.726:10): avc: denied { bind } for comm="audio@2.0-servi" scontext=u:r:hal_audio_default:s0 tcontext=u:r:hal_audio_default:s0 tclass=tcp_socket permissive=1
[    9.411192] type=1400 audit(1733305004.726:10): avc: denied { bind } for comm="audio@2.0-servi" scontext=u:r:hal_audio_default:s0 tcontext=u:r:hal_audio_default:s0 tclass=tcp_socket permissive=1
[    9.620275] aicbsp_init
[    9.623078] RELEASE_DATE:2024_0712_e2a932c1
[    9.624857] read descriptors
[    9.624870] read strings
[    9.633955] aicbsp_resv_mem_init
[    9.639293] init: Command 'insmod /vendor/modules/aic8800_bsp.ko' action=persist.vendor.bluetooth_vendor=aic (/vendor/etc/init/init.wireless.bluetooth.rc:34) took 294ms and succeeded
[    9.659657] init: Service 'preloaddata' (pid 2177) exited with status 0
[    9.667917] init: Sending signal 9 to service 'preloaddata' (pid 2177) process group...
[    9.677763] libprocessgroup: Successfully killed process cgroup uid 0 pid 2177 in 0ms
[    9.759076] aic_bluetooth_mod_init
[    9.765079] -->rfkill_bluetooth_init
[    9.769688] <--rfkill_bluetooth_init
[    9.770171] treadahead: go to process_files
[    9.778746] [BT_LPM] bluesleep_init: BlueSleep Mode Driver Ver 1.3.3
[    9.786437] [BT_LPM] bluesleep_probe: bt_hostwake gpio=203 assert=1
[    9.786437]
[    9.795229] [BT_LPM] bluesleep_probe: bt_wake gpio=204 assert=1
[    9.795229]
[    9.803532] [BT_LPM] bluesleep_probe: uart_index (1)
[    9.803532]
[    9.811287] init: Command 'insmod /vendor/modules/aic8800_btlpm.ko' action=persist.vendor.bluetooth_vendor=aic (/vendor/etc/init/init.wireless.bluetooth.rc:35) took 122ms and succeeded
[    9.832066] init: Service 'exec 10 (/system/bin/gsid run-startup-tasks)' (pid 2175) exited with status 0
[    9.843019] init: Sending signal 9 to service 'exec 10 (/system/bin/gsid run-startup-tasks)' (pid 2175) process group...
[    9.855715] libprocessgroup: Successfully killed process cgroup uid 0 pid 2175 in 0ms
[    9.865187] init: processing action (nonencrypted) from (/init.rc:760)
[    9.872754] init: Could not start service 'flash_recovery' as part of class 'main': Cannot find '/system/bin/install-recovery.sh': No such file or directory
[   10.425396] android_work: sent uevent USB_STATE=CONNECTED
[   10.718412] configfs-gadget gadget: high-speed config #1: b
[   10.725000] android_work: sent uevent USB_STATE=CONFIGURED
[   10.931968] type=1400 audit(1733305005.736:16): avc: denied { write } for comm="radio_monitor" name="uevent" dev="sysfs" ino=20547 scontext=u:r:radio_monitor:s0 tcontext=u:object_r:sysfs_usb:s0 tclass=file permissive=1
[   10.933210] input: sunxi-ir-uinput as /devices/virtual/input/input5
[   10.961025] type=1400 audit(1733305006.426:17): avc: denied { read } for comm="multi_ir" name="sunxi_ir_protocol" dev="proc" ino=4026532136 scontext=u:r:multi_ir:s0 tcontext=u:object_r:proc:s0 tclass=file permissive=1
[   10.982976] type=1400 audit(1733305006.426:17): avc: denied { read } for comm="multi_ir" name="sunxi_ir_protocol" dev="proc" ino=4026532136 scontext=u:r:multi_ir:s0 tcontext=u:object_r:proc:s0 tclass=file permissive=1
[   11.004650] type=1400 audit(1733305006.426:18): avc: denied { open } for comm="multi_ir" path="/proc/sunxi_ir_protocol" dev="proc" ino=4026532136 scontext=u:r:multi_ir:s0 tcontext=u:object_r:proc:s0 tclass=file permissive=1
[   12.855219] type=1400 audit(1733305006.426:18): avc: denied { open } for comm="multi_ir" path="/proc/sunxi_ir_protocol" dev="proc" ino=4026532136 scontext=u:r:multi_ir:s0 tcontext=u:object_r:proc:s0 tclass=file permissive=1
[   12.861558] pvrsrvkm: loading out-of-tree module taints kernel.
[   12.871912] audit: audit_backlog=70 > audit_backlog_limit=64
[   12.871917] audit: audit_lost=1 audit_rate_limit=0 audit_backlog_limit=64
[   12.871920] audit: backlog limit exceeded
[   12.871927] audit: audit_backlog=70 > audit_backlog_limit=64
[   12.871930] audit: audit_lost=2 audit_rate_limit=0 audit_backlog_limit=64
[   12.871932] audit: backlog limit exceeded
[   12.871977] audit: audit_backlog=70 > audit_backlog_limit=64
[   12.871980] audit: audit_lost=3 audit_rate_limit=0 audit_backlog_limit=64
[   12.871982] audit: backlog limit exceeded
[   12.871989] audit: audit_backlog=70 > audit_backlog_limit=64
[   12.948915] type=1400 audit(1733305008.350:19): avc: denied { open } for comm="getprop" path="/dev/__properties__/u:object_r:apexd_prop:s0" dev="tmpfs" ino=335 scontext=u:r:shell:s0 tcontext=u:object_r:apexd_prop:s0 tclass=file permissive=1
[   12.952679] pvrsrvkm gpu: set gpu core rate:504000000 freq:504000000-950000uV dfs:0x00000001
[   12.952684] pvrsrvkm gpu: set gpu core rate:504000000 freq:472500000-950000uV dfs:0x00000002
[   12.952688] pvrsrvkm gpu: set gpu core rate:504000000 freq:441000000-950000uV dfs:0x00000004
[   12.952692] pvrsrvkm gpu: set gpu core rate:252000000 freq:252000000-950000uV dfs:0x00000001
[   12.952836] pvrsrvkm gpu: idle:1 dvfs:0 power:0 Yes mode:1 volt:950000 core:504000000
[   12.952894] PVR_K:  2144: Read BVNC 22.102.54.38 from HW device registers
[   12.952921] PVR_K:  2144: RGX Device registered with BVNC 22.102.54.38
[   12.953500] pvrsrvkm gpu: opp[1/4]: (252000000 Hz, 950000 uV)
[   12.953504] pvrsrvkm gpu: opp[2/4]: (441000000 Hz, 950000 uV)
[   12.953508] pvrsrvkm gpu: opp[3/4]: (472500000 Hz, 950000 uV)
[   12.953512] pvrsrvkm gpu: opp[4/4]: (504000000 Hz, 950000 uV)
[   12.953946] pvrsrvkm gpu: Cooling: power ops not registered, not enabling cooling
[   12.962155] [drm] Initialized pvr 1.11.5516664 20170530 on minor 0
[   12.962538] snddaudio snddaudio0: codec: snd-soc-dummy, codec_dai: snd-soc-dummy-dai.
[   12.962551] snddaudio snddaudio0: ASoC: CPU DAI (null) not registered
[   12.962556] snddaudio snddaudio0: snd_soc_register_card failed
[   13.099869] type=1400 audit(1733305008.350:19): avc: denied { open } for comm="getprop" path="/dev/__properties__/u:object_r:apexd_prop:s0" dev="tmpfs" ino=335 scontext=u:r:shell:s0 tcontext=u:object_r:apexd_prop:s0 tclass=file permissive=1
[   13.123801] type=1400 audit(1733305008.350:20): avc: denied { getattr } for comm="getprop" path="/dev/__properties__/u:object_r:apexd_prop:s0" dev="tmpfs" ino=335 scontext=u:r:shell:s0 tcontext=u:object_r:apexd_prop:s0 tclass=file permissive=1
[   13.148120] type=1400 audit(1733305008.350:20): avc: denied { getattr } for comm="getprop" path="/dev/__properties__/u:object_r:apexd_prop:s0" dev="tmpfs" ino=335 scontext=u:r:shell:s0 tcontext=u:object_r:apexd_prop:s0 tclass=file permissive=1
[   13.172361] type=1400 audit(1733305008.350:21): avc: denied { read } for comm="getprop" name="u:object_r:audio_hal_prop:s0" dev="tmpfs" ino=336 scontext=u:r:shell:s0 tcontext=u:object_r:audio_hal_prop:s0 tclass=file permissive=1
[   13.310915] PVR_K:  2135: RGX Firmware image 'rgx.fw.22.102.54.38' loaded
[   13.397699] random: crng init done
[   13.401504] random: 6 urandom warning(s) missed due to ratelimiting
[   14.121847] sid_rd_ver_reg()418 - ver >= 4, soc ver:6
[   14.875615] init: Received control message 'start' for 'bootanim' from pid: 2149 (/system/bin/surfaceflinger)
[   14.888015] init: starting service 'bootanim'...
[   18.747938] healthd: battery none chg=au
[   18.901350] healthd: battery none chg=au
[   18.913124] healthd: battery none chg=au
[   19.155806] type=1400 audit(1733305008.460:93): avc: denied { getattr } for comm="pvrsrvctl" path="/proc/modules" dev="proc" ino=4026532050 scontext=u:r:pvr:s0 tcontext=u:object_r:proc_modules:s0 tclass=file permissive=1
[   19.185502] type=1400 audit(1733305014.650:94): avc: denied { read } for comm="system_server" name="hctosys" dev="sysfs" ino=21117 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[   19.207436] type=1400 audit(1733305014.650:94): avc: denied { read } for comm="system_server" name="hctosys" dev="sysfs" ino=21117 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[   19.228997] type=1400 audit(1733305014.650:95): avc: denied { open } for comm="system_server" path="/sys/devices/platform/soc/twi3/i2c-3/3-0051/rtc/rtc0/hctosys" dev="sysfs" ino=21117 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[   19.263276] type=1400 audit(1733305014.650:95): avc: denied { open } for comm="system_server" path="/sys/devices/platform/soc/twi3/i2c-3/3-0051/rtc/rtc0/hctosys" dev="sysfs" ino=21117 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[   19.290205] type=1400 audit(1733305014.650:96): avc: denied { getattr } for comm="system_server" path="/sys/devices/platform/soc/twi3/i2c-3/3-0051/rtc/rtc0/hctosys" dev="sysfs" ino=21117 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[   19.457576] init: processing action (sys.sysctl.extra_free_kbytes=*) from (/init.rc:806)
[   20.251253] acc_open
[   20.253717] acc_release
[   20.540638] init: Received control message 'interface_start' for 'android.hardware.wifi@1.0::IWifi/default' from pid: 1990 (/system/bin/hwservicemanager)
[   20.559647] init: starting service 'vendor.wifi_hal_legacy'...
[   20.574137] init: Received control message 'interface_start' for 'android.hardware.wifi@1.0::IWifi/default' from pid: 1990 (/system/bin/hwservicemanager)
[   20.749276] libphy: gmac0: probed
[   20.790992] sunxi-gmac gmac0 eth0: eth0: Type(7) PHY ID 001cc916 at 0 IRQ poll (gmac0-0:00)
[   20.800897] snddaudio snddaudio0: codec: snd-soc-dummy, codec_dai: snd-soc-dummy-dai.
[   20.800912] snddaudio snddaudio0: ASoC: CPU DAI (null) not registered
[   20.800917] snddaudio snddaudio0: snd_soc_register_card failed
[   21.896241] AICWFDBG(LOGTRACE)       >>> rwnx_mod_init()
[   21.901709] AICWFDBG(LOGINFO)        rwnx v6.4.3.0 - - 241c091M (master)
[   21.908735] AICWFDBG(LOGINFO)        RELEASE_DATE:2024_0712_e2a932c1
[   21.915608] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array Enter
[   21.921875] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[0]:ffffff8000e2c900
[   21.930461] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[1]:ffffff8000e2c960
[   21.938967] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[2]:ffffff8000e2c9c0
[   21.947524] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[3]:ffffff8000e2ca20
[   21.956035] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[4]:ffffff8000e2ca80
[   21.964617] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[5]:ffffff8000e2cae0
[   21.973122] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[6]:ffffff8000e2cb40
[   21.981784] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[7]:ffffff8000e2cba0
[   21.990301] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[8]:ffffff8000e2cc00
[   21.998870] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[9]:ffffff8000e2cc60
[   22.007378] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[10]:ffffff8000e2ccc0
[   22.016036] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[11]:ffffff8000e2cd20
[   22.024636] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[12]:ffffff8000e2cd80
[   22.033276] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[13]:ffffff8000e2cde0
[   22.041902] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[14]:ffffff8000e2ce40
[   22.050550] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[15]:ffffff8000e2cea0
[   22.059115] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[16]:ffffff8000e2cf00
[   22.067726] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[17]:ffffff8000e2cf60
[   22.076310] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[18]:ffffff8000e2cfc0
[   22.084989] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[19]:ffffff8000e2d020
[   22.093661] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[20]:ffffff8000e2d080
[   22.102266] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[21]:ffffff8000e2d0e0
[   22.110851] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[22]:ffffff8000e2d140
[   22.119436] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[23]:ffffff8000e2d1a0
[   22.128009] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[24]:ffffff8000e2d200
[   22.136582] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[25]:ffffff8000e2d260
[   22.145178] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[26]:ffffff8000e2d2c0
[   22.153835] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[27]:ffffff8000e2d320
[   22.162498] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[28]:ffffff8000e2d380
[   22.171108] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[29]:ffffff8000e2d3e0
[   22.179750] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[30]:ffffff8000e2d440
[   22.188383] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[31]:ffffff8000e2d4a0
[   22.197058] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[32]:ffffff8000e2d500
[   22.205740] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[33]:ffffff8000e2d560
[   22.214389] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[34]:ffffff8000e2d5c0
[   22.223056] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[35]:ffffff8000e2d620
[   22.231944] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[36]:ffffff8000e2d680
[   22.240589] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[37]:ffffff8000e2d6e0
[   22.249266] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[38]:ffffff8000e2d740
[   22.257904] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[39]:ffffff8000e2d7a0
[   22.266573] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array Exit
[   22.272681] aicbsp: aicbsp_set_subsys, subsys: AIC_WIFI, state to: 1
[   22.279923] aicbsp: aicbsp_set_subsys, power state change to 1 dure to AIC_WIFI
[   22.288171] aicbsp: aicbsp_platform_power_on
[   22.292993] sunxi-wlan soc@03000000:wlan@0: bus_index: 1
[   22.406805] sunxi-wlan soc@03000000:wlan@0: check wlan wlan_power voltage: 1900000
[   22.480711] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   22.511126] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   22.538570] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[   22.545360] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[   22.555640] type=1400 audit(1733305014.650:96): avc: denied { getattr } for comm="system_server" path="/sys/devices/platform/soc/twi3/i2c-3/3-0051/rtc/rtc0/hctosys" dev="sysfs" ino=21117 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[   22.557299] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   22.568263] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   22.598825] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[   22.598942] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[   22.599150] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[   22.601324] mmc2: new high speed SDIO card at address 390b
[   22.612677] snddaudio snddaudio0: codec: snd-soc-dummy, codec_dai: snd-soc-dummy-dai.
[   22.612693] snddaudio snddaudio0: ASoC: CPU DAI (null) not registered
[   22.612698] snddaudio snddaudio0: snd_soc_register_card failed
[   22.624319] snddaudio snddaudio0: codec: snd-soc-dummy, codec_dai: snd-soc-dummy-dai.
[   22.624334] snddaudio snddaudio0: ASoC: CPU DAI (null) not registered
[   22.624339] snddaudio snddaudio0: snd_soc_register_card failed
[   22.632664] aicbsp: aicbsp_sdio_probe:1 vid:0xC8A1  did:0x0082
[   22.632751] aicbsp: aicbsp_sdio_probe:2 vid:0xC8A1  did:0x0182
[   22.632754] aicbsp: aicbsp_sdio_probe after replace:1
[   22.632759] AICWFDBG(LOGINFO)        aicwf_sdio_chipmatch USE AIC8800D80
[   22.632764] aicbsp: aicbsp_get_feature, set FEATURE_SDIO_CLOCK 150 MHz
[   22.632767] aicbsp: aicwf_sdio_reg_init
[   22.633947] snddaudio snddaudio0: codec: snd-soc-dummy, codec_dai: snd-soc-dummy-dai.
[   22.633962] snddaudio snddaudio0: ASoC: CPU DAI (null) not registered
[   22.633967] snddaudio snddaudio0: snd_soc_register_card failed
[   22.636187] AICWFDBG(LOGINFO)        aicbsp: aicbsp_driver_fw_init, chip rev: 7
[   22.636195] rwnx_load_firmware :firmware path = /vendor/etc/firmware/fw_patch_table_8800d80_u02.bin
[   22.639597] file md5:313babc74ae8b1d44dc0e0a4c4c73686
[   22.639707] rwnx_plat_bin_fw_upload_android
[   22.639712] rwnx_load_firmware :firmware path = /vendor/etc/firmware/fw_adid_8800d80_u02.bin
[   22.640442] file md5:f546881a81b960d89a672578eb45a809
[   22.641951] rwnx_plat_bin_fw_upload_android
[   22.641958] rwnx_load_firmware :firmware path = /vendor/etc/firmware/fw_patch_8800d80_u02.bin
[   22.644338] file md5:8e83d7b94620c2a5444b2aaaab1a510d
[   22.849795] type=1400 audit(1733305018.050:97): avc: denied { getattr } for comm="webview_zygote" path="/data/data/com.android.webview" dev="mmcblk0p17" ino=1068 scontext=u:r:webview_zygote:s0 tcontext=u:object_r:app_data_file:s0:c99,c256,c512,c768 tclass=dir permissive=1
[   23.706006] axp803_usb_power: current limit setted: usb pc type
[   23.706006]
[   24.269910] aicbt_patch_table_load bt btmode[3]:5
[   24.281183] aicbt_patch_table_load bt uart_baud[3]:115200
[   24.297300] aicbt_patch_table_load bt uart_flowctrl[3]:1
[   24.314325] aicbt_patch_table_load bt lpm_enable[3]:0
[   24.424044] aicbt_patch_table_load bt tx_pwr[3]:28463
[   24.462749] aicbsp: bt patch version: - Jul 11 2024 10:38:54 - git 73d2ce5
[   24.470653] rwnx_plat_bin_fw_upload_android
[   24.478138] rwnx_load_firmware :firmware path = /vendor/etc/firmware/fmacfw_8800d80_u02.bin
[   24.510099] file md5:b39016c6531b5a0f6f5012eca50bc258
[   24.706566] rd_version_val=06090101
[   24.731561] AICWFDBG(LOGDEBUG)       aicwf_sdio_probe:1
[   24.737028] AICWFDBG(LOGDEBUG)       Class=7
[   24.741367] AICWFDBG(LOGDEBUG)       sdio vendor ID: 0xc8a1
[   24.751448] AICWFDBG(LOGDEBUG)       sdio device ID: 0x0082
[   24.757303] AICWFDBG(LOGDEBUG)       Function#: 1
[   24.762144] AICWFDBG(LOGINFO)        aicwf_sdio_chipmatch USE AIC8800D80
[   24.763909] aicbsp: sdio_err:<aicwf_sdio_bus_pwrctl,1402>: bus down
[   24.776501] aicbsp: aicbsp_get_feature, set FEATURE_SDIO_CLOCK 150 MHz
[   24.784426] aicsdio: aicwf_sdio_reg_init
[   24.794027] AICWFDBG(LOGINFO)        sdio ready
[   24.798585] aicwf_prealloc_init enter
[   24.803127] pre alloc rxbuff list len: 30
[   24.807700] aicbsp: aicbsp_resv_mem_alloc_skb, alloc resv_mem_txdata succuss, id: 0, size: 98304
[   24.819584] AICWFDBG(LOGINFO)        sdio_bustx_thread the policy of current thread is:1
[   24.828090] AICWFDBG(LOGINFO)        sdio_bustx_thread the rt_priority of current thread is:1
[   24.828163] AICWFDBG(LOGINFO)        sdio_busrx_thread the policy of current thread is:1
[   24.828165] AICWFDBG(LOGINFO)        sdio_busrx_thread the rt_priority of current thread is:1
[   24.828167] AICWFDBG(LOGINFO)        sdio_busrx_thread the current pid is:3331
[   24.828496] AICWFDBG(LOGTRACE)       >>> rwnx_platform_init()
[   24.828500] AICWFDBG(LOGTRACE)       >>> rwnx_cfg80211_init()
[   24.828628] aicbsp: aicbsp_get_feature, set FEATURE_SDIO_CLOCK 150 MHz
[   24.828643] AICWFDBG(LOGINFO)        rwnx_cfg80211_init sizeof(struct rwnx_hw):17784
[   24.828777] AICWFDBG(LOGTRACE)       >>> rwnx_init_aic()
[   24.828784] AICWFDBG(LOGTRACE)       >>> rwnx_cmd_mgr_init()
[   24.833600] tcp_ack_init
[   24.833610] AICWFDBG(LOGINFO)        aicwf_prealloc_txq_alloc size is diff will to be kzalloc
[   24.833634] AICWFDBG(LOGINFO)        aicwf_prealloc_txq_alloc txq kzalloc successful
[   24.845622] AICWFDBG(LOGTRACE)       >>> rwnx_send_dbg_mem_read_req()
[   24.845629] AICWFDBG(LOGTRACE)       rwnx_send_msg (1025)DBG_MEM_READ_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   24.845638] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   24.947619] AICWFDBG(LOGINFO)        sdio_bustx_thread the current pid is:3330
[   24.955470] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x401
[   24.962356] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   24.970760] AICWFDBG(LOGTRACE)       >>> rwnx_send_dbg_mem_read_req()
[   24.977479] AICWFDBG(LOGTRACE)       rwnx_send_msg (1025)DBG_MEM_READ_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   24.990279] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   24.999945] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x401
[   25.006889] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   25.015037] AICWFDBG(LOGINFO)        FDRV chip_id=7, chip_sub_id=2!!
[   25.021566] AICWFDBG(LOGTRACE)       >>> rwnx_platform_on()
[   25.027295] AICWFDBG(LOGINFO)        userconfig file path:aic_userconfig_8800d80.txt
[   25.035555] AICWFDBG(LOGINFO)        ### Load file aic_userconfig_8800d80.txt
[   25.042980] AICWFDBG(LOGINFO)        rwnx_load_firmware :firmware path = /vendor/etc/firmware/aic_userconfig_8800d80.txt
[   25.056857] AICWFDBG(LOGINFO)        file md5:35c8e99f3edd34d2a39bc9920e1da494
[   25.064702] AICWFDBG(LOGINFO)        ### Load file done: aic_userconfig_8800d80.txt, size=2683
[   25.073751] AICWFDBG(LOGINFO)        rwnx_plat_userconfig_parsing3: AIC USERCONFIG 2022/0803/1707
[   25.083501] AICWFDBG(LOGINFO)        rwnx_plat_userconfig_parsing3: txpwr_lvl
[   25.090940] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=enable value=1
[   25.099694] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11b_11ag_1m_2g4 value=18
[   25.109518] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11b_11ag_2m_2g4 value=18
[   25.119728] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11b_11ag_5m5_2g4 value=18
[   25.129802] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11b_11ag_11m_2g4 value=18
[   25.139710] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11b_11ag_6m_2g4 value=18
[   25.149479] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11b_11ag_9m_2g4 value=18
[   25.159410] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11b_11ag_12m_2g4 value=18
[   25.169533] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11b_11ag_18m_2g4 value=18
[   25.179603] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11b_11ag_24m_2g4 value=16
[   25.189505] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11b_11ag_36m_2g4 value=16
[   25.199409] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11b_11ag_48m_2g4 value=15
[   25.209275] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11b_11ag_54m_2g4 value=15
[   25.220404] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs0_2g4 value=18
[   25.230717] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs1_2g4 value=18
[   25.241127] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs2_2g4 value=18
[   25.251502] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs3_2g4 value=18
[   25.261535] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs4_2g4 value=16
[   25.272512] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs5_2g4 value=16
[   25.283110] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs6_2g4 value=15
[   25.293120] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs7_2g4 value=15
[   25.303469] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs8_2g4 value=14
[   25.313727] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs9_2g4 value=14
[   25.323720] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs0_2g4 value=18
[   25.333625] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs1_2g4 value=18
[   25.343232] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs2_2g4 value=18
[   25.353204] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs3_2g4 value=18
[   25.363165] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs4_2g4 value=16
[   25.372793] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs5_2g4 value=16
[   25.382513] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs6_2g4 value=15
[   25.392110] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs7_2g4 value=15
[   25.401674] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs8_2g4 value=14
[   25.411246] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs9_2g4 value=14
[   25.421068] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs10_2g4 value=13
[   25.430970] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs11_2g4 value=13
[   25.440620] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11a_6m_5g value=18
[   25.449834] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11a_9m_5g value=18
[   25.459007] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11a_12m_5g value=18
[   25.468300] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11a_18m_5g value=18
[   25.477567] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11a_24m_5g value=16
[   25.486902] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11a_36m_5g value=16
[   25.496162] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11a_48m_5g value=15
[   25.505715] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11a_54m_5g value=15
[   25.515138] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs0_5g value=18
[   25.525086] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs1_5g value=18
[   25.534969] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs2_5g value=18
[   25.544822] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs3_5g value=18
[   25.554720] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs4_5g value=16
[   25.564632] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs5_5g value=16
[   25.574486] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs6_5g value=15
[   25.584599] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs7_5g value=15
[   25.594487] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs8_5g value=14
[   25.604521] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs9_5g value=14
[   25.614394] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs0_5g value=18
[   25.623939] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs1_5g value=18
[   25.633425] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs2_5g value=18
[   25.642876] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs3_5g value=18
[   25.652358] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs4_5g value=16
[   25.661808] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs5_5g value=16
[   25.671574] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs6_5g value=14
[   25.681196] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs7_5g value=14
[   25.690649] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs8_5g value=13
[   25.700178] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs9_5g value=13
[   25.709681] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs10_5g value=12
[   25.719276] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs11_5g value=12
[   25.728855] AICWFDBG(LOGINFO)        rwnx_plat_userconfig_parsing3: txpwr_lvl_adj
[   25.736701] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_adj_enable value=0
[   25.745890] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_adj_2g4_chan_1_4 value=0
[   25.755954] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_adj_2g4_chan_5_9 value=0
[   25.765893] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_adj_2g4_chan_10_13 value=0
[   25.775922] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_adj_5g_chan_42 value=0
[   25.785511] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_adj_5g_chan_58 value=0
[   25.795097] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_adj_5g_chan_106 value=0
[   25.805798] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_adj_5g_chan_122 value=0
[   25.816543] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_adj_5g_chan_138 value=0
[   25.826264] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_adj_5g_chan_155 value=0
[   25.836295] AICWFDBG(LOGINFO)        rwnx_plat_userconfig_parsing3: txpwr_loss
[   25.843858] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=loss_enable value=0
[   25.853098] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=loss_value value=2
[   25.861949] AICWFDBG(LOGINFO)        rwnx_plat_userconfig_parsing3: txpwr_ofst
[   25.869786] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_enable value=0
[   25.878693] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_2g4_11b_chan_1_4 value=0
[   25.888638] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_2g4_11b_chan_5_9 value=0
[   25.898525] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_2g4_11b_chan_10_13 value=0
[   25.908681] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_2g4_ofdm_highrate_chan_1_4 value=0
[   25.919831] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_2g4_ofdm_highrate_chan_5_9 value=0
[   25.930853] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_2g4_ofdm_highrate_chan_10_13 value=0
[   25.942179] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_2g4_ofdm_lowrate_chan_1_4 value=0
[   25.953372] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_2g4_ofdm_lowrate_chan_5_9 value=0
[   25.964287] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_2g4_ofdm_lowrate_chan_10_13 value=0
[   25.975544] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_5g_ofdm_lowrate_chan_42 value=0
[   25.986474] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_5g_ofdm_lowrate_chan_58 value=0
[   25.997227] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_5g_ofdm_lowrate_chan_106 value=0
[   26.008148] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_5g_ofdm_lowrate_chan_122 value=0
[   26.018994] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_5g_ofdm_lowrate_chan_138 value=0
[   26.029699] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_5g_ofdm_lowrate_chan_155 value=0
[   26.040368] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_5g_ofdm_highrate_chan_42 value=0
[   26.051271] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_5g_ofdm_highrate_chan_58 value=0
[   26.062001] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_5g_ofdm_highrate_chan_106 value=0
[   26.073681] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_5g_ofdm_highrate_chan_122 value=0
[   26.084875] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_5g_ofdm_highrate_chan_138 value=0
[   26.096620] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_5g_ofdm_highrate_chan_155 value=0
[   26.107409] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_5g_ofdm_midrate_chan_42 value=0
[   26.118258] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_5g_ofdm_midrate_chan_58 value=0
[   26.128821] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_5g_ofdm_midrate_chan_106 value=0
[   26.139733] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_5g_ofdm_midrate_chan_122 value=0
[   26.150469] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_5g_ofdm_midrate_chan_138 value=0
[   26.161295] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_5g_ofdm_midrate_chan_155 value=0
[   26.172284] AICWFDBG(LOGINFO)        rwnx_plat_userconfig_parsing3: xtal cap
[   26.179800] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=xtal_enable value=0
[   26.188739] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=xtal_cap value=24
[   26.197415] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=xtal_cap_fine value=31
[   26.206611] AICWFDBG(LOGINFO)        userconfig download complete
[   26.206611]
[   26.214481] AICWFDBG(LOGTRACE)       rwnx_send_msg (124)MM_SET_STACK_START_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   26.226285] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   26.235464] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x7c
[   26.242323] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   26.250567] AICWFDBG(LOGINFO)        is 5g support = 1, vendor_info = 0x21
[   26.257597] AICWFDBG(LOGTRACE)       rwnx_send_msg (129)MM_GET_FW_VERSION_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   26.269473] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   26.278245] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x81
[   26.285041] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   26.293124] AICWFDBG(LOGINFO)        Firmware Version: la Jul 03 2024 15:25:18 - g21266be
[   26.302741] AICWFDBG(LOGTRACE)       >>> rwnx_send_txpwr_lvl_v3_req()
[   26.309433] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:enable:1
[   26.317379] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11b_11ag_1m_2g4:18
[   26.326569] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11b_11ag_2m_2g4:18
[   26.336288] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11b_11ag_5m5_2g4:18
[   26.345895] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11b_11ag_11m_2g4:18
[   26.355488] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11b_11ag_6m_2g4:18
[   26.364762] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11b_11ag_9m_2g4:18
[   26.373943] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11b_11ag_12m_2g4:18
[   26.383459] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11b_11ag_18m_2g4:18
[   26.392785] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11b_11ag_24m_2g4:16
[   26.402399] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11b_11ag_36m_2g4:16
[   26.411953] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11b_11ag_48m_2g4:15
[   26.421604] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11b_11ag_54m_2g4:15
[   26.430977] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs0_2g4:18
[   26.440677] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs1_2g4:18
[   26.450414] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs2_2g4:18
[   26.460099] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs3_2g4:18
[   26.469918] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs4_2g4:16
[   26.479480] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs5_2g4:16
[   26.489182] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs6_2g4:15
[   26.498908] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs7_2g4:15
[   26.499284] init: processing action (sys.boot_completed=1) from (/init.rc:800)
[   26.499374] init: processing action (sys.boot_completed=1) from (/vendor/etc/init/hw/init.device.rc:54)
[   26.502461] init: Command 'write /sys/class/gpio/export 66' action=sys.boot_completed=1 (/vendor/etc/init/hw/init.device.rc:60) took 0ms and failed: Unable to write to file '/sys/class/gpio/export': Unable to write file contents: Device or resource busy
[   26.503255] init: Command 'write /sys/class/gpio/export 67' action=sys.boot_completed=1 (/vendor/etc/init/hw/init.device.rc:61) took 0ms and failed: Unable to write to file '/sys/class/gpio/export': Unable to write file contents: Device or resource busy
[   26.506224] init: Command 'write /sys/class/gpio/export 68' action=sys.boot_completed=1 (/vendor/etc/init/hw/init.device.rc:70) took 0ms and failed: Unable to write to file '/sys/class/gpio/export': Unable to write file contents: Device or resource busy
[   26.511515] init: Command 'write /sys/class/gpio/export 76' action=sys.boot_completed=1 (/vendor/etc/init/hw/init.device.rc:71) took 5ms and failed: Unable to write to file '/sys/class/gpio/export': Unable to write file contents: Device or resource busy
[   26.519515] init: processing action (sys.boot_completed=1) from (/system/etc/init/aw_thermal.rc:10)
[   26.519658] init: starting service 'aw_thermal'...
[   26.525641] init: processing action (sys.boot_completed=1 && sys.logbootcomplete=1) from (/system/etc/init/bootstat.rc:78)
[   26.526435] init: starting service 'exec 11 (/system/bin/bootstat --record_boot_complete --record_boot_reason --record_time_since_factory_reset -l)'...
[   26.533575] sdcardfs version 2.0
[   26.533582] sdcardfs: dev_name -> /data/media
[   26.533585] sdcardfs: options -> fsuid=1023,fsgid=1023,multiuser,derive_gid,default_normal,unshared_obb,mask=6,userid=0,gid=1015
[   26.533589] sdcardfs: mnt -> ffffffc072e741e0
[   26.533668] sdcardfs: mounted on top of /data/media type f2fs
[   26.534809] Remount options were mask=23,gid=9997 for vfsmnt ffffffc072e75c20.
[   26.534822] sdcardfs : options - debug:1
[   26.534825] sdcardfs : options - gid:9997
[   26.534827] sdcardfs : options - mask:23
[   26.535273] Remount options were mask=7,gid=9997 for vfsmnt ffffffc07382ec60.
[   26.535278] sdcardfs : options - debug:1
[   26.535280] sdcardfs : options - gid:9997
[   26.535282] sdcardfs : options - mask:7
[   26.535747] Remount options were mask=7,gid=9997 for vfsmnt ffffffc073718020.
[   26.535752] sdcardfs : options - debug:1
[   26.535754] sdcardfs : options - gid:9997
[   26.535756] sdcardfs : options - mask:7
[   26.773429] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs8_2g4:14
[   26.782804] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs9_2g4:14
[   26.792116] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs0_2g4:18
[   26.801051] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs1_2g4:18
[   26.809971] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs2_2g4:18
[   26.818894] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs3_2g4:18
[   26.827886] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs4_2g4:16
[   26.836922] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs5_2g4:16
[   26.845962] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs6_2g4:15
[   26.855006] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs7_2g4:15
[   26.863999] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs8_2g4:14
[   26.872974] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs9_2g4:14
[   26.881947] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs10_2g4:13
[   26.891005] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs11_2g4:13
[   26.900091] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11a_1m_5g:-128
[   26.908887] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11a_2m_5g:-128
[   26.917649] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11a_5m5_5g:-128
[   26.926532] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11a_11m_5g:-128
[   26.935431] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11a_6m_5g:18
[   26.944003] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11a_9m_5g:18
[   26.952594] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11a_12m_5g:18
[   26.961336] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11a_18m_5g:18
[   26.970042] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11a_24m_5g:16
[   26.978723] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11a_36m_5g:16
[   26.987384] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11a_48m_5g:15
[   26.996052] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11a_54m_5g:15
[   27.004721] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs0_5g:18
[   27.013982] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs1_5g:18
[   27.023246] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs2_5g:18
[   27.032496] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs3_5g:18
[   27.041794] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs4_5g:16
[   27.051107] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs5_5g:16
[   27.060373] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs6_5g:15
[   27.069653] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs7_5g:15
[   27.078980] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs8_5g:14
[   27.088260] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs9_5g:14
[   27.097498] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs0_5g:18
[   27.106405] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs1_5g:18
[   27.115282] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs2_5g:18
[   27.124151] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs3_5g:18
[   27.133013] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs4_5g:16
[   27.141891] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs5_5g:16
[   27.150745] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs6_5g:14
[   27.159673] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs7_5g:14
[   27.168616] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs8_5g:13
[   27.177488] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs9_5g:13
[   27.186384] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs10_5g:12
[   27.195363] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs11_5g:12
[   27.204348] AICWFDBG(LOGINFO)        get_userconfig_txpwr_loss:loss_enable:0
[   27.211710] AICWFDBG(LOGINFO)        get_userconfig_txpwr_loss:loss_value:2
[   27.218924] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:enable:1
[   27.225926] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11b_11ag_1m_2g4:18
[   27.234204] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11b_11ag_2m_2g4:18
[   27.242552] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11b_11ag_5m5_2g4:18
[   27.251302] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11b_11ag_11m_2g4:18
[   27.259788] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11b_11ag_6m_2g4:18
[   27.268667] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11b_11ag_9m_2g4:18
[   27.277025] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11b_11ag_12m_2g4:18
[   27.286033] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11b_11ag_18m_2g4:18
[   27.294974] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11b_11ag_24m_2g4:16
[   27.304009] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11b_11ag_36m_2g4:16
[   27.313037] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11b_11ag_48m_2g4:15
[   27.321476] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11b_11ag_54m_2g4:15
[   27.329940] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs0_2g4:18
[   27.338537] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs1_2g4:18
[   27.347120] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs2_2g4:18
[   27.355688] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs3_2g4:18
[   27.364254] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs4_2g4:16
[   27.372935] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs5_2g4:16
[   27.381913] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs6_2g4:15
[   27.391336] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs7_2g4:15
[   27.399957] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs8_2g4:14
[   27.409037] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs9_2g4:14
[   27.418246] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs0_2g4:18
[   27.432537] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs1_2g4:18
[   27.441027] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs2_2g4:18
[   27.449928] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs3_2g4:18
[   27.458621] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs4_2g4:16
[   27.468676] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs5_2g4:16
[   27.480474] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs6_2g4:15
[   27.488836] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs7_2g4:15
[   27.497722] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs8_2g4:14
[   27.506475] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs9_2g4:14
[   27.515088] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs10_2g4:13
[   27.524112] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs11_2g4:13
[   27.534372] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11a_1m_5g:-128
[   27.542857] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11a_2m_5g:-128
[   27.551450] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11a_5m5_5g:-128
[   27.559590] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11a_11m_5g:-128
[   27.569035] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11a_6m_5g:18
[   27.576980] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11a_9m_5g:18
[   27.588499] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11a_12m_5g:18
[   27.596894] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11a_18m_5g:18
[   27.605860] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11a_24m_5g:16
[   27.617934] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11a_36m_5g:16
[   27.631156] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11a_48m_5g:15
[   27.639608] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11a_54m_5g:15
[   27.647935] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs0_5g:18
[   27.656359] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs1_5g:18
[   27.665382] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs2_5g:18
[   27.674509] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs3_5g:18
[   27.683530] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs4_5g:16
[   27.692056] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs5_5g:16
[   27.701079] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs6_5g:15
[   27.709519] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs7_5g:15
[   27.718406] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs8_5g:14
[   27.726847] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs9_5g:14
[   27.735655] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs0_5g:18
[   27.743715] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs1_5g:18
[   27.752478] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs2_5g:18
[   27.760560] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs3_5g:18
[   27.769230] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs4_5g:16
[   27.777311] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs5_5g:16
[   27.785359] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs6_5g:14
[   27.794336] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs7_5g:14
[   27.815144] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs8_5g:13
[   27.823406] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs9_5g:13
[   27.831709] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs10_5g:12
[   27.840035] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs11_5g:12
[   27.848582] AICWFDBG(LOGTRACE)       rwnx_send_msg (120)MM_SET_TXPWR_IDX_LVL_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   27.861160] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   27.870669] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x78
[   27.877440] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   27.892890] AICWFDBG(LOGTRACE)       >>> rwnx_send_txpwr_lvl_adj_req()
[   27.914340] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_adj_in_fdrv:enable:0
[   27.922786] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_adj_in_fdrv:lvl_adj_2g4_chan_1_4:0
[   27.934483] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_adj_in_fdrv:lvl_adj_2g4_chan_5_9:0
[   27.944282] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_adj_in_fdrv:lvl_adj_2g4_chan_10_13:0
[   27.956352] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_adj_in_fdrv:lvl_adj_5g_chan_42:0
[   27.967430] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_adj_in_fdrv:lvl_adj_5g_chan_58:0
[   27.977049] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_adj_in_fdrv:lvl_adj_5g_chan_106:0
[   28.013963] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_adj_in_fdrv:lvl_adj_5g_chan_122:0
[   28.028935] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_adj_in_fdrv:lvl_adj_5g_chan_138:0
[   28.038452] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_adj_in_fdrv:lvl_adj_5g_chan_155:0
[   28.048426] AICWFDBG(LOGTRACE)       >>> rwnx_msg_free()
[   28.057273] AICWFDBG(LOGTRACE)       >>> rwnx_send_txpwr_ofst2x_req()
[   28.063939] AICWFDBG(LOGINFO)        get_userconfig_txpwr_ofst2x_in_fdrv:enable      :0
[   28.089546] AICWFDBG(LOGINFO)        pwrofst2x 2.4g: [0]:11b, [1]:ofdm_highrate, [2]:ofdm_lowrate
  chan= 1-4     5-9     10-13AICWFDBG(LOGINFO)
  [0] =AICWFDBG(LOGINFO)                0AICWFDBG(LOGINFO)              0AICWFDBG(LOGINFO)              0AICWFDBG(LOGINFO)
  [1] =AICWFDBG(LOGINFO)                0AICWFDBG(LOGINFO)              0AICWFDBG(LOGINFO)              0AICWFDBG(LOGINFO)
  [2] =AICWFDBG(LOGINFO)                0AICWFDBG(LOGINFO)              0AICWFDBG(LOGINFO)              0AICWFDBG(LOGINFO)
pwrofst2x 5g: [0]:ofdm_lowrate, [1]:ofdm_highrate, [2]:ofdm_midrate
  chan= 36-50   51-64   98-114  115-130 131-146 147-166AICWFDBG(LOGINFO)
  [0] =AICWFDBG(LOGINFO)                0AICWFDBG(LOGINFO)              0AICWFDBG(LOGINFO)              0AICWFDBG(LOGINFO)              0AICWFDBG(LOGINFO)              0AICWFDBG(LOGINFO)        0AICWFDBG(LOGINFO)
  [1] =AICWFDBG(LOGINFO)                0AICWFDBG(LOGINFO)              0AICWFDBG(LOGINFO)              0AICWFDBG(LOGINFO)              0AICWFDBG(LOGINFO)              0AICWFDBG(LOGINFO)        0AICWFDBG(LOGINFO)
  [2] =AICWFDBG(LOGINFO)                0AICWFDBG(LOGINFO)              0AICWFDBG(LOGINFO)              0AICWFDBG(LOGINFO)              0AICWFDBG(LOGINFO)              0AICWFDBG(LOGINFO)        0AICWFDBG(LOGINFO)
[   28.195388] AICWFDBG(LOGINFO)        rwnx_send_txpwr_ofst2x_req:Do not use txpwr_ofst2x
[   28.204254] AICWFDBG(LOGTRACE)       >>> rwnx_msg_free()
[   28.209705] AICWFDBG(LOGTRACE)       >>> rwnx_send_rf_calib_req()
[   28.216214] AICWFDBG(LOGINFO)        get_userconfig_xtal_cap:enable       :0
[   28.223595] AICWFDBG(LOGINFO)        get_userconfig_xtal_cap:xtal_cap     :0
[   28.230968] AICWFDBG(LOGINFO)        get_userconfig_xtal_cap:xtal_cap_fine:0
[   28.238289] AICWFDBG(LOGTRACE)       rwnx_send_msg (106)MM_SET_RF_CALIB_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   28.249880] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   28.416672] BOOTEVENT:     28416.656140: OFF
[   29.047710] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x6a
[   29.054587] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   29.062952] AICWFDBG(LOGTRACE)       >>> rwnx_send_get_macaddr_req()
[   29.070349] AICWFDBG(LOGTRACE)       rwnx_send_msg (116)MM_GET_MAC_ADDR_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   29.083528] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   29.093940] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x74
[   29.102272] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   29.114245] AICWFDBG(LOGINFO)        get macaddr: 40:9c:a7:38:78:54
[   29.121520] AICWFDBG(LOGTRACE)       >>> rwnx_send_reset()
[   29.127238] AICWFDBG(LOGTRACE)       rwnx_send_msg (1)MM_RESET_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   29.138165] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   29.147666] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1
[   29.154510] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   29.162541] AICWFDBG(LOGTRACE)       >>> rwnx_send_version_req()
[   29.168870] AICWFDBG(LOGTRACE)       rwnx_send_msg (5)MM_VERSION_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   29.180147] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   29.189087] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x5
[   29.195847] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   29.203917] AICWFDBG(LOGTRACE)       >>> rwnx_set_vers()
[   29.209309] AICWFDBG(LOGTRACE)       >>> rwnx_send_me_config_req()
[   29.215710] ieee80211 phy0: HT supp 1, VHT supp 1, HE supp 0
[   29.222050] AICWFDBG(LOGTRACE)       rwnx_send_msg (5121)ME_CONFIG_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   29.233076] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   29.241936] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1401
[   29.248930] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   29.257601] AICWFDBG(LOGTRACE)       >>> rwnx_send_me_chan_config_req()
[   29.264479] AICWFDBG(LOGTRACE)       rwnx_send_msg (5123)ME_CHAN_CONFIG_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   29.280709] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   29.289827] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1403
[   29.296909] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   29.305842] AICWFDBG(LOGINFO)        getRegdomainFromRwnxDB set ccode:00
[   29.314369] AICWFDBG(LOGINFO)        rwnx_get_countrycode_channels support channel:1 2 3 4 5 6 7 8 9 10 11 12 13 14 36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140 144 149 153 157 161 165
[   29.334724] ieee80211 phy0:
[   29.334724] *******************************************************
[   29.334724] ** CAUTION: USING PERMISSIVE CUSTOM REGULATORY RULES **
[   29.358992] AICWFDBG(LOGTRACE)       >>> rwnx_send_me_chan_config_req()
[   29.366015] AICWFDBG(LOGTRACE)       rwnx_send_msg (5123)ME_CHAN_CONFIG_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   29.377569] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   29.386757] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1403
[   29.393983] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   29.401981] AICWFDBG(LOGTRACE)       >>> rwnx_dbgfs_register()
[   29.408710] AICWFDBG(LOGINFO)        rwnx_interface_add: wlan%d, 2, 10
[   29.415649] AICWFDBG(LOGINFO)        interface add:40 9c a7 38 78 54
[   29.477736] get_txpwr_max:txpwr_max:18
[   29.484661] AICWFDBG(LOGINFO)        New interface create wlan0
[   29.491859] snddaudio snddaudio0: codec: snd-soc-dummy, codec_dai: snd-soc-dummy-dai.
[   29.502313] snddaudio snddaudio0: ASoC: CPU DAI (null) not registered
[   29.510906] snddaudio snddaudio0: snd_soc_register_card failed
[   29.698780] capability: warning: `wpa_supplicant' uses 32-bit capabilities (legacy support in use)
[   29.762485] apexd: Can't open /product/apex for reading : No such file or directory
[   29.765872] AICWFDBG(LOGTRACE)       >>> rwnx_open()
[   29.765877] AICWFDBG(LOGTRACE)       >>> rwnx_send_start()
[   29.765883] AICWFDBG(LOGTRACE)       rwnx_send_msg (3)MM_START_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   29.765893] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   29.771744] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x3
[   29.771779] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   29.771785] AICWFDBG(LOGTRACE)       >>> rwnx_send_coex_req()
[   29.771791] AICWFDBG(LOGTRACE)       rwnx_send_msg (102)MM_SET_COEX_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   29.771796] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   29.772026] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x66
[   29.773007] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   29.773015] AICWFDBG(LOGDEBUG)       rwnx_open rwnx_vif->drv_flags:4
[   29.773018] AICWFDBG(LOGTRACE)       >>> rwnx_send_add_if()
[   29.773023] AICWFDBG(LOGTRACE)       rwnx_send_msg (7)MM_ADD_IF_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   29.773031] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   29.783704] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x7
[   29.783907] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   29.783913] AICWFDBG(LOGDEBUG)       rwnx_open sta create vif in rwnx_hw->vif_table[0]
[   29.860772] get_txpwr_max:txpwr_max:18
[   29.960084] get_txpwr_max:txpwr_max:18
[   29.965353] get_txpwr_max:txpwr_max:18
[   29.972112] get_txpwr_max:txpwr_max:18
[   29.977145] get_txpwr_max:txpwr_max:18
[   29.985292] get_txpwr_max:txpwr_max:18
[   30.054573] rwnx_virtual_interface_add: 10, p2p-dev-wlan0
[   30.060639] rwnx_virtual_interface_add, ifname=p2p-dev-wlan0, wdev=ffffffc04eabe018, vif_idx=1
[   30.070623] p2p dev addr=40 9c a7 38 78 55
[   30.075501] get_txpwr_max:txpwr_max:18
[   30.080156] get_txpwr_max:txpwr_max:18
[   30.091680] get_txpwr_max:txpwr_max:18
[   30.107030] get_txpwr_max:txpwr_max:18
[   30.125679] get_txpwr_max:txpwr_max:18
[   30.176831] get_txpwr_max:txpwr_max:18
[   30.193734] get_txpwr_max:txpwr_max:18
[   30.204523] get_txpwr_max:txpwr_max:18
[   30.213634] P2P interface started
[   30.381214] AICWFDBG(LOGINFO)        IOCTL PRIVATE
[   30.393944] AICWFDBG(LOGTRACE)       >>> android_priv_cmd()
[   30.403707] AICWFDBG(LOGINFO)        android_priv_cmd: Android private cmd "BTCOEXSCAN-STOP" on wlan0
[   30.413793] AICWFDBG(LOGINFO)        cmd = 35313
[   30.420948] AICWFDBG(LOGINFO)        buf_size=4096
[   30.427579] AICWFDBG(LOGTRACE)       >>> handle_private_cmd()
[   30.437580] AICWFDBG(LOGERROR)       Unknown command 'BTCOEXSCAN-STOP'
[   30.455676] AICWFDBG(LOGINFO)        IOCTL PRIVATE
[   30.460476] AICWFDBG(LOGTRACE)       >>> android_priv_cmd()
[   30.466252] AICWFDBG(LOGINFO)        android_priv_cmd: Android private cmd "RXFILTER-STOP" on wlan0
[   30.475808] AICWFDBG(LOGINFO)        cmd = 35313
[   30.480437] AICWFDBG(LOGINFO)        buf_size=4096
[   30.485160] AICWFDBG(LOGTRACE)       >>> handle_private_cmd()
[   30.491077] AICWFDBG(LOGERROR)       Unknown command 'RXFILTER-STOP'
[   30.498891] AICWFDBG(LOGINFO)        IOCTL PRIVATE
[   30.503682] AICWFDBG(LOGTRACE)       >>> android_priv_cmd()
[   30.509420] AICWFDBG(LOGINFO)        android_priv_cmd: Android private cmd "RXFILTER-ADD 2" on wlan0
[   30.519017] AICWFDBG(LOGINFO)        cmd = 35313
[   30.523537] AICWFDBG(LOGINFO)        buf_size=4096
[   30.528316] AICWFDBG(LOGTRACE)       >>> handle_private_cmd()
[   30.534236] AICWFDBG(LOGERROR)       Unknown command 'RXFILTER-ADD'
[   30.542439] AICWFDBG(LOGINFO)        IOCTL PRIVATE
[   30.547191] AICWFDBG(LOGTRACE)       >>> android_priv_cmd()
[   30.553762] AICWFDBG(LOGINFO)        android_priv_cmd: Android private cmd "RXFILTER-START" on wlan0
[   30.563846] AICWFDBG(LOGINFO)        cmd = 35313
[   30.568415] AICWFDBG(LOGINFO)        buf_size=4096
[   30.574652] AICWFDBG(LOGTRACE)       >>> handle_private_cmd()
[   30.580619] AICWFDBG(LOGERROR)       Unknown command 'RXFILTER-START'
[   30.589249] AICWFDBG(LOGINFO)        IOCTL PRIVATE
[   30.594213] AICWFDBG(LOGTRACE)       >>> android_priv_cmd()
[   30.600106] AICWFDBG(LOGINFO)        android_priv_cmd: Android private cmd "RXFILTER-STOP" on wlan0
[   30.609681] AICWFDBG(LOGINFO)        cmd = 35313
[   30.614202] AICWFDBG(LOGINFO)        buf_size=4096
[   30.618921] AICWFDBG(LOGTRACE)       >>> handle_private_cmd()
[   30.624830] AICWFDBG(LOGERROR)       Unknown command 'RXFILTER-STOP'
[   30.632272] AICWFDBG(LOGINFO)        IOCTL PRIVATE
[   30.637069] AICWFDBG(LOGTRACE)       >>> android_priv_cmd()
[   30.642875] AICWFDBG(LOGINFO)        android_priv_cmd: Android private cmd "RXFILTER-ADD 3" on wlan0
[   30.654129] AICWFDBG(LOGINFO)        cmd = 35313
[   30.658857] AICWFDBG(LOGINFO)        buf_size=4096
[   30.663732] AICWFDBG(LOGTRACE)       >>> handle_private_cmd()
[   30.669671] AICWFDBG(LOGERROR)       Unknown command 'RXFILTER-ADD'
[   30.676833] AICWFDBG(LOGINFO)        IOCTL PRIVATE
[   30.681580] AICWFDBG(LOGTRACE)       >>> android_priv_cmd()
[   30.687285] AICWFDBG(LOGINFO)        android_priv_cmd: Android private cmd "RXFILTER-START" on wlan0
[   30.696846] AICWFDBG(LOGINFO)        cmd = 35313
[   30.701354] AICWFDBG(LOGINFO)        buf_size=4096
[   30.706075] AICWFDBG(LOGTRACE)       >>> handle_private_cmd()
[   30.711944] AICWFDBG(LOGERROR)       Unknown command 'RXFILTER-START'
[   30.719387] AICWFDBG(LOGINFO)        IOCTL PRIVATE
[   30.724109] AICWFDBG(LOGTRACE)       >>> android_priv_cmd()
[   30.729792] AICWFDBG(LOGINFO)        android_priv_cmd: Android private cmd "SETSUSPENDMODE 0" on wlan0
[   30.739519] AICWFDBG(LOGINFO)        cmd = 35313
[   30.744020] AICWFDBG(LOGINFO)        buf_size=4096
[   30.810959] type=1400 audit(1733305018.050:97): avc: denied { getattr } for comm="webview_zygote" path="/data/data/com.android.webview" dev="mmcblk0p17" ino=1068 scontext=u:r:webview_zygote:s0 tcontext=u:object_r:app_data_file:s0:c99,c256,c512,c768 tclass=dir permissive=1
[   30.815940] AICWFDBG(LOGTRACE)       >>> rwnx_cfg80211_scan()
[   30.815944] AICWFDBG(LOGTRACE)       >>> rwnx_send_scanu_req()
[   30.815953] AICWFDBG(LOGDEBUG)       scan channel:1(2412)
[   30.815955] AICWFDBG(LOGDEBUG)       scan channel:2(2417)
[   30.815957] AICWFDBG(LOGDEBUG)       scan channel:3(2422)
[   30.815959] AICWFDBG(LOGDEBUG)       scan channel:4(2427)
[   30.815961] AICWFDBG(LOGDEBUG)       scan channel:5(2432)
[   30.815963] AICWFDBG(LOGDEBUG)       scan channel:6(2437)
[   30.815965] AICWFDBG(LOGDEBUG)       scan channel:7(2442)
[   30.815967] AICWFDBG(LOGDEBUG)       scan channel:8(2447)
[   30.815969] AICWFDBG(LOGDEBUG)       scan channel:9(2452)
[   30.815971] AICWFDBG(LOGDEBUG)       scan channel:10(2457)
[   30.815973] AICWFDBG(LOGDEBUG)       scan channel:11(2462)
[   30.815975] AICWFDBG(LOGDEBUG)       scan channel:12(2467)
[   30.815977] AICWFDBG(LOGDEBUG)       scan channel:13(2472)
[   30.815979] AICWFDBG(LOGDEBUG)       scan channel:14(2484)
[   30.815981] AICWFDBG(LOGDEBUG)       scan channel:36(5180)
[   30.815983] AICWFDBG(LOGDEBUG)       scan channel:40(5200)
[   30.815985] AICWFDBG(LOGDEBUG)       scan channel:44(5220)
[   30.815987] AICWFDBG(LOGDEBUG)       scan channel:48(5240)
[   30.815989] AICWFDBG(LOGDEBUG)       scan channel:52(5260)
[   30.815991] AICWFDBG(LOGDEBUG)       scan channel:56(5280)
[   30.815993] AICWFDBG(LOGDEBUG)       scan channel:60(5300)
[   30.815994] AICWFDBG(LOGDEBUG)       scan channel:64(5320)
[   30.815996] AICWFDBG(LOGDEBUG)       scan channel:100(5500)
[   30.815998] AICWFDBG(LOGDEBUG)       scan channel:104(5520)
[   30.816000] AICWFDBG(LOGDEBUG)       scan channel:108(5540)
[   30.816002] AICWFDBG(LOGDEBUG)       scan channel:112(5560)
[   30.816004] AICWFDBG(LOGDEBUG)       scan channel:116(5580)
[   30.816006] AICWFDBG(LOGDEBUG)       scan channel:120(5600)
[   30.816008] AICWFDBG(LOGDEBUG)       scan channel:124(5620)
[   30.816010] AICWFDBG(LOGDEBUG)       scan channel:128(5640)
[   30.816012] AICWFDBG(LOGDEBUG)       scan channel:132(5660)
[   30.816014] AICWFDBG(LOGDEBUG)       scan channel:136(5680)
[   30.816016] AICWFDBG(LOGDEBUG)       scan channel:140(5700)
[   30.816018] AICWFDBG(LOGDEBUG)       scan channel:144(5720)
[   30.816020] AICWFDBG(LOGDEBUG)       scan channel:149(5745)
[   30.816022] AICWFDBG(LOGDEBUG)       scan channel:153(5765)
[   30.816024] AICWFDBG(LOGDEBUG)       scan channel:157(5785)
[   30.816026] AICWFDBG(LOGDEBUG)       scan channel:161(5805)
[   30.816028] AICWFDBG(LOGDEBUG)       scan channel:165(5825)
[   30.816033] AICWFDBG(LOGTRACE)       rwnx_send_msg (4105)SCANU_START_CFM_ADDTIONAL reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   30.816042] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   30.838446] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1009
[   30.838531] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   30.843375] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   30.847299] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   30.878051] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   30.886920] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   30.893457] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   30.918467] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   30.928463] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   30.941297] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   30.963489] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   30.998527] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.005728] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   31.033580] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.055484] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   31.092287] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.103309] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   31.127310] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.162338] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.197359] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.245882] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.252914] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   31.261140] type=1400 audit(1733305026.303:98): avc: granted { read } for comm="main" name="u:object_r:net_dns_prop:s0" dev="tmpfs" ino=421 scontext=u:r:untrusted_app_25:s0:c512,c768 tcontext=u:object_r:net_dns_prop:s0 tclass=file app=com.android.email
[   31.287380] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.322381] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.377409] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.412410] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.419186] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   31.426155] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   31.449237] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   31.456177] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   31.467402] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.502476] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.557464] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.592498] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.627584] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.662535] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.697527] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.732618] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.767575] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.802590] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.837633] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.872596] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.907674] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.942757] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.977680] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   32.012720] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   32.047701] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   32.082753] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   32.117744] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   32.152819] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   32.159589] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   32.166586] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   32.173624] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   32.180683] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   32.187703] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   32.194743] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   32.201733] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   32.242857] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   32.298043] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   32.353072] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   32.388214] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   32.395124] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1001
[   32.402167] AICWFDBG(LOGTRACE)       >>> rwnx_rx_scanu_start_cfm()
[   32.476541] AICWFDBG(LOGTRACE)       >>> rwnx_cfg80211_remain_on_channel_()
[   32.483857] remain:0,0,0
[   32.486737] AICWFDBG(LOGTRACE)       >>> rwnx_send_roc()
[   32.492191] AICWFDBG(LOGTRACE)       rwnx_send_msg (71)MM_REMAIN_ON_CHANNEL_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   32.504110] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   32.513839] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x47
[   32.520611] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x44
[   32.520619] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   32.535671] AICWFDBG(LOGDEBUG)       mgmt xmit d0 0 AICWFDBG(LOGINFO)        need cfm mgmt:d0,user_idx=1, skb=ffffffc04f74ae00
[   32.549673] AICWFDBG(LOGINFO)        sdio_host_tx_cfm_handler:used_idx=0, 0xffffffc040a00700, status=9
[   32.559527] done=1 retry_required=0 sw_retry_required=0 acknowledged=1
[   32.567112] AICWFDBG(LOGTRACE)       >>> rwnx_close()
[   32.572222] aicwf_sdio mmc2:390b:1 wlan0: CLOSE
[   32.577302] rwnx_close clear roc
[   32.580936] AICWFDBG(LOGDEBUG)       rwnx_close rwnx_vif[0] down
[   32.588378] AICWFDBG(LOGTRACE)       >>> rwnx_send_remove_if()
[   32.594466] rwnx_send_msg1 (9)MM_REMOVE_IF_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   32.603859] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   32.612672] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x9
[   32.619371] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   32.627292] AICWFDBG(LOGTRACE)       >>> rwnx_send_coex_req()
[   32.633139] AICWFDBG(LOGTRACE)       rwnx_send_msg (102)MM_SET_COEX_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   32.644248] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   32.653039] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x66
[   32.659778] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   32.667665] AICWFDBG(LOGTRACE)       >>> rwnx_send_reset()
[   32.673324] AICWFDBG(LOGTRACE)       rwnx_send_msg (1)MM_RESET_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   32.684109] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   32.693359] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1
[   32.699998] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   32.707893] AICWFDBG(LOGTRACE)       >>> rwnx_send_me_config_req()
[   32.714214] ieee80211 phy0: HT supp 1, VHT supp 1, HE supp 0
[   32.720544] AICWFDBG(LOGTRACE)       rwnx_send_msg (5121)ME_CONFIG_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   32.731511] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   32.740828] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1401
[   32.747799] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   32.755828] AICWFDBG(LOGTRACE)       >>> rwnx_send_me_chan_config_req()
[   32.762696] AICWFDBG(LOGTRACE)       rwnx_send_msg (5123)ME_CHAN_CONFIG_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   32.774176] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   32.783193] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1403
[   32.790152] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   32.798079] AICWFDBG(LOGDEBUG)       rwnx_close rwnx_vif->drv_flags:0
[   32.805221] AICWFDBG(LOGTRACE)       rwnx_set_mac_address enter
[   32.811585] AICWFDBG(LOGINFO)        rwnx_set_mac_address set D6:EB:B7:0D:F8:AF
[   32.819502] AICWFDBG(LOGTRACE)       >>> rwnx_open()
[   32.824511] AICWFDBG(LOGTRACE)       >>> rwnx_send_start()
[   32.830075] AICWFDBG(LOGTRACE)       rwnx_send_msg (3)MM_START_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   32.840666] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   32.850324] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x3
[   32.856983] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   32.864868] AICWFDBG(LOGTRACE)       >>> rwnx_send_coex_req()
[   32.870697] AICWFDBG(LOGTRACE)       rwnx_send_msg (102)MM_SET_COEX_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   32.881764] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   32.891321] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x66
[   32.898075] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   32.906037] AICWFDBG(LOGDEBUG)       rwnx_open rwnx_vif->drv_flags:4
[   32.912745] AICWFDBG(LOGTRACE)       >>> rwnx_send_add_if()
[   32.918441] AICWFDBG(LOGTRACE)       rwnx_send_msg (7)MM_ADD_IF_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   32.929166] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   32.938293] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x7
[   32.945032] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   32.952993] AICWFDBG(LOGDEBUG)       rwnx_open sta create vif in rwnx_hw->vif_table[0]
[   32.965288] AICWFDBG(LOGTRACE)       >>> rwnx_cfg80211_cancel_remain_on_channel()
[   33.108440] AICWFDBG(LOGTRACE)       >>> rwnx_cfg80211_scan()
[   33.114369] AICWFDBG(LOGTRACE)       >>> rwnx_send_scanu_req()
[   33.120376] AICWFDBG(LOGTRACE)       rwnx_send_msg (4104)SCANU_VENDOR_IE_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   33.132102] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   33.141537] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1008
[   33.148527] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   33.156472] AICWFDBG(LOGDEBUG)       scan channel:1(2412)
[   33.162146] AICWFDBG(LOGDEBUG)       scan channel:2(2417)
[   33.167829] AICWFDBG(LOGDEBUG)       scan channel:3(2422)
[   33.173503] AICWFDBG(LOGDEBUG)       scan channel:4(2427)
[   33.179199] AICWFDBG(LOGDEBUG)       scan channel:5(2432)
[   33.184889] AICWFDBG(LOGDEBUG)       scan channel:6(2437)
[   33.190591] AICWFDBG(LOGDEBUG)       scan channel:7(2442)
[   33.196289] AICWFDBG(LOGDEBUG)       scan channel:8(2447)
[   33.202066] AICWFDBG(LOGDEBUG)       scan channel:9(2452)
[   33.207768] AICWFDBG(LOGDEBUG)       scan channel:10(2457)
[   33.213572] AICWFDBG(LOGDEBUG)       scan channel:11(2462)
[   33.219376] AICWFDBG(LOGDEBUG)       scan channel:12(2467)
[   33.225171] AICWFDBG(LOGDEBUG)       scan channel:13(2472)
[   33.230963] AICWFDBG(LOGDEBUG)       scan channel:14(2484)
[   33.236761] AICWFDBG(LOGDEBUG)       scan channel:36(5180)
[   33.242553] AICWFDBG(LOGDEBUG)       scan channel:40(5200)
[   33.248358] AICWFDBG(LOGDEBUG)       scan channel:44(5220)
[   33.254133] AICWFDBG(LOGDEBUG)       scan channel:48(5240)
[   33.259998] AICWFDBG(LOGDEBUG)       scan channel:52(5260)
[   33.265754] AICWFDBG(LOGDEBUG)       scan channel:56(5280)
[   33.271504] AICWFDBG(LOGDEBUG)       scan channel:60(5300)
[   33.277290] AICWFDBG(LOGDEBUG)       scan channel:64(5320)
[   33.283184] AICWFDBG(LOGDEBUG)       scan channel:100(5500)
[   33.289079] AICWFDBG(LOGDEBUG)       scan channel:104(5520)
[   33.294994] AICWFDBG(LOGDEBUG)       scan channel:108(5540)
[   33.300980] AICWFDBG(LOGDEBUG)       scan channel:112(5560)
[   33.306906] AICWFDBG(LOGDEBUG)       scan channel:116(5580)
[   33.312805] AICWFDBG(LOGDEBUG)       scan channel:120(5600)
[   33.318799] AICWFDBG(LOGDEBUG)       scan channel:124(5620)
[   33.324718] AICWFDBG(LOGDEBUG)       scan channel:128(5640)
[   33.330899] AICWFDBG(LOGDEBUG)       scan channel:132(5660)
[   33.336816] AICWFDBG(LOGDEBUG)       scan channel:136(5680)
[   33.342698] AICWFDBG(LOGDEBUG)       scan channel:140(5700)
[   33.348557] AICWFDBG(LOGDEBUG)       scan channel:144(5720)
[   33.354574] AICWFDBG(LOGDEBUG)       scan channel:149(5745)
[   33.360681] AICWFDBG(LOGDEBUG)       scan channel:153(5765)
[   33.366767] AICWFDBG(LOGDEBUG)       scan channel:157(5785)
[   33.372995] AICWFDBG(LOGDEBUG)       scan channel:161(5805)
[   33.379527] AICWFDBG(LOGDEBUG)       scan channel:165(5825)
[   33.385512] AICWFDBG(LOGTRACE)       rwnx_send_msg (4105)SCANU_START_CFM_ADDTIONAL reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   33.398260] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   33.407059] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1009
[   33.414006] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   33.414007] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   33.414025] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   33.435943] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   33.453571] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   33.462133] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   33.478574] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   33.497297] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   33.532341] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   33.567486] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   33.602570] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   33.614390] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   33.657477] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   33.664220] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   33.673475] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   33.692495] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   33.727669] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   33.763065] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   33.797645] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   33.808600] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   33.853002] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   33.888125] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   33.942616] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   33.977874] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   33.984752] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   33.991815] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   34.009628] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   34.016689] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   34.032838] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.067780] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.123200] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.158103] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.192902] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.227920] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.262637] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.297559] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.332551] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.367608] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.402542] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.437812] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.472874] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.508409] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.543441] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.578177] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.613047] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.648255] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.683522] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.718581] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.725455] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   34.732522] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   34.739585] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   34.753093] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.808504] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.815395] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   34.863609] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.918588] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.952925] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.959719] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1001
[   34.966666] AICWFDBG(LOGTRACE)       >>> rwnx_rx_scanu_start_cfm()
[   34.980946] AICWFDBG(LOGTRACE)       >>> rwnx_cfg80211_connect()
[   34.987167] AICWFDBG(LOGTRACE)       >>> rwnx_send_sm_connect_req()
[   34.993657] rwnx_send_sm_connect_req drv_vif_index:0 connect to whycan(6) channel:2412 auth_type:0
[   35.003933] AICWFDBG(LOGTRACE)       rwnx_send_msg (6145)SM_CONNECT_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   35.015105] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   35.024493] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1801
[   35.031513] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   35.039677] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   35.046454] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   35.329686] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x44
[   35.372385] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1802
[   35.379462] AICWFDBG(LOGTRACE)       >>> rwnx_rx_sm_connect_ind()
[   35.385814] AICWFDBG(LOGINFO)        rwnx_rx_sm_connect_ind ind->status_code:0
[   35.393541] AICWFDBG(LOGINFO)        rwnx_rx_sm_connect_ind ind->roamed:0 ind->status_code:0 rwnx_vif->drv_conn_state:2
[   35.405203] AICWFDBG(LOGINFO)        rwnx_rx_sm_connect_ind cfg80211_connect_result pass, rwnx_vif->drv_conn_state:3
[   35.419611] AICWFDBG(LOGINFO)        need cfm ethertype:    8e88,user_idx=2, skb=ffffffc04f201800
[   35.434120] AICWFDBG(LOGINFO)        sdio_host_tx_cfm_handler:used_idx=1, 0xffffffc040a00700, status=9
[   35.444933] AICWFDBG(LOGINFO)        need cfm ethertype:    8e88,user_idx=3, skb=ffffffc04f201800
[   35.455028] AICWFDBG(LOGTRACE)       >>> rwnx_cfg80211_add_key()
[   35.461324] AICWFDBG(LOGTRACE)       >>> rwnx_send_key_add()
[   35.467383] AICWFDBG(LOGTRACE)       rwnx_send_key_add: sta_idx:0 key_idx:0 inst_nbr:0 cipher:2 key_len:16
[   35.467506] AICWFDBG(LOGINFO)        sdio_host_tx_cfm_handler:used_idx=2, 0xffffffc040a00700, status=9
[   35.487821] key: 00000000: 7d 49 82 46 49 7c f4 45 c9 1e 00 dd 1a b7 c3 0b  }I.FI|.E........
[   35.497411] AICWFDBG(LOGTRACE)       rwnx_send_msg (37)MM_KEY_ADD_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   35.508729] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   35.518256] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x25
[   35.525096] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   35.533588] AICWFDBG(LOGTRACE)       >>> rwnx_cfg80211_set_default_key()
[   35.541929] AICWFDBG(LOGTRACE)       >>> rwnx_cfg80211_add_key()
[   35.548157] AICWFDBG(LOGTRACE)       >>> rwnx_send_key_add()
[   35.553998] AICWFDBG(LOGTRACE)       rwnx_send_key_add: sta_idx:255 key_idx:2 inst_nbr:0 cipher:2 key_len:16
[   35.564778] key: 00000000: b2 63 27 8f ce 76 e0 30 7d 0e 24 cd 8e 85 bc a5  .c'..v.0}.$.....
[   35.574526] AICWFDBG(LOGTRACE)       rwnx_send_msg (37)MM_KEY_ADD_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   35.585743] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   35.595344] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x25
[   35.602150] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   35.610888] AICWFDBG(LOGTRACE)       >>> rwnx_cfg80211_add_key()
[   35.617106] AICWFDBG(LOGTRACE)       >>> rwnx_send_key_add()
[   35.622915] AICWFDBG(LOGTRACE)       rwnx_send_key_add: sta_idx:255 key_idx:5 inst_nbr:0 cipher:5 key_len:16
[   35.633496] key: 00000000: 9a 61 64 f0 f3 06 8f 29 d5 c2 76 6a d2 0a 16 f7  .ad....)..vj....
[   35.643082] AICWFDBG(LOGTRACE)       rwnx_send_msg (37)MM_KEY_ADD_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   35.654135] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   35.664183] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x25
[   35.671131] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   35.680273] AICWFDBG(LOGTRACE)       >>> rwnx_send_me_set_control_port_req()
[   35.687728] AICWFDBG(LOGTRACE)       rwnx_send_msg (5125)ME_SET_CONTROL_PORT_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   35.699869] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   35.708953] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1405
[   35.716058] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   35.773727] AICWFDBG(LOGINFO)        IOCTL PRIVATE
[   35.778507] AICWFDBG(LOGTRACE)       >>> android_priv_cmd()
[   35.784182] AICWFDBG(LOGINFO)        android_priv_cmd: Android private cmd "BTCOEXMODE 2" on wlan0
[   35.793511] AICWFDBG(LOGINFO)        cmd = 35313
[   35.797995] AICWFDBG(LOGINFO)        buf_size=4096
[   35.802667] AICWFDBG(LOGTRACE)       >>> handle_private_cmd()
[   35.808504] AICWFDBG(LOGERROR)       Unknown command 'BTCOEXMODE'
[   35.837463] AICWFDBG(LOGTRACE)       rwnx_send_msg (118)MM_GET_STA_INFO_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   35.849078] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   35.857910] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x76
[   35.864700] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   35.872647] AICWFDBG(LOGDEBUG)       rwnx_fill_station_info ModTx(0):4 TxIndex:8 ModRx(0):0 RxHTIndex:0 RxVHTIndex:0 RxHEIndex:0 RSSI:-28
[   35.937946] nf_conntrack: default automatic helper assignment has been turned off for security reasons and CT-based  firewall rule not found. Use the iptables CT target to attach helpers instead.
[   35.944651] AICWFDBG(LOGINFO)        IOCTL PRIVATE
[   35.944658] AICWFDBG(LOGTRACE)       >>> android_priv_cmd()
[   35.944671] AICWFDBG(LOGINFO)        android_priv_cmd: Android private cmd "BTCOEXMODE 1" on wlan0
[   35.944678] AICWFDBG(LOGINFO)        cmd = 35313
[   35.944681] AICWFDBG(LOGINFO)        buf_size=4096
[   35.944686] AICWFDBG(LOGTRACE)       >>> handle_private_cmd()
[   35.944694] AICWFDBG(LOGERROR)       Unknown command 'BTCOEXMODE'
[   35.945337] AICWFDBG(LOGINFO)        IOCTL PRIVATE
[   35.945343] AICWFDBG(LOGTRACE)       >>> android_priv_cmd()
[   35.945353] AICWFDBG(LOGINFO)        android_priv_cmd: Android private cmd "SETSUSPENDMODE 0" on wlan0
[   35.945359] AICWFDBG(LOGINFO)        cmd = 35313
[   35.945362] AICWFDBG(LOGINFO)        buf_size=4096
[   36.027834] AICWFDBG(LOGINFO)        reord_init_sta:d6:eb:b7:0d:f8:af
[   36.063935] AICWFDBG(LOGINFO)        paired=fac04, should=fac04
[   36.069892] AICWFDBG(LOGTRACE)       >>> rwnx_send_arpoffload_en_req()
[   36.076594] AICWFDBG(LOGTRACE)       rwnx_send_msg (98)MM_SET_ARPOFFLOAD_CFM reqcfm:1 in_irq:0 in_softirq:512 in_atomic:1
[   36.088321] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   36.096928] AICWFDBG(LOGTRACE)       >>> cmd_mgr_task_process()
[   36.103805] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x62
[   36.109414] AICWFDBG(LOGINFO)        IOCTL PRIVATE
[   36.109423] AICWFDBG(LOGTRACE)       >>> android_priv_cmd()
[   36.109444] AICWFDBG(LOGINFO)        android_priv_cmd: Android private cmd "BTCOEXMODE 2" on wlan0
[   36.109453] AICWFDBG(LOGINFO)        cmd = 35313
[   36.109458] AICWFDBG(LOGINFO)        buf_size=4096
[   36.109464] AICWFDBG(LOGTRACE)       >>> handle_private_cmd()
[   36.109475] AICWFDBG(LOGERROR)       Unknown command 'BTCOEXMODE'
[   36.151911] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   36.255434] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x140b
[   36.262424] AICWFDBG(LOGTRACE)       >>> rwnx_rx_me_tx_credits_update_ind()
[   36.315431] init: processing action (sys.sysctl.tcp_def_init_rwnd=*) from (/init.rc:810)
[   37.202384] type=1400 audit(1733305026.303:98): avc: granted { read } for comm="main" name="u:object_r:net_dns_prop:s0" dev="tmpfs" ino=421 scontext=u:r:untrusted_app_25:s0:c512,c768 tcontext=u:object_r:net_dns_prop:s0 tclass=file app=com.android.email
[   37.227511] type=1400 audit(1733305032.696:99): avc: denied { dac_override } for comm="irqbalance" capability=1 scontext=u:r:shell:s0 tcontext=u:r:shell:s0 tclass=capability permissive=1
[   38.909733] AICWFDBG(LOGTRACE)       rwnx_send_msg (118)MM_GET_STA_INFO_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   38.921392] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   38.930910] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x76
[   38.937876] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   38.945939] AICWFDBG(LOGDEBUG)       rwnx_fill_station_info ModTx(0):4 TxIndex:8 ModRx(0):0 RxHTIndex:0 RxVHTIndex:0 RxHEIndex:0 RSSI:-29
楼主 #2 2024-12-04 17:38:41
memory
已发帖子: 487
Re: A133 AW869C 蓝牙开启失败,请问是什么原因呢?
logcat 日志:
[   90.891162] logd: logdr: UID=0 GID=0 PID=4606 b tail=0 logMask=19 pid=0 start=0ns timeout=0ns
--------- beginning of main
12-04 17:37:54.388  2444  2664 E WifiVendorHal: getWifiLinkLayerStats_1_3_Internal(l.926) failed {.code = ERROR_NOT_AVAILABLE, .description = }
12-04 17:37:54.447  2765  2765 W StatusBarIconController: setIconVisibility index: 27
12-04 17:37:55.891  2125  2308 I netd    : trafficSwapActiveStatsMap() <18.41ms>
12-04 17:37:55.898  2125  2308 I netd    : tetherGetStats() <5.08ms>
12-04 17:37:55.925  2125  2308 I netd    : bandwidthSetGlobalAlert(2097152) <1.53ms>
12-04 17:37:56.396  2444  4583 I system_server: The ClassLoaderContext is a special shared library.
12-04 17:37:56.680  2444  4583 I chatty  : uid=1000 system_server identical 5 lines
12-04 17:37:56.690  2444  4583 I system_server: The ClassLoaderContext is a special shared library.
12-04 17:37:56.726  2444  4583 I BackgroundDexOptService: Pinning optimized code {}
12-04 17:37:57.450  2444  2664 E WifiVendorHal: getWifiLinkLayerStats_1_3_Internal(l.926) failed {.code = ERROR_NOT_AVAILABLE, .description = }
12-04 17:37:57.522  2765  2765 W StatusBarIconController: setIconVisibility index: 27
12-04 17:37:58.920  2444  2470 D WificondControl: Scan result ready event
12-04 17:37:58.961  3999  3999 I wpa_supplicant: wlan0: GAS-QUERY-START addr=dc:d8:7c:4c:10:3a dialog_token=6 freq=2437
12-04 17:37:58.963  2444  2664 D HS20    : ANQP initiated on dc:d8:7c:4c:10:3a
12-04 17:37:58.964  2444  2664 D PasspointManager: ANQP entry not found for: dc:d8:7c:4c:10:3a:<1613>
12-04 17:37:59.015  3999  3999 I wpa_supplicant: wlan0: GAS-QUERY-START addr=de:d8:7c:3c:10:3a dialog_token=7 freq=5180
12-04 17:37:59.016  2444  2664 D HS20    : ANQP initiated on de:d8:7c:3c:10:3a
12-04 17:37:59.017  2444  2664 D PasspointManager: ANQP entry not found for: de:d8:7c:3c:10:3a:<1613>
12-04 17:37:59.029  2444  2664 D ANQPRequestManager: Not allowed to send ANQP request to 242822356406330 for another 39 seconds
12-04 17:37:59.030  2444  2664 D PasspointManager: ANQP entry not found for: dc:d8:7c:4c:10:3a:<1613>
12-04 17:37:59.030  2444  2664 D ANQPRequestManager: Not allowed to send ANQP request to 245021378613306 for another 39 seconds
12-04 17:37:59.030  2444  2664 D PasspointManager: ANQP entry not found for: de:d8:7c:3c:10:3a:<1613>
12-04 17:37:59.817  3999  3999 I wpa_supplicant: wlan0: GAS-QUERY-DONE addr=dc:d8:7c:4c:10:3a dialog_token=6 freq=2437 status_code=0 result=TIMEOUT
12-04 17:37:59.817  3999  3999 I wpa_supplicant: wlan0: ANQP-QUERY-DONE addr=dc:d8:7c:4c:10:3a result=FAILURE
12-04 17:38:00.004  2765  2765 D KeyguardClockSwitch: Updating clock: 538
12-04 17:38:00.528  2444  2664 E WifiVendorHal: getWifiLinkLayerStats_1_3_Internal(l.926) failed {.code = ERROR_NOT_AVAILABLE, .description = }
12-04 17:38:00.672  3999  3999 I wpa_supplicant: wlan0: GAS-QUERY-DONE addr=de:d8:7c:3c:10:3a dialog_token=7 freq=5180 status_code=0 result=TIMEOUT
12-04 17:38:00.673  3999  3999 I wpa_supplicant: wlan0: ANQP-QUERY-DONE addr=de:d8:7c:3c:10:3a result=FAILURE
12-04 17:38:03.593  2444  2664 E WifiVendorH[   91.163172] AICWFDBG(LOGTRACE)   rwnx_send_msg (118)MM_GET_STA_INFO_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
al: getWifiLinkLayerStats_1_3_In[   91.177842] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
ternal(l.926) failed {.code = ER[   91.189652] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x76
ROR_NOT_AVAILABLE, .description [   91.198591] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
12-04 17:38:03.651  2765  2[   91.209258] AICWFDBG(LOGDEBUG)    rwnx_fill_station_info ModTx(0):4 TxIndex:8 ModRx(0):0 RxHTIndex:0 RxVHTIndex:0 RxHEIndex:0 RSSI:-32
12-04 17:38:06.657  2444  2664 E WifiVendorHal: getWifiLinkLayerStats_1_3_Internal(l.926) failed {.code = ERROR_NOT_AVAILABLE, .description = }
[   94.237181] AICWFDBG(LOGTRACE)       rwnx_send_msg (118)MM_GET_STA_INFO_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   94.248927] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   94.258344] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x76
[   94.265270] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   94.273339] AICWFDBG(LOGDEBUG)       rwnx_fill_station_info ModTx(0):4 TxIndex:8 ModRx(0):0 RxHTIndex:0 RxVHTIndex:0 RxHEIndex:0 RSSI:-31
12-04 17:38:09.731  2444  2664 E WifiVendorHal: getWifiLinkLayerStats_1_3_Internal(l.926) failed {.code = ERROR_NOT_AVAILABLE, .description = }
12-04 17:38:09.789  2765  2765 W StatusBarIconController: setIconVisibility index: 27
12-04 17:38:12.782  2444  2636 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 17:38:12.790  2444  2636 I[   97.303788] AICWFDBG(LOGTRACE)       rwnx_send_msg (118)MM_GET_STA_INFO_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
 chatty  : uid=1000(system) Inpu[   97.318662] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
tDispatcher identical 3 lines
1[   97.327833] AICWFDBG(LOGDEBUG)      rwnx_rx_handle_msg msg->id:0x76
2-04 17:38:12.794  2444  2636 V [   97.337082] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
InputDispatcher: Asynchronous in[   97.347727] AICWFDBG(LOGDEBUG)       rwnx_fill_station_info ModTx(0):4 TxIndex:8 ModRx(0):0 RxHTIndex:0 RxVHTIndex:0 RxHEIndex:0 RSSI:-31
12-04 17:38:12.797  2444  2664 E WifiVendorHal: getWifiLinkLayerStats_1_3_Internal(l.926) failed {.code = ERROR_NOT_AVAILABLE, .description = }
12-04 17:38:12.798  2444  2636 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 17:38:12.852  2444  2636 I chatty  : uid=1000(system) InputDispatcher identical 16 lines
12-04 17:38:12.860  2444  2636 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 17:38:12.863  2765  2765 W StatusBarIconController: setIconVisibility index: 27
12-04 17:38:12.865  2444  2636 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 17:38:13.967  2444  2636 I chatty  : uid=1000(system) InputDispatcher identical 3 lines
12-04 17:38:13.971  2444  2636 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 17:38:13.979  2444  4545 E TAG     : Exception = android.content.pm.PackageManager$NameNotFoundException: com.google.android.simappdialog.gts
12-04 17:38:13.979  2444  4545 E TAG     : Exception = android.content.pm.PackageManager$NameNotFoundException: android.net.cts
12-04 17:38:13.980  2444  2636 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 17:38:14.007  2444  2636 I chatty  : uid=1000(system) InputDispatcher identical 7 lines
12-04 17:38:14.009  2444  2636 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 17:38:14.011  2765  2765 D StatusBar: disable<e i a s b h r c s > disable2<q i n >
12-04 17:38:14.014  2444  2636 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 17:38:14.015  2765  2765 W StatusBarIconController: setIconVisibility index: 18
12-04 17:38:14.024  2444  2636 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 17:38:14.033  2444  2636 I chatty  : uid=1000(system) InputDispatcher identical 4 lines
12-04 17:38:14.037  2444  2636 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 17:38:14.038  3000  3000 I AwReadingModeTileService: onBind
12-04 17:38:14.047  2444  2636 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 17:38:14.074  2444  2636 I chatty  : uid=1000(system) InputDispatcher identical 6 lines
12-04 17:38:14.077  2444  2636 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 17:38:14.105  2765  2765 I ScreenshotTileService: onBind
12-04 17:38:14.110  2765  2765 I ScreenrecordTileService: onBind
12-04 17:38:14.219  3000  3000 I AwReadingModeTileService: onStartListening
12-04 17:38:14.227  3000  3000 I awdisplay: init service
12-04 17:38:14.244  3000  3000 I awdisplay: AWDisplay remoteVersion: 10000 clientVersion: 10000
12-04 17:38:14.330  2765  2765 I ScreenshotTileService: onStartListening
12-04 17:38:14.334  2765  2765 I ScreenrecordTileService: onStartListening
12-04 17:38:14.402  2124  2124 D Zygote  : Forked child process 4647
--------- beginning of system
12-04 17:38:14.407  2444  2497 I ActivityManager: app.processName = com.android.systemui:screenrecord
12-04 17:38:14.407  2444  2497 I ActivityManager: Start proc 4647:com.android.systemui:screenrecord/u0a87 for service {com.android.systemui/com.softwinner.screenrecord.TakeScreenrecordService}
12-04 17:38:14.408  4647  4647 I Zygote  : seccomp disabled by setenforce 0
12-04 17:38:14.473  4647  4647 I ui:screenrecor: The ClassLoaderContext is a special shared library.
12-04 17:38:14.914  2210  2287 D omx_venc: <__AwOmxVencFillThisBuffer:2082>: vencOutPort: fill_this_buffer 50 times
12-04 17:38:15.312  2444  2636 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 17:38:15.399  2210  4507 D omx_venc: <__AwOmxVencEmptyThisBuffer:2043>: vencInPort: , empty_this_buffer 50 times
12-04 17:38:15.407  2444  2636 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 17:38:15.432  2444  4545 D BluetoothManagerService: enable(com.android.systemui):  mBluetooth =null mBinding = false mState = OFF
12-04 17:38:15.432  2444  2489 D BluetoothManagerService: MESSAGE_ENABLE(0): mBluetooth = null
12-04 17:38:15.432  2444  4545 D BluetoothManagerService: enable returning
12-04 17:38:15.444  2146  2263 W AudioFlinger: createTrack_l(): mismatch between requested flags (00000004) and output flags (00000002)
12-04 17:38:15.461  2146  2263 D AF::TrackHandle: OpPlayAudio: track:55 usage:13 not muted
12-04 17:38:15.465  2444  2694 W AudioTrack: createTrack_l(7143525): AUDIO_OUTPUT_FLAG_FAST denied by server; frameCount 0 -> 8994
12-04 17:38:15.473  2124  2124 D Zygote  : Forked child process 4688
12-04 17:38:15.476  2444  2497 I ActivityManager: app.processName = com.android.bluetooth
12-04 17:38:15.476  2444  2497 I ActivityManager: Start proc 4688:com.android.bluetooth/1002 for service {com.android.bluetooth/com.android.bluetooth.btservice.AdapterService}
12-04 17:38:15.482  4688  4688 I Zygote  : seccomp disabled by setenforce 0
12-04 17:38:15.549  4688  4688 I droid.bluetoot: The ClassLoaderContext is a special shared library.
12-04 17:38:15.567  2130  4714 D audio_hw_primary: start_output_stream
12-04 17:38:15.567  2130  4714 V audio_platform: disable backend pcm(direction:PCM_OUT)
12-04 17:38:15.567  2130  4714 D audio_route: Apply path: out-reset
12-04 17:38:15.570  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.570  2130  4714 D audio_route: Apply path: media-speaker
12-04 17:38:15.570  2130  4714 D audio_hw_primary: select device(out):pdev:OUT_DULSPK, path:media-speaker
12-04 17:38:15.571  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.572  2130  4714 D audio_hw_primary: +++++++++++++++ start_output_stream: pcm sample_rate: 48000,pcm fmt: 0x00000000,pcm channels: 2
12-04 17:38:15.572  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.608  2130  4714 I chatty  : uid=1041(audioserver) writer identical 1 line
12-04 17:38:15.619  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.622  4688  4688 D BluetoothOppFileProvider: Initialized
12-04 17:38:15.630  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.649  2146  2271 D AudioFlinger: mixer(0x79e922d800) throttle end: throttle time(11)
12-04 17:38:15.650  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.652  4688  4688 V AdapterServiceConfig: Adding HeadsetService
12-04 17:38:15.653  4688  4688 V AdapterServiceConfig: Adding A2dpService
12-04 17:38:15.653  4688  4688 V AdapterServiceConfig: Adding HidHostService
12-04 17:38:15.654  4688  4688 V AdapterServiceConfig: Adding PanService
12-04 17:38:15.654  4688  4688 V AdapterServiceConfig: Adding GattService
12-04 17:38:15.655  4688  4688 V AdapterServiceConfig: Adding BluetoothMapService
12-04 17:38:15.655  4688  4688 V AdapterServiceConfig: Adding AvrcpTargetService
12-04 17:38:15.655  4688  4688 V AdapterServiceConfig: Adding HidDeviceService
12-04 17:38:15.655  4688  4688 V AdapterServiceConfig: Adding BluetoothOppService
12-04 17:38:15.655  4688  4688 V AdapterServiceConfig: Adding BluetoothPbapService
12-04 17:38:15.671  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.693  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.700  4688  4688 I         : [1204/173815.700228:INFO:com_android_bluetooth_btservice_AdapterService.cpp(628)] hal_util_load_bt_library loaded HAL: btinterface=0x7c0a9e3440, handle=0xd5abacc6474cf439
12-04 17:38:15.701  4688  4688 D BluetoothAdapterService: onCreate()
12-04 17:38:15.709  4688  4688 D AdapterState: make() - Creating AdapterState
12-04 17:38:15.714  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.715  4688  4723 I AdapterState: OFF : entered
12-04 17:38:15.715  4688  4723 D AdapterProperties: Setting state to OFF
12-04 17:38:15.716  4688  4688 I bt_btif : init: start restricted = 0 ; single user = 0
12-04 17:38:15.716  4688  4688 D bt_osi_allocation_tracker: canary initialized
12-04 17:38:15.716  4688  4724 I         : [1204/173815.716866:INFO:message_loop_thread.cc(175)] Run: message loop starting for thread bt_stack_manager_thread
12-04 17:38:15.717  4688  4724 I bt_stack_manager: event_init_stack is initializing the stack
12-04 17:38:15.718  4688[  100.371638] AICWFDBG(LOGTRACE)       rwnx_send_msg (118)MM_GET_STA_INFO_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
  4724 I         : [1204/173815.[  100.385767] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
718303:INFO:btif_config.cc(647)][  100.397670] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x76
 hash_file: Disabled for multi-u[  100.406447] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
ser
12-04 17:38:15.718  4688  4[  100.417108] AICWFDBG(LOGDEBUG)    rwnx_fill_station_info ModTx(0):4 TxIndex:8 ModRx(0):0 RxHTIndex:0 RxVHTIndex:0 RxHEIndex:0 RSSI:-30
724 I         : [1204/173815.718452:INFO:btif_config.cc(675)] re[  100.437696] bluetooth_set_power: start_block=1
ad_checksum_file: Disabled for m[  100.443939] aicbsp: aicbsp_set_subsys, subsys: AIC_BLUETOOTH, state to: 0
ulti-user
12-04 17:38:15.718  4[  100.454125] aicbsp: aicbsp_set_subsys, power state no need to change, current: 1
688  4724 E bt_btif_config: Conf[  100.465203] bluetooth_set_power: end_block=1
ig is missing adapter section
1[  100.473932] bluetooth_set_power: start_block=0
2-04 17:38:15.718  4688  4724 W [  100.480556] aicbsp: aicbsp_set_subsys, subsys: AIC_BLUETOOTH, state to: 1
bt_btif_config: init unable to l[  100.490875] aicbsp: aicbsp_set_subsys, power state no need to change, current: 1
oad config file: /data/misc/blue[  100.501970] bluetooth_set_power: end_block=0
droid/bt_config.conf; using back[  100.511287] [BT_LPM] bluesleep_outgoing_data: tx was sleeping, wakeup it
up.
12-04 17:38:15.718  4688  4[  100.519800] [BT_LPM] hsuart_power: bsi->uport = NULL, has_lpm_enabled = 0
724 I         : [1204/173815.718778:INFO:btif_config.cc(647)] hash_file: Disabled for multi-user
12-04 17:38:15.718  4688  4724 I         : [1204/173815.718835:INFO:btif_config.cc(675)] read_checksum_file: Disabled for multi-user
12-04 17:38:15.718  4688  4724 E bt_btif_config: Config is missing adapter section
12-04 17:38:15.718  4688  4724 W bt_btif_config: init unable to load backup; attempting to transcode legacy file.
12-04 17:38:15.719  4688  4724 E bt_btif_config_transcode: btif_config_transcode unable to load XML file '/data/misc/bluedroid/bt_config.xml': 3
12-04 17:38:15.719  4688  4724 E bt_btif_config: init unable to transcode legacy file; creating empty config.
12-04 17:38:15.719  4688  4724 W         : [1204/173815.719178:WARNING:btif_config.cc(151)] read_or_set_metrics_salt: Failed to read metrics salt from config
12-04 17:38:15.719  4688  4724 I         : [1204/173815.719241:INFO:btif_config.cc(162)] read_or_set_metrics_salt: Metrics salt is not invalid, creating new one
12-04 17:38:15.720  4688  4724 E bt_osi_alarm: timer_create_internal unable to [  100.622537] type=1400 audit(1733305052.693:106): avc: denied { dac_override } for comm="irqbalance" capability=1 scontext=u:r:shell:s0 tcontext=u:r:shell:s0 tclass=capability permissive=1
create timer with clock 9: Unknown error 524
12-04 17:38:15.720  4688  4724 E bt_osi_alarm: The[  100.628621] logd: logdr: UID=1002 GID=1002 PID=4765 n tail=50 logMask=8 pid=2131 start=0ns timeout=0ns
 kernel might not have support f[  100.629830] logd: logdr: UID=1002 GID=1002 PID=4765 n tail=50 logMask=1 pid=2131 start=0ns timeout=0ns
or timer_create(CLOCK_BOOTTIME_ALARM): https://lwn.net/Articles/[  100.649992] logd: logdr: UID=1002 GID=1002 PID=4765 n tail=0 logMask=8 pid=2131 start=0ns timeout=0ns
429925/
12-04 17:38:15.720  468[  100.651862] logd: logdr: UID=1002 GID=1002 PID=4765 n tail=0 logMask=1 pid=2131 start=0ns timeout=0ns
8  4724 E bt_osi_alarm: See foll[  100.658544] init: Untracked pid 4765 exited with status 0
owing patches: https://git.kerne[  100.670447] init: Service 'vendor.bluetooth-1-0' (pid 2131) received signal 6
l.org/cgit/linux/kernel/git/torv[  100.670482] init: Sending signal 9 to service 'vendor.bluetooth-1-0' (pid 2131) process group...
alds/linux.git/log/?qt=grep&q=CL[  100.671058] libprocessgroup: Successfully killed process cgroup uid 1002 pid 2131 in 0ms
OCK_BOOTTIME_ALARM
12-04 17:38:[  100.672011] init: Untracked pid 4768 exited with status 0
15.720  4688  4728 I bt_osi_thread: run_thread: thread id 4728, [  100.675533] init: starting service 'vendor.bluetooth-1-0'...
thread name alarm_default_ca sta[  100.769781] type=1400 audit(1733305096.116:107): avc: denied { open } for comm="crash_dump64" path="/dev/__properties__/u:object_r:exported_bluetooth_prop:s0" dev="tmpfs" ino=390 scontext=u:r:crash_dump:s0 tcontext=u:object_r:exported_bluetooth_prop:s0 tclass=file permissive=1
rted
12-04 17:38:15.722  4688  [  100.799106] type=1400 audit(1733305096.116:107): avc: denied { open } for comm="crash_dump64" path="/dev/__properties__/u:object_r:exported_bluetooth_prop:s0" dev="tmpfs" ino=390 scontext=u:r:crash_dump:s0 tcontext=u:object_r:exported_bluetooth_prop:s0 tclass=file permissive=1
4729 I bt_osi_thread: run_thread[  100.829017] type=1400 audit(1733305096.116:108): avc: denied { getattr } for comm="crash_dump64" path="/dev/__properties__/u:object_r:exported_bluetooth_prop:s0" dev="tmpfs" ino=390 scontext=u:r:crash_dump:s0 tcontext=u:object_r:exported_bluetooth_prop:s0 tclass=file permissive=1
: thread id 4729, thread name al[  100.860657] type=1400 audit(1733305096.116:108): avc: denied { getattr } for comm="crash_dump64" path="/dev/__properties__/u:object_r:exported_bluetooth_prop:s0" dev="tmpfs" ino=390 scontext=u:r:crash_dump:s0 tcontext=u:object_r:exported_bluetooth_prop:s0 tclass=file permissive=1
arm_dispatcher started
12-04 17[  100.889832] type=1400 audit(1733305096.116:109): avc: denied { open } for comm="crash_dump64" path="/dev/__properties__/u:object_r:hwservicemanager_prop:s0" dev="tmpfs" ino=411 scontext=u:r:crash_dump:s0 tcontext=u:object_r:hwservicemanager_prop:s0 tclass=file permissive=1
:38:15.724  4688  4724 I bt_btif_core: btif_init_bluetooth entered
12-04 17:38:15.725  4688  4724 I bt_stack_config: init attempt to load stack conf from /etc/bluetooth/bt_stack.conf
12-04 17:38:15.728  4688  4731 I         : [1204/173815.727976:INFO:message_loop_thread.cc(175)] Run: message loop starting for thread bt_jni_thread
12-04 17:38:15.728  4688  4724 I bt_btif_core: btif_init_bluetooth finished
12-04 17:38:15.728  4688  4724 I bt_stack_manager: event_init_stack finished
12-04 17:38:15.728  4688  4688 I bt_osi_wakelock: wakelock_set_os_callouts set to non-native
12-04 17:38:15.729  4688  4688 I bt_btif : get_profile_interface: id = socket
12-04 17:38:15.732  4688  4731 E bt_btif_storage: btif_storage_get_adapter_property: Controller not ready! Unable to return Bluetooth Address
12-04 17:38:15.732  4688  [  100.988909] audit_log_lost: 104 callbacks suppressed
4731 E BluetoothServiceJni: adap[  100.988916] audit: audit_lost=39 audit_rate_limit=5 audit_backlog_limit=64
ter_properties_callback: Status [  101.007579] audit: rate limit exceeded
1 is incorrect
12-04 17:38:15.732  4688  4688 I bt_btif : get_profile_interface: id = sdp
12-04 17:38:15.735  4688  4731 D AdapterProperties: Name is: QUAD-CORE A133 c3
12-04 17:38:15.735  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.736  4688  4731 D AdapterProperties: BT Class:1a011c
12-04 17:38:15.737  2444  2444 D BluetoothManagerService: Bluetooth Adapter name changed to QUAD-CORE A133 c3
12-04 17:38:15.737  2444  2444 D BluetoothManagerService: Stored Bluetooth name: QUAD-CORE A133 c3
12-04 17:38:15.738  4688  4688 I BluetoothAdapterService: Phone policy enabled
12-04 17:38:15.746  4688  4688 D BluetoothActiveDeviceManager: start()
12-04 17:38:15.753  4688  4733 D BluetoothActiveDeviceManager: onAudioDevicesAdded
12-04 17:38:15.753  4688  4733 D BluetoothActiveDeviceManager: Audio device added: QUAD-CORE A133 c3 type: 2
12-04 17:38:15.753  4688  4733 D BluetoothActiveDeviceManager: Audio device added: QUAD-CORE A133 c3 type: 15
12-04 17:38:15.756  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.769  4688  4688 D BluetoothDatabase: start()
12-04 17:38:15.772  4688  4688 D BluetoothDatabase: Load Database
12-04 17:38:15.777  4688  4688 D BluetoothAdapterService: setAdapterService() - trying to set service to com.android.bluetooth.btservice.AdapterService@ce331bd
12-04 17:38:15.786  4688  4688 D BluetoothAdapterService: onBind()
12-04 17:38:15.787  2444  2444 D BluetoothManagerService: BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
12-04 17:38:15.787  2444  2489 D BluetoothManagerService: MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
12-04 17:38:15.788  2444  2489 D BluetoothManagerService: Broadcasting onBluetoothServiceUp() to 4 receivers.
12-04 17:38:15.789  4688  4709 D BluetoothAdapter: onBluetoothServiceUp: com.android.bluetooth.btservice.AdapterService$AdapterServiceBinder@fbeb629
12-04 17:38:15.790  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.791  2444  2489 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@302e680
12-04 17:38:15.791  2891  3169 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@b9a1092
12-04 17:38:15.791  2765  2782 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@4e7737b
12-04 17:38:15.806  4688  4712 D BluetoothAdapterService: enable() - Enable called with quiet mode status =  false
12-04 17:38:15.807  2444  2489 D BluetoothManagerService: MESSAGE_GET_NAME_AND_ADDRESS
12-04 17:38:15.807  4688  4723 I AdapterState: BLE_TURNING_ON : entered
12-04 17:38:15.807  4688  4723 D AdapterProperties: Setting state to BLE_TURNING_ON
12-04 17:38:15.807  4688  4723 D BluetoothAdapterService: updateAdapterState() - Broadcasting state BLE_TURNING_ON to 1 receivers.
12-04 17:38:15.810  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.816  4688  4723 D BluetoothAdapterService: bleOnProcessStart()
12-04 17:38:15.817  4688  4723 I AdapterProperties: init(), maxConnectedAudioDevices, default=5, propertyOverlayed=5, finalValue=5
12-04 17:38:15.817  4688  4736 I BluetoothDatabase: cacheMetadata
12-04 17:38:15.818  2444  2489 D BluetoothManagerService: Stored Bluetooth name: QUAD-CORE A133 c3
12-04 17:38:15.818  2444  2489 D BluetoothManagerService: MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
12-04 17:38:15.818  2444  2489 D BluetoothManagerService: Sending BLE State Change: OFF > BLE_TURNING_ON
12-04 17:38:15.819  4688  4723 D BluetoothAdapterService: bleOnProcessStart() - Make Bond State Machine
12-04 17:38:15.820  4688  4723 D BluetoothBondStateMachine: make
12-04 17:38:15.823  4688  4743 I BluetoothBondStateMachine: StableState(): Entering Off State
12-04 17:38:15.834  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.837  4688  4688 I BtGatt.JNI: classInitNative(L876): classInitNative: Success!
12-04 17:38:15.845  4688  4688 D BtGatt.DebugUtils: handleDebugAction() action=null
12-04 17:38:15.846  4688  4688 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@ce331bd
12-04 17:38:15.849  4688  4688 I bt_btif : get_profile_interface: id = gatt
12-04 17:38:15.851  4688  4688 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@ce331bd
12-04 17:38:15.853  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.866  2444  2664 E WifiVendorHal: getWifiLinkLayerStats_1_3_Internal(l.926) failed {.code = ERROR_NOT_AVAILABLE, .description = }
12-04 17:38:15.874  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.884  4688  4688 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@ce331bd
12-04 17:38:15.887  4688  4724 I bt_stack_manager: event_start_up_stack is bringing up the stack
12-04 17:38:15.887  4688  4724 I bt_core_module: module_start_up Starting module "btif_config_module"
12-04 17:38:15.887  4688  4724 I bt_core_module: module_start_up Started module "btif_config_module"
12-04 17:38:15.887  4688  4724 I bt_core_module: module_start_up Starting module "btsnoop_module"
12-04 17:38:15.887  4688  4724 I         : [1204/173815.887791:INFO:btsnoop.cc(207)] start_up: Snoop Logs disabled
12-04 17:38:15.887  4688  4724 I         : [1204/173815.887912:INFO:btsnoop.cc(338)] delete_btsnoop_files: Deleting snoop logs if they exist. filtered = 1
12-04 17:38:15.888  4688  4724 I         : [1204/173815.888094:INFO:btsnoop.cc(338)] delete_btsnoop_files: Deleting snoop logs if they exist. filtered = 0
12-04 17:38:15.888  4688  4724 I bt_core_module: module_start_up Started module "btsnoop_module"
12-04 17:38:15.888  4688  4724 I bt_core_module: module_start_up Starting module "hci_module"
12-04 17:38:15.888  4688  4724 I bt_hci  : hci_module_start_up
12-04 17:38:15.888  4688  4752 I         : [1204/173815.888727:INFO:message_loop_thread.cc(175)] Run: message loop starting for thread bt_hci_thread
12-04 17:38:15.889  4688  4724 D bt_hci  : hci_module_start_up starting async portion
12-04 17:38:15.889  4688  4752 I bt_hci  : hci_initialize
12-04 17:38:15.892  4688  4752 I bt_hci  : hci_initialize: IBluetoothHci::getService() returned 0x7c5d8b4220 (remote)
12-04 17:38:15.903  2131  2150 I android.hardware.bluetooth@1.0-impl: BluetoothHci::initialize()
12-04 17:38:15.906  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.917  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.932  2131  2150 D         : get_local_address: Trying /sys/class/addr_mgt/addr_bt
12-04 17:38:15.933  2131  2150 D         : get_local_address: Got Factory BDA 52:24:EB:E7:63:5D
12-04 17:38:15.933  2131  2150 I bt_vendor: init
12-04 17:38:15.933  2131  2150 W bt_vendor: *****************************************************************
12-04 17:38:15.933  2131  2150 W bt_vendor: ** Warning - BT Vendor Lib is loaded in debug tuning mode!
12-04 17:38:15.933  2131  2150 W bt_vendor: ** If this is not intentional, rebuild libbt-vendor.so
12-04 17:38:15.933  2131  2150 W bt_vendor: ** with VENDOR_LIB_RUNTIME_TUNING_ENABLED=FALSE and
12-04 17:38:15.933  2131  2150 W bt_vendor: ** check if any run-time tuning parameters needed to be
12-04 17:38:15.933  2131  2150 W bt_vendor: ** carried to the build-time configuration accordingly.
12-04 17:38:15.933  2131  2150 I bt_vnd_conf: Attempt to load conf from /etc/bluetooth/bt_vendor.conf
12-04 17:38:15.933  2131  2150 I bt_vnd_conf: vnd_load_conf file >/etc/bluetooth/bt_vendor.conf< not found
12-04 17:38:15.933  2131  2150 D android.hardware.bluetooth@1.0-impl: Open vendor library loaded
12-04 17:38:15.933  2131  2150 D bt_vendor: op for 0
12-04 17:38:15.934  2131  2150 D bt_upio : init_rfkill: rfkill path /sys/devices/platform/aic-bt/rfkill/rfkill1
12-04 17:38:15.941  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.944  2765  2765 W StatusBarIconController: setIconVisibility index: 27
12-04 17:38:15.959  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.970  2131  2150 W bt_vendor: NOTE: BT_VND_PWR_ON now forces power-off first
12-04 17:38:15.970  2131  2150 D bt_upio : init_rfkill: rfkill path /sys/devices/platform/aic-bt/rfkill/rfkill1
12-04 17:38:15.981  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.002  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.006  2131  2150 D bt_vendor: op for 3
12-04 17:38:16.006 [  101.822831] init: Untracked pid 4783 exited with status 0
 2131  2150 I bt_userial_vendor: userial vendor open: opening /dev/ttyS1
12-04 17:38:16.007  2131  2150 I bt_userial_vendor: device fd = 6 open
12-04 17:38:16.007  2131  2150 D bt_vendor: op for 1
12-04 17:38:16.007  2131  2150 E bt_hwcfg: hw_config_sta[  101.850255] init: Untracked pid 4788 exited with status 0
rt
12-04 17:38:16.007  2131  2150 D bt_vendor: op for 7
12-04 17:38:16.007  2131  2150 E bt_hwcfg: set_wake_stat 1
12-04 17:38:16.007  2131  2150 D bt_upio : upio_set : pio 0 action 2, polarity 1
12-04 17:38:16.023  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.026  2131  2150 D bt_upio : upio_set: proc btwrite assertion, buffer: 1, timer_armed 1 0
12-04 17:38:16.027  2131  4760 F android.hardware.bluetooth-hci-h4: OnDataReady: Unimplemented packet type 0
--------- beginning of crash
12-04 17:38:16.028  2131  4760 F libc    : Fatal signal 6 (SIGABRT), code -1 (SI_QUEUE) in tid 4760 (HwBinder:2131_1), pid 2131 (bluetooth@1.0-s)
12-04 17:[  101.917573] binder: undelivered death notification, 0000007cf44621e0
38:16.045  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.066  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.073  4765  4765 I crash_dump64: obtaining output fd from tombstoned, type: kDebuggerdTombstone
12-04 17:38:16.074  2217  2217 I /system/bin/tombstoned: received crash request for pid 4760
12-04 17:38:16.076  4765  4765 I crash_dump64: performing dump of process 2131 (target tid = 4760)
12-04 17:38:16.079  4765  4765 F DEBUG   : *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
12-04 17:38:16.080  4765  4765 F DEBUG   : Build fingerprint: 'Allwinner/ceres_c3/ceres-c3:10/QP1A.191105.004/eng.ubuntu.20241127.164531:userdebug/test-keys'
12-04 17:38:16.080  4765  4765 F DEBUG   : Revision: '0'
12-04 17:38:16.080  4765  4765 F DEBUG   : ABI: 'arm64'
12-04 17:38:16.082  4765  4765 F DEBUG   : Timestamp: 2024-12-04 17:38:16+0800
12-04 17:38:16.082  4765  4765 F DEBUG   : pid: 2131, tid: 4760, name: HwBinder:2131_1  >>> /vendor/bin/hw/android.hardware.bluetooth@1.0-service <<<
12-04 17:38:16.082  4765  4765 F DEBUG   : uid: 1002
12-04 17:38:16.082  4765  4765 F DEBUG   : signal 6 (SIGABRT), code -1 (SI_QUEUE), fault addr --------
12-04 17:38:16.082  4765  4765 F DEBUG   : Abort message: 'OnDataReady: Unimplemented packet type 0'
12-04 17:38:16.082  4765  4765 F DEBUG   :     x0  0000000000000000  x1  0000000000001298  x2  0000000000000006  x3  00000077218e9540
12-04 17:38:16.082  4765  4765 F DEBUG   :     x4  2e6761772e000000  x5  2e6761772e000000  x6  2e6761772e000000  x7  000000ffffffffff
12-04 17:38:16.082  4765  4765 F DEBUG   :     x8  00000000000000f0  x9  1ba5523419805c05  x10 0000000000000001  x11 0000000000000000
12-04 17:38:16.082  4765  4765 F DEBUG   :     x12 fffffff0ffffffdf  x13 ffffffffffffffff  x14 0000000000000004  x15 ffffffffffffffff
12-04 17:38:16.082  4765  4765 F DEBUG   :     x16 0000007723a978c0  x17 0000007723a75100  x18 000000772171c000  x19 0000000000000853
12-04 17:38:16.082  4765  4765 F DEBUG   :     x20 0000000000001298  x21 00000000ffffffff  x22 00000077218ea020  x23 00000077218e9bb0
12-04 17:38:16.082  4765  4765 F DEBUG   :     x24 0000007723019208  x25 0000007723019208  x26 20c49ba5e353f7cf  x27 00000000000003e8
12-04 17:38:16.082  4765  4765 F DEBUG   :     x28 0000007723009180  x29 00000077218e95e0
12-04 17:38:16.082  4765  4765 F DEBUG   :     sp  00000077218e9520  lr  0000007723a29f48  pc  0000007723a29f74
12-04 17:38:16.087  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.089  4765  4765 F DEBUG   :
12-04 17:38:16.089  4765  4765 F DEBUG   : backtrace:
12-04 17:38:16.089  4765  4765 F DEBUG   :       #00 pc 0000000000081f74  /apex/com.android.runtime/lib64/bionic/libc.so (abort+160) (BuildId: 42603fd538b769308cd4c199a3a97e47)
12-04 17:38:16.089  4765  4765 F DEBUG   :       #01 pc 00000000000089f8  /system/lib64/liblog.so (__android_log_assert+324) (BuildId: 861a081c2056965edab68796c1ed73e0)
12-04 17:38:16.089  4765  4765 F DEBUG   :       #02 pc 000000000000a230  /vendor/lib64/hw/android.hardware.bluetooth@1.0-impl.so (android::hardware::bluetooth::hci::H4Protocol::OnDataReady(int)+180) (BuildId: d049058a6c7deb74b092a5074bd90e52)
12-04 17:38:16.089  4765  4765 F DEBUG   :       #03 pc 0000000000009c24  /vendor/lib64/hw/android.hardware.bluetooth@1.0-impl.so (android::hardware::bluetooth::async::AsyncFdWatcher::ThreadRoutine()+656) (BuildId: d049058a6c7deb74b092a5074bd90e52)
12-04 17:38:16.089  4765  4765 F DEBUG   :       #04 pc 0000000000009fa0  /vendor/lib64/hw/android.hardware.bluetooth@1.0-impl.so (_ZNSt3__114__thread_proxyINS_5tupleIJNS_10unique_ptrINS_15__thread_structENS_14default_deleteIS3_EEEEZN7android8hardware9bluetooth5async14AsyncFdWatcher14tryStartThreadEvE3$_0EEEEEPvSE_+40) (BuildId: d049058a6c7deb74b092a5074bd90e52)
12-04 17:38:16.089  4765  4765 F DEBUG   :       #05 pc 00000000000e1100  /apex/com.android.runtime/lib64/bionic/libc.so (__pthread_start(void*)+36) (BuildId: 42603fd538b769308cd4c199a3a97e47)
12-04 17:38:16.089  4765  4765 F DEBUG   :       #06 pc 0000000000083ab0  /apex/com.android.runtime/lib64/bionic/libc.so (__start_thread+64) (BuildId: 42603fd538b769308cd4c199a3a97e47)
12-04 17:38:16.151  2444  2818 W NativeCrashListener: Couldn't find ProcessRecord for pid 2131
12-04 17:38:16.112  2130  4714 I chatty  : uid=1041(audioserver) writer identical 1 line
12-04 17:38:16.130  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.152  2217  2217 E /system/bin/tombstoned: Tombstone written to: /data/tombstones/tombstone_47
12-04 17:38:16.156  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.168  2444  2510 I BootReceiver: Copying /data/tombstones/tombstone_47 to DropBox (SYSTEM_TOMBSTONE)
12-04 17:38:16.170  2444  2510 I DropBoxManagerService: add tag=SYSTEM_TOMBSTONE isTagEnabled=true flags=0x2
12-04 17:38:16.172  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.175  4688  4753 E bt_hci  : Bluetooth HAL service died!
12-04 17:38:16.175  4688  4753 F libc    : Fatal signal 6 (SIGABRT), code -1 (SI_QUEUE) in tid 4753 (HwBinder:4688_1), pid 4688 (droid.bluetooth)
12-04 17:38:16.194  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.216  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.253  4783  4783 I crash_dump64: obtaining output fd from tombstoned, type: kDebuggerdTombstone
12-04 17:38:16.254  2217  2217 I /system/bin/tombstoned: received crash request for pid 4753
12-04 17:38:16.254  2136  2355 D sunxihwc: checkPerformance: PerfMonitor total[w]:   67 acquire:    0 submit:    1 release:   66
12-04 17:38:16.254  4779  4779 I ServiceManagement: Registered android.hardware.bluetooth@1.0::IBluetoothHci/default (start delay of 87ms)
12-04 17:38:16.255  4779  4779 I ServiceManagement: Removing namespace from process name android.hardware.bluetooth@1.0-service to bluetooth@1.0-service.
12-04 17:38:16.255  4779  4779 I android.hardware.bluetooth@1.0-service: Registration complete for android.hardware.bluetooth@1.0::IBluetoothHci/default.
12-04 17:38:16.256  4783  4783 I crash_dump64: performing dump of process 4688 (target tid = 4753)
12-04 17:38:16.266  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.276  4783  4783 F DEBUG   : *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
12-04 17:38:16.276  4783  4783 F DEBUG   : Build fingerprint: 'Allwinner/ceres_c3/ceres-c3:10/QP1A.191105.004/eng.ubuntu.20241127.164531:userdebug/test-keys'
12-04 17:38:16.276  4[  102.519498] bluetooth_set_power: start_block=1
783  4783 F DEBUG   : Revision: [  102.525644] aicbsp: aicbsp_set_subsys, subsys: AIC_BLUETOOTH, state to: 0
'0'
12-04 17:38:16.276  4783  4[  102.535690] aicbsp: aicbsp_set_subsys, power state no need to change, current: 1
783 F DEBUG   : ABI: 'arm64'
12[  102.546950] bluetooth_set_power: end_block=1
-04 17:38:16.277  4783  4783 F D[  102.555200] bluetooth_set_power: start_block=0
EBUG   : Timestamp: 2024-12-04 1[  102.562018] aicbsp: aicbsp_set_subsys, subsys: AIC_BLUETOOTH, state to: 1
7:38:16+0800
12-04 17:38:16.277[  102.572462] aicbsp: aicbsp_set_subsys, power state no need to change, current: 1
  4783  4783 F DEBUG   : pid: 46[  102.583430] bluetooth_set_power: end_block=0
88, tid: 4753, name: HwBinder:4688_1  >>> com.android.bluetooth <<<
12-04 17:38:16.277  4783  4783 F DEBUG   : uid: 1002
12-04 17:38:16.277  4783  4783 F DEBUG   : signal 6 (SIGABRT), code -1 (SI_QUEUE), fault addr --------
12-04 17:38:16.278  4783  4783 F DEBUG   :     x0  0000000000000000  x1  0000000000001291  x2  0000000000000006  x3  0000007bf94436d0
12-04 17:38:16.278  4783  4783 F DEBUG   :     x4  f8433f1efeff6862  x5  f8433f1efeff6862  x6  f8433f1efeff6862  x7  ff7f7f7f7f7f7f7f
12-04 17:38:16.278  4783  4783 F DEBUG   :     x8  00000000000000f0  x9  65b5bbbb335a5371  x10 0000000000000001  x11 0000000000000000
12-04 17:38:16.278  4783  4783 F DEBUG   :     x12 fffffff0fffffbdf  x13 ffffffffffffffff  x14 0000000000000004  x15 ffffffffffffffff
12-04 17:38:16.278  4783  4783 F DEBUG   :     x16 0000007cf1e018c0  x17 0000007cf1ddf100  x18 0000007bf8cda008  x19 0000000000001250
12-04 17:38:16.278  4783  4783 F DEBUG   :     x20 0000000000001291  x21 00000000ffffffff  x22 0000000000000000  x23 000000008008720f
12-04 17:38:16.278  4783  4783 F DEBUG   :     x24 0000007bf9444020  x25 0000007bf9443a38  x26 0000007bf9444020  x27 0000007bfa63f020
12-04 17:38:16.278  4783  4783 F DEBUG   :     x28 0000000000000009  x29 0000007bf9443770
12-04 17:38:16.278  4783  4783 F DEBUG   :     sp  0000007bf94436b0  lr  0000007cf1d93f48  pc  0000007cf1d93f74
12-04 17:38:16.279  2130  4714 I chatty  : uid=1041(audioserver) writer identical 1 line
12-04 17:38:16.290  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.116  4765  4765 I crash_dump64: type=1400 audit(0.0:107): avc: denied { open } for path="/dev/__properties__/u:object_r:exported_bluetooth_prop:s0" dev="tmpfs" ino=390 scontext=u:r:crash_dump:s0 tcontext=u:object_r:exported_bluetooth_prop:s0 tclass=file permissive=1
12-04 17:38:16.303  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.356  4783  4783 F DEBUG   :
12-04 17:38:16.356  4783  4783 F DEBUG   : backtrace:
12-04 17:38:16.356  4783  4783 F DEBUG   :       #00 pc 0000000000081f74  /apex/com.android.runtime/lib64/bionic/libc.so (abort+160) (BuildId: 42603fd538b769308cd4c199a3a97e47)
12-04 17:38:16.356  4783  4783 F DEBUG   :       #01 pc 0000000000265154  /system/lib64/libbluetooth.so (hal_service_died()+160) (BuildId: ff706d003775a24c2416240a147a9ab6)
12-04 17:38:16.357  4783  4783 F DEBUG   :       #02 pc 0000000000055d84  /system/lib64/libhidlbase.so (android::hardware::hidl_binder_death_recipient::binderDied(android::wp<android::hardware::IBinder> const&)+112) (BuildId: 58cced33adaf1be9a5dabb1206d0e08e)
12-04 17:38:16.322  2130  4714 I chatty  : uid=1041(audioserver) writer identical 1 line
12-04 17:38:16.350  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.116  4765  4765 I crash_dump64: type=1400 audit(0.0:108): avc: denied { getattr } for path="/dev/__properties__/u:object_r:exported_bluetooth_prop:s0" dev="tmpfs" ino=390 scontext=u:r:crash_dump:s0 tcontext=u:object_r:exported_bluetooth_prop:s0 tclass=file permissive=1
12-04 17:38:16.357  4783  4783 F DEBUG   :       #03 pc 0000000000096ca8  /system/lib64/libhidlbase.so (android::hardware::BpHwBinder::reportOneDeath(android::hardware::BpHwBinder::Obituary const&)+128) (BuildId: 58cced33adaf1be9a5dabb1206d0e08e)
12-04 17:38:16.357  4783  4783 F DEBUG   :       #04 pc 0000000000096c10  /system/lib64/libhidlbase.so (android::hardware::BpHwBinder::sendObituary()+204) (BuildId: 58cced33adaf1be9a5dabb1206d0e08e)
12-04 17:38:16.357  4783  4783 F DEBUG   :       #05 pc 0000000000099e10  /system/lib64/libhidlbase.so (android::hardware::IPCThreadState::getAndExecuteCommand()+3000) (BuildId: 58cced33adaf1be9a5dabb1206d0e08e)
12-04 17:38:16.357  4783  4783 F DEBUG   :       #06 pc 000000000009acf4  /system/lib64/libhidlbase.so (android::hardware::IPCThreadState::joinThreadPool(bool)+152) (BuildId: 58cced33adaf1be9a5dabb1206d0e08e)
12-04 17:38:16.357  4783  4783 F DEBUG   :       #07 pc 00000000000a9c84  /system/lib64/libhidlbase.so (android::hardware::PoolThread::threadLoop()+24) (BuildId: 58cced33adaf1be9a5dabb1206d0e08e)
12-04 17:38:16.357  4783  4783 F DEBUG   :       #08 pc 0000000000013670  /system/lib64/libutils.so (android::Thread::_threadLoop(void*)+288) (BuildId: e694ec4393425b1d99ea7621766c5862)
12-04 17:38:16.357  4783  4783 F DEBUG   :       #09 pc 00000000000c1748  /system/lib64/libandroid_runtime.so (android::AndroidRuntime::javaThreadShell(void*)+140) (BuildId: b65a8685227b31d2613995f2e0a17273)
12-04 17:38:16.357  4783  4783 F DEBUG   :       #10 pc 00000000000e1100  /apex/com.android.runtime/lib64/bionic/libc.so (__pthread_start(void*)+36) (BuildId: 42603fd538b769308cd4c199a3a97e47)
12-04 17:38:16.357  4783  4783 F DEBUG   :       #11 pc 0000000000083ab0  /apex/com.android.runtime/lib64/bionic/libc.so (__start_thread+64) (BuildId: 42603fd538b769308cd4c199a3a97e47)
12-04 17:38:16.367  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.385  2130  4714 I chatty  : uid=1041(audioserver) writer identical 1 line
12-04 17:38:16.407  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.116  4765  4765 I crash_dump64: type=1400 audit(0.0:109): avc: denied { open } for path="/dev/__properties__/u:object_r:hwservicemanager_prop:s0" dev="tmpfs" ino=411 scontext=u:r:crash_dump:s0 tcontext=u:object_r:hwservicemanager_prop:s0 tclass=file permissive=1
12-04 17:38:16.116  4765  4765 I crash_dump64: type=1400 audit(0.0:110): avc: denied { getattr } for path="/dev/__properties__/u:object_r:hwservicemanager_prop:s0" dev="tmpfs" ino=411 scontext=u:r:crash_dump:s0 tcontext=u:object_r:hwservicemanager_prop:s0 tclass=file permissive=1
12-04 17:38:16.430  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.446  2210  4710 D omx_venc: <__AwOmxVencFillThisBuffer:2082>: vencOutPort: fill_this_buffer 50 times
12-04 17:38:16.450  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.472  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.483  4783  4783 I crash_dump64: type=1400 audit(0.0:111): avc: denied { open } for path="/dev/__properties__/u:object_r:bluetooth_a2dp_offload_prop:s0" dev="tmpfs" ino=338 scontext=u:r:crash_dump:s0 tcontext=u:object_r:bluetooth_a2dp_offload_prop:s0 tclass=file permissive=1
12-04 17:38:16.498  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.515  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.518  2210  4710 D omx_venc: <__AwOmxVencEmptyThisBuffer:2043>: vencInPort: , empty_this_buffer 50 times
12-04 17:38:16.535  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.243  2130  4714 I chatty  : uid=1041(audioserver) writer identical 33 lines
12-04 17:38:17.261  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.264  2217  2217 E /system/bin/tombstoned: Tombstone written to: /data/tombstones/tombstone_48
12-04 17:38:17.282  2444  4842 I DropBoxManagerService: add tag=system_app_native_crash isTagEnabled=true flags=0x2
12-04 17:38:17.282  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.301  2444  2510 I BootReceiver: Copying /data/tombstones/tombstone_48 to DropBox (SYSTEM_TOMBSTONE)
12-04 17:38:17.303  2444  2510 I DropBoxManagerService: add tag=SYSTEM_TOMBSTONE isTagEnabled=true flags=0x2
12-04 17:38:17.303  2210  4710 D omx_venc: <__AwOmxVencFillThisBuffer:2082>: vencOutPort: fill_this_buffer 50 times
12-04 17:38:17.305  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.331  2130  4714 I chatty  : uid=1041(audioserver) writer identical 1 line
12-04 17:38:17.349  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.363  2210  4710 D omx_venc: <__AwOmxVencEmptyThisBuffer:2043>: vencInPort: , empty_this_buffer 50 times
12-04 17:38:17.367  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.385  2444  2462 I system_server: Background young concurrent copying GC freed 66696(3139KB) AllocSpace objects, 22(1480KB) LOS objects, 27% free, 8626KB/11MB, paused 1.507ms total 114.225ms
12-04 17:38:17.389  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.411  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.419  2124  2124 I Zygote  : Process 4688 exited due to signal 6 (Aborted)
12-04 17:38:17.426  2444  2444 D BluetoothManagerService: BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
12-04 17:38:17.427  2444  2489 E BluetoothManagerService: MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
12-04 17:38:17.427  2444  2489 D BluetoothManagerService: Broadcasting onBluetoothServiceDown() to 3 receivers.
12-04 17:38:17.429  2444  2936 I ActivityManager: Process com.android.bluetooth (pid 4688) has died: psvc PER
12-04 17:38:17.431  2444  2498 I libprocessgroup: Successfully killed process cgroup uid 1002 pid 4688 in 0ms
12-04 17:38:17.431  2891  3169 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@b9a1092
12-04 17:38:17.431  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.432  2765  2782 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@4e7737b
12-04 17:38:17.433  2444  2936 W ActivityManager: Scheduling restart of crashed service com.android.b[  103.450006] AICWFDBG(LOGTRACE)  rwnx_send_msg (118)MM_GET_STA_INFO_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
luetooth/.btservice.AdapterServi[  103.463930] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
ce in 1000ms
12-04 17:38:17.433[  103.474397] AICWFDBG(LOGDEBUG)     rwnx_rx_handle_msg msg->id:0x76
  2444  2936 W ActivityManager: [  103.483203] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
Scheduling restart of crashed se[  103.494209] AICWFDBG(LOGDEBUG)       rwnx_fill_station_info ModTx(0):4 TxIndex:8 ModRx(0):0 RxHTIndex:0 RxVHTIndex:0 RxHEIndex:0 RSSI:-32
rvice com.android.bluetooth/.gatt.GattService in 11000ms
12-04 17:38:17.434  2444  2489 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@302e680
12-04 17:38:17.452  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.628  2444  2489 D BluetoothManagerService: MESSAGE_RESTART_BLUETOOTH_SERVICE
12-04 17:38:17.623  2130  4714 I chatty  : uid=1041(audioserver) writer identical 8 lines
12-04 17:38:17.645  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.649  2124  2124 D Zygote  : Forked child process 4863
12-04 17:38:17.652  2444  2497 I ActivityManager: app.processName = com.android.bluetooth
12-04 17:38:17.652  2444  2497 I ActivityManager: Start proc 4863:com.android.bluetooth/1002 for service {com.android.bluetooth/com.android.bluetooth.btservice.AdapterService}
12-04 17:38:17.660  4863  4863 I Zygote  : seccomp disabled by setenforce 0
12-04 17:38:17.666  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.687  2130  4714 I chatty  : uid=1041(audioserver) writer identical 1 line
12-04 17:38:17.710  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.720  4863  4863 I droid.bluetoot: The ClassLoaderContext is a special shared library.
12-04 17:38:17.730  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.751  2130  4714 I chatty  : uid=1041(audioserver) writer identical 1 line
12-04 17:38:17.773  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.773  4863  4863 D BluetoothOppFileProvider: Initialized
12-04 17:38:17.795  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.805  4863  4863 V AdapterServiceConfig: Adding HeadsetService
12-04 17:38:17.806  4863  4863 V AdapterServiceConfig: Adding A2dpService
12-04 17:38:17.807  4863  4863 V AdapterServiceConfig: Adding HidHostService
12-04 17:38:17.807  4863  4863 V AdapterServiceConfig: Adding PanService
12-04 17:38:17.807  4863  4863 V AdapterServiceConfig: Adding GattService
12-04 17:38:17.807  4863  4863 V AdapterServiceConfig: Adding BluetoothMapService
12-04 17:38:17.807  4863  4863 V AdapterServiceConfig: Adding AvrcpTargetService
12-04 17:38:17.807  4863  4863 V AdapterServiceConfig: Adding HidDeviceService
12-04 17:38:17.807  4863  4863 V AdapterServiceConfig: Adding BluetoothOppService
12-04 17:38:17.807  4863  4863 V AdapterServiceConfig: Adding BluetoothPbapService
12-04 17:38:17.815  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.836  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.846  4863  4863 I         : [1204/173817.846267:INFO:com_android_bluetooth_btservice_AdapterService.cpp(628)] hal_util_load_bt_library loaded HAL: btinterface=0x7c0aa61440, handle=0x4231b39a6b02c329
12-04 17:38:17.849  4863  4863 D BluetoothAdapterService: onCreate()
12-04 17:38:17.855  4863  4863 D AdapterState: make() - Creating AdapterState
12-04 17:38:17.858  4863  4895 I AdapterState: OFF : entered
12-04 17:38:17.858  4863  4895 D AdapterProperties: Setting state to OFF
12-04 17:38:17.859  4863  4863 I bt_btif : init: start restricted = 0 ; single user = 0
12-04 17:38:17.859  4863  4863 D bt_osi_allocation_tracker: canary initialized
12-04 17:38:17.860  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.861  4863  4896 I         : [1204/173817.861101:INFO:message_loop_thread.cc(175)] Run: message loop starting for thread bt_stack_manager_thread
12-04 17:38:17.862  4863  4896 I bt_stack_manager: event_init_stack is initializing the stack
12-04 17:38:17.863  4863  4896 I         : [1204/173817.863579:INFO:btif_config.cc(647)] hash_file: Disabled for multi-user
12-04 17:38:17.863  4863  4896 I         : [1204/173817.863734:INFO:btif_config.cc(675)] read_checksum_file: Disabled for multi-user
12-04 17:38:17.863  4863  4896 E bt_btif_config: Config is missing adapter section
12-04 17:38:17.864  4863  4896 W bt_btif_config: init unable to load config file: /data/misc/bluedroid/bt_config.conf; using backup.
12-04 17:38:17.864  4863  4896 I         : [1204/173817.864126:INFO:btif_config.cc(647)] hash_file: Disabled for multi-user
12-04 17:38:17.864  4863  4896 I         : [1204/173817.864207:INFO:btif_config.cc(675)] read_checksum_file: Disabled for multi-user
12-04 17:38:17.864  4863  4896 E bt_btif_config: Config is missing adapter section
12-04 17:38:17.864  4863  4896 W bt_btif_config: init unable to load backup; attempting to transcode legacy file.
12-04 17:38:17.864  4863  4896 E bt_btif_config_transcode: btif_config_transcode unable to load XML file '/data/misc/bluedroid/bt_config.xml': 3
12-04 17:38:17.864  4863  4896 E bt_btif_config: init unable to transcode legacy file; creating empty config.
12-04 17:38:17.864  4863  4896 W         : [1204/173817.864558:WARNING:btif_config.cc(151)] read_or_set_metrics_salt: Failed to read metrics salt from config
12-04 17:38:17.864  4863  4896 I         : [1204/173817.864632:INFO:btif_config.cc(162)] read_or_set_metrics_salt: Metrics salt is not invalid, creating new one
12-04 17:38:17.865  4863  4896 E bt_osi_alarm: timer_create_internal unable to create timer with clock 9: Unknown error 524
12-04 17:38:17.866  4863  4896 E bt_osi_alarm: The kernel might not have support for timer_create(CLOCK_BOOTTIME_ALARM): https://lwn.net/Articles/429925/
12-04 17:38:17.866  4863  4896 E bt_osi_alarm: See following patches: https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/log/?qt=grep&q=CLOCK_BOOTTIME_ALARM
12-04 17:38:17.867  4863  4900 I bt_osi_thread: run_thread: thread id 4900, thread name alarm_default_ca started
12-04 17:38:17.867  4863  4901 I bt_osi_thread: run_thread: thread id 4901, thread name alarm_dispatcher started
12-04 17:38:17.869  4863  4896 I bt_btif_core: btif_init_bluetooth entered
12-04 17:38:17.870  4863  4896 I bt_stack_config: init attempt to load stack conf from /etc/bluetooth/bt_stack.conf
12-04 17:38:17.870  4863  4902 I         : [1204/173817.870753:INFO:message_loop_thread.cc(175)] Run: message loop starting for thread bt_jni_thread
12-04 17:38:17.870  4863  4896 I bt_btif_core: btif_init_bluetooth finished
12-04 17:38:17.871  4863  4896 I bt_stack_manager: event_init_stack finished
12-04 17:38:17.871  4863  4863 I bt_osi_wakelock: wakelock_set_os_callouts set to non-native
12-04 17:38:17.871  4863  4863 I bt_btif : get_profile_interface: id = socket
12-04 17:38:17.871  4863  4902 E bt_btif_storage: btif_storage_get_adapter_property: Controller not ready! Unable to return Bluetooth Address
12-04 17:38:17.871  4863  4902 E BluetoothServiceJni: adapter_properties_callback: Status 1 is incorrect
12-04 17:38:17.873  4863  4863 I bt_btif : get_profile_interface: id = sdp
12-04 17:38:17.874  4863  4902 D AdapterProperties: Name is: QUAD-CORE A133 c3
12-04 17:38:17.874  4863  4902 D AdapterProperties: BT Class:1a011c
12-04 17:38:17.877  2444  2444 D BluetoothManagerService: Bluetooth Adapter name changed to QUAD-CORE A133 c3
12-04 17:38:17.879  4863  4863 I BluetoothAdapterService: Phone policy enabled
12-04 17:38:17.879  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.880  2444  2444 D BluetoothManagerService: Stored Bluetooth name: QUAD-CORE A133 c3
12-04 17:38:17.883  4863  4863 D BluetoothActiveDeviceManager: start()
12-04 17:38:17.891  4863  4904 D BluetoothActiveDeviceManager: onAudioDevicesAdded
12-04 17:38:17.891  4863  4904 D BluetoothActiveDeviceManager: Audio device added: QUAD-CORE A133 c3 type: 2
12-04 17:38:17.891  4863  4904 D BluetoothActiveDeviceManager: Audio device added: QUAD-CORE A133 c3 type: 15
12-04 17:38:17.900  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.904  4863  4863 D BluetoothDatabase: start()
12-04 17:38:17.907  4863  4863 D BluetoothDatabase: Load Database
12-04 17:38:17.908  4863  4863 D BluetoothAdapterService: setAdapterService() - trying to set service to com.android.bluetooth.btservice.AdapterService@ce331bd
12-04 17:38:17.917  4863  4863 D BluetoothAdapterService: onBind()
12-04 17:38:17.919  2444  2444 D BluetoothManagerService: BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
12-04 17:38:17.919  2444  2489 D BluetoothManagerService: MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
12-04 17:38:17.920  2444  2489 D BluetoothManagerService: Broadcasting onBluetoothServiceUp() to 4 receivers.
12-04 17:38:17.921  2891  3169 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@491ba63
12-04 17:38:17.921  4863  4882 D BluetoothAdapter: onBluetoothServiceUp: com.android.bluetooth.btservice.AdapterService$AdapterServiceBinder@fbeb629
12-04 17:38:17.921  2765  2782 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@7ddd598
12-04 17:38:17.922  2444  2489 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@6c12a72
12-04 17:38:17.922  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.931  4863  4882 D BluetoothAdapterService: enable() - Enable called with quiet mode status =  false
12-04 17:38:17.932  2444  2489 D BluetoothManagerService: MESSAGE_GET_NAME_AND_ADDRESS
12-04 17:38:17.935  4863  4895 I AdapterState: BLE_TURNING_ON : entered
12-04 17:38:17.935  4863  4895 D AdapterProperties: Setting state to BLE_TURNING_ON
12-04 17:38:17.935  4863  4895 D BluetoothAdapterService: updateAdapterState() - Broadcasting state BLE_TURNING_ON to 1 receivers.
12-04 17:38:17.935  2444  2489 D BluetoothManagerService: Stored Bluetooth name: QUAD-CORE A133 c3
12-04 17:38:17.936  2444  2489 D BluetoothManagerService: MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
12-04 17:38:17.936  2444  2489 D BluetoothManagerService: Sending BLE State Change: OFF > BLE_TURNING_ON
12-04 17:38:17.944  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.952  4863  4895 D BluetoothAdapterService: bleOnProcessStart()
12-04 17:38:17.953  4863  4895 I AdapterProperties: init(), maxConnectedAudioDevices, default=5, propertyOverlayed=5, finalValue=5
12-04 17:38:17.955  4863  4907 I BluetoothDatabase: cacheMetadata
12-04 17:38:17.956  4863  4895 D BluetoothAdapterService: bleOnProcessStart() - Make Bond State Machine
12-04 17:38:17.957  4863  4895 D BluetoothBondStateMachine: make
12-04 17:38:17.958  4863  4915 I BluetoothBondStateMachine: StableState(): Entering Off State
12-04 17:38:17.965  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.968  4863  4863 I BtGatt.JNI: classInitNative(L876): classInitNative: Success!
12-04 17:38:17.971  4863  4863 D BtGatt.DebugUtils: handleDebugAction() action=null
12-04 17:38:17.972  4863  4863 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@ce331bd
12-04 17:38:17.982  4863  4863 I bt_btif : get_profile_interface: id = gatt
12-04 17:38:17.982  4863  4863 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@ce331bd
12-04 17:38:17.986  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:18.002  4863  4863 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@ce331bd
12-04 17:38:18.004  4863  4896 I bt_stack_manager: event_start_up_stack is bringing up the stack
12-04 17:38:18.006  4863  4896 I bt_core_module: module_start_up Starting module "btif_config_module"
12-04 17:38:18.006  4863  4896 I bt_core_module: module_start_up Started module "btif_config_module"
12-04 17:38:18.006  4863  4896 I bt_core_module: module_start_up Starting module "btsnoop_module"
12-04 17:38:18.006  4863  4896 I         : [1204/173818.006369:INFO:btsnoop.cc(207)] start_up: Snoop Logs disabled
12-04 17:38:18.006  4863  4896 I         : [1204/173818.006495:INFO:btsnoop.cc(338)] delete_btsnoop_files: Deleting snoop logs if they exist. filtered = 1
12-04 17:38:18.006  4863  4896 I         : [1204/173818.006645:INFO:btsnoop.cc(338)] delete_btsnoop_files: Deleting snoop logs if they exist. filtered = 0
12-04 17:38:18.006  4863  4896 I bt_core_module: module_start_up Started module "btsnoop_module"
12-04 17:38:18.007  4863  4896 I bt_core_module: module_start_up Starting module "hci_module"
12-04 17:38:18.007  4863  4896 I bt_hci  : hci_module_start_up
12-04 17:38:18.007  4863  4922 I         : [1204/173818.007486:INFO:message_loop_thread.cc(175)] Run: message loop starting for thread bt_hci_thread
12-04 17:38:18.007  4863  4922 I bt_hci  : hci_initialize
12-04 17:38:18.007  4863  4896 D bt_hci  : hci_module_start_up starting async portion
12-04 17:38:18.009  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:18.013  4863  4922 I bt_hci  : hci_initialize: IBluetoothHci::getService() returned 0x7c5d8b43e0 (remote)
12-04 17:38:18.013  4779  4786 I android.hardware.bluetooth@1.0-impl: BluetoothHci::initialize()
12-04 17:38:18.015  4779  4786 D         : get_local_address: Trying /sys/class/addr_mgt/addr_bt
12-04 17:38:18.015  4779  4786 D         : get_local_address: Got Factory BDA 52:24:EB:E7:63:5D
12-04 17:38:18.015  4779  4786 I bt_vendor: init
12-04 17:38:18.015  4779  4786 W bt_vendor: *****************************************************************
12-04 17:38:18.015  4779  4786 W bt_vendor: ** Warning - BT Vendor Lib is loaded in debug tuning mode!
12-04 17:38:18.015  4779  4786 W bt_vendor: ** If this is not intentional, rebuild libbt-vendor.so
12-04 17:38:18.015  4779  4786 W bt_vendor: ** with VENDOR_LIB_RUNTIME_TUNING_ENABLED=FALSE and
12-04 17:38:18.015  4779  4786 W bt_vendor: ** check if any run-time tuning parameters needed to be
12-04 17:38:18.015  4779  4786 W bt_vendor: ** carried to the build-time configuration accordingly.
12-04 17:38:18.015  4779  4786 I bt_vnd_conf: Attempt to load conf from /etc/bluetooth/bt_vendor.conf
12-04 17:38:18.015  4779  4786 I bt_vnd_conf: vnd_load_conf file >/etc/bluetooth/bt_vendor.conf< not found
12-04 17:38:18.015  4779  4786 D android.hardware.bluetooth@1.0-impl: Open vendor library loaded
12-04 17:38:18.015  4779  4786 D bt_vendor: op for 0
12-04 17:38:18.016  4779  4786 D bt_upio : init_rfkill: rfkill path /sys/devices/platform/aic-bt/rfkill/rfkill1
12-04 17:38:18.044  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:18.051  4779  4786 W bt_vendor: NOTE: BT_VND_PWR_ON now forces power-off first
12-04 17:38:18.051  4779  4786 D bt_upio : init_rfkill: rfkill path /sys/devices/platform/aic-bt/rfkill/rfkill1
12-04 17:38:18.055  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:18.080  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:18.088  4779  4786 D bt_vendor: op for 3
12-04 17:38:18.088  4779  4786 I bt_userial_vendor: userial vendor open: opening /dev/ttyS1
12-04 17:38:18.088  4779  4786 I bt_userial_vendor: device fd = 6 open
12-04 17:38:18.089  4779  4786 D bt_vendor: op for 1
12-04 17:38:18.089  4779  4786 E bt_hwcfg: hw_config_start
12-04 17:38:18.089  4779  4786 D bt_vendor: op for 7
12-04 17:38:18.089  4779  4786 E bt_hwcfg: set_wake_stat 1
12-04 17:38:18.089  4779  4786 D bt_upio : upio_set : pio 0 action 2, polarity 1
12-04 17:38:18.090  4779  4786 D bt_upio : upio_set: proc btwrite assertion, buffer: 1, timer_armed 1 0
12-04 17:38:18.102  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:18.114  2130  4714 I chatty  : uid=1041(audioserver) writer identical 1 line
12-04 17:38:18.135  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:18.148  2210  4710 D omx_venc: <__AwOmxVencFillThisBuffer:2082>: vencOutPort: fill_this_buffer 50 times
12-04 17:38:18.157  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:18.178  2130  4714 I chatty  : uid=1041(audioserver) writer identical 1 line
12-04 17:38:18.199  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:18.213  2210  4710 D omx_venc: <__AwOmxVencEmptyThisBuffer:2043>: vencInPort: , empty_this_buffer 50 times
12-04 17:38:18.220  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:18.732  2130  4714 I chatty  : uid=1041(audioserver) writer identical 24 lines
12-04 17:38:18.754  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:18.765  2130  2130 D audio_hw_primary: out_standby
12-04 17:38:18.943  2444  2664 E WifiVendorHal: getWifiLinkLayerStats_1_3_Internal(l.926) failed {.code = ERROR_NOT_AVAILABLE, .description = }
12-04 17:38:18.983  2210  2287 D omx_venc: <__AwOmxVencFillThisBuffer:2082>: vencOutPort: fill_this_buffer 50 times
12-04 17:38:19.063  2210  4500 D omx_venc: <__AwOmxVencEmptyThisBuffer:2043>: vencInPort: , empty_this_buffer 50 times
12-04 17:38:19.835  2210  4710 D omx_venc: <__AwOmxVencFillThisBuffer:2082>: vencOutPort: fill_this_buffer 50 times
12-04 17:38:19.897  2210  4710 D omx_venc: <__AwOmxVencEmptyThisBuffer:2043>: vencInPort: , empty_this_buffer 50 times
12-04 17:38:20.674  2210  4710 D omx_venc: <__AwOmxVencFillThisBuffer:2082>: vencOutPort: fill_this_buffer 50 times
12-04 17:38:20.730  2210  4710 D omx_venc: <__AwOmxVencEmptyThisBuffer:2043>: vencInPort: , empty_this_buffer 50 times
楼主 #3 2024-12-04 17:49:53
memory
已发帖子: 487
Re: A133 AW869C 蓝牙开启失败,请问是什么原因呢?
这是A133 + AW869A 正常的日志
130|ceres-c3:/ #
130|ceres-c3:/ # logcat |grep bluetooth
08-23 21:00:06.855  2131  2131 I ServiceManagement: Registered android.hardware.bluetooth@1.0::IBluetoothHci/default (start delay of 390ms)
08-23 21:00:06.856  2131  2131 I ServiceManagement: Removing namespace from process name android.hardware.bluetooth@1.0-service to bluetooth@1.0-service.
08-23 21:00:06.857  2131  2131 I android.hardware.bluetooth@1.0-service: Registration complete for android.hardware.bluetooth@1.0::IBluetoothHci/default.
08-23 21:00:06.890  1988  1988 I hwservicemanager: getTransport: Cannot find entry android.hardware.bluetooth.audio@2.0::IBluetoothAudioProvidersFactory/default in either framework or device manifest.
08-23 21:00:06.891  2130  2130 E audiohalservice: Could not get passthrough implementation for android.hardware.bluetooth.audio@2.0::IBluetoothAudioProvidersFactory/default.
08-23 21:00:06.892  1988  1988 I hwservicemanager: getTransport: Cannot find entry android.hardware.bluetooth.a2dp@1.0::IBluetoothAudioOffload/default in either framework or device manifest.
08-23 21:00:06.892  2130  2130 E audiohalservice: Could not get passthrough implementation for android.hardware.bluetooth.a2dp@1.0::IBluetoothAudioOffload/default.
08-23 21:00:07.477  2138  2138 E light   : light_open lights bluetooth failed: -22
08-23 21:00:10.683  2323  2323 I getprop : type=1400 audit(0.0:19): avc: denied { open } for path="/dev/__properties__/u:object_r:bluetooth_a2dp_offload_prop:s0" dev="tmpfs" ino=2245 scontext=u:r:shell:s0 tcontext=u:object_r:bluetooth_a2dp_offload_prop:s0 tclass=file permissive=1
08-23 21:00:10.683  2323  2323 I getprop : type=1400 audit(0.0:20): avc: denied { getattr } for path="/dev/__properties__/u:object_r:bluetooth_a2dp_offload_prop:s0" dev="tmpfs" ino=2245 scontext=u:r:shell:s0 tcontext=u:object_r:bluetooth_a2dp_offload_prop:s0 tclass=file permissive=1
08-23 21:00:10.683  2323  2323 I getprop : type=1400 audit(0.0:21): avc: denied { open } for path="/dev/__properties__/u:object_r:bluetooth_audio_hal_prop:s0" dev="tmpfs" ino=2246 scontext=u:r:shell:s0 tcontext=u:object_r:bluetooth_audio_hal_prop:s0 tclass=file permissive=1
08-23 21:00:10.683  2323  2323 I getprop : type=1400 audit(0.0:22): avc: denied { getattr } for path="/dev/__properties__/u:object_r:bluetooth_audio_hal_prop:s0" dev="tmpfs" ino=2246 scontext=u:r:shell:s0 tcontext=u:object_r:bluetooth_audio_hal_prop:s0 tclass=file permissive=1
08-23 21:00:10.683  2323  2323 I getprop : type=1400 audit(0.0:23): avc: denied { open } for path="/dev/__properties__/u:object_r:bluetooth_prop:s0" dev="tmpfs" ino=2247 scontext=u:r:shell:s0 tcontext=u:object_r:bluetooth_prop:s0 tclass=file permissive=1
08-23 21:00:10.683  2323  2323 I getprop : type=1400 audit(0.0:24): avc: denied { getattr } for path="/dev/__properties__/u:object_r:bluetooth_prop:s0" dev="tmpfs" ino=2247 scontext=u:r:shell:s0 tcontext=u:object_r:bluetooth_prop:s0 tclass=file permissive=1
08-23 21:00:10.690  2323  2323 I getprop : type=1400 audit(0.0:79): avc: denied { open } for path="/dev/__properties__/u:object_r:exported_bluetooth_prop:s0" dev="tmpfs" ino=2297 scontext=u:r:shell:s0 tcontext=u:object_r:exported_bluetooth_prop:s0 tclass=file permissive=1
08-23 21:00:10.690  2323  2323 I getprop : type=1400 audit(0.0:80): avc: denied { getattr } for path="/dev/__properties__/u:object_r:exported_bluetooth_prop:s0" dev="tmpfs" ino=2297 scontext=u:r:shell:s0 tcontext=u:object_r:exported_bluetooth_prop:s0 tclass=file permissive=1
08-23 21:00:12.052  2124  2124 W Zygote  : Class not found for preloading: android.bluetooth.BluetoothA2dp$2
08-23 21:00:16.150  2428  2560 W PackageParser: Ignoring duplicate uses-permissions/uses-permissions-sdk-m: android.permission.READ_CONTACTS in package: com.android.bluetooth at: Binary XML file line #67
11-23 11:34:04.215  2126  2126 W Zygote  : Class not found for preloading: android.bluetooth.BluetoothA2dp$2
11-23 11:34:04.264  2428  2428 D BluetoothManagerService: Stored bluetooth Name=QUAD-CORE A133 c3,Address=01:42:D9:21:DE:89
11-23 11:34:05.973  2428  2484 I ActivityManager: app.processName = com.android.bluetooth
11-23 11:34:05.973  2428  2484 I ActivityManager: Start proc 2815:com.android.bluetooth/1002 for service {com.android.bluetooth/com.android.bluetooth.btservice.AdapterService}
11-23 11:34:06.715  2815  2815 I         : [1123/113406.715271:INFO:com_android_bluetooth_btservice_AdapterService.cpp(628)] hal_util_load_bt_library loaded HAL: btinterface=0x7c0cae5440, handle=0xe161d939f04fe2f3
11-23 11:34:06.793  2815  3020 I bt_btif_core: btif_init_bluetooth entered
11-23 11:34:06.794  2815  3020 I bt_stack_config: init attempt to load stack conf from /etc/bluetooth/bt_stack.conf
11-23 11:34:06.797  2815  3020 I bt_btif_core: btif_init_bluetooth finished
11-23 11:34:06.905  2815  2815 D BluetoothAdapterService: setAdapterService() - trying to set service to com.android.bluetooth.btservice.AdapterService@dba49b6
11-23 11:34:07.597  2428  2428 D BluetoothManagerService: BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
11-23 11:34:07.601  2428  2473 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@337c8b
11-23 11:34:07.608  2815  2836 D BluetoothAdapter: onBluetoothServiceUp: com.android.bluetooth.btservice.AdapterService$AdapterServiceBinder@d1c55c0
11-23 11:34:07.677  2815  2815 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@dba49b6
11-23 11:34:07.690  2815  2815 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@dba49b6
11-23 11:34:07.768  2815  2815 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@dba49b6
11-23 11:34:07.790  2131  2172 I android.hardware.bluetooth@1.0-impl: BluetoothHci::initialize()
11-23 11:34:07.800  2131  2172 E libbt_vendor: aicbt_load_stack_conf unable to open file '/vendor/etc/bluetooth/aicbt.conf': No such file or directory
11-23 11:34:07.800  2131  2172 E libbt_vendor: no config find from file '/vendor/etc/bluetooth/aicbt.conf'
11-23 11:34:07.804  2131  2172 D android.hardware.bluetooth@1.0-impl: Open vendor library loaded
11-23 11:34:07.800  2131  2131 I HwBinder:2131_1: type=1400 audit(0.0:130): avc: denied { create } for scontext=u:r:hal_bluetooth_default:s0 tcontext=u:r:hal_bluetooth_default:s0 tclass=udp_socket permissive=1
11-23 11:34:07.810  2131  2131 I HwBinder:2131_1: type=1400 audit(0.0:131): avc: denied { read } for name="/" dev="tmpfs" ino=7445 scontext=u:r:hal_bluetooth_default:s0 tcontext=u:object_r:device:s0 tclass=dir permissive=1
11-23 11:34:07.987  2131  3256 D android.hardware.bluetooth@1.0-impl: OnFirmwareConfigured result: 0
11-23 11:34:07.987  2131  3256 I android.hardware.bluetooth@1.0-impl: Firmware configured in 0.083s
11-23 11:34:07.987  2131  3256 I android.hardware.bluetooth@1.0-impl: OnFirmwareConfigured: lpm_timeout_ms 3000
11-23 11:34:07.987  2131  3256 D android.hardware.bluetooth@1.0-impl: low_power_mode_cb result: 0
11-23 11:34:07.987  2131  3256 D android.hardware.bluetooth@1.0-impl: OnFirmwareConfigured Calling StartLowPowerWatchdog()
11-23 11:34:08.123  2131  3250 E aic_heartbeat: load_aicbt_heartbeat_conf unable to open file '/vendor/etc/bluetooth/aicbt_heartbeat.conf': No such file or directory
11-23 11:34:08.202  2815  3028 I bt_btif_core: btif_enable_bluetooth_evt entered: status 0
11-23 11:34:08.207  2815  3028 I bt_btif_core: btif_enable_bluetooth_evt finished
11-23 11:34:08.233  2428  2428 D BluetoothManagerService: BluetoothServiceConnection: com.android.bluetooth.gatt.GattService
11-23 11:34:08.277  2815  2815 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@dba49b6
11-23 11:34:08.308  2815  2815 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@dba49b6
11-23 11:34:08.390  2815  2815 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@dba49b6
11-23 11:34:08.395  2815  2815 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@dba49b6
11-23 11:34:08.448  2815  3269 I chatty  : uid=1002(bluetooth) identical 2 lines
11-23 11:34:08.461  2815  2815 D A2dpService: setA2dpService(): set to: com.android.bluetooth.a2dp.A2dpService@938178f
11-23 11:34:08.468  2815  2815 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@dba49b6
11-23 11:34:08.478  2815  2815 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@dba49b6
11-23 11:34:08.492  2815  2815 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@dba49b6
11-23 11:34:08.504  2815  2815 D BluetoothMapAccountLoader: Found 0 application(s) with intent android.bluetooth.action.BLUETOOTH_MAP_PROVIDER
11-23 11:34:08.507  2815  2815 D BluetoothMapAccountLoader: Found 0 application(s) with intent android.bluetooth.action.BLUETOOTH_MAP_IM_PROVIDER
11-23 11:34:08.510  2815  2815 D BluetoothMapService: setBluetoothMapService(): set to: com.android.bluetooth.map.BluetoothMapService@d2994dd
11-23 11:34:08.512  2815  2815 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@dba49b6
11-23 11:34:08.529  2428  2639 D MediaSessionService: The callback android.media.session.ICallback$Stub$Proxy@901abf1 is set by com.android.bluetooth
11-23 11:34:08.532  2815  3269 I bt_stack: [INFO:connection_handler.cc(206)] virtual bool bluetooth::avrcp::ConnectionHandler::AvrcpConnect(bool, const RawAddress &): handle=0000 status= 000000
11-23 11:34:08.546  2815  2815 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@dba49b6
11-23 11:34:08.559  2815  2815 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@dba49b6
11-23 11:34:08.571  2815  2815 D BtOppService: setBluetoothOppService(): set to: com.android.bluetooth.opp.BluetoothOppService@b8a3ee4
11-23 11:34:08.575  2815  2815 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@dba49b6
11-23 11:34:08.587  2815  2815 D BluetoothPbapService: setBluetoothPbapService(): set to: com.android.bluetooth.pbap.BluetoothPbapService@d8c867c
11-23 11:34:12.107  3674  3674 D music_MediaPlaybackSer: OnGetRoot: clientPackageName=com.android.bluetooth; clientUid=1002 ; rootHints=null
11-23 11:34:12.172  3674  3674 D music_MediaPlaybackSer: OnGetRoot: clientPackageName=com.android.bluetooth; clientUid=1002 ; rootHints=null
11-23 11:36:11.909  2428  2639 D BluetoothManagerService: disable(): mBluetooth = android.bluetooth.IBluetooth$Stub$Proxy@337c8b mBinding = false
11-23 11:36:11.910  2428  2473 D BluetoothManagerService: MESSAGE_DISABLE: mBluetooth = android.bluetooth.IBluetooth$Stub$Proxy@337c8b
11-23 11:36:11.910  2428  2428 V SettingsProvider: Notifying for 0: content://settings/global/bluetooth_on
11-23 11:36:11.966  2428  3127 D MediaSessionService: The callback null is set by com.android.bluetooth
11-23 11:36:11.977  2815  2815 D BluetoothSocket: close() this: android.bluetooth.BluetoothSocket@57dc280, channel: 5, mSocketIS: android.net.LocalSocketImpl$SocketInputStream@6cf00b9, mSocketOS: android.net.LocalSocketImpl$SocketOutputStream@71dcfemSocket: android.net.LocalSocket@c44ac5f impl:android.net.LocalSocketImpl@63c86ac fd:java.io.FileDescriptor@dd5ef75, mSocketState: LISTENING
11-23 11:36:11.979  2815  2815 D BluetoothSocket: close() this: android.bluetooth.BluetoothSocket@c8acb0a, channel: 4099, mSocketIS: android.net.LocalSocketImpl$SocketInputStream@4b1af7b, mSocketOS: android.net.LocalSocketImpl$SocketOutputStream@7416198mSocket: android.net.LocalSocket@6230df1 impl:android.net.LocalSocketImpl@4928dd6 fd:java.io.FileDescriptor@321c857, mSocketState: LISTENING
11-23 11:36:11.988  2815  3412 D BluetoothSocket: close() this: android.bluetooth.BluetoothSocket@ab6ff44, channel: 4, mSocketIS: android.net.LocalSocketImpl$SocketInputStream@449982d, mSocketOS: android.net.LocalSocketImpl$SocketOutputStream@f81b162mSocket: android.net.LocalSocket@21092f3 impl:android.net.LocalSocketImpl@8c6cbb0 fd:java.io.FileDescriptor@8d48a29, mSocketState: LISTENING
11-23 11:36:11.991  2815  3412 D BluetoothSocket: close() this: android.bluetooth.BluetoothSocket@94d81ae, channel: 4097, mSocketIS: android.net.LocalSocketImpl$SocketInputStream@e176b4f, mSocketOS: android.net.LocalSocketImpl$SocketOutputStream@c4f2dcmSocket: android.net.LocalSocket@8029fe5 impl:android.net.LocalSocketImpl@5f40aba fd:java.io.FileDescriptor@a096d6b, mSocketState: LISTENING
11-23 11:36:11.999  2815  2815 W BtOppService: unregisterReceivers java.lang.IllegalArgumentException: Receiver not registered: com.android.bluetooth.opp.BluetoothOppService$3@15e6f4d
11-23 11:36:12.017  2815  3020 I bt_btif_core: btif_disable_bluetooth entered
11-23 11:36:12.019  2815  3020 I bt_btif_core: btif_disable_bluetooth finished
11-23 11:36:13.011  2428  2473 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@337c8b
11-23 11:36:13.013  2916  3587 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@1832417
11-23 11:36:13.013  2428  2473 D BluetoothManagerService: unbindAndFinish(): android.bluetooth.IBluetooth$Stub$Proxy@337c8b mBinding = false mUnbinding = false
11-23 11:36:13.013  2815  3380 D BluetoothAdapter: onBluetoothServiceDown: com.android.bluetooth.btservice.AdapterService$AdapterServiceBinder@d1c55c0
11-23 11:36:13.013  2788  2808 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@23f4100
11-23 11:36:13.022  2815  3028 I bt_btif_core: btif_disable_bluetooth_evt entered
11-23 11:36:13.024  2131  2172 I android.hardware.bluetooth@1.0-impl: BluetoothHci::close()
11-23 11:36:13.024  2131  2172 D android.hardware.bluetooth@1.0-impl: low_power_mode_cb result: 0
11-23 11:36:13.508  2815  3028 I bt_btif_core: btif_disable_bluetooth_evt finished
11-23 11:36:13.510  2815  3020 I bt_btif_core: btif_cleanup_bluetooth entered
11-23 11:36:13.512  2815  3020 I bt_btif_core: btif_cleanup_bluetooth finished
11-23 11:36:13.593  2428  4425 I ActivityManager: Process com.android.bluetooth (pid 2815) has died: fore SVC
11-23 11:36:22.299  2428  2484 I ActivityManager: app.processName = com.android.bluetooth
11-23 11:36:22.299  2428  2484 I ActivityManager: Start proc 4719:com.android.bluetooth/1002 for service {com.android.bluetooth/com.android.bluetooth.btservice.AdapterService}
11-23 11:36:22.524  4719  4719 I         : [1123/113622.524548:INFO:com_android_bluetooth_btservice_AdapterService.cpp(628)] hal_util_load_bt_library loaded HAL: btinterface=0x7c0cba4440, handle=0x18f04452a7b9dec5
11-23 11:36:22.547  4719  4755 I bt_btif_core: btif_init_bluetooth entered
11-23 11:36:22.548  4719  4755 I bt_stack_config: init attempt to load stack conf from /etc/bluetooth/bt_stack.conf
11-23 11:36:22.552  4719  4755 I bt_btif_core: btif_init_bluetooth finished
11-23 11:36:22.608  4719  4719 D BluetoothAdapterService: setAdapterService() - trying to set service to com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:36:22.616  2428  2428 D BluetoothManagerService: BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
11-23 11:36:22.617  2428  2473 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@766fd53
11-23 11:36:22.618  2916  3587 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@a9f9004
11-23 11:36:22.621  2788  2809 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@9e43e3f
11-23 11:36:22.623  4719  4740 D BluetoothAdapter: onBluetoothServiceUp: com.android.bluetooth.btservice.AdapterService$AdapterServiceBinder@31cbb43
11-23 11:36:22.674  4719  4719 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:36:22.680  4719  4719 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:36:22.712  4719  4719 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:36:22.722  2131  2172 I android.hardware.bluetooth@1.0-impl: BluetoothHci::initialize()
11-23 11:36:22.724  2131  2172 E libbt_vendor: aicbt_load_stack_conf unable to open file '/vendor/etc/bluetooth/aicbt.conf': No such file or directory
11-23 11:36:22.724  2131  2172 E libbt_vendor: no config find from file '/vendor/etc/bluetooth/aicbt.conf'
11-23 11:36:22.727  2131  2172 D android.hardware.bluetooth@1.0-impl: Open vendor library loaded
11-23 11:36:22.736  2131  4797 D android.hardware.bluetooth@1.0-impl: OnFirmwareConfigured result: 0
11-23 11:36:22.736  2131  4797 I android.hardware.bluetooth@1.0-impl: Firmware configured in 0.007s
11-23 11:36:22.746  2131  4797 I android.hardware.bluetooth@1.0-impl: OnFirmwareConfigured: lpm_timeout_ms 3000
11-23 11:36:22.746  2131  4797 D android.hardware.bluetooth@1.0-impl: low_power_mode_cb result: 0
11-23 11:36:22.746  2131  4797 D android.hardware.bluetooth@1.0-impl: OnFirmwareConfigured Calling StartLowPowerWatchdog()
11-23 11:36:22.723  2131  2131 I HwBinder:2131_1: type=1400 audit(0.0:139): avc: denied { create } for scontext=u:r:hal_bluetooth_default:s0 tcontext=u:r:hal_bluetooth_default:s0 tclass=udp_socket permissive=1
11-23 11:36:22.743  2131  2131 I HwBinder:2131_1: type=1400 audit(0.0:140): avc: denied { read } for name="/" dev="tmpfs" ino=7445 scontext=u:r:hal_bluetooth_default:s0 tcontext=u:object_r:device:s0 tclass=dir permissive=1
11-23 11:36:22.872  2131  4791 E aic_heartbeat: load_aicbt_heartbeat_conf unable to open file '/vendor/etc/bluetooth/aicbt_heartbeat.conf': No such file or directory
11-23 11:36:22.904  4719  4762 I bt_btif_core: btif_enable_bluetooth_evt entered: status 0
11-23 11:36:22.914  4719  4762 I bt_btif_core: btif_enable_bluetooth_evt finished
11-23 11:36:22.935  2428  2428 D BluetoothManagerService: BluetoothServiceConnection: com.android.bluetooth.gatt.GattService
11-23 11:36:22.940  2428  2428 V SettingsProvider: Notifying for 0: content://settings/global/bluetooth_on
11-23 11:36:22.953  4719  4719 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:36:22.958  4719  4719 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:36:22.982  4719  4719 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:36:22.991  4719  4719 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:36:23.042  4719  4802 I chatty  : uid=1002(bluetooth) identical 3 lines
11-23 11:36:23.055  4719  4719 D A2dpService: setA2dpService(): set to: com.android.bluetooth.a2dp.A2dpService@ba9ca1c
11-23 11:36:23.060  4719  4719 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:36:23.065  4719  4719 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:36:23.077  4719  4719 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:36:23.099  4719  4719 D BluetoothMapAccountLoader: Found 0 application(s) with intent android.bluetooth.action.BLUETOOTH_MAP_PROVIDER
11-23 11:36:23.103  4719  4719 D BluetoothMapAccountLoader: Found 0 application(s) with intent android.bluetooth.action.BLUETOOTH_MAP_IM_PROVIDER
11-23 11:36:23.108  4719  4719 D BluetoothMapService: setBluetoothMapService(): set to: com.android.bluetooth.map.BluetoothMapService@5fde852
11-23 11:36:23.114  4719  4719 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:36:23.129  2428  4425 D MediaSessionService: The callback android.media.session.ICallback$Stub$Proxy@9ed147c is set by com.android.bluetooth
11-23 11:36:23.130  4719  4802 I bt_stack: [INFO:connection_handler.cc(206)] virtual bool bluetooth::avrcp::ConnectionHandler::AvrcpConnect(bool, const RawAddress &): handle=0000 status= 000000
11-23 11:36:23.147  4719  4719 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:36:23.162  4719  4719 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:36:23.177  4719  4719 D BtOppService: setBluetoothOppService(): set to: com.android.bluetooth.opp.BluetoothOppService@dad0a02
11-23 11:36:23.180  4719  4719 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:36:23.197  4719  4719 D BluetoothPbapService: setBluetoothPbapService(): set to: com.android.bluetooth.pbap.BluetoothPbapService@dddd75a
11-23 11:36:23.470  4846  4846 D music_MediaPlaybackSer: OnGetRoot: clientPackageName=com.android.bluetooth; clientUid=1002 ; rootHints=null
11-23 11:36:23.496  4846  4846 D music_MediaPlaybackSer: OnGetRoot: clientPackageName=com.android.bluetooth; clientUid=1002 ; rootHints=null
11-23 11:36:26.267  2428  2473 W BluetoothManagerService: Unable to bind with intent: Intent { act=android.bluetooth.IBluetoothHeadset cmp=com.android.bluetooth/.hfp.HeadsetService }
11-23 11:36:30.464  2961  2961 D SettingsActivity: Switching to fragment com.android.settings.bluetooth.BluetoothPairingDetail
11-23 11:36:30.464  2961  2961 D SubSettings: Launching fragment com.android.settings.bluetooth.BluetoothPairingDetail
11-23 11:36:30.472  2961  2961 D PrefCtrlListHelper: Could not find Context-only controller for pref: com.android.settings.bluetooth.BluetoothDeviceRenamePreferenceController
11-23 11:39:36.865  2428  4314 D BluetoothManagerService: disable(): mBluetooth = android.bluetooth.IBluetooth$Stub$Proxy@766fd53 mBinding = false
11-23 11:39:36.868  2428  2428 V SettingsProvider: Notifying for 0: content://settings/global/bluetooth_on
11-23 11:39:36.873  2428  2473 D BluetoothManagerService: MESSAGE_DISABLE: mBluetooth = android.bluetooth.IBluetooth$Stub$Proxy@766fd53
11-23 11:39:36.948  4719  4719 D BluetoothSocket: close() this: android.bluetooth.BluetoothSocket@6cf00b9, channel: 5, mSocketIS: android.net.LocalSocketImpl$SocketInputStream@71dcfe, mSocketOS: android.net.LocalSocketImpl$SocketOutputStream@c44ac5fmSocket: android.net.LocalSocket@63c86ac impl:android.net.LocalSocketImpl@dd5ef75 fd:java.io.FileDescriptor@c8acb0a, mSocketState: LISTENING
11-23 11:39:36.954  4719  4719 D BluetoothSocket: close() this: android.bluetooth.BluetoothSocket@4b1af7b, channel: 4099, mSocketIS: android.net.LocalSocketImpl$SocketInputStream@7416198, mSocketOS: android.net.LocalSocketImpl$SocketOutputStream@6230df1mSocket: android.net.LocalSocket@4928dd6 impl:android.net.LocalSocketImpl@321c857 fd:java.io.FileDescriptor@ab6ff44, mSocketState: LISTENING
11-23 11:39:36.997  2428  4425 D MediaSessionService: The callback null is set by com.android.bluetooth
11-23 11:39:37.031  4719  4838 D BluetoothSocket: close() this: android.bluetooth.BluetoothSocket@f81b162, channel: 4, mSocketIS: android.net.LocalSocketImpl$SocketInputStream@21092f3, mSocketOS: android.net.LocalSocketImpl$SocketOutputStream@8c6cbb0mSocket: android.net.LocalSocket@8d48a29 impl:android.net.LocalSocketImpl@94d81ae fd:java.io.FileDescriptor@e176b4f, mSocketState: LISTENING
11-23 11:39:37.032  4719  4838 D BluetoothSocket: close() this: android.bluetooth.BluetoothSocket@c4f2dc, channel: 4097, mSocketIS: android.net.LocalSocketImpl$SocketInputStream@8029fe5, mSocketOS: android.net.LocalSocketImpl$SocketOutputStream@5f40abamSocket: android.net.LocalSocket@a096d6b impl:android.net.LocalSocketImpl@11c60c8 fd:java.io.FileDescriptor@1425561, mSocketState: LISTENING
11-23 11:39:37.060  4719  4719 W BtOppService: unregisterReceivers java.lang.IllegalArgumentException: Receiver not registered: com.android.bluetooth.opp.BluetoothOppService$3@b460f13
11-23 11:39:37.093  4719  4755 I bt_btif_core: btif_disable_bluetooth entered
11-23 11:39:37.099  4719  4755 I bt_btif_core: btif_disable_bluetooth finished
11-23 11:39:38.075  2428  2473 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@766fd53
11-23 11:39:38.075  2961  3536 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@4fdcc7c
11-23 11:39:38.075  2788  4856 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@9e43e3f
11-23 11:39:38.075  2428  2473 D BluetoothManagerService: unbindAndFinish(): android.bluetooth.IBluetooth$Stub$Proxy@766fd53 mBinding = false mUnbinding = false
11-23 11:39:38.075  2916  3587 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@a9f9004
11-23 11:39:38.075  4719  4859 D BluetoothAdapter: onBluetoothServiceDown: com.android.bluetooth.btservice.AdapterService$AdapterServiceBinder@31cbb43
11-23 11:39:38.099  4719  4762 E BluetoothAdapterService: Repeated wake lock release; aborting release: bluetooth_timer
11-23 11:39:38.100  4719  4762 I bt_btif_core: btif_disable_bluetooth_evt entered
11-23 11:39:38.101  2131  4812 I android.hardware.bluetooth@1.0-impl: BluetoothHci::close()
11-23 11:39:38.101  2131  4812 D android.hardware.bluetooth@1.0-impl: low_power_mode_cb result: 0
11-23 11:39:38.973  4719  4762 I bt_btif_core: btif_disable_bluetooth_evt finished
11-23 11:39:38.976  4719  4755 I bt_btif_core: btif_cleanup_bluetooth entered
11-23 11:39:38.978  4719  4755 I bt_btif_core: btif_cleanup_bluetooth finished
11-23 11:39:39.085  2428  3014 I ActivityManager: Process com.android.bluetooth (pid 4719) has died: psvc PER
11-23 11:39:39.087  2428  3014 W ActivityManager: Scheduling restart of crashed service com.android.bluetooth/.btservice.AdapterService in 1000ms
11-23 11:39:40.117  2428  2484 I ActivityManager: app.processName = com.android.bluetooth
11-23 11:39:40.117  2428  2484 I ActivityManager: Start proc 14877:com.android.bluetooth/1002 for service {com.android.bluetooth/com.android.bluetooth.btservice.AdapterService}
11-23 11:39:40.331 14877 14877 I         : [1123/113940.330742:INFO:com_android_bluetooth_btservice_AdapterService.cpp(628)] hal_util_load_bt_library loaded HAL: btinterface=0x7c0baa4440, handle=0xc80620b44be4bbf3
11-23 11:39:40.368 14877 14913 I bt_btif_core: btif_init_bluetooth entered
11-23 11:39:40.368 14877 14913 I bt_stack_config: init attempt to load stack conf from /etc/bluetooth/bt_stack.conf
11-23 11:39:40.376 14877 14913 I bt_btif_core: btif_init_bluetooth finished
11-23 11:39:40.448 14877 14877 D BluetoothAdapterService: setAdapterService() - trying to set service to com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:39:40.457  2428  2428 D BluetoothManagerService: BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
11-23 11:39:40.464 14877 14899 D BluetoothAdapter: onBluetoothServiceUp: com.android.bluetooth.btservice.AdapterService$AdapterServiceBinder@31cbb43
11-23 11:39:40.464  2961  2986 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@fd9219c
11-23 11:39:40.465  2428  2473 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@2e4718a
11-23 11:39:40.465  2916  3587 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@ae9b9ed
11-23 11:39:40.466  2788  4856 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@229397
11-23 11:39:40.512 14877 14877 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:39:40.519 14877 14877 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:39:40.564 14877 14877 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:39:40.586  2131  2131 I HwBinder:2131_2: type=1400 audit(0.0:142): avc: denied { create } for scontext=u:r:hal_bluetooth_default:s0 tcontext=u:r:hal_bluetooth_default:s0 tclass=udp_socket permissive=1
11-23 11:39:40.586  2131  2131 I HwBinder:2131_2: type=1400 audit(0.0:143): avc: denied { read } for name="/" dev="tmpfs" ino=7445 scontext=u:r:hal_bluetooth_default:s0 tcontext=u:object_r:device:s0 tclass=dir permissive=1
11-23 11:39:40.585  2131  4812 I android.hardware.bluetooth@1.0-impl: BluetoothHci::initialize()
11-23 11:39:40.588  2131  4812 E libbt_vendor: aicbt_load_stack_conf unable to open file '/vendor/etc/bluetooth/aicbt.conf': No such file or directory
11-23 11:39:40.588  2131  4812 E libbt_vendor: no config find from file '/vendor/etc/bluetooth/aicbt.conf'
11-23 11:39:40.591  2131  4812 D android.hardware.bluetooth@1.0-impl: Open vendor library loaded
11-23 11:39:40.764  2131 14965 D android.hardware.bluetooth@1.0-impl: OnFirmwareConfigured result: 0
11-23 11:39:40.764  2131 14965 I android.hardware.bluetooth@1.0-impl: Firmware configured in 0.039s
11-23 11:39:40.764  2131 14965 I android.hardware.bluetooth@1.0-impl: OnFirmwareConfigured: lpm_timeout_ms 3000
11-23 11:39:40.764  2131 14965 D android.hardware.bluetooth@1.0-impl: low_power_mode_cb result: 0
11-23 11:39:40.764  2131 14965 D android.hardware.bluetooth@1.0-impl: OnFirmwareConfigured Calling StartLowPowerWatchdog()
11-23 11:39:40.830  2131 14959 E aic_heartbeat: load_aicbt_heartbeat_conf unable to open file '/vendor/etc/bluetooth/aicbt_heartbeat.conf': No such file or directory
11-23 11:39:40.895 14877 14920 I bt_btif_core: btif_enable_bluetooth_evt entered: status 0
11-23 11:39:40.901 14877 14920 I bt_btif_core: btif_enable_bluetooth_evt finished
11-23 11:39:40.961  2428  2428 D BluetoothManagerService: BluetoothServiceConnection: com.android.bluetooth.gatt.GattService
11-23 11:39:40.967  2428  2428 V SettingsProvider: Notifying for 0: content://settings/global/bluetooth_on
11-23 11:39:40.977 14877 14877 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:39:40.982 14877 14877 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:39:41.005 14877 14877 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:39:41.009 14877 14877 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:39:41.034 14877 14970 I chatty  : uid=1002(bluetooth) bt_main_thread identical 3 lines
11-23 11:39:41.040 14877 14877 D A2dpService: setA2dpService(): set to: com.android.bluetooth.a2dp.A2dpService@ba9ca1c
11-23 11:39:41.043 14877 14877 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:39:41.047 14877 14877 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:39:41.055 14877 14877 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:39:41.063 14877 14877 D BluetoothMapAccountLoader: Found 0 application(s) with intent android.bluetooth.action.BLUETOOTH_MAP_PROVIDER
11-23 11:39:41.064 14877 14877 D BluetoothMapAccountLoader: Found 0 application(s) with intent android.bluetooth.action.BLUETOOTH_MAP_IM_PROVIDER
11-23 11:39:41.066 14877 14877 D BluetoothMapService: setBluetoothMapService(): set to: com.android.bluetooth.map.BluetoothMapService@5fde852
11-23 11:39:41.071 14877 14877 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:39:41.079  2428  3214 D MediaSessionService: The callback android.media.session.ICallback$Stub$Proxy@b4e5a7c is set by com.android.bluetooth
11-23 11:39:41.080 14877 14970 I bt_stack: [INFO:connection_handler.cc(206)] virtual bool bluetooth::avrcp::ConnectionHandler::AvrcpConnect(bool, const RawAddress &): handle=0000 status= 000000
11-23 11:39:41.088 14877 14877 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:39:41.096 14877 14877 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:39:41.103 14877 14877 D BtOppService: setBluetoothOppService(): set to: com.android.bluetooth.opp.BluetoothOppService@dad0a02
11-23 11:39:41.107 14877 14877 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:39:41.114 14877 14877 D BluetoothPbapService: setBluetoothPbapService(): set to: com.android.bluetooth.pbap.BluetoothPbapService@dddd75a
11-23 11:39:41.160  4846  4846 D music_MediaPlaybackSer: OnGetRoot: clientPackageName=com.android.bluetooth; clientUid=1002 ; rootHints=null
11-23 11:39:41.230  4846  4846 D music_MediaPlaybackSer: OnGetRoot: clientPackageName=com.android.bluetooth; clientUid=1002 ; rootHints=null
11-23 11:39:42.411  2961  2961 D SettingsActivity: Switching to fragment com.android.settings.bluetooth.BluetoothPairingDetail
11-23 11:39:42.411  2961  2961 D SubSettings: Launching fragment com.android.settings.bluetooth.BluetoothPairingDetail
11-23 11:39:42.414  2961  2961 D PrefCtrlListHelper: Could not find Context-only controller for pref: com.android.settings.bluetooth.BluetoothDeviceRenamePreferenceController
