楼主 # 2024-12-04 17:30:52
memory
已发帖子: 703
A133 AW869C 蓝牙开启失败,请问是什么原因呢?
12-04 16:39:58.393  2451  2661 E[  877.899234] AICWFDBG(LOGTRACE)       rwnx_send_msg (118)MM_GET_STA_INFO_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
 WifiVendorHal: getWifiLinkLayer[  877.912624] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
Stats_1_3_Internal(l.926) failed[  877.924856] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x76
 {.code = ERROR_NOT_AVAILABLE, .[  877.933604] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
description = }
[  877.944334] AICWFDBG(LOGDEBUG)       rwnx_fill_station_info ModTx(0):4 TxIndex:6 ModRx(0):0 RxHTIndex:0 RxVHTIndex:0 RxHEIndex:0 RSSI:-35
12-04 16:40:00.003  2768  2768 D KeyguardClockSwitch: Updating clock: 440
12-04 16:40:00.931  2451  2638 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 16:40:01.025  2451  7203 I ActivityTaskManager: START u0 {act=android.intent.action.MAIN cmp=com.android.settings/.SubSettings (has extras)} from uid 1000
12-04 16:40:01.016  2451  2638 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 16:40:01.029  2140  2140 I AW_PowerHAL_Platform: ==LAUNCH_MODE==
12-04 16:40:01.030  2130  4727 D audio_hw_primary: start_output_stream
12-04 16:40:01.030  2130  4727 V audio_platform: disable backend pcm(direction:PCM_OUT)
12-04 16:40:01.030  2130  4727 D audio_route: Apply path: out-reset
12-04 16:40:01.030  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.030  2130  4727 D audio_route: Apply path: media-speaker
12-04 16:40:01.030  2130  4727 D audio_hw_primary: select device(out):pdev:OUT_DULSPK, path:media-speaker
12-04 16:40:01.030  2130  4727 D audio_hw_primary: +++++++++++++++ start_output_stream: pcm sample_rate: 48000,pcm fmt: 0x00000000,pcm channels: 2
12-04 16:40:01.031  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.052  2140  2140 D AW_PowerHAL: c-s = 8
12-04 16:40:01.068  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.079  2130  4727 I chatty  : uid=1041(audioserver) writer identical 1 line
12-04 16:40:01.091  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.096  3026  3026 W ActivityThread: handleWindowVisibility: no activity for token android.os.BinderProxy@ba65f49
12-04 16:40:01.109  2146  2227 D AudioFlinger: mixer(0x77d6647f80) throttle end: throttle time(11)
12-04 16:40:01.112  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.118  3026  3026 D SettingsActivity: Starting onCreate
12-04 16:40:01.131  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.142  3026  3026 D SettingsActivity: Starting to set activity title
12-04 16:40:01.143  3026  3026 D SettingsActivity: Done setting title
12-04 16:40:01.143  3026  3026 D SettingsActivity: Switching to fragment com.android.settings.bluetooth.BluetoothPairingDetail
12-04 16:40:01.143  3026  3026 D SubSettings: Launching fragment com.android.settings.bluetooth.BluetoothPairingDetail
12-04 16:40:01.147  3026  3026 D PrefCtrlListHelper: Could not find Context-only controller for pref: com.android.settings.bluetooth.BluetoothDeviceRenamePreferenceController
12-04 16:40:01.153  3026  3026 D BluetoothPairingDetail: NO dashboard tiles for BluetoothPairingDetail
12-04 16:40:01.153  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.153  3026  3026 D BluetoothPairingDetail: All preferences added, reporting fully drawn
12-04 16:40:01.158  2451  2499 I ActivityTaskManager: Fully drawn com.android.settings/.SubSettings: +131ms
12-04 16:40:01.162  3026  3026 D SettingsActivity: Executed frag manager pendingTransactions
12-04 16:40:01.174  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.181  3026  3026 D LocalBluetoothManager: setting foreground activity to non-null context
12-04 16:40:01.182  2451  7203 D BluetoothManagerService: enable(com.android.settings):  mBluetooth =null mBinding = false mState = OFF
12-04 16:40:01.182  2451  7203 D BluetoothManagerService: enable returning
12-04 16:40:01.182  2451  2492 D BluetoothManagerService: MESSAGE_ENABLE(0): mBluetooth = null
12-04 16:40:01.194  3026  6738 W TileUtils: Found com.android.settings.Settings$DataUsageSummaryActivity for intent Intent { act=com.android.settings.action.SETTINGS pkg=com.android.settings } missing metadata com.android.settings.category
12-04 16:40:01.195  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.211  2124  2124 D Zygote  : Forked child process 8620
12-04 16:40:01.217  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.217  2451  2501 I ActivityManager: app.processName = com.android.bluetooth
12-04 16:40:01.217  2451  2501 I ActivityManager: Start proc 8620:com.android.bluetooth/1002 for service {com.android.bluetooth/com.android.bluetooth.btservice.AdapterService}
12-04 16:40:01.218  8620  8620 I Zygote  : seccomp disabled by setenforce 0
12-04 16:40:01.243  2451  3243 D PackageManager: Instant App installer not found with android.intent.action.INSTALL_INSTANT_APP_PACKAGE
12-04 16:40:01.244  2451  3243 D PackageManager: Clear ephemeral installer activity
12-04 16:40:01.250  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.267  3026  8619 D SettingsActivity: Enabled state changed for some tiles, reloading all categories {com.android.settings/com.android.settings.Settings$PowerUsageSummaryActivity},
12-04 16:40:01.273  2130  4727 V audio_platfor[  880.972191] AICWFDBG(LOGTRACE) rwnx_send_msg (118)MM_GET_STA_INFO_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
12-04 16:40:01.295  2130  4727 V audio_platform: mode(0),devices(0x2):p[  880.996240] AICWFDBG(LOGTRACE)        rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[  881.005789] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x76
12-04 16:40:01.296  3026  6738 W TileUtils: Found com.android.se[  881.017080] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
ttings.Settings$DataUsageSummaryActivity for intent Intent { act[  881.031524] AICWFDBG(LOGDEBUG)       rwnx_fill_station_info ModTx(0):4 TxIndex:6 ModRx(0):0 RxHTIndex:0 RxVHTIndex:0 RxHEIndex:0 RSSI:-34
12-04 16:40:01.305  8620  8620 I droid.bluetoot: The ClassLoaderContext is a special shared library.
12-04 16:40:01.313  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.369  2451  7111 D PackageManager: Instant App installer not found with android.intent.action.INSTALL_INSTANT_APP_PACKAGE
12-04 16:40:01.369  2451  7111 D PackageManager: Clear ephemeral installer activity
12-04 16:40:01.376  2130  4727 I chatty  : uid=1041(audioserver) writer identical 3 lines
12-04 16:40:01.397  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.399  8620  8620 D BluetoothOppFileProvider: Initialized
12-04 16:40:01.418  3026  8619 D SettingsActivity: Enabled state changed for some tiles, reloading all categories {com.android.settings/com.android.settings.Settings$PowerUsageSummaryActivity},
12-04 16:40:01.422  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.430  3026  6738 W TileUtils: Found com.android.settings.Settings$DataUsageSummaryActivity for intent Intent { act=com.android.settings.action.SETTINGS pkg=com.android.settings } missing metadata com.android.settings.category
12-04 16:40:01.432  2140  2140 I AW_PowerHAL_Platform: ==NORMAL MODE==
12-04 16:40:01.436  2140  2140 D AW_PowerHAL: c-s = 18
12-04 16:40:01.442  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.462  2130  4727 V audio_platform: mode(0)[  881.186922] bluetooth_set_power: start_block=1
,devices(0x2):platform device:OU[  881.193501] aicbsp: aicbsp_set_subsys, subsys: AIC_BLUETOOTH, state to: 0
T_DULSPK(0x4)
12-04 16:40:01.46[  881.203569] aicbsp: aicbsp_set_subsys, power state no need to change, current: 1
5  2451  2661 E WifiVendorHal: g[  881.214784] bluetooth_set_power: end_block=1
etWifiLinkLayerStats_1_3_Interna[  881.222610] bluetooth_set_power: start_block=0
l(l.926) failed {.code = ERROR_N[  881.230064] aicbsp: aicbsp_set_subsys, subsys: AIC_BLUETOOTH, state to: 1
OT_AVAILABLE, .description = }
[  881.240387] aicbsp: aicbsp_set_subsys, power state no need to change, current: 1
12-04 16:40:01.480  8620  8620 V[  881.251412] bluetooth_set_power: end_block=0
 AdapterServiceConfig: Adding HeadsetService
12-04 16:40:01.482[  881.262458] [BT_LPM] bluesleep_outgoing_data: tx was sleeping, wakeup it
  8620  8620 V AdapterServiceCon[  881.272082] [BT_LPM] hsuart_power: bsi->uport = NULL, has_lpm_enabled = 0
fig: Adding A2dpService
12-04 16:40:01.482  8620  8620 V AdapterServiceConfig: Adding HidHostService
12-04 16:40:01.482  8620  8620 V AdapterServiceConfig: Adding PanService
12-04 16:40:01.482  8620  8620 V AdapterServiceConfig: Adding GattService
12-04 16:40:01.482  8620  8620 V AdapterServiceConfig: Adding BluetoothMapService
12-04 16:40:01.482  8620  8620 V AdapterServiceConfig: Adding AvrcpTargetService
12-04 16:40:01.482  8620  8620 V AdapterServiceConfig: Adding HidDeviceService
12-04 16:40:01.482  8620  8620 V AdapterServiceConfig: Adding BluetoothOppService
12-04 16:40:01.482  8620  8620 V AdapterServiceConfig: Adding BluetoothPbapService
12-04 16:40:01.483  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.485  3026  3041 I ndroid.setting: Background concurrent copying GC freed 67525(3451KB) AllocSpace objects, 28(616KB) LOS objects, 49% free, 4827KB/9654KB, paused 102us total 243.028ms
12-04 16:40:01.507  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.520  8620  8620 I         : [1204/164001.520505:INFO:com_android_bluetooth_btservice_AdapterService.cpp(628)] hal_util_load_bt_library loaded HAL: btinterface=0x79b8b64440, handle=0x2ad82ce9145ff26d
12-04 16:40:01.521  8620  8620 D BluetoothAdapterService: onCreate()
12-04 16:40:01.526  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.528  8620  8620 D AdapterState: make() - Creating AdapterState
12-04 16:40:01.528  2230  2230 D omx_venc: <__AwOmxVencFillThisBuffer:2082>: vencOutPort: fill_this_buffer 50 times
12-04 16:40:01.531  8620  8660 I AdapterState: OFF : entered
12-04 16:40:01.531  8620  8660 D AdapterProperties: Setting state to OFF
12-04 16:40:01.532  8620  8620 I bt_btif : init: start restricted = 0 ; single user = 0
12-04 16:40:01.532  8620  8620 D bt_osi_allocation_tracker: canary initialized
12-04 16:40:01.533  8620  8661 I         : [1204/164001.533189:INFO:message_loop_thread.cc(175)] Run: message loop starting for thread bt_stack_manager_thread
12-04 16:40:01.533  8620  8661 I bt_stack_manager: event_init_stack is initializing the stack
12-04 16:40:01.536  8620  8661 I         : [1204/164001.536857:INFO:btif_config.cc(647)] hash_file: Disabled for multi-user
12-04 16:40:01.536  8620  8661 I         : [1204/164001.536961:INFO:btif_config.cc(675)] read_checksum_file: Disabled for multi-user
12-04 16:40:01.537  8620  8661 E bt_btif_config: Config is missing adapter section
12-04 16:40:01.537  8620  8661 W bt_btif_config: init unable to load config file: /data/misc/bluedroid/bt_config.conf; using backup.
12-04 16:40:01.537  8620  8661 I         : [1204/164001.537382:INFO:btif_config.cc(647)] hash_file: Disabled for multi-user
12-04 16:40:01.537  8620  8661 I         : [1204/164001.537440:INFO:btif_config.cc(675)] read_checksum_file: Disabled for multi-user
12-04 16:40:01.537  8620  8661 W bt_btif_config: init unable to load backup; attempting to transcode legacy file.
12-04 16:40:01.538  8620  8661 E bt_btif_config_transcode: btif_config_transcode unable to load XML file '/data/misc/bluedroid/bt_config.xml': 3
12-04 16:40:01.538  8620  8661 E bt_btif_config: init unable to transcode legacy file; creating empty config.
12-04 16:40:01.538  8620  8661 W         : [1204/164001.538167:WARNING:btif_config.cc(151)] read_or_set_metrics_salt: Failed to read metrics salt from config
12-04 16:40:01.538  8620  8661 I         : [1204/164001.538239:INFO:btif_config.cc(162)] read_or_set_metrics_salt: Metrics salt is not invalid, creating new one
12-04 16:40:01.539  8620  8661 E bt_osi_alarm: timer_create_internal unable to create timer with clock 9: Unknown error 524
12-04 16:40:01.539  8620  8661 E bt_osi_alarm: The kernel might not have support for timer_create(CLOCK_BOOTTIME_ALARM): https://lwn.net/Articles/429925/
12-04 16:40:01.539  8620  8661 E bt_osi_alarm: See following patches: https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/log/?qt=grep&q=CLOCK_BOOTTIME_ALARM
12-04 16:40:01.540  8620  8665 I bt_osi_thread: run_thread: thread id 8665, thread name alarm_default_ca started
12-04 16:40:01.541  8620  8666 I bt_osi_thread: run_thread: thread id 8666, thread name alarm_dispatcher started
12-04 16:40:01.543  8620  8661 I bt_btif_core: btif_init_bluetooth entered
12-04 16:40:01.544  8620  8661 I bt_stack_config: init attempt to load stack conf from /etc/bluetooth/bt_stack.conf
12-04 16:40:01.545  8620  8667 I         : [1204/164001.545291:INFO:message_loop_thread.cc(175)] Run: message loop starting for thread bt_jni_thread
12-04 16:40:01.545  8620  8661 I bt_btif_core: btif_init_bluetooth finished
12-04 16:40:01.545  8620  8661 I bt_stack_manager: event_init_stack finished
12-04 16:40:01.545  8620  8620 I bt_osi_wakelock: wakelock_set_os_callouts set to non-native
12-04 16:40:01.545  8620  8620 I bt_btif : get_profile_interface: id = socket
12-04 16:40:01.546  8620  8667 E bt_btif_storage: btif_storage_get_adapter_property: Controller not ready! Unable to return Bluetooth Address
12-04 16:40:01.546  8620  8667 E BluetoothServiceJni: adapter_properties_callback: Status 1 is incorrect
12-04 16:40:01.547  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.548  8620  8620 I bt_btif : get_profile_interface: id = sdp
12-04 16:40:01.548  8620  8667 D AdapterProperties: Name is: QUAD-CORE A133 c3
12-04 16:40:01.548  8620  8667 D AdapterProperties: BT Class:1a011c
12-04 16:40:01.549  2451  2451 D BluetoothManagerService: Bluetooth Adapter name changed to QUAD-CORE A133 c3
12-04 16:40:01.549  2451  2451 D BluetoothManagerService: Stored Bluetooth name: QUAD-CORE A133 c3
12-04 16:40:01.551  8620  8620 I BluetoothAdapterService: Phone policy enabled
12-04 16:40:01.553  2768  2768 W StatusBarIconController: setIconVisibility index: 27
12-04 16:40:01.556  8620  8620 D BluetoothActiveDeviceManager: start()
12-04 16:40:01.568  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.569  8620  8670 D BluetoothActiveDeviceManager: onAudioDevicesAdded
12-04 16:40:01.571  8620  8670 D BluetoothActiveDeviceManager: Audio device added: QUAD-CORE A133 c3 type: 2
12-04 16:40:01.571  8620  8670 D BluetoothActiveDeviceManager: Audio device added: QUAD-CORE A133 c3 type: 15
12-04 16:40:01.580  3026  3026 D LocalBluetoothManager: setting foreground activity to null
12-04 16:40:01.583  8620  8620 D BluetoothDatabase: start()
12-04 16:40:01.585  8620  8620 D BluetoothDatabase: Load Database
12-04 16:40:01.589  8620  8620 D BluetoothAdapterService: setAdapterService() - trying to set service to com.android.bluetooth.btservice.AdapterService@3d23669
12-04 16:40:01.589  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.598  8620  8620 D BluetoothAdapterService: onBind()
12-04 16:40:01.599  2451  2451 D BluetoothManagerService: BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
12-04 16:40:01.599  2451  2492 D BluetoothManagerService: MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
12-04 16:40:01.601  2451  2492 D BluetoothManagerService: Broadcasting onBluetoothServiceUp() to 5 receivers.
12-04 16:40:01.601  2451  2492 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@b27333
12-04 16:40:01.602  3026  3045 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@bf2291e
12-04 16:40:01.602  2768  2786 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@407851d
12-04 16:40:01.602  2894  3435 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@c170371
12-04 16:40:01.603  8620  8640 D BluetoothAdapter: onBluetoothServiceUp: com.android.bluetooth.btservice.AdapterService$AdapterServiceBinder@f0d0c95
12-04 16:40:01.605  8620  8643 D BluetoothAdapterService: enable() - Enable called with quiet mode status =  false
12-04 16:40:01.606  8620  8660 I AdapterState: BLE_TURNING_ON : entered
12-04 16:40:01.606  8620  8660 D AdapterProperties: Setting state to BLE_TURNING_ON
12-04 16:40:01.606  8620  8660 D BluetoothAdapterService: updateAdapterState() - Broadcasting state BLE_TURNING_ON to 1 receivers.
12-04 16:40:01.607  2451  2492 D BluetoothManagerService: MESSAGE_GET_NAME_AND_ADDRESS
12-04 16:40:01.612  2230  2940 D omx_venc: <__AwOmxVencEmptyThisBuffer:2043>: vencInPort: , empty_this_buffer 50 times
12-04 16:40:01.613  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.614  2451  2492 D BluetoothManagerService: Stored Bluetooth name: QUAD-CORE A133 c3
12-04 16:40:01.615  2451  2492 D BluetoothManagerService: MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
12-04 16:40:01.615  2451  2492 D BluetoothManagerService: Sending BLE State Change: OFF > BLE_TURNING_ON
12-04 16:40:01.626  8620  8660 D BluetoothAdapterService: bleOnProcessStart()
12-04 16:40:01.627  8620  8660 I AdapterProperties: init(), maxConnectedAudioDevices, default=5, propertyOverlayed=5, finalValue=5
12-04 16:40:01.628  8620  8672 I BluetoothDatabase: cacheMetadata
12-04 16:40:01.630  8620  8660 D BluetoothAdapterService: bleOnProcessStart() - Make Bond State Machine
12-04 16:40:01.630  8620  8660 D BluetoothBondStateMachine: make
12-04 16:40:01.632  8620  8681 I BluetoothBondStateMachine: StableState(): Entering Off State
12-04 16:40:01.632  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.638  8620  8620 I BtGatt.JNI: classInitNative(L876): classInitNative: Success!
12-04 16:40:01.642  8620  8620 D BtGatt.DebugUtils: handleDebugAction() action=null
12-04 16:40:01.644  8620  8620 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@3d23669
12-04 16:40:01.647  8620  8620 I bt_btif : get_profile_interface: id = gatt
12-04 16:40:01.647  8620  8620 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@3d23669
12-04 16:40:01.654  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.669  8620  8620 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@3d23669
12-04 16:40:01.675  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.675  8620  8661 I bt_stack_manager: event_start_up_stack is bringing up the stack
12-04 16:40:01.675  8620  8661 I bt_core_module: module_start_up Starting module "btif_config_module"
12-04 16:40:01.676  8620  8661 I bt_core_module: module_start_up Started module "btif_config_module"
12-04 16:40:01.676  8620  8661 I bt_core_module: module_start_up Starting module "btsnoop_module"
12-04 16:40:01.677  8620  8661 I         : [1204/164001.676979:INFO:btsnoop.cc(207)] start_up: Snoop Logs disabled
12-04 16:40:01.677  8620  8661 I         : [1204/164001.677131:INFO:btsnoop.cc(338)] delete_btsnoop_files: Deleting snoop logs if they exist. filtered = 1
12-04 16:40:01.677  8620  8661 I         : [1204/164001.677400:INFO:btsnoop.cc(338)] delete_btsnoop_files: Deleting snoop logs if they exist. filtered = 0
12-04 16:40:01.677  8620  8661 I bt_core_module: module_start_up Started module "btsnoop_module"
12-04 16:40:01.677  8620  8661 I bt_core_module: module_start_up Starting module "hci_module"
12-04 16:40:01.677  8620  8661 I bt_hci  : hci_module_start_up
12-04 16:40:01.678  8620  8688 I         : [1204/164001.678402:INFO:message_loop_thread.cc(175)] Run: message loop starting for thread bt_hci_thread
12-04 16:40:01.678  8620  8661 D bt_hci  : hci_module_start_up starting async portion
12-04 16:40:01.678  8620  8688 I bt_hci  : hci_initialize
12-04 16:40:01.681  8620  8688 I bt_hci  : hci_initialize: IBluetoothHci::getService() returned 0x7a0b7d8220 (remote)
12-04 16:40:01.681  5034  5040 I android.hardware.bluetooth@1.0-impl: BluetoothHci::initialize()
12-04 16:40:01.682  5034  5040 D         : get_local_address: Trying /sys/class/addr_mgt/addr_bt
12-04 16:40:01.682  5034  5040 D         : get_local_address: Got Factory BDA 52:24:EB:E7:63:5D
12-04 16:40:01.682  5034  5040 I bt_vendor: init
12-04 16:40:01.682  5034  5040 W bt_vendor: *****************************************************************
12-04 16:40:01.682  5034  5040 W bt_vendor: ** Warning - BT Vendor Lib is loaded in debug tuning mode!
12-04 16:40:01.682  5034  5040 W bt_vendor: ** If this is not intentional, rebuild libbt-vendor.so
12-04 16:40:01.682  5034  5040 W bt_vendor: ** with VENDOR_LIB_RUNTIME_TUNING_ENABLED=FALSE and
12-04 16:40:01.682  5034  5040 W bt_vendor: ** check if any run-time tuning parameters needed to be
12-04 16:40:01.682  5034  5040 W bt_vendor: ** carried to the build-time configuration accordingly.
12-04 16:40:01.683  5034  5040 I bt_vnd_conf: Attempt to load conf from /etc/bluetooth/bt_vendor.conf
12-04 16:40:01.683  5034  5040 I bt_vnd_conf: vnd_load_conf file >/etc/bluetooth/bt_vendor.conf< not found
12-04 16:40:01.683  5034  5040 D android.hardware.bluetooth@1.0-impl: Open vendor library loaded
12-04 16:40:01.683  5034  5040 D bt_vendor: op for 0
12-04 16:40:01.683  5034  5040 D bt_upio : init_rfkill: rfkill path /sys/devices/platform/aic-bt/rfkill/rfkill1
12-04 16:40:01.700  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.718  5034  5040 W bt_vendor: NOTE: BT_VND_PWR_ON now forces power-off first
12-04 16:40:01.718  5034  5040 D bt_upio : init_rfkill: rfkill path /sys/devices/platform/aic-bt/rfkill/rfkill1
12-04 16:40:01.726  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.742  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.756  5034  5040 D bt_vendor: op for 3
12-04 16:40:01.757  5034  5040 I bt_userial_vendor: userial vendor open: opening /dev/ttyS1
12-04 16:40:01.757  5034  5040 I bt_userial_vendor: device fd = 6 open
12-04 16:40:01.757  5034  5040 D bt_vendor: op for 1
12-04 16:40:01.757  5034  5040 E bt_hwcfg: hw_config_start
12-04 16:40:01.758  5034  5040 D bt_vendor: op for 7
12-04 16:40:01.758  5034  5040 E bt_hwcfg: set_wake_stat 1
12-04 16:40:01.758  5034  5040 D bt_upio : upio_set : pio 0 action 2, polarity 1
12-04 16:40:01.766  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:01.779  5034  5040 D bt_upio : upio_set: proc btwrite assertion, buffer: 1, timer_armed 1 0
12-04 16:40:01.790  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:02.272  2130  4727 I chatty  : uid=1041(audioserver) writer identical 23 lines
12-04 16:40:02.294  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:02.302  2451  2499 E system_server: No package ID 7f found for ID 0x7f08024a.
12-04 16:40:02.302  2451  2499 E system_server: No package ID 7f found for ID 0x7f1211a1.
12-04 16:40:02.302  2451  2499 E system_server: No package ID 7f found for ID 0x7f080249.
12-04 16:40:02.303  2451  2499 E system_server: No package ID 7f found for ID 0x7f1204e0.
12-04 16:40:02.303  2451  2499 E system_server: No package ID 7f found for ID 0x7f080248.
12-04 16:40:02.303  2451  2499 E system_server: No package ID 7f found for ID 0x7f120afa.
12-04 16:40:02.309  2894  2894 E PhoneInterfaceManager: [PhoneIntfMgr] getCarrierPackageNamesForIntent: No UICC
12-04 16:40:02.309  2894  2894 D CarrierSvcBindHelper: No carrier app for: 0
12-04 16:40:02.310  2451  2451 D DeviceIdleController: find package null
12-04 16:40:02.314  2451  2639 I InputReader: Reconfiguring input devices.  changes=0x00000010
12-04 16:40:02.316  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:02.320  2451  2451 I Telecom : DefaultDialerCache: Refreshing default dialer for user 0: now null: DDC.oR@ABE
12-04 16:40:02.325  3026  6738 W TileUtils: Found com.android.settings.Settings$DataUsageSummaryActivity for intent Intent { act=com.android.settings.action.SETTINGS pkg=com.android.settings } missing metadata com.android.settings.category
12-04 16:40:02.326  2451  2499 W VoiceInteractionManagerService: no available voice interaction services found for user 0
12-04 16:40:02.336  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:03.106  2130  4727 I chatty  : uid=1041(audioserver) writer identical 36 lines
12-04 16:40:03.126  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:03.146  2230  2276 D omx_venc: <__AwOmxVencFillThisBuffer:2082>: vencOutPort: fill_this_buffer 50 times
12-04 16:40:03.147  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:03.168  2130  4727 I chatty  : uid=1041(audioserver) writer identical 1 line
12-04 16:40:03.190  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:03.210  2230  2276 D omx_venc: <__AwOmxVencEmptyThisBuffer:2043>: vencInPort: , empty_this_buffer 50 times
12-04 16:40:03.211  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.149  2130  4727 I chatty  : uid=1041(audioserver) writer identical 44 lines
12-04 16:40:04.171  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.177  2451  2638 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 16:40:04.188  2768  2768 W KeyButtonRipple: mSupportHardware: true mDark: true mLastDark: false pressed: true
12-04 16:40:04.189  2768  2768 W KeyButtonRipple: mDelayTouchFeedback: false
12-04 16:40:04.189  2768  2768 W KeyButtonRipple: enterHardware cancelAnimations
12-04 16:40:04.189  2768  2768 W KeyButtonRipple: enterHardware isHorizontal is true!
12-04 16:40:04.191  2768  2768 W KeyButtonRipple: enterHardware mDelayTouchFeedback: false mPressed: false
12-04 16:40:04.191  2768  2768 W KeyButtonView: mCode: 4
12-04 16:40:04.192  2768  2768 I KeyButtonView: Back button event: ACTION_DOWN
12-04 16:40:04.192  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.195  2451  2638 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 16:40:04.205  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.225  2130  4727 I chatty  : uid=1041(audioserver) writer identical 1 line
12-04 16:40:04.247  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.261  2451  2638 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 16:40:04.262  2768  2768 W KeyButtonRipple: mSupportHardware: true mDark: true mLastDark: true pressed: false
12-04 16:40:04.264  2768  2768 I KeyButtonView: Back button event: ACTION_UP
12-04 16:40:04.267  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.268  2451  2638 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 16:40:04.268  2451  2491 D AutofillManagerService: onBackKeyPressed()
12-04 16:40:04.268  2451  2491 D AutofillManagerServiceImpl: Reset component for user 0:
12-04 16:40:04.269  2451  2491 D AutofillUI: destroySaveUiUiThread(): already destroyed
12-04 16:40:04.291  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.304  3026  3026 E ActivityThread: Failed to find provider info for com.google.android.gms.nearby.fastpair
12-04 16:40:04.306  3026  6738 E ActivityThread: Failed to find provider info for com.google.android.gms.nearby.fastpair
12-04 16:40:04.306  3026  3026 D LocalBluetoothManager: setting foreground activity to non-null context
12-04 16:40:04.306  3026  6738 W SliceManager: Unknown URI: content://com.google.android.gms.nearby.fastpair/device_status_list_item
12-04 16:40:04.308  3026  3026 D LocalBluetoothManager: setting foreground activity to non-null context
12-04 16:40:04.311  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.317  3026  3026 D LocalBluetoothManager: setting foreground activity to non-null context
12-04 16:40:04.331  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.337  3026  6738 W TileUtils: Found com.android.settings.Settings$DataUsageSummaryActivity for intent Intent { act=com.android.settings.action.SETTINGS pkg=com.android.settings } missing metadata com.android.settings.category
12-04 16:40:04.352  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.366  3026  8619 D SettingsActivity: No enabled state changed, skipping updateCategory call
12-04 16:40:04.374  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
[  884.064240] AICWFDBG(LOGTRACE)       rwnx_send_msg (118)MM_GET_STA_INFO_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[  884.075822] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
12-04 16:40:04.512  2130  4727 I[  884.084809] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x76
 chatty  : uid=1041(audioserver)[  884.095772] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
 writer identical 6 lines
12-04[  884.104606] AICWFDBG(LOGDEBUG)  rwnx_fill_station_info ModTx(0):4 TxIndex:6 ModRx(0):0 RxHTIndex:0 RxVHTIndex:0 RxHEIndex:0 RSSI:-35
 16:40:04.533  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.557  2451  2661 E WifiVendorHal: getWifiLinkLayerStats_1_3_Internal(l.926) failed {.code = ERROR_NOT_AVAILABLE, .description = }
12-04 16:40:04.558  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.603  2130  4727 I chatty  : uid=1041(audioserver) writer identical 2 lines
12-04 16:40:04.619  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.622  2768  2768 W StatusBarIconController: setIconVisibility index: 27
12-04 16:40:04.637  3026  3026 D LocalBluetoothManager: setting foreground activity to null
12-04 16:40:04.640  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.651  2451  3438 E TaskPersister: File error accessing recents directory (directory doesn't exist?).
12-04 16:40:04.790  2130  4727 I chatty  : uid=1041(audioserver) writer identical 7 lines
12-04 16:40:04.811  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.812  2451  2638 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 16:40:04.813  2768  2768 W KeyButtonRipple: mSupportHardware: true mDark: true mLastDark: true pressed: true
12-04 16:40:04.813  2768  2768 W KeyButtonRipple: mDelayTouchFeedback: false
12-04 16:40:04.813  2768  2768 W KeyButtonRipple: enterHardware cancelAnimations
12-04 16:40:04.813  2768  2768 W KeyButtonRipple: enterHardware isHorizontal is true!
12-04 16:40:04.815  2768  2768 W KeyButtonRipple: enterHardware mDelayTouchFeedback: false mPressed: false
12-04 16:40:04.815  2768  2768 W KeyButtonView: mCode: 4
12-04 16:40:04.816  2768  2768 I KeyButtonView: Back button event: ACTION_DOWN
12-04 16:40:04.821  2451  2638 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 16:40:04.830  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.865  2130  4727 I chatty  : uid=1041(audioserver) writer identical 2 lines
12-04 16:40:04.886  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.896  2451  2638 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 16:40:04.897  2768  2768 W KeyButtonRipple: mSupportHardware: true mDark: true mLastDark: true pressed: false
12-04 16:40:04.898  2768  2768 I KeyButtonView: Back button event: ACTION_UP
12-04 16:40:04.899  2230  2276 D omx_venc: <__AwOmxVencFillThisBuffer:2082>: vencOutPort: fill_this_buffer 50 times
12-04 16:40:04.899  2451  2491 D AutofillManagerService: onBackKeyPressed()
12-04 16:40:04.900  2451  2638 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 16:40:04.907  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.929  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.936  2451  7203 E TAG     : Exception = android.content.pm.PackageManager$NameNotFoundException: com.google.android.simappdialog.gts
12-04 16:40:04.936  2451  3243 E TAG     : Exception = android.content.pm.PackageManager$NameNotFoundException: com.google.android.simappdialog.gts
12-04 16:40:04.936  2451  3243 E TAG     : Exception = android.content.pm.PackageManager$NameNotFoundException: android.net.cts
12-04 16:40:04.936  2451  7203 E TAG     : Exception = android.content.pm.PackageManager$NameNotFoundException: android.net.cts
12-04 16:40:04.945  2451  2507 E BatteryExternalStatsWorker: no controller energy info supplied for bluetooth
12-04 16:40:04.946  3026  3026 D AvatarViewMixin: Feature disabled by config. Skipping
12-04 16:40:04.950  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.961  2230  2940 D omx_venc: <__AwOmxVencEmptyThisBuffer:2043>: vencInPort: , empty_this_buffer 50 times
12-04 16:40:04.964  2451  2507 E KernelCpuSpeedReader: Failed to read cpu-freq: /sys/devices/system/cpu/cpu0/cpufreq/stats/time_in_state: open failed: ENOENT (No such file or directory)
12-04 16:40:04.965  2451  7111 E TAG     : Exception = android.content.pm.PackageManager$NameNotFoundException: com.google.android.simappdialog.gts
12-04 16:40:04.965  2451  7111 E TAG     : Exception = android.content.pm.PackageManager$NameNotFoundException: android.net.cts
12-04 16:40:04.967  2451  2507 W BatteryExternalStatsWorker: modem info is invalid: ModemActivityInfo{ mTimestamp=0 mSleepTimeMs=0 mIdleTimeMs=0 mTxTimeMs[]=[0, 0, 0, 0, 0] mRxTimeMs=0 mEnergyUsed=0}
12-04 16:40:04.967  2451  2507 D KernelCpuUidUserSysTimeReader: Removing uids 1037-1037
12-04 16:40:04.971  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.996  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.998  3026  8619 D BatteryInfo: time for getStats: 63ms
12-04 16:40:04.999  3026  4758 D BatteryTipLoader: BatteryInfoLoader post query: 1ms
12-04 16:40:04.999  3026  4758 D BatteryInfo: time for getBatteryInfo: 0ms
12-04 16:40:04.999  3026  4758 D BatteryTipLoader: BatteryInfoLoader.loadInBackground: 1ms
12-04 16:40:05.001  3026  8619 D BatteryInfo: time for regular BatteryInfo: 3ms
12-04 16:40:05.001  3026  8619 D BatteryInfo: time for getBatteryInfo: 0ms
12-04 16:40:05.014  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:05.046  2130  4727 I chatty  : uid=1041(audioserver) writer identical 1 line
12-04 16:40:05.067  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:05.089  2451  6775 E TAG     : Exception = android.content.pm.PackageManager$NameNotFoundException: com.google.android.simappdialog.gts
12-04 16:40:05.089  2451  6775 E TAG     : Exception = android.content.pm.PackageManager$NameNotFoundException: android.net.cts
12-04 16:40:05.091  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:04.969  2451  2507 D KernelCpuUidUserSysTimeReader: Removing uids 1037-1037
12-04 16:40:05.101  2451  2507 E BatteryExternalStatsWorker: no controller energy info supplied for bluetooth
12-04 16:40:05.112  2451  2507 E KernelCpuSpeedReader: Failed to read cpu-freq: /sys/devices/system/cpu/cpu0/cpufreq/stats/time_in_state: open failed: ENOENT (No such file or directory)
12-04 16:40:05.110  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:05.117  3026  3026 D BatteryInfo: time for callback: 0ms
12-04 16:40:05.119  2451  2507 W BatteryExternalStatsWorker: modem info is invalid: ModemActivityInfo{ mTimestamp=0 mSleepTimeMs=0 mIdleTimeMs=0 mTxTimeMs[]=[0, 0, 0, 0, 0] mRxTimeMs=0 mEnergyUsed=0}
12-04 16:40:05.132  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:05.153  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:05.156  3026  4758 D BatteryTipLoader: BatteryInfoLoader post query: 1ms
12-04 16:40:05.157  3026  4758 D BatteryInfo: time for getBatteryInfo: 1ms
12-04 16:40:05.157  3026  4758 D BatteryTipLoader: BatteryInfoLoader.loadInBackground: 3ms
12-04 16:40:05.174  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:05.211  2451  3438 E TaskPersister: File error accessing recents directory (directory doesn't exist?).
12-04 16:40:05.600  2130  4727 I chatty  : uid=1041(audioserver) writer identical 20 lines
12-04 16:40:05.621  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:05.630  8620  8660 E AdapterState: BLE_TURNING_ON : BLE_START_TIMEOUT
12-04 16:40:05.630  8620  8660 I AdapterState: BLE_TURNING_OFF : entered
12-04 16:40:05.630  8620  8660 D AdapterProperties: Setting state to BLE_TURNING_OFF
12-04 16:40:05.630  8620  8660 D BluetoothAdapterService: updateAdapterState() - Broadcasting state BLE_TURNING_OFF to 1 receivers.
12-04 16:40:05.631  2451  2492 D BluetoothManagerService: MESSAGE_BLUETOOTH_STATE_CHANGE: BLE_TURNING_ON > BLE_TURNING_OFF
12-04 16:40:05.631  2451  2492 D BluetoothManagerService: Sending BLE State Change: BLE_TURNING_ON > BLE_TURNING_OFF
12-04 16:40:05.631  8620  8660 D AdapterProperties: onBleDisable
12-04 16:40:05.633  8620  8620 D BtGatt.DebugUtils: handleDebugAction() action=null
12-04 16:40:05.638  8620  8620 W         : [1204/164005.637971:WARNING:bta_gattc_api.cc(61)] GATTC Module not enabled/already disabled
12-04 16:40:05.638  8620  8620 W         : [1204/164005.638173:WARNING:bta_gatts_api.cc(56)] GATTS Module not enabled/already disabled
12-04 16:40:05.639  8620  8620 W BtGatt.ScanManager: exception when invoking removeOnUidImportanceListener
12-04 16:40:05.639  8620  8620 W BtGatt.ScanManager: java.lang.IllegalArgumentException: Listener not registered: com.android.bluetooth.gatt.ScanManager$2@7371d49
12-04 16:40:05.639  8620  8620 W BtGatt.ScanManager:    at android.app.ActivityManager.removeOnUidImportanceListener(ActivityManager.java:3382)
12-04 16:40:05.639  8620  8620 W BtGatt.ScanManager:    at com.android.bluetooth.gatt.ScanManager.cleanup(ScanManager.java:157)
12-04 16:40:05.639  8620  8620 W BtGatt.ScanManager:    at com.android.bluetooth.gatt.GattService.cleanup(GattService.java:254)
12-04 16:40:05.639  8620  8620 W BtGatt.ScanManager:    at com.android.bluetooth.btservice.ProfileService.onDestroy(ProfileService.java:211)
12-04 16:40:05.639  8620  8620 W BtGatt.ScanManager:    at android.app.ActivityThread.handleStopService(ActivityThread.java:4140)
12-04 16:40:05.639  8620  8620 W BtGatt.ScanManager:    at android.app.ActivityThread.access$1900(ActivityThread.java:219)
12-04 16:40:05.639  8620  8620 W BtGatt.ScanManager:    at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1905)
12-04 16:40:05.639  8620  8620 W BtGatt.ScanManager:    at android.os.Handler.dispatchMessage(Handler.java:107)
12-04 16:40:05.639  8620  8620 W BtGatt.ScanManager:    at android.os.Looper.loop(Looper.java:214)
12-04 16:40:05.639  8620  8620 W BtGatt.ScanManager:    at android.app.ActivityThread.main(ActivityThread.java:7386)
12-04 16:40:05.639  8620  8620 W BtGatt.ScanManager:    at java.lang.reflect.Method.invoke(Native Method)
12-04 16:40:05.639  8620  8620 W BtGatt.ScanManager:    at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:492)
12-04 16:40:05.639  8620  8620 W BtGatt.ScanManager:    at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1072)
12-04 16:40:05.640  8620  8620 W BtGatt.ScanManager: exception when invoking unregisterReceiver(mLocationReceiver)
12-04 16:40:05.640  8620  8620 W BtGatt.ScanManager: java.lang.IllegalArgumentException: Receiver not registered: com.android.bluetooth.gatt.ScanManager$3@cd9e64e
12-04 16:40:05.640  8620  8620 W BtGatt.ScanManager:    at android.app.LoadedApk.forgetReceiverDispatcher(LoadedApk.java:1429)
12-04 16:40:05.640  8620  8620 W BtGatt.ScanManager:    at android.app.ContextImpl.unregisterReceiver(ContextImpl.java:1543)
12-04 16:40:05.640  8620  8620 W BtGatt.ScanManager:    at android.content.ContextWrapper.unregisterReceiver(ContextWrapper.java:664)
12-04 16:40:05.640  8620  8620 W BtGatt.ScanManager:    at com.android.bluetooth.gatt.ScanManager.cleanup(ScanManager.java:178)
12-04 16:40:05.640  8620  8620 W BtGatt.ScanManager:    at com.android.bluetooth.gatt.GattService.cleanup(GattService.java:254)
12-04 16:40:05.640  8620  8620 W BtGatt.ScanManager:    at com.android.bluetooth.btservice.ProfileService.onDestroy(ProfileService.java:211)
12-04 16:40:05.640  8620  8620 W BtGatt.ScanManager:    at android.app.ActivityThread.handleStopService(ActivityThread.java:4140)
12-04 16:40:05.640  8620  8620 W BtGatt.ScanManager:    at android.app.ActivityThread.access$1900(ActivityThread.java:219)
12-04 16:40:05.640  8620  8620 W BtGatt.ScanManager:    at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1905)
12-04 16:40:05.640  8620  8620 W BtGatt.ScanManager:    at android.os.Handler.dispatchMessage(Handler.java:107)
12-04 16:40:05.640  8620  8620 W BtGatt.ScanManager:    at android.os.Looper.loop(Looper.java:214)
12-04 16:40:05.640  8620  8620 W BtGatt.ScanManager:    at android.app.ActivityThread.main(ActivityThread.java:7386)
12-04 16:40:05.640  8620  8620 W BtGatt.ScanManager:    at java.lang.reflect.Method.invoke(Native Method)
12-04 16:40:05.640  8620  8620 W BtGatt.ScanManager:    at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:492)
12-04 16:40:05.640  8620  8620 W BtGatt.ScanManager:    at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1072)
12-04 16:40:05.643  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:06.475  2130  4727 I chatty  : uid=1041(audioserver) writer identical 39 lines
12-04 16:40:06.496  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:06.505  2451  2638 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 16:40:06.506  2768  2768 W KeyButtonRipple: mSupportHardware: true mDark: true mLastDark: true pressed: true
12-04 16:40:06.506  2768  2768 W KeyButtonRipple: mDelayTouchFeedback: false
12-04 16:40:06.506  2768  2768 W KeyButtonRipple: enterHardware cancelAnimations
12-04 16:40:06.507  2768  2768 W KeyButtonRipple: enterHardware isHorizontal is true!
12-04 16:40:06.509  2768  2768 W KeyButtonRipple: enterHardware mDelayTouchFeedback: false mPressed: false
12-04 16:40:06.509  2768  2768 W KeyButtonView: mCode: 4
12-04 16:40:06.509  2768  2768 I KeyButtonView: Back button event: ACTION_DOWN
12-04 16:40:06.514  2451  2638 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 16:40:06.518  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:06.551  2130  4727 I chatty  : uid=1041(audioserver) writer identical 2 lines
12-04 16:40:06.572  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:06.582  2451  2638 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 16:40:06.584  2768  2768 W KeyButtonRipple: mSupportHardware: true mDark: true mLastDark: true pressed: false
12-04 16:40:06.586  2768  2768 I KeyButtonView: Back button event: ACTION_UP
12-04 16:40:06.588  2451  2491 D AutofillManagerService: onBackKeyPressed()
12-04 16:40:06.588  2451  2638 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 16:40:06.593  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:06.614  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:06.633  8620  8660 E AdapterState: BLE_TURNING_OFF : BLE_STOP_TIMEOUT
12-04 16:40:06.633  8620  8660 I AdapterState: OFF : entered
12-04 16:40:06.633  8620  8660 D AdapterProperties: Setting state to OFF
12-04 16:40:06.634  8620  8660 D BluetoothAdapterService: updateAdapterState() - Broadcasting state OFF to 1 receivers.
12-04 16:40:06.634  2451  2492 D BluetoothManagerService: MESSAGE_BLUETOOTH_STATE_CHANGE: BLE_TURNING_OFF > OFF
12-04 16:40:06.634  2451  2492 D BluetoothManagerService: Bluetooth is complete send Service Down
12-04 16:40:06.634  2451  2492 D BluetoothManagerService: Broadcasting onBluetoothServiceDown() to 5 receivers.
12-04 16:40:06.635  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:06.635  2451  2492 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@b27333
12-04 16:40:06.635  3026  3045 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@bf2291e
12-04 16:40:06.636  2768  2786 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@407851d
12-04 16:40:06.636  2451  2492 D BluetoothManagerService: unbindAndFinish(): android.bluetooth.IBluetooth$Stub$Proxy@b27333 mBinding = false mUnbinding = false
12-04 16:40:06.636  8620  8676 D BluetoothAdapter: onBluetoothServiceDown: com.android.bluetooth.btservice.AdapterService$AdapterServiceBinder@f0d0c95
12-04 16:40:06.636  2894  3435 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@c170371
12-04 16:40:06.657  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:06.662  8620  8620 D BluetoothAdapterService: onUnbind() - calling cleanup
12-04 16:40:06.662  8620  8620 D BluetoothAdapterService: cleanup()
12-04 16:40:06.672  2451  2492 D BluetoothManagerService: Sending BLE State Change: BLE_TURNING_OFF > OFF
12-04 16:40:06.678  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:06.681  2451  2492 D BluetoothManagerService: Entering STATE_OFF but mEnabled is true; restarting.
12-04 16:40:06.681  8620  8620 W BluetoothSdpJni: Cleaning up Bluetooth SDP Interface...
12-04 16:40:06.681  2451  2492 E BluetoothManagerService: waitForState [10] time out
12-04 16:40:06.681  8620  8620 W BluetoothSdpJni: Cleaning up Bluetooth SDP object
12-04 16:40:06.681  8620  8620 D BluetoothAdapterService: cleanup() - Cleaning up adapter native
12-04 16:40:06.699  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:06.720  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:06.729  3194  3194 I Launcher: Launcher:onResume start
12-04 16:40:06.731  3194  3194 I Launcher: Launcher:onResume end
12-04 16:40:06.733  2230  2230 D omx_venc: <__AwOmxVencFillThisBuffer:2082>: vencOutPort: fill_this_buffer 50 times
12-04 16:40:06.753  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:06.774  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:06.797  2230  2940 D omx_venc: <__AwOmxVencEmptyThisBuffer:2043>: vencInPort: , empty_this_buffer 50 times
12-04 16:40:06.798  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:06.816  2130  4727 I chatty  : uid=1041(audioserver) writer identical 1 line
12-04 16:40:06.839  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 16:40:06.860  2149  2525 D PermissionCache: checking android.permission.READ_FRAME_BUFFER for uid=1000 => granted (274 us)
12-04 16:40:06.861  2135  2340 E IMGSRV  : :0: OSMMapPMR: SVM mmap not supported on architecture.
12-04 16:40:06.863  2135  2340 I chatty  : uid=1000(system) HwBinder:2135_1 identical 36 lines
12-04 16:40:06.863  2135  2340 E IMGSRV  : :0: OSMMapPMR: SVM mmap not supported on architecture.
12-04 16:40:06.866  2130  4727 V audio_platform: mode(0),devices(0x2):platform device:OUT_
楼主 #1 2024-12-04 17:37:36
memory
已发帖子: 703
Re: A133 AW869C 蓝牙开启失败,请问是什么原因呢?
开机日志:
[40]HELLO! BOOT0 is starting!
[43]BOOT0 commit : f10e8c3
[46]set pll start
[48]periph0 has been enabled
[51]set pll end
[53][pmu]: bus read error
[56]PMU: AXP803
[75]vaild para:1  select dram para0
[79]board init ok
[80]rtc[3] value = 0xb00f
[103]DRAM BOOT DRIVE INFO: V0.67
[106]the chip id is 0x1400
[109]the chip id is 0x1400
[112]the chip id is 0x1400
[114]the chip id is 0x1400
[117]the chip id is 0x1400
[120]chip id check OK
[122]DRAM_VCC set to 1500 mv
[125]DRAM CLK =648 MHZ
[127]DRAM Type =3 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4)
[136]DRAM SIZE =2048 MBytes, para1 = 310a, para2 = 8000000, tpr13 = 6001
[148]DRAM simple test OK.
[150]dram size =2048
[153]chipid = 54401400
[155]nsi init ok 2020-4-7
[158]card no is 2
[160]sdcard 2 line count 8
[163][mmc]: mmc driver ver 2020-05-25 09:40-202007019516
[174][mmc]: Wrong media type 0x0
[177][mmc]: ***Try SD card 2***
[181][mmc]: mmc 2 cmd 8 timeout, err 100
[185][mmc]: mmc 2 cmd 8 err 100
[188][mmc]: mmc 2 send if cond failed
[192][mmc]: mmc 2 cmd 55 timeout, err 100
[196][mmc]: mmc 2 cmd 55 err 100
[200][mmc]: mmc 2 send app cmd failed
[203][mmc]: ***Try MMC card 2***
[229][mmc]: RMCA OK!
[232][mmc]: bias 4
[233][mmc]: mmc 2 bias 4
[237][mmc]: MMC 5.1
[239][mmc]: HSSDR52/SDR25 8 bit
[242][mmc]: 50000000 Hz
[244][mmc]: 7400 MB
[246][mmc]: ***SD/MMC 2 init OK!!!***
[306]Loading boot-pkg Succeed(index=0).
[310]Entry_name        = u-boot
[317]Entry_name        = monitor
[321]Entry_name        = scp
[324]set arisc reset to assert state
[333]set arisc reset to de-assert state
[337]Entry_name        = dtb
[340]tunning data addr:0x4a0003e8
[344]Jump to second Boot.
NOTICE:  BL3-1: v1.0(debug):e138ea9
NOTICE:  BL3-1: Built : 09:21:33, 2020-11-18
NOTICE:  BL3-1 commit: 8
NOTICE:  cpuidle init version V2.0
ERROR:   Error initializing runtime service tspd_fast
NOTICE:  BL3-1: Preparing for EL3 exit to normal world
NOTICE:  BL3-1: Next image address = 0x4a000000
NOTICE:  BL3-1: Next image spsr = 0x1d3
U-Boot 2018.05 (Jun 01 2023 - 05:30:25 +0000) Allwinner Technology
[00.427]CPU:   Allwinner Family
[00.430]Model: sun50iw10
I2C:   smallwit i2c init begin ...
smallwit i2c init end ...
ready
[00.706]DRAM:  2 GiB
[00.709]Relocation Offset is: 75f00000
[00.743]secure enable bit: 0
read 0x05 register result : 0
i2c write 0x01 register ok
read 0x01 register result : 0
[00.765]PMU: AXP803
[00.767]PMU: pmu_axp81X found
FDT ERROR:fdt_get_regulator_name:get property handle twi-supply error:FDT_ERR_INTERNAL
[00.785]gpio_bias, pc_bias: 1800, pc_supply: not set
[00.790]gpio_bias, pl_bias:   -1, pl_supply: not set
[00.797]dcdc1_vol = 3300, onoff=1
[00.801]aldo1_vol = 1800, onoff=1
[00.806]aldo2_vol = 1800, onoff=1
[00.810]aldo3_vol = 3300, onoff=1
[00.814]dldo1_vol = 0, onoff=0
[00.819]dldo2_vol = 1800, onoff=1
[00.823]dldo3_vol = 1800, onoff=1
[00.828]dldo4_vol = 1800, onoff=1
[00.832]eldo1_vol = 1800, onoff=1
[00.837]eldo2_vol = 1800, onoff=1
[00.842]eldo3_vol = 1800, onoff=1
[00.846]fldo1_vol = 900, onoff=1
[00.850]dc1sw_vol = 0, onoff=1
bias_name:pc_bias        bias_vol:1800
[00.858]SMALLWIT CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=400Mhz
[00.865]not need merged sunxi overlay
[00.868]gic: sec monitor mode
[00.871]sunxi flash type@2 not support fast burn key
[00.875]flash init start
[00.878]workmode = 0,storage type = 2
[00.881][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
[00.887][mmc]: get sdc_type fail and use default host:tm4.
[00.899][mmc]: SUNXI SDMMC Controller Version:0x50300
[00.927][mmc]: Best spd md: 4-HS400, freq: 3-100000000, Bus width: 8
[00.933]sunxi flash init ok
[00.935]non secure, do not need update backup boot0 to toc0
[00.941]init_clocks:finish
[00.943]drv_disp_init
[00.976]get flash lcd idx 0
request pwm success, pwm2:pwm2:0x300a000.
[00.988]drv_disp_init finish
[00.997]Loading Environment from SUNXI_FLASH... OK
[01.006]boot_gui_init:start
[01.010]set disp.dev2_output_type fail. using defval=0
[01.014]disp 0, clk: pll(364000000),clk(364000000),dclk(52000000) dsi_rate(364000000)
     clk real:pll(360000000),clk(360000000),dclk(51428571) dsi_rate(0)
[01.028]enable power dc1sw, ret=0
[01.031]enable power dcdc1, ret=0
[01.034]enable power eldo3, ret=0
[01.037]enable power dldo2, ret=0
[01.044]switch device: sel=0, type=1, mode=4, format=0, bits=0, eotf=4, cs=260
[01.052]boot_gui_init:finish
54 bytes read in 1 ms (52.7 KiB/s)
[01.059]bmp_name=bootlogo.bmp size 793494
793494 bytes read in 8 ms (94.6 MiB/s)
[01.079]no secure os for keybox operation
[01.082]try to burn key
[01.085]out of usb burn from boot: not need burn key
[01.090][ARISC] :arisc initialize
[01.095][ARISC ERROR] :get [allwinner,sunxi-hwspinlock] device node error
CACHE: Misaligned operation at range [bffa0ae0, bffa0df8]
[01.106][ARISC] :arisc para ok
[SCP] :sunxi-arisc driver begin startup 2
[SCP] :0x1
[SCP] :arisc version: [66fd4f97463a87fc2a2bcebebcee26f774992e52rid-]
[SCP] :arisc startup ready
[SCP] :arisc startup notify message feedback
[SCP] :send hard sync feedback message: 0x900200
[SCP] :sunxi-arisc driver v1.10 is starting
[01.136]soc ic_ver:0x6, qa_val:0x0, markid:0x1400 dclk[0-200] display_cfg_flag:0
[01.143][ARISC] :sunxi-arisc driver startup succeeded
[01.148]read item0 copy0
[01.161]Item0 (Map) magic is bad
[01.164]the secure storage item0 copy0 magic is bad
[01.179]Item0 (Map) magic is bad
[01.182]the secure storage item0 copy1 magic is bad
[01.186]Item0 (Map) magic is bad
[01.189]the secure storage map is empty
[01.193]no item name device_unlock in the map
[01.197]no item name fastboot_status_flag in the map
[01.202]sunxi secure storage has no flag
List file under ULI/factory
** Unrecognized filesystem type **
[01.211]no item name snum in the map
[01.214]no item name mac in the map
[01.217]no item name wifi_mac in the map
[01.221]no item name bt_mac in the map
[01.225]no item name specialstr in the map
[01.229]update part info
[01.231]key 0
[01.232]misc partition found
pin_name = pwm2
compat=/soc/pwm2
[01.250]LCD open finish
[01.264]update bootcmd
[01.266]serial num is: 8c000c5dd642884235d
disable nand error: FDT_ERR_BADPATH
[01.278](weak)update dtb dram start
[01.298]update dtb dram  end
[01.305]update dts
[01.315]partinfo: name boot, start 0x3a000, size 0x10000
[01.466]read data in addr ret = 1
[01.469]magic = AVB0
[01.471]major version = 1  minor version = 0
[01.475]authentication_data_block_size = 240
[01.479]auxiliary_data_block_size = d40
[01.483]vbmeta_size = 4224
[01.485]algorithm_type = 0
[01.488]flag = 0
[01.490]release tool = avbtool 1.1.0
[01.504]read data in addr ret = 1
[01.507]magic = AVB0
[01.509]major version = 1  minor version = 0
[01.513]authentication_data_block_size = 140
[01.517]auxiliary_data_block_size = 3c0
[01.520]vbmeta_size = 1536
[01.523]algorithm_type = 0
[01.525]flag = 0
[01.527]release tool = avbtool 1.1.0
[01.541]read data in addr ret = 1
[01.544]magic = AVB0
[01.546]major version = 1  minor version = 0
[01.550]authentication_data_block_size = 140
[01.554]auxiliary_data_block_size = 340
[01.558]vbmeta_size = 1408
[01.560]algorithm_type = 0
[01.563]flag = 0
[01.564]release tool = avbtool 1.1.0
[01.568]total_size = 7168
[01.570]alloc block = 17
[01.604]vbmeta hash is a32ee9eb894a2f7a2eb86a847bbba8c767586f8ea3d0680b3f2eb37f88ce77ad
[01.615]no vendor_boot partition is found
[01.618]in boot normal mode,pass normal para to cmdline
[01.625]android.hardware = sun50iw10p1
[01.629]line:110 dtbo_idx= 0
[01.631]line:110 dtbo_idx= 1
[01.634]dtbo_idx= 118
[01.715]partinfo: name dtbo, start 0x61a000, size 0x1000
[01.779]Starting kernel ...
[01.782][mmc]: mmc exit start
[01.800][mmc]: mmc 2 exit ok
[    0.000000] Linux version 4.9.170 (ubuntu@ubuntu) (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05) ) #1 SMP PREEMPT Wed Dec 4 11:27:00 CST 2024
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] disp reserve base 0xbbf4f000 ,size 0x258000
[    0.000000] cma: Reserved 8 MiB at 0x00000000bf800000
[    0.000000] On node 0 totalpages: 524288
[    0.000000]   DMA zone: 8192 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 524288 pages, LIFO batch:31
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.0
[    0.000000] percpu: Embedded 23 pages/cpu @ffffffc07f6e9000 s53376 r8192 d32640 u94208
[    0.000000] pcpu-alloc: s53376 r8192 d32640 u94208 alloc=23*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 516096
[    0.000000] Kernel command line: earlyprintk=sunxi-uart,0x05000000 initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mmcblk0p4 init=/init partitions=bootloader@mmcblk0p1:env@mmcblk0p2:boot@mmcblk0p3:super@mmcblk0p4:misc@mmcblk0p5:recovery@mmcblk0p6:cache@mmcblk0p7:vbmeta@mmcblk0p8:vbmeta_system@mmcblk0p9:vbmeta_vendor@mmcblk0p10:metadata@mmcblk0p11:private@mmcblk0p12:frp@mmcblk0p13:empty@mmcblk0p14:dtbo@mmcblk0p15:media_data@mmcblk0p16:UDISK@mmcblk0p17 cma=8M snum=8c000c5dd642884235d mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.vbmeta.avb_version=2.0 androidboot.vbmeta.hash_alg=sha256 androidboot.vbmeta.size=7168 androidboot.vbmeta.digest=a32ee9eb894a2f7a2eb86a847bbba8c767586f8ea3d0680b3f2eb37f88ce77ad androidboot.vbmeta.device_state=locked androidboot.veritymode=enforcing androidboot.mode=normal androidboot.serialno=8c000c5dd642884235d androidboot.hardware=sun50iw10p1 boot_type=2 androidboot.boot_type=2 androidboot.secure_os_exist=0 androidboot.trustchain=false an[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Memory: 2011348K/2097152K available (10878K kernel code, 1852K rwdata, 3800K rodata, 3712K init, 599K bss, 77612K reserved, 8192K cma-reserved)
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008b20000   ( 10880 KB)
[    0.000000]     .rodata : 0xffffff8008b20000 - 0xffffff8008ee0000   (  3840 KB)
[    0.000000]       .init : 0xffffff8008ee0000 - 0xffffff8009280000   (  3712 KB)
[    0.000000]       .data : 0xffffff8009280000 - 0xffffff800944f008   (  1853 KB)
[    0.000000]        .bss : 0xffffff800944f008 - 0xffffff80094e4ef8   (   600 KB)
[    0.000000]     fixed   : 0xffffffbefe7fb000 - 0xffffffbefec00000   (  4116 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf02000000   (    32 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc080000000   (  2048 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000]  Build-time adjustment of leaf fanout to 64.
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (virt).
[    0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.008163] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[    0.018200] pid_max: default: 32768 minimum: 301
[    0.023020] Security Framework initialized
[    0.026880] SELinux:  Initializing.
[    0.030470] SELinux:  Starting in permissive mode
[    0.035131] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.041699] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.049547] ftrace: allocating 34120 entries in 134 pages
[    0.131536] sched-energy: CPU device node has no sched-energy-costs
[    0.132177] Invalid sched_group_energy for CPU0
[    0.136714] CPU0: update cpu_capacity 1024
[    0.150820] ASID allocator initialised with 32768 entries
[    0.168247] nsi: no limit for F version(except 1080P-LP4)
[    0.168478] BOOTEVENT:       168.474165: ON
[    0.202427] Detected VIPT I-cache on CPU1
[    0.202476] Invalid sched_group_energy for CPU1
[    0.202479] CPU1: update cpu_capacity 1024
[    0.202482] CPU1: Booted secondary processor [410fd034]
[    0.225812] Detected VIPT I-cache on CPU2
[    0.225840] Invalid sched_group_energy for CPU2
[    0.225842] CPU2: update cpu_capacity 1024
[    0.225845] CPU2: Booted secondary processor [410fd034]
[    0.249219] Detected VIPT I-cache on CPU3
[    0.249245] Invalid sched_group_energy for CPU3
[    0.249247] CPU3: update cpu_capacity 1024
[    0.249250] CPU3: Booted secondary processor [410fd034]
[    0.249329] Brought up 4 CPUs
[    0.299963] SMP: Total of 4 processors activated.
[    0.304655] CPU features: detected feature: 32-bit EL0 Support
[    0.310459] CPU features: detected feature: Kernel page table isolation (KPTI)
[    0.321382] CPU: All CPU(s) started at EL1
[    0.321731] alternatives: patching kernel code
[    0.326335] Invalid sched_group_energy for CPU3
[    0.330657] CPU3: update max cpu_capacity 1024
[    0.335073] Invalid sched_group_energy for Cluster3
[    0.339925] Invalid sched_group_energy for CPU2
[    0.344432] Invalid sched_group_energy for Cluster2
[    0.349285] Invalid sched_group_energy for CPU1
[    0.353793] Invalid sched_group_energy for Cluster1
[    0.358645] Invalid sched_group_energy for CPU0
[    0.363152] Invalid sched_group_energy for Cluster0
[    0.368657] CPU1: update max cpu_capacity 1024
[    0.373157] devtmpfs: initialized
[    0.412765] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.416892] futex hash table entries: 1024 (order: 5, 131072 bytes)
[    0.423670] atomic64_test: passed
[    0.426397] pinctrl core: initialized pinctrl subsystem
[    0.433712] NET: Registered protocol family 16
[    0.437451] dump_class_init,861, success
[    0.453328] cpuidle: using governor menu
[    0.454761] sunxi iommu: irq = 9
[    0.455684] vdso: 2 pages (1 code @ ffffff8008b28000, 1 data @ ffffff8009284000)
[    0.462242] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.470356] DMA: preallocated 256 KiB pool for atomic allocations
[    0.478056] sun50iw10p1-r-pinctrl r_pio: initialized sunXi PIO driver
[    0.496591] sun50iw10p1-pinctrl pio: initialized sunXi PIO driver
[    0.500924] iommu: Adding device 1c0e000.ve to group 0
[    0.511049] iommu: Adding device soc@03000000:disp1@1 to group 0
[    0.512237] iommu: Adding device 6000000.disp to group 0
[    0.517236] iommu: Adding device 6400000.eink to group 0
[    0.523065] iommu: Adding device 6480000.g2d to group 0
[    0.565392] pwm module init!
[    0.570760] sunxi-pm debug v3.10
[    0.572193] SCSI subsystem initialized
[    0.573150] usbcore: registered new interface driver usbfs
[    0.577632] usbcore: registered new interface driver hub
[    0.582955] usbcore: registered new device driver usb
[    0.588050] sunxi_i2c_adap_init()2541 - init
[    0.592639] sunxi_i2c_probe()2289 - [i2c6] twi_drv_used = 1
[    0.597668] sunxi_i2c_probe()2293 - [i2c6] twi_pkt_interval = 0
[    0.603572] twi6 supply twi not found, using dummy regulator
[    0.609265] twi_request_gpio()453 - [i2c6] init name: twi6
[    0.615229] axp20x-i2c 6-0034: AXP20x variant AXP803 found
[    0.626393] axp2101-regulator axp2101-regulator.0: Setting DCDC frequency for unsupported AXP variant
[    0.629991] axp2101-regulator axp2101-regulator.0: Error setting dcdc frequency: -22
[    0.668880] axp803-dldo1: Bringing 3300000uV into 1900000-1900000uV
[    0.696562] axp20x-i2c 6-0034: AXP20X driver loaded
[    0.696669] sunxi_i2c_dma_request()1123 - [i2c6] using dma0chan0 (tx) and dma0chan1 (rx)for DMA transfers
[    0.705872] sunxi_i2c_probe()2289 - [i2c0] twi_drv_used = 0
[    0.710911] sunxi_i2c_probe()2293 - [i2c0] twi_pkt_interval = 0
[    0.716835] twi0 supply twi not found, using dummy regulator
[    0.722519] twi_request_gpio()453 - [i2c0] init name: twi0
[    0.728809] sunxi_i2c_probe()2289 - [i2c1] twi_drv_used = 0
[    0.733451] sunxi_i2c_probe()2293 - [i2c1] twi_pkt_interval = 0
[    0.739381] twi1 supply twi not found, using dummy regulator
[    0.745036] twi_request_gpio()453 - [i2c1] init name: twi1
[    0.751007] sunxi_i2c_probe()2289 - [i2c2] twi_drv_used = 0
[    0.755974] sunxi_i2c_probe()2293 - [i2c2] twi_pkt_interval = 0
[    0.762246] twi_request_gpio()453 - [i2c2] init name: twi2
[    0.768025] sunxi_i2c_probe()2289 - [i2c3] twi_drv_used = 0
[    0.772876] sunxi_i2c_probe()2293 - [i2c3] twi_pkt_interval = 0
[    0.778811] twi3 supply twi not found, using dummy regulator
[    0.784491] twi_request_gpio()453 - [i2c3] init name: twi3
[    0.790737] media: Linux media interface: v0.10
[    0.794425] Linux video capture interface: v2.00
[    0.799914] ion_parse_dt_heap_common: id 0 type 0 name sys_user align 1000
[    0.806017] ion_parse_dt_heap_common: id 4 type 4 name cma align 1000
[    0.812379] ion_parse_dt_heap_common: id 6 type 6 name secure align 1000
[    0.819190] drm config service not available: FFFFFFFF
[    0.824427] Advanced Linux Sound Architecture Driver Initialized.
[    0.830711] Bluetooth: Core ver 2.22
[    0.833674] NET: Registered protocol family 31
[    0.838040] Bluetooth: HCI device and connection manager initialized
[    0.844380] Bluetooth: HCI socket layer initialized
[    0.849225] Bluetooth: L2CAP socket layer initialized
[    0.854294] Bluetooth: SCO socket layer initialized
[    0.860547] clocksource: Switched to clocksource arch_sys_counter
[    0.932592] VFS: Disk quotas dquot_6.6.0
[    0.932735] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.940353] udc_init,0
[    0.941520] NET: Registered protocol family 2
[    0.970741] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    0.972436] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[    0.979190] TCP: Hash tables configured (established 16384 bind 16384)
[    0.985492] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[    0.991444] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[    0.998166] NET: Registered protocol family 1
[    1.002438] Trying to unpack rootfs image as initramfs...
[    1.041914] Freeing initrd memory: 776K
[    1.043542] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    1.050458] audit: initializing netlink subsys (disabled)
[    1.053302] audit: type=2000 audit(0.863:1): initialized
[    1.059529] workingset: timestamp_bits=45 max_order=19 bucket_order=0
[    1.075115] Registering sdcardfs 0.1
[    1.075624] ntfs: driver 2.1.32 [Flags: R/W].
[    1.077912] fuse init (API version 7.26)
[    1.083289] SELinux:  Registering netfilter hooks
[    1.090414] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    1.093552] io scheduler noop registered
[    1.097361] io scheduler deadline registered
[    1.101754] io scheduler cfq registered (default)
[    1.108158] [DISP]disp_module_init
[    1.109946] disp soc@03000000:disp1@1: unable to map de registers
[    1.115673] disp: probe of soc@03000000:disp1@1 failed with error -22
[    1.122863] [DISP] disp_init,line:2345:
[    1.125699] smooth display screen:0 type:1 mode:4
[    1.172306] [DISP] lcd_clk_config,line:675:
[    1.172353] disp 0, clk: pll(364000000),clk(364000000),dclk(52000000) dsi_rate(364000000)
[    1.172353]      clk real:pll(360000000),clk(360000000),dclk(51428571) dsi_rate(0)
[    1.174524] [DISP]disp_module_init finish
[    1.198440] uart uart0: get regulator failed
[    1.199046] uart0: ttyS0 at MMIO 0x5000000 (irq = 349, base_baud = 1500000) is a SUNXI
[    1.205027] sw_console_▒[    1.212943] console [ttyS0] enabled
[    1.216950] bootconsole [earlycon0] disabled
[    1.225926] uart uart1: get regulator failed
[    1.234239] uart1 supply uart not found, using dummy regulator
[    1.241064] uart1: ttyS1 at MMIO 0x5000400 (irq = 350, base_baud = 1500000) is a SUNXI
[    1.250513] uart uart2: get regulator failed
[    1.255374] uart2 supply uart not found, using dummy regulator
[    1.262169] uart2: ttyS2 at MMIO 0x5000800 (irq = 351, base_baud = 1500000) is a SUNXI
[    1.271448] sun50iw10p1-pinctrl pio: missing pins property in node uart3
[    1.279010] uart: probe of uart3 failed with error -22
[    1.284840] sun50iw10p1-pinctrl pio: missing pins property in node uart4
[    1.292394] uart: probe of uart4 failed with error -22
[    1.298920] misc dump reg init
[    1.303531] G2D: Module initialized.major:245
[    1.309281] [drm] Initialized
[    1.312783] Unable to detect cache hierarchy for CPU 0
[    1.330937] brd: module loaded
[    1.348172] loop: module loaded
[    1.352656] zram: Added device: zram0
[    1.357028] [NAND][NE] Not found valid nand node on dts
[    1.363627] Boot type 2
[    1.366870] sunxi-bt soc@03000000:bt@0: bt_power_name (axp803-dldo1)
[    1.374081] sunxi-bt soc@03000000:bt@0: Missing bt_io_regulator.
[    1.380859] sunxi-bt soc@03000000:bt@0: io_regulator_name ((null))
[    1.387884] sunxi-bt soc@03000000:bt@0: get gpio bt_rst failed
[    1.394515] sunxi-bt soc@03000000:bt@0: devm_pinctrl_get() failed!
[    1.402162] sunxi-wlan soc@03000000:wlan@0: wlan_busnum (1)
[    1.408464] sunxi-wlan soc@03000000:wlan@0: wlan_power_name (axp803-dldo1)
[    1.416213] sunxi-wlan soc@03000000:wlan@0: Missing wlan_io_regulator.
[    1.423575] sunxi-wlan soc@03000000:wlan@0: io_regulator_name ((null))
[    1.430959] sunxi-wlan soc@03000000:wlan@0: wlan_regon gpio=202  mul-sel=1  pull=-1  drv_level=-1  data=1
[    1.441778] sunxi-wlan soc@03000000:wlan@0: get gpio chip_en failed
[    1.448843] sunxi-wlan soc@03000000:wlan@0: get gpio power_en failed
[    1.456022] sunxi-wlan soc@03000000:wlan@0: wlan_hostwake gpio=205  mul-sel=6  pull=-1  drv_level=-1  data=0
[    1.467159] sunxi-wlan soc@03000000:wlan@0: clk not config
[    1.473357] sunxi-wlan soc@03000000:wlan@0: dcxo not config
[    1.479660] sunxi-wlan soc@03000000:wlan@0: pinctrl_lookup_state(default) failed! return ffffffffffffffed
[    1.491683] [ADDR_MGT] addr_mgt_probe: success.
[    1.499896] libphy: Fixed MDIO Bus: probed
[    1.504563] tun: Universal TUN/TAP device driver, 1.6
[    1.510261] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.518962] deviceless supply  not found, using dummy regulator
[    1.525713] deviceless supply  not found, using dummy regulator
[    1.532411] deviceless supply  not found, using dummy regulator
[    1.540022] PPP generic driver version 2.4.2
[    1.545086] PPP BSD Compression module registered
[    1.550398] PPP Deflate Compression module registered
[    1.556119] PPP MPPE Compression module registered
[    1.561527] NET: Registered protocol family 24
[    1.566534] PPTP driver version 0.8.5
[    1.571032] usbcore: registered new interface driver rtl8150
[    1.577480] usbcore: registered new interface driver r8152
[    1.583729] usbcore: registered new interface driver asix
[    1.589878] usbcore: registered new interface driver ax88179_178a
[    1.596799] usbcore: registered new interface driver cdc_ether
[    1.603478] usbcore: registered new interface driver smsc75xx
[    1.610025] usbcore: registered new interface driver smsc95xx
[    1.616551] usbcore: registered new interface driver net1080
[    1.622993] usbcore: registered new interface driver cdc_subset
[    1.629716] usbcore: registered new interface driver zaurus
[    1.636057] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[    1.644471] usbcore: registered new interface driver cdc_ncm
[    1.650854] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.658581] get ehci0-controller, regulator_io is no nocare
[    1.664868] get ehci0-controller wakeup-source is fail.
[    1.670996] sunxi ehci0-controller don't init wakeup source
[    1.677286] [sunxi-ehci0]: probe, pdev->name: 5101000.ehci0-controller, sunxi_ehci: 0xffffff80094d08b0, 0x:ffffff8009c56000, irq_no:168
[    1.690998] [sunxi-ehci0]: Not init ehci0
[    1.695641] get ehci1-controller, regulator_io is no nocare
[    1.701921] get ehci1-controller wakeup-source is fail.
[    1.707945] sunxi ehci1-controller don't init wakeup source
[    1.714229] [sunxi-ehci1]: probe, pdev->name: 5200000.ehci1-controller, sunxi_ehci: 0xffffff80094d0c38, 0x:ffffff8009cf2000, irq_no:16a
[    1.729237] sunxi-ehci 5200000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.739466] sunxi-ehci 5200000.ehci1-controller: new USB bus registered, assigned bus number 1
[    1.749644] sunxi-ehci 5200000.ehci1-controller: irq 362, io mem 0xffffffc07c70a010
[    1.770566] sunxi-ehci 5200000.ehci1-controller: USB 0.0 started, EHCI 1.00
[    1.778413] sunxi-ehci 5200000.ehci1-controller: ehci_irq: highspeed device connect
[    1.788013] hub 1-0:1.0: USB hub found
[    1.792276] hub 1-0:1.0: 1 port detected
[    1.797624] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.804980] get ohci0-controller, regulator_io is no nocare
[    1.811268] get ohci0-controller wakeup-source is fail.
[    1.817387] sunxi ohci0-controller don't init wakeup source
[    1.823787] [sunxi-ohci0]: probe, pdev->name: 5101000.ohci0-controller, sunxi_ohci: 0xffffff80094d1348
[    1.834274] [sunxi-ohci0]: Not init ohci0
[    1.838917] get ohci1-controller, regulator_io is no nocare
[    1.845203] get ohci1-controller wakeup-source is fail.
[    1.851218] sunxi ohci1-controller don't init wakeup source
[    1.857596] [sunxi-ohci1]: probe, pdev->name: 5200000.ohci1-controller, sunxi_ohci: 0xffffff80094d16d0
[    1.868227] sunxi-ohci 5200000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.878050] sunxi-ohci 5200000.ohci1-controller: new USB bus registered, assigned bus number 2
[    1.887826] sunxi-ohci 5200000.ohci1-controller: irq 363, io mem 0xffffffc07c70a400
[    1.955506] hub 2-0:1.0: USB hub found
[    1.959772] hub 2-0:1.0: 1 port detected
[    1.965359] usbcore: registered new interface driver uas
[    1.971471] usbcore: registered new interface driver usb-storage
[    1.978303] usbcore: registered new interface driver ums-alauda
[    1.985029] usbcore: registered new interface driver ums-cypress
[    1.991854] usbcore: registered new interface driver ums-datafab
[    1.998672] usbcore: registered new interface driver ums_eneub6250
[    2.005696] usbcore: registered new interface driver ums-freecom
[    2.012515] usbcore: registered new interface driver ums-isd200
[    2.019241] usbcore: registered new interface driver ums-jumpshot
[    2.026157] usbcore: registered new interface driver ums-karma
[    2.032786] usbcore: registered new interface driver ums-onetouch
[    2.039721] usbcore: registered new interface driver ums-realtek
[    2.046547] usbcore: registered new interface driver ums-sddr09
[    2.053268] usbcore: registered new interface driver ums-sddr55
[    2.059997] usbcore: registered new interface driver ums-usbat
[    2.066693] usbcore: registered new interface driver usbserial
[    2.073455] usbcore: registered new interface driver option
[    2.079784] usbserial: USB Serial support registered for GSM modem (1-port)
[    2.087816] usbcore: registered new interface driver cdc_xr_usb_serial
[    2.095171] xr_usb_serial_common: Exar USB UART (serial port) driver
[    2.102499] usb_serial_number:20080411
[    2.107504] sunxikbd_key_init: key0 vol= 590 code= 0
[    2.113104] sunxikbd_key_init: key1 vol= 646 code= 115
[    2.113896] usb 1-1: new high-speed USB device number 2 using sunxi-ehci
[    2.126445] sunxikbd_key_init: key2 vol= 897 code= 114
[    2.132532] input: sunxi-keyboard as /devices/virtual/input/input0
[    2.148098] input: axp803-pek as /devices/platform/soc/7081400.s_twi/i2c-6/6-0034/axp2101-pek.0/input/input1
[    2.163014] random: fast init done
[    2.169477] rtc-hym8563 3-0051: rtc core: registered hym8563 as rtc0
[    2.177632] i2c /dev entries driver
[    2.182701] lirc_dev: IR Remote Control driver registered, major 244
[    2.189895] IR NEC protocol handler initialized
[    2.195001] IR RC5(x/sz) protocol handler initialized
[    2.200697] IR RC6 protocol handler initialized
[    2.205809] IR JVC protocol handler initialized
[    2.210918] IR Sony protocol handler initialized
[    2.216120] IR SANYO protocol handler initialized
[    2.221431] IR Sharp protocol handler initialized
[    2.226730] IR MCE Keyboard/mouse protocol handler initialized
[    2.233357] IR LIRC bridge handler initialized
[    2.238413] IR XMP protocol handler initialized
[    2.244020] sunxi_ir_startup: get ir protocol failed
[    2.249481] 7040000.s_cir supply ir0 not found, using dummy regulator
[    2.257113] Registered IR keymap rc_map_sunxi
[    2.262485] input: sunxi-ir as /devices/platform/soc/7040000.s_cir/rc/rc0/input2
[    2.271093] rc rc0: sunxi-ir as /devices/platform/soc/7040000.s_cir/rc/rc0
[    2.279369] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input3
[    2.289348] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
[    2.289518] hub 1-1:1.0: USB hub found
[    2.289936] hub 1-1:1.0: 4 ports detected
[    2.308060] sunxi cedar version 0.1
[    2.312147] VE: install start!!!
[    2.312147]
[    2.317612] cedar_ve: cedar-ve the get irq is 347
[    2.323334] VE: get debugfs_mpp_root is NULL, please check mpp
[    2.323334]
[    2.331580] VE: sunxi ve debug register driver failed!
[    2.331580]
[    2.351960] axp803_battery: axp803_bat_power_dt_parse: failed
[    2.351960]
[    2.360107] axp803_battery: axp803_bat_power_probe parse device tree err
[    2.360107]
[    2.369350] axp803-battery-power-supply: probe of axp803-battery-power-supply.0 failed with error -22
[    2.381148] device-mapper: uevent: version 1.0.3
[    2.386840] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[    2.396512] device-mapper: verity-avb: AVB error handler initialized with vbmeta device:
[    2.405735] Bluetooth: HCI UART driver ver 2.3
[    2.410754] Bluetooth: HCI UART protocol H4 registered
[    2.416548] Bluetooth: HCI UART protocol LL registered
[    2.422337] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    2.433975] sunxi-mmc sdc2: SD/MMC/SDIO Host Controller Driver(v3.46 2020-6-1 11:33-202006021635)
[    2.444056] sunxi-mmc sdc2: ***ctl-spec-caps*** 308
[    2.450204] sunxi-mmc sdc2: No vdmmc regulator found
[    2.455805] sunxi-mmc sdc2: No vd33sw regulator found
[    2.461504] sunxi-mmc sdc2: No vd18sw regulator found
[    2.467197] sunxi-mmc sdc2: No vq33sw regulator found
[    2.472899] sunxi-mmc sdc2: No vq18sw regulator found
[    2.479266] sunxi-mmc sdc2: set host busy
[    2.483878] mmc:failed to get gpios
[    2.488070] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm UP vdd 22 width 1 timing LEGACY(SDR12) dt B
[    2.513962] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[    2.540806] sunxi-mmc sdc2: detmode:alway in(non removable)
[    2.540840] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[    2.549301] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[    2.550369] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[    2.561223] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[    2.561287] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[    2.574133] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[    2.618630] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
[    2.628043] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
[    2.637474] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
[    2.646897] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
[    2.656310] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
[    2.665737] sun50iw10p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag0
[    2.675480] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.46 2020-6-1 11:33-202006021635)
[    2.685559] sunxi-mmc sdc0: ***ctl-spec-caps*** 8
[    2.692569] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[    2.692957] sunxi-mmc sdc0: No vqmmc regulator found
[    2.692962] sunxi-mmc sdc0: No vdmmc regulator found
[    2.703450] sunxi-mmc sdc0: set host busy
[    2.703513] sunxi-mmc sdc0: Got CD GPIO
[    2.703842] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 22 width 1 timing LEGACY(SDR12) dt B
[    2.703887] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
[    2.720576] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 1 timing LEGACY(SDR12) dt B
[    2.737469] sunxi-mmc sdc0: detmode:gpio irq
[    2.737984] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.46 2020-6-1 11:33-202006021635)
[    2.738053] sunxi-mmc sdc1: ***ctl-spec-caps*** 1
[    2.738238] sunxi-mmc sdc1: No vmmc regulator found
[    2.738242] sunxi-mmc sdc1: No vqmmc regulator found
[    2.738247] sunxi-mmc sdc1: No vdmmc regulator found
[    2.738251] sunxi-mmc sdc1: No vd33sw regulator found
[    2.738255] sunxi-mmc sdc1: No vd18sw regulator found
[    2.738259] sunxi-mmc sdc1: No vq33sw regulator found
[    2.738264] sunxi-mmc sdc1: No vq18sw regulator found
[    2.738858] sunxi-mmc sdc1: set host busy
[    2.738936] mmc:failed to get gpios
[    2.738972] sunxi-mmc sdc1: min-frequency:150000
[    2.739187] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.753912] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.770588] sunxi-mmc sdc1: detmode:manually by software
[    2.771429] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[    2.772267] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[    2.772293] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.774774] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.776667] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    2.777542] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    2.778411] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    2.779278] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    2.779306] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[    2.780392] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.782407] ledtrig-cpu: registered to indicate activity on CPUs
[    2.782833] hidraw: raw HID events driver (C) Jiri Kosina
[    2.785401] usbcore: registered new interface driver usbhid
[    2.785405] usbhid: USB HID core driver
[    2.785811] ashmem: initialized
[    2.787669] optee: probing for conduit method from DT.
[    2.787679] optee: api uid mismatch
[    2.788098] usbcore: registered new interface driver snd-usb-audio
[    2.789428] sun50iw10p1-pinctrl pio: pin PB4 already requested by twi1; cannot claim for daudio0
[    2.789434] sun50iw10p1-pinctrl pio: pin-36 (daudio0) status -22
[    2.789441] sun50iw10p1-pinctrl pio: could not request pin 36 (PB4) from group PB4  on device pio
[    2.789446] sunxi-daudio daudio0: Error applying setting, reverse things back
[    2.789467] sunxi-daudio: probe of daudio0 failed with error -22
[    2.789945] sun50iw10p1-pinctrl pio: missing pins property in node spdif
[    2.789953] sunxi-spdif: probe of spdif failed with error -22
[    2.793195] sunxi-internal-codec codec: pa_power_always_on get failed and set it off.
[    2.793202] digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:0, pa_power_always_on:0
[    2.793211] adcdrc_cfg:2, adchpf_cfg:1, dacdrc_cfg:2, dachpf:0
[    2.793271] sunxi-internal-codec codec: [sunxi_internal_codec_probe] codec probe finished.
[    2.793930] sunxi-mmc sdc1: sdc set ios:clk 300000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.794341] [sunxi_card_init] card init finished.
[    2.794432] Audio: [soc_new_pcm] -> 2699
[    2.794437] Audio: [soc_new_pcm] -> 2718
[    2.794545] Audio: [soc_new_pcm] -> 2746
[    2.795910] sunxi-codec-machine sndcodec: sun50iw10codec <-> codec mapping ok
[    2.797154] input: sun50iw10-codec sunxi Audio Jack as /devices/platform/soc/sndcodec/sound/card0/input4
[    2.797545] [audio] hp_detect_case: 1
[    2.797550] [audio] noheadphonemic missing or it has headphonemic.
[    2.797812] sunxi-codec-machine sndcodec: [sunxi_card_dev_probe] register card finished.
[    2.798773] sndspdif sndspdif: ASoC: CPU DAI (null) not registered
[    2.798781] sndspdif sndspdif: snd_soc_register_card failed: -517
[    2.798892] sndspdif: probe of sndspdif failed with error -16
[    2.799685] u32 classifier
[    2.799687]     Actions configured
[    2.799697] Netfilter messages via NETLINK v0.30.
[    2.799714] nfnl_acct: registering with nfnetlink.
[    2.800046] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    2.800271] ctnetlink v0.93: registering with nfnetlink.
[    2.800821] xt_time: kernel timezone is -0000
[    2.800920] ipip: IPv4 and MPLS over IPv4 tunneling driver
[    2.801527] gre: GRE over IPv4 demultiplexor driver
[    2.801531] ip_gre: GRE over IPv4 tunneling driver
[    2.802643] IPv4 over IPsec tunneling driver
[    2.805093] ip_tables: (C) 2000-2006 Netfilter Core Team
[    2.805340] arp_tables: arp_tables: (C) 2002 David S. Miller
[    2.811836] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[    2.815263] Initializing XFRM netlink socket
[    2.815299] IPsec XFRM device driver
[    2.816053] NET: Registered protocol family 10
[    2.816328] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[    2.816358] sunxi-mmc sdc1: sdc set ios:clk 300000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.818998] sunxi-mmc sdc1: sdc set ios:clk 300000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.821157] mip6: Mobile IPv6
[    2.821191] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    2.821193] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    2.822294] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    2.823391] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    2.824487] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    2.824510] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[    2.825602] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.843886] sunxi-mmc sdc1: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.846475] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    2.847797] NET: Registered protocol family 17
[    2.847828] NET: Registered protocol family 15
[    2.847859] l2tp_core: L2TP core driver, V2.0
[    2.847875] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[    2.851417] Registered cp15_barrier emulation handler
[    2.851431] Registered setend emulation handler
[    2.852253] registered taskstats version 1
[    2.865567] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[    2.867234] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[    2.867275] sunxi-mmc sdc1: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.868366] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[    2.868373] cpu cpu0: _opp_add: OPP not supported by regulators (1464000000)
[    2.868685] cpu cpu1: opp_list_debug_create_link: Failed to create link
[    2.868691] cpu cpu1: _add_opp_dev: Failed to register opp debugfs (-12)
[    2.868726] cpu cpu2: opp_list_debug_create_link: Failed to create link
[    2.868732] cpu cpu2: _add_opp_dev: Failed to register opp debugfs (-12)
[    2.868767] cpu cpu3: opp_list_debug_create_link: Failed to create link
[    2.868772] cpu cpu3: _add_opp_dev: Failed to register opp debugfs (-12)
[    2.870148] sunxi-mmc sdc1: sdc set ios:clk 200000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.871015] get usb_detect_mode is fail, 22
[    2.871532] sunxi_ctp_startup: ctp_power_io is invalid.
[    2.871557] get ctp_gesture_wakeup fail, no gesture wakeup
[    2.871595] 0-005d supply ctp not found, using dummy regulator
[    2.871696] get ctp_screen_max_x is fail, -22
[    2.872971] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    2.874601] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    2.876221] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    2.877841] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    2.877856] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[    2.878936] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.897212] sunxi-mmc sdc1: sdc set ios:clk 150000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.919368] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[    2.921527] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[    2.921540] sunxi-mmc sdc1: sdc set ios:clk 150000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.924600] sunxi-mmc sdc1: sdc set ios:clk 150000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    2.927843] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    2.930003] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    2.932162] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    2.934309] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[    2.934321] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[    2.940558] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[    2.967553] GTP I2C Address:0x5d
[    2.967805] sunxi_i2c_do_xfer()1946 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x5d)
[    2.968008] sunxi_i2c_do_xfer()1946 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x5d)
[    2.984133] gtp_i2c_read:I2C retry timeout, reset chip.GTP i2c test failed time 1.
[    2.984133] sunxi_i2c_do_xfer()1946 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x5d)
[    2.984336] sunxi_i2c_do_xfer()1946 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x5d)
[    3.000599] gtp_i2c_read:I2C retry timeout, reset chip.GTP i2c test failed time 2.I2C communication ERROR!
[    3.000630] gt9xx_ts: probe of 0-005d failed with error -70
[    3.000752] sunxi_i2c_drv_core_process()1007 - [i2c6] Timeout when sending 9th SCL clk
[    3.000770] i2c_sunxi_drv_complete()1181 - [i2c6] incomplete xfer(status: 0x1, dev addr: 0x14)
[    3.000777] 0x07081600: 01011001 00000001 00002800 0001ffff
[    3.000781] 0x07081610: 00008040 00010004 00010010 00000000
[    3.000853] sunxi_i2c_drv_core_process()1007 - [i2c6] Timeout when sending 9th SCL clk
[    3.000865] i2c_sunxi_drv_complete()1181 - [i2c6] incomplete xfer(status: 0x1, dev addr: 0x5d)
[    3.000869] 0x07081600: 11011001 00000001 0000bb00 00000001
[    3.000874] 0x07081610: 00008040 00010004 00010010 00000000
[    3.001035] sunxi_i2c_do_xfer()1946 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x14)
[    3.001254] sunxi_i2c_do_xfer()1946 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x14)
[    3.001440] sunxi_i2c_do_xfer()1946 - [i2c1] incomplete xfer (status: 0x48, dev addr: 0x5d)
[    3.001650] sunxi_i2c_do_xfer()1946 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
[    3.001834] sunxi_i2c_do_xfer()1946 - [i2c2] incomplete xfer (status: 0x48, dev addr: 0x5d)
[    3.002022] sunxi_i2c_do_xfer()1946 - [i2c3] incomplete xfer (status: 0x20, dev addr: 0x14)
[    3.002206] sunxi_i2c_do_xfer()1946 - [i2c3] incomplete xfer (status: 0x48, dev addr: 0x5d)
[    3.002549] ERROR! get hall_para failed, func:switch_init, line:269
[    3.006879] rtc-hym8563 3-0051: setting system clock to 2024-12-04 09:36:38 UTC (1733304998)
[    3.007435] snddaudio snddaudio0: codec: snd-soc-dummy, codec_dai: snd-soc-dummy-dai.
[    3.007447] snddaudio snddaudio0: ASoC: CPU DAI (null) not registered
[    3.007451] snddaudio snddaudio0: snd_soc_register_card failed
[    3.008882] axp803-dcdc6: disabling
[    3.009727] axp803-dldo3: disabling
[    3.010341] axp803-dldo4: disabling
[    3.010958] axp803-eldo2: disabling
[    3.012020] ALSA device list:
[    3.012023]   #0: sun50iw10-codec
[    3.889700] Freeing unused kernel memory: 3712K
[    3.894851] Kernel init done
[    3.901859] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 8 timing LEGACY(SDR12) dt B
[    3.912991] init: init first stage started!
[    3.918346] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 22 width 8 timing MMC-HS200 dt B
[    3.918652] init: [libfs_mgr]ReadFstabFromDt(): failed to read fstab from dt
[    3.920216] init: Using Android DT directory /proc/device-tree/firmware/android/
[    3.945304] sunxi-mmc sdc2: sdc set ios:clk 100000000Hz bm PP pm ON vdd 22 width 8 timing MMC-HS200 dt B
[    3.956313] sunxi-mmc sdc2: sdc set ios:clk 100000000Hz bm PP pm ON vdd 22 width 8 timing MMC-HS(SDR20) dt B
[    3.967526] sunxi-mmc sdc2: sdc set ios:clk 52000000Hz bm PP pm ON vdd 22 width 8 timing MMC-HS(SDR20) dt B
[    3.978934] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 22 width 8 timing MMC-HS400 dt B
[    3.989681] sunxi_mmc_get_hs400_cmd_dly,222
[    3.994391] sunxi-mmc sdc2: failed to get HS400_cmd used default
[    4.001235] sunxi-mmc sdc2: sdc set ios:clk 100000000Hz bm PP pm ON vdd 22 width 8 timing MMC-HS400 dt B
[    4.010622] init: bool android::init::FirstStageMount::InitRequiredDevices(): partition(s) not found in /sys, waiting for their uevent(s): metadata, super
[    4.027449] sunxi_mmc_get_hs400_cmd_dly,222
[    4.032135] sunxi-mmc sdc2: failed to get HS400_cmd used default
[    4.039249] mmc0: new HS400 MMC card at address 0001
[    4.048743] mmcblk0: mmc0:0001 AT2S38 7.23 GiB
[    4.057452] mmcblk0boot0: mmc0:0001 AT2S38 partition 1 4.00 MiB
[    4.067719] mmcblk0boot1: mmc0:0001 AT2S38 partition 2 4.00 MiB
[    4.077858] mmcblk0rpmb: mmc0:0001 AT2S38 partition 3 4.00 MiB
[    4.086282]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
[    4.099552] snddaudio snddaudio0: codec: snd-soc-dummy, codec_dai: snd-soc-dummy-dai.
[    4.100852] init: Wait for partitions returned after 90ms
[    4.103732] init: [libfs_mgr]Created logical partition system on device /dev/block/dm-0
[    4.105125] init: [libfs_mgr]Created logical partition vendor on device /dev/block/dm-1
[    4.106420] init: [libfs_mgr]Created logical partition product on device /dev/block/dm-2
[    4.107193] init: [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/by-name/metadata
[    4.107355] init: [libfs_mgr]Filesystem on /dev/block/by-name/metadata was not cleanly shutdown; state flags: 0x1, incompat feature flags: 0x46
[    4.113099] EXT4-fs (mmcblk0p11): recovery complete
[    4.113229] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: errors=panic
[    4.119279] EXT4-fs (dm-0): mounted filesystem without journal. Opts: barrier=1
[    4.131097] EXT4-fs (dm-1): mounted filesystem without journal. Opts: barrier=1
[    4.134142] EXT4-fs (dm-2): mounted filesystem without journal. Opts: barrier=1
[    4.147553] init: 14 output lines suppressed due to ratelimiting
[    4.157439] random: init: uninitialized urandom read (40 bytes read)
[    4.218444] snddaudio snddaudio0: ASoC: CPU DAI (null) not registered
[    4.225660] snddaudio snddaudio0: snd_soc_register_card failed
[    4.286478] random: init: uninitialized urandom read (40 bytes read)
[    4.312951] init: Loading SELinux policy
[    4.331466] SELinux: 8192 avtab hash slots, 22279 rules.
[    4.348949] SELinux: 8192 avtab hash slots, 22279 rules.
[    4.354953] SELinux:  1 users, 4 roles, 1373 types, 0 bools, 1 sens, 1024 cats
[    4.363036] SELinux:  97 classes, 22279 rules
[    4.371478] SELinux:  Completing initialization.
[    4.376652] SELinux:  Setting up existing superblocks.
[    4.490126] audit: type=1403 audit(1733304999.983:2): policy loaded auid=4294967295 ses=4294967295
[    4.500422] selinux: SELinux: Loaded policy from /vendor/etc/selinux/precompiled_sepolicy
[    4.500422]
[    4.516822] selinux: SELinux:  Skipping /product/etc/selinux/product_file_contexts:  empty file
[    4.516822]
[    4.531988] selinux: SELinux: Loaded file_contexts
[    4.531988]
[    4.545439] random: init: uninitialized urandom read (40 bytes read)
[    4.589052] init: init second stage started!
[    4.623935] init: Using Android DT directory /proc/device-tree/firmware/android/
[    4.637517] selinux: SELinux:  Skipping /product/etc/selinux/product_file_contexts:  empty file
[    4.637517]
[    4.649088] selinux: SELinux: Loaded file_contexts
[    4.649088]
[    4.656150] init: Running restorecon...
[    4.673426] init: Overriding previous 'ro.' property 'pm.dexopt.shared':'speed' with new value 'quicken'
[    4.686764] selinux: avc:  denied  { set } for  scontext=u:r:vendor_init:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=1
[    4.686764]
[    4.703398] init: Overriding previous 'ro.' property 'ro.zygote':'zygote32' with new value 'zygote64_32'
[    4.714654] selinux: avc:  denied  { set } for  scontext=u:r:vendor_init:s0 tcontext=u:object_r:dalvik_prop:s0 tclass=property_service permissive=1
[    4.714654]
[    4.731171] init: Overriding previous 'ro.' property 'pm.dexopt.boot':'verify' with new value 'extract'
[    4.989761] ueventd: ueventd started!
[    4.997663] selinux: SELinux:  Skipping /product/etc/selinux/product_file_contexts:  empty file
[    4.997663]
[    5.009450] selinux: SELinux: Loaded file_contexts
[    5.009450]
[    5.016801] ueventd: Parsing file /ueventd.rc...
[    5.023404] ueventd: Parsing file /vendor/ueventd.rc...
[    5.030182] ueventd: Parsing file /odm/ueventd.rc...
[    5.035820] ueventd: Unable to read config file '/odm/ueventd.rc': open() failed: No such file or directory
[    5.046810] ueventd: Parsing file /ueventd.sun50iw10p1.rc...
[    5.053208] ueventd: Unable to read config file '/ueventd.sun50iw10p1.rc': open() failed: No such file or directory
[    5.073112] apexd: Bootstrap subcommand detected
[    5.089139] apexd: Scanning /system/apex for embedded keys
[    5.096982] apexd: Scanning /product/apex for embedded keys
[    5.103534] apexd: ... does not exist. Skipping
[    5.108953] apexd: Scanning /system/apex looking for APEX packages.
[    5.116447] apexd: Found /system/apex/com.android.tzdata
[    5.123253] apexd: Successfully bind-mounted flattened package /system/apex/com.android.tzdata on /apex/com.android.tzdata@290000000
[    5.137099] apexd: Found /system/apex/com.android.runtime.release
[    5.144853] apexd: Successfully bind-mounted flattened package /system/apex/com.android.runtime.release on /apex/com.android.runtime@1
[    5.158864] apexd: Found /system/apex/com.android.media.swcodec
[    5.171452] apexd: 9 output lines suppressed due to ratelimiting
[    5.203001] audit: type=1400 audit(1733305000.696:3): avc:  denied  { read } for  pid=1577 comm="ueventd" name="/" dev="debugfs" ino=1 scontext=u:r:ueventd:s0 tcontext=u:object_r:debugfs:s0 tclass=dir permissive=1
[    5.224418] audit: type=1400 audit(1733305000.720:4): avc:  denied  { open } for  pid=1577 comm="ueventd" path="/sys/kernel/debug" dev="debugfs" ino=1 scontext=u:r:ueventd:s0 tcontext=u:object_r:debugfs:s0 tclass=dir permissive=1
[    5.247439] audit: type=1400 audit(1733305000.743:5): avc:  denied  { getattr } for  pid=1577 comm="ueventd" path="/sys/kernel/debug/fault_around_bytes" dev="debugfs" ino=1199 scontext=u:r:ueventd:s0 tcontext=u:object_r:debugfs:s0 tclass=file permissive=1
[    5.272991] audit: type=1400 audit(1733305000.766:6): avc:  denied  { getattr } for  pid=1577 comm="ueventd" path="/sys/kernel/debug/wakeup_sources" dev="debugfs" ino=18 scontext=u:r:ueventd:s0 tcontext=u:object_r:debugfs_wakeup_sources:s0 tclass=file permissive=1
[    5.364202] ueventd: Coldboot took 0.297 seconds
[    5.430928] Registered swp emulation handler
[    5.489611] init: wait for '/dev/block/by-name/media_data' took 0ms
[    5.499379] FAT-fs (mmcblk0p16): bogus number of reserved sectors
[    5.506255] FAT-fs (mmcblk0p16): Can't find a valid FAT filesystem
[    5.589798] fsck.f2fs: Info: Fix the reported corruption.
[    5.589798]
[    5.591081] logd.auditd: start
[    5.601074] fsck.f2fs:       Info: No support kernel version!
[    5.601074]
[    5.608726] fsck.f2fs: Info: Segments per section = 1
[    5.608726]
[    5.616161] fsck.f2fs: Info: Sections per zone = 1
[    5.616161]
[    5.623239] fsck.f2fs: Info: sector size = 512
[    5.623239]
[    5.629916] fsck.f2fs: Info: total sectors = 8720351 (4257 MB)
[    5.629916]
[    5.638134] fsck.f2fs: Info: MKFS version
[    5.638134]
[    5.644300] fsck.f2fs:   "4.9.170 #1 SMP PREEMPT Wed Dec 4 11:27:00 CST 2024"
[    5.644300]
[    5.653983] fsck.f2fs: Info: FSCK version
[    5.653983]
[    5.660143] fsck.f2fs:   from "4.9.170 #1 SMP PREEMPT Wed Dec 4 11:27:00 CST 2024"
[    5.660143]
[    5.758931] F2FS-fs (mmcblk0p17): recover_inode: ino = 7fd, name = external.db, inline = 1
[    5.768206] F2FS-fs (mmcblk0p17): recover_data: ino = 7fd (i_size: recover) recovered = 0, err = 0
[    5.778213] F2FS-fs (mmcblk0p17): recover_inode: ino = 13af, name = persistent_properties.tmp, inline = b
[    5.789500] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13af, name = persistent_properties.tmp, dir = 47, err = 0
[    5.800975] F2FS-fs (mmcblk0p17): recover_data: ino = 13af (i_size: recover) recovered = 0, err = 0
[    5.811061] F2FS-fs (mmcblk0p17): recover_inode: ino = 13b1, name = drop34.tmp, inline = b
[    5.824026] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13b1, name = drop34.tmp, dir = 58, err = 0
[    5.834095] F2FS-fs (mmcblk0p17): recover_data: ino = 13b1 (i_size: recover) recovered = 0, err = 0
[    5.844211] F2FS-fs (mmcblk0p17): recover_inode: ino = 13b2, name = log-files.xml, inline = 1
[    5.854301] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13b2, name = log-files.xml, dir = 57, err = 0
[    5.864704] F2FS-fs (mmcblk0p17): recover_data: ino = 13b2 (i_size: recover) recovered = 1, err = 0
[    5.874810] F2FS-fs (mmcblk0p17): recover_inode: ino = 13b4, name = drop177.tmp, inline = 3
[    5.884699] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13b4, name = drop177.tmp, dir = 58, err = 0
[    5.894812] F2FS-fs (mmcblk0p17): recover_data: ino = 13b4 (i_size: recover) recovered = 0, err = 0
[    5.904945] F2FS-fs (mmcblk0p17): recover_inode: ino = 13b5, name = drop34.tmp, inline = b
[    5.914198] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13b5, name = drop34.tmp, dir = 58, err = 0
[    5.924276] F2FS-fs (mmcblk0p17): recover_data: ino = 13b5 (i_size: recover) recovered = 0, err = 0
[    5.934419] F2FS-fs (mmcblk0p17): recover_inode: ino = 13b6, name = log-files.xml, inline = 1
[    5.943990] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13b6, name = log-files.xml, dir = 57, err = 0
[    5.954342] F2FS-fs (mmcblk0p17): recover_data: ino = 13b6 (i_size: recover) recovered = 1, err = 0
[    5.964439] F2FS-fs (mmcblk0p17): recover_inode: ino = 13b9, name = persistent_properties.tmp, inline = b
[    5.975139] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13b9, name = persistent_properties.tmp, dir = 47, err = 0
[    5.986606] F2FS-fs (mmcblk0p17): recover_data: ino = 13b9 (i_size: recover) recovered = 0, err = 0
[    5.996773] F2FS-fs (mmcblk0p17): recover_inode: ino = 5fd, name = primary.prof, inline = 3
[    6.006110] F2FS-fs (mmcblk0p17): recover_data: ino = 5fd (i_size: recover) recovered = 0, err = 0
[    6.016116] F2FS-fs (mmcblk0p17): recover_inode: ino = 13bb, name = drop180.tmp, inline = 3
[    6.038429] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13bb, name = drop180.tmp, dir = 58, err = 0
[    6.048535] F2FS-fs (mmcblk0p17): recover_data: ino = 13bb (i_size: recover) recovered = 0, err = 0
[    6.058638] F2FS-fs (mmcblk0p17): recover_inode: ino = 13bc, name = drop34.tmp, inline = b
[    6.067905] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13bc, name = drop34.tmp, dir = 58, err = 0
[    6.077919] F2FS-fs (mmcblk0p17): recover_data: ino = 13bc (i_size: recover) recovered = 0, err = 0
[    6.088020] F2FS-fs (mmcblk0p17): recover_inode: ino = 13bd, name = log-files.xml, inline = 1
[    6.097541] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13bd, name = log-files.xml, dir = 57, err = 0
[    6.107864] F2FS-fs (mmcblk0p17): recover_data: ino = 13bd (i_size: recover) recovered = 1, err = 0
[    6.117963] F2FS-fs (mmcblk0p17): recover_inode: ino = 13be, name = persistent_properties.tmp, inline = b
[    6.128656] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13be, name = persistent_properties.tmp, dir = 47, err = 0
[    6.140112] F2FS-fs (mmcblk0p17): recover_data: ino = 13be (i_size: recover) recovered = 0, err = 0
[    6.150205] F2FS-fs (mmcblk0p17): recover_inode: ino = 5fd, name = primary.prof, inline = 3
[    6.159537] F2FS-fs (mmcblk0p17): recover_data: ino = 5fd (i_size: recover) recovered = 0, err = 0
[    6.169536] F2FS-fs (mmcblk0p17): recover_inode: ino = 13c0, name = drop183.tmp, inline = 3
[    6.191852] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13c0, name = drop183.tmp, dir = 58, err = 0
[    6.201952] F2FS-fs (mmcblk0p17): recover_data: ino = 13c0 (i_size: recover) recovered = 0, err = 0
[    6.212042] F2FS-fs (mmcblk0p17): recover_inode: ino = 13c1, name = drop34.tmp, inline = b
[    6.221288] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13c1, name = drop34.tmp, dir = 58, err = 0
[    6.231296] F2FS-fs (mmcblk0p17): recover_data: ino = 13c1 (i_size: recover) recovered = 0, err = 0
[    6.241398] F2FS-fs (mmcblk0p17): recover_inode: ino = 13c2, name = log-files.xml, inline = 1
[    6.250927] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13c2, name = log-files.xml, dir = 57, err = 0
[    6.261240] F2FS-fs (mmcblk0p17): recover_data: ino = 13c2 (i_size: recover) recovered = 1, err = 0
[    6.271328] F2FS-fs (mmcblk0p17): recover_inode: ino = 13c3, name = persistent_properties.tmp, inline = b
[    6.282017] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13c3, name = persistent_properties.tmp, dir = 47, err = 0
[    6.293495] F2FS-fs (mmcblk0p17): recover_data: ino = 13c3 (i_size: recover) recovered = 0, err = 0
[    6.303590] F2FS-fs (mmcblk0p17): recover_inode: ino = 5fd, name = primary.prof, inline = 3
[    6.312916] F2FS-fs (mmcblk0p17): recover_data: ino = 5fd (i_size: recover) recovered = 0, err = 0
[    6.322904] F2FS-fs (mmcblk0p17): recover_inode: ino = 13c5, name = drop185.tmp, inline = 3
[    6.332232] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13c5, name = drop185.tmp, dir = 58, err = 0
[    6.342348] F2FS-fs (mmcblk0p17): recover_data: ino = 13c5 (i_size: recover) recovered = 0, err = 0
[    6.352438] F2FS-fs (mmcblk0p17): recover_inode: ino = 13c6, name = drop34.tmp, inline = b
[    6.361672] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13c6, name = drop34.tmp, dir = 58, err = 0
[    6.371676] F2FS-fs (mmcblk0p17): recover_data: ino = 13c6 (i_size: recover) recovered = 0, err = 0
[    6.381771] F2FS-fs (mmcblk0p17): recover_inode: ino = 13c7, name = log-files.xml, inline = 1
[    6.391299] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13c7, name = log-files.xml, dir = 57, err = 0
[    6.401608] F2FS-fs (mmcblk0p17): recover_data: ino = 13c7 (i_size: recover) recovered = 1, err = 0
[    6.411703] F2FS-fs (mmcblk0p17): recover_inode: ino = 13c8, name = persistent_properties.tmp, inline = b
[    6.422392] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13c8, name = persistent_properties.tmp, dir = 47, err = 0
[    6.433852] F2FS-fs (mmcblk0p17): recover_data: ino = 13c8 (i_size: recover) recovered = 0, err = 0
[    6.443954] F2FS-fs (mmcblk0p17): recover_inode: ino = 5fd, name = primary.prof, inline = 3
[    6.453275] F2FS-fs (mmcblk0p17): recover_data: ino = 5fd (i_size: recover) recovered = 0, err = 0
[    6.463269] F2FS-fs (mmcblk0p17): recover_inode: ino = 13ca, name = drop187.tmp, inline = 3
[    6.472604] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13ca, name = drop187.tmp, dir = 58, err = 0
[    6.482711] F2FS-fs (mmcblk0p17): recover_data: ino = 13ca (i_size: recover) recovered = 0, err = 0
[    6.492813] F2FS-fs (mmcblk0p17): recover_inode: ino = 13cb, name = drop34.tmp, inline = b
[    6.502054] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13cb, name = drop34.tmp, dir = 58, err = 0
[    6.512059] F2FS-fs (mmcblk0p17): recover_data: ino = 13cb (i_size: recover) recovered = 0, err = 0
[    6.522169] F2FS-fs (mmcblk0p17): recover_inode: ino = 13cc, name = log-files.xml, inline = 1
[    6.531682] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13cc, name = log-files.xml, dir = 57, err = 0
[    6.541997] F2FS-fs (mmcblk0p17): recover_data: ino = 13cc (i_size: recover) recovered = 1, err = 0
[    6.552104] F2FS-fs (mmcblk0p17): recover_inode: ino = 13cd, name = persistent_properties.tmp, inline = b
[    6.562793] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13cd, name = persistent_properties.tmp, dir = 47, err = 0
[    6.574252] F2FS-fs (mmcblk0p17): recover_data: ino = 13cd (i_size: recover) recovered = 0, err = 0
[    6.584344] F2FS-fs (mmcblk0p17): recover_inode: ino = 5fd, name = primary.prof, inline = 3
[    6.593672] F2FS-fs (mmcblk0p17): recover_data: ino = 5fd (i_size: recover) recovered = 0, err = 0
[    6.603670] F2FS-fs (mmcblk0p17): recover_inode: ino = 13cf, name = drop189.tmp, inline = 3
[    6.613003] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13cf, name = drop189.tmp, dir = 58, err = 0
[    6.623104] F2FS-fs (mmcblk0p17): recover_data: ino = 13cf (i_size: recover) recovered = 0, err = 0
[    6.633216] F2FS-fs (mmcblk0p17): recover_inode: ino = 13d0, name = drop34.tmp, inline = b
[    6.642435] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13d0, name = drop34.tmp, dir = 58, err = 0
[    6.652439] F2FS-fs (mmcblk0p17): recover_data: ino = 13d0 (i_size: recover) recovered = 0, err = 0
[    6.662532] F2FS-fs (mmcblk0p17): recover_inode: ino = 13d1, name = log-files.xml, inline = 1
[    6.672045] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13d1, name = log-files.xml, dir = 57, err = 0
[    6.682363] F2FS-fs (mmcblk0p17): recover_data: ino = 13d1 (i_size: recover) recovered = 1, err = 0
[    6.692465] F2FS-fs (mmcblk0p17): recover_inode: ino = 13d2, name = persistent_properties.tmp, inline = b
[    6.703145] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13d2, name = persistent_properties.tmp, dir = 47, err = 0
[    6.714616] F2FS-fs (mmcblk0p17): recover_data: ino = 13d2 (i_size: recover) recovered = 0, err = 0
[    6.724711] F2FS-fs (mmcblk0p17): recover_inode: ino = 5fd, name = primary.prof, inline = 3
[    6.734037] F2FS-fs (mmcblk0p17): recover_data: ino = 5fd (i_size: recover) recovered = 0, err = 0
[    6.744045] F2FS-fs (mmcblk0p17): recover_inode: ino = 13d5, name = drop192.tmp, inline = 3
[    6.753377] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13d5, name = drop192.tmp, dir = 58, err = 0
[    6.763482] F2FS-fs (mmcblk0p17): recover_data: ino = 13d5 (i_size: recover) recovered = 0, err = 0
[    6.773574] F2FS-fs (mmcblk0p17): recover_inode: ino = 13d4, name = drop34.tmp, inline = b
[    6.782809] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13d4, name = drop34.tmp, dir = 58, err = 0
[    6.792815] F2FS-fs (mmcblk0p17): recover_data: ino = 13d4 (i_size: recover) recovered = 0, err = 0
[    6.802914] F2FS-fs (mmcblk0p17): recover_inode: ino = 13d6, name = log-files.xml, inline = 1
[    6.812449] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13d6, name = log-files.xml, dir = 57, err = 0
[    6.822751] F2FS-fs (mmcblk0p17): recover_data: ino = 13d6 (i_size: recover) recovered = 1, err = 0
[    6.832853] F2FS-fs (mmcblk0p17): recover_inode: ino = 13d7, name = persistent_properties.tmp, inline = b
[    6.843533] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13d7, name = persistent_properties.tmp, dir = 47, err = 0
[    6.854993] F2FS-fs (mmcblk0p17): recover_data: ino = 13d7 (i_size: recover) recovered = 0, err = 0
[    6.865087] F2FS-fs (mmcblk0p17): recover_inode: ino = 5fd, name = primary.prof, inline = 3
[    6.874399] F2FS-fs (mmcblk0p17): recover_data: ino = 5fd (i_size: recover) recovered = 0, err = 0
[    6.884400] F2FS-fs (mmcblk0p17): recover_inode: ino = 13d9, name = drop194.tmp, inline = 3
[    6.893730] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13d9, name = drop194.tmp, dir = 58, err = 0
[    6.903833] F2FS-fs (mmcblk0p17): recover_data: ino = 13d9 (i_size: recover) recovered = 0, err = 0
[    6.913941] F2FS-fs (mmcblk0p17): recover_inode: ino = 13da, name = drop34.tmp, inline = b
[    6.923179] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13da, name = drop34.tmp, dir = 58, err = 0
[    6.933321] F2FS-fs (mmcblk0p17): recover_data: ino = 13da (i_size: recover) recovered = 0, err = 0
[    6.943468] F2FS-fs (mmcblk0p17): recover_inode: ino = 13db, name = log-files.xml, inline = 1
[    6.953041] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13db, name = log-files.xml, dir = 57, err = 0
[    6.976237] F2FS-fs (mmcblk0p17): recover_data: ino = 13db (i_size: recover) recovered = 1, err = 0
[    6.986352] F2FS-fs (mmcblk0p17): recover_inode: ino = 13dc, name = persistent_properties.tmp, inline = b
[    6.997057] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13dc, name = persistent_properties.tmp, dir = 47, err = 0
[    7.008524] F2FS-fs (mmcblk0p17): recover_data: ino = 13dc (i_size: recover) recovered = 0, err = 0
[    7.010608]
[    7.010608] insmod_device_driver
[    7.010608]
[    7.010846] device_chose finished 137!
[    7.029684] F2FS-fs (mmcblk0p17): recover_inode: ino = 5fd, name = primary.prof, inline = 3
[    7.038996] F2FS-fs (mmcblk0p17): recover_data: ino = 5fd (i_size: recover) recovered = 0, err = 0
[    7.048992] F2FS-fs (mmcblk0p17): recover_inode: ino = 13de, name = drop34.tmp, inline = b
[    7.058253] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13de, name = drop34.tmp, dir = 58, err = 0
[    7.068258] F2FS-fs (mmcblk0p17): recover_data: ino = 13de (i_size: recover) recovered = 0, err = 0
[    7.078362] F2FS-fs (mmcblk0p17): recover_inode: ino = 13df, name = log-files.xml, inline = 1
[    7.087890] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13df, name = log-files.xml, dir = 57, err = 0
[    7.098220] F2FS-fs (mmcblk0p17): recover_data: ino = 13df (i_size: recover) recovered = 1, err = 0
[    7.108309] F2FS-fs (mmcblk0p17): recover_inode: ino = 13e0, name = drop196.tmp, inline = 3
[    7.117647] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13e0, name = drop196.tmp, dir = 58, err = 0
[    7.127742] F2FS-fs (mmcblk0p17): recover_data: ino = 13e0 (i_size: recover) recovered = 0, err = 0
[    7.137829] F2FS-fs (mmcblk0p17): recover_inode: ino = 13e1, name = persistent_properties.tmp, inline = b
[    7.148526] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13e1, name = persistent_properties.tmp, dir = 47, err = 0
[    7.159994] F2FS-fs (mmcblk0p17): recover_data: ino = 13e1 (i_size: recover) recovered = 0, err = 0
[    7.170103] F2FS-fs (mmcblk0p17): recover_inode: ino = 5fd, name = primary.prof, inline = 3
[    7.179422] F2FS-fs (mmcblk0p17): recover_data: ino = 5fd (i_size: recover) recovered = 0, err = 0
[    7.189413] F2FS-fs (mmcblk0p17): recover_inode: ino = 13e3, name = drop198.tmp, inline = 3
[    7.198748] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13e3, name = drop198.tmp, dir = 58, err = 0
[    7.208869] F2FS-fs (mmcblk0p17): recover_data: ino = 13e3 (i_size: recover) recovered = 0, err = 0
[    7.218958] F2FS-fs (mmcblk0p17): recover_inode: ino = 13e4, name = drop34.tmp, inline = b
[    7.228209] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13e4, name = drop34.tmp, dir = 58, err = 0
[    7.238226] F2FS-fs (mmcblk0p17): recover_data: ino = 13e4 (i_size: recover) recovered = 0, err = 0
[    7.248320] F2FS-fs (mmcblk0p17): recover_inode: ino = 13e5, name = log-files.xml, inline = 1
[    7.257858] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13e5, name = log-files.xml, dir = 57, err = 0
[    7.268179] F2FS-fs (mmcblk0p17): recover_data: ino = 13e5 (i_size: recover) recovered = 1, err = 0
[    7.278395] F2FS-fs (mmcblk0p17): recover_inode: ino = 13e6, name = persistent_properties.tmp, inline = b
[    7.289129] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13e6, name = persistent_properties.tmp, dir = 47, err = 0
[    7.300624] F2FS-fs (mmcblk0p17): recover_data: ino = 13e6 (i_size: recover) recovered = 0, err = 0
[    7.310722] F2FS-fs (mmcblk0p17): recover_inode: ino = 5fd, name = primary.prof, inline = 3
[    7.320054] F2FS-fs (mmcblk0p17): recover_data: ino = 5fd (i_size: recover) recovered = 0, err = 0
[    7.330055] F2FS-fs (mmcblk0p17): recover_inode: ino = 13e8, name = drop201.tmp, inline = 3
[    7.339403] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13e8, name = drop201.tmp, dir = 58, err = 0
[    7.349502] F2FS-fs (mmcblk0p17): recover_data: ino = 13e8 (i_size: recover) recovered = 0, err = 0
[    7.359609] F2FS-fs (mmcblk0p17): recover_inode: ino = 13e9, name = drop34.tmp, inline = b
[    7.368863] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13e9, name = drop34.tmp, dir = 58, err = 0
[    7.378875] F2FS-fs (mmcblk0p17): recover_data: ino = 13e9 (i_size: recover) recovered = 0, err = 0
[    7.388969] F2FS-fs (mmcblk0p17): recover_inode: ino = 13ea, name = log-files.xml, inline = 1
[    7.398486] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13ea, name = log-files.xml, dir = 57, err = 0
[    7.408807] F2FS-fs (mmcblk0p17): recover_data: ino = 13ea (i_size: recover) recovered = 1, err = 0
[    7.418898] F2FS-fs (mmcblk0p17): recover_inode: ino = 13eb, name = persistent_properties.tmp, inline = b
[    7.429583] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13eb, name = persistent_properties.tmp, dir = 47, err = 0
[    7.441061] F2FS-fs (mmcblk0p17): recover_data: ino = 13eb (i_size: recover) recovered = 0, err = 0
[    7.451145] F2FS-fs (mmcblk0p17): recover_inode: ino = 5fd, name = primary.prof, inline = 3
[    7.460464] F2FS-fs (mmcblk0p17): recover_data: ino = 5fd (i_size: recover) recovered = 0, err = 0
[    7.470464] F2FS-fs (mmcblk0p17): recover_inode: ino = 13ed, name = drop203.tmp, inline = 3
[    7.479797] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13ed, name = drop203.tmp, dir = 58, err = 0
[    7.489908] F2FS-fs (mmcblk0p17): recover_data: ino = 13ed (i_size: recover) recovered = 0, err = 0
[    7.500011] F2FS-fs (mmcblk0p17): recover_inode: ino = 13ee, name = drop34.tmp, inline = b
[    7.509245] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13ee, name = drop34.tmp, dir = 58, err = 0
[    7.519246] F2FS-fs (mmcblk0p17): recover_data: ino = 13ee (i_size: recover) recovered = 0, err = 0
[    7.529337] F2FS-fs (mmcblk0p17): recover_inode: ino = 13ef, name = log-files.xml, inline = 1
[    7.538856] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13ef, name = log-files.xml, dir = 57, err = 0
[    7.549181] F2FS-fs (mmcblk0p17): recover_data: ino = 13ef (i_size: recover) recovered = 1, err = 0
[    7.559275] F2FS-fs (mmcblk0p17): recover_inode: ino = 13f0, name = persistent_properties.tmp, inline = b
[    7.569959] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13f0, name = persistent_properties.tmp, dir = 47, err = 0
[    7.581419] F2FS-fs (mmcblk0p17): recover_data: ino = 13f0 (i_size: recover) recovered = 0, err = 0
[    7.591505] F2FS-fs (mmcblk0p17): recover_inode: ino = 5fd, name = primary.prof, inline = 3
[    7.600831] F2FS-fs (mmcblk0p17): recover_data: ino = 5fd (i_size: recover) recovered = 0, err = 0
[    7.610837] F2FS-fs (mmcblk0p17): recover_inode: ino = 13f2, name = drop205.tmp, inline = 3
[    7.620174] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13f2, name = drop205.tmp, dir = 58, err = 0
[    7.630283] F2FS-fs (mmcblk0p17): recover_data: ino = 13f2 (i_size: recover) recovered = 0, err = 0
[    7.640389] F2FS-fs (mmcblk0p17): recover_inode: ino = 13f3, name = drop34.tmp, inline = b
[    7.649623] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13f3, name = drop34.tmp, dir = 58, err = 0
[    7.659630] F2FS-fs (mmcblk0p17): recover_data: ino = 13f3 (i_size: recover) recovered = 0, err = 0
[    7.669716] F2FS-fs (mmcblk0p17): recover_inode: ino = 13f4, name = log-files.xml, inline = 1
[    7.679236] F2FS-fs (mmcblk0p17): recover_dentry: ino = 13f4, name = log-files.xml, dir = 57, err = 0
[    7.689541] F2FS-fs (mmcblk0p17): recover_data: ino = 13f4 (i_size: recover) recovered = 1, err = 0
[    7.718953] F2FS-fs (mmcblk0p17): checkpoint: version = 32a82eda
[    7.725807] F2FS-fs (mmcblk0p17): Mounted with checkpoint version = 32a82eda
[    7.736384] EXT4-fs (mmcblk0p7): Ignoring removed nomblk_io_submit option
[    7.749080] EXT4-fs (mmcblk0p7): recovery complete
[    7.754569] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[    7.853130] EXT4-fs (mmcblk0p7): Ignoring removed nomblk_io_submit option
[    7.862097] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: barrier=1,data=ordered,nomblk_io_submit,noauto_da_alloc,errors=panic
[    7.897470] init: 14 output lines suppressed due to ratelimiting
[    7.911165] zram0: detected capacity change from 0 to 1554452480
[    7.942835] mkswap: Swapspace size: 1518016k, UUID=3ad44fa5-0cf8-48a1-9075-ee5cd99d996a
[    7.952867] Adding 1518016k swap on /dev/block/zram0.  Priority:-1 extents:1 across:1518016k SS
console:/ $ [    8.092506] videobuf2_vmalloc: disagrees about version of symbol module_layout
[    8.351103] apexd: Marking APEXd as starting
[    8.357006] apexd: Scanning /system/apex for embedded keys
[    8.365123] apexd: Scanning /product/apex for embedded keys
[    8.371698] apexd: ... does not exist. Skipping
[    8.376990] apexd: Populating APEX database from mounts...
[    8.383758] apexd: Failed to walk /product/apex : Can't open /product/apex for reading : No such file or directory
[    8.396167] apexd: Found "/apex/com.android.tzdata@290000000"
[    8.402931] apexd: Found "/apex/com.android.runtime@1"
[    8.408892] apexd: 2 packages restored.
[    8.413299] apexd: Scanning /data/apex/sessions looking for sessions to be activated.
[    8.455252] vdc: Waited 0ms for vold
[    8.528921] type=1400 audit(1733305004.023:7): avc: denied { setattr } for comm="init" name="audio_d" dev="mmcblk0p17" ino=118 scontext=u:r:vendor_init:s0 tcontext=u:object_r:audio_rw_data_file:s0 tclass=dir permissive=1
[    8.689335] logd.daemon: reinit
[    9.220026] file system registered
[    9.232822] type=1400 audit(1733305004.023:7): avc: denied { setattr } for comm="init" name="audio_d" dev="mmcblk0p17" ino=118 scontext=u:r:vendor_init:s0 tcontext=u:object_r:audio_rw_data_file:s0 tclass=dir permissive=1
[    9.254898] type=1400 audit(1733305004.726:8): avc: denied { create } for comm="audio@2.0-servi" scontext=u:r:hal_audio_default:s0 tcontext=u:r:hal_audio_default:s0 tclass=tcp_socket permissive=1
[    9.257919] using random self ethernet address
[    9.257924] using random host ethernet address
[    9.288994] healthd: No battery devices found
[    9.303052] sunxi-bt soc@03000000:bt@0: block state already is 1
[    9.314480] healthd: battery none chg=au
[    9.327591] type=1400 audit(1733305004.726:8): avc: denied { create } for comm="audio@2.0-servi" scontext=u:r:hal_audio_default:s0 tcontext=u:r:hal_audio_default:s0 tclass=tcp_socket permissive=1
[    9.351715] type=1400 audit(1733305004.726:9): avc: denied { setopt } for comm="audio@2.0-servi" scontext=u:r:hal_audio_default:s0 tcontext=u:r:hal_audio_default:s0 tclass=tcp_socket permissive=1
[    9.372060] type=1400 audit(1733305004.726:9): avc: denied { setopt } for comm="audio@2.0-servi" scontext=u:r:hal_audio_default:s0 tcontext=u:r:hal_audio_default:s0 tclass=tcp_socket permissive=1
[    9.391627] type=1400 audit(1733305004.726:10): avc: denied { bind } for comm="audio@2.0-servi" scontext=u:r:hal_audio_default:s0 tcontext=u:r:hal_audio_default:s0 tclass=tcp_socket permissive=1
[    9.411192] type=1400 audit(1733305004.726:10): avc: denied { bind } for comm="audio@2.0-servi" scontext=u:r:hal_audio_default:s0 tcontext=u:r:hal_audio_default:s0 tclass=tcp_socket permissive=1
[    9.620275] aicbsp_init
[    9.623078] RELEASE_DATE:2024_0712_e2a932c1
[    9.624857] read descriptors
[    9.624870] read strings
[    9.633955] aicbsp_resv_mem_init
[    9.639293] init: Command 'insmod /vendor/modules/aic8800_bsp.ko' action=persist.vendor.bluetooth_vendor=aic (/vendor/etc/init/init.wireless.bluetooth.rc:34) took 294ms and succeeded
[    9.659657] init: Service 'preloaddata' (pid 2177) exited with status 0
[    9.667917] init: Sending signal 9 to service 'preloaddata' (pid 2177) process group...
[    9.677763] libprocessgroup: Successfully killed process cgroup uid 0 pid 2177 in 0ms
[    9.759076] aic_bluetooth_mod_init
[    9.765079] -->rfkill_bluetooth_init
[    9.769688] <--rfkill_bluetooth_init
[    9.770171] treadahead: go to process_files
[    9.778746] [BT_LPM] bluesleep_init: BlueSleep Mode Driver Ver 1.3.3
[    9.786437] [BT_LPM] bluesleep_probe: bt_hostwake gpio=203 assert=1
[    9.786437]
[    9.795229] [BT_LPM] bluesleep_probe: bt_wake gpio=204 assert=1
[    9.795229]
[    9.803532] [BT_LPM] bluesleep_probe: uart_index (1)
[    9.803532]
[    9.811287] init: Command 'insmod /vendor/modules/aic8800_btlpm.ko' action=persist.vendor.bluetooth_vendor=aic (/vendor/etc/init/init.wireless.bluetooth.rc:35) took 122ms and succeeded
[    9.832066] init: Service 'exec 10 (/system/bin/gsid run-startup-tasks)' (pid 2175) exited with status 0
[    9.843019] init: Sending signal 9 to service 'exec 10 (/system/bin/gsid run-startup-tasks)' (pid 2175) process group...
[    9.855715] libprocessgroup: Successfully killed process cgroup uid 0 pid 2175 in 0ms
[    9.865187] init: processing action (nonencrypted) from (/init.rc:760)
[    9.872754] init: Could not start service 'flash_recovery' as part of class 'main': Cannot find '/system/bin/install-recovery.sh': No such file or directory
[   10.425396] android_work: sent uevent USB_STATE=CONNECTED
[   10.718412] configfs-gadget gadget: high-speed config #1: b
[   10.725000] android_work: sent uevent USB_STATE=CONFIGURED
[   10.931968] type=1400 audit(1733305005.736:16): avc: denied { write } for comm="radio_monitor" name="uevent" dev="sysfs" ino=20547 scontext=u:r:radio_monitor:s0 tcontext=u:object_r:sysfs_usb:s0 tclass=file permissive=1
[   10.933210] input: sunxi-ir-uinput as /devices/virtual/input/input5
[   10.961025] type=1400 audit(1733305006.426:17): avc: denied { read } for comm="multi_ir" name="sunxi_ir_protocol" dev="proc" ino=4026532136 scontext=u:r:multi_ir:s0 tcontext=u:object_r:proc:s0 tclass=file permissive=1
[   10.982976] type=1400 audit(1733305006.426:17): avc: denied { read } for comm="multi_ir" name="sunxi_ir_protocol" dev="proc" ino=4026532136 scontext=u:r:multi_ir:s0 tcontext=u:object_r:proc:s0 tclass=file permissive=1
[   11.004650] type=1400 audit(1733305006.426:18): avc: denied { open } for comm="multi_ir" path="/proc/sunxi_ir_protocol" dev="proc" ino=4026532136 scontext=u:r:multi_ir:s0 tcontext=u:object_r:proc:s0 tclass=file permissive=1
[   12.855219] type=1400 audit(1733305006.426:18): avc: denied { open } for comm="multi_ir" path="/proc/sunxi_ir_protocol" dev="proc" ino=4026532136 scontext=u:r:multi_ir:s0 tcontext=u:object_r:proc:s0 tclass=file permissive=1
[   12.861558] pvrsrvkm: loading out-of-tree module taints kernel.
[   12.871912] audit: audit_backlog=70 > audit_backlog_limit=64
[   12.871917] audit: audit_lost=1 audit_rate_limit=0 audit_backlog_limit=64
[   12.871920] audit: backlog limit exceeded
[   12.871927] audit: audit_backlog=70 > audit_backlog_limit=64
[   12.871930] audit: audit_lost=2 audit_rate_limit=0 audit_backlog_limit=64
[   12.871932] audit: backlog limit exceeded
[   12.871977] audit: audit_backlog=70 > audit_backlog_limit=64
[   12.871980] audit: audit_lost=3 audit_rate_limit=0 audit_backlog_limit=64
[   12.871982] audit: backlog limit exceeded
[   12.871989] audit: audit_backlog=70 > audit_backlog_limit=64
[   12.948915] type=1400 audit(1733305008.350:19): avc: denied { open } for comm="getprop" path="/dev/__properties__/u:object_r:apexd_prop:s0" dev="tmpfs" ino=335 scontext=u:r:shell:s0 tcontext=u:object_r:apexd_prop:s0 tclass=file permissive=1
[   12.952679] pvrsrvkm gpu: set gpu core rate:504000000 freq:504000000-950000uV dfs:0x00000001
[   12.952684] pvrsrvkm gpu: set gpu core rate:504000000 freq:472500000-950000uV dfs:0x00000002
[   12.952688] pvrsrvkm gpu: set gpu core rate:504000000 freq:441000000-950000uV dfs:0x00000004
[   12.952692] pvrsrvkm gpu: set gpu core rate:252000000 freq:252000000-950000uV dfs:0x00000001
[   12.952836] pvrsrvkm gpu: idle:1 dvfs:0 power:0 Yes mode:1 volt:950000 core:504000000
[   12.952894] PVR_K:  2144: Read BVNC 22.102.54.38 from HW device registers
[   12.952921] PVR_K:  2144: RGX Device registered with BVNC 22.102.54.38
[   12.953500] pvrsrvkm gpu: opp[1/4]: (252000000 Hz, 950000 uV)
[   12.953504] pvrsrvkm gpu: opp[2/4]: (441000000 Hz, 950000 uV)
[   12.953508] pvrsrvkm gpu: opp[3/4]: (472500000 Hz, 950000 uV)
[   12.953512] pvrsrvkm gpu: opp[4/4]: (504000000 Hz, 950000 uV)
[   12.953946] pvrsrvkm gpu: Cooling: power ops not registered, not enabling cooling
[   12.962155] [drm] Initialized pvr 1.11.5516664 20170530 on minor 0
[   12.962538] snddaudio snddaudio0: codec: snd-soc-dummy, codec_dai: snd-soc-dummy-dai.
[   12.962551] snddaudio snddaudio0: ASoC: CPU DAI (null) not registered
[   12.962556] snddaudio snddaudio0: snd_soc_register_card failed
[   13.099869] type=1400 audit(1733305008.350:19): avc: denied { open } for comm="getprop" path="/dev/__properties__/u:object_r:apexd_prop:s0" dev="tmpfs" ino=335 scontext=u:r:shell:s0 tcontext=u:object_r:apexd_prop:s0 tclass=file permissive=1
[   13.123801] type=1400 audit(1733305008.350:20): avc: denied { getattr } for comm="getprop" path="/dev/__properties__/u:object_r:apexd_prop:s0" dev="tmpfs" ino=335 scontext=u:r:shell:s0 tcontext=u:object_r:apexd_prop:s0 tclass=file permissive=1
[   13.148120] type=1400 audit(1733305008.350:20): avc: denied { getattr } for comm="getprop" path="/dev/__properties__/u:object_r:apexd_prop:s0" dev="tmpfs" ino=335 scontext=u:r:shell:s0 tcontext=u:object_r:apexd_prop:s0 tclass=file permissive=1
[   13.172361] type=1400 audit(1733305008.350:21): avc: denied { read } for comm="getprop" name="u:object_r:audio_hal_prop:s0" dev="tmpfs" ino=336 scontext=u:r:shell:s0 tcontext=u:object_r:audio_hal_prop:s0 tclass=file permissive=1
[   13.310915] PVR_K:  2135: RGX Firmware image 'rgx.fw.22.102.54.38' loaded
[   13.397699] random: crng init done
[   13.401504] random: 6 urandom warning(s) missed due to ratelimiting
[   14.121847] sid_rd_ver_reg()418 - ver >= 4, soc ver:6
[   14.875615] init: Received control message 'start' for 'bootanim' from pid: 2149 (/system/bin/surfaceflinger)
[   14.888015] init: starting service 'bootanim'...
[   18.747938] healthd: battery none chg=au
[   18.901350] healthd: battery none chg=au
[   18.913124] healthd: battery none chg=au
[   19.155806] type=1400 audit(1733305008.460:93): avc: denied { getattr } for comm="pvrsrvctl" path="/proc/modules" dev="proc" ino=4026532050 scontext=u:r:pvr:s0 tcontext=u:object_r:proc_modules:s0 tclass=file permissive=1
[   19.185502] type=1400 audit(1733305014.650:94): avc: denied { read } for comm="system_server" name="hctosys" dev="sysfs" ino=21117 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[   19.207436] type=1400 audit(1733305014.650:94): avc: denied { read } for comm="system_server" name="hctosys" dev="sysfs" ino=21117 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[   19.228997] type=1400 audit(1733305014.650:95): avc: denied { open } for comm="system_server" path="/sys/devices/platform/soc/twi3/i2c-3/3-0051/rtc/rtc0/hctosys" dev="sysfs" ino=21117 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[   19.263276] type=1400 audit(1733305014.650:95): avc: denied { open } for comm="system_server" path="/sys/devices/platform/soc/twi3/i2c-3/3-0051/rtc/rtc0/hctosys" dev="sysfs" ino=21117 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[   19.290205] type=1400 audit(1733305014.650:96): avc: denied { getattr } for comm="system_server" path="/sys/devices/platform/soc/twi3/i2c-3/3-0051/rtc/rtc0/hctosys" dev="sysfs" ino=21117 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[   19.457576] init: processing action (sys.sysctl.extra_free_kbytes=*) from (/init.rc:806)
[   20.251253] acc_open
[   20.253717] acc_release
[   20.540638] init: Received control message 'interface_start' for 'android.hardware.wifi@1.0::IWifi/default' from pid: 1990 (/system/bin/hwservicemanager)
[   20.559647] init: starting service 'vendor.wifi_hal_legacy'...
[   20.574137] init: Received control message 'interface_start' for 'android.hardware.wifi@1.0::IWifi/default' from pid: 1990 (/system/bin/hwservicemanager)
[   20.749276] libphy: gmac0: probed
[   20.790992] sunxi-gmac gmac0 eth0: eth0: Type(7) PHY ID 001cc916 at 0 IRQ poll (gmac0-0:00)
[   20.800897] snddaudio snddaudio0: codec: snd-soc-dummy, codec_dai: snd-soc-dummy-dai.
[   20.800912] snddaudio snddaudio0: ASoC: CPU DAI (null) not registered
[   20.800917] snddaudio snddaudio0: snd_soc_register_card failed
[   21.896241] AICWFDBG(LOGTRACE)       >>> rwnx_mod_init()
[   21.901709] AICWFDBG(LOGINFO)        rwnx v6.4.3.0 - - 241c091M (master)
[   21.908735] AICWFDBG(LOGINFO)        RELEASE_DATE:2024_0712_e2a932c1
[   21.915608] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array Enter
[   21.921875] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[0]:ffffff8000e2c900
[   21.930461] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[1]:ffffff8000e2c960
[   21.938967] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[2]:ffffff8000e2c9c0
[   21.947524] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[3]:ffffff8000e2ca20
[   21.956035] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[4]:ffffff8000e2ca80
[   21.964617] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[5]:ffffff8000e2cae0
[   21.973122] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[6]:ffffff8000e2cb40
[   21.981784] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[7]:ffffff8000e2cba0
[   21.990301] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[8]:ffffff8000e2cc00
[   21.998870] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[9]:ffffff8000e2cc60
[   22.007378] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[10]:ffffff8000e2ccc0
[   22.016036] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[11]:ffffff8000e2cd20
[   22.024636] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[12]:ffffff8000e2cd80
[   22.033276] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[13]:ffffff8000e2cde0
[   22.041902] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[14]:ffffff8000e2ce40
[   22.050550] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[15]:ffffff8000e2cea0
[   22.059115] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[16]:ffffff8000e2cf00
[   22.067726] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[17]:ffffff8000e2cf60
[   22.076310] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[18]:ffffff8000e2cfc0
[   22.084989] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[19]:ffffff8000e2d020
[   22.093661] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[20]:ffffff8000e2d080
[   22.102266] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[21]:ffffff8000e2d0e0
[   22.110851] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[22]:ffffff8000e2d140
[   22.119436] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[23]:ffffff8000e2d1a0
[   22.128009] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[24]:ffffff8000e2d200
[   22.136582] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[25]:ffffff8000e2d260
[   22.145178] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[26]:ffffff8000e2d2c0
[   22.153835] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[27]:ffffff8000e2d320
[   22.162498] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[28]:ffffff8000e2d380
[   22.171108] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[29]:ffffff8000e2d3e0
[   22.179750] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[30]:ffffff8000e2d440
[   22.188383] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[31]:ffffff8000e2d4a0
[   22.197058] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[32]:ffffff8000e2d500
[   22.205740] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[33]:ffffff8000e2d560
[   22.214389] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[34]:ffffff8000e2d5c0
[   22.223056] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[35]:ffffff8000e2d620
[   22.231944] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[36]:ffffff8000e2d680
[   22.240589] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[37]:ffffff8000e2d6e0
[   22.249266] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[38]:ffffff8000e2d740
[   22.257904] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array cmd_queue[39]:ffffff8000e2d7a0
[   22.266573] AICWFDBG(LOGTRACE)       rwnx_init_cmd_array Exit
[   22.272681] aicbsp: aicbsp_set_subsys, subsys: AIC_WIFI, state to: 1
[   22.279923] aicbsp: aicbsp_set_subsys, power state change to 1 dure to AIC_WIFI
[   22.288171] aicbsp: aicbsp_platform_power_on
[   22.292993] sunxi-wlan soc@03000000:wlan@0: bus_index: 1
[   22.406805] sunxi-wlan soc@03000000:wlan@0: check wlan wlan_power voltage: 1900000
[   22.480711] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   22.511126] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   22.538570] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[   22.545360] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[   22.555640] type=1400 audit(1733305014.650:96): avc: denied { getattr } for comm="system_server" path="/sys/devices/platform/soc/twi3/i2c-3/3-0051/rtc/rtc0/hctosys" dev="sysfs" ino=21117 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[   22.557299] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   22.568263] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   22.598825] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[   22.598942] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[   22.599150] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[   22.601324] mmc2: new high speed SDIO card at address 390b
[   22.612677] snddaudio snddaudio0: codec: snd-soc-dummy, codec_dai: snd-soc-dummy-dai.
[   22.612693] snddaudio snddaudio0: ASoC: CPU DAI (null) not registered
[   22.612698] snddaudio snddaudio0: snd_soc_register_card failed
[   22.624319] snddaudio snddaudio0: codec: snd-soc-dummy, codec_dai: snd-soc-dummy-dai.
[   22.624334] snddaudio snddaudio0: ASoC: CPU DAI (null) not registered
[   22.624339] snddaudio snddaudio0: snd_soc_register_card failed
[   22.632664] aicbsp: aicbsp_sdio_probe:1 vid:0xC8A1  did:0x0082
[   22.632751] aicbsp: aicbsp_sdio_probe:2 vid:0xC8A1  did:0x0182
[   22.632754] aicbsp: aicbsp_sdio_probe after replace:1
[   22.632759] AICWFDBG(LOGINFO)        aicwf_sdio_chipmatch USE AIC8800D80
[   22.632764] aicbsp: aicbsp_get_feature, set FEATURE_SDIO_CLOCK 150 MHz
[   22.632767] aicbsp: aicwf_sdio_reg_init
[   22.633947] snddaudio snddaudio0: codec: snd-soc-dummy, codec_dai: snd-soc-dummy-dai.
[   22.633962] snddaudio snddaudio0: ASoC: CPU DAI (null) not registered
[   22.633967] snddaudio snddaudio0: snd_soc_register_card failed
[   22.636187] AICWFDBG(LOGINFO)        aicbsp: aicbsp_driver_fw_init, chip rev: 7
[   22.636195] rwnx_load_firmware :firmware path = /vendor/etc/firmware/fw_patch_table_8800d80_u02.bin
[   22.639597] file md5:313babc74ae8b1d44dc0e0a4c4c73686
[   22.639707] rwnx_plat_bin_fw_upload_android
[   22.639712] rwnx_load_firmware :firmware path = /vendor/etc/firmware/fw_adid_8800d80_u02.bin
[   22.640442] file md5:f546881a81b960d89a672578eb45a809
[   22.641951] rwnx_plat_bin_fw_upload_android
[   22.641958] rwnx_load_firmware :firmware path = /vendor/etc/firmware/fw_patch_8800d80_u02.bin
[   22.644338] file md5:8e83d7b94620c2a5444b2aaaab1a510d
[   22.849795] type=1400 audit(1733305018.050:97): avc: denied { getattr } for comm="webview_zygote" path="/data/data/com.android.webview" dev="mmcblk0p17" ino=1068 scontext=u:r:webview_zygote:s0 tcontext=u:object_r:app_data_file:s0:c99,c256,c512,c768 tclass=dir permissive=1
[   23.706006] axp803_usb_power: current limit setted: usb pc type
[   23.706006]
[   24.269910] aicbt_patch_table_load bt btmode[3]:5
[   24.281183] aicbt_patch_table_load bt uart_baud[3]:115200
[   24.297300] aicbt_patch_table_load bt uart_flowctrl[3]:1
[   24.314325] aicbt_patch_table_load bt lpm_enable[3]:0
[   24.424044] aicbt_patch_table_load bt tx_pwr[3]:28463
[   24.462749] aicbsp: bt patch version: - Jul 11 2024 10:38:54 - git 73d2ce5
[   24.470653] rwnx_plat_bin_fw_upload_android
[   24.478138] rwnx_load_firmware :firmware path = /vendor/etc/firmware/fmacfw_8800d80_u02.bin
[   24.510099] file md5:b39016c6531b5a0f6f5012eca50bc258
[   24.706566] rd_version_val=06090101
[   24.731561] AICWFDBG(LOGDEBUG)       aicwf_sdio_probe:1
[   24.737028] AICWFDBG(LOGDEBUG)       Class=7
[   24.741367] AICWFDBG(LOGDEBUG)       sdio vendor ID: 0xc8a1
[   24.751448] AICWFDBG(LOGDEBUG)       sdio device ID: 0x0082
[   24.757303] AICWFDBG(LOGDEBUG)       Function#: 1
[   24.762144] AICWFDBG(LOGINFO)        aicwf_sdio_chipmatch USE AIC8800D80
[   24.763909] aicbsp: sdio_err:<aicwf_sdio_bus_pwrctl,1402>: bus down
[   24.776501] aicbsp: aicbsp_get_feature, set FEATURE_SDIO_CLOCK 150 MHz
[   24.784426] aicsdio: aicwf_sdio_reg_init
[   24.794027] AICWFDBG(LOGINFO)        sdio ready
[   24.798585] aicwf_prealloc_init enter
[   24.803127] pre alloc rxbuff list len: 30
[   24.807700] aicbsp: aicbsp_resv_mem_alloc_skb, alloc resv_mem_txdata succuss, id: 0, size: 98304
[   24.819584] AICWFDBG(LOGINFO)        sdio_bustx_thread the policy of current thread is:1
[   24.828090] AICWFDBG(LOGINFO)        sdio_bustx_thread the rt_priority of current thread is:1
[   24.828163] AICWFDBG(LOGINFO)        sdio_busrx_thread the policy of current thread is:1
[   24.828165] AICWFDBG(LOGINFO)        sdio_busrx_thread the rt_priority of current thread is:1
[   24.828167] AICWFDBG(LOGINFO)        sdio_busrx_thread the current pid is:3331
[   24.828496] AICWFDBG(LOGTRACE)       >>> rwnx_platform_init()
[   24.828500] AICWFDBG(LOGTRACE)       >>> rwnx_cfg80211_init()
[   24.828628] aicbsp: aicbsp_get_feature, set FEATURE_SDIO_CLOCK 150 MHz
[   24.828643] AICWFDBG(LOGINFO)        rwnx_cfg80211_init sizeof(struct rwnx_hw):17784
[   24.828777] AICWFDBG(LOGTRACE)       >>> rwnx_init_aic()
[   24.828784] AICWFDBG(LOGTRACE)       >>> rwnx_cmd_mgr_init()
[   24.833600] tcp_ack_init
[   24.833610] AICWFDBG(LOGINFO)        aicwf_prealloc_txq_alloc size is diff will to be kzalloc
[   24.833634] AICWFDBG(LOGINFO)        aicwf_prealloc_txq_alloc txq kzalloc successful
[   24.845622] AICWFDBG(LOGTRACE)       >>> rwnx_send_dbg_mem_read_req()
[   24.845629] AICWFDBG(LOGTRACE)       rwnx_send_msg (1025)DBG_MEM_READ_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   24.845638] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   24.947619] AICWFDBG(LOGINFO)        sdio_bustx_thread the current pid is:3330
[   24.955470] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x401
[   24.962356] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   24.970760] AICWFDBG(LOGTRACE)       >>> rwnx_send_dbg_mem_read_req()
[   24.977479] AICWFDBG(LOGTRACE)       rwnx_send_msg (1025)DBG_MEM_READ_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   24.990279] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   24.999945] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x401
[   25.006889] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   25.015037] AICWFDBG(LOGINFO)        FDRV chip_id=7, chip_sub_id=2!!
[   25.021566] AICWFDBG(LOGTRACE)       >>> rwnx_platform_on()
[   25.027295] AICWFDBG(LOGINFO)        userconfig file path:aic_userconfig_8800d80.txt
[   25.035555] AICWFDBG(LOGINFO)        ### Load file aic_userconfig_8800d80.txt
[   25.042980] AICWFDBG(LOGINFO)        rwnx_load_firmware :firmware path = /vendor/etc/firmware/aic_userconfig_8800d80.txt
[   25.056857] AICWFDBG(LOGINFO)        file md5:35c8e99f3edd34d2a39bc9920e1da494
[   25.064702] AICWFDBG(LOGINFO)        ### Load file done: aic_userconfig_8800d80.txt, size=2683
[   25.073751] AICWFDBG(LOGINFO)        rwnx_plat_userconfig_parsing3: AIC USERCONFIG 2022/0803/1707
[   25.083501] AICWFDBG(LOGINFO)        rwnx_plat_userconfig_parsing3: txpwr_lvl
[   25.090940] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=enable value=1
[   25.099694] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11b_11ag_1m_2g4 value=18
[   25.109518] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11b_11ag_2m_2g4 value=18
[   25.119728] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11b_11ag_5m5_2g4 value=18
[   25.129802] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11b_11ag_11m_2g4 value=18
[   25.139710] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11b_11ag_6m_2g4 value=18
[   25.149479] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11b_11ag_9m_2g4 value=18
[   25.159410] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11b_11ag_12m_2g4 value=18
[   25.169533] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11b_11ag_18m_2g4 value=18
[   25.179603] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11b_11ag_24m_2g4 value=16
[   25.189505] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11b_11ag_36m_2g4 value=16
[   25.199409] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11b_11ag_48m_2g4 value=15
[   25.209275] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11b_11ag_54m_2g4 value=15
[   25.220404] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs0_2g4 value=18
[   25.230717] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs1_2g4 value=18
[   25.241127] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs2_2g4 value=18
[   25.251502] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs3_2g4 value=18
[   25.261535] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs4_2g4 value=16
[   25.272512] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs5_2g4 value=16
[   25.283110] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs6_2g4 value=15
[   25.293120] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs7_2g4 value=15
[   25.303469] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs8_2g4 value=14
[   25.313727] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs9_2g4 value=14
[   25.323720] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs0_2g4 value=18
[   25.333625] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs1_2g4 value=18
[   25.343232] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs2_2g4 value=18
[   25.353204] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs3_2g4 value=18
[   25.363165] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs4_2g4 value=16
[   25.372793] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs5_2g4 value=16
[   25.382513] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs6_2g4 value=15
[   25.392110] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs7_2g4 value=15
[   25.401674] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs8_2g4 value=14
[   25.411246] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs9_2g4 value=14
[   25.421068] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs10_2g4 value=13
[   25.430970] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs11_2g4 value=13
[   25.440620] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11a_6m_5g value=18
[   25.449834] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11a_9m_5g value=18
[   25.459007] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11a_12m_5g value=18
[   25.468300] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11a_18m_5g value=18
[   25.477567] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11a_24m_5g value=16
[   25.486902] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11a_36m_5g value=16
[   25.496162] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11a_48m_5g value=15
[   25.505715] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11a_54m_5g value=15
[   25.515138] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs0_5g value=18
[   25.525086] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs1_5g value=18
[   25.534969] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs2_5g value=18
[   25.544822] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs3_5g value=18
[   25.554720] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs4_5g value=16
[   25.564632] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs5_5g value=16
[   25.574486] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs6_5g value=15
[   25.584599] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs7_5g value=15
[   25.594487] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs8_5g value=14
[   25.604521] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11n_11ac_mcs9_5g value=14
[   25.614394] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs0_5g value=18
[   25.623939] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs1_5g value=18
[   25.633425] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs2_5g value=18
[   25.642876] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs3_5g value=18
[   25.652358] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs4_5g value=16
[   25.661808] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs5_5g value=16
[   25.671574] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs6_5g value=14
[   25.681196] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs7_5g value=14
[   25.690649] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs8_5g value=13
[   25.700178] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs9_5g value=13
[   25.709681] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs10_5g value=12
[   25.719276] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_11ax_mcs11_5g value=12
[   25.728855] AICWFDBG(LOGINFO)        rwnx_plat_userconfig_parsing3: txpwr_lvl_adj
[   25.736701] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_adj_enable value=0
[   25.745890] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_adj_2g4_chan_1_4 value=0
[   25.755954] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_adj_2g4_chan_5_9 value=0
[   25.765893] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_adj_2g4_chan_10_13 value=0
[   25.775922] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_adj_5g_chan_42 value=0
[   25.785511] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_adj_5g_chan_58 value=0
[   25.795097] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_adj_5g_chan_106 value=0
[   25.805798] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_adj_5g_chan_122 value=0
[   25.816543] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_adj_5g_chan_138 value=0
[   25.826264] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=lvl_adj_5g_chan_155 value=0
[   25.836295] AICWFDBG(LOGINFO)        rwnx_plat_userconfig_parsing3: txpwr_loss
[   25.843858] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=loss_enable value=0
[   25.853098] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=loss_value value=2
[   25.861949] AICWFDBG(LOGINFO)        rwnx_plat_userconfig_parsing3: txpwr_ofst
[   25.869786] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_enable value=0
[   25.878693] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_2g4_11b_chan_1_4 value=0
[   25.888638] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_2g4_11b_chan_5_9 value=0
[   25.898525] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_2g4_11b_chan_10_13 value=0
[   25.908681] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_2g4_ofdm_highrate_chan_1_4 value=0
[   25.919831] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_2g4_ofdm_highrate_chan_5_9 value=0
[   25.930853] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_2g4_ofdm_highrate_chan_10_13 value=0
[   25.942179] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_2g4_ofdm_lowrate_chan_1_4 value=0
[   25.953372] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_2g4_ofdm_lowrate_chan_5_9 value=0
[   25.964287] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_2g4_ofdm_lowrate_chan_10_13 value=0
[   25.975544] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_5g_ofdm_lowrate_chan_42 value=0
[   25.986474] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_5g_ofdm_lowrate_chan_58 value=0
[   25.997227] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_5g_ofdm_lowrate_chan_106 value=0
[   26.008148] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_5g_ofdm_lowrate_chan_122 value=0
[   26.018994] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_5g_ofdm_lowrate_chan_138 value=0
[   26.029699] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_5g_ofdm_lowrate_chan_155 value=0
[   26.040368] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_5g_ofdm_highrate_chan_42 value=0
[   26.051271] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_5g_ofdm_highrate_chan_58 value=0
[   26.062001] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_5g_ofdm_highrate_chan_106 value=0
[   26.073681] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_5g_ofdm_highrate_chan_122 value=0
[   26.084875] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_5g_ofdm_highrate_chan_138 value=0
[   26.096620] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_5g_ofdm_highrate_chan_155 value=0
[   26.107409] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_5g_ofdm_midrate_chan_42 value=0
[   26.118258] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_5g_ofdm_midrate_chan_58 value=0
[   26.128821] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_5g_ofdm_midrate_chan_106 value=0
[   26.139733] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_5g_ofdm_midrate_chan_122 value=0
[   26.150469] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_5g_ofdm_midrate_chan_138 value=0
[   26.161295] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=ofst_5g_ofdm_midrate_chan_155 value=0
[   26.172284] AICWFDBG(LOGINFO)        rwnx_plat_userconfig_parsing3: xtal cap
[   26.179800] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=xtal_enable value=0
[   26.188739] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=xtal_cap value=24
[   26.197415] AICWFDBG(LOGINFO)        rwnx_plat_nvram_set_value_v3:command=xtal_cap_fine value=31
[   26.206611] AICWFDBG(LOGINFO)        userconfig download complete
[   26.206611]
[   26.214481] AICWFDBG(LOGTRACE)       rwnx_send_msg (124)MM_SET_STACK_START_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   26.226285] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   26.235464] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x7c
[   26.242323] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   26.250567] AICWFDBG(LOGINFO)        is 5g support = 1, vendor_info = 0x21
[   26.257597] AICWFDBG(LOGTRACE)       rwnx_send_msg (129)MM_GET_FW_VERSION_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   26.269473] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   26.278245] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x81
[   26.285041] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   26.293124] AICWFDBG(LOGINFO)        Firmware Version: la Jul 03 2024 15:25:18 - g21266be
[   26.302741] AICWFDBG(LOGTRACE)       >>> rwnx_send_txpwr_lvl_v3_req()
[   26.309433] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:enable:1
[   26.317379] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11b_11ag_1m_2g4:18
[   26.326569] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11b_11ag_2m_2g4:18
[   26.336288] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11b_11ag_5m5_2g4:18
[   26.345895] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11b_11ag_11m_2g4:18
[   26.355488] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11b_11ag_6m_2g4:18
[   26.364762] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11b_11ag_9m_2g4:18
[   26.373943] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11b_11ag_12m_2g4:18
[   26.383459] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11b_11ag_18m_2g4:18
[   26.392785] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11b_11ag_24m_2g4:16
[   26.402399] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11b_11ag_36m_2g4:16
[   26.411953] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11b_11ag_48m_2g4:15
[   26.421604] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11b_11ag_54m_2g4:15
[   26.430977] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs0_2g4:18
[   26.440677] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs1_2g4:18
[   26.450414] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs2_2g4:18
[   26.460099] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs3_2g4:18
[   26.469918] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs4_2g4:16
[   26.479480] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs5_2g4:16
[   26.489182] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs6_2g4:15
[   26.498908] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs7_2g4:15
[   26.499284] init: processing action (sys.boot_completed=1) from (/init.rc:800)
[   26.499374] init: processing action (sys.boot_completed=1) from (/vendor/etc/init/hw/init.device.rc:54)
[   26.502461] init: Command 'write /sys/class/gpio/export 66' action=sys.boot_completed=1 (/vendor/etc/init/hw/init.device.rc:60) took 0ms and failed: Unable to write to file '/sys/class/gpio/export': Unable to write file contents: Device or resource busy
[   26.503255] init: Command 'write /sys/class/gpio/export 67' action=sys.boot_completed=1 (/vendor/etc/init/hw/init.device.rc:61) took 0ms and failed: Unable to write to file '/sys/class/gpio/export': Unable to write file contents: Device or resource busy
[   26.506224] init: Command 'write /sys/class/gpio/export 68' action=sys.boot_completed=1 (/vendor/etc/init/hw/init.device.rc:70) took 0ms and failed: Unable to write to file '/sys/class/gpio/export': Unable to write file contents: Device or resource busy
[   26.511515] init: Command 'write /sys/class/gpio/export 76' action=sys.boot_completed=1 (/vendor/etc/init/hw/init.device.rc:71) took 5ms and failed: Unable to write to file '/sys/class/gpio/export': Unable to write file contents: Device or resource busy
[   26.519515] init: processing action (sys.boot_completed=1) from (/system/etc/init/aw_thermal.rc:10)
[   26.519658] init: starting service 'aw_thermal'...
[   26.525641] init: processing action (sys.boot_completed=1 && sys.logbootcomplete=1) from (/system/etc/init/bootstat.rc:78)
[   26.526435] init: starting service 'exec 11 (/system/bin/bootstat --record_boot_complete --record_boot_reason --record_time_since_factory_reset -l)'...
[   26.533575] sdcardfs version 2.0
[   26.533582] sdcardfs: dev_name -> /data/media
[   26.533585] sdcardfs: options -> fsuid=1023,fsgid=1023,multiuser,derive_gid,default_normal,unshared_obb,mask=6,userid=0,gid=1015
[   26.533589] sdcardfs: mnt -> ffffffc072e741e0
[   26.533668] sdcardfs: mounted on top of /data/media type f2fs
[   26.534809] Remount options were mask=23,gid=9997 for vfsmnt ffffffc072e75c20.
[   26.534822] sdcardfs : options - debug:1
[   26.534825] sdcardfs : options - gid:9997
[   26.534827] sdcardfs : options - mask:23
[   26.535273] Remount options were mask=7,gid=9997 for vfsmnt ffffffc07382ec60.
[   26.535278] sdcardfs : options - debug:1
[   26.535280] sdcardfs : options - gid:9997
[   26.535282] sdcardfs : options - mask:7
[   26.535747] Remount options were mask=7,gid=9997 for vfsmnt ffffffc073718020.
[   26.535752] sdcardfs : options - debug:1
[   26.535754] sdcardfs : options - gid:9997
[   26.535756] sdcardfs : options - mask:7
[   26.773429] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs8_2g4:14
[   26.782804] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs9_2g4:14
[   26.792116] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs0_2g4:18
[   26.801051] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs1_2g4:18
[   26.809971] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs2_2g4:18
[   26.818894] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs3_2g4:18
[   26.827886] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs4_2g4:16
[   26.836922] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs5_2g4:16
[   26.845962] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs6_2g4:15
[   26.855006] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs7_2g4:15
[   26.863999] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs8_2g4:14
[   26.872974] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs9_2g4:14
[   26.881947] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs10_2g4:13
[   26.891005] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs11_2g4:13
[   26.900091] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11a_1m_5g:-128
[   26.908887] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11a_2m_5g:-128
[   26.917649] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11a_5m5_5g:-128
[   26.926532] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11a_11m_5g:-128
[   26.935431] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11a_6m_5g:18
[   26.944003] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11a_9m_5g:18
[   26.952594] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11a_12m_5g:18
[   26.961336] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11a_18m_5g:18
[   26.970042] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11a_24m_5g:16
[   26.978723] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11a_36m_5g:16
[   26.987384] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11a_48m_5g:15
[   26.996052] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11a_54m_5g:15
[   27.004721] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs0_5g:18
[   27.013982] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs1_5g:18
[   27.023246] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs2_5g:18
[   27.032496] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs3_5g:18
[   27.041794] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs4_5g:16
[   27.051107] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs5_5g:16
[   27.060373] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs6_5g:15
[   27.069653] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs7_5g:15
[   27.078980] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs8_5g:14
[   27.088260] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11n_11ac_mcs9_5g:14
[   27.097498] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs0_5g:18
[   27.106405] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs1_5g:18
[   27.115282] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs2_5g:18
[   27.124151] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs3_5g:18
[   27.133013] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs4_5g:16
[   27.141891] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs5_5g:16
[   27.150745] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs6_5g:14
[   27.159673] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs7_5g:14
[   27.168616] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs8_5g:13
[   27.177488] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs9_5g:13
[   27.186384] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs10_5g:12
[   27.195363] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_v3_in_fdrv:lvl_11ax_mcs11_5g:12
[   27.204348] AICWFDBG(LOGINFO)        get_userconfig_txpwr_loss:loss_enable:0
[   27.211710] AICWFDBG(LOGINFO)        get_userconfig_txpwr_loss:loss_value:2
[   27.218924] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:enable:1
[   27.225926] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11b_11ag_1m_2g4:18
[   27.234204] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11b_11ag_2m_2g4:18
[   27.242552] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11b_11ag_5m5_2g4:18
[   27.251302] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11b_11ag_11m_2g4:18
[   27.259788] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11b_11ag_6m_2g4:18
[   27.268667] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11b_11ag_9m_2g4:18
[   27.277025] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11b_11ag_12m_2g4:18
[   27.286033] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11b_11ag_18m_2g4:18
[   27.294974] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11b_11ag_24m_2g4:16
[   27.304009] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11b_11ag_36m_2g4:16
[   27.313037] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11b_11ag_48m_2g4:15
[   27.321476] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11b_11ag_54m_2g4:15
[   27.329940] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs0_2g4:18
[   27.338537] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs1_2g4:18
[   27.347120] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs2_2g4:18
[   27.355688] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs3_2g4:18
[   27.364254] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs4_2g4:16
[   27.372935] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs5_2g4:16
[   27.381913] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs6_2g4:15
[   27.391336] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs7_2g4:15
[   27.399957] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs8_2g4:14
[   27.409037] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs9_2g4:14
[   27.418246] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs0_2g4:18
[   27.432537] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs1_2g4:18
[   27.441027] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs2_2g4:18
[   27.449928] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs3_2g4:18
[   27.458621] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs4_2g4:16
[   27.468676] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs5_2g4:16
[   27.480474] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs6_2g4:15
[   27.488836] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs7_2g4:15
[   27.497722] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs8_2g4:14
[   27.506475] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs9_2g4:14
[   27.515088] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs10_2g4:13
[   27.524112] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs11_2g4:13
[   27.534372] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11a_1m_5g:-128
[   27.542857] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11a_2m_5g:-128
[   27.551450] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11a_5m5_5g:-128
[   27.559590] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11a_11m_5g:-128
[   27.569035] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11a_6m_5g:18
[   27.576980] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11a_9m_5g:18
[   27.588499] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11a_12m_5g:18
[   27.596894] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11a_18m_5g:18
[   27.605860] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11a_24m_5g:16
[   27.617934] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11a_36m_5g:16
[   27.631156] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11a_48m_5g:15
[   27.639608] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11a_54m_5g:15
[   27.647935] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs0_5g:18
[   27.656359] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs1_5g:18
[   27.665382] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs2_5g:18
[   27.674509] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs3_5g:18
[   27.683530] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs4_5g:16
[   27.692056] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs5_5g:16
[   27.701079] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs6_5g:15
[   27.709519] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs7_5g:15
[   27.718406] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs8_5g:14
[   27.726847] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11n_11ac_mcs9_5g:14
[   27.735655] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs0_5g:18
[   27.743715] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs1_5g:18
[   27.752478] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs2_5g:18
[   27.760560] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs3_5g:18
[   27.769230] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs4_5g:16
[   27.777311] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs5_5g:16
[   27.785359] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs6_5g:14
[   27.794336] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs7_5g:14
[   27.815144] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs8_5g:13
[   27.823406] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs9_5g:13
[   27.831709] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs10_5g:12
[   27.840035] AICWFDBG(LOGINFO)        rwnx_send_txpwr_lvl_v3_req:lvl_11ax_mcs11_5g:12
[   27.848582] AICWFDBG(LOGTRACE)       rwnx_send_msg (120)MM_SET_TXPWR_IDX_LVL_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   27.861160] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   27.870669] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x78
[   27.877440] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   27.892890] AICWFDBG(LOGTRACE)       >>> rwnx_send_txpwr_lvl_adj_req()
[   27.914340] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_adj_in_fdrv:enable:0
[   27.922786] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_adj_in_fdrv:lvl_adj_2g4_chan_1_4:0
[   27.934483] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_adj_in_fdrv:lvl_adj_2g4_chan_5_9:0
[   27.944282] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_adj_in_fdrv:lvl_adj_2g4_chan_10_13:0
[   27.956352] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_adj_in_fdrv:lvl_adj_5g_chan_42:0
[   27.967430] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_adj_in_fdrv:lvl_adj_5g_chan_58:0
[   27.977049] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_adj_in_fdrv:lvl_adj_5g_chan_106:0
[   28.013963] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_adj_in_fdrv:lvl_adj_5g_chan_122:0
[   28.028935] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_adj_in_fdrv:lvl_adj_5g_chan_138:0
[   28.038452] AICWFDBG(LOGINFO)        get_userconfig_txpwr_lvl_adj_in_fdrv:lvl_adj_5g_chan_155:0
[   28.048426] AICWFDBG(LOGTRACE)       >>> rwnx_msg_free()
[   28.057273] AICWFDBG(LOGTRACE)       >>> rwnx_send_txpwr_ofst2x_req()
[   28.063939] AICWFDBG(LOGINFO)        get_userconfig_txpwr_ofst2x_in_fdrv:enable      :0
[   28.089546] AICWFDBG(LOGINFO)        pwrofst2x 2.4g: [0]:11b, [1]:ofdm_highrate, [2]:ofdm_lowrate
  chan= 1-4     5-9     10-13AICWFDBG(LOGINFO)
  [0] =AICWFDBG(LOGINFO)                0AICWFDBG(LOGINFO)              0AICWFDBG(LOGINFO)              0AICWFDBG(LOGINFO)
  [1] =AICWFDBG(LOGINFO)                0AICWFDBG(LOGINFO)              0AICWFDBG(LOGINFO)              0AICWFDBG(LOGINFO)
  [2] =AICWFDBG(LOGINFO)                0AICWFDBG(LOGINFO)              0AICWFDBG(LOGINFO)              0AICWFDBG(LOGINFO)
pwrofst2x 5g: [0]:ofdm_lowrate, [1]:ofdm_highrate, [2]:ofdm_midrate
  chan= 36-50   51-64   98-114  115-130 131-146 147-166AICWFDBG(LOGINFO)
  [0] =AICWFDBG(LOGINFO)                0AICWFDBG(LOGINFO)              0AICWFDBG(LOGINFO)              0AICWFDBG(LOGINFO)              0AICWFDBG(LOGINFO)              0AICWFDBG(LOGINFO)        0AICWFDBG(LOGINFO)
  [1] =AICWFDBG(LOGINFO)                0AICWFDBG(LOGINFO)              0AICWFDBG(LOGINFO)              0AICWFDBG(LOGINFO)              0AICWFDBG(LOGINFO)              0AICWFDBG(LOGINFO)        0AICWFDBG(LOGINFO)
  [2] =AICWFDBG(LOGINFO)                0AICWFDBG(LOGINFO)              0AICWFDBG(LOGINFO)              0AICWFDBG(LOGINFO)              0AICWFDBG(LOGINFO)              0AICWFDBG(LOGINFO)        0AICWFDBG(LOGINFO)
[   28.195388] AICWFDBG(LOGINFO)        rwnx_send_txpwr_ofst2x_req:Do not use txpwr_ofst2x
[   28.204254] AICWFDBG(LOGTRACE)       >>> rwnx_msg_free()
[   28.209705] AICWFDBG(LOGTRACE)       >>> rwnx_send_rf_calib_req()
[   28.216214] AICWFDBG(LOGINFO)        get_userconfig_xtal_cap:enable       :0
[   28.223595] AICWFDBG(LOGINFO)        get_userconfig_xtal_cap:xtal_cap     :0
[   28.230968] AICWFDBG(LOGINFO)        get_userconfig_xtal_cap:xtal_cap_fine:0
[   28.238289] AICWFDBG(LOGTRACE)       rwnx_send_msg (106)MM_SET_RF_CALIB_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   28.249880] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   28.416672] BOOTEVENT:     28416.656140: OFF
[   29.047710] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x6a
[   29.054587] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   29.062952] AICWFDBG(LOGTRACE)       >>> rwnx_send_get_macaddr_req()
[   29.070349] AICWFDBG(LOGTRACE)       rwnx_send_msg (116)MM_GET_MAC_ADDR_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   29.083528] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   29.093940] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x74
[   29.102272] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   29.114245] AICWFDBG(LOGINFO)        get macaddr: 40:9c:a7:38:78:54
[   29.121520] AICWFDBG(LOGTRACE)       >>> rwnx_send_reset()
[   29.127238] AICWFDBG(LOGTRACE)       rwnx_send_msg (1)MM_RESET_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   29.138165] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   29.147666] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1
[   29.154510] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   29.162541] AICWFDBG(LOGTRACE)       >>> rwnx_send_version_req()
[   29.168870] AICWFDBG(LOGTRACE)       rwnx_send_msg (5)MM_VERSION_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   29.180147] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   29.189087] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x5
[   29.195847] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   29.203917] AICWFDBG(LOGTRACE)       >>> rwnx_set_vers()
[   29.209309] AICWFDBG(LOGTRACE)       >>> rwnx_send_me_config_req()
[   29.215710] ieee80211 phy0: HT supp 1, VHT supp 1, HE supp 0
[   29.222050] AICWFDBG(LOGTRACE)       rwnx_send_msg (5121)ME_CONFIG_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   29.233076] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   29.241936] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1401
[   29.248930] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   29.257601] AICWFDBG(LOGTRACE)       >>> rwnx_send_me_chan_config_req()
[   29.264479] AICWFDBG(LOGTRACE)       rwnx_send_msg (5123)ME_CHAN_CONFIG_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   29.280709] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   29.289827] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1403
[   29.296909] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   29.305842] AICWFDBG(LOGINFO)        getRegdomainFromRwnxDB set ccode:00
[   29.314369] AICWFDBG(LOGINFO)        rwnx_get_countrycode_channels support channel:1 2 3 4 5 6 7 8 9 10 11 12 13 14 36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140 144 149 153 157 161 165
[   29.334724] ieee80211 phy0:
[   29.334724] *******************************************************
[   29.334724] ** CAUTION: USING PERMISSIVE CUSTOM REGULATORY RULES **
[   29.358992] AICWFDBG(LOGTRACE)       >>> rwnx_send_me_chan_config_req()
[   29.366015] AICWFDBG(LOGTRACE)       rwnx_send_msg (5123)ME_CHAN_CONFIG_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   29.377569] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   29.386757] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1403
[   29.393983] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   29.401981] AICWFDBG(LOGTRACE)       >>> rwnx_dbgfs_register()
[   29.408710] AICWFDBG(LOGINFO)        rwnx_interface_add: wlan%d, 2, 10
[   29.415649] AICWFDBG(LOGINFO)        interface add:40 9c a7 38 78 54
[   29.477736] get_txpwr_max:txpwr_max:18
[   29.484661] AICWFDBG(LOGINFO)        New interface create wlan0
[   29.491859] snddaudio snddaudio0: codec: snd-soc-dummy, codec_dai: snd-soc-dummy-dai.
[   29.502313] snddaudio snddaudio0: ASoC: CPU DAI (null) not registered
[   29.510906] snddaudio snddaudio0: snd_soc_register_card failed
[   29.698780] capability: warning: `wpa_supplicant' uses 32-bit capabilities (legacy support in use)
[   29.762485] apexd: Can't open /product/apex for reading : No such file or directory
[   29.765872] AICWFDBG(LOGTRACE)       >>> rwnx_open()
[   29.765877] AICWFDBG(LOGTRACE)       >>> rwnx_send_start()
[   29.765883] AICWFDBG(LOGTRACE)       rwnx_send_msg (3)MM_START_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   29.765893] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   29.771744] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x3
[   29.771779] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   29.771785] AICWFDBG(LOGTRACE)       >>> rwnx_send_coex_req()
[   29.771791] AICWFDBG(LOGTRACE)       rwnx_send_msg (102)MM_SET_COEX_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   29.771796] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   29.772026] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x66
[   29.773007] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   29.773015] AICWFDBG(LOGDEBUG)       rwnx_open rwnx_vif->drv_flags:4
[   29.773018] AICWFDBG(LOGTRACE)       >>> rwnx_send_add_if()
[   29.773023] AICWFDBG(LOGTRACE)       rwnx_send_msg (7)MM_ADD_IF_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   29.773031] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   29.783704] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x7
[   29.783907] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   29.783913] AICWFDBG(LOGDEBUG)       rwnx_open sta create vif in rwnx_hw->vif_table[0]
[   29.860772] get_txpwr_max:txpwr_max:18
[   29.960084] get_txpwr_max:txpwr_max:18
[   29.965353] get_txpwr_max:txpwr_max:18
[   29.972112] get_txpwr_max:txpwr_max:18
[   29.977145] get_txpwr_max:txpwr_max:18
[   29.985292] get_txpwr_max:txpwr_max:18
[   30.054573] rwnx_virtual_interface_add: 10, p2p-dev-wlan0
[   30.060639] rwnx_virtual_interface_add, ifname=p2p-dev-wlan0, wdev=ffffffc04eabe018, vif_idx=1
[   30.070623] p2p dev addr=40 9c a7 38 78 55
[   30.075501] get_txpwr_max:txpwr_max:18
[   30.080156] get_txpwr_max:txpwr_max:18
[   30.091680] get_txpwr_max:txpwr_max:18
[   30.107030] get_txpwr_max:txpwr_max:18
[   30.125679] get_txpwr_max:txpwr_max:18
[   30.176831] get_txpwr_max:txpwr_max:18
[   30.193734] get_txpwr_max:txpwr_max:18
[   30.204523] get_txpwr_max:txpwr_max:18
[   30.213634] P2P interface started
[   30.381214] AICWFDBG(LOGINFO)        IOCTL PRIVATE
[   30.393944] AICWFDBG(LOGTRACE)       >>> android_priv_cmd()
[   30.403707] AICWFDBG(LOGINFO)        android_priv_cmd: Android private cmd "BTCOEXSCAN-STOP" on wlan0
[   30.413793] AICWFDBG(LOGINFO)        cmd = 35313
[   30.420948] AICWFDBG(LOGINFO)        buf_size=4096
[   30.427579] AICWFDBG(LOGTRACE)       >>> handle_private_cmd()
[   30.437580] AICWFDBG(LOGERROR)       Unknown command 'BTCOEXSCAN-STOP'
[   30.455676] AICWFDBG(LOGINFO)        IOCTL PRIVATE
[   30.460476] AICWFDBG(LOGTRACE)       >>> android_priv_cmd()
[   30.466252] AICWFDBG(LOGINFO)        android_priv_cmd: Android private cmd "RXFILTER-STOP" on wlan0
[   30.475808] AICWFDBG(LOGINFO)        cmd = 35313
[   30.480437] AICWFDBG(LOGINFO)        buf_size=4096
[   30.485160] AICWFDBG(LOGTRACE)       >>> handle_private_cmd()
[   30.491077] AICWFDBG(LOGERROR)       Unknown command 'RXFILTER-STOP'
[   30.498891] AICWFDBG(LOGINFO)        IOCTL PRIVATE
[   30.503682] AICWFDBG(LOGTRACE)       >>> android_priv_cmd()
[   30.509420] AICWFDBG(LOGINFO)        android_priv_cmd: Android private cmd "RXFILTER-ADD 2" on wlan0
[   30.519017] AICWFDBG(LOGINFO)        cmd = 35313
[   30.523537] AICWFDBG(LOGINFO)        buf_size=4096
[   30.528316] AICWFDBG(LOGTRACE)       >>> handle_private_cmd()
[   30.534236] AICWFDBG(LOGERROR)       Unknown command 'RXFILTER-ADD'
[   30.542439] AICWFDBG(LOGINFO)        IOCTL PRIVATE
[   30.547191] AICWFDBG(LOGTRACE)       >>> android_priv_cmd()
[   30.553762] AICWFDBG(LOGINFO)        android_priv_cmd: Android private cmd "RXFILTER-START" on wlan0
[   30.563846] AICWFDBG(LOGINFO)        cmd = 35313
[   30.568415] AICWFDBG(LOGINFO)        buf_size=4096
[   30.574652] AICWFDBG(LOGTRACE)       >>> handle_private_cmd()
[   30.580619] AICWFDBG(LOGERROR)       Unknown command 'RXFILTER-START'
[   30.589249] AICWFDBG(LOGINFO)        IOCTL PRIVATE
[   30.594213] AICWFDBG(LOGTRACE)       >>> android_priv_cmd()
[   30.600106] AICWFDBG(LOGINFO)        android_priv_cmd: Android private cmd "RXFILTER-STOP" on wlan0
[   30.609681] AICWFDBG(LOGINFO)        cmd = 35313
[   30.614202] AICWFDBG(LOGINFO)        buf_size=4096
[   30.618921] AICWFDBG(LOGTRACE)       >>> handle_private_cmd()
[   30.624830] AICWFDBG(LOGERROR)       Unknown command 'RXFILTER-STOP'
[   30.632272] AICWFDBG(LOGINFO)        IOCTL PRIVATE
[   30.637069] AICWFDBG(LOGTRACE)       >>> android_priv_cmd()
[   30.642875] AICWFDBG(LOGINFO)        android_priv_cmd: Android private cmd "RXFILTER-ADD 3" on wlan0
[   30.654129] AICWFDBG(LOGINFO)        cmd = 35313
[   30.658857] AICWFDBG(LOGINFO)        buf_size=4096
[   30.663732] AICWFDBG(LOGTRACE)       >>> handle_private_cmd()
[   30.669671] AICWFDBG(LOGERROR)       Unknown command 'RXFILTER-ADD'
[   30.676833] AICWFDBG(LOGINFO)        IOCTL PRIVATE
[   30.681580] AICWFDBG(LOGTRACE)       >>> android_priv_cmd()
[   30.687285] AICWFDBG(LOGINFO)        android_priv_cmd: Android private cmd "RXFILTER-START" on wlan0
[   30.696846] AICWFDBG(LOGINFO)        cmd = 35313
[   30.701354] AICWFDBG(LOGINFO)        buf_size=4096
[   30.706075] AICWFDBG(LOGTRACE)       >>> handle_private_cmd()
[   30.711944] AICWFDBG(LOGERROR)       Unknown command 'RXFILTER-START'
[   30.719387] AICWFDBG(LOGINFO)        IOCTL PRIVATE
[   30.724109] AICWFDBG(LOGTRACE)       >>> android_priv_cmd()
[   30.729792] AICWFDBG(LOGINFO)        android_priv_cmd: Android private cmd "SETSUSPENDMODE 0" on wlan0
[   30.739519] AICWFDBG(LOGINFO)        cmd = 35313
[   30.744020] AICWFDBG(LOGINFO)        buf_size=4096
[   30.810959] type=1400 audit(1733305018.050:97): avc: denied { getattr } for comm="webview_zygote" path="/data/data/com.android.webview" dev="mmcblk0p17" ino=1068 scontext=u:r:webview_zygote:s0 tcontext=u:object_r:app_data_file:s0:c99,c256,c512,c768 tclass=dir permissive=1
[   30.815940] AICWFDBG(LOGTRACE)       >>> rwnx_cfg80211_scan()
[   30.815944] AICWFDBG(LOGTRACE)       >>> rwnx_send_scanu_req()
[   30.815953] AICWFDBG(LOGDEBUG)       scan channel:1(2412)
[   30.815955] AICWFDBG(LOGDEBUG)       scan channel:2(2417)
[   30.815957] AICWFDBG(LOGDEBUG)       scan channel:3(2422)
[   30.815959] AICWFDBG(LOGDEBUG)       scan channel:4(2427)
[   30.815961] AICWFDBG(LOGDEBUG)       scan channel:5(2432)
[   30.815963] AICWFDBG(LOGDEBUG)       scan channel:6(2437)
[   30.815965] AICWFDBG(LOGDEBUG)       scan channel:7(2442)
[   30.815967] AICWFDBG(LOGDEBUG)       scan channel:8(2447)
[   30.815969] AICWFDBG(LOGDEBUG)       scan channel:9(2452)
[   30.815971] AICWFDBG(LOGDEBUG)       scan channel:10(2457)
[   30.815973] AICWFDBG(LOGDEBUG)       scan channel:11(2462)
[   30.815975] AICWFDBG(LOGDEBUG)       scan channel:12(2467)
[   30.815977] AICWFDBG(LOGDEBUG)       scan channel:13(2472)
[   30.815979] AICWFDBG(LOGDEBUG)       scan channel:14(2484)
[   30.815981] AICWFDBG(LOGDEBUG)       scan channel:36(5180)
[   30.815983] AICWFDBG(LOGDEBUG)       scan channel:40(5200)
[   30.815985] AICWFDBG(LOGDEBUG)       scan channel:44(5220)
[   30.815987] AICWFDBG(LOGDEBUG)       scan channel:48(5240)
[   30.815989] AICWFDBG(LOGDEBUG)       scan channel:52(5260)
[   30.815991] AICWFDBG(LOGDEBUG)       scan channel:56(5280)
[   30.815993] AICWFDBG(LOGDEBUG)       scan channel:60(5300)
[   30.815994] AICWFDBG(LOGDEBUG)       scan channel:64(5320)
[   30.815996] AICWFDBG(LOGDEBUG)       scan channel:100(5500)
[   30.815998] AICWFDBG(LOGDEBUG)       scan channel:104(5520)
[   30.816000] AICWFDBG(LOGDEBUG)       scan channel:108(5540)
[   30.816002] AICWFDBG(LOGDEBUG)       scan channel:112(5560)
[   30.816004] AICWFDBG(LOGDEBUG)       scan channel:116(5580)
[   30.816006] AICWFDBG(LOGDEBUG)       scan channel:120(5600)
[   30.816008] AICWFDBG(LOGDEBUG)       scan channel:124(5620)
[   30.816010] AICWFDBG(LOGDEBUG)       scan channel:128(5640)
[   30.816012] AICWFDBG(LOGDEBUG)       scan channel:132(5660)
[   30.816014] AICWFDBG(LOGDEBUG)       scan channel:136(5680)
[   30.816016] AICWFDBG(LOGDEBUG)       scan channel:140(5700)
[   30.816018] AICWFDBG(LOGDEBUG)       scan channel:144(5720)
[   30.816020] AICWFDBG(LOGDEBUG)       scan channel:149(5745)
[   30.816022] AICWFDBG(LOGDEBUG)       scan channel:153(5765)
[   30.816024] AICWFDBG(LOGDEBUG)       scan channel:157(5785)
[   30.816026] AICWFDBG(LOGDEBUG)       scan channel:161(5805)
[   30.816028] AICWFDBG(LOGDEBUG)       scan channel:165(5825)
[   30.816033] AICWFDBG(LOGTRACE)       rwnx_send_msg (4105)SCANU_START_CFM_ADDTIONAL reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   30.816042] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   30.838446] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1009
[   30.838531] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   30.843375] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   30.847299] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   30.878051] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   30.886920] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   30.893457] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   30.918467] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   30.928463] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   30.941297] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   30.963489] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   30.998527] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.005728] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   31.033580] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.055484] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   31.092287] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.103309] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   31.127310] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.162338] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.197359] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.245882] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.252914] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   31.261140] type=1400 audit(1733305026.303:98): avc: granted { read } for comm="main" name="u:object_r:net_dns_prop:s0" dev="tmpfs" ino=421 scontext=u:r:untrusted_app_25:s0:c512,c768 tcontext=u:object_r:net_dns_prop:s0 tclass=file app=com.android.email
[   31.287380] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.322381] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.377409] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.412410] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.419186] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   31.426155] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   31.449237] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   31.456177] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   31.467402] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.502476] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.557464] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.592498] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.627584] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.662535] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.697527] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.732618] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.767575] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.802590] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.837633] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.872596] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.907674] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.942757] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   31.977680] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   32.012720] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   32.047701] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   32.082753] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   32.117744] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   32.152819] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   32.159589] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   32.166586] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   32.173624] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   32.180683] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   32.187703] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   32.194743] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   32.201733] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   32.242857] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   32.298043] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   32.353072] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   32.388214] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   32.395124] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1001
[   32.402167] AICWFDBG(LOGTRACE)       >>> rwnx_rx_scanu_start_cfm()
[   32.476541] AICWFDBG(LOGTRACE)       >>> rwnx_cfg80211_remain_on_channel_()
[   32.483857] remain:0,0,0
[   32.486737] AICWFDBG(LOGTRACE)       >>> rwnx_send_roc()
[   32.492191] AICWFDBG(LOGTRACE)       rwnx_send_msg (71)MM_REMAIN_ON_CHANNEL_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   32.504110] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   32.513839] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x47
[   32.520611] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x44
[   32.520619] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   32.535671] AICWFDBG(LOGDEBUG)       mgmt xmit d0 0 AICWFDBG(LOGINFO)        need cfm mgmt:d0,user_idx=1, skb=ffffffc04f74ae00
[   32.549673] AICWFDBG(LOGINFO)        sdio_host_tx_cfm_handler:used_idx=0, 0xffffffc040a00700, status=9
[   32.559527] done=1 retry_required=0 sw_retry_required=0 acknowledged=1
[   32.567112] AICWFDBG(LOGTRACE)       >>> rwnx_close()
[   32.572222] aicwf_sdio mmc2:390b:1 wlan0: CLOSE
[   32.577302] rwnx_close clear roc
[   32.580936] AICWFDBG(LOGDEBUG)       rwnx_close rwnx_vif[0] down
[   32.588378] AICWFDBG(LOGTRACE)       >>> rwnx_send_remove_if()
[   32.594466] rwnx_send_msg1 (9)MM_REMOVE_IF_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   32.603859] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   32.612672] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x9
[   32.619371] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   32.627292] AICWFDBG(LOGTRACE)       >>> rwnx_send_coex_req()
[   32.633139] AICWFDBG(LOGTRACE)       rwnx_send_msg (102)MM_SET_COEX_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   32.644248] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   32.653039] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x66
[   32.659778] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   32.667665] AICWFDBG(LOGTRACE)       >>> rwnx_send_reset()
[   32.673324] AICWFDBG(LOGTRACE)       rwnx_send_msg (1)MM_RESET_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   32.684109] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   32.693359] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1
[   32.699998] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   32.707893] AICWFDBG(LOGTRACE)       >>> rwnx_send_me_config_req()
[   32.714214] ieee80211 phy0: HT supp 1, VHT supp 1, HE supp 0
[   32.720544] AICWFDBG(LOGTRACE)       rwnx_send_msg (5121)ME_CONFIG_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   32.731511] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   32.740828] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1401
[   32.747799] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   32.755828] AICWFDBG(LOGTRACE)       >>> rwnx_send_me_chan_config_req()
[   32.762696] AICWFDBG(LOGTRACE)       rwnx_send_msg (5123)ME_CHAN_CONFIG_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   32.774176] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   32.783193] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1403
[   32.790152] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   32.798079] AICWFDBG(LOGDEBUG)       rwnx_close rwnx_vif->drv_flags:0
[   32.805221] AICWFDBG(LOGTRACE)       rwnx_set_mac_address enter
[   32.811585] AICWFDBG(LOGINFO)        rwnx_set_mac_address set D6:EB:B7:0D:F8:AF
[   32.819502] AICWFDBG(LOGTRACE)       >>> rwnx_open()
[   32.824511] AICWFDBG(LOGTRACE)       >>> rwnx_send_start()
[   32.830075] AICWFDBG(LOGTRACE)       rwnx_send_msg (3)MM_START_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   32.840666] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   32.850324] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x3
[   32.856983] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   32.864868] AICWFDBG(LOGTRACE)       >>> rwnx_send_coex_req()
[   32.870697] AICWFDBG(LOGTRACE)       rwnx_send_msg (102)MM_SET_COEX_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   32.881764] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   32.891321] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x66
[   32.898075] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   32.906037] AICWFDBG(LOGDEBUG)       rwnx_open rwnx_vif->drv_flags:4
[   32.912745] AICWFDBG(LOGTRACE)       >>> rwnx_send_add_if()
[   32.918441] AICWFDBG(LOGTRACE)       rwnx_send_msg (7)MM_ADD_IF_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   32.929166] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   32.938293] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x7
[   32.945032] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   32.952993] AICWFDBG(LOGDEBUG)       rwnx_open sta create vif in rwnx_hw->vif_table[0]
[   32.965288] AICWFDBG(LOGTRACE)       >>> rwnx_cfg80211_cancel_remain_on_channel()
[   33.108440] AICWFDBG(LOGTRACE)       >>> rwnx_cfg80211_scan()
[   33.114369] AICWFDBG(LOGTRACE)       >>> rwnx_send_scanu_req()
[   33.120376] AICWFDBG(LOGTRACE)       rwnx_send_msg (4104)SCANU_VENDOR_IE_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   33.132102] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   33.141537] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1008
[   33.148527] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   33.156472] AICWFDBG(LOGDEBUG)       scan channel:1(2412)
[   33.162146] AICWFDBG(LOGDEBUG)       scan channel:2(2417)
[   33.167829] AICWFDBG(LOGDEBUG)       scan channel:3(2422)
[   33.173503] AICWFDBG(LOGDEBUG)       scan channel:4(2427)
[   33.179199] AICWFDBG(LOGDEBUG)       scan channel:5(2432)
[   33.184889] AICWFDBG(LOGDEBUG)       scan channel:6(2437)
[   33.190591] AICWFDBG(LOGDEBUG)       scan channel:7(2442)
[   33.196289] AICWFDBG(LOGDEBUG)       scan channel:8(2447)
[   33.202066] AICWFDBG(LOGDEBUG)       scan channel:9(2452)
[   33.207768] AICWFDBG(LOGDEBUG)       scan channel:10(2457)
[   33.213572] AICWFDBG(LOGDEBUG)       scan channel:11(2462)
[   33.219376] AICWFDBG(LOGDEBUG)       scan channel:12(2467)
[   33.225171] AICWFDBG(LOGDEBUG)       scan channel:13(2472)
[   33.230963] AICWFDBG(LOGDEBUG)       scan channel:14(2484)
[   33.236761] AICWFDBG(LOGDEBUG)       scan channel:36(5180)
[   33.242553] AICWFDBG(LOGDEBUG)       scan channel:40(5200)
[   33.248358] AICWFDBG(LOGDEBUG)       scan channel:44(5220)
[   33.254133] AICWFDBG(LOGDEBUG)       scan channel:48(5240)
[   33.259998] AICWFDBG(LOGDEBUG)       scan channel:52(5260)
[   33.265754] AICWFDBG(LOGDEBUG)       scan channel:56(5280)
[   33.271504] AICWFDBG(LOGDEBUG)       scan channel:60(5300)
[   33.277290] AICWFDBG(LOGDEBUG)       scan channel:64(5320)
[   33.283184] AICWFDBG(LOGDEBUG)       scan channel:100(5500)
[   33.289079] AICWFDBG(LOGDEBUG)       scan channel:104(5520)
[   33.294994] AICWFDBG(LOGDEBUG)       scan channel:108(5540)
[   33.300980] AICWFDBG(LOGDEBUG)       scan channel:112(5560)
[   33.306906] AICWFDBG(LOGDEBUG)       scan channel:116(5580)
[   33.312805] AICWFDBG(LOGDEBUG)       scan channel:120(5600)
[   33.318799] AICWFDBG(LOGDEBUG)       scan channel:124(5620)
[   33.324718] AICWFDBG(LOGDEBUG)       scan channel:128(5640)
[   33.330899] AICWFDBG(LOGDEBUG)       scan channel:132(5660)
[   33.336816] AICWFDBG(LOGDEBUG)       scan channel:136(5680)
[   33.342698] AICWFDBG(LOGDEBUG)       scan channel:140(5700)
[   33.348557] AICWFDBG(LOGDEBUG)       scan channel:144(5720)
[   33.354574] AICWFDBG(LOGDEBUG)       scan channel:149(5745)
[   33.360681] AICWFDBG(LOGDEBUG)       scan channel:153(5765)
[   33.366767] AICWFDBG(LOGDEBUG)       scan channel:157(5785)
[   33.372995] AICWFDBG(LOGDEBUG)       scan channel:161(5805)
[   33.379527] AICWFDBG(LOGDEBUG)       scan channel:165(5825)
[   33.385512] AICWFDBG(LOGTRACE)       rwnx_send_msg (4105)SCANU_START_CFM_ADDTIONAL reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   33.398260] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   33.407059] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1009
[   33.414006] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   33.414007] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   33.414025] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   33.435943] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   33.453571] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   33.462133] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   33.478574] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   33.497297] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   33.532341] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   33.567486] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   33.602570] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   33.614390] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   33.657477] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   33.664220] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   33.673475] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   33.692495] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   33.727669] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   33.763065] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   33.797645] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   33.808600] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   33.853002] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   33.888125] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   33.942616] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   33.977874] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   33.984752] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   33.991815] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   34.009628] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   34.016689] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   34.032838] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.067780] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.123200] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.158103] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.192902] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.227920] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.262637] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.297559] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.332551] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.367608] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.402542] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.437812] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.472874] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.508409] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.543441] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.578177] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.613047] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.648255] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.683522] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.718581] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.725455] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   34.732522] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   34.739585] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   34.753093] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.808504] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.815395] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   34.863609] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.918588] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.952925] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   34.959719] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1001
[   34.966666] AICWFDBG(LOGTRACE)       >>> rwnx_rx_scanu_start_cfm()
[   34.980946] AICWFDBG(LOGTRACE)       >>> rwnx_cfg80211_connect()
[   34.987167] AICWFDBG(LOGTRACE)       >>> rwnx_send_sm_connect_req()
[   34.993657] rwnx_send_sm_connect_req drv_vif_index:0 connect to whycan(6) channel:2412 auth_type:0
[   35.003933] AICWFDBG(LOGTRACE)       rwnx_send_msg (6145)SM_CONNECT_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   35.015105] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   35.024493] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1801
[   35.031513] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   35.039677] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x4f
[   35.046454] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1004
[   35.329686] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x44
[   35.372385] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1802
[   35.379462] AICWFDBG(LOGTRACE)       >>> rwnx_rx_sm_connect_ind()
[   35.385814] AICWFDBG(LOGINFO)        rwnx_rx_sm_connect_ind ind->status_code:0
[   35.393541] AICWFDBG(LOGINFO)        rwnx_rx_sm_connect_ind ind->roamed:0 ind->status_code:0 rwnx_vif->drv_conn_state:2
[   35.405203] AICWFDBG(LOGINFO)        rwnx_rx_sm_connect_ind cfg80211_connect_result pass, rwnx_vif->drv_conn_state:3
[   35.419611] AICWFDBG(LOGINFO)        need cfm ethertype:    8e88,user_idx=2, skb=ffffffc04f201800
[   35.434120] AICWFDBG(LOGINFO)        sdio_host_tx_cfm_handler:used_idx=1, 0xffffffc040a00700, status=9
[   35.444933] AICWFDBG(LOGINFO)        need cfm ethertype:    8e88,user_idx=3, skb=ffffffc04f201800
[   35.455028] AICWFDBG(LOGTRACE)       >>> rwnx_cfg80211_add_key()
[   35.461324] AICWFDBG(LOGTRACE)       >>> rwnx_send_key_add()
[   35.467383] AICWFDBG(LOGTRACE)       rwnx_send_key_add: sta_idx:0 key_idx:0 inst_nbr:0 cipher:2 key_len:16
[   35.467506] AICWFDBG(LOGINFO)        sdio_host_tx_cfm_handler:used_idx=2, 0xffffffc040a00700, status=9
[   35.487821] key: 00000000: 7d 49 82 46 49 7c f4 45 c9 1e 00 dd 1a b7 c3 0b  }I.FI|.E........
[   35.497411] AICWFDBG(LOGTRACE)       rwnx_send_msg (37)MM_KEY_ADD_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   35.508729] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   35.518256] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x25
[   35.525096] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   35.533588] AICWFDBG(LOGTRACE)       >>> rwnx_cfg80211_set_default_key()
[   35.541929] AICWFDBG(LOGTRACE)       >>> rwnx_cfg80211_add_key()
[   35.548157] AICWFDBG(LOGTRACE)       >>> rwnx_send_key_add()
[   35.553998] AICWFDBG(LOGTRACE)       rwnx_send_key_add: sta_idx:255 key_idx:2 inst_nbr:0 cipher:2 key_len:16
[   35.564778] key: 00000000: b2 63 27 8f ce 76 e0 30 7d 0e 24 cd 8e 85 bc a5  .c'..v.0}.$.....
[   35.574526] AICWFDBG(LOGTRACE)       rwnx_send_msg (37)MM_KEY_ADD_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   35.585743] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   35.595344] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x25
[   35.602150] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   35.610888] AICWFDBG(LOGTRACE)       >>> rwnx_cfg80211_add_key()
[   35.617106] AICWFDBG(LOGTRACE)       >>> rwnx_send_key_add()
[   35.622915] AICWFDBG(LOGTRACE)       rwnx_send_key_add: sta_idx:255 key_idx:5 inst_nbr:0 cipher:5 key_len:16
[   35.633496] key: 00000000: 9a 61 64 f0 f3 06 8f 29 d5 c2 76 6a d2 0a 16 f7  .ad....)..vj....
[   35.643082] AICWFDBG(LOGTRACE)       rwnx_send_msg (37)MM_KEY_ADD_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   35.654135] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   35.664183] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x25
[   35.671131] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   35.680273] AICWFDBG(LOGTRACE)       >>> rwnx_send_me_set_control_port_req()
[   35.687728] AICWFDBG(LOGTRACE)       rwnx_send_msg (5125)ME_SET_CONTROL_PORT_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   35.699869] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   35.708953] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x1405
[   35.716058] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   35.773727] AICWFDBG(LOGINFO)        IOCTL PRIVATE
[   35.778507] AICWFDBG(LOGTRACE)       >>> android_priv_cmd()
[   35.784182] AICWFDBG(LOGINFO)        android_priv_cmd: Android private cmd "BTCOEXMODE 2" on wlan0
[   35.793511] AICWFDBG(LOGINFO)        cmd = 35313
[   35.797995] AICWFDBG(LOGINFO)        buf_size=4096
[   35.802667] AICWFDBG(LOGTRACE)       >>> handle_private_cmd()
[   35.808504] AICWFDBG(LOGERROR)       Unknown command 'BTCOEXMODE'
[   35.837463] AICWFDBG(LOGTRACE)       rwnx_send_msg (118)MM_GET_STA_INFO_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   35.849078] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   35.857910] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x76
[   35.864700] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   35.872647] AICWFDBG(LOGDEBUG)       rwnx_fill_station_info ModTx(0):4 TxIndex:8 ModRx(0):0 RxHTIndex:0 RxVHTIndex:0 RxHEIndex:0 RSSI:-28
[   35.937946] nf_conntrack: default automatic helper assignment has been turned off for security reasons and CT-based  firewall rule not found. Use the iptables CT target to attach helpers instead.
[   35.944651] AICWFDBG(LOGINFO)        IOCTL PRIVATE
[   35.944658] AICWFDBG(LOGTRACE)       >>> android_priv_cmd()
[   35.944671] AICWFDBG(LOGINFO)        android_priv_cmd: Android private cmd "BTCOEXMODE 1" on wlan0
[   35.944678] AICWFDBG(LOGINFO)        cmd = 35313
[   35.944681] AICWFDBG(LOGINFO)        buf_size=4096
[   35.944686] AICWFDBG(LOGTRACE)       >>> handle_private_cmd()
[   35.944694] AICWFDBG(LOGERROR)       Unknown command 'BTCOEXMODE'
[   35.945337] AICWFDBG(LOGINFO)        IOCTL PRIVATE
[   35.945343] AICWFDBG(LOGTRACE)       >>> android_priv_cmd()
[   35.945353] AICWFDBG(LOGINFO)        android_priv_cmd: Android private cmd "SETSUSPENDMODE 0" on wlan0
[   35.945359] AICWFDBG(LOGINFO)        cmd = 35313
[   35.945362] AICWFDBG(LOGINFO)        buf_size=4096
[   36.027834] AICWFDBG(LOGINFO)        reord_init_sta:d6:eb:b7:0d:f8:af
[   36.063935] AICWFDBG(LOGINFO)        paired=fac04, should=fac04
[   36.069892] AICWFDBG(LOGTRACE)       >>> rwnx_send_arpoffload_en_req()
[   36.076594] AICWFDBG(LOGTRACE)       rwnx_send_msg (98)MM_SET_ARPOFFLOAD_CFM reqcfm:1 in_irq:0 in_softirq:512 in_atomic:1
[   36.088321] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   36.096928] AICWFDBG(LOGTRACE)       >>> cmd_mgr_task_process()
[   36.103805] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x62
[   36.109414] AICWFDBG(LOGINFO)        IOCTL PRIVATE
[   36.109423] AICWFDBG(LOGTRACE)       >>> android_priv_cmd()
[   36.109444] AICWFDBG(LOGINFO)        android_priv_cmd: Android private cmd "BTCOEXMODE 2" on wlan0
[   36.109453] AICWFDBG(LOGINFO)        cmd = 35313
[   36.109458] AICWFDBG(LOGINFO)        buf_size=4096
[   36.109464] AICWFDBG(LOGTRACE)       >>> handle_private_cmd()
[   36.109475] AICWFDBG(LOGERROR)       Unknown command 'BTCOEXMODE'
[   36.151911] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   36.255434] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x140b
[   36.262424] AICWFDBG(LOGTRACE)       >>> rwnx_rx_me_tx_credits_update_ind()
[   36.315431] init: processing action (sys.sysctl.tcp_def_init_rwnd=*) from (/init.rc:810)
[   37.202384] type=1400 audit(1733305026.303:98): avc: granted { read } for comm="main" name="u:object_r:net_dns_prop:s0" dev="tmpfs" ino=421 scontext=u:r:untrusted_app_25:s0:c512,c768 tcontext=u:object_r:net_dns_prop:s0 tclass=file app=com.android.email
[   37.227511] type=1400 audit(1733305032.696:99): avc: denied { dac_override } for comm="irqbalance" capability=1 scontext=u:r:shell:s0 tcontext=u:r:shell:s0 tclass=capability permissive=1
[   38.909733] AICWFDBG(LOGTRACE)       rwnx_send_msg (118)MM_GET_STA_INFO_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   38.921392] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   38.930910] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x76
[   38.937876] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   38.945939] AICWFDBG(LOGDEBUG)       rwnx_fill_station_info ModTx(0):4 TxIndex:8 ModRx(0):0 RxHTIndex:0 RxVHTIndex:0 RxHEIndex:0 RSSI:-29
楼主 #2 2024-12-04 17:38:41
memory
已发帖子: 703
Re: A133 AW869C 蓝牙开启失败,请问是什么原因呢?
logcat 日志:
[   90.891162] logd: logdr: UID=0 GID=0 PID=4606 b tail=0 logMask=19 pid=0 start=0ns timeout=0ns
--------- beginning of main
12-04 17:37:54.388  2444  2664 E WifiVendorHal: getWifiLinkLayerStats_1_3_Internal(l.926) failed {.code = ERROR_NOT_AVAILABLE, .description = }
12-04 17:37:54.447  2765  2765 W StatusBarIconController: setIconVisibility index: 27
12-04 17:37:55.891  2125  2308 I netd    : trafficSwapActiveStatsMap() <18.41ms>
12-04 17:37:55.898  2125  2308 I netd    : tetherGetStats() <5.08ms>
12-04 17:37:55.925  2125  2308 I netd    : bandwidthSetGlobalAlert(2097152) <1.53ms>
12-04 17:37:56.396  2444  4583 I system_server: The ClassLoaderContext is a special shared library.
12-04 17:37:56.680  2444  4583 I chatty  : uid=1000 system_server identical 5 lines
12-04 17:37:56.690  2444  4583 I system_server: The ClassLoaderContext is a special shared library.
12-04 17:37:56.726  2444  4583 I BackgroundDexOptService: Pinning optimized code {}
12-04 17:37:57.450  2444  2664 E WifiVendorHal: getWifiLinkLayerStats_1_3_Internal(l.926) failed {.code = ERROR_NOT_AVAILABLE, .description = }
12-04 17:37:57.522  2765  2765 W StatusBarIconController: setIconVisibility index: 27
12-04 17:37:58.920  2444  2470 D WificondControl: Scan result ready event
12-04 17:37:58.961  3999  3999 I wpa_supplicant: wlan0: GAS-QUERY-START addr=dc:d8:7c:4c:10:3a dialog_token=6 freq=2437
12-04 17:37:58.963  2444  2664 D HS20    : ANQP initiated on dc:d8:7c:4c:10:3a
12-04 17:37:58.964  2444  2664 D PasspointManager: ANQP entry not found for: dc:d8:7c:4c:10:3a:<1613>
12-04 17:37:59.015  3999  3999 I wpa_supplicant: wlan0: GAS-QUERY-START addr=de:d8:7c:3c:10:3a dialog_token=7 freq=5180
12-04 17:37:59.016  2444  2664 D HS20    : ANQP initiated on de:d8:7c:3c:10:3a
12-04 17:37:59.017  2444  2664 D PasspointManager: ANQP entry not found for: de:d8:7c:3c:10:3a:<1613>
12-04 17:37:59.029  2444  2664 D ANQPRequestManager: Not allowed to send ANQP request to 242822356406330 for another 39 seconds
12-04 17:37:59.030  2444  2664 D PasspointManager: ANQP entry not found for: dc:d8:7c:4c:10:3a:<1613>
12-04 17:37:59.030  2444  2664 D ANQPRequestManager: Not allowed to send ANQP request to 245021378613306 for another 39 seconds
12-04 17:37:59.030  2444  2664 D PasspointManager: ANQP entry not found for: de:d8:7c:3c:10:3a:<1613>
12-04 17:37:59.817  3999  3999 I wpa_supplicant: wlan0: GAS-QUERY-DONE addr=dc:d8:7c:4c:10:3a dialog_token=6 freq=2437 status_code=0 result=TIMEOUT
12-04 17:37:59.817  3999  3999 I wpa_supplicant: wlan0: ANQP-QUERY-DONE addr=dc:d8:7c:4c:10:3a result=FAILURE
12-04 17:38:00.004  2765  2765 D KeyguardClockSwitch: Updating clock: 538
12-04 17:38:00.528  2444  2664 E WifiVendorHal: getWifiLinkLayerStats_1_3_Internal(l.926) failed {.code = ERROR_NOT_AVAILABLE, .description = }
12-04 17:38:00.672  3999  3999 I wpa_supplicant: wlan0: GAS-QUERY-DONE addr=de:d8:7c:3c:10:3a dialog_token=7 freq=5180 status_code=0 result=TIMEOUT
12-04 17:38:00.673  3999  3999 I wpa_supplicant: wlan0: ANQP-QUERY-DONE addr=de:d8:7c:3c:10:3a result=FAILURE
12-04 17:38:03.593  2444  2664 E WifiVendorH[   91.163172] AICWFDBG(LOGTRACE)   rwnx_send_msg (118)MM_GET_STA_INFO_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
al: getWifiLinkLayerStats_1_3_In[   91.177842] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
ternal(l.926) failed {.code = ER[   91.189652] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x76
ROR_NOT_AVAILABLE, .description [   91.198591] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
12-04 17:38:03.651  2765  2[   91.209258] AICWFDBG(LOGDEBUG)    rwnx_fill_station_info ModTx(0):4 TxIndex:8 ModRx(0):0 RxHTIndex:0 RxVHTIndex:0 RxHEIndex:0 RSSI:-32
12-04 17:38:06.657  2444  2664 E WifiVendorHal: getWifiLinkLayerStats_1_3_Internal(l.926) failed {.code = ERROR_NOT_AVAILABLE, .description = }
[   94.237181] AICWFDBG(LOGTRACE)       rwnx_send_msg (118)MM_GET_STA_INFO_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
[   94.248927] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
[   94.258344] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x76
[   94.265270] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
[   94.273339] AICWFDBG(LOGDEBUG)       rwnx_fill_station_info ModTx(0):4 TxIndex:8 ModRx(0):0 RxHTIndex:0 RxVHTIndex:0 RxHEIndex:0 RSSI:-31
12-04 17:38:09.731  2444  2664 E WifiVendorHal: getWifiLinkLayerStats_1_3_Internal(l.926) failed {.code = ERROR_NOT_AVAILABLE, .description = }
12-04 17:38:09.789  2765  2765 W StatusBarIconController: setIconVisibility index: 27
12-04 17:38:12.782  2444  2636 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 17:38:12.790  2444  2636 I[   97.303788] AICWFDBG(LOGTRACE)       rwnx_send_msg (118)MM_GET_STA_INFO_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
 chatty  : uid=1000(system) Inpu[   97.318662] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
tDispatcher identical 3 lines
1[   97.327833] AICWFDBG(LOGDEBUG)      rwnx_rx_handle_msg msg->id:0x76
2-04 17:38:12.794  2444  2636 V [   97.337082] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
InputDispatcher: Asynchronous in[   97.347727] AICWFDBG(LOGDEBUG)       rwnx_fill_station_info ModTx(0):4 TxIndex:8 ModRx(0):0 RxHTIndex:0 RxVHTIndex:0 RxHEIndex:0 RSSI:-31
12-04 17:38:12.797  2444  2664 E WifiVendorHal: getWifiLinkLayerStats_1_3_Internal(l.926) failed {.code = ERROR_NOT_AVAILABLE, .description = }
12-04 17:38:12.798  2444  2636 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 17:38:12.852  2444  2636 I chatty  : uid=1000(system) InputDispatcher identical 16 lines
12-04 17:38:12.860  2444  2636 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 17:38:12.863  2765  2765 W StatusBarIconController: setIconVisibility index: 27
12-04 17:38:12.865  2444  2636 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 17:38:13.967  2444  2636 I chatty  : uid=1000(system) InputDispatcher identical 3 lines
12-04 17:38:13.971  2444  2636 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 17:38:13.979  2444  4545 E TAG     : Exception = android.content.pm.PackageManager$NameNotFoundException: com.google.android.simappdialog.gts
12-04 17:38:13.979  2444  4545 E TAG     : Exception = android.content.pm.PackageManager$NameNotFoundException: android.net.cts
12-04 17:38:13.980  2444  2636 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 17:38:14.007  2444  2636 I chatty  : uid=1000(system) InputDispatcher identical 7 lines
12-04 17:38:14.009  2444  2636 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 17:38:14.011  2765  2765 D StatusBar: disable<e i a s b h r c s > disable2<q i n >
12-04 17:38:14.014  2444  2636 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 17:38:14.015  2765  2765 W StatusBarIconController: setIconVisibility index: 18
12-04 17:38:14.024  2444  2636 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 17:38:14.033  2444  2636 I chatty  : uid=1000(system) InputDispatcher identical 4 lines
12-04 17:38:14.037  2444  2636 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 17:38:14.038  3000  3000 I AwReadingModeTileService: onBind
12-04 17:38:14.047  2444  2636 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 17:38:14.074  2444  2636 I chatty  : uid=1000(system) InputDispatcher identical 6 lines
12-04 17:38:14.077  2444  2636 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 17:38:14.105  2765  2765 I ScreenshotTileService: onBind
12-04 17:38:14.110  2765  2765 I ScreenrecordTileService: onBind
12-04 17:38:14.219  3000  3000 I AwReadingModeTileService: onStartListening
12-04 17:38:14.227  3000  3000 I awdisplay: init service
12-04 17:38:14.244  3000  3000 I awdisplay: AWDisplay remoteVersion: 10000 clientVersion: 10000
12-04 17:38:14.330  2765  2765 I ScreenshotTileService: onStartListening
12-04 17:38:14.334  2765  2765 I ScreenrecordTileService: onStartListening
12-04 17:38:14.402  2124  2124 D Zygote  : Forked child process 4647
--------- beginning of system
12-04 17:38:14.407  2444  2497 I ActivityManager: app.processName = com.android.systemui:screenrecord
12-04 17:38:14.407  2444  2497 I ActivityManager: Start proc 4647:com.android.systemui:screenrecord/u0a87 for service {com.android.systemui/com.softwinner.screenrecord.TakeScreenrecordService}
12-04 17:38:14.408  4647  4647 I Zygote  : seccomp disabled by setenforce 0
12-04 17:38:14.473  4647  4647 I ui:screenrecor: The ClassLoaderContext is a special shared library.
12-04 17:38:14.914  2210  2287 D omx_venc: <__AwOmxVencFillThisBuffer:2082>: vencOutPort: fill_this_buffer 50 times
12-04 17:38:15.312  2444  2636 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 17:38:15.399  2210  4507 D omx_venc: <__AwOmxVencEmptyThisBuffer:2043>: vencInPort: , empty_this_buffer 50 times
12-04 17:38:15.407  2444  2636 V InputDispatcher: Asynchronous input event injection succeeded.
12-04 17:38:15.432  2444  4545 D BluetoothManagerService: enable(com.android.systemui):  mBluetooth =null mBinding = false mState = OFF
12-04 17:38:15.432  2444  2489 D BluetoothManagerService: MESSAGE_ENABLE(0): mBluetooth = null
12-04 17:38:15.432  2444  4545 D BluetoothManagerService: enable returning
12-04 17:38:15.444  2146  2263 W AudioFlinger: createTrack_l(): mismatch between requested flags (00000004) and output flags (00000002)
12-04 17:38:15.461  2146  2263 D AF::TrackHandle: OpPlayAudio: track:55 usage:13 not muted
12-04 17:38:15.465  2444  2694 W AudioTrack: createTrack_l(7143525): AUDIO_OUTPUT_FLAG_FAST denied by server; frameCount 0 -> 8994
12-04 17:38:15.473  2124  2124 D Zygote  : Forked child process 4688
12-04 17:38:15.476  2444  2497 I ActivityManager: app.processName = com.android.bluetooth
12-04 17:38:15.476  2444  2497 I ActivityManager: Start proc 4688:com.android.bluetooth/1002 for service {com.android.bluetooth/com.android.bluetooth.btservice.AdapterService}
12-04 17:38:15.482  4688  4688 I Zygote  : seccomp disabled by setenforce 0
12-04 17:38:15.549  4688  4688 I droid.bluetoot: The ClassLoaderContext is a special shared library.
12-04 17:38:15.567  2130  4714 D audio_hw_primary: start_output_stream
12-04 17:38:15.567  2130  4714 V audio_platform: disable backend pcm(direction:PCM_OUT)
12-04 17:38:15.567  2130  4714 D audio_route: Apply path: out-reset
12-04 17:38:15.570  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.570  2130  4714 D audio_route: Apply path: media-speaker
12-04 17:38:15.570  2130  4714 D audio_hw_primary: select device(out):pdev:OUT_DULSPK, path:media-speaker
12-04 17:38:15.571  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.572  2130  4714 D audio_hw_primary: +++++++++++++++ start_output_stream: pcm sample_rate: 48000,pcm fmt: 0x00000000,pcm channels: 2
12-04 17:38:15.572  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.608  2130  4714 I chatty  : uid=1041(audioserver) writer identical 1 line
12-04 17:38:15.619  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.622  4688  4688 D BluetoothOppFileProvider: Initialized
12-04 17:38:15.630  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.649  2146  2271 D AudioFlinger: mixer(0x79e922d800) throttle end: throttle time(11)
12-04 17:38:15.650  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.652  4688  4688 V AdapterServiceConfig: Adding HeadsetService
12-04 17:38:15.653  4688  4688 V AdapterServiceConfig: Adding A2dpService
12-04 17:38:15.653  4688  4688 V AdapterServiceConfig: Adding HidHostService
12-04 17:38:15.654  4688  4688 V AdapterServiceConfig: Adding PanService
12-04 17:38:15.654  4688  4688 V AdapterServiceConfig: Adding GattService
12-04 17:38:15.655  4688  4688 V AdapterServiceConfig: Adding BluetoothMapService
12-04 17:38:15.655  4688  4688 V AdapterServiceConfig: Adding AvrcpTargetService
12-04 17:38:15.655  4688  4688 V AdapterServiceConfig: Adding HidDeviceService
12-04 17:38:15.655  4688  4688 V AdapterServiceConfig: Adding BluetoothOppService
12-04 17:38:15.655  4688  4688 V AdapterServiceConfig: Adding BluetoothPbapService
12-04 17:38:15.671  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.693  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.700  4688  4688 I         : [1204/173815.700228:INFO:com_android_bluetooth_btservice_AdapterService.cpp(628)] hal_util_load_bt_library loaded HAL: btinterface=0x7c0a9e3440, handle=0xd5abacc6474cf439
12-04 17:38:15.701  4688  4688 D BluetoothAdapterService: onCreate()
12-04 17:38:15.709  4688  4688 D AdapterState: make() - Creating AdapterState
12-04 17:38:15.714  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.715  4688  4723 I AdapterState: OFF : entered
12-04 17:38:15.715  4688  4723 D AdapterProperties: Setting state to OFF
12-04 17:38:15.716  4688  4688 I bt_btif : init: start restricted = 0 ; single user = 0
12-04 17:38:15.716  4688  4688 D bt_osi_allocation_tracker: canary initialized
12-04 17:38:15.716  4688  4724 I         : [1204/173815.716866:INFO:message_loop_thread.cc(175)] Run: message loop starting for thread bt_stack_manager_thread
12-04 17:38:15.717  4688  4724 I bt_stack_manager: event_init_stack is initializing the stack
12-04 17:38:15.718  4688[  100.371638] AICWFDBG(LOGTRACE)       rwnx_send_msg (118)MM_GET_STA_INFO_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
  4724 I         : [1204/173815.[  100.385767] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
718303:INFO:btif_config.cc(647)][  100.397670] AICWFDBG(LOGDEBUG)       rwnx_rx_handle_msg msg->id:0x76
 hash_file: Disabled for multi-u[  100.406447] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
ser
12-04 17:38:15.718  4688  4[  100.417108] AICWFDBG(LOGDEBUG)    rwnx_fill_station_info ModTx(0):4 TxIndex:8 ModRx(0):0 RxHTIndex:0 RxVHTIndex:0 RxHEIndex:0 RSSI:-30
724 I         : [1204/173815.718452:INFO:btif_config.cc(675)] re[  100.437696] bluetooth_set_power: start_block=1
ad_checksum_file: Disabled for m[  100.443939] aicbsp: aicbsp_set_subsys, subsys: AIC_BLUETOOTH, state to: 0
ulti-user
12-04 17:38:15.718  4[  100.454125] aicbsp: aicbsp_set_subsys, power state no need to change, current: 1
688  4724 E bt_btif_config: Conf[  100.465203] bluetooth_set_power: end_block=1
ig is missing adapter section
1[  100.473932] bluetooth_set_power: start_block=0
2-04 17:38:15.718  4688  4724 W [  100.480556] aicbsp: aicbsp_set_subsys, subsys: AIC_BLUETOOTH, state to: 1
bt_btif_config: init unable to l[  100.490875] aicbsp: aicbsp_set_subsys, power state no need to change, current: 1
oad config file: /data/misc/blue[  100.501970] bluetooth_set_power: end_block=0
droid/bt_config.conf; using back[  100.511287] [BT_LPM] bluesleep_outgoing_data: tx was sleeping, wakeup it
up.
12-04 17:38:15.718  4688  4[  100.519800] [BT_LPM] hsuart_power: bsi->uport = NULL, has_lpm_enabled = 0
724 I         : [1204/173815.718778:INFO:btif_config.cc(647)] hash_file: Disabled for multi-user
12-04 17:38:15.718  4688  4724 I         : [1204/173815.718835:INFO:btif_config.cc(675)] read_checksum_file: Disabled for multi-user
12-04 17:38:15.718  4688  4724 E bt_btif_config: Config is missing adapter section
12-04 17:38:15.718  4688  4724 W bt_btif_config: init unable to load backup; attempting to transcode legacy file.
12-04 17:38:15.719  4688  4724 E bt_btif_config_transcode: btif_config_transcode unable to load XML file '/data/misc/bluedroid/bt_config.xml': 3
12-04 17:38:15.719  4688  4724 E bt_btif_config: init unable to transcode legacy file; creating empty config.
12-04 17:38:15.719  4688  4724 W         : [1204/173815.719178:WARNING:btif_config.cc(151)] read_or_set_metrics_salt: Failed to read metrics salt from config
12-04 17:38:15.719  4688  4724 I         : [1204/173815.719241:INFO:btif_config.cc(162)] read_or_set_metrics_salt: Metrics salt is not invalid, creating new one
12-04 17:38:15.720  4688  4724 E bt_osi_alarm: timer_create_internal unable to [  100.622537] type=1400 audit(1733305052.693:106): avc: denied { dac_override } for comm="irqbalance" capability=1 scontext=u:r:shell:s0 tcontext=u:r:shell:s0 tclass=capability permissive=1
create timer with clock 9: Unknown error 524
12-04 17:38:15.720  4688  4724 E bt_osi_alarm: The[  100.628621] logd: logdr: UID=1002 GID=1002 PID=4765 n tail=50 logMask=8 pid=2131 start=0ns timeout=0ns
 kernel might not have support f[  100.629830] logd: logdr: UID=1002 GID=1002 PID=4765 n tail=50 logMask=1 pid=2131 start=0ns timeout=0ns
or timer_create(CLOCK_BOOTTIME_ALARM): https://lwn.net/Articles/[  100.649992] logd: logdr: UID=1002 GID=1002 PID=4765 n tail=0 logMask=8 pid=2131 start=0ns timeout=0ns
429925/
12-04 17:38:15.720  468[  100.651862] logd: logdr: UID=1002 GID=1002 PID=4765 n tail=0 logMask=1 pid=2131 start=0ns timeout=0ns
8  4724 E bt_osi_alarm: See foll[  100.658544] init: Untracked pid 4765 exited with status 0
owing patches: https://git.kerne[  100.670447] init: Service 'vendor.bluetooth-1-0' (pid 2131) received signal 6
l.org/cgit/linux/kernel/git/torv[  100.670482] init: Sending signal 9 to service 'vendor.bluetooth-1-0' (pid 2131) process group...
alds/linux.git/log/?qt=grep&q=CL[  100.671058] libprocessgroup: Successfully killed process cgroup uid 1002 pid 2131 in 0ms
OCK_BOOTTIME_ALARM
12-04 17:38:[  100.672011] init: Untracked pid 4768 exited with status 0
15.720  4688  4728 I bt_osi_thread: run_thread: thread id 4728, [  100.675533] init: starting service 'vendor.bluetooth-1-0'...
thread name alarm_default_ca sta[  100.769781] type=1400 audit(1733305096.116:107): avc: denied { open } for comm="crash_dump64" path="/dev/__properties__/u:object_r:exported_bluetooth_prop:s0" dev="tmpfs" ino=390 scontext=u:r:crash_dump:s0 tcontext=u:object_r:exported_bluetooth_prop:s0 tclass=file permissive=1
rted
12-04 17:38:15.722  4688  [  100.799106] type=1400 audit(1733305096.116:107): avc: denied { open } for comm="crash_dump64" path="/dev/__properties__/u:object_r:exported_bluetooth_prop:s0" dev="tmpfs" ino=390 scontext=u:r:crash_dump:s0 tcontext=u:object_r:exported_bluetooth_prop:s0 tclass=file permissive=1
4729 I bt_osi_thread: run_thread[  100.829017] type=1400 audit(1733305096.116:108): avc: denied { getattr } for comm="crash_dump64" path="/dev/__properties__/u:object_r:exported_bluetooth_prop:s0" dev="tmpfs" ino=390 scontext=u:r:crash_dump:s0 tcontext=u:object_r:exported_bluetooth_prop:s0 tclass=file permissive=1
: thread id 4729, thread name al[  100.860657] type=1400 audit(1733305096.116:108): avc: denied { getattr } for comm="crash_dump64" path="/dev/__properties__/u:object_r:exported_bluetooth_prop:s0" dev="tmpfs" ino=390 scontext=u:r:crash_dump:s0 tcontext=u:object_r:exported_bluetooth_prop:s0 tclass=file permissive=1
arm_dispatcher started
12-04 17[  100.889832] type=1400 audit(1733305096.116:109): avc: denied { open } for comm="crash_dump64" path="/dev/__properties__/u:object_r:hwservicemanager_prop:s0" dev="tmpfs" ino=411 scontext=u:r:crash_dump:s0 tcontext=u:object_r:hwservicemanager_prop:s0 tclass=file permissive=1
:38:15.724  4688  4724 I bt_btif_core: btif_init_bluetooth entered
12-04 17:38:15.725  4688  4724 I bt_stack_config: init attempt to load stack conf from /etc/bluetooth/bt_stack.conf
12-04 17:38:15.728  4688  4731 I         : [1204/173815.727976:INFO:message_loop_thread.cc(175)] Run: message loop starting for thread bt_jni_thread
12-04 17:38:15.728  4688  4724 I bt_btif_core: btif_init_bluetooth finished
12-04 17:38:15.728  4688  4724 I bt_stack_manager: event_init_stack finished
12-04 17:38:15.728  4688  4688 I bt_osi_wakelock: wakelock_set_os_callouts set to non-native
12-04 17:38:15.729  4688  4688 I bt_btif : get_profile_interface: id = socket
12-04 17:38:15.732  4688  4731 E bt_btif_storage: btif_storage_get_adapter_property: Controller not ready! Unable to return Bluetooth Address
12-04 17:38:15.732  4688  [  100.988909] audit_log_lost: 104 callbacks suppressed
4731 E BluetoothServiceJni: adap[  100.988916] audit: audit_lost=39 audit_rate_limit=5 audit_backlog_limit=64
ter_properties_callback: Status [  101.007579] audit: rate limit exceeded
1 is incorrect
12-04 17:38:15.732  4688  4688 I bt_btif : get_profile_interface: id = sdp
12-04 17:38:15.735  4688  4731 D AdapterProperties: Name is: QUAD-CORE A133 c3
12-04 17:38:15.735  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.736  4688  4731 D AdapterProperties: BT Class:1a011c
12-04 17:38:15.737  2444  2444 D BluetoothManagerService: Bluetooth Adapter name changed to QUAD-CORE A133 c3
12-04 17:38:15.737  2444  2444 D BluetoothManagerService: Stored Bluetooth name: QUAD-CORE A133 c3
12-04 17:38:15.738  4688  4688 I BluetoothAdapterService: Phone policy enabled
12-04 17:38:15.746  4688  4688 D BluetoothActiveDeviceManager: start()
12-04 17:38:15.753  4688  4733 D BluetoothActiveDeviceManager: onAudioDevicesAdded
12-04 17:38:15.753  4688  4733 D BluetoothActiveDeviceManager: Audio device added: QUAD-CORE A133 c3 type: 2
12-04 17:38:15.753  4688  4733 D BluetoothActiveDeviceManager: Audio device added: QUAD-CORE A133 c3 type: 15
12-04 17:38:15.756  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.769  4688  4688 D BluetoothDatabase: start()
12-04 17:38:15.772  4688  4688 D BluetoothDatabase: Load Database
12-04 17:38:15.777  4688  4688 D BluetoothAdapterService: setAdapterService() - trying to set service to com.android.bluetooth.btservice.AdapterService@ce331bd
12-04 17:38:15.786  4688  4688 D BluetoothAdapterService: onBind()
12-04 17:38:15.787  2444  2444 D BluetoothManagerService: BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
12-04 17:38:15.787  2444  2489 D BluetoothManagerService: MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
12-04 17:38:15.788  2444  2489 D BluetoothManagerService: Broadcasting onBluetoothServiceUp() to 4 receivers.
12-04 17:38:15.789  4688  4709 D BluetoothAdapter: onBluetoothServiceUp: com.android.bluetooth.btservice.AdapterService$AdapterServiceBinder@fbeb629
12-04 17:38:15.790  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.791  2444  2489 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@302e680
12-04 17:38:15.791  2891  3169 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@b9a1092
12-04 17:38:15.791  2765  2782 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@4e7737b
12-04 17:38:15.806  4688  4712 D BluetoothAdapterService: enable() - Enable called with quiet mode status =  false
12-04 17:38:15.807  2444  2489 D BluetoothManagerService: MESSAGE_GET_NAME_AND_ADDRESS
12-04 17:38:15.807  4688  4723 I AdapterState: BLE_TURNING_ON : entered
12-04 17:38:15.807  4688  4723 D AdapterProperties: Setting state to BLE_TURNING_ON
12-04 17:38:15.807  4688  4723 D BluetoothAdapterService: updateAdapterState() - Broadcasting state BLE_TURNING_ON to 1 receivers.
12-04 17:38:15.810  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.816  4688  4723 D BluetoothAdapterService: bleOnProcessStart()
12-04 17:38:15.817  4688  4723 I AdapterProperties: init(), maxConnectedAudioDevices, default=5, propertyOverlayed=5, finalValue=5
12-04 17:38:15.817  4688  4736 I BluetoothDatabase: cacheMetadata
12-04 17:38:15.818  2444  2489 D BluetoothManagerService: Stored Bluetooth name: QUAD-CORE A133 c3
12-04 17:38:15.818  2444  2489 D BluetoothManagerService: MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
12-04 17:38:15.818  2444  2489 D BluetoothManagerService: Sending BLE State Change: OFF > BLE_TURNING_ON
12-04 17:38:15.819  4688  4723 D BluetoothAdapterService: bleOnProcessStart() - Make Bond State Machine
12-04 17:38:15.820  4688  4723 D BluetoothBondStateMachine: make
12-04 17:38:15.823  4688  4743 I BluetoothBondStateMachine: StableState(): Entering Off State
12-04 17:38:15.834  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.837  4688  4688 I BtGatt.JNI: classInitNative(L876): classInitNative: Success!
12-04 17:38:15.845  4688  4688 D BtGatt.DebugUtils: handleDebugAction() action=null
12-04 17:38:15.846  4688  4688 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@ce331bd
12-04 17:38:15.849  4688  4688 I bt_btif : get_profile_interface: id = gatt
12-04 17:38:15.851  4688  4688 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@ce331bd
12-04 17:38:15.853  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.866  2444  2664 E WifiVendorHal: getWifiLinkLayerStats_1_3_Internal(l.926) failed {.code = ERROR_NOT_AVAILABLE, .description = }
12-04 17:38:15.874  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.884  4688  4688 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@ce331bd
12-04 17:38:15.887  4688  4724 I bt_stack_manager: event_start_up_stack is bringing up the stack
12-04 17:38:15.887  4688  4724 I bt_core_module: module_start_up Starting module "btif_config_module"
12-04 17:38:15.887  4688  4724 I bt_core_module: module_start_up Started module "btif_config_module"
12-04 17:38:15.887  4688  4724 I bt_core_module: module_start_up Starting module "btsnoop_module"
12-04 17:38:15.887  4688  4724 I         : [1204/173815.887791:INFO:btsnoop.cc(207)] start_up: Snoop Logs disabled
12-04 17:38:15.887  4688  4724 I         : [1204/173815.887912:INFO:btsnoop.cc(338)] delete_btsnoop_files: Deleting snoop logs if they exist. filtered = 1
12-04 17:38:15.888  4688  4724 I         : [1204/173815.888094:INFO:btsnoop.cc(338)] delete_btsnoop_files: Deleting snoop logs if they exist. filtered = 0
12-04 17:38:15.888  4688  4724 I bt_core_module: module_start_up Started module "btsnoop_module"
12-04 17:38:15.888  4688  4724 I bt_core_module: module_start_up Starting module "hci_module"
12-04 17:38:15.888  4688  4724 I bt_hci  : hci_module_start_up
12-04 17:38:15.888  4688  4752 I         : [1204/173815.888727:INFO:message_loop_thread.cc(175)] Run: message loop starting for thread bt_hci_thread
12-04 17:38:15.889  4688  4724 D bt_hci  : hci_module_start_up starting async portion
12-04 17:38:15.889  4688  4752 I bt_hci  : hci_initialize
12-04 17:38:15.892  4688  4752 I bt_hci  : hci_initialize: IBluetoothHci::getService() returned 0x7c5d8b4220 (remote)
12-04 17:38:15.903  2131  2150 I android.hardware.bluetooth@1.0-impl: BluetoothHci::initialize()
12-04 17:38:15.906  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.917  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.932  2131  2150 D         : get_local_address: Trying /sys/class/addr_mgt/addr_bt
12-04 17:38:15.933  2131  2150 D         : get_local_address: Got Factory BDA 52:24:EB:E7:63:5D
12-04 17:38:15.933  2131  2150 I bt_vendor: init
12-04 17:38:15.933  2131  2150 W bt_vendor: *****************************************************************
12-04 17:38:15.933  2131  2150 W bt_vendor: ** Warning - BT Vendor Lib is loaded in debug tuning mode!
12-04 17:38:15.933  2131  2150 W bt_vendor: ** If this is not intentional, rebuild libbt-vendor.so
12-04 17:38:15.933  2131  2150 W bt_vendor: ** with VENDOR_LIB_RUNTIME_TUNING_ENABLED=FALSE and
12-04 17:38:15.933  2131  2150 W bt_vendor: ** check if any run-time tuning parameters needed to be
12-04 17:38:15.933  2131  2150 W bt_vendor: ** carried to the build-time configuration accordingly.
12-04 17:38:15.933  2131  2150 I bt_vnd_conf: Attempt to load conf from /etc/bluetooth/bt_vendor.conf
12-04 17:38:15.933  2131  2150 I bt_vnd_conf: vnd_load_conf file >/etc/bluetooth/bt_vendor.conf< not found
12-04 17:38:15.933  2131  2150 D android.hardware.bluetooth@1.0-impl: Open vendor library loaded
12-04 17:38:15.933  2131  2150 D bt_vendor: op for 0
12-04 17:38:15.934  2131  2150 D bt_upio : init_rfkill: rfkill path /sys/devices/platform/aic-bt/rfkill/rfkill1
12-04 17:38:15.941  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.944  2765  2765 W StatusBarIconController: setIconVisibility index: 27
12-04 17:38:15.959  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:15.970  2131  2150 W bt_vendor: NOTE: BT_VND_PWR_ON now forces power-off first
12-04 17:38:15.970  2131  2150 D bt_upio : init_rfkill: rfkill path /sys/devices/platform/aic-bt/rfkill/rfkill1
12-04 17:38:15.981  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.002  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.006  2131  2150 D bt_vendor: op for 3
12-04 17:38:16.006 [  101.822831] init: Untracked pid 4783 exited with status 0
 2131  2150 I bt_userial_vendor: userial vendor open: opening /dev/ttyS1
12-04 17:38:16.007  2131  2150 I bt_userial_vendor: device fd = 6 open
12-04 17:38:16.007  2131  2150 D bt_vendor: op for 1
12-04 17:38:16.007  2131  2150 E bt_hwcfg: hw_config_sta[  101.850255] init: Untracked pid 4788 exited with status 0
rt
12-04 17:38:16.007  2131  2150 D bt_vendor: op for 7
12-04 17:38:16.007  2131  2150 E bt_hwcfg: set_wake_stat 1
12-04 17:38:16.007  2131  2150 D bt_upio : upio_set : pio 0 action 2, polarity 1
12-04 17:38:16.023  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.026  2131  2150 D bt_upio : upio_set: proc btwrite assertion, buffer: 1, timer_armed 1 0
12-04 17:38:16.027  2131  4760 F android.hardware.bluetooth-hci-h4: OnDataReady: Unimplemented packet type 0
--------- beginning of crash
12-04 17:38:16.028  2131  4760 F libc    : Fatal signal 6 (SIGABRT), code -1 (SI_QUEUE) in tid 4760 (HwBinder:2131_1), pid 2131 (bluetooth@1.0-s)
12-04 17:[  101.917573] binder: undelivered death notification, 0000007cf44621e0
38:16.045  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.066  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.073  4765  4765 I crash_dump64: obtaining output fd from tombstoned, type: kDebuggerdTombstone
12-04 17:38:16.074  2217  2217 I /system/bin/tombstoned: received crash request for pid 4760
12-04 17:38:16.076  4765  4765 I crash_dump64: performing dump of process 2131 (target tid = 4760)
12-04 17:38:16.079  4765  4765 F DEBUG   : *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
12-04 17:38:16.080  4765  4765 F DEBUG   : Build fingerprint: 'Allwinner/ceres_c3/ceres-c3:10/QP1A.191105.004/eng.ubuntu.20241127.164531:userdebug/test-keys'
12-04 17:38:16.080  4765  4765 F DEBUG   : Revision: '0'
12-04 17:38:16.080  4765  4765 F DEBUG   : ABI: 'arm64'
12-04 17:38:16.082  4765  4765 F DEBUG   : Timestamp: 2024-12-04 17:38:16+0800
12-04 17:38:16.082  4765  4765 F DEBUG   : pid: 2131, tid: 4760, name: HwBinder:2131_1  >>> /vendor/bin/hw/android.hardware.bluetooth@1.0-service <<<
12-04 17:38:16.082  4765  4765 F DEBUG   : uid: 1002
12-04 17:38:16.082  4765  4765 F DEBUG   : signal 6 (SIGABRT), code -1 (SI_QUEUE), fault addr --------
12-04 17:38:16.082  4765  4765 F DEBUG   : Abort message: 'OnDataReady: Unimplemented packet type 0'
12-04 17:38:16.082  4765  4765 F DEBUG   :     x0  0000000000000000  x1  0000000000001298  x2  0000000000000006  x3  00000077218e9540
12-04 17:38:16.082  4765  4765 F DEBUG   :     x4  2e6761772e000000  x5  2e6761772e000000  x6  2e6761772e000000  x7  000000ffffffffff
12-04 17:38:16.082  4765  4765 F DEBUG   :     x8  00000000000000f0  x9  1ba5523419805c05  x10 0000000000000001  x11 0000000000000000
12-04 17:38:16.082  4765  4765 F DEBUG   :     x12 fffffff0ffffffdf  x13 ffffffffffffffff  x14 0000000000000004  x15 ffffffffffffffff
12-04 17:38:16.082  4765  4765 F DEBUG   :     x16 0000007723a978c0  x17 0000007723a75100  x18 000000772171c000  x19 0000000000000853
12-04 17:38:16.082  4765  4765 F DEBUG   :     x20 0000000000001298  x21 00000000ffffffff  x22 00000077218ea020  x23 00000077218e9bb0
12-04 17:38:16.082  4765  4765 F DEBUG   :     x24 0000007723019208  x25 0000007723019208  x26 20c49ba5e353f7cf  x27 00000000000003e8
12-04 17:38:16.082  4765  4765 F DEBUG   :     x28 0000007723009180  x29 00000077218e95e0
12-04 17:38:16.082  4765  4765 F DEBUG   :     sp  00000077218e9520  lr  0000007723a29f48  pc  0000007723a29f74
12-04 17:38:16.087  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.089  4765  4765 F DEBUG   :
12-04 17:38:16.089  4765  4765 F DEBUG   : backtrace:
12-04 17:38:16.089  4765  4765 F DEBUG   :       #00 pc 0000000000081f74  /apex/com.android.runtime/lib64/bionic/libc.so (abort+160) (BuildId: 42603fd538b769308cd4c199a3a97e47)
12-04 17:38:16.089  4765  4765 F DEBUG   :       #01 pc 00000000000089f8  /system/lib64/liblog.so (__android_log_assert+324) (BuildId: 861a081c2056965edab68796c1ed73e0)
12-04 17:38:16.089  4765  4765 F DEBUG   :       #02 pc 000000000000a230  /vendor/lib64/hw/android.hardware.bluetooth@1.0-impl.so (android::hardware::bluetooth::hci::H4Protocol::OnDataReady(int)+180) (BuildId: d049058a6c7deb74b092a5074bd90e52)
12-04 17:38:16.089  4765  4765 F DEBUG   :       #03 pc 0000000000009c24  /vendor/lib64/hw/android.hardware.bluetooth@1.0-impl.so (android::hardware::bluetooth::async::AsyncFdWatcher::ThreadRoutine()+656) (BuildId: d049058a6c7deb74b092a5074bd90e52)
12-04 17:38:16.089  4765  4765 F DEBUG   :       #04 pc 0000000000009fa0  /vendor/lib64/hw/android.hardware.bluetooth@1.0-impl.so (_ZNSt3__114__thread_proxyINS_5tupleIJNS_10unique_ptrINS_15__thread_structENS_14default_deleteIS3_EEEEZN7android8hardware9bluetooth5async14AsyncFdWatcher14tryStartThreadEvE3$_0EEEEEPvSE_+40) (BuildId: d049058a6c7deb74b092a5074bd90e52)
12-04 17:38:16.089  4765  4765 F DEBUG   :       #05 pc 00000000000e1100  /apex/com.android.runtime/lib64/bionic/libc.so (__pthread_start(void*)+36) (BuildId: 42603fd538b769308cd4c199a3a97e47)
12-04 17:38:16.089  4765  4765 F DEBUG   :       #06 pc 0000000000083ab0  /apex/com.android.runtime/lib64/bionic/libc.so (__start_thread+64) (BuildId: 42603fd538b769308cd4c199a3a97e47)
12-04 17:38:16.151  2444  2818 W NativeCrashListener: Couldn't find ProcessRecord for pid 2131
12-04 17:38:16.112  2130  4714 I chatty  : uid=1041(audioserver) writer identical 1 line
12-04 17:38:16.130  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.152  2217  2217 E /system/bin/tombstoned: Tombstone written to: /data/tombstones/tombstone_47
12-04 17:38:16.156  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.168  2444  2510 I BootReceiver: Copying /data/tombstones/tombstone_47 to DropBox (SYSTEM_TOMBSTONE)
12-04 17:38:16.170  2444  2510 I DropBoxManagerService: add tag=SYSTEM_TOMBSTONE isTagEnabled=true flags=0x2
12-04 17:38:16.172  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.175  4688  4753 E bt_hci  : Bluetooth HAL service died!
12-04 17:38:16.175  4688  4753 F libc    : Fatal signal 6 (SIGABRT), code -1 (SI_QUEUE) in tid 4753 (HwBinder:4688_1), pid 4688 (droid.bluetooth)
12-04 17:38:16.194  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.216  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.253  4783  4783 I crash_dump64: obtaining output fd from tombstoned, type: kDebuggerdTombstone
12-04 17:38:16.254  2217  2217 I /system/bin/tombstoned: received crash request for pid 4753
12-04 17:38:16.254  2136  2355 D sunxihwc: checkPerformance: PerfMonitor total[w]:   67 acquire:    0 submit:    1 release:   66
12-04 17:38:16.254  4779  4779 I ServiceManagement: Registered android.hardware.bluetooth@1.0::IBluetoothHci/default (start delay of 87ms)
12-04 17:38:16.255  4779  4779 I ServiceManagement: Removing namespace from process name android.hardware.bluetooth@1.0-service to bluetooth@1.0-service.
12-04 17:38:16.255  4779  4779 I android.hardware.bluetooth@1.0-service: Registration complete for android.hardware.bluetooth@1.0::IBluetoothHci/default.
12-04 17:38:16.256  4783  4783 I crash_dump64: performing dump of process 4688 (target tid = 4753)
12-04 17:38:16.266  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.276  4783  4783 F DEBUG   : *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
12-04 17:38:16.276  4783  4783 F DEBUG   : Build fingerprint: 'Allwinner/ceres_c3/ceres-c3:10/QP1A.191105.004/eng.ubuntu.20241127.164531:userdebug/test-keys'
12-04 17:38:16.276  4[  102.519498] bluetooth_set_power: start_block=1
783  4783 F DEBUG   : Revision: [  102.525644] aicbsp: aicbsp_set_subsys, subsys: AIC_BLUETOOTH, state to: 0
'0'
12-04 17:38:16.276  4783  4[  102.535690] aicbsp: aicbsp_set_subsys, power state no need to change, current: 1
783 F DEBUG   : ABI: 'arm64'
12[  102.546950] bluetooth_set_power: end_block=1
-04 17:38:16.277  4783  4783 F D[  102.555200] bluetooth_set_power: start_block=0
EBUG   : Timestamp: 2024-12-04 1[  102.562018] aicbsp: aicbsp_set_subsys, subsys: AIC_BLUETOOTH, state to: 1
7:38:16+0800
12-04 17:38:16.277[  102.572462] aicbsp: aicbsp_set_subsys, power state no need to change, current: 1
  4783  4783 F DEBUG   : pid: 46[  102.583430] bluetooth_set_power: end_block=0
88, tid: 4753, name: HwBinder:4688_1  >>> com.android.bluetooth <<<
12-04 17:38:16.277  4783  4783 F DEBUG   : uid: 1002
12-04 17:38:16.277  4783  4783 F DEBUG   : signal 6 (SIGABRT), code -1 (SI_QUEUE), fault addr --------
12-04 17:38:16.278  4783  4783 F DEBUG   :     x0  0000000000000000  x1  0000000000001291  x2  0000000000000006  x3  0000007bf94436d0
12-04 17:38:16.278  4783  4783 F DEBUG   :     x4  f8433f1efeff6862  x5  f8433f1efeff6862  x6  f8433f1efeff6862  x7  ff7f7f7f7f7f7f7f
12-04 17:38:16.278  4783  4783 F DEBUG   :     x8  00000000000000f0  x9  65b5bbbb335a5371  x10 0000000000000001  x11 0000000000000000
12-04 17:38:16.278  4783  4783 F DEBUG   :     x12 fffffff0fffffbdf  x13 ffffffffffffffff  x14 0000000000000004  x15 ffffffffffffffff
12-04 17:38:16.278  4783  4783 F DEBUG   :     x16 0000007cf1e018c0  x17 0000007cf1ddf100  x18 0000007bf8cda008  x19 0000000000001250
12-04 17:38:16.278  4783  4783 F DEBUG   :     x20 0000000000001291  x21 00000000ffffffff  x22 0000000000000000  x23 000000008008720f
12-04 17:38:16.278  4783  4783 F DEBUG   :     x24 0000007bf9444020  x25 0000007bf9443a38  x26 0000007bf9444020  x27 0000007bfa63f020
12-04 17:38:16.278  4783  4783 F DEBUG   :     x28 0000000000000009  x29 0000007bf9443770
12-04 17:38:16.278  4783  4783 F DEBUG   :     sp  0000007bf94436b0  lr  0000007cf1d93f48  pc  0000007cf1d93f74
12-04 17:38:16.279  2130  4714 I chatty  : uid=1041(audioserver) writer identical 1 line
12-04 17:38:16.290  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.116  4765  4765 I crash_dump64: type=1400 audit(0.0:107): avc: denied { open } for path="/dev/__properties__/u:object_r:exported_bluetooth_prop:s0" dev="tmpfs" ino=390 scontext=u:r:crash_dump:s0 tcontext=u:object_r:exported_bluetooth_prop:s0 tclass=file permissive=1
12-04 17:38:16.303  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.356  4783  4783 F DEBUG   :
12-04 17:38:16.356  4783  4783 F DEBUG   : backtrace:
12-04 17:38:16.356  4783  4783 F DEBUG   :       #00 pc 0000000000081f74  /apex/com.android.runtime/lib64/bionic/libc.so (abort+160) (BuildId: 42603fd538b769308cd4c199a3a97e47)
12-04 17:38:16.356  4783  4783 F DEBUG   :       #01 pc 0000000000265154  /system/lib64/libbluetooth.so (hal_service_died()+160) (BuildId: ff706d003775a24c2416240a147a9ab6)
12-04 17:38:16.357  4783  4783 F DEBUG   :       #02 pc 0000000000055d84  /system/lib64/libhidlbase.so (android::hardware::hidl_binder_death_recipient::binderDied(android::wp<android::hardware::IBinder> const&)+112) (BuildId: 58cced33adaf1be9a5dabb1206d0e08e)
12-04 17:38:16.322  2130  4714 I chatty  : uid=1041(audioserver) writer identical 1 line
12-04 17:38:16.350  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.116  4765  4765 I crash_dump64: type=1400 audit(0.0:108): avc: denied { getattr } for path="/dev/__properties__/u:object_r:exported_bluetooth_prop:s0" dev="tmpfs" ino=390 scontext=u:r:crash_dump:s0 tcontext=u:object_r:exported_bluetooth_prop:s0 tclass=file permissive=1
12-04 17:38:16.357  4783  4783 F DEBUG   :       #03 pc 0000000000096ca8  /system/lib64/libhidlbase.so (android::hardware::BpHwBinder::reportOneDeath(android::hardware::BpHwBinder::Obituary const&)+128) (BuildId: 58cced33adaf1be9a5dabb1206d0e08e)
12-04 17:38:16.357  4783  4783 F DEBUG   :       #04 pc 0000000000096c10  /system/lib64/libhidlbase.so (android::hardware::BpHwBinder::sendObituary()+204) (BuildId: 58cced33adaf1be9a5dabb1206d0e08e)
12-04 17:38:16.357  4783  4783 F DEBUG   :       #05 pc 0000000000099e10  /system/lib64/libhidlbase.so (android::hardware::IPCThreadState::getAndExecuteCommand()+3000) (BuildId: 58cced33adaf1be9a5dabb1206d0e08e)
12-04 17:38:16.357  4783  4783 F DEBUG   :       #06 pc 000000000009acf4  /system/lib64/libhidlbase.so (android::hardware::IPCThreadState::joinThreadPool(bool)+152) (BuildId: 58cced33adaf1be9a5dabb1206d0e08e)
12-04 17:38:16.357  4783  4783 F DEBUG   :       #07 pc 00000000000a9c84  /system/lib64/libhidlbase.so (android::hardware::PoolThread::threadLoop()+24) (BuildId: 58cced33adaf1be9a5dabb1206d0e08e)
12-04 17:38:16.357  4783  4783 F DEBUG   :       #08 pc 0000000000013670  /system/lib64/libutils.so (android::Thread::_threadLoop(void*)+288) (BuildId: e694ec4393425b1d99ea7621766c5862)
12-04 17:38:16.357  4783  4783 F DEBUG   :       #09 pc 00000000000c1748  /system/lib64/libandroid_runtime.so (android::AndroidRuntime::javaThreadShell(void*)+140) (BuildId: b65a8685227b31d2613995f2e0a17273)
12-04 17:38:16.357  4783  4783 F DEBUG   :       #10 pc 00000000000e1100  /apex/com.android.runtime/lib64/bionic/libc.so (__pthread_start(void*)+36) (BuildId: 42603fd538b769308cd4c199a3a97e47)
12-04 17:38:16.357  4783  4783 F DEBUG   :       #11 pc 0000000000083ab0  /apex/com.android.runtime/lib64/bionic/libc.so (__start_thread+64) (BuildId: 42603fd538b769308cd4c199a3a97e47)
12-04 17:38:16.367  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.385  2130  4714 I chatty  : uid=1041(audioserver) writer identical 1 line
12-04 17:38:16.407  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.116  4765  4765 I crash_dump64: type=1400 audit(0.0:109): avc: denied { open } for path="/dev/__properties__/u:object_r:hwservicemanager_prop:s0" dev="tmpfs" ino=411 scontext=u:r:crash_dump:s0 tcontext=u:object_r:hwservicemanager_prop:s0 tclass=file permissive=1
12-04 17:38:16.116  4765  4765 I crash_dump64: type=1400 audit(0.0:110): avc: denied { getattr } for path="/dev/__properties__/u:object_r:hwservicemanager_prop:s0" dev="tmpfs" ino=411 scontext=u:r:crash_dump:s0 tcontext=u:object_r:hwservicemanager_prop:s0 tclass=file permissive=1
12-04 17:38:16.430  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.446  2210  4710 D omx_venc: <__AwOmxVencFillThisBuffer:2082>: vencOutPort: fill_this_buffer 50 times
12-04 17:38:16.450  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.472  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.483  4783  4783 I crash_dump64: type=1400 audit(0.0:111): avc: denied { open } for path="/dev/__properties__/u:object_r:bluetooth_a2dp_offload_prop:s0" dev="tmpfs" ino=338 scontext=u:r:crash_dump:s0 tcontext=u:object_r:bluetooth_a2dp_offload_prop:s0 tclass=file permissive=1
12-04 17:38:16.498  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.515  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:16.518  2210  4710 D omx_venc: <__AwOmxVencEmptyThisBuffer:2043>: vencInPort: , empty_this_buffer 50 times
12-04 17:38:16.535  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.243  2130  4714 I chatty  : uid=1041(audioserver) writer identical 33 lines
12-04 17:38:17.261  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.264  2217  2217 E /system/bin/tombstoned: Tombstone written to: /data/tombstones/tombstone_48
12-04 17:38:17.282  2444  4842 I DropBoxManagerService: add tag=system_app_native_crash isTagEnabled=true flags=0x2
12-04 17:38:17.282  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.301  2444  2510 I BootReceiver: Copying /data/tombstones/tombstone_48 to DropBox (SYSTEM_TOMBSTONE)
12-04 17:38:17.303  2444  2510 I DropBoxManagerService: add tag=SYSTEM_TOMBSTONE isTagEnabled=true flags=0x2
12-04 17:38:17.303  2210  4710 D omx_venc: <__AwOmxVencFillThisBuffer:2082>: vencOutPort: fill_this_buffer 50 times
12-04 17:38:17.305  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.331  2130  4714 I chatty  : uid=1041(audioserver) writer identical 1 line
12-04 17:38:17.349  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.363  2210  4710 D omx_venc: <__AwOmxVencEmptyThisBuffer:2043>: vencInPort: , empty_this_buffer 50 times
12-04 17:38:17.367  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.385  2444  2462 I system_server: Background young concurrent copying GC freed 66696(3139KB) AllocSpace objects, 22(1480KB) LOS objects, 27% free, 8626KB/11MB, paused 1.507ms total 114.225ms
12-04 17:38:17.389  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.411  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.419  2124  2124 I Zygote  : Process 4688 exited due to signal 6 (Aborted)
12-04 17:38:17.426  2444  2444 D BluetoothManagerService: BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
12-04 17:38:17.427  2444  2489 E BluetoothManagerService: MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
12-04 17:38:17.427  2444  2489 D BluetoothManagerService: Broadcasting onBluetoothServiceDown() to 3 receivers.
12-04 17:38:17.429  2444  2936 I ActivityManager: Process com.android.bluetooth (pid 4688) has died: psvc PER
12-04 17:38:17.431  2444  2498 I libprocessgroup: Successfully killed process cgroup uid 1002 pid 4688 in 0ms
12-04 17:38:17.431  2891  3169 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@b9a1092
12-04 17:38:17.431  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.432  2765  2782 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@4e7737b
12-04 17:38:17.433  2444  2936 W ActivityManager: Scheduling restart of crashed service com.android.b[  103.450006] AICWFDBG(LOGTRACE)  rwnx_send_msg (118)MM_GET_STA_INFO_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0
luetooth/.btservice.AdapterServi[  103.463930] AICWFDBG(LOGTRACE)       rwnx_cmd_malloc get cmd_array[0]:ffffff8000e2c900
ce in 1000ms
12-04 17:38:17.433[  103.474397] AICWFDBG(LOGDEBUG)     rwnx_rx_handle_msg msg->id:0x76
  2444  2936 W ActivityManager: [  103.483203] AICWFDBG(LOGTRACE)       rwnx_cmd_free cmd_array[0]:ffffff8000e2c900
Scheduling restart of crashed se[  103.494209] AICWFDBG(LOGDEBUG)       rwnx_fill_station_info ModTx(0):4 TxIndex:8 ModRx(0):0 RxHTIndex:0 RxVHTIndex:0 RxHEIndex:0 RSSI:-32
rvice com.android.bluetooth/.gatt.GattService in 11000ms
12-04 17:38:17.434  2444  2489 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@302e680
12-04 17:38:17.452  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.628  2444  2489 D BluetoothManagerService: MESSAGE_RESTART_BLUETOOTH_SERVICE
12-04 17:38:17.623  2130  4714 I chatty  : uid=1041(audioserver) writer identical 8 lines
12-04 17:38:17.645  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.649  2124  2124 D Zygote  : Forked child process 4863
12-04 17:38:17.652  2444  2497 I ActivityManager: app.processName = com.android.bluetooth
12-04 17:38:17.652  2444  2497 I ActivityManager: Start proc 4863:com.android.bluetooth/1002 for service {com.android.bluetooth/com.android.bluetooth.btservice.AdapterService}
12-04 17:38:17.660  4863  4863 I Zygote  : seccomp disabled by setenforce 0
12-04 17:38:17.666  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.687  2130  4714 I chatty  : uid=1041(audioserver) writer identical 1 line
12-04 17:38:17.710  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.720  4863  4863 I droid.bluetoot: The ClassLoaderContext is a special shared library.
12-04 17:38:17.730  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.751  2130  4714 I chatty  : uid=1041(audioserver) writer identical 1 line
12-04 17:38:17.773  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.773  4863  4863 D BluetoothOppFileProvider: Initialized
12-04 17:38:17.795  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.805  4863  4863 V AdapterServiceConfig: Adding HeadsetService
12-04 17:38:17.806  4863  4863 V AdapterServiceConfig: Adding A2dpService
12-04 17:38:17.807  4863  4863 V AdapterServiceConfig: Adding HidHostService
12-04 17:38:17.807  4863  4863 V AdapterServiceConfig: Adding PanService
12-04 17:38:17.807  4863  4863 V AdapterServiceConfig: Adding GattService
12-04 17:38:17.807  4863  4863 V AdapterServiceConfig: Adding BluetoothMapService
12-04 17:38:17.807  4863  4863 V AdapterServiceConfig: Adding AvrcpTargetService
12-04 17:38:17.807  4863  4863 V AdapterServiceConfig: Adding HidDeviceService
12-04 17:38:17.807  4863  4863 V AdapterServiceConfig: Adding BluetoothOppService
12-04 17:38:17.807  4863  4863 V AdapterServiceConfig: Adding BluetoothPbapService
12-04 17:38:17.815  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.836  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.846  4863  4863 I         : [1204/173817.846267:INFO:com_android_bluetooth_btservice_AdapterService.cpp(628)] hal_util_load_bt_library loaded HAL: btinterface=0x7c0aa61440, handle=0x4231b39a6b02c329
12-04 17:38:17.849  4863  4863 D BluetoothAdapterService: onCreate()
12-04 17:38:17.855  4863  4863 D AdapterState: make() - Creating AdapterState
12-04 17:38:17.858  4863  4895 I AdapterState: OFF : entered
12-04 17:38:17.858  4863  4895 D AdapterProperties: Setting state to OFF
12-04 17:38:17.859  4863  4863 I bt_btif : init: start restricted = 0 ; single user = 0
12-04 17:38:17.859  4863  4863 D bt_osi_allocation_tracker: canary initialized
12-04 17:38:17.860  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.861  4863  4896 I         : [1204/173817.861101:INFO:message_loop_thread.cc(175)] Run: message loop starting for thread bt_stack_manager_thread
12-04 17:38:17.862  4863  4896 I bt_stack_manager: event_init_stack is initializing the stack
12-04 17:38:17.863  4863  4896 I         : [1204/173817.863579:INFO:btif_config.cc(647)] hash_file: Disabled for multi-user
12-04 17:38:17.863  4863  4896 I         : [1204/173817.863734:INFO:btif_config.cc(675)] read_checksum_file: Disabled for multi-user
12-04 17:38:17.863  4863  4896 E bt_btif_config: Config is missing adapter section
12-04 17:38:17.864  4863  4896 W bt_btif_config: init unable to load config file: /data/misc/bluedroid/bt_config.conf; using backup.
12-04 17:38:17.864  4863  4896 I         : [1204/173817.864126:INFO:btif_config.cc(647)] hash_file: Disabled for multi-user
12-04 17:38:17.864  4863  4896 I         : [1204/173817.864207:INFO:btif_config.cc(675)] read_checksum_file: Disabled for multi-user
12-04 17:38:17.864  4863  4896 E bt_btif_config: Config is missing adapter section
12-04 17:38:17.864  4863  4896 W bt_btif_config: init unable to load backup; attempting to transcode legacy file.
12-04 17:38:17.864  4863  4896 E bt_btif_config_transcode: btif_config_transcode unable to load XML file '/data/misc/bluedroid/bt_config.xml': 3
12-04 17:38:17.864  4863  4896 E bt_btif_config: init unable to transcode legacy file; creating empty config.
12-04 17:38:17.864  4863  4896 W         : [1204/173817.864558:WARNING:btif_config.cc(151)] read_or_set_metrics_salt: Failed to read metrics salt from config
12-04 17:38:17.864  4863  4896 I         : [1204/173817.864632:INFO:btif_config.cc(162)] read_or_set_metrics_salt: Metrics salt is not invalid, creating new one
12-04 17:38:17.865  4863  4896 E bt_osi_alarm: timer_create_internal unable to create timer with clock 9: Unknown error 524
12-04 17:38:17.866  4863  4896 E bt_osi_alarm: The kernel might not have support for timer_create(CLOCK_BOOTTIME_ALARM): https://lwn.net/Articles/429925/
12-04 17:38:17.866  4863  4896 E bt_osi_alarm: See following patches: https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/log/?qt=grep&q=CLOCK_BOOTTIME_ALARM
12-04 17:38:17.867  4863  4900 I bt_osi_thread: run_thread: thread id 4900, thread name alarm_default_ca started
12-04 17:38:17.867  4863  4901 I bt_osi_thread: run_thread: thread id 4901, thread name alarm_dispatcher started
12-04 17:38:17.869  4863  4896 I bt_btif_core: btif_init_bluetooth entered
12-04 17:38:17.870  4863  4896 I bt_stack_config: init attempt to load stack conf from /etc/bluetooth/bt_stack.conf
12-04 17:38:17.870  4863  4902 I         : [1204/173817.870753:INFO:message_loop_thread.cc(175)] Run: message loop starting for thread bt_jni_thread
12-04 17:38:17.870  4863  4896 I bt_btif_core: btif_init_bluetooth finished
12-04 17:38:17.871  4863  4896 I bt_stack_manager: event_init_stack finished
12-04 17:38:17.871  4863  4863 I bt_osi_wakelock: wakelock_set_os_callouts set to non-native
12-04 17:38:17.871  4863  4863 I bt_btif : get_profile_interface: id = socket
12-04 17:38:17.871  4863  4902 E bt_btif_storage: btif_storage_get_adapter_property: Controller not ready! Unable to return Bluetooth Address
12-04 17:38:17.871  4863  4902 E BluetoothServiceJni: adapter_properties_callback: Status 1 is incorrect
12-04 17:38:17.873  4863  4863 I bt_btif : get_profile_interface: id = sdp
12-04 17:38:17.874  4863  4902 D AdapterProperties: Name is: QUAD-CORE A133 c3
12-04 17:38:17.874  4863  4902 D AdapterProperties: BT Class:1a011c
12-04 17:38:17.877  2444  2444 D BluetoothManagerService: Bluetooth Adapter name changed to QUAD-CORE A133 c3
12-04 17:38:17.879  4863  4863 I BluetoothAdapterService: Phone policy enabled
12-04 17:38:17.879  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.880  2444  2444 D BluetoothManagerService: Stored Bluetooth name: QUAD-CORE A133 c3
12-04 17:38:17.883  4863  4863 D BluetoothActiveDeviceManager: start()
12-04 17:38:17.891  4863  4904 D BluetoothActiveDeviceManager: onAudioDevicesAdded
12-04 17:38:17.891  4863  4904 D BluetoothActiveDeviceManager: Audio device added: QUAD-CORE A133 c3 type: 2
12-04 17:38:17.891  4863  4904 D BluetoothActiveDeviceManager: Audio device added: QUAD-CORE A133 c3 type: 15
12-04 17:38:17.900  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.904  4863  4863 D BluetoothDatabase: start()
12-04 17:38:17.907  4863  4863 D BluetoothDatabase: Load Database
12-04 17:38:17.908  4863  4863 D BluetoothAdapterService: setAdapterService() - trying to set service to com.android.bluetooth.btservice.AdapterService@ce331bd
12-04 17:38:17.917  4863  4863 D BluetoothAdapterService: onBind()
12-04 17:38:17.919  2444  2444 D BluetoothManagerService: BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
12-04 17:38:17.919  2444  2489 D BluetoothManagerService: MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
12-04 17:38:17.920  2444  2489 D BluetoothManagerService: Broadcasting onBluetoothServiceUp() to 4 receivers.
12-04 17:38:17.921  2891  3169 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@491ba63
12-04 17:38:17.921  4863  4882 D BluetoothAdapter: onBluetoothServiceUp: com.android.bluetooth.btservice.AdapterService$AdapterServiceBinder@fbeb629
12-04 17:38:17.921  2765  2782 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@7ddd598
12-04 17:38:17.922  2444  2489 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@6c12a72
12-04 17:38:17.922  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.931  4863  4882 D BluetoothAdapterService: enable() - Enable called with quiet mode status =  false
12-04 17:38:17.932  2444  2489 D BluetoothManagerService: MESSAGE_GET_NAME_AND_ADDRESS
12-04 17:38:17.935  4863  4895 I AdapterState: BLE_TURNING_ON : entered
12-04 17:38:17.935  4863  4895 D AdapterProperties: Setting state to BLE_TURNING_ON
12-04 17:38:17.935  4863  4895 D BluetoothAdapterService: updateAdapterState() - Broadcasting state BLE_TURNING_ON to 1 receivers.
12-04 17:38:17.935  2444  2489 D BluetoothManagerService: Stored Bluetooth name: QUAD-CORE A133 c3
12-04 17:38:17.936  2444  2489 D BluetoothManagerService: MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
12-04 17:38:17.936  2444  2489 D BluetoothManagerService: Sending BLE State Change: OFF > BLE_TURNING_ON
12-04 17:38:17.944  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.952  4863  4895 D BluetoothAdapterService: bleOnProcessStart()
12-04 17:38:17.953  4863  4895 I AdapterProperties: init(), maxConnectedAudioDevices, default=5, propertyOverlayed=5, finalValue=5
12-04 17:38:17.955  4863  4907 I BluetoothDatabase: cacheMetadata
12-04 17:38:17.956  4863  4895 D BluetoothAdapterService: bleOnProcessStart() - Make Bond State Machine
12-04 17:38:17.957  4863  4895 D BluetoothBondStateMachine: make
12-04 17:38:17.958  4863  4915 I BluetoothBondStateMachine: StableState(): Entering Off State
12-04 17:38:17.965  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:17.968  4863  4863 I BtGatt.JNI: classInitNative(L876): classInitNative: Success!
12-04 17:38:17.971  4863  4863 D BtGatt.DebugUtils: handleDebugAction() action=null
12-04 17:38:17.972  4863  4863 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@ce331bd
12-04 17:38:17.982  4863  4863 I bt_btif : get_profile_interface: id = gatt
12-04 17:38:17.982  4863  4863 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@ce331bd
12-04 17:38:17.986  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:18.002  4863  4863 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@ce331bd
12-04 17:38:18.004  4863  4896 I bt_stack_manager: event_start_up_stack is bringing up the stack
12-04 17:38:18.006  4863  4896 I bt_core_module: module_start_up Starting module "btif_config_module"
12-04 17:38:18.006  4863  4896 I bt_core_module: module_start_up Started module "btif_config_module"
12-04 17:38:18.006  4863  4896 I bt_core_module: module_start_up Starting module "btsnoop_module"
12-04 17:38:18.006  4863  4896 I         : [1204/173818.006369:INFO:btsnoop.cc(207)] start_up: Snoop Logs disabled
12-04 17:38:18.006  4863  4896 I         : [1204/173818.006495:INFO:btsnoop.cc(338)] delete_btsnoop_files: Deleting snoop logs if they exist. filtered = 1
12-04 17:38:18.006  4863  4896 I         : [1204/173818.006645:INFO:btsnoop.cc(338)] delete_btsnoop_files: Deleting snoop logs if they exist. filtered = 0
12-04 17:38:18.006  4863  4896 I bt_core_module: module_start_up Started module "btsnoop_module"
12-04 17:38:18.007  4863  4896 I bt_core_module: module_start_up Starting module "hci_module"
12-04 17:38:18.007  4863  4896 I bt_hci  : hci_module_start_up
12-04 17:38:18.007  4863  4922 I         : [1204/173818.007486:INFO:message_loop_thread.cc(175)] Run: message loop starting for thread bt_hci_thread
12-04 17:38:18.007  4863  4922 I bt_hci  : hci_initialize
12-04 17:38:18.007  4863  4896 D bt_hci  : hci_module_start_up starting async portion
12-04 17:38:18.009  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:18.013  4863  4922 I bt_hci  : hci_initialize: IBluetoothHci::getService() returned 0x7c5d8b43e0 (remote)
12-04 17:38:18.013  4779  4786 I android.hardware.bluetooth@1.0-impl: BluetoothHci::initialize()
12-04 17:38:18.015  4779  4786 D         : get_local_address: Trying /sys/class/addr_mgt/addr_bt
12-04 17:38:18.015  4779  4786 D         : get_local_address: Got Factory BDA 52:24:EB:E7:63:5D
12-04 17:38:18.015  4779  4786 I bt_vendor: init
12-04 17:38:18.015  4779  4786 W bt_vendor: *****************************************************************
12-04 17:38:18.015  4779  4786 W bt_vendor: ** Warning - BT Vendor Lib is loaded in debug tuning mode!
12-04 17:38:18.015  4779  4786 W bt_vendor: ** If this is not intentional, rebuild libbt-vendor.so
12-04 17:38:18.015  4779  4786 W bt_vendor: ** with VENDOR_LIB_RUNTIME_TUNING_ENABLED=FALSE and
12-04 17:38:18.015  4779  4786 W bt_vendor: ** check if any run-time tuning parameters needed to be
12-04 17:38:18.015  4779  4786 W bt_vendor: ** carried to the build-time configuration accordingly.
12-04 17:38:18.015  4779  4786 I bt_vnd_conf: Attempt to load conf from /etc/bluetooth/bt_vendor.conf
12-04 17:38:18.015  4779  4786 I bt_vnd_conf: vnd_load_conf file >/etc/bluetooth/bt_vendor.conf< not found
12-04 17:38:18.015  4779  4786 D android.hardware.bluetooth@1.0-impl: Open vendor library loaded
12-04 17:38:18.015  4779  4786 D bt_vendor: op for 0
12-04 17:38:18.016  4779  4786 D bt_upio : init_rfkill: rfkill path /sys/devices/platform/aic-bt/rfkill/rfkill1
12-04 17:38:18.044  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:18.051  4779  4786 W bt_vendor: NOTE: BT_VND_PWR_ON now forces power-off first
12-04 17:38:18.051  4779  4786 D bt_upio : init_rfkill: rfkill path /sys/devices/platform/aic-bt/rfkill/rfkill1
12-04 17:38:18.055  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:18.080  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:18.088  4779  4786 D bt_vendor: op for 3
12-04 17:38:18.088  4779  4786 I bt_userial_vendor: userial vendor open: opening /dev/ttyS1
12-04 17:38:18.088  4779  4786 I bt_userial_vendor: device fd = 6 open
12-04 17:38:18.089  4779  4786 D bt_vendor: op for 1
12-04 17:38:18.089  4779  4786 E bt_hwcfg: hw_config_start
12-04 17:38:18.089  4779  4786 D bt_vendor: op for 7
12-04 17:38:18.089  4779  4786 E bt_hwcfg: set_wake_stat 1
12-04 17:38:18.089  4779  4786 D bt_upio : upio_set : pio 0 action 2, polarity 1
12-04 17:38:18.090  4779  4786 D bt_upio : upio_set: proc btwrite assertion, buffer: 1, timer_armed 1 0
12-04 17:38:18.102  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:18.114  2130  4714 I chatty  : uid=1041(audioserver) writer identical 1 line
12-04 17:38:18.135  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:18.148  2210  4710 D omx_venc: <__AwOmxVencFillThisBuffer:2082>: vencOutPort: fill_this_buffer 50 times
12-04 17:38:18.157  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:18.178  2130  4714 I chatty  : uid=1041(audioserver) writer identical 1 line
12-04 17:38:18.199  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:18.213  2210  4710 D omx_venc: <__AwOmxVencEmptyThisBuffer:2043>: vencInPort: , empty_this_buffer 50 times
12-04 17:38:18.220  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:18.732  2130  4714 I chatty  : uid=1041(audioserver) writer identical 24 lines
12-04 17:38:18.754  2130  4714 V audio_platform: mode(0),devices(0x2):platform device:OUT_DULSPK(0x4)
12-04 17:38:18.765  2130  2130 D audio_hw_primary: out_standby
12-04 17:38:18.943  2444  2664 E WifiVendorHal: getWifiLinkLayerStats_1_3_Internal(l.926) failed {.code = ERROR_NOT_AVAILABLE, .description = }
12-04 17:38:18.983  2210  2287 D omx_venc: <__AwOmxVencFillThisBuffer:2082>: vencOutPort: fill_this_buffer 50 times
12-04 17:38:19.063  2210  4500 D omx_venc: <__AwOmxVencEmptyThisBuffer:2043>: vencInPort: , empty_this_buffer 50 times
12-04 17:38:19.835  2210  4710 D omx_venc: <__AwOmxVencFillThisBuffer:2082>: vencOutPort: fill_this_buffer 50 times
12-04 17:38:19.897  2210  4710 D omx_venc: <__AwOmxVencEmptyThisBuffer:2043>: vencInPort: , empty_this_buffer 50 times
12-04 17:38:20.674  2210  4710 D omx_venc: <__AwOmxVencFillThisBuffer:2082>: vencOutPort: fill_this_buffer 50 times
12-04 17:38:20.730  2210  4710 D omx_venc: <__AwOmxVencEmptyThisBuffer:2043>: vencInPort: , empty_this_buffer 50 times
楼主 #3 2024-12-04 17:49:53
memory
已发帖子: 703
Re: A133 AW869C 蓝牙开启失败,请问是什么原因呢?
这是A133 + AW869A 正常的日志
130|ceres-c3:/ #
130|ceres-c3:/ # logcat |grep bluetooth
08-23 21:00:06.855  2131  2131 I ServiceManagement: Registered android.hardware.bluetooth@1.0::IBluetoothHci/default (start delay of 390ms)
08-23 21:00:06.856  2131  2131 I ServiceManagement: Removing namespace from process name android.hardware.bluetooth@1.0-service to bluetooth@1.0-service.
08-23 21:00:06.857  2131  2131 I android.hardware.bluetooth@1.0-service: Registration complete for android.hardware.bluetooth@1.0::IBluetoothHci/default.
08-23 21:00:06.890  1988  1988 I hwservicemanager: getTransport: Cannot find entry android.hardware.bluetooth.audio@2.0::IBluetoothAudioProvidersFactory/default in either framework or device manifest.
08-23 21:00:06.891  2130  2130 E audiohalservice: Could not get passthrough implementation for android.hardware.bluetooth.audio@2.0::IBluetoothAudioProvidersFactory/default.
08-23 21:00:06.892  1988  1988 I hwservicemanager: getTransport: Cannot find entry android.hardware.bluetooth.a2dp@1.0::IBluetoothAudioOffload/default in either framework or device manifest.
08-23 21:00:06.892  2130  2130 E audiohalservice: Could not get passthrough implementation for android.hardware.bluetooth.a2dp@1.0::IBluetoothAudioOffload/default.
08-23 21:00:07.477  2138  2138 E light   : light_open lights bluetooth failed: -22
08-23 21:00:10.683  2323  2323 I getprop : type=1400 audit(0.0:19): avc: denied { open } for path="/dev/__properties__/u:object_r:bluetooth_a2dp_offload_prop:s0" dev="tmpfs" ino=2245 scontext=u:r:shell:s0 tcontext=u:object_r:bluetooth_a2dp_offload_prop:s0 tclass=file permissive=1
08-23 21:00:10.683  2323  2323 I getprop : type=1400 audit(0.0:20): avc: denied { getattr } for path="/dev/__properties__/u:object_r:bluetooth_a2dp_offload_prop:s0" dev="tmpfs" ino=2245 scontext=u:r:shell:s0 tcontext=u:object_r:bluetooth_a2dp_offload_prop:s0 tclass=file permissive=1
08-23 21:00:10.683  2323  2323 I getprop : type=1400 audit(0.0:21): avc: denied { open } for path="/dev/__properties__/u:object_r:bluetooth_audio_hal_prop:s0" dev="tmpfs" ino=2246 scontext=u:r:shell:s0 tcontext=u:object_r:bluetooth_audio_hal_prop:s0 tclass=file permissive=1
08-23 21:00:10.683  2323  2323 I getprop : type=1400 audit(0.0:22): avc: denied { getattr } for path="/dev/__properties__/u:object_r:bluetooth_audio_hal_prop:s0" dev="tmpfs" ino=2246 scontext=u:r:shell:s0 tcontext=u:object_r:bluetooth_audio_hal_prop:s0 tclass=file permissive=1
08-23 21:00:10.683  2323  2323 I getprop : type=1400 audit(0.0:23): avc: denied { open } for path="/dev/__properties__/u:object_r:bluetooth_prop:s0" dev="tmpfs" ino=2247 scontext=u:r:shell:s0 tcontext=u:object_r:bluetooth_prop:s0 tclass=file permissive=1
08-23 21:00:10.683  2323  2323 I getprop : type=1400 audit(0.0:24): avc: denied { getattr } for path="/dev/__properties__/u:object_r:bluetooth_prop:s0" dev="tmpfs" ino=2247 scontext=u:r:shell:s0 tcontext=u:object_r:bluetooth_prop:s0 tclass=file permissive=1
08-23 21:00:10.690  2323  2323 I getprop : type=1400 audit(0.0:79): avc: denied { open } for path="/dev/__properties__/u:object_r:exported_bluetooth_prop:s0" dev="tmpfs" ino=2297 scontext=u:r:shell:s0 tcontext=u:object_r:exported_bluetooth_prop:s0 tclass=file permissive=1
08-23 21:00:10.690  2323  2323 I getprop : type=1400 audit(0.0:80): avc: denied { getattr } for path="/dev/__properties__/u:object_r:exported_bluetooth_prop:s0" dev="tmpfs" ino=2297 scontext=u:r:shell:s0 tcontext=u:object_r:exported_bluetooth_prop:s0 tclass=file permissive=1
08-23 21:00:12.052  2124  2124 W Zygote  : Class not found for preloading: android.bluetooth.BluetoothA2dp$2
08-23 21:00:16.150  2428  2560 W PackageParser: Ignoring duplicate uses-permissions/uses-permissions-sdk-m: android.permission.READ_CONTACTS in package: com.android.bluetooth at: Binary XML file line #67
11-23 11:34:04.215  2126  2126 W Zygote  : Class not found for preloading: android.bluetooth.BluetoothA2dp$2
11-23 11:34:04.264  2428  2428 D BluetoothManagerService: Stored bluetooth Name=QUAD-CORE A133 c3,Address=01:42:D9:21:DE:89
11-23 11:34:05.973  2428  2484 I ActivityManager: app.processName = com.android.bluetooth
11-23 11:34:05.973  2428  2484 I ActivityManager: Start proc 2815:com.android.bluetooth/1002 for service {com.android.bluetooth/com.android.bluetooth.btservice.AdapterService}
11-23 11:34:06.715  2815  2815 I         : [1123/113406.715271:INFO:com_android_bluetooth_btservice_AdapterService.cpp(628)] hal_util_load_bt_library loaded HAL: btinterface=0x7c0cae5440, handle=0xe161d939f04fe2f3
11-23 11:34:06.793  2815  3020 I bt_btif_core: btif_init_bluetooth entered
11-23 11:34:06.794  2815  3020 I bt_stack_config: init attempt to load stack conf from /etc/bluetooth/bt_stack.conf
11-23 11:34:06.797  2815  3020 I bt_btif_core: btif_init_bluetooth finished
11-23 11:34:06.905  2815  2815 D BluetoothAdapterService: setAdapterService() - trying to set service to com.android.bluetooth.btservice.AdapterService@dba49b6
11-23 11:34:07.597  2428  2428 D BluetoothManagerService: BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
11-23 11:34:07.601  2428  2473 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@337c8b
11-23 11:34:07.608  2815  2836 D BluetoothAdapter: onBluetoothServiceUp: com.android.bluetooth.btservice.AdapterService$AdapterServiceBinder@d1c55c0
11-23 11:34:07.677  2815  2815 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@dba49b6
11-23 11:34:07.690  2815  2815 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@dba49b6
11-23 11:34:07.768  2815  2815 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@dba49b6
11-23 11:34:07.790  2131  2172 I android.hardware.bluetooth@1.0-impl: BluetoothHci::initialize()
11-23 11:34:07.800  2131  2172 E libbt_vendor: aicbt_load_stack_conf unable to open file '/vendor/etc/bluetooth/aicbt.conf': No such file or directory
11-23 11:34:07.800  2131  2172 E libbt_vendor: no config find from file '/vendor/etc/bluetooth/aicbt.conf'
11-23 11:34:07.804  2131  2172 D android.hardware.bluetooth@1.0-impl: Open vendor library loaded
11-23 11:34:07.800  2131  2131 I HwBinder:2131_1: type=1400 audit(0.0:130): avc: denied { create } for scontext=u:r:hal_bluetooth_default:s0 tcontext=u:r:hal_bluetooth_default:s0 tclass=udp_socket permissive=1
11-23 11:34:07.810  2131  2131 I HwBinder:2131_1: type=1400 audit(0.0:131): avc: denied { read } for name="/" dev="tmpfs" ino=7445 scontext=u:r:hal_bluetooth_default:s0 tcontext=u:object_r:device:s0 tclass=dir permissive=1
11-23 11:34:07.987  2131  3256 D android.hardware.bluetooth@1.0-impl: OnFirmwareConfigured result: 0
11-23 11:34:07.987  2131  3256 I android.hardware.bluetooth@1.0-impl: Firmware configured in 0.083s
11-23 11:34:07.987  2131  3256 I android.hardware.bluetooth@1.0-impl: OnFirmwareConfigured: lpm_timeout_ms 3000
11-23 11:34:07.987  2131  3256 D android.hardware.bluetooth@1.0-impl: low_power_mode_cb result: 0
11-23 11:34:07.987  2131  3256 D android.hardware.bluetooth@1.0-impl: OnFirmwareConfigured Calling StartLowPowerWatchdog()
11-23 11:34:08.123  2131  3250 E aic_heartbeat: load_aicbt_heartbeat_conf unable to open file '/vendor/etc/bluetooth/aicbt_heartbeat.conf': No such file or directory
11-23 11:34:08.202  2815  3028 I bt_btif_core: btif_enable_bluetooth_evt entered: status 0
11-23 11:34:08.207  2815  3028 I bt_btif_core: btif_enable_bluetooth_evt finished
11-23 11:34:08.233  2428  2428 D BluetoothManagerService: BluetoothServiceConnection: com.android.bluetooth.gatt.GattService
11-23 11:34:08.277  2815  2815 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@dba49b6
11-23 11:34:08.308  2815  2815 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@dba49b6
11-23 11:34:08.390  2815  2815 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@dba49b6
11-23 11:34:08.395  2815  2815 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@dba49b6
11-23 11:34:08.448  2815  3269 I chatty  : uid=1002(bluetooth) identical 2 lines
11-23 11:34:08.461  2815  2815 D A2dpService: setA2dpService(): set to: com.android.bluetooth.a2dp.A2dpService@938178f
11-23 11:34:08.468  2815  2815 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@dba49b6
11-23 11:34:08.478  2815  2815 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@dba49b6
11-23 11:34:08.492  2815  2815 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@dba49b6
11-23 11:34:08.504  2815  2815 D BluetoothMapAccountLoader: Found 0 application(s) with intent android.bluetooth.action.BLUETOOTH_MAP_PROVIDER
11-23 11:34:08.507  2815  2815 D BluetoothMapAccountLoader: Found 0 application(s) with intent android.bluetooth.action.BLUETOOTH_MAP_IM_PROVIDER
11-23 11:34:08.510  2815  2815 D BluetoothMapService: setBluetoothMapService(): set to: com.android.bluetooth.map.BluetoothMapService@d2994dd
11-23 11:34:08.512  2815  2815 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@dba49b6
11-23 11:34:08.529  2428  2639 D MediaSessionService: The callback android.media.session.ICallback$Stub$Proxy@901abf1 is set by com.android.bluetooth
11-23 11:34:08.532  2815  3269 I bt_stack: [INFO:connection_handler.cc(206)] virtual bool bluetooth::avrcp::ConnectionHandler::AvrcpConnect(bool, const RawAddress &): handle=0000 status= 000000
11-23 11:34:08.546  2815  2815 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@dba49b6
11-23 11:34:08.559  2815  2815 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@dba49b6
11-23 11:34:08.571  2815  2815 D BtOppService: setBluetoothOppService(): set to: com.android.bluetooth.opp.BluetoothOppService@b8a3ee4
11-23 11:34:08.575  2815  2815 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@dba49b6
11-23 11:34:08.587  2815  2815 D BluetoothPbapService: setBluetoothPbapService(): set to: com.android.bluetooth.pbap.BluetoothPbapService@d8c867c
11-23 11:34:12.107  3674  3674 D music_MediaPlaybackSer: OnGetRoot: clientPackageName=com.android.bluetooth; clientUid=1002 ; rootHints=null
11-23 11:34:12.172  3674  3674 D music_MediaPlaybackSer: OnGetRoot: clientPackageName=com.android.bluetooth; clientUid=1002 ; rootHints=null
11-23 11:36:11.909  2428  2639 D BluetoothManagerService: disable(): mBluetooth = android.bluetooth.IBluetooth$Stub$Proxy@337c8b mBinding = false
11-23 11:36:11.910  2428  2473 D BluetoothManagerService: MESSAGE_DISABLE: mBluetooth = android.bluetooth.IBluetooth$Stub$Proxy@337c8b
11-23 11:36:11.910  2428  2428 V SettingsProvider: Notifying for 0: content://settings/global/bluetooth_on
11-23 11:36:11.966  2428  3127 D MediaSessionService: The callback null is set by com.android.bluetooth
11-23 11:36:11.977  2815  2815 D BluetoothSocket: close() this: android.bluetooth.BluetoothSocket@57dc280, channel: 5, mSocketIS: android.net.LocalSocketImpl$SocketInputStream@6cf00b9, mSocketOS: android.net.LocalSocketImpl$SocketOutputStream@71dcfemSocket: android.net.LocalSocket@c44ac5f impl:android.net.LocalSocketImpl@63c86ac fd:java.io.FileDescriptor@dd5ef75, mSocketState: LISTENING
11-23 11:36:11.979  2815  2815 D BluetoothSocket: close() this: android.bluetooth.BluetoothSocket@c8acb0a, channel: 4099, mSocketIS: android.net.LocalSocketImpl$SocketInputStream@4b1af7b, mSocketOS: android.net.LocalSocketImpl$SocketOutputStream@7416198mSocket: android.net.LocalSocket@6230df1 impl:android.net.LocalSocketImpl@4928dd6 fd:java.io.FileDescriptor@321c857, mSocketState: LISTENING
11-23 11:36:11.988  2815  3412 D BluetoothSocket: close() this: android.bluetooth.BluetoothSocket@ab6ff44, channel: 4, mSocketIS: android.net.LocalSocketImpl$SocketInputStream@449982d, mSocketOS: android.net.LocalSocketImpl$SocketOutputStream@f81b162mSocket: android.net.LocalSocket@21092f3 impl:android.net.LocalSocketImpl@8c6cbb0 fd:java.io.FileDescriptor@8d48a29, mSocketState: LISTENING
11-23 11:36:11.991  2815  3412 D BluetoothSocket: close() this: android.bluetooth.BluetoothSocket@94d81ae, channel: 4097, mSocketIS: android.net.LocalSocketImpl$SocketInputStream@e176b4f, mSocketOS: android.net.LocalSocketImpl$SocketOutputStream@c4f2dcmSocket: android.net.LocalSocket@8029fe5 impl:android.net.LocalSocketImpl@5f40aba fd:java.io.FileDescriptor@a096d6b, mSocketState: LISTENING
11-23 11:36:11.999  2815  2815 W BtOppService: unregisterReceivers java.lang.IllegalArgumentException: Receiver not registered: com.android.bluetooth.opp.BluetoothOppService$3@15e6f4d
11-23 11:36:12.017  2815  3020 I bt_btif_core: btif_disable_bluetooth entered
11-23 11:36:12.019  2815  3020 I bt_btif_core: btif_disable_bluetooth finished
11-23 11:36:13.011  2428  2473 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@337c8b
11-23 11:36:13.013  2916  3587 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@1832417
11-23 11:36:13.013  2428  2473 D BluetoothManagerService: unbindAndFinish(): android.bluetooth.IBluetooth$Stub$Proxy@337c8b mBinding = false mUnbinding = false
11-23 11:36:13.013  2815  3380 D BluetoothAdapter: onBluetoothServiceDown: com.android.bluetooth.btservice.AdapterService$AdapterServiceBinder@d1c55c0
11-23 11:36:13.013  2788  2808 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@23f4100
11-23 11:36:13.022  2815  3028 I bt_btif_core: btif_disable_bluetooth_evt entered
11-23 11:36:13.024  2131  2172 I android.hardware.bluetooth@1.0-impl: BluetoothHci::close()
11-23 11:36:13.024  2131  2172 D android.hardware.bluetooth@1.0-impl: low_power_mode_cb result: 0
11-23 11:36:13.508  2815  3028 I bt_btif_core: btif_disable_bluetooth_evt finished
11-23 11:36:13.510  2815  3020 I bt_btif_core: btif_cleanup_bluetooth entered
11-23 11:36:13.512  2815  3020 I bt_btif_core: btif_cleanup_bluetooth finished
11-23 11:36:13.593  2428  4425 I ActivityManager: Process com.android.bluetooth (pid 2815) has died: fore SVC
11-23 11:36:22.299  2428  2484 I ActivityManager: app.processName = com.android.bluetooth
11-23 11:36:22.299  2428  2484 I ActivityManager: Start proc 4719:com.android.bluetooth/1002 for service {com.android.bluetooth/com.android.bluetooth.btservice.AdapterService}
11-23 11:36:22.524  4719  4719 I         : [1123/113622.524548:INFO:com_android_bluetooth_btservice_AdapterService.cpp(628)] hal_util_load_bt_library loaded HAL: btinterface=0x7c0cba4440, handle=0x18f04452a7b9dec5
11-23 11:36:22.547  4719  4755 I bt_btif_core: btif_init_bluetooth entered
11-23 11:36:22.548  4719  4755 I bt_stack_config: init attempt to load stack conf from /etc/bluetooth/bt_stack.conf
11-23 11:36:22.552  4719  4755 I bt_btif_core: btif_init_bluetooth finished
11-23 11:36:22.608  4719  4719 D BluetoothAdapterService: setAdapterService() - trying to set service to com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:36:22.616  2428  2428 D BluetoothManagerService: BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
11-23 11:36:22.617  2428  2473 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@766fd53
11-23 11:36:22.618  2916  3587 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@a9f9004
11-23 11:36:22.621  2788  2809 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@9e43e3f
11-23 11:36:22.623  4719  4740 D BluetoothAdapter: onBluetoothServiceUp: com.android.bluetooth.btservice.AdapterService$AdapterServiceBinder@31cbb43
11-23 11:36:22.674  4719  4719 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:36:22.680  4719  4719 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:36:22.712  4719  4719 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:36:22.722  2131  2172 I android.hardware.bluetooth@1.0-impl: BluetoothHci::initialize()
11-23 11:36:22.724  2131  2172 E libbt_vendor: aicbt_load_stack_conf unable to open file '/vendor/etc/bluetooth/aicbt.conf': No such file or directory
11-23 11:36:22.724  2131  2172 E libbt_vendor: no config find from file '/vendor/etc/bluetooth/aicbt.conf'
11-23 11:36:22.727  2131  2172 D android.hardware.bluetooth@1.0-impl: Open vendor library loaded
11-23 11:36:22.736  2131  4797 D android.hardware.bluetooth@1.0-impl: OnFirmwareConfigured result: 0
11-23 11:36:22.736  2131  4797 I android.hardware.bluetooth@1.0-impl: Firmware configured in 0.007s
11-23 11:36:22.746  2131  4797 I android.hardware.bluetooth@1.0-impl: OnFirmwareConfigured: lpm_timeout_ms 3000
11-23 11:36:22.746  2131  4797 D android.hardware.bluetooth@1.0-impl: low_power_mode_cb result: 0
11-23 11:36:22.746  2131  4797 D android.hardware.bluetooth@1.0-impl: OnFirmwareConfigured Calling StartLowPowerWatchdog()
11-23 11:36:22.723  2131  2131 I HwBinder:2131_1: type=1400 audit(0.0:139): avc: denied { create } for scontext=u:r:hal_bluetooth_default:s0 tcontext=u:r:hal_bluetooth_default:s0 tclass=udp_socket permissive=1
11-23 11:36:22.743  2131  2131 I HwBinder:2131_1: type=1400 audit(0.0:140): avc: denied { read } for name="/" dev="tmpfs" ino=7445 scontext=u:r:hal_bluetooth_default:s0 tcontext=u:object_r:device:s0 tclass=dir permissive=1
11-23 11:36:22.872  2131  4791 E aic_heartbeat: load_aicbt_heartbeat_conf unable to open file '/vendor/etc/bluetooth/aicbt_heartbeat.conf': No such file or directory
11-23 11:36:22.904  4719  4762 I bt_btif_core: btif_enable_bluetooth_evt entered: status 0
11-23 11:36:22.914  4719  4762 I bt_btif_core: btif_enable_bluetooth_evt finished
11-23 11:36:22.935  2428  2428 D BluetoothManagerService: BluetoothServiceConnection: com.android.bluetooth.gatt.GattService
11-23 11:36:22.940  2428  2428 V SettingsProvider: Notifying for 0: content://settings/global/bluetooth_on
11-23 11:36:22.953  4719  4719 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:36:22.958  4719  4719 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:36:22.982  4719  4719 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:36:22.991  4719  4719 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:36:23.042  4719  4802 I chatty  : uid=1002(bluetooth) identical 3 lines
11-23 11:36:23.055  4719  4719 D A2dpService: setA2dpService(): set to: com.android.bluetooth.a2dp.A2dpService@ba9ca1c
11-23 11:36:23.060  4719  4719 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:36:23.065  4719  4719 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:36:23.077  4719  4719 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:36:23.099  4719  4719 D BluetoothMapAccountLoader: Found 0 application(s) with intent android.bluetooth.action.BLUETOOTH_MAP_PROVIDER
11-23 11:36:23.103  4719  4719 D BluetoothMapAccountLoader: Found 0 application(s) with intent android.bluetooth.action.BLUETOOTH_MAP_IM_PROVIDER
11-23 11:36:23.108  4719  4719 D BluetoothMapService: setBluetoothMapService(): set to: com.android.bluetooth.map.BluetoothMapService@5fde852
11-23 11:36:23.114  4719  4719 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:36:23.129  2428  4425 D MediaSessionService: The callback android.media.session.ICallback$Stub$Proxy@9ed147c is set by com.android.bluetooth
11-23 11:36:23.130  4719  4802 I bt_stack: [INFO:connection_handler.cc(206)] virtual bool bluetooth::avrcp::ConnectionHandler::AvrcpConnect(bool, const RawAddress &): handle=0000 status= 000000
11-23 11:36:23.147  4719  4719 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:36:23.162  4719  4719 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:36:23.177  4719  4719 D BtOppService: setBluetoothOppService(): set to: com.android.bluetooth.opp.BluetoothOppService@dad0a02
11-23 11:36:23.180  4719  4719 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:36:23.197  4719  4719 D BluetoothPbapService: setBluetoothPbapService(): set to: com.android.bluetooth.pbap.BluetoothPbapService@dddd75a
11-23 11:36:23.470  4846  4846 D music_MediaPlaybackSer: OnGetRoot: clientPackageName=com.android.bluetooth; clientUid=1002 ; rootHints=null
11-23 11:36:23.496  4846  4846 D music_MediaPlaybackSer: OnGetRoot: clientPackageName=com.android.bluetooth; clientUid=1002 ; rootHints=null
11-23 11:36:26.267  2428  2473 W BluetoothManagerService: Unable to bind with intent: Intent { act=android.bluetooth.IBluetoothHeadset cmp=com.android.bluetooth/.hfp.HeadsetService }
11-23 11:36:30.464  2961  2961 D SettingsActivity: Switching to fragment com.android.settings.bluetooth.BluetoothPairingDetail
11-23 11:36:30.464  2961  2961 D SubSettings: Launching fragment com.android.settings.bluetooth.BluetoothPairingDetail
11-23 11:36:30.472  2961  2961 D PrefCtrlListHelper: Could not find Context-only controller for pref: com.android.settings.bluetooth.BluetoothDeviceRenamePreferenceController
11-23 11:39:36.865  2428  4314 D BluetoothManagerService: disable(): mBluetooth = android.bluetooth.IBluetooth$Stub$Proxy@766fd53 mBinding = false
11-23 11:39:36.868  2428  2428 V SettingsProvider: Notifying for 0: content://settings/global/bluetooth_on
11-23 11:39:36.873  2428  2473 D BluetoothManagerService: MESSAGE_DISABLE: mBluetooth = android.bluetooth.IBluetooth$Stub$Proxy@766fd53
11-23 11:39:36.948  4719  4719 D BluetoothSocket: close() this: android.bluetooth.BluetoothSocket@6cf00b9, channel: 5, mSocketIS: android.net.LocalSocketImpl$SocketInputStream@71dcfe, mSocketOS: android.net.LocalSocketImpl$SocketOutputStream@c44ac5fmSocket: android.net.LocalSocket@63c86ac impl:android.net.LocalSocketImpl@dd5ef75 fd:java.io.FileDescriptor@c8acb0a, mSocketState: LISTENING
11-23 11:39:36.954  4719  4719 D BluetoothSocket: close() this: android.bluetooth.BluetoothSocket@4b1af7b, channel: 4099, mSocketIS: android.net.LocalSocketImpl$SocketInputStream@7416198, mSocketOS: android.net.LocalSocketImpl$SocketOutputStream@6230df1mSocket: android.net.LocalSocket@4928dd6 impl:android.net.LocalSocketImpl@321c857 fd:java.io.FileDescriptor@ab6ff44, mSocketState: LISTENING
11-23 11:39:36.997  2428  4425 D MediaSessionService: The callback null is set by com.android.bluetooth
11-23 11:39:37.031  4719  4838 D BluetoothSocket: close() this: android.bluetooth.BluetoothSocket@f81b162, channel: 4, mSocketIS: android.net.LocalSocketImpl$SocketInputStream@21092f3, mSocketOS: android.net.LocalSocketImpl$SocketOutputStream@8c6cbb0mSocket: android.net.LocalSocket@8d48a29 impl:android.net.LocalSocketImpl@94d81ae fd:java.io.FileDescriptor@e176b4f, mSocketState: LISTENING
11-23 11:39:37.032  4719  4838 D BluetoothSocket: close() this: android.bluetooth.BluetoothSocket@c4f2dc, channel: 4097, mSocketIS: android.net.LocalSocketImpl$SocketInputStream@8029fe5, mSocketOS: android.net.LocalSocketImpl$SocketOutputStream@5f40abamSocket: android.net.LocalSocket@a096d6b impl:android.net.LocalSocketImpl@11c60c8 fd:java.io.FileDescriptor@1425561, mSocketState: LISTENING
11-23 11:39:37.060  4719  4719 W BtOppService: unregisterReceivers java.lang.IllegalArgumentException: Receiver not registered: com.android.bluetooth.opp.BluetoothOppService$3@b460f13
11-23 11:39:37.093  4719  4755 I bt_btif_core: btif_disable_bluetooth entered
11-23 11:39:37.099  4719  4755 I bt_btif_core: btif_disable_bluetooth finished
11-23 11:39:38.075  2428  2473 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@766fd53
11-23 11:39:38.075  2961  3536 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@4fdcc7c
11-23 11:39:38.075  2788  4856 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@9e43e3f
11-23 11:39:38.075  2428  2473 D BluetoothManagerService: unbindAndFinish(): android.bluetooth.IBluetooth$Stub$Proxy@766fd53 mBinding = false mUnbinding = false
11-23 11:39:38.075  2916  3587 D BluetoothAdapter: onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@a9f9004
11-23 11:39:38.075  4719  4859 D BluetoothAdapter: onBluetoothServiceDown: com.android.bluetooth.btservice.AdapterService$AdapterServiceBinder@31cbb43
11-23 11:39:38.099  4719  4762 E BluetoothAdapterService: Repeated wake lock release; aborting release: bluetooth_timer
11-23 11:39:38.100  4719  4762 I bt_btif_core: btif_disable_bluetooth_evt entered
11-23 11:39:38.101  2131  4812 I android.hardware.bluetooth@1.0-impl: BluetoothHci::close()
11-23 11:39:38.101  2131  4812 D android.hardware.bluetooth@1.0-impl: low_power_mode_cb result: 0
11-23 11:39:38.973  4719  4762 I bt_btif_core: btif_disable_bluetooth_evt finished
11-23 11:39:38.976  4719  4755 I bt_btif_core: btif_cleanup_bluetooth entered
11-23 11:39:38.978  4719  4755 I bt_btif_core: btif_cleanup_bluetooth finished
11-23 11:39:39.085  2428  3014 I ActivityManager: Process com.android.bluetooth (pid 4719) has died: psvc PER
11-23 11:39:39.087  2428  3014 W ActivityManager: Scheduling restart of crashed service com.android.bluetooth/.btservice.AdapterService in 1000ms
11-23 11:39:40.117  2428  2484 I ActivityManager: app.processName = com.android.bluetooth
11-23 11:39:40.117  2428  2484 I ActivityManager: Start proc 14877:com.android.bluetooth/1002 for service {com.android.bluetooth/com.android.bluetooth.btservice.AdapterService}
11-23 11:39:40.331 14877 14877 I         : [1123/113940.330742:INFO:com_android_bluetooth_btservice_AdapterService.cpp(628)] hal_util_load_bt_library loaded HAL: btinterface=0x7c0baa4440, handle=0xc80620b44be4bbf3
11-23 11:39:40.368 14877 14913 I bt_btif_core: btif_init_bluetooth entered
11-23 11:39:40.368 14877 14913 I bt_stack_config: init attempt to load stack conf from /etc/bluetooth/bt_stack.conf
11-23 11:39:40.376 14877 14913 I bt_btif_core: btif_init_bluetooth finished
11-23 11:39:40.448 14877 14877 D BluetoothAdapterService: setAdapterService() - trying to set service to com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:39:40.457  2428  2428 D BluetoothManagerService: BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
11-23 11:39:40.464 14877 14899 D BluetoothAdapter: onBluetoothServiceUp: com.android.bluetooth.btservice.AdapterService$AdapterServiceBinder@31cbb43
11-23 11:39:40.464  2961  2986 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@fd9219c
11-23 11:39:40.465  2428  2473 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@2e4718a
11-23 11:39:40.465  2916  3587 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@ae9b9ed
11-23 11:39:40.466  2788  4856 D BluetoothAdapter: onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@229397
11-23 11:39:40.512 14877 14877 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:39:40.519 14877 14877 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:39:40.564 14877 14877 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:39:40.586  2131  2131 I HwBinder:2131_2: type=1400 audit(0.0:142): avc: denied { create } for scontext=u:r:hal_bluetooth_default:s0 tcontext=u:r:hal_bluetooth_default:s0 tclass=udp_socket permissive=1
11-23 11:39:40.586  2131  2131 I HwBinder:2131_2: type=1400 audit(0.0:143): avc: denied { read } for name="/" dev="tmpfs" ino=7445 scontext=u:r:hal_bluetooth_default:s0 tcontext=u:object_r:device:s0 tclass=dir permissive=1
11-23 11:39:40.585  2131  4812 I android.hardware.bluetooth@1.0-impl: BluetoothHci::initialize()
11-23 11:39:40.588  2131  4812 E libbt_vendor: aicbt_load_stack_conf unable to open file '/vendor/etc/bluetooth/aicbt.conf': No such file or directory
11-23 11:39:40.588  2131  4812 E libbt_vendor: no config find from file '/vendor/etc/bluetooth/aicbt.conf'
11-23 11:39:40.591  2131  4812 D android.hardware.bluetooth@1.0-impl: Open vendor library loaded
11-23 11:39:40.764  2131 14965 D android.hardware.bluetooth@1.0-impl: OnFirmwareConfigured result: 0
11-23 11:39:40.764  2131 14965 I android.hardware.bluetooth@1.0-impl: Firmware configured in 0.039s
11-23 11:39:40.764  2131 14965 I android.hardware.bluetooth@1.0-impl: OnFirmwareConfigured: lpm_timeout_ms 3000
11-23 11:39:40.764  2131 14965 D android.hardware.bluetooth@1.0-impl: low_power_mode_cb result: 0
11-23 11:39:40.764  2131 14965 D android.hardware.bluetooth@1.0-impl: OnFirmwareConfigured Calling StartLowPowerWatchdog()
11-23 11:39:40.830  2131 14959 E aic_heartbeat: load_aicbt_heartbeat_conf unable to open file '/vendor/etc/bluetooth/aicbt_heartbeat.conf': No such file or directory
11-23 11:39:40.895 14877 14920 I bt_btif_core: btif_enable_bluetooth_evt entered: status 0
11-23 11:39:40.901 14877 14920 I bt_btif_core: btif_enable_bluetooth_evt finished
11-23 11:39:40.961  2428  2428 D BluetoothManagerService: BluetoothServiceConnection: com.android.bluetooth.gatt.GattService
11-23 11:39:40.967  2428  2428 V SettingsProvider: Notifying for 0: content://settings/global/bluetooth_on
11-23 11:39:40.977 14877 14877 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:39:40.982 14877 14877 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:39:41.005 14877 14877 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:39:41.009 14877 14877 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:39:41.034 14877 14970 I chatty  : uid=1002(bluetooth) bt_main_thread identical 3 lines
11-23 11:39:41.040 14877 14877 D A2dpService: setA2dpService(): set to: com.android.bluetooth.a2dp.A2dpService@ba9ca1c
11-23 11:39:41.043 14877 14877 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:39:41.047 14877 14877 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:39:41.055 14877 14877 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:39:41.063 14877 14877 D BluetoothMapAccountLoader: Found 0 application(s) with intent android.bluetooth.action.BLUETOOTH_MAP_PROVIDER
11-23 11:39:41.064 14877 14877 D BluetoothMapAccountLoader: Found 0 application(s) with intent android.bluetooth.action.BLUETOOTH_MAP_IM_PROVIDER
11-23 11:39:41.066 14877 14877 D BluetoothMapService: setBluetoothMapService(): set to: com.android.bluetooth.map.BluetoothMapService@5fde852
11-23 11:39:41.071 14877 14877 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:39:41.079  2428  3214 D MediaSessionService: The callback android.media.session.ICallback$Stub$Proxy@b4e5a7c is set by com.android.bluetooth
11-23 11:39:41.080 14877 14970 I bt_stack: [INFO:connection_handler.cc(206)] virtual bool bluetooth::avrcp::ConnectionHandler::AvrcpConnect(bool, const RawAddress &): handle=0000 status= 000000
11-23 11:39:41.088 14877 14877 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:39:41.096 14877 14877 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:39:41.103 14877 14877 D BtOppService: setBluetoothOppService(): set to: com.android.bluetooth.opp.BluetoothOppService@dad0a02
11-23 11:39:41.107 14877 14877 D BluetoothAdapterService: getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@38b06b7
11-23 11:39:41.114 14877 14877 D BluetoothPbapService: setBluetoothPbapService(): set to: com.android.bluetooth.pbap.BluetoothPbapService@dddd75a
11-23 11:39:41.160  4846  4846 D music_MediaPlaybackSer: OnGetRoot: clientPackageName=com.android.bluetooth; clientUid=1002 ; rootHints=null
11-23 11:39:41.230  4846  4846 D music_MediaPlaybackSer: OnGetRoot: clientPackageName=com.android.bluetooth; clientUid=1002 ; rootHints=null
11-23 11:39:42.411  2961  2961 D SettingsActivity: Switching to fragment com.android.settings.bluetooth.BluetoothPairingDetail
11-23 11:39:42.411  2961  2961 D SubSettings: Launching fragment com.android.settings.bluetooth.BluetoothPairingDetail
11-23 11:39:42.414  2961  2961 D PrefCtrlListHelper: Could not find Context-only controller for pref: com.android.settings.bluetooth.BluetoothDeviceRenamePreferenceController
#4 2025-02-07 13:46:09
Johnohhh1
Did you figure this out I have been dealing with this with H618 Android 12 build (Apolo p2 user debug) I thought it was a config issue because it was set to Box True. But the Modules we not loaded in Make config. Had to add module the find modules.order and add AIC8800 to the modules.order still working some things out. if you are already build then look at slevated pris apps like awsettingsmanager you might m=beable to change it there or get root mount read write nano the settings xml and hack it in that way. also I had a little pwnagotchi that would never stay connected via bt and it was one mispelled word in an obscure bt file that was killing the whole thing.
#5 2025-04-17 11:57:04
frank.zheng
在 TIAN SDK 4.0 上是可以的,SDK 5.0 上加载失败, root@TinaLinux:/lib/modules/4.9.191# insmod aic8800_fdrv.ko
[ 1454.043548] >>> rwnx_mod_init()
[ 1454.047074] rwnx 20220429-6.4.3.0 - - 241c091M (master)
[ 1454.052913] Driver Release Tag: aic-rwnx-sdio-20220429-6.4.3.0
[ 1454.059427] aicbsp: aicbsp_set_subsys, subsys: AIC_WIFI, state to: 1
[ 1454.066513] aicbsp: aicbsp_set_subsys, power state change to 1 dure to AIC_WIFI
[ 1454.074654] aicbsp: aicbsp_platform_power_on
[ 1454.079440] sunxi-wlan soc@03000000:wlan@0: bus_index: 1
[ 1454.145670] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1454.155947] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
[ 1454.180242] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1454.209078] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[ 1454.215841] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
[ 1454.221768] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1454.234878] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1454.247414] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[ 1454.254087] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[ 1454.260750] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[ 1454.267409] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
[ 1454.273243] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 1456.179404] aicbsp: aicbsp_set_subsys, fail to set AIC_WIFI power state to 1
[ 1456.187263] rwnx_mod_init, set power on fail!
failed to insert aic8800_fdrv.ko
#6 2025-04-17 11:57:49
frank.zheng
root@TinaLinux:/lib/modules/4.9.191# insmod aic8800_bsp.ko
[ 1405.822246] aicbsp_init
[ 1405.825007] aicbsp_init, Driver Release Tag: aic-bsp-sdio-20220429
[ 1405.833010] -->aicbt_rfkill_init
[ 1405.836648] <--aicbt_rfkill_init
root@TinaLinux:/lib/modules/4.9.191# insmod aic8800_btlpm.ko
[ 1418.219174] [BT_LPM] bluesleep_init: BlueSleep Mode Driver Ver 1.3.3
[ 1418.226286] [BT_LPM] bluesleep_init: Driver Release Tag: aic-btlpm-20220429
[ 1418.234615] [BT_LPM] bluesleep_probe: bt_hostwake gpio=363 assert=0
[ 1418.234615]
[ 1418.243525] [BT_LPM] bluesleep_probe: bt_wake gpio=359 assert=0
[ 1418.243525]
[ 1418.251784] [BT_LPM] bluesleep_probe: uart_index (1)
[ 1418.251784]
insmod aic8800_bsp.ko 和 insmod aic8800_btlpm.ko  这个看上去是OK的
#7 2025-07-26 23:03:30
donny681
首先要分析可以看下有没有/dev/ttyAS1节点,没有的话看配置串口dts,有的话然后用逻辑分析仪分析,看看有没有串口数据。
如果逻辑分析仪有串口数据的话,可以看一下是不是dts btlmp节点是不是配置管脚错了。
这个跟aic8800_fdrv.ko半条线关系都没有。
