楼主 # 2024-12-21 02:28:15
Run
SoniTranslate?
Who knows, what can be?
After installing my own RVC2 voice model, the script abruptly stops and shuts down almost at the end of the processing (around 70-95%). However, the same model works perfectly in the “Test RVC” section.
Here’s a portion of the terminal log:
1st
[INFO] >> Loading weights/vihrov.pth gin_channels: 256 self.spk_embed_dim: 109 [INFO] >> Loading vocal pitch estimator model Progress:  96%|██████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████▎      | 27/28 [00:29<00:00,  1.15it/s]
2nd
[INFO] >> Apply acceleration [INFO] >> Content in 'audio2/audio/' removed. 28it [00:02, 13.19it/s] [INFO] >> Applying customized voices... [INFO] >> Parallel workers: 1 Progress:   0%|        | 0/28 [00:00<?, ?it/s][INFO] >> Loading weights/vihrov.pth gin_channels: 256 self.spk_embed_dim: 109 [INFO] >> Loading vocal pitch estimator model Progress:  46%|███████████████████████████████████████████████████████████████████████████████████████▊        | 13/28 [00:16<00:11,  1.29it/s] (sonitr) D:\W\SoniTranslate-main>
After it, scripts stops work without any warrnings
