楼主 # 2024-10-10 16:05:35
hzqlz
已发帖子: 173
请教如何定位D133程序崩溃的位置
日志如下:
CPU Exception: NO.7
x1: 40026450    x2: 30081610    x3: 30048620    x4: deadbeef
x5: deadbeef    x6: 00000000    x7: deadbeef    x8: 30075bb4
x9: 80006088    x10: 80006080   x11: 3004bb14   x12: 00000003
x13: 00000002   x14: 80100400   x15: 80100400   x16: 30081724
x17: 00000000   x18: 300811ec   x19: 30049e38   x20: 30049d38
x21: 30049d28   x22: 30075bd0   x23: 00000000   x24: deadbeef
x25: deadbeef   x26: deadbeef   x27: deadbeef   x28: deadbeef
x29: deadbeef   x30: deadbeef   x31: deadbeef
mcause : 30000007
mtval  : 00000000
mepc   : 400002e6
mstatus: 80007800
#1 2024-10-11 17:49:06
AICxia
Re: 请教如何定位D133程序崩溃的位置
您好,有更加详细的信息吗,是在什么环境情况下发生的
#2 2024-10-12 16:42:40
海石生风
已发帖子: 767
目前来说比较好的手段是连接jtag调试器来调试,不然真不好找CPU异常出处。除非异常发生于系统启动阶段,此时可以打log调试。
建议官方将CmBacktrace移植到RISC-V,方便追踪程序崩溃位置。
#3 2024-10-14 09:39:09
已发帖子: 1,409
不用硬件调试器行不行啊?
像linux那样,可以通过usb或网口进行gdb调试就好了。
楼主 #4 2024-10-14 17:40:31
hzqlz
已发帖子: 173
AICxia 说:
我使用SD卡存放ttf字库,写了一个非常简单的测试demo,代码如下:
void user_ttf_init(void)
    static lv_ft_info_t info;
    rt_kprintf("=================> user_ttf_init\n");
    //rt_thread_mdelay(5000);
    /*FreeType uses C standard file system, so no driver letter is required.*/
    //info.name = "/rodata/font.ttf";
    info.name = "/sdcard/font/font.ttf";
    info.weight = 64;
    info.style = FT_FONT_STYLE_NORMAL;
    info.mem = NULL;
    if (!lv_ft_font_init(&info))
        rt_kprintf("font create failed.\n");
        return;
        rt_kprintf("font create success.\n");
    /*Create style with the new font*/
    static lv_style_t style;
    lv_style_init(&style);
    lv_style_set_text_font(&style, info.font);
    lv_style_set_text_align(&style, LV_TEXT_ALIGN_CENTER);
    /*Create a label with the new style*/
    lv_obj_t *label = lv_label_create(lv_scr_act());
    lv_obj_add_style(label, &style, 0);
    lv_label_set_text(label, "你好啊");
    lv_obj_center(label);
// INIT_APP_EXPORT(user_ttf_init);
MSH_CMD_EXPORT(user_ttf_init, test free type);
使用串口命令运行user_ttf_init,结果打印如下日志:
[Error] (16.537, +16039)         get_glyph_dsc_cb_cache: ImageCache_Lookup error        (in lv_freetype.c line #307)
[Error] (16.588, +51)    _lv_inv_area: detected modifying dirty areas in render         (in lv_refr.c line #217)
[Error] (16.598, +10)    _lv_inv_area: detected modifying dirty areas in render         (in lv_refr.c line #217)
[Error] (16.607, +9)     _lv_inv_area: detected modifying dirty areas in render         (in lv_refr.c line #217)
[Error] (16.634, +27)    get_glyph_dsc_cb_cache: ImageCache_Lookup error        (in lv_freetype.c line [Error]  (16.658, in lv_freetype.c line #307)
CPU Exception: NO.4
x1: 400c553a    x2: 3004e6c0    x3: 300423bc    x4: deadbeef
x5: 400024b8    x6: 0000003b    x7: 300900a0    x8: 3004e760
x9: 00004f60    x10: 00000032   x11: 3004e708   x12: 3004e6f4
x13: 0000597d   x14: 00000003   x15: 00000001   x16: 00000080
x17: 0000003b   x18: 3004f8a4   x19: 3004f8b8   x20: 0000597d
x21: 3004f8b8   x22: 00000000   x23: 00000000   x24: 00000001
x25: 00000023   x26: 00004f60   x27: 00000020   x28: 00000039
x29: 000032a8   x30: 00000000   x31: 30079f10
mcause : 38000004
mtval  : 000000be
mepc   : 400564fe
mstatus: 80007880
重要的是要掌握解决此类问题的方法,如果能有一个类似《ESP8266重启原因以及常见Fatal Exceptionܻ原因》的文档,那就非常棒了,麻烦大佬帮忙指点一下,谢谢!
楼主 #5 2024-10-14 17:42:30
hzqlz
已发帖子: 173
海石生风 说:
我之前习惯用串口日志定位问题,大佬的方法的确是个不错的选择,我学习一下怎么用jtag仿真,感谢指点
楼主 #6 2024-10-14 17:43:33
hzqlz
已发帖子: 173
Gentlepig 说:
不用硬件调试器行不行啊?
基础太差了,还不了解这方法,我学习一下,谢谢大佬提供思路
楼主 #7 2024-10-14 17:47:16
hzqlz
已发帖子: 173
AICxia 说:
奇怪的是,字库放在SPI FLASH里面就可以正常显示,放到SD卡就出问题了
#8 2024-10-15 17:38:06
已发帖子: 1,409
hzqlz 说:
Gentlepig 说:
不用硬件调试器行不行啊?
我是说如果rtt也能像linux那样可以通过usb或网口进行gdb调试就好了。
楼主 #9 2024-10-16 16:44:10
hzqlz
已发帖子: 173
我把矢量字体的weight改为72,出现tshell stack overflow,然后我把tshell的任务堆栈给大一点,现在又出现LVGL stack overflow,一环扣一环,头大tshell_stack_overflow.jpg
楼主 #10 2024-10-16 16:52:07
hzqlz
已发帖子: 173
胆子放大一点,把tshell和LVGL任务堆栈都调到40960,显示正常了,但是显示速度有点慢,有什么办法提速吗,矢量字库是放在TF卡的
最近编辑记录 hzqlz (2024-10-16 16:55:20)
#11 2024-12-21 11:35:13
wxlinus
toolchain_gcc_t-head_windows/bin/riscv64-unknown-elf-addr2line -a a0037f4e -e ./build/build_out/Project_basic_bl616.elf
以前用博牛的芯片可以通过这个方法获取 但是这个芯片是打包成img不知道能不能用
#12 2024-12-22 15:26:37
资本家大善人
已发帖子: 193
addr2line,gdb,coredump
楼主 #13 2024-12-22 15:37:07
hzqlz
已发帖子: 173
wxlinus 说:
感谢大佬指点,编译会产生.elf文件,等下次出现异常我试下这个方法
楼主 #14 2024-12-22 15:38:00
hzqlz
已发帖子: 173
资本家大善人 说:
感谢感谢,我经验太浅了,向大佬们学习
#15 2024-12-23 14:55:16
wakuwadu
海石生风 说:
官方已经移植了一个RVBacktrace了,之前看到群里发过相关培训的邀请
#16 2024-12-24 08:38:08
staunchheart
已发帖子: 232
用BL616调试时
比如异常
exception_entry
mcause=38000006
mepc:a00b9946
mtval:00000121
Store/AMO address misaligned
得到
mepc:a00b9946
./riscv64-unknown-elf-addr2line -a a00b9946 -e  debug\xxxxx.elf
D131应该也可以这样调吧,不过有的错误,通过这个也分析不出来,报错的行未必是引发的地方。
