楼主 # 2024-12-26 16:40:09
wdawd
V3s nor flash 报错 USB0: musb_init_controller failed with status -22
完整log,求大佬指正
U-Boot SPL 2017.01-rc2-00073-gdd6e8740dc-dirty (Dec 26 2024 - 01:19:55)
DRAM: 64 MiB
Trying to boot from sunxi SPI
U-Boot 2017.01-rc2-00073-gdd6e8740dc-dirty (Dec 26 2024 - 01:19:55 +0000) Allwinner Technology
Model: Lichee Pi Zero
DRAM:  64 MiB
MMC:   SUNXI SD/MMC: 0
SF: Detected mx25l25635f with page size 256 Bytes, erase size 64 KiB, total 32 MiB
In:    serial@01c28000
Out:   serial@01c28000
Err:   serial@01c28000
DRAM:  64 MiB
In:    serial@01c28000
Net:   phy interface0
eth0: ethernet@1c30000
probe failed, error -5
USB error: all controllers failed lowlevel init
   Loading Device Tree to 42dfa000, end 42dfffd9 ... OK
[    0.000000] Linux version 5.2.0-licheepi-zero+ (linux@linux) (gcc version 7.5.0 (Linaro GCC 7.5-2019.12)) #18 SMP Thu Dec 26 16:06:08 CST 2024
[    0.000000] percpu: Embedded 16 pages/cpu s34508 r8192 d22836 u65536
[    0.000000] Kernel command line: console=ttyS0,115200 earlyprintk panic=5 rootwait mtdparts=spi0.0:1M(uboot)ro,64k(dtb)ro,4M(kernel)ro,-(rootfs) root=31:03 rw rootfstype=jffs2
[    0.000000] Memory: 55060K/65536K available (6144K kernel code, 284K rwdata, 1672K rodata, 1024K init, 252K bss, 10476K reserved, 0K cma-reserved, 0K highmem)
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] random: get_random_bytes called from start_kernel+0x2f8/0x484 with crng_init=0
[    0.000198] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000439] Console: colour dummy device 80x30
[    0.000497] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000514] pid_max: default: 32768 minimum: 301
[    0.000676] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.000694] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.001483] CPU: Testing write buffer coherency: ok
[    0.001989] /cpus/cpu@0 missing clock-frequency property
[    0.002016] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.002835] Setting up static identity map for 0x40100000 - 0x40100060
[    0.003050] rcu: Hierarchical SRCU implementation.
[    0.003583] smp: Bringing up secondary CPUs ...
[    0.003603] smp: Brought up 1 node, 1 CPU
[    0.003612] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[    0.003619] CPU: All CPU(s) started in SVC mode.
[    0.004698] devtmpfs: initialized
[    0.008189] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.008508] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.008538] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[    0.008781] pinctrl core: initialized pinctrl subsystem
[    0.009809] NET: Registered protocol family 16
[    0.010413] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.011668] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.011687] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.035754] SCSI subsystem initialized
[    0.036036] usbcore: registered new interface driver usbfs
[    0.036091] usbcore: registered new interface driver hub
[    0.036198] usbcore: registered new device driver usb
[    0.036434] mc: Linux media interface: v0.10
[    0.036474] videodev: Linux video capture interface: v2.00
[    0.037925] clocksource: Switched to clocksource arch_sys_counter
[    0.049958] NET: Registered protocol family 2
[    0.050763] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    0.050802] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.050826] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[    0.050849] TCP: Hash tables configured (established 1024 bind 1024)
[    0.050993] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.051043] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.051365] NET: Registered protocol family 1
[    0.053229] Initialise system trusted keyrings
[    0.053602] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[    0.059841] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    0.097203] Key type asymmetric registered
[    0.097225] Asymmetric key parser 'x509' registered
[    0.097340] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    0.097354] io scheduler mq-deadline registered
[    0.097363] io scheduler kyber registered
[    0.098577] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO
[    0.102273] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.171857] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.174202] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pb not found, using dummy regulator
[    0.175262] printk: console [ttyS0] disabled
[    0.195570] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 36, base_baud = 1500000) is a U6_16550A
[    0.708183] printk: console [ttyS0] enabled
[    0.738352] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
[    0.750004] m25p80 spi0.0: mx25l25635e (32768 Kbytes)
[    0.755092] 4 cmdlinepart partitions found on MTD device spi0.0
[    0.761079] Creating 4 MTD partitions on "spi0.0":
[    0.765876] 0x000000000000-0x000000100000 : "uboot"
[    0.771567] 0x000000100000-0x000000110000 : "dtb"
[    0.776792] 0x000000110000-0x000000510000 : "kernel"
[    0.782396] 0x000000510000-0x000002000000 : "rootfs"
[    0.788531] libphy: Fixed MDIO Bus: probed
[    0.793200] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[    0.799093] dwmac-sun8i 1c30000.ethernet: No regulator found
[    0.805293] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 148000 (expect 58000)
[    0.814781] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[    0.822018] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[    0.829247] dwmac-sun8i 1c30000.ethernet: COE Type 2
[    0.834208] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[    0.841000] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[    0.846652] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[    0.852557] libphy: stmmac: probed
[    0.856680] dwmac-sun8i 1c30000.ethernet: Found internal PHY node
[    0.863034] libphy: mdio_mux: probed
[    0.866637] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY
[    0.873038] dwmac-sun8i 1c30000.ethernet: Powering internal PHY
[    0.880196] libphy: mdio_mux: probed
[    0.884108] PPP generic driver version 2.4.2
[    0.888916] usbcore: registered new interface driver cdc_ether
[    0.894790] usbcore: registered new interface driver rndis_host
[    0.900876] usbcore: registered new interface driver zaurus
[    0.906460] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.913016] ehci-platform: EHCI generic platform driver
[    0.918557] ehci-platform 1c1a000.usb: EHCI Host Controller
[    0.924171] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[    0.932173] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000
[    0.967915] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    0.975108] hub 1-0:1.0: USB hub found
[    0.979078] hub 1-0:1.0: 1 port detected
[    0.983740] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.990069] ohci-platform: OHCI generic platform driver
[    0.995615] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    1.002337] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[    1.010328] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400
[    1.083022] hub 2-0:1.0: USB hub found
[    1.086868] hub 2-0:1.0: 1 port detected
[    1.094201] usbcore: registered new interface driver cdc_acm
[    1.099969] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    1.108070] usbcore: registered new interface driver cdc_wdm
[    1.113838] usbcore: registered new interface driver usbserial_generic
[    1.120475] usbserial: USB Serial support registered for generic
[    1.126519] usbcore: registered new interface driver option
[    1.132181] usbserial: USB Serial support registered for GSM modem (1-port)
[    1.139338] usbcore: registered new interface driver usb_serial_simple
[    1.145918] usbserial: USB Serial support registered for carelink
[    1.152084] usbserial: USB Serial support registered for zio
[    1.157764] usbserial: USB Serial support registered for funsoft
[    1.163814] usbserial: USB Serial support registered for flashloader
[    1.170205] usbserial: USB Serial support registered for google
[    1.176153] usbserial: USB Serial support registered for libtransistor
[    1.182720] usbserial: USB Serial support registered for vivopay
[    1.188759] usbserial: USB Serial support registered for moto_modem
[    1.195038] usbserial: USB Serial support registered for motorola_tetra
[    1.201694] usbserial: USB Serial support registered for novatel_gps
[    1.208078] usbserial: USB Serial support registered for hp4x
[    1.213839] usbserial: USB Serial support registered for suunto
[    1.219791] usbserial: USB Serial support registered for siemens_mpi
[    1.226757] udc-core: couldn't find an available UDC - added [g_ether] to list of pending drivers
[    1.236454] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input0
[    1.246288] sun6i-rtc 1c20400.rtc: registered as rtc0
[    1.251476] sun6i-rtc 1c20400.rtc: RTC enabled
[    1.256096] i2c /dev entries driver
[    1.261075] input: ns2009_ts as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0048/input/input1
[    1.270890] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    1.279609] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
[    1.316092] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[    1.323406] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
[    1.359793] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB
[    1.367855] usbcore: registered new interface driver usbhid
[    1.373521] usbhid: USB HID core driver
[    1.377994] Initializing XFRM netlink socket
[    1.382306] NET: Registered protocol family 17
[    1.387377] Registering SWP/SWPB emulation handler
[    1.393437] Loading compiled-in X.509 certificates
[    1.404635] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    1.416192] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    1.422045] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[    1.431475] hub 3-0:1.0: USB hub found
[    1.435440] hub 3-0:1.0: 1 port detected
[    1.440747] using random self ethernet address
[    1.445201] using random host ethernet address
[    1.450360] usb0: HOST MAC 12:9c:f0:3e:ad:4f
[    1.454687] usb0: MAC b6:7a:5c:ef:71:96
[    1.458649] using random self ethernet address
[    1.463095] using random host ethernet address
[    1.467623] g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
[    1.474273] g_ether gadget: g_ether ready
[    1.478812] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01T06:53:24 UTC (24804)
[    1.487378] vcc5v0: disabling
[    1.492701] random: fast init done
[    1.515033] mmc1: queuing unknown CIS tuple 0x01 (3 bytes)
[    1.540214] mmc1: queuing unknown CIS tuple 0x1a (5 bytes)
[    1.549245] random: crng init done
[    1.560854] mmc1: queuing unknown CIS tuple 0x1b (8 bytes)
[    1.572614] mmc1: queuing unknown CIS tuple 0x80 (1 bytes)
[    1.582774] mmc1: queuing unknown CIS tuple 0x81 (1 bytes)
[    1.592160] mmc1: queuing unknown CIS tuple 0x82 (1 bytes)
[    1.600082] mmc1: new high speed SDIO card at address 0001
[    7.527354] VFS: Mounted root (jffs2 filesystem) on device 31:3.
[    7.534716] devtmpfs: mounted
[    7.538929] Freeing unused kernel memory: 1024K
[    7.543622] Run /sbin/init as init process
Starting logging: OK
Starting mdev...
/etc/init.d/S10mdev: line 21: can't create /proc/sys/kernel/hotplug: nonexistent directory
Starting network: OK
