楼主 # 2025-02-05 23:10:32
kmmyk
已发帖子: 45
F1C200s,C文件里定义全局数据,超过1K就读不到数组里的数据
如果数组小于1K,程序正常,能收到串口发送的数据
但如果大于1K,串口收到的数据就为0
请问,这与连接文件有关系吗?链接文件如下:
OUTPUT_FORMAT("elf32-littlearm", "elf32-bigarm", "elf32-littlearm")
OUTPUT_ARCH(arm)
ENTRY(_image_start)
STACK_UND_SIZE = 0x100;
STACK_ABT_SIZE = 0x100;
STACK_IRQ_SIZE = 0x100;
STACK_FIQ_SIZE = 0x100;
STACK_SVC_SIZE = 0x400;
HEAP_SIZE = 0x00100;
MEMORY
sram : org = 0x00000000, len = 128K
SECTIONS
.text :
PROVIDE(__image_start = .);
*(.image_header)
PROVIDE(__text_start = .);
*(.vectors)
(.text)
PROVIDE(__text_end = .);
} > sram
#1 2025-02-06 00:40:17
aozima
已发帖子: 488
Re: F1C200s,C文件里定义全局数据,超过1K就读不到数组里的数据
SVC_SIZE = 0x400;
栈溢出了吧?看下你代码中这数据是在全局还是在栈中?
