楼主 # 2025-02-12 16:13:57
kedren
求固件,全志A40I,sun8iw11p1
[     0.33]HELLO! BOOT0 is starting!
[     0.37]boot0 commit : f9c9977c4b0831d470ee78e31aac15ce486185f7
[     0.44]boot0 version : 4.0
[     0.47]set pll start
[     0.51]set pll end
[     0.87]rtc[0] value = 0x00000000
[     0.90]rtc[1] value = 0x00000000
[     0.93]rtc[2] value = 0x00000000
[     0.97]rtc[3] value = 0x00000000
[     0.100]rtc[4] value = 0x00000000
[     0.103]rtc[5] value = 0x00000000
[     0.107]DRAMC IS FOUR
[     0.109]DRAM BOOT DRIVE INFO: V1.1
[     0.113]Found A40
[     0.115]Found A40
[     0.117]Found A40
[     0.119]Found A40
[     0.121]Found A40
[     0.127]PMU: [     0.128]AXP221
[     0.130]ddr voltage = 1500 mv
[     0.133]DRAM CLK =576 MHZ
[     0.136]DRAM Type =3 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3)
[     0.141]DRAM zq value: 0x003b3bfb
[     0.147]DRAM SIZE =1024 M
[     0.150]DRAM simple test OK.
[     0.153]dram size =1024
[     0.156]rtc standby flag is 0x00000000, super standby flag is 0x00000000
[     0.164]card no is 2
[     0.166]sdcard 2 line count 8
[     0.169][mmc]: mmc driver ver 2016-07-01 15:30
[     0.174][mmc]: wrong freq 2 at spd md 2
[     0.187][mmc]: ***Try MMC card 2***
[     0.203][mmc]: MMC 5.1
[     0.206][mmc]: HSSDR52/SDR25 8 bit
[     0.209][mmc]: 50000000 Hz
[     0.212][mmc]: 7456 MB
[     0.214][mmc]: ***SD/MMC 2 init OK!!!***
[     0.305]Succeed in loading uboot from sdmmc flash.
[     0.309]Entry_name        = u-boot
[     0.329]Ready to disable icache.
[     0.332]0xffffffff 0xffffffff
[     0.335]0xffffffff 0xffffffff
[     0.339]0xffffffff 0xffffffff
[     0.342]0xffffffff 0xffffffff
[     0.345]0xffffffff 0xffffffff
[     0.348]0xffffffff 0xffffffff
[     0.351]Jump to secend Boot.
U-Boot 2014.07 (Aug 01 2022 - 11:28:11) ThunderStone Technology
uboot commit : 8e504c02cd7217d2bce20b5a78d0be6c4e478794
i2c_init: by cpux
i2c_init ok
[      0.368]pmbus:   ready
[      0.387]PMU: AXP221
[      0.387]PMU: AXP22x found
[      0.388]PMU: dcdc2 1160
[      0.431]PMU: cpux 1008 Mhz,AXI=336 Mhz
PLL6=600 Mhz,AHB1=200 Mhz, APB1=100Mhz  MBus=400Mhz
set power on vol to default
dcdc1_vol = 3300, onoff=1
dcdc2_vol = 1160, onoff=1
dcdc3_vol = 1100, onoff=1
dcdc4_vol = 1100, onoff=0
dcdc5_vol = 1550, onoff=1
aldo1_vol = 3300, onoff=1
aldo2_vol = 1800, onoff=1
aldo3_vol = 3000, onoff=1
dc1sw_vol = 3300, onoff=1
dc5ldo_vol = 1100, onoff=0
dldo1_vol = 3300, onoff=1
dldo2_vol = 1800, onoff=1
dldo3_vol = 1800, onoff=1
dldo4_vol = 2500, onoff=0
eldo1_vol = 2800, onoff=0
eldo2_vol = 3300, onoff=1
eldo3_vol = 1200, onoff=0
gpio0_vol = 3300, onoff=1
gpio1_vol = 3300, onoff=1
find power_sply to end
vbus exist
run key detect
no key found
no uart input
DRAM:  1 GiB
fdt addr: 0x76e7ce58
Relocation Offset is: 35edf000
In:    serial
Out:   serial
Err:   serial
gic: normal mode
workmode = 0,storage type = 2
[      0.581]MMC:        2
[mmc]: mmc driver ver 2016-07-01 15:50:00
[mmc]: mmc_update_timing_para: error sdc_no 2
SUNXI SD/MMC: 2
[mmc]: 50 MHz...
[mmc]: sample: 52 - 192(ps)
[mmc]: ds: 52 - 192(ps)
[mmc]: 100 MHz...
[mmc]: sample: 26 - 192(ps)
[mmc]: ds: 26 - 192(ps)
[mmc]: 200 MHz...
[mmc]: sample: 13 - 192(ps)
[mmc]: ds: 13 - 192(ps)
[mmc]: media type 0x8000000
[mmc]: ************Try MMC card 2************
[mmc]: host caps: 0x6f
[mmc]: MID 0000ea PSN 1b13233e
[mmc]: PNM SPeMMC -- 0x53-50-65-4d-4d
[mmc]: PRV 1.0
[mmc]: MDT m-8 y-2022
[mmc]: MMC v5.1
[mmc]: speed mode     : HSSDR52/SDR25
[mmc]: clock          : 50000000 Hz
[mmc]: bus_width      : 8 bit
[mmc]: user capacity  : 7456 MB
[mmc]: boot capacity  : 4096 KB
[mmc]: rpmb capacity  : 4096 KB
[mmc]: ************SD/MMC 2 init OK!!!************
[mmc]: use default speed mode: 1-HSSDR52/SDR25, ifreq: 2
[mmc]: ========best spd md: 1-HSSDR52/SDR25, freq: 2-50000000
[mmc]: already at HSSDR52_SDR25 mode
[mmc]: erase_grp_size      : 0x400WrBlk*0x200=0x80000 Byte
[mmc]: secure_feature      : 0x55
[mmc]: secure_removal_type : 0x1
[mmc]: EOL Info(Rev blks): Normal
[mmc]: Wear out(type A): 0%-10% life time used
[mmc]: Wear out(type B): 0%-10% life time used
[      0.784]sunxi flash init ok
最近编辑记录 kedren (2025-02-12 16:14:17)
楼主 #1 2025-02-14 08:44:42
kedren
Re: 求固件,全志A40I,sun8iw11p1
有没有大佬看一下这款屏幕怎么点亮,下面是我的屏幕参数,板子上电后屏幕没有任何反应
[lcd0]
lcd_used            = 1
lcd_driver_name     = "default_lcd"
lcd_backlight       = 150
lcd_if              = 3
lcd_x               = 1600
lcd_y               = 900
lcd_width           =
lcd_height          =
lcd_dclk_freq       = 58
lcd_pwm_used        = 1
lcd_pwm_ch          = 2
lcd_pwm_freq        = 25000
lcd_pwm_pol         = 1
lcd_pwm_max_limit   = 255
lcd_hbp             = 216
lcd_ht              = 1056
lcd_hspw            = 8
lcd_vbp             = 26
lcd_vt              = 926
lcd_vspw            = 2
lcd_lvds_if         = 1
lcd_lvds_colordepth = 0
lcd_lvds_mode       = 0
lcd_frm             = 0
lcd_hv_clk_phase    = 0
lcd_hv_sync_polarity= 0
lcd_gamma_en        = 0
lcd_bright_curve_en = 0
lcd_cmap_en         = 0
deu_mode            = 1
lcdgamma4iep        = 22
smart_color         = 90
lcd_bl_en           = port:PB13<1><0><default><1>
;vdd_5v
lcd_gpio_0                     = port:PH26<1><0><default><1>
;vdd_3v3
lcd_gpio_1                     = port:PH27<1><0><default><1>
;pwm
lcd_gpio_2            = port:PB9<4><0><default><1>
lcd_power           = "vcc-lcd"
lcdd0                   = port:PD00<3><0><default><default>
lcdd1                   = port:PD01<3><0><default><default>
lcdd2                   = port:PD02<3><0><default><default>
lcdd3                   = port:PD03<3><0><default><default>
lcdd4                   = port:PD04<3><0><default><default>
lcdd5                   = port:PD05<3><0><default><default>
lcdd6                   = port:PD06<3><0><default><default>
lcdd7                   = port:PD07<3><0><default><default>
lcdd8                   = port:PD08<3><0><default><default>
lcdd9                   = port:PD09<3><0><default><default>
lcdd10                  = port:PD10<3><0><default><default>
lcdd11                  = port:PD11<3><0><default><default>
lcdd12                  = port:PD12<3><0><default><default>
lcdd13                  = port:PD13<3><0><default><default>
lcdd14                  = port:PD14<3><0><default><default>
lcdd15                  = port:PD15<3><0><default><default>
lcdd16                  = port:PD16<3><0><default><default>
lcdd17                  = port:PD17<3><0><default><default>
lcdd18                  = port:PD18<3><0><default><default>
lcdd19                  = port:PD19<3><0><default><default>
;lcdd20                  = port:PD20<2><0><default><default>
;lcdd21                  = port:PD21<2><0><default><default>
;lcdd22                  = port:PD22<2><0><default><default>
;lcdd23                  = port:PD23<2><0><default><default>
;lcdclk                  = port:PD24<2><0><default><default>
;lcdde                   = port:PD25<2><0><default><default>
;lcdhsync                = port:PD26<2><0><default><default>
;lcdvsync                = port:PD27<2><0><default><default>
[lcd0_suspend]
lcdd0               = port:PD00<7><0><default><default>
lcdd1               = port:PD01<7><0><default><default>
lcdd2               = port:PD02<7><0><default><default>
lcdd3               = port:PD03<7><0><default><default>
lcdd4               = port:PD04<7><0><default><default>
lcdd5               = port:PD05<7><0><default><default>
lcdd6               = port:PD06<7><0><default><default>
lcdd7               = port:PD07<7><0><default><default>
lcdd8               = port:PD08<7><0><default><default>
lcdd9               = port:PD09<7><0><default><default>
lcdd10                  = port:PD10<7><0><default><default>
lcdd11                  = port:PD11<7><0><default><default>
lcdd12                  = port:PD12<7><0><default><default>
lcdd13                  = port:PD13<7><0><default><default>
lcdd14                  = port:PD14<7><0><default><default>
lcdd15                  = port:PD15<7><0><default><default>
lcdd16                  = port:PD16<7><0><default><default>
lcdd17                  = port:PD17<7><0><default><default>
lcdd18                  = port:PD18<7><0><default><default>
lcdd19                  = port:PD19<7><0><default><default>
;lcdd20                  = port:PD20<7><0><default><default>
;lcdd21                  = port:PD21<7><0><default><default>
;lcdd22                  = port:PD22<7><0><default><default>
;lcdd23                  = port:PD23<7><0><default><default>
;lcdclk                  = port:PD24<7><0><default><default>
;lcdde                   = port:PD25<7><0><default><default>
;lcdhsync                = port:PD26<7><0><default><default>
;lcdvsync                = port:PD27<7><0><default><default>
