楼主 # 2025-03-24 10:32:52
cloudway
gitee上下载下来的luban-lite编译出错,是什么问题?
下载下来后只运行了
scons --apply-def=15
scons
最后编译报错:
python3 D:\dev\artinchip\luban-lite\tools/scripts/fsinstall.py --sdkout D:\dev\artinchip\luban-lite\output/d13x_kunlunpi88-nor_rt-thread_helloworld/images/ --clean rodata/,data/
python3 D:\dev\artinchip\luban-lite\tools/scripts/fsinstall.py --sdkout D:\dev\artinchip\luban-lite\output/d13x_kunlunpi88-nor_rt-thread_helloworld/images/ --src D:\dev\artinchip\luban-lite\packages\artinchip\lvgl-ui\aic_demo\demo_hub\assets/480x272/ --dst rodata/
python3 D:\dev\artinchip\luban-lite\tools/scripts/fsinstall.py --sdkout D:\dev\artinchip\luban-lite\output/d13x_kunlunpi88-nor_rt-thread_helloworld/images/ --src D:\dev\artinchip\luban-lite\packages\artinchip\aic-startup-ui\assets/ --dst data/
python3 D:\dev\artinchip\luban-lite\tools/scripts/linked_size.py -m D:\dev\artinchip\luban-lite\output/d13x_kunlunpi88-nor_rt-thread_helloworld/images/d13x.map
python3 D:\dev\artinchip\luban-lite\tools/scripts/makefatfs.py --fullpart --volab default --cluster 8 --sector 512 --tooldir D:\dev\artinchip\luban-lite\tools/scripts/ --inputdir rodata --outfile D:\dev\artinchip\luban-lite\output/d13x_kunlunpi88-nor_rt-thread_helloworld/images/rodata.fatfs
python3 D:\dev\artinchip\luban-lite\tools/scripts/makelittlefs.py --pagesize 256 --blocksize 4096 --tooldir D:\dev\artinchip\luban-lite\tools/scripts/ --inputdir data/ --outfile D:\dev\artinchip\luban-lite\output/d13x_kunlunpi88-nor_rt-thread_helloworld/images/data.lfs
D:\dev\artinchip\luban-lite\output/d13x_kunlunpi88-nor_rt-thread_helloworld/images\data/
D:\dev\artinchip\luban-lite\tools/scripts/mklittlefs.exe -c D:\dev\artinchip\luban-lite\output/d13x_kunlunpi88-nor_rt-thread_helloworld/images\data/ -b 4096 -p 256 -s 1048576 D:\dev\artinchip\luban-lite\output/d13x_kunlunpi88-nor_rt-thread_helloworld/images/data.lfs
D:\dev\artinchip\luban-lite\tools/scripts/mk_private_resource.exe -v -l D:\dev\artinchip\luban-lite\output/d13x_kunlunpi88-nor_rt-thread_helloworld/images/pbp_cfg.json,D:\dev\artinchip\luban-lite\output/d13x_kunlunpi88-nor_rt-thread_helloworld/images/partition.json -o D:\dev\artinchip\luban-lite\output/d13x_kunlunpi88-nor_rt-thread_helloworld/images/pbp_cfg.bin
psram
python3 D:\dev\artinchip\luban-lite\tools/scripts/elf_parse.py output\d13x_kunlunpi88-nor_rt-thread_helloworld\images\d13x.elf D:\dev\artinchip\luban-lite\output/d13x_kunlunpi88-nor_rt-thread_helloworld/images/ riscv64-unknown-elf-
D:\dev\artinchip\luban-lite\tools/scripts/mk_image.exe -v -c D:\dev\artinchip\luban-lite\output/d13x_kunlunpi88-nor_rt-thread_helloworld/images/image_cfg.json -d D:\dev\artinchip\luban-lite\output/d13x_kunlunpi88-nor_rt-thread_helloworld/images/
        Creating D:\dev\artinchip\luban-lite\output/d13x_kunlunpi88-nor_rt-thread_helloworld/images/d13x_os.itb ...
        Creating D:\dev\artinchip\luban-lite\output/d13x_kunlunpi88-nor_rt-thread_helloworld/images/env.bin ...
        Creating D:\dev\artinchip\luban-lite\output/d13x_kunlunpi88-nor_rt-thread_helloworld/images/usbupg-psram-init.aic ...
        Creating D:\dev\artinchip\luban-lite\output/d13x_kunlunpi88-nor_rt-thread_helloworld/images/pbp_ext.aic ...
        Creating D:\dev\artinchip\luban-lite\output/d13x_kunlunpi88-nor_rt-thread_helloworld/images/loader.aic ...
  File "\\Exdroid019\hao.xiong\lite-umm\luban-lite\tools\scripts\mk_image.py", line 2564, in <module>
  File "\\Exdroid019\hao.xiong\lite-umm\luban-lite\tools\scripts\mk_image.py", line 2130, in firmware_component_preproc
  File "\\Exdroid019\hao.xiong\lite-umm\luban-lite\tools\scripts\mk_image.py", line 2077, in firmware_component_preproc_aicimage
  File "\\Exdroid019\hao.xiong\lite-umm\luban-lite\tools\scripts\mk_image.py", line 1004, in aic_boot_create_image_v2
  File "\\Exdroid019\hao.xiong\lite-umm\luban-lite\tools\scripts\mk_image.py", line 782, in aic_boot_gen_header_bytes_v2
ValueError: invalid literal for int() with base 16: 'CONFIG_AIC_BOOTLOADER_LOAD_BASE'
[3552] Failed to execute script 'mk_image' due to unhandled exception!
scons: *** [output\d13x_kunlunpi88-nor_rt-thread_helloworld\images\d13x.elf] Error 1
scons: building terminated because of errors.
#1 2025-03-24 11:16:16
lgkgkfg
Re: gitee上下载下来的luban-lite编译出错,是什么问题?
先把BOOTLOADER编译了就行了
楼主 #2 2025-03-24 12:08:27
cloudway
谢谢楼上的兄弟。解决了,用list、lunch、 m、 c的命令就可以编译成功了,scons命令会出错,这是sdk的bug吗?
#3 2025-03-24 12:38:15
海石生风
已发帖子: 755
原厂那边人没有用zsh这种比较便利的shell,所以才搞了OneStep命令。并且原厂那边可能OneStep命令用得多,非OneStep命令用得少,所以容易出问题。
我用zsh,根本不需要OneStep命令就用得很便利了。另外,OneStep命令不支持zsh shell,我都懒得提了。
最近编辑记录 海石生风 (2025-03-24 12:40:02)
#4 2025-03-25 16:28:43
cnbox
cloudway 说:
你好 能具体讲下 list  lunch  m c 完整命令吗  我这也是同样的问题 感谢
楼主 #5 2025-03-25 18:14:41
cloudway
上面这些就是完整命令啊,敲一下就可以运行了。
另外还发现一个bug,在vscode下的menuconfig,方向键不能用。。。无法配置,只能用tab退出
#6 2025-04-01 23:27:00
sagade
cloudway 说:
上下可以用+-代替,不过感觉还是有别的问题,不如直接在vscode外面运行menuconfig
