楼主 # 2025-04-26 17:44:35
memory
已发帖子: 712
发现 rtl8188eu 不支持 acs 自动信道设置,用aic8800dc 试一试
楼主 #1 2025-04-26 17:44:46
memory
已发帖子: 712
Re: 发现 rtl8188eu 不支持 acs 自动信道设置,用aic8800dc 试一试
$ lsusb
Bus 001 Device 003: ID a69c:88dc
hostapd.conf
interface=wlx8800a1017a94
driver=nl80211
ssid=aaa_test
channel=0
hw_mode=g
macaddr_acl=0
ignore_broadcast_ssid=0
auth_algs=1
wpa=3
wpa_passphrase=12345678
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
固件复制到:/lib/firmware/aic8800DC/
sudo insmod ./aic_load_fw/aic_load_fw.ko
sudo insmod ./aic8800_fdrv/aic8800_fdrv.ko
ubuntu@ubuntu:/opt/hostapd$  sudo ifconfig wlx8800a1017a94 192.168.88.1
ubuntu@ubuntu:/opt/hostapd$ sudo killall wpa_supplicant
ubuntu@ubuntu:/opt/hostapd$ sudo hostapd -d hostapd.conf
random: Trying to read entropy from /dev/random
Configuration file: hostapd.conf
rfkill: initial event: idx=14 type=2 op=0 soft=1 hard=0
rfkill: initial event: idx=15 type=1 op=0 soft=0 hard=0
nl80211: Supported cipher 00-0f-ac:1
nl80211: Supported cipher 00-0f-ac:5
nl80211: Supported cipher 00-0f-ac:2
nl80211: Supported cipher 00-0f-ac:4
nl80211: Supported cipher 00-0f-ac:6
nl80211: Supported cipher 00-14-72:1
nl80211: Supported vendor command: vendor_id=0x1a11 subcmd=5632
nl80211: Supported vendor command: vendor_id=0x1a11 subcmd=5633
nl80211: Supported vendor command: vendor_id=0x1a11 subcmd=5123
nl80211: Supported vendor command: vendor_id=0x1a11 subcmd=4105
nl80211: Supported vendor command: vendor_id=0x1a11 subcmd=4110
nl80211: Supported vendor command: vendor_id=0x1a11 subcmd=5121
nl80211: Supported vendor command: vendor_id=0x1a11 subcmd=4106
nl80211: Supported vendor command: vendor_id=0x1a11 subcmd=5126
nl80211: Supported vendor command: vendor_id=0x1a11 subcmd=5124
nl80211: Supported vendor command: vendor_id=0x1a11 subcmd=5120
nl80211: Supported vendor command: vendor_id=0x1a11 subcmd=5125
nl80211: Supported vendor command: vendor_id=0x1a11 subcmd=5133
nl80211: Supported vendor command: vendor_id=0x1a11 subcmd=6144
nl80211: Supported vendor command: vendor_id=0x1a11 subcmd=5130
nl80211: Supported vendor command: vendor_id=0x1a11 subcmd=5131
nl80211: Supported vendor command: vendor_id=0x1a11 subcmd=5132
nl80211: Supported vendor command: vendor_id=0x1018 subcmd=6
nl80211: Use separate P2P group interface (driver advertised support)
nl80211: Enable multi-channel concurrent (driver advertised support)
nl80211: use P2P_DEVICE support
nl80211: interface wlx8800a1017a94 in phy phy4
nl80211: Set mode ifindex 4 iftype 3 (AP)
nl80211: Setup AP(wlx8800a1017a94) - device_ap_sme=0 use_monitor=0
nl80211: Subscribe to mgmt frames with AP handle 0x556d845470e0
nl80211: Register frame type=0xb0 (WLAN_FC_STYPE_AUTH) nl_handle=0x556d845470e0 match=
nl80211: Register frame type=0x0 (WLAN_FC_STYPE_ASSOC_REQ) nl_handle=0x556d845470e0 match=
nl80211: Register frame type=0x20 (WLAN_FC_STYPE_REASSOC_REQ) nl_handle=0x556d845470e0 match=
nl80211: Register frame type=0xa0 (WLAN_FC_STYPE_DISASSOC) nl_handle=0x556d845470e0 match=
nl80211: Register frame type=0xc0 (WLAN_FC_STYPE_DEAUTH) nl_handle=0x556d845470e0 match=
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x556d845470e0 match=
nl80211: Register frame type=0x40 (WLAN_FC_STYPE_PROBE_REQ) nl_handle=0x556d845470e0 match=
nl80211: Add own interface ifindex 4
nl80211: if_indices[16]: 4
phy: phy4
BSS count 1, BSSID mask 00:00:00:00:00:00 (0 bits)
nl80211: Regulatory information - country=00
nl80211: 2402-2472 @ 40 MHz 20 mBm
nl80211: 2457-2482 @ 20 MHz 20 mBm (no IR)
nl80211: 2474-2494 @ 20 MHz 20 mBm (no OFDM) (no IR)
nl80211: 5170-5250 @ 80 MHz 20 mBm (no IR)
nl80211: 5250-5330 @ 80 MHz 20 mBm (DFS) (no IR)
nl80211: 5490-5730 @ 160 MHz 20 mBm (DFS) (no IR)
nl80211: 5735-5835 @ 80 MHz 20 mBm (no IR)
nl80211: 57240-63720 @ 2160 MHz 0 mBm
nl80211: Added 802.11b mode based on 802.11g information
ACS: Automatic channel selection started, this may take a bit
ACS: Scanning 1 / 5
wlx8800a1017a94: nl80211: scan request
Scan requested (ret=0) - scan timeout 10 seconds
wlx8800a1017a94: interface state UNINITIALIZED->ACS
wlx8800a1017a94: ACS-STARTED
Interface initialization will be completed in a callback (ACS)
ctrl_iface not configured!
random: Got 20/20 bytes from /dev/random
nl80211: Drv Event 33 (NL80211_CMD_TRIGGER_SCAN) received for wlx8800a1017a94
wlx8800a1017a94: nl80211: Scan trigger
wlx8800a1017a94: Event SCAN_STARTED (47) received
Unknown event 47
RTM_NEWLINK: ifi_index=4 ifname= wext ifi_family=0 ifi_flags=0x1003 ([UP])
nl80211: Drv Event 34 (NL80211_CMD_NEW_SCAN_RESULTS) received for wlx8800a1017a94
wlx8800a1017a94: nl80211: New scan results available
nl80211: Scan included frequencies: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 2467 2472 2484
wlx8800a1017a94: Event SCAN_RESULTS (3) received
ACS: Using survey based algorithm (acs_num_scans=5)
nl80211: Fetch survey data
nl80211: Freq survey dump event (freq=2412 MHz noise=-89 channel_time=50 busy_time=32 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2417 MHz noise=-89 channel_time=30 busy_time=0 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2422 MHz noise=-89 channel_time=30 busy_time=3 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2427 MHz noise=-89 channel_time=30 busy_time=29 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2432 MHz noise=-89 channel_time=30 busy_time=29 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2437 MHz noise=-89 channel_time=50 busy_time=36 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2442 MHz noise=-89 channel_time=30 busy_time=0 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2447 MHz noise=-89 channel_time=30 busy_time=18 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2452 MHz noise=-89 channel_time=30 busy_time=0 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2457 MHz noise=-89 channel_time=30 busy_time=6 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2462 MHz noise=-89 channel_time=50 busy_time=5 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2467 MHz noise=-89 channel_time=30 busy_time=0 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2472 MHz noise=-89 channel_time=50 busy_time=48 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2484 MHz noise=-89 channel_time=30 busy_time=0 tx_time=0 rx_time=0 filled=0007)
wlx8800a1017a94: Event SURVEY (46) received
ACS: Scanning 2 / 5
Scan requested (ret=0) - scan timeout 30 seconds
Unknown event 47
nl80211: Freq survey dump event (freq=2412 MHz noise=-89 channel_time=50 busy_time=12 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2417 MHz noise=-89 channel_time=30 busy_time=24 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2422 MHz noise=-89 channel_time=30 busy_time=13 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2427 MHz noise=-89 channel_time=30 busy_time=25 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2432 MHz noise=-89 channel_time=30 busy_time=19 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2437 MHz noise=-89 channel_time=50 busy_time=12 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2442 MHz noise=-89 channel_time=30 busy_time=30 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2447 MHz noise=-89 channel_time=30 busy_time=19 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2457 MHz noise=-89 channel_time=30 busy_time=19 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2462 MHz noise=-89 channel_time=50 busy_time=0 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2467 MHz noise=-89 channel_time=30 busy_time=4 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2472 MHz noise=-89 channel_time=50 busy_time=21 tx_time=0 rx_time=0 filled=0007)
ACS: Scanning 3 / 5
Unknown event 47
nl80211: Freq survey dump event (freq=2412 MHz noise=-89 channel_time=50 busy_time=3 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2417 MHz noise=-89 channel_time=30 busy_time=3 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2422 MHz noise=-89 channel_time=30 busy_time=28 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2427 MHz noise=-89 channel_time=30 busy_time=28 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2432 MHz noise=-89 channel_time=30 busy_time=6 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2437 MHz noise=-89 channel_time=50 busy_time=5 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2442 MHz noise=-89 channel_time=30 busy_time=14 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2447 MHz noise=-89 channel_time=30 busy_time=5 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2457 MHz noise=-89 channel_time=30 busy_time=0 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2467 MHz noise=-89 channel_time=30 busy_time=34 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2472 MHz noise=-89 channel_time=50 busy_time=0 tx_time=0 rx_time=0 filled=0007)
ACS: Scanning 4 / 5
Unknown event 47
nl80211: Freq survey dump event (freq=2412 MHz noise=-89 channel_time=50 busy_time=11 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2417 MHz noise=-89 channel_time=30 busy_time=30 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2422 MHz noise=-89 channel_time=30 busy_time=21 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2427 MHz noise=-89 channel_time=30 busy_time=24 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2432 MHz noise=-89 channel_time=30 busy_time=4 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2437 MHz noise=-89 channel_time=50 busy_time=21 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2447 MHz noise=-89 channel_time=30 busy_time=17 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2484 MHz noise=-89 channel_time=30 busy_time=31 tx_time=0 rx_time=0 filled=0007)
ACS: Scanning 5 / 5
Unknown event 47
nl80211: Freq survey dump event (freq=2412 MHz noise=-89 channel_time=50 busy_time=49 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2422 MHz noise=-89 channel_time=30 busy_time=0 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2427 MHz noise=-89 channel_time=30 busy_time=8 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2432 MHz noise=-89 channel_time=30 busy_time=3 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2437 MHz noise=-89 channel_time=50 busy_time=47 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2442 MHz noise=-89 channel_time=30 busy_time=18 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2447 MHz noise=-89 channel_time=30 busy_time=12 tx_time=0 rx_time=0 filled=0007)
nl80211: Freq survey dump event (freq=2462 MHz noise=-89 channel_time=50 busy_time=3 tx_time=0 rx_time=0 filled=0007)
ACS: Trying survey-based ACS
ACS: Survey analysis for channel 1 (2412 MHz)
ACS: 1: min_nf=-89 interference_factor=0.64 nf=-89 time=50 busy=32 rx=0
ACS: 2: min_nf=-89 interference_factor=0.24 nf=-89 time=50 busy=12 rx=0
ACS: 3: min_nf=-89 interference_factor=0.06 nf=-89 time=50 busy=3 rx=0
ACS: 4: min_nf=-89 interference_factor=0.22 nf=-89 time=50 busy=11 rx=0
ACS: 5: min_nf=-89 interference_factor=0.98 nf=-89 time=50 busy=49 rx=0
ACS:  * interference factor average: 0.428
ACS: Survey analysis for channel 2 (2417 MHz)
ACS: 1: min_nf=-89 interference_factor=1.58489e-18 nf=-89 time=30 busy=0 rx=0
ACS: 2: min_nf=-89 interference_factor=0.8 nf=-89 time=30 busy=24 rx=0
ACS: 3: min_nf=-89 interference_factor=0.1 nf=-89 time=30 busy=3 rx=0
ACS: 4: min_nf=-89 interference_factor=1 nf=-89 time=30 busy=30 rx=0
ACS: 5: min_nf=-89 interference_factor=1.58489e-18 nf=-89 time=30 busy=0 rx=0
ACS:  * interference factor average: 0.38
ACS: Survey analysis for channel 3 (2422 MHz)
ACS: 1: min_nf=-89 interference_factor=0.1 nf=-89 time=30 busy=3 rx=0
ACS: 2: min_nf=-89 interference_factor=0.433333 nf=-89 time=30 busy=13 rx=0
ACS: 3: min_nf=-89 interference_factor=0.933333 nf=-89 time=30 busy=28 rx=0
ACS: 4: min_nf=-89 interference_factor=0.7 nf=-89 time=30 busy=21 rx=0
ACS:  * interference factor average: 0.433333
ACS: Survey analysis for channel 4 (2427 MHz)
ACS: 1: min_nf=-89 interference_factor=0.966667 nf=-89 time=30 busy=29 rx=0
ACS: 2: min_nf=-89 interference_factor=0.833333 nf=-89 time=30 busy=25 rx=0
ACS: 4: min_nf=-89 interference_factor=0.8 nf=-89 time=30 busy=24 rx=0
ACS: 5: min_nf=-89 interference_factor=0.266667 nf=-89 time=30 busy=8 rx=0
ACS:  * interference factor average: 0.76
ACS: Survey analysis for channel 5 (2432 MHz)
ACS: 2: min_nf=-89 interference_factor=0.633333 nf=-89 time=30 busy=19 rx=0
ACS: 3: min_nf=-89 interference_factor=0.2 nf=-89 time=30 busy=6 rx=0
ACS: 4: min_nf=-89 interference_factor=0.133333 nf=-89 time=30 busy=4 rx=0
ACS: 5: min_nf=-89 interference_factor=0.1 nf=-89 time=30 busy=3 rx=0
ACS:  * interference factor average: 0.406667
ACS: Survey analysis for channel 6 (2437 MHz)
ACS: 1: min_nf=-89 interference_factor=0.72 nf=-89 time=50 busy=36 rx=0
ACS: 3: min_nf=-89 interference_factor=0.1 nf=-89 time=50 busy=5 rx=0
ACS: 4: min_nf=-89 interference_factor=0.42 nf=-89 time=50 busy=21 rx=0
ACS: 5: min_nf=-89 interference_factor=0.94 nf=-89 time=50 busy=47 rx=0
ACS:  * interference factor average: 0.484
ACS: Survey analysis for channel 7 (2442 MHz)
ACS: 2: min_nf=-89 interference_factor=1 nf=-89 time=30 busy=30 rx=0
ACS: 3: min_nf=-89 interference_factor=0.466667 nf=-89 time=30 busy=14 rx=0
ACS: 4: min_nf=-89 interference_factor=1.58489e-18 nf=-89 time=30 busy=0 rx=0
ACS: 5: min_nf=-89 interference_factor=0.6 nf=-89 time=30 busy=18 rx=0
ACS:  * interference factor average: 0.413333
ACS: Survey analysis for channel 8 (2447 MHz)
ACS: 1: min_nf=-89 interference_factor=0.6 nf=-89 time=30 busy=18 rx=0
ACS: 3: min_nf=-89 interference_factor=0.166667 nf=-89 time=30 busy=5 rx=0
ACS: 4: min_nf=-89 interference_factor=0.566667 nf=-89 time=30 busy=17 rx=0
ACS: 5: min_nf=-89 interference_factor=0.4 nf=-89 time=30 busy=12 rx=0
ACS:  * interference factor average: 0.473333
ACS: Survey analysis for channel 9 (2452 MHz)
ACS: 2: min_nf=-89 interference_factor=1.58489e-18 nf=-89 time=30 busy=0 rx=0
ACS: 3: min_nf=-89 interference_factor=1.58489e-18 nf=-89 time=30 busy=0 rx=0
ACS:  * interference factor average: 1.58489e-18
ACS: Survey analysis for channel 10 (2457 MHz)
ACS: 1: min_nf=-89 interference_factor=0.2 nf=-89 time=30 busy=6 rx=0
ACS:  * interference factor average: 0.166667
ACS: Survey analysis for channel 11 (2462 MHz)
ACS: 1: min_nf=-89 interference_factor=0.1 nf=-89 time=50 busy=5 rx=0
ACS: 2: min_nf=-89 interference_factor=1.58489e-18 nf=-89 time=50 busy=0 rx=0
ACS: 3: min_nf=-89 interference_factor=1.58489e-18 nf=-89 time=50 busy=0 rx=0
ACS: 4: min_nf=-89 interference_factor=1.58489e-18 nf=-89 time=50 busy=0 rx=0
ACS: 5: min_nf=-89 interference_factor=0.06 nf=-89 time=50 busy=3 rx=0
ACS:  * interference factor average: 0.032
ACS: Survey analysis for channel 12 (2467 MHz)
ACS: 2: min_nf=-89 interference_factor=0.133333 nf=-89 time=30 busy=4 rx=0
ACS: 3: min_nf=-89 interference_factor=1.13333 nf=-89 time=30 busy=34 rx=0
ACS:  * interference factor average: 0.253333
ACS: Survey analysis for channel 13 (2472 MHz)
ACS: 1: min_nf=-89 interference_factor=0.96 nf=-89 time=50 busy=48 rx=0
ACS: 2: min_nf=-89 interference_factor=0.42 nf=-89 time=50 busy=21 rx=0
ACS: 5: min_nf=-89 interference_factor=1.58489e-18 nf=-89 time=50 busy=0 rx=0
ACS:  * interference factor average: 0.276
ACS: Survey analysis for channel 14 (2484 MHz)
ACS: 4: min_nf=-89 interference_factor=1.03333 nf=-89 time=30 busy=31 rx=0
ACS:  * interference factor average: 0.206667
ACS: Survey analysis for selected bandwidth 20 MHz
ACS:  * channel 1: total interference = 0.329778 (0.800000 bias)
ACS:  * channel 2: total interference = 0.47081
ACS:  * channel 3: total interference = 0.489842
ACS:  * channel 4: total interference = 0.512947
ACS:  * channel 5: total interference = 0.507825
ACS:  * channel 6: total interference = 0.391439 (0.800000 bias)
ACS:  * channel 7: total interference = 0.381772
ACS:  * channel 8: total interference = 0.311193
ACS:  * channel 9: total interference = 0.207614
ACS:  * channel 10: total interference = 0.156193
ACS:  * channel 11: total interference = 0.113853 (0.800000 bias)
ACS:  * channel 12: total interference = 0.186708
ACS:  * channel 13: total interference = 0.212056
ACS:  * channel 14: total interference = 0.206667
ACS: Ideal channel is 11 (2462 MHz) with total interference factor of 0.113853
wlx8800a1017a94: ACS-COMPLETED freq=2462 channel=11
Completing interface initialization
Mode: IEEE 802.11g  Channel: 11  Frequency: 2462 MHz
DFS 0 channels required radar detection
nl80211: Set freq 2462 (ht_enabled=0, vht_enabled=0, bandwidth=20 MHz, cf1=2462 MHz, cf2=0 MHz)
  * freq=2462
  * vht_enabled=0
  * ht_enabled=0
RATE[0] rate=10 flags=0x1
RATE[1] rate=20 flags=0x1
RATE[2] rate=55 flags=0x1
RATE[3] rate=110 flags=0x1
RATE[4] rate=60 flags=0x0
RATE[5] rate=90 flags=0x0
RATE[6] rate=120 flags=0x0
RATE[7] rate=180 flags=0x0
RATE[8] rate=240 flags=0x0
RATE[9] rate=360 flags=0x0
RATE[10] rate=480 flags=0x0
RATE[11] rate=540 flags=0x0
hostapd_setup_bss(hapd=0x556d84547900 (wlx8800a1017a94), first=1)
wlx8800a1017a94: Flushing old station entries
nl80211: flush -> DEL_STATION wlx8800a1017a94 (all)
wlx8800a1017a94: Deauthenticate all stations
nl80211: send_mlme - da= ff:ff:ff:ff:ff:ff noack=0 freq=0 no_cck=0 offchanok=0 wait_time=0 fc=0xc0 (WLAN_FC_STYPE_DEAUTH) nlmode=3
nl80211: send_mlme -> send_frame
nl80211: send_frame - Use bss->freq=2462
nl80211: send_frame -> send_frame_cmd
nl80211: Frame command failed: ret=-16 (Device or resource busy) (freq=2462 wait=0)
wpa_driver_nl80211_set_key: ifindex=4 (wlx8800a1017a94) alg=0 addr=(nil) key_idx=0 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=4 (wlx8800a1017a94) alg=0 addr=(nil) key_idx=1 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=4 (wlx8800a1017a94) alg=0 addr=(nil) key_idx=2 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=4 (wlx8800a1017a94) alg=0 addr=(nil) key_idx=3 set_tx=0 seq_len=0 key_len=0
Using interface wlx8800a1017a94 with hwaddr 88:00:a1:01:7a:94 and ssid "aaa_test"
Deriving WPA PSK based on passphrase
SSID - hexdump_ascii(len=8):
     61 61 61 5f 74 65 73 74                           aaa_test
PSK (ASCII passphrase) - hexdump_ascii(len=8): [REMOVED]
PSK (from passphrase) - hexdump(len=32): [REMOVED]
GMK - hexdump(len=32): [REMOVED]
Key Counter - hexdump(len=32): [REMOVED]
WPA: Delay group state machine start until Beacon frames have been configured
nl80211: Set beacon (beacon_set=0)
nl80211: Beacon head - hexdump(len=59): 80 00 00 00 ff ff ff ff ff ff 88 00 a1 01 7a 94 88 00 a1 01 7a 94 00 00 00 00 00 00 00 00 00 00 64 00 11 04 00 08 61 61 61 5f 74 65 73 74 01 08 82 84 8b 96 0c 12 18 24 03 01 0b
nl80211: Beacon tail - hexdump(len=65): 2a 01 04 32 04 30 48 60 6c 30 14 01 00 00 0f ac 02 01 00 00 0f ac 04 01 00 00 0f ac 02 00 00 dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02 7f 08 04 00 00 02 00 00 00 40
nl80211: ifindex=4
nl80211: beacon_int=100
nl80211: dtim_period=2
nl80211: ssid - hexdump_ascii(len=8):
  * beacon_int=100
nl80211: hidden SSID not in use
nl80211: privacy=1
nl80211: auth_algs=0x1
nl80211: wpa_version=0x3
nl80211: key_mgmt_suites=0x2
nl80211: pairwise_ciphers=0x18
nl80211: group_cipher=0x8
nl80211: SMPS mode - off
nl80211: beacon_ies - hexdump(len=10): 7f 08 04 00 00 02 00 00 00 40
nl80211: proberesp_ies - hexdump(len=10): 7f 08 04 00 00 02 00 00 00 40
nl80211: assocresp_ies - hexdump(len=10): 7f 08 04 00 00 02 00 00 00 40
WPA: Start group state machine to set initial keys
WPA: group state machine entering state GTK_INIT (VLAN-ID 0)
GTK - hexdump(len=32): [REMOVED]
WPA: group state machine entering state SETKEYSDONE (VLAN-ID 0)
wpa_driver_nl80211_set_key: ifindex=4 (wlx8800a1017a94) alg=2 addr=0x556d829c08db key_idx=1 set_tx=1 seq_len=0 key_len=32
nl80211: KEY_DATA - hexdump(len=32): [REMOVED]
   broadcast key
nl80211: Set wlx8800a1017a94 operstate 0->1 (UP)
netlink: Operstate: ifindex=4 linkmode=-1 (no change), operstate=6 (IF_OPER_UP)
wlx8800a1017a94: interface state ACS->ENABLED
wlx8800a1017a94: AP-ENABLED
wlx8800a1017a94: Setup of interface done.
RTM_NEWLINK: ifi_index=4 ifname= operstate=6 linkmode=0 ifi_family=0 ifi_flags=0x11043 ([UP][RUNNING][LOWER_UP])
VLAN: RTM_NEWLINK: ifi_index=4 ifname=wlx8800a1017a94 ifi_family=0 ifi_flags=0x11043 ([UP][RUNNING][LOWER_UP])
VLAN: vlan_newlink(wlx8800a1017a94)
nl80211: BSS Event 59 (NL80211_CMD_FRAME) received for wlx8800a1017a94
nl80211: RX frame sa=92:a0:22:8c:72:28 freq=2462 ssi_signal=-49 fc=0x40 seq_ctrl=0x1920 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=88
nl80211: RX frame sa=92:a0:22:8c:72:28 freq=2462 ssi_signal=-50 fc=0x40 seq_ctrl=0x1930 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=85
nl80211: RX frame sa=92:a0:22:8c:72:28 freq=2462 ssi_signal=-50 fc=0x40 seq_ctrl=0x1aa0 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=88
nl80211: RX frame sa=92:a0:22:8c:72:28 freq=2462 ssi_signal=-51 fc=0x40 seq_ctrl=0x1ab0 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=85
nl80211: RX frame sa=92:a0:22:8c:72:28 freq=2462 ssi_signal=-58 fc=0x40 seq_ctrl=0x1d10 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=85
Ignore Probe Request due to DS Params mismatch: chan=11 != ds.chan=10
nl80211: RX frame sa=92:a0:22:8c:72:28 freq=2462 ssi_signal=-45 fc=0x40 seq_ctrl=0x1d30 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=88
nl80211: RX frame sa=92:a0:22:8c:72:28 freq=2462 ssi_signal=-46 fc=0x40 seq_ctrl=0x1d40 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=85
nl80211: RX frame sa=92:a0:22:8c:72:28 freq=2462 ssi_signal=-43 fc=0x40 seq_ctrl=0x1d60 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=88
Ignore Probe Request due to DS Params mismatch: chan=11 != ds.chan=12
nl80211: RX frame sa=92:a0:22:8c:72:28 freq=2462 ssi_signal=-43 fc=0x40 seq_ctrl=0x1d70 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=85
nl80211: RX frame sa=88:78:73:19:67:61 freq=2462 ssi_signal=-34 fc=0x40 seq_ctrl=0xd10 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=79
nl80211: RX frame sa=88:78:73:19:67:61 freq=2462 ssi_signal=-33 fc=0x40 seq_ctrl=0xd20 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=79
nl80211: RX frame sa=92:a0:22:8c:72:28 freq=2462 ssi_signal=-46 fc=0x40 seq_ctrl=0x2180 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=88
nl80211: RX frame sa=92:a0:22:8c:72:28 freq=2462 ssi_signal=-46 fc=0x40 seq_ctrl=0x2190 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=85
nl80211: RX frame sa=92:a0:22:8c:72:28 freq=2462 ssi_signal=-45 fc=0x40 seq_ctrl=0x21b0 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=88
nl80211: RX frame sa=92:a0:22:8c:72:28 freq=2462 ssi_signal=-45 fc=0x40 seq_ctrl=0x21c0 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=85
nl80211: RX frame sa=92:a0:22:8c:72:28 freq=2462 ssi_signal=-46 fc=0x40 seq_ctrl=0x24e0 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=88
选中了11信道
