楼主 # 2025-05-03 22:39:07
无情一刀
已发帖子: 723
T113进入uboot0断电后下一次可能起不来问题 ,
下面是打印信息  问下各位大佬有遇到吗
[350]Jump to second Boot.
M/TC: OP-TEE version: 6aef7bb2-dirty (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Fri Jul 23 09:25:11 UTC 2021 arm
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.4.61 (root@ubuntu) (arm-openwrt-linux-muslgnueabi-gcc.bin (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) 6.4.1, GNU ld (GNU Binutils) 2.27) #430 SMP PREEMPT Sat May 3 14:19:26 UTC 2025
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: sun8iw20
[    0.000000] printk: bootconsole [earlycon0] enabled
▒[    0.484278] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[    0.493563] CPU0: stopping
[    0.496603] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.4.61 #430
[    0.503432] Hardware name: Generic DT based system
[    0.508827] [<c010df0c>] (unwind_backtrace) from [<c010a690>] (show_stack+0x10/0x14)
[    0.517520] [<c010a690>] (show_stack) from [<c076b610>] (dump_stack+0x88/0xa4)
[    0.525627] [<c076b610>] (dump_stack) from [<c010c2d4>] (handle_IPI+0xe4/0x180)
[    0.533833] [<c010c2d4>] (handle_IPI) from [<c034255c>] (gic_handle_irq+0x70/0x78)
[    0.542329] [<c034255c>] (gic_handle_irq) from [<c01021cc>] (__irq_svc+0x6c/0xa8)
[    0.550721] Exception stack(0xc0c01f40 to 0xc0c01f88)
[    0.556390] 1f40: 00000838 c7aba534 00000000 c0114820 00000001 c0c00000 c0c04e24 c0c04e60
[    0.565566] 1f60: c0c57000 c7bff540 c0b2a0c0 00000000 00000001 c0c01f90 c0107fc8 c0107fb8
[    0.574737] 1f80: 60000013 ffffffff
[    0.578654] [<c01021cc>] (__irq_svc) from [<c0107fb8>] (arch_cpu_idle+0x1c/0x38)
[    0.586955] [<c0107fb8>] (arch_cpu_idle) from [<c013d588>] (do_idle+0xd4/0x128)
[    0.595158] [<c013d588>] (do_idle) from [<c013d86c>] (cpu_startup_entry+0x18/0x1c)
[    0.603654] [<c013d86c>] (cpu_startup_entry) from [<c0b00c80>] (start_kernel+0x360/0x3ec)
[    0.612830] [<c0b00c80>] (start_kernel) from [<00000000>] (0x0)
[    0.619468] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---
#1 2025-05-03 23:14:02
ubuntu
已发帖子: 312
Re: T113进入uboot0断电后下一次可能起不来问题 ,
spi nand?
