出厂固件的开机日志:
[11677]Training result is = 7
[11680]DRAM Pstate 0 training, frequency is 1800 Mhz
[11688]Actual DRAM SIZE =6144 M
[11691]DRAM SIZE =6144 MBytes, para1 = a10a, para2 = 18001001, dram_tpr13 = 10061
[11701]DRAM simple test OK.
[11704]rtc[3] value = 0xb00f
[11707]rtc[7] value = 0x2
[11709]init dram ok
U-Boot 2018.07 (Mar 31 2025 - 06:54:43 +0000) Allwinner Technology
[13.838]CPU: Allwinner Family
[13.841]Model: sun60iw2
I2C: ready
[13.901]DRAM: 512 MiB
[13.906]Relocation Offset is: 15dac000
[13.956]sunxi_drm_dsi_post_bind:706
[13.960]secure enable bit: 0
[13.963]PMU: AXP8191
[13.965]PMU: AXP8191 VER_A
[13.967]PMU: pmu_axp8191 found
FDT ERROR:fdt_get_regulator_name:get property handle twi-supply error:FDT_ERR_INTERNAL
[13.979]gpio_bias, pc_bias: -1, pc_supply: not set
[13.984]gpio_bias, pl_bias: -1, pl_supply: not set
[13.989]BMU: no found
[13.991][AXP8191] onoff status: 0x50 = 0x0, 0x51 = 0x0
[13.996][AXP8191] charge status: 0x4 = 0x0
[14.000]CPU=1014 MHz,PLL6=1200 Mhz,AHB=200 Mhz, APB1=24Mhz MBus=600Mhz
[14.006]gic: normal mode
[14.008]sunxi flash type@0 not support fast burn key
[14.013]sunxi flash map init
[14.018]init_clocks:finish
[14.020]flash init start
[14.022]workmode = 16,storage type = 0
try card 2
set card number 2
get card number 2
[14.030][mmc]: mmc driver ver uboot2018:2024-10-18 9:01:00
[14.039][mmc]: Is not Boot mode!
[14.041][mmc]: SUNXI SDMMC Controller Version:0x50610
[14.049][mmc]: 200 MHz...
[14.051][mmc]: sample: 23 - 108(ps)
[14.054][mmc]: ds: 23 - 108(ps)
[14.061][mmc]: ************Try SD card 2************
[14.066][mmc]: mmc 2 cmd timeout 100 status 100
[14.070][mmc]: smc 2 err, cmd 8, RTO
[14.074][mmc]: mmc 2 close bus gating and reset
[14.079][mmc]: mmc 2 cmd timeout 100 status 100
[14.083][mmc]: smc 2 err, cmd 55, RTO
[14.086][mmc]: mmc 2 close bus gating and reset
[14.090][mmc]: ************Try MMC card 2************
[14.199][mmc]: mmc 2 cmd timeout 100 status 100
[14.203][mmc]: smc 2 err, cmd 8, RTO
[14.206][mmc]: mmc 2 close bus gating and reset
[14.211][mmc]: mmc 2 cmd timeout 100 status 100
[14.215][mmc]: smc 2 err, cmd 55, RTO
[14.219][mmc]: mmc 2 close bus gating and reset
[14.234][mmc]: gen_tuning_blk_bus8: total blk 10
[14.239][mmc]: gen_tuning_blk_bus4: total blk 6
[14.243][mmc]: Using 8 bit tuning now
[14.278][mmc]: write_tuning_try_freq: write ok
[14.283][mmc]: Pattern compare ok
[14.286][mmc]: Write tuning pattern ok
[14.289][mmc]: ================== HSSDR52_SDR25...
[14.294][mmc]: skip freq 400000
[14.297][mmc]: skip freq 25000000
[14.300][mmc]: freq: 2-50000000-64-4
[15.069][mmc]: [0-63|64]
[15.071][mmc]: ================== HS200_SDR104...
[15.076][mmc]: skip freq 400000
[15.078][mmc]: skip freq 25000000
[15.081][mmc]: freq: 2-50000000-64-4
[15.840][mmc]: freq: 3-100000000-64-4
[16.539][mmc]: freq: 4-150000000-64-4
[17.157][mmc]: freq: 5-200000000-64-4
[17.756][mmc]: [0-62|63]
[17.759][mmc]: [0-62|63]
[17.761][mmc]: [0-0|1] [7-62|56]
[17.764][mmc]: [0-15|16] [23-61|39]
[17.767][mmc]: ================== HSDDR52_DDR50...
[17.772][mmc]: skip freq 400000
[17.775][mmc]: freq: 1-25000000-64-4
[18.503][mmc]: freq: 2-50000000-64-4
[19.149][mmc]: [0-59|60]
[19.151][mmc]: [0-44|45] [47-59|13]
[19.154][mmc]: ================== HS400...
[19.158][mmc]: skip freq 400000
[19.161][mmc]: skip freq 25000000
[19.164][mmc]: freq: 2-50000000
[19.189][mmc]: freq: 3-100000000
[19.213][mmc]: freq: 4-150000000
[19.235][mmc]: freq: 5-200000000
[19.257][mmc]: speed mode: HS400
[19.260][mmc]: [0-63|64]
[19.262][mmc]: [0-63|64]
[19.265][mmc]: [0-3|4] [7-63|57]
[19.268][mmc]: [0-20|21] [23-63|41]
[19.271][mmc]: skip freq 400000
[19.274][mmc]: skip freq 25000000
[19.277][mmc]: freq: 2-50000000-64-4
[19.963][mmc]: freq: 3-100000000-64-4
[20.400][mmc]: freq: 4-150000000-64-4
[20.679][mmc]: freq: 5-200000000-64-4
[20.888][mmc]: [2-63|62]
[20.890][mmc]: [2-41|40]
[20.892][mmc]: [2-26|25]
[20.895][mmc]: *** hs400 200m: data win=10, delay cell = 108 ***
[20.900][mmc]: [2-19|18]
[20.903][mmc]: DS26/SDR12: 0xffffffff 0xffffffff
[20.907][mmc]: HSSDR52/SDR25: 0xff20ffff 0xffffffff
[20.912][mmc]: HSDDR52/DDR50: 0xff161eff 0xffffffff
[20.916][mmc]: HS200/SDR104: 0x1f1fffff 0xffff2a23
[20.921][mmc]: HS400: 0x1621ffff 0xffff0b0e
[20.925][mmc]: HS400: 0x2020ffff 0xffff2b23
[20.929][mmc]: Best spd md: 4-HS400, freq: 5-200000000, Bus width: 8
[20.935]Loading Environment from SUNXI_FLASH... OK
[20.940]try to burn key
[20.942]out of usb burn from boot: not boot mode
sunxi work mode=0x10
run usb efex
buf queue page size = 65536
delay time 2500
usb init ok
set address 0xe
set address 0xe ok
set address 0xf
set address 0xf ok
SUNXI_EFEX_ERASE_TAG
erase_flag = 0x12
origin_erase_flag = 0x1
FEX_CMD_fes_verify_status
FEX_CMD_fes_verify last err=0
the 0 mbr table is ok
the 1 mbr table is ok
the 2 mbr table is ok
the 3 mbr table is ok
*************MBR DUMP***************
total mbr part 29
part[0] name :bootloader_a
part[0] classname :DISK
part[0] addrlo :0x8000
part[0] lenlo :0x10000
part[0] user_type :32768
part[0] keydata :0
part[0] ro :0
part[1] name :bootloader_b
part[1] classname :DISK
part[1] addrlo :0x18000
part[1] lenlo :0x10000
part[1] user_type :32768
part[1] keydata :0
part[1] ro :0
part[2] name :env_a
part[2] classname :DISK
part[2] addrlo :0x28000
part[2] lenlo :0x200
part[2] user_type :32768
part[2] keydata :0
part[2] ro :0
part[3] name :env_b
part[3] classname :DISK
part[3] addrlo :0x28200
part[3] lenlo :0x200
part[3] user_type :32768
part[3] keydata :0
part[3] ro :0
part[4] name :boot_a
part[4] classname :DISK
part[4] addrlo :0x28400
part[4] lenlo :0x20000
part[4] user_type :32768
part[4] keydata :0
part[4] ro :0
part[5] name :boot_b
part[5] classname :DISK
part[5] addrlo :0x48400
part[5] lenlo :0x20000
part[5] user_type :32768
part[5] keydata :0
part[5] ro :0
part[6] name :vendor_boot_a
part[6] classname :DISK
part[6] addrlo :0x68400
part[6] lenlo :0x10000
part[6] user_type :32768
part[6] keydata :0
part[6] ro :0
part[7] name :vendor_boot_b
part[7] classname :DISK
part[7] addrlo :0x78400
part[7] lenlo :0x10000
part[7] user_type :32768
part[7] keydata :0
part[7] ro :0
part[8] name :init_boot_a
part[8] classname :DISK
part[8] addrlo :0x88400
part[8] lenlo :0x4000
part[8] user_type :32768
part[8] keydata :0
part[8] ro :0
part[9] name :init_boot_b
part[9] classname :DISK
part[9] addrlo :0x8c400
part[9] lenlo :0x4000
part[9] user_type :32768
part[9] keydata :0
part[9] ro :0
part[10] name :super
part[10] classname :DISK
part[10] addrlo :0x90400
part[10] lenlo :0x700000
part[10] user_type :32768
part[10] keydata :0
part[10] ro :0
part[11] name :misc
part[11] classname :DISK
part[11] addrlo :0x790400
part[11] lenlo :0x8000
part[11] user_type :32768
part[11] keydata :0
part[11] ro :0
part[12] name :vbmeta_a
part[12] classname :DISK
part[12] addrlo :0x798400
part[12] lenlo :0x100
part[12] user_type :32768
part[12] keydata :0
part[12] ro :0
part[13] name :vbmeta_b
part[13] classname :DISK
part[13] addrlo :0x798500
part[13] lenlo :0x100
part[13] user_type :32768
part[13] keydata :0
part[13] ro :0
part[14] name :vbmeta_system_a
part[14] classname :DISK
part[14] addrlo :0x798600
part[14] lenlo :0x80
part[14] user_type :32768
part[14] keydata :0
part[14] ro :0
part[15] name :vbmeta_system_b
part[15] classname :DISK
part[15] addrlo :0x798680
part[15] lenlo :0x80
part[15] user_type :32768
part[15] keydata :0
part[15] ro :0
part[16] name :vbmeta_vendor_a
part[16] classname :DISK
part[16] addrlo :0x798700
part[16] lenlo :0x80
part[16] user_type :32768
part[16] keydata :0
part[16] ro :0
part[17] name :vbmeta_vendor_b
part[17] classname :DISK
part[17] addrlo :0x798780
part[17] lenlo :0x80
part[17] user_type :32768
part[17] keydata :0
part[17] ro :0
part[18] name :frp
part[18] classname :DISK
part[18] addrlo :0x798800
part[18] lenlo :0x400
part[18] user_type :32768
part[18] keydata :32768
part[18] ro :0
part[19] name :empty
part[19] classname :DISK
part[19] addrlo :0x798c00
part[19] lenlo :0x7800
part[19] user_type :32768
part[19] keydata :0
part[19] ro :0
part[20] name :metadata
part[20] classname :DISK
part[20] addrlo :0x7a0400
part[20] lenlo :0x8000
part[20] user_type :32768
part[20] keydata :0
part[20] ro :0
part[21] name :treadahead
part[21] classname :DISK
part[21] addrlo :0x7a8400
part[21] lenlo :0x30000
part[21] user_type :32768
part[21] keydata :0
part[21] ro :0
part[22] name :private
part[22] classname :DISK
part[22] addrlo :0x7d8400
part[22] lenlo :0x8000
part[22] user_type :32768
part[22] keydata :0
part[22] ro :0
part[23] name :dtbo_a
part[23] classname :DISK
part[23] addrlo :0x7e0400
part[23] lenlo :0x1000
part[23] user_type :32768
part[23] keydata :0
part[23] ro :0
part[24] name :dtbo_b
part[24] classname :DISK
part[24] addrlo :0x7e1400
part[24] lenlo :0x1000
part[24] user_type :32768
part[24] keydata :0
part[24] ro :0
part[25] name :media_data
part[25] classname :DISK
part[25] addrlo :0x7e2400
part[25] lenlo :0x8000
part[25] user_type :32768
part[25] keydata :0
part[25] ro :0
part[26] name :Reserve0
part[26] classname :DISK
part[26] addrlo :0x7ea400
part[26] lenlo :0x20000
part[26] user_type :32768
part[26] keydata :0
part[26] ro :0
part[27] name :pstore
part[27] classname :DISK
part[27] addrlo :0x80a400
part[27] lenlo :0x10000
part[27] user_type :32768
part[27] keydata :0
part[27] ro :0
part[28] name :UDISK
part[28] classname :DISK
part[28] addrlo :0x81a400
part[28] lenlo :0x0
part[28] user_type :33024
part[28] keydata :0
part[28] ro :0
[24.598]erase all part start
need erase flash: 18
[24.603][mmc]: erase from: 0, to: 61194239, cnt: 61194240, erase_group: 1024
[25.101][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0x1e9 ms
[25.107]read item0 copy0
[25.117]Item0 (Map) magic is bad
[25.119]the secure storage item0 copy0 magic is bad
[25.131]Item0 (Map) magic is bad
[25.134]the secure storage item0 copy1 magic is bad
[25.138]Item0 (Map) magic is bad
[25.141]the secure storage map is empty
[25.159]erase secure storage: 0 ok
SUNXI_EFEX_MBR_TAG
mbr size = 0x10000
write primary GPT success
write Backup GPT success
[25.173]update partition map
******Has init
FEX_CMD_fes_verify_value, start 0x8000, size high 0x0:low 0x111d400
FEX_CMD_fes_verify_value 0xa14dbd74
FEX_CMD_fes_verify_value, start 0x28000, size high 0x0:low 0x20000
FEX_CMD_fes_verify_value 0xf00b1936
FEX_CMD_fes_verify_value, start 0x28400, size high 0x0:low 0x4000000
FEX_CMD_fes_verify_value 0x2d9ccd73
FEX_CMD_fes_verify_value, start 0x68400, size high 0x0:low 0x2000000
FEX_CMD_fes_verify_value 0x7435dd4a
FEX_CMD_fes_verify_value, start 0x88400, size high 0x0:low 0x800000
FEX_CMD_fes_verify_value 0xbad6702e
FEX_CMD_fes_verify_value, start 0x790400, size high 0x0:low 0x1000000
FEX_CMD_fes_verify_value 0xb961f417
FEX_CMD_fes_verify_value, start 0x798400, size high 0x0:low 0x2000
FEX_CMD_fes_verify_value 0x81ff878d
FEX_CMD_fes_verify_value, start 0x798600, size high 0x0:low 0x1000
FEX_CMD_fes_verify_value 0xd3178e38
FEX_CMD_fes_verify_value, start 0x798700, size high 0x0:low 0x1000
FEX_CMD_fes_verify_value 0xccfd9b0c
FEX_CMD_fes_verify_value, start 0x7e0400, size high 0x0:low 0x200000
FEX_CMD_fes_verify_value 0x9d9c6d85
FEX_CMD_fes_verify_value, start 0x7ea400, size high 0x0:low 0x1000000
FEX_CMD_fes_verify_value 0x0
bootfile_mode=4
SUNXI_EFEX_BOOT1_TAG
boot1 size = 0x13c000, max size = 0x400000
uboot size = 0x13c000
storage type = 2
bootfile_mode=4
SUNXI_EFEX_BOOT0_TAG
boot0 size = 0x3c000
[68.943][mmc]: write mmc 2 info ok
storage type = 2
sunxi_efex_next_action=2
exit usb
next work 2
SUNXI_UPDATE_NEXT_ACTION_REBOOT▒......
[176]HELLO! BOOT0 is starting!
[179]BOOT0 commit : {cfda5fbe}
[188]volume key pressed!
[190][mmc]: mmc driver ver 2024-03-20 10:36
[200][mmc]: Wrong media type 0x0, but host sdc2, try mmc first
[206][mmc]: ***Try MMC card 2***
[228][mmc]: RMCA OK!
[235][mmc]: MMC 5.1
[237][mmc]: HSSDR52/SDR25 8 bit
[240][mmc]: 50000000 Hz
[242][mmc]: 29880 MB
[244][mmc]: ***SD/MMC 2 init OK!!!***
[249]DRAM BOOT DRIVE INFO: V0.599
[254]DRAM_VCC set to 560 mv
[257]DRAM CLK =1800 MHZ
[259]DRAM Type =9 (8:LPDDR4,9:LPDDR5)
[386]Training result is = 7
[388]DRAM Pstate 0 training, frequency is 1800 Mhz
[397]Actual DRAM SIZE =6144 M
[400]DRAM SIZE =6144 MBytes, para1 = a10a, para2 = 18001001, dram_tpr13 = 10061
[414]DRAM simple test OK.
[456]error: dtb not found for scp
[461]tunning data addr:0x4a0003e8
[464]Jump to ATF: monitor_base = 0x48000000, uboot_base = 0x4a000000, optee_base = 0x0
NOTICE: BL31: OP-TEE 32bit detected
NOTICE: BL31: U-BOOT 32bit detected
NOTICE: BL31: v2.5(debug):eec78cd3c
NOTICE: BL31: Built : 14:02:13, Oct 29 2024
NOTICE: BL31: No DTB found.
ERROR: Error initializing runtime service opteed_fast
[00.511]CPU: Allwinner Family
[00.514]Model: sun60iw2
I2C: ready
[00.574]DRAM: 6 GiB
[00.578]Relocation Offset is: 75dac000
[00.634]secure enable bit: 0
[00.637]PMU: AXP8191
[00.639]PMU: AXP8191 VER_A
[00.651][AXP8191] onoff status: 0x50 = 0x0, 0x51 = 0x0
[00.656][AXP8191] charge status: 0x4 = 0x0
[00.660]CPU=1014 MHz,PLL6=1200 Mhz,AHB=200 Mhz, APB1=24Mhz MBus=600Mhz
[00.666]gic: sec monitor mode
[00.671]flash init start
[00.673]workmode = 0,storage type = 2
[00.677][mmc]: mmc driver ver uboot2018:2024-10-18 9:01:00
[00.685][mmc]: SUNXI SDMMC Controller Version:0x50610
[00.695][mmc]: 200 MHz...
[00.697][mmc]: sample: 23 - 108(ps)
[00.700][mmc]: ds: 23 - 108(ps)
[00.718][mmc]: Best spd md: 4-HS400, freq: 5-200000000, Bus width: 8
[00.724]sunxi flash init ok
[00.740]Loading Environment from SUNXI_FLASH... [00.751]the secure storage item0 copy0 magic is bad
[00.763]the secure storage item0 copy1 magic is bad
erase secure storage failed
OK
[00.827]NOT support bridge yet
[00.829]Warn: no find panel or bridge
[00.837]failed to request regulator(avdd-supply): -22
[00.842]failed to request regulator_vol(avdd-output-voltage): -22
[00.848]failed to request regulator(avee-supply): -22
[00.852]failed to request regulator_vol(avee-output-voltage): -22
** Unrecognized filesystem type **
[00.868]get file(disp_rsl.fex) size from Reserve0 error
dsi0@5506000: detailed mode clock 50000 kHz, flags[0]
H: 1024 1174 1194 1344
V: 0600 0608 0611 0635
bus_format: 0
[00.884]hdmi@5520000 disconnected
[00.887]bad framebuffer width 0
[00.904]m:6, m0:1, m1:6, m2:3, m3:12
[01.816]failed to display uboot logo for disp 64
[01.827]the secure storage item0 copy0 magic is bad
[01.838]the secure storage item0 copy1 magic is bad
[01.843]usb burn from boot
delay time 0
[01.849]usb prepare ok
[02.057]usb sof ok
[02.059]usb probe ok
[02.061]usb setup ok
set address 0x10
set address 0x10 ok
set address 0x11
set address 0x11 ok
[02.467]do_burn_from_boot usb : have no handshake
skip update boot_param
List file under ULI/factory
[02.481]update part info
[02.485]battery temp is -1
[02.502]update bootcmd
[02.570]change working_fdt 0xbbd5be30 to 0xbbd2be30
ret 0
[02.690]no battery, disabled battery functons
[02.696]update dts
Android's image name: arm64
kernel addr 0x40080000 0x4289a000 exceed boot_a scope
boot_a addr 0x4007f000 0x4289a000
ERROR: reserving fdt memory region failed (addr=bbe31000 size=258000)
[03.033]Starting kernel ...
[03.036]total: 3036 ms
[03.038][mmc]: mmc exit start
[03.055][mmc]: mmc 2 exit ok
NOTICE: [SCP] :wait arisc ready....
NOTICE: [SCP] :arisc version: [c82a3c8d0b638500aa1ffe037d00fa24cf20a903-dirty]
NOTICE: [SCP] :arisc startup ready
NOTICE: [SCP] :arisc startup notify message feedback
NOTICE: [SCP] :sunxi-arisc driver is starting
NOTICE: BL3-1: Next image address = 0x40080000
NOTICE: BL3-1: Next image spsr = 0x3c5
[ 0.000000][ T0] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[ 0.000000][ T0] Linux version 5.15.119-gc82a3c8d0b63-dirty (xtx@ubuntu-201) (Android (8490178, based on r450784d) clang version 14.0.6 (https://android.googlesource.com/toolchain/llvm-project 4c603efb0cca074e9238af8b4106c30add4418f6), LLD 14.0.6) #13 SMP PREEMPT Mon Mar 31 06:56:51 UTC 2025
[ 0.000000][ T0] Machine model: sun60iw2
[ 0.000000][ T0] Stack Depot is disabled
[ 0.000000][ T0] KVM is not available. Ignoring kvm-arm.mode
[ 0.000000][ T0] earlycon: uart8250 at MMIO32 0x0000000002500000 (options '')
[ 0.000000][ T0] printk: bootconsole [uart8250] enabled
[ 0.000000][ T0] efi: UEFI not found.
[ 0.000000][ T0] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
[ 0.000000][ T0] OF: reserved mem: 0x0000000048000000..0x0000000048ffffff (16384 KiB) map non-reusable bl31
[ 0.000000][ T0] Zone ranges:
[ 0.000000][ T0] DMA32 [mem 0x0000000040000000-0x00000000ffffffff]
[ 0.000000][ T0] Normal [mem 0x0000000100000000-0x00000001bfffffff]
[ 0.000000][ T0] Movable zone start for each node
[ 0.000000][ T0] Early memory node ranges
[ 0.000000][ T0] node 0: [mem 0x0000000040000000-0x00000001bfffffff]
[ 0.000000][ T0] Initmem setup node 0 [mem 0x0000000040000000-0x00000001bfffffff]
[ 0.000000][ T0] cma: Reserved 8 MiB at 0x00000000ff800000
[ 0.000000][ T0] psci: probing for conduit method from DT.
[ 0.000000][ T0] psci: PSCIv1.1 detected in firmware.
[ 0.000000][ T0] psci: Using standard PSCI v0.2 function IDs
[ 0.000000][ T0] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000][ T0] psci: SMC Calling Convention v1.2
[ 0.000000][ T0] Load bootconfig: 810 bytes 50 nodes
[ 0.000000][ T0] percpu: Embedded 29 pages/cpu s81752 r8192 d28840 u118784
[ 0.000000][ T0] pcpu-alloc: s81752 r8192 d28840 u118784 alloc=29*4096
[ 0.000000][ T0] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[ 0.000000][ T0] Detected VIPT I-cache on CPU0
[ 0.000000][ T0] CPU features: SYS_ID_AA64MMFR1_EL1[11:8]: forced to 0
[ 0.000000][ T0] CPU features: detected: GIC system register CPU interface
[ 0.000000][ T0] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000][ T0] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000][ T0] CPU features: detected: Qualcomm erratum 1009, or ARM erratum 1286807, 2441009
[ 0.000000][ T0] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000][ T0] Built 1 zonelists, mobility grouping on. Total pages: 1548288
[ 0.000000][ T0] Kernel command line: stack_depot_disable=on kasan.stacktrace=off kvm-arm.mode=protected cgroup_disable=pressure rcutree.rcu_idle_gp_delay=1 cpufreq.default_governor=performance earlycon=uart8250,mmio32,0x02500000 clk_ignore_unused= initcall_debug=0 console=ttyAS0,115200 loglevel=8 root=/dev/mmcblk0p4 init=/init init_rc= cma=8M slub_min_objects=8 snum=7c00161172014741e8d mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 sn2= deferred_probe_timeout=10 boot_type=2 gpt=1 uboot_message=2018.07(03/31/2025-06:54:43) bootreason=button uboot_backup=ubootA loop.max_part=4 mmcblk.perdev_minors=16 firmware_class.path=/vendor/etc/firmware bootconfig buildvariant=userdebug
[ 0.000000][ T0] cgroup: Disabling pressure control group feature
[ 0.000000][ T0] Unknown kernel command line parameters "init_rc= snum=7c00161172014741e8d mac_addr= wifi_mac= bt_mac= specialstr= sn2= boot_type=2 uboot_message=2018.07(03/31/2025-06:54:43) bootreason=button uboot_backup=ubootA buildvariant=userdebug", will be passed to user space.
[ 0.000000][ T0] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000][ T0] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000][ T0] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[ 0.000000][ T0] software IO TLB: mapped [mem 0x00000000fb800000-0x00000000ff800000] (64MB)
[ 0.000000][ T0] Memory: 6008524K/6291456K available (18432K kernel code, 2214K rwdata, 18820K rodata, 1472K init, 614K bss, 274740K reserved, 8192K cma-reserved)
[ 0.000000][ T0] SLUB: HWalign=64, Order=0-3, MinObjects=8, CPUs=8, Nodes=1
[ 0.000000][ T0] trace event string verifier disabled
[ 0.000000][ T0] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000][ T0] rcu: RCU event tracing is enabled.
[ 0.000000][ T0] rcu: RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000][ T0] rcu: RCU restricting CPUs from NR_CPUS=32 to nr_cpu_ids=8.
[ 0.000000][ T0] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.000000][ T0] Trampoline variant of Tasks RCU enabled.
[ 0.000000][ T0] Tracing variant of Tasks RCU enabled.
[ 0.000000][ T0] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000][ T0] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[ 0.000000][ T0] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000][ T0] GICv3: 256 SPIs implemented
[ 0.000000][ T0] GICv3: 0 Extended SPIs implemented
[ 0.000000][ T0] GICv3: Distributor has no Range Selector support
[ 0.000000][ T0] Root IRQ handler: gic_handle_irq.10d7cf410c142aff6d31b6303c3f9f87.cfi_jt
[ 0.000000][ T0] GICv3: 16 PPIs implemented
[ 0.000000][ T0] GICv3: CPU0: found redistributor 0 region 0:0x0000000003460000
[ 0.000000][ T0] ITS: No ITS available, not enabling LPIs
[ 0.000000][ T0] rcu: Offload RCU callbacks from CPUs: (none).
[ 0.000000][ T0] kfence: initialized - using 524288 bytes for 63 objects at 0x(____ptrval____)-0x(____ptrval____)
[ 0.000000][ T0] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
[ 0.000000][ T0] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000001][ T0] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.011206][ T0] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[ 0.023251][ T0] pid_max: default: 32768 minimum: 301
[ 0.029401][ T0] LSM: Security Framework initializing
[ 0.035321][ T0] SELinux: Initializing.
[ 0.040291][ T0] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.049394][ T0] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.062026][ T1] rcu: Hierarchical SRCU implementation.
[ 0.069177][ T1] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.079182][ T1] EFI services will not be available.
[ 0.085811][ T1] smp: Bringing up secondary CPUs ...
[ 0.092555][ T0] Detected VIPT I-cache on CPU1
[ 0.092593][ T0] GICv3: CPU1: found redistributor 100 region 0:0x0000000003480000
[ 0.092646][ T0] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[ 0.093765][ T0] Detected VIPT I-cache on CPU2
[ 0.093797][ T0] GICv3: CPU2: found redistributor 200 region 0:0x00000000034a0000
[ 0.093835][ T0] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[ 0.094846][ T0] Detected VIPT I-cache on CPU3
[ 0.094873][ T0] GICv3: CPU3: found redistributor 300 region 0:0x00000000034c0000
[ 0.094904][ T0] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[ 0.095934][ T0] Detected VIPT I-cache on CPU4
[ 0.095962][ T0] GICv3: CPU4: found redistributor 400 region 0:0x00000000034e0000
[ 0.095991][ T0] CPU4: Booted secondary processor 0x0000000400 [0x412fd050]
[ 0.097035][ T0] Detected VIPT I-cache on CPU5
[ 0.097063][ T0] GICv3: CPU5: found redistributor 500 region 0:0x0000000003500000
[ 0.097091][ T0] CPU5: Booted secondary processor 0x0000000500 [0x412fd050]
[ 0.098117][ T0] CPU features: detected: Spectre-v4
[ 0.098122][ T0] CPU features: detected: Spectre-BHB
[ 0.098126][ T0] Detected PIPT I-cache on CPU6
[ 0.098142][ T0] GICv3: CPU6: found redistributor 600 region 0:0x0000000003520000
[ 0.098160][ T0] CPU6: Booted secondary processor 0x0000000600 [0x414fd0b1]
[ 0.099144][ T0] Detected PIPT I-cache on CPU7
[ 0.099164][ T0] GICv3: CPU7: found redistributor 700 region 0:0x0000000003540000
[ 0.099183][ T0] CPU7: Booted secondary processor 0x0000000700 [0x414fd0b1]
[ 0.099267][ T1] smp: Brought up 1 node, 8 CPUs
[ 0.266949][ T1] SMP: Total of 8 processors activated.
[ 0.272877][ T1] CPU features: detected: 32-bit EL0 Support
[ 0.279280][ T1] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.289499][ T1] CPU features: detected: Common not Private translations
[ 0.297149][ T1] CPU features: detected: CRC32 instructions
[ 0.303563][ T1] CPU features: detected: RCpc load-acquire (LDAPR)
[ 0.310640][ T1] CPU features: detected: LSE atomic instructions
[ 0.317523][ T1] CPU features: detected: Privileged Access Never
[ 0.324403][ T1] CPU features: detected: RAS Extension Support
[ 0.331093][ T1] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.375725][ T1] CPU: All CPU(s) started at EL1
[ 0.381083][ T19] alternatives: patching kernel code
[ 0.425590][ T1] Registered cp15_barrier emulation handler
[ 0.431914][ T1] Registered setend emulation handler
[ 0.437644][ T1] KASLR disabled due to lack of seed
[ 0.443388][ T1] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.454558][ T1] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.463257][ T1] pinctrl core: initialized pinctrl subsystem
[ 0.470425][ T1] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.480071][ T1] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.489149][ T1] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.498686][ T1] audit: initializing netlink subsys (disabled)
[ 0.505553][ T80] audit: type=2000 audit(0.328:1): state=initialized audit_enabled=0 res=1
[ 0.505817][ T1] thermal_sys: Registered thermal governor 'step_wise'
[ 0.514825][ T1] thermal_sys: Registered thermal governor 'user_space'
[ 0.522174][ T1] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.530251][ T1] cpuidle: using governor menu
[ 0.543389][ T1] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.551779][ T1] ASID allocator initialised with 32768 entries
[ 0.558547][ T1] Serial: AMBA PL011 UART driver
[ 0.578553][ T1] platform 5501000.tcon0: Fixing up cyclic dependency with 5000000.de
[ 0.587564][ T1] platform 5506000.dsi0: Fixing up cyclic dependency with 5501000.tcon0
[ 0.596791][ T1] platform 5730000.tcon3: Fixing up cyclic dependency with 5000000.de
[ 0.605712][ T1] platform 5731000.tcon4: Fixing up cyclic dependency with 5000000.de
[ 0.614648][ T1] platform 5520000.hdmi: Fixing up cyclic dependency with 5730000.tcon3
[ 0.631804][ T1] iommu: Default domain type: Translated
[ 0.637948][ T1] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.645969][ T1] SCSI subsystem initialized
[ 0.650927][ T1] usbcore: registered new interface driver usbfs
[ 0.657722][ T1] usbcore: registered new interface driver hub
[ 0.664321][ T1] usbcore: registered new device driver usb
[ 0.670697][ T1] mc: Linux media interface: v0.10
[ 0.676093][ T1] videodev: Linux video capture interface: v2.00
[ 0.682916][ T1] EDAC MC: Ver: 3.0.0
[ 0.687831][ T1] Advanced Linux Sound Architecture Driver Initialized.
[ 0.695569][ T1] Bluetooth: Core ver 2.22
[ 0.700127][ T1] NET: Registered PF_BLUETOOTH protocol family
[ 0.706131][ T1] Bluetooth: HCI device and connection manager initialized
[ 0.713862][ T1] Bluetooth: HCI socket layer initialized
[ 0.719988][ T1] Bluetooth: L2CAP socket layer initialized
[ 0.726239][ T1] Bluetooth: SCO socket layer initialized
[ 0.732435][ T1] nfc: nfc_init: NFC Core ver 0.1
[ 0.737798][ T1] NET: Registered PF_NFC protocol family
[ 0.744146][ T1] clocksource: Switched to clocksource arch_sys_counter
[ 0.773471][ T1] VFS: Disk quotas dquot_6.6.0
[ 0.778592][ T1] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.787374][ T1] NET: Registered PF_INET protocol family
[ 0.793795][ T1] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.805406][ T1] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.815696][ T1] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.824962][ T1] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.834814][ T1] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.844505][ T1] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.852583][ T1] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.860990][ T1] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.869178][ T1] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.876174][ T1] NET: Registered PF_XDP protocol family
[ 0.882197][ T1] PCI: CLS 0 bytes, default 64
[ 0.887640][ T8] Trying to unpack rootfs image as initramfs...
[ 0.894583][ T1] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.904250][ T1] kvm [1]: HYP mode not available
[ 0.910328][ T1] Initialise system trusted keyrings
[ 0.916089][ T1] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 0.928051][ T1] fuse: init (API version 7.36)
[ 0.960477][ T1] Key type asymmetric registered
[ 0.965693][ T1] Asymmetric key parser 'x509' registered
[ 0.971889][ T1] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 241)
[ 0.980720][ T1] io scheduler mq-deadline registered
[ 0.986368][ T1] io scheduler kyber registered
[ 0.991598][ T1] io scheduler bfq registered
[ 0.999925][ T22] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 1.010986][ T1] brd: module loaded
[ 1.022092][ T1] loop: module loaded
[ 1.028304][ T1] wireguard: WireGuard 1.0.0 loaded. See www.wireguard.com for information.
[ 1.037626][ T1] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <Jason@zx2c4.com>. All Rights Reserved.
[ 1.040110][ T8] Freeing initrd memory: 22396K
[ 1.049267][ T1] MACsec IEEE 802.1AE
[ 1.058637][ T1] tun: Universal TUN/TAP device driver, 1.6
[ 1.064988][ T1] CAN device driver interface
[ 1.069955][ T1] PPP generic driver version 2.4.2
[ 1.075436][ T1] PPP BSD Compression module registered
[ 1.081356][ T1] PPP Deflate Compression module registered
[ 1.087669][ T1] PPP MPPE Compression module registered
[ 1.093684][ T1] NET: Registered PF_PPPOX protocol family
[ 1.099732][ T1] PPTP driver version 0.8.5
[ 1.104757][ T1] usbcore: registered new interface driver rtl8150
[ 1.111749][ T1] usbcore: registered new interface driver r8152
[ 1.118544][ T1] usbcore: registered new interface driver asix
[ 1.124655][ T1] usbcore: registered new interface driver ax88179_178a
[ 1.132110][ T1] usbcore: registered new interface driver cdc_ether
[ 1.139278][ T1] usbcore: registered new interface driver cdc_eem
[ 1.146267][ T1] usbcore: registered new interface driver cdc_ncm
[ 1.152958][ T1] usbcore: registered new interface driver aqc111
[ 1.159839][ T1] usbcore: registered new interface driver r8153_ecm
[ 1.167381][ T1] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.174594][ T1] ehci-pci: EHCI PCI platform driver
[ 1.180240][ T1] ehci-platform: EHCI generic platform driver
[ 1.187024][ T1] usbcore: registered new interface driver cdc_acm
[ 1.193967][ T1] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.203530][ T1] usbcore: registered new interface driver uas
[ 1.210138][ T1] usbcore: registered new interface driver usb-storage
[ 1.217634][ T1] usbcore: registered new interface driver xpad
[ 1.224279][ T1] usbcore: registered new interface driver uvcvideo
[ 1.231343][ T1] gspca_main: v2.14.0 registered
[ 1.236769][ T1] device-mapper: uevent: version 1.0.3
[ 1.242710][ T1] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[ 1.252697][ T1] Bluetooth: HCI UART driver ver 2.3
[ 1.258198][ T1] Bluetooth: HCI UART protocol H4 registered
[ 1.264602][ T1] Bluetooth: HCI UART protocol LL registered
[ 1.271034][ T1] Bluetooth: HCI UART protocol Broadcom registered
[ 1.278008][ T1] Bluetooth: HCI UART protocol QCA registered
[ 1.285541][ T1] mmcblk: using 16 minors per device
[ 1.291191][ T1] sdhci: Secure Digital Host Controller Interface driver
[ 1.298729][ T1] sdhci: Copyright(c) Pierre Ossman
[ 1.304265][ T1] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.311390][ T1] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 1.319243][ T1] hid: raw HID events driver (C) Jiri Kosina
[ 1.326126][ T1] usbcore: registered new interface driver usbhid
[ 1.333001][ T1] usbhid: USB HID core driver
[ 1.338099][ T1] ashmem: initialized
[ 1.342479][ T1] gnss: GNSS driver registered with major 509
[ 1.349344][ T1] usbcore: registered new interface driver snd-usb-audio
[ 1.357177][ T1] GACT probability NOT on
[ 1.361548][ T1] Mirror/redirect action on
[ 1.366332][ T1] netem: version 1.3
[ 1.370334][ T1] u32 classifier
[ 1.374060][ T1] input device check on
[ 1.378836][ T1] Actions configured
[ 1.385137][ T1] xt_time: kernel timezone is -0000
[ 1.390815][ T1] ipip: IPv4 and MPLS over IPv4 tunneling driver
[ 1.397847][ T1] gre: GRE over IPv4 demultiplexor driver
[ 1.403961][ T1] ip_gre: GRE over IPv4 tunneling driver
[ 1.410455][ T1] IPv4 over IPsec tunneling driver
[ 1.415866][ T1] Initializing XFRM netlink socket
[ 1.421344][ T1] IPsec XFRM device driver
[ 1.426317][ T1] NET: Registered PF_INET6 protocol family
[ 1.433706][ T1] Segment Routing with IPv6
[ 1.438519][ T1] In-situ OAM (IOAM) with IPv6
[ 1.443665][ T1] mip6: Mobile IPv6
[ 1.448024][ T1] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 1.455708][ T1] ip6_gre: GRE over IPv6 tunneling driver
[ 1.462024][ T1] NET: Registered PF_PACKET protocol family
[ 1.468352][ T1] NET: Registered PF_KEY protocol family
[ 1.474434][ T1] can: controller area network core
[ 1.480042][ T1] NET: Registered PF_CAN protocol family
[ 1.486074][ T1] can: raw protocol
[ 1.490097][ T1] can: broadcast manager protocol
[ 1.495448][ T1] can: netlink gateway - max_hops=1
[ 1.501195][ T1] Bluetooth: RFCOMM TTY layer initialized
[ 1.507323][ T1] Bluetooth: RFCOMM socket layer initialized
[ 1.513734][ T1] Bluetooth: RFCOMM ver 1.11
[ 1.518610][ T1] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.525214][ T1] Bluetooth: HIDP socket layer initialized
[ 1.531430][ T1] l2tp_core: L2TP core driver, V2.0
[ 1.536974][ T1] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 1.542987][ T1] 8021q: 802.1Q VLAN Support v1.8
[ 1.548348][ T1] tipc: Activated (version 2.0.0)
[ 1.553793][ T1] NET: Registered PF_TIPC protocol family
[ 1.559972][ T1] tipc: Started in single node mode
[ 1.565627][ T1] NET: Registered PF_IEEE802154 protocol family
[ 1.572443][ T1] NET: Registered PF_VSOCK protocol family
[ 1.579433][ T1] registered taskstats version 1
[ 1.584703][ T1] Loading compiled-in X.509 certificates
[ 1.591081][ T108] cryptomgr_probe (108) used greatest stack depth: 14016 bytes left
[ 1.592666][ T1] Loaded X.509 cert 'Build time autogenerated kernel key: ce4e882886e7b069224779dcae2c567271036ca1'
[ 1.612155][ T1] page_owner is disabled
[ 1.616371][ T1] Key type .fscrypt registered
[ 1.621437][ T1] Key type fscrypt-provisioning registered
[ 1.629066][ T1] clk: Not disabling unused clocks
[ 1.634535][ T1] ALSA device list:
[ 1.638551][ T1] No soundcards found.
[ 1.643107][ T1] Warning: unable to open an initial console.
[ 1.650156][ T1] Freeing unused kernel memory: 1472K
[ 1.660374][ T1] Run /init as init process
[ 1.665171][ T1] with arguments:
[ 1.668931][ T1] /init
[ 1.672182][ T1] with environment:
[ 1.676383][ T1] HOME=/
[ 1.679645][ T1] TERM=linux
[ 1.683370][ T1] init_rc=
[ 1.686600][ T1] snum=7c00161172014741e8d
[ 1.691633][ T1] mac_addr=
[ 1.695262][ T1] wifi_mac=
[ 1.698890][ T1] bt_mac=
[ 1.702327][ T1] specialstr=
[ 1.706146][ T1] sn2=
[ 1.709280][ T1] boot_type=2
[ 1.713104][ T1] uboot_message=2018.07(03/31/2025-06:54:43)
[ 1.719879][ T1] bootreason=button
[ 1.724271][ T1] uboot_backup=ubootA
[ 1.728618][ T1] buildvariant=userdebug
[ 1.735151][ T1] init: init first stage started!
[ 1.743053][ T109] init: Loading module /lib/modules/zsmalloc.ko with args ''
[ 1.743112][ T112] init: Loading module /lib/modules/twi-sunxi.ko with args ''
[ 1.743312][ T111] init: Loading module /lib/modules/timer-sun50i.ko with args ''
[ 1.743347][ T113] init: Loading module /lib/modules/tee.ko with args ''
[ 1.743400][ T110] init: Loading module /lib/modules/sunxi-uart-ng.ko with args ''
[ 1.743545][ T114] init: Loading module /lib/modules/sunxi-smc.ko with args ''
[ 1.743578][ T111] timer_sun50i: module verification failed: signature and/or required key missing - tainting kernel
[ 1.743664][ T115] init: Loading module /lib/modules/sunxi-power-notifier.ko with args ''
[ 1.744255][ T116] init: Loading module /lib/modules/sunxi_pd_test.ko with args ''
[ 1.816859][ T114] init: Loaded kernel module /lib/modules/sunxi-smc.ko
[ 1.831229][ T116] [drm] [DSI-PANEL] panel_dsi_init start
[ 1.837444][ T116] [drm] [DSI-PANEL] dsi driver regsiter finsh
[ 1.845139][ T113] i2c_dev: i2c /dev entries driver
[ 1.845757][ T112] BOOTEVENT: 1845.756325: ON
[ 1.846424][ T116] init (116) used greatest stack depth: 12480 bytes left
[ 1.852407][ T115] init (115) used greatest stack depth: 12368 bytes left
[ 1.864155][ T125] sunxi:ccu-ng:[INFO]: sunxi rtc-ccu version: 0.5.3
[ 1.865025][ T124] optee: probing for conduit method.
[ 1.865039][ T124] optee: api uid mismatch
[ 1.865042][ T124] optee: probe of firmware:optee failed with error -22
[ 1.865713][ T118] zram: Added device: zram0
[ 1.879489][ T119] AW BSP version: UNKNOWN, 2025-04-28 11:18:30
[ 1.883900][ T125] AW BSP version: UNKNOWN, 2025-04-28 11:18:30
[ 1.890517][ T119] sunxi:ccu-ng:[INFO]: r_ccu: sunxi ccu init OK
[ 1.896699][ T125] sunxi:ccu-ng:[INFO]: rtc_ccu: sunxi ccu init OK
[ 1.900534][ T119] sunxi:ccu-ng:[INFO]: sunxi ccu common driver version: 1.2.4
[ 1.907682][ T125] init (125) used greatest stack depth: 11920 bytes left
[ 1.911549][ T117] sunxi:ccu-ng:[INFO]: cpupll_ccu: sunxi ccu init OK
[ 1.911556][ T117] sunxi:ccu-ng:[INFO]: sunxi pll_cpu driver version: 0.0.3
[ 1.912364][ T117] sunxi:ccu-ng:[INFO]: ccu will stop clk in init process
[ 1.913991][ T119] sunxi:ccu-ng:[INFO]: sunxi ccu driver version: 0.5.4
[ 1.954266][ T117] sunxi:ccu-ng:[INFO]: ccu: sunxi ccu init OK
[ 1.973165][ T129] [ADDR_MGT] addr_mgt_probe: module version: v1.0.12
[ 1.973567][ T133] init (133) used greatest stack depth: 11376 bytes left
[ 1.978579][ T117] sunxi:ccu-ng:[INFO]: sunxi ccu driver version: 1.0.13
[ 1.986218][ T129] sunxi:sunxi_sidget_soc_ver_regs() +293: Failed to find "soc_bin" in dts.
[ 1.993341][ T126] [drm] [TCON] sunxi_tcon_probe start
[ 1.993476][ T117] sunxi:ccu_ddr:[ERR]: dram_clk:1800
[ 1.993482][ T117] sunxi:ccu_ddr:[ERR]: dram_div:0x11080503
[ 1.994428][ T117] sun55iw3-timer 3009000.timer: sun50i timer init:0xffffff0000000a
[ 1.994434][ T117] clocksource: timer: mask: 0xffffffffffffff max_cycles: 0x1623fa770, max_idle_ns: 440795202238 ns
[ 1.995080][ T117] sunxi:pwm-2527000.pwm:[INFO]: pwmchip probe success
[ 1.995431][ T117] sunxi:pwm-2528000.pwm:[INFO]: pwmchip probe success
[ 1.995800][ T117] sunxi:pwm-7023000.pwm:[INFO]: pwmchip probe success
[ 1.996083][ T117] sunxi iommu: irq = 19
[ 1.996115][ T117] sunxi iommu: irq = 20
[ 1.997464][ T117] sun6i-dma 4601000.dma-controller: sunxi dma probed, driver version: 1.2.6
[ 1.997853][ T117] pwm-backlight backlight1: supply power not found, using dummy regulator
[ 1.998144][ T117] sunxi:pin:[INFO]: sunxi r-pinctrl version: 0.0.2
[ 1.998458][ T8] sunxi:rtc:[INFO]: Saving SoC boot-reason: OTHERS
[ 1.999302][ T8] sunxi-rtc 7090000.rtc: registered as rtc0
[ 1.999311][ T117] sunxi:pin-7025000.pinctrl:[INFO]: pinctrl withstand voltage config mode=auto_hard
[ 1.999314][ T117] sunxi:pin:[INFO]: sunxi pinctrl core driver version: 1.4.8
[ 1.999360][ T8] sunxi-rtc 7090000.rtc: setting system clock to 2025-05-29T13:49:17 UTC (1748526557)
[ 1.999389][ T8] sunxi:rtc-7090000.rtc:[INFO]: sunxi rtc probed
[ 1.999439][ T117] sunxi:pin:[INFO]: sunxi pinctrl version: 0.6.7
[ 2.004331][ T129] [ADDR_MGT] addr_mgt_probe: success.
[ 2.009919][ T126] [drm] [SUNXI-TCON] sunxi_tcon_of_get_id 0
[ 2.016490][ T117] sunxi:pin-2000000.pinctrl:[INFO]: pinctrl withstand voltage config mode=auto_hard
[ 2.021296][ T126] [drm] [TCON] sunxi_tcon_probe ret = 0
[ 2.028203][ T117] sunxi:pin-2000000.pinctrl:[INFO]: Auto power withstand voltage configuration detected, automatically exit!
[ 2.035827][ T126] [drm] [TCON] sunxi_tcon_probe start
[ 2.046908][ T117] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: SD/MMC/SDIO Host Controller Driver(v5.58 2024-11-11 09:32)
[ 2.054231][ T126] [drm] [SUNXI-TCON] sunxi_tcon_of_get_id 4
[ 2.061554][ T117] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: ctl-spec-caps 428
[ 2.068655][ T126] [drm] [TCON] sunxi_tcon_probe ret = 0
[ 2.072742][ T117] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: No vmmc regulator found
[ 2.077255][ T126] [drm] [TCON] sunxi_tcon_probe start
[ 2.086349][ T117] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: No vqmmc regulator found
[ 2.095132][ T126] [drm] [SUNXI-TCON] sunxi_tcon_of_get_id 5
[ 2.102020][ T117] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: No vdmmc regulator found
[ 2.109197][ T126] [drm] [TCON] sunxi_tcon_probe ret = 0
[ 2.115354][ T117] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: No vd33sw regulator found
[ 2.115357][ T117] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: No vd18sw regulator found
[ 2.115358][ T117] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: No vq33sw regulator found
[ 2.115360][ T117] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: No vq18sw regulator found
[ 2.125724][ T126] [drm] sunxi_drm_platform_probe start
[ 2.133387][ T117] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: manual set ocr
[ 2.133400][ T117] sunxi:sunxi_mmc_host-4021000.sdmmc:[WARN]: Cann't get uart0 pinstate,check if needed
[ 2.143697][ T126] [drm] sunxi_drm_match_add start
[ 2.150470][ T117] sunxi:sunxi_mmc_host-4021000.sdmmc:[WARN]: Cann't get pin bias hs pinstate,check if needed
[ 2.158003][ T126] [drm] sunxi_drm_match_add finish
[ 2.163578][ T117] sunxi-mmc 4021000.sdmmc: sunxi:sunxi_mmc_hostexecute tuning in kernel, retune_period=3600
[ 2.371929][ T117] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.396156][ T117] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.420270][ T117] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: detmode:manually by software
[ 2.421096][ C0] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 1 p1 err, cmd 52, RTO !!
[ 2.430877][ T117] NSI_PMU 2020000.nsi-controller: Get support-ecc failed
[ 2.446364][ T117] [drm] [TCON_TOP]sunxi_tcon_top_probe start
[ 2.446829][ C0] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 1 p1 err, cmd 52, RTO !!
[ 2.452951][ T117] [drm] [TCON_TOP]sunxi_tcon_top_probe start
[ 2.467861][ T70] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.482102][ T117] sunxi-display-engine 5000000.de: Adding to iommu group 0
[ 2.484817][ T70] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.490037][ T117] [drm] de use no display sys
[ 2.505297][ C0] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 1 p1 err, cmd 5, RTO !!
[ 2.508511][ T117] sunxi-display-engine 5000000.de: register iommu fault callback for sunxi-drm, master=8
[ 2.517719][ C0] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 1 p1 err, cmd 5, RTO !!
[ 2.526965][ T117] [drm] [PHY] sunxi_dsi_combophy_probe start
[ 2.536423][ C0] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 1 p1 err, cmd 5, RTO !!
[ 2.542302][ T117] [drm] [PHY]sunxi_dsi_combophy_probe finish
[ 2.551798][ C0] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 1 p1 err, cmd 5, RTO !!
[ 2.557752][ T117] [drm] [DSI] sunxi_drm_dsi_probe start
[ 2.566328][ T70] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 2.572439][ T117] mipi-dsi 5506000.dsi0.0: Fixing up cyclic dependency with dsi_panel@1
[ 2.585102][ T70] sunxi:pin-2000000.pinctrl:[INFO]: Auto power withstand voltage configuration detected, automatically exit!
[ 2.594114][ T117] [drm] [DSI]sunxi_drm_dsi_probe ok
[ 2.611971][ T117] pwm-backlight backlight0: supply power not found, using dummy regulator
[ 2.621384][ T117] sunxi:pin-2000000.pinctrl:[ERR]: unknown pin
[ 2.621390][ T117] sunxi:pin-2000000.pinctrl:[ERR]: unknown pin
[ 2.628076][ T117] uart-ng 2500000.uart: there is not valid maps for state default
[ 2.643169][ T117] sunxi:pin-2000000.pinctrl:[ERR]: unknown pin
[ 2.643173][ T117] sunxi:pin-2000000.pinctrl:[ERR]: unknown pin
[ 2.649776][ T117] uart-ng 2500000.uart: there is not valid maps for state sleep
[ 2.664893][ T117] uart-ng uart-ng0: supply uart not found, using dummy regulator
[ 2.673298][ T117] sunxi:uart-ng-uart-ng0:[INFO]: cannot get the TX DMA channel!
[ 2.681507][ T117] sunxi:uart-ng-uart-ng0:[INFO]: cannot get the RX DMA channel!
[ 2.689761][ T117] sunxi:uart-ng:[INFO]: sunxi uart-ng driver version: 1.1.7
[ 2.697391][ T117] uart-ng0: ttyAS0 at MMIO 0x2500000 (irq = 426, base_baud = 1500000) is a SUNXI
[ 2.707228][ T117] sunxi:uart-ng-uart-ng0:[INFO]: console setup baud 115200 parity n bits 8, flow n
[ 2.717275][ T117] printk: console [ttyAS0] enabled
[ 2.728254][ T117] printk: bootconsole [uart8250] disabled
[ 2.741160][ T117] uart-ng uart-ng1: supply uart not found, using dummy regulator
[ 2.749734][ T117] sunxi:uart-ng-uart-ng1:[INFO]: cannot get the TX DMA channel!
[ 2.758119][ T117] sunxi:uart-ng-uart-ng1:[INFO]: cannot get the RX DMA channel!
[ 2.766560][ T117] uart-ng1: ttyAS1 at MMIO 0x2501000 (irq = 427, base_baud = 1500000) is a SUNXI
[ 2.777071][ T117] uart-ng uart-ng4: supply uart not found, using dummy regulator
[ 2.785622][ T117] sunxi:uart-ng-uart-ng4:[INFO]: cannot get the TX DMA channel!
[ 2.793984][ T117] sunxi:uart-ng-uart-ng4:[INFO]: cannot get the RX DMA channel!
[ 2.802402][ T117] uart-ng4: ttyAS4 at MMIO 0x2504000 (irq = 428, base_baud = 1500000) is a SUNXI
[ 2.812897][ T117] sunxi-twi 7083000.twi: supply twi not found, using dummy regulator
[ 2.823032][ T117] sunxi:axp2101-13-0036:[INFO]: AXP20x variant AXP8191 found
[ 2.836296][ T117] axp8191-dcdc1: supplied by regulator-dummy
[ 2.845230][ T117] axp8191-dcdc2: supplied by regulator-dummy
[ 2.854161][ T117] axp8191-dcdc3: supplied by regulator-dummy
[ 2.863079][ T117] axp8191-dcdc4: supplied by regulator-dummy
[ 2.872522][ T117] axp8191-dcdc5: supplied by regulator-dummy
[ 2.881923][ T117] axp8191-dcdc6: supplied by regulator-dummy
[ 2.891339][ T117] axp8191-dcdc7: supplied by regulator-dummy
[ 2.900781][ T117] axp8191-dcdc8: supplied by regulator-dummy
[ 2.909448][ T117] axp8191-dcdc9: supplied by regulator-dummy
[ 2.918401][ T117] axp8191-dc1sw1: supplied by axp8191-dcdc1
[ 2.925130][ T117] axp8191-dc1sw2: supplied by axp8191-dcdc1
[ 2.932227][ T117] axp8191-aldo1: supplied by regulator-dummy
[ 2.942011][ T117] axp8191-aldo2: supplied by regulator-dummy
[ 2.949641][ T117] axp8191-aldo3: supplied by regulator-dummy
[ 2.957288][ T117] axp8191-aldo4: supplied by regulator-dummy
[ 2.964899][ T117] axp8191-aldo5: supplied by regulator-dummy
[ 2.972562][ T117] axp8191-aldo6: supplied by regulator-dummy
[ 2.979684][ T117] axp8191-bldo1: supplied by regulator-dummy
[ 2.986737][ T117] axp8191-bldo2: supplied by regulator-dummy
[ 2.993767][ T117] axp8191-bldo3: supplied by regulator-dummy
[ 3.000807][ T117] axp8191-bldo4: supplied by regulator-dummy
[ 3.007611][ T117] axp8191-bldo5: supplied by regulator-dummy
[ 3.016108][ T117] axp8191-cldo1: supplied by regulator-dummy
[ 3.024910][ T117] axp8191-cldo2: supplied by regulator-dummy
[ 3.031699][ T117] axp8191-cldo3: supplied by regulator-dummy
[ 3.040823][ T117] axp8191-cldo4: supplied by regulator-dummy
[ 3.047656][ T117] axp8191-cldo5: supplied by regulator-dummy
[ 3.056289][ T117] axp8191-dldo1: supplied by regulator-dummy
[ 3.065861][ T117] axp8191-dldo2: supplied by regulator-dummy
[ 3.072934][ T117] axp8191-dldo3: supplied by regulator-dummy
[ 3.079998][ T117] axp8191-dldo4: supplied by regulator-dummy
[ 3.086762][ T117] axp8191-dldo5: Bringing 2800000uV into 3300000-3300000uV
[ 3.095601][ T117] axp8191-dldo5: supplied by regulator-dummy
[ 3.104259][ T117] axp8191-dldo6: supplied by regulator-dummy
[ 3.113229][ T117] axp8191-eldo1: supplied by regulator-dummy
[ 3.122650][ T117] axp8191-eldo2: supplied by regulator-dummy
[ 3.131865][ T117] axp8191-eldo3: supplied by regulator-dummy
[ 3.138958][ T117] axp8191-eldo4: supplied by regulator-dummy
[ 3.146031][ T117] axp8191-eldo5: supplied by regulator-dummy
[ 3.152819][ T117] axp8191-eldo6: supplied by regulator-dummy
[ 3.161158][ T117] axp8191-rtcldo: supplied by regulator-dummy
[ 3.168054][ T117] axp2101-pek axp2101-pek.0: DMA mask not set
[ 3.179544][ T117] input: axp8191-pek as /devices/platform/soc@3000000/7083000.twi/i2c-13/13-0036/axp2101-pek.0/input/input0
[ 3.192257][ T117] axp8191-temp-ctrl: Failed to locate of_node [id: 0]
[ 3.199739][ T117] sunxi:axp8191_temp_ctrl:[ERR]: axp8191-temp-ctrl device is not configed
[ 3.211329][ T117] reg-virt-consumer: Failed to locate of_node [id: -2]
[ 3.218886][ T117] reg-virt-consumer: Failed to locate of_node [id: -2]
[ 3.226423][ T117] reg-virt-consumer: Failed to locate of_node [id: -2]
[ 3.233965][ T117] reg-virt-consumer: Failed to locate of_node [id: -2]
[ 3.241504][ T117] reg-virt-consumer: Failed to locate of_node [id: -2]
[ 3.249038][ T117] reg-virt-consumer: Failed to locate of_node [id: -2]
[ 3.256568][ T117] reg-virt-consumer: Failed to locate of_node [id: -2]
[ 3.264095][ T117] reg-virt-consumer: Failed to locate of_node [id: -2]
[ 3.271631][ T117] reg-virt-consumer: Failed to locate of_node [id: -2]
[ 3.279189][ T117] reg-virt-consumer: Failed to locate of_node [id: -2]
[ 3.288979][ T117] sunxi:axp2101-13-0036:[INFO]: AXP20X driver loaded
[ 3.296421][ T117] i2c 13-004e: Fixing up cyclic dependency with 10.usbc0
[ 3.304232][ T117] sunxi:twi-7083000.twi:[INFO]: v2.7.4 probe success
[ 3.312030][ T117] sunxi-twi 7084000.twi: supply twi not found, using dummy regulator
[ 3.321798][ T117] sunxi:twi-7084000.twi:[INFO]: v2.7.4 probe success
[ 3.332693][ T117] sunxi:sunxi_mmc_host-4023000.sdmmc:[INFO]: SD/MMC/SDIO Host Controller Driver(v5.58 2024-11-11 09:32)
[ 3.345168][ T117] sunxi:sunxi_mmc_host-4023000.sdmmc:[INFO]: ctl-spec-caps 328
[ 3.354815][ T117] sunxi:sunxi_mmc_host-4023000.sdmmc:[INFO]: No vdmmc regulator found
[ 3.363796][ T117] sunxi:sunxi_mmc_host-4023000.sdmmc:[INFO]: No vd33sw regulator found
[ 3.372833][ T117] sunxi:sunxi_mmc_host-4023000.sdmmc:[INFO]: No vd18sw regulator found
[ 3.381871][ T117] sunxi:sunxi_mmc_host-4023000.sdmmc:[INFO]: No vq33sw regulator found
[ 3.390907][ T117] sunxi:sunxi_mmc_host-4023000.sdmmc:[INFO]: No vq18sw regulator found
[ 3.399962][ T117] sunxi:sunxi_mmc_host-4023000.sdmmc:[WARN]: Cann't get uart0 pinstate,check if needed
[ 3.410558][ T117] sunxi:sunxi_mmc_host-4023000.sdmmc:[WARN]: Cann't get pin bias hs pinstate,check if needed
[ 3.421860][ T117] sunxi:sunxi_mmc_host-4023000.sdmmc:[ERR]: Could not get store clock
[ 3.431499][ T117] sunxi-mmc 4023000.sdmmc: sunxi:sunxi_mmc_host***ctl-cmdq-md*** 20
[ 3.440518][ T117] sunxi:sunxi_mmc_host-4023000.sdmmc:[INFO]: cq_host:ffffff80c81d7c80, mmc:ffffff80c775d000, host:ffffff80c775d7c0
[ 3.453859][ T117] mmc0: CQHCI version 0.00
[ 3.458740][ T117] sunxi:sunxi_mmc_host-4023000.sdmmc:[INFO]: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.485223][ T117] sunxi:sunxi_mmc_host-4023000.sdmmc:[INFO]: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.512205][ T70] sunxi:sunxi_mmc_host-4023000.sdmmc:[INFO]: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.526330][ T117] sunxi:sunxi_mmc_host-4023000.sdmmc:[INFO]: detmode:alway in(non removable)
[ 3.536955][ T117] sunxi:sunxi_mmc_host-4020000.sdmmc:[INFO]: SD/MMC/SDIO Host Controller Driver(v5.58 2024-11-11 09:32)
[ 3.549577][ T117] sunxi:sunxi_mmc_host-4020000.sdmmc:[INFO]: ctl-spec-caps 428
[ 3.552323][ T70] sunxi:sunxi_mmc_host-4023000.sdmmc:[INFO]: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.560037][ T117] sunxi:sunxi_mmc_host-4020000.sdmmc:[INFO]: No vqmmc regulator found
[ 3.573280][ T70] sunxi:sunxi_mmc_host-4023000.sdmmc:[INFO]: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.580893][ T117] sunxi:sunxi_mmc_host-4020000.sdmmc:[INFO]: No vdmmc regulator found
[ 3.604593][ T117] sunxi-mmc 4020000.sdmmc: Got CD GPIO
[ 3.608583][ T70] sunxi:sunxi_mmc_host-4023000.sdmmc:[INFO]: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.610575][ T117] sunxi-mmc 4020000.sdmmc: sunxi:sunxi_mmc_hostcd-set-debounce is 0x1
[ 3.624695][ T70] sunxi:sunxi_mmc_host-4023000.sdmmc:[INFO]: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.647963][ T117] sunxi:sunxi_mmc_host-4020000.sdmmc:[INFO]: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.650703][ T70] sunxi:sunxi_mmc_host-4023000.sdmmc:[INFO]: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.692120][ T70] sunxi:sunxi_mmc_host-4023000.sdmmc:[INFO]: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.720595][ T70] sunxi:sunxi_mmc_host-4023000.sdmmc:[ERR]: avoid to switch power_off_notification to POWERED_ON(0x01)
[ 3.732777][ T70] sunxi:sunxi_mmc_host-4023000.sdmmc:[ERR]: avoid to switch power_off_notification to POWERED_ON(0x01)
[ 3.744924][ T70] sunxi:sunxi_mmc_host-4023000.sdmmc:[ERR]: avoid to switch power_off_notification to POWERED_ON(0x01)
[ 3.757066][ T70] sunxi:sunxi_mmc_host-4023000.sdmmc:[ERR]: avoid to switch power_off_notification to POWERED_ON(0x01)
[ 3.770313][ T70] sunxi:sunxi_mmc_host-4023000.sdmmc:[INFO]: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 8 timing LEGACY(SDR12) dt B
[ 3.787946][ T70] sunxi:sunxi_mmc_host-4023000.sdmmc:[INFO]: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 8 timing MMC-HS200 dt B
[ 3.801794][ T70] sunxi:sunxi_mmc_host-4023000.sdmmc:[INFO]: sdc set ios:clk 52000000Hz bm PP pm ON vdd 21 width 8 timing MMC-HS200 dt B
[ 3.815969][ T70] sunxi:sunxi_mmc_host-4023000.sdmmc:[INFO]: sdc set ios:clk 200000000Hz bm PP pm ON vdd 21 width 8 timing MMC-HS200 dt B
[ 3.830148][ T70] sunxi:sunxi_mmc_host-4023000.sdmmc:[ERR]: sdc3 :the host don't support tuning in kernel
[ 3.841091][ T70] sunxi:sunxi_mmc_host-4023000.sdmmc:[INFO]: sdc set ios:clk 200000000Hz bm PP pm ON vdd 21 width 8 timing MMC-HS(SDR20) dt B
[ 3.855629][ T70] sunxi:sunxi_mmc_host-4023000.sdmmc:[INFO]: sdc set ios:clk 52000000Hz bm PP pm ON vdd 21 width 8 timing MMC-HS(SDR20) dt B
[ 3.870252][ T70] sunxi:sunxi_mmc_host-4023000.sdmmc:[INFO]: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 8 timing MMC-HS400 dt B
[ 3.880351][ T117] sunxi:sunxi_mmc_host-4020000.sdmmc:[INFO]: no vqmmc,Check if there is regulator
[ 3.884337][ T70] sunxi:sunxi_mmc_host-4023000.sdmmc:[INFO]: sdc set ios:clk 200000000Hz bm PP pm ON vdd 21 width 8 timing MMC-HS400 dt B
[ 3.906905][ T117] sunxi:sunxi_mmc_host-4020000.sdmmc:[INFO]: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.922452][ T70] mmc0: Command Queue Engine enabled
[ 3.928202][ T70] mmc0: new HS400 MMC card at address 0001
[ 3.935404][ T70] blk_queue_max_segment_size: set to minimum 4096
[ 3.935497][ T95] sunxi:sunxi_mmc_host-4020000.sdmmc:[INFO]: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 3.942434][ T70] mmcblk0: mmc0:0001 MMC32G 29.2 GiB
[ 3.956040][ T117] sunxi:sunxi_mmc_host-4020000.sdmmc:[INFO]: detmode:gpio irq
[ 3.966283][ T70] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29
[ 3.970902][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 3.984917][ T70] mmcblk0rpmb: mmc0:0001 MMC32G 4.00 MiB, chardev (235:0)
[ 3.992948][ T168] random: fsck_msdos: uninitialized urandom read (40 bytes read)
[ 3.994465][ T117] cpu cpu0: _opp_add: OPP not supported by regulators (408000000)
[ 3.994665][ T1] fsck_msdos: linker: Warning: failed to find generated linker configuration from "/linkerconfig/ld.config.txt"
[ 3.994680][ T1] fsck_msdos: WARNING: linker: Warning: failed to find generated linker configuration from "/linkerconfig/ld.config.txt"
[ 3.998470][ T168] random: fsck_msdos: uninitialized urandom read (40 bytes read)
[ 4.001284][ T1] fsck_msdos: Invalid signature in boot block: 0000
[ 4.001297][ T1] fsck_msdos: /dev/block/by-name/media_data: UNEXPECTED INCONSISTENCY; RUN fsck_msdos MANUALLY.
[ 4.002171][ T1] fsck_msdos: fsck_msdos terminated by exit(8)
[ 4.002171][ T1]
[ 4.005333][ T1] random: init: uninitialized urandom read (16 bytes read)
[ 4.010791][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 4.028719][ T1] erofs: (device dm-0): mounted with root inode @ nid 65.
[ 4.032349][ T117] cpu cpu0: _opp_add: OPP not supported by regulators (720000000)
[ 4.032431][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 4.052039][ T1] EXT4-fs (dm-4): mounted filesystem without journal. Opts: . Quota mode: none.
[ 4.054787][ T117] cpu cpu0: _opp_add: OPP not supported by regulators (792000000)
[ 4.054866][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 4.063844][ T1] erofs: (device dm-1): mounted with root inode @ nid 42.
[ 4.073498][ T117] cpu cpu0: _opp_add: OPP not supported by regulators (1008000000)
[ 4.073591][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 4.084207][ T1] erofs: (device dm-3): mounted with root inode @ nid 39.
[ 4.090603][ T117] cpu cpu0: _opp_add: OPP not supported by regulators (1104000000)
[ 4.102037][ T1] erofs: (device dm-2): mounted with root inode @ nid 39.
[ 4.109142][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 4.122387][ T1] newfs_msdos: executing /system/bin/newfs_msdos failed: No such file or directory
[ 4.128327][ T117] cpu cpu0: _opp_add: OPP not supported by regulators (1200000000)
[ 4.138262][ T1] newfs_msdos: newfs_msdos terminated by exit(255)
[ 4.138262][ T1]
[ 4.146866][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 4.157856][ T1] FAT-fs (mmcblk0p26): bogus number of reserved sectors
[ 4.165261][ T117] cpu cpu0: _opp_add: OPP not supported by regulators (1296000000)
[ 4.165345][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 4.173919][ T1] FAT-fs (mmcblk0p26): Can't find a valid FAT filesystem
[ 4.175180][ T1] newfs_msdos: executing /system/bin/newfs_msdos failed: No such file or directory
[ 4.184621][ T117] cpu cpu0: _opp_add: OPP not supported by regulators (1392000000)
[ 4.184707][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 4.192425][ T1] newfs_msdos: newfs_msdos terminated by exit(255)
[ 4.192425][ T1]
[ 4.201126][ T117] cpu cpu0: _opp_add: OPP not supported by regulators (1416000000)
[ 4.209321][ T1] FAT-fs (mmcblk0p27): bogus number of reserved sectors
[ 4.219627][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 4.229791][ T1] FAT-fs (mmcblk0p27): Can't find a valid FAT filesystem
[ 4.238414][ T117] cpu cpu0: _opp_add: OPP not supported by regulators (1512000000)
[ 4.274912][ T1] printk: init: 146 output lines suppressed due to ratelimiting
[ 4.285616][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 4.394547][ T117] cpu cpu0: _opp_add: OPP not supported by regulators (1608000000)
[ 4.403420][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 4.410423][ T1] init: DM_DEV_STATUS failed for system_ext_a: No such device or address
[ 4.414137][ T117] cpu cpu0: _opp_add: OPP not supported by regulators (1704000000)
[ 4.423429][ T1] init: Could not update logical partition
[ 4.433038][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 4.438435][ T1] init: Opening SELinux policy
[ 4.449246][ T117] cpu cpu0: _opp_add: OPP not supported by regulators (1800000000)
[ 4.454978][ T1] init: Falling back to standard signature check. TODO implementent support for fsverity SEPolicy.
[ 4.463070][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 4.474709][ T1] init: Error: Apex SEPolicy failed signature check
[ 4.485336][ T117] cpu cpu0: _opp_add: OPP not supported by regulators (728000000)
[ 4.492569][ T1] init: Loading APEX Sepolicy from /system/etc/selinux/apex/SEPolicy.zip
[ 4.501239][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 4.510367][ T1] init: Failed to open package /system/etc/selinux/apex/SEPolicy.zip: No such file or directory
[ 4.521007][ T117] cpu cpu0: _opp_add: OPP not supported by regulators (1092000000)
[ 4.521264][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 4.541118][ T1] init: Loading SELinux policy
[ 4.556918][ T1] SELinux: Permission bpf in class capability2 not defined in policy.
[ 4.556964][ T117] cpu cpu0: _opp_add: OPP not supported by regulators (1586000000)
[ 4.566030][ T1] SELinux: Permission checkpoint_restore in class capability2 not defined in policy.
[ 4.575509][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 4.585169][ T1] SELinux: Permission bpf in class cap2_userns not defined in policy.
[ 4.595849][ T117] cpu cpu6: _opp_add: OPP not supported by regulators (408000000)
[ 4.595927][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 4.604905][ T1] SELinux: Permission checkpoint_restore in class cap2_userns not defined in policy.
[ 4.613450][ T117] cpu cpu6: _opp_add: OPP not supported by regulators (720000000)
[ 4.613511][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 4.624210][ T1] SELinux: Class mctp_socket not defined in policy.
[ 4.634634][ T117] cpu cpu6: _opp_add: OPP not supported by regulators (792000000)
[ 4.634702][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 4.643203][ T1] SELinux: the above unknown classes and permissions will be denied
[ 4.653885][ T117] cpu cpu6: _opp_add: OPP not supported by regulators (1008000000)
[ 4.653956][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 4.665791][ T1] SELinux: policy capability network_peer_controls=1
[ 4.669722][ T117] cpu cpu6: _opp_add: OPP not supported by regulators (1200000000)
[ 4.669796][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 4.680461][ T1] SELinux: policy capability open_perms=1
[ 4.689183][ T117] cpu cpu6: _opp_add: OPP not supported by regulators (1296000000)
[ 4.689247][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 4.697838][ T1] SELinux: policy capability extended_socket_class=1
[ 4.708520][ T117] cpu cpu6: _opp_add: OPP not supported by regulators (1392000000)
[ 4.708593][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 4.715921][ T1] SELinux: policy capability always_check_network=0
[ 4.724559][ T117] cpu cpu6: _opp_add: OPP not supported by regulators (1512000000)
[ 4.724636][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 4.735275][ T1] SELinux: policy capability cgroup_seclabel=0
[ 4.741577][ T117] cpu cpu6: _opp_add: OPP not supported by regulators (1608000000)
[ 4.741634][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 4.750234][ T1] SELinux: policy capability nnp_nosuid_transition=1
[ 4.760918][ T117] cpu cpu6: _opp_add: OPP not supported by regulators (1704000000)
[ 4.760991][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 4.768311][ T1] SELinux: policy capability genfs_seclabel_symlinks=0
[ 4.776956][ T117] cpu cpu6: _opp_add: OPP not supported by regulators (1800000000)
[ 4.777030][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 4.787654][ T1] SELinux: policy capability ioctl_skip_cloexec=0
[ 4.794937][ T117] cpu cpu6: _opp_add: OPP not supported by regulators (1896000000)
[ 4.795009][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 4.920482][ T117] cpu cpu6: _opp_add: OPP not supported by regulators (1920000000)
[ 4.929331][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 4.940028][ T117] cpu cpu6: _opp_add: OPP not supported by regulators (1992000000)
[ 4.948900][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 4.959595][ T117] cpu cpu6: _opp_add: OPP not supported by regulators (728000000)
[ 4.968562][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 4.979262][ T117] cpu cpu6: _opp_add: OPP not supported by regulators (1300000000)
[ 4.988221][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 4.998915][ T117] cpu cpu6: _opp_add: OPP not supported by regulators (1586000000)
[ 5.007763][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 5.018456][ T117] cpu cpu6: _opp_add: OPP not supported by regulators (1690000000)
[ 5.027527][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 5.038223][ T117] cpu cpu6: _opp_add: OPP not supported by regulators (1976000000)
[ 5.047369][ T117] cpu cpu0: EM: created perf domain
[ 5.058868][ T117] cpu cpu6: EM: created perf domain
[ 5.064587][ T80] audit: type=1403 audit(1748526560.564:2): auid=4294967295 ses=4294967295 lsm=selinux res=1
[ 5.067994][ T117] sunxi:sunxi_dsufreq:[WARN]: dsu dvfs: 26m-vf0200
[ 5.070180][ T1] selinux: SELinux: Loaded file_contexts
[ 5.070185][ T1] selinux:
[ 5.075564][ T1] random: init: uninitialized urandom read (40 bytes read)
[ 5.082221][ T1] random: init: uninitialized urandom read (40 bytes read)
[ 5.082999][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 5.091100][ T1] init: init second stage started!
[ 5.092311][ T117] sunxi-dsufreq 8860000.dsufreq: _opp_add: OPP not supported by regulators (288000000)
[ 5.092468][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 5.145524][ T117] sunxi-dsufreq 8860000.dsufreq: _opp_add: OPP not supported by regulators (528000000)
[ 5.147758][ T1] FAT-fs (mmcblk0p26): bogus number of reserved sectors
[ 5.156188][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 5.163701][ T1] FAT-fs (mmcblk0p26): Can't find a valid FAT filesystem
[ 5.174545][ T117] sunxi-dsufreq 8860000.dsufreq: _opp_add: OPP not supported by regulators (600000000)
[ 5.182159][ T1] init: mount media_data fail*****Invalid argument
[ 5.192705][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 5.210415][ T117] sunxi-dsufreq 8860000.dsufreq: _opp_add: OPP not supported by regulators (744000000)
[ 5.219149][ T1] init: Using Android DT directory /proc/device-tree/firmware/android/
[ 5.221086][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 5.233982][ T1] init: Couldn't load property file '/vendor/default.prop': open() failed: No such file or directory: No such file or directory
[ 5.240734][ T117] sunxi-dsufreq 8860000.dsufreq: _opp_add: OPP not supported by regulators (792000000)
[ 5.240807][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 5.257627][ T1] init: Couldn't load property file '/odm_dlkm/etc/build.prop': open() failed: No such file or directory: No such file or directory
[ 5.265886][ T117] sunxi-dsufreq 8860000.dsufreq: _opp_add: OPP not supported by regulators (840000000)
[ 5.265955][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 5.277404][ T1] init: Couldn't load property file '/oem/build.prop': open() failed: No such file or directory: No such file or directory
[ 5.291526][ T117] sunxi-dsufreq 8860000.dsufreq: _opp_add: OPP not supported by regulators (888000000)
[ 5.291596][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 5.302488][ T1] init: Could not set 'ro.boot.dynamic_partitions' to 'true' while loading .prop filesRead-only property was already set
[ 5.312793][ T117] sunxi-dsufreq 8860000.dsufreq: _opp_add: OPP not supported by regulators (912000000)
[ 5.312858][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 5.326898][ T1] init: Could not set 'ro.boot.dynamic_partitions_retrofit' to 'true' while loading .prop filesRead-only property was already set
[ 5.337453][ T117] sunxi-dsufreq 8860000.dsufreq: _opp_add: OPP not supported by regulators (984000000)
[ 5.337522][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 5.348750][ T1] init: Setting product property ro.product.brand to 'Allwinner' (from ro.product.product.brand)
[ 5.362023][ T117] sunxi-dsufreq 8860000.dsufreq: _opp_add: OPP not supported by regulators (1032000000)
[ 5.362089][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 5.372630][ T1] init: Setting product property ro.product.device to 'a733-demo-aiot' (from ro.product.product.device)
[ 5.383287][ T117] sunxi-dsufreq 8860000.dsufreq: _opp_add: OPP not supported by regulators (1056000000)
[ 5.383352][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 5.485850][ T117] sunxi-dsufreq 8860000.dsufreq: _opp_add: OPP not supported by regulators (1152000000)
[ 5.496624][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 5.507329][ T117] sunxi-dsufreq 8860000.dsufreq: _opp_add: OPP not supported by regulators (1200000000)
[ 5.511106][ T184] random: init: uninitialized urandom read (40 bytes read)
[ 5.518096][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 5.536625][ T117] sunxi-dsufreq 8860000.dsufreq: _opp_add: OPP not supported by regulators (1224000000)
[ 5.547448][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 5.558134][ T117] sunxi-dsufreq 8860000.dsufreq: _opp_add: OPP not supported by regulators (1296000000)
[ 5.568887][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 5.579571][ T117] sunxi-dsufreq 8860000.dsufreq: _opp_add: OPP not supported by regulators (546000000)
[ 5.590325][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 5.601006][ T117] sunxi-dsufreq 8860000.dsufreq: _opp_add: OPP not supported by regulators (832000000)
[ 5.611878][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 5.622568][ T117] sunxi-dsufreq 8860000.dsufreq: _opp_add: OPP not supported by regulators (1196000000)
[ 5.633432][ T117] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 5.644114][ T117] sunxi-dsufreq 8860000.dsufreq: _opp_add: OPP not supported by regulators (1352000000)
[ 5.654927][ T117] [drm] [DSI-PANEL] panel_dsi_probe start
[ 5.661354][ T117] [drm] reset-on-sequence property not found
[ 5.668136][ T117] [drm] [DSI]sunxi_drm_dsi_host_attach start
[ 5.674668][ T117] [drm] [DSI]sunxi_drm_dsi_host_attach finish
[ 5.681272][ T117] [drm] [DSI-PANEL] panel_dsi_probe finish
[ 5.687866][ T117] [drm] sunxi_drm_bind start
[ 5.692983][ T117] [drm] [TCON_TOP]sunxi_tcon_top_bind start
[ 5.699517][ T117] sunxi-drm soc@3000000:sunxi-drm: bound 5500000.vo0 (ops sunxi_tcon_top_component_ops [sunxidrm])
[ 5.711367][ T117] [drm] [TCON_TOP]sunxi_tcon_top_bind start
[ 5.717820][ T117] sunxi-drm soc@3000000:sunxi-drm: bound 5510000.vo1 (ops sunxi_tcon_top_component_ops [sunxidrm])
[ 5.729663][ T117] [drm] [SUNXI-DE] sunxi_de_bind start
[ 5.735620][ T117] sunxi-drm soc@3000000:sunxi-drm: Adding to iommu group 0
[ 5.743626][ T117] [drm] sunxi_de_bind crtc init for de 0 ok
[ 5.750086][ T117] [drm] sunxi_de_bind crtc init for de 1 ok
[ 5.757000][ T117] sunxi-drm soc@3000000:sunxi-drm: bound 5000000.de (ops sunxi_de_component_ops [sunxidrm])
[ 5.768182][ T117] sunxi-drm soc@3000000:sunxi-drm: bound 5507000.phy (ops sunxi_cphy_component_ops [sunxi_drm_phy])
[ 5.780041][ T117] [drm] [DSI]sunxi_drm_dsi_bind start
[ 5.786045][ T117] [drm] [SUNXI-TCON] sunxi_tcon_of_get_id 0
[ 5.787979][ T188] linkerconfig: Unable to access VNDK APEX at path: /apex/com.android.vndk.v33: No such file or directory
[ 5.792489][ T117] sunxi-drm soc@3000000:sunxi-drm: bound 5506000.dsi0 (ops sunxi_drm_dsi_component_ops [sunxidrm])
[ 5.805116][ T188] linkerconfig: Unable to access VNDK APEX at path: /apex/com.android.vndk.v33: No such file or directory
[ 5.816785][ T117] [drm] [SUNXI-TCON] sunxi_tcon_of_get_id 4
[ 5.831259][ T188] linkerconfig (188) used greatest stack depth: 11104 bytes left
[ 5.835909][ T117] [drm] sunxi-hdmi: hdmi drv init dts done
[ 5.851357][ T117] [drm] sunxi-hdmi: hdmi drv enable resource done
[ 5.858364][ T117] [drm] sunxi-hdmi: hdmi drv init resource done
[ 5.865265][ T117] [drm] sunxi-hdmi: hdmi drv init i2c adapter finish
[ 5.865619][ T189] ueventd: ueventd started!
[ 5.878252][ T117] [drm] sunxi-hdmi: drm hdmi connector create finish
[ 5.879202][ T189] selinux: SELinux: Loaded file_contexts
[ 5.885578][ T117] [drm] sunxi-hdmi: hdmi devices bind done <<<<<<<<<<
[ 5.885578][ T117]
[ 5.885591][ T117] sunxi-drm soc@3000000:sunxi-drm: bound 5520000.hdmi (ops sunxi_hdmi_compoent_ops [sunxidrm])
[ 5.891794][ T189] selinux:
[ 5.898693][ T190] apexd: Bootstrap subcommand detected
[ 5.898765][ T190] apexd: ActivateFlattenedApex
[ 5.898801][ T190] apexd: Scanning /system/apex
[ 5.899419][ T190] apexd: Bind mounting /system/apex/com.android.adbd onto /apex/com.android.adbd
[ 5.900047][ T190] apexd: Bind mounting /system/apex/com.android.adservices onto /apex/com.android.adservices
[ 5.900637][ T190] apexd: Bind mounting /system/apex/com.android.appsearch onto /apex/com.android.appsearch
[ 5.901214][ T190] apexd: Bind mounting /system/apex/com.android.art onto /apex/com.android.art
[ 5.901543][ T117] sunxi-drm soc@3000000:sunxi-drm: bound 5501000.tcon0 (ops sunxi_tcon_component_ops [sunxidrm])
[ 5.901818][ T190] apexd: Bind mounting /system/apex/com.android.btservices onto /apex/com.android.btservices
[ 5.902431][ T190] apexd: Bind mounting /system/apex/com.android.conscrypt onto /apex/com.android.conscrypt
[ 5.902952][ T190] apexd: Bind mounting /system/apex/com.android.extservices onto /apex/com.android.extservices
[ 5.913451][ T189] ueventd: Parsing file /system/etc/ueventd.rc...
[ 5.916216][ T117] sunxi-drm soc@3000000:sunxi-drm: bound 5730000.tcon3 (ops sunxi_tcon_component_ops [sunxidrm])
[ 5.922254][ T189] ueventd: Added '/vendor/etc/ueventd.rc' to import list
[ 5.923944][ T190] printk: apexd: 24 output lines suppressed due to ratelimiting
[ 5.924165][ T190] apexd (190) used greatest stack depth: 10464 bytes left
[ 5.927303][ T117] sunxi-drm soc@3000000:sunxi-drm: bound 5731000.tcon4 (ops sunxi_tcon_component_ops [sunxidrm])
[ 5.932561][ T189] ueventd: Added '/odm/etc/ueventd.rc' to import list
[ 5.942755][ T80] audit: type=1400 audit(1748526561.440:3): avc: denied { sys_admin } for pid=117 comm="kworker/u16:2" capability=21 scontext=u:r:kernel:s0 tcontext=u:r:kernel:s0 tclass=capability permissive=1
[ 5.945132][ T117] [drm] [SUNXI-CRTC]sunxi_crtc_atomic_enable
[ 5.945137][ T117] [drm] sunxi_de_enable index 0
[ 5.949771][ T117] [drm] sunxi_de_enable finish sw en=1
[ 5.949787][ T117] [drm] [DSI] sunxi_drm_dsi_encoder_atomic_enable vrr_setp:0 start
[ 5.949789][ T117] [drm] [DSI] sunxi_tcon_dsi_mode_init start
[ 5.949909][ T117] [drm] [DSI] sunxi_lcd_pin_set_state start
[ 5.954570][ T189] ueventd: Parsing file /vendor/etc/ueventd.rc...
[ 6.095342][ T197] random: boringssl_self_: uninitialized urandom read (40 bytes read)
[ 6.102506][ T189] ueventd: Parsing file /odm/etc/ueventd.rc...
[ 6.131448][ T198] random: prng_seeder: uninitialized urandom read (40 bytes read)
[ 6.135110][ T189] ueventd: Unable to read config file '/odm/etc/ueventd.rc': open() failed: No such file or directory
[ 6.136105][ T199] random: boringssl_self_: uninitialized urandom read (40 bytes read)
[ 6.172749][ T117] [drm] [DSI] sunxi_drm_dsi_encoder_atomic_enable finish
[ 6.188569][ T198] prng_seeder: Hanging forever because setup failed: Unable to open hwrng /dev/hw_random
[ 6.188569][ T198]
[ 6.208178][ T117] [drm] Initialized sunxi-drm 3.0.0 20230901 for soc@3000000:sunxi-drm on minor 0
[ 6.214976][ T198] Caused by:
[ 6.216997][ T80] audit: type=1400 audit(1748526561.712:4): avc: denied { search } for pid=184 comm="init" name="/" dev="dm-4" ino=2 scontext=u:r:vendor_init:s0 tcontext=u:object_r:system_dlkm_file:s0 tclass=dir permissive=1
[ 6.224886][ T117] [drm] sunxi_drm_bind ok
[ 6.226074][ T184] sunxi-rfkill soc@3000000:rfkill: module version: v1.1.4
[ 6.226269][ T117] i2c i2c-2: of_i2c: modalias failure on /soc@3000000/twi@2512000/focaltech@38
[ 6.226273][ T117] i2c i2c-2: Failed to create I2C device for /soc@3000000/twi@2512000/focaltech@38
[ 6.226319][ T117] sunxi:twi-2512000.twi:[INFO]: v2.7.4 probe success
[ 6.227254][ T117] sunxi:twi-2513000.twi:[INFO]: v2.7.4 probe success
[ 6.228366][ T117] sunxi-cadence-combophy 6c00000.serdes: Sub System Version v2.0.0
[ 6.228651][ T198] No such file or directory (os error 2)
[ 6.283755][ T184] sunxi-rfkill soc@3000000:rfkill: pinctrl_lookup_state(default) failed! return ffffffffffffffed
[ 6.312737][ T189] ueventd: Coldboot took 0.127 seconds
[ 6.320158][ T184] sunxi-rfkill soc@3000000:rfkill: get gpio chip_en failed
[ 6.339567][ T184] sunxi-rfkill soc@3000000:rfkill: get gpio power_en failed
[ 6.347617][ T184] sunxi-rfkill soc@3000000:rfkill: wlan_busnum (1)
[ 6.355182][ T184] sunxi-rfkill soc@3000000:rfkill: wlan power[0] (axp8191-dcdc1) voltage: 3300mV
[ 6.365441][ T184] sunxi-rfkill soc@3000000:rfkill: wlan power[1] (axp8191-bldo5) voltage: 1800mV
[ 6.375694][ T184] sunxi-rfkill soc@3000000:rfkill: wlan power[2] (axp8191-cldo1) voltage: 1800mV
[ 6.385726][ T184] sunxi-rfkill soc@3000000:rfkill: wlan_regon gpio=385 assert=1
[ 6.394097][ T184] sunxi-rfkill soc@3000000:rfkill: wlan_hostwake gpio=384 assert=1
[ 6.402743][ T184] sunxi-rfkill soc@3000000:rfkill: wakeup source is enabled
[ 6.410703][ T184] sunxi-rfkill soc@3000000:rfkill: wlan power boot-on: 0, always-on: 0
[ 6.419999][ T184] sunxi-rfkill soc@3000000:rfkill: bt power[0] (axp8191-dcdc1) voltage: 3300mV
[ 6.430136][ T184] sunxi-rfkill soc@3000000:rfkill: bt power[1] (axp8191-bldo5) voltage: 1800mV
[ 6.440266][ T184] sunxi-rfkill soc@3000000:rfkill: bt power[2] (axp8191-cldo1) voltage: 1800mV
[ 6.450122][ T184] sunxi-rfkill soc@3000000:rfkill: bt_rst gpio=386 assert=0
[ 6.458111][ T184] sunxi-rfkill soc@3000000:rfkill: bluetooth power boot-on: 0, always-on: 0
[ 6.527208][ T1] Registered swp emulation handler
[ 6.583577][ T184] g2d 5440000.g2d: Adding to iommu group 0
[ 6.584547][ T212] logd.auditd: start
[ 6.591007][ T184] sunxi:g2d_sunxi:[INFO]: [G2D]: rcq version initialized.major:505
[ 6.594231][ T212] logd.klogd: 6418075835
[ 6.602808][ T184] sunxi:g2d_sunxi:[INFO]: [G2D]: g2d_module_init
console:/ $ [ 6.618121][ T212] logd: Loaded bug_map file: /system_ext/etc/selinux/bug_map
[ 6.626659][ T212] logd: Loaded bug_map file: /vendor/etc/selinux/selinux_denial_metadata
[ 6.636575][ T212] logd: Loaded bug_map file: /system/etc/selinux/bug_map
[ 6.643045][ T219] treadahead: /treadahead/readahead_file_offset not exist;
[ 6.652380][ T219] treadahead: go to open trace
[ 6.686710][ T1] mke2fs: mke2fs 1.46.2 (28-Feb-2021)
[ 6.692604][ T1] mke2fs: Discarding device blocks: done
[ 6.703208][ T1] mke2fs: Creating filesystem with 4096 4k blocks and 4096 inodes
[ 6.711758][ T1] mke2fs:
[ 6.714970][ T1] mke2fs: Allocating group tables: done
[ 6.724875][ T1] mke2fs: Writing inode tables: done
[ 6.734495][ T1] mke2fs: Creating journal (1024 blocks): done
[ 6.741203][ T1] mke2fs: Writing superblocks and filesystem accounting information: done
[ 6.751691][ T1] mke2fs:
[ 6.781266][ T1] e2fsdroid: Created filesystem with 11/4096 inodes and 1545/4096 blocks
[ 6.792430][ T1] EXT4-fs (mmcblk0p21): Ignoring removed nomblk_io_submit option
[ 6.803250][ T1] EXT4-fs (mmcblk0p21): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit. Quota mode: none.
[ 6.876619][ T1] EXT4-fs (mmcblk0p21): mounted filesystem with ordered data mode. Opts: errors=panic. Quota mode: none.
[ 6.999862][ T1] EXT4-fs (mmcblk0p22): Ignoring removed nomblk_io_submit option
[ 7.010725][ T1] EXT4-fs (mmcblk0p22): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit. Quota mode: none.
[ 7.052736][ T1] EXT4-fs (mmcblk0p22): mounted filesystem with ordered data mode. Opts: errors=panic. Quota mode: none.
[ 7.098465][ T251] random: newfs_msdos: uninitialized urandom read (40 bytes read)
[ 7.194125][ T229] type=1400 audit(1748526562.692:5): avc: denied { getattr } for comm="init" path="/sys/kernel/debug/devices_deferred" dev="debugfs" ino=11811 scontext=u:r:init:s0 tcontext=u:object_r:debugfs:s0 tclass=file permissive=1
[ 7.218829][ T229] type=1400 audit(1748526562.692:6): avc: denied { getattr } for comm="init" path="/sys/kernel/debug/wakeup_sources" dev="debugfs" ino=1048 scontext=u:r:init:s0 tcontext=u:object_r:debugfs_wakeup_sources:s0 tclass=file permissive=1
[ 7.289947][ T257] AW_keymint_2 : starting aw keymint service
[ 7.290616][ T257] AW_keymint_2 : no optee, use software keymint
[ 7.332656][ T257] AW_keymint_2 : adding keymint service instance: android.hardware.security.keymint.IKeyMintDevice/default
[ 7.340360][ T257] AW_keymint_2 : adding keymint service instance: android.hardware.security.secureclock.ISecureClock/default
[ 7.353464][ T257] AW_keymint_2 : adding keymint service instance: android.hardware.security.sharedsecret.ISharedSecret/default
[ 7.366575][ T257] AW_keymint_2 : adding keymint service instance: android.hardware.security.keymint.IRemotelyProvisionedComponent/default
[ 7.380207][ T257] AW_keymint_2 : start aw keymint service ok
[ 9.361924][ T1] EXT4-fs (mmcblk0p29): Ignoring removed nomblk_io_submit option
[ 9.381124][ T1] EXT4-fs (mmcblk0p29): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit. Quota mode: journalled.
[ 9.480150][ C6] random: crng init done
[ 9.484731][ C6] random: 84 urandom warning(s) missed due to ratelimiting
[ 9.604721][ T1] EXT4-fs (mmcblk0p29): Ignoring removed nomblk_io_submit option
[ 9.613270][ T1] EXT4-fs (mmcblk0p29): Using encoding defined by superblock: utf8-12.1.0 with flags 0x0
[ 9.631024][ T1] EXT4-fs (mmcblk0p29): mounted filesystem with ordered data mode. Opts: barrier=1,data=ordered,nomblk_io_submit,noauto_da_alloc,errors=panic,resuid=0,resgid=1065. Quota mode: journalled.
[ 9.704261][ T184] pvrsrvkm: loading out-of-tree module taints kernel.
[ 9.735350][ T184] [sunxi bxm]SysDevInit start!
[ 9.740526][ T184] pvrsrvkm 1800000.gpu: sunxi_platform_init start
[ 9.747581][ T184] pvrsrvkm 1800000.gpu: warning: default clk_rate is NOT set in DTS, set it to default:600000000
[ 9.759138][ T184] pvrsrvkm 1800000.gpu: sunxi_parse_dts clk_rate:600000000
[ 9.768272][ T184] pvrsrvkm 1800000.gpu: succeed to get gpu regulator, default volt value:800000
[ 9.778315][ T184] pvrsrvkm 1800000.gpu: get opp:(400000000 hz, 800000 uv)
[ 9.786097][ T184] pvrsrvkm 1800000.gpu: get opp:(600000000 hz, 800000 uv)
[ 9.793865][ T184] pvrsrvkm 1800000.gpu: get opp:(800000000 hz, 840000 uv)
[ 9.801636][ T184] pvrsrvkm 1800000.gpu: get opp:(1008000000 hz, 960000 uv)
[ 9.809500][ T184] pvrsrvkm 1800000.gpu: opp count:4
[ 9.815135][ T184] pvrsrvkm 1800000.gpu: set default clk_rate to max opp freq:1008000000
[ 9.824260][ T184] pvrsrvkm 1800000.gpu: sunxi_parse_dts finished
[ 9.831273][ T184] pvrsrvkm 1800000.gpu: sunxi_set_device_clk_rate:1008000000
[ 9.839353][ T184] pvrsrvkm 1800000.gpu: sunxi_platform_init end
[ 9.846159][ T184] [sunxi bxm]SysDevInit end!
[ 9.851140][ T184] pvrsrvkm 1800000.gpu: sunxiPrePowerState ePwrFlags:1 current power status:1 1
[ 9.861047][ T184] pvrsrvkm 1800000.gpu: sunxiPostPowerState ePwrFlags:1 current power status:1 1
[ 9.871049][ T184] PVR_K: 184: Read BVNC 36.56.104.183 from HW device registers
[ 9.879399][ T184] pvrsrvkm 1800000.gpu: sunxiPrePowerState ePwrFlags:1 current power status:1 1
[ 9.889309][ T184] pvrsrvkm 1800000.gpu: sunxiPostPowerState ePwrFlags:1 current power status:1 1
[ 9.899350][ T184] PVR_K: 184: RGX Device registered BVNC 36.56.104.183 with 1 core in the system
[ 9.909820][ T184] pvrsrvkm 1800000.gpu: Found 4 OPP points.
[ 9.916239][ T184] pvrsrvkm 1800000.gpu: opp[1/4]: (400000000 Hz, 800000 uV)
[ 9.924206][ T184] pvrsrvkm 1800000.gpu: opp[2/4]: (600000000 Hz, 800000 uV)
[ 9.932170][ T184] pvrsrvkm 1800000.gpu: opp[3/4]: (800000000 Hz, 840000 uV)
[ 9.940133][ T184] pvrsrvkm 1800000.gpu: opp[4/4]: (1008000000 Hz, 960000 uV)
[ 9.949382][ T184] [drm] Initialized pvr 24.2.6643903 20170530 for 1800000.gpu on minor 1
[ 10.073537][ T226] vold: keystore2 Keystore earlyBootEnded returned service specific error: -68
[ 10.096527][ T1] init: Not setting encryption policy on: /data/apex
[ 10.108086][ T1] init: Inferred action different from explicit one, expected 0 but got 2
[ 10.120795][ T1] init: Inferred action different from explicit one, expected 0 but got 3
[ 10.121294][ T225] logd: logd reinit
[ 10.131331][ T1] init: Inferred action different from explicit one, expected 0 but got 2
[ 10.134684][ T225] logd: Cannot read /data/misc/logd/event-log-tags
[ 10.145083][ T1] init: starting service 'apexd'...
[ 10.151673][ T225] logd: FrameworkListener: read() failed (Connection reset by peer)
[ 10.158952][ T1] init: Service 'logd-reinit' (pid 289) exited with status 0 oneshot service took 0.065000 seconds in background
[ 10.178530][ T1] init: Sending signal 9 to service 'logd-reinit' (pid 289) process group...
[ 10.186057][ T290] apexd: This device does not support updatable APEX. Exiting
[ 10.188691][ T1] libprocessgroup: Successfully killed process cgroup uid 1036 pid 289 in 0ms
[ 10.196399][ T290] apexd: Marking APEXd as activated
[ 10.207566][ T1] init: Command 'copy /data/misc/recovery/ro.build.fingerprint /data/misc/recovery/ro.build.fingerprint.1' action=post-fs-data (/system/etc/init/hw/init.rc:754) took 0ms and failed: Could not read input file '/data/misc/recovery/ro.build.fingerprint': open() failed: No such file or directory
[ 10.242371][ T1] init: Service 'apexd' (pid 290) exited with status 0 oneshot service took 0.084000 seconds in background
[ 10.446885][ T295] vdc: Waited 0ms for vold
[ 10.498427][ T226] vold: Failed to chmod /data/system_ce/0: No such file or directory
[ 10.507563][ T226] vold: Failed to chmod /data/misc_ce/0: No such file or directory
[ 10.516427][ T226] vold: Failed to chmod /data/media/0: No such file or directory
[ 10.727306][ T301] apexd: This device does not support updatable APEX. Exiting
[ 10.735722][ T301] apexd: Marking APEXd as ready
[ 10.793386][ T184] init: Top-level directory needs encryption action, eg mkdir /data/audio_d <mode> <uid> <gid> encryption=Require
[ 10.828546][ T184] init: Inferred action different from explicit one, expected 0 but got 2
[ 10.841725][ T1] WARNING: Unprivileged eBPF is enabled, data leaks possible via Spectre v2 BHB attacks!
[ 10.879971][ T305] bpfloader: Override /apex/com.android.tethering/etc/bpf/offload.o with /system/etc/bpf-override/offload.o
[ 10.893957][ T305] LibBpfLoader: Loading critical for tethering ELF object /system/etc/bpf-override/offload.o with license Apache 2.0
[ 10.907540][ T305] LibBpfLoader: Section bpfloader_min_ver value is 2 [0x2]
[ 10.915478][ T305] LibBpfLoader: Section bpfloader_max_ver value is 65536 [0x10000]
[ 10.924190][ T305] LibBpfLoader: Section size_of_bpf_map_def value is 116 [0x74]
[ 10.932613][ T305] LibBpfLoader: Section size_of_bpf_prog_def value is 92 [0x5c]
[ 10.940970][ T305] LibBpfLoader: BpfLoader version 0x00013 processing ELF object /system/etc/bpf-override/offload.o with ver [0x00002,0x10000)
[ 10.958101][ T305] LibBpfLoader: Loaded code section 3 (schedcls_tether_downstream6_ether)
[ 10.967725][ T305] LibBpfLoader: Loaded relo section 3 (.relschedcls/tether_downstream6_ether)
[ 10.977447][ T305] LibBpfLoader: Adding section 3 to cs list
[ 11.183655][ T305] printk: bpfloader: 1670 output lines suppressed due to ratelimiting
[ 11.222764][ T308] update_verifier: Started with arg 1: nonencrypted
[ 11.233363][ T308] update_verifier: Booting slot 0: isSlotMarkedSuccessful=1
[ 11.241388][ T308] update_verifier: Leaving update_verifier.
[ 11.343807][ T315] sunxi-rfkill soc@3000000:rfkill: wlan power on success
[ 11.344486][ T184] [Awinic] aw87xxx_pa_init:driver version: v2.14.0
[ 11.359212][ T184] [Awinic] [14-0058]aw87xxx_dtsi_parse: get det_battery_supply failed
[ 11.359212][ T184]
[ 11.371639][ T184] [Awinic] [14-0059]aw87xxx_dtsi_parse: get det_battery_supply failed
[ 11.371639][ T184]
[ 11.401134][ T184] sunxi:sound-i2s:[WARN]: 2206 snd_sunxi_dts_params_init(): clk-en-post-delay missing
[ 11.411709][ T184] sunxi:sound-i2s:[WARN]: 2214 snd_sunxi_dts_params_init(): clk-keep missing
[ 11.421777][ T184] sunxi:sound-i2s:[WARN]: 2206 snd_sunxi_dts_params_init(): clk-en-post-delay missing
[ 11.432302][ T184] sunxi:sound-i2s:[WARN]: 2214 snd_sunxi_dts_params_init(): clk-keep missing
[ 11.446002][ T184] sunxi:sound-ac101:[INFO]: 2626 ac101_i2c_probe():
[ 11.451768][ T315] misc sunxi-wlan: start scan device on bus_index: 1
[ 11.453414][ T184] sunxi:sound-ac101:[ERR]: 2592 ac101_set_params_from_of(): det_gpio -> 34
[ 11.460668][ T95] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 11.470750][ T184] sunxi:sound-ac101:[ERR]: 2593 ac101_set_params_from_of(): plug_gpio -> 313
[ 11.495768][ T184] sunxi:sound-common:[INFO]: 36 snd_sunxi_pa_user_trig_init(): pa user mode -> init
[ 11.496150][ T95] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 11.506090][ T184] sunxi:sound-common:[INFO]: 36 snd_sunxi_pa_user_trig_init(): pa user mode -> init
[ 11.533005][ C0] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 1 p1 err, cmd 52, RTO !!
[ 11.543098][ C0] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 1 p1 err, cmd 52, RTO !!
[ 11.552374][ T95] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 11.569459][ T95] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 11.585843][ C0] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 1 p1 err, cmd 11, RE !!
[ 11.595029][ T95] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 11.610981][ T184] sunxi:sound-codec-hdmi:[ERR]: 442 sunxi_codec_dev_probe(): register codec-hdmi success
[ 11.611256][ T95] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 11.637540][ T184] sunxi:sound-mach:[WARN]: 372 asoc_simple_parse_ucfmt(): set data late to default
[ 11.648055][ T95] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 11.662907][ T94] platform boost5v-en: deferred probe pending
[ 11.689441][ T95] mmc1: queuing unknown CIS tuple 0x10 [07 00 11 00 8e] (5 bytes)
[ 11.703261][ T95] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 11.704497][ T184] sunxi:sound-ac101:[INFO]: 1529 ac101_probe(): wait ac101 reset successfully, need 0x101/257
[ 11.717684][ T95] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing LEGACY(SDR12) dt B
[ 11.741916][ T184] debugfs: Directory '2532000.i2s0_plat' with parent 'sndi2s0' already present!
[ 11.743293][ T95] mmc1: queuing unknown CIS tuple 0x10 [07 00 31 00 32] (5 bytes)
[ 11.753048][ T160] sunxi:sound-ac101:[INFO]: 531 sunxi_jack_adv_det_scan_work():
[ 11.770114][ T160] [sound] jack report -> OUT
[ 11.775378][ T95] mmc1: new SDIO card at address ac4d
[ 11.776478][ T184] input: sndi2s0 Headphones as /devices/platform/soc@3000000/soc@3000000:i2s0_mach/sound/card0/input1
[ 11.784648][ T315] sunxi-rfkill soc@3000000:rfkill: wlan power off success
[ 11.793712][ T184] sunxi:sound-mach:[WARN]: 372 asoc_simple_parse_ucfmt(): set data late to default
[ 11.801118][ T315] misc sunxi-wlan: start scan device on bus_index: 1
[ 11.811664][ T184] debugfs: Directory '2535000.i2s3_plat' with parent 'sndhdmi' already present!
[ 11.818680][ C0] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 1 p1 err, cmd 7, RTO !!
[ 11.837682][ C0] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 1 p1 err, cmd 7, RTO !!
[ 11.846907][ C0] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 1 p1 err, cmd 7, RTO !!
[ 11.856110][ C0] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 1 p1 err, cmd 7, RTO !!
[ 11.856901][ T184] npu[b8][b8] vipcore, platform driver init
[ 11.871918][ T95] mmc1: card ac4d removed
[ 11.872407][ T184] npu[b8][b8] vipcore, insmod param cpu_physical=0x0
[ 11.876690][ T95] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 11.884000][ T184] npu[b8][b8] vipcore, insmod param cpu_physical=0x0
[ 11.898907][ T95] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 11.905459][ T184] npu[b8][b8] vipcore, insmod param cpu_physical=0x0
[ 11.919205][ T315] aicbsp_init
[ 11.926452][ T184] npu[b8][b8] vipcore, insmod param cpu_physical=0x0
[ 11.929400][ T95] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 11.929504][ T315] aicbsp_init, Driver Release Tag: aic-bsp-compatible(sdio)-20240730-002
[ 11.936851][ T184] npu[b8][b8] vipcore, platform device compatible=allwinner,npu
[ 11.951401][ T315] -->aicbt_rfkill_init
[ 11.951716][ C0] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 1 p1 err, cmd 52, RTO !!
[ 11.960349][ T184] npu[b8][b8] vipcore, platform driver device=0xffffff80c0b7e410
[ 11.968565][ T315] <--aicbt_rfkill_init
[ 11.969279][ C0] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 1 p1 err, cmd 52, RTO !!
[ 11.972957][ T184] npu[b8][b8] clock_rate: 26000000
[ 11.982153][ T95] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 11.990777][ T184] npu[b8][b8] vipcore irq number is 463.
[ 11.997953][ T95] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 12.004224][ T184] npu[b8][b8] npu power domains status: 0
[ 12.004941][ T315] [BT_LPM] bluesleep_init: BlueSleep Mode Driver Ver 1.3.3
[ 12.004949][ T315] [BT_LPM] bluesleep_init: Driver Release Tag: aic-btlpm-20220429-008
[ 12.005329][ T315] [BT_LPM] bluesleep_probe: bt_hostwake gpio=388 assert=1
[ 12.005329][ T315]
[ 12.005333][ T315] [BT_LPM] bluesleep_probe: override host_wake assert to 1
[ 12.005367][ T315] [BT_LPM] bluesleep_probe: wakeup source is disabled!
[ 12.005367][ T315]
[ 12.005380][ T315] [BT_LPM] bluesleep_probe: bt_wake gpio=387 assert=1
[ 12.005380][ T315]
[ 12.005384][ T315] [BT_LPM] bluesleep_probe: override ext_wake assert to 1
[ 12.005400][ T315] [BT_LPM] bluesleep_probe: uart_index (1)
[ 12.005400][ T315]
[ 12.012191][ C0] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 1 p1 err, cmd 5, RTO !!
[ 12.023847][ T184] NPU AXI CLK NULL
[ 12.030788][ C0] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 1 p1 err, cmd 5, RTO !!
[ 12.044049][ T184] NPU AHB CLK NULL
[ 12.051092][ C0] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 1 p1 err, cmd 5, RTO !!
[ 12.058151][ T184] NPU TZMA CLK NULL
[ 12.067894][ C0] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 1 p1 err, cmd 5, RTO !!
[ 12.077302][ T184] npu[b8][b8] EXTRA: 0x00005100, SID: 0x0, max_freq: 1100000000, default_freq: 1100000000
[ 12.085225][ T95] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 12.095058][ T184] npu[b8][b8] current dvfs: 0, vf index: 0
[ 12.095174][ T184] vipcore 3600000.npu: dev_pm_opp_set_regulators: no regulator (npu) found: -19
[ 12.210697][ T184] npu[b8][b8] failed to set opp regulator
[ 12.216944][ T184] npu[b8][b8] enable aw vip devfreq
[ 12.222590][ T184] npu[b8][b8] no available freq info
[ 12.228375][ T184] vipcore 3600000.npu: supply npu not found, using dummy regulator
[ 12.237305][ T184] npu[b8][b8] vipcore, device_cnt=1, core_cnt=1
[ 12.244308][ T184] npu[b8][b8] core_0, request irqline=463, name=vipcore_0
[ 12.252171][ T184] npu[b8][b8] vipcore, allocate page for video memory, size: 0x400000 bytes
[ 12.263004][ T184] npu[b8][b8] vipcore, heap_cnt=0, reserved video memory cpu_phy=0x11ac00000, vip_phy=0x11ac00000, size=0x400000
[ 12.276294][ T184] npu[b8][b8] VIPLite driver version 2.0.3.0-AW-2024-05-29
[ 12.308072][ T229] type=1400 audit(1748526567.804:10): avc: denied { write } for comm="init" name="discard_max_bytes" dev="sysfs" ino=39324 scontext=u:r:init:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[ 12.330221][ T229] type=1400 audit(1748526567.804:11): avc: denied { open } for comm="init" path="/sys/devices/platform/soc@3000000/4023000.sdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/queue/discard_max_bytes" dev="sysfs" ino=39324 scontext=u:r:init:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[ 12.425767][ T344] healthd: No battery devices found
[ 12.433879][ T344] healthd: battery none chg=
[ 12.438935][ T344] healthd: battery none chg=
[ 12.444250][ T344] healthd: battery none chg=
[ 12.479970][ T343] PVR_K: 343: RGX Firmware image 'rgx.fw.36.56.104.183' loaded
[ 12.499008][ T343] PVR_K: 343: Shader binary image 'rgx.sh.36.56.104.183' loaded
[ 12.512245][ T343] pvrsrvkm 1800000.gpu: sunxiPrePowerState ePwrFlags:1 current power status:0 1
[ 12.513689][ T229] type=1400 audit(1748526568.012:12): avc: denied { read } for comm="display.output-" name="u:object_r:boot_status_prop:s0" dev="tmpfs" ino=80 scontext=u:r:hal_awdisplayoutput_default:s0 tcontext=u:object_r:boot_status_prop:s0 tclass=file permissive=1
[ 12.522326][ T343] pvrsrvkm 1800000.gpu: sunxiPostPowerState ePwrFlags:1 current power status:1 1
[ 12.549389][ T229] type=1400 audit(1748526568.012:13): avc: denied { open } for comm="display.output-" path="/dev/__properties__/u:object_r:boot_status_prop:s0" dev="tmpfs" ino=80 scontext=u:r:hal_awdisplayoutput_default:s0 tcontext=u:object_r:boot_status_prop:s0 tclass=file permissive=1
[ 12.575490][ T343] pvrsrvkm 1800000.gpu: sunxiPrePowerState ePwrFlags:1 current power status:1 1
[ 12.588254][ T229] type=1400 audit(1748526568.012:14): avc: denied { getattr } for comm="display.output-" path="/dev/__properties__/u:object_r:boot_status_prop:s0" dev="tmpfs" ino=80 scontext=u:r:hal_awdisplayoutput_default:s0 tcontext=u:object_r:boot_status_prop:s0 tclass=file permissive=1
[ 12.598117][ T343] pvrsrvkm 1800000.gpu: sunxiPostPowerState ePwrFlags:1 current power status:1 1
[ 12.601525][ T344] healthd: battery none chg=
[ 12.625376][ T344] healthd: battery none chg=
[ 12.626833][ T229] type=1400 audit(1748526568.012:15): avc: denied { map } for comm="display.output-" path="/dev/__properties__/u:object_r:boot_status_prop:s0" dev="tmpfs" ino=80 scontext=u:r:hal_awdisplayoutput_default:s0 tcontext=u:object_r:boot_status_prop:s0 tclass=file permissive=1
[ 12.637247][ T362] function = msa_startup = = = = = = = = = LINE = 1043.
[ 12.637765][ T343] pvrsrvkm 1800000.gpu: sunxiPrePowerState ePwrFlags:1 current power status:0 1
[ 12.637837][ T343] pvrsrvkm 1800000.gpu: sunxiPostPowerState ePwrFlags:1 current power status:1 1
[ 12.637843][ T343] pvrsrvkm 1800000.gpu: sunxiPrePowerState ePwrFlags:1 current power status:1 1
[ 12.637845][ T343] pvrsrvkm 1800000.gpu: sunxiPostPowerState ePwrFlags:1 current power status:1 1
[ 12.637882][ T344] healthd: battery none chg=
[ 12.640102][ T344] healthd: battery none chg=
[ 12.641800][ T229] type=1400 audit(1748526568.056:16): avc: denied { read } for comm="android.hardwar" name="thermal" dev="sysfs" ino=9141 scontext=u:r:hal_power_default:s0 tcontext=u:object_r:sysfs_thermal:s0 tclass=dir permissive=1
[ 12.643025][ T344] healthd: battery none chg=
[ 12.645330][ T184] file system registered
[ 12.647025][ T362] msa use sepical device node name = msa
[ 12.652935][ T184] using random self ethernet address
[ 12.652944][ T184] using random host ethernet address
[ 12.656841][ T343] PVR_K: 343: FTrace event from "gpu_work_period" enabled
[ 12.675510][ T229] type=1400 audit(1748526568.056:17): avc: denied { open } for comm="android.hardwar" path="/sys/class/thermal" dev="sysfs" ino=9141 scontext=u:r:hal_power_default:s0 tcontext=u:object_r:sysfs_thermal:s0 tclass=dir permissive=1
[ 12.685146][ T362] ERROR! get gsensor_para failed, func:sunxi_gsensor_startup, line:304
[ 12.693964][ T229] type=1400 audit(1748526568.072:18): avc: denied { setattr } for comm="init" name="ext_csd" dev="debugfs" ino=11031 scontext=u:r:init:s0 tcontext=u:object_r:debugfs_mmc:s0 tclass=file permissive=1
[ 12.703702][ T362] =========gsensor script_get_err============
[ 12.703710][ T362] msa_startup: err.
[ 12.710831][ T184] sunxi-rfkill soc@3000000:rfkill: block state already is 1
[ 12.714169][ T229] type=1400 audit(1748526568.088:19): avc: denied { integrity } for comm="init" lockdown_reason="debugfs access" scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=lockdown permissive=1
[ 12.735457][ T344] healthd: battery none chg=
[ 12.763702][ T184] pps_core: LinuxPPS API ver. 1 registered
[ 12.900186][ T184] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 12.914661][ T362] qst-qmi8658_i2c_init(line:1046) qmi8658 A+G driver: init
[ 12.922816][ T362] function=startup=========LINE=1025.
[ 12.923403][ T184] PTP clock support registered
[ 12.929763][ T362] ERROR! get gsensor_para failed, func:sunxi_gsensor_startup, line:304
[ 12.943343][ T362] =========gsensor script_get_err============
[ 12.950007][ T362] startup: err.
[ 12.955627][ T184] dwmac-sunxi 4500000.ethernet: IRQ eth_wake_irq not found
[ 12.963890][ T184] sunxi:stmmac-4500000.ethernet:[INFO]: Phy use soc fanout
[ 12.972399][ T184] sunxi:stmmac-4500000.ethernet:[INFO]: Not found delay-maps in dts
[ 12.981662][ T184] sunxi:stmmac-4500000.ethernet:[INFO]: RGMII use external transmit clock
[ 12.991313][ T184] dwmac-sunxi 4500000.ethernet: User ID: 0x20, Synopsys ID: 0x53
[ 12.999835][ T184] dwmac-sunxi 4500000.ethernet: DWMAC4/5
[ 13.006089][ T184] dwmac-sunxi 4500000.ethernet: DMA HW capability register supported
[ 13.008638][ T389] [drm] sunxi-hdmi: [warn] hdmi drv check old dynamic range 1 unsupport!
[ 13.014951][ T184] dwmac-sunxi 4500000.ethernet: RX Checksum Offload Engine supported
[ 13.014954][ T184] dwmac-sunxi 4500000.ethernet: TX Checksum insertion supported
[ 13.014955][ T184] dwmac-sunxi 4500000.ethernet: Wake-Up On Lan supported
[ 13.015092][ T184] dwmac-sunxi 4500000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 13.015098][ T184] dwmac-sunxi 4500000.ethernet: Enabled RFS Flow TC (entries=8)
[ 13.015103][ T184] dwmac-sunxi 4500000.ethernet: Using 32 bits DMA width
[ 13.025269][ T362] ERROR! get ls_para failed, func:sunxi_ls_startup, line:563
[ 13.033997][ T389] [drm] sunxi-hdmi: drm hdmi detect: disconnect
[ 13.041985][ T362] startup: ls_fetch_sysconfig_para err.
[ 13.049853][ T389] [drm] sunxi-hdmi: [warn] hdmi drv check old dynamic range 1 unsupport!
[ 13.193111][ T184] sunxi:stmmac-4500000.ethernet:[INFO]: probe success (Version 0.3.2)
[ 13.196839][ T418] [drm] sunxi-hdmi: drm hdmi detect: disconnect
[ 13.218417][ T418] [drm] sunxi-hdmi: [warn] hdmi drv check old dynamic range 1 unsupport!
[ 13.218839][ T184] IR NEC protocol handler initialized
[ 13.240427][ T184] sun60iw2-r-pinctrl 7025000.pinctrl: pin PL4 already requested by 7025000.pinctrl:356; cannot claim for 7040000.irrx
[ 13.254084][ T184] sun60iw2-r-pinctrl 7025000.pinctrl: pin-356 (7040000.irrx) status -22
[ 13.263233][ T184] sun60iw2-r-pinctrl 7025000.pinctrl: could not request pin 356 (PL4) from group PL4 on device 7025000.pinctrl
[ 13.276254][ T184] sunxi-rc-recv 7040000.irrx: Error applying setting, reverse things back
[ 13.313983][ T184] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 13.318667][ T418] [drm] sunxi-hdmi: drm hdmi detect: disconnect
[ 13.323851][ T184] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 13.330621][ T418] [drm] sunxi-hdmi: [warn] hdmi drv check old dynamic range 1 unsupport!
[ 13.338692][ T95] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 13.358365][ T95] cfg80211: failed to load regulatory.db
[ 13.385258][ T184] deinterlace 5400000.deinterlace: Adding to iommu group 0
[ 13.393262][ T184] sunxi:deinterlace:[INFO]: DI probe
[ 13.403432][ T184] sunxi:ehci_sunxi:[INFO]: sunxi-ehci: EHCI SUNXI driver
[ 13.417438][ T184] sunxi:sunxi_hci:[INFO]: sunxi ehci0-controller don't init wakeup source
[ 13.426852][ T184] sunxi:ehci_sunxi:[INFO]: [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xffffffc001df0030, 0x:ffffffc00ca4d000, irq_no:1d5
[ 13.443656][ T184] sunxi:ehci_sunxi:[INFO]: [sunxi-ehci0]: Not init ehci0
[ 13.451870][ T184] sunxi:sunxi_hci:[INFO]: sunxi ehci1-controller don't init wakeup source
[ 13.461224][ T184] sunxi:ehci_sunxi:[INFO]: [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xffffffc001df0930, 0x:ffffffc00ca65000, irq_no:1d6
[ 13.478132][ T184] sunxi-ehci 4200000.ehci1-controller: supply drvvbus not found, using dummy regulator
[ 13.488964][ T184] sunxi-ehci 4200000.ehci1-controller: supply hci not found, using dummy regulator
[ 13.499325][ T184] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
[ 13.507340][ T184] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
[ 13.517819][ T184] sunxi-ehci 4200000.ehci1-controller: irq 470, io mem 0x04200000
[ 13.540163][ T184] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
[ 13.548795][ T184] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 13.558810][ T184] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 13.567653][ T184] usb usb1: Product: EHCI Host Controller
[ 13.573870][ T184] usb usb1: Manufacturer: Linux 5.15.119-gc82a3c8d0b63-dirty ehci_hcd
[ 13.582807][ T184] usb usb1: SerialNumber: sunxi-ehci
[ 13.588827][ T184] hub 1-0:1.0: USB hub found
[ 13.593830][ T184] hub 1-0:1.0: 1 port detected
[ 13.608353][ T184] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 13.618398][ T184] ohci-pci: OHCI PCI platform driver
[ 13.627014][ T184] sunxi:ohci_sunxi:[INFO]: sunxi-ohci: OHCI SUNXI driver
[ 13.635291][ T184] sunxi:sunxi_hci:[INFO]: sunxi ohci0-controller don't init wakeup source
[ 13.644689][ T184] sunxi:ohci_sunxi:[INFO]: [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xffffffc001df04b0
[ 13.658331][ T184] sunxi:ohci_sunxi:[INFO]: [sunxi-ohci0]: Not init ohci0
[ 13.666544][ T184] sunxi:sunxi_hci:[INFO]: sunxi ohci1-controller don't init wakeup source
[ 13.675926][ T184] sunxi:ohci_sunxi:[INFO]: [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xffffffc001df0db0
[ 13.689639][ T184] sunxi-ohci 4200400.ohci1-controller: supply drvvbus not found, using dummy regulator
[ 13.700480][ T184] sunxi-ohci 4200400.ohci1-controller: supply hci not found, using dummy regulator
[ 13.710834][ T184] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
[ 13.718846][ T184] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
[ 13.729379][ T184] sunxi-ohci 4200400.ohci1-controller: irq 472, io mem 0x04200400
[ 13.800390][ T184] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15
[ 13.810415][ T184] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 13.819257][ T184] usb usb2: Product: OHCI Host Controller
[ 13.825477][ T184] usb usb2: Manufacturer: Linux 5.15.119-gc82a3c8d0b63-dirty ohci_hcd
[ 13.834416][ T184] usb usb2: SerialNumber: sunxi-ohci
[ 13.840451][ T184] hub 2-0:1.0: USB hub found
[ 13.845456][ T184] hub 2-0:1.0: 1 port detected
[ 13.852562][ T95] usb 1-1: new high-speed USB device number 2 using sunxi-ehci
[ 13.861921][ T184] sunxi:phy_sunxi_plat-6b00000.phy:[INFO]: resistance calibration supported - enabled, mode - V2
[ 13.873943][ T184] sunxi:phy_sunxi_plat-6b00000.phy:[INFO]: phy provider register success
[ 13.887686][ T184] sunxi:dwc3_sunxi_plat-12.usbc2:[ERR]: couldn't get drvvbus supply
[ 13.897741][ T184] sunxi-cadence-combophy 6c00000.serdes: combophy1 set power ON
[ 13.919545][ T441] sunxi:sound-ac101:[INFO]: 653 ac101_startup(): wait ac101 reset successfully, need 0x101/257
[ 13.933017][ T184] xhci-hcd xhci-hcd.41.auto: xHCI Host Controller
[ 13.935958][ T441] sunxi-ac101 14-001a: sunxi:sound-ac101ac101 sysclk source don't pll, don't need config pll
[ 13.940064][ T184] xhci-hcd xhci-hcd.41.auto: new USB bus registered, assigned bus number 3
[ 13.940166][ T184] xhci-hcd xhci-hcd.41.auto: hcc params 0x0118ffc5 hci version 0x120 quirks 0x0000000000010010
[ 13.966260][ T441] dma dma0chan0: The timeout func is not suportted or chan->private is NULL, timeout mode not used
[ 13.972188][ T184] xhci-hcd xhci-hcd.41.auto: irq 473, io mem 0x06a00000
[ 13.991639][ T184] xhci-hcd xhci-hcd.41.auto: xHCI Host Controller
[ 13.998683][ T184] xhci-hcd xhci-hcd.41.auto: new USB bus registered, assigned bus number 4
[ 14.008116][ T184] xhci-hcd xhci-hcd.41.auto: Host supports USB 3.1 Enhanced SuperSpeed
[ 14.017244][ T184] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 14.027289][ T184] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 14.036167][ T184] usb usb3: Product: xHCI Host Controller
[ 14.042403][ T184] usb usb3: Manufacturer: Linux 5.15.119-gc82a3c8d0b63-dirty xhci-hcd
[ 14.051351][ T184] usb usb3: SerialNumber: xhci-hcd.41.auto
[ 14.057671][ T95] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
[ 14.060470][ T184] hub 3-0:1.0: USB hub found
[ 14.067579][ T95] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 14.067581][ T95] usb 1-1: Product: USB 2.0 Hub
[ 14.068916][ T95] hub 1-1:1.0: USB hub found
[ 14.072601][ T184] hub 3-0:1.0: 1 port detected
[ 14.085454][ T95] hub 1-1:1.0: 4 ports detected
[ 14.086840][ T184] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 14.111935][ T184] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 14.121962][ T184] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 14.130811][ T184] usb usb4: Product: xHCI Host Controller
[ 14.137040][ T184] usb usb4: Manufacturer: Linux 5.15.119-gc82a3c8d0b63-dirty xhci-hcd
[ 14.145986][ T184] usb usb4: SerialNumber: xhci-hcd.41.auto
[ 14.152602][ T184] hub 4-0:1.0: USB hub found
[ 14.157604][ T184] hub 4-0:1.0: 1 port detected
[ 14.163161][ T184] sunxi:dwc3_sunxi_plat-12.usbc2:[INFO]: DesignWare USB3 Allwinner Glue Layer Driver(v1.0.22 2024-10-08 16:30)
[ 14.184539][ T184] sunxi_usb_udc 4100000.udc-controller: sunxi:sunxi_usb_udc UDC Inner DMA Feature - wordaddr: 1, extend: enabled
[ 14.201634][ T184] sunxi:sunxi_usbc:[INFO]: OTG can't find bcten-gpio, use default mode.
[ 14.211003][ T184] sunxi:sunxi_usbc:[INFO]: get det_vbus is fail, -84
[ 14.218364][ T184] sunxi:sunxi_usbc:[INFO]: get id is fail, -84
[ 14.233759][ T184] usbcore: registered new interface driver option
[ 14.246127][ T184] usbserial: USB Serial support registered for GSM modem (1-port)
[ 14.257084][ T184] I2C functionality : OK...
[ 14.262411][ T184] husb311 failed to find usb power
[ 14.270733][ T184] husb311 13-004e: vbus is already Off
[ 14.277974][ T184] sunxi:sunxi_usbc:[INFO]: usb role switch set null -> null
[ 14.287433][ T448] husb311 13-004e: vbus is already Off
[ 14.287730][ T184] husb311 13-004e: Vendor ID:0x2e99, Product ID:0x0311, probe success
[ 14.294758][ T448] sunxi:sunxi_usbc:[INFO]: usb role switch set null -> null
[ 14.331714][ T184] sunxi:lradc-2524000.lradc:[WARN]: get key_debounce failed, please check whether to enable key debounce
[ 14.344215][ T184] sunxi:lradc-2524000.lradc:[WARN]: warn: filter_cnt not set, default value is 3
[ 14.355347][ T184] input: sunxi-keyboard as /devices/platform/soc@3000000/2524000.lradc/input/input2
[ 14.367079][ T184] sunxi:lradc-2524000.lradc:[INFO]: sunxi lradc init success
[ 14.377856][ T184] sunxi:sunxi_smcdrm config service not available: FFFFFFFF
[ 14.428922][ T184] sunxi:VE:[INFO]: 2373 sunxi_cedar_init(): sunxi cedar version 1.1
[ 14.445886][ T184] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
[ 14.452968][ T184] sunxi:VE:[INFO]: 2295 sunxi_cedar_probe(): probe ve
[ 14.460508][ T184] sunxi-cedar 1c0e000.ve: supply ve not found, using dummy regulator
[ 14.469664][ T184] sunxi-cedar 1c0e000.ve: sunxi:VE no or not support operating-points-v2 node
[ 14.479573][ T184] sunxi-cedar soc@3000000:ve1@1c0e000: Adding to iommu group 0
[ 14.487906][ T184] sunxi:VE:[INFO]: 2298 sunxi_cedar_probe(): probe ve1
[ 14.495464][ T184] sunxi-cedar 1c10000.ve2: Adding to iommu group 0
[ 14.502611][ T184] sunxi:VE:[INFO]: 2301 sunxi_cedar_probe(): probe ve2
[ 14.510241][ T184] sunxi-cedar 1c10000.ve2: supply ve not found, using dummy regulator
[ 14.519484][ T184] sunxi-cedar 1c10000.ve2: sunxi:VE no or not support operating-points-v2 node
[ 14.533175][ T184] reg-virt-consumer reg-virt-consumer.1.auto: DMA mask not set
[ 14.541952][ T184] reg-virt-consumer reg-virt-consumer.2.auto: DMA mask not set
[ 14.550587][ T184] reg-virt-consumer reg-virt-consumer.3.auto: DMA mask not set
[ 14.559241][ T184] reg-virt-consumer reg-virt-consumer.4.auto: DMA mask not set
[ 14.567912][ T184] reg-virt-consumer reg-virt-consumer.5.auto: DMA mask not set
[ 14.576654][ T184] reg-virt-consumer reg-virt-consumer.6.auto: DMA mask not set
[ 14.585462][ T184] reg-virt-consumer reg-virt-consumer.7.auto: DMA mask not set
[ 14.594237][ T184] reg-virt-consumer reg-virt-consumer.8.auto: DMA mask not set
[ 14.603129][ T184] reg-virt-consumer reg-virt-consumer.9.auto: DMA mask not set
[ 14.611998][ T184] reg-virt-consumer reg-virt-consumer.10.auto: DMA mask not set
[ 14.620799][ T184] reg-virt-consumer reg-virt-consumer.11.auto: DMA mask not set
[ 14.629414][ T184] reg-virt-consumer reg-virt-consumer.12.auto: DMA mask not set
[ 14.638020][ T184] reg-virt-consumer reg-virt-consumer.13.auto: DMA mask not set
[ 14.646611][ T184] reg-virt-consumer reg-virt-consumer.14.auto: DMA mask not set
[ 14.655215][ T184] reg-virt-consumer reg-virt-consumer.15.auto: DMA mask not set
[ 14.663866][ T184] reg-virt-consumer reg-virt-consumer.16.auto: supply bldo1 not found, using dummy regulator
[ 14.675256][ T184] reg-virt-consumer reg-virt-consumer.17.auto: supply bldo2 not found, using dummy regulator
[ 14.686640][ T184] reg-virt-consumer reg-virt-consumer.18.auto: supply bldo3 not found, using dummy regulator
[ 14.697990][ T184] reg-virt-consumer reg-virt-consumer.19.auto: supply bldo4 not found, using dummy regulator
[ 14.709334][ T184] reg-virt-consumer reg-virt-consumer.20.auto: supply bldo5 not found, using dummy regulator
[ 14.720692][ T184] reg-virt-consumer reg-virt-consumer.21.auto: supply cldo1 not found, using dummy regulator
[ 14.732041][ T184] reg-virt-consumer reg-virt-consumer.22.auto: supply cldo2 not found, using dummy regulator
[ 14.743409][ T184] reg-virt-consumer reg-virt-consumer.23.auto: supply cldo3 not found, using dummy regulator
[ 14.754753][ T184] reg-virt-consumer reg-virt-consumer.24.auto: supply cldo4 not found, using dummy regulator
[ 14.766146][ T184] reg-virt-consumer reg-virt-consumer.25.auto: supply cldo5 not found, using dummy regulator
[ 14.777496][ T184] reg-virt-consumer reg-virt-consumer.26.auto: DMA mask not set
[ 14.786234][ T184] reg-virt-consumer reg-virt-consumer.27.auto: DMA mask not set
[ 14.794792][ T184] reg-virt-consumer reg-virt-consumer.28.auto: DMA mask not set
[ 14.796543][ T317] husb311 13-004e: CC1: 0 - Open, CC2: 0 - Open
[ 14.803345][ T184] reg-virt-consumer reg-virt-consumer.29.auto: DMA mask not set
[ 14.810001][ T317] sunxi:sunxi_usbc:[INFO]: usb role switch set null -> null
[ 14.818488][ T184] reg-virt-consumer reg-virt-consumer.30.auto: DMA mask not set
[ 14.834989][ T184] reg-virt-consumer reg-virt-consumer.31.auto: DMA mask not set
[ 14.843734][ T184] reg-virt-consumer reg-virt-consumer.32.auto: DMA mask not set
[ 14.852624][ T184] reg-virt-consumer reg-virt-consumer.33.auto: DMA mask not set
[ 14.861411][ T184] reg-virt-consumer reg-virt-consumer.34.auto: DMA mask not set
[ 14.870127][ T184] reg-virt-consumer reg-virt-consumer.35.auto: DMA mask not set
[ 14.878712][ T184] reg-virt-consumer reg-virt-consumer.36.auto: DMA mask not set
[ 14.887398][ T184] reg-virt-consumer reg-virt-consumer.37.auto: DMA mask not set
[ 14.896274][ T184] reg-virt-consumer reg-virt-consumer.38.auto: DMA mask not set
[ 14.904995][ T184] reg-virt-consumer reg-virt-consumer.39.auto: DMA mask not set
[ 14.913412][ T184] reg-virt-consumer reg-virt-consumer.39.auto: supply dc1sw1 not found, using dummy regulator
[ 14.924909][ T184] reg-virt-consumer reg-virt-consumer.40.auto: DMA mask not set
[ 14.933333][ T184] reg-virt-consumer reg-virt-consumer.40.auto: supply dc1sw2 not found, using dummy regulator
[ 15.102309][ T1] init: Command 'mkdir /sys/kernel/tracing/instances/bootreceiver 0700 system system' action=bootreceiver.enable=1 && ro.product.cpu.abilist64=* (/system/etc/init/hw/init.rc:656) took 67ms and succeeded
[ 15.126380][ T1] init: processing action (net.tcp_def_init_rwnd=*) from (/system/etc/init/hw/init.rc:1211)
[ 15.137848][ T1] init: processing action (sys.init.perf_lsm_hooks=1) from (/system/etc/init/hw/init.rc:1222)
[ 15.149422][ T1] init: processing action (security.perf_harden=1) from (/system/etc/init/hw/init.rc:1236)
[ 15.160789][ T1] init: processing action (ro.debuggable=1) from (/system/etc/init/hw/init.rc:1271)
[ 15.171367][ T1] init: processing action (init.svc.audioserver=running) from (/system/etc/init/audioserver.rc:38)
[ 15.183165][ T1] init: service 'vendor.audio-hal' requested start, but it is already running (flags: 4)
[ 15.193983][ T1] init: Command 'start vendor.audio-hal-4-0-msd' action=init.svc.audioserver=running (/system/etc/init/audioserver.rc:40) took 0ms and failed: service vendor.audio-hal-4-0-msd not found
[ 15.214279][ T1] init: Command 'start audio_proxy_service' action=init.svc.audioserver=running (/system/etc/init/audioserver.rc:41) took 0ms and failed: service audio_proxy_service not found
[ 15.233625][ T1] init: Command 'start vendor.audio-hal-2-0' action=init.svc.audioserver=running (/system/etc/init/audioserver.rc:43) took 0ms and failed: service vendor.audio-hal-2-0 not found
[ 15.390477][ T104] sunxi:sunxi_mmc_host-4023000.sdmmc:[INFO]: have to disable cqe when send cmd with data!!!, CQHCI_CFG:2001020
[ 15.404602][ C0] sunxi:sunxi_mmc_host-4023000.sdmmc:[INFO]: cmd with data done, restore cqe enable and halt:2001021,1,6,6
[ 15.716746][ T337] [Awinic] [14-0059]aw_monitor_get_battery_status: get power supply failed
[ 15.720789][ T536] read descriptors
[ 15.726930][ T337] [Awinic] [14-0058]aw_monitor_get_battery_status: get power supply failed
[ 15.736197][ T536] read strings
[ 15.739980][ T337] [Awinic] aw87xxx_hal_monitor_time_get:get monitor time 3000
[ 15.756692][ T317] husb311 13-004e: CC1: 3 - Rp-def, CC2: 3 - Rp-def
[ 15.764332][ T317] sunxi:sunxi_usbc:[INFO]: usb role switch set null -> device
[ 15.772840][ T317] sunxi:sunxi_usbc:[INFO]: auto set usb role [device]
[ 15.780576][ T317] sunxi:sunxi_usbc:[INFO]: insmod_device_driver
[ 15.780576][ T317]
[ 15.790671][ T317] sunxi_usb_udc 4100000.udc-controller: supply udc not found, using dummy regulator
[ 16.435316][ T317] sunxi:sunxi_usb_udc:[WARN]: sunxi_set_cur_vol_work()537 WARN: get power supply failed
[ 16.522187][ T317] android_work: sent uevent USB_STATE=CONNECTED
[ 16.687823][ T21] sunxi:sunxi_usb_udc:[WARN]: sunxi_set_cur_vol_work()537 WARN: get power supply failed
[ 16.780216][ T317] sunxi:sunxi_usb_udc:[WARN]: sunxi_vbus_det_work()3728 WARN: get power supply failed
[ 16.791713][ T317] android_work: sent uevent USB_STATE=DISCONNECTED
[ 16.802842][ T317] android_work: sent uevent USB_STATE=CONNECTED
[ 16.831884][ T317] android_work: sent uevent USB_STATE=CONFIGURED
[ 18.341302][ T229] type=1400 audit(1748526573.840:54): avc: denied { open } for comm="getprop" path="/dev/__properties__/u:object_r:aac_drc_prop:s0" dev="tmpfs" ino=59 scontext=u:r:shell:s0 tcontext=u:object_r:aac_drc_prop:s0 tclass=file permissive=1
[ 18.345749][ T608] audit: audit_backlog=65 > audit_backlog_limit=64
[ 18.364522][ T362] audit: audit_backlog=65 > audit_backlog_limit=64
[ 18.364531][ T362] audit: audit_lost=1 audit_rate_limit=0 audit_backlog_limit=64
[ 18.364535][ T362] audit: backlog limit exceeded
[ 18.366819][ T229] type=1400 audit(1748526573.840:55): avc: denied { getattr } for comm="getprop" path="/dev/__properties__/u:object_r:aac_drc_prop:s0" dev="tmpfs" ino=59 scontext=u:r:shell:s0 tcontext=u:object_r:aac_drc_prop:s0 tclass=file permissive=1
[ 18.370523][ T344] healthd: battery none chg=
[ 18.372078][ T344] healthd: battery none chg=
[ 18.372476][ T344] healthd: battery none chg=
[ 18.373547][ T608] audit: audit_lost=2 audit_rate_limit=0 audit_backlog_limit=64
[ 18.381050][ T229] type=1400 audit(1748526573.840:56): avc: denied { map } for comm="getprop" path="/dev/__properties__/u:object_r:aac_drc_prop:s0" dev="tmpfs" ino=59 scontext=u:r:shell:s0 tcontext=u:object_r:aac_drc_prop:s0 tclass=file permissive=1
[ 18.382334][ T344] healthd: battery none chg=
[ 18.382911][ T344] healthd: battery none chg=
[ 18.385306][ T344] healthd: battery none chg=
[ 18.389152][ T608] audit: backlog limit exceeded
[ 18.394629][ T229] type=1400 audit(1748526573.840:57): avc: denied { open } for comm="getprop" path="/dev/__properties__/u:object_r:ab_update_gki_prop:s0" dev="tmpfs" ino=61 scontext=u:r:shell:s0 tcontext=u:object_r:ab_update_gki_prop:s0 tclass=file permissive=1
[ 18.419640][ T608] audit: audit_backlog=65 > audit_backlog_limit=64
[ 18.424660][ T229] type=1400 audit(1748526573.840:58): avc: denied { getattr } for comm="getprop" path="/dev/__properties__/u:object_r:ab_update_gki_prop:s0" dev="tmpfs" ino=61 scontext=u:r:shell:s0 tcontext=u:object_r:ab_update_gki_prop:s0 tclass=file permissive=1
[ 18.429511][ T608] audit: audit_lost=3 audit_rate_limit=0 audit_backlog_limit=64
[ 18.434564][ T229] type=1400 audit(1748526573.840:59): avc: denied { map } for comm="getprop" path="/dev/__properties__/u:object_r:ab_update_gki_prop:s0" dev="tmpfs" ino=61 scontext=u:r:shell:s0 tcontext=u:object_r:ab_update_gki_prop:s0 tclass=file permissive=1
[ 18.442787][ T608] audit: backlog limit exceeded
[ 18.442899][ T608] audit: audit_backlog=65 > audit_backlog_limit=64
[ 18.469395][ T229] type=1400 audit(1748526573.840:60): avc: denied { open } for comm="getprop" path="/dev/__properties__/u:object_r:adaptive_haptics_prop:s0" dev="tmpfs" ino=62 scontext=u:r:shell:s0 tcontext=u:object_r:adaptive_haptics_prop:s0 tclass=file permissive=1
[ 18.620830][ T229] type=1400 audit(1748526573.840:61): avc: denied { getattr } for comm="getprop" path="/dev/__properties__/u:object_r:adaptive_haptics_prop:s0" dev="tmpfs" ino=62 scontext=u:r:shell:s0 tcontext=u:object_r:adaptive_haptics_prop:s0 tclass=file permissive=1
[ 18.647877][ T229] type=1400 audit(1748526573.840:62): avc: denied { map } for comm="getprop" path="/dev/__properties__/u:object_r:adaptive_haptics_prop:s0" dev="tmpfs" ino=62 scontext=u:r:shell:s0 tcontext=u:object_r:adaptive_haptics_prop:s0 tclass=file permissive=1
[ 18.674481][ T229] type=1400 audit(1748526573.840:63): avc: denied { open } for comm="getprop" path="/dev/__properties__/u:object_r:adbd_prop:s0" dev="tmpfs" ino=64 scontext=u:r:shell:s0 tcontext=u:object_r:adbd_prop:s0 tclass=file permissive=1
[ 18.810467][ T344] healthd: battery none chg=
[ 18.816778][ T344] healthd: battery none chg=
[ 18.822488][ T344] healthd: battery none chg=
[ 18.828438][ T344] healthd: battery none chg=
[ 24.999219][ T441] sunxi:sound-ac101:[INFO]: 653 ac101_startup(): wait ac101 reset successfully, need 0x101/257
[ 25.016396][ T441] sunxi-ac101 14-001a: sunxi:sound-ac101ac101 sysclk source don't pll, don't need config pll
[ 25.172235][ T95] sunxi:sunxi_pd_test-soc@3000000:pd_pcie_test@0:[WARN]: runtime_suspend disable clock
[ 25.182858][ T95] sunxi:sunxi_pd_test-soc@3000000:pd_usb2_test@0:[WARN]: runtime_suspend disable clock
[ 25.193652][ T95] sunxi:sunxi_pd_test-soc@3000000:pd_de_sys_test@0:[WARN]: runtime_suspend disable clock
[ 25.204584][ T95] sunxi:sunxi_pd_test-soc@3000000:pd_vo_test@0:[WARN]: runtime_suspend disable clock
[ 25.215000][ T95] sunxi:sunxi_pd_test-soc@3000000:pd_vo1_test@0:[WARN]: runtime_suspend disable clock
[ 28.553250][ T1] init: Sending signal 9 to service 'idmap2d' (pid 483) process group...
[ 28.568012][ T1] libprocessgroup: Successfully killed process cgroup uid 1000 pid 483 in 5ms
[ 28.578387][ T1] init: Control message: Processed ctl.stop for 'idmap2d' from pid: 450 (system_server)
[ 28.589418][ T1] init: Service 'idmap2d' (pid 483) received signal 9
[ 29.077868][ T615] read descriptors
[ 29.081889][ T615] read strings
[ 29.085581][ T615] read descriptors
[ 29.089583][ T615] read strings
[ 29.757067][ T344] healthd: battery none chg=
[ 29.866566][ T1] init: starting service 'vendor.wifi_hal_legacy'...
[ 29.877917][ T1] init: Control message: Processed ctl.interface_start for 'android.hardware.wifi@1.0::IWifi/default' from pid: 215 (/system/bin/hwservicemanager)
[ 29.895306][ T1] init: service 'vendor.wifi_hal_legacy' requested start, but it is already running (flags: 134)
[ 29.907141][ T1] init: Control message: Processed ctl.interface_start for 'android.hardware.wifi@1.0::IWifi/default' from pid: 215 (/system/bin/hwservicemanager)
[ 29.997174][ T344] healthd: battery none chg=
[ 30.014342][ T1002] >>> rwnx_mod_init()
[ 30.018712][ T1002] rwnx 20240730-005-6.4.3.0 - - 241c091M (master)
[ 30.025735][ T1002] Driver Release Tag: aic-rwnx-compatible(sdio)-20240730-005
[ 30.033872][ T1002] aicbsp: aicbsp_set_subsys, subsys: AIC_WIFI, state to: 1
[ 30.041778][ T1002] aicbsp: aicbsp_set_subsys, power state change to 1 dure to AIC_WIFI
[ 30.050806][ T1002] aicbsp: aicbsp_platform_power_on
[ 30.060502][ T1002] sunxi-rfkill soc@3000000:rfkill: bus_index: 1
[ 30.067930][ T1002] aicbsp: aicbsp_platform_power_on disable MMC_CAP_UHS_DDR50 for host 00000000b1358c3e
[ 30.078886][ T344] healthd: battery none chg=
[ 30.089841][ T1002] sunxi-rfkill soc@3000000:rfkill: wlan power on success
[ 30.147563][ T160] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 30.164459][ T310] dwmac-sunxi 4500000.ethernet eth0: PHY [stmmac-0:01] driver [Generic PHY] (irq=POLL)
[ 30.175596][ T160] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 30.176352][ T310] dwmac-sunxi 4500000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
[ 30.201056][ C0] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 1 p1 err, cmd 52, RTO !!
[ 30.208168][ T310] dwmac4: Master AXI performs fixed burst length
[ 30.211245][ C0] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 1 p1 err, cmd 52, RTO !!
[ 30.217317][ T310] dwmac-sunxi 4500000.ethernet eth0: No Safety Features support found
[ 30.226572][ T160] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 30.245548][ T310] dwmac-sunxi 4500000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[ 30.252559][ T160] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 30.260130][ T344] healthd: battery none chg=
[ 30.275047][ T310] dwmac-sunxi 4500000.ethernet eth0: registered PTP clock
[ 30.286773][ T344] healthd: battery none chg=
[ 30.287964][ C0] sunxi:sunxi_mmc_host-4021000.sdmmc:[ERR]: smc 1 p1 err, cmd 11, RE !!
[ 30.291883][ T310] dwmac-sunxi 4500000.ethernet eth0: configuring for phy/rgmii link mode
[ 30.292309][ T344] healthd: battery none chg=
[ 30.292438][ T344] healthd: battery none chg=
[ 30.292564][ T344] healthd: battery none chg=
[ 30.292676][ T344] healthd: battery none chg=
[ 30.292784][ T344] healthd: battery none chg=
[ 30.300905][ T160] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 30.303531][ T160] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 30.310683][ T310] 8021q: adding VLAN 0 to HW filter on device eth0
[ 30.327762][ T160] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 30.413655][ T160] mmc1: queuing unknown CIS tuple 0x10 [07 00 11 00 8e] (5 bytes)
[ 30.427681][ T160] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 30.442190][ T160] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing LEGACY(SDR12) dt B
[ 30.456687][ T160] mmc1: queuing unknown CIS tuple 0x10 [07 00 31 00 32] (5 bytes)
[ 30.466396][ T160] mmc1: new SDIO card at address 96ec
[ 30.489266][ T1002] aicbsp: aicbsp_sdio_probe:2
[ 30.494361][ T1002] aicbsp: aicbsp_sdio_probe:2, matched chip: aic8800d
[ 30.501775][ T1002] aicbsp: aicbsp_sdio_probe after replace:1
[ 30.508193][ T1002] aicbsp: aicbsp_sdio_probe host max clock frequecy: 208000000
[ 30.516459][ T1002] aicbsp: aicwf_sdio_reg_init
[ 30.521609][ T1002] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: sdc set ios:clk 70000000Hz bm PP pm ON vdd 21 width 4 timing LEGACY(SDR12) dt B
[ 30.535990][ T1002] aicbsp: Set SDIO Clock 66 MHz
[ 30.543179][ T1002] aicbsp: aicbsp_8800d_fw_init, rev id: 0x7, subrev id: 0x20
[ 30.554646][ T1002] rwnx_request_firmware, name: fw_patch_table_u03.bin
[ 30.562083][ T1002] aicbt_patch_info_unpack bt patch version: - Jun 24 2024 21:01:47 - git 0bcba10
[ 30.572099][ T1002] aicbt_init no patch info found in bt fw
[ 30.578885][ T1002] rwnx_request_firmware, name: fw_adid_u03.bin
[ 30.587722][ T1002] rwnx_request_firmware, name: fw_patch_u03.bin
[ 30.610188][ T1002] aicbt_patch_table_load bt uart baud: 1500000, flowctrl: 1, lpm_enable: 1, tx_pwr: 24608, bt mode:255.
[ 30.655276][ T1002] rwnx_request_firmware, name: fmacfw.bin
[ 30.731715][ T1002] rwnx_request_firmware, name: fmacfw_patch.bin
[ 30.748002][ T1002] aicbsp: crypto data BBAD831C477E445AC3A462102C50D125
[ 30.755693][ T1002] aicbsp: verify data 52C1C402DC4E526F51C01D59442A8008
[ 30.764406][ T1002] aicsdio: aicwf_sdio_probe:1
[ 30.769617][ T1002] aicsdio: aicwf_sdio_reg_init
[ 30.775410][ T1002] sunxi:sunxi_mmc_host-4021000.sdmmc:[INFO]: sdc set ios:clk 70000000Hz bm PP pm ON vdd 21 width 4 timing LEGACY(SDR12) dt B
[ 30.790214][ T1002] aicsdio: Set SDIO Clock 66 MHz
[ 30.796167][ C7] aicbsp: err:<aicwf_sdio_bus_pwrctl,1257>: bus down
[ 30.806825][ T1002] aicbsp: aicbsp_resv_mem_alloc_skb, alloc resv_mem_txdata succuss, id: 0, size: 98304
[ 30.818886][ T1002] >>> rwnx_platform_init()
[ 30.824712][ T1002] >>> rwnx_cfg80211_init()
[ 30.829988][ T1002] rwnx_cfg80211_init sizeof(struct rwnx_hw):47616
[ 30.839359][ T1002] >>> rwnx_init_aic()
[ 30.843701][ T1002] >>> rwnx_cmd_mgr_init()
[ 30.852307][ T1002] tcp_ack_init
[ 30.856650][ T1002] >>> rwnx_send_set_stack_start_req()
[ 30.865250][ T1002] is 5g support = 1, vendor_info = 0x21
[ 30.871750][ T1002] Firmware Version: di Nov 14 2024 17:34:41 - g9aed4718
[ 30.871769][ T1002] >>> rwnx_platform_on()
[ 30.884313][ T1002] >>> rwnx_plat_fmac_load()
[ 30.889578][ T1002] userconfig file path:aic_userconfig.txt
[ 30.897883][ T1002] rwnx_plat_userconfig_parsing, enable = 1
[ 30.908928][ T1002] rwnx_plat_userconfig_parsing, dsss = 10
[ 30.915284][ T1002] rwnx_plat_userconfig_parsing, ofdmlowrate_2g4 = 11
[ 30.922595][ T1002] rwnx_plat_userconfig_parsing, ofdm64qam_2g4 = 10
[ 30.930072][ T1002] rwnx_plat_userconfig_parsing, ofdm256qam_2g4 = 10
[ 30.937650][ T1002] rwnx_plat_userconfig_parsing, ofdm1024qam_2g4 = 9
[ 30.945329][ T1002] rwnx_plat_userconfig_parsing, ofdmlowrate_5g = 11
[ 30.953537][ T1002] rwnx_plat_userconfig_parsing, ofdm64qam_5g = 10
[ 30.961230][ T1002] rwnx_plat_userconfig_parsing, ofdm256qam_5g = 10
[ 30.968681][ T1002] rwnx_plat_userconfig_parsing, ofdm1024qam_5g = 9
[ 30.977630][ T1002] rwnx_plat_userconfig_parsing, ofst_enable = 1
[ 30.984742][ T1002] rwnx_plat_userconfig_parsing, ofst_chan_1_4 = -5
[ 30.992222][ T1002] rwnx_plat_userconfig_parsing, ofst_chan_5_9 = -2
[ 31.002539][ T1002] rwnx_plat_userconfig_parsing, ofst_chan_10_13 = -2
[ 31.010779][ T1002] rwnx_plat_userconfig_parsing, ofst_chan_36_64 = -5
[ 31.018437][ T1002] rwnx_plat_userconfig_parsing, ofst_chan_100_120 = -6
[ 31.026217][ T1002] rwnx_plat_userconfig_parsing, ofst_chan_122_140 = -6
[ 31.033983][ T1002] rwnx_plat_userconfig_parsing, ofst_chan_142_165 = 4
[ 31.041585][ T1002] >>> rwnx_send_txpwr_idx_req()
[ 31.048236][ T1002] >>> rwnx_send_txpwr_ofst_req()
[ 31.054049][ T1002] >>> rwnx_send_rf_calib_req()
[ 31.390545][ T1002] get macaddr: 94:ff:6e:cd:1f:cc
[ 31.396015][ T1002] >>> rwnx_send_reset()
[ 31.401929][ T1002] >>> rwnx_send_version_req()
[ 31.407285][ T1002] >>> rwnx_set_vers()
[ 31.411583][ T1002] >>> rwnx_send_me_config_req()
[ 31.416835][ T1002] ieee80211 phy0: HT supp 1, VHT supp 1, HE supp 1
[ 31.424666][ T1002] >>> rwnx_send_me_chan_config_req()
[ 31.431003][ T1002] >>> rwnx_send_me_chan_config_req()
[ 31.437213][ T1002] >>> rwnx_dbgfs_register()
[ 31.442192][ T1002] rwnx_interface_add: wlan%d, 2, 10
[ 31.442226][ T1002] interface add:94 ff 6e cd 1f cc
[ 31.460241][ T1002] ieee80211 phy0: New interface create wlan0
[ 31.500677][ T1002] >>> rwnx_open()
[ 31.504653][ T1002] >>> rwnx_send_me_set_lp_level()
[ 31.510152][ T1002] rwnx_send_me_set_lp_level 1 1
[ 31.518129][ T1002] >>> rwnx_send_start()
[ 31.524513][ T1002] >>> rwnx_send_coex_req()
[ 31.529878][ T1002] rwnx_open rwnx_vif->drv_flags:4
[ 31.535501][ T1002] >>> rwnx_send_add_if()
[ 31.548562][ T229] type=1107 audit(1748526587.044:313): uid=0 auid=4294967295 ses=4294967295 subj=u:r:init:s0 msg='avc: denied { set } for property=vendor.wlan.firmware.version pid=1002 uid=1010 gid=1010 scontext=u:r:hal_wifi_default:s0 tcontext=u:object_r:vendor_default_prop:s0 tclass=property_service permissive=1'
[ 31.653165][ T1] init: starting service 'wpa_supplicant'...
[ 31.660385][ T1] init: Created socket '/dev/socket/wpa_wlan0', mode 660, user 1010, group 1010
[ 31.749168][ T1190] capability: warning: `wpa_supplicant' uses 32-bit capabilities (legacy support in use)
[ 31.920048][ T1190] rwnx_virtual_interface_add: 10, p2p-dev-wlan0
[ 31.926970][ T1190] rwnx_virtual_interface_add, ifname=p2p-dev-wlan0, wdev=00000000670e1c4a, vif_idx=1
[ 31.937393][ T1190] p2p dev addr=94 ff 6e cd 1f cd
[ 31.945929][ T1190] P2P interface started
[ 32.009541][ T1190] IOCTL PRIVATE
[ 32.013322][ T1190] android_priv_cmd: Android private cmd "COUNTRY CN" on wlan0
[ 32.021779][ T1190] wrong cmd:(null) in handle_private_cmd
[ 32.045484][ T1190] IOCTL PRIVATE
[ 32.049702][ T1190] android_priv_cmd: Android private cmd "SETSUSPENDMODE 1" on wlan0
[ 32.058898][ T1190] >>> rwnx_send_me_set_lp_level()
[ 32.064553][ T1190] rwnx_send_me_set_lp_level 1 0
[ 32.067369][ T229] type=1400 audit(1748526587.564:314): avc: granted { read } for comm="rkstack.process" name="psched" dev="proc" ino=4026531986 scontext=u:r:network_stack:s0 tcontext=u:object_r:proc_net:s0 tclass=file
[ 32.072791][ T1190] set suspend mode 1
[ 32.093242][ T229] type=1400 audit(1748526587.564:315): avc: granted { read open } for comm="rkstack.process" path="/proc/1204/net/psched" dev="proc" ino=4026531986 scontext=u:r:network_stack:s0 tcontext=u:object_r:proc_net:s0 tclass=file
[ 32.120002][ T229] type=1400 audit(1748526587.564:316): avc: granted { getattr } for comm="rkstack.process" path="/proc/1204/net/psched" dev="proc" ino=4026531986 scontext=u:r:network_stack:s0 tcontext=u:object_r:proc_net:s0 tclass=file
[ 33.059997][ T338] aicbt_set_power: start_block=1
[ 33.065431][ T338] aicbsp: aicbsp_set_subsys, subsys: AIC_BLUETOOTH, state to: 0
[ 33.074320][ T338] aicbsp: aicbsp_set_subsys, power state no need to change, current: 1
[ 33.083431][ T338] aicbt_set_power: end_block=1
[ 33.088950][ T338] aicbt_set_power: start_block=0
[ 33.094393][ T338] aicbsp: aicbsp_set_subsys, subsys: AIC_BLUETOOTH, state to: 1
[ 33.102957][ T338] aicbsp: aicbsp_set_subsys, power state no need to change, current: 1
[ 33.112201][ T338] aicbt_set_power: end_block=0
[ 33.127845][ T1002] >>> rwnx_close()
[ 33.131914][ T1002] aicwf_sdio mmc1:96ec:1 wlan0: CLOSE
[ 33.137906][ T8] >>> rwnx_cfg80211_del_key()
[ 33.138859][ T1002] >>> rwnx_send_remove_if()
[ 33.142993][ T8] >>> rwnx_send_key_del()
[ 33.145537][ T8] >>> rwnx_cfg80211_del_key()
[ 33.148618][ T1002] >>> rwnx_send_msg1()
[ 33.152573][ T8] >>> rwnx_send_key_del()
[ 33.153485][ T8] >>> rwnx_cfg80211_del_key()
[ 33.158626][ T1002] >>> rwnx_send_coex_req()
[ 33.163220][ T8] >>> rwnx_send_key_del()
[ 33.167525][ T1002] >>> rwnx_send_reset()
[ 33.172234][ T8] >>> rwnx_cfg80211_del_key()
[ 33.178309][ T1002] >>> rwnx_send_me_config_req()
[ 33.181730][ T8] >>> rwnx_send_key_del()
[ 33.185845][ T1002] ieee80211 phy0: HT supp 1, VHT supp 1, HE supp 1
[ 33.186282][ T1002] >>> rwnx_send_me_chan_config_req()
[ 33.191582][ T8] >>> rwnx_cfg80211_del_key()
[ 33.196765][ T1002] rwnx_close rwnx_vif->drv_flags:0
[ 33.201120][ T8] >>> rwnx_send_key_del()
[ 33.229682][ T8] >>> rwnx_cfg80211_del_key()
[ 33.234761][ T8] >>> rwnx_send_key_del()
[ 33.240302][ T1002] >>> rwnx_open()
[ 33.244215][ T1002] >>> rwnx_send_me_set_lp_level()
[ 33.249663][ T1002] rwnx_send_me_set_lp_level 1 1
[ 33.255483][ T1002] >>> rwnx_send_start()
[ 33.260675][ T1002] >>> rwnx_send_coex_req()
[ 33.265850][ T1002] rwnx_open rwnx_vif->drv_flags:4
[ 33.271416][ T1002] >>> rwnx_send_add_if()
[ 33.276561][ T160] >>> rwnx_send_me_chan_config_req()
[ 33.282716][ T160] >>> rwnx_send_me_chan_config_req()
[ 33.320559][ T338] [BT_LPM] bluesleep_get_uart_port: bluesleep_get_uart_port get uart_port from blusleep_uart_dev: 2501000.uart, port irq: 427
[ 33.368684][ T1190] IOCTL PRIVATE
[ 33.372412][ T1190] android_priv_cmd: Android private cmd "BTCOEXSCAN-STOP" on wlan0
[ 33.381074][ T1190] wrong cmd:(null) in handle_private_cmd
[ 33.387730][ T1190] IOCTL PRIVATE
[ 33.391588][ T1190] android_priv_cmd: Android private cmd "RXFILTER-STOP" on wlan0
[ 33.400173][ T1190] wrong cmd:(null) in handle_private_cmd
[ 33.406901][ T1190] IOCTL PRIVATE
[ 33.410622][ T1190] android_priv_cmd: Android private cmd "RXFILTER-ADD 2" on wlan0
[ 33.419192][ T1190] wrong cmd:(null) in handle_private_cmd
[ 33.425748][ T1190] IOCTL PRIVATE
[ 33.429483][ T1190] android_priv_cmd: Android private cmd "RXFILTER-START" on wlan0
[ 33.438041][ T1190] wrong cmd:(null) in handle_private_cmd
[ 33.444459][ T1190] IOCTL PRIVATE
[ 33.448179][ T1190] android_priv_cmd: Android private cmd "RXFILTER-STOP" on wlan0
[ 33.456642][ T1190] wrong cmd:(null) in handle_private_cmd
[ 33.463066][ T1190] IOCTL PRIVATE
[ 33.466800][ T1190] android_priv_cmd: Android private cmd "RXFILTER-ADD 3" on wlan0
[ 33.475373][ T1190] wrong cmd:(null) in handle_private_cmd
[ 33.481777][ T1190] IOCTL PRIVATE
[ 33.485498][ T1190] android_priv_cmd: Android private cmd "RXFILTER-START" on wlan0
[ 33.494062][ T1190] wrong cmd:(null) in handle_private_cmd
[ 33.500593][ T1190] IOCTL PRIVATE
[ 33.504314][ T1190] android_priv_cmd: Android private cmd "SETSUSPENDMODE 1" on wlan0
[ 33.513079][ T1190] >>> rwnx_send_me_set_lp_level()
[ 33.518526][ T1190] rwnx_send_me_set_lp_level 1 0
[ 33.524545][ T1190] set suspend mode 1
[ 33.579613][ T1190] IOCTL PRIVATE
[ 33.583365][ T1190] android_priv_cmd: Android private cmd "SETSUSPENDMODE 0" on wlan0
[ 33.592132][ T1190] >>> rwnx_send_me_set_lp_level()
[ 33.597578][ T1190] rwnx_send_me_set_lp_level 1 1
[ 33.603637][ T1190] set suspend mode 0
[ 34.132751][ T1] init: starting service 'idmap2d'...
[ 34.142467][ T1] init: Control message: Processed ctl.start for 'idmap2d' from pid: 450 (system_server)
[ 34.348171][ C7] [BT_LPM] bluesleep_rx_timer_expire: bluesleep_rx_timer_expire
[ 35.326899][ T1] init: processing action (sys.boot_completed=1) from (/system/etc/init/hw/init.rc:1193)
[ 35.339953][ T1] init: starting service 'exec 19 (/bin/rm -rf /data/per_boot)'...
[ 35.354540][ T1] init: SVC_EXEC service 'exec 19 (/bin/rm -rf /data/per_boot)' pid 1584 (uid 1000 gid 1000+0 context default) started; waiting...
[ 35.370880][ T1] init: Service 'exec 19 (/bin/rm -rf /data/per_boot)' (pid 1584) exited with status 0 waiting took 0.018000 seconds
[ 35.374592][ T500] >>> rwnx_cfg80211_scan()
[ 35.384489][ C7] [BT_LPM] bluesleep_rx_timer_expire: bluesleep_rx_timer_expire
[ 35.384773][ T1] init: Sending signal 9 to service 'exec 19 (/bin/rm -rf /data/per_boot)' (pid 1584) process group...
[ 35.389347][ T500] >>> rwnx_send_scanu_req()
[ 35.398294][ T1] libprocessgroup: Successfully killed process cgroup uid 1000 pid 1584 in 0ms
[ 35.426295][ T1] init: processing action (sys.boot_completed=1) from (/vendor/etc/init/hw/init.sun60iw2p1.rc:138)
[ 35.438798][ T1] init: Command 'insmod /vendor/lib/modules/kheaders.ko' action=sys.boot_completed=1 (/vendor/etc/init/hw/init.sun60iw2p1.rc:139) took 0ms and failed: open("/vendor/lib/modules/kheaders.ko") failed: No such file or directory
[ 35.754224][ T184] init (184): drop_caches: 3
[ 35.754822][ T344] healthd: battery none chg=
[ 35.788907][ T1] zram0: detected capacity change from 0 to 9060872
[ 35.846457][ T1] mkswap: Swapspace size: 4530432k, UUID=aa727031-8a5d-4aba-ae20-95608634a812
[ 35.858906][ T1] Adding 4530432k swap on /dev/block/zram0. Priority:-2 extents:1 across:4530432k SS
[ 35.893905][ T229] type=1400 audit(1748526591.392:317): avc: denied { entrypoint } for comm="init" path="/system/bin/fix_traceing" dev="dm-0" ino=8778258 scontext=u:r:shell:s0 tcontext=u:object_r:system_file:s0 tclass=file permissive=1
[ 35.955090][ T229] type=1400 audit(1748526591.452:318): avc: denied { dac_read_search } for comm="runin.sh" capability=2 scontext=u:r:shell:s0 tcontext=u:r:shell:s0 tclass=capability permissive=1
[ 35.989174][ T229] type=1400 audit(1748526591.484:319): avc: denied { search } for comm="treadahead" name="/" dev="mmcblk0p22" ino=2 scontext=u:r:vendor_init:s0 tcontext=u:object_r:unlabeled:s0 tclass=dir permissive=1
[ 35.989614][ T1658] treadahead: /treadahead/readahead_file_offset not exist;
[ 36.021142][ T1658] treadahead: go to read trace
[ 36.226833][ T344] healthd: battery none chg=
[ 36.233557][ T344] healthd: battery none chg=
[ 36.242210][ T184] get ctp_power is fail, -22
[ 36.247556][ T184] get ctp_power_ldo_vol is fail, -22
[ 36.255059][ T184] sunxi_ctp_startup: ctp_power_io is invalid.
[ 36.261894][ T184] get ctp_gesture_wakeup fail, no gesture wakeup
[ 36.270165][ T184] i2c 2-0040: supply ctp not found, using dummy regulator
[ 36.287139][ T344] healthd: battery none chg=
[ 36.318690][ T184] can not get fw from file gsl_firmware/gsl1680_7inch.bin
[ 36.328547][ T184] input: gslX680 as /devices/platform/soc@3000000/2512000.twi/i2c-2/2-0040/input/input3
[ 36.328604][ T344] healthd: battery none chg=
[ 36.344913][ T344] healthd: battery none chg=
[ 36.346238][ T184] ERROR! get hall_para failed, func:switch_init, line:236
[ 36.350540][ T344] healthd: battery none chg=
[ 36.363209][ T344] healthd: battery none chg=
[ 36.363377][ T229] type=1400 audit(1748526591.860:320): avc: denied { read } for comm="InputReader" name="u:object_r:vendor_awdisplayoutput_prop:s0" dev="tmpfs" ino=301 scontext=u:r:system_server:s0 tcontext=u:object_r:vendor_awdisplayoutput_prop:s0 tclass=file permissive=1
[ 36.371924][ T344] healthd: battery none chg=
[ 36.397127][ T229] type=1400 audit(1748526591.860:321): avc: denied { open } for comm="InputReader" path="/dev/__properties__/u:object_r:vendor_awdisplayoutput_prop:s0" dev="tmpfs" ino=301 scontext=u:r:system_server:s0 tcontext=u:object_r:vendor_awdisplayoutput_prop:s0 tclass=file permissive=1
[ 36.400495][ C7] [BT_LPM] bluesleep_rx_timer_expire: bluesleep_rx_timer_expire
[ 36.404502][ T344] healthd: battery none chg=
[ 36.431874][ T229] type=1400 audit(1748526591.860:322): avc: denied { getattr } for comm="InputReader" path="/dev/__properties__/u:object_r:vendor_awdisplayoutput_prop:s0" dev="tmpfs" ino=301 scontext=u:r:system_server:s0 tcontext=u:object_r:vendor_awdisplayoutput_prop:s0 tclass=file permissive=1
[ 36.553997][ T1104] >>> rwnx_rx_scanu_start_cfm()
[ 36.575575][ T229] type=1400 audit(1748526592.072:324): avc: denied { write } for comm="HwBinder:346_2" name="property_service" dev="tmpfs" ino=335 scontext=u:r:mediacodec:s0 tcontext=u:object_r:property_socket:s0 tclass=sock_file permissive=1
[ 36.600890][ T229] type=1400 audit(1748526592.072:325): avc: denied { connectto } for comm="HwBinder:346_2" path="/dev/socket/property_service" scontext=u:r:mediacodec:s0 tcontext=u:r:init:s0 tclass=unix_stream_socket permissive=1
[ 36.624583][ T229] type=1107 audit(1748526592.072:326): uid=0 auid=4294967295 ses=4294967295 subj=u:r:init:s0 msg='avc: denied { set } for property=vendor.display.codec2_aisr_process pid=346 uid=1046 gid=1006 scontext=u:r:mediacodec:s0 tcontext=u:object_r:vendor_default_prop:s0 tclass=property_service permissive=1'
[ 36.849265][ T1450] [BT_LPM] bluesleep_tx_allow_sleep: Tx has been idle
[ 36.964510][ T1919] audit_log_lost: 503 callbacks suppressed
[ 36.964516][ T1919] audit: audit_lost=172 audit_rate_limit=5 audit_backlog_limit=64
[ 36.967844][ T229] type=1400 audit(1748526592.460:327): avc: denied { setattr } for comm="chmod" name="/" dev="tracefs" ino=1 scontext=u:r:shell:s0 tcontext=u:object_r:debugfs_tracing_debug:s0 tclass=dir permissive=1
[ 36.971757][ T1919] audit: rate limit exceeded
[ 37.158118][ T1309] BOOTEVENT: 37158.117399: OFF
[ 37.369794][ T338] [BT_LPM] bluesleep_outgoing_data: tx was sleeping, wakeup it
[ 37.417090][ T229] type=1400 audit(1748526592.916:330): avc: denied { read } for comm="binder:254_2" name="event_count" dev="sysfs" ino=46443 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[ 37.447404][ T229] type=1400 audit(1748526592.916:331): avc: denied { open } for comm="binder:254_2" path="/sys/devices/platform/soc@3000000/7083000.twi/i2c-13/13-004e/wakeup/wakeup12/event_count" dev="sysfs" ino=46443 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[ 37.477822][ T229] type=1400 audit(1748526592.916:332): avc: denied { getattr } for comm="binder:254_2" path="/sys/devices/platform/soc@3000000/7083000.twi/i2c-13/13-004e/wakeup/wakeup12/event_count" dev="sysfs" ino=46443 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[ 37.636006][ T229] type=1400 audit(1748526593.132:333): avc: denied { search } for comm="android.hardwar" name="1" dev="proc" ino=30 scontext=u:r:hal_power_default:s0 tcontext=u:r:init:s0 tclass=dir permissive=1
[ 37.657750][ T229] type=1400 audit(1748526593.132:334): avc: denied { read } for comm="android.hardwar" name="cmdline" dev="proc" ino=23769 scontext=u:r:hal_power_default:s0 tcontext=u:r:init:s0 tclass=file permissive=1
[ 37.868174][ C1] [BT_LPM] bluesleep_rx_timer_expire: bluesleep_rx_timer_expire
[ 38.027515][ T1658] treadahead: getpartitiondev /system= 254:0
[ 38.036843][ T1658] treadahead: getpartitiondev /product= 254:2
[ 38.045477][ T1658] treadahead: getpartitiondev /vendor= 254:1
[ 38.053325][ T1658] treadahead: getpartitiondev /vendor_dlkm= 254:3
[ 38.092516][ T1658] audit: audit_lost=277 audit_rate_limit=5 audit_backlog_limit=64
[ 38.101804][ T1658] audit: rate limit exceeded
[ 38.108677][ T1658] treadahead: begain fgets_alloc ======== 254:0 254:2
[ 38.892175][ C1] [BT_LPM] bluesleep_rx_timer_expire: bluesleep_rx_timer_expire
[ 39.916177][ C1] [BT_LPM] bluesleep_rx_timer_expire: bluesleep_rx_timer_expire
[ 40.401219][ T1450] [BT_LPM] bluesleep_tx_allow_sleep: Tx has been idle
[ 41.420174][ C5] [BT_LPM] bluesleep_rx_timer_expire: bluesleep_rx_timer_expire
[ 41.435573][ T79] [BT_LPM] bluesleep_sleep_work: going to sleep...
[ 42.390131][ T1658] treadahead: treadahead read-trace over 327701 345525
[ 42.505827][ T1] init: starting service 'vendor.drm-clearkey-service'...
[ 42.518906][ T1] init: Control message: Processed ctl.interface_start for 'aidl/android.hardware.drm.IDrmFactory/clearkey' from pid: 214 (/system/bin/servicemanager)
[ 42.565481][ T1] init: starting service 'vendor.drm-widevine-hal'...
[ 42.579417][ T1] init: Control message: Processed ctl.interface_start for 'aidl/android.hardware.drm.IDrmFactory/widevine' from pid: 214 (/system/bin/servicemanager)
[ 42.733367][ T1658] treadahead: treadahead write trace end
[ 42.990365][ T1] init: processing action (persist.service.dragon.start=1) from (/system/etc/init/dragonservice.rc:1)
[ 43.004493][ T1] init: starting service 'dragonservice'...
[ 43.104392][ T1] init: processing action (persist.service.dragon.start=0) from (/system/etc/init/dragonservice.rc:4)
[ 43.116584][ T1] init: Sending signal 9 to service 'dragonservice' (pid 2469) process group...
[ 43.132631][ T1] libprocessgroup: Successfully killed process cgroup uid 0 pid 2469 in 5ms
[ 43.143970][ T1] init: Service 'dragonservice' (pid 2469) received signal 9
[ 51.168801][ T1658] treadahead: read trace end
[ 51.476065][ T1658] treadahead: begin match traceinfo
[ 51.483300][ T229] type=1400 audit(1748526606.980:443): avc: denied { search } for comm="treadahead" name="/" dev="mmcblk0p22" ino=2 scontext=u:r:vendor_init:s0 tcontext=u:object_r:unlabeled:s0 tclass=dir permissive=1
[ 51.505850][ T229] type=1400 audit(1748526606.980:444): avc: denied { write } for comm="treadahead" name="/" dev="mmcblk0p22" ino=2 scontext=u:r:vendor_init:s0 tcontext=u:object_r:unlabeled:s0 tclass=dir permissive=1
[ 51.529592][ T229] type=1400 audit(1748526606.980:445): avc: denied { add_name } for comm="treadahead" name="readahead_file_offset" scontext=u:r:vendor_init:s0 tcontext=u:object_r:unlabeled:s0 tclass=dir permissive=1
[ 51.551336][ T229] type=1400 audit(1748526606.980:446): avc: denied { create } for comm="treadahead" name="readahead_file_offset" scontext=u:r:vendor_init:s0 tcontext=u:object_r:unlabeled:s0 tclass=file permissive=1
[ 51.573015][ T229] type=1400 audit(1748526606.980:447): avc: denied { read write open } for comm="treadahead" path="/treadahead/readahead_file_offset" dev="mmcblk0p22" ino=15 scontext=u:r:vendor_init:s0 tcontext=u:object_r:unlabeled:s0 tclass=file permissive=1
[ 51.602351][ T1] init: Service 'vendor.drm-clearkey-service' (pid 2434) exited with status 0 oneshot service took 9.086000 seconds in background
[ 51.617399][ T1] init: Sending signal 9 to service 'vendor.drm-clearkey-service' (pid 2434) process group...
[ 51.629259][ T1] libprocessgroup: Successfully killed process cgroup uid 1013 pid 2434 in 0ms
[ 51.652328][ T1] init: Service 'vendor.drm-widevine-hal' (pid 2437) exited with status 0 oneshot service took 9.077000 seconds in background
[ 51.667180][ T1] init: Sending signal 9 to service 'vendor.drm-widevine-hal' (pid 2437) process group...
[ 51.678647][ T1] libprocessgroup: Successfully killed process cgroup uid 1013 pid 2437 in 0ms
[ 51.948662][ T1658] audit: audit_lost=282 audit_rate_limit=5 audit_backlog_limit=64
[ 51.957280][ T1658] audit: rate limit exceeded
[ 52.019280][ T1658] treadahead: trace readahead complete
[ 52.019840][ T1] init: processing action (persist.device_config.runtime_native_boot.iorap_perfetto_enable=true && persist.sys.without.treadahead=1 && ro.iorapd.enable=true) from (/system/etc/init/iorapd.rc:34)
[ 52.047472][ T1] init: starting service 'iorapd'...
[ 52.060493][ T1] init: Service 'treadahead_trace' (pid 1658) exited with status 0 oneshot service took 16.128000 seconds in background
[ 52.074782][ T1] init: Sending signal 9 to service 'treadahead_trace' (pid 1658) process group...
[ 55.383165][ T500] >>> rwnx_cfg80211_scan()
[ 55.388008][ T500] >>> rwnx_send_scanu_req()
[ 56.542667][ T1104] >>> rwnx_rx_scanu_start_cfm()
console:/ $
console:/ $
console:/ $
烧录自己编译的固件,出现:
[225]HELLO! BOOT0 is starting!
[228]BOOT0 commit : {cfda5fbe}
[237]volume key pressed!
[240][mmc]: mmc driver ver 2024-03-20 10:36
[250][mmc]: Wrong media type 0x0, but host sdc2, try mmc first
[256][mmc]: ***Try MMC card 2***
[278][mmc]: RMCA OK!
[284][mmc]: MMC 5.1
[286][mmc]: HSSDR52/SDR25 8 bit
[289][mmc]: 50000000 Hz
[292][mmc]: 29880 MB
[294][mmc]: ***SD/MMC 2 init OK!!!***
[299]DRAM BOOT DRIVE INFO: V0.599
[304]DRAM_VCC set to 560 mv
[307]DRAM CLK =1800 MHZ
[309]DRAM Type =9 (8:LPDDR4,9:LPDDR5)
[435]Training result is = 7
[438]DRAM Pstate 0 training, frequency is 1800 Mhz
[447]Actual DRAM SIZE =6144 M
[449]DRAM SIZE =6144 MBytes, para1 = a10a, para2 = 18001001, dram_tpr13 = 10061
[464]DRAM simple test OK.
[505]error: dtb not found for scp
[510]tunning data addr:0x4a0003e8
[513]Jump to ATF: monitor_base = 0x48000000, uboot_base = 0x4a000000, optee_base = 0x0
NOTICE: BL31: OP-TEE 32bit detected
NOTICE: BL31: U-BOOT 32bit detected
NOTICE: BL31: v2.5(debug):eec78cd3c
NOTICE: BL31: Built : 14:02:13, Oct 29 2024
NOTICE: hardware check error1
BACKTRACE: START: bl31_platform_setup
0: EL3: 0x48003c9c
1: EL3: 0x4800407c
2: EL3: 0x48003f78
3: EL3: 0x480001f0
BACKTRACE: END: bl31_platform_setup
PANIC in EL3.
x30 = 0x0000000048004088
x0 = 0x0000000002500000
x1 = 0x0000000000000060
x2 = 0x0000000000000060
x3 = 0x00000000ffffffc8
x4 = 0x0000000000000034
x5 = 0x0000000000000034
x6 = 0x0000000000000004
x7 = 0x0000000000000000
x8 = 0x000000023fffffff
x9 = 0x0000000048013000
x10 = 0x0000000000000000
x11 = 0x0000000000000000
x12 = 0x0000000000000010
x13 = 0x0000000000000000
x14 = 0x0000000000000000
x15 = 0x0000000000000000
x16 = 0x0000000000000000
x17 = 0x0000000000048c00
x18 = 0x0000000000000020
x19 = 0x000000004800f4b4
x20 = 0x0000000000000000
x21 = 0x0000000000001903
x22 = 0x0000000000000000
x23 = 0x0000000000000000
x24 = 0x0000000000000000
x25 = 0x0000000000000000
x26 = 0x0000000000000000
x27 = 0x0000000000000000
x28 = 0x0000000000000000
x29 = 0x0000000048014280
scr_el3 = 0x0000000000000238
sctlr_el3 = 0x0000000030cd183f
cptr_el3 = 0x0000000000000000
tcr_el3 = 0x000000008081351e
daif = 0x00000000000002c0
mair_el3 = 0x00000000004404ff
spsr_el3 = 0x00000000000001cd
elr_el3 = 0x0000000000000000
ttbr0_el3 = 0x0000000048041001
esr_el3 = 0x0000000000000000
far_el3 = 0x0000000000000000
spsr_el1 = 0x00000000000001cd
elr_el1 = 0x0000000000000000
spsr_abt = 0x00000000400bfc0e
spsr_und = 0x00000000f08378cd
spsr_irq = 0x0000000034037e06
spsr_fiq = 0x0000000030077c14
sctlr_el1 = 0x0000000000c50838
actlr_el1 = 0x0000000000000000
cpacr_el1 = 0x0000000000000000
csselr_el1 = 0x0000000000000000
sp_el1 = 0x0000000000000000
esr_el1 = 0x00000000000c0000
ttbr0_el1 = 0x000000003a3f7f7c
ttbr1_el1 = 0x000000080c7f7f7c
mair_el1 = 0x44e048e000098aa4
amair_el1 = 0x0000000000000000
tcr_el1 = 0x0000000000000000
tpidr_el1 = 0x7f3fff00fdff7f00
tpidr_el0 = 0x7f007f8000ff0800
tpidrro_el0 = 0x00000000ff0c0080
par_el1 = 0xff00000048000980
mpidr_el1 = 0x0000000081000000
afsr0_el1 = 0x0000000000000000
afsr1_el1 = 0x0000000000000000
contextidr_el1 = 0x0000000000000000
vbar_el1 = 0x0000000000000000
cntp_ctl_el0 = 0x0000000000000000
cntp_cval_el0 = 0xf6de00005fffeeee
cntv_ctl_el0 = 0x0000000000000000
cntv_cval_el0 = 0xffde00005fffffef
cntkctl_el1 = 0x0000000000000000
sp_el0 = 0x0000000048014280
isr_el1 = 0x0000000000000000
cpuectlr_el1 = 0x000000002808bc00
icc_hppir0_el1 = 0x00000000000003ff
icc_hppir1_el1 = 0x00000000000003ff
icc_ctlr_el3 = 0x0000000000028400
gicd_ispendr regs (Offsets 0x200-0x278)
Offset Value
0x200: 0x0000000000000000
0x208: 0x0000000000000000
0x210: 0x0000000000000000
0x218: 0x0000000000000000
0x220: 0x0000000000000000
0x228: 0x0000000000000000
0x230: 0x0000000000000000
0x238: 0x0000000000000000
0x240: 0x0000000000000000
0x248: 0x0000000000000000
0x250: 0x0000000000000000
0x258: 0x0000000000000000
0x260: 0x0000000000000000
0x268: 0x0000000000000000
0x270: 0x0000000000000000
0x278: 0x0000000000000000
不勾选任何选项刷出厂固件,可以正常启动。
找到一个相关的问题,但是我的这个和命令长度没有关系:
【FAQ3027】 SDK所在目录路径过长引发固件异常无法启动.pdf
1.主题
SDK所在目录路径过长引发固件异常无法启动2.问题背景
有客户反馈,sdk按如下目录放置,编译出的固件烧写后无法启动,错误如下:/ibm/ExdroidData/workspace/mynewroot/jenkins/code/dailybuild/androidv/platform/android14
[2024-07-07 01:11:06.834698] [387]phy_dfs_clk3 = 150M [2024-07-07 01:11:06.837708] [390]phy_dfs_clk0 = 1200M [2024-07-07 01:11:06.841707] [392]DRAM MDFS VERSION INFO: V0.660 [2024-07-07 01:11:06.844748] [396]DRAM MDFS time =38136 ns [2024-07-07 01:11:06.851745] [399]DRAM SIZE =4096 MBytes, para1 = 310a, para2 = 10001000, tpr13 = 6065 [2024-07-07 01:11:06.855749] [407]DRAM simple test OK. [2024-07-07 01:11:06.857749] [410]dram size =4096 [2024-07-07 01:11:06.859749] [412]nsi init 2023-2-23 [2024-07-07 01:11:06.911773] [462]read toc1 from emmc 32800 sector [2024-07-07 01:11:06.915730] [467]don't have rotpk, skip check [2024-07-07 01:11:06.917719] [470]OLD version: 0.0 [2024-07-07 01:11:06.919729] [472]NEW version: 0.0 [2024-07-07 01:11:07.031703] [583]monitor entry=0x48000000 [2024-07-07 01:11:07.033702] [585]uboot entry=0x4a000000 [2024-07-07 01:11:07.036642] [588]optee entry=0x48600000 [2024-07-07 01:11:07.038641] [591]opensbi entry=0x0 [2024-07-07 01:11:07.040638] [593]no need rotpk flag [2024-07-07 01:11:07.044622] [595]tunning data addr:0x4a0003e8 [2024-07-07 01:11:07.049625] [599]sec_mem_map[0]: addr = 0x48000000, size = 0x100000 [2024-07-07 01:11:07.055622] [604]sec_mem_map[1]: addr = 0x48600000, size = 0x100000 [2024-07-07 01:11:07.057653] [610]run out of boot0 [2024-07-07 01:11:07.067667] NOTICE: BL31: v2.5(debug):55b180a27 [2024-07-07 01:11:07.071665] NOTICE: BL31: Built : 11:09:52, Sep 18 2023 [2024-07-07 01:11:07.074610] NOTICE: hardware check error1 [2024-07-07 01:11:07.077657] BACKTRACE: START: bl31_platform_setup [2024-07-07 01:11:07.079655] 0: EL3: 0x480038a4 [2024-07-07 01:11:07.081653] 1: EL3: 0x48003b40 [2024-07-07 01:11:07.083616] 2: EL3: 0x48003a94 [2024-07-07 01:11:07.085619] 3: EL3: 0x480001e0 [2024-07-07 01:11:07.088622] BACKTRACE: END: bl31_platform_setup [2024-07-07 01:11:07.089654] PANIC in EL3. [2024-07-07 01:11:07.093608] x30 = 0x0000000048003b4c [2024-07-07 01:11:07.096654] x0 = 0x0000000002500000 [2024-07-07 01:11:07.100609] x1 = 0x0000000000000060 [2024-07-07 01:11:07.103654] x2 = 0x0000000000000060 [2024-07-07 01:11:07.106609] x3 = 0x00000000ffffffc8 [2024-07-07 01:11:07.110608] x4 = 0x0000000000000034 [2024-07-07 01:11:07.113667] x5 = 0x0000000000000034 [2024-07-07 01:11:07.116619] x6 = 0x0000000000000004 [2024-07-07 01:11:07.120606] x7 = 0x0000000000000000 [2024-07-07 01:11:07.123654] x8 = 0x000000023fffffff [2024-07-07 01:11:07.126603] x9 = 0x0000000048600000 [2024-07-07 01:11:07.130611] x10 = 0x0000000000000000 [2024-07-07 01:11:07.133654] x11 = 0x0000000000100000 [2024-07-07 01:11:07.137665] x12 = 0x0000000000000018 [2024-07-07 01:11:07.140618] x13 = 0x0000000000000000 [2024-07-07 01:11:07.143658] x14 = 0x0000000000000000 [2024-07-07 01:11:07.147657] x15 = 0x0000000000000000 [2024-07-07 01:11:07.150611] x16 = 0x0000000000000000 [2024-07-07 01:11:07.153651] x17 = 0x0000000000045400 [2024-07-07 01:11:07.157653] x18 = 0x0000000000000020 [2024-07-07 01:11:07.168273] x19 = 0x000000004800e3f6 [2024-07-07 01:11:07.168345] x20 = 0x0000000000000000 [2024-07-07 01:11:07.168360] x21 = 0x0000000000001890 [2024-07-07 01:11:07.170569] x22 = 0x0000000000000000 [2024-07-07 01:11:07.173624] x23 = 0x0000000000000000 [2024-07-07 01:11:07.177663] x24 = 0x0000000000000000 [2024-07-07 01:11:07.180668] x25 = 0x0000000000000000 [2024-07-07 01:11:07.184671] x26 = 0x0000000000000000 [2024-07-07 01:11:07.187621] x27 = 0x0000000000000000 [2024-07-07 01:11:07.190672] x28 = 0x0000000000000000 [2024-07-07 01:11:07.194658] x29 = 0x00000000480112c0 [2024-07-07 01:11:07.197625] scr_el3 = 0x0000000000000238 [2024-07-07 01:11:07.200677] sctlr_el3 = 0x0000000030cd183f [2024-07-07 01:11:07.204676] cptr_el3 = 0x0000000000000000 [2024-07-07 01:11:07.207626] tcr_el3 = 0x000000008081351e [2024-07-07 01:11:07.211638] daif = 0x00000000000002c0 [2024-07-07 01:11:07.214678] mair_el3 = 0x00000000004404ff [2024-07-07 01:11:07.217635] spsr_el3 = 0x00000000000001cd [2024-07-07 01:11:07.221632] elr_el3 = 0x0000000000012ea4 [2024-07-07 01:11:07.224661] ttbr0_el3 = 0x000000004803e381 [2024-07-07 01:11:07.227617] esr_el3 = 0x00000000b2050b37 [2024-07-07 01:11:07.231620] far_el3 = 0x5ad7c3dbfffe3ff9 [2024-07-07 01:11:07.234664] spsr_el1 = 0x00000000000001cd [2024-07-07 01:11:07.238658] elr_el1 = 0x0000000000000000 [2024-07-07 01:11:07.241683] spsr_abt = 0x00000000f01f28b9 [2024-07-07 01:11:07.244659] spsr_und = 0x00000000f0478217 [2024-07-07 01:11:07.248612] spsr_irq = 0x00000000f00b8ebd [2024-07-07 01:11:07.251658] spsr_fiq = 0x00000000f40f6460 [2024-07-07 01:11:07.254613] sctlr_el1 = 0x0000000000c50838 [2024-07-07 01:11:07.258618] actlr_el1 = 0x0000000000000000 [2024-07-07 01:11:07.261660] cpacr_el1 = 0x0000000000000000 [2024-07-07 01:11:07.265661] csselr_el1 = 0x0000000000000000 [2024-07-07 01:11:07.268613] sp_el1 = 0x0000000000000000 [2024-07-07 01:11:07.271659] esr_el1 = 0x00000000b4897f9c [2024-07-07 01:11:07.274616] ttbr0_el1 = 0x0000f63708ac0ce2 [2024-07-07 01:11:07.278663] ttbr1_el1 = 0x00000bfc5c0958d0 [2024-07-07 01:11:07.281624] mair_el1 = 0x44e048e000098aa4 [2024-07-07 01:11:07.285628] amair_el1 = 0x0000000000000000 [2024-07-07 01:11:07.288657] tcr_el1 = 0x0000000000000000 [2024-07-07 01:11:07.291610] tpidr_el1 = 0x3a0c50eb9150e67b [2024-07-07 01:11:07.295614] tpidr_el0 = 0xdc178f81ebf9d7ff [2024-07-07 01:11:07.298664] tpidrro_el0 = 0xfb10d70cdeff6571 [2024-07-07 01:11:07.301621] par_el1 = 0xff00000048000980 [2024-07-07 01:11:07.305628] mpidr_el1 = 0x0000000081000000 [2024-07-07 01:11:07.308625] afsr0_el1 = 0x0000000000000000 [2024-07-07 01:11:07.312624] afsr1_el1 = 0x0000000000000000 [2024-07-07 01:11:07.315625] contextidr_el1 = 0x0000000000000000 [2024-07-07 01:11:07.318667] vbar_el1 = 0x0000000000000000 [2024-07-07 01:11:07.322622] cntp_ctl_el0 = 0x0000000000000000 [2024-07-07 01:11:07.325666] cntp_cval_el0 = 0xff5f39fefd2bd7ce [2024-07-07 01:11:07.328614] cntv_ctl_el0 = 0x0000000000000000 [2024-07-07 01:11:07.332623] cntv_cval_el0 = 0xd7f5971ac72c673d [2024-07-07 01:11:07.335660] cntkctl_el1 = 0x0000000000000000 [2024-07-07 01:11:07.338663] sp_el0 = 0x00000000480112c0 [2024-07-07 01:11:07.342662] isr_el1 = 0x0000000000000000 [2024-07-07 01:11:07.345612] dacr32_el2 = 0x0000000000000000 [2024-07-07 01:11:07.348657] ifsr32_el2 = 0x0000000000000217 [2024-07-07 01:11:07.352666] cpuectlr_el1 = 0x000000002808bc00 [2024-07-07 01:11:07.355622] icc_hppir0_el1 = 0x00000000000003ff [2024-07-07 01:11:07.359625] icc_hppir1_el1 = 0x00000000000003ff [2024-07-07 01:11:07.362686] icc_ctlr_el3 = 0x0000000000028400 [2024-07-07 01:11:07.366678] gicd_ispendr regs (Offsets 0x200-0x278) [2024-07-07 01:11:07.367626] Offset Value [2024-07-07 01:11:07.370673] 0x200: 0x0000000000000000 [2024-07-07 01:11:07.373673] 0x208: 0x0000000000000000 [2024-07-07 01:11:07.375675] 0x210: 0x0000000000000000 [2024-07-07 01:11:07.378592] 0x218: 0x0000000000000000 [2024-07-07 01:11:07.380634] 0x220: 0x0000000000000000 [2024-07-07 01:11:07.383664] 0x228: 0x0000000000000000 [2024-07-07 01:11:07.386613] 0x230: 0x0000000000000000 [2024-07-07 01:11:07.388617] 0x238: 0x0000000000000000 [2024-07-07 01:11:07.391612] 0x240: 0x0000000000000000 [2024-07-07 01:11:07.394648] 0x248: 0x0000000000000000 [2024-07-07 01:11:07.396647] 0x250: 0x0000000000000000 [2024-07-07 01:11:07.399601] 0x258: 0x0000000000000000 [2024-07-07 01:11:07.401601] 0x260: 0x0000000000000000 [2024-07-07 01:11:07.404653] 0x268: 0x0000000000000000 [2024-07-07 01:11:07.407609] 0x270: 0x0000000000000000 [2024-07-07 01:11:07.409613] 0x278: 0x0000000000000000
3.原因分析
当前编译工具对路径长度有要求。如果longan所在的路径过长,会引起编译时image异常。当前所支持的bsp的绝对路径长度为83个字符,如android sdk,则为包含longan目录时的长度,如:/ibm/ExdroidData/workspace/mynewroot/jenkins/code/dailybuild/androidv/platform/android14/longan
长度以及超过83字符限制。4.解决措施
缩短sdk所在目录长度。
现在基本确定了,就是打包工具导致 boot0_*.fex 几个文件并没有更新成功
折腾半小时,修改 longan/build/pack 脚本,从正常的img提取出来的boot0_*.fex 复制到 longan/out/a733/demo_aiot/pack_out/ 目录,
然后强制 boot0_*.fex 不更新
longan/build/pack 修改前:
#!/bin/bash
# pack/pack
# (c) Copyright 2013
# Allwinner Technology Co., Ltd. <www.allwinnertech.com>
# James Deng <csjamesdeng@allwinnertech.com>
# This program is free software; you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# (at your option) any later version.
############################ Notice #####################################
# a. Some config files priority is as follows:
# - xxx_${platform}.{cfg|fex} > xxx.{cfg|fex}
# - ${chip}/${board}/*.{cfg|fex} > ${chip}/default/*.{cfg|fex}
# - ${chip}/default/*.cfg > ${LICHEE_COMMON_CONFIG_DIR}/imagecfg/*.cfg
# - ${chip}/default/*.fex > ${LICHEE_COMMON_CONFIG_DIR}/partition/*.fex
# e.g. sun8iw7p1/configs/perf/image_linux.cfg > sun8iw7p1/configs/default/image_linux.cfg
# > ${LICHEE_COMMON_CONFIG_DIR}/imagecfg/image_linux.cfg > sun8iw7p1/configs/perf/image.cfg
# > sun8iw7p1/configs/default/image.cfg > ${LICHEE_COMMON_CONFIG_DIR}/imagecfg/image.cfg
# b. Support Nor storages rule:
# - Need to create sys_partition_nor.fex or sys_partition_nor_${platform}.fex
# - Add "{filename = "full_img.fex", maintype = "12345678", \
# subtype = "FULLIMG_00000000",}" to image[_${platform}].cfg
# c. Switch uart port
# - Need to add your chip configs into ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_pin
# - Call pack with 'debug' parameters
#if you want to debug pack, set vlaue to 1. use pause func in the place where you want to stop
enable_pause=0
function get_char()
SAVEDSTTY=`stty -g`
stty -echo
stty cbreak
dd if=/dev/tty bs=1 count=1 2> /dev/null
stty -raw
stty echo
stty $SAVEDSTTY
function pause()
if [ "x$1" != "x" ] ;then
echo "$1"
fi
if [ $enable_pause -eq 1 ] ; then
echo "Press any key to continue!"
char=`get_char`
fi
function pack_error()
echo -e "\033[47;31mERROR: $*\033[0m"
function pack_warn()
echo -e "\033[47;34mWARN: $*\033[0m"
function pack_info()
echo -e "\033[47;30mINFO: $*\033[0m"
localpath=$(cd $(dirname $0) && pwd)
. $localpath/shflags
# define option, format:
# 'long option' 'default value' 'help message' 'short option'
DEFINE_string 'chip' '' 'chip to build, e.g. sun7i' 'c'
DEFINE_string 'ic' '' 'ic to build, e.g. a50' 'i'
DEFINE_string 'addition' '' 'additional config files, e.g. xx.fex' 'a'
DEFINE_string 'platform' '' 'platform to build, e.g. linux, android' 'p'
DEFINE_string 'platform_version' '' 'platform version to build' 'V'
DEFINE_string 'board' '' 'board to build, e.g. evb' 'b'
DEFINE_string 'kernel' '' 'kernel to build, e.g. linux-3.4, linux-3.10' 'k'
DEFINE_string 'debug_mode' 'uart0' 'config debug mode, e.g. uart0, card0' 'd'
DEFINE_string 'signture' 'none' 'pack boot signture to do secure boot' 's'
DEFINE_string 'secure' 'none' 'pack secure boot with -v arg' 'v'
DEFINE_string 'mode' 'normal' 'pack dump firmware' 'm'
DEFINE_string 'function' 'android' 'pack private firmware' 'f'
DEFINE_string 'vsp' '' 'pack firmware for vsp' 't'
DEFINE_string 'programmer' '' 'creat programmer img or not' 'w'
DEFINE_string 'key_path' '' 'the path of keys' 'P'
DEFINE_string 'nor' 'none' 'pack nor image' 'n'
DEFINE_boolean 'verity' false 'if enable dm-verity' ''
DEFINE_boolean 'signfel' false 'if enable fel signing' ''
DEFINE_string 'boot_path' '' 'the path of gki boot.img' 'B'
DEFINE_string 'output_resources' '' 'only output resources to pack-out' ''
DEFINE_string 'from_resources' '' 'pack from resources path' ''
# parse the command-line
FLAGS "$@" || exit $?
eval set -- "${FLAGS_ARGV}"
PACK_CHIP=${FLAGS_chip}
PACK_IC=${FLAGS_ic}
PACK_PLATFORM=${FLAGS_platform}
PACK_PLATFORM_VERSION=${FLAGS_platform_version}
PACK_BOARD=${FLAGS_board}
PACK_KERN=${FLAGS_kernel}
PACK_DEBUG=${FLAGS_debug_mode}
PACK_SIG=${FLAGS_signture}
PACK_SECURE=${FLAGS_secure}
PACK_MODE=${FLAGS_mode}
PACK_FUNC=${FLAGS_function}
PACK_VSP=${FLAGS_vsp}
PACK_PROGRAMMER=${FLAGS_programmer}
PACK_NOR=${FLAGS_nor}
PACK_PRODUCT=${FLAGS_product}
PACK_VERITY=${FLAGS_verity}
PACK_SIGNFEL=${FLAGS_signfel}
PACK_ADD_FILES=(${FLAGS_addition})
PACK_KEY_PATH=${FLAGS_key_path}
PACK_BOOT_PATH=${FLAGS_boot_path}
CFG_TOP_DIR=$(cd $localpath/../ && pwd)
CFG_PLAT_OUT=$CFG_TOP_DIR/out/$PACK_IC/$PACK_BOARD/$PACK_PLATFORM
CFG_KEY_DIR=$CFG_TOP_DIR/out/$PACK_IC/common/keys
if [ ! -z "${PACK_KEY_PATH}" ]; then
CFG_KEY_DIR=${PACK_KEY_PATH}
fi
pack_info "${CFG_KEY_DIR}"
if [ ! -d ${CFG_PLAT_OUT} ] || \
[ ! -f $CFG_PLAT_OUT/.buildconfig ]; then
pack_error "config & build lichee before you pack"
exit 1
fi
source $CFG_PLAT_OUT/.buildconfig
if [ -z "${PACK_KERN}" ]; then
pack_info "No kernel param, parse it from .buildconfig"
PACK_KERN=$LICHEE_KERN_VER
pack_error "Failed to parse kernel param from .buildconfig"
exit 1
fi
fi
PACK_TYPE=""
case "x${PACK_PLATFORM}" in
"xandroid")
PACK_TYPE="android"
"xdragonboard")
PACK_TYPE="dragonboard"
"xdragonabts")
PACK_TYPE="dragonabts"
"xbsp"|"xsata"|"xbuildroot"|"xopenwrt"|"xdebian")
PACK_TYPE="linux"
pack_error "Unsupport PACK_PLATFORM: ${PACK_PLATFORM}"
exit 1
esac
export PATH=${LICHEE_TOOLS_DIR}/pack/pctools/linux/mod_update:${LICHEE_TOOLS_DIR}/pack/pctools/linux/openssl:${LICHEE_TOOLS_DIR}/pack/pctools/linux/eDragonEx:${LICHEE_TOOLS_DIR}/pack/pctools/linux/fsbuild200:${LICHEE_TOOLS_DIR}/pack/pctools/linux/android:$PATH
export LD_LIBRARY_PATH=${LICHEE_TOOLS_DIR}/pack/pctools/linux/softhsm/lib/:$LD_LIBRARY_PATH
tools_file_list=(
${LICHEE_COMMON_CONFIG_DIR}/tools/split_xxxx.fex
${LICHEE_CHIP_CONFIG_DIR}/tools/split_xxxx.fex
${LICHEE_COMMON_CONFIG_DIR}/tools/usbtool_test.fex
${LICHEE_COMMON_CONFIG_DIR}/tools/usbtool_crash.fex
${LICHEE_CHIP_CONFIG_DIR}/tools/usbtool_test.fex
${LICHEE_COMMON_CONFIG_DIR}/tools/cardscript.fex
${LICHEE_COMMON_CONFIG_DIR}/tools/cardscript_secure.fex
${LICHEE_CHIP_CONFIG_DIR}/tools/cardscript.fex
${LICHEE_CHIP_CONFIG_DIR}/tools/cardscript_secure.fex
${LICHEE_COMMON_CONFIG_DIR}/tools/cardtool.fex
${LICHEE_CHIP_CONFIG_DIR}/tools/cardtool.fex
${LICHEE_COMMON_CONFIG_DIR}/tools/usbtool.fex
${LICHEE_CHIP_CONFIG_DIR}/tools/usbtool.fex
${LICHEE_CHIP_CONFIG_DIR}/tools/usbtool_crash.fex
${LICHEE_COMMON_CONFIG_DIR}/tools/aultls32.fex
${LICHEE_CHIP_CONFIG_DIR}/tools/aultls32.fex
${LICHEE_COMMON_CONFIG_DIR}/tools/aultools.fex
${LICHEE_CHIP_CONFIG_DIR}/tools/aultools.fex
configs_file_list=(
${LICHEE_COMMON_CONFIG_DIR}/toc/toc1.fex
${LICHEE_COMMON_CONFIG_DIR}/toc/toc0.fex
${LICHEE_COMMON_CONFIG_DIR}/toc/toc0_sdcard.fex
${LICHEE_COMMON_CONFIG_DIR}/toc/toc0_nand.fex
${LICHEE_COMMON_CONFIG_DIR}/toc/toc0_ufs.fex
${LICHEE_COMMON_CONFIG_DIR}/toc/toc0_ft.fex
${LICHEE_COMMON_CONFIG_DIR}/toc/boot_package.fex
${LICHEE_COMMON_CONFIG_DIR}/hdcp/esm.fex
${LICHEE_COMMON_CONFIG_DIR}/dtb/sunxi.fex
${LICHEE_COMMON_CONFIG_DIR}/partition/sys_partition_dump.fex
${LICHEE_COMMON_CONFIG_DIR}/partition/sys_partition_private.fex
${LICHEE_COMMON_CONFIG_DIR}/version/version_base.mk
${LICHEE_CHIP_CONFIG_DIR}/configs/default/*
${LICHEE_CHIP_CONFIG_DIR}/configs/${PACK_BOARD}/*.fex
${LICHEE_CHIP_CONFIG_DIR}/configs/${PACK_BOARD}/boot_package*.cfg
${LICHEE_CHIP_CONFIG_DIR}/configs/${PACK_BOARD}/${LICHEE_KERN_VER}/*.cfg
${LICHEE_CHIP_CONFIG_DIR}/configs/default/version_base.mk
${LICHEE_CHIP_CONFIG_DIR}/dtbo/*
${LICHEE_BOARD_CONFIG_DIR}/dtbo/*
${LICHEE_CHIP_CONFIG_DIR}/${BIN_PATH}/ft_${PACK_CHIP}.bin
${LICHEE_COMMON_CONFIG_DIR}/sign_config/dragon_toc_ft.cfg
${LICHEE_CHIP_CONFIG_DIR}/configs/default/dragon_toc_ft.cfg
${LICHEE_COMMON_CONFIG_DIR}/sign_config/cnf_base.cnf
${LICHEE_PLAT_OUT}/.buildconfig
product_configs_file_list=(
${LICHEE_CHIP_CONFIG_DIR}/configs/${PACK_BOARD}/${PACK_PLATFORM}/*.fex
${LICHEE_CHIP_CONFIG_DIR}/configs/${PACK_BOARD}/${PACK_PLATFORM}/*.cfg
boot_resource_list=(
${LICHEE_CHIP_CONFIG_DIR}/boot-resource/boot-resource:${LICHEE_PACK_OUT_DIR}
${LICHEE_CHIP_CONFIG_DIR}/boot-resource/boot-resource.ini:${LICHEE_PACK_OUT_DIR}
${LICHEE_CHIP_CONFIG_DIR}/configs/${PACK_BOARD}/*.bmp:${LICHEE_PACK_OUT_DIR}/boot-resource/
${LICHEE_CHIP_CONFIG_DIR}/configs/${PACK_BOARD}/bootlogo.bmp:${LICHEE_PACK_OUT_DIR}/bootlogo.bmp
${LICHEE_CHIP_CONFIG_DIR}/configs/${PACK_BOARD}/wavefile/*:${LICHEE_PACK_OUT_DIR}/boot-resource/wavefile/
${LICHEE_CHIP_CONFIG_DIR}/configs/${PACK_BOARD}/${PACK_TYPE}/*.bmp:${LICHEE_PACK_OUT_DIR}/boot-resource/
${LICHEE_CHIP_CONFIG_DIR}/boot-resource/boot-resource/bat/bempty.bmp:${LICHEE_PACK_OUT_DIR}/bempty.bmp
${LICHEE_CHIP_CONFIG_DIR}/boot-resource/boot-resource/bat/battery_charge.bmp:${LICHEE_PACK_OUT_DIR}/battery_charge.bmp
boot_file_list=(
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/boot0_nand_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/boot0_nand.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/boot0_sdcard_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/boot0_sdcard.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/boot0_ufs_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/boot0_ufs.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/boot0_${LICHEE_BOOT0_BIN_NAME}_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/boot0_${LICHEE_BOOT0_BIN_NAME}.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/boot0_nandfastboot_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/boot0_nandfastboot_${PACK_CHIP}.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/boot0_spinor_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/boot0_spinor.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/fes1_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/fes1.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/fes1_uart_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/fes1_uart.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/u-boot-${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/u-boot.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/u-boot-${LICHEE_EFEX_BIN_NAME}.bin:${LICHEE_PACK_OUT_DIR}/u-boot-${LICHEE_EFEX_BIN_NAME}.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/u-boot-crashdump-${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/u-boot-crash.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/u-boot-crashdump-spinor-${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/u-boot-spinor-crash.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/bl31.bin:${LICHEE_PACK_OUT_DIR}/monitor.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/bl31_${PACK_BOARD}.bin:${LICHEE_PACK_OUT_DIR}/monitor.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/scp.bin:${LICHEE_PACK_OUT_DIR}/scp.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/amp_dsp0.bin:${LICHEE_PACK_OUT_DIR}/amp_dsp0.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/amp_dsp1.bin:${LICHEE_PACK_OUT_DIR}/amp_dsp1.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/amp_arm64.bin:${LICHEE_PACK_OUT_DIR}/amp_arm64.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/amp_rv0.bin:${LICHEE_PACK_OUT_DIR}/amp_rv0.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/video.bin:${LICHEE_PACK_OUT_DIR}/video.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/optee_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/optee.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/optee_${PACK_CHIP}-monitor.bin:${LICHEE_PACK_OUT_DIR}/optee-monitor.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/opensbi_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/opensbi.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/u-boot-spinor-${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/u-boot-spinor.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/u-boot-spinor-secure-${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/u-boot-spinor-secure.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/*.fex:${LICHEE_PACK_OUT_DIR}/
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/*.dtb:${LICHEE_PACK_OUT_DIR}/
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/*.bin:${LICHEE_PACK_OUT_DIR}/
boot_file_list_2=(
${LICHEE_PLAT_OUT}/arisc:${LICHEE_PACK_OUT_DIR}/arisc.fex
${LICHEE_PLAT_OUT}/sunxi.dtb:${LICHEE_PACK_OUT_DIR}/sunxi.fex
${LICHEE_PLAT_OUT}/boot0_nand_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/boot0_nand.fex
${LICHEE_PLAT_OUT}/boot0_sdcard_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/boot0_sdcard.fex
${LICHEE_PLAT_OUT}/boot0_${LICHEE_BOOT0_BIN_NAME}_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/boot0_${LICHEE_BOOT0_BIN_NAME}.fex
${LICHEE_PLAT_OUT}/boot0_spinor_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/boot0_spinor.fex
${LICHEE_PLAT_OUT}/fes1_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/fes1.fex
${LICHEE_PLAT_OUT}/fes1_uart_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/fes1_uart.fex
${LICHEE_PLAT_OUT}/sboot_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/sboot.bin
${LICHEE_PLAT_OUT}/sboot_nor_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/sboot_nor.bin
${LICHEE_PLAT_OUT}/sboot_sdcard_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/sboot_sdcard.bin
${LICHEE_PLAT_OUT}/sboot_nand_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/sboot_nand.bin
${LICHEE_PLAT_OUT}/sboot_ufs_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/sboot_ufs.bin
${LICHEE_PLAT_OUT}/u-boot-${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/u-boot.fex
${LICHEE_PLAT_OUT}/u-boot-${LICHEE_EFEX_BIN_NAME}.bin:${LICHEE_PACK_OUT_DIR}/u-boot-${LICHEE_EFEX_BIN_NAME}.fex
${LICHEE_PLAT_OUT}/u-boot-crashdump-${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/u-boot-crash.fex
${LICHEE_PLAT_OUT}/u-boot-crashdump-spinor-${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/u-boot-spinor-crash.fex
${LICHEE_PLAT_OUT}/scp.bin:${LICHEE_PACK_OUT_DIR}/scp.fex
${LICHEE_PLAT_OUT}/u-boot-spinor-${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/u-boot-spinor.fex
${LICHEE_PLAT_OUT}/u-boot-spinor-secure-${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/u-boot-spinor-secure.fex
${LICHEE_PLAT_OUT}/vmlinux.tar.bz2:${LICHEE_PACK_OUT_DIR}/vmlinux.fex
arm_boot_file_secure=(
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/semelis_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/semelis.bin
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/sboot_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/sboot.bin
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/sboot_nor_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/sboot_nor.bin
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/sboot_sdcard_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/sboot_sdcard.bin
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/sboot_nand_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/sboot_nand.bin
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/sboot_ufs_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/sboot_ufs.bin
${LICHEE_COMMON_CONFIG_DIR}/sign_config/dragon_toc_android.cfg:${LICHEE_PACK_OUT_DIR}/dragon_toc.cfg
${LICHEE_CHIP_CONFIG_DIR}/configs/default/dragon_toc_android.cfg:${LICHEE_PACK_OUT_DIR}/dragon_toc.cfg
arm64_boot_file_secure=(
${LICHEE_COMMON_CONFIG_DIR}/sign_config/dragon_toc_a64_android.cfg:${LICHEE_PACK_OUT_DIR}/dragon_toc.cfg
# This function can get the realpath between $SRC and $DST
function get_realpath()
local src=$(cd $1; pwd);
local dst=$(cd $2; pwd);
local res="./";
local tmp="$dst"
while [ "${src##*$tmp}" == "${src}" ]; do
tmp=${tmp%/*};
res=$res"../"
done
res="$res${src#*$tmp/}"
printf "%s" $res
function show_boards()
printf "\nAll avaiable chips, platforms and boards:\n\n"
printf "Chip Board\n"
for chipdir in $(find chips/ -mindepth 1 -maxdepth 1 -type d) ; do
chip=`basename ${chipdir}`
printf "${chip}\n"
for boarddir in $(find chips/${chip}/configs/${platform} \
board=`basename ${boarddir}`
printf " ${board}\n"
done
done
printf "\nFor Usage:\n"
printf " $(basename $0) -h\n\n"
function uart_switch()
rm -rf ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
touch ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
TX=`awk '$0~"'$PACK_CHIP'"{print $2}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_pin`
RX=`awk '$0~"'$PACK_CHIP'"{print $3}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_pin`
PORT=`awk '$0~"'$PACK_CHIP'"{print $4}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_pin`
MS=`awk '$0~"'$PACK_CHIP'"{print $5}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_pin`
CK=`awk '$0~"'$PACK_CHIP'"{print $6}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_pin`
DO=`awk '$0~"'$PACK_CHIP'"{print $7}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_pin`
DI=`awk '$0~"'$PACK_CHIP'"{print $8}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_pin`
BOOT_UART_ST=`awk '$0~"'$PACK_CHIP'"{print $2}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_string`
BOOT_PORT_ST=`awk '$0~"'$PACK_CHIP'"{print $3}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_string`
BOOT_TX_ST=`awk '$0~"'$PACK_CHIP'"{print $4}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_string`
BOOT_RX_ST=`awk '$0~"'$PACK_CHIP'"{print $5}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_string`
UART0_ST=`awk '$0~"'$PACK_CHIP'"{print $6}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_string`
UART0_USED_ST=`awk '$0~"'$PACK_CHIP'"{print $7}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_string`
UART0_PORT_ST=`awk '$0~"'$PACK_CHIP'"{print $8}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_string`
UART0_TX_ST=`awk '$0~"'$PACK_CHIP'"{print $9}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_string`
UART0_RX_ST=`awk '$0~"'$PACK_CHIP'"{print $10}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_string`
UART1_ST=`awk '$0~"'$PACK_CHIP'"{print $11}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_string`
JTAG_ST=`awk '$0~"'$PACK_CHIP'"{print $12}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_string`
MS_ST=`awk '$0~"'$PACK_CHIP'"{print $13}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_string`
CK_ST=`awk '$0~"'$PACK_CHIP'"{print $14}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_string`
DO_ST=`awk '$0~"'$PACK_CHIP'"{print $15}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_string`
DI_ST=`awk '$0~"'$PACK_CHIP'"{print $16}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_string`
MMC0_ST=`awk '$0~"'$PACK_CHIP'"{print $17}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_string`
MMC0_USED_ST=`awk '$0~"'$PACK_CHIP'"{print $18}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_string`
if [ -z "$TX" ] || [ -z "$BOOT_UART_ST" ]; then
pack_error "$FUNCNAME: $PACK_CHIP not configured in card_debug_pin/card_debug_string!"
exit 1
fi
echo '$0!~";" && $0~"'$BOOT_TX_ST'"{if(C)$0="'$BOOT_TX_ST' = '$TX'"} \' >> ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
echo '$0!~";" && $0~"'$BOOT_RX_ST'"{if(C)$0="'$BOOT_RX_ST' = '$RX'"} \' >> ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
echo '$0!~";" && $0~"'$BOOT_PORT_ST'"{if(C)$0="'$BOOT_PORT_ST' = '$PORT'"} \' >> ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
if [ "`grep "auto_print_used" "${LICHEE_PACK_OUT_DIR}/sys_config.fex" | grep "1"`" ]; then
echo '$0!~";" && $0~"'$MMC0_USED_ST'"{if(A)$0="'$MMC0_USED_ST' = 1";A=0} \' >> ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
echo '$0!~";" && $0~"'$MMC0_USED_ST'"{if(A)$0="'$MMC0_USED_ST' = 0";A=0} \' >> ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
fi
echo '$0!~";" && $0~"\\['$MMC0_ST'\\]"{A=1} \' >> ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
echo '$0!~";" && $0~"'$UART0_TX_ST'"{if(B)$0="'$UART0_TX_ST' = '$TX'"} \' >> ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
echo '$0!~";" && $0~"'$UART0_RX_ST'"{if(B)$0="'$UART0_RX_ST' = '$RX'"} \' >> ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
echo '$0!~";" && $0~"\\['$UART0_ST'\\]"{B=1} \' >> ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
echo '$0!~";" && $0~"'$UART0_USED_ST'"{if(B)$0="'$UART0_USED_ST' = 1"} \' >> ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
echo '/^'$UART0_PORT_ST'/{next} \' >> ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
echo '$0!~";" && $0~"\\['$UART1_ST'\\]"{B=0} \' >> ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
echo '$0!~";" && $0~"\\['$BOOT_UART_ST'\\]"{C=1} \' >> ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
echo '$0!~";" && $0~"\\['$JTAG_ST'\\]"{C=0} \' >> ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
echo '$0!~";" && $0~"'$MS_ST'"{$0="'$MS_ST' = '$MS'"} \' >> ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
echo '$0!~";" && $0~"'$CK_ST'"{$0="'$CK_ST' = '$CK'"} \' >> ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
echo '$0!~";" && $0~"'$DO_ST'"{$0="'$DO_ST' = '$DO'"} \' >> ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
echo '$0!~";" && $0~"'$DI_ST'"{$0="'$DI_ST' = '$DI'"} \' >> ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
echo '1' >> ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
sed -i -e '/^uart0_rx/a\pinctrl-1=' ${LICHEE_PACK_OUT_DIR}/sys_config.fex
sed -i -e '/^uart0_rx/a\pinctrl-0=' ${LICHEE_PACK_OUT_DIR}/sys_config.fex
fi
awk -f ${LICHEE_PACK_OUT_DIR}/awk_debug_card0 ${LICHEE_PACK_OUT_DIR}/sys_config.fex > ${LICHEE_PACK_OUT_DIR}/sys_config_debug.fex
rm -f ${LICHEE_PACK_OUT_DIR}/sys_config.fex
mv ${LICHEE_PACK_OUT_DIR}/sys_config_debug.fex ${LICHEE_PACK_OUT_DIR}/sys_config.fex
echo "uart -> card0"
function add_lzma_header()
lzma_file=$1
original_file=$2
file_size=$(printf "%.8x\n" `stat -c%s ${lzma_file}`)
original_file_size=$(printf "%.8x\n" `stat -c%s ${original_file}`)
bin_str=""
file_size_len=${#file_size}
#"LZMA"+size+origin_size
bin_str="\x4c\x5a\x4d\x41\x${file_size:6:2}\x${file_size:4:2}\x${file_size:2:2}\x${file_size:0:2}"
bin_str+="\x${original_file_size:6:2}\x${original_file_size:4:2}\x${original_file_size:2:2}\x${original_file_size:0:2}"
printf "%b" ${bin_str} > tempbin
cat ${lzma_file} >> tempbin
mv tempbin "${lzma_file}.head"
function partition_size_handle()
echo "handle partition_size"
local filename=${LICHEE_PACK_OUT_DIR}/sys_partition.fex
local size
local number
local dimension
local blocks
local line
local m
local index=0
while read line; do
let "index++"
size=$(echo $line | awk -F= '/^[[:space:]]*size[[:space:]]*=/{print $2}' | sed 's|\s\+||g')
if [ -n "$size" ]; then
dimension=$(echo $size | sed 's|^[0-9,.]\+||g')
[ -z "$dimension" ] && continue
case $dimension in
B|b)
m=1
K|k)
m=1024
M|m)
m=1048576
G|g)
m=1073741824
pack_error "ERROR Dimension($dimension)!"
return 1
esac
number=$(echo $size | sed 's|[a-z,A-Z]*$||g')
blocks=$(echo "$number * $m / 512" | bc | awk -F. '{print $1}')
printf "sys_partition.fex: size %6s => %7d Blocks\n" "${number}${dimension}" "${blocks}"
size="$(echo "$line" | sed "s|=.*$|= $blocks|g")"
sed -i "${index}s|$line|$size|g" $filename
fi
done < $filename
return 0
function do_prepare()
local runinfo=($(lsof 2>/dev/null | awk '$9~"'$LICHEE_TOP_DIR/tools/build/buildserver'"{print $2}'))
local possible_bin_path="${LICHEE_POSSIBLE_BIN_PATH}"
if [ ${#runinfo[@]} -lt 2 ]; then
pack_error "something is incorrect:please <./build.sh config>."
fi
if [ -z "${PACK_CHIP}" -o -z "${PACK_TYPE}" -o -z "${PACK_BOARD}" ] ; then
pack_error "Invalid parameters Chip: ${PACK_CHIP}, \
Platform: ${PACK_TYPE}, Board: ${PACK_BOARD}"
show_boards
exit 1
fi
if [ ! -d ${LICHEE_CHIP_CONFIG_DIR}/configs/${PACK_BOARD} ] ; then
pack_error "Board's directory \
\"${LICHEE_CHIP_CONFIG_DIR}/configs/${PACK_BOARD}\" is not exist."
show_boards
exit 1
fi
# Cleanup
if [ "x" != "x${LICHEE_PACK_OUT_DIR}" ]; then
fi
mkdir -p ${LICHEE_PACK_OUT_DIR}
cd $LICHEE_OUT_DIR
if [ "${LICHEE_PACK_OUT_DIR}" != "$LICHEE_OUT_DIR/pack_out" ]; then
rm -rf pack_out
ln -sf ${LICHEE_IC}/${LICHEE_BOARD}/pack_out pack_out
fi
printf "copying tools file\n"
for file in ${tools_file_list[@]} ; do
cp -f $file ${LICHEE_PACK_OUT_DIR} 2> /dev/null
done
if [ "x${PACK_KERN}" = "xlinux-3.4" ]; then
cp -f ${LICHEE_COMMON_CONFIG_DIR}/tools/cardscript.fex ${LICHEE_PACK_OUT_DIR} 2> /dev/null
fi
printf "copying configs file\n"
for file in ${configs_file_list[@]} ; do
done
printf "copying product configs file\n"
for file in ${product_configs_file_list[@]}; do
cp -f $file ${LICHEE_PACK_OUT_DIR} 2>/dev/null
done
if [ x"${PACK_PLATFORM}" != x"android" ]; then
printf "linux copying boardt&linux_kernel_version configs file\n"
local possible_env_path=(
configs/default
configs/${LICHEE_BOARD}
configs/${LICHEE_BOARD}/${LICHEE_KERN_VER}
configs/${LICHEE_BOARD}/${PACK_PLATFORM}
local possible_env_list=(
env.cfg
env-$(echo ${LICHEE_KERN_VER} | awk -F '-' '{print $2}').cfg
local copy_env_file=''
for d in ${possible_env_path[@]}; do
[ ! -d ${LICHEE_CHIP_CONFIG_DIR}/$d ] && continue
for file in ${possible_env_list[@]} ; do
if [ -e "${LICHEE_CHIP_CONFIG_DIR}/$d/$file" ]; then
copy_env_file=${LICHEE_CHIP_CONFIG_DIR}/$d/$file
fi
done
done
echo "Use u-boot env file: ${copy_env_file}"
if [[ ! -f ${copy_env_file} ]]
then
echo -e "\e[33mWarning: u-boot env file '${copy_env_file}' not exist! use file in default directory other than '${PACK_BOARD}' directory\e[0m"
fi
cp -f ${copy_env_file} ${LICHEE_PACK_OUT_DIR}/env.cfg 2>/dev/null
cp -f ${LICHEE_CHIP_CONFIG_DIR}/configs/${PACK_BOARD}/${LICHEE_KERN_VER}/sys_* ${LICHEE_PACK_OUT_DIR} 2>/dev/null
fi
# If platform config files exist, we will cover the default files
# For example, mv pack_out/image_linux.cfg pack_out/image.cfg
if [ ${PACK_PLATFORM} != "android" ]; then
cp -f ${LICHEE_BOARD_CONFIG_DIR}/${PACK_PLATFORM}/* ${LICHEE_PACK_OUT_DIR} 2> /dev/null
if [ ${PACK_PLATFORM} = "bsp" -o "x${PACK_PLATFORM}" = "xsata" ] ; then
find ${LICHEE_PACK_OUT_DIR}/* -type f -a \( -name "*.fex" -o -name "*.cfg" \) -print | \
sed "s#\(.*\)_linux\(\..*\)#mv -fv & \1\2#e"
sed "s#\(.*\)_${PACK_PLATFORM}\(\..*\)#mv -fv & \1\2#e"
fi
sed "s#\(.*\)_${PACK_TYPE}\(\..*\)#mv -fv & \1\2#e"
fi
if [ "x${PACK_MODE}" = "xdump" ] ; then
cp -vf ${LICHEE_PACK_OUT_DIR}/sys_partition_dump.fex ${LICHEE_PACK_OUT_DIR}/sys_partition.fex
cp -vf ${LICHEE_PACK_OUT_DIR}/usbtool_test.fex ${LICHEE_PACK_OUT_DIR}/usbtool.fex
elif [ "x${PACK_FUNC}" = "xprvt" ] ; then
cp -vf ${LICHEE_PACK_OUT_DIR}/sys_partition_private.fex ${LICHEE_PACK_OUT_DIR}/sys_partition.fex
fi
printf "copying boot resource\n"
for file in ${boot_resource_list[@]} ; do
cp -rf $(echo $file | sed -e 's/:/ /g') 2>/dev/null
done
# openwrt use these logo files
if [ x"${PACK_PLATFORM}" = x"openwrt" ]; then
rm -rf ${LICHEE_PACK_OUT_DIR}/boot-resource
cp -rf $CFG_TOP_DIR/${PACK_PLATFORM}/target/$PACK_IC/$PACK_IC-common/boot-resource/boot-resource ${LICHEE_PACK_OUT_DIR}
cp -rf $CFG_TOP_DIR/${PACK_PLATFORM}/target/$PACK_IC/$PACK_IC-common/boot-resource/boot-resource.ini ${LICHEE_PACK_OUT_DIR}/boot-resource.ini
fi
if [ ! -f ${LICHEE_PACK_OUT_DIR}/bootlogo.bmp ]; then
cp ${LICHEE_PACK_OUT_DIR}/boot-resource/bootlogo.bmp ${LICHEE_PACK_OUT_DIR}/bootlogo.bmp
fi
lzma -k ${LICHEE_PACK_OUT_DIR}/bootlogo.bmp
lzma -k ${LICHEE_PACK_OUT_DIR}/bempty.bmp
lzma -k ${LICHEE_PACK_OUT_DIR}/battery_charge.bmp
if [ -f ${LICHEE_PACK_OUT_DIR}/bootlogo.bmp.lzma ]; then
add_lzma_header "${LICHEE_PACK_OUT_DIR}/bootlogo.bmp.lzma" "${LICHEE_PACK_OUT_DIR}/bootlogo.bmp"
(cd ${LICHEE_PACK_OUT_DIR}; ln -sf bootlogo.bmp.lzma.head bootlogo.fex)
fi
printf "copying boot file\n"
for d in ${possible_bin_path[@]}; do
BIN_PATH=$d
for file in ${boot_file_list[@]} ; do
eval cp -v -f $(echo $file | sed -e 's/:/ /g') 2>/dev/null
done
done
printf "copying boot file 2.0\n"
for file in ${boot_file_list_2[@]} ; do
done
if [[ ${LICHEE_BOARD} == *fastboot*spinand* ]] ; then
mv -v ${LICHEE_PACK_OUT_DIR}/boot0_nandfastboot_${PACK_CHIP}.fex ${LICHEE_PACK_OUT_DIR}/boot0_nand.fex
fi
if ! [ -z ${LICHEE_BOOT0_BIN_NAME} ]; then
# nand fastboot
cp -v -f ${LICHEE_PACK_OUT_DIR}/boot0_${LICHEE_BOOT0_BIN_NAME}.fex ${LICHEE_PACK_OUT_DIR}/boot0_nand.fex
if [[ ${LICHEE_FLASH} == default ]] ; then
mv -v ${LICHEE_PACK_OUT_DIR}/boot0_${LICHEE_BOOT0_BIN_NAME}.fex ${LICHEE_PACK_OUT_DIR}/boot0_sdcard.fex
elif [[ ${LICHEE_FLASH} == nor ]] ; then
mv -v ${LICHEE_PACK_OUT_DIR}/boot0_${LICHEE_BOOT0_BIN_NAME}.fex ${LICHEE_PACK_OUT_DIR}/boot0_spinor.fex
echo "invalid LICHEE_FLASH, default choose sdcard!"
fi
fi
[ -z "${BIN_PATH}" ] &&
pack_error "No BIN_PATH found!" && exit 1
printf "copying $LICHEE_ARCH secure boot file\n"
BIN_PATH=$d
for file in $(eval echo '$'"{${LICHEE_ARCH}_boot_file_secure[@]}"); do
eval cp -f $(echo $file | sed -e 's/:/ /g') 2>/dev/null
done
done
# If platform config use
if [ -f ${LICHEE_CHIP_CONFIG_DIR}/tools/plat_config.sh ] ; then
fi
if [ "x${PACK_NOR}" = "xnor" ] ; then
cp -vf ${LICHEE_PACK_OUT_DIR}/image_nor.cfg ${LICHEE_PACK_OUT_DIR}/image.cfg
cp -vf ${LICHEE_PACK_OUT_DIR}/sboot_nor.bin ${LICHEE_PACK_OUT_DIR}/sboot.bin
cp -vf ${LICHEE_PACK_OUT_DIR}/dragon_toc_nor.cfg ${LICHEE_PACK_OUT_DIR}/dragon_toc.cfg
fi
if [ "x${PACK_VSP}" = "xvsp" ] ; then
printf "change usb_port_type to device...\n"
printf "disable usb_serial_unique...\n"
printf "change usb_serial_number to ${PACK_TYPE}_android...\n"
sed -i 's/^usb_port_type.*/usb_port_type = 0/g' ${LICHEE_PACK_OUT_DIR}/sys_config.fex
sed -i 's/^usb_serial_unique.*/usb_serial_unique = 0/g' ${LICHEE_PACK_OUT_DIR}/sys_config.fex
sed -i 's/^usb_serial_number.*/usb_serial_number = "'"${PACK_CHIP}"'_android"/g' ${LICHEE_PACK_OUT_DIR}/sys_config.fex
fi
printf "copying additional files\n"
for file in ${PACK_ADD_FILES[@]}; do
cp -vf $(echo $file | sed -e 's/:/ /g') 2>/dev/null
done
if [ "x${PACK_PLATFORM}" == "xandroid" ] && [ "x$TARGET_BUILD_VARIANT" == "xuser" ]; then
pack_info "change kernel loglevel to 3 for android user build"
sed -i 's|^\s*loglevel=[0-9]\s*$|loglevel=3|g' ${LICHEE_PACK_OUT_DIR}/env.cfg
if [ "${ENABLE_VENDOR_ADB}" == "true" ]; then
pack_info "enable vendor adb for android user build"
sed -i 's|^init_rc=.*$|init_rc=/vendor/etc/init/hw/init.aw.rc|g' ${LICHEE_PACK_OUT_DIR}/env.cfg
fi
fi
if [ "x${PACK_PROGRAMMER}" = "xprogrammer" ]; then
printf "add programmer img info target in sys config\n"
sed -i -e '/^\[target\]/a\programmer=1' ${LICHEE_PACK_OUT_DIR}/sys_config.fex
fi
sed -i 's/\\boot-resource/\/boot-resource/g' ${LICHEE_PACK_OUT_DIR}/boot-resource.ini
sed -i 's/\\\\/\//g' ${LICHEE_PACK_OUT_DIR}/image.cfg
sed -i 's/^imagename/;imagename/g' ${LICHEE_PACK_OUT_DIR}/image.cfg
prepare_mixed_androiddragonboard
[ $? -ne 0 ] && exit 1
cd ${LICHEE_PACK_OUT_DIR}/
echo "vmlinux" > ${LICHEE_PACK_OUT_DIR}/vmlinux.fex
make_user_res sys_partition_nor.fex
make_app_res sys_partition_nor.fex
make_data_res sys_partition_nor.fex
make_user_res sys_partition.fex
make_app_res sys_partition.fex
make_data_res sys_partition.fex
fi
cd - > /dev/null
fi
function img_to_programmer()
local out_img=$1
local in_img=$2
if [ "x${PACK_SECURE}" = "xsecure" ]; then
if [ -f toc0_sdcard.fex ] ; then
programmer_img toc0_sdcard.fex toc1.fex ${out_img} > /dev/null
elif [ -f toc0_nand.fex ] ; then
programmer_img toc0_nand.fex toc1.fex ${out_img} > /dev/null
programmer_img toc0.fex toc1.fex ${out_img} > /dev/null
fi
programmer_img boot0_sdcard.fex boot_package.fex ${out_img} > /dev/null
fi
if [ -f sunxi_gpt.fex ] ; then
#create_img for sunxi_gpt.fex
programmer_img sys_partition.bin sunxi_mbr.fex ${out_img} ${in_img} sunxi_gpt.fex > /dev/null
#create_img for sunxi_mbr.fex
programmer_img sys_partition.bin sunxi_mbr.fex ${out_img} ${in_img} > /dev/null
fi
function uboot_ini_to_dts()
local TARGET_UBOOT
local PLATFORM_ADDR
local SOC_ADDR
local DTC_FLAGS=""
if [ x${LICHEE_BRANDY_UBOOT_VER} == x2023 ]; then
pack_info "skip split fdt"
return
fi
if [ "x${PACK_NOR}" == "xnor" ]; then
TARGET_UBOOT=${LICHEE_PACK_OUT_DIR}/u-boot-spinor.fex
TARGET_UBOOT=${LICHEE_PACK_OUT_DIR}/u-boot.fex
fi
sunxi_ubootools split ${TARGET_UBOOT} > /dev/null
if [ $? -ne 0 ]
then
pack_warn "split uboot and fdt failed!!"
return
fi
[ "$(readlink -f .)" != "$(readlink -f ${LICHEE_PACK_OUT_DIR})" ] && {
mv temp_fdt.dtb ${LICHEE_PACK_OUT_DIR}
mv temp_ubootnodtb.bin ${LICHEE_PACK_OUT_DIR}
# to dts
$DTC_COMPILER ${DTC_FLAGS} -I dtb -O dts -o ${LICHEE_PACK_OUT_DIR}/.uboot.dtb.dts.tmp ${LICHEE_PACK_OUT_DIR}/temp_fdt.dtb 2>/dev/null
PLATFORM_ADDR=`grep -Po "(?<=platform@)(\w+)(?=\s*{)" ${LICHEE_PACK_OUT_DIR}/.uboot.dtb.dts.tmp | head -1`
SOC_ADDR=`grep -Po "(?<=soc@)(\w+)(?=\s*{)" ${LICHEE_PACK_OUT_DIR}/.uboot.dtb.dts.tmp | head -1`
if [ "x${PACK_TYPE}" = "xdragonboard" -o "x${PACK_TYPE}" = "xdragonabts" ] ; then
cat <<- EOF >> ${LICHEE_PACK_OUT_DIR}/.uboot.dtb.dts.tmp
soc@${SOC_ADDR} {
platform@${PLATFORM_ADDR} {
dragonboard_test = <1>;
EOF
fi
# to dtb
$DTC_COMPILER ${DTC_FLAGS} -I dts -O dtb -o ${LICHEE_PACK_OUT_DIR}/temp_fdt.dtb ${LICHEE_PACK_OUT_DIR}/.uboot.dtb.dts.tmp 2>/dev/null
# get update_to_ubootfdt value from sysconfig
sunxi_ubootools subkey_value sys_config.bin sunxi_ubootools update_to_ubootfdt > /dev/null
if [ $? -eq 1 ]; then
echo "uboot ini to dts"
$DTC_COMPILER -p 2048 ${DTC_FLAGS} -@ -O dtb -o ${LICHEE_PACK_OUT_DIR}/new_fdt.dtb \
-b 0 \
-i ${LICHEE_PACK_OUT_DIR} \
-F $DTC_INI_FILE \
-d ${LICHEE_PACK_OUT_DIR}/temp_fdt.dtb ${LICHEE_PACK_OUT_DIR}/.uboot.dtb.dts.tmp 2>/dev/null
mv ${LICHEE_PACK_OUT_DIR}/temp_fdt.dtb ${LICHEE_PACK_OUT_DIR}/new_fdt.dtb
fi
sunxi_ubootools merge ${LICHEE_PACK_OUT_DIR}/temp_ubootnodtb.bin ${LICHEE_PACK_OUT_DIR}/new_fdt.dtb > /dev/null
cp -vf ${LICHEE_PACK_OUT_DIR}/temp_ubootnodtb.bin ${TARGET_UBOOT}
# .uboot.dts is the last dts of uboot
$DTC_COMPILER ${DTC_FLAGS} -I dtb -O dts -o ${LICHEE_PACK_OUT_DIR}/.uboot.dts ${LICHEE_PACK_OUT_DIR}/new_fdt.dtb 2>/dev/null
function do_ini_to_dts()
maybe_busybox unix2dos sys_config.fex
script sys_config.fex > /dev/null
local DTC_SRC_PATH=${LICHEE_PLAT_OUT}
local DTC_COMPILER=${LICHEE_PLAT_OUT}/dtc
local DTC_FLAGS=""
uboot_ini_to_dts
if [ "x${PACK_KERN}" == "xlinux-3.4" \
-o "x${PACK_KERN}" == "xlinux-3.10" \
-o "x${PACK_KERN}" == "xlinux-4.4" \
-o "x${PACK_KERN}" == "xlinux-5.4" \
-o "x${PACK_KERN}" == "xlinux-5.4-ansc" \
-o "x${PACK_KERN}" == "xlinux-5.10" \
-o "x${PACK_KERN}" == "xlinux-5.10-origin" \
-o "x${PACK_KERN}" == "xlinux-5.15" \
-o "x${PACK_KERN}" == "xlinux-5.15-origin" ] || [[ ${PACK_KERN/linux-} > 5.15 ]]; then
# For debug: sunxi.dtb -> .sunxi.dts
$DTC_COMPILER ${DTC_FLAGS} -I dtb -O dts -o ${LICHEE_PLAT_OUT}/.sunxi.dts ${LICHEE_PLAT_OUT}/sunxi.dtb 2>/dev/null
return
fi
local dtc_file_list=(
.board.dtb.d.dtc.tmp:.board.dtb.dts.tmp
.${PACK_CHIP}-${PACK_BOARD}.dtb.d.dtc.tmp:.${PACK_CHIP}-${PACK_BOARD}.dtb.dts.tmp
.${PACK_CHIP}-${LICHEE_BUSSINESS}.dtb.d.dtc.tmp:.${PACK_CHIP}-${LICHEE_BUSSINESS}.dtb.dts.tmp
.${PACK_CHIP}-soc.dtb.d.dtc.tmp:.${PACK_CHIP}-soc.dtb.dts.tmp)
local DTC_INI_FILE_BASE=${LICHEE_PACK_OUT_DIR}/sys_config.fex
local DTC_INI_FILE=${LICHEE_PACK_OUT_DIR}/sys_config_fix.fex
cp $DTC_INI_FILE_BASE $DTC_INI_FILE
sed -i "s/\(\[dram\)_para\(\]\)/\1\2/g" $DTC_INI_FILE
sed -i "s/\(\[nand[0-9]\)_para\(\]\)/\1\2/g" $DTC_INI_FILE
if [ ! -f $DTC_COMPILER ]; then
pack_error "Script_to_dts: Can not find dtc compiler.\n"
exit 1
fi
local DTC_DEP_FILE DTC_SRC_FILE
for e in ${dtc_file_list[@]}; do
DTC_DEP_FILE=$DTC_SRC_PATH/${e/:*}
if [ -f $DTC_DEP_FILE ]; then
DTC_SRC_FILE=$DTC_SRC_PATH/${e#*:}
break
fi
done
echo "sunxi_dtb create"
$DTC_COMPILER -p 2048 ${DTC_FLAGS} -@ -O dtb -o ${LICHEE_PLAT_OUT}/sunxi.dtb \
-b 0 \
-i $DTC_SRC_PATH \
-F $DTC_INI_FILE \
-d $DTC_DEP_FILE $DTC_SRC_FILE 2>/dev/null
if [ $? -ne 0 ]; then
pack_error "Conver script to dts failed"
exit 1
fi
#restore the orignal dtsi
if [ "x${PACK_TYPE}" = "xdragonboard" \
-o "x${PACK_TYPE}" = "xdragonmat" ]; then
local DTS_PATH=${LICHEE_KERN_DIR}/arch/${LICHEE_ARCH}/boot/dts
[ "x${LICHEE_ARCH}" = "xarm64" ] && DTS_PATH=${LICHEE_KERN_DIR}/arch/${LICHEE_ARCH}/boot/dts/sunxi
if [ -f ${DTS_PATH}/${PACK_CHIP}_bak.dtsi ];then
rm -f ${DTS_PATH}/${PACK_CHIP}.dtsi
mv ${DTS_PATH}/${PACK_CHIP}_bak.dtsi ${DTS_PATH}/${PACK_CHIP}.dtsi
fi
fi
printf "Conver script to dts ok.\n"
# It'is used for debug dtb
return
function maybe_busybox()
if [ "x$(which busybox)" == "x" ]; then
pack_error "Tool busybox does not exist!"
exit 1
fi
busybox $@ || $@
function generate_env_for_uboot()
printf "$1 Conver to $2.\n"
printf "LICHEE_BRANDY_UBOOT_VER : ${LICHEE_BRANDY_UBOOT_VER}\n"
if [ -n "${LICHEE_BRANDY_UBOOT_VER}" ] && [ ${LICHEE_BRANDY_UBOOT_VER} -ge 2023 ]; then
printf "create env.fex for uboot2023 or later, size 128K\n"
# mkenvimage -p 0x00 -s 0x20000 -o env.fex env.cfg
mkenvimage -p 0x00 -s 0x20000 -o $2 $1
# u_boot_env_gen env_nor.cfg env_nor.fex >/dev/null
u_boot_env_gen $1 $2 >/dev/null
fi
function do_common()
echo $(date -d "$ts" +"%Y-%m-%d %H:%M:%S") > ${LICHEE_PACK_OUT_DIR}/sunxi_version.fex
# Here, we can switch uart to card or normal
if [ "x${PACK_DEBUG}" = "xcard0" -a "x${PACK_MODE}" != "xdump" \
-a "x${PACK_FUNC}" != "xprvt" ] ; then \
uart_switch
sed -i -e '/^auto_print_used/s\1\0\' ${LICHEE_PACK_OUT_DIR}/sys_config.fex
fi
printf "add burn_secure_mode in target in sys config\n"
sed -i -e '/^\[target\]/a\burn_secure_mode=1' ${LICHEE_PACK_OUT_DIR}/sys_config.fex
sed -i -e '/^\[platform\]/a\secure_without_OS=0' ${LICHEE_PACK_OUT_DIR}/sys_config.fex
if [ -f ${LICHEE_PACK_OUT_DIR}/optee-monitor.fex ]; then
rm -f ${LICHEE_PACK_OUT_DIR}/optee-monitor.fex
fi
sed -i '/^burn_secure_mod/d' ${LICHEE_PACK_OUT_DIR}/sys_config.fex
sed -i '/^secure_without_OS/d' ${LICHEE_PACK_OUT_DIR}/sys_config.fex
mv -v ${LICHEE_PACK_OUT_DIR}/optee-monitor.fex ${LICHEE_PACK_OUT_DIR}/optee.fex
fi
fi
if [ ! -f board_config.fex ]; then
echo "[empty]" > board_config.fex
fi
maybe_busybox unix2dos board_config.fex
cp -f sys_config.bin config.fex
script board_config.fex > /dev/null
cp -f board_config.bin board.fex
maybe_busybox unix2dos sys_partition.fex
script sys_partition.fex > /dev/null
if [ "x${PACK_TYPE}" = "xdragonboard" ] ; then
maybe_busybox dos2unix test_config.fex
cp test_config.fex boot-resource/
maybe_busybox unix2dos test_config.fex
script test_config.fex > /dev/null
cp test_config.bin boot-resource/
fi
if [ "x${PACK_TYPE}" = "xdragonabts" ] ; then
fi
# Those files for SpiNor. We will try to find sys_partition_nor.fex
if [ ! -f sys_partition_nor.fex ]; then
echo "sys partition for nor not exist"
exit 1
fi
if [ ! -f ${LICHEE_CHIP_CONFIG_DIR}/tools/arisc_config_parse.sh ]; then
if [ -f "scp.fex" ]; then
echo "update scp"
update_scp scp.fex sunxi.fex >/dev/null
fi
fi
# Here, will create sys_partition_nor.bin
maybe_busybox unix2dos sys_partition_nor.fex
script sys_partition_nor.fex > /dev/null
update_boot0 boot0_spinor.fex sys_config.bin SPINOR_FLASH > /dev/null
update_chip boot0_spinor.fex > /dev/null
update_fes1 fes1.fex sys_config.bin > /dev/null
if [ "x${PACK_KERN}" = "xlinux-3.4" ] ; then
update_uboot -merge u-boot-spinor.fex sys_config.bin > /dev/null
update_uboot -no_merge u-boot-spinor.fex sys_config.bin > /dev/null
update_uboot -no_merge u-boot-spinor-secure.fex sys_config.bin > /dev/null
[ -f u-boot-efex.fex ] && {
update_uboot -no_merge u-boot-efex.fex sys_config.bin > /dev/null
fi
while read line
do
compress_name=(`echo $line | awk '($1 !~ ";" && ($2 ~ "lzma" || $2 ~ "lz4" || $2 ~ "gz")) {print $2}'`)
source_name=(`echo $compress_name | cut -d \. -f 1,2 | cut -d \ -f 2`)
compress_type=(`echo $compress_name | cut -d \. -f 3 | cut -d \ -f 2`)
[ -z "$compress_name" ] && continue
case $compress_type in
"gz")
[ -f $source_name ] && gzip -c $source_name > $compress_name || echo "no exist $source_name"
echo "compress name: $compress_name"
"lzma")
[ -f $source_name ] && lzma -k $source_name || echo "no exist $source_name"
mv $source_name.lzma $compress_name >/dev/null 2<&1
"lz4")
[ -f $source_name ] && lz4 -f $source_name $compress_name || echo "no exist $source_name"
echo "no match compress type"
esac
echo "compress type: $compress_type"
done < boot_package_nor.cfg
if [ -f boot_package_nor.cfg ]; then
mv u-boot-spinor-crash.fex u-boot-crash.fex
echo "pack boot package"
maybe_busybox unix2dos boot_package.cfg
dragonsecboot -pack boot_package_nor.cfg
cp boot_package.fex boot_package_nor.fex
fi
# Ugly, but I don't have a better way to change it.
# We just set env's downloadfile name to env_nor.cfg in sys_partition_nor.fex
# And if env_nor.cfg is not exist, we should copy one.
if [ ! -f env_nor.cfg ]; then
cp -f env.cfg env_nor.cfg >/dev/null 2<&1
fi
#card sprite
if [ -f "boot0_sdcard.fex" ]; then
update_boot0 boot0_sdcard.fex sys_config.bin SDMMC_CARD > /dev/null
update_chip boot0_sdcard.fex > /dev/null
fi
# Fixup boot mode for SPINor, just can bootm
sed -i '/^boot_normal/s#\<boota\>#bootm#g' env_nor.cfg
echo 1:LICHEE_REDUNDANT_ENV_SIZE:$LICHEE_REDUNDANT_ENV_SIZE
if [ "x${LICHEE_REDUNDANT_ENV_SIZE}" != "x" ]; then
echo "--mkenvimage create redundant env data!--"
echo "--redundant nor env data size ${LICHEE_REDUNDANT_ENV_SIZE}---"
mkenvimage -r -p 0x00 -s ${LICHEE_REDUNDANT_ENV_SIZE} -o env_nor.fex env_nor.cfg
generate_env_for_uboot env_nor.cfg env_nor.fex
fi
update_boot0 boot0_nand.fex sys_config.bin NAND > /dev/null
update_boot0 boot0_ufs.fex sys_config.bin UFS > /dev/null
update_chip boot0_nand.fex >/dev/null
update_chip boot0_sdcard.fex >/dev/null
update_chip boot0_ufs.fex >/dev/null
fi
if [ ! -f "u-boot-crash.fex" ]; then
touch "u-boot-crash.fex"
echo "ensure u-boot-crash.fex is not empty" > u-boot-crash.fex
fi
if [ -f "sunxi.fex" ]; then
update_dtb sunxi.fex 4096
fi
echo "update scp"
fi
fi
if [ -f "optee.fex" ]; then
echo "update optee"
update_optee optee.fex sunxi.fex >/dev/null
fi
# Those files for Nand or Card
update_uboot -merge u-boot.fex sys_config.bin > /dev/null
update_uboot -no_merge u-boot.fex sys_config.bin > /dev/null
[ -f u-boot-nodtb.fex ] && {
update_uboot -no_merge u-boot-nodtb.fex sys_config.bin > /dev/null
fi
if [ -f "fes1_uart.fex" ]; then
update_fes1 fes1_uart.fex sys_config.bin > /dev/null
fi
if [ -f ${LICHEE_TOOLS_DIR}/pack/pctools/linux/mod_update/update_sboot ];then
update_sboot sboot.bin sys_config.bin > /dev/null
if [ $? -ne 0 ]
then
pack_error "update sboot run error"
exit 1
fi
fi
fsbuild boot-resource.ini split_xxxx.fex > /dev/null
if [ -f boot_package_uartburn.cfg ]; then
dragonsecboot -pack boot_package_uartburn.cfg
if [ $? -ne 0 ]
then
pack_error "dragon pack boot_package_uartburn run error"
exit 1
fi
mv boot_package.fex boot_package_uartburn.fex
fi
if [ -f boot_package.cfg ]; then
if [ "x$LINUX_DTBO_FILE" = "x" ]; then
echo "do not set LINUX_DTBO_FILE"
line_num=`sed -n -e "/default.dtbo/=" boot_package.cfg`
if [ "x$line_num" != "x" ]; then
sed -i "$line_num s/^/;/g" boot_package.cfg
fi
if [ -f $LINUX_DTBO_FILE ]
then
sed -i "s/default.dtbo/$LINUX_DTBO_FILE/g" boot_package.cfg
fi
fi
fi
dragonsecboot -pack boot_package.cfg
if [ $? -ne 0 ]
then
pack_error "dragon pack run error"
exit 1
fi
fi
echo 2:LICHEE_REDUNDANT_ENV_SIZE:$LICHEE_REDUNDANT_ENV_SIZE
echo "--redundant env data size ${LICHEE_REDUNDANT_ENV_SIZE}---"
mkenvimage -r -p 0x00 -s ${LICHEE_REDUNDANT_ENV_SIZE} -o env.fex env_burn.cfg
generate_env_for_uboot env_burn.cfg env.fex
fi
mkenvimage -r -p 0x00 -s ${LICHEE_REDUNDANT_ENV_SIZE} -o env.fex env.cfg
generate_env_for_uboot env.cfg env.fex
fi
fi
dmverity_deal clean
function do_finish()
# Yeah, it should contain all files into full_img.fex for spinor
# Because, as usually, spinor image size is very small.
# If fail to create full_img.fex, we should fake it empty.
# WTF, it is so ugly!!! It must be sunxi_mbr.fex & sys_partition.bin,
# not sunxi_mbr_xxx.fex & sys_partition_xxx.bin. In order to advoid this
# loathsome thing, we need to backup & copy files. Check whether
# sys_partition_nor.bin is exist, and create sunxi_mbr.fex for Nor.
local max_toc_size=2097152
local IMG_NAME="${PACK_IC}_${PACK_TYPE}${PACK_PLATFORM_VERSION}_${PACK_BOARD}_${PACK_DEBUG}"
IMG_NAME="${IMG_NAME}_${PACK_MODE}"
fi
if [ "x${PACK_FUNC}" = "xprvt" ]; then
IMG_NAME="${IMG_NAME}_${PACK_FUNC}"
fi
if [ "x${PACK_SECURE}" = "xsecure" ] ; then
IMG_NAME="${IMG_NAME}_${PACK_SECURE}"
fi
if [ "x${PACK_FUNC}" = "xprev_refurbish" ] ; then
fi
IMG_NAME="${IMG_NAME}_${PACK_NOR}"
fi
if [ "x${PACK_SECURE}" != "xnone" ]; then
local MAIN_VERION=$(readcfg dragon_toc.cfg rollback_ver ver)
if [ ! -n "${MAIN_VERION}" ]; then
local MAIN_VERION="$(echo '__unique:;@echo ${MAIN_VERSION}' | make -f - -f ${LICHEE_PACK_OUT_DIR}/version_base.mk --no-print-directory __unique)"
fi
IMG_NAME="${IMG_NAME}_v${MAIN_VERION}.img"
IMG_NAME="${IMG_NAME}.img"
fi
local IMG_PROGRAMMER_NAME="${IMG_NAME%.*}_programmer.img"
echo "imagename = $IMG_NAME" >> ${LICHEE_PACK_OUT_DIR}/image.cfg
echo "" >> ${LICHEE_PACK_OUT_DIR}/image.cfg
local imagesize
local toc_size
local max_toc_size=3883264
toc_size=`stat toc1.fex --format="%s"`
toc_size=`stat boot_package.fex --format="%s"`
fi
if [ "$LICHEE_CHIP" == "sun55iw3p1" ]; then
fi
if [ ${toc_size} -gt ${max_toc_size} ];then
pack_error "boot_package.fex/toc1.fex More than ${max_toc_size} bytes limit too large!!!"
exit 1
fi
NOR_LOGIC_START=2016
NOR_UBOOT_START=128
NOR_FLASH_SIZE=65536 #32M
NOR_LOGIC_START_KB=`expr ${NOR_LOGIC_START} / 2`
NOR_UBOOT_START_KB=`expr ${NOR_UBOOT_START} / 2`
local uboot_dts=""
uboot_dts="${LICHEE_BOARD_CONFIG_DIR}/uboot-${LICHEE_BRANDY_UBOOT_VER}/uboot-board.dts"
uboot_dts="${LICHEE_BOARD_CONFIG_DIR}/uboot-board.dts"
fi
if [ -f ${uboot_dts} ] && [ x"$(grep "nor_map" ${uboot_dts})" != x"" ]; then
echo "get flashmap from ${uboot_dts}"
NOR_FLASH_SIZE=$(awk '/nor_map {/,/}/ {print NR ": " $0}' ${uboot_dts} \
| grep "\bflash_size\b" | grep -oP "(?<=\<)\d+(?=\>)")
NOR_LOGIC_START=$(awk '/nor_map {/,/}/ {print NR ": " $0}' ${uboot_dts} \
| grep "\blogic_offset\b" | grep -oP "(?<=\<)\d+(?=\>)")
NOR_UBOOT_START=$(awk '/nor_map {/,/}/ {print NR ": " $0}' ${uboot_dts} \
| grep "\buboot_start\b" | grep -oP "(?<=\<)\d+(?=\>)")
[ x"${NOR_FLASH_SIZE}" = x"" -o x"${NOR_LOGIC_START}" = x"" -o x"${NOR_UBOOT_START}" = x"" ] && {
pack_warn "flash_size,logic_offset,uboot_start maybe not set in uboot-board.dts"
NOR_UBOOT_START=128
echo "flash size:${NOR_FLASH_SIZE}, logic start:${NOR_LOGIC_START}, uboot start:${NOR_UBOOT_START}"
fi
update_mbr sys_partition_nor.bin 1 sunxi_mbr_nor.fex dlinfo.fex \
${NOR_FLASH_SIZE} ${NOR_LOGIC_START} 1
pack_error "update_mbr failed"
exit 1
fi
echo '----------programmer nor image is full_img.fex ----------'
#when use devicetree, the size of uboot+dtb is larger then 256K
#BOOT1_FILE=u-boot-spinor.fex
#LOGIC_START=240 #240+16=256K
#merge_package full_img.fex boot0_spinor.fex \
# u-boot-spinor.fex sunxi_mbr_nor.fex sys_partition_nor.bin
merge_full_img --out full_img.fex --boot0 boot0_spinor.fex --boot1 u-boot-spinor.fex \
--mbr sunxi_mbr_nor.fex --partition sys_partition_nor.bin \
--logic_start 240 > /dev/null
merge_full_img --out full_img.fex --boot0 boot0_spinor.fex --boot1 boot_package_nor.fex \
--mbr sunxi_gpt.fex --partition sys_partition_nor.bin \
--logic_start ${NOR_LOGIC_START_KB} --uboot_start ${NOR_UBOOT_START_KB} > /dev/null
fi
pack_error "merge_full_img failed"
exit 1
fi
mv sys_partition_nor.fex sys_partition.fex
fi
if [ ! -f sys_partition_nor.bin ]; then
update_mbr sys_partition.bin 4
exit 1
fi
#15269888 is from emmc datasheet, sec_count in Extended CSD is 0xe90000 = 15269888.
#40960 is the mbr location for emmc
#0 is emmc/nand ; 1 is spinor
update_mbr sys_partition.bin 4 sunxi_mbr.fex dlinfo.fex 15269888 40960 0
pack_error "update_mbr_gpt failed"
exit 1
fi
fi
echo "===================================="
echo "show sys_partition.fex message"
show_partition_message sys_partition.fex
fi
local e cfgadd cfgget lastcfgline localfile filename
local imgcfg_add_list=(
# localfile filename-in-cfg maintype subtype
'vmlinux.fex vmlinux.fex 12345678 123456789VMLINUX'
'vendor_boot-debug.fex vendor_boot-debug.fex RFSFAT16 VENDOR_BOOTDEBUG'
'dragon_toc.cfg dragon_toc.fex 12345678 12345678DGTOCCFG'
for e in "${imgcfg_add_list[@]}"; do
localfile="$(awk '{print $1}' <<< $e)"
filename="$(awk '{print $2}' <<< $e)"
maintype="$(awk '{print $3}' <<< $e)"
subtype="$(awk '{print $4}' <<< $e)"
cfgget="$(sed -n '/^\s*{\s*filename\s*=\s*"'$filename'"\s*,/p' image.cfg)"
lastcfgline="$(sed -n '/^\s*{\s*filename\s*=/=' image.cfg | tail -1)"
[ ! -f "$localfile" -o -n "$cfgget" -o -z "$lastcfgline" ] && continue
[ "$localfile" != "$filename" ] && ln -sf $localfile $filename
cfgadd=' {filename = "'$filename'",'
cfgadd+=' maintype = "'$maintype'",'
cfgadd+=' subtype = "'$subtype'",},'
sed -i -e ''"${lastcfgline}"'a\' -e "$cfgadd" image.cfg
done
dragon image.cfg sys_partition.fex
if [ $? -eq 0 ]; then
if [ -e ${IMG_NAME} ]; then
mv ${IMG_NAME} $LICHEE_OUT_DIR/$LICHEE_IC/$LICHEE_BOARD/$LICHEE_LINUX_DEV/${IMG_NAME}
rm -f $LICHEE_OUT_DIR/${IMG_NAME}
ln -f $LICHEE_OUT_DIR/$LICHEE_IC/$LICHEE_BOARD/$LICHEE_LINUX_DEV/${IMG_NAME} $LICHEE_OUT_DIR/${IMG_NAME}
imagesize=$(du --apparent-size -sh $LICHEE_OUT_DIR/$LICHEE_IC/$LICHEE_BOARD/$LICHEE_LINUX_DEV/${IMG_NAME} | awk '{print $1}')
echo '----------image is at----------'
echo -e '\033[0;31;1m'
echo -e "$imagesize\t${LICHEE_OUT_DIR}/${IMG_NAME}"
echo -e '\033[0m'
fi
fi
cd ..
if [ -f $LICHEE_PACK_OUT_DIR/super.fex ]; then
mv $LICHEE_PACK_OUT_DIR/super.fex $LICHEE_PACK_OUT_DIR/super.bak.fex
simg2img $LICHEE_PACK_OUT_DIR/super.bak.fex $LICHEE_PACK_OUT_DIR/super.fex
fi
echo "waiting to ceate programmer img..."
img_to_programmer ${IMG_PROGRAMMER_NAME} $LICHEE_OUT_DIR/${LICHEE_IC}/${LICHEE_BOARD}/${LICHEE_LINUX_DEV}/${IMG_NAME}
if [ -e ${IMG_PROGRAMMER_NAME} ]; then
mv $LICHEE_PACK_OUT_DIR/${IMG_PROGRAMMER_NAME} $LICHEE_OUT_DIR/${LICHEE_IC}/${LICHEE_BOARD}/${LICHEE_LINUX_DEV}/${IMG_PROGRAMMER_NAME}
imagesize=$(du --apparent-size -sh $LICHEE_OUT_DIR/${LICHEE_IC}/${LICHEE_BOARD}/${LICHEE_LINUX_DEV}/${IMG_PROGRAMMER_NAME} | awk '{print $1}')
echo '----------programmer image is at----------'
echo -e "$imagesize\t${LICHEE_OUT_DIR}/${IMG_PROGRAMMER_NAME}"
echo -e '\033[0m'
fi
fi
fi
cd ..
do_finish_SATA
printf "pack finish\n"
[ -e ${LICHEE_TOP_DIR}/build/.hooks/post-dragon ] &&
source ${LICHEE_TOP_DIR}/build/.hooks/post-dragon
return 0
function do_finish_SATA()
if [ "x$BUILD_SATA" = "xtrue" ];then
SATA_TAR=$LICHEE_TOP_DIR/SATA/linux/${LICHEE_CHIP}.tar
if [ -f $SATA_TAR ];then
echo '----------SATA is at----------'
echo $SATA_TAR
echo -e '\033[0m'
echo PACK SATA failed!
fi
fi
function dmverity_deal()
local script_name=scripts/build.sh
local script_path=$LICHEE_KERN_DIR
if [ ! -x $script_path/$script_name ]; then
script_path=$LICHEE_BUILD_DIR
script_name=mkkernel.sh
fi
[ ! -x $script_path/$script_name ] && return 255
[ -z "$(grep "^\s*deal_verity)\s*$" $script_path/$script_name)" ] && return 1
(cd $script_path && ./$script_name "deal_verity" $@)
function dmverity_get_blk_count()
local size=`du --apparent-size -b $1 | awk '{print $1}'`
local BLK_SIZE=$2
if [ `expr ${size} % ${BLK_SIZE}` = "0" ]; then
local blks=`(expr ${size} / ${BLK_SIZE})`
local blks=`(expr ${size} / ${BLK_SIZE} + 1 )`
fi
echo $blks
function dmverity_determ_blk_size()
local type_info=`file -L $1`
#check rootfs file system type to determ block size
if [ "x""`echo ${type_info}| grep "ext4 filesystem"`" != "x" ];then
block_size=`tune2fs -l $1|grep "Block size"|awk {'print $3'}`
echo ${block_size}
echo "not support file system type"
return -1
fi
function dmverity_genHashTable()
local fs_name=$1
local tree_name=$2
local table_name=$3
local block_size=`dmverity_determ_blk_size ${fs_name}`
if [ ${block_size} -lt 0 ];then
return -1
fi
veritysetup format --data-block-size=${block_size} --hash-block-size=${block_size} ${fs_name} ${tree_name} > ${table_name}
return $?
function dmverity_genDownloadFile()
local fs_name=$1
local sign_name=$2
local table_name=$3
local tree_name=$4
local download_file_name=$5
local BLK_SIZE=`dmverity_determ_blk_size ${fs_name}`
if [ ${BLK_SIZE} -lt 0 ];then
return -1
fi
local SIGN_BLK=`dmverity_get_blk_count ${sign_name} ${BLK_SIZE}`
local TABLE_BLK=`dmverity_get_blk_count ${table_name} ${BLK_SIZE}`
local TREE_BLK=`dmverity_get_blk_count ${tree_name} ${BLK_SIZE}`
# 3.1 copy sign
dd if=${sign_name} of=${download_file_name}"tmp" bs=${BLK_SIZE} count=${SIGN_BLK} >/dev/null 2>&1
# 3.2 copy table size
local TABLE_SIZE=`du --apparent-size -b ${table_name} | awk '{print $1}'`
local HIGH_BYTES=`expr $TABLE_SIZE / 256 `
local LOW_BYTES=`expr $TABLE_SIZE % 256 `
if [ $HIGH_BYTES -gt 256 ]; then
echo "ERROR rootfs_hash_table size should < 64KB"
return -1
fi
local HIGH_BYTES_H=`echo "obase=16;ibase=10;$HIGH_BYTES" | bc`
local LOW_BYTES_H=`echo "obase=16;ibase=10;$LOW_BYTES" | bc`
echo -e -n "\x$LOW_BYTES_H\x$HIGH_BYTES_H" >> ${download_file_name}"tmp"
# 3.3 copy rootfs_hash_table
dd if=${table_name} of=${download_file_name}"tmp" bs=${BLK_SIZE} seek=${SIGN_BLK} count=${TABLE_BLK} > /dev/null 2>&1
# 3.4 copy rootfs_hash_tree.bin
dd if=${tree_name} of=${download_file_name}"tmp" bs=${BLK_SIZE} seek=`expr ${SIGN_BLK} + ${TABLE_BLK}` count=${TREE_BLK} > /dev/null 2>&1
dd of=${download_file_name} if=${download_file_name}"tmp" bs=${BLK_SIZE} count=`expr ${SIGN_BLK} + ${TABLE_BLK} + ${TREE_BLK}`>/dev/null 2>&1
rm ${download_file_name}"tmp"
function do_signature_dsp()
local DSP0_BIN=${LICHEE_PACK_OUT_DIR}/amp_dsp0.fex;
local DSP1_BIN=${LICHEE_PACK_OUT_DIR}/amp_dsp1.fex;
local CFG_FILE=${LICHEE_CHIP_CONFIG_DIR}/configs/default/image_header_secure.cfg;
if [ -f ${CFG_FILE} ] ; then
cp -v ${CFG_FILE} image_header_secure.cfg
printf "can not found image_header_secure cfg\n"
return 1
fi
if [ -f ${DSP0_BIN} ] ; then
mkimage_header -C 5 -c image_header_secure.cfg -s rsa -k $CFG_KEY_DIR
if [ $? -ne 0 ]
then
pack_error "mkimage_header signature dsp error\n"
exit 1
fi
mv amp_dsp0.fex.pack amp_dsp0.fex
printf "can not found amp_dsp0 bin\n"
return 3
fi
if [ -f ${DSP1_BIN} ] ; then
fi
function do_signature_riscv()
local RV0_BIN=${LICHEE_PACK_OUT_DIR}/amp_rv0.fex;
local RV1_BIN=${LICHEE_PACK_OUT_DIR}/amp_rv1.fex;
local key_type=$(readcfg dragon_toc.cfg key_para key_toc1 | cut -c 1-3)
if [ x${key_type} == "xecc" ]; then
sign_alg=ecc
sign_alg=rsa
fi
return 1
fi
if [ -f ${RV0_BIN} ] ; then
mkimage_header -C 5 -c image_header_secure.cfg -s $sign_alg -k $CFG_KEY_DIR
if [ $? -ne 0 ]
then
pack_error "mkimage_header signature rv error\n"
exit 1
fi
mv amp_rv0.fex.pack amp_rv0.fex
printf "can not found amp_rv0 bin\n"
return 3
fi
if [ -f ${RV1_BIN} ] ; then
mv amp_rv1.fex.pack amp_rv1.fex
fi
function do_signature_ft()
if [ ! -e ${LICHEE_PACK_OUT_DIR}/ft_${PACK_CHIP}.bin ]; then
printf "can not found ft bin\n"
return 1
fi
if [ -e ${LICHEE_PACK_OUT_DIR}/dragon_toc_ft.cfg ]; then
printf "can not found dragon_toc_ft cfg\n"
fi
printf "prepare for signature for ft bin\n"
mv ${LICHEE_PACK_OUT_DIR}/ft_${PACK_CHIP}.bin ${LICHEE_PACK_OUT_DIR}/ft.bin
dragonsecboot -toc0 dragon_toc_ft.cfg $CFG_KEY_DIR ${LICHEE_PACK_OUT_DIR}/version_base.mk > /dev/null
pack_error "dragon toc0_ft run error\n"
exit 1
fi
mv toc0.fex toc0_ft.fex
function do_signature_fel()
printf "prepare for signature for fex tools\n"
local ROOT_KEY_NAME="";
local UBOOT_NAME="u-boot";
local sign_tools=$(readcfg dragon_toc.cfg sign_fel_tools sign_tools)
if [ -f u-boot-efex.fex ]; then
UBOOT_NAME="u-boot-efex"
fi
echo UBOOT_NAME ${UBOOT_NAME}
if [ x${sign_tools} == "xdragonsboot" ]; then
printf "using dragonsboot to sign fel\n"
if [ -f ${CFG_KEY_DIR}/RootKey_Level_0.pem ]; then
ROOT_KEY_NAME=${CFG_KEY_DIR}/RootKey_Level_0.pem
elif [ -f ${CFG_KEY_DIR}/Trustkey.pem ]; then
ROOT_KEY_NAME=${CFG_KEY_DIR}/Trustkey.pem
pack_error "can not found root key to sign fex tool"
exit 1
fi
echo rootkeyname ${ROOT_KEY_NAME}
dragonsecboot -sign fes1.fex ${ROOT_KEY_NAME} ${LICHEE_PACK_OUT_DIR}/version_base.mk > /dev/null
dragonsecboot -sign ${UBOOT_NAME}.fex ${ROOT_KEY_NAME} ${LICHEE_PACK_OUT_DIR}/version_base.mk > /dev/null
if [ $? -ne 0 ]
then
pack_error "dragonsecboot uboot fail"
fi
fi
printf "using sig_fel_image to sign fel\n"
if [ -f ${CFG_KEY_DIR}/RootKey_Level_0.bin ]; then
ROOT_KEY_NAME=${CFG_KEY_DIR}/RootKey_Level_0.bin
elif [ -f ${CFG_KEY_DIR}/Trustkey.bin ]; then
ROOT_KEY_NAME=${CFG_KEY_DIR}/Trustkey.bin
exit 1
fi
sig_fel_image --input fes1.fex --rsakey ${ROOT_KEY_NAME} --output fes1_sign.fex --version_base ${LICHEE_PACK_OUT_DIR}/version_base.mk
if [ $? -ne 0 ]
then
pack_error "sig_fel_image fes fail"
exit 1
fi
sig_fel_image --input ${UBOOT_NAME}.fex --rsakey ${ROOT_KEY_NAME} --output ${UBOOT_NAME}_sign.fex --version_base ${LICHEE_PACK_OUT_DIR}/version_base.mk
if [ $? -ne 0 ]
then
pack_error "sig_fel_image uboot fail"
fi
fi
if [ -f fes1_sign.fex ]; then
cp fes1_sign.fex fes1.fex
fi
if [ -f ${UBOOT_NAME}_sign.fex ]; then
cp ${UBOOT_NAME}_sign.fex ${UBOOT_NAME}.fex
fi
function readcfg()
local fid=$1
local section=$2
local option=$3
test ! -f $fid && echo "file not exits:$fid" && exit 1
if [ $# -eq 3 ] ; then
local src=$(cat $fid | awk '/\['$section'\]/{f=1;next} /\[*\]/{f=0} f' |
grep ^$option |
grep '=' |
cut -d'=' -f2|
cut -d'#' -f1|
cut -d';' -f1|
awk '{gsub(/^\s+|\s+$/, "");print}')
echo -n $src
test ${#src} -eq 0 && return 1 || return 0
echo "the input parameters should be 3"
exit 1
fi
function get_item_from_cfg()
name=()
bin=()
cert=()
counts=0
local toc_cfg=$1
local field=$2
local key=$3
toc1_item_content=$(readcfg ${toc_cfg} ${field} ${key})
i=0
IFS=', ' read -r -a parts <<< $toc1_item_content
for part in "${parts[@]}"; do
if [ $(($i % 3)) -eq 0 ]; then
name[counts]=$part
elif [ $(($i % 3)) -eq 1 ]; then
bin[counts]=$part
cert[counts]=$part
counts=$((counts + 1))
fi
i=$((i + 1))
done
function create_toc0()
local toc_cfg=$1
local key=""
local cert_type=""
local key_type=""
local psck_mode=""
rm -rf toc0
if [ ! -d "toc0" ]; then
mkdir -p toc0
fi
if [ ! -d "temp" ]; then
mkdir -p temp
fi
get_item_from_cfg ${toc_cfg} toc0 item
key=$(readcfg ${toc_cfg} key_toc0 ${name[0]})
cert_type=$(readcfg ${toc_cfg} cert_type cert_type_toc0)
key_type=$(readcfg ${toc_cfg} key_para key_toc0 | cut -c 1-3)
if [ x${key_type} == "xrsa" ]; then
psck_mode=RSA-PKCS
elif [ x${key_type} == "xecc" ]; then
psck_mode=ECDSA
pack_error "key_toc0 type error"
exit 1
fi
#gen sboot hash
dragon_securetool hash --mode 256 --in ${bin[0]} --out ./temp/${bin[0]}.hash.out
if [ $? -ne 0 ]
then
pack_error "gen sboot hash error"
exit 1
fi
#req no sign cert, ext is sboot_hash; use pubkey
dragon_securetool req_cert --type ${cert_type} --cfg ${toc_cfg} --pubkey ${CFG_KEY_DIR}/${key}.pem.pub --ext ./temp/${bin[0]}.hash.out --out ./temp/${name[0]}.req
if [ $? -ne 0 ]
then
pack_error "req no sign cert for toc0 error"
exit 1
fi
#gen no sign cert hash, witch is to be signed
dragon_securetool hash --mode 256 --type ${cert_type} --in ./temp/${name[0]}.req --out ./temp/${name[0]}.req.hash
if [ $? -ne 0 ]
then
pack_error "gen no sign cert hash for toc0 error"
exit 1
fi
#sign cert(to be signed) hash
if [ "x$SOFTHSM_FLAG" == "x1" ]; then
local id=$(echo "$key" | md5sum | awk '{print $1}')
pkcs11-tool --label ${key} --id ${id} -s -p ${PIN} -m ${psck_mode} --module ${MODULES} --input-file ./temp/${name[0]}.req.hash --output-file ./temp/${name[0]}.req.sign
if [ $? -ne 0 ]
then
pack_error "softhsm sign cert(to be signed) hash for toc0 error"
exit 1
fi
dragon_securetool sign --cfg ${toc_cfg} --privatekey ${CFG_KEY_DIR}/${key}.pem --in ./temp/${name[0]}.req.hash --out ./temp/${name[0]}.req.sign
if [ $? -ne 0 ]
then
pack_error "sign cert(to be signed) hash for toc0 error"
exit 1
fi
fi
#create cert with sign
dragon_securetool create_cert --type ${cert_type} --cfg ${toc_cfg} --pubkey ${CFG_KEY_DIR}/${key}.pem.pub --reqfile ./temp/${name[0]}.req --signfile ./temp/${name[0]}.req.sign --out ./toc0/${cert[0]}
if [ $? -ne 0 ]
then
pack_error "create cert with sign for toc0 error"
exit 1
fi
#create toc0.fex(toc0_head + sboot.crtpt + sboot)
dragon_securetool create_toc0 --cfg ${toc_cfg} --out ./toc0.fex
if [ $? -ne 0 ]
then
pack_error "dragon toc0 run error"
exit 1
fi
function do_signature_sboot()
local sboot_file=$1;
local flash_type=$2;
#dram_param
if [ -f ${LICHEE_TOOLS_DIR}/pack/pctools/linux/mod_update/update_sboot ]; then
update_sboot $sboot_file sys_config.bin > /dev/null
if [ $? -ne 0 ]
then
exit 1
fi
fi
update_chip $sboot_file > /dev/null
#dragon_toc only load sboot.bin
[ "$(readlink -f $sboot_file)" != "$(readlink -f sboot.bin)" ] && \
mv $sboot_file sboot.bin
#readcfg determines whether the cfg file is legacy or new
readcfg dragon_toc.cfg key_para key > /dev/null
dragonsecboot -toc0 dragon_toc.cfg $CFG_KEY_DIR ${LICHEE_PACK_OUT_DIR}/version_base.mk > /dev/null
if [ $? -ne 0 ]
then
exit 1
fi
create_toc0 dragon_toc.cfg
fi
update_toc0 toc0.fex sys_config.bin
if [ $? -ne 0 ]
then
pack_error "update toc0 run error"
exit 1
fi
mv sboot.bin $sboot_file
if [ -f toc0_$flash_type.fex ]; then
rm -rf toc0_$flash_type.fex
fi
mv toc0.fex toc0_$flash_type.fex
mv toc0 toc0_$flash_type
function do_signature_toc0()
if [ -f sboot.bin ]; then
do_signature_sboot sboot.bin bak
mv sboot.bin sboot_bak.bin
fi
if [ -f sboot_sdcard.bin ]; then
if [ -f cardscript.fex ]; then
sed -i "s/TOC0_00000000000/TOC0_SDCARD00000/g" cardscript.fex
fi
do_signature_sboot sboot_sdcard.bin sdcard
fi
if [ -f sboot_nand.bin ]; then
do_signature_sboot sboot_nand.bin nand
fi
if [ -f sboot_ufs.bin ]; then
do_signature_sboot sboot_ufs.bin ufs
fi
if [ -f sboot_nor.bin ]; then
do_signature_sboot sboot_nor.bin nor
fi
mv sboot_bak.bin sboot.bin
mv toc0_bak.fex toc0.fex
mv toc0_bak toc0
function toc1_create_cert_for_per_bin()
local toc_cfg=$1
local key=""
local cert_type=""
local key_type=""
local psck_mode=""
cert_type=$(readcfg ${toc_cfg} cert_type cert_type_toc1)
key_type=$(readcfg ${toc_cfg} key_para key_toc1 | cut -c 1-3)
psck_mode=RSA-PKCS
psck_mode=ECDSA
pack_error "key_toc1 type error"
exit 1
fi
for ((count=0; count < counts; count++)); do
key=$(readcfg ${toc_cfg} key_toc1 ${name[count]})
#gen ${bin[count]} hash
dragon_securetool hash --mode 256 --in ${bin[count]} --out temp/${name[count]}_hash.out
if [ $? -ne 0 ]
then
pack_error "gen hash ${name[count]} error"
exit 1
fi
dragon_securetool req_cert --type ${cert_type} --cfg ${toc_cfg} --pubkey ${CFG_KEY_DIR}/$key.pem.pub --ext temp/${name[count]}_hash.out --out temp/${cert[count]}.req
if [ $? -ne 0 ]
then
pack_error "req no sign cert ${name[count]} error"
exit 1
fi
dragon_securetool hash --mode 256 --type ${cert_type} --in temp/${cert[count]}.req --out temp/to_be_signed_${name[count]}_hash.out
if [ $? -ne 0 ]
then
pack_error "gen no sign cert hash ${name[count]} error"
exit 1
fi
pkcs11-tool --label ${key} --id ${id} -s -p ${PIN} -m ${psck_mode} --module ${MODULES} --input-file temp/to_be_signed_${name[count]}_hash.out --output-file temp/${name[count]}_sign.out
if [ $? -ne 0 ]
then
pack_error "softhsm sign cert(to be signed) hash ${name[count]} error"
exit 1
fi
dragon_securetool sign --cfg ${toc_cfg} --privatekey ${CFG_KEY_DIR}/$key.pem --in temp/to_be_signed_${name[count]}_hash.out --out temp/${name[count]}_sign.out
if [ $? -ne 0 ]
then
pack_error "sign cert(to be signed) hash ${name[count]} error"
exit 1
fi
fi
dragon_securetool create_cert --type ${cert_type} --cfg ${toc_cfg} --pubkey ${CFG_KEY_DIR}/${key}.pem.pub --reqfile temp/${cert[count]}.req --signfile temp/${name[count]}_sign.out --out toc1/cert/${cert[count]}
if [ $? -ne 0 ]
then
pack_error "create cert with sign ${name[count]} error"
exit 1
fi
done
function toc1_create_cert_for_rootkey()
local toc_cfg=$1
local key=""
local cert_type=""
local key_type=""
local psck_mode=""
get_item_from_cfg ${toc_cfg} toc1 rootkey
key=$(readcfg ${toc_cfg} key_toc0 rootkey)
psck_mode=RSA-PKCS
psck_mode=ECDSA
exit 1
fi
#rootkey no sign cert
#req no sign rootkey cert, insert extensions in the dragon_toc.cfg; use pubkey
dragon_securetool req_rootkey_cert --type ${cert_type} --cfg ${toc_cfg} --keypath ${CFG_KEY_DIR} --pubkey ${CFG_KEY_DIR}/${key}.pem.pub
if [ $? -ne 0 ]
then
pack_error "req rootkey cert error"
exit 1
fi
mv toc1/cert/${cert[0]} temp/${cert[0]}.req
#gen no sign rootkey cert hash, witch is to be signed; Non-x509 certificates do not need to skip 4 bytes
dragon_securetool hash --mode 256 --type ${cert_type} --in temp/${cert[0]}.req --out temp/to_be_signed_${name[0]}_hash.out
if [ $? -ne 0 ]
then
pack_error "gen no sign rootkey cert hash error"
exit 1
fi
#sign rootkey cert(to be signed) hash
pkcs11-tool --label ${key} --id ${id} -s -p ${PIN} -m ${psck_mode} --module ${MODULES} --input-file temp/to_be_signed_${name[0]}_hash.out --output-file temp/${name[0]}_sign.out
if [ $? -ne 0 ]
then
pack_error "softhsm sign rootkey cert(to be signed) hash error"
exit 1
fi
dragon_securetool sign --cfg ${toc_cfg} --privatekey ${CFG_KEY_DIR}/${key}.pem --in temp/to_be_signed_${name[0]}_hash.out --out temp/${name[0]}_sign.out
if [ $? -ne 0 ]
then
pack_error "sign rootkey cert(to be signed) hash error"
exit 1
fi
fi
#create rootkey cert with sign
dragon_securetool create_cert --type ${cert_type} --cfg ${toc_cfg} --pubkey ${CFG_KEY_DIR}/${key}.pem.pub --reqfile temp/${cert[0]}.req --signfile temp/${name[0]}_sign.out --out toc1/cert/${cert[0]}
if [ $? -ne 0 ]
then
pack_error "create rootkey cert with sign error"
exit 1
fi
function do_signature_toc1()
rm -rf toc1
if [ ! -d "toc1/cert" ]; then
mkdir -p toc1/cert
fi
mkdir -p temp
fi
#create cert for toc1 item
get_item_from_cfg dragon_toc.cfg toc1 item
toc1_create_cert_for_per_bin dragon_toc.cfg
#create cert for toc1 onlykey
get_item_from_cfg dragon_toc.cfg toc1 onlykey
toc1_create_cert_for_rootkey dragon_toc.cfg
#create toc1.fex(toc1_head + rootkey.crtpt + ..)
dragon_securetool create_toc1 --cfg dragon_toc.cfg --out toc1.fex
if [ $? -ne 0 ]
then
pack_error "dragon toc1 run error"
exit 1
fi
function do_signature()
printf "prepare for signature by openssl\n"
if [ ! -d $CFG_KEY_DIR ] ; then
pack_error "No key exist, please run './build/createkeys' to generate keys first."
exit 1
fi
if [ "x${PACK_SIG}" = "xprev_refurbish" ] ; then
if [ "x${LICHEE_ARCH}" = "xarm64" ] ; then
cp -v ${LICHEE_COMMON_CONFIG_DIR}/sign_config/dragon_toc_a64_no_secureos.cfg dragon_toc.cfg
cp -v ${LICHEE_COMMON_CONFIG_DIR}/sign_config/dragon_toc_no_secureos.cfg dragon_toc.cfg
fi
if [ -f ${LICHEE_CHIP_CONFIG_DIR}/configs/default/dragon_toc.cfg ] ; then
cp -v ${LICHEE_CHIP_CONFIG_DIR}/configs/default/dragon_toc.cfg dragon_toc.cfg
cp -v ${LICHEE_COMMON_CONFIG_DIR}/sign_config/dragon_toc_a64.cfg dragon_toc.cfg
fi
cp -v ${LICHEE_COMMON_CONFIG_DIR}/sign_config/dragon_toc.cfg dragon_toc.cfg
fi
fi
fi
fi
if [ -f ${CFG_KEY_DIR}/softhsm2.cfg ]; then
# fix tokendir
tokendir=$(grep tokendir ${CFG_KEY_DIR}/softhsm2.cfg | awk '{print $3}')
if [ "x$tokendir" != "x${CFG_KEY_DIR}/.token" ]; then
sed -i "s#${tokendir}#${CFG_KEY_DIR}/.token#g" ${CFG_KEY_DIR}/softhsm2.cfg
fi
PIN=1234
SOPIN=12345678
SOFTHSM_TOOLS_DIR=${LICHEE_TOOLS_DIR}/pack/pctools/linux/softhsm
MODULES=${SOFTHSM_TOOLS_DIR}/lib/softhsm/libsofthsm2.so
export LD_LIBRARY_PATH=${SOFTHSM_TOOLS_DIR}/lib:${SOFTHSM_TOOLS_DIR}/lib/softhsm:${LIB_LIBRARY_PATH}
export PATH=${SOFTHSM_TOOLS_DIR}/bin:$PATH
export SOFTHSM2_CONF=${CFG_KEY_DIR}/softhsm2.cfg
SOFTHSM_FLAG=1
fi
if [ $? -ne 0 ]
then
pack_error "dragon toc config file is not exist"
exit 1
fi
rm -f cardscript.fex
mv cardscript_secure.fex cardscript.fex
if [ $? -ne 0 ]
then
pack_error "dragon cardscript_secure.fex file is not exist"
exit 1
fi
if [ ! -f ${LICHEE_PLAT_OUT}/recovery.img ]; then
printf "recovery img is not exist, remove recovery cert from dragon_toc.cfg\n"
sed -i '/recovery/d' dragon_toc.cfg > /dev/null
local recovery_buf=$(grep "recovery" -nr dragon_toc.cfg)
if [ x"${recovery_buf}" = x"" ]; then
sed -i '/^onlykey=boot/a\onlykey=recovery, recovery.fex, SCPFirmwareContentCertPK' dragon_toc.cfg
sed -i '/^boot=/a recovery=NonTrustedFirmwareContentCertPK' dragon_toc.cfg
sed -i '/^onlykey=boot/a\onlykey=recovery, recovery.fex, recovery.crtpt' dragon_toc.cfg
fi
fi
fi
if [ "x${PACK_VERITY}" = "x${FLAGS_TRUE}" ]; then
# verity setup for squashfs type filesystem
if [ x"${PACK_PLATFORM}" = x"openwrt" ] || [ x"${PACK_PLATFORM}" = x"bsp" ] || [ x"${PACK_PLATFORM}" = x"buildroot" ]; then
rm -rf rootfs.fex
local link_real_new=$(get_realpath ${LICHEE_PLAT_OUT} ./)
cp ${link_real_new}/rootfs.img rootfs.fex
cp ${link_real_new}/rootfs.squashfs rootfs.fex
fi
if [ "x${PACK_KERN}" == "xlinux-5.4" \
-o "x${PACK_KERN}" == "xlinux-5.15-origin" ]; then
squashfs_real_size=`hexdump -s 0x28 -n 4 -e '/4 "%d"' rootfs.fex`
squashfs_data_blocks=`expr \( ${squashfs_real_size} + 4095 \) / 4096`
local TEMP=${LC_ALL}
export LC_ALL=C
veritysetup --data-blocks=${squashfs_data_blocks} format rootfs.fex hash_tree > raw_table
export LC_ALL=${TEMP}
sed -i '/^onlykey=boot/a\onlykey=rootfs, hash_tree, SCPFirmwareContentCertPK' dragon_toc.cfg
sed -i '/^boot=/a rootfs=NonTrustedFirmwareContentCertPK' dragon_toc.cfg
sed -i '/^onlykey=boot/a\onlykey=rootfs, hash_tree, rootfs.crtpt' dragon_toc.cfg
fi
# get sample from squashfs rootfs
local rootfs_per_MB=`grep "^rootfs_per_MB=" env.cfg | awk -F = '{printf $2}'`
if [ -z $rootfs_per_MB ]; then
echo "rootfs_per_MB is not defined in env.cfg, use default value 4096"
rootfs_per_MB=4096
fi
extract_squashfs $rootfs_per_MB rootfs.fex rootfs-extract.fex
echo "extract squashfs error"
exit 1;
fi
sed -i '/^onlykey=boot/a\onlykey=rootfs, rootfs-extract.fex, SCPFirmwareContentCertPK' dragon_toc.cfg
sed -i '/^onlykey=boot/a\onlykey=rootfs, rootfs-extract.fex, rootfs.crtpt' dragon_toc.cfg
fi
fi
# generate verity data, suport more different filesystem in the future
(dmverity_genHashTable rootfs.fex rootfsHashTree.fex rootfsHashTable.fex &&
openssl dgst -sha256 -binary -sign $CFG_KEY_DIR/SCPFirmwareContentCertPK.pem rootfsHashTable.fex > rootfsHashSign.fex &&
openssl rsa -in $CFG_KEY_DIR/SCPFirmwareContentCertPK.pem -pubout -out rootfsPubKey.pk &&
dmverity_genDownloadFile rootfs.fex rootfsHashSign.fex rootfsHashTable.fex rootfsHashTree.fex VerityInfo.fex) ||
{ pack_error "generate verity data failed"; exit 1; }
# add partition for verity data
(add_partition -2 rootfsverityInfo 4096 "VerityInfo.fex" &&
maybe_busybox unix2dos sys_partition.fex &&
script sys_partition.fex > /dev/null) ||
{ pack_error "add verity info part failed"; exit 1; }
# add verity tools into ramdisk
local rootfsPath=`readlink -f rootfs.fex`
local keyPath=`readlink -f rootfsPubKey.pk`
local blockSize=`dmverity_determ_blk_size ${rootfsPath}`
dmverity_deal $blockSize rootfsverityInfo ext4 $keyPath ||
{ pack_error "deal verity utils failed"; exit 1; }
fi
fi
if [ "x${PACK_SIGNFEL}" = "x${FLAGS_TRUE}" ]; then
do_signature_fel
fi
do_signature_ft
do_signature_toc0
dragonsecboot -toc1 dragon_toc.cfg $CFG_KEY_DIR ${LICHEE_PACK_OUT_DIR}/cnf_base.cnf ${LICHEE_PACK_OUT_DIR}/version_base.mk
if [ $? -ne 0 ]
then
exit 1
fi
cert=".der"
do_signature_toc1
cert=".crtpt"
fi
sigbootimg --image boot.fex --cert toc1/cert/boot${cert} --output boot_sig.fex
if [ $? -ne 0 ] ; then
pack_error "Pack cert to image error"
exit 1
mv -f boot_sig.fex boot.fex
fi
do_signature_dsp
do_signature_riscv
verity_root_hash_str=`grep "Root hash:" raw_table | awk '{print $3}'`
verity_salt_str=`grep "Salt:" raw_table | awk '{print $2}'`
update_squashfs_verity -f rootfs.fex -c toc1/cert/rootfs${cert} -t hash_tree -r ${verity_root_hash_str} -s ${verity_salt_str}
pack_error "add verity block error."
exit 1
fi
update_squashfs rootfs.fex toc1/cert/rootfs${cert}
if [ $? -ne 0 ]
then
pack_error "signature squashfs rootfs error."
exit 1
fi
fi
fi
fi
local link_real=$(get_realpath ${LICHEE_PLAT_OUT} ./)
local recovery_path=${link_real}/recovery.img
if [ -f "$recovery_path" ]; then
sigbootimg --image recovery.fex --cert toc1/cert/recovery${cert} --output recovery_sig.fex
exit 1
mv -f recovery_sig.fex recovery.fex
fi
fi
echo "secure signature ok!"
function do_android_signature()
line_num=`sed -n -e "/default.dtbo/=" dragon_toc.cfg`
sed -i "$line_num s/^/;/g" dragon_toc.cfg
fi
then
sed -i "s/default.dtbo/$LINUX_DTBO_FILE/g" dragon_toc.cfg
fi
fi
fi
if [ $? -ne 0 ]
then
exit 1
fi
if [ $? -ne 0 ]
then
exit 1
fi
do_signature_ft
do_signature_toc0
if [ $? -ne 0 ]
then
exit 1
fi
cert=".der"
do_signature_toc1
cert=".crtpt"
fi
if [ -e dboot.fex ]; then
local keyname=$(awk -F, '/^[[:space:]]*onlykey=boot\S*,[[:space:]]*dboot.fex,/{print $1}' dragon_toc.cfg | awk -F= '{print $2}')
sigbootimg --image dboot.fex --cert toc1/cert/${keyname}${cert} --output dboot_sig.fex
[ $? -ne 0 ] && pack_error "Pack cert to image error" && exit 1
mv -f dboot_sig.fex dboot.fex
fi
echo "secure android signature ok!"
################################ Tina func ################################
function get_partition_downfile_size()
local downloadfile_name=`echo $1 | awk -F '=' '{print $2}'`
if [ x${downloadfile_name: 0-4} != x".fex" ]; then
pack_error "downloadfile format is wrong, it should be end with .fex"
exit -1
fi
if [ ! -f ${downloadfile_name} ]; then
echo " file ${downloadfile_name} not find"
if [ -L ${downloadfile_name} ]; then
local downloadfile_name_link=`readlink -f ${downloadfile_name}`
local linkfile_name=${downloadfile_name_link##*/}
echo " ${downloadfile_name} -> ${downloadfile_name_link}"
if [ ! -f ${downloadfile_name_link} ]; then
echo " link file ${linkfile_name} not find"
local linkfile_size=`ls -lh ${downloadfile_name_link} | awk '{print $5}'`
echo " ${linkfile_name} size : ${linkfile_size} byte"
fi
local downloadfile_size=`ls -lh ${downloadfile_name} | awk '{print $5}'`
echo " ${downloadfile_name} size : ${downloadfile_size} byte"
fi
fi
function get_partition_mbr_size()
local partition_size_name=`echo $1 | awk -F '=' '{print $1}' | sed 's/partition/mbr/g'`
local partition_size=`echo $1 | awk -F '=' '{print $2}'`
echo " ${partition_size_name} : ${partition_size} Kbyte"
function show_partition_message()
grep -c '[mbr]' $1 > /dev/null
cp $1 ./show_sys_partition.tmp;
sed -i '/^[\r;]/d' ./show_sys_partition.tmp;
sed -i '/partition_start/d' ./show_sys_partition.tmp;
sed -i '/user_type/d' ./show_sys_partition.tmp;
sed -i 's/\[partition\]/------------------------------------/g' ./show_sys_partition.tmp;
sed -i 's/[ "\r]//g' ./show_sys_partition.tmp;
sed -i '/^[;]/d' ./show_sys_partition.tmp;
sed -i 's/name/partition_name/g' ./show_sys_partition.tmp;
sed -i 's/size/partition_size/g' ./show_sys_partition.tmp;
echo "------------------------------------"
while read line
do
if [ "$line" == "------------------------------------" ];then
echo "$line"
echo " $line" | sed 's/=/ : /g'
echo " $line" | grep "mbr" >> /dev/null
read line
get_partition_mbr_size $line
fi
echo "$line" | grep "downloadfile" >> /dev/null
get_partition_downfile_size $line
fi
fi
done < ./show_sys_partition.tmp
rm ./show_sys_partition.tmp
echo "==========input is not a partition file=========="
fi
function sparse_ext4()
local img=$1
local sparse_img=$2
if file $img | grep -q ext4 ;then
echo "now make sparse ext4 img: $img"
echo "$img is not ext4 img"
file $img
return
fi
img2simg $img $sparse_img
# pack user resources to a vfat filesystem
# To use this, please add a folder "user-resource" in configs to save files, and add a partition to sys_partition.fex/sys_partition_nor.fex like this:
# [partition]
# name = user-res
# size = 1024 //size should be 32 aligned
# downloadfile = "user-resource.fex"
# user_type = 0x8000
function make_user_res()
printf "make user resource for : $1\n"
local USER_RES_SYS_PARTITION=$1
local USER_RES_PART_NAME=user-res
local USER_RES_FILE=user-resource
printf "handle partition ${USER_RES_PART_NAME}\n"
local USER_RES_PART_DOWNLOAD_FILE=user-resource.fex
local USER_RES_PART_SIZE=`sed -n "/${USER_RES_PART_NAME}/{N;p}" ${USER_RES_SYS_PARTITION} | awk '$0~"size"{print $3/2}'`
local USER_RES_FILE_PATH=$CFG_TOP_DIR/${PACK_PLATFORM}/target/$PACK_IC/$PACK_IC-${PACK_BOARD}/configs/${USER_RES_FILE}
if [ x"${USER_RES_PART_DOWNLOAD_FILE}" != x"" -a x"${USER_RES_PART_SIZE}" != x"" ]; then
rm -f ${LICHEE_PACK_OUT_DIR}/user-resource.fex
mkfs.vfat ${LICHEE_PACK_OUT_DIR}/user-resource.fex -C ${USER_RES_PART_SIZE}
if [ -d ${USER_RES_FILE_PATH} ]; then
USER_RES_FILE_SIZE=`du --apparent-size --summarize "${USER_RES_FILE_PATH}" | awk '{print $1}'`
printf "file size: ${USER_RES_FILE_SIZE}\n"
printf "partition size: ${USER_RES_PART_SIZE}\n"
if [ ${USER_RES_PART_SIZE} -le ${USER_RES_FILE_SIZE} ]; then
printf "file size is larger than partition size, please check your configuration\n"
printf "please enlarge size of ${USER_RES_PART_NAME} in sys_partition or remove some files in $USER_RES_FILE_PATH\n"
exit -1
fi
mcopy -s -v -i ${LICHEE_PACK_OUT_DIR}/${USER_RES_PART_DOWNLOAD_FILE} ${USER_RES_FILE_PATH}/* ::
printf "mcopy file fail, exit\n"
exit -1
fi
printf "can not find ${USER_RES_FILE_PATH}, ignore it\n"
fi
printf "no user resource partitions\n"
fi
#[partition]
# name = app
# size = 10080
# downloadfile = "app.fex"
function make_app_res()
local APP_PART_NAME=app
cp $1 sys_partition_tmp_app.fex
sed -i '/^[ \t]*downloadfile/d' sys_partition_tmp_app.fex
maybe_busybox unix2dos sys_partition_tmp_app.fex
script sys_partition_tmp_app.fex > /dev/null
update_mbr sys_partition_tmp_app.bin 1 sunxi_mbr_tmp_app.fex > /dev/null
local APP_PART_DOWNLOAD_FILE=app.fex
local APP_PART_FILE_PATH=$CFG_TOP_DIR/out/$PACK_IC/$PACK_BOARD/$PACK_PLATFORM/build_dir/target/app
local APP_PART_SIZE_IN_SECTOR=`parser_mbr sunxi_mbr_tmp_app.fex get_size_by_name ${APP_PART_NAME}`
local TINA_TOOLS_PATH=$CFG_TOP_DIR/out/$PACK_IC/$PACK_BOARD/$PACK_PLATFORM/staging_dir/host/bin
if [ x${APP_PART_DOWNLOAD_FILE} != x'' -a x${APP_PART_SIZE_IN_SECTOR} != x'' ]; then
let APP_PART_SIZE_IN_K=$APP_PART_SIZE_IN_SECTOR/2
echo "APP_PART_DOWNLOAD_FILE = ${LICHEE_PACK_OUT_DIR}/${APP_PART_DOWNLOAD_FILE}"
rm -f ${LICHEE_PACK_OUT_DIR}/${APP_PART_DOWNLOAD_FILE}
${TINA_TOOLS_PATH}/make_ext4fs -l ${APP_PART_SIZE_IN_K}k -b 1024 -m 0 -j 1024 ${LICHEE_PACK_OUT_DIR}/${APP_PART_DOWNLOAD_FILE} ${APP_PART_FILE_PATH}
printf "no app resource partitions\n"
fi
#[partition]
# name = data
# size = 10080
# downloadfile = "data.fex"
function make_data_res()
local DATA_PART_NAME=data
cp $1 sys_partition_tmp_data.fex
sed -i '/^[ \t]*downloadfile/d' sys_partition_tmp_data.fex
maybe_busybox unix2dos sys_partition_tmp_data.fex
script sys_partition_tmp_data.fex > /dev/null
update_mbr sys_partition_tmp_data.bin 1 sunxi_mbr_tmp_data.fex > /dev/null
local DATA_PART_DOWNLOAD_FILE=data.fex
local DATA_PART_DOWNLOAD_FILE_SPARSE=data_s.fex
local DATA_PART_FILE_PATH=$CFG_TOP_DIR/out/$PACK_IC/$PACK_BOARD/$PACK_PLATFORM/build_dir/target/data
local DATA_PART_SIZE_IN_SECTOR=`parser_mbr sunxi_mbr_tmp_data.fex get_size_by_name ${DATA_PART_NAME}`
if [ x${DATA_PART_DOWNLOAD_FILE} != x'' -a x${DATA_PART_SIZE_IN_SECTOR} != x'0' ]; then
let DATA_PART_SIZE_IN_K=$DATA_PART_SIZE_IN_SECTOR/2
echo "DATA_PART_DOWNLOAD_FILE = ${LICHEE_PACK_OUT_DIR}/${DATA_PART_DOWNLOAD_FILE}"
rm -f ${LICHEE_PACK_OUT_DIR}/${DATA_PART_DOWNLOAD_FILE}
rm -f ${LICHEE_PACK_OUT_DIR}/${DATA_PART_DOWNLOAD_FILE_SPARSE}
${TINA_TOOLS_PATH}/make_ext4fs -l ${DATA_PART_SIZE_IN_K}k -b 1024 -m 0 -j 1024 ${LICHEE_PACK_OUT_DIR}/${DATA_PART_DOWNLOAD_FILE} ${DATA_PART_FILE_PATH}
sparse_ext4 ${LICHEE_PACK_OUT_DIR}/${DATA_PART_DOWNLOAD_FILE} ${LICHEE_PACK_OUT_DIR}/${DATA_PART_DOWNLOAD_FILE_SPARSE}
printf "no data resource partitions\n"
fi
################################ Platform func ################################
function do_pack_android()
local localpath=$(readlink -f $(pwd))
local androidout=$(readlink -f ${ANDROID_IMAGE_OUT})
local link_real=$(get_realpath $androidout $localpath)
printf "packing for android\n"
if [ -z "${ANDROID_IMAGE_OUT}" ] ; then
pack_error "please specify ANDROID_IMAGE_OUT env"
exit 1
fi
local fex_list=($(\gawk '$0~"^[[:space:]]*downloadfile[[:space:]]*="{print $NF}' sys_partition.fex | sed 's/[",\r,\n]//g'))
fex_list+=(vendor_boot-debug.fex)
local img_name=""
for fex_name in ${fex_list[@]}; do
img_name=${fex_name%\.fex}.img
if [ -f ${ANDROID_IMAGE_OUT}/${img_name} ]; then
ln -sf ${link_real}/${img_name} ${fex_name}
echo "link ${img_name} -> ${fex_name}"
fi
done
if [ -e $androidout/vmlinux ]; then
export PATH=$PATH:${LICHEE_TOP_DIR}/build/bin
local vmlinuxpath=$(dirname $(readlink -f $androidout/vmlinux))
local vmlinuxname=$(basename $(readlink -f $androidout/vmlinux))
(cd $vmlinuxpath && tar cf $localpath/vmlinux.tar.bz2 --use-compress-prog=lbzip2 $vmlinuxname)
rm -rf vmlinux.fex
ln -sf vmlinux.tar.bz2 vmlinux.fex
fi
if [ -n "${PACK_BOOT_PATH}" ] && [ "x${PACK_BOOT_PATH}" != "xnone" ]; then
ln -sf $PACK_BOOT_PATH boot.fex
fi
echo "secure"
echo "normal"
fi
function prepare_mixed_androiddragonboard()
local mixed_fw_type
if [ "${PACK_TYPE}" != "android" ] || [ -z "$PACK_MIXED_FIRMWARE" ]; then
return 0
fi
case "$PACK_MIXED_FIRMWARE" in
dragonboard|dragonabts)
mixed_fw_type="$PACK_MIXED_FIRMWARE"
pack_info "${FUNCNAME[0]}: mixed firmware type: $mixed_fw_type"
echo "Unsupport mixed firmware type: $PACK_MIXED_FIRMWARE"
return 1
esac
local mixedboardout=$(readlink -f ${CFG_PLAT_OUT}/../$mixed_fw_type)
if [ ! -d $mixedboardout ]; then
pack_error "${FUNCNAME[0]}: cannot find out path for $mixed_fw_type"
exit 1
fi
local envpath=($LICHEE_BOARD_CONFIG_DIR/$mixed_fw_type $LICHEE_CHIP_CONFIG_DIR/configs/default)
local partition=(bootloader_b:boot-resource.fex env_b:denv.fex
boot_b:dboot.fex vendor_boot_b:vendor_boot.fex media_data)
local item name linenum nstart nend nmax file
for item in ${partition[@]}; do
name=${item/:*}
linenum=$(sed -n "/^\s*name\s*=\s*$name/=" sys_partition.fex)
if [ -z "$linenum" ]; then
pack_error "${FUNCNAME[@]}: leak neccery partition $name in sys_partition.fex"
exit 1
fi
done
for item in ${envpath[@]}; do
if [ -e $item/env.cfg ]; then
cp $item/env.cfg denv.cfg
sed -i '/^\s*boot_normal=/s/\<boot\>/boot_b/g' denv.cfg
generate_env_for_uboot denv.cfg $mixedboardout/env.img
rm -rf denv.cfg
break
fi
done
if [ ! -e $mixedboardout/env.img ] || \
[ ! -e $mixedboardout/boot.img ] || \
[ ! -e $mixedboardout/rootfs.ext4 ] || \
[ ! -e $LICHEE_BOARD_CONFIG_DIR/$mixed_fw_type/test_config.fex ]; then
pack_error "${FUNCNAME[@]}: leak neccery img/fex for $mixed_fw_type"
exit 1
fi
printf "prepare for mixed android/$mixed_fw_type packing...\n"
name=${item/:*}
nstart=$linenum
nend=$linenum
nmax=$(wc -l sys_partition.fex | awk '{print $1}')
while [ $nstart -gt 1 ]; do
nstart=$((nstart-1))
if [ -n "$(sed -n "$nstart p" sys_partition.fex | grep "^\s*\[\S\+\]")" ]; then
break;
fi
done
while [ $nend -lt $nmax ]; do
nend=$((nend+1))
if [ -n "$(sed -n "$nend p" sys_partition.fex | grep "^\s*\[\S\+\]")" ]; then
break;
fi
done
[ $nend -ne $nmax ] && nend=$((nend-1))
file="$(sed -n "${nstart},${nend}p" sys_partition.fex | \
awk -F= '/^[[:space:]]*downloadfile[[:space:]]*=/{print $2}')"
dlfile=${e#*:}
case $name in
bootloader_b|env_b|boot_b|vendor_boot_b)
if [ -z "$file" ]; then
sed -i "$linenum a\ \ \ \ downloadfile = \"${item#*:}\"" sys_partition.fex
fi
media_data)
local cmd="$nstart i"
local size=$(stat $mixedboardout/rootfs.ext4 --format="%s")
size=$(((size+32*1024*1024-1)/(16*1024*1024)*16)) # at least size + 16M, and 16M align
if [ -z "$(grep "^\s*name\s*=\s*rootfs" sys_partition.fex)" ]; then
cmd+="[partition]\n"
cmd+=" name = rootfs\n"
cmd+=" size = ${size}M\n"
cmd+=" downloadfile = \"drootfs.fex\"\n"
cmd+=" user_type = 0x8000\n"
cmd+="\n"
fi
[ "$cmd" != "$nstart i" ] && sed -i "$cmd" sys_partition.fex
esac
done
# Delete "^M" under Windows
sed -i 's|
||g' sys_partition.fex
[ -z "$(grep "^\s*onlykey=boot_b,\s*dboot.fex," dragon_toc.cfg)" ] && \
sed -i 's|^\(\s*onlykey=boot_b,\s*\)\S*,|\1dboot.fex,|g' dragon_toc.cfg
echo "onlykey=boot_b,dboot.fex,SCPFirmwareContentCertPK" >> dragon_toc.cfg
if [ -z "$(grep "^\s*onlykey=boot_b,\s*dboot.fex," dragon_toc.cfg)" ]; then
sed -i '/^optee=/a boot_b=SCPFirmwareContentCertPK' dragon_toc.cfg
sed -i '/^item=optee/a\onlykey=boot_b,dboot.fex,boot_b.crtpt' dragon_toc.cfg
fi
fi
cp $LICHEE_BOARD_CONFIG_DIR/$mixed_fw_type/test_config.fex .
cp $mixedboardout/env.img denv.fex
cp $mixedboardout/boot.img dboot.fex
cp $mixedboardout/rootfs.ext4 drootfs.fex
echo "android:$PACK_MIXED_FIRMWARE" > mixed-image-type.txt
pack_error "${FUNCNAME[0]} fail"
return 1
fi
return 0
function do_pack_dragonboard()
printf "packing for dragonboard\n"
ln -sf ${link_real}/boot.img boot.fex
ln -sf ${link_real}/rootfs.ext4 rootfs.fex
ln -sf ${link_real}/rootfs.ubifs rootfs-ubifs.fex
do_signature
echo "normal"
fi
function do_pack_dragonabts()
printf "packing for dragonabts\n"
do_signature
echo "normal"
fi
function do_pack_linux()
printf "packing for linux\n"
do_fit_image
[ -f kernel.itb ] && mv kernel.itb kernel.fex
[ -f kernel-dtb.itb ] && mv kernel-dtb.itb kernel-dtb.fex
[ -f ${link_real}/bootB.img ] && ln -sf ${link_real}/bootB.img bootB.fex
# Those files is ready for SPINor.
ln -sf ${link_real}/uImage kernel.fex
ln -sf ${link_real}/rootfs.img rootfs_nor.fex
ln -sf ${link_real}/rootfs.squashfs rootfs_nor.fex
fi
fi
ln -sf ${link_real}/rootfs.img rootfs.fex
fi
ln -sf ${recovery_path} recovery.fex
fi
echo "secure"
do_signature
echo "normal"
fi
function create_kernel_fit_image()
local its_name=$1
printf "create_kernel_fit_image\n"
if [ ! -f ${LICHEE_PACK_OUT_DIR}/${its_name}.its ]; then
printf "can not found ${its_name}.its\n"
return 1
fi
mkimage -f ${its_name}.its ${its_name}.itb
pack_error "mkimage ${its_name}.itb error\n"
exit 1
fi
function do_fit_image()
printf "do_fit_image\n"
create_kernel_fit_image kernel
return 1
fi
create_kernel_fit_image kernel-dtb
return 1
fi
function main()
local output_resources=${FLAGS_output_resources:-false}
local from_resources=${FLAGS_from_resources}
local support_secure_type
case x$LICHEE_PACK_SECURE_TYPE in
xnone|xsecure|xany)
support_secure_type=$LICHEE_PACK_SECURE_TYPE
x)
support_secure_type=any
pack_error "Unsupport pack secure type: $LICHEE_PACK_SECURE_TYPE"
return 1
esac
if [ "$support_secure_type" != "any" ] && [ "$support_secure_type" != "$PACK_SECURE" ]; then
pack_error "This platform only support secure type [$support_secure_type], but current using [$PACK_SECURE], please check!!!"
pack_error "Now, we try using secure type [$support_secure_type]!!!"
PACK_SECURE=$support_secure_type
fi
if [ "$output_resources" == "false" ] && [ -z "$from_resources" ]; then
do_prepare
do_ini_to_dts
do_common
do_pack_${PACK_TYPE}
do_finish
return $?
fi
if [ "$output_resources" == "true" ]; then
do_prepare
do_ini_to_dts
elif [ -n "$from_resources" ]; then
if [ ! -d $from_resources ]; then
pack_error "Cannot find resources path: $from_resources"
return 1
fi
local count=0
while [ -e ${LICHEE_PACK_OUT_DIR} -a $count -lt 20 ]; do
count=$((count+1))
done
cp -rax $from_resources ${LICHEE_PACK_OUT_DIR}
cd $LICHEE_OUT_DIR
if [ "${LICHEE_PACK_OUT_DIR}" != "$LICHEE_OUT_DIR/pack_out" ]; then
rm -rf pack_out
ln -sf ${LICHEE_IC}/${LICHEE_BOARD}/pack_out pack_out
fi
if [ "${PACK_PLATFORM}" == "android" ] && [ -n "$PACK_MIXED_FIRMWARE" ]; then
local resource_type="$(cat ${LICHEE_PACK_OUT_DIR}/mixed-image-type.txt)"
local mixed_fw_type="android:$PACK_MIXED_FIRMWARE"
if [ "$resource_type" != "android:$PACK_MIXED_FIRMWARE" ]; then
pack_error "mixed firmware type [$mixed_fw_type] but resource type [$resource_type]"
exit 1
fi
pack_info "mixed firmware type [$mixed_fw_type]"
fi
do_common
do_finish
fi
return $?
main "$@"
longan/build/pack 修改后:
#!/bin/bash
# pack/pack
# (c) Copyright 2013
# Allwinner Technology Co., Ltd. <www.allwinnertech.com>
# James Deng <csjamesdeng@allwinnertech.com>
# This program is free software; you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# (at your option) any later version.
############################ Notice #####################################
# a. Some config files priority is as follows:
# - xxx_${platform}.{cfg|fex} > xxx.{cfg|fex}
# - ${chip}/${board}/*.{cfg|fex} > ${chip}/default/*.{cfg|fex}
# - ${chip}/default/*.cfg > ${LICHEE_COMMON_CONFIG_DIR}/imagecfg/*.cfg
# - ${chip}/default/*.fex > ${LICHEE_COMMON_CONFIG_DIR}/partition/*.fex
# e.g. sun8iw7p1/configs/perf/image_linux.cfg > sun8iw7p1/configs/default/image_linux.cfg
# > ${LICHEE_COMMON_CONFIG_DIR}/imagecfg/image_linux.cfg > sun8iw7p1/configs/perf/image.cfg
# > sun8iw7p1/configs/default/image.cfg > ${LICHEE_COMMON_CONFIG_DIR}/imagecfg/image.cfg
# b. Support Nor storages rule:
# - Need to create sys_partition_nor.fex or sys_partition_nor_${platform}.fex
# - Add "{filename = "full_img.fex", maintype = "12345678", \
# subtype = "FULLIMG_00000000",}" to image[_${platform}].cfg
# c. Switch uart port
# - Need to add your chip configs into ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_pin
# - Call pack with 'debug' parameters
#if you want to debug pack, set vlaue to 1. use pause func in the place where you want to stop
enable_pause=0
function get_char()
SAVEDSTTY=`stty -g`
stty -echo
stty cbreak
dd if=/dev/tty bs=1 count=1 2> /dev/null
stty -raw
stty echo
stty $SAVEDSTTY
function pause()
if [ "x$1" != "x" ] ;then
echo "$1"
fi
if [ $enable_pause -eq 1 ] ; then
echo "Press any key to continue!"
char=`get_char`
fi
function pack_error()
echo -e "\033[47;31mERROR: $*\033[0m"
function pack_warn()
echo -e "\033[47;34mWARN: $*\033[0m"
function pack_info()
echo -e "\033[47;30mINFO: $*\033[0m"
localpath=$(cd $(dirname $0) && pwd)
. $localpath/shflags
# define option, format:
# 'long option' 'default value' 'help message' 'short option'
DEFINE_string 'chip' '' 'chip to build, e.g. sun7i' 'c'
DEFINE_string 'ic' '' 'ic to build, e.g. a50' 'i'
DEFINE_string 'addition' '' 'additional config files, e.g. xx.fex' 'a'
DEFINE_string 'platform' '' 'platform to build, e.g. linux, android' 'p'
DEFINE_string 'platform_version' '' 'platform version to build' 'V'
DEFINE_string 'board' '' 'board to build, e.g. evb' 'b'
DEFINE_string 'kernel' '' 'kernel to build, e.g. linux-3.4, linux-3.10' 'k'
DEFINE_string 'debug_mode' 'uart0' 'config debug mode, e.g. uart0, card0' 'd'
DEFINE_string 'signture' 'none' 'pack boot signture to do secure boot' 's'
DEFINE_string 'secure' 'none' 'pack secure boot with -v arg' 'v'
DEFINE_string 'mode' 'normal' 'pack dump firmware' 'm'
DEFINE_string 'function' 'android' 'pack private firmware' 'f'
DEFINE_string 'vsp' '' 'pack firmware for vsp' 't'
DEFINE_string 'programmer' '' 'creat programmer img or not' 'w'
DEFINE_string 'key_path' '' 'the path of keys' 'P'
DEFINE_string 'nor' 'none' 'pack nor image' 'n'
DEFINE_boolean 'verity' false 'if enable dm-verity' ''
DEFINE_boolean 'signfel' false 'if enable fel signing' ''
DEFINE_string 'boot_path' '' 'the path of gki boot.img' 'B'
DEFINE_string 'output_resources' '' 'only output resources to pack-out' ''
DEFINE_string 'from_resources' '' 'pack from resources path' ''
# parse the command-line
FLAGS "$@" || exit $?
eval set -- "${FLAGS_ARGV}"
PACK_CHIP=${FLAGS_chip}
PACK_IC=${FLAGS_ic}
PACK_PLATFORM=${FLAGS_platform}
PACK_PLATFORM_VERSION=${FLAGS_platform_version}
PACK_BOARD=${FLAGS_board}
PACK_KERN=${FLAGS_kernel}
PACK_DEBUG=${FLAGS_debug_mode}
PACK_SIG=${FLAGS_signture}
PACK_SECURE=${FLAGS_secure}
PACK_MODE=${FLAGS_mode}
PACK_FUNC=${FLAGS_function}
PACK_VSP=${FLAGS_vsp}
PACK_PROGRAMMER=${FLAGS_programmer}
PACK_NOR=${FLAGS_nor}
PACK_PRODUCT=${FLAGS_product}
PACK_VERITY=${FLAGS_verity}
PACK_SIGNFEL=${FLAGS_signfel}
PACK_ADD_FILES=(${FLAGS_addition})
PACK_KEY_PATH=${FLAGS_key_path}
PACK_BOOT_PATH=${FLAGS_boot_path}
CFG_TOP_DIR=$(cd $localpath/../ && pwd)
CFG_PLAT_OUT=$CFG_TOP_DIR/out/$PACK_IC/$PACK_BOARD/$PACK_PLATFORM
CFG_KEY_DIR=$CFG_TOP_DIR/out/$PACK_IC/common/keys
if [ ! -z "${PACK_KEY_PATH}" ]; then
CFG_KEY_DIR=${PACK_KEY_PATH}
fi
pack_info "${CFG_KEY_DIR}"
if [ ! -d ${CFG_PLAT_OUT} ] || \
[ ! -f $CFG_PLAT_OUT/.buildconfig ]; then
pack_error "config & build lichee before you pack"
exit 1
fi
source $CFG_PLAT_OUT/.buildconfig
if [ -z "${PACK_KERN}" ]; then
pack_info "No kernel param, parse it from .buildconfig"
PACK_KERN=$LICHEE_KERN_VER
pack_error "Failed to parse kernel param from .buildconfig"
exit 1
fi
fi
PACK_TYPE=""
case "x${PACK_PLATFORM}" in
"xandroid")
PACK_TYPE="android"
"xdragonboard")
PACK_TYPE="dragonboard"
"xdragonabts")
PACK_TYPE="dragonabts"
"xbsp"|"xsata"|"xbuildroot"|"xopenwrt"|"xdebian")
PACK_TYPE="linux"
pack_error "Unsupport PACK_PLATFORM: ${PACK_PLATFORM}"
exit 1
esac
export PATH=${LICHEE_TOOLS_DIR}/pack/pctools/linux/mod_update:${LICHEE_TOOLS_DIR}/pack/pctools/linux/openssl:${LICHEE_TOOLS_DIR}/pack/pctools/linux/eDragonEx:${LICHEE_TOOLS_DIR}/pack/pctools/linux/fsbuild200:${LICHEE_TOOLS_DIR}/pack/pctools/linux/android:$PATH
export LD_LIBRARY_PATH=${LICHEE_TOOLS_DIR}/pack/pctools/linux/softhsm/lib/:$LD_LIBRARY_PATH
tools_file_list=(
${LICHEE_COMMON_CONFIG_DIR}/tools/split_xxxx.fex
${LICHEE_CHIP_CONFIG_DIR}/tools/split_xxxx.fex
${LICHEE_COMMON_CONFIG_DIR}/tools/usbtool_test.fex
${LICHEE_COMMON_CONFIG_DIR}/tools/usbtool_crash.fex
${LICHEE_CHIP_CONFIG_DIR}/tools/usbtool_test.fex
${LICHEE_COMMON_CONFIG_DIR}/tools/cardscript.fex
${LICHEE_COMMON_CONFIG_DIR}/tools/cardscript_secure.fex
${LICHEE_CHIP_CONFIG_DIR}/tools/cardscript.fex
${LICHEE_CHIP_CONFIG_DIR}/tools/cardscript_secure.fex
${LICHEE_COMMON_CONFIG_DIR}/tools/cardtool.fex
${LICHEE_CHIP_CONFIG_DIR}/tools/cardtool.fex
${LICHEE_COMMON_CONFIG_DIR}/tools/usbtool.fex
${LICHEE_CHIP_CONFIG_DIR}/tools/usbtool.fex
${LICHEE_CHIP_CONFIG_DIR}/tools/usbtool_crash.fex
${LICHEE_COMMON_CONFIG_DIR}/tools/aultls32.fex
${LICHEE_CHIP_CONFIG_DIR}/tools/aultls32.fex
${LICHEE_COMMON_CONFIG_DIR}/tools/aultools.fex
${LICHEE_CHIP_CONFIG_DIR}/tools/aultools.fex
configs_file_list=(
${LICHEE_COMMON_CONFIG_DIR}/toc/toc1.fex
${LICHEE_COMMON_CONFIG_DIR}/toc/toc0.fex
${LICHEE_COMMON_CONFIG_DIR}/toc/toc0_sdcard.fex
${LICHEE_COMMON_CONFIG_DIR}/toc/toc0_nand.fex
${LICHEE_COMMON_CONFIG_DIR}/toc/toc0_ufs.fex
${LICHEE_COMMON_CONFIG_DIR}/toc/toc0_ft.fex
${LICHEE_COMMON_CONFIG_DIR}/toc/boot_package.fex
${LICHEE_COMMON_CONFIG_DIR}/hdcp/esm.fex
${LICHEE_COMMON_CONFIG_DIR}/dtb/sunxi.fex
${LICHEE_COMMON_CONFIG_DIR}/partition/sys_partition_dump.fex
${LICHEE_COMMON_CONFIG_DIR}/partition/sys_partition_private.fex
${LICHEE_COMMON_CONFIG_DIR}/version/version_base.mk
${LICHEE_CHIP_CONFIG_DIR}/configs/default/*
${LICHEE_CHIP_CONFIG_DIR}/configs/${PACK_BOARD}/*.fex
${LICHEE_CHIP_CONFIG_DIR}/configs/${PACK_BOARD}/boot_package*.cfg
${LICHEE_CHIP_CONFIG_DIR}/configs/${PACK_BOARD}/${LICHEE_KERN_VER}/*.cfg
${LICHEE_CHIP_CONFIG_DIR}/configs/default/version_base.mk
${LICHEE_CHIP_CONFIG_DIR}/dtbo/*
${LICHEE_BOARD_CONFIG_DIR}/dtbo/*
${LICHEE_CHIP_CONFIG_DIR}/${BIN_PATH}/ft_${PACK_CHIP}.bin
${LICHEE_COMMON_CONFIG_DIR}/sign_config/dragon_toc_ft.cfg
${LICHEE_CHIP_CONFIG_DIR}/configs/default/dragon_toc_ft.cfg
${LICHEE_COMMON_CONFIG_DIR}/sign_config/cnf_base.cnf
${LICHEE_PLAT_OUT}/.buildconfig
product_configs_file_list=(
${LICHEE_CHIP_CONFIG_DIR}/configs/${PACK_BOARD}/${PACK_PLATFORM}/*.fex
${LICHEE_CHIP_CONFIG_DIR}/configs/${PACK_BOARD}/${PACK_PLATFORM}/*.cfg
boot_resource_list=(
${LICHEE_CHIP_CONFIG_DIR}/boot-resource/boot-resource:${LICHEE_PACK_OUT_DIR}
${LICHEE_CHIP_CONFIG_DIR}/boot-resource/boot-resource.ini:${LICHEE_PACK_OUT_DIR}
${LICHEE_CHIP_CONFIG_DIR}/configs/${PACK_BOARD}/*.bmp:${LICHEE_PACK_OUT_DIR}/boot-resource/
${LICHEE_CHIP_CONFIG_DIR}/configs/${PACK_BOARD}/bootlogo.bmp:${LICHEE_PACK_OUT_DIR}/bootlogo.bmp
${LICHEE_CHIP_CONFIG_DIR}/configs/${PACK_BOARD}/wavefile/*:${LICHEE_PACK_OUT_DIR}/boot-resource/wavefile/
${LICHEE_CHIP_CONFIG_DIR}/configs/${PACK_BOARD}/${PACK_TYPE}/*.bmp:${LICHEE_PACK_OUT_DIR}/boot-resource/
${LICHEE_CHIP_CONFIG_DIR}/boot-resource/boot-resource/bat/bempty.bmp:${LICHEE_PACK_OUT_DIR}/bempty.bmp
${LICHEE_CHIP_CONFIG_DIR}/boot-resource/boot-resource/bat/battery_charge.bmp:${LICHEE_PACK_OUT_DIR}/battery_charge.bmp
#${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/boot0_nand_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/boot0_nand.fex
#${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/boot0_sdcard_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/boot0_sdcard.fex
#${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/boot0_ufs_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/boot0_ufs.fex
#${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/boot0_${LICHEE_BOOT0_BIN_NAME}_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/boot0_${LICHEE_BOOT0_BIN_NAME}.fex
#${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/boot0_nandfastboot_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/boot0_nandfastboot_${PACK_CHIP}.fex
#${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/boot0_spinor_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/boot0_spinor.fex
boot_file_list=(
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/fes1_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/fes1.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/fes1_uart_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/fes1_uart.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/u-boot-${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/u-boot.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/u-boot-${LICHEE_EFEX_BIN_NAME}.bin:${LICHEE_PACK_OUT_DIR}/u-boot-${LICHEE_EFEX_BIN_NAME}.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/u-boot-crashdump-${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/u-boot-crash.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/u-boot-crashdump-spinor-${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/u-boot-spinor-crash.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/bl31.bin:${LICHEE_PACK_OUT_DIR}/monitor.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/bl31_${PACK_BOARD}.bin:${LICHEE_PACK_OUT_DIR}/monitor.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/scp.bin:${LICHEE_PACK_OUT_DIR}/scp.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/amp_dsp0.bin:${LICHEE_PACK_OUT_DIR}/amp_dsp0.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/amp_dsp1.bin:${LICHEE_PACK_OUT_DIR}/amp_dsp1.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/amp_arm64.bin:${LICHEE_PACK_OUT_DIR}/amp_arm64.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/amp_rv0.bin:${LICHEE_PACK_OUT_DIR}/amp_rv0.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/video.bin:${LICHEE_PACK_OUT_DIR}/video.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/optee_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/optee.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/optee_${PACK_CHIP}-monitor.bin:${LICHEE_PACK_OUT_DIR}/optee-monitor.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/opensbi_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/opensbi.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/u-boot-spinor-${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/u-boot-spinor.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/u-boot-spinor-secure-${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/u-boot-spinor-secure.fex
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/*.fex:${LICHEE_PACK_OUT_DIR}/
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/*.dtb:${LICHEE_PACK_OUT_DIR}/
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/*.bin:${LICHEE_PACK_OUT_DIR}/
#${LICHEE_PLAT_OUT}/boot0_nand_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/boot0_nand.fex
#${LICHEE_PLAT_OUT}/boot0_sdcard_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/boot0_sdcard.fex
#${LICHEE_PLAT_OUT}/boot0_${LICHEE_BOOT0_BIN_NAME}_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/boot0_${LICHEE_BOOT0_BIN_NAME}.fex
#${LICHEE_PLAT_OUT}/boot0_spinor_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/boot0_spinor.fex
boot_file_list_2=(
${LICHEE_PLAT_OUT}/arisc:${LICHEE_PACK_OUT_DIR}/arisc.fex
${LICHEE_PLAT_OUT}/sunxi.dtb:${LICHEE_PACK_OUT_DIR}/sunxi.fex
${LICHEE_PLAT_OUT}/fes1_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/fes1.fex
${LICHEE_PLAT_OUT}/fes1_uart_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/fes1_uart.fex
${LICHEE_PLAT_OUT}/sboot_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/sboot.bin
${LICHEE_PLAT_OUT}/sboot_nor_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/sboot_nor.bin
${LICHEE_PLAT_OUT}/sboot_sdcard_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/sboot_sdcard.bin
${LICHEE_PLAT_OUT}/sboot_nand_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/sboot_nand.bin
${LICHEE_PLAT_OUT}/sboot_ufs_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/sboot_ufs.bin
${LICHEE_PLAT_OUT}/u-boot-${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/u-boot.fex
${LICHEE_PLAT_OUT}/u-boot-${LICHEE_EFEX_BIN_NAME}.bin:${LICHEE_PACK_OUT_DIR}/u-boot-${LICHEE_EFEX_BIN_NAME}.fex
${LICHEE_PLAT_OUT}/u-boot-crashdump-${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/u-boot-crash.fex
${LICHEE_PLAT_OUT}/u-boot-crashdump-spinor-${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/u-boot-spinor-crash.fex
${LICHEE_PLAT_OUT}/scp.bin:${LICHEE_PACK_OUT_DIR}/scp.fex
${LICHEE_PLAT_OUT}/u-boot-spinor-${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/u-boot-spinor.fex
${LICHEE_PLAT_OUT}/u-boot-spinor-secure-${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/u-boot-spinor-secure.fex
${LICHEE_PLAT_OUT}/vmlinux.tar.bz2:${LICHEE_PACK_OUT_DIR}/vmlinux.fex
arm_boot_file_secure=(
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/semelis_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/semelis.bin
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/sboot_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/sboot.bin
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/sboot_nor_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/sboot_nor.bin
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/sboot_sdcard_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/sboot_sdcard.bin
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/sboot_nand_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/sboot_nand.bin
${LICHEE_CHIP_CONFIG_DIR}/\${BIN_PATH}/sboot_ufs_${PACK_CHIP}.bin:${LICHEE_PACK_OUT_DIR}/sboot_ufs.bin
${LICHEE_COMMON_CONFIG_DIR}/sign_config/dragon_toc_android.cfg:${LICHEE_PACK_OUT_DIR}/dragon_toc.cfg
${LICHEE_CHIP_CONFIG_DIR}/configs/default/dragon_toc_android.cfg:${LICHEE_PACK_OUT_DIR}/dragon_toc.cfg
arm64_boot_file_secure=(
${LICHEE_COMMON_CONFIG_DIR}/sign_config/dragon_toc_a64_android.cfg:${LICHEE_PACK_OUT_DIR}/dragon_toc.cfg
# This function can get the realpath between $SRC and $DST
function get_realpath()
local src=$(cd $1; pwd);
local dst=$(cd $2; pwd);
local res="./";
local tmp="$dst"
while [ "${src##*$tmp}" == "${src}" ]; do
tmp=${tmp%/*};
res=$res"../"
done
res="$res${src#*$tmp/}"
printf "%s" $res
function show_boards()
printf "\nAll avaiable chips, platforms and boards:\n\n"
printf "Chip Board\n"
for chipdir in $(find chips/ -mindepth 1 -maxdepth 1 -type d) ; do
chip=`basename ${chipdir}`
printf "${chip}\n"
for boarddir in $(find chips/${chip}/configs/${platform} \
board=`basename ${boarddir}`
printf " ${board}\n"
done
done
printf "\nFor Usage:\n"
printf " $(basename $0) -h\n\n"
function uart_switch()
rm -rf ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
touch ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
TX=`awk '$0~"'$PACK_CHIP'"{print $2}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_pin`
RX=`awk '$0~"'$PACK_CHIP'"{print $3}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_pin`
PORT=`awk '$0~"'$PACK_CHIP'"{print $4}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_pin`
MS=`awk '$0~"'$PACK_CHIP'"{print $5}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_pin`
CK=`awk '$0~"'$PACK_CHIP'"{print $6}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_pin`
DO=`awk '$0~"'$PACK_CHIP'"{print $7}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_pin`
DI=`awk '$0~"'$PACK_CHIP'"{print $8}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_pin`
BOOT_UART_ST=`awk '$0~"'$PACK_CHIP'"{print $2}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_string`
BOOT_PORT_ST=`awk '$0~"'$PACK_CHIP'"{print $3}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_string`
BOOT_TX_ST=`awk '$0~"'$PACK_CHIP'"{print $4}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_string`
BOOT_RX_ST=`awk '$0~"'$PACK_CHIP'"{print $5}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_string`
UART0_ST=`awk '$0~"'$PACK_CHIP'"{print $6}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_string`
UART0_USED_ST=`awk '$0~"'$PACK_CHIP'"{print $7}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_string`
UART0_PORT_ST=`awk '$0~"'$PACK_CHIP'"{print $8}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_string`
UART0_TX_ST=`awk '$0~"'$PACK_CHIP'"{print $9}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_string`
UART0_RX_ST=`awk '$0~"'$PACK_CHIP'"{print $10}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_string`
UART1_ST=`awk '$0~"'$PACK_CHIP'"{print $11}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_string`
JTAG_ST=`awk '$0~"'$PACK_CHIP'"{print $12}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_string`
MS_ST=`awk '$0~"'$PACK_CHIP'"{print $13}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_string`
CK_ST=`awk '$0~"'$PACK_CHIP'"{print $14}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_string`
DO_ST=`awk '$0~"'$PACK_CHIP'"{print $15}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_string`
DI_ST=`awk '$0~"'$PACK_CHIP'"{print $16}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_string`
MMC0_ST=`awk '$0~"'$PACK_CHIP'"{print $17}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_string`
MMC0_USED_ST=`awk '$0~"'$PACK_CHIP'"{print $18}' ${LICHEE_COMMON_CONFIG_DIR}/debug/card_debug_string`
if [ -z "$TX" ] || [ -z "$BOOT_UART_ST" ]; then
pack_error "$FUNCNAME: $PACK_CHIP not configured in card_debug_pin/card_debug_string!"
exit 1
fi
echo '$0!~";" && $0~"'$BOOT_TX_ST'"{if(C)$0="'$BOOT_TX_ST' = '$TX'"} \' >> ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
echo '$0!~";" && $0~"'$BOOT_RX_ST'"{if(C)$0="'$BOOT_RX_ST' = '$RX'"} \' >> ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
echo '$0!~";" && $0~"'$BOOT_PORT_ST'"{if(C)$0="'$BOOT_PORT_ST' = '$PORT'"} \' >> ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
if [ "`grep "auto_print_used" "${LICHEE_PACK_OUT_DIR}/sys_config.fex" | grep "1"`" ]; then
echo '$0!~";" && $0~"'$MMC0_USED_ST'"{if(A)$0="'$MMC0_USED_ST' = 1";A=0} \' >> ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
echo '$0!~";" && $0~"'$MMC0_USED_ST'"{if(A)$0="'$MMC0_USED_ST' = 0";A=0} \' >> ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
fi
echo '$0!~";" && $0~"\\['$MMC0_ST'\\]"{A=1} \' >> ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
echo '$0!~";" && $0~"'$UART0_TX_ST'"{if(B)$0="'$UART0_TX_ST' = '$TX'"} \' >> ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
echo '$0!~";" && $0~"'$UART0_RX_ST'"{if(B)$0="'$UART0_RX_ST' = '$RX'"} \' >> ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
echo '$0!~";" && $0~"\\['$UART0_ST'\\]"{B=1} \' >> ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
echo '$0!~";" && $0~"'$UART0_USED_ST'"{if(B)$0="'$UART0_USED_ST' = 1"} \' >> ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
echo '/^'$UART0_PORT_ST'/{next} \' >> ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
echo '$0!~";" && $0~"\\['$UART1_ST'\\]"{B=0} \' >> ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
echo '$0!~";" && $0~"\\['$BOOT_UART_ST'\\]"{C=1} \' >> ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
echo '$0!~";" && $0~"\\['$JTAG_ST'\\]"{C=0} \' >> ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
echo '$0!~";" && $0~"'$MS_ST'"{$0="'$MS_ST' = '$MS'"} \' >> ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
echo '$0!~";" && $0~"'$CK_ST'"{$0="'$CK_ST' = '$CK'"} \' >> ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
echo '$0!~";" && $0~"'$DO_ST'"{$0="'$DO_ST' = '$DO'"} \' >> ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
echo '$0!~";" && $0~"'$DI_ST'"{$0="'$DI_ST' = '$DI'"} \' >> ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
echo '1' >> ${LICHEE_PACK_OUT_DIR}/awk_debug_card0
sed -i -e '/^uart0_rx/a\pinctrl-1=' ${LICHEE_PACK_OUT_DIR}/sys_config.fex
sed -i -e '/^uart0_rx/a\pinctrl-0=' ${LICHEE_PACK_OUT_DIR}/sys_config.fex
fi
awk -f ${LICHEE_PACK_OUT_DIR}/awk_debug_card0 ${LICHEE_PACK_OUT_DIR}/sys_config.fex > ${LICHEE_PACK_OUT_DIR}/sys_config_debug.fex
rm -f ${LICHEE_PACK_OUT_DIR}/sys_config.fex
mv ${LICHEE_PACK_OUT_DIR}/sys_config_debug.fex ${LICHEE_PACK_OUT_DIR}/sys_config.fex
echo "uart -> card0"
function add_lzma_header()
lzma_file=$1
original_file=$2
file_size=$(printf "%.8x\n" `stat -c%s ${lzma_file}`)
original_file_size=$(printf "%.8x\n" `stat -c%s ${original_file}`)
bin_str=""
file_size_len=${#file_size}
#"LZMA"+size+origin_size
bin_str="\x4c\x5a\x4d\x41\x${file_size:6:2}\x${file_size:4:2}\x${file_size:2:2}\x${file_size:0:2}"
bin_str+="\x${original_file_size:6:2}\x${original_file_size:4:2}\x${original_file_size:2:2}\x${original_file_size:0:2}"
printf "%b" ${bin_str} > tempbin
cat ${lzma_file} >> tempbin
mv tempbin "${lzma_file}.head"
function partition_size_handle()
echo "handle partition_size"
local filename=${LICHEE_PACK_OUT_DIR}/sys_partition.fex
local size
local number
local dimension
local blocks
local line
local m
local index=0
while read line; do
let "index++"
size=$(echo $line | awk -F= '/^[[:space:]]*size[[:space:]]*=/{print $2}' | sed 's|\s\+||g')
if [ -n "$size" ]; then
dimension=$(echo $size | sed 's|^[0-9,.]\+||g')
[ -z "$dimension" ] && continue
case $dimension in
B|b)
m=1
K|k)
m=1024
M|m)
m=1048576
G|g)
m=1073741824
pack_error "ERROR Dimension($dimension)!"
return 1
esac
number=$(echo $size | sed 's|[a-z,A-Z]*$||g')
blocks=$(echo "$number * $m / 512" | bc | awk -F. '{print $1}')
printf "sys_partition.fex: size %6s => %7d Blocks\n" "${number}${dimension}" "${blocks}"
size="$(echo "$line" | sed "s|=.*$|= $blocks|g")"
sed -i "${index}s|$line|$size|g" $filename
fi
done < $filename
return 0
function do_prepare()
local runinfo=($(lsof 2>/dev/null | awk '$9~"'$LICHEE_TOP_DIR/tools/build/buildserver'"{print $2}'))
local possible_bin_path="${LICHEE_POSSIBLE_BIN_PATH}"
if [ ${#runinfo[@]} -lt 2 ]; then
pack_error "something is incorrect:please <./build.sh config>."
fi
if [ -z "${PACK_CHIP}" -o -z "${PACK_TYPE}" -o -z "${PACK_BOARD}" ] ; then
pack_error "Invalid parameters Chip: ${PACK_CHIP}, \
Platform: ${PACK_TYPE}, Board: ${PACK_BOARD}"
show_boards
exit 1
fi
if [ ! -d ${LICHEE_CHIP_CONFIG_DIR}/configs/${PACK_BOARD} ] ; then
pack_error "Board's directory \
\"${LICHEE_CHIP_CONFIG_DIR}/configs/${PACK_BOARD}\" is not exist."
show_boards
exit 1
fi
# Cleanup
# if [ "x" != "x${LICHEE_PACK_OUT_DIR}" ]; then
# rm -rf ${LICHEE_PACK_OUT_DIR}
# fi
mkdir -p ${LICHEE_PACK_OUT_DIR}
cd $LICHEE_OUT_DIR
# rm -rf pack_out
fi
printf "copying tools file\n"
for file in ${tools_file_list[@]} ; do
cp -f $file ${LICHEE_PACK_OUT_DIR} 2> /dev/null
done
if [ "x${PACK_KERN}" = "xlinux-3.4" ]; then
cp -f ${LICHEE_COMMON_CONFIG_DIR}/tools/cardscript.fex ${LICHEE_PACK_OUT_DIR} 2> /dev/null
fi
printf "copying configs file\n"
for file in ${configs_file_list[@]} ; do
done
printf "copying product configs file\n"
for file in ${product_configs_file_list[@]}; do
cp -f $file ${LICHEE_PACK_OUT_DIR} 2>/dev/null
done
if [ x"${PACK_PLATFORM}" != x"android" ]; then
printf "linux copying boardt&linux_kernel_version configs file\n"
local possible_env_path=(
configs/default
configs/${LICHEE_BOARD}
configs/${LICHEE_BOARD}/${LICHEE_KERN_VER}
configs/${LICHEE_BOARD}/${PACK_PLATFORM}
local possible_env_list=(
env.cfg
env-$(echo ${LICHEE_KERN_VER} | awk -F '-' '{print $2}').cfg
local copy_env_file=''
for d in ${possible_env_path[@]}; do
[ ! -d ${LICHEE_CHIP_CONFIG_DIR}/$d ] && continue
for file in ${possible_env_list[@]} ; do
if [ -e "${LICHEE_CHIP_CONFIG_DIR}/$d/$file" ]; then
copy_env_file=${LICHEE_CHIP_CONFIG_DIR}/$d/$file
fi
done
done
echo "Use u-boot env file: ${copy_env_file}"
if [[ ! -f ${copy_env_file} ]]
then
echo -e "\e[33mWarning: u-boot env file '${copy_env_file}' not exist! use file in default directory other than '${PACK_BOARD}' directory\e[0m"
fi
cp -f ${copy_env_file} ${LICHEE_PACK_OUT_DIR}/env.cfg 2>/dev/null
cp -f ${LICHEE_CHIP_CONFIG_DIR}/configs/${PACK_BOARD}/${LICHEE_KERN_VER}/sys_* ${LICHEE_PACK_OUT_DIR} 2>/dev/null
fi
# If platform config files exist, we will cover the default files
# For example, mv pack_out/image_linux.cfg pack_out/image.cfg
if [ ${PACK_PLATFORM} != "android" ]; then
cp -f ${LICHEE_BOARD_CONFIG_DIR}/${PACK_PLATFORM}/* ${LICHEE_PACK_OUT_DIR} 2> /dev/null
if [ ${PACK_PLATFORM} = "bsp" -o "x${PACK_PLATFORM}" = "xsata" ] ; then
find ${LICHEE_PACK_OUT_DIR}/* -type f -a \( -name "*.fex" -o -name "*.cfg" \) -print | \
sed "s#\(.*\)_linux\(\..*\)#mv -fv & \1\2#e"
sed "s#\(.*\)_${PACK_PLATFORM}\(\..*\)#mv -fv & \1\2#e"
fi
sed "s#\(.*\)_${PACK_TYPE}\(\..*\)#mv -fv & \1\2#e"
fi
if [ "x${PACK_MODE}" = "xdump" ] ; then
cp -vf ${LICHEE_PACK_OUT_DIR}/sys_partition_dump.fex ${LICHEE_PACK_OUT_DIR}/sys_partition.fex
cp -vf ${LICHEE_PACK_OUT_DIR}/usbtool_test.fex ${LICHEE_PACK_OUT_DIR}/usbtool.fex
elif [ "x${PACK_FUNC}" = "xprvt" ] ; then
cp -vf ${LICHEE_PACK_OUT_DIR}/sys_partition_private.fex ${LICHEE_PACK_OUT_DIR}/sys_partition.fex
fi
printf "copying boot resource\n"
for file in ${boot_resource_list[@]} ; do
cp -rf $(echo $file | sed -e 's/:/ /g') 2>/dev/null
done
# openwrt use these logo files
if [ x"${PACK_PLATFORM}" = x"openwrt" ]; then
rm -rf ${LICHEE_PACK_OUT_DIR}/boot-resource
cp -rf $CFG_TOP_DIR/${PACK_PLATFORM}/target/$PACK_IC/$PACK_IC-common/boot-resource/boot-resource ${LICHEE_PACK_OUT_DIR}
cp -rf $CFG_TOP_DIR/${PACK_PLATFORM}/target/$PACK_IC/$PACK_IC-common/boot-resource/boot-resource.ini ${LICHEE_PACK_OUT_DIR}/boot-resource.ini
fi
if [ ! -f ${LICHEE_PACK_OUT_DIR}/bootlogo.bmp ]; then
cp ${LICHEE_PACK_OUT_DIR}/boot-resource/bootlogo.bmp ${LICHEE_PACK_OUT_DIR}/bootlogo.bmp
fi
lzma -k ${LICHEE_PACK_OUT_DIR}/bootlogo.bmp
lzma -k ${LICHEE_PACK_OUT_DIR}/bempty.bmp
lzma -k ${LICHEE_PACK_OUT_DIR}/battery_charge.bmp
if [ -f ${LICHEE_PACK_OUT_DIR}/bootlogo.bmp.lzma ]; then
add_lzma_header "${LICHEE_PACK_OUT_DIR}/bootlogo.bmp.lzma" "${LICHEE_PACK_OUT_DIR}/bootlogo.bmp"
(cd ${LICHEE_PACK_OUT_DIR}; ln -sf bootlogo.bmp.lzma.head bootlogo.fex)
fi
printf "copying boot file\n"
for d in ${possible_bin_path[@]}; do
BIN_PATH=$d
for file in ${boot_file_list[@]} ; do
eval cp -v -f $(echo $file | sed -e 's/:/ /g') 2>/dev/null
done
done
printf "copying boot file 2.0\n"
for file in ${boot_file_list_2[@]} ; do
done
if [[ ${LICHEE_BOARD} == *fastboot*spinand* ]] ; then
mv -v ${LICHEE_PACK_OUT_DIR}/boot0_nandfastboot_${PACK_CHIP}.fex ${LICHEE_PACK_OUT_DIR}/boot0_nand.fex
fi
if ! [ -z ${LICHEE_BOOT0_BIN_NAME} ]; then
echo 1111111111111111111111111111111111111
# nand fastboot
# cp -v -f ${LICHEE_PACK_OUT_DIR}/boot0_${LICHEE_BOOT0_BIN_NAME}.fex ${LICHEE_PACK_OUT_DIR}/boot0_nand.fex
# if [[ ${LICHEE_FLASH} == default ]] ; then
# mv -v ${LICHEE_PACK_OUT_DIR}/boot0_${LICHEE_BOOT0_BIN_NAME}.fex ${LICHEE_PACK_OUT_DIR}/boot0_sdcard.fex
# elif [[ ${LICHEE_FLASH} == nor ]] ; then
# mv -v ${LICHEE_PACK_OUT_DIR}/boot0_${LICHEE_BOOT0_BIN_NAME}.fex ${LICHEE_PACK_OUT_DIR}/boot0_spinor.fex
# else
# echo "invalid LICHEE_FLASH, default choose sdcard!"
# fi
fi
[ -z "${BIN_PATH}" ] &&
pack_error "No BIN_PATH found!" && exit 1
printf "copying $LICHEE_ARCH secure boot file\n"
BIN_PATH=$d
for file in $(eval echo '$'"{${LICHEE_ARCH}_boot_file_secure[@]}"); do
eval cp -f $(echo $file | sed -e 's/:/ /g') 2>/dev/null
done
done
# If platform config use
if [ -f ${LICHEE_CHIP_CONFIG_DIR}/tools/plat_config.sh ] ; then
fi
if [ "x${PACK_NOR}" = "xnor" ] ; then
cp -vf ${LICHEE_PACK_OUT_DIR}/image_nor.cfg ${LICHEE_PACK_OUT_DIR}/image.cfg
cp -vf ${LICHEE_PACK_OUT_DIR}/sboot_nor.bin ${LICHEE_PACK_OUT_DIR}/sboot.bin
cp -vf ${LICHEE_PACK_OUT_DIR}/dragon_toc_nor.cfg ${LICHEE_PACK_OUT_DIR}/dragon_toc.cfg
fi
if [ "x${PACK_VSP}" = "xvsp" ] ; then
printf "change usb_port_type to device...\n"
printf "disable usb_serial_unique...\n"
printf "change usb_serial_number to ${PACK_TYPE}_android...\n"
sed -i 's/^usb_port_type.*/usb_port_type = 0/g' ${LICHEE_PACK_OUT_DIR}/sys_config.fex
sed -i 's/^usb_serial_unique.*/usb_serial_unique = 0/g' ${LICHEE_PACK_OUT_DIR}/sys_config.fex
sed -i 's/^usb_serial_number.*/usb_serial_number = "'"${PACK_CHIP}"'_android"/g' ${LICHEE_PACK_OUT_DIR}/sys_config.fex
fi
printf "copying additional files\n"
for file in ${PACK_ADD_FILES[@]}; do
cp -vf $(echo $file | sed -e 's/:/ /g') 2>/dev/null
done
if [ "x${PACK_PLATFORM}" == "xandroid" ] && [ "x$TARGET_BUILD_VARIANT" == "xuser" ]; then
pack_info "change kernel loglevel to 3 for android user build"
sed -i 's|^\s*loglevel=[0-9]\s*$|loglevel=3|g' ${LICHEE_PACK_OUT_DIR}/env.cfg
if [ "${ENABLE_VENDOR_ADB}" == "true" ]; then
pack_info "enable vendor adb for android user build"
sed -i 's|^init_rc=.*$|init_rc=/vendor/etc/init/hw/init.aw.rc|g' ${LICHEE_PACK_OUT_DIR}/env.cfg
fi
fi
if [ "x${PACK_PROGRAMMER}" = "xprogrammer" ]; then
printf "add programmer img info target in sys config\n"
sed -i -e '/^\[target\]/a\programmer=1' ${LICHEE_PACK_OUT_DIR}/sys_config.fex
fi
sed -i 's/\\boot-resource/\/boot-resource/g' ${LICHEE_PACK_OUT_DIR}/boot-resource.ini
sed -i 's/\\\\/\//g' ${LICHEE_PACK_OUT_DIR}/image.cfg
sed -i 's/^imagename/;imagename/g' ${LICHEE_PACK_OUT_DIR}/image.cfg
[ $? -ne 0 ] && exit 1
cd ${LICHEE_PACK_OUT_DIR}/
echo "vmlinux" > ${LICHEE_PACK_OUT_DIR}/vmlinux.fex
make_user_res sys_partition_nor.fex
make_app_res sys_partition_nor.fex
make_data_res sys_partition_nor.fex
make_user_res sys_partition.fex
make_app_res sys_partition.fex
make_data_res sys_partition.fex
fi
cd - > /dev/null
fi
function img_to_programmer()
local out_img=$1
local in_img=$2
if [ "x${PACK_SECURE}" = "xsecure" ]; then
if [ -f toc0_sdcard.fex ] ; then
programmer_img toc0_sdcard.fex toc1.fex ${out_img} > /dev/null
elif [ -f toc0_nand.fex ] ; then
programmer_img toc0_nand.fex toc1.fex ${out_img} > /dev/null
programmer_img toc0.fex toc1.fex ${out_img} > /dev/null
fi
programmer_img boot0_sdcard.fex boot_package.fex ${out_img} > /dev/null
fi
if [ -f sunxi_gpt.fex ] ; then
#create_img for sunxi_gpt.fex
programmer_img sys_partition.bin sunxi_mbr.fex ${out_img} ${in_img} sunxi_gpt.fex > /dev/null
#create_img for sunxi_mbr.fex
programmer_img sys_partition.bin sunxi_mbr.fex ${out_img} ${in_img} > /dev/null
fi
function uboot_ini_to_dts()
local TARGET_UBOOT
local PLATFORM_ADDR
local SOC_ADDR
local DTC_FLAGS=""
if [ x${LICHEE_BRANDY_UBOOT_VER} == x2023 ]; then
pack_info "skip split fdt"
return
fi
if [ "x${PACK_NOR}" == "xnor" ]; then
TARGET_UBOOT=${LICHEE_PACK_OUT_DIR}/u-boot-spinor.fex
TARGET_UBOOT=${LICHEE_PACK_OUT_DIR}/u-boot.fex
fi
sunxi_ubootools split ${TARGET_UBOOT} > /dev/null
if [ $? -ne 0 ]
then
pack_warn "split uboot and fdt failed!!"
return
fi
[ "$(readlink -f .)" != "$(readlink -f ${LICHEE_PACK_OUT_DIR})" ] && {
mv temp_fdt.dtb ${LICHEE_PACK_OUT_DIR}
mv temp_ubootnodtb.bin ${LICHEE_PACK_OUT_DIR}
# to dts
$DTC_COMPILER ${DTC_FLAGS} -I dtb -O dts -o ${LICHEE_PACK_OUT_DIR}/.uboot.dtb.dts.tmp ${LICHEE_PACK_OUT_DIR}/temp_fdt.dtb 2>/dev/null
PLATFORM_ADDR=`grep -Po "(?<=platform@)(\w+)(?=\s*{)" ${LICHEE_PACK_OUT_DIR}/.uboot.dtb.dts.tmp | head -1`
SOC_ADDR=`grep -Po "(?<=soc@)(\w+)(?=\s*{)" ${LICHEE_PACK_OUT_DIR}/.uboot.dtb.dts.tmp | head -1`
if [ "x${PACK_TYPE}" = "xdragonboard" -o "x${PACK_TYPE}" = "xdragonabts" ] ; then
cat <<- EOF >> ${LICHEE_PACK_OUT_DIR}/.uboot.dtb.dts.tmp
soc@${SOC_ADDR} {
platform@${PLATFORM_ADDR} {
dragonboard_test = <1>;
EOF
fi
# to dtb
$DTC_COMPILER ${DTC_FLAGS} -I dts -O dtb -o ${LICHEE_PACK_OUT_DIR}/temp_fdt.dtb ${LICHEE_PACK_OUT_DIR}/.uboot.dtb.dts.tmp 2>/dev/null
# get update_to_ubootfdt value from sysconfig
sunxi_ubootools subkey_value sys_config.bin sunxi_ubootools update_to_ubootfdt > /dev/null
if [ $? -eq 1 ]; then
echo "uboot ini to dts"
$DTC_COMPILER -p 2048 ${DTC_FLAGS} -@ -O dtb -o ${LICHEE_PACK_OUT_DIR}/new_fdt.dtb \
-b 0 \
-i ${LICHEE_PACK_OUT_DIR} \
-F $DTC_INI_FILE \
-d ${LICHEE_PACK_OUT_DIR}/temp_fdt.dtb ${LICHEE_PACK_OUT_DIR}/.uboot.dtb.dts.tmp 2>/dev/null
mv ${LICHEE_PACK_OUT_DIR}/temp_fdt.dtb ${LICHEE_PACK_OUT_DIR}/new_fdt.dtb
fi
sunxi_ubootools merge ${LICHEE_PACK_OUT_DIR}/temp_ubootnodtb.bin ${LICHEE_PACK_OUT_DIR}/new_fdt.dtb > /dev/null
cp -vf ${LICHEE_PACK_OUT_DIR}/temp_ubootnodtb.bin ${TARGET_UBOOT}
# .uboot.dts is the last dts of uboot
$DTC_COMPILER ${DTC_FLAGS} -I dtb -O dts -o ${LICHEE_PACK_OUT_DIR}/.uboot.dts ${LICHEE_PACK_OUT_DIR}/new_fdt.dtb 2>/dev/null
function do_ini_to_dts()
maybe_busybox unix2dos sys_config.fex
script sys_config.fex > /dev/null
local DTC_SRC_PATH=${LICHEE_PLAT_OUT}
local DTC_COMPILER=${LICHEE_PLAT_OUT}/dtc
local DTC_FLAGS=""
uboot_ini_to_dts
if [ "x${PACK_KERN}" == "xlinux-3.4" \
-o "x${PACK_KERN}" == "xlinux-3.10" \
-o "x${PACK_KERN}" == "xlinux-4.4" \
-o "x${PACK_KERN}" == "xlinux-5.4" \
-o "x${PACK_KERN}" == "xlinux-5.4-ansc" \
-o "x${PACK_KERN}" == "xlinux-5.10" \
-o "x${PACK_KERN}" == "xlinux-5.10-origin" \
-o "x${PACK_KERN}" == "xlinux-5.15" \
-o "x${PACK_KERN}" == "xlinux-5.15-origin" ] || [[ ${PACK_KERN/linux-} > 5.15 ]]; then
# For debug: sunxi.dtb -> .sunxi.dts
$DTC_COMPILER ${DTC_FLAGS} -I dtb -O dts -o ${LICHEE_PLAT_OUT}/.sunxi.dts ${LICHEE_PLAT_OUT}/sunxi.dtb 2>/dev/null
return
fi
local dtc_file_list=(
.board.dtb.d.dtc.tmp:.board.dtb.dts.tmp
.${PACK_CHIP}-${PACK_BOARD}.dtb.d.dtc.tmp:.${PACK_CHIP}-${PACK_BOARD}.dtb.dts.tmp
.${PACK_CHIP}-${LICHEE_BUSSINESS}.dtb.d.dtc.tmp:.${PACK_CHIP}-${LICHEE_BUSSINESS}.dtb.dts.tmp
.${PACK_CHIP}-soc.dtb.d.dtc.tmp:.${PACK_CHIP}-soc.dtb.dts.tmp)
local DTC_INI_FILE_BASE=${LICHEE_PACK_OUT_DIR}/sys_config.fex
local DTC_INI_FILE=${LICHEE_PACK_OUT_DIR}/sys_config_fix.fex
cp $DTC_INI_FILE_BASE $DTC_INI_FILE
sed -i "s/\(\[dram\)_para\(\]\)/\1\2/g" $DTC_INI_FILE
sed -i "s/\(\[nand[0-9]\)_para\(\]\)/\1\2/g" $DTC_INI_FILE
if [ ! -f $DTC_COMPILER ]; then
pack_error "Script_to_dts: Can not find dtc compiler.\n"
exit 1
fi
local DTC_DEP_FILE DTC_SRC_FILE
for e in ${dtc_file_list[@]}; do
DTC_DEP_FILE=$DTC_SRC_PATH/${e/:*}
if [ -f $DTC_DEP_FILE ]; then
DTC_SRC_FILE=$DTC_SRC_PATH/${e#*:}
break
fi
done
echo "sunxi_dtb create"
$DTC_COMPILER -p 2048 ${DTC_FLAGS} -@ -O dtb -o ${LICHEE_PLAT_OUT}/sunxi.dtb \
-b 0 \
-i $DTC_SRC_PATH \
-F $DTC_INI_FILE \
-d $DTC_DEP_FILE $DTC_SRC_FILE 2>/dev/null
if [ $? -ne 0 ]; then
pack_error "Conver script to dts failed"
exit 1
fi
#restore the orignal dtsi
if [ "x${PACK_TYPE}" = "xdragonboard" \
-o "x${PACK_TYPE}" = "xdragonmat" ]; then
local DTS_PATH=${LICHEE_KERN_DIR}/arch/${LICHEE_ARCH}/boot/dts
[ "x${LICHEE_ARCH}" = "xarm64" ] && DTS_PATH=${LICHEE_KERN_DIR}/arch/${LICHEE_ARCH}/boot/dts/sunxi
if [ -f ${DTS_PATH}/${PACK_CHIP}_bak.dtsi ];then
rm -f ${DTS_PATH}/${PACK_CHIP}.dtsi
mv ${DTS_PATH}/${PACK_CHIP}_bak.dtsi ${DTS_PATH}/${PACK_CHIP}.dtsi
fi
fi
printf "Conver script to dts ok.\n"
# It'is used for debug dtb
return
function maybe_busybox()
if [ "x$(which busybox)" == "x" ]; then
pack_error "Tool busybox does not exist!"
exit 1
fi
busybox $@ || $@
function generate_env_for_uboot()
printf "$1 Conver to $2.\n"
printf "LICHEE_BRANDY_UBOOT_VER : ${LICHEE_BRANDY_UBOOT_VER}\n"
if [ -n "${LICHEE_BRANDY_UBOOT_VER}" ] && [ ${LICHEE_BRANDY_UBOOT_VER} -ge 2023 ]; then
printf "create env.fex for uboot2023 or later, size 128K\n"
# mkenvimage -p 0x00 -s 0x20000 -o env.fex env.cfg
mkenvimage -p 0x00 -s 0x20000 -o $2 $1
# u_boot_env_gen env_nor.cfg env_nor.fex >/dev/null
u_boot_env_gen $1 $2 >/dev/null
fi
function do_common()
echo $(date -d "$ts" +"%Y-%m-%d %H:%M:%S") > ${LICHEE_PACK_OUT_DIR}/sunxi_version.fex
# Here, we can switch uart to card or normal
if [ "x${PACK_DEBUG}" = "xcard0" -a "x${PACK_MODE}" != "xdump" \
-a "x${PACK_FUNC}" != "xprvt" ] ; then \
uart_switch
sed -i -e '/^auto_print_used/s\1\0\' ${LICHEE_PACK_OUT_DIR}/sys_config.fex
fi
printf "add burn_secure_mode in target in sys config\n"
sed -i -e '/^\[target\]/a\burn_secure_mode=1' ${LICHEE_PACK_OUT_DIR}/sys_config.fex
sed -i -e '/^\[platform\]/a\secure_without_OS=0' ${LICHEE_PACK_OUT_DIR}/sys_config.fex
if [ -f ${LICHEE_PACK_OUT_DIR}/optee-monitor.fex ]; then
rm -f ${LICHEE_PACK_OUT_DIR}/optee-monitor.fex
fi
sed -i '/^burn_secure_mod/d' ${LICHEE_PACK_OUT_DIR}/sys_config.fex
sed -i '/^secure_without_OS/d' ${LICHEE_PACK_OUT_DIR}/sys_config.fex
mv -v ${LICHEE_PACK_OUT_DIR}/optee-monitor.fex ${LICHEE_PACK_OUT_DIR}/optee.fex
fi
fi
if [ ! -f board_config.fex ]; then
echo "[empty]" > board_config.fex
fi
maybe_busybox unix2dos board_config.fex
cp -f sys_config.bin config.fex
script board_config.fex > /dev/null
cp -f board_config.bin board.fex
if [ "x${PACK_TYPE}" = "xdragonboard" ] ; then
maybe_busybox dos2unix test_config.fex
cp test_config.fex boot-resource/
maybe_busybox unix2dos test_config.fex
script test_config.fex > /dev/null
cp test_config.bin boot-resource/
fi
if [ "x${PACK_TYPE}" = "xdragonabts" ] ; then
fi
# Those files for SpiNor. We will try to find sys_partition_nor.fex
if [ ! -f sys_partition_nor.fex ]; then
echo "sys partition for nor not exist"
exit 1
fi
if [ ! -f ${LICHEE_CHIP_CONFIG_DIR}/tools/arisc_config_parse.sh ]; then
if [ -f "scp.fex" ]; then
echo "update scp"
update_scp scp.fex sunxi.fex >/dev/null
fi
fi
# Here, will create sys_partition_nor.bin
maybe_busybox unix2dos sys_partition_nor.fex
script sys_partition_nor.fex > /dev/null
update_boot0 boot0_spinor.fex sys_config.bin SPINOR_FLASH > /dev/null
update_chip boot0_spinor.fex > /dev/null
update_fes1 fes1.fex sys_config.bin > /dev/null
if [ "x${PACK_KERN}" = "xlinux-3.4" ] ; then
update_uboot -merge u-boot-spinor.fex sys_config.bin > /dev/null
update_uboot -no_merge u-boot-spinor.fex sys_config.bin > /dev/null
update_uboot -no_merge u-boot-spinor-secure.fex sys_config.bin > /dev/null
[ -f u-boot-efex.fex ] && {
update_uboot -no_merge u-boot-efex.fex sys_config.bin > /dev/null
fi
while read line
do
compress_name=(`echo $line | awk '($1 !~ ";" && ($2 ~ "lzma" || $2 ~ "lz4" || $2 ~ "gz")) {print $2}'`)
source_name=(`echo $compress_name | cut -d \. -f 1,2 | cut -d \ -f 2`)
compress_type=(`echo $compress_name | cut -d \. -f 3 | cut -d \ -f 2`)
[ -z "$compress_name" ] && continue
case $compress_type in
"gz")
[ -f $source_name ] && gzip -c $source_name > $compress_name || echo "no exist $source_name"
echo "compress name: $compress_name"
"lzma")
[ -f $source_name ] && lzma -k $source_name || echo "no exist $source_name"
mv $source_name.lzma $compress_name >/dev/null 2<&1
"lz4")
[ -f $source_name ] && lz4 -f $source_name $compress_name || echo "no exist $source_name"
echo "no match compress type"
esac
echo "compress type: $compress_type"
done < boot_package_nor.cfg
if [ -f boot_package_nor.cfg ]; then
mv u-boot-spinor-crash.fex u-boot-crash.fex
echo "pack boot package"
maybe_busybox unix2dos boot_package.cfg
dragonsecboot -pack boot_package_nor.cfg
cp boot_package.fex boot_package_nor.fex
fi
# Ugly, but I don't have a better way to change it.
# We just set env's downloadfile name to env_nor.cfg in sys_partition_nor.fex
# And if env_nor.cfg is not exist, we should copy one.
if [ ! -f env_nor.cfg ]; then
cp -f env.cfg env_nor.cfg >/dev/null 2<&1
fi
#card sprite
if [ -f "boot0_sdcard.fex" ]; then
echo 22222222222222222222222222222222222222
#update_boot0 boot0_sdcard.fex sys_config.bin SDMMC_CARD > /dev/null
#update_chip boot0_sdcard.fex > /dev/null
fi
# Fixup boot mode for SPINor, just can bootm
sed -i '/^boot_normal/s#\<boota\>#bootm#g' env_nor.cfg
echo 1:LICHEE_REDUNDANT_ENV_SIZE:$LICHEE_REDUNDANT_ENV_SIZE
if [ "x${LICHEE_REDUNDANT_ENV_SIZE}" != "x" ]; then
echo "--mkenvimage create redundant env data!--"
echo "--redundant nor env data size ${LICHEE_REDUNDANT_ENV_SIZE}---"
mkenvimage -r -p 0x00 -s ${LICHEE_REDUNDANT_ENV_SIZE} -o env_nor.fex env_nor.cfg
generate_env_for_uboot env_nor.cfg env_nor.fex
fi
echo 333333333333333333333333333333333333333333
#update_boot0 boot0_nand.fex sys_config.bin NAND > /dev/null
#update_boot0 boot0_ufs.fex sys_config.bin UFS > /dev/null
#update_chip boot0_nand.fex >/dev/null
#update_chip boot0_sdcard.fex >/dev/null
#update_chip boot0_ufs.fex >/dev/null
fi
if [ ! -f "u-boot-crash.fex" ]; then
touch "u-boot-crash.fex"
echo "ensure u-boot-crash.fex is not empty" > u-boot-crash.fex
fi
if [ -f "sunxi.fex" ]; then
update_dtb sunxi.fex 4096
fi
echo "update scp"
fi
fi
if [ -f "optee.fex" ]; then
echo "update optee"
update_optee optee.fex sunxi.fex >/dev/null
fi
# Those files for Nand or Card
update_uboot -merge u-boot.fex sys_config.bin > /dev/null
update_uboot -no_merge u-boot.fex sys_config.bin > /dev/null
[ -f u-boot-nodtb.fex ] && {
update_uboot -no_merge u-boot-nodtb.fex sys_config.bin > /dev/null
fi
if [ -f "fes1_uart.fex" ]; then
update_fes1 fes1_uart.fex sys_config.bin > /dev/null
fi
if [ -f ${LICHEE_TOOLS_DIR}/pack/pctools/linux/mod_update/update_sboot ];then
update_sboot sboot.bin sys_config.bin > /dev/null
if [ $? -ne 0 ]
then
pack_error "update sboot run error"
exit 1
fi
fi
fsbuild boot-resource.ini split_xxxx.fex > /dev/null
if [ -f boot_package_uartburn.cfg ]; then
dragonsecboot -pack boot_package_uartburn.cfg
if [ $? -ne 0 ]
then
pack_error "dragon pack boot_package_uartburn run error"
exit 1
fi
mv boot_package.fex boot_package_uartburn.fex
fi
if [ -f boot_package.cfg ]; then
if [ "x$LINUX_DTBO_FILE" = "x" ]; then
echo "do not set LINUX_DTBO_FILE"
line_num=`sed -n -e "/default.dtbo/=" boot_package.cfg`
if [ "x$line_num" != "x" ]; then
sed -i "$line_num s/^/;/g" boot_package.cfg
fi
if [ -f $LINUX_DTBO_FILE ]
then
sed -i "s/default.dtbo/$LINUX_DTBO_FILE/g" boot_package.cfg
fi
fi
fi
dragonsecboot -pack boot_package.cfg
if [ $? -ne 0 ]
then
pack_error "dragon pack run error"
exit 1
fi
fi
echo 2:LICHEE_REDUNDANT_ENV_SIZE:$LICHEE_REDUNDANT_ENV_SIZE
echo "--redundant env data size ${LICHEE_REDUNDANT_ENV_SIZE}---"
mkenvimage -r -p 0x00 -s ${LICHEE_REDUNDANT_ENV_SIZE} -o env.fex env_burn.cfg
generate_env_for_uboot env_burn.cfg env.fex
fi
mkenvimage -r -p 0x00 -s ${LICHEE_REDUNDANT_ENV_SIZE} -o env.fex env.cfg
generate_env_for_uboot env.cfg env.fex
fi
fi
dmverity_deal clean
function do_finish()
# Yeah, it should contain all files into full_img.fex for spinor
# Because, as usually, spinor image size is very small.
# If fail to create full_img.fex, we should fake it empty.
# WTF, it is so ugly!!! It must be sunxi_mbr.fex & sys_partition.bin,
# not sunxi_mbr_xxx.fex & sys_partition_xxx.bin. In order to advoid this
# loathsome thing, we need to backup & copy files. Check whether
# sys_partition_nor.bin is exist, and create sunxi_mbr.fex for Nor.
local max_toc_size=2097152
local IMG_NAME="${PACK_IC}_${PACK_TYPE}${PACK_PLATFORM_VERSION}_${PACK_BOARD}_${PACK_DEBUG}"
IMG_NAME="${IMG_NAME}_${PACK_MODE}"
fi
if [ "x${PACK_FUNC}" = "xprvt" ]; then
IMG_NAME="${IMG_NAME}_${PACK_FUNC}"
fi
if [ "x${PACK_SECURE}" = "xsecure" ] ; then
IMG_NAME="${IMG_NAME}_${PACK_SECURE}"
fi
if [ "x${PACK_FUNC}" = "xprev_refurbish" ] ; then
fi
IMG_NAME="${IMG_NAME}_${PACK_NOR}"
fi
if [ "x${PACK_SECURE}" != "xnone" ]; then
local MAIN_VERION=$(readcfg dragon_toc.cfg rollback_ver ver)
if [ ! -n "${MAIN_VERION}" ]; then
local MAIN_VERION="$(echo '__unique:;@echo ${MAIN_VERSION}' | make -f - -f ${LICHEE_PACK_OUT_DIR}/version_base.mk --no-print-directory __unique)"
fi
IMG_NAME="${IMG_NAME}_v${MAIN_VERION}.img"
IMG_NAME="${IMG_NAME}.img"
fi
local IMG_PROGRAMMER_NAME="${IMG_NAME%.*}_programmer.img"
echo "imagename = $IMG_NAME" >> ${LICHEE_PACK_OUT_DIR}/image.cfg
echo "" >> ${LICHEE_PACK_OUT_DIR}/image.cfg
local imagesize
local toc_size
local max_toc_size=3883264
toc_size=`stat toc1.fex --format="%s"`
toc_size=`stat boot_package.fex --format="%s"`
fi
if [ "$LICHEE_CHIP" == "sun55iw3p1" ]; then
fi
if [ ${toc_size} -gt ${max_toc_size} ];then
pack_error "boot_package.fex/toc1.fex More than ${max_toc_size} bytes limit too large!!!"
exit 1
fi
NOR_LOGIC_START=2016
NOR_UBOOT_START=128
NOR_FLASH_SIZE=65536 #32M
NOR_LOGIC_START_KB=`expr ${NOR_LOGIC_START} / 2`
NOR_UBOOT_START_KB=`expr ${NOR_UBOOT_START} / 2`
local uboot_dts=""
uboot_dts="${LICHEE_BOARD_CONFIG_DIR}/uboot-${LICHEE_BRANDY_UBOOT_VER}/uboot-board.dts"
uboot_dts="${LICHEE_BOARD_CONFIG_DIR}/uboot-board.dts"
fi
if [ -f ${uboot_dts} ] && [ x"$(grep "nor_map" ${uboot_dts})" != x"" ]; then
echo "get flashmap from ${uboot_dts}"
NOR_FLASH_SIZE=$(awk '/nor_map {/,/}/ {print NR ": " $0}' ${uboot_dts} \
| grep "\bflash_size\b" | grep -oP "(?<=\<)\d+(?=\>)")
NOR_LOGIC_START=$(awk '/nor_map {/,/}/ {print NR ": " $0}' ${uboot_dts} \
| grep "\blogic_offset\b" | grep -oP "(?<=\<)\d+(?=\>)")
NOR_UBOOT_START=$(awk '/nor_map {/,/}/ {print NR ": " $0}' ${uboot_dts} \
| grep "\buboot_start\b" | grep -oP "(?<=\<)\d+(?=\>)")
[ x"${NOR_FLASH_SIZE}" = x"" -o x"${NOR_LOGIC_START}" = x"" -o x"${NOR_UBOOT_START}" = x"" ] && {
pack_warn "flash_size,logic_offset,uboot_start maybe not set in uboot-board.dts"
NOR_UBOOT_START=128
echo "flash size:${NOR_FLASH_SIZE}, logic start:${NOR_LOGIC_START}, uboot start:${NOR_UBOOT_START}"
fi
update_mbr sys_partition_nor.bin 1 sunxi_mbr_nor.fex dlinfo.fex \
${NOR_FLASH_SIZE} ${NOR_LOGIC_START} 1
pack_error "update_mbr failed"
exit 1
fi
echo '----------programmer nor image is full_img.fex ----------'
#when use devicetree, the size of uboot+dtb is larger then 256K
#BOOT1_FILE=u-boot-spinor.fex
#LOGIC_START=240 #240+16=256K
#merge_package full_img.fex boot0_spinor.fex \
# u-boot-spinor.fex sunxi_mbr_nor.fex sys_partition_nor.bin
merge_full_img --out full_img.fex --boot0 boot0_spinor.fex --boot1 u-boot-spinor.fex \
--mbr sunxi_mbr_nor.fex --partition sys_partition_nor.bin \
--logic_start 240 > /dev/null
merge_full_img --out full_img.fex --boot0 boot0_spinor.fex --boot1 boot_package_nor.fex \
--mbr sunxi_gpt.fex --partition sys_partition_nor.bin \
--logic_start ${NOR_LOGIC_START_KB} --uboot_start ${NOR_UBOOT_START_KB} > /dev/null
fi
pack_error "merge_full_img failed"
exit 1
fi
mv sys_partition_nor.fex sys_partition.fex
fi
if [ ! -f sys_partition_nor.bin ]; then
update_mbr sys_partition.bin 4
exit 1
fi
#15269888 is from emmc datasheet, sec_count in Extended CSD is 0xe90000 = 15269888.
#40960 is the mbr location for emmc
#0 is emmc/nand ; 1 is spinor
update_mbr sys_partition.bin 4 sunxi_mbr.fex dlinfo.fex 15269888 40960 0
pack_error "update_mbr_gpt failed"
exit 1
fi
fi
echo "===================================="
echo "show sys_partition.fex message"
show_partition_message sys_partition.fex
fi
local e cfgadd cfgget lastcfgline localfile filename
local imgcfg_add_list=(
# localfile filename-in-cfg maintype subtype
'vmlinux.fex vmlinux.fex 12345678 123456789VMLINUX'
'vendor_boot-debug.fex vendor_boot-debug.fex RFSFAT16 VENDOR_BOOTDEBUG'
'dragon_toc.cfg dragon_toc.fex 12345678 12345678DGTOCCFG'
for e in "${imgcfg_add_list[@]}"; do
localfile="$(awk '{print $1}' <<< $e)"
filename="$(awk '{print $2}' <<< $e)"
maintype="$(awk '{print $3}' <<< $e)"
subtype="$(awk '{print $4}' <<< $e)"
cfgget="$(sed -n '/^\s*{\s*filename\s*=\s*"'$filename'"\s*,/p' image.cfg)"
lastcfgline="$(sed -n '/^\s*{\s*filename\s*=/=' image.cfg | tail -1)"
[ ! -f "$localfile" -o -n "$cfgget" -o -z "$lastcfgline" ] && continue
[ "$localfile" != "$filename" ] && ln -sf $localfile $filename
cfgadd=' {filename = "'$filename'",'
cfgadd+=' maintype = "'$maintype'",'
cfgadd+=' subtype = "'$subtype'",},'
sed -i -e ''"${lastcfgline}"'a\' -e "$cfgadd" image.cfg
done
dragon image.cfg sys_partition.fex
if [ $? -eq 0 ]; then
if [ -e ${IMG_NAME} ]; then
mv ${IMG_NAME} $LICHEE_OUT_DIR/$LICHEE_IC/$LICHEE_BOARD/$LICHEE_LINUX_DEV/${IMG_NAME}
rm -f $LICHEE_OUT_DIR/${IMG_NAME}
ln -f $LICHEE_OUT_DIR/$LICHEE_IC/$LICHEE_BOARD/$LICHEE_LINUX_DEV/${IMG_NAME} $LICHEE_OUT_DIR/${IMG_NAME}
imagesize=$(du --apparent-size -sh $LICHEE_OUT_DIR/$LICHEE_IC/$LICHEE_BOARD/$LICHEE_LINUX_DEV/${IMG_NAME} | awk '{print $1}')
echo '----------image is at----------'
echo -e '\033[0;31;1m'
echo -e "$imagesize\t${LICHEE_OUT_DIR}/${IMG_NAME}"
echo -e '\033[0m'
fi
fi
cd ..
if [ -f $LICHEE_PACK_OUT_DIR/super.fex ]; then
mv $LICHEE_PACK_OUT_DIR/super.fex $LICHEE_PACK_OUT_DIR/super.bak.fex
simg2img $LICHEE_PACK_OUT_DIR/super.bak.fex $LICHEE_PACK_OUT_DIR/super.fex
fi
echo "waiting to ceate programmer img..."
img_to_programmer ${IMG_PROGRAMMER_NAME} $LICHEE_OUT_DIR/${LICHEE_IC}/${LICHEE_BOARD}/${LICHEE_LINUX_DEV}/${IMG_NAME}
if [ -e ${IMG_PROGRAMMER_NAME} ]; then
mv $LICHEE_PACK_OUT_DIR/${IMG_PROGRAMMER_NAME} $LICHEE_OUT_DIR/${LICHEE_IC}/${LICHEE_BOARD}/${LICHEE_LINUX_DEV}/${IMG_PROGRAMMER_NAME}
imagesize=$(du --apparent-size -sh $LICHEE_OUT_DIR/${LICHEE_IC}/${LICHEE_BOARD}/${LICHEE_LINUX_DEV}/${IMG_PROGRAMMER_NAME} | awk '{print $1}')
echo '----------programmer image is at----------'
echo -e "$imagesize\t${LICHEE_OUT_DIR}/${IMG_PROGRAMMER_NAME}"
echo -e '\033[0m'
fi
fi
fi
cd ..
do_finish_SATA
printf "pack finish\n"
[ -e ${LICHEE_TOP_DIR}/build/.hooks/post-dragon ] &&
source ${LICHEE_TOP_DIR}/build/.hooks/post-dragon
return 0
function do_finish_SATA()
if [ "x$BUILD_SATA" = "xtrue" ];then
SATA_TAR=$LICHEE_TOP_DIR/SATA/linux/${LICHEE_CHIP}.tar
if [ -f $SATA_TAR ];then
echo '----------SATA is at----------'
echo $SATA_TAR
echo -e '\033[0m'
echo PACK SATA failed!
fi
fi
function dmverity_deal()
local script_name=scripts/build.sh
local script_path=$LICHEE_KERN_DIR
if [ ! -x $script_path/$script_name ]; then
script_path=$LICHEE_BUILD_DIR
script_name=mkkernel.sh
fi
[ ! -x $script_path/$script_name ] && return 255
[ -z "$(grep "^\s*deal_verity)\s*$" $script_path/$script_name)" ] && return 1
(cd $script_path && ./$script_name "deal_verity" $@)
function dmverity_get_blk_count()
local size=`du --apparent-size -b $1 | awk '{print $1}'`
local BLK_SIZE=$2
if [ `expr ${size} % ${BLK_SIZE}` = "0" ]; then
local blks=`(expr ${size} / ${BLK_SIZE})`
local blks=`(expr ${size} / ${BLK_SIZE} + 1 )`
fi
echo $blks
function dmverity_determ_blk_size()
local type_info=`file -L $1`
#check rootfs file system type to determ block size
if [ "x""`echo ${type_info}| grep "ext4 filesystem"`" != "x" ];then
block_size=`tune2fs -l $1|grep "Block size"|awk {'print $3'}`
echo ${block_size}
echo "not support file system type"
return -1
fi
function dmverity_genHashTable()
local fs_name=$1
local tree_name=$2
local table_name=$3
local block_size=`dmverity_determ_blk_size ${fs_name}`
if [ ${block_size} -lt 0 ];then
return -1
fi
veritysetup format --data-block-size=${block_size} --hash-block-size=${block_size} ${fs_name} ${tree_name} > ${table_name}
return $?
function dmverity_genDownloadFile()
local fs_name=$1
local sign_name=$2
local table_name=$3
local tree_name=$4
local download_file_name=$5
local BLK_SIZE=`dmverity_determ_blk_size ${fs_name}`
if [ ${BLK_SIZE} -lt 0 ];then
return -1
fi
local SIGN_BLK=`dmverity_get_blk_count ${sign_name} ${BLK_SIZE}`
local TABLE_BLK=`dmverity_get_blk_count ${table_name} ${BLK_SIZE}`
local TREE_BLK=`dmverity_get_blk_count ${tree_name} ${BLK_SIZE}`
# 3.1 copy sign
dd if=${sign_name} of=${download_file_name}"tmp" bs=${BLK_SIZE} count=${SIGN_BLK} >/dev/null 2>&1
# 3.2 copy table size
local TABLE_SIZE=`du --apparent-size -b ${table_name} | awk '{print $1}'`
local HIGH_BYTES=`expr $TABLE_SIZE / 256 `
local LOW_BYTES=`expr $TABLE_SIZE % 256 `
if [ $HIGH_BYTES -gt 256 ]; then
echo "ERROR rootfs_hash_table size should < 64KB"
return -1
fi
local HIGH_BYTES_H=`echo "obase=16;ibase=10;$HIGH_BYTES" | bc`
local LOW_BYTES_H=`echo "obase=16;ibase=10;$LOW_BYTES" | bc`
echo -e -n "\x$LOW_BYTES_H\x$HIGH_BYTES_H" >> ${download_file_name}"tmp"
# 3.3 copy rootfs_hash_table
dd if=${table_name} of=${download_file_name}"tmp" bs=${BLK_SIZE} seek=${SIGN_BLK} count=${TABLE_BLK} > /dev/null 2>&1
# 3.4 copy rootfs_hash_tree.bin
dd if=${tree_name} of=${download_file_name}"tmp" bs=${BLK_SIZE} seek=`expr ${SIGN_BLK} + ${TABLE_BLK}` count=${TREE_BLK} > /dev/null 2>&1
dd of=${download_file_name} if=${download_file_name}"tmp" bs=${BLK_SIZE} count=`expr ${SIGN_BLK} + ${TABLE_BLK} + ${TREE_BLK}`>/dev/null 2>&1
rm ${download_file_name}"tmp"
function do_signature_dsp()
local DSP0_BIN=${LICHEE_PACK_OUT_DIR}/amp_dsp0.fex;
local DSP1_BIN=${LICHEE_PACK_OUT_DIR}/amp_dsp1.fex;
local CFG_FILE=${LICHEE_CHIP_CONFIG_DIR}/configs/default/image_header_secure.cfg;
if [ -f ${CFG_FILE} ] ; then
cp -v ${CFG_FILE} image_header_secure.cfg
printf "can not found image_header_secure cfg\n"
return 1
fi
if [ -f ${DSP0_BIN} ] ; then
mkimage_header -C 5 -c image_header_secure.cfg -s rsa -k $CFG_KEY_DIR
if [ $? -ne 0 ]
then
pack_error "mkimage_header signature dsp error\n"
exit 1
fi
mv amp_dsp0.fex.pack amp_dsp0.fex
printf "can not found amp_dsp0 bin\n"
return 3
fi
if [ -f ${DSP1_BIN} ] ; then
fi
function do_signature_riscv()
local RV0_BIN=${LICHEE_PACK_OUT_DIR}/amp_rv0.fex;
local RV1_BIN=${LICHEE_PACK_OUT_DIR}/amp_rv1.fex;
local key_type=$(readcfg dragon_toc.cfg key_para key_toc1 | cut -c 1-3)
if [ x${key_type} == "xecc" ]; then
sign_alg=ecc
sign_alg=rsa
fi
return 1
fi
if [ -f ${RV0_BIN} ] ; then
mkimage_header -C 5 -c image_header_secure.cfg -s $sign_alg -k $CFG_KEY_DIR
if [ $? -ne 0 ]
then
pack_error "mkimage_header signature rv error\n"
exit 1
fi
mv amp_rv0.fex.pack amp_rv0.fex
printf "can not found amp_rv0 bin\n"
return 3
fi
if [ -f ${RV1_BIN} ] ; then
mv amp_rv1.fex.pack amp_rv1.fex
fi
function do_signature_ft()
if [ ! -e ${LICHEE_PACK_OUT_DIR}/ft_${PACK_CHIP}.bin ]; then
printf "can not found ft bin\n"
return 1
fi
if [ -e ${LICHEE_PACK_OUT_DIR}/dragon_toc_ft.cfg ]; then
printf "can not found dragon_toc_ft cfg\n"
fi
printf "prepare for signature for ft bin\n"
mv ${LICHEE_PACK_OUT_DIR}/ft_${PACK_CHIP}.bin ${LICHEE_PACK_OUT_DIR}/ft.bin
dragonsecboot -toc0 dragon_toc_ft.cfg $CFG_KEY_DIR ${LICHEE_PACK_OUT_DIR}/version_base.mk > /dev/null
pack_error "dragon toc0_ft run error\n"
exit 1
fi
mv toc0.fex toc0_ft.fex
function do_signature_fel()
printf "prepare for signature for fex tools\n"
local ROOT_KEY_NAME="";
local UBOOT_NAME="u-boot";
local sign_tools=$(readcfg dragon_toc.cfg sign_fel_tools sign_tools)
if [ -f u-boot-efex.fex ]; then
UBOOT_NAME="u-boot-efex"
fi
echo UBOOT_NAME ${UBOOT_NAME}
if [ x${sign_tools} == "xdragonsboot" ]; then
printf "using dragonsboot to sign fel\n"
if [ -f ${CFG_KEY_DIR}/RootKey_Level_0.pem ]; then
ROOT_KEY_NAME=${CFG_KEY_DIR}/RootKey_Level_0.pem
elif [ -f ${CFG_KEY_DIR}/Trustkey.pem ]; then
ROOT_KEY_NAME=${CFG_KEY_DIR}/Trustkey.pem
pack_error "can not found root key to sign fex tool"
exit 1
fi
echo rootkeyname ${ROOT_KEY_NAME}
dragonsecboot -sign fes1.fex ${ROOT_KEY_NAME} ${LICHEE_PACK_OUT_DIR}/version_base.mk > /dev/null
dragonsecboot -sign ${UBOOT_NAME}.fex ${ROOT_KEY_NAME} ${LICHEE_PACK_OUT_DIR}/version_base.mk > /dev/null
if [ $? -ne 0 ]
then
pack_error "dragonsecboot uboot fail"
fi
fi
printf "using sig_fel_image to sign fel\n"
if [ -f ${CFG_KEY_DIR}/RootKey_Level_0.bin ]; then
ROOT_KEY_NAME=${CFG_KEY_DIR}/RootKey_Level_0.bin
elif [ -f ${CFG_KEY_DIR}/Trustkey.bin ]; then
ROOT_KEY_NAME=${CFG_KEY_DIR}/Trustkey.bin
exit 1
fi
sig_fel_image --input fes1.fex --rsakey ${ROOT_KEY_NAME} --output fes1_sign.fex --version_base ${LICHEE_PACK_OUT_DIR}/version_base.mk
if [ $? -ne 0 ]
then
pack_error "sig_fel_image fes fail"
exit 1
fi
sig_fel_image --input ${UBOOT_NAME}.fex --rsakey ${ROOT_KEY_NAME} --output ${UBOOT_NAME}_sign.fex --version_base ${LICHEE_PACK_OUT_DIR}/version_base.mk
if [ $? -ne 0 ]
then
pack_error "sig_fel_image uboot fail"
fi
fi
if [ -f fes1_sign.fex ]; then
cp fes1_sign.fex fes1.fex
fi
if [ -f ${UBOOT_NAME}_sign.fex ]; then
cp ${UBOOT_NAME}_sign.fex ${UBOOT_NAME}.fex
fi
function readcfg()
local fid=$1
local section=$2
local option=$3
test ! -f $fid && echo "file not exits:$fid" && exit 1
if [ $# -eq 3 ] ; then
local src=$(cat $fid | awk '/\['$section'\]/{f=1;next} /\[*\]/{f=0} f' |
grep ^$option |
grep '=' |
cut -d'=' -f2|
cut -d'#' -f1|
cut -d';' -f1|
awk '{gsub(/^\s+|\s+$/, "");print}')
echo -n $src
test ${#src} -eq 0 && return 1 || return 0
echo "the input parameters should be 3"
exit 1
fi
function get_item_from_cfg()
name=()
bin=()
cert=()
counts=0
local toc_cfg=$1
local field=$2
local key=$3
toc1_item_content=$(readcfg ${toc_cfg} ${field} ${key})
i=0
IFS=', ' read -r -a parts <<< $toc1_item_content
for part in "${parts[@]}"; do
if [ $(($i % 3)) -eq 0 ]; then
name[counts]=$part
elif [ $(($i % 3)) -eq 1 ]; then
bin[counts]=$part
cert[counts]=$part
counts=$((counts + 1))
fi
i=$((i + 1))
done
function create_toc0()
local toc_cfg=$1
local key=""
local cert_type=""
local key_type=""
local psck_mode=""
rm -rf toc0
if [ ! -d "toc0" ]; then
mkdir -p toc0
fi
if [ ! -d "temp" ]; then
mkdir -p temp
fi
get_item_from_cfg ${toc_cfg} toc0 item
key=$(readcfg ${toc_cfg} key_toc0 ${name[0]})
cert_type=$(readcfg ${toc_cfg} cert_type cert_type_toc0)
key_type=$(readcfg ${toc_cfg} key_para key_toc0 | cut -c 1-3)
if [ x${key_type} == "xrsa" ]; then
psck_mode=RSA-PKCS
elif [ x${key_type} == "xecc" ]; then
psck_mode=ECDSA
pack_error "key_toc0 type error"
exit 1
fi
#gen sboot hash
dragon_securetool hash --mode 256 --in ${bin[0]} --out ./temp/${bin[0]}.hash.out
if [ $? -ne 0 ]
then
pack_error "gen sboot hash error"
exit 1
fi
#req no sign cert, ext is sboot_hash; use pubkey
dragon_securetool req_cert --type ${cert_type} --cfg ${toc_cfg} --pubkey ${CFG_KEY_DIR}/${key}.pem.pub --ext ./temp/${bin[0]}.hash.out --out ./temp/${name[0]}.req
if [ $? -ne 0 ]
then
pack_error "req no sign cert for toc0 error"
exit 1
fi
#gen no sign cert hash, witch is to be signed
dragon_securetool hash --mode 256 --type ${cert_type} --in ./temp/${name[0]}.req --out ./temp/${name[0]}.req.hash
if [ $? -ne 0 ]
then
pack_error "gen no sign cert hash for toc0 error"
exit 1
fi
#sign cert(to be signed) hash
if [ "x$SOFTHSM_FLAG" == "x1" ]; then
local id=$(echo "$key" | md5sum | awk '{print $1}')
pkcs11-tool --label ${key} --id ${id} -s -p ${PIN} -m ${psck_mode} --module ${MODULES} --input-file ./temp/${name[0]}.req.hash --output-file ./temp/${name[0]}.req.sign
if [ $? -ne 0 ]
then
pack_error "softhsm sign cert(to be signed) hash for toc0 error"
exit 1
fi
dragon_securetool sign --cfg ${toc_cfg} --privatekey ${CFG_KEY_DIR}/${key}.pem --in ./temp/${name[0]}.req.hash --out ./temp/${name[0]}.req.sign
if [ $? -ne 0 ]
then
pack_error "sign cert(to be signed) hash for toc0 error"
exit 1
fi
fi
#create cert with sign
dragon_securetool create_cert --type ${cert_type} --cfg ${toc_cfg} --pubkey ${CFG_KEY_DIR}/${key}.pem.pub --reqfile ./temp/${name[0]}.req --signfile ./temp/${name[0]}.req.sign --out ./toc0/${cert[0]}
if [ $? -ne 0 ]
then
pack_error "create cert with sign for toc0 error"
exit 1
fi
#create toc0.fex(toc0_head + sboot.crtpt + sboot)
dragon_securetool create_toc0 --cfg ${toc_cfg} --out ./toc0.fex
if [ $? -ne 0 ]
then
pack_error "dragon toc0 run error"
exit 1
fi
function do_signature_sboot()
local sboot_file=$1;
local flash_type=$2;
#dram_param
if [ -f ${LICHEE_TOOLS_DIR}/pack/pctools/linux/mod_update/update_sboot ]; then
update_sboot $sboot_file sys_config.bin > /dev/null
if [ $? -ne 0 ]
then
exit 1
fi
fi
update_chip $sboot_file > /dev/null
#dragon_toc only load sboot.bin
[ "$(readlink -f $sboot_file)" != "$(readlink -f sboot.bin)" ] && \
mv $sboot_file sboot.bin
#readcfg determines whether the cfg file is legacy or new
readcfg dragon_toc.cfg key_para key > /dev/null
dragonsecboot -toc0 dragon_toc.cfg $CFG_KEY_DIR ${LICHEE_PACK_OUT_DIR}/version_base.mk > /dev/null
if [ $? -ne 0 ]
then
exit 1
fi
create_toc0 dragon_toc.cfg
fi
update_toc0 toc0.fex sys_config.bin
if [ $? -ne 0 ]
then
pack_error "update toc0 run error"
exit 1
fi
mv sboot.bin $sboot_file
if [ -f toc0_$flash_type.fex ]; then
rm -rf toc0_$flash_type.fex
fi
mv toc0.fex toc0_$flash_type.fex
mv toc0 toc0_$flash_type
function do_signature_toc0()
if [ -f sboot.bin ]; then
do_signature_sboot sboot.bin bak
mv sboot.bin sboot_bak.bin
fi
if [ -f sboot_sdcard.bin ]; then
if [ -f cardscript.fex ]; then
sed -i "s/TOC0_00000000000/TOC0_SDCARD00000/g" cardscript.fex
fi
do_signature_sboot sboot_sdcard.bin sdcard
fi
if [ -f sboot_nand.bin ]; then
do_signature_sboot sboot_nand.bin nand
fi
if [ -f sboot_ufs.bin ]; then
do_signature_sboot sboot_ufs.bin ufs
fi
if [ -f sboot_nor.bin ]; then
do_signature_sboot sboot_nor.bin nor
fi
mv sboot_bak.bin sboot.bin
mv toc0_bak.fex toc0.fex
mv toc0_bak toc0
function toc1_create_cert_for_per_bin()
local toc_cfg=$1
local key=""
local cert_type=""
local key_type=""
local psck_mode=""
cert_type=$(readcfg ${toc_cfg} cert_type cert_type_toc1)
key_type=$(readcfg ${toc_cfg} key_para key_toc1 | cut -c 1-3)
psck_mode=RSA-PKCS
psck_mode=ECDSA
pack_error "key_toc1 type error"
exit 1
fi
for ((count=0; count < counts; count++)); do
key=$(readcfg ${toc_cfg} key_toc1 ${name[count]})
#gen ${bin[count]} hash
dragon_securetool hash --mode 256 --in ${bin[count]} --out temp/${name[count]}_hash.out
if [ $? -ne 0 ]
then
pack_error "gen hash ${name[count]} error"
exit 1
fi
dragon_securetool req_cert --type ${cert_type} --cfg ${toc_cfg} --pubkey ${CFG_KEY_DIR}/$key.pem.pub --ext temp/${name[count]}_hash.out --out temp/${cert[count]}.req
if [ $? -ne 0 ]
then
pack_error "req no sign cert ${name[count]} error"
exit 1
fi
dragon_securetool hash --mode 256 --type ${cert_type} --in temp/${cert[count]}.req --out temp/to_be_signed_${name[count]}_hash.out
if [ $? -ne 0 ]
then
pack_error "gen no sign cert hash ${name[count]} error"
exit 1
fi
pkcs11-tool --label ${key} --id ${id} -s -p ${PIN} -m ${psck_mode} --module ${MODULES} --input-file temp/to_be_signed_${name[count]}_hash.out --output-file temp/${name[count]}_sign.out
if [ $? -ne 0 ]
then
pack_error "softhsm sign cert(to be signed) hash ${name[count]} error"
exit 1
fi
dragon_securetool sign --cfg ${toc_cfg} --privatekey ${CFG_KEY_DIR}/$key.pem --in temp/to_be_signed_${name[count]}_hash.out --out temp/${name[count]}_sign.out
if [ $? -ne 0 ]
then
pack_error "sign cert(to be signed) hash ${name[count]} error"
exit 1
fi
fi
dragon_securetool create_cert --type ${cert_type} --cfg ${toc_cfg} --pubkey ${CFG_KEY_DIR}/${key}.pem.pub --reqfile temp/${cert[count]}.req --signfile temp/${name[count]}_sign.out --out toc1/cert/${cert[count]}
if [ $? -ne 0 ]
then
pack_error "create cert with sign ${name[count]} error"
exit 1
fi
done
function toc1_create_cert_for_rootkey()
local toc_cfg=$1
local key=""
local cert_type=""
local key_type=""
local psck_mode=""
get_item_from_cfg ${toc_cfg} toc1 rootkey
key=$(readcfg ${toc_cfg} key_toc0 rootkey)
psck_mode=RSA-PKCS
psck_mode=ECDSA
exit 1
fi
#rootkey no sign cert
#req no sign rootkey cert, insert extensions in the dragon_toc.cfg; use pubkey
dragon_securetool req_rootkey_cert --type ${cert_type} --cfg ${toc_cfg} --keypath ${CFG_KEY_DIR} --pubkey ${CFG_KEY_DIR}/${key}.pem.pub
if [ $? -ne 0 ]
then
pack_error "req rootkey cert error"
exit 1
fi
mv toc1/cert/${cert[0]} temp/${cert[0]}.req
#gen no sign rootkey cert hash, witch is to be signed; Non-x509 certificates do not need to skip 4 bytes
dragon_securetool hash --mode 256 --type ${cert_type} --in temp/${cert[0]}.req --out temp/to_be_signed_${name[0]}_hash.out
if [ $? -ne 0 ]
then
pack_error "gen no sign rootkey cert hash error"
exit 1
fi
#sign rootkey cert(to be signed) hash
pkcs11-tool --label ${key} --id ${id} -s -p ${PIN} -m ${psck_mode} --module ${MODULES} --input-file temp/to_be_signed_${name[0]}_hash.out --output-file temp/${name[0]}_sign.out
if [ $? -ne 0 ]
then
pack_error "softhsm sign rootkey cert(to be signed) hash error"
exit 1
fi
dragon_securetool sign --cfg ${toc_cfg} --privatekey ${CFG_KEY_DIR}/${key}.pem --in temp/to_be_signed_${name[0]}_hash.out --out temp/${name[0]}_sign.out
if [ $? -ne 0 ]
then
pack_error "sign rootkey cert(to be signed) hash error"
exit 1
fi
fi
#create rootkey cert with sign
dragon_securetool create_cert --type ${cert_type} --cfg ${toc_cfg} --pubkey ${CFG_KEY_DIR}/${key}.pem.pub --reqfile temp/${cert[0]}.req --signfile temp/${name[0]}_sign.out --out toc1/cert/${cert[0]}
if [ $? -ne 0 ]
then
pack_error "create rootkey cert with sign error"
exit 1
fi
function do_signature_toc1()
rm -rf toc1
if [ ! -d "toc1/cert" ]; then
mkdir -p toc1/cert
fi
mkdir -p temp
fi
#create cert for toc1 item
get_item_from_cfg dragon_toc.cfg toc1 item
toc1_create_cert_for_per_bin dragon_toc.cfg
#create cert for toc1 onlykey
get_item_from_cfg dragon_toc.cfg toc1 onlykey
toc1_create_cert_for_rootkey dragon_toc.cfg
#create toc1.fex(toc1_head + rootkey.crtpt + ..)
dragon_securetool create_toc1 --cfg dragon_toc.cfg --out toc1.fex
if [ $? -ne 0 ]
then
pack_error "dragon toc1 run error"
exit 1
fi
function do_signature()
printf "prepare for signature by openssl\n"
if [ ! -d $CFG_KEY_DIR ] ; then
pack_error "No key exist, please run './build/createkeys' to generate keys first."
exit 1
fi
if [ "x${PACK_SIG}" = "xprev_refurbish" ] ; then
if [ "x${LICHEE_ARCH}" = "xarm64" ] ; then
cp -v ${LICHEE_COMMON_CONFIG_DIR}/sign_config/dragon_toc_a64_no_secureos.cfg dragon_toc.cfg
cp -v ${LICHEE_COMMON_CONFIG_DIR}/sign_config/dragon_toc_no_secureos.cfg dragon_toc.cfg
fi
if [ -f ${LICHEE_CHIP_CONFIG_DIR}/configs/default/dragon_toc.cfg ] ; then
cp -v ${LICHEE_CHIP_CONFIG_DIR}/configs/default/dragon_toc.cfg dragon_toc.cfg
cp -v ${LICHEE_COMMON_CONFIG_DIR}/sign_config/dragon_toc_a64.cfg dragon_toc.cfg
fi
cp -v ${LICHEE_COMMON_CONFIG_DIR}/sign_config/dragon_toc.cfg dragon_toc.cfg
fi
fi
fi
fi
if [ -f ${CFG_KEY_DIR}/softhsm2.cfg ]; then
# fix tokendir
tokendir=$(grep tokendir ${CFG_KEY_DIR}/softhsm2.cfg | awk '{print $3}')
if [ "x$tokendir" != "x${CFG_KEY_DIR}/.token" ]; then
sed -i "s#${tokendir}#${CFG_KEY_DIR}/.token#g" ${CFG_KEY_DIR}/softhsm2.cfg
fi
PIN=1234
SOPIN=12345678
SOFTHSM_TOOLS_DIR=${LICHEE_TOOLS_DIR}/pack/pctools/linux/softhsm
MODULES=${SOFTHSM_TOOLS_DIR}/lib/softhsm/libsofthsm2.so
export LD_LIBRARY_PATH=${SOFTHSM_TOOLS_DIR}/lib:${SOFTHSM_TOOLS_DIR}/lib/softhsm:${LIB_LIBRARY_PATH}
export PATH=${SOFTHSM_TOOLS_DIR}/bin:$PATH
export SOFTHSM2_CONF=${CFG_KEY_DIR}/softhsm2.cfg
SOFTHSM_FLAG=1
fi
if [ $? -ne 0 ]
then
pack_error "dragon toc config file is not exist"
exit 1
fi
rm -f cardscript.fex
mv cardscript_secure.fex cardscript.fex
if [ $? -ne 0 ]
then
pack_error "dragon cardscript_secure.fex file is not exist"
exit 1
fi
if [ ! -f ${LICHEE_PLAT_OUT}/recovery.img ]; then
printf "recovery img is not exist, remove recovery cert from dragon_toc.cfg\n"
sed -i '/recovery/d' dragon_toc.cfg > /dev/null
local recovery_buf=$(grep "recovery" -nr dragon_toc.cfg)
if [ x"${recovery_buf}" = x"" ]; then
sed -i '/^onlykey=boot/a\onlykey=recovery, recovery.fex, SCPFirmwareContentCertPK' dragon_toc.cfg
sed -i '/^boot=/a recovery=NonTrustedFirmwareContentCertPK' dragon_toc.cfg
sed -i '/^onlykey=boot/a\onlykey=recovery, recovery.fex, recovery.crtpt' dragon_toc.cfg
fi
fi
fi
if [ "x${PACK_VERITY}" = "x${FLAGS_TRUE}" ]; then
# verity setup for squashfs type filesystem
if [ x"${PACK_PLATFORM}" = x"openwrt" ] || [ x"${PACK_PLATFORM}" = x"bsp" ] || [ x"${PACK_PLATFORM}" = x"buildroot" ]; then
rm -rf rootfs.fex
local link_real_new=$(get_realpath ${LICHEE_PLAT_OUT} ./)
cp ${link_real_new}/rootfs.img rootfs.fex
cp ${link_real_new}/rootfs.squashfs rootfs.fex
fi
if [ "x${PACK_KERN}" == "xlinux-5.4" \
-o "x${PACK_KERN}" == "xlinux-5.15-origin" ]; then
squashfs_real_size=`hexdump -s 0x28 -n 4 -e '/4 "%d"' rootfs.fex`
squashfs_data_blocks=`expr \( ${squashfs_real_size} + 4095 \) / 4096`
local TEMP=${LC_ALL}
export LC_ALL=C
veritysetup --data-blocks=${squashfs_data_blocks} format rootfs.fex hash_tree > raw_table
export LC_ALL=${TEMP}
sed -i '/^onlykey=boot/a\onlykey=rootfs, hash_tree, SCPFirmwareContentCertPK' dragon_toc.cfg
sed -i '/^boot=/a rootfs=NonTrustedFirmwareContentCertPK' dragon_toc.cfg
sed -i '/^onlykey=boot/a\onlykey=rootfs, hash_tree, rootfs.crtpt' dragon_toc.cfg
fi
# get sample from squashfs rootfs
local rootfs_per_MB=`grep "^rootfs_per_MB=" env.cfg | awk -F = '{printf $2}'`
if [ -z $rootfs_per_MB ]; then
echo "rootfs_per_MB is not defined in env.cfg, use default value 4096"
rootfs_per_MB=4096
fi
extract_squashfs $rootfs_per_MB rootfs.fex rootfs-extract.fex
echo "extract squashfs error"
exit 1;
fi
sed -i '/^onlykey=boot/a\onlykey=rootfs, rootfs-extract.fex, SCPFirmwareContentCertPK' dragon_toc.cfg
sed -i '/^onlykey=boot/a\onlykey=rootfs, rootfs-extract.fex, rootfs.crtpt' dragon_toc.cfg
fi
fi
# generate verity data, suport more different filesystem in the future
(dmverity_genHashTable rootfs.fex rootfsHashTree.fex rootfsHashTable.fex &&
openssl dgst -sha256 -binary -sign $CFG_KEY_DIR/SCPFirmwareContentCertPK.pem rootfsHashTable.fex > rootfsHashSign.fex &&
openssl rsa -in $CFG_KEY_DIR/SCPFirmwareContentCertPK.pem -pubout -out rootfsPubKey.pk &&
dmverity_genDownloadFile rootfs.fex rootfsHashSign.fex rootfsHashTable.fex rootfsHashTree.fex VerityInfo.fex) ||
{ pack_error "generate verity data failed"; exit 1; }
# add partition for verity data
(add_partition -2 rootfsverityInfo 4096 "VerityInfo.fex" &&
maybe_busybox unix2dos sys_partition.fex &&
script sys_partition.fex > /dev/null) ||
{ pack_error "add verity info part failed"; exit 1; }
# add verity tools into ramdisk
local rootfsPath=`readlink -f rootfs.fex`
local keyPath=`readlink -f rootfsPubKey.pk`
local blockSize=`dmverity_determ_blk_size ${rootfsPath}`
dmverity_deal $blockSize rootfsverityInfo ext4 $keyPath ||
{ pack_error "deal verity utils failed"; exit 1; }
fi
fi
if [ "x${PACK_SIGNFEL}" = "x${FLAGS_TRUE}" ]; then
do_signature_fel
fi
do_signature_ft
do_signature_toc0
dragonsecboot -toc1 dragon_toc.cfg $CFG_KEY_DIR ${LICHEE_PACK_OUT_DIR}/cnf_base.cnf ${LICHEE_PACK_OUT_DIR}/version_base.mk
if [ $? -ne 0 ]
then
exit 1
fi
cert=".der"
do_signature_toc1
cert=".crtpt"
fi
sigbootimg --image boot.fex --cert toc1/cert/boot${cert} --output boot_sig.fex
if [ $? -ne 0 ] ; then
pack_error "Pack cert to image error"
exit 1
mv -f boot_sig.fex boot.fex
fi
do_signature_dsp
do_signature_riscv
verity_root_hash_str=`grep "Root hash:" raw_table | awk '{print $3}'`
verity_salt_str=`grep "Salt:" raw_table | awk '{print $2}'`
update_squashfs_verity -f rootfs.fex -c toc1/cert/rootfs${cert} -t hash_tree -r ${verity_root_hash_str} -s ${verity_salt_str}
pack_error "add verity block error."
exit 1
fi
update_squashfs rootfs.fex toc1/cert/rootfs${cert}
if [ $? -ne 0 ]
then
pack_error "signature squashfs rootfs error."
exit 1
fi
fi
fi
fi
local link_real=$(get_realpath ${LICHEE_PLAT_OUT} ./)
local recovery_path=${link_real}/recovery.img
if [ -f "$recovery_path" ]; then
sigbootimg --image recovery.fex --cert toc1/cert/recovery${cert} --output recovery_sig.fex
exit 1
mv -f recovery_sig.fex recovery.fex
fi
fi
echo "secure signature ok!"
function do_android_signature()
line_num=`sed -n -e "/default.dtbo/=" dragon_toc.cfg`
sed -i "$line_num s/^/;/g" dragon_toc.cfg
fi
then
sed -i "s/default.dtbo/$LINUX_DTBO_FILE/g" dragon_toc.cfg
fi
fi
fi
if [ $? -ne 0 ]
then
exit 1
fi
if [ $? -ne 0 ]
then
exit 1
fi
do_signature_ft
do_signature_toc0
if [ $? -ne 0 ]
then
exit 1
fi
cert=".der"
do_signature_toc1
cert=".crtpt"
fi
if [ -e dboot.fex ]; then
local keyname=$(awk -F, '/^[[:space:]]*onlykey=boot\S*,[[:space:]]*dboot.fex,/{print $1}' dragon_toc.cfg | awk -F= '{print $2}')
sigbootimg --image dboot.fex --cert toc1/cert/${keyname}${cert} --output dboot_sig.fex
[ $? -ne 0 ] && pack_error "Pack cert to image error" && exit 1
mv -f dboot_sig.fex dboot.fex
fi
echo "secure android signature ok!"
################################ Tina func ################################
function get_partition_downfile_size()
local downloadfile_name=`echo $1 | awk -F '=' '{print $2}'`
if [ x${downloadfile_name: 0-4} != x".fex" ]; then
pack_error "downloadfile format is wrong, it should be end with .fex"
exit -1
fi
if [ ! -f ${downloadfile_name} ]; then
echo " file ${downloadfile_name} not find"
if [ -L ${downloadfile_name} ]; then
local downloadfile_name_link=`readlink -f ${downloadfile_name}`
local linkfile_name=${downloadfile_name_link##*/}
echo " ${downloadfile_name} -> ${downloadfile_name_link}"
if [ ! -f ${downloadfile_name_link} ]; then
echo " link file ${linkfile_name} not find"
local linkfile_size=`ls -lh ${downloadfile_name_link} | awk '{print $5}'`
echo " ${linkfile_name} size : ${linkfile_size} byte"
fi
local downloadfile_size=`ls -lh ${downloadfile_name} | awk '{print $5}'`
echo " ${downloadfile_name} size : ${downloadfile_size} byte"
fi
fi
function get_partition_mbr_size()
local partition_size_name=`echo $1 | awk -F '=' '{print $1}' | sed 's/partition/mbr/g'`
local partition_size=`echo $1 | awk -F '=' '{print $2}'`
echo " ${partition_size_name} : ${partition_size} Kbyte"
function show_partition_message()
grep -c '[mbr]' $1 > /dev/null
cp $1 ./show_sys_partition.tmp;
sed -i '/^[\r;]/d' ./show_sys_partition.tmp;
sed -i '/partition_start/d' ./show_sys_partition.tmp;
sed -i '/user_type/d' ./show_sys_partition.tmp;
sed -i 's/\[partition\]/------------------------------------/g' ./show_sys_partition.tmp;
sed -i 's/[ "\r]//g' ./show_sys_partition.tmp;
sed -i '/^[;]/d' ./show_sys_partition.tmp;
sed -i 's/name/partition_name/g' ./show_sys_partition.tmp;
sed -i 's/size/partition_size/g' ./show_sys_partition.tmp;
echo "------------------------------------"
while read line
do
if [ "$line" == "------------------------------------" ];then
echo "$line"
echo " $line" | sed 's/=/ : /g'
echo " $line" | grep "mbr" >> /dev/null
read line
get_partition_mbr_size $line
fi
echo "$line" | grep "downloadfile" >> /dev/null
get_partition_downfile_size $line
fi
fi
done < ./show_sys_partition.tmp
rm ./show_sys_partition.tmp
echo "==========input is not a partition file=========="
fi
function sparse_ext4()
local img=$1
local sparse_img=$2
if file $img | grep -q ext4 ;then
echo "now make sparse ext4 img: $img"
echo "$img is not ext4 img"
file $img
return
fi
img2simg $img $sparse_img
# pack user resources to a vfat filesystem
# To use this, please add a folder "user-resource" in configs to save files, and add a partition to sys_partition.fex/sys_partition_nor.fex like this:
# [partition]
# name = user-res
# size = 1024 //size should be 32 aligned
# downloadfile = "user-resource.fex"
# user_type = 0x8000
function make_user_res()
printf "make user resource for : $1\n"
local USER_RES_SYS_PARTITION=$1
local USER_RES_PART_NAME=user-res
local USER_RES_FILE=user-resource
printf "handle partition ${USER_RES_PART_NAME}\n"
local USER_RES_PART_DOWNLOAD_FILE=user-resource.fex
local USER_RES_PART_SIZE=`sed -n "/${USER_RES_PART_NAME}/{N;p}" ${USER_RES_SYS_PARTITION} | awk '$0~"size"{print $3/2}'`
local USER_RES_FILE_PATH=$CFG_TOP_DIR/${PACK_PLATFORM}/target/$PACK_IC/$PACK_IC-${PACK_BOARD}/configs/${USER_RES_FILE}
if [ x"${USER_RES_PART_DOWNLOAD_FILE}" != x"" -a x"${USER_RES_PART_SIZE}" != x"" ]; then
rm -f ${LICHEE_PACK_OUT_DIR}/user-resource.fex
mkfs.vfat ${LICHEE_PACK_OUT_DIR}/user-resource.fex -C ${USER_RES_PART_SIZE}
if [ -d ${USER_RES_FILE_PATH} ]; then
USER_RES_FILE_SIZE=`du --apparent-size --summarize "${USER_RES_FILE_PATH}" | awk '{print $1}'`
printf "file size: ${USER_RES_FILE_SIZE}\n"
printf "partition size: ${USER_RES_PART_SIZE}\n"
if [ ${USER_RES_PART_SIZE} -le ${USER_RES_FILE_SIZE} ]; then
printf "file size is larger than partition size, please check your configuration\n"
printf "please enlarge size of ${USER_RES_PART_NAME} in sys_partition or remove some files in $USER_RES_FILE_PATH\n"
exit -1
fi
mcopy -s -v -i ${LICHEE_PACK_OUT_DIR}/${USER_RES_PART_DOWNLOAD_FILE} ${USER_RES_FILE_PATH}/* ::
printf "mcopy file fail, exit\n"
exit -1
fi
printf "can not find ${USER_RES_FILE_PATH}, ignore it\n"
fi
printf "no user resource partitions\n"
fi
#[partition]
# name = app
# size = 10080
# downloadfile = "app.fex"
function make_app_res()
local APP_PART_NAME=app
cp $1 sys_partition_tmp_app.fex
sed -i '/^[ \t]*downloadfile/d' sys_partition_tmp_app.fex
maybe_busybox unix2dos sys_partition_tmp_app.fex
script sys_partition_tmp_app.fex > /dev/null
update_mbr sys_partition_tmp_app.bin 1 sunxi_mbr_tmp_app.fex > /dev/null
local APP_PART_DOWNLOAD_FILE=app.fex
local APP_PART_FILE_PATH=$CFG_TOP_DIR/out/$PACK_IC/$PACK_BOARD/$PACK_PLATFORM/build_dir/target/app
local APP_PART_SIZE_IN_SECTOR=`parser_mbr sunxi_mbr_tmp_app.fex get_size_by_name ${APP_PART_NAME}`
local TINA_TOOLS_PATH=$CFG_TOP_DIR/out/$PACK_IC/$PACK_BOARD/$PACK_PLATFORM/staging_dir/host/bin
if [ x${APP_PART_DOWNLOAD_FILE} != x'' -a x${APP_PART_SIZE_IN_SECTOR} != x'' ]; then
let APP_PART_SIZE_IN_K=$APP_PART_SIZE_IN_SECTOR/2
echo "APP_PART_DOWNLOAD_FILE = ${LICHEE_PACK_OUT_DIR}/${APP_PART_DOWNLOAD_FILE}"
rm -f ${LICHEE_PACK_OUT_DIR}/${APP_PART_DOWNLOAD_FILE}
${TINA_TOOLS_PATH}/make_ext4fs -l ${APP_PART_SIZE_IN_K}k -b 1024 -m 0 -j 1024 ${LICHEE_PACK_OUT_DIR}/${APP_PART_DOWNLOAD_FILE} ${APP_PART_FILE_PATH}
printf "no app resource partitions\n"
fi
#[partition]
# name = data
# size = 10080
# downloadfile = "data.fex"
function make_data_res()
local DATA_PART_NAME=data
cp $1 sys_partition_tmp_data.fex
sed -i '/^[ \t]*downloadfile/d' sys_partition_tmp_data.fex
maybe_busybox unix2dos sys_partition_tmp_data.fex
script sys_partition_tmp_data.fex > /dev/null
update_mbr sys_partition_tmp_data.bin 1 sunxi_mbr_tmp_data.fex > /dev/null
local DATA_PART_DOWNLOAD_FILE=data.fex
local DATA_PART_DOWNLOAD_FILE_SPARSE=data_s.fex
local DATA_PART_FILE_PATH=$CFG_TOP_DIR/out/$PACK_IC/$PACK_BOARD/$PACK_PLATFORM/build_dir/target/data
local DATA_PART_SIZE_IN_SECTOR=`parser_mbr sunxi_mbr_tmp_data.fex get_size_by_name ${DATA_PART_NAME}`
if [ x${DATA_PART_DOWNLOAD_FILE} != x'' -a x${DATA_PART_SIZE_IN_SECTOR} != x'0' ]; then
let DATA_PART_SIZE_IN_K=$DATA_PART_SIZE_IN_SECTOR/2
echo "DATA_PART_DOWNLOAD_FILE = ${LICHEE_PACK_OUT_DIR}/${DATA_PART_DOWNLOAD_FILE}"
rm -f ${LICHEE_PACK_OUT_DIR}/${DATA_PART_DOWNLOAD_FILE}
rm -f ${LICHEE_PACK_OUT_DIR}/${DATA_PART_DOWNLOAD_FILE_SPARSE}
${TINA_TOOLS_PATH}/make_ext4fs -l ${DATA_PART_SIZE_IN_K}k -b 1024 -m 0 -j 1024 ${LICHEE_PACK_OUT_DIR}/${DATA_PART_DOWNLOAD_FILE} ${DATA_PART_FILE_PATH}
sparse_ext4 ${LICHEE_PACK_OUT_DIR}/${DATA_PART_DOWNLOAD_FILE} ${LICHEE_PACK_OUT_DIR}/${DATA_PART_DOWNLOAD_FILE_SPARSE}
printf "no data resource partitions\n"
fi
################################ Platform func ################################
function do_pack_android()
local localpath=$(readlink -f $(pwd))
local androidout=$(readlink -f ${ANDROID_IMAGE_OUT})
local link_real=$(get_realpath $androidout $localpath)
printf "packing for android\n"
if [ -z "${ANDROID_IMAGE_OUT}" ] ; then
pack_error "please specify ANDROID_IMAGE_OUT env"
exit 1
fi
local fex_list=($(\gawk '$0~"^[[:space:]]*downloadfile[[:space:]]*="{print $NF}' sys_partition.fex | sed 's/[",\r,\n]//g'))
fex_list+=(vendor_boot-debug.fex)
local img_name=""
for fex_name in ${fex_list[@]}; do
img_name=${fex_name%\.fex}.img
if [ -f ${ANDROID_IMAGE_OUT}/${img_name} ]; then
ln -sf ${link_real}/${img_name} ${fex_name}
echo "link ${img_name} -> ${fex_name}"
fi
done
if [ -e $androidout/vmlinux ]; then
export PATH=$PATH:${LICHEE_TOP_DIR}/build/bin
local vmlinuxpath=$(dirname $(readlink -f $androidout/vmlinux))
local vmlinuxname=$(basename $(readlink -f $androidout/vmlinux))
(cd $vmlinuxpath && tar cf $localpath/vmlinux.tar.bz2 --use-compress-prog=lbzip2 $vmlinuxname)
rm -rf vmlinux.fex
ln -sf vmlinux.tar.bz2 vmlinux.fex
fi
if [ -n "${PACK_BOOT_PATH}" ] && [ "x${PACK_BOOT_PATH}" != "xnone" ]; then
ln -sf $PACK_BOOT_PATH boot.fex
fi
echo "secure"
echo "normal"
fi
function prepare_mixed_androiddragonboard()
local mixed_fw_type
if [ "${PACK_TYPE}" != "android" ] || [ -z "$PACK_MIXED_FIRMWARE" ]; then
return 0
fi
case "$PACK_MIXED_FIRMWARE" in
dragonboard|dragonabts)
mixed_fw_type="$PACK_MIXED_FIRMWARE"
pack_info "${FUNCNAME[0]}: mixed firmware type: $mixed_fw_type"
echo "Unsupport mixed firmware type: $PACK_MIXED_FIRMWARE"
return 1
esac
local mixedboardout=$(readlink -f ${CFG_PLAT_OUT}/../$mixed_fw_type)
if [ ! -d $mixedboardout ]; then
pack_error "${FUNCNAME[0]}: cannot find out path for $mixed_fw_type"
exit 1
fi
local envpath=($LICHEE_BOARD_CONFIG_DIR/$mixed_fw_type $LICHEE_CHIP_CONFIG_DIR/configs/default)
local partition=(bootloader_b:boot-resource.fex env_b:denv.fex
boot_b:dboot.fex vendor_boot_b:vendor_boot.fex media_data)
local item name linenum nstart nend nmax file
for item in ${partition[@]}; do
name=${item/:*}
linenum=$(sed -n "/^\s*name\s*=\s*$name/=" sys_partition.fex)
if [ -z "$linenum" ]; then
pack_error "${FUNCNAME[@]}: leak neccery partition $name in sys_partition.fex"
exit 1
fi
done
for item in ${envpath[@]}; do
if [ -e $item/env.cfg ]; then
cp $item/env.cfg denv.cfg
sed -i '/^\s*boot_normal=/s/\<boot\>/boot_b/g' denv.cfg
generate_env_for_uboot denv.cfg $mixedboardout/env.img
rm -rf denv.cfg
break
fi
done
if [ ! -e $mixedboardout/env.img ] || \
[ ! -e $mixedboardout/boot.img ] || \
[ ! -e $mixedboardout/rootfs.ext4 ] || \
[ ! -e $LICHEE_BOARD_CONFIG_DIR/$mixed_fw_type/test_config.fex ]; then
pack_error "${FUNCNAME[@]}: leak neccery img/fex for $mixed_fw_type"
exit 1
fi
printf "prepare for mixed android/$mixed_fw_type packing...\n"
name=${item/:*}
nstart=$linenum
nend=$linenum
nmax=$(wc -l sys_partition.fex | awk '{print $1}')
while [ $nstart -gt 1 ]; do
nstart=$((nstart-1))
if [ -n "$(sed -n "$nstart p" sys_partition.fex | grep "^\s*\[\S\+\]")" ]; then
break;
fi
done
while [ $nend -lt $nmax ]; do
nend=$((nend+1))
if [ -n "$(sed -n "$nend p" sys_partition.fex | grep "^\s*\[\S\+\]")" ]; then
break;
fi
done
[ $nend -ne $nmax ] && nend=$((nend-1))
file="$(sed -n "${nstart},${nend}p" sys_partition.fex | \
awk -F= '/^[[:space:]]*downloadfile[[:space:]]*=/{print $2}')"
dlfile=${e#*:}
case $name in
bootloader_b|env_b|boot_b|vendor_boot_b)
if [ -z "$file" ]; then
sed -i "$linenum a\ \ \ \ downloadfile = \"${item#*:}\"" sys_partition.fex
fi
media_data)
local cmd="$nstart i"
local size=$(stat $mixedboardout/rootfs.ext4 --format="%s")
size=$(((size+32*1024*1024-1)/(16*1024*1024)*16)) # at least size + 16M, and 16M align
if [ -z "$(grep "^\s*name\s*=\s*rootfs" sys_partition.fex)" ]; then
cmd+="[partition]\n"
cmd+=" name = rootfs\n"
cmd+=" size = ${size}M\n"
cmd+=" downloadfile = \"drootfs.fex\"\n"
cmd+=" user_type = 0x8000\n"
cmd+="\n"
fi
[ "$cmd" != "$nstart i" ] && sed -i "$cmd" sys_partition.fex
esac
done
# Delete "^M" under Windows
sed -i 's|
||g' sys_partition.fex
[ -z "$(grep "^\s*onlykey=boot_b,\s*dboot.fex," dragon_toc.cfg)" ] && \
sed -i 's|^\(\s*onlykey=boot_b,\s*\)\S*,|\1dboot.fex,|g' dragon_toc.cfg
echo "onlykey=boot_b,dboot.fex,SCPFirmwareContentCertPK" >> dragon_toc.cfg
if [ -z "$(grep "^\s*onlykey=boot_b,\s*dboot.fex," dragon_toc.cfg)" ]; then
sed -i '/^optee=/a boot_b=SCPFirmwareContentCertPK' dragon_toc.cfg
sed -i '/^item=optee/a\onlykey=boot_b,dboot.fex,boot_b.crtpt' dragon_toc.cfg
fi
fi
cp $LICHEE_BOARD_CONFIG_DIR/$mixed_fw_type/test_config.fex .
cp $mixedboardout/env.img denv.fex
cp $mixedboardout/boot.img dboot.fex
cp $mixedboardout/rootfs.ext4 drootfs.fex
echo "android:$PACK_MIXED_FIRMWARE" > mixed-image-type.txt
pack_error "${FUNCNAME[0]} fail"
return 1
fi
return 0
function do_pack_dragonboard()
printf "packing for dragonboard\n"
ln -sf ${link_real}/boot.img boot.fex
ln -sf ${link_real}/rootfs.ext4 rootfs.fex
ln -sf ${link_real}/rootfs.ubifs rootfs-ubifs.fex
do_signature
echo "normal"
fi
function do_pack_dragonabts()
printf "packing for dragonabts\n"
do_signature
echo "normal"
fi
function do_pack_linux()
printf "packing for linux\n"
do_fit_image
[ -f kernel.itb ] && mv kernel.itb kernel.fex
[ -f kernel-dtb.itb ] && mv kernel-dtb.itb kernel-dtb.fex
[ -f ${link_real}/bootB.img ] && ln -sf ${link_real}/bootB.img bootB.fex
# Those files is ready for SPINor.
ln -sf ${link_real}/uImage kernel.fex
ln -sf ${link_real}/rootfs.img rootfs_nor.fex
ln -sf ${link_real}/rootfs.squashfs rootfs_nor.fex
fi
fi
ln -sf ${link_real}/rootfs.img rootfs.fex
fi
ln -sf ${recovery_path} recovery.fex
fi
echo "secure"
do_signature
echo "normal"
fi
function create_kernel_fit_image()
local its_name=$1
printf "create_kernel_fit_image\n"
if [ ! -f ${LICHEE_PACK_OUT_DIR}/${its_name}.its ]; then
printf "can not found ${its_name}.its\n"
return 1
fi
mkimage -f ${its_name}.its ${its_name}.itb
pack_error "mkimage ${its_name}.itb error\n"
exit 1
fi
function do_fit_image()
printf "do_fit_image\n"
create_kernel_fit_image kernel
return 1
fi
create_kernel_fit_image kernel-dtb
return 1
fi
function main()
local output_resources=${FLAGS_output_resources:-false}
local from_resources=${FLAGS_from_resources}
local support_secure_type
case x$LICHEE_PACK_SECURE_TYPE in
xnone|xsecure|xany)
support_secure_type=$LICHEE_PACK_SECURE_TYPE
x)
support_secure_type=any
pack_error "Unsupport pack secure type: $LICHEE_PACK_SECURE_TYPE"
return 1
esac
if [ "$support_secure_type" != "any" ] && [ "$support_secure_type" != "$PACK_SECURE" ]; then
pack_error "This platform only support secure type [$support_secure_type], but current using [$PACK_SECURE], please check!!!"
pack_error "Now, we try using secure type [$support_secure_type]!!!"
PACK_SECURE=$support_secure_type
fi
if [ "$output_resources" == "false" ] && [ -z "$from_resources" ]; then
do_prepare
do_ini_to_dts
do_common
do_pack_${PACK_TYPE}
do_finish
return $?
fi
if [ "$output_resources" == "true" ]; then
do_prepare
do_ini_to_dts
elif [ -n "$from_resources" ]; then
if [ ! -d $from_resources ]; then
pack_error "Cannot find resources path: $from_resources"
return 1
fi
local count=0
while [ -e ${LICHEE_PACK_OUT_DIR} -a $count -lt 20 ]; do
count=$((count+1))
done
cp -rax $from_resources ${LICHEE_PACK_OUT_DIR}
cd $LICHEE_OUT_DIR
if [ "${LICHEE_PACK_OUT_DIR}" != "$LICHEE_OUT_DIR/pack_out" ]; then
rm -rf pack_out
ln -sf ${LICHEE_IC}/${LICHEE_BOARD}/pack_out pack_out
fi
if [ "${PACK_PLATFORM}" == "android" ] && [ -n "$PACK_MIXED_FIRMWARE" ]; then
local resource_type="$(cat ${LICHEE_PACK_OUT_DIR}/mixed-image-type.txt)"
local mixed_fw_type="android:$PACK_MIXED_FIRMWARE"
if [ "$resource_type" != "android:$PACK_MIXED_FIRMWARE" ]; then
pack_error "mixed firmware type [$mixed_fw_type] but resource type [$resource_type]"
exit 1
fi
pack_info "mixed firmware type [$mixed_fw_type]"
fi
do_common
do_finish
fi
return $?
main "$@"
a733-pro3:/ # dumpsys SurfaceFlinger --layer
Display 4619827499077779712 (active) HWC layers:
Layer name
Z | Window Type | Comp Type | Transform | Disp Frame (LTRB) | Source Crop (LTRB) | Frame Rate (Explicit) (Seamlessness) [Focused]
Display 4619827813008632833 (inactive) HWC layers:
Layer name
ColorFade BLAST#551
rel 0 | 0 | CLIENT | 0 | 0 0 1920 1080 | 0.0 0.0 1920.0 1080.0 | [ ]
h/w composer state:
h/w composer enabled
SUNXI HWC:
Display[0] 1024x600 DPI=240000 FrameNumber=1556 LayerCount=0
DeviceInfo:
DRM Pipeline information:
crtc : [ 100] DE.0 DEBAND DITHER SMBL
connector : [ 147] DSI 1024x600@59.00Hz connection : connected
encoder current - 146 available: 146
planes :
[ 0] ID 93 mask 0x00001381
[ 1] ID 101 mask 0x00001201
[ 2] ID 107 mask 0x00000201
[ 3] ID 113 mask 0x00000001
Device name : CRTC.100
Power mode : Off
Vsync state : Disable
Output state: 1024x600 59 Hz
Supported configs:
0 1024x600P@59.00Hz
Margin: l:100 r:100 t:100 b:100
Android Color Transform [0]:
White Point: R:255 G:255 B:255
| 1.0000 0.0000 0.0000 0.0000 |
| 0.0000 1.0000 0.0000 0.0000 |
| 0.0000 0.0000 1.0000 0.0000 |
| 0.0000 0.0000 0.0000 1.0000 |
Compositor:
Screen Transform: FrameBufferBounds[1024, 600] ScreenBounds[1024, 600] Scale[1, 1]
Layer:
|Composition|PLN| ZO|Alpha| BlendingMode|Transform| Dataspace| PixelFormat | FBC| Handle | sourceCrop(LTRB) | displayFrame(LTRB) | scale | reason
Total bandwidth required: 0 (MB/s)
DRM Planes:
Zpos| buffer_handle_t |Plane ID| Feature Masks
G2D:
toatal RotateSession: 0, total pending task: 0
DE-Perf [disabled]
Display[1] 1920x1080 DPI=240000 FrameNumber=1312 LayerCount=4
DeviceInfo:
crtc : [ 126] DE.1 DITHER SMBL CRC
connector : [ 149] HDMI-A 1280x720@60.00Hz connection : connected
encoder current - 148 available: 148
planes :
[ 0] ID 120 mask 0x00001001
[ 1] ID 127 mask 0x00000201
[ 2] ID 133 mask 0x00000001
Device name : CRTC.126
Power mode : Off
Output state: 1280x720 60 Hz
Supported configs:
0 1280x720P@60.00Hz
Compositor:
Screen Transform: FrameBufferBounds[1920, 1080] ScreenBounds[1280, 720] Scale[1, 1]
Layer:
00| Client| 0| 0|1.000|Premultiplied| None|0x08810000| RGBA8888|TFBC|0xb40000792722da40| 0, 0, 1024, 28| 38, 0, 1881, 50|1.00 1.00| 0x0000000000000201 no suitable hardware plane for layer BT709-FULL-SRGB
01| Client| 0| 1|1.000|Premultiplied| None|0x08810000| RGBA8888|TFBC|0xb40000792722f700| 0, 0, 1024, 99| 38, 902, 1881, 1080|1.00 1.00| 0x0000000000000201 no suitable hardware plane for layer BT709-FULL-SRGB
02| Client| 0| 2|1.000|Premultiplied| None|0x08810000| RGBA8888|TFBC|0xb40000792722df40| 0, 0, 112, 36| 38, 1015, 240, 1080|1.00 1.00| 0x0000000000000201 cover by client target BT709-FULL-SRGB
03| Client| 0| 3|1.000|Premultiplied| None|0x08810000| RGBA8888|TFBC|0xb40000792722fc00| 0, 0, 1920, 1080| 0, 0, 1920, 1080|1.00 1.00| 0x0000000000000201 cover by client target BT709-FULL-SRGB
04| Device|127|255|1.000|Premultiplied| None|0x00000000| RGBA8888|TFBC|0xb40000792722e440| 0, 0, 1920, 1080| 0, 0, 1920, 1080|0.67 0.67| 0x0000000000000201 client target UNSPECIFIED-UNSPECIFIED-UNSPECIFIED
Total bandwidth required: 189 (MB/s)
DRM Planes:
G2D:
DE-Perf [disabled]
Connected displays:
Display[1] 0xb40000792726f298
Display[0] 0xb40000792726f018
Pipeline(s):
[0] -----------------------------------
planes :
[1] -----------------------------------
planes :
a733-pro3:/ #
130|console:/ $ dumpsys input
INPUT MANAGER (dumpsys input)
Input properties:
velocitytracker_strategy (flag value) = default
Input Manager State:
Interactive: false
System UI Lights Out: false
Pointer Speed: 0
Pointer Acceleration: 3.000
Pointer Gestures Enabled: true
Show Touches: false
Pointer Capture: Disabled, seq=0
PointerController:
Presentation: POINTER
Pointer Display ID: 0
Viewports:
DisplayViewport[id=-1]
Width=1024, Height=600
Transform (ROT_0) (IDENTITY)
Spot Controllers:
Event Hub State:
BuiltInKeyboardId: -2
Devices:
1: USB OPTICAL MOUSE
Classes: CURSOR | EXTERNAL
Path: /dev/input/event3
Enabled: true
Descriptor: 656b94976ab852e7ebc35aeb509ed5b7f7069a4d
ControllerNumber: 0
UniqueId:
Identifier: bus=0x0003, vendor=0x2188, product=0x0ae1, version=0x0111, bluetoothAddress=<not set>
KeyLayoutFile:
KeyCharacterMapFile:
ConfigurationFile:
VideoDevice: <none>
SysfsDevicePath: /sys/devices/platform/soc@3000000/12.usbc2/6a00000.xhci2-controller/xhci-hcd.41.auto/usb3/3-1/3-1:1.0/0003:2188:0AE1.0001
2: sunxi-keyboard
Classes: KEYBOARD
Path: /dev/input/event2
Enabled: true
Descriptor: 485d69228e24f5e46da1598745890b214130dbc4
ControllerNumber: 0
UniqueId:
Identifier: bus=0x0019, vendor=0x0001, product=0x0001, version=0x0100, bluetoothAddress=<not set>
KeyLayoutFile: /system/usr/keylayout/Generic.kl
KeyCharacterMapFile: /system/usr/keychars/Generic.kcm
ConfigurationFile:
VideoDevice: <none>
SysfsDevicePath: /sys/devices/platform/soc@3000000/2524000.lradc
3: sndi2s0 Headphones
Classes: KEYBOARD | SWITCH
Path: /dev/input/event1
Enabled: true
Descriptor: 5a9f67bbdafe6b3f56e43825ac01b657197098d3
ControllerNumber: 0
UniqueId:
Identifier: bus=0x0000, vendor=0x0000, product=0x0000, version=0x0000, bluetoothAddress=<not set>
ConfigurationFile:
VideoDevice: <none>
SysfsDevicePath: <none>
4: axp8191-pek
Classes: KEYBOARD
Path: /dev/input/event0
Enabled: true
Descriptor: 97bb2b9c48bb91bf6988750715eaca392c200e89
ControllerNumber: 0
UniqueId:
ConfigurationFile:
VideoDevice: <none>
SysfsDevicePath: /sys/devices/platform/soc@3000000/7083000.twi/i2c-13/13-0036/axp2101-pek.0
-1: Virtual
Classes: KEYBOARD | ALPHAKEY | DPAD | VIRTUAL
Path: <virtual>
Enabled: true
Descriptor: a718a782d34bc767f4689c232d64d527998ea7fd
ControllerNumber: 0
UniqueId: <virtual>
KeyCharacterMapFile: /system/usr/keychars/Virtual.kcm
ConfigurationFile:
VideoDevice: <none>
Unattached video devices:
<none>
Input Reader State (Nums of device: 5):
Device 5: USB OPTICAL MOUSE
EventHub Devices: [ 1 ]
Generation: 90
IsExternal: true
AssociatedDisplayPort: <none>
AssociatedDisplayUniqueId: <none>
HasMic: false
Sources: MOUSE
KeyboardType: 0
ControllerNum: 0
Motion Ranges:
X: source=MOUSE, min=0.000, max=1023.000, flat=0.000, fuzz=0.000, resolution=0.000
Y: source=MOUSE, min=0.000, max=599.000, flat=0.000, fuzz=0.000, resolution=0.000
PRESSURE: source=MOUSE, min=0.000, max=1.000, flat=0.000, fuzz=0.000, resolution=0.000
VSCROLL: source=MOUSE, min=-1.000, max=1.000, flat=0.000, fuzz=0.000, resolution=0.000
Cursor Input Mapper:
Parameters:
HasAssociatedDisplay: true
Mode: POINTER
OrientationAware: false
XScale: 1.000
YScale: 1.000
XPrecision: 1.000
YPrecision: 1.000
HaveVWheel: true
HaveHWheel: false
WheelYVelocityControlParameters: scale=1.000, lowThreshold=15.000, highThreshold=50.000, acceleration=4.000
WheelXVelocityControlParameters: scale=1.000, lowThreshold=15.000, highThreshold=50.000, acceleration=4.000
VWheelScale: 1.000
HWheelScale: 1.000
DisplayId: 0
Orientation: 0
ButtonState: 0x00000000
Down: false
DownTime: 30180386639000
Device 3: sndi2s0 Headphones
EventHub Devices: [ 3 ]
Generation: 61
IsExternal: false
HasMic: false
Sources: KEYBOARD
KeyboardType: 1
ControllerNum: 0
Switch Input Mapper:
SwitchValues: 0
Keyboard Input Mapper:
Parameters:
HandlesKeyRepeat: false
KeyboardType: 1
Orientation: 0
KeyDowns: 0 keys currently down
MetaState: 0x0
KeyboardLayoutInfo: <not set>
Device 2: axp8191-pek
EventHub Devices: [ 4 ]
Generation: 62
IsExternal: false
HasMic: false
Sources: KEYBOARD
KeyboardType: 1
ControllerNum: 0
Parameters:
KeyboardType: 1
Orientation: 0
MetaState: 0x0
Device 4: sunxi-keyboard
EventHub Devices: [ 2 ]
Generation: 60
IsExternal: false
HasMic: false
Sources: KEYBOARD
KeyboardType: 1
ControllerNum: 0
Parameters:
KeyboardType: 1
Orientation: 0
MetaState: 0x0
Device -1: Virtual
EventHub Devices: [ -1 ]
Generation: 3
IsExternal: false
HasMic: false
Sources: KEYBOARD | DPAD
KeyboardType: 2
ControllerNum: 0
Parameters:
KeyboardType: 2
Orientation: 0
MetaState: 0x0
Configuration:
ExcludedDeviceNames: []
VirtualKeyQuietTime: 0.0ms
PointerVelocityControlParameters: scale=1.000, lowThreshold=500.000, highThreshold=3000.000, acceleration=3.000
WheelVelocityControlParameters: scale=1.000, lowThreshold=15.000, highThreshold=50.000, acceleration=4.000
PointerGesture:
Enabled: true
QuietInterval: 100.0ms
DragMinSwitchSpeed: 50.0px/s
TapInterval: 150.0ms
TapDragInterval: 300.0ms
TapSlop: 20.0px
MultitouchSettleInterval: 100.0ms
MultitouchMinDistance: 15.0px
SwipeTransitionAngleCosine: 0.3
SwipeMaxWidthRatio: 0.2
MovementSpeedRatio: 0.8
ZoomSpeedRatio: 0.3
Viewports:
Viewport INTERNAL: displayId=0, uniqueId=local:4619827499077779712, port=0, orientation=0, logicalFrame=[0, 0, 1024, 600], physicalFrame=[0, 0, 1024, 600], deviceSize=[1024, 600], isActive=[0]
Viewport EXTERNAL: displayId=3, uniqueId=local:4619827813008632833, port=1, orientation=0, logicalFrame=[0, 0, 1920, 1080], physicalFrame=[0, 0, 1920, 1080], deviceSize=[1920, 1080], isActive=[0]
UnwantedInteractionBlocker:
mPreferStylusOverTouchBlocker:
mActiveStyli: {}
mLastTouchEvents:
mDevicesWithMixedToolType: {}
mCanceledDevices: {}
mEnablePalmRejection: 0
isPalmRejectionEnabled (flag value): 0
mPalmRejectors: None
Input Processor State:
Motion Classifier:
<nullptr>
Input Dispatcher State:
DispatchEnabled: true
DispatchFrozen: false
InputFilterEnabled: false
FocusedDisplayId: 0
FocusedApplications:
displayId=0, name='ActivityRecord{1173278 u0 com.android.launcher3/.Launcher3QuickStepGo t7}', dispatchingTimeout=5000ms
FocusedWindows:
displayId=0, name='fe034e6 NotificationShade'
FocusRequests:
displayId=0, name='fe034e6 NotificationShade' result='OK'
Pointer Capture Requested: false
Current Window with Pointer Capture: None
TouchStatesByDisplay:
0 : deviceId=5, source=MOUSE
Windows: <none>
Display: 3
No DisplayInfo found!
Windows:
0: name='ColorFade BLAST#565', id=565, displayId=3, inputConfig=NO_INPUT_CHANNEL | NOT_TOUCHABLE, alpha=1.00, frame=[0,0][1920,1080], globalScale=1.000000, applicationInfo.name=, applicationInfo.token=<null>, touchableRegion=<empty>, ownerPid=361, ownerUid=1000, dispatchingTimeout=5000ms, hasToken=<null>, touchOcclusionMode=BLOCK_UNTRUSTED
transform (ROT_0) (IDENTITY)
1: name='46764ca com.android.systemui', id=557, displayId=3, inputConfig=NOT_FOCUSABLE | NOT_TOUCHABLE, alpha=1.00, frame=[0,0][1920,1080], globalScale=1.000000, applicationInfo.name=, applicationInfo.token=<null>, touchableRegion=[-1920,-1080][3840,2160], ownerPid=1117, ownerUid=10112, dispatchingTimeout=5000ms, hasToken=0xb400007a9db7f030, touchOcclusionMode=BLOCK_UNTRUSTED
Display: 0
Windows:
0: name='ColorFade BLAST#563', id=563, displayId=0, inputConfig=NO_INPUT_CHANNEL | NOT_TOUCHABLE, alpha=1.00, frame=[0,0][1024,600], globalScale=1.000000, applicationInfo.name=, applicationInfo.token=<null>, touchableRegion=<empty>, ownerPid=361, ownerUid=1000, dispatchingTimeout=5000ms, hasToken=<null>, touchOcclusionMode=BLOCK_UNTRUSTED
1: name='d646573 android', id=141, displayId=0, inputConfig=NOT_FOCUSABLE | NOT_TOUCHABLE | PREVENT_SPLITTING | TRUSTED_OVERLAY, alpha=1.00, frame=[0,564][112,600], globalScale=1.000000, applicationInfo.name=, applicationInfo.token=<null>, touchableRegion=[0,564][112,600], ownerPid=361, ownerUid=1000, dispatchingTimeout=5000ms, hasToken=0xb400007b3dfa8f00, touchOcclusionMode=BLOCK_UNTRUSTED
transform (ROT_0) (TRANSLATE)
1.0000 0.0000 -0.0000
0.0000 1.0000 -564.0000
2: name='49130ed Taskbar', id=216, displayId=0, inputConfig=NOT_VISIBLE | NOT_FOCUSABLE | NOT_TOUCHABLE | TRUSTED_OVERLAY | SLIPPERY, alpha=0.00, frame=[0,548][1024,600], globalScale=1.000000, applicationInfo.name=, applicationInfo.token=<null>, touchableRegion=<empty>, ownerPid=1385, ownerUid=10107, dispatchingTimeout=5000ms, hasToken=0xb400007b1d25a800, touchOcclusionMode=BLOCK_UNTRUSTED
0.0000 1.0000 -548.0000
3: name='fe034e6 NotificationShade', id=552, displayId=0, inputConfig=NOT_TOUCHABLE | TRUSTED_OVERLAY | WATCH_OUTSIDE_TOUCH | DISABLE_USER_ACTIVITY, alpha=1.00, frame=[0,0][1024,600], globalScale=1.000000, applicationInfo.name=, applicationInfo.token=<null>, touchableRegion=[-1024,-600][2048,1200], ownerPid=1117, ownerUid=10112, dispatchingTimeout=5000ms, hasToken=0xb400007a9e823b00, touchOcclusionMode=BLOCK_UNTRUSTED
4: name='42c5ecc StatusBar', id=177, displayId=0, inputConfig=NOT_FOCUSABLE | NOT_TOUCHABLE | TRUSTED_OVERLAY, alpha=1.00, frame=[0,0][1024,28], globalScale=1.000000, applicationInfo.name=, applicationInfo.token=<null>, touchableRegion=[0,0][1024,28], ownerPid=1117, ownerUid=10112, dispatchingTimeout=5000ms, hasToken=0xb400007a9e823ef0, touchOcclusionMode=BLOCK_UNTRUSTED
5: name='eaab7db ActivityRecordInputSink com.android.launcher3/.Launcher3QuickStepGo', id=231, displayId=0, inputConfig=NO_INPUT_CHANNEL | NOT_VISIBLE | NOT_FOCUSABLE | NOT_TOUCHABLE, alpha=1.00, frame=[0,0][0,0], globalScale=0.000000, applicationInfo.name=, applicationInfo.token=<null>, touchableRegion=[-19199,-10799][19200,10800], ownerPid=361, ownerUid=1000, dispatchingTimeout=0ms, hasToken=<null>, touchOcclusionMode=BLOCK_UNTRUSTED
6: name='Wallpaper BBQ wrapper#155', id=155, displayId=0, inputConfig=NO_INPUT_CHANNEL | NOT_VISIBLE | NOT_TOUCHABLE, alpha=1.00, frame=[-50,-29][1123,630], globalScale=1.000000, applicationInfo.name=, applicationInfo.token=<null>, touchableRegion=<empty>, ownerPid=1117, ownerUid=10112, dispatchingTimeout=5000ms, hasToken=<null>, touchOcclusionMode=BLOCK_UNTRUSTED
transform (ROT_0) (SCALE TRANSLATE)
1.8173 -0.0000 92.6838
-0.0000 1.8182 54.5454
7: name='428f1f7 com.android.systemui.wallpapers.ImageWallpaper', id=154, displayId=0, inputConfig=NOT_VISIBLE | NOT_FOCUSABLE | NOT_TOUCHABLE | PREVENT_SPLITTING | IS_WALLPAPER, alpha=1.00, frame=[-50,-29][-50,-29], globalScale=1.000000, applicationInfo.name=, applicationInfo.token=<null>, touchableRegion=<empty>, ownerPid=1117, ownerUid=10112, dispatchingTimeout=5000ms, hasToken=0xb400007a9e822c60, touchOcclusionMode=BLOCK_UNTRUSTED
Global monitors on display 3:
0: 'PointerEventDispatcher3 (server)',
Global monitors on display 0:
0: 'PointerEventDispatcher0 (server)',
RecentQueue: length=10
MotionEvent(deviceId=5, eventTime=30221370641000, source=MOUSE, displayId=0, action=HOVER_MOVE, actionButton=0x00000000, flags=0x00000000, metaState=0x00000000, buttonState=0x00000000, classification=NONE, edgeFlags=0x00000000, xPrecision=1.0, yPrecision=1.0, xCursorPosition=1023.0, yCursorPosition=373.0, pointers=[0: (1023.0, 373.0)]), policyFlags=0x62000001, age=487687ms
MotionEvent(deviceId=5, eventTime=30221386654000, source=MOUSE, displayId=0, action=HOVER_MOVE, actionButton=0x00000000, flags=0x00000000, metaState=0x00000000, buttonState=0x00000000, classification=NONE, edgeFlags=0x00000000, xPrecision=1.0, yPrecision=1.0, xCursorPosition=1023.0, yCursorPosition=372.0, pointers=[0: (1023.0, 372.0)]), policyFlags=0x62000001, age=487671ms
FocusEvent(hasFocus=false), age=427093ms
FocusEvent(hasFocus=true), age=426136ms
MotionEvent(deviceId=5, eventTime=30491634641000, source=MOUSE, displayId=0, action=HOVER_MOVE, actionButton=0x00000000, flags=0x00000000, metaState=0x00000000, buttonState=0x00000000, classification=NONE, edgeFlags=0x00000000, xPrecision=1.0, yPrecision=1.0, xCursorPosition=1023.0, yCursorPosition=371.0, pointers=[0: (1023.0, 371.0)]), policyFlags=0x02000001, age=217423ms
MotionEvent(deviceId=5, eventTime=30491658695000, source=MOUSE, displayId=0, action=HOVER_MOVE, actionButton=0x00000000, flags=0x00000000, metaState=0x00000000, buttonState=0x00000000, classification=NONE, edgeFlags=0x00000000, xPrecision=1.0, yPrecision=1.0, xCursorPosition=1023.0, yCursorPosition=372.0, pointers=[0: (1023.0, 372.0)]), policyFlags=0x62000001, age=217399ms
MotionEvent(deviceId=5, eventTime=30491674665000, source=MOUSE, displayId=0, action=HOVER_MOVE, actionButton=0x00000000, flags=0x00000000, metaState=0x00000000, buttonState=0x00000000, classification=NONE, edgeFlags=0x00000000, xPrecision=1.0, yPrecision=1.0, xCursorPosition=1023.0, yCursorPosition=372.0, pointers=[0: (1023.0, 372.0)]), policyFlags=0x62000001, age=217383ms
MotionEvent(deviceId=5, eventTime=30609666842000, source=MOUSE, displayId=0, action=HOVER_MOVE, actionButton=0x00000000, flags=0x00000000, metaState=0x00000000, buttonState=0x00000000, classification=NONE, edgeFlags=0x00000000, xPrecision=1.0, yPrecision=1.0, xCursorPosition=1023.0, yCursorPosition=371.0, pointers=[0: (1023.0, 371.0)]), policyFlags=0x02000001, age=99391ms
MotionEvent(deviceId=5, eventTime=30609674651000, source=MOUSE, displayId=0, action=HOVER_MOVE, actionButton=0x00000000, flags=0x00000000, metaState=0x00000000, buttonState=0x00000000, classification=NONE, edgeFlags=0x00000000, xPrecision=1.0, yPrecision=1.0, xCursorPosition=1023.0, yCursorPosition=371.0, pointers=[0: (1023.0, 371.0)]), policyFlags=0x62000001, age=99383ms
MotionEvent(deviceId=5, eventTime=30609682648000, source=MOUSE, displayId=0, action=HOVER_MOVE, actionButton=0x00000000, flags=0x00000000, metaState=0x00000000, buttonState=0x00000000, classification=NONE, edgeFlags=0x00000000, xPrecision=1.0, yPrecision=1.0, xCursorPosition=1023.0, yCursorPosition=371.0, pointers=[0: (1023.0, 371.0)]), policyFlags=0x62000001, age=99375ms
PendingEvent: <none>
InboundQueue: <empty>
ReplacedKeys: <empty>
CommandQueue: <empty>
Connections:
563: channelName='46764ca com.android.systemui (server)', windowName='46764ca com.android.systemui (server)', status=NORMAL, monitor=false, responsive=true
OutboundQueue: <empty>
WaitQueue: <empty>
354: channelName='PointerEventDispatcher3 (server)', windowName='PointerEventDispatcher3 (server)', status=NORMAL, monitor=true, responsive=true
WaitQueue: <empty>
585: channelName='d76ac85 com.android.launcher3/com.android.launcher3.Launcher3QuickStepGo (server)', windowName='d76ac85 com.android.launcher3/com.android.launcher3.Launcher3QuickStepGo (server)', status=NORMAL, monitor=false, responsive=true
WaitQueue: <empty>
545: channelName='49130ed Taskbar (server)', windowName='49130ed Taskbar (server)', status=NORMAL, monitor=false, responsive=true
WaitQueue: <empty>
512: channelName='afd28e5 InputMethod (server)', windowName='afd28e5 InputMethod (server)', status=NORMAL, monitor=false, responsive=true
WaitQueue: <empty>
516: channelName='recents_animation_input_consumer (server)', windowName='recents_animation_input_consumer (server)', status=NORMAL, monitor=false, responsive=true
WaitQueue: <empty>
455: channelName='428f1f7 com.android.systemui.wallpapers.ImageWallpaper (server)', windowName='428f1f7 com.android.systemui.wallpapers.ImageWallpaper (server)', status=NORMAL, monitor=false, responsive=true
WaitQueue: <empty>
219: channelName='2266371 ScreenDecorOverlayBottom (server)', windowName='2266371 ScreenDecorOverlayBottom (server)', status=NORMAL, monitor=false, responsive=true
WaitQueue: <empty>
183: channelName='PointerEventDispatcher0 (server)', windowName='PointerEventDispatcher0 (server)', status=NORMAL, monitor=true, responsive=true
WaitQueue: <empty>
207: channelName='7482c83 ScreenDecorOverlay (server)', windowName='7482c83 ScreenDecorOverlay (server)', status=NORMAL, monitor=false, responsive=true
WaitQueue: <empty>
405: channelName='e74b7b9 ShellDropTarget (server)', windowName='e74b7b9 ShellDropTarget (server)', status=NORMAL, monitor=false, responsive=true
WaitQueue: <empty>
460: channelName='fe034e6 NotificationShade (server)', windowName='fe034e6 NotificationShade (server)', status=NORMAL, monitor=false, responsive=true
WaitQueue: <empty>
364: channelName='d646573 android (server)', windowName='d646573 android (server)', status=NORMAL, monitor=false, responsive=true
WaitQueue: <empty>
469: channelName='42c5ecc StatusBar (server)', windowName='42c5ecc StatusBar (server)', status=NORMAL, monitor=false, responsive=true
WaitQueue: <empty>
AppSwitch: not pending
TouchModePerDisplay:
Display: 0 TouchMode: 1
Display: 3 TouchMode: 1
Configuration:
KeyRepeatDelay: 50ms
KeyRepeatTimeout: 400ms
LatencyTracker:
mTimelines.size() = 3
mEventTimes.size() = 3
LatencyAggregator:
Sketches:
mDownSketches[0]->num_values = 13 size = 0.0KB mMoveSketches[0]->num_values = 834 size = 0.6KB
mDownSketches[1]->num_values = 1 size = 0.0KB mMoveSketches[1]->num_values = 58 size = 0.1KB
mDownSketches[2]->num_values = 1 size = 0.0KB mMoveSketches[2]->num_values = 58 size = 0.1KB
mDownSketches[3]->num_values = 1 size = 0.0KB mMoveSketches[3]->num_values = 58 size = 0.1KB
mDownSketches[4]->num_values = 1 size = 0.0KB mMoveSketches[4]->num_values = 58 size = 0.1KB
mDownSketches[5]->num_values = 1 size = 0.0KB mMoveSketches[5]->num_values = 58 size = 0.1KB
mDownSketches[6]->num_values = 1 size = 0.0KB mMoveSketches[6]->num_values = 58 size = 0.1KB
mNumSketchEventsProcessed=847
mLastSlowEventTime=30179386714264
mNumEventsSinceLastSlowEventReport = 7
mNumSkippedSlowEvents = 0
Input Manager Service (Java) State:
mAcknowledgedPointerDisplayId=0
mRequestedPointerDisplayId=0
mPointerIconType=NOT_SPECIFIED
mPointerIcon=null
BatteryController:
State: Polling = false, Interactive = false
Listeners: 0 battery listeners
Device Monitors: 0 monitors
KbdBacklightController: 0 keyboard backlights, isBacklightOn = false
console:/ $
