楼主 # 2025-06-06 13:46:36
number007cool
t113s3 驱动st7789控制器屏幕,能够显示,但是显示错乱
linux  内核版本5.4
设备树:
&spi1 {
    clock-frequency = <5000000>;
    pinctrl-0 = <&spi1_pins_a>;
    spi_slave_mode = <0>;
    cs-gpios = <&pio 3 10 GPIO_ACTIVE_LOW>; // 可选:指定 CS 脚,如 PD10
     display@0{
        compatible = "sitronix,st7789v";
        reg = <0>;
        spi-max-frequency = <96000000>;
        spi-cpol;
        spi-cpha;
        rotate = <270>;
        width = <320>;
        height = <240>;
        fps = <10>;
        buswidth = <8>;
        dc-gpios = <&pio 3 14 GPIO_ACTIVE_HIGH>;  // Pd14  dc
        reset-gpios = <&pio 3 15 GPIO_ACTIVE_HIGH>; // Pd15
        //led-gpios = <&pio 0 0 GPIO_ACTIVE_LOW>;  // PA0
        debug = <0x0>;
应用程序:
#include <stdio.h>
#include <stdlib.h>
#include <fcntl.h>
#include <unistd.h>
#include <sys/mman.h>
#include <string.h>
#include <sys/ioctl.h>
#include <linux/fb.h>
#define FB_DEV "/dev/fb0"
// 将 8 位的 RGB 颜色转换为 16 位的 RGB565 格式
unsigned short rgb_to_rgb565(int r, int g, int b) {
    // RGB565: R 5 bits, G 6 bits, B 5 bits
    return ((r >> 3) << 11) | ((g >> 2) << 5) | (b >> 3);
// 填充屏幕颜色
void fill_screen(unsigned short *framebuffer, int width, int height, unsigned short color) {
    for (int y = 0; y < height; y++) {
        for (int x = 0; x < width; x++) {
            framebuffer[y * width + x] = color;
int main(void) {
    int fb = open(FB_DEV, O_RDWR);
    if (fb == -1) {
        perror("打开 framebuffer 设备失败");
        return -1;
    // 获取 framebuffer 的信息
    struct fb_var_screeninfo vinfo;
    if (ioctl(fb, FBIOGET_VSCREENINFO, &vinfo)) {
        perror("获取屏幕信息失败");
        close(fb);
        return -1;
    // 获取屏幕的宽度、高度以及颜色深度
    int width = vinfo.xres;
    int height = vinfo.yres;
    int bpp = vinfo.bits_per_pixel;
    printf("屏幕分辨率: %dx%d, 位深: %d\n", width, height, bpp);
    // 映射 framebuffer 到进程的内存
    unsigned short *framebuffer = (unsigned short *)mmap(NULL, width * height * (bpp / 8), PROT_READ | PROT_WRITE, MAP_SHARED, fb, 0);
    if (framebuffer == MAP_FAILED) {
        perror("映射 framebuffer 失败");
        close(fb);
        return -1;
    // 循环测试:每隔一秒切换颜色
    while (1) {
        // 填充红色 (RGB: 255, 0, 0 -> RGB565: 0xF800)
        fill_screen(framebuffer, width, height, rgb_to_rgb565(255, 0, 0));
        usleep(1000000);  // 延时 1 秒
        // 填充绿色 (RGB: 0, 255, 0 -> RGB565: 0x07E0)
        fill_screen(framebuffer, width, height, rgb_to_rgb565(0, 255, 0));
        // 填充蓝色 (RGB: 0, 0, 255 -> RGB565: 0x001F)
        fill_screen(framebuffer, width, height, rgb_to_rgb565(0, 0, 255));
    // 解除内存映射
    munmap(framebuffer, width * height * (bpp / 8));
    close(fb);
效果:
【t113s3 驱动spi  st7789显示屏,花屏-哔哩哔哩】 https://b23.tv/cqHvRyK
不知道问题在哪?
楼主 #1 2025-06-06 14:32:04
number007cool
Re: t113s3 驱动st7789控制器屏幕,能够显示,但是显示错乱
内核7789源码:
// SPDX-License-Identifier: GPL-2.0+
* FB driver for the ST7789V LCD Controller
* Copyright (C) 2015 Dennis Menschel
#include <linux/bitops.h>
#include <linux/delay.h>
#include <linux/init.h>
#include <linux/kernel.h>
#include <linux/module.h>
#include <video/mipi_display.h>
#include "fbtft.h"
#define DRVNAME "fb_st7789v"
#define DEFAULT_GAMMA \
    "70 2C 2E 15 10 09 48 33 53 0B 19 18 20 25\n" \
    "70 2C 2E 15 10 09 48 33 53 0B 19 18 20 25"
* enum st7789v_command - ST7789V display controller commands
* @PORCTRL: porch setting
* @GCTRL: gate control
* @VCOMS: VCOM setting
* @VDVVRHEN: VDV and VRH command enable
* @VRHS: VRH set
* @VDVS: VDV set
* @VCMOFSET: VCOM offset set
* @PWCTRL1: power control 1
* @PVGAMCTRL: positive voltage gamma control
* @NVGAMCTRL: negative voltage gamma control
* The command names are the same as those found in the datasheet to ease
* looking up their semantics and usage.
* Note that the ST7789V display controller offers quite a few more commands
* which have been omitted from this list as they are not used at the moment.
* Furthermore, commands that are compliant with the MIPI DCS have been left
* out as well to avoid duplicate entries.
enum st7789v_command {
    PORCTRL = 0xB2,
    GCTRL = 0xB7,
    VCOMS = 0xBB,
    VDVVRHEN = 0xC2,
    VRHS = 0xC3,
    VDVS = 0xC4,
    VCMOFSET = 0xC5,
    PWCTRL1 = 0xD0,
    PVGAMCTRL = 0xE0,
    NVGAMCTRL = 0xE1,
#define MADCTL_BGR BIT(3) /* bitmask for RGB/BGR order */
#define MADCTL_MV BIT(5) /* bitmask for page/column order */
#define MADCTL_MX BIT(6) /* bitmask for column address order */
#define MADCTL_MY BIT(7) /* bitmask for page address order */
* init_display() - initialize the display controller
* @par: FBTFT parameter object
* Most of the commands in this init function set their parameters to the
* same default values which are already in place after the display has been
* powered up. (The main exception to this rule is the pixel format which
* would default to 18 instead of 16 bit per pixel.)
* Nonetheless, this sequence can be used as a template for concrete
* displays which usually need some adjustments.
* Return: 0 on success, < 0 if error occurred.
static int init_display(struct fbtft_par *par)
    /* turn off sleep mode */
    write_reg(par, MIPI_DCS_EXIT_SLEEP_MODE);
    mdelay(120);
    /* set pixel format to RGB-565 */
    write_reg(par, MIPI_DCS_SET_PIXEL_FORMAT, MIPI_DCS_PIXEL_FMT_16BIT);
    write_reg(par, PORCTRL, 0x08, 0x08, 0x00, 0x22, 0x22);
     * VGH = 13.26V
     * VGL = -10.43V
    write_reg(par, GCTRL, 0x35);
     * VDV and VRH register values come from command write
     * (instead of NVM)
    write_reg(par, VDVVRHEN, 0x01, 0xFF);
     * VAP =  4.1V + (VCOM + VCOM offset + 0.5 * VDV)
     * VAN = -4.1V + (VCOM + VCOM offset + 0.5 * VDV)
    write_reg(par, VRHS, 0x0B);
    /* VDV = 0V */
    write_reg(par, VDVS, 0x20);
    /* VCOM = 0.9V */
    write_reg(par, VCOMS, 0x20);
    /* VCOM offset = 0V */
    write_reg(par, VCMOFSET, 0x20);
     * AVDD = 6.8V
     * AVCL = -4.8V
     * VDS = 2.3V
    write_reg(par, PWCTRL1, 0xA4, 0xA1);
    write_reg(par, MIPI_DCS_SET_DISPLAY_ON);
* set_var() - apply LCD properties like rotation and BGR mode
static int set_var(struct fbtft_par *par)
    u8 madctl_par = 0;
    if (par->bgr)
        madctl_par |= MADCTL_BGR;
    switch (par->info->var.rotate) {
    case 0:
        break;
    case 90:
        madctl_par |= (MADCTL_MV | MADCTL_MY);
        break;
    case 180:
        madctl_par |= (MADCTL_MX | MADCTL_MY);
        break;
    case 270:
        madctl_par |= (MADCTL_MV | MADCTL_MX);
        break;
    default:
        return -EINVAL;
    write_reg(par, MIPI_DCS_SET_ADDRESS_MODE, madctl_par);
* set_gamma() - set gamma curves
* @curves: gamma curves
* Before the gamma curves are applied, they are preprocessed with a bitmask
* to ensure syntactically correct input for the display controller.
* This implies that the curves input parameter might be changed by this
* function and that illegal gamma values are auto-corrected and not
* reported as errors.
static int set_gamma(struct fbtft_par *par, u32 *curves)
    int i;
    int j;
    int c; /* curve index offset */
     * Bitmasks for gamma curve command parameters.
     * The masks are the same for both positive and negative voltage
     * gamma curves.
    static const u8 gamma_par_mask[] = {
        0xFF, /* V63[3:0], V0[3:0]*/
        0x3F, /* V1[5:0] */
        0x3F, /* V2[5:0] */
        0x1F, /* V4[4:0] */
        0x1F, /* V6[4:0] */
        0x3F, /* J0[1:0], V13[3:0] */
        0x7F, /* V20[6:0] */
        0x77, /* V36[2:0], V27[2:0] */
        0x7F, /* V43[6:0] */
        0x3F, /* J1[1:0], V50[3:0] */
        0x1F, /* V57[4:0] */
        0x1F, /* V59[4:0] */
        0x3F, /* V61[5:0] */
        0x3F, /* V62[5:0] */
    for (i = 0; i < par->gamma.num_curves; i++) {
        c = i * par->gamma.num_values;
        for (j = 0; j < par->gamma.num_values; j++)
            curves[c + j] &= gamma_par_mask[j];
        write_reg(par, PVGAMCTRL + i,
              curves[c + 0],  curves[c + 1],  curves[c + 2],
              curves[c + 3],  curves[c + 4],  curves[c + 5],
              curves[c + 6],  curves[c + 7],  curves[c + 8],
              curves[c + 9],  curves[c + 10], curves[c + 11],
              curves[c + 12], curves[c + 13]);
* blank() - blank the display
* @on: whether to enable or disable blanking the display
static int blank(struct fbtft_par *par, bool on)
    if (on)
        write_reg(par, MIPI_DCS_SET_DISPLAY_OFF);
static struct fbtft_display display = {
    .regwidth = 8,
    .width = 240,
    .height = 320,
    .gamma_num = 2,
    .gamma_len = 14,
    .gamma = DEFAULT_GAMMA,
    .fbtftops = {
        .init_display = init_display,
        .set_var = set_var,
        .set_gamma = set_gamma,
        .blank = blank,
FBTFT_REGISTER_DRIVER(DRVNAME, "sitronix,st7789v", &display);
MODULE_ALIAS("spi:" DRVNAME);
MODULE_ALIAS("platform:" DRVNAME);
MODULE_ALIAS("spi:st7789v");
MODULE_ALIAS("platform:st7789v");
MODULE_DESCRIPTION("FB driver for the ST7789V LCD Controller");
MODULE_AUTHOR("Dennis Menschel");
MODULE_LICENSE("GPL");
楼主 #2 2025-06-10 11:40:08
number007cool
已经搞定,设备树如下:
&spi1 {
    clock-frequency = <15000000>;
    bias-pull-up;
     display@0{
        reg = <0>;
        spi-max-frequency = <15000000>;//96000000
        spi-cpol;
        spi-cpha;
        rotate = <180>;
       // width = <320>;
        // height = <240>;
        fps = <10>;
        buswidth = <8>;
        debug = <0x0>;
