板子是自己画的 想调一下屏参 结果无论是adb还是串口 调屏这项一点读取或者写入 系统直接死机
按照aipq帮助文档操作的 不知道还有哪里问题? 请调过 朋友指点一下,谢谢
系统日志如下
Pre-Boot Program ... (25-06-25 13:50 16 03 0b2edf9)
SPINOR
cs=0, phase=3
cs=1, phase=2
Psram_init done.
goto run SPL
tinySPL [Built on May 14 2025 10:44:19]
Reboot action: Warm-Reset, reason: External-Reset
[I/USB] EHCI HCIVERSION:0x0100
[I/USB] EHCI HCSPARAMS:0x001111
[I/USB] EHCI HCCPARAMS:0xa010
[I/USB] EHCI ppc:1, n_ports:1, n_cc:1, n_pcc:1
[I/USB] EHCI uses companion controller for ls/fs device
[I/USB] OHCI hcrevision:0x110
[I/USB] OHCI n_ports:1
qspi0 freq (input): 99000000Hz
qspi0 freq ( bus ): 49500000Hz
qspi0 freq ( bus ): 99000000Hz
Selecting default config 'Luban-lite firmware'
spl read: 2373008 byte, 47410 us -> 48878 KB/s
CRC32 verify OK.
No config partition
1322143 : Run APP
_ _ ___ ___ _ _
/ \ _ __| |_|_ _|_ __ / __| |__ (_)_ __
/ _ \ | '__| __|| || '_ \| | | '_ \| | '_ \
/ ___ \| | | |_ | || | | | |__| | | | | |_) |
/_/ \_\_| \__|___|_| |_|\___|_| |_|_| .__/
|_|
Welcome to ArtInChip Luban-Lite 1.2.1 [D13x Inside]
Image version: 1.0.1
Built on Aug 8 2025 07:42:17
lwIP-2.1.2 initialized!
01-01 08:00:00 I/PWM: ArtInChip PWM loaded
01-01 08:00:00 I/NO_TAG: Flash ID: 0xef4016
01-01 08:00:00 I/NO_TAG: Find a Winbond flash chip. Size is 4194304 bytes.
01-01 08:00:00 I/NO_TAG: norflash0 flash device initialized successfully.
01-01 08:00:00 I/NO_TAG: Probe SPI flash norflash0 by SPI device qspi01 success.
01-01 08:00:00 I/touch: rt_touch init success
01-01 08:00:00 I/CIR: ArtInChip CIR device register success
[I] aicfb_find_component()837 find component: artinchip-de
[I] aicfb_find_component()837 find component: artinchip-rgb
[I] aicfb_probe()1261 fb0 allocated at 0x402973a0
[I] aic_sdmc_clk_init()562 SDMC0 sclk: 49500 KHz, parent clk 792000 KHz
01-01 08:00:00 I/SDMC: SDMC0 BW 1, sclk 49500 KHz, clk expt 400 KHz(act 399 KHz), div 2-62
[I] aic_sdmc_probe()693 SDMC0 driver loaded
[I] aic_sdmc_clk_init()562 SDMC1 sclk: 49500 KHz, parent clk 792000 KHz
01-01 08:00:00 I/SDMC: SDMC1 BW 1, sclk 49500 KHz, clk expt 400 KHz(act 399 KHz), div 2-62
[I] aic_sdmc_probe()693 SDMC1 driver loaded
01-01 08:00:00 I/sensor: rt_sensor[temp_tsen_cpu] init success
01-01 08:00:00 I/sensor: rt_sensor[temp_tsen_gpai] init success
01-01 08:00:00 I/WDT: ArtInChip WDT loaded
01-01 08:00:00 I/sal.skt: Socket Abstraction Layer initialize success.
01-01 08:00:00 I/NEC: CIR NEC decoder register
01-01 08:00:00 I/RC5: CIR RC5 decoder register
Startup time: 1.739 sec
[W] get_len()443 Open file /rootfs/wlan_cfg fail
msh /> 01-01 08:00:00 W/SDIO: Card ocr below the defined voltage rang.
01-01 08:00:00 W/SDIO: Can't support the low voltage SDIO card.
01-01 08:00:00 I/SDMC: SDMC0 BW 1, sclk 49500 KHz, clk expt 49500 KHz(act 49500 KHz), div 1-0
01-01 08:00:00 I/SDIO: SD card capacity 3887104 KB.
01-01 08:00:00 I/SDMC: SDMC1 BW 1, sclk 49500 KHz, clk expt 50000 KHz(act 49500 KHz), div 1-0
01-01 08:00:00 I/DFS: mount fs[elm] device[sd1p0] to /sdcard ok.
[I/USB] Open ep:0x02 type:2 mps:512
[I/USB] Open ep:0x81 type:2 mps:512
01-01 08:00:00 I/NO_TAG: float test: +15.6°C, Humidity: 20%
panel-rgb type: RGB pclk: 33 Mhz h: 800 v: 480 fps: 63
card insertion detected!
01-01 08:00:00 I/ADB usb: ADB init success !离线
aipq 使用需要关 lvgl demo,不然会有问题。menuconfig 使能 AIC_FB_DRV_DEBUG 就可以使用了
这个工具有两点很好用
RGB 屏幕颜色不对拿来定位问题
MIPI-DSI 屏幕时序不对拿来调 timing
其它的就很一般了
