sdk给的测试代码如下,
程序抓到数据使用yuv播放器可以正常显示,说明摄像头部分没有问题。
但是显示屏上无任何显示。
read_frame()中有调用显示的代码:
disp_set_addr(input_size.width, input_size.height, &buf);是图层的问题吗?还是其它什么原因?
* drivers/media/platform/sunxi-vin/vin_test/mplane_image/csi_test_mplane.c
* Copyright (c) 2014 softwinner.
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* zw
* for csi & isp test
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <assert.h>
#include <time.h>
#include <signal.h>
#include <linux/fb.h>
#include <linux/input.h>
#include <linux/version.h>
#include <getopt.h>
#include <fcntl.h>
#include <unistd.h>
#include <errno.h>
#include <malloc.h>
#include <signal.h>
#include <sys/stat.h>
#include <sys/types.h>
#include <sys/time.h>
#include <sys/mman.h>
#include <sys/ioctl.h>
#include <asm/types.h>
#include "sunxi_camera_v2.h"
#include "sunxi_display2.h"
#define CLEAR(x) (memset(&(x), 0, sizeof(x)))
#define ALIGN_4K(x) (((x) + (4095)) & ~(4095))
#define ALIGN_16B(x) (((x) + (15)) & ~(15))
#define display_frame 1
#define video_s_ctrl 0
struct size {
int width;
int height;
struct buffer {
void *start[3];
int length[3];
typedef enum {
TVD_PL_YUV420 = 0,
TVD_MB_YUV420 = 1,
TVD_PL_YUV422 = 2,
} TVD_FMT_T;
struct disp_screen {
int x;
int y;
int w;
int h;
struct test_layer_info {
int screen_id;
int layer_id;
int mem_id;
disp_layer_config layer_config;
int addr_map;
int width, height;/* screen size */
int dispfh;/* device node handle */
int fh;/* picture resource file handle */
int mem;
int clear;/* is clear layer */
char filename[32];
int full_screen;
unsigned int pixformat;
disp_output_type output_type;
* tvd_dev info
struct tvd_dev {
unsigned int ch_id;
unsigned int height;
unsigned int width;
unsigned int interface;
unsigned int system;
unsigned int row;
unsigned int column;
unsigned int ch0_en;
unsigned int ch1_en;
unsigned int ch2_en;
unsigned int ch3_en;
struct test_layer_info layer_info;
int frame_no_to_grap;
FILE *raw_fp;
struct tvd_dev dev;
static char path_name[20];
static char dev_name[20];
static int fd = -1;
static int isp0_fd = -1;
static int isp1_fd = -1;
struct buffer *buffers;
static unsigned int n_buffers;
struct size input_size;
unsigned int req_frame_num = 8;
unsigned int read_num = 20;
unsigned int count;
unsigned int nplanes;
unsigned int save_flag;
int dev_id;
unsigned int fps = 30;
unsigned int wdr_mode;
#define ROT_90 0
static void yuv_r90(char *dst, char *src, int width, int height)
int i = 0, j = 0;
for (i = 0; i < width; i++) {
for (j = 0; j < height; j++)
*(char *)(dst + j + i * height) = *(char *)(src + (height - j - 1) * width + i);
static void uv_r90(char *dst, char *src, int width, int height)
int i = 0, j = 0;
for (i = 0; i < width/2; i++) {
for (j = 0; j < height/2; j++)
*(char *)(dst + j * 2 + i * height) = *(char *)(src + (height/2 - j - 1) * width + i * 2);
*(char *)(dst + j * 2 + 1 + i * height) = *(char *)(src + (height/2 - j - 1) * width + i * 2 + 1);
static int disp_set_addr(int width, int height, struct v4l2_buffer *buf)
unsigned long arg[6];
int ret;
if (dev.layer_info.pixformat == TVD_PL_YUV420) {
/* printf("******YUV420!\n"); */
dev.layer_info.layer_config.info.fb.size[0].width = width;
dev.layer_info.layer_config.info.fb.size[0].height = height;
dev.layer_info.layer_config.info.fb.size[1].width = width / 2;
dev.layer_info.layer_config.info.fb.size[1].height = height / 2;
dev.layer_info.layer_config.info.fb.size[2].width = width / 2;
dev.layer_info.layer_config.info.fb.size[2].height = height / 2;
dev.layer_info.layer_config.info.fb.crop.width =
(unsigned long long)width << 32;
dev.layer_info.layer_config.info.fb.crop.height =
(unsigned long long)height << 32;
dev.layer_info.layer_config.info.fb.addr[0] = buf->m.planes[0].m.mem_offset;
dev.layer_info.layer_config.info.fb.addr[1] = buf->m.planes[1].m.mem_offset;
dev.layer_info.layer_config.info.fb.addr[2] = buf->m.planes[2].m.mem_offset;
/* dev.layer_info.layer_config.info.fb.addr[0] = (*addr);
(dev.layer_info.layer_config.info.fb.addr[0] + width * height);
width * height * 5 / 4;
dev.layer_info.layer_config.info.fb.trd_right_addr[0] =
width * height * 3 / 2);
dev.layer_info.layer_config.info.fb.trd_right_addr[1] =
dev.layer_info.layer_config.info.fb.trd_right_addr[2] =
width * height * 5 / 4); */
} else {
dev.layer_info.layer_config.info.fb.size[1].height = height;
dev.layer_info.layer_config.info.fb.size[2].height = height;
width * height * 2 / 2;
width * height * 2);
(dev.layer_info.layer_config.info.fb.addr[0] + width * height); */
//printf("disp_set_addr[0]:%lx \n",buf->m.planes[0].m.mem_offset);
//printf("disp_set_addr[1]:%lx \n",buf->m.planes[1].m.mem_offset);
//printf("disp_set_addr[2]:%lx \n",buf->m.planes[2].m.mem_offset);
dev.layer_info.layer_config.enable = 1;
arg[0] = dev.layer_info.screen_id;
arg[1] = (unsigned long)&dev.layer_info.layer_config;
arg[2] = 1;
arg[3] = 0;
ret = ioctl(dev.layer_info.dispfh, DISP_LAYER_SET_CONFIG, (void *)arg);
if (ret != 0)
printf("disp_set_addr fail to set layer info\n");
static int read_frame(int mode)
struct v4l2_buffer buf;
char fdstr[50];
FILE *file_fd = NULL;
char *dst = NULL;
CLEAR(buf);
buf.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
buf.memory = V4L2_MEMORY_MMAP;
buf.length = nplanes;
buf.m.planes =
(struct v4l2_plane *)calloc(nplanes, sizeof(struct v4l2_plane));
if (-1 == ioctl(fd, VIDIOC_DQBUF, &buf)) {
free(buf.m.planes);
printf("VIDIOC_DQBUF failed\n");
return -1;
assert(buf.index < n_buffers);
if (save_flag == 0) {
if ((count == read_num / 2) || ((count > 0) && (nplanes == 1))) {
printf("file length = %d \n", buffers[buf.index].length[0]);
printf("file start = %p \n", buffers[buf.index].start[0]);
switch (nplanes) {
case 0: /*webcam's nplanes=0 */
case 1:
sprintf(fdstr, "%s/fb%d_y%d_%d_%d_%u.bin", path_name, dev_id, mode, input_size.width, input_size.height, count);
file_fd = fopen(fdstr, "w");
fwrite(buffers[buf.index].start[0], buffers[buf.index].length[0], 1, file_fd);
fclose(file_fd);
break;
case 2:
#if ROT_90
dst = (char *)malloc(buffers[buf.index].length[0]);
yuv_r90(dst, buffers[buf.index].start[0], input_size.width, input_size.height);
sprintf(fdstr, "%s/fb%d_y%d_%d_%d.bin", path_name, dev_id, mode, input_size.height, input_size.width);
fwrite(dst, buffers[buf.index].length[0], 1, file_fd);
fclose(file_fd);
free(dst);
sprintf(fdstr, "%s/fb%d_uv%d_%d_%d.bin", path_name, dev_id, mode, input_size.height, input_size.width);
fclose(file_fd);
free(dst);
#else
sprintf(fdstr, "%s/fb%d_y%d_%d_%d.bin", path_name, dev_id, mode, input_size.width, input_size.height);
fclose(file_fd);
sprintf(fdstr, "%s/fb%d_uv%d_%d_%d.bin", path_name, dev_id, mode, input_size.width, input_size.height);
fclose(file_fd);
break;
case 3:
#if ROT_90
fclose(file_fd);
free(dst);
yuv_r90(dst, buffers[buf.index].start[0], input_size.width/2, input_size.height/2);
sprintf(fdstr, "%s/fb%d_u%d_%d_%d.bin", path_name, dev_id, mode, input_size.height, input_size.width);
fclose(file_fd);
free(dst);
sprintf(fdstr, "%s/fb%d_v%d_%d_%d.bin", path_name, dev_id, mode, input_size.height, input_size.width);
fclose(file_fd);
free(dst);
#else
fclose(file_fd);
sprintf(fdstr, "%s/fb%d_u%d_%d_%d.bin", path_name, dev_id, mode, input_size.width, input_size.height);
fclose(file_fd);
sprintf(fdstr, "%s/fb%d_v%d_%d_%d.bin", path_name, dev_id, mode, input_size.width, input_size.height);
fclose(file_fd);
break;
default:
break;
} else if (save_flag == 1) {
//if ((count > 0) && (count % 4 == 0)) {
if ((count > 0)) {
switch (nplanes) {
case 1:
sprintf(fdstr, "%s/fb%d_yuv%d_%d_%d.bin", path_name, dev_id, mode, input_size.width, input_size.height);
file_fd = fopen(fdstr, "ab");
fclose(file_fd);
break;
case 2:
fclose(file_fd);
fclose(file_fd);
break;
case 3:
fclose(file_fd);
fclose(file_fd);
fclose(file_fd);
break;
default:
break;
} else if (save_flag == 2) {
if (count <= 1)
count = read_num;
#if display_frame
} else {
count = 0;
if (-1 == ioctl(fd, VIDIOC_QBUF, &buf)) {
printf("VIDIOC_QBUF buf.index %d failed\n", buf.index);
//free(buf.m.planes);
return -1;
static struct disp_screen get_disp_screen(int w1, int h1, int w2, int h2)
struct disp_screen screen;
float r1, r2;
r1 = (float)w1/(float)w2;
r2 = (float)h1/(float)h2;
if (r1 < r2) {
screen.w = w2*r1;
screen.h = h2*r1;
} else {
screen.w = w2*r2;
screen.h = h2*r2;
screen.x = (w1 - screen.w)/2;
screen.y = (h1 - screen.h)/2;
return screen;
static int disp_disable(void)
#if display_frame
int ret;
struct disp_layer_config disp;
/* release memory && clear layer */
arg[0] = 0;
arg[1] = 0;
arg[2] = 0;
arg[3] = 0;
ioctl(dev.layer_info.dispfh, DISP_LAYER_DISABLE, (void *)arg);
/*close channel 0*/
memset(&disp, 0, sizeof(disp_layer_config));
disp.channel = 0;
disp.layer_id = 0;
disp.enable = 0;
arg[1] = (unsigned long)&disp;
arg[2] = 1;
arg[3] = 0;
if (ret != 0)
printf("disp_disable:disp_set_addr fail to set layer info\n");
/*close channel 2*/
disp.channel = 2;
disp.layer_id = 0;
disp.enable = 0;
arg[2] = 1;
arg[3] = 0;
if (ret != 0)
return ret;
#else
static int disp_init(int width, int height, unsigned int pixformat)
/* display_handle* disp = (display_handle*)display; */
unsigned int arg[6] = {0};
int layer_id = 0;
dev.layer_info.screen_id = 0;
if (dev.layer_info.screen_id < 0)
/* open device /dev/disp */
dev.layer_info.dispfh = open("/dev/disp", O_RDWR);
if (dev.layer_info.dispfh == -1) {
printf("open display device fail!\n");
return -1;
/* get current output type */
dev.layer_info.output_type = (disp_output_type)ioctl(
dev.layer_info.dispfh, DISP_GET_OUTPUT_TYPE, (void *)arg);
if (dev.layer_info.output_type == DISP_OUTPUT_TYPE_NONE) {
printf("the output type is DISP_OUTPUT_TYPE_NONE %d\n",
dev.layer_info.output_type);
return -1;
disp_disable();
dev.layer_info.pixformat = pixformat;
dev.layer_info.layer_config.channel = 0;
dev.layer_info.layer_config.layer_id = layer_id;
dev.layer_info.layer_config.info.zorder = 1;
dev.layer_info.layer_config.info.alpha_mode = 1;
dev.layer_info.layer_config.info.alpha_value = 0xff;
dev.layer_info.width =
ioctl(dev.layer_info.dispfh, DISP_GET_SCN_WIDTH, (void *)arg);
dev.layer_info.height =
ioctl(dev.layer_info.dispfh, DISP_GET_SCN_HEIGHT, (void *)arg);
dev.layer_info.layer_config.info.mode = LAYER_MODE_BUFFER;
dev.layer_info.layer_config.info.fb.format = DISP_FORMAT_YUV420_P; /*DISP_FORMAT_YUV420_P ---- V4L2_PIX_FMT_YUV420M*/
//DISP_FORMAT_YUV420_SP_UVUV; /*DISP_FORMAT_YUV420_SP_UVUV ---- V4L2_PIX_FMT_NV12*/
DISP_FORMAT_YUV422_SP_VUVU;
if (dev.layer_info.full_screen == 0 && width < dev.layer_info.width &&
height < dev.layer_info.height) {
dev.layer_info.layer_config.info.screen_win.x =
(dev.layer_info.width - width) / 2;
dev.layer_info.layer_config.info.screen_win.y =
(dev.layer_info.height - height) / 2;
if (!dev.layer_info.layer_config.info.screen_win.width) {
dev.layer_info.layer_config.info.screen_win.width = width;
dev.layer_info.layer_config.info.screen_win.height =
height;
} else {
/* struct disp_screen screen; */
get_disp_screen(dev.layer_info.width, dev.layer_info.height,
width, height);
dev.layer_info.layer_config.info.screen_win.x = 0; /* screen.x; */
dev.layer_info.layer_config.info.screen_win.y = 0; /* screen.y; */
dev.layer_info.width;
dev.layer_info.height;
/* printf("x: %d, y: %d, w: %d, h: %d\n",screen.x,screen.y,screen.w,screen.h); */
static void terminate(int sig_no)
printf("Got signal %d, exiting ...\n", sig_no);
disp_disable();
usleep(20*1000);
exit(1);
static void install_sig_handler(void)
signal(SIGBUS, terminate);
signal(SIGFPE, terminate);
signal(SIGHUP, terminate);
signal(SIGILL, terminate);
signal(SIGKILL, terminate);
signal(SIGINT, terminate);
signal(SIGIOT, terminate);
signal(SIGPIPE, terminate);
signal(SIGQUIT, terminate);
signal(SIGSEGV, terminate);
signal(SIGSYS, terminate);
signal(SIGTERM, terminate);
signal(SIGTRAP, terminate);
signal(SIGUSR1, terminate);
signal(SIGUSR2, terminate);
static int req_frame_buffers(void)
unsigned int i;
struct v4l2_requestbuffers req;
CLEAR(req);
req.count = req_frame_num;
req.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
req.memory = V4L2_MEMORY_MMAP;
if (-1 == ioctl(fd, VIDIOC_REQBUFS, &req)) {
printf("VIDIOC_REQBUFS error\n");
return -1;
buffers = calloc (req.count, sizeof (*buffers));
for (n_buffers = 0; n_buffers < req.count; ++n_buffers) {
CLEAR(buf);
buf.index = n_buffers;
if (-1 == ioctl(fd, VIDIOC_QUERYBUF, &buf)) {
printf("VIDIOC_QUERYBUF error\n");
free(buf.m.planes);
return -1;
buffers[n_buffers].length[0] = (int)buf.length;
buffers[n_buffers].start[0] = (void *)mmap (NULL /* start anywhere */,
buf.length,
PROT_READ | PROT_WRITE /* required */,
MAP_SHARED /* recommended */,
fd, buf.m.offset);
if (MAP_FAILED == buffers[n_buffers].start[0])
printf ("mmap failed\n");
return -1;
for (i = 0; i < n_buffers; ++i)
CLEAR (buf);
buf.index = i;
if (-1 == ioctl (fd, VIDIOC_QBUF, &buf))
printf ("VIDIOC_QBUF failed\n");
return -1;
static int free_frame_buffers(void)
unsigned int i, j;
for (i = 0; i < n_buffers; ++i) {
if (-1 == munmap(buffers[i].start[0], buffers[i].length[0])) {
printf("munmap error");
return -1;
free(buffers);
static int subdev_open(int *sub_fd, char *str)
char subdev[20] = {'\0'};
char node[50] = {'\0'};
char data[20] = {'\0'};
int i, fs = -1;
for (i = 0; i < 255; i++) {
sprintf(node, "/sys/class/video4linux/v4l-subdev%d/name", i);
fs = open(node, O_RDONLY/* required */| O_NONBLOCK, 0);
if (fs < 0) {
printf("open %s falied\n", node);
continue;
/*data_length = lseek(fd, 0, SEEK_END);*/
lseek(fs, 0L, SEEK_SET);
read(fs, data, 20);
close(fs);
if (!strncmp(str, data, strlen(str))) {
sprintf(subdev, "/dev/v4l-subdev%d", i);
printf("find %s is %s\n", str, subdev);
*sub_fd = open(subdev, O_RDWR | O_NONBLOCK, 0);
if (*sub_fd < 0) {
printf("open %s falied\n", str);
return -1;
printf("open %s fd = %d\n", str, *sub_fd);
printf("can not find %s!\n", str);
return -1;
static tryFmt(int format) {
struct v4l2_fmtdesc fmtdesc;
fmtdesc.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
for (int i = 0; i < 12; i++) {
fmtdesc.index = i;
if (-1 == ioctl(fd, VIDIOC_ENUM_FMT, &fmtdesc)) {
break;
printf("format index = %d, name = %s, v4l2 pixel format = %x\n",
i, fmtdesc.description, fmtdesc.pixelformat);
if (fmtdesc.pixelformat == format) {
return -1;
static int camera_init(int sel, int mode)
struct v4l2_input inp;
struct v4l2_streamparm parms;
fd = open(dev_name, O_RDWR /* required */ | O_NONBLOCK, 0);
if (fd < 0) {
printf("open falied\n");
return -1;
printf("open %s fd = %d\n", dev_name, fd);
#ifdef SUBDEV_TEST
if (-1 == subdev_open(&isp0_fd, "sunxi_isp.0"))
return -1;
if (-1 == subdev_open(&isp1_fd, "sunxi_isp.1"))
return -1;
struct v4l2_capability cap={0};
int ret = ioctl(fd, VIDIOC_QUERYCAP, &cap);
if(ret < 0){
printf("dbg1 VIDIOC_QUERYCAP failed ret=%d\n",ret);
exit;
if (!strcmp((char *) cap.driver, "uvcvideo")) {
int mCaptureFormat = 0;
printf("mCameraType = CAMERA_TYPE_UVC\n");
if (tryFmt(V4L2_PIX_FMT_NV21) == 0) {
mCaptureFormat = V4L2_PIX_FMT_NV21;
printf("capture format: V4L2_PIX_FMT_NV21\n");
else if (tryFmt(V4L2_PIX_FMT_H264) == 0) {
mCaptureFormat = V4L2_PIX_FMT_H264;
printf("capture format: V4L2_PIX_FMT_H264\n");
else if (tryFmt(V4L2_PIX_FMT_YUYV) == 0) {
mCaptureFormat = V4L2_PIX_FMT_YUYV; // maybe usb camera
printf("capture format: V4L2_PIX_FMT_YUYV\n");
else if (tryFmt(V4L2_PIX_FMT_MJPEG) == 0) {
mCaptureFormat = V4L2_PIX_FMT_MJPEG; // maybe usb camera
printf("capture format: V4L2_PIX_FMT_MJPEG\n");
else {
printf("driver should surpport NV21/NV12 or YUYV format, but it not!");
exit;
inp.index = sel;
if (-1 == ioctl(fd, VIDIOC_S_INPUT, &inp)) {
printf("VIDIOC_S_INPUT %d error!\n", sel);
return -1;
CLEAR(parms);
parms.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
parms.parm.capture.timeperframe.numerator = 1;
parms.parm.capture.timeperframe.denominator = fps;
parms.parm.capture.capturemode = V4L2_MODE_VIDEO;
/* parms.parm.capture.capturemode = V4L2_MODE_IMAGE; */
/*when different video have the same sensor source, 1:use sensor current win, 0:find the nearest win*/
parms.parm.capture.reserved[0] = 0;
parms.parm.capture.reserved[1] = wdr_mode;/*2:command, 1: wdr, 0: normal*/
if (-1 == ioctl(fd, VIDIOC_S_PARM, &parms)) {
printf("VIDIOC_S_PARM error\n");
return -1;
static int camera_fmt_set(int mode)
struct v4l2_format fmt;
CLEAR(fmt);
fmt.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
fmt.fmt.pix_mp.width = input_size.width;
fmt.fmt.pix_mp.height = input_size.height;
switch (mode) {
case 0:
fmt.fmt.pix_mp.pixelformat = V4L2_PIX_FMT_SBGGR8;
break;
case 1:
fmt.fmt.pix_mp.pixelformat = V4L2_PIX_FMT_YUV420M;
break;
case 2:
fmt.fmt.pix_mp.pixelformat = V4L2_PIX_FMT_YUV420;
break;
case 3:
fmt.fmt.pix_mp.pixelformat = V4L2_PIX_FMT_NV12M;
break;
case 4:
fmt.fmt.pix_mp.pixelformat = V4L2_PIX_FMT_NV21;
break;
case 5:
fmt.fmt.pix_mp.pixelformat = V4L2_PIX_FMT_SBGGR10;
break;
case 6:
fmt.fmt.pix_mp.pixelformat = V4L2_PIX_FMT_SBGGR12;
break;
case 7:
fmt.fmt.pix_mp.pixelformat = V4L2_PIX_FMT_LBC_2_5X;
break;
case 8:
fmt.fmt.pix_mp.pixelformat = V4L2_PIX_FMT_H264;
break;
default:
break;
fmt.fmt.pix_mp.field = V4L2_FIELD_NONE;
if (-1 == ioctl(fd, VIDIOC_S_FMT, &fmt)) {
printf("VIDIOC_S_FMT error!\n");
return -1;
if (-1 == ioctl(fd, VIDIOC_G_FMT, &fmt)) {
printf("VIDIOC_G_FMT error!\n");
return -1;
} else {
nplanes = fmt.fmt.pix_mp.num_planes;
printf("resolution got from sensor = %d*%d num_planes = %d\n",
fmt.fmt.pix_mp.width, fmt.fmt.pix_mp.height,
fmt.fmt.pix_mp.num_planes);
static int video_set_control(int cmd, int value)
struct v4l2_control control;
control.id = cmd;
control.value = value;
if (-1 == ioctl(fd, VIDIOC_S_CTRL, &control)) {
printf("VIDIOC_S_CTRL failed\n");
return -1;
static int video_get_control(int cmd)
control.id = cmd;
if (-1 == ioctl(fd, VIDIOC_G_CTRL, &control)) {
printf("VIDIOC_G_CTRL failed\n");
return -1;
return control.value;
static int main_test(int sel, int mode)
enum v4l2_buf_type type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
struct v4l2_ext_control ctrls[4];
struct v4l2_ext_controls ext_ctrls;
int ret;
int i, j = 0;
if (-1 == camera_init(sel, mode))
return -1;
if (-1 == camera_fmt_set(mode))
return -1;
if (-1 == req_frame_buffers())
return -1;
#if display_frame
pixformat = TVD_PL_YUV420;
ret = disp_init(input_size.width, input_size.height, pixformat);
if (ret)
return 2;
if (-1 == ioctl(fd, VIDIOC_STREAMON, &type)) {
printf("VIDIOC_STREAMON failed\n");
return -1;
} else
printf("VIDIOC_STREAMON ok\n");
count = read_num;
while (count-- > 0) {
for (;;) {
fd_set fds;
struct timeval tv;
int r;
FD_ZERO(&fds);
FD_SET(fd, &fds);
tv.tv_sec = 2; /* Timeout. */
tv.tv_usec = 0;
#if video_s_ctrl
if (count%3 == 0) {
if (j == 0) {
video_set_control(V4L2_CID_VFLIP, 0);
video_set_control(V4L2_CID_HFLIP, 0);
j = 1;
printf("V4L2_CID_VFLIP done, j = %d, count = %d\n", j, count);
} else {
video_set_control(V4L2_CID_VFLIP, 1);
video_set_control(V4L2_CID_HFLIP, 1);
j = 0;
printf("V4L2_CID_VFLIP no done, j = %d, count = %d\n", j, count);
#ifdef SUBDEV_TEST
for (i = 0; i < 4; i++) {
ctrls[i].id = V4L2_CID_R_GAIN + i;
ctrls[i].value = count % 256;
memset(&ext_ctrls, 0, sizeof(ext_ctrls));
ext_ctrls.ctrl_class = V4L2_CID_R_GAIN;
ext_ctrls.count = 4;
ext_ctrls.controls = ctrls;
ioctl(isp0_fd, VIDIOC_S_EXT_CTRLS, &ext_ctrls);
ctrls[i].id = V4L2_CID_AE_WIN_X1 + i;
ctrls[i].value = count*16 % 256;
ext_ctrls.ctrl_class = V4L2_CID_AE_WIN_X1;
ctrls[i].id = V4L2_CID_AF_WIN_X1 + i;
ext_ctrls.ctrl_class = V4L2_CID_AF_WIN_X1;
if (count == read_num / 4) {
control.id = V4L2_CID_VFLIP;
control.value = 1;
return -1;
} else
printf("VIDIOC_S_CTRL ok\n");
if (count == read_num / 2) {
control.id = V4L2_CID_HFLIP;
control.value = 1;
return -1;
} else
r = select(fd + 1, &fds, NULL, NULL, &tv);
if (-1 == r) {
if (errno == EINTR)
continue;
printf("select err\n");
if (r == 0) {
fprintf(stderr, "select timeout\n");
#ifdef TIMEOUT
if (-1 == ioctl(fd, VIDIOC_STREAMOFF, &type))
printf("VIDIOC_STREAMOFF failed\n");
printf("VIDIOC_STREAMOFF ok\n");
free_frame_buffers();
return -1;
#else
continue;
if (!read_frame(mode))
break;
return -1;
disp_disable();
usleep(20*1000);
if (-1 == ioctl(fd, VIDIOC_STREAMOFF, &type)) {
return -1;
} else
if (-1 == free_frame_buffers())
return -1;
#if SUBDEV_TEST
close(isp0_fd);
close(isp1_fd);
int i, test_cnt = 1;
int sel = 0;
int width = 640;
int height = 480;
int mode = 1;
struct timeval tv1, tv2;
float tv;
install_sig_handler();
CLEAR(dev_name);
CLEAR(path_name);
if (argc == 1) {
sprintf(dev_name, "/dev/video0");
sprintf(path_name, "/mnt/sdcard");
} else if (argc == 3) {
dev_id = atoi(argv[1]);
sprintf(dev_name, "/dev/video%d", dev_id);
sel = atoi(argv[2]);
} else if (argc == 5) {
width = atoi(argv[3]);
height = atoi(argv[4]);
} else if (argc == 6) {
sprintf(path_name, "%s", argv[5]);
} else if (argc == 7) {
mode = atoi(argv[6]);
} else if (argc == 8) {
test_cnt = atoi(argv[7]);
} else if (argc == 9) {
fps = atoi(argv[8]);
} else if (argc == 10) {
wdr_mode = atoi(argv[9]);
} else {
printf("please select the video device: 0-video0 1-video1 ......\n");
scanf("%d", &dev_id);
printf("please select the camera: 0-dev0 1-dev1 ......\n");
scanf("%d", &sel);
printf("please input the resolution: width height......\n");
scanf("%d %d", &width, &height);
printf("please input the frame saving path......\n");
scanf("%15s", path_name);
printf("please input the test mode: 0~3......\n");
scanf("%d", &mode);
printf("please input the test_cnt: >=1......\n");
scanf("%d", &test_cnt);
input_size.width = width;
input_size.height = height;
if (test_cnt < read_num) {
read_num = test_cnt;
save_flag = 0;
test_cnt = 1;
} else if (test_cnt < 1000) {
/*if output is raw then save one frame*/
if (mode < 5)
save_flag = 1;
save_flag = 0;
test_cnt = 1;
} else if (test_cnt < 10000) {
save_flag = 3;
test_cnt = 10;
} else {
save_flag = 2;
test_cnt = 1;
for (i = 0; i < test_cnt; i++) {
gettimeofday(&tv1, NULL);
if (0 == main_test(sel, mode))
printf("mode %d test done at the %d time!!\n", mode, i);
printf("mode %d test failed at the %d time!!\n", mode, i);
close(fd);
gettimeofday(&tv2, NULL);
tv = (float)((tv2.tv_sec - tv1.tv_sec) * 1000000 + tv2.tv_usec - tv1.tv_usec) / 1000000;
printf("time cost %f(s)\n", tv);
}离线
