楼主 # 2025-09-22 19:10:14
yu yinxi
求助各位大佬,全志A133烧录固件后无法进入系统
[145]BOOT0 commit : 5991375c7e
[148]set pll start
[150]periph0 has been enabled
[154]set pll end
[155]PL gpio voltage : 3.3V
[160]PMU: AXP803
[179]dram return write ok
[182]dram_para[0]:0x318
[184]dram_para[1]:0x8
[186]dram_para[2]:0x7070707
[189]dram_para[3]:0xd0d0d0d
[192]dram_para[4]:0xe0e
[194]dram_para[5]:0xd0a050c
[197]dram_para[6]:0x310a
[199]dram_para[7]:0x10001000
[202]dram_para[8]:0x0
[204]dram_para[9]:0x34
[207]dram_para[10]:0x1b
[209]dram_para[11]:0x33
[211]dram_para[12]:0x3
[214]dram_para[13]:0x0
[216]dram_para[14]:0x0
[218]dram_para[15]:0x4
[221]dram_para[16]:0x72
[223]dram_para[17]:0x0
[225]dram_para[18]:0x7
[227]dram_para[19]:0x0
[230]dram_para[20]:0x0
[232]dram_para[21]:0x26
[234]dram_para[22]:0x6060606
[237]dram_para[23]:0x84040404
[240]dram_para[24]:0x0
[243]dram_para[25]:0x0
[245]dram_para[26]:0x48000000
[248]dram_para[27]:0x273333
[251]dram_para[28]:0x1d17121b
[253]dram_para[29]:0x14141313
[256]dram_para[30]:0x7521
[259]dram_para[31]:0x2023211f
[262]board init ok, set sys_vol to 940mv!
[286]enable_jtag
[288]DRAM BOOT DRIVE INFO: V0.697
[291]the chip id is 0x8000
[294]the chip id is 0x8000
[297]the chip id is 0x8000
[299]the chip id is 0x8000
[302]the chip id is 0x8000
[305]chip id check OK
[314]DRAM_VCC set to 1100 mv
[317]DRAM CLK =792 MHZ
[319]DRAM Type =8 (3:DDR3,4:DDR4,6:LPDDR2,7:LPDDR3,8:LPDDR4)
[331]DRAM SIZE =4096 MBytes, para1 = 310a, para2 = 10001000, tpr13 = 7521
[342]DRAM simple test OK.
[345]dram size =4096
[348]card no is 2
[350]sdcard 2 line count 8
[352][mmc]: mmc driver ver 2021-10-12 13:56
[357][mmc]: b mmc 2 bias 0
[365][mmc]: Wrong media type 0x0, but host sdc2, try mmc first
[371][mmc]: ***Try MMC card 2***
[397][mmc]: RMCA OK!
[400][mmc]: MMC 5.1
[402][mmc]: HSSDR52/SDR25 8 bit
[405][mmc]: 50000000 Hz
[408][mmc]: 59640 MB
[410][mmc]: ***SD/MMC 2 init OK!!!***
[477]Loading boot-pkg Succeed(index=0).
[481][mmc]: b mmc 2 bias 0
[484]Entry_name        = u-boot
[492]Entry_name        = monitor
[496]Entry_name        = scp
[499]set arisc reset to assert state
[508]set arisc reset to de-assert state
[512]Entry_name        = dtb
[515]tunning data addr:0x4a0003e8
[519]Jump to second Boot.
NOTICE:  BL3-1: v1.0(debug):da6c454
NOTICE:  BL3-1: Built : 15:51:09, 2023-02-21
NOTICE:  BL3-1 commit: 8
nsi init ok 2022-11-08
NOTICE:  cpuidle init version V2.0
ERROR:   Error initializing runtime service tspd_fast
NOTICE:  BL3-1: Preparing for EL3 exit to normal world
NOTICE:  BL3-1: Next image address = 0x4a000000
▒OTICE:  BL3-1: Next image spsr = 0x1d3
U-Boot 2018.07-g12e5399-dirty (Sep 22 2025 - 15:49:39 +0800) Allwinner Technology
[00.568]CPU:   Allwinner Family
[00.571]Model: sun50iw10
I2C:   ready
[00.587]DRAM:  4 GiB
[00.591]Relocation Offset is: 75ed8000
[00.634]secure enable bit: 0
[00.636]axp519 pmic_bus_read fail
[00.639]pmu_axp806_probe pmic_bus_read fail
[00.643]PMU: AXP803
[01.480]PMU: AXP803
[01.483][axp][err]: can't find bldo1_vol from table
[01.487][axp][err]: can't find bldo1_vol from table
[01.492][axp][err]: can't find bldo2_vol from table
[01.496][axp][err]: can't find bldo2_vol from table
[01.501][axp][err]: can't find cldo4_vol from table
[01.505][axp][err]: can't find cldo4_vol from table
[01.511]pmu_sy8827g_probe pmic_bus_read fail
[01.515]pmu_tcs4838_probe pmic_bus_read fail
[01.520]CPU=1416 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=400Mhz
[01.526]gic: sec monitor mode
[01.530]flash init start
[01.532]workmode = 0,storage type = 2
[01.535][mmc]: mmc driver ver uboot2018:2023-07-4 16:18:00
[01.541][mmc]: SUNXI SDMMC Controller Version:0x50300
[01.566][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 8
[01.572]sunxi flash init ok
[01.575]drv_disp_init
request pwm success, pwm0:pwm0:0x300a000.
[01.628]drv_disp_init finish
[01.640]Loading Environment from SUNXI_FLASH... [01.652]Item0 (Map) magic is bad
[01.655]the secure storage item0 copy0 magic is bad
[01.667]Item0 (Map) magic is bad
[01.670]the secure storage item0 copy1 magic is bad
[01.675]Item0 (Map) magic is bad
[01.678]sunxi_secure_storage_exit err: secure storage has not been inited
OK
[01.687]boot_gui_init:start
partno erro : can't find partition Reserve0
[01.700][axp][err]: can't find cldo4 from table
[01.709][axp][err]: can't find cldo1 from table
[01.743][axp][err]: can't find cldo3 from table
bad fb1_cfg[w=0,h=0,bpp=32,format=0]
[01.812]boot_gui_init:finish
[01.827]Item0 (Map) magic is bad
[01.830]the secure storage item0 copy0 magic is bad
[01.842]Item0 (Map) magic is bad
[01.845]the secure storage item0 copy1 magic is bad
[01.850]Item0 (Map) magic is bad
[01.853]usb burn from boot
delay time 0
weak:otg_phy_config
[01.863]usb prepare ok
[01.918]LCD open finish
[02.028]usb sof ok
[02.030]usb probe ok
[02.032]usb setup ok
set address 0x1a
set address 0x1a ok
try to update
[02.439]do_burn_from_boot usb : have no handshake
[02.443][ARISC ERROR] :get [allwinner,arisc_space] device node error
[SCP] :sunxi-arisc driver begin startup 2
[SCP] :0x1
[SCP] :arisc version: [lbata-te-325rdna1diorg-41v-fd-1.ytri]
[SCP] :arisc startup ready
[SCP] :arisc startup notify message feedback
[SCP] :send hard sync feedback message: 0x900200
[SCP] :sunxi-arisc driver v1.10 is starting
List file under ULI/factory
** Unrecognized filesystem type **
[02.486]update part info
[02.489]battery temp is 305
[02.492]bat_ratio:0     safe_ratio:1    bat_vol:0mV     safe_vol:3400mV
有没有大佬能不能帮我看一下这个问题是出在哪里,当前固件烧录之后都无法进入内核当中,希望大佬稍微指点一下,十分十分的感谢!
