楼主 # 2025-09-30 11:47:14
a-path
F1C200S驱动GPIO
介绍
使用LC-PI-200S开发板驱动LED闪烁
开发板芯片:F1C200S
开发板网址:http://wiki.lcmaker.com/index.php?title=LC-PI-200S
测试驱动引脚:PA0
设备树
路径"\lc\buildroot\board\widora\mangopi\r3\devicetree\linux\devicetree.dts"
	led {
		compatible = "led";
		gpios = <&pio 0 0 GPIO_ACTIVE_LOW>;
		pinctrl-names = "default";
&pio {
    led_pins: led_pins {
        pins = "PA0";
驱动
led.c
#include <linux/init.h>
#include <linux/module.h>
#include <linux/fs.h>
#include <linux/io.h>
#include <linux/uaccess.h>
#include <linux/device.h>
#include <linux/of.h>
#include <linux/gpio.h>
#include <linux/of_gpio.h>
#define CDEV_NAME "led"
#define LED_NODE_PATH "/led"
#define LED_NODE_PROPERTY "gpios"
int major = -1;
int gpionum = -1;
struct class *cls = NULL;
struct device *dev = NULL;
struct device_node *led_node = NULL;
char kbuf[128] = {0};
ssize_t my_write (struct file *file, const char __user *ubuf, size_t size, loff_t *offset)
	size = size > sizeof(kbuf)  ? sizeof(kbuf) : size;
	if(copy_from_user(kbuf, ubuf, size))
		printk("copy data from user failed!\n");
		return -EINVAL;
	if(kbuf[0] == '1')
		gpio_set_value(gpionum,1); //设置高电平
		gpio_set_value(gpionum,0); //设置低电平
	return size;
struct file_operations fops = {
	.write = my_write,
int gpio_init(void)
	//获取节点
	led_node = of_find_node_by_path(LED_NODE_PATH);
	if(led_node == NULL)
		printk("find node %s failed!\n",LED_NODE_PATH );
		return -ENODEV;
	//获取gpio编号
	gpionum = of_get_named_gpio(led_node, LED_NODE_PROPERTY, 0);
	if(gpionum < 0)
		printk("get property %s failed!\n",LED_NODE_PROPERTY );
		return -EINVAL;
	//申请GPIO
	if(gpio_request(gpionum,NULL))
		printk("request gpio failed!\n");
		return -EINVAL;
	//设置GPIO为输出
	if(gpio_direction_output(gpionum, 0))
		printk("set gpio direction failed!\n");
		return -EINVAL;
static int __init mydev_init(void)
	//注册字符设备
	major = register_chrdev(0,CDEV_NAME,&fops);
	if(major < 0)
		printk("register chardev failed! \n");
		return -1;
	//自动创建设备节点
	//提交目录信息
	cls = class_create(THIS_MODULE,CDEV_NAME);
	if(IS_ERR(cls))
		printk("auto create node failed! \n");
		return PTR_ERR(cls);
	//提交设备信息
	dev = device_create(cls,NULL,MKDEV(major,0),NULL,CDEV_NAME);
		if(IS_ERR(dev))
			printk("device create failed! \n");
			return PTR_ERR(dev);
	gpio_init();
void gpio_deinit(void)
	gpio_free(gpionum);
static void __exit mydev_exit(void)
	gpio_deinit();
	device_destroy(cls, MKDEV(major,0));
	class_destroy(cls);
	unregister_chrdev(major,CDEV_NAME);
module_init(mydev_init);
module_exit(mydev_exit);
MODULE_LICENSE("GPL");
MODULE_AUTHOR("yuan u1232@qq.com");
MODULE_VERSION("1.0");
Makefile
KERNELDIR:=/home/test/lc/buildroot/output/build/linux-5.4.99/  #内核源码路径
ARCH=arm
CROSS_COMPILE=/home/test/lc/buildroot/output/host/bin/arm-buildroot-linux-gnueabi-
export  ARCH  CROSS_COMPILE
obj-m += led.o
module:
	make -C $(KERNELDIR) M=$(CURDIR) ARCH=arm modules
clean:
	make -C $(KERNELDIR) M=$(CURDIR) ARCH=arm clean
应用
编译"/home/test/lc/buildroot/output/host/bin/arm-linux-gcc test.c -o test"
test.c
#include <stdio.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <unistd.h>
int main()
	int fd = open("/dev/led",O_RDWR);
	if(fd == -1)
		printf("open failed");
		return -1;
	while(1)
		write(fd,"1",1);
		sleep(1);
		write(fd,"0",1);
		sleep(1);
	close(fd);
最近编辑记录 a-path (2025-09-30 11:48:51)
#1 2025-10-01 10:15:46
lanlanzhilian
已发帖子: 159
Re: F1C200S驱动GPIO
这个芯片还是老老实实玩裸机吧
楼主 #3 2025-10-16 10:51:33
a-path
Re: F1C200S驱动GPIO
lanlanzhilian 说:
这个芯片还是老老实实玩裸机吧
我感觉还可以吧,为啥不建议跑Linux
