楼主 # 2025-10-15 11:30:53
fenglichao
t113 使用tina5.0 驱动aic8800d80出错 请大佬指正
报错log
# modprobe aic8800_fdrv.ko
[  191.452261] aicbsp_init
[  191.455016] aicbsp_init, Driver Release Tag: aic-bsp-compatible(sdio)-20221108-001
[  191.464580] [sound  403][MACH simple_parse_of] simple_dai_link_of failed
[  191.472356] -->aicbt_rfkill_init
[  191.476221] <--aicbt_rfkill_init
[  191.499263] >>> rwnx_mod_init()
[  191.502804] rwnx 20221108-004-6.4.3.0 - - 241c091M (master)
[  191.509121] Driver Release Tag: aic-rwnx-compatible(sdio)-20221108-004
[  191.516450] aicbsp: aicbsp_set_subsys, subsys: AIC_WIFI, state to: 1
[  191.523612] aicbsp: aicbsp_set_subsys, power state change to 1 dure to AIC_WIFI
[  191.531824] aicbsp: aicbsp_platform_power_on
[  191.536619] sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
[  191.553047] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
[  191.611290] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[  191.622565] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
[  191.642741] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[  191.667848] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[  191.675554] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[  191.682470] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[  191.697111] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[  191.719837] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[  191.731461] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[  191.743348] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[  191.756879] mmc1: new high speed SDIO card at address 390b
[  193.643754] sunxi-rfkill soc@3000000:rfkill@0: wlan power off success
[  193.651029] aicbsp: aicbsp_set_subsys, fail to set AIC_WIFI power state to 1
[  193.658983] rwnx_mod_init, set power on fail!
[  193.754579] >>> rwnx_mod_init()
[  193.758116] rwnx 20221108-004-6.4.3.0 - - 241c091M (master)
[  193.764454] Driver Release Tag: aic-rwnx-compatible(sdio)-20221108-004
[  193.764463] aicbsp: aicbsp_set_subsys, subsys: AIC_WIFI, state to: 1
[  193.764468] aicbsp: aicbsp_set_subsys, power state change to 1 dure to AIC_WIFI
[  193.764471] aicbsp: aicbsp_platform_power_on
[  193.774633] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
[  193.851051] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
[  193.857827] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
[  193.864599] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
[  193.871364] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
[  193.878521] mmc1: card 390b removed
[  193.883375] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[  193.896101] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[  193.907348] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
[  193.927546] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[  193.952632] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[  193.960310] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[  193.967175] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[  193.981817] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[  194.004388] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[  194.016015] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[  194.027907] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[  194.041243] mmc1: new high speed SDIO card at address 390b
[  195.883630] sunxi-rfkill soc@3000000:rfkill@0: wlan power off success
[  195.890912] aicbsp: aicbsp_set_subsys, fail to set AIC_WIFI power state to 1
[  195.898853] rwnx_mod_init, set power on fail!
modprobe: can't load module aic8800_fdrv.ko (aic8800_fdrv.ko): No such device
dts配置
    rfkill: rfkill@0 {
        compatible    = "allwinner,sunxi-rfkill";
        chip_en;
        pinctrl-0 = <&wlan_pins_a>;
        pinctrl-names = "default";
        status        = "okay";
        wlan: wlan@0 {
            compatible    = "allwinner,sunxi-wlan";
            clock-names = "32k-fanout1";
            clocks = <&ccu CLK_FANOUT1_OUT>;
            wlan_busnum    = <0x1>;
            wlan_regon    = <&pio PG 12 GPIO_ACTIVE_HIGH>;
            wlan_hostwake  = <&pio PG 10 GPIO_ACTIVE_HIGH>;
            /*wlan_power    = "VCC-3V3";
            wlan_power_vol = <3300000>;*/
            /*interrupt-parent = <&pio>;
            interrupts = < PG 10 IRQ_TYPE_LEVEL_HIGH>;*/
            wakeup-source;
        bt: bt@0 {
            compatible    = "allwinner,sunxi-bt";
            /*bt_power_num = <0x01>;*/
            /*bt_power      = "axp803-dldo1";*/
            /*bt_io_regulator = "axp803-dldo1";*/
            /*bt_io_vol = <3300000>;*/
            /*bt_power_vol = <330000>;*/
            bt_rst_n      = <&pio PD 22 GPIO_ACTIVE_LOW>;
            status        = "disabled";
    btlpm: btlpm@0 {
        compatible  = "allwinner,sunxi-btlpm";
        uart_index  = <0x1>;
        bt_wake     = <&pio PG 15 GPIO_ACTIVE_HIGH>;
        bt_hostwake = <&pio PG 14 GPIO_ACTIVE_HIGH>;
    addr_mgt: addr_mgt@0 {
        compatible     = "allwinner,sunxi-addr_mgt";
        type_addr_wifi = <0x0>;
        type_addr_bt   = <0x0>;
        type_addr_eth  = <0x0>;
        status         = "okay";
#1 2025-10-15 12:35:29
4610
已发帖子: 138
Re: t113 使用tina5.0 驱动aic8800d80出错 请大佬指正
像没使能,量一下模块的供电和使能
楼主 #2 2025-10-15 13:08:36
fenglichao
4610 说:
像没使能,量一下模块的供电和使能
看着打印已经扫到卡了 mmc1: new high speed SDIO card at address 390b
