root@TinaLinux:/# gst-launch-1.0 playbin uri=file:///mnt/exUDISK/test.mp4
divx class init!
mjpeg class init!
(gst-plugin-scanner:2814): GStreamer-WARNING **: 08:38:19.604: Failed to load plugin '/usr/lib/gstreamer-1.0/libgstvideo4linux2.so': /usr/lib/gstreamer-1.0/libgstvideo4linux2.so: undefined symbol: gst_v4l2_buffer_pool_resurect_buffer
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ...
-->sunxifbsink init.
dd: error writing '/dev/fb0': No space left on device
9601+0 records in
9600+0 records out
Succesfully opened fbdev framebuffer device /dev/fb0, mapped sized 12.00 MB of which 11.72 MB (5 buffers) usable for page flipping.
fbdev phy=0x00000000,len=0x4b0000,vir=0xb33b3000,size=0xc00000.
-->/dev/transform does not exist, hardware rotation is not supported.
-->reserver layer called (screen = 1024 x 600).
-->Hardware overlay available.
Succesfully opened screen of pixel depth 32, dimensions 1024 x 600, format BGRx, 12.00 MB video memory available, max 5 pannable screen buffers, vsync enabled.
Redistribute latency...
---->sunxifb pre overlay(SCWxSCN=672 x 378,out_rec=[176 111,672,378]).
Using one framebuffer plus 8 overlays in video memory (format YV12).
[ 38.538140] VE: enable hw clock
[ 38.541906] enable_cedar_hw_clk,558
[ 39.584836] 8<--- cut here ---
[ 39.588283] Unable to handle kernel paging request at virtual address 10101000
[ 39.597073] pgd = 924a5d4d
[ 39.600189] [10101000] *pgd=00000000
[ 39.604209] Internal error: Oops: 2805 [#1] PREEMPT SMP ARM
[ 39.610457] Modules linked in:
[ 39.613886] CPU: 1 PID: 2824 Comm: vqueue:src Not tainted 5.4.61 #1
[ 39.620912] Hardware name: Generic DT based system
[ 39.626297] PC is at b15_dma_flush_range+0x1c/0x34
[ 39.631675] LR is at compat_cedardev_ioctl+0xc20/0xdb0
[ 39.637439] pc : [<c01146a0>] lr : [<c0610604>] psr: 600c0013
[ 39.644469] sp : c6785ed0 ip : 00000010 fp : b494be30
[ 39.650328] r10: c0d03dc8 r9 : c6784000 r8 : b1328c78
[ 39.656189] r7 : c6767600 r6 : 00000506 r5 : c0d03dc8 r4 : b1328c78
[ 39.663510] r3 : 0000003f r2 : 00000040 r1 : 1015e070 r0 : 10101000
[ 39.670833] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none
[ 39.678836] Control: 10c5387d Table: 467a406a DAC: 00000051
[ 39.685282] Process vqueue:src (pid: 2824, stack limit = 0x9c80ac09)
[ 39.692408] Stack: (0xc6785ed0 to 0xc6786000)
[ 39.697295] 5ec0: 10101010 00000000 1015e070 00000000
[ 39.706473] 5ee0: b3668000 c5bd32a4 c67a6cd8 b1328c78 c4bd2c08 c6767600 00000506 b1328c78
[ 39.715650] 5f00: c6784000 c01ec0fc b1328c78 c01ece8c 00000000 00000000 00000000 00000000
[ 39.724827] 5f20: 00000800 c5bd32a4 c67e7040 c6785fb0 00000055 b3668000 c67e7040 c014f6e4
[ 39.734005] 5f40: c6785fb0 00000055 b3668000 c010f268 c6767600 00000001 00004000 c65f9500
[ 39.743182] 5f60: 0000000b c5bd32a4 00000036 0000000b c6767601 c6767600 00000506 b1328c78
[ 39.752360] 5f80: c6784000 00000036 b494be30 c01ecf6c b4a96f10 10101010 10101010 00000036
[ 39.761537] 5fa0: c0101228 c0101000 b4a96f10 10101010 0000000b 00000506 b1328c78 b494b398
[ 39.770715] 5fc0: b4a96f10 10101010 10101010 00000036 01553178 b494be30 b4ae7f34 b494be30
[ 39.779892] 5fe0: b4a96f3c b1328c74 b4a84a20 b6b1f92c 200c0010 0000000b 00000000 00000000
[ 39.789082] [<c01146a0>] (b15_dma_flush_range) from [<c0610604>] (compat_cedardev_ioctl+0xc20/0xdb0)
[ 39.799342] [<c0610604>] (compat_cedardev_ioctl) from [<c01ec0fc>] (vfs_ioctl+0x18/0x3c)
[ 39.808427] [<c01ec0fc>] (vfs_ioctl) from [<c01ece8c>] (do_vfs_ioctl+0x618/0x6c4)
[ 39.816830] [<c01ece8c>] (do_vfs_ioctl) from [<c01ecf6c>] (ksys_ioctl+0x34/0x5c)
[ 39.825137] [<c01ecf6c>] (ksys_ioctl) from [<c0101000>] (ret_fast_syscall+0x0/0x54)
[ 39.833726] Exception stack(0xc6785fa8 to 0xc6785ff0)
[ 39.839393] 5fa0: b4a96f10 10101010 0000000b 00000506 b1328c78 b494b398
[ 39.848571] 5fc0: b4a96f10 10101010 10101010 00000036 01553178 b494be30 b4ae7f34 b494be30
[ 39.857745] 5fe0: b4a96f3c b1328c74 b4a84a20 b6b1f92c
[ 39.863416] Code: e3a02004 e1a02312 e2423001 e1c00003 (ee070f3e)
[ 39.870353] ---[ end trace 684dce851284c2be ]---
有哪位大神遇到过相同的问题,
楼主解决了吗?
