楼主 # 2025-11-20 17:39:20
青木城池
为什么用webclient 访问https会报错啊 错误码-0x7780
[115672] I/wifi_test: HTTPS test start, connecting to https://www.baidu.com
packages\third-party\mbedtls\mbedtls\library\ssl_tls.c:5904: => handshake
packages\third-party\mbedtls\mbedtls\library\ssl_cli.c:4483: client state: 0
packages\third-party\mbedtls\mbedtls\library\ssl_msg.c:2102: => flush output
packages\third-party\mbedtls\mbedtls\library\ssl_msg.c:2114: <= flush output
packages\third-party\mbedtls\mbedtls\library\ssl_cli.c:4483: client state: 1
packages\third-party\mbedtls\mbedtls\library\ssl_cli.c:0999: => write client hello
packages\third-party\mbedtls\mbedtls\library\ssl_msg.c:2542: => write handshake message
packages\third-party\mbedtls\mbedtls\library\ssl_msg.c:2701: => write record
packages\third-party\mbedtls\mbedtls\library\ssl_msg.c:2120: message length: 112, out_left: 112
packages\third-party\mbedtls\mbedtls\library\ssl_msg.c:2127: ssl->f_send() returned 112 (-0xffffff90)
packages\third-party\mbedtls\mbedtls\library\ssl_msg.c:2155: <= flush output
packages\third-party\mbedtls\mbedtls\library\ssl_msg.c:2870: <= write record
packages\third-party\mbedtls\mbedtls\library\ssl_msg.c:2678: <= write handshake message
packages\third-party\mbedtls\mbedtls\library\ssl_cli.c:1467: <= write client hello
packages\third-party\mbedtls\mbedtls\library\ssl_cli.c:4483: client state: 2
packages\third-party\mbedtls\mbedtls\library\ssl_cli.c:2082: => parse server hello
packages\third-party\mbedtls\mbedtls\library\ssl_msg.c:3941: => read record
packages\third-party\mbedtls\mbedtls\library\ssl_msg.c:1886: => fetch input
packages\third-party\mbedtls\mbedtls\library\ssl_msg.c:2041: in_left: 0, nb_want: 5
packages\third-party\mbedtls\mbedtls\library\ssl_msg.c:2066: in_left: 0, nb_want: 5
packages\third-party\mbedtls\mbedtls\library\ssl_msg.c:2069: ssl->f_recv(_timeout)() returned 5 (-0xfffffffb)
packages\third-party\mbedtls\mbedtls\library\ssl_msg.c:2089: <= fetch input
packages\third-party\mbedtls\mbedtls\library\ssl_msg.c:2041: in_left: 5, nb_want: 7
packages\third-party\mbedtls\mbedtls\library\ssl_msg.c:2066: in_left: 5, nb_want: 7
packages\third-party\mbedtls\mbedtls\library\ssl_msg.c:2069: ssl->f_recv(_timeout)() returned 2 (-0xfffffffe)
packages\third-party\mbedtls\mbedtls\library\ssl_msg.c:4897: got an alert message, type: [2:40]
packages\third-party\mbedtls\mbedtls\library\ssl_msg.c:4905: is a fatal alert message (msg 40)
packages\third-party\mbedtls\mbedtls\library\ssl_msg.c:3999: mbedtls_ssl_handle_message_type() returned -30592 (-0x7780)
packages\third-party\mbedtls\mbedtls\library\ssl_cli.c:2087: mbedtls_ssl_read_record() returned -30592 (-0x7780)
packages\third-party\mbedtls\mbedtls\library\ssl_tls.c:5915: <= handshake
[116920] E/mbedtls.clnt: mbedtls_ssl_handshake error, return -0x7780
[116927] E/web: connect failed, https client connect return: -0x7780
[116934] E/wifi_test: HTTPS request failed, HTTP status: -6
packages\third-party\mbedtls\mbedtls\library\ssl_msg.c:5863: => write close notify
packages\third-party\mbedtls\mbedtls\library\ssl_msg.c:5876: <= write close notify
[116958] I/wifi_test: HTTPS test completed
[116963] I/wifi_test: HTTP test start, connecting to http://www.baidu.com
header: GET / HTTP/1.1
Host: www.baidu.com
User-Agent: RT-Thread HTTP Agent
[117427] I/wifi_test: Receiving response...
[117443] I/wifi_test: Received 1023 bytes:
<!DOCTYPE html>
<html>
<head>
    <meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
    <meta http-equiv="X-UA-Compatible" content="IE=edge,chrome=1" />
    <meta content="always" name="referrer" />
    <meta
        name="description"
