楼主 # 2025-11-10 20:23:55
billymc
已发帖子: 39
求助T113-S3主线LVDS显示
之前用的主线6.6.8,但是用的RGB接口,现在想改成LVDS,DTS配置如下:
panel {
        /*compatible = "shelly,sca07010-bfn-lnn", "simple-panel";*/
        /*compatible = "cdtech,s070pws19hp-fc21", "simple-panel";*/
        compatible = "boe,ev121wxm-n10-1850", "simple-panel";
        /*compatible = "tbs,a711-panel", "panel-lvds";*/
        backlight = <&backlight>;
        panel-timing {
                clock-frequency = <71000000>;   // 71 MHz pixel clock
                hactive = <1280>;
               vactive = <800>;
                hfront-porch = <48>;
                hback-porch = <80>;
                hsync-len = <32>;
               vfront-porch = <3>;
               vback-porch = <10>;
                vsync-len = <4>;
                hsync-active = <0>;   // negative polarity
                vsync-active = <0>;   // negative polarity
                de-active = <1>;
                pixelclk-active = <1>; // rising edge
        port {
            panel_input: endpoint {
                remote-endpoint = <&tcon_lcd0_out_lvds>;
&tcon_lcd0 {
    pinctrl-names = "default";
    pinctrl-0 = <&lcd_lvds0_pins>;
&tcon_lcd0_out {
    tcon_lcd0_out_lvds: endpoint@0 {
        reg = <0>;
系统中有/dev/fb0,但是没有显示,lvds0上面没有信号。求助有没有懂的大佬。多谢!
楼主 #1 2025-11-11 00:11:11
billymc
已发帖子: 39
Re: 求助T113-S3主线LVDS显示
另外,芒果派之前提供的SDK LVDS显示是不是有问题?RGB显示正常,切换到LVDS后,没显示,用示波器看还是RGB信号。用全志提供的新版相同配置就输出LVDS信号。不过所有驱动和文件系统都要重新再做一遍。。。
楼主 #2 昨天 14:00:56
billymc
已发帖子: 39
目前根据邮件列表里面提到的补丁修改,内核启动提示有LVDS初始化成功和/dev/fb0。但管脚输出没有波形。用TINA正常,确认硬件没问题。
https://lore.kernel.org/linux-riscv/20251116134609.447043-1-kuba@szczodrzynski.pl/T/#t
DT如下:
panel {
        /*compatible = "boe,ev121wxm-n10-1850", "panel-lvds";*/
        compatible = "panel-lvds";
        power-supply = <&reg_3v3>;
        enable-gpios = <&pio 4 1 GPIO_ACTIVE_HIGH>;
        width-mm = <153>;
        height-mm = <90>;
        data-mapping = "vesa-24";
        panel-timing {
                hactive = <1280>;
                vactive = <800>;
                hback-porch = <80>;
                hsync-len = <32>;
                vfront-porch = <3>;
                vback-porch = <10>;
                vsync-len = <4>;
        port {
                remote-endpoint = <&tcon_lcd0_out_panel>;
&dphy {
    allwinner,lvds-mode;
&de {
&tcon_lcd0 {
    pinctrl-0 = <&lcd_rgb666_pins>;
&tcon_lcd0 {
&tcon_lcd0_out {
    tcon_lcd0_out_panel: endpoint@0 {
        reg = <0>;
