楼主 # 昨天 02:00:36
Quotation
已发帖子: 301
T113-S3怎么改CPU频率?
用的xboot,xboot里设置CPU频率的代码和awboot是基本一致的。
奇怪的是,改代码里这一行的数字没有作用。不管改成多少,执行同一段计算代码的时间是一样的。
val |= (41 << 8)
完整代码from xboot
static void set_pll_cpux_axi(void)
	uint32_t val;
	/* AXI: Select cpu clock src to PLL_PERI(1x) */
	write32(T113_CCU_BASE + CCU_CPU_AXI_CFG_REG, (4 << 24) | (1 << 0));
	sdelay(10);
	/* Disable pll gating */
	val = read32(T113_CCU_BASE + CCU_PLL_CPU_CTRL_REG);
	val &= ~(1 << 27);
	write32(T113_CCU_BASE + CCU_PLL_CPU_CTRL_REG, val);
	/* Enable pll ldo */
	val |= (1 << 30);
	sdelay(5);
	/* Set default clk to 1008mhz */
	val &= ~((0x3 << 16) | (0xff << 8) | (0x3 << 0));
	val |= (41 << 8);
	/* Lock enable */
	val |= (1 << 29);
	/* Enable pll */
	val |= (1 << 31);
	/* Wait pll stable */
	while(!(read32(T113_CCU_BASE + CCU_PLL_CPU_CTRL_REG) & (0x1 << 28)));
	sdelay(20);
	/* Enable pll gating */
	val |= (1 << 27);
	/* Lock disable */
	val &= ~(1 << 29);
	sdelay(1);
	/* AXI: set and change cpu clk src to PLL_CPUX, PLL_CPUX:AXI0 = 1200MHz:600MHz */
	val = read32(T113_CCU_BASE + CCU_CPU_AXI_CFG_REG);
	val &= ~(0x07 << 24 | 0x3 << 16 | 0x3 << 8 | 0xf << 0);
	val |= (0x03 << 24 | 0x0 << 16 | 0x1 << 8 | 0x1 << 0);
	write32(T113_CCU_BASE + CCU_CPU_AXI_CFG_REG, val);
	sdelay(1);
