楼主 # 2026-01-05 17:59:20
xuuu
全志a133的mipi屏幕点不亮
static void LCD_bl_open(u32 sel)
    pr_info("[LCD] %s: screen %u\n", __func__, sel);
    sunxi_lcd_pwm_enable(sel);
    sunxi_lcd_delay_ms(50);
    sunxi_lcd_backlight_enable(sel);//config lcd_bl_en pin to open lcd backlight
static void LCD_bl_close(u32 sel)
    sunxi_lcd_backlight_disable(sel);//config lcd_bl_en pin to close lcd backlight
    sunxi_lcd_delay_ms(20);
    sunxi_lcd_pwm_disable(sel);
#define REGFLAG_DELAY                                     0XFE
#define REGFLAG_END_OF_TABLE                              0xFD   // END OF REGISTERS MARKER
struct LCM_setting_table {
    u8 cmd;
    u32 count;
    u8 para_list[64];
/*add panel initialization below*/
static struct LCM_setting_table lcm_initialization_setting[] = {
    {REGFLAG_DELAY, REGFLAG_DELAY, {120}},            /* 120 ms after reset  */
    /* Page-1  (0x3001) */
    {0xFF, 1, {0x30}},
    {0xFF, 1, {0x52}},
    {0xFF, 1, {0x01}},
    {0xE3, 1, {0x04}},
    {0x08, 1, {0x0E}},
    {0x25, 1, {0x10}},
    {0x28, 1, {0x5F}},
    {0x2C, 1, {0x22}},
    {0x30, 1, {0x58}},
    {0x45, 1, {0x91}},
    {0x37, 1, {0x9C}},
    {0x38, 1, {0xA7}},
    {0x39, 1, {0x27}},
    {0x44, 1, {0x00}},
    {0x49, 1, {0x1C}},
    {0x59, 1, {0xFE}},
    {0x5C, 1, {0x00}},
    {0x91, 1, {0x77}},
    {0x92, 1, {0x77}},
    {0xA0, 1, {0x55}},
    {0xA1, 1, {0x50}},
    {0xA3, 1, {0x58}},
    {0xA4, 1, {0x9C}},
    {0xA7, 1, {0x02}},
    {0xA8, 1, {0x01}},
    {0xA9, 1, {0x01}},
    {0xAA, 1, {0xFC}},
    {0xAB, 1, {0x28}},
    {0xAC, 1, {0x06}},
    {0xAD, 1, {0x06}},
    {0xAE, 1, {0x06}},
    {0xAF, 1, {0x03}},
    {0xB0, 1, {0x08}},
    {0xB1, 1, {0x26}},
    {0xB2, 1, {0x28}},
    {0xB3, 1, {0x28}},
    {0xB4, 1, {0x03}},
    {0xB5, 1, {0x08}},
    {0xB6, 1, {0x26}},
    {0xB7, 1, {0x08}},
    {0xB8, 1, {0x26}},
    {0xC0, 1, {0x00}},
    {0xC1, 1, {0x00}},
    {0xC3, 1, {0x0F}},
    /* Page-2  (0x3002) */
    {0xFF, 1, {0x30}},
    {0xFF, 1, {0x52}},
    {0xFF, 1, {0x02}},
    {0xB0, 1, {0x00}},
    {0xB1, 1, {0x05}},
    {0xB2, 1, {0x02}},
    {0xB3, 1, {0x24}},
    {0xB4, 1, {0x25}},
    {0xB5, 1, {0x30}},
    {0xB6, 1, {0x0C}},
    {0xB7, 1, {0x27}},
    {0xB8, 1, {0x0F}},
    {0xB9, 1, {0x05}},
    {0xBA, 1, {0x11}},
    {0xBB, 1, {0x10}},
    {0xBC, 1, {0x11}},
    {0xBD, 1, {0x12}},
    {0xBE, 1, {0x17}},
    {0xBF, 1, {0x0C}},
    {0xC0, 1, {0x14}},
    {0xC1, 1, {0x0A}},
    {0xD0, 1, {0x08}},
    {0xD1, 1, {0x0F}},
    {0xD2, 1, {0x09}},
    {0xD3, 1, {0x35}},
    {0xD4, 1, {0x38}},
    {0xD5, 1, {0x3D}},
    {0xD6, 1, {0x1B}},
    {0xD7, 1, {0x3B}},
    {0xD8, 1, {0x0F}},
    {0xD9, 1, {0x05}},
    {0xDA, 1, {0x11}},
    {0xDB, 1, {0x10}},
    {0xDC, 1, {0x11}},
    {0xDD, 1, {0x14}},
    {0xDE, 1, {0x19}},
    {0xDF, 1, {0x11}},
    {0xE0, 1, {0x19}},
    {0xE1, 1, {0x09}},
    /* Page-3  (0x3003) */
    {0xFF, 1, {0x30}},
    {0xFF, 1, {0x52}},
    {0xFF, 1, {0x03}},
    {0x08, 1, {0x8B}},
    {0x09, 1, {0x8A}},
    {0x0A, 1, {0x89}},
    {0x0B, 1, {0x88}},
    {0x34, 1, {0x61}},
    {0x35, 1, {0xD4}},
    {0x36, 1, {0x24}},
    {0x37, 1, {0x03}},
    {0x40, 1, {0x8B}},
    {0x41, 1, {0x8A}},
    {0x42, 1, {0x89}},
    {0x43, 1, {0x88}},
    {0x45, 1, {0x01}},
    {0x46, 1, {0x02}},
    {0x48, 1, {0x03}},
    {0x49, 1, {0x04}},
    {0x50, 1, {0x87}},
    {0x51, 1, {0x86}},
    {0x52, 1, {0x85}},
    {0x53, 1, {0x84}},
    {0x55, 1, {0x05}},
    {0x56, 1, {0x06}},
    {0x58, 1, {0x07}},
    {0x59, 1, {0x08}},
    {0x80, 1, {0x0F}},
    {0x81, 1, {0x0E}},
    {0x82, 1, {0x07}},
    {0x83, 1, {0x06}},
    {0x84, 1, {0x05}},
    {0x85, 1, {0x04}},
    {0x92, 1, {0x0E}},
    {0x93, 1, {0x0F}},
    {0x94, 1, {0x01}},
    {0x95, 1, {0x00}},
    {0x96, 1, {0x0F}},
    {0x97, 1, {0x0E}},
    {0x98, 1, {0x07}},
    {0x99, 1, {0x06}},
    {0x9A, 1, {0x05}},
    {0x9B, 1, {0x04}},
    {0xA8, 1, {0x0E}},
    {0xA9, 1, {0x0F}},
    {0xAA, 1, {0x01}},
    {0xAB, 1, {0x00}},
    {0xE0, 1, {0x02}},
    {0xE1, 1, {0x52}},
    /* Page-0  (0x3000) */
    {0xFF, 1, {0x30}},
    {0xFF, 1, {0x52}},
    {0xFF, 1, {0x00}},
    {0x35, 1, {0x00}},
    {0x36, 1, {0x02}},
    {0x53, 1, {0x2C}},
    /* Display ON sequence */
    //SLP OUT
    {0x11,     0,     {0x00} },      // SLPOUT
    {REGFLAG_DELAY, REGFLAG_DELAY, {120} },
    //DISP ON
    {0x29,     0,     {0x00} },      // DSPON
    {REGFLAG_DELAY, REGFLAG_DELAY, {100} },
    {REGFLAG_END_OF_TABLE, REGFLAG_END_OF_TABLE, {} }
/*static void LCD_panel_try_switch(u32 sel)
    u8 result[16] = {0};
    u32 num = 0;
    sunxi_lcd_delay_ms(100);
    sunxi_lcd_dsi_dcs_read(sel, 0x04, result, &num);
    printf("get lcd id 0x%x\n", result[0]);
    if (result[0] == 0x93) {
        LCD_power_off(sel);
        sunxi_lcd_switch_compat_panel(sel, 1);
        return;
static void LCD_panel_init(u32 sel)
    __u32 i;
    pr_info("[LCD] %s: screen %u - start init table\n", __func__, sel);
    sunxi_lcd_dsi_clk_enable(sel);
    pr_info("[LCD] %s: sending SW reset\n", __func__);
    sunxi_lcd_dsi_dcs_write_0para(sel, DSI_DCS_SOFT_RESET);
    //sunxi_lcd_delay_ms(10);
    sunxi_lcd_delay_ms(120);
    pr_info("[LCD] %s: entering init table loop\n", __func__);
    for (i = 0; ; i++) {
            if (lcm_initialization_setting[i ].count == REGFLAG_END_OF_TABLE)
                break;
            else if (lcm_initialization_setting[i ].count == REGFLAG_DELAY)
                sunxi_lcd_delay_ms(lcm_initialization_setting[i ].para_list[0]);
#ifdef SUPPORT_DSI
                dsi_dcs_wr(sel, lcm_initialization_setting[i ].cmd, lcm_initialization_setting[i ].para_list, lcm_initialization_setting[i ].count);
        //break;
    pr_info("[LCD] %s: screen %u - init table done\n", __func__, sel);
    return;
static void LCD_panel_exit(u32 sel)
    sunxi_lcd_dsi_dcs_write_0para(sel, DSI_DCS_SET_DISPLAY_OFF);
    sunxi_lcd_dsi_dcs_write_0para(sel, DSI_DCS_ENTER_SLEEP_MODE);
    sunxi_lcd_delay_ms(80);
    return ;
disp: disp@06000000 {
            disp_init_enable         = <1>;
            disp_mode                = <0>;
            screen0_output_type      = <1>;
            screen0_output_mode      = <4>;
            screen1_output_type      = <1>;
            screen1_output_mode      = <4>;
            screen1_output_format    = <0>;
            screen1_output_bits      = <0>;
            screen1_output_eotf      = <4>;
            screen1_output_cs        = <257>;
            screen1_output_dvi_hdmi  = <2>;
            screen1_output_range     = <2>;
            screen1_output_scan      = <0>;
            screen1_output_aspect_ratio = <8>;
            dev0_output_type         = <1>;
            dev0_output_mode         = <4>;
            dev0_screen_id           = <0>;
            dev0_do_hpd              = <0>;
            dev1_output_type         = <4>;
            dev1_output_mode         = <10>;
            dev1_screen_id           = <1>;
            dev1_do_hpd              = <1>;
            def_output_dev           = <0>;
            hdmi_mode_check          = <1>;
            fb0_format               = <0>;
            fb0_width                = <720>;
            fb0_height               = <1280>;
            fb1_format               = <0>;
            fb1_width                = <0>;
            fb1_height               = <0>;
            chn_cfg_mode             = <1>;
            disp_para_zone           = <1>;
            /*VCC-LCD*/
            cldo4-supply = <&reg_cldo4>;
            /*VCC-LVDS-1.8V*/
            cldo1-supply = <&reg_cldo1>;
            /*VCC-DSI*/
            /*VCC-PD-3.3V*/
            cldo3-supply = <&reg_cldo3>;
        lcd0: lcd0@01c0c000 {
            lcd_used            = <1>;
            lcd_driver_name     = "K080_IM2HYL802R_800X1280";
            lcd_backlight       = <50>;
            lcd_if              = <4>;
            lcd_x               = <720>;
            lcd_y               = <1280>;
            lcd_width           = <150>;
            lcd_height          = <36>;
            lcd_dclk_freq       = <58>;
            /* PWM for backlight */
            lcd_pwm_used        = <1>;
            lcd_pwm_ch          = <0>;
            lcd_pwm_freq        = <50000>;
            lcd_pwm_pol         = <1>;
            lcd_pwm_max_limit   = <255>;
            lcd_hbp             = <30>;
            lcd_ht              = <770>;
            lcd_hspw            = <6>;
            lcd_vbp             = <16>;
            lcd_vt              = <1311>;
            lcd_vspw            = <4>;
            lcd_frm             = <0>;
            lcd_gamma_en        = <0>;
            lcd_bright_curve_en = <0>;
            lcd_cmap_en         = <0>;
            deu_mode            = <0>;
            lcdgamma4iep        = <22>;
            smart_color         = <90>;
            lcd_dsi_if          = <0>;
            lcd_dsi_lane        = <4>;
            lcd_dsi_format      = <0>;
            lcd_dsi_te          = <0>;
            lcd_dsi_eotp        = <0>;
            lcd_pin_power       = "cldo3";      // VCC-PD  (3.3 V)
            lcd_power1          = "cldo1";      // VCC-LVDS (1.8 V)
            lcd_power2          = "cldo4";      // VCC-LCD (3.3 V)
            lcd_gpio_1          = <&pio PD 22 1 0 3 1>; /* RESET */
            pinctrl-0           = <&dsi4lane_pins_a>;
            pinctrl-1           = <&dsi4lane_pins_b>;
            lcd_bl_en           = <&pio PD 23 1 1 0 3 1>;
            lcd_bl_0_percent    = <15>;
            lcd_bl_100_percent  = <100>;
