[138214]fes begin commit:
[138216]set pll start
[138219]periph0 has been enabled
[138222]set pll end
[138223]board init ok
[138225]beign to init dram
[138228] _____ ___ ___ ___ ____ _____ _____ _____
[138233]|_ _|_ | |_ | |_ | | \| __ | _ | |
[138238] | | _| |_ _| |_|_ | | | | -| | | | |
[138243] |_| |_____|_____|___| |____/|__|__|__|__|_|_|_|
[138249]=============================================================
[138255]DRAM DRIVER FOR T113-S4 256M SiP DDR3 DRAM
[138259]YuzukiTsuru <gloomyghost@gloomyghost.com>
[138264]=============================================================
[138270]DRAM BOOT DRIVE INFO: V0.24-t113-s4
[138274]DRAM CLK = 936 MHz
[138276]DRAM Type = 3 (2:DDR2,3:DDR3)
[138280]DRAMC read ODT off
[138282]ZQ value = 0x2c
[138284]DDR CLK = 1872 MHz
[138287]DDR efuse: 0xa
[138289]chip id efuse: 0x7200
[138293]single rank and full DQ!
[138296]DDR CLK = 1872 MHz
[138298]DDR efuse: 0xa
[138300]chip id efuse: 0x7200
[138304]rank 0 row = 14
[138306]para->dram_para1 = 0x10e2
[138309]rank 0 bank = 8
[138312]para->dram_para1 = 0x10e2
[138315]rank 0 page size = 2 KB
[138318]para->dram_para1 = 0x10e2
[138321]DRAM ODT value: 0x42
[138323]DDR CLK = 1872 MHz
[138326]DDR efuse: 0xa
[138328]chip id efuse: 0x7200
[138332]DRAM: size = 256MB
[138335]DRAM: simple test OK
[138338]init dram ok
记着,显示信息是串口3
测试对t113m4020dc0这个无效
t113m4020dc0 id 是7200 如果你的不是,请检查 这个 无论 xfel ddr t113-s3 t113-s4都可以检测到。检测不到的话,一定是焊接ddr部分供电 芯片问题或者衬底虚焊(没接地)
最近编辑记录 jflbr (2026-02-04 01:00:03)
