楼主 # 2026-01-15 13:58:00
dsf
D133CBS烧录失败问题
烧录日志
[debug] Start burn online ...
[debug] Progress range: 0 ~  11425792
[debug] Burn Image file "D:/Project/MasterV4/luban-lite/output/d13x_JLC_rt-thread_helloworld/images/d13x_JLC_v1.0.0.img" ...
[debug] Meta 0 image.updater.psram , size 28688 ...
[debug] Blocksize 4 , chunk 1048576 * 0 , rest 28688
[debug] Offset: 6144 Size: 28688
[debug]  Dev "4:2-3" Send the rest data 28688
[debug] Don't check the result of image.updater.psram
[debug] Meta 1 image.updater.spl , size 218384 ...
[debug] Blocksize 4 , chunk 1048576 * 0 , rest 218384
[debug] Offset: 36864 Size: 218384
[debug]  Dev "4:2-3" Send the rest data 218384
[info ] aicupg_trans_recv_pkt()322:             no CSW. (rc = 0)
[info ] aicupg_cmd_send_fwc_data_final()726:    no resp
[debug] Don't check the result of image.updater.spl
[debug] Meta 2 image.info , size 2048 ...
[debug] Wait to reconnect dev "4:2-3"
[debug] QTime("13:53:05.933") Wait for Dev "4:2-3" ready
[debug] WinEvent: Some devnode changed
[info ] QTime("13:53:06.331") Dev "4:2-3" reconnected
[debug] Blocksize 4 , chunk 1048576 * 0 , rest 2048
[debug] Offset: 0 Size: 2048
[debug]  Dev "4:2-3" Send the rest data 2048
[debug] Meta 3 image.target.spl , size 218384 ...
[debug] Offset: 256000 Size: 218384
[debug] Meta 4 image.target.env , size 4096 ...
[debug] Blocksize 4 , chunk 1048576 * 0 , rest 4096
[debug] Offset: 475136 Size: 4096
[debug]  Dev "4:2-3" Send the rest data 4096
[debug] Meta 5 image.target.os , size 2191360 ...
[debug] Blocksize 4 , chunk 1048576 * 2 , rest 94208
[debug] Offset: 479232 Size: 2191360
[debug]  Dev "4:2-3" Send chunk 0 ...
[debug]  Dev "4:2-3" Send chunk 1 ...
[debug]  Dev "4:2-3" Send the rest data 94208
[debug] Meta 6 image.target.rodata , size 7712768 ...
[debug] Blocksize 4 , chunk 1048576 * 7 , rest 372736
[debug] Offset: 2670592 Size: 7712768
[debug]  Dev "4:2-3" Send chunk 2 ...
[debug]  Dev "4:2-3" Send chunk 3 ...
[debug]  Dev "4:2-3" Send chunk 4 ...
[debug]  Dev "4:2-3" Send chunk 5 ...
[debug]  Dev "4:2-3" Send chunk 6 ...
[debug]  Dev "4:2-3" Send the rest data 372736
[debug] Meta 7 image.target.data , size 1048576 ...
[debug] Blocksize 4 , chunk 1048576 * 1 , rest 0
[debug] Offset: 10383360 Size: 1048576
[error] Datas sent finished, but burn failed!
描述:同一个镜像,开发板芯片D133EBS可以烧录成功
#1 昨天 14:09:30
gemrisk
Re: D133CBS烧录失败问题
看你提供的log已经去烧录data分区才失败的,要看串口打印,会不会是flash不够了
