烧录日志
[debug] Start burn online ...
[debug] Progress range: 0 ~ 11425792
[debug] Burn Image file "D:/Project/MasterV4/luban-lite/output/d13x_JLC_rt-thread_helloworld/images/d13x_JLC_v1.0.0.img" ...
[debug] Meta 0 image.updater.psram , size 28688 ...
[debug] Blocksize 4 , chunk 1048576 * 0 , rest 28688
[debug] Offset: 6144 Size: 28688
[debug] Dev "4:2-3" Send the rest data 28688
[debug] Don't check the result of image.updater.psram
[debug] Meta 1 image.updater.spl , size 218384 ...
[debug] Blocksize 4 , chunk 1048576 * 0 , rest 218384
[debug] Offset: 36864 Size: 218384
[debug] Dev "4:2-3" Send the rest data 218384
[info ] aicupg_trans_recv_pkt()322: no CSW. (rc = 0)
[info ] aicupg_cmd_send_fwc_data_final()726: no resp
[debug] Don't check the result of image.updater.spl
[debug] Meta 2 image.info , size 2048 ...
[debug] Wait to reconnect dev "4:2-3"
[debug] QTime("13:53:05.933") Wait for Dev "4:2-3" ready
[debug] WinEvent: Some devnode changed
[info ] QTime("13:53:06.331") Dev "4:2-3" reconnected
[debug] Blocksize 4 , chunk 1048576 * 0 , rest 2048
[debug] Offset: 0 Size: 2048
[debug] Dev "4:2-3" Send the rest data 2048
[debug] Meta 3 image.target.spl , size 218384 ...
[debug] Offset: 256000 Size: 218384
[debug] Meta 4 image.target.env , size 4096 ...
[debug] Blocksize 4 , chunk 1048576 * 0 , rest 4096
[debug] Offset: 475136 Size: 4096
[debug] Dev "4:2-3" Send the rest data 4096
[debug] Meta 5 image.target.os , size 2191360 ...
[debug] Blocksize 4 , chunk 1048576 * 2 , rest 94208
[debug] Offset: 479232 Size: 2191360
[debug] Dev "4:2-3" Send chunk 0 ...
[debug] Dev "4:2-3" Send chunk 1 ...
[debug] Dev "4:2-3" Send the rest data 94208
[debug] Meta 6 image.target.rodata , size 7712768 ...
[debug] Blocksize 4 , chunk 1048576 * 7 , rest 372736
[debug] Offset: 2670592 Size: 7712768
[debug] Dev "4:2-3" Send chunk 2 ...
[debug] Dev "4:2-3" Send chunk 3 ...
[debug] Dev "4:2-3" Send chunk 4 ...
[debug] Dev "4:2-3" Send chunk 5 ...
[debug] Dev "4:2-3" Send chunk 6 ...
[debug] Dev "4:2-3" Send the rest data 372736
[debug] Meta 7 image.target.data , size 1048576 ...
[debug] Blocksize 4 , chunk 1048576 * 1 , rest 0
[debug] Offset: 10383360 Size: 1048576
[error] Datas sent finished, but burn failed!
描述:同一个镜像,开发板芯片D133EBS可以烧录成功
看你提供的log已经去烧录data分区才失败的,要看串口打印,会不会是flash不够了
下载成功日志
Pre-Boot Program ... (24-08-30 16:16 9ac5e6f)
USB/UART
cs=0, phase=4
cs=1, phase=3
Psram_init done.
PBP return
[2026-01-19 16:08:52.401]# RECV ASCII>
USB/UART
PSRAM already initialized
goto run SPL
tinySPL [Built on Jan 19 2026 15:54:15]
Reboot action: Watchdog-Reset, reason: Command-Reboot
[2026-01-19 16:08:52.819]# RECV ASCII>
Init UPGMODE:
Full disk upgrade
[2026-01-19 16:08:53.339]# RECV ASCII>
UPGMODE: Partition upgrade
Firmware Component:
partition:
attr: required
Media: RAM(0)
qspi0 freq (input): 99000000Hz
qspi0 freq ( bus ): 49500000Hz
qspi0 freq ( bus ): 99000000Hz
Firmware Component:
partition: spl
attr: mtd;required
Media: SPI_NOR(3)
下载失败日志
USB/UART
Trainning failed...
xspi cs0 trainning failed.
Trainning failed...
xspi cs1 trainning failed.
Psram_init done.
PBP return
两个板子的烧录串口输出信息
看打印psram初始化失败了,试试用比较新的SDK吧,有的芯片型号后面才出来,旧的SDK不一定支持
已经是最新的SDK,烧录的是SDK的Demo
看时间戳这个还是24年8月的,最新的SDK这个时间戳是25年8月20号的,看看bootloader有没有重新编译
我今天烧录D21x也有这个问题了,楼主大神,您找到原因了吗?如何解决的?
