设备树:
lcd0_1: lcd0_1@01c0c00f {
lcd_used = <1>;
lcd_driver_name = "NV3052_BV055HDL_NB6_720X1280";
lcd_backlight = <50>;
lcd_if = <4>;
lcd_x = <720>;
lcd_y = <1280>;
lcd_width = <108>;
lcd_height = <172>;
lcd_dclk_freq = <64>;
lcd_pwm_used = <0>;
lcd_pwm_ch = <0>;
lcd_pwm_freq = <50000>;
lcd_pwm_pol = <1>;
lcd_pwm_max_limit = <255>;
lcd_hbp = <44>;
lcd_ht = <814>;
lcd_hspw = <4>;
lcd_vbp = <14>;
lcd_vt = <1314>;
lcd_vspw = <4>;
lcd_frm = <0>;
lcd_gamma_en = <0>;
lcd_bright_curve_en = <0>;
lcd_cmap_en = <0>;
deu_mode = <0>;
lcdgamma4iep = <22>;
smart_color = <90>;
lcd_dsi_if = <0>;
lcd_dsi_lane = <4>;
lcd_dsi_format = <0>;
lcd_dsi_te = <0>;
lcd_dsi_eotp = <0>;
//lcd_pin_power = "dcdc1";
lcd_power = "cldo4";
lcd_power1 = "cldo3";
lcd_power2 = "cldo1";
lcd_gpio_0 = <&pio PD 22 1 0 3 1>; /* RESET - gpio_index=0 */
lcd_gpio_1 = <&pio PB 7 1 0 3 1>; /* 1.8V - gpio_index=1 */
lcd_gpio_2 = <&pio PB 5 1 0 3 1>; /* 3.3V - gpio_index=2 */
lcd_gpio_3 = <&pio PB 6 1 0 3 1>; /* VSP/VSN - gpio_index=3 */
pinctrl-0 = <&dsi4lane_pins_a>;
pinctrl-1 = <&dsi4lane_pins_b>;
//lcd_bl_en = <&pio PD 23 1 0 3 1>;
lcd_bl_0_percent = <15>;
lcd_bl_100_percent = <100>;
kerne的驱动:
* Allwinner SoCs display driver.
* Copyright (c) 2020 Allwinnertech Co., Ltd.
* Author: libairong <libairong@allwinnertech.com>
* NV3052_BV055HDL_NB6_720X1280 panel driver
* This file is licensed under the terms of the GNU General Public
* License version 2. This program is licensed "as is" without any
* warranty of any kind, whether express or implied.
#include "NV3052_BV055HDL_NB6_720X1280.h"
#include "panels.h"
static void LCD_power_on(u32 sel);
static void LCD_power_off(u32 sel);
static void LCD_bl_open(u32 sel);
static void LCD_bl_close(u32 sel);
static void LCD_panel_init(u32 sel);
static void LCD_panel_exit(u32 sel);
#define panel_reset(val) sunxi_lcd_gpio_set_value(sel, 0, val) /* PD22 - RESET */
#define power_1v8(val) sunxi_lcd_gpio_set_value(sel, 1, val) /* PB7 - 1.8V */
#define power_3v3(val) sunxi_lcd_gpio_set_value(sel, 2, val) /* PB5 - 3.3V */
#define power_vspvsn(val) sunxi_lcd_gpio_set_value(sel, 3, val) /* PB6 - VSP/VSN */
static void
LCD_cfg_panel_info(struct panel_extend_para *info)
printk("[LCD] %s: enter\n", __func__);
u32 i = 0, j = 0;
u32 items;
u8 lcd_gamma_tbl[][2] = {
{0, 0},
{15, 15},
{30, 30},
{45, 45},
{60, 60},
{75, 75},
{90, 90},
{105, 105},
{120, 120},
{135, 135},
{150, 150},
{165, 165},
{180, 180},
{195, 195},
{210, 210},
{225, 225},
{240, 240},
{255, 255},
u32 lcd_cmap_tbl[2][3][4] = {
{LCD_CMAP_G0, LCD_CMAP_B1, LCD_CMAP_G2, LCD_CMAP_B3},
{LCD_CMAP_B0, LCD_CMAP_R1, LCD_CMAP_B2, LCD_CMAP_R3},
{LCD_CMAP_R0, LCD_CMAP_G1, LCD_CMAP_R2, LCD_CMAP_G3},
{LCD_CMAP_B3, LCD_CMAP_G2, LCD_CMAP_B1, LCD_CMAP_G0},
{LCD_CMAP_R3, LCD_CMAP_B2, LCD_CMAP_R1, LCD_CMAP_B0},
{LCD_CMAP_G3, LCD_CMAP_R2, LCD_CMAP_G1, LCD_CMAP_R0},
items = sizeof(lcd_gamma_tbl) / 2;
for (i = 0; i < items - 1; i++) {
u32 num = lcd_gamma_tbl[i + 1][0] - lcd_gamma_tbl[0];
for (j = 0; j < num; j++) {
u32 value = 0;
value = lcd_gamma_tbl[1] + ((lcd_gamma_tbl[i + 1][1]
- lcd_gamma_tbl[1]) * j) / num;
info->lcd_gamma_tbl[lcd_gamma_tbl[0] + j] =
(value << 16) + (value << 8) + value;
info->lcd_gamma_tbl[255] = (lcd_gamma_tbl[items - 1][1] << 16)
+ (lcd_gamma_tbl[items - 1][1] << 8)
+ lcd_gamma_tbl[items - 1][1];
memcpy(info->lcd_cmap_tbl, lcd_cmap_tbl, sizeof(lcd_cmap_tbl));
printk("[LCD] %s: exit\n", __func__);
static s32 LCD_open_flow(u32 sel)
printk("[LCD] %s: sel=%d\n", __func__, sel);
LCD_OPEN_FUNC(sel, LCD_power_on, 100); // open lcd power, and delay 50ms
LCD_OPEN_FUNC(sel, LCD_panel_init, 200); // open lcd power, than delay 200ms
LCD_OPEN_FUNC(sel, sunxi_lcd_tcon_enable, 50); // open lcd controller, and delay 100ms
LCD_OPEN_FUNC(sel, LCD_bl_open, 0); // open lcd backlight, and delay 0ms
static s32 LCD_close_flow(u32 sel)
printk("LCD_close_flow\n");
LCD_CLOSE_FUNC(sel, LCD_bl_close, 200); // close lcd backlight, and delay 0ms
LCD_CLOSE_FUNC(sel, sunxi_lcd_tcon_disable, 20); // close lcd controller, and delay 0ms
LCD_CLOSE_FUNC(sel, LCD_panel_exit, 10); // open lcd power, than delay 200ms
LCD_CLOSE_FUNC(sel, LCD_power_off, 500); // close lcd power, and delay 500ms
printk("LCD_power_on\n");
panel_reset(0);
sunxi_lcd_delay_ms(5);
sunxi_lcd_power_enable(sel, 0); // config lcd_power pin to open lcd power
sunxi_lcd_power_enable(sel, 1); // config lcd_power pin to open lcd power1
sunxi_lcd_power_enable(sel, 2); // config lcd_power pin to open lcd power2
panel_reset(0);
power_vspvsn(0);
power_1v8(0);
sunxi_lcd_delay_ms(50);
power_3v3(1);
power_1v8(1);
sunxi_lcd_delay_ms(10);
power_vspvsn(1);
panel_reset(1);
panel_reset(0);
panel_reset(1);
sunxi_lcd_pin_cfg(sel, 1);
printk("LCD_power_off\n");
sunxi_lcd_pin_cfg(sel, 0);
power_vspvsn(0);
power_1v8(0);
power_3v3(0);
sunxi_lcd_delay_ms(20);
panel_reset(0);
sunxi_lcd_power_disable(sel, 2); // config lcd_power pin to close lcd power2
sunxi_lcd_power_disable(sel, 1); // config lcd_power pin to close lcd power1
sunxi_lcd_power_disable(sel, 0); // config lcd_power pin to close lcd power
printk("[LCD] %s: PWM enable\n", __func__);
sunxi_lcd_pwm_enable(sel);
sunxi_lcd_backlight_enable(sel); // config lcd_bl_en pin to open lcd backlight
printk("LCD_bl_close\n");
sunxi_lcd_backlight_disable(sel); // config lcd_bl_en pin to close lcd backlight
sunxi_lcd_pwm_disable(sel);
#define REGFLAG_DELAY 0XFE
#define REGFLAG_END_OF_TABLE 0xFD // END OF REGISTERS MARKER
struct LCM_setting_table {
u8 cmd;
u32 count;
u8 para_list[64];
/* add panel initialization below */
static struct LCM_setting_table lcm_initialization_setting[] = {
//----------NV305F+BOE5.5(BV055HDL-NB6) Initial------------------
{REGFLAG_DELAY, REGFLAG_DELAY, {120}},
{0xFF,0x01,{0x30}},
{0xFF,0x01,{0x52}},
{0xFF,0x01,{0x01}},
{0xE3,0x01,{0x04}},
{0x08,0x01,{0x0e}},
{0x25,0x01,{0x10}},
{0x28,0x01,{0x5F}},
{0x2C,0x01,{0x22}},
{0x30,0x01,{0x58}},
{0x45,0x01,{0x91}},
{0x37,0x01,{0x9C}},
{0x38,0x01,{0xA7}},
{0x39,0x01,{0x27}},
{0x44,0x01,{0x00}},
{0x49,0x01,{0x1C}},
{0x59,0x01,{0xFE}},
{0x5C,0x01,{0x00}},
{0x91,0x01,{0x77}},
{0x92,0x01,{0x77}},
{0xA0,0x01,{0x55}},
{0xA1,0x01,{0x50}},
{0xA3,0x01,{0x58}},
{0xA4,0x01,{0x9C}},
{0xA7,0x01,{0x02}},
{0xA8,0x01,{0x01}},
{0xA9,0x01,{0x01}},
{0xAA,0x01,{0xFC}},
{0xAB,0x01,{0x28}},
{0xAC,0x01,{0x06}},
{0xAD,0x01,{0x06}},
{0xAE,0x01,{0x06}},
{0xAF,0x01,{0x03}},
{0xB0,0x01,{0x08}},
{0xB1,0x01,{0x26}},
{0xB2,0x01,{0x28}},
{0xB3,0x01,{0x28}},
{0xB4,0x01,{0x03}},
{0xB5,0x01,{0x08}},
{0xB6,0x01,{0x26}},
{0xB7,0x01,{0x08}},
{0xB8,0x01,{0x26}},
{0xc0,0x01,{0x00}},
{0xc1,0x01,{0x00}},
{0xc3,0x01,{0x0F}},
{0xFF,0x01,{0x30}},
{0xFF,0x01,{0x52}},
{0xFF,0x01,{0x02}},
{0xB0,0x01,{0x00}},
{0xB1,0x01,{0x05}},
{0xB2,0x01,{0x02}},
{0xB3,0x01,{0x24}},
{0xB4,0x01,{0x25}},
{0xB5,0x01,{0x30}},
{0xB6,0x01,{0x0C}},
{0xB7,0x01,{0x27}},
{0xB8,0x01,{0x0F}},
{0xB9,0x01,{0x05}},
{0xBA,0x01,{0x11}},
{0xBB,0x01,{0x10}},
{0xBC,0x01,{0x11}},
{0xBD,0x01,{0x12}},
{0xBE,0x01,{0x17}},
{0xBF,0x01,{0x0C}},
{0xC0,0x01,{0x14}},
{0xC1,0x01,{0x0A}},
{0xD0,0x01,{0x08}},
{0xD1,0x01,{0x0F}},
{0xD2,0x01,{0x09}},
{0xD3,0x01,{0x35}},
{0xD4,0x01,{0x38}},
{0xD5,0x01,{0x3D}},
{0xD6,0x01,{0x1B}},
{0xD7,0x01,{0x3B}},
{0xD8,0x01,{0x0F}},
{0xD9,0x01,{0x05}},
{0xDA,0x01,{0x11}},
{0xDB,0x01,{0x10}},
{0xDC,0x01,{0x11}},
{0xDD,0x01,{0x14}},
{0xDE,0x01,{0x19}},
{0xDF,0x01,{0x11}},
{0xE0,0x01,{0x19}},
{0xE1,0x01,{0x09}},
{0xFF,0x01,{0x30}},
{0xFF,0x01,{0x52}},
{0xFF,0x01,{0x03}},
{0x08,0x01,{0x8B}},
{0x09,0x01,{0x8A}},
{0x0A,0x01,{0x89}},
{0x0B,0x01,{0x88}},
{0x34,0x01,{0x61}},
{0x35,0x01,{0xD4}},
{0x36,0x01,{0x24}},
{0x37,0x01,{0x03}},
{0x40,0x01,{0x8B}},
{0x41,0x01,{0x8A}},
{0x42,0x01,{0x89}},
{0x43,0x01,{0x88}},
{0x45,0x01,{0x01}},
{0x46,0x01,{0x02}},
{0x48,0x01,{0x03}},
{0x49,0x01,{0x04}},
{0x50,0x01,{0x87}},
{0x51,0x01,{0x86}},
{0x52,0x01,{0x85}},
{0x53,0x01,{0x84}},
{0x55,0x01,{0x05}},
{0x56,0x01,{0x06}},
{0x58,0x01,{0x07}},
{0x59,0x01,{0x08}},
{0x80,0x01,{0x0F}},
{0x81,0x01,{0x0E}},
{0x82,0x01,{0x07}},
{0x83,0x01,{0x06}},
{0x84,0x01,{0x05}},
{0x85,0x01,{0x04}},
{0x92,0x01,{0x0E}},
{0x93,0x01,{0x0F}},
{0x94,0x01,{0x01}},
{0x95,0x01,{0x00}},
{0x96,0x01,{0x0F}},
{0x97,0x01,{0x0E}},
{0x98,0x01,{0x07}},
{0x99,0x01,{0x06}},
{0x9A,0x01,{0x05}},
{0x9B,0x01,{0x04}},
{0xA8,0x01,{0x0E}},
{0xA9,0x01,{0x0F}},
{0xAA,0x01,{0x01}},
{0xAB,0x01,{0x00}},
{0xE0,0x01,{0x02}},
{0xE1,0x01,{0x52}},
{0xFF,0x01,{0x30}},
{0xFF,0x01,{0x52}},
{0xFF,0x01,{0x00}},
{0x35,0x01,{0x00}},
{0x36,0x01,{0x02}},
{0x53,0x01,{0x2C}},
{0x11, 0, {0x00}},
{REGFLAG_DELAY, REGFLAG_DELAY, {200}},
{0x29, 0, {0x00}},
{REGFLAG_DELAY, REGFLAG_DELAY, {100}},
{REGFLAG_END_OF_TABLE, REGFLAG_END_OF_TABLE, {0x00}}
printk("[LCD] %s: uboot, first cmd=0x%02X\n", __func__,
lcm_initialization_setting[0].cmd);
__u32 i;
char model_name[25];
disp_sys_script_get_item("lcd0", "lcd_model_name", (int *) model_name, 25);
sunxi_lcd_dsi_clk_enable(sel);
sunxi_lcd_dsi_dcs_write_0para(sel, DSI_DCS_SOFT_RESET);
for (i = 0; ; i++) {
if (lcm_initialization_setting.count == REGFLAG_END_OF_TABLE)
break;
else if (lcm_initialization_setting.count == REGFLAG_DELAY)
sunxi_lcd_delay_ms(lcm_initialization_setting.para_list[0]);
#ifdef SUPPORT_DSI
dsi_dcs_wr(sel, lcm_initialization_setting.cmd,
lcm_initialization_setting.para_list,
lcm_initialization_setting.count);
//break;
printk("[LCD] %s: finish\n", __func__);
return;
sunxi_lcd_dsi_dcs_write_0para(sel, DSI_DCS_SET_DISPLAY_OFF);
sunxi_lcd_dsi_dcs_write_0para(sel, DSI_DCS_ENTER_SLEEP_MODE);
sunxi_lcd_delay_ms(80);
return ;
// sel: 0:lcd0; 1:lcd1
static s32 LCD_user_defined_func(u32 sel, u32 para1, u32 para2, u32 para3)
* static s32 LCD_set_bright(u32 sel, u32 bright)
* sunxi_lcd_dsi_dcs_write_1para(sel, 0x51, bright);
* return 0;
struct __lcd_panel NV3052_BV055HDL_NB6_720X1280_mipi_panel = {
/* panel driver name, must mach the name of lcd_drv_name in sys_config.fex */
.name = "NV3052_BV055HDL_NB6_720X1280",
.func = {
.cfg_panel_info = LCD_cfg_panel_info,
.cfg_open_flow = LCD_open_flow,
.cfg_close_flow = LCD_close_flow,
.lcd_user_defined_func = LCD_user_defined_func,
// .set_bright = LCD_set_bright,
uboot的驱动:
#include "panels.h"
static void
LCD_cfg_panel_info(panel_extend_para *info)
printf("[LCD] %s: enter\n", __func__);
u32 i = 0, j = 0;
u32 items;
{0, 0},
{15, 15},
{30, 30},
{45, 45},
{60, 60},
{75, 75},
{90, 90},
{105, 105},
{120, 120},
{135, 135},
{150, 150},
{165, 165},
{180, 180},
{195, 195},
{210, 210},
{225, 225},
{240, 240},
{255, 255},
u32 value = 0;
printf("[LCD] %s: exit\n", __func__);
printf("[LCD] %s: sel=%d\n", __func__, sel);
LCD_OPEN_FUNC(sel, LCD_power_on, 0);
// LCD_OPEN_FUNC(sel, LCD_panel_init1, 20);
printf("LCD_close_flow\n");
printf("LCD_power_on\n");
// panel_reset(0);
// sunxi_lcd_delay_ms(5);
panel_reset(0);
power_vspvsn(0);
power_1v8(0);
power_3v3(1);
power_1v8(1);
power_vspvsn(1);
panel_reset(1);
panel_reset(0);
panel_reset(1);
printf("LCD_power_off\n");
power_vspvsn(0);
power_1v8(0);
power_3v3(0);
panel_reset(0);
printf("[LCD] %s: PWM enable\n", __func__);
printf("LCD_bl_close\n");
u8 cmd;
u32 count;
u8 para_list[64];
{0xFF,0x01,{0x30}},
{0xFF,0x01,{0x52}},
{0xFF,0x01,{0x01}},
{0xE3,0x01,{0x04}},
{0x08,0x01,{0x0e}},
{0x25,0x01,{0x10}},
{0x28,0x01,{0x5F}},
{0x2C,0x01,{0x22}},
{0x30,0x01,{0x58}},
{0x45,0x01,{0x91}},
{0x37,0x01,{0x9C}},
{0x38,0x01,{0xA7}},
{0x39,0x01,{0x27}},
{0x44,0x01,{0x00}},
{0x49,0x01,{0x1C}},
{0x59,0x01,{0xFE}},
{0x5C,0x01,{0x00}},
{0x91,0x01,{0x77}},
{0x92,0x01,{0x77}},
{0xA0,0x01,{0x55}},
{0xA1,0x01,{0x50}},
{0xA3,0x01,{0x58}},
{0xA4,0x01,{0x9C}},
{0xA7,0x01,{0x02}},
{0xA8,0x01,{0x01}},
{0xA9,0x01,{0x01}},
{0xAA,0x01,{0xFC}},
{0xAB,0x01,{0x28}},
{0xAC,0x01,{0x06}},
{0xAD,0x01,{0x06}},
{0xAE,0x01,{0x06}},
{0xAF,0x01,{0x03}},
{0xB0,0x01,{0x08}},
{0xB1,0x01,{0x26}},
{0xB2,0x01,{0x28}},
{0xB3,0x01,{0x28}},
{0xB4,0x01,{0x03}},
{0xB5,0x01,{0x08}},
{0xB6,0x01,{0x26}},
{0xB7,0x01,{0x08}},
{0xB8,0x01,{0x26}},
{0xc0,0x01,{0x00}},
{0xc1,0x01,{0x00}},
{0xc3,0x01,{0x0F}},
{0xFF,0x01,{0x30}},
{0xFF,0x01,{0x52}},
{0xFF,0x01,{0x02}},
{0xB0,0x01,{0x00}},
{0xB1,0x01,{0x05}},
{0xB2,0x01,{0x02}},
{0xB3,0x01,{0x24}},
{0xB4,0x01,{0x25}},
{0xB5,0x01,{0x30}},
{0xB6,0x01,{0x0C}},
{0xB7,0x01,{0x27}},
{0xB8,0x01,{0x0F}},
{0xB9,0x01,{0x05}},
{0xBA,0x01,{0x11}},
{0xBB,0x01,{0x10}},
{0xBC,0x01,{0x11}},
{0xBD,0x01,{0x12}},
{0xBE,0x01,{0x17}},
{0xBF,0x01,{0x0C}},
{0xC0,0x01,{0x14}},
{0xC1,0x01,{0x0A}},
{0xD0,0x01,{0x08}},
{0xD1,0x01,{0x0F}},
{0xD2,0x01,{0x09}},
{0xD3,0x01,{0x35}},
{0xD4,0x01,{0x38}},
{0xD5,0x01,{0x3D}},
{0xD6,0x01,{0x1B}},
{0xD7,0x01,{0x3B}},
{0xD8,0x01,{0x0F}},
{0xD9,0x01,{0x05}},
{0xDA,0x01,{0x11}},
{0xDB,0x01,{0x10}},
{0xDC,0x01,{0x11}},
{0xDD,0x01,{0x14}},
{0xDE,0x01,{0x19}},
{0xDF,0x01,{0x11}},
{0xE0,0x01,{0x19}},
{0xE1,0x01,{0x09}},
{0xFF,0x01,{0x30}},
{0xFF,0x01,{0x52}},
{0xFF,0x01,{0x03}},
{0x08,0x01,{0x8B}},
{0x09,0x01,{0x8A}},
{0x0A,0x01,{0x89}},
{0x0B,0x01,{0x88}},
{0x34,0x01,{0x61}},
{0x35,0x01,{0xD4}},
{0x36,0x01,{0x24}},
{0x37,0x01,{0x03}},
{0x40,0x01,{0x8B}},
{0x41,0x01,{0x8A}},
{0x42,0x01,{0x89}},
{0x43,0x01,{0x88}},
{0x45,0x01,{0x01}},
{0x46,0x01,{0x02}},
{0x48,0x01,{0x03}},
{0x49,0x01,{0x04}},
{0x50,0x01,{0x87}},
{0x51,0x01,{0x86}},
{0x52,0x01,{0x85}},
{0x53,0x01,{0x84}},
{0x55,0x01,{0x05}},
{0x56,0x01,{0x06}},
{0x58,0x01,{0x07}},
{0x59,0x01,{0x08}},
{0x80,0x01,{0x0F}},
{0x81,0x01,{0x0E}},
{0x82,0x01,{0x07}},
{0x83,0x01,{0x06}},
{0x84,0x01,{0x05}},
{0x85,0x01,{0x04}},
{0x92,0x01,{0x0E}},
{0x93,0x01,{0x0F}},
{0x94,0x01,{0x01}},
{0x95,0x01,{0x00}},
{0x96,0x01,{0x0F}},
{0x97,0x01,{0x0E}},
{0x98,0x01,{0x07}},
{0x99,0x01,{0x06}},
{0x9A,0x01,{0x05}},
{0x9B,0x01,{0x04}},
{0xA8,0x01,{0x0E}},
{0xA9,0x01,{0x0F}},
{0xAA,0x01,{0x01}},
{0xAB,0x01,{0x00}},
{0xE0,0x01,{0x02}},
{0xE1,0x01,{0x52}},
{0xFF,0x01,{0x30}},
{0xFF,0x01,{0x52}},
{0xFF,0x01,{0x00}},
{0x35,0x01,{0x00}},
{0x36,0x01,{0x02}},
{0x53,0x01,{0x2C}},
{0x11, 0, {0x00}},
{0x29, 0, {0x00}},
printf("[LCD] %s: uboot, first cmd=0x%02X\n", __func__,
__u32 i;
break;
#ifdef SUPPORT_DSI
//break;
printf("[LCD] %s: finish\n", __func__);
return;
return ;
* return 0;
__lcd_panel_t NV3052_BV055HDL_NB6_720X1280_mipi_panel = {
.func = {
日志打印:
Line 154: [LCD] LCD_open_flow: sel=0
Line 155: [LCD] LCD_cfg_panel_info: enter
Line 156: [LCD] LCD_cfg_panel_info: exit
Line 159: [LCD] LCD_open_flow: sel=0
Line 160: LCD_power_on
Line 164: [LCD] LCD_open_flow: sel=0
Line 165: [LCD] LCD_panel_try_switch: screen 0 - reading panel ID via DCS
Line 166: [LCD] LCD_panel_try_switch: ID bytes = 18 32 41 (0x183241)
Line 167: [LCD] LCD_open_flow: sel=0
Line 168: [LCD] LCD_panel_init: uboot, first cmd=0xBB
Line 169: [LCD] LCD_panel_init: finish
Line 200: [LCD] LCD_open_flow: sel=0
Line 204: [LCD] LCD_open_flow: sel=0
Line 205: [LCD] LCD_bl_open: PWM enable
Line 206: [LCD] LCD_open_flow: sel=0
Line 207: [LCD] LCD_open_flow: sel=0
Line 208: [06.652]LCD open finish
Line 466: [ 1.405376] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.smartbl_low_limit fail
Line 467: [ 1.414568] [DISP] disp_init_lcd,line:3243:disp_init_lcd
Line 468: [ 1.419837] [DISP] disp_init_lcd,line:3317:total number of clk in dsi:1
Line 469: [ 1.426242] [DISP] disp_init_lcd,line:3320:lcd 0, irq_no=362, irq_no_dsi=364
Line 470: [ 1.433263] [DISP] disp_lcd_init,line:2710:lcd 0
Line 471: [ 1.437845] [DISP] lcd_get_sys_config,line:360:lcd0 get sys config begin
Line 472: [ 1.444879] [DISP] disp_sys_script_get_item,line:237:lcd0.lcd_bl_en gpio=119,mul_sel=1,data:1
Line 473: [ 1.453190] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_bl_en_power fail
Line 474: [ 1.462462] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_fix_power fail
Line 475: [ 1.471564] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_fix_power1 fail
Line 476: [ 1.480749] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_fix_power2 fail
Line 477: [ 1.489936] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_fix_power3 fail
Line 478: [ 1.499637] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_power3 fail
Line 479: [ 1.507972] [DISP] disp_sys_script_get_item,line:237:lcd0.lcd_gpio_0 gpio=118,mul_sel=1,data:1
Line 480: [ 1.516553] [DISP] disp_sys_script_get_item,line:237:lcd0.lcd_gpio_1 gpio=39,mul_sel=1,data:1
Line 481: [ 1.525046] [DISP] disp_sys_script_get_item,line:237:lcd0.lcd_gpio_2 gpio=37,mul_sel=1,data:1
Line 482: [ 1.533539] [DISP] disp_sys_script_get_item,line:237:lcd0.lcd_gpio_3 gpio=38,mul_sel=1,data:1
Line 483: [ 1.542705] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_gpio_power0 fail
Line 484: [ 1.551295] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_gpio_power1 fail
Line 485: [ 1.560569] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_gpio_power2 fail
Line 486: [ 1.569844] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_pin_power fail
Line 487: [ 1.578943] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_pin_power1 fail
Line 488: [ 1.588129] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_pin_power2 fail
Line 489: [ 1.597490] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_1_percent fail
Line 490: [ 1.606935] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_2_percent fail
Line 491: [ 1.616556] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_3_percent fail
Line 492: [ 1.626176] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_4_percent fail
Line 493: [ 1.635795] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_5_percent fail
Line 494: [ 1.645415] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_6_percent fail
Line 495: [ 1.655036] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_7_percent fail
Line 496: [ 1.664655] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_8_percent fail
Line 497: [ 1.674277] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_9_percent fail
Line 498: [ 1.683896] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_10_percent fail
Line 499: [ 1.693603] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_11_percent fail
Line 500: [ 1.703312] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_12_percent fail
Line 501: [ 1.713014] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_13_percent fail
Line 502: [ 1.722735] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_14_percent fail
Line 503: [ 1.732429] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_15_percent fail
Line 504: [ 1.742136] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_16_percent fail
Line 505: [ 1.751842] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_17_percent fail
Line 506: [ 1.761550] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_18_percent fail
Line 507: [ 1.771259] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_19_percent fail
Line 508: [ 1.780964] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_20_percent fail
Line 509: [ 1.790669] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_21_percent fail
Line 510: [ 1.800377] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_22_percent fail
Line 511: [ 1.810082] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_23_percent fail
Line 512: [ 1.819788] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_24_percent fail
Line 513: [ 1.829497] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_25_percent fail
Line 514: [ 1.839202] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_26_percent fail
Line 515: [ 1.848909] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_27_percent fail
Line 516: [ 1.858620] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_28_percent fail
Line 517: [ 1.868325] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_29_percent fail
Line 518: [ 1.878028] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_30_percent fail
Line 519: [ 1.887736] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_31_percent fail
Line 520: [ 1.897442] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_32_percent fail
Line 521: [ 1.907148] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_33_percent fail
Line 522: [ 1.916856] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_34_percent fail
Line 523: [ 1.926564] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_35_percent fail
Line 524: [ 1.936269] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_36_percent fail
Line 525: [ 1.945986] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_37_percent fail
Line 526: [ 1.955683] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_38_percent fail
Line 527: [ 1.965389] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_39_percent fail
Line 528: [ 1.975096] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_40_percent fail
Line 529: [ 1.984802] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_41_percent fail
Line 530: [ 1.994510] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_42_percent fail
Line 531: [ 2.004216] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_43_percent fail
Line 532: [ 2.013922] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_44_percent fail
Line 533: [ 2.023632] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_45_percent fail
Line 534: [ 2.033335] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_46_percent fail
Line 535: [ 2.043041] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_47_percent fail
Line 536: [ 2.052760] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_48_percent fail
Line 537: [ 2.062456] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_49_percent fail
Line 538: [ 2.072163] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_50_percent fail
Line 539: [ 2.081868] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_51_percent fail
Line 540: [ 2.091576] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_52_percent fail
Line 541: [ 2.101282] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_53_percent fail
Line 542: [ 2.110994] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_54_percent fail
Line 543: [ 2.120697] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_55_percent fail
Line 544: [ 2.130403] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_56_percent fail
Line 545: [ 2.140108] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_57_percent fail
Line 546: [ 2.149817] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_58_percent fail
Line 547: [ 2.159522] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_59_percent fail
Line 548: [ 2.169228] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_60_percent fail
Line 549: [ 2.178935] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_61_percent fail
Line 550: [ 2.188644] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_62_percent fail
Line 551: [ 2.198349] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_63_percent fail
Line 552: [ 2.208058] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_64_percent fail
Line 553: [ 2.217762] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_65_percent fail
Line 554: [ 2.227470] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_66_percent fail
Line 555: [ 2.237175] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_67_percent fail
Line 556: [ 2.246885] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_68_percent fail
Line 557: [ 2.256588] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_69_percent fail
Line 558: [ 2.266296] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_70_percent fail
Line 559: [ 2.276015] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_71_percent fail
Line 560: [ 2.285708] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_72_percent fail
Line 561: [ 2.295417] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_73_percent fail
Line 562: [ 2.305121] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_74_percent fail
Line 563: [ 2.314832] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_75_percent fail
Line 564: [ 2.324536] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_76_percent fail
Line 565: [ 2.334243] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_77_percent fail
Line 566: [ 2.343950] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_78_percent fail
Line 567: [ 2.353656] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_79_percent fail
Line 568: [ 2.363363] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_80_percent fail
Line 569: [ 2.373094] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_81_percent fail
Line 570: [ 2.382794] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_82_percent fail
Line 571: [ 2.392485] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_83_percent fail
Line 572: [ 2.402190] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_84_percent fail
Line 573: [ 2.411895] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_85_percent fail
Line 574: [ 2.421603] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_86_percent fail
Line 575: [ 2.431309] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_87_percent fail
Line 576: [ 2.441015] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_88_percent fail
Line 577: [ 2.450723] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_89_percent fail
Line 578: [ 2.460430] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_90_percent fail
Line 579: [ 2.470135] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_91_percent fail
Line 580: [ 2.479842] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_92_percent fail
Line 581: [ 2.489550] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_93_percent fail
Line 582: [ 2.499255] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_94_percent fail
Line 583: [ 2.508963] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_95_percent fail
Line 584: [ 2.518669] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_96_percent fail
Line 585: [ 2.528377] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_97_percent fail
Line 586: [ 2.538084] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_98_percent fail
Line 587: [ 2.547790] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_99_percent fail
Line 588: [ 2.557660] [DISP] lcd_get_sys_config,line:490:lcd0 sys config: used=1, bl_en_used=1, bl_en_power=, backlight=50
Line 589: [ 2.567468] [DISP] lcd_get_sys_config,line:496:lcd0 power[0]: used=1 name=cldo4, fix_used=0 fix=
Line 590: [ 2.576222] [DISP] lcd_get_sys_config,line:496:lcd0 power[1]: used=1 name=cldo3, fix_used=0 fix=
Line 591: [ 2.584974] [DISP] lcd_get_sys_config,line:496:lcd0 power[2]: used=1 name=cldo1, fix_used=0 fix=
Line 592: [ 2.593728] [DISP] lcd_get_sys_config,line:496:lcd0 power[3]: used=0 name=, fix_used=0 fix=
Line 593: [ 2.602048] [DISP] lcd_get_sys_config,line:501:lcd0 gpio[0] used=1
Line 594: [ 2.608190] [DISP] lcd_get_sys_config,line:501:lcd0 gpio[1] used=1
Line 595: [ 2.614354] [DISP] lcd_get_sys_config,line:501:lcd0 gpio[2] used=1
Line 596: [ 2.620508] [DISP] lcd_get_sys_config,line:501:lcd0 gpio[3] used=1
Line 597: [ 2.626662] [DISP] lcd_get_sys_config,line:501:lcd0 gpio[4] used=0
Line 598: [ 2.632814] [DISP] lcd_get_sys_config,line:501:lcd0 gpio[5] used=0
Line 599: [ 2.638957] [DISP] lcd_get_sys_config,line:501:lcd0 gpio[6] used=0
Line 600: [ 2.645110] [DISP] lcd_get_sys_config,line:501:lcd0 gpio[7] used=0
Line 601: [ 2.651264] [DISP] lcd_get_sys_config,line:507:lcd0 gpio_power[0]= pin_power[0]=
Line 602: [ 2.658641] [DISP] lcd_get_sys_config,line:507:lcd0 gpio_power[1]= pin_power[1]=
Line 603: [ 2.666008] [DISP] lcd_get_sys_config,line:507:lcd0 gpio_power[2]= pin_power[2]=
Line 604: [ 2.675194] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_tcon_div fail
Line 605: [ 2.683480] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_hv_if fail
Line 606: [ 2.692160] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_lvds_if fail
Line 607: [ 2.701020] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_lvds_mode fail
Line 608: [ 2.710375] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_lvds_colordepth fail
Line 609: [ 2.720254] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_lvds_io_polarity fail
Line 610: [ 2.730222] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_cpu_if fail
Line 611: [ 2.739334] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_cpu_te fail
Line 612: [ 2.748421] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_cpu_mode fail
Line 613: [ 2.758691] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_dsi_port_num fail
Line 614: [ 2.767315] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_tcon_mode fail
Line 615: [ 2.776675] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_slave_tcon_num fail
Line 616: [ 2.786468] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_slave_stop_pos fail
Line 617: [ 2.796262] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_sync_pixel_num fail
Line 618: [ 2.806067] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_sync_line_num fail
Line 619: [ 2.815763] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_tcon_en_odd_even_div fail
Line 620: [ 2.826086] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_fsync_en fail
Line 621: [ 2.835348] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_fsync_act_time fail
Line 622: [ 2.845143] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_fsync_dis_time fail
Line 623: [ 2.854935] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_fsync_pol fail
Line 624: [ 2.864297] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_hv_clk_phase fail
Line 625: [ 2.873917] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_hv_sync_polarity fail
Line 626: [ 2.883888] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_hv_srgb_seq fail
Line 627: [ 2.893415] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_rb_swap fail
Line 628: [ 2.902602] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_hv_syuv_seq fail
Line 629: [ 2.912134] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_hv_syuv_fdly fail
Line 630: [ 2.922086] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_xtal_freq fail
Line 631: [ 2.931118] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_size fail
Line 632: [ 2.939782] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_model_name fail
Line 635: [ 2.965362] [DISP] lcd_clk_init,line:521:lcd 0 clk init
Line 636: [ 2.970728] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd1.lcd_used fail
Line 676: [ 3.211911] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name default_lcd
Line 677: [ 3.222839] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name lt070me05000
Line 678: [ 3.233841] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name wtq05027d01
Line 679: [ 3.244762] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name t27p06
Line 680: [ 3.255248] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name dx0960be40a1
Line 681: [ 3.266256] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name tft720x1280
Line 682: [ 3.277176] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name S6D7AA0X01
Line 683: [ 3.288008] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name gg1p4062utsw
Line 684: [ 3.299016] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name ls029b3sx02
Line 685: [ 3.309936] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name he0801a068
Line 686: [ 3.320768] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name inet_dsi_panel
Line 687: [ 3.331947] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name lq101r1sx03
Line 688: [ 3.342868] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name WilliamLcd
Line 689: [ 3.353704] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name fx070
Line 690: [ 3.364100] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name FX070_DHM18BOEL2_1024X600
Line 691: [ 3.376235] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name bp101wx1
Line 692: [ 3.386895] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name m133x56
Line 693: [ 3.397475] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name m133x56_two
Line 694: [ 3.408388] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name k101im2qa04
Line 695: [ 3.419318] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name k101im2byl02l
Line 696: [ 3.430401] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name lt8911ex
Line 697: [ 3.441060] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name K101_IM2BYL02_L_800X1280
Line 698: [ 3.453107] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name kd080d24
Line 699: [ 3.463769] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name k080_im2b801_h
Line 700: [ 3.474948] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name K080_IM2HYL802R_800X1280
Line 701: [ 3.486994] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name CC08021801_310_800X1280
Line 702: [ 3.498954] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name AXS1832_055FS01_720X1280
Line 703: [ 3.510836] [LCD] LCD_cfg_panel_info: enter
Line 704: [ 3.514998] [LCD] LCD_cfg_panel_info: exit
Line 705: [ 3.519069] [DISP] bsp_disp_lcd_set_panel_funs,line:1565:panel driver AXS1832_055FS01_720X1280 register
Line 827: [ 3.934899] [DISP] lcd_clk_config,line:684:clk_set_rate:dsi's 0 th clk with 150000000
Line 828: [ 3.934909] [DISP] lcd_clk_config,line:699:
Line 831: [ 3.934958] [DISP] cal_real_frame_period,line:605:lcd frame period:16770250
Line 836: [ 3.943448] [DISP] disp_sys_gpio_request,line:280:disp_sys_gpio_request, gpio_name=lcd_gpio_0, gpio=118, <1,0,3,1>ret=0
Line 837: [ 3.943501] [DISP] disp_sys_gpio_request,line:280:disp_sys_gpio_request, gpio_name=lcd_gpio_1, gpio=39, <1,0,3,1>ret=0
Line 838: [ 3.943527] [DISP] disp_sys_gpio_request,line:280:disp_sys_gpio_request, gpio_name=lcd_gpio_2, gpio=37, <1,0,3,1>ret=0
Line 839: [ 3.943551] [DISP] disp_sys_gpio_request,line:280:disp_sys_gpio_request, gpio_name=lcd_gpio_3, gpio=38, <1,0,3,1>ret=0
Line 840: [ 3.943577] [DISP] disp_sys_gpio_request,line:280:disp_sys_gpio_request, gpio_name=lcd_bl_en, gpio=119, <1,0,3,1>ret=0
Line 26851: [LCD] LCD_open_flow: sel=0
Line 26852: [LCD] LCD_cfg_panel_info: enter
Line 26853: [LCD] LCD_cfg_panel_info: exit
Line 26856: [LCD] LCD_open_flow: sel=0
Line 26857: LCD_power_on
Line 26861: [LCD] LCD_open_flow: sel=0
Line 26862: [LCD] LCD_panel_try_switch: screen 0 - reading panel ID via DCS
Line 26863: [LCD] LCD_panel_try_switch: ID bytes = 18 32 41 (0x183241)
Line 26864: [LCD] LCD_open_flow: sel=0
Line 26865: [LCD] LCD_panel_init: uboot, first cmd=0xBB
Line 26866: [LCD] LCD_panel_init: finish
Line 26897: [05.488]update[LCD] LCD_open_flow: sel=0
Line 26903: [LCD] LCD_open_flow: sel=0
Line 26904: [LCD] LCD_bl_open: PWM enable
Line 26905: [LCD] LCD_open_flow: sel=0
Line 26906: [LCD] LCD_open_flow: sel=0
Line 26907: [05.612]LCD open finish
Line 27165: [ 1.424442] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.smartbl_low_limit fail
Line 27166: [ 1.433662] [DISP] disp_init_lcd,line:3243:disp_init_lcd
Line 27167: [ 1.438937] [DISP] disp_init_lcd,line:3317:total number of clk in dsi:1
Line 27168: [ 1.445340] [DISP] disp_init_lcd,line:3320:lcd 0, irq_no=362, irq_no_dsi=364
Line 27169: [ 1.452361] [DISP] disp_lcd_init,line:2710:lcd 0
Line 27170: [ 1.456942] [DISP] lcd_get_sys_config,line:360:lcd0 get sys config begin
Line 27171: [ 1.463980] [DISP] disp_sys_script_get_item,line:237:lcd0.lcd_bl_en gpio=119,mul_sel=1,data:1
Line 27172: [ 1.472289] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_bl_en_power fail
Line 27173: [ 1.481573] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_fix_power fail
Line 27174: [ 1.490660] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_fix_power1 fail
Line 27175: [ 1.499847] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_fix_power2 fail
Line 27176: [ 1.509033] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_fix_power3 fail
Line 27177: [ 1.518734] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_power3 fail
Line 27178: [ 1.527072] [DISP] disp_sys_script_get_item,line:237:lcd0.lcd_gpio_0 gpio=118,mul_sel=1,data:1
Line 27179: [ 1.535649] [DISP] disp_sys_script_get_item,line:237:lcd0.lcd_gpio_1 gpio=39,mul_sel=1,data:1
Line 27180: [ 1.544144] [DISP] disp_sys_script_get_item,line:237:lcd0.lcd_gpio_2 gpio=37,mul_sel=1,data:1
Line 27181: [ 1.552637] [DISP] disp_sys_script_get_item,line:237:lcd0.lcd_gpio_3 gpio=38,mul_sel=1,data:1
Line 27182: [ 1.561802] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_gpio_power0 fail
Line 27183: [ 1.570394] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_gpio_power1 fail
Line 27184: [ 1.579667] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_gpio_power2 fail
Line 27185: [ 1.588938] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_pin_power fail
Line 27186: [ 1.598041] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_pin_power1 fail
Line 27187: [ 1.607227] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_pin_power2 fail
Line 27188: [ 1.616585] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_1_percent fail
Line 27189: [ 1.626034] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_2_percent fail
Line 27190: [ 1.635656] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_3_percent fail
Line 27191: [ 1.645275] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_4_percent fail
Line 27192: [ 1.654904] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_5_percent fail
Line 27193: [ 1.664513] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_6_percent fail
Line 27194: [ 1.674136] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_7_percent fail
Line 27195: [ 1.683754] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_8_percent fail
Line 27196: [ 1.693373] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_9_percent fail
Line 27197: [ 1.702994] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_10_percent fail
Line 27198: [ 1.712701] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_11_percent fail
Line 27199: [ 1.722409] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_12_percent fail
Line 27200: [ 1.732115] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_13_percent fail
Line 27201: [ 1.741821] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_14_percent fail
Line 27202: [ 1.751526] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_15_percent fail
Line 27203: [ 1.761234] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_16_percent fail
Line 27204: [ 1.770941] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_17_percent fail
Line 27205: [ 1.780648] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_18_percent fail
Line 27206: [ 1.790355] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_19_percent fail
Line 27207: [ 1.800061] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_20_percent fail
Line 27208: [ 1.809767] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_21_percent fail
Line 27209: [ 1.819474] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_22_percent fail
Line 27210: [ 1.829180] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_23_percent fail
Line 27211: [ 1.838888] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_24_percent fail
Line 27212: [ 1.848594] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_25_percent fail
Line 27213: [ 1.858313] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_26_percent fail
Line 27214: [ 1.868006] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_27_percent fail
Line 27215: [ 1.877714] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_28_percent fail
Line 27216: [ 1.887422] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_29_percent fail
Line 27217: [ 1.897133] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_30_percent fail
Line 27218: [ 1.906835] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_31_percent fail
Line 27219: [ 1.916540] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_32_percent fail
Line 27220: [ 1.926247] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_33_percent fail
Line 27221: [ 1.935955] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_34_percent fail
Line 27222: [ 1.945661] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_35_percent fail
Line 27223: [ 1.955366] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_36_percent fail
Line 27224: [ 1.965074] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_37_percent fail
Line 27225: [ 1.974778] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_38_percent fail
Line 27226: [ 1.984487] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_39_percent fail
Line 27227: [ 1.994196] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_40_percent fail
Line 27228: [ 2.003900] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_41_percent fail
Line 27229: [ 2.013608] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_42_percent fail
Line 27230: [ 2.023314] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_43_percent fail
Line 27231: [ 2.033021] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_44_percent fail
Line 27232: [ 2.042729] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_45_percent fail
Line 27233: [ 2.052435] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_46_percent fail
Line 27234: [ 2.062141] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_47_percent fail
Line 27235: [ 2.071848] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_48_percent fail
Line 27236: [ 2.081566] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_49_percent fail
Line 27237: [ 2.091259] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_50_percent fail
Line 27238: [ 2.100969] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_51_percent fail
Line 27239: [ 2.110674] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_52_percent fail
Line 27240: [ 2.120381] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_53_percent fail
Line 27241: [ 2.130087] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_54_percent fail
Line 27242: [ 2.139794] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_55_percent fail
Line 27243: [ 2.149500] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_56_percent fail
Line 27244: [ 2.159207] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_57_percent fail
Line 27245: [ 2.168914] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_58_percent fail
Line 27246: [ 2.178620] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_59_percent fail
Line 27247: [ 2.188340] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_60_percent fail
Line 27248: [ 2.198032] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_61_percent fail
Line 27249: [ 2.207740] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_62_percent fail
Line 27250: [ 2.217447] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_63_percent fail
Line 27251: [ 2.227154] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_64_percent fail
Line 27252: [ 2.236860] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_65_percent fail
Line 27253: [ 2.246568] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_66_percent fail
Line 27254: [ 2.256274] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_67_percent fail
Line 27255: [ 2.265981] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_68_percent fail
Line 27256: [ 2.275687] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_69_percent fail
Line 27257: [ 2.285394] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_70_percent fail
Line 27258: [ 2.295107] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_71_percent fail
Line 27259: [ 2.304808] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_72_percent fail
Line 27260: [ 2.314516] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_73_percent fail
Line 27261: [ 2.324220] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_74_percent fail
Line 27262: [ 2.333928] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_75_percent fail
Line 27263: [ 2.343633] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_76_percent fail
Line 27264: [ 2.353340] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_77_percent fail
Line 27265: [ 2.363050] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_78_percent fail
Line 27266: [ 2.372754] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_79_percent fail
Line 27267: [ 2.382462] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_80_percent fail
Line 27268: [ 2.392168] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_81_percent fail
Line 27269: [ 2.401875] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_82_percent fail
Line 27270: [ 2.411592] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_83_percent fail
Line 27271: [ 2.421287] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_84_percent fail
Line 27272: [ 2.430996] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_85_percent fail
Line 27273: [ 2.440700] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_86_percent fail
Line 27274: [ 2.450408] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_87_percent fail
Line 27275: [ 2.460112] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_88_percent fail
Line 27276: [ 2.469821] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_89_percent fail
Line 27277: [ 2.479528] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_90_percent fail
Line 27278: [ 2.489236] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_91_percent fail
Line 27279: [ 2.498940] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_92_percent fail
Line 27280: [ 2.508647] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_93_percent fail
Line 27281: [ 2.518365] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_94_percent fail
Line 27282: [ 2.528060] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_95_percent fail
Line 27283: [ 2.537768] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_96_percent fail
Line 27284: [ 2.547474] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_97_percent fail
Line 27285: [ 2.557179] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_98_percent fail
Line 27286: [ 2.566888] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_99_percent fail
Line 27287: [ 2.576763] [DISP] lcd_get_sys_config,line:490:lcd0 sys config: used=1, bl_en_used=1, bl_en_power=, backlight=50
Line 27288: [ 2.586566] [DISP] lcd_get_sys_config,line:496:lcd0 power[0]: used=1 name=cldo4, fix_used=0 fix=
Line 27289: [ 2.595319] [DISP] lcd_get_sys_config,line:496:lcd0 power[1]: used=1 name=cldo3, fix_used=0 fix=
Line 27290: [ 2.604072] [DISP] lcd_get_sys_config,line:496:lcd0 power[2]: used=1 name=cldo1, fix_used=0 fix=
Line 27291: [ 2.612826] [DISP] lcd_get_sys_config,line:496:lcd0 power[3]: used=0 name=, fix_used=0 fix=
Line 27292: [ 2.621146] [DISP] lcd_get_sys_config,line:501:lcd0 gpio[0] used=1
Line 27293: [ 2.627288] [DISP] lcd_get_sys_config,line:501:lcd0 gpio[1] used=1
Line 27294: [ 2.633442] [DISP] lcd_get_sys_config,line:501:lcd0 gpio[2] used=1
Line 27295: [ 2.639606] [DISP] lcd_get_sys_config,line:501:lcd0 gpio[3] used=1
Line 27296: [ 2.645759] [DISP] lcd_get_sys_config,line:501:lcd0 gpio[4] used=0
Line 27297: [ 2.651912] [DISP] lcd_get_sys_config,line:501:lcd0 gpio[5] used=0
Line 27298: [ 2.658055] [DISP] lcd_get_sys_config,line:501:lcd0 gpio[6] used=0
Line 27299: [ 2.664208] [DISP] lcd_get_sys_config,line:501:lcd0 gpio[7] used=0
Line 27300: [ 2.670361] [DISP] lcd_get_sys_config,line:507:lcd0 gpio_power[0]= pin_power[0]=
Line 27301: [ 2.677739] [DISP] lcd_get_sys_config,line:507:lcd0 gpio_power[1]= pin_power[1]=
Line 27302: [ 2.685106] [DISP] lcd_get_sys_config,line:507:lcd0 gpio_power[2]= pin_power[2]=
Line 27303: [ 2.694294] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_tcon_div fail
Line 27304: [ 2.702576] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_hv_if fail
Line 27305: [ 2.711254] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_lvds_if fail
Line 27306: [ 2.720112] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_lvds_mode fail
Line 27307: [ 2.729472] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_lvds_colordepth fail
Line 27308: [ 2.739353] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_lvds_io_polarity fail
Line 27309: [ 2.749319] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_cpu_if fail
Line 27310: [ 2.758420] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_cpu_te fail
Line 27311: [ 2.767519] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_cpu_mode fail
Line 27312: [ 2.777791] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_dsi_port_num fail
Line 27313: [ 2.786416] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_tcon_mode fail
Line 27314: [ 2.795774] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_slave_tcon_num fail
Line 27315: [ 2.805565] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_slave_stop_pos fail
Line 27316: [ 2.815360] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_sync_pixel_num fail
Line 27317: [ 2.825152] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_sync_line_num fail
Line 27318: [ 2.834860] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_tcon_en_odd_even_div fail
Line 27319: [ 2.845174] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_fsync_en fail
Line 27320: [ 2.854446] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_fsync_act_time fail
Line 27321: [ 2.864239] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_fsync_dis_time fail
Line 27322: [ 2.874033] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_fsync_pol fail
Line 27323: [ 2.883393] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_hv_clk_phase fail
Line 27324: [ 2.893014] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_hv_sync_polarity fail
Line 27325: [ 2.902980] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_hv_srgb_seq fail
Line 27326: [ 2.912513] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_rb_swap fail
Line 27327: [ 2.921710] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_hv_syuv_seq fail
Line 27328: [ 2.931234] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_hv_syuv_fdly fail
Line 27329: [ 2.941184] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_xtal_freq fail
Line 27330: [ 2.950214] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_size fail
Line 27331: [ 2.958878] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_model_name fail
Line 27334: [ 2.984460] [DISP] lcd_clk_init,line:521:lcd 0 clk init
Line 27335: [ 2.989816] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd1.lcd_used fail
Line 27375: [ 3.231010] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name default_lcd
Line 27376: [ 3.241935] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name lt070me05000
Line 27377: [ 3.252940] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name wtq05027d01
Line 27378: [ 3.263859] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name t27p06
Line 27379: [ 3.274346] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name dx0960be40a1
Line 27380: [ 3.285353] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name tft720x1280
Line 27381: [ 3.296274] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name S6D7AA0X01
Line 27382: [ 3.307105] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name gg1p4062utsw
Line 27383: [ 3.318112] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name ls029b3sx02
Line 27384: [ 3.329032] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name he0801a068
Line 27385: [ 3.339867] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name inet_dsi_panel
Line 27386: [ 3.351046] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name lq101r1sx03
Line 27387: [ 3.361965] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name WilliamLcd
Line 27388: [ 3.372799] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name fx070
Line 27389: [ 3.383201] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name FX070_DHM18BOEL2_1024X600
Line 27390: [ 3.395332] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name bp101wx1
Line 27391: [ 3.405994] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name m133x56
Line 27392: [ 3.416566] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name m133x56_two
Line 27393: [ 3.427487] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name k101im2qa04
Line 27394: [ 3.438407] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name k101im2byl02l
Line 27395: [ 3.449500] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name lt8911ex
Line 27396: [ 3.460159] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name K101_IM2BYL02_L_800X1280
Line 27397: [ 3.472206] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name kd080d24
Line 27398: [ 3.482868] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name k080_im2b801_h
Line 27399: [ 3.494045] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name K080_IM2HYL802R_800X1280
Line 27400: [ 3.506094] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name CC08021801_310_800X1280
Line 27401: [ 3.518053] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280, panel_name AXS1832_055FS01_720X1280
Line 27402: [ 3.529933] [LCD] LCD_cfg_panel_info: enter
Line 27403: [ 3.534096] [LCD] LCD_cfg_panel_info: exit
Line 27404: [ 3.538167] [DISP] bsp_disp_lcd_set_panel_funs,line:1565:panel driver AXS1832_055FS01_720X1280 register
Line 27525: [ 3.957207] [DISP] lcd_clk_config,line:684:clk_set_rate:dsi's 0 th clk with 150000000
Line 27526: [ 3.957214] [DISP] lcd_clk_config,line:699:[ 3.957221] disp 0, clk: pll(384000000),clk(384000000),dclk(64000000) dsi_rate(64000000)
Line 27528: [ 3.957265] [DISP] cal_real_frame_period,line:605:lcd frame period:16770250
Line 27533: [ 3.962337] [DISP] disp_sys_gpio_request,line:280:disp_sys_gpio_request, gpio_name=lcd_gpio_0, gpio=118, <1,0,3,1>ret=0
Line 27534: [ 3.962391] [DISP] disp_sys_gpio_request,line:280:disp_sys_gpio_request, gpio_name=lcd_gpio_1, gpio=39, <1,0,3,1>ret=0
Line 27535: [ 3.962416] [DISP] disp_sys_gpio_request,line:280:disp_sys_gpio_request, gpio_name=lcd_gpio_2, gpio=37, <1,0,3,1>ret=0
Line 27536: [ 3.962440] [DISP] disp_sys_gpio_request,line:280:disp_sys_gpio_request, gpio_name=lcd_gpio_3, gpio=38, <1,0,3,1>ret=0
Line 27537: [ 3.962466] [DISP] disp_sys_gpio_request,line:280:disp_sys_gpio_request, gpio_name=lcd_bl_en, gpio=119, <1,0,3,1>ret=0
Line 43967: [ 264.585556] [DISP] disp_lcd_disable,line:2042:lcd 0
Line 43968: [ 264.591138] LCD_close_flow
Line 43969: [ 264.594251] LCD_bl_close
Line 43972: [ 264.637362] [DISP] disp_lcd_panel_close,line:1754:close flow:step 0 finish, to delay 200
Line 43973: [ 264.915205] [DISP] disp_lcd_panel_close,line:1754:close flow:step 1 finish, to delay 20
Line 43974: [ 265.051867] [DISP] disp_lcd_panel_close,line:1754:close flow:step 2 finish, to delay 10
Line 43975: [ 265.071857] LCD_power_off
Line 43976: [ 265.074908] [DISP] disp_lcd_pin_cfg,line:1004:lcd 0 pin config, state off, 0
Line 43999: [ 265.238754] [DISP] disp_lcd_panel_close,line:1754:close flow:step 3 finish, to delay 500
Line 44041: [ 265.755115] [DISP] disp_sys_gpio_request,line:280:disp_sys_gpio_request, gpio_name=lcd_gpio_0, gpio=118, <7,0,3,1>ret=0
Line 44042: [ 265.755250] [DISP] disp_sys_gpio_request,line:280:disp_sys_gpio_request, gpio_name=lcd_gpio_1, gpio=39, <7,0,3,1>ret=0
Line 44043: [ 265.755338] [DISP] disp_sys_gpio_request,line:280:disp_sys_gpio_request, gpio_name=lcd_gpio_2, gpio=37, <7,0,3,1>ret=0
Line 44044: [ 265.755424] [DISP] disp_sys_gpio_request,line:280:disp_sys_gpio_request, gpio_name=lcd_gpio_3, gpio=38, <7,0,3,1>ret=0
屏幕是mipi的720*1280的NV3052_BV055HDL_NB6型号
求助
还没解决吗?这种光看log也定位不到问题在哪里
那怎么解决 硬件没有问题 就是全志的a133的mipi屏幕710*1280的 我设置这个lcd_vspw和lcd_hspw 这两个值 我按规格书调的是2 但是改成4才不会卡 流程是正常 改成4之后 但是只有背光不亮屏 没有看见错误是怎么回事
