楼主 # 2025-12-11 14:48:25
ccwwbb76
用衡山派D133EBS芯片,在线调试采用CKLINK LITE,在线调试一进入就停止
GDB connection command for CPUs(CPU0):
    target remote 192.168.132.1:1025
    target remote 192.168.223.1:1025
    target remote 192.168.0.94:1025
WARNING: Flash Algorithm File: The flash-algorithm have DevDscr section.
Get connection from 192.168.0.94 for CPU 0, at 2025-12-11 14:31:44
WARNING: Address 0x0000000040035b5a can't be written when insert soft-bkpt.
ERROR: After reading/writing memory operations get ABSTRCTCS.cmderr 1(busy) and ABSTRACTCS.busy is still busy after ABSTRCTCS.cmderr has been cleared and then dm has been reset by DMCONTROL.dmactive.
Connection to CPU 0 is lost, at 2025-12-11 14:31:45
DebuggerServer quit
Stop Debugger Server.
Flash setting is cancelled.
#1 2026-03-20 14:09:45
ssulg
Re: 用衡山派D133EBS芯片,在线调试采用CKLINK LITE,在线调试一进入就停止
我用t-head server都连不上芯片。。。引脚设置已经使能了jtag。楼主能正常连接到芯片吗?
