日志卡在kernel是什么情况:
[BEGIN] 2026/3/27 10:22:14
962]fes begin:54b5c2f5b3
[965]set pll start
[967]periph0 has been enabled
[970]set pll end
[972]PL gpio voltage : 3.3V
[975][pmu]: bus read error
[978]PMU: AXP803
[980][pmu]: bus read error
[1026]vaild para:1 select dram para0
[1029]board init ok, set sys_vol to 920mv!
[1034]beign to init dram
[1036]DRAM BOOT DRIVE INFO: V0.697
[1040]the chip id is 0x1400
[1042]the chip id is 0x1400
[1045]the chip id is 0x1400
[1048]the chip id is 0x1400
[1051]the chip id is 0x1400
[1054]chip id check OK
[1080]DRAM_VCC set to 1500 mv
[1127]DRAM retraining ten
[1135][AUTO DEBUG]32bit,1 ranks training success!
[1149]DRAM CLK =576 MHZ
[1151]DRAM Type =3 (3:DDR3,4:DDR4,6:LPDDR2,7:LPDDR3,8:LPDDR4)
[1161]DRAM SIZE =1024 MBytes, para1 = 30fa, para2 = 4000000, tpr13 = 6001
[1179]DRAM simple test OK.
[1181]init dram ok
U-Boot 2018.05 (Feb 02 2026 - 02:07:18 +0000) Allwinner Technology
[08.991]CPU: Allwinner Family
[08.994]Model: sun50iw10
I2C: ready
[09.121]DRAM: 512 MiB
[09.125]Relocation Offset is: 15f03000
[09.158]secure enable bit: 0
[09.162]pmu_axp806_probe pmic_bus_read fail
[09.166]PMU: AXP803
[09.168]PMU: pmu_axp81X found
[09.171]PMU: AXP803
[09.173]BMU: bmu_axp81X found
FDT ERROR:fdt_get_regulator_name:get property handle twi-for-pmu-supply error:FDT_ERR_INTERNAL
[09.193]gpio_bias, pc_bias: 1800, pc_supply: not set
[09.198]gpio_bias, pl_bias: -1, pl_supply: not set
[09.205]dcdc1_vol = 3300, onoff=1
[09.210]aldo1_vol = 1800, onoff=1
[09.215]aldo2_vol = 1800, onoff=1
[09.220]aldo3_vol = 3300, onoff=1
[09.225]dldo1_vol = 0, onoff=0
[09.230]dldo2_vol = 1800, onoff=1
[09.235]dldo3_vol = 1800, onoff=1
[09.240]dldo4_vol = 1800, onoff=1
[09.245]eldo1_vol = 1800, onoff=1
[09.251]eldo2_vol = 1800, onoff=1
[09.256]eldo3_vol = 1800, onoff=1
[09.261]fldo1_vol = 900, onoff=1
[09.266]dc1sw_vol = 0, onoff=1
bias_name:pc_bias bias_vol:1800
[09.277]bat_vol=2764, ratio=0
[09.280]safe_vol=3500, safe_ratio=1
[09.284]TCS: TCS_probe
[09.286]pmu_tcs4838_probe pmic_bus_read fail
[09.289]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=400Mhz
[09.299]gic: normal mode
[09.301]flash init start
[09.303]workmode = 16,storage type = 0
try card 2
set card number 2
get card number 2
[09.311][mmc]: mmc driver ver uboot2018:2020-5-25 9:26:00-2021-09-17 14:45:00
[09.319][mmc]: get sdc_type fail and use default host:tm4.
[09.330][mmc]: Is not Boot mode!
[09.333][mmc]: SUNXI SDMMC Controller Version:0x50300
[09.344][mmc]: ************Try SD card 2************
[09.349][mmc]: mmc 2 cmd timeout 100 status 100
[09.353][mmc]: smc 2 err, cmd 8, RTO
[09.357][mmc]: mmc 2 close bus gating and reset
[09.362][mmc]: mmc 2 cmd timeout 100 status 100
[09.366][mmc]: smc 2 err, cmd 55, RTO
[09.370][mmc]: mmc 2 close bus gating and reset
[09.374][mmc]: ************Try MMC card 2************
[09.402][mmc]: mmc 2 cmd timeout 100 status 100
[09.406][mmc]: smc 2 err, cmd 8, RTO
[09.410][mmc]: mmc 2 close bus gating and reset
[09.415][mmc]: mmc 2 cmd timeout 100 status 100
[09.419][mmc]: smc 2 err, cmd 55, RTO
[09.422][mmc]: mmc 2 close bus gating and reset
[09.438][mmc]: gen_tuning_blk_bus8: total blk 10
[09.442][mmc]: gen_tuning_blk_bus4: total blk 6
[09.446][mmc]: Using 8 bit tuning now
[09.451][mmc]: write_tuning_try_freq: write ok
[09.456][mmc]: Pattern compare ok
[09.459][mmc]: Write tuning pattern ok
[09.462][mmc]: ================== HSSDR52_SDR25...
[09.467][mmc]: skip freq 400000
[09.470][mmc]: skip freq 25000000
[09.473][mmc]: freq: 2-50000000-64-4
[10.207][mmc]: [0-42|43] [47-63|17]
[10.210][mmc]: ================== HS200_SDR104...
[10.215][mmc]: skip freq 400000
[10.218][mmc]: skip freq 25000000
[10.221][mmc]: freq: 2-50000000-64-4
[10.959][mmc]: freq: 3-100000000-64-4
[11.656][mmc]: freq: 4-150000000-64-4
[12.298][mmc]: skip freq 200000000
[12.301][mmc]: [0-34|35] [39-63|25]
[12.305][mmc]: [0-34|35] [39-63|25]
[12.308][mmc]: [4-34|31] [39-63|25]
[12.311][mmc]: ================== HSDDR52_DDR50...
[12.316][mmc]: skip freq 400000
[12.319][mmc]: freq: 1-25000000-64-4
[13.053][mmc]: freq: 2-50000000-64-4
[13.751][mmc]: [0-37|38] [41-51|11] [54-63|10]
[13.755][mmc]: [0-25|26] [27-37|11] [41-63|23]
[13.759][mmc]: ================== HS400...
[13.764][mmc]: skip freq 400000
[13.766][mmc]: skip freq 25000000
[13.770][mmc]: freq: 2-50000000
[13.786][mmc]: freq: 3-100000000
[13.800][mmc]: skip freq 150000000
[13.803][mmc]: skip freq 200000000
[13.806][mmc]: speed mode: HS400
[13.809][mmc]: [0-34|35] [36-63|28]
[13.813][mmc]: [0-34|35] [36-63|28]
[13.816][mmc]: skip freq 400000
[13.819][mmc]: skip freq 25000000
[13.822][mmc]: freq: 2-50000000-64-4
[14.365][mmc]: freq: 3-100000000-64-4
[14.599][mmc]: skip freq 150000000
[14.602][mmc]: skip freq 200000000
[14.605][mmc]: [0-45|46]
[14.607][mmc]: [0-10|11] [12-20|9]
[14.612][mmc]: DS26/SDR12: 0xffffffff 0xffffffff
[14.616][mmc]: HSSDR52/SDR25: 0xff15ffff 0xffffffff
[14.620][mmc]: HSDDR52/DDR50: 0xff0d13ff 0xffffffff
[14.625][mmc]: HS200/SDR104: 0x1111ffff 0xffffff13
[14.629][mmc]: HS400: 0x0517ffff 0xffffffff
[14.633][mmc]: HS400: 0x1111ffff 0xffffffff
[14.638][mmc]: Best spd md: 4-HS400, freq: 3-100000000, Bus width: 8
[14.645]Loading Environment from SUNXI_FLASH... OK
[14.649]try to burn key
[14.653]out of usb burn from boot: not boot mode
sunxi work mode=0x10
run usb efex
buf queue page size = 65536
delay time 2500
weak:otg_phy_config
usb init ok
set address 0x56
set address 0x56 ok
SUNXI_EFEX_ERASE_TAG
erase_flag = 0x1
FEX_CMD_fes_verify_status
FEX_CMD_fes_verify last err=0
the 0 mbr table is ok
the 1 mbr table is ok
the 2 mbr table is ok
the 3 mbr table is ok
*************MBR DUMP***************
total mbr part 17
part[0] name :bootloader
part[0] classname :DISK
part[0] addrlo :0x8000
part[0] lenlo :0x10000
part[0] user_type :32768
part[0] keydata :0
part[0] ro :0
part[1] name :env
part[1] classname :DISK
part[1] addrlo :0x18000
part[1] lenlo :0x8000
part[1] user_type :32768
part[1] keydata :0
part[1] ro :0
part[2] name :boot
part[2] classname :DISK
part[2] addrlo :0x20000
part[2] lenlo :0x10000
part[2] user_type :32768
part[2] keydata :0
part[2] ro :0
part[3] name :super
part[3] classname :DISK
part[3] addrlo :0x30000
part[3] lenlo :0x400000
part[3] user_type :32768
part[3] keydata :0
part[3] ro :0
part[4] name :misc
part[4] classname :DISK
part[4] addrlo :0x430000
part[4] lenlo :0x8000
part[4] user_type :32768
part[4] keydata :0
part[4] ro :0
part[5] name :recovery
part[5] classname :DISK
part[5] addrlo :0x438000
part[5] lenlo :0x10000
part[5] user_type :32768
part[5] keydata :0
part[5] ro :0
part[6] name :cache
part[6] classname :DISK
part[6] addrlo :0x448000
part[6] lenlo :0x180000
part[6] user_type :32768
part[6] keydata :0
part[6] ro :0
part[7] name :vbmeta
part[7] classname :DISK
part[7] addrlo :0x5c8000
part[7] lenlo :0x8000
part[7] user_type :32768
part[7] keydata :0
part[7] ro :0
part[8] name :vbmeta_system
part[8] classname :DISK
part[8] addrlo :0x5d0000
part[8] lenlo :0x8000
part[8] user_type :32768
part[8] keydata :0
part[8] ro :0
part[9] name :vbmeta_vendor
part[9] classname :DISK
part[9] addrlo :0x5d8000
part[9] lenlo :0x8000
part[9] user_type :32768
part[9] keydata :0
part[9] ro :0
part[10] name :metadata
part[10] classname :DISK
part[10] addrlo :0x5e0000
part[10] lenlo :0x8000
part[10] user_type :32768
part[10] keydata :0
part[10] ro :0
part[11] name :private
part[11] classname :DISK
part[11] addrlo :0x5e8000
part[11] lenlo :0x8000
part[11] user_type :32768
part[11] keydata :0
part[11] ro :0
part[12] name :frp
part[12] classname :DISK
part[12] addrlo :0x5f0000
part[12] lenlo :0x400
part[12] user_type :32768
part[12] keydata :32768
part[12] ro :0
part[13] name :empty
part[13] classname :DISK
part[13] addrlo :0x5f0400
part[13] lenlo :0x7c00
part[13] user_type :32768
part[13] keydata :0
part[13] ro :0
part[14] name :dtbo
part[14] classname :DISK
part[14] addrlo :0x5f8000
part[14] lenlo :0x1000
part[14] user_type :32768
part[14] keydata :0
part[14] ro :0
part[15] name :media_data
part[15] classname :DISK
part[15] addrlo :0x5f9000
part[15] lenlo :0x8000
part[15] user_type :32768
part[15] keydata :0
part[15] ro :0
part[16] name :UDISK
part[16] classname :DISK
part[16] addrlo :0x601000
part[16] lenlo :0x0
part[16] user_type :33024
part[16] keydata :0
part[16] ro :0
total part: 18
mbr 0, 8000, 8000
bootloader 1, 10000, 8000
env 2, 8000, 8000
boot 3, 10000, 8000
super 4, 400000, 8000
misc 5, 8000, 8000
recovery 6, 10000, 8000
cache 7, 180000, 8000
vbmeta 8, 8000, 8000
vbmeta_system 9, 8000, 8000
vbmeta_vendor 10, 8000, 8000
metadata 11, 8000, 8000
private 12, 8000, 8000
frp 13, 400, 8000
empty 14, 7c00, 8000
dtbo 15, 1000, 8000
media_data 16, 8000, 8000
UDISK 17, 0, 8100
[17.828]erase all part start
need erase flash: 1
******Has init
private part exist
GPT:bootloader : 12000 21fff
GPT:env : 22000 29fff
GPT:boot : 2a000 39fff
GPT:super : 3a000 439fff
GPT:misc : 43a000 441fff
GPT:recovery : 442000 451fff
GPT:cache : 452000 5d1fff
GPT:vbmeta : 5d2000 5d9fff
GPT:vbmeta_system: 5da000 5e1fff
GPT:vbmeta_vendor: 5e2000 5e9fff
GPT:metadata : 5ea000 5f1fff
GPT:private : 5f2000 5f9fff
GPT:frp : 5fa000 5fa3ff
GPT:empty : 5fa400 601fff
GPT:dtbo : 602000 602fff
GPT:media_data : 603000 60afff
GPT:UDISK : 60b000 747ffde
begin to store data
part 0 name bootloader
keydata = 0x0
part 1 name env
keydata = 0x0
part 2 name boot
keydata = 0x0
part 3 name super
keydata = 0x0
part 4 name misc
keydata = 0x0
part 5 name recovery
keydata = 0x0
part 6 name cache
keydata = 0x0
part 7 name vbmeta
keydata = 0x0
part 8 name vbmeta_system
keydata = 0x0
part 9 name vbmeta_vendor
keydata = 0x0
part 10 name metadata
keydata = 0x0
part 11 name private
keydata = 0x0
find keypart private
keypart read start: 0x5e8000, sectors 0x8000
keypart part private read 0x5e8000, sectors 0x8000
part 12 name frp
keydata = 0x1
find keypart frp
keypart read start: 0x5f0000, sectors 0x400
keypart part frp read 0x5f0000, sectors 0x400
part 13 name empty
keydata = 0x0
part 14 name dtbo
keydata = 0x0
part 15 name media_data
keydata = 0x0
part 16 name UDISK
keydata = 0x0
begin to erase
[18.092]erase all part start
card2 erase boot0
erase env part
[18.102][mmc]: erase from: 139264, to: 172031, cnt: 32768, erase_group: 1024
[18.119][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0xa ms
erase boot part
[18.127][mmc]: erase from: 172032, to: 237567, cnt: 65536, erase_group: 1024
[18.138][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0x4 ms
erase super part
[18.146][mmc]: erase from: 237568, to: 4431871, cnt: 4194304, erase_group: 1024
[18.180][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0x1a ms
erase misc part
[18.187][mmc]: erase from: 4431872, to: 4464639, cnt: 32768, erase_group: 1024
[18.198][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0x3 ms
erase recovery part
[18.207][mmc]: erase from: 4464640, to: 4530175, cnt: 65536, erase_group: 1024
[18.218][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0x4 ms
erase cache part
[18.226][mmc]: erase from: 4530176, to: 6103039, cnt: 1572864, erase_group: 1024
[18.236][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0x3 ms
erase vbmeta part
[18.244][mmc]: erase from: 6103040, to: 6135807, cnt: 32768, erase_group: 1024
[18.255][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0x4 ms
erase vbmeta_system part
[18.263][mmc]: erase from: 6135808, to: 6168575, cnt: 32768, erase_group: 1024
[18.274][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0x3 ms
erase vbmeta_vendor part
[18.283][mmc]: erase from: 6168576, to: 6201343, cnt: 32768, erase_group: 1024
[18.293][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0x3 ms
erase metadata part
[18.301][mmc]: erase from: 6201344, to: 6234111, cnt: 32768, erase_group: 1024
[18.311][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0x2 ms
erase private part
[18.319][mmc]: erase from: 6234112, to: 6266879, cnt: 32768, erase_group: 1024
[18.330][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0x4 ms
erase frp part
[18.338][mmc]: erase from: 6266880, to: 6267903, cnt: 1024, erase_group: 1024
[18.347][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0x2 ms
erase empty part
[18.355][mmc]: erase from: 6267904, to: 6299647, cnt: 31744, erase_group: 1024
[18.365][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0x3 ms
erase dtbo part
[18.373][mmc]: erase from: 6299648, to: 6303743, cnt: 4096, erase_group: 1024
[18.382][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0x2 ms
erase media_data part
[18.391][mmc]: erase from: 6303744, to: 6336511, cnt: 32768, erase_group: 1024
[18.400][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0x2 ms
erase UDISK part
sunxi_sprite_mmc_phyerase: @nr is 0, erase from @from to end
[18.413][mmc]: erase from: 6336512, to: 122158079, cnt: 115821568, erase_group: 1024
[18.428][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0x7 ms
[18.434][mmc]: mmc_mmc_erase: some sectors in emmc are ignored!
[18.440][mmc]: --0: from122158080 nr1023
card erase all
finish erase
******Has init
rewrite
******Has init
write primary GPT success
write Backup GPT success
keypart write start: 0x5e8000, sectors 0x8000
keypart write start: 0x5f0000, sectors 0x400
flash exit
SUNXI_EFEX_MBR_TAG
mbr size = 0x10000
******Has init
******Has init
FEX_CMD_fes_verify_value, start 0x8000, size high 0x0:low 0x1d00c00
FEX_CMD_fes_verify_value 0x7714d079
FEX_CMD_fes_verify_value, start 0x18000, size high 0x0:low 0x20000
FEX_CMD_fes_verify_value 0x5cb1c247
FEX_CMD_fes_verify_value, start 0x20000, size high 0x0:low 0x2000000
FEX_CMD_fes_verify_value 0x148a1092
FEX_CMD_fes_verify_value, start 0x438000, size high 0x0:low 0x2000000
FEX_CMD_fes_verify_value 0x9ab00eb6
FEX_CMD_fes_verify_value, start 0x5c8000, size high 0x0:low 0x2000
FEX_CMD_fes_verify_value 0x9721238c
FEX_CMD_fes_verify_value, start 0x5d0000, size high 0x0:low 0x1000
FEX_CMD_fes_verify_value 0x83ac2ad5
FEX_CMD_fes_verify_value, start 0x5d8000, size high 0x0:low 0x1000
FEX_CMD_fes_verify_value 0xbcfe36ce
FEX_CMD_fes_verify_value, start 0x5f8000, size high 0x0:low 0x200000
FEX_CMD_fes_verify_value 0xa7478a68
bootfile_mode=4
SUNXI_EFEX_BOOT1_TAG
boot1 size = 0x108000, max size = 0x400000
uboot size = 0x108000
storage type = 2
bootfile_mode=4
SUNXI_EFEX_BOOT0_TAG
boot0 size = 0x10000
[58.137][mmc]: write mmc 2 info ok
dram para[0] = 240
dram para[1] = 3
dram para[2] = 7070707
dram para[3] = c0c0c0c
dram para[4] = e0e
dram para[5] = 15101212
dram para[6] = 30fa
dram para[7] = 4000000
dram para[8] = 1f14
dram para[9] = 4
dram para[10] = 20
dram para[11] = 0
dram para[12] = 0
dram para[13] = 0
dram para[14] = 0
dram para[15] = 0
dram para[16] = 0
dram para[17] = 0
dram para[18] = 0
dram para[19] = 0
dram para[20] = 0
dram para[21] = 0
dram para[22] = 0
dram para[23] = 0
dram para[24] = 0
dram para[25] = 0
dram para[26] = 33808080
dram para[27] = 2f7458
dram para[28] = f0b0e0c
dram para[29] = 19191818
dram para[30] = 80006001
dram para[31] = 26232323
storage type = 2
sunxi_efex_next_action=2
exit usb
next work 2
SUNXI_UPDATE_NEXT_ACTION_REBOOT
[142]HELLO! BOOT0 is starting!
[145]BOOT0 commit : 54b5c2f5b3
[148]set pll start
[150]periph0 has been enabled
[154]set pll end
[155]PL gpio voltage : 3.3V
[158][pmu]: bus read error
[161]PMU: AXP803
[163][pmu]: bus read error
[208]vaild para:1 select dram para0
[212]board init ok, set sys_vol to 920mv!
[236]DRAM BOOT DRIVE INFO: V0.697
[239]the chip id is 0x1400
[242]the chip id is 0x1400
[245]the chip id is 0x1400
[247]the chip id is 0x1400
[250]the chip id is 0x1400
[253]chip id check OK
[278]DRAM_VCC set to 1500 mv
[281]DRAM CLK =576 MHZ
[283]DRAM Type =3 (3:DDR3,4:DDR4,6:LPDDR2,7:LPDDR3,8:LPDDR4)
[293]DRAM SIZE =1024 MBytes, para1 = 30fa, para2 = 4000000, tpr13 = 80006001
[305]DRAM simple test OK.
[308]dram size =1024
[310]chipid = 54401400
[312]nsi init ok 2020-4-7
[314]key press : [
[317]card no is 2
[319]sdcard 2 line count 8
[322][mmc]: mmc driver ver 2020-05-25 09:40-202007019516
[333][mmc]: Wrong media type 0x0
[336][mmc]: ***Try SD card 2***
[340][mmc]: mmc 2 cmd 8 timeout, err 100
[344][mmc]: mmc 2 cmd 8 err 100
[347][mmc]: mmc 2 send if cond failed
[351][mmc]: mmc 2 cmd 55 timeout, err 100
[355][mmc]: mmc 2 cmd 55 err 100
[359][mmc]: mmc 2 send app cmd failed
[362][mmc]: ***Try MMC card 2***
[387][mmc]: RMCA OK!
[389][mmc]: bias 4
[391][mmc]: mmc 2 bias 4
[396][mmc]: MMC 5.1
[398][mmc]: HSSDR52/SDR25 8 bit
[401][mmc]: 50000000 Hz
[403][mmc]: 59648 MB
[405][mmc]: ***SD/MMC 2 init OK!!!***
[469]Loading boot-pkg Succeed(index=0).
[473]Entry_name = u-boot
[480]Entry_name = monitor
[484]Entry_name = scp
[488]set arisc reset to assert state
[496]set arisc reset to de-assert state
[500]Entry_name = dtb
[504]tunning data addr:0x4a0003e8
[507]Jump to second Boot.
NOTICE: BL3-1: v1.0(debug):0f6655c
NOTICE: BL3-1: Built : 15:24:20, 2022-07-05
NOTICE: BL3-1 commit: 8
NOTICE: cpuidle init version V2.0
ERROR: Error initializing runtime service tspd_fast
NOTICE: BL3-1: Preparing for EL3 exit to normal world
NOTICE: BL3-1: Next image address = 0x4a000000
ÿOTICE: BL3-1: Next image spsr = 0x1d3
[00.593]CPU: Allwinner Family
[00.596]Model: sun50iw10
I2C: ready
[00.723]DRAM: 1 GiB
[00.726]Relocation Offset is: 35f03000
[00.760]secure enable bit: 0
[00.764][ARISC ERROR] :get [allwinner,sunxi-hwspinlock] device node error
CACHE: Misaligned operation at range [7ffa77a8, 7ffa7ac0]
[SCP] :sunxi-arisc driver begin startup 2
[SCP] :0x1
[SCP] :arisc version: [9c3683bc6b4e32f25317f3b20455e1c18f5e6778rid-]
[SCP] :arisc startup ready
[SCP] :arisc startup notify message feedback
[SCP] :send hard sync feedback message: 0x900200
[SCP] :sunxi-arisc driver v1.10 is starting
[00.804]pmu_axp806_probe pmic_bus_read fail
[00.808]PMU: AXP803
[00.811]PMU: AXP803
[00.868]TCS: TCS_probe
[00.870]pmu_tcs4838_probe pmic_bus_read fail
[00.874]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=400Mhz
[00.881]drv_disp_init
=== disp_init_lcd start ===
=== disp_lcd_init start ===
=== lcd_parse_panel_para start ====
=== lcd_parse_panel_para end ====
request pwm success, pwm0:pwm0:0x300a000.
=== disp_lcd_init end ===
=== lcd_init start ===
=== lcd_set_panel_funs start ====
=== sunxi_lcd_set_panel_funs start ====
=== lcd_set_panel_funs end ====
=== lcd_init end ===
[01.010]drv_disp_init finish
[01.016]gic: sec monitor mode
[01.018]flash init start
[01.021]workmode = 0,storage type = 2
[01.024][mmc]: mmc driver ver uboot2018:2020-5-25 9:26:00-2021-09-17 14:45:00
[01.032][mmc]: get sdc_type fail and use default host:tm4.
[01.043][mmc]: SUNXI SDMMC Controller Version:0x50300
[01.068][mmc]: Best spd md: 4-HS400, freq: 3-100000000, Bus width: 8
[01.074]sunxi flash init ok
[01.078]Loading Environment from SUNXI_FLASH... OK
[01.099]Item0 (Map) magic is bad
[01.102]the secure storage item0 copy0 magic is bad
[01.119]Item0 (Map) magic is bad
[01.121]the secure storage item0 copy1 magic is bad
[01.126]Item0 (Map) magic is bad
[01.129]usb burn from boot
delay time 0
weak:otg_phy_config
[01.140]usb prepare ok
[01.370]usb sof ok
[01.371]usb probe ok
[01.373]usb setup ok
set address 0x57
set address 0x57 ok
try to update
[04.380]do_burn_from_boot usb : have no handshake
[04.384]boot_gui_init:start
[04.389]set disp.dev2_output_type fail. using defval=0
[LCD] LCD_open_flow: sel=0
[LCD] LCD_cfg_panel_info: enter
[LCD] LCD_cfg_panel_info: exit
=LCD_power_on start=
=JD9366_WSVGANL_1024x600=
[LCD] LCD_power_on: panel=JD9366_WSVGANL_1024x600 sel=0
[LCD] LCD_power_on: power0 on
[LCD] LCD_power_on: power1 on
[LCD] LCD_power_on: power2 on
[LCD] LCD_power_on: gamma_en=1
[LCD] LCD_power_on: reset=1
[LCD] LCD_power_on: reset=0
[LCD] LCD_power_on: pin_cfg=1
=LCD_power_on end=
[LCD] LCD_panel_init: uboot, first cmd=0x11
[LCD] LCD_panel_init: dsi_clk_enable done
[LCD] LCD_trace_table_step: sel=0 step=0 cmd=0x11 count=0
[LCD] LCD_panel_send_cmd: sel=0 step=0 cmd=0x11 ret=0
[LCD] LCD_trace_table_step: sel=0 step=1 delay=250 ms
[LCD] LCD_trace_table_step: sel=0 step=2 cmd=0x29 count=0
[LCD] LCD_panel_send_cmd: sel=0 step=2 cmd=0x29 ret=0
[LCD] LCD_trace_table_step: sel=0 step=3 delay=50 ms
[LCD] LCD_trace_table_step: sel=0 step=4 end-of-table
[LCD] LCD_panel_init: finish
[04.976]boot_gui_init:finish
4096056 bytes read in 25 ms (156.3 MiB/s)
no support big size bmp[800x1280] on fb[1024x600]
[05.016]show bmp on fb failed !-1
[05.026]update dts
** Unrecognized filesystem type **
[05.039]load file(ULI/factory/snum.txt) error.
[05.054]load file(ULI/factory/mac.txt) error.
[05.069]load file(ULI/factory/wifi_mac.txt) error.
[05.085]load file(ULI/factory/bt_mac.txt) error.
[05.100]load file(ULI/factory/specialstr.txt) error.
[05.115]update part info
[05.149]update bootcmd
[05.178]soc ic_ver:0x6, qa_val:0x0, markid:0x1400 dclk[0-200] display_cfg_flag:0
[LCD] LCD_bl_open: PWM enable
[LCD] LCD_bl_open: backlight_en=1
[05.301]LCD open finish
[05.552]Starting kernel ...
[05.554][mmc]: mmc exit start
[05.572][mmc]: mmc 2 exit ok
[ 0.000000] Linux version 4.9.170 (ok@ok) (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05) ) #85 SMP PREEMPT Fri Mar 27 10:17:38 CST 2026
[ 0.000000] Boot CPU: AArch64 Processor [410fd034]
[ 0.000000] bootconsole [earlycon0] enabled
[ 0.000000] disp reserve base 0x7bf51140 ,size 0x258000
[ 0.000000] cma: Reserved 8 MiB at 0x000000007f800000
[ 0.000000] On node 0 totalpages: 262144
[ 0.000000] DMA zone: 4096 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 262144 pages, LIFO batch:31
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.0
[ 0.000000] percpu: Embedded 23 pages/cpu @ffffffc03f6e8000 s53376 r8192 d32640 u94208
[ 0.000000] pcpu-alloc: s53376 r8192 d32640 u94208 alloc=23*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for ARM erratum 845719
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 258048
[ 0.000000] Kernel command line: earlyprintk=sunxi-uart,0x05000000 initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mmcblk0p4 init=/init partitions=bootloader@mmcblk0p1:env@mmcblk0p2:boot@mmcblk0p3:super@mmcblk0p4:misc@mmcblk0p5:recovery@mmcblk0p6:cache@mmcblk0p7:vbmeta@mmcblk0p8:vbmeta_system@mmcblk0p9:vbmeta_vendor@mmcblk0p10:metadata@mmcblk0p11:private@mmcblk0p12:frp@mmcblk0p13:empty@mmcblk0p14:dtbo@mmcblk0p15:media_data@mmcblk0p16:UDISK@mmcblk0p17 cma=8M snum=6c000c81c504c8b241d mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.vbmeta.avb_version=2.0 androidboot.vbmeta.hash_alg=sha256 androidboot.vbmeta.size=7168 androidboot.vbmeta.digest=215d2a51b3f5d2f24e2a8064769fd6419c878d296abb6b91df0ba794dd3e7941 androidboot.vbmeta.device_state=locked androidboot.mode=normal androidboot.serialno=6c000c81c504c8b241d androidboot.hardware=sun50iw10p1 boot_type=2 androidboot.boot_type=2 androidboot.secure_os_exist=0 androidboot.trustchain=false gpt=1 uboot_message=2018.05(02/02/2[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.000000] Memory: 979588K/1048576K available (10942K kernel code, 2210K rwdata, 3948K rodata, 4288K init, 597K bss, 60796K reserved, 8192K cma-reserved)
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008b30000 ( 10944 KB)
[ 0.000000] .rodata : 0xffffff8008b30000 - 0xffffff8008f10000 ( 3968 KB)
[ 0.000000] .init : 0xffffff8008f10000 - 0xffffff8009340000 ( 4288 KB)
[ 0.000000] .data : 0xffffff8009340000 - 0xffffff8009568808 ( 2211 KB)
[ 0.000000] .bss : 0xffffff8009568808 - 0xffffff80095fdc78 ( 598 KB)
[ 0.000000] fixed : 0xffffffbefe7fb000 - 0xffffffbefec00000 ( 4116 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf01000000 ( 16 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc040000000 ( 1024 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (virt).
[ 0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.008169] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.018199] pid_max: default: 32768 minimum: 301
[ 0.023045] Security Framework initialized
[ 0.026878] SELinux: Initializing.
[ 0.030481] SELinux: Starting in permissive mode
[ 0.035136] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.041697] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.049583] ftrace: allocating 33773 entries in 132 pages
[ 0.132283] sched-energy: CPU device node has no sched-energy-costs
[ 0.132925] Invalid sched_group_energy for CPU0
[ 0.137465] CPU0: update cpu_capacity 1024
[ 0.151572] ASID allocator initialised with 32768 entries
[ 0.170598] nsi: no limit for F version(except 1080P-LP4)
[ 0.170846] BOOTEVENT: 170.841748: ON
[ 0.204847] Detected VIPT I-cache on CPU1
[ 0.204902] Invalid sched_group_energy for CPU1
[ 0.204905] CPU1: update cpu_capacity 1024
[ 0.204909] CPU1: Booted secondary processor [410fd034]
[ 0.228224] Detected VIPT I-cache on CPU2
[ 0.228252] Invalid sched_group_energy for CPU2
[ 0.228254] CPU2: update cpu_capacity 1024
[ 0.228257] CPU2: Booted secondary processor [410fd034]
[ 0.251642] Detected VIPT I-cache on CPU3
[ 0.251668] Invalid sched_group_energy for CPU3
[ 0.251671] CPU3: update cpu_capacity 1024
[ 0.251673] CPU3: Booted secondary processor [410fd034]
[ 0.251757] Brought up 4 CPUs
[ 0.302392] SMP: Total of 4 processors activated.
[ 0.307084] CPU features: detected feature: 32-bit EL0 Support
[ 0.312889] CPU features: detected feature: Kernel page table isolation (KPTI)
[ 0.323984] CPU: All CPU(s) started at EL1
[ 0.324160] alternatives: patching kernel code
[ 0.328764] Invalid sched_group_energy for CPU3
[ 0.333087] CPU3: update max cpu_capacity 1024
[ 0.337502] Invalid sched_group_energy for Cluster3
[ 0.342354] Invalid sched_group_energy for CPU2
[ 0.346862] Invalid sched_group_energy for Cluster2
[ 0.351714] Invalid sched_group_energy for CPU1
[ 0.356221] Invalid sched_group_energy for Cluster1
[ 0.361074] Invalid sched_group_energy for CPU0
[ 0.365582] Invalid sched_group_energy for Cluster0
[ 0.370986] CPU1: update max cpu_capacity 1024
[ 0.375592] devtmpfs: initialized
[ 0.423909] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.428048] futex hash table entries: 1024 (order: 5, 131072 bytes)
[ 0.434853] atomic64_test: passed
[ 0.437545] pinctrl core: initialized pinctrl subsystem
[ 0.445049] NET: Registered protocol family 16
[ 0.448573] dump_class_init,861, success
[ 0.467822] cpuidle: using governor menu
[ 0.469372] sunxi iommu: irq = 9
[ 0.470193] vdso: 2 pages (1 code @ ffffff8008b38000, 1 data @ ffffff8009344000)
[ 0.476724] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.484920] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.492791] sun50iw10p1-r-pinctrl r_pio: initialized sunXi PIO driver
[ 0.513362] sun50iw10p1-pinctrl pio: initialized sunXi PIO driver
[ 0.518043] iommu: Adding device 1c0e000.ve to group 0
[ 0.527068] iommu: Adding device soc@03000000:disp1@1 to group 0
[ 0.528292] iommu: Adding device 6000000.disp to group 0
[ 0.533312] iommu: Adding device 6400000.eink to group 0
[ 0.539190] iommu: Adding device 6480000.g2d to group 0
[ 0.547301] iommu: Adding device csi0 to group 0
[ 0.548252] iommu: Adding device csi1 to group 0
[ 0.553535] iommu: Adding device 2108000.tdm to group 0
[ 0.558083] iommu: Adding device 2100000.isp to group 0
[ 0.563296] iommu: Adding device 2102000.isp to group 0
[ 0.568309] iommu: Adding device 2110000.scaler to group 0
[ 0.573786] iommu: Adding device 2110400.scaler to group 0
[ 0.579220] iommu: Adding device 2110800.scaler to group 0
[ 0.584684] iommu: Adding device 2110c00.scaler to group 0
[ 0.590700] iommu: Adding device vinc0 to group 0
[ 0.594996] iommu: Adding device vinc1 to group 0
[ 0.599666] iommu: Adding device vinc2 to group 0
[ 0.604338] iommu: Adding device vinc3 to group 0
[ 0.650244] pwm module init!
[ 0.656080] sunxi-pm debug v3.10
[ 0.660420] SCSI subsystem initialized
[ 0.661202] usbcore: registered new interface driver usbfs
[ 0.664106] usbcore: registered new interface driver hub
[ 0.669424] usbcore: registered new device driver usb
[ 0.674531] sunxi_i2c_adap_init()2580 - init
[ 0.679139] sunxi_i2c_probe()2299 - [i2c6] twi_drv_used = 0
[ 0.684126] sunxi_i2c_probe()2303 - [i2c6] twi_pkt_interval = 0
[ 0.690032] twi6 supply twi not found, using dummy regulator
[ 0.695734] twi_request_gpio()454 - [i2c6] init name: twi6
[ 0.701776] axp20x-i2c 6-0034: AXP20x variant AXP803 found
[ 0.720058] axp2101-regulator axp2101-regulator.0: Setting DCDC frequency for unsupported AXP variant
[ 0.723658] axp2101-regulator axp2101-regulator.0: Error setting dcdc frequency: -22
[ 0.749167] random: fast init done
[ 0.806467] axp20x-i2c 6-0034: AXP20X driver loaded
[ 0.807146] sunxi_i2c_probe()2299 - [i2c0] twi_drv_used = 0
[ 0.811292] sunxi_i2c_probe()2303 - [i2c0] twi_pkt_interval = 0
[ 0.817211] twi0 supply twi not found, using dummy regulator
[ 0.822896] twi_request_gpio()454 - [i2c0] init name: twi0
[ 0.829319] sunxi_i2c_probe()2299 - [i2c1] twi_drv_used = 0
[ 0.833824] sunxi_i2c_probe()2303 - [i2c1] twi_pkt_interval = 0
[ 0.839755] twi1 supply twi not found, using dummy regulator
[ 0.845413] twi_request_gpio()454 - [i2c1] init name: twi1
[ 0.851858] sunxi_i2c_probe()2299 - [i2c2] twi_drv_used = 0
[ 0.856363] sunxi_i2c_probe()2303 - [i2c2] twi_pkt_interval = 0
[ 0.862754] twi_request_gpio()454 - [i2c2] init name: twi2
[ 0.868692] sunxi_i2c_probe()2299 - [i2c3] twi_drv_used = 0
[ 0.873262] sunxi_i2c_probe()2303 - [i2c3] twi_pkt_interval = 0
[ 0.879174] twi3 supply twi not found, using dummy regulator
[ 0.884867] twi_request_gpio()454 - [i2c3] init name: twi3
[ 0.891036] media: Linux media interface: v0.10
[ 0.894802] Linux video capture interface: v2.00
[ 0.900457] ion_parse_dt_heap_common: id 0 type 0 name sys_user align 1000
[ 0.906411] ion_parse_dt_heap_common: id 4 type 4 name cma align 1000
[ 0.912781] ion_parse_dt_heap_common: id 6 type 6 name secure align 1000
[ 0.919590] drm config service not available: FFFFFFFF
[ 0.924777] Advanced Linux Sound Architecture Driver Initialized.
[ 0.931175] Bluetooth: Core ver 2.22
[ 0.934054] NET: Registered protocol family 31
[ 0.938412] Bluetooth: HCI device and connection manager initialized
[ 0.944755] Bluetooth: HCI socket layer initialized
[ 0.949599] Bluetooth: L2CAP socket layer initialized
[ 0.954667] Bluetooth: SCO socket layer initialized
[ 0.960895] clocksource: Switched to clocksource arch_sys_counter
[ 1.035630] VFS: Disk quotas dquot_6.6.0
[ 1.035779] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.043810] udc_init,0
[ 1.045134] NET: Registered protocol family 2
[ 1.067765] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 1.069237] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
[ 1.075827] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.082095] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 1.087935] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 1.094576] NET: Registered protocol family 1
[ 1.098874] Trying to unpack rootfs image as initramfs...
[ 1.131844] Freeing initrd memory: 752K
[ 1.133500] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.140691] audit: initializing netlink subsys (disabled)
[ 1.143240] audit: type=2000 audit(0.933:1): initialized
[ 1.149532] workingset: timestamp_bits=45 max_order=18 bucket_order=0
[ 1.166613] Registering sdcardfs 0.1
[ 1.167182] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.169408] fuse init (API version 7.26)
[ 1.175215] SELinux: Registering netfilter hooks
[ 1.182170] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 1.184863] io scheduler noop registered
[ 1.188859] io scheduler deadline registered
[ 1.193265] io scheduler cfq registered (default)
[ 1.199850] [DISP]disp_module_init
[ 1.201518] disp soc@03000000:disp1@1: unable to map de registers
[ 1.207169] disp: probe of soc@03000000:disp1@1 failed with error -22
[ 1.214438] [DISP] disp_init,line:2345:
[ 1.217168] smooth display screen:0 type:1 mode:4
[ 1.258868] [LCD] LCD_cfg_panel_info: enter
[ 1.258916] [LCD] LCD_cfg_panel_info: exit
[ 1.265574] [DISP] Fb_copy_boot_fb,line:1645:
[ 1.265653] no boot_fb0
[ 1.269503] [DISP] lcd_clk_config,line:699:[ 1.271647] [DISP]disp_module_init finish
[ 1.276249] disp 0,
[END] 2026/3/27 10:31:07
