正在学习开发V821的低功耗模式,固件启动介质是TF卡。使用的模板固件是v821-perf2b_fastboot-tina。
开发板是自制的。电源部分原理图参考perf2b,芯片是V821L2-WXX。
硬件未链接摄像头。PL3为配置为唤醒源。
使用SDK为tina-v821-v1.3
root@(none):/# echo 1 > /sys/class/ae350_standby/use_ultra_standby
ac327 send hard syn message: 0x80300202
ac327 receive hard syn message feedback: 0x300202
root@(none):/# poweroff
The system is going down NOW!
Sent SIGTERM to all processes
Requesting system poweroff
ac327 send hard syn message: 0x260202
ac327 receive hard syn message feedback: 0x260202
ac327 send hard syn message: 0x280202
ac327 receive hard syn message feedback: 0x280202
[ 661.055340] reboot: Power down
ae350_system_reset(): CPU[0] SHUTDOWN
ac327 send hard syn message: 0x80240202
ac327 receive hard syn message feedback: 0x240202[634.384][PLAT_LOG]STEP_REC_HEAD state: 0x02 attr: 0x02 type: 0x30
[634.385][PLAT_LOG]STEP_REC_LEN cnt: 0x0000 len: 0x0001
[661.080][PLAT_LOG]STEP_REC_HEAD state: 0x02 attr: 0x02 type: 0x26
[661.081][PLAT_LOG]STEP_REC_LEN cnt: 0x0000 len: 0x0001
[661.086][PLAT_LOG]STEP_REC_HEAD state: 0x02 attr: 0x02 type: 0x26
[661.086][PLAT_LOG]STEP_REC_LEN cnt: 0x0000 len: 0x0001
[661.099][PLAT_LOG]STEP_REC_HEAD state: 0x02 attr: 0x02 type: 0x28
[661.100][PLAT_LOG]STEP_REC_LEN cnt: 0x0000 len: 0x0001
[661.112][PLAT_LOG]STEP_REC_HEAD state: 0x02 attr: 0x02 type: 0x24
[661.112][PLAT_LOG]STEP_REC_LEN cnt: 0x0000 len: 0x0001
[661.113][PLAT_LOG]enter ultra standby
[661.116][VIN]csi_link_deinit standby_mode is 1
[661.121][RPBUF_INFO][rpbuf_free_buffer_internal:1391]buffer "isp0_load_rpbuf" (id:2): buffers -> remote_dummy_buffers
[661.132][RPBUF_INFO][rpbuf_free_buffer_internal:1391]buffer "isp0_save_rpbuf" (id:3): buffers -> remote_dummy_buffers
[661.143][RPBUF_INFO][rpbuf_free_buffer_internal:1391]buffer "isp0_ldci_rpbuf" (id:4): buffers -> remote_dummy_buffers
[661.154][ISP]isp0 exit end!!!
[661.157]wlan_fmac_xrlink_deinit start
[661.160]xrlink txrx deinit finish.
[661.164][RPBUF_INFO][rpbuf_free_buffer_internal:1391]buffer "xradio_mtx" (id:0): buffers -> remote_dummy_buffers
[661.174][RPBUF_INFO][rpbuf_free_buffer_internal:1391]buffer "xradio_mrx" (id:1): buffers -> remote_dummy_buffers
[661.185]rpmsg_xradio_deinit
[661.188][RV] [AMP_INFO][rpmsg_unregister_driver:218]Unsupport rpmsg_unregister_driver
[661.874]hal_msgbox_channel_send_data(764): message queue is full for a long time!!!
[661.875][RV] [AMP_ERR][msgbox_ipi_notify:211]rv-vring-ipi: Failed to send message to remote
[661.879][RV] [AMP_ERR][rproc_common_notify:261]rv-vring-ipi (id: 0) notify failed
[662.566]hal_msgbox_channel_send_data(764): message queue is full for a long time!!!
[662.566][RV] [AMP_ERR][msgbox_ipi_notify:211]rv-vring-ipi: Failed to send message to remote
[662.571][RV] [AMP_ERR][rproc_common_notify:261]rv-vring-ipi (id: 0) notify failed
[663.257]hal_msgbox_channel_send_data(764): message queue is full for a long time!!!
[663.257][RV] [AMP_ERR][msgbox_ipi_notify:211]rv-vring-ipi: Failed to send message to remote
[663.262][RV] [AMP_ERR][rproc_common_notify:261]rv-vring-ipi (id: 0) notify failed
[663.270][RV] [AMP_INFO][rproc_common_remove:100]remove rproc...小核在remove rproc...后,串口循环打印乱码,此时小核应当是跑飞了,电源控制引脚,PL0,PL1,PL2,PL6均未拉低
[全志在线-V821-Standby-休眠唤醒]https://docs.aw-ol.com/docs/soc/v821/system/standby
参考此资料对代码进行调整。
Tina_Linux_快启功耗管理_开发指南.md.txt
=================分割线===================
请各位大佬有空的时候指导我一下,应当从哪里排查问题。 ![]()
最近编辑记录 粗制乱造_0b1cd9a8 (今天 11:58:57)
看日志的话,我觉得重点不在 poweroff 本身,而是在小核进入 ultra standby 以后,仍然有 AMP/rpmsg/rproc 相关路径在试图和“大核/远端”通信,最后卡在 msgbox 队列满,然后走到 rproc_common_remove() 后异常。这个更像是 standby 收尾顺序或某个外设/AMP 资源没有正确静默,而不是单纯 GPIO 配置问题。
可以按下面几条线排:
先把 WiFi / ISP / VIN / camera 相关功能彻底裁掉验证
你硬件没有接摄像头,但小核日志里仍然有:
buffer "isp0_load_rpbuf" ...
rpmsg_xradio_deinit这说明小核的低功耗流程里还在跑 ISP/VIN/WLAN/XRadio 相关 deinit。自制板如果没有摄像头、没有 WiFi,建议先做一个“最小系统 standby”镜像:
dts 里 disable vin/isp/csi 相关节点;
disable wlan/xradio 相关节点和固件加载;
Tina menuconfig 里能关的 ISP/VIN/WLAN/RPBUF demo 先关掉;
小核工程里如果有对应模块初始化,也先裁掉或让 deinit 直接返回。
如果裁掉后能正常拉低 PL0/PL1/PL2/PL6,说明问题就在这些 AMP 外设资源释放顺序上。
重点查 hal_msgbox_channel_send_data queue is full 的发送方
这条日志很关键:
rproc_common_notify: notify failed进入 ultra standby 后,大核已经在关机/停 remoteproc 流程里了,但小核还在通过 vring/msgbox 发 notify。正常低功耗流程应该先停止业务线程、停止 rpmsg/rpbuf 发送,再关 IPI/msgbox/rproc。如果顺序反了,就会出现发送队列满、notify failed,后面 remove rproc 时更容易跑飞。
建议在小核代码里给以下函数加调用栈/模块名 log:
hal_msgbox_channel_send_data()
msgbox_ipi_notify()
rproc_common_notify()
rpmsg_xradio_deinit()
rpbuf_free_buffer_internal()目标是确认到底是谁在 standby 期间最后还在发 IPI。尤其是 rpbuf_free_buffer_internal() 释放 buffer 时是否会通知 remote,如果 remote 已经停了,这里就不应该继续 notify。
确认 standby 命令和电源模式是否匹配
你现在是:
poweroff这条路径走的是“关机 + ultra standby”的组合,和普通 mem suspend 不是一回事。建议对照文档确认当前 SDK 推荐入口,是不是还需要配置 standby bin / cpusys / wakeup source / power domain。可以分别测:
echo mem > /sys/power/state以及你现在的 poweroff 路径,看是哪一条会触发跑飞。如果 mem 正常、poweroff 异常,那问题基本就在 fastboot/poweroff ultra standby 的收尾流程;如果两条都异常,再看小核通用 standby 流程。
PL0/PL1/PL2/PL6 未拉低,可能是流程还没走到 PMIC/GPIO poweroff 阶段
现在日志停在:
remove rproc...后面乱码,说明还没完成最终电源控制动作。也就是说 PL0/PL1/PL2/PL6 没拉低不一定是 pinmux 配错,而可能是小核在执行电源控制前已经异常了。
建议在小核控制 PL0/PL1/PL2/PL6 的函数前后加 log,例如:
printf("standby: before power gpio off
printf("standby: set PL0/PL1/PL2/PL6 low
printf("standby: after power gpio off
");如果这些 log 没出现,先解决前面的 rpmsg/msgbox/rproc;如果出现了但电平没变,再查 pinmux、gpio bank 电源域、是否被其它功能复用。
自制板还要核对 RTC/PL 电源域和唤醒脚
PL3 配唤醒源时,需要确认:
PL bank 在 ultra standby 下是否仍有供电;
PL3 的上下拉和有效电平是否正确;
唤醒源配置是否写入小核/standby 固件实际使用的配置,而不仅是 Linux dts;
参考板上由 PMIC 或外部电源控制的 rail,你的板子是否等价。
不过从你当前日志看,优先级还是 msgbox queue full -> rproc remove -> 乱码 这条链。
我建议先做一个最小化实验:
关闭 VIN/ISP/WLAN/XRadio;
保留串口、PL3 唤醒、必要电源 GPIO;
重新测 use_ultra_standby + poweroff;
在 rproc_common_remove() 后面、真正拉 GPIO 前后加 log。
如果最小系统可以进休眠,再逐个打开 ISP/WLAN 等模块,就能定位是哪一个 deinit 阶段把 msgbox/rpmsg 搞挂。现在这份日志里最可疑的是 WLAN/XRadio 的 rpmsg 注销和 rpbuf 释放顺序。
