最近想用一下 AP模式,按下面操作还是无法配置成功。我把我的操作流程贴出来:
1、首先用Buildroot 把hostapd 、openssl、dhcp (ISC)都加到了 文件系统中,
2、我用的是F1C100S芯片,用的是linux 4.19的内核,ESP8089的源码是荔枝派给的,移植成功了,可以成功连接WIFI。
3、hostapd.conf 的文件如下
ctrl_interface=/var/run/hostapd
#change wlan0 to your wireless device
interface=wlan0
driver=nl80211
ssid=Linux /* 名字 */
channel=1
# 认证/加密方式
macaddr_acl=0
auth_algs=1
ignore_broadcast_ssid=0
wpa=3
wpa_passphrase=linuxdrv /* 密码*/
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP 4、启动流程如下
modprobe esp8089.ko config=crystal_26M_en=1
ifconfig wlan0 up
ifconfig wlan0 172.16.1.1 netmask 255.255.255.0
route add default gw 172.16.1.1 /* 这两条路由命令需要添加 */
route add default gw 172.16.148.111
echo 1 > /proc/sys/net/ipv4/ip_forward /* 打开IP转发 */
dhcpd -cf /etc/dhcp/dhcpd.conf wlan0 &
hostapd -d /etc/hostapd.conf 打印的日志 如下
Your text here
ctrl_interface_group=0
nl80211: Supported cipher 00-0f-ac:1
nl80211: Supported cipher 00-0f-ac:5
nl80211: Supported cipher 00-0f-ac:2
nl80211: Supported cipher 00-0f-ac:4
nl80211: Using driver-based off-channel TX
nl80211: Driver-advertised extended capabilities (default) - hexdump(len=8): 00 00 00 00 00 00 00 40
nl80211: Driver-advertised extended capabilities mask (default) - hexdump(len=8): 00 00 00 00 00 00 00 40
nl80211: interface wlan0 in phy phy0
nl80211: Set mode ifindex 3 iftype 3 (AP)
nl80211: Setup AP(wlan0) - device_ap_sme=0 use_monitor=0
nl80211: Subscribe to mgmt frames with AP handle 0x10078b0
nl80211: Register frame type=0xb0 (WLAN_FC_STYPE_AUTH) nl_handle=0x10078b0 match=
nl80211: Register frame type=0x0 (WLAN_FC_STYPE_ASSOC_REQ) nl_handle=0x10078b0 match=
nl80211: Register frame type=0x20 (WLAN_FC_STYPE_REASSOC_REQ) nl_handle=0x10078b0 match=
nl80211: Register frame type=0xa0 (WLAN_FC_STYPE_DISASSOC) nl_handle=0x10078b0 match=
nl80211: Register frame type=0xc0 (WLAN_FC_STYPE_DEAUTH) nl_handle=0x10078b0 match=
nl80211: Register frame type=0x40 (WLAN_FC_STYPE_PROBE_REQ) nl_handle=0x10078b0 match=
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x10078b0 match=04
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x10078b0 match=0501
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x10078b0 match=0504
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x10078b0 match=06
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x10078b0 match=08
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x10078b0 match=09
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x10078b0 match=0a
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x10078b0 match=11
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x10078b0 match=7f
rfkill: initial event: idx=0 type=1 op=0 soft=0 hard=0
nl80211: Add own interface ifindex 3 (ifidx_reason -1)
nl80211: if_indices[16]: 3(-1)
phy: phy0
BSS count 1, BSSID mask 00:00:00:00:00:00 (0 bits)
nl80211: Regulatory information - country=00
nl80211: 2402-2472 @ 40 MHz 20 mBm
nl80211: 2457-2482 @ 20 MHz 20 mBm (no IR)
nl80211: 2474-2494 @ 20 MHz 20 mBm (no OFDM) (no IR)
nl80211: 5170-5250 @ 80 MHz 20 mBm (no IR)
nl80211: 5250-5330 @ 80 MHz 20 mBm (DFS) (no IR)
nl80211: 5490-5730 @ 160 MHz 20 mBm (DFS) (no IR)
nl80211: 5735-5835 @ 80 MHz 20 mBm (no IR)
nl80211: 57240-63720 @ 2160 MHz 0 mBm
nl80211: Added 802.11b mode based on 802.11g information
Completing interface initialization
Mode: IEEE 802.11g Channel: 1 Frequency: 2412 MHz
DFS 0 channels required radar detection
nl80211: Set freq 2412 (ht_enabled=0, vht_enabled=0, bandwidth=20 MHz, cf1=2412 MHz, cf2=0 MHz)
* freq=2412
* vht_enabled=0
* ht_enabled=0
* channel_type=0
RATE[0] rate=10 flags=0x1
RATE[1] rate=20 flags=0x1
RATE[2] rate=55 flags=0x1
RATE[3] rate=110 flags=0x1
RATE[4] rate=60 flags=0x0
RATE[5] rate=90 flags=0x0
RATE[6] rate=120 flags=0x0
RATE[7] rate=180 flags=0x0
RATE[8] rate=240 flags=0x0
RATE[9] rate=360 flags=0x0
RATE[10] rate=480 flags=0x0
RATE[11] rate=540 flags=0x0
hostapd_setup_bss(hapd=0x1007110 (wlan0), first=1)
wlan0: Flushing old station entries
nl80211: flush -> DEL_STATION wlan0 (all)
wlan0: Deauthenticate all stations
nl80211: send_mlme - da= ff:ff:ff:ff:ff:ff noack=0 freq=0 no_cck=0 offchanok=0 wait_time=0 fc=0xc0 (WLAN_FC_STYPE_DEAUTH) nlmode=3
nl80211: send_mlme -> send_frame
nl80211: send_frame - Use bss->freq=2412
nl80211: send_frame -> send_frame_cmd
nl80211: Frame command failed: ret=-16 (Device or resource busy) (freq=2412 wait=0)
wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=0 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=1 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=2 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=3 set_tx=0 seq_len=0 key_len=0
Using interface wlan0 with hwaddr ac:d0:74:1f:61:16 and ssid "test_zj"
Deriving WPA PSK based on passphrase
SSID - hexdump_ascii(len=7):
74 65 73 74 5f 7a 6a test_zj
PSK (ASCII passphrase) - hexdump_ascii(len=8): [REMOVED]
PSK (from passphrase) - hexdump(len=32): [REMOVED]
random: Got 20/20 bytes from /dev/random
GMK - hexdump(len=32): [REMOVED]
Key Counter - hexdump(len=32): [REMOVED]
WPA: Delay group state machine start until Beacon frames have been configured
nl80211: Set beacon (beacon_set=0)
nl80211: Beacon head - hexdump(len=58): 80 00 00 00 ff ff ff ff ff ff ac d0 74 1f 61 16 ac d0 74 1f 61 16 00 00 00 00 00 00 00 00 00 00 64 00 11 04 00 07 74 65 73 74 5f 7a 6a 01 08 82 84 8b 96 0c 12 18 24 03 01 01
nl80211: Beacon tail - hexdump(len=91): 2a 01 04 32 04 30 48 60 6c 30 14 01 00 00 0f ac 02 01 00 00 0f ac 04 01 00 00 0f ac 02 0c 00 dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02 7f 08 00 00 00 00 00 00 00 40 dd 18 00 50 f2 02 01 01 00 00 03 a4 00 00 27 a4 00 00 42 43 5e 00 62 32 2f 00
nl80211: ifindex=3
nl80211: beacon_int=100
nl80211: dtim_period=2
nl80211: ssid - hexdump_ascii(len=7):
* beacon_int=100
* dtim_period=2
nl80211: hidden SSID not in use
nl80211: privacy=1
nl80211: auth_algs=0x1
nl80211: wpa_version=0x3
nl80211: key_mgmt_suites=0x2
nl80211: pairwise_ciphers=0x18
nl80211: group_cipher=0x8
nl80211: beacon_ies - hexdump(len=10): 7f 08 00 00 00 00 00 00 00 40
nl80211: proberesp_ies - hexdump(len=10): 7f 08 00 00 00 00 00 00 00 40
nl80211: assocresp_ies - hexdump(len=10): 7f 08 00 00 00 00 00 00 00 40
WPA: Start group state machine to set initial keys
WPA: group state machine entering state GTK_INIT (VLAN-ID 0)
GTK - hexdump(len=32): [REMOVED]
WPA: group state machine entering state SETKEYSDONE (VLAN-ID 0)
wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=2 addr=0xb911f key_idx=1 set_tx=1 seq_len=0 key_len=32
nl80211: KEY_DATA - hexdump(len=32): [REMOVED]
broadcast key
nl80211: Set wlan0 operstate 0->1 (UP)
netlink: Operstate: ifindex=3 linkmode=-1 (no change), operstate=6 (IF_OPER_UP)
wlan0: interface state UNINITIALIZED->ENABLED
wlan0: AP-ENABLED
wlan0: Setup of interface done.
ctrl_iface not configured!离线
日志 如下
# modprobe esp8089.ko config=crystal_26M_en=1
[ 1067.284412] mmc0: card 0001 removed
[ 1067.339992] mmc0: queuing unknown CIS tuple 0x01 (3 bytes)
[ 1067.353024] mmc0: queuing unknown CIS tuple 0x1a (5 bytes)
[ 1067.362974] mmc0: queuing unknown CIS tuple 0x1b (8 bytes)
[ 1067.371380] mmc0: queuing unknown CIS tuple 0x80 (1 bytes)
[ 1067.378339] mmc0: queuing unknown CIS tuple 0x81 (1 bytes)
[ 1067.384089] mmc0: queuing unknown CIS tuple 0x82 (1 bytes)
[ 1067.389661] mmc0: new high speed SDIO card at address 0001
# ifconfig wlan0 up
# ifconfig wlan0 192.168.2.1 netmask 255.255.255.0
# route add default gw 192.168.2.1
# route add default gw 192.168.148.111
# echo 1 > /proc/sys/net/ipv4/ip_forward
# ifconfig
lo Link encap:Local Loopback
UP LOOPBACK RUNNING MTU:65536 Metric:1
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
wlan0 Link encap:Ethernet HWaddr AC:D0:74:1F:61:16
inet addr:192.168.2.1 Bcast:192.168.2.255 Mask:255.255.255.0
UP BROADCAST MULTICAST MTU:1500 Metric:1
# hostapd -d -B /etc/hostapd.conf
random: Trying to read entropy from /dev/random
Configuration file: /etc/hostapd.conf
nl80211: Subscribe to mgmt frames with AP handle 0x18d8b0
nl80211: Register frame type=0xb0 (WLAN_FC_STYPE_AUTH) nl_handle=0x18d8b0 match=
nl80211: Register frame type=0x0 (WLAN_FC_STYPE_ASSOC_REQ) nl_handle=0x18d8b0 match=
nl80211: Register frame type=0x20 (WLAN_FC_STYPE_REASSOC_REQ) nl_handle=0x18d8b0 match=
nl80211: Register frame type=0xa0 (WLAN_FC_STYPE_DISASSOC) nl_handle=0x18d8b0 match=
nl80211: Register frame type=0xc0 (WLAN_FC_STYPE_DEAUTH) nl_handle=0x18d8b0 match=
nl80211: Register frame type=0x40 (WLAN_FC_STYPE_PROBE_REQ) nl_handle=0x18d8b0 match=
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x18d8b0 match=04
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x18d8b0 match=0501
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x18d8b0 match=0504
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x18d8b0 match=06
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x18d8b0 match=08
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x18d8b0 match=09
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x18d8b0 match=0a
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x18d8b0 match=11
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x18d8b0 match=7f
phy: phy0
* freq=2412
* vht_enabled=0
* ht_enabled=0
* channel_type=0
hostapd_setup_bss(hapd=0x18d110 (wlan0), first=1)
Using interface wlan0 with hwaddr ac:d0:74:1f:61:16 and ssid "zhuajian"
SSID - hexdump_ascii(len=8):
7a 68 75 61 6a 69 61 6e zhuajian
nl80211: Beacon head - hexdump(len=59): 80 00 00 00 ff ff ff ff ff ff ac d0 74 1f 61 16 ac d0 74 1f 61 16 00 00 00 00 00 00 00 00 00 00 64 00 11 04 00 08 7a 68 75 61 6a 69 61 6e 01 08 82 84 8b 96 0c 12 18 24 03 01 01
nl80211: ifindex=3
nl80211: ssid - hexdump_ascii(len=8):
* beacon_int=100
* dtim_period=2
nl80211: privacy=1
broadcast key
wlan0: AP-ENABLED
请问 esp8089 源码在哪里下载的呢?
看日志貌似成功了,现在手机能搜索到热点吗?
这里下载的 https://github.com/Lichee-Pi
手机搜索不到。
ESP8089可以在STA模式下连接WIFI ,但是我配置AP模式不能工作,这个可能是驱动的问题吗?
V3s camdroid 也是用 ESP8089,可以做热点,你可以了解一下,看看有什么不同
之前在v3s上试过是可以的:
dnsmasq.conf:
interface=wlan0
bind-interfaces
except-interface=lo
#dhcp-range=192.168.2.100,192.168.2.109,2h #设置dhcp地址范围hostapd.conf:
interface=wlan0
driver=nl80211
ssid=mywifi
channel=1
wmm_enabled=0
wpa=3
wpa_passphrase=wa12345678
wpa_pairwise=TKIP
rsn_pairwise=CCMP
auth_algs=1
macaddr_acl=0 配置wifi:
insmod /lib/modules/esp8089.ko
ifconfig wlan0 192.168.2.234 netmask 255.255.255.0 up
route add default gw 192.168.2.1启动dnsmasq:
dnsmasq -i wlan0 --dhcp-range=192.168.2.100,192.168.2.109,2h开启热点:
hostapd /etc/hostapd.conf&顺带一提 esp8089连接WiFi成功后会崩溃吗 之前试的时候会不定时崩溃 就换了模块
我这个是在主线linux上,V3S应该是全志的SDK,不知道是不是这个的原因,我按照你的再试下。
我在F1C100S上用ESP8089没有出现过崩溃。
木子猫 wrote:
之前在v3s上试过是可以的:
dnsmasq.conf:interface=wlan0
bind-interfaces
except-interface=lo
interface=wlan0
driver=nl80211
ssid=mywifi
channel=1
wmm_enabled=0
wpa=3
wpa_pairwise=TKIP
rsn_pairwise=CCMP
auth_algs=1
macaddr_acl=0配置wifi:
我看了下海豚派的ESP8089驱动,感觉这个是全志自己移植过的,驱动里面很多全志专有的函数和变量
楼主, 我加载驱动时也有上面这个,另外还有下面这些:
[ 5.414933] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 53, RTO EBE !!
[ 5.414981] [mmc]: found data error, need to send stop command !!
[ 5.415010] [mmc]: *** sunxi_mci_send_manual_stop(L795): sdc 1 send stop command failed
[ 5.666111] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 53, RTO EBE !!
[ 5.666159] [mmc]: found data error, need to send stop command !!
[ 5.666188] [mmc]: *** sunxi_mci_send_manual_stop(L795): sdc 1 send stop command failed
楼主知道是怎么回事吗? 另外,想问一下,esp8089是 firmware 是如何加载的, 要将firmware 拷贝到lib/firmware目录?
我在F1C100S上用ESP8089没有出现过崩溃。木子猫 wrote:
之前在v3s上试过是可以的:
bind-interfaces
except-interface=lo
interface=wlan0
driver=nl80211
ssid=mywifi
channel=1
wmm_enabled=0
wpa=3
wpa_pairwise=TKIP
rsn_pairwise=CCMP
auth_algs=1
我在v3s下也是用的主线
Your text here
这个是我做的笔记 应该对你有用
[ 1067.389661] mmc0: new high speed SDIO card at address 0001楼主, 我加载驱动时也有上面这个,另外还有下面这些:
[ 5.666188] [mmc]: *** sunxi_mci_send_manual_stop(L795): sdc 1 send stop command failed楼主知道是怎么回事吗? 另外,想问一下,esp8089是 firmware 是如何加载的, 要将firmware 拷贝到lib/firmware目录?
方便把ESP8089的源码提供一下吗? 主线版本是多少?
之前在v3s上试过是可以的:
bind-interfaces
except-interface=lo
interface=wlan0
driver=nl80211
ssid=mywifi
channel=1
wmm_enabled=0
wpa=3
wpa_pairwise=TKIP
rsn_pairwise=CCMP
auth_algs=1
我在v3s下也是用的主线
谢谢楼主, 迟点我试一下你的源码和方法
有没有人 能发一下成功的log给我看一下,我好有个对比。
木子猫 wrote:
我在F1C100S上用ESP8089没有出现过崩溃。我在v3s下也是用的主线
8089的源码就是drivers目录下的 主线是4.10
你是在那个板子上用的SDK? 海豚派、彩虹派,荔枝派? 方便把你的调试信息发出来吗? 或者您能不能加一下我QQ 903853013 这个我弄了很久。。。。
木子猫 wrote:
木子猫 wrote:
我在v3s下也是用的主线
之前是4.10 因为那个联网老是崩溃就换成 8723了 4.13的内核 荔枝派 文件系统还是原来的 流程也没变 直接也是可以执行成功开启热点的 这个不会插图
驱动呢,能麻烦把驱动上传一下吗!谢了,可以加一下你的QQ吗,你QQ多少?
HELLO! BOOT0 is starting!
boot0 version : 4.0.0
boot0 commit : 8
fel flag = 0x00000000
rtc[0] value = 0x00000000
rtc[1] value = 0x00000000
rtc[2] value = 0x00000000
rtc[3] value = 0x00000000
rtc[4] value = 0x00000000
rtc[5] value = 0x00000000
rtc[6] value = 0x80000000
rtc[7] value = 0x00000005
DRAM DRIVE INFO: V0.7
DRAM Type = 2 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3)
DRAM CLK = 360 MHz
DRAM zq value: 000039bb
DRAM size = 64 MB
dram size =64
Reg 0x01c20848: 0x00003333
0x01c20028 0x90041811
0x01c200a0 0x8100000f
spinand UBOOT_LAST_BLK_NUM 19
Succeed in opening spi nand flash.
Succeed in reading Boot1 file head.
current block is 2.
current block is 3.
current block is 4.
current block is 5.
current block is 6.
current block is 7.
sum=5e56afaa
src_sum=5e56afaa
The file stored in block 2 to block 6 is perfect.
----------storage_type = 5 in boot0-------------------------
Ready to disable icache.
Jump to secend Boot.
[ 0.498]
U-Boot 2011.09-rc1 (Nov 13 2018 - 15:47:40) Allwinner Technology
[ 0.505]version: 1.1.0
[ 0.508]uboot commit : 8
[ 0.514]pmbus: ready
not set main pmu id
axp_probe error
[ 0.520]PMU: pll1 408 Mhz,PLL6=600 Mhz
AXI=204 Mhz,AHB=204 Mhz, APB1=102 Mhz
set power on vol to default
dcdc2_vol = 1200
axp set dcdc2_vol to 1200 failed
dcdc3_vol = 3300
axp set dcdc3_vol to 3300 failed
aldo2_vol = 2500
axp set aldo2_vol to 2500 failed
aldo3_vol = 3000
axp set aldo3_vol to 3000 failed
ldo1_vol = 3300
axp set ldo1_vol to 3300 failed
ldo2_vol = 3000
axp set ldo2_vol to 3000 failed
ldo3_vol = 3000
axp set ldo3_vol to 3000 failed
find power_sply to end
vbus exist
no battery, limit to dc
no key input
dram_para_set start
dram_para_set end
[ 0.651]DRAM: 64 MiB
relocation Offset is: 0309c000
save config for small mem_size
workmode = 0
storage type = 5
[ 0.749]SPINAND: NAND_UbootInit
NAND_UbootInit start
NB1 : enter NAND_LogicInit
NandHwInit: Start Nand Hardware initializing .....
uboot:nand version: 2 25 20150917 1145
Reg 0x01c20848: 0x3333
Reg 0x01c2085c: 0x55
Reg 0x01c20864: 0x10
uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x43a31aa0
request general tx dma channel ok!
uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x43a31abc
request general rx dma channel ok!
SPI nand ID: 12c212c2 12c212c2
[SCAN_DBG] NandTwoPlaneOp: 1, DriverTwoPlaneOPCfg: 1, 0xffcfffff
nand : get id_number_ctl fail, a
_UpdateExtAccessFreqPara: no para.
PHY_Scan_DelayMode: right delay mode 0x0
PHY_Scan_DelayMode: right delay mode 0x800
PHY_Scan_DelayMode: right delay mode,clk 75 MHz, bit[13]=0,bit[11]=1
_GetOldPhysicArch: chip 0, block 20, page 0, oob: 0x0, 0x50, 0x48, 0x59
_GetOldPhysicArch: get old physic arch ok, 0x6d 0x2!
NAND_ReadPhyArch: get old physic arch ok, use old cfg, now:0x2 0x6d - old:0x2 0x6d!
[SCAN_DBG] ==============Nand Architecture Parameter==============
[SCAN_DBG] Nand Chip ID: 0xffff12c2 0xffffffff
[SCAN_DBG] Nand Chip Count: 0x1
[SCAN_DBG] Nand Chip Connect: 0x1
[SCAN_DBG] Sector Count Of Page: 0x4
[SCAN_DBG] Page Count Of Block: 0x40
[SCAN_DBG] Block Count Of Die: 0x400
[SCAN_DBG] Plane Count Of Die: 0x2
[SCAN_DBG] Die Count Of Chip: 0x1
[SCAN_DBG] Bank Count Of Chip: 0x1
[SCAN_DBG] Optional Operation: 0x6d
[SCAN_DBG] Access Frequence: 0x4b
[SCAN_DBG] =======================================================
[FORMAT_DBG] ===========Logical Architecture Parameter===========
[FORMAT_DBG] Page Count of Logic Block: 0x40
[FORMAT_DBG] Sector Count of Logic Page: 0x8
[FORMAT_DBG] Block Count of Die: 0x200
[FORMAT_DBG] Die Count: 0x1
[FORMAT_DBG] ===================================================
nand:found factory_bad_block(new version) table in block:26!
nand:support secure storage
secure storage updata ok!
nand secure storage ok: 21,22
NandHwInit: End Nand Hardware initializing ..... OK!
nand : get CapacityLevel fail, a
not burn nand partition table!
start block:23
[NE]mbr read 12
[NE]mbr read ok!
[NE]mbr read end!
[NE]mbr partition start!
[NE]mbr partition ok!
[NE]mbr partition end!
[NE]new nand info init!!
[NE]mbr read 12
[NE]mbr read ok!
[NE]mbr read end!
[NE]get mbr_data table
[ND]ok get factory_bad_block table!
[NE]new_bad_block table new format!
[ND]ok get a new bad table!
[ND]build all_phy partition start!
[NE]partition_num: 0,size :0x36400,cross_talk 0
[NE]part mbr size: 0x800 type: 0
[NE]part bootloader size: 0x4000 type: 0
[NE]part env size: 0x400 type: 0
[NE]part boot size: 0x4000 type: 0
[NE]part system size: 0x2d000 type: 0
[NE]part UDISK size: 0x800 type: 0
[ND]build 1 phy_partition !
[ND]nand_info->type :0
[ND]nand_info->SectorNumsPerPage :8
[ND]nand_info->BytesUserData :16
[ND]nand_info->PageNumsPerBlk :64
[ND]nand_info->BlkPerChip :512
[ND]nand_info->FirstBuild :0
[ND]nand_info->FullBitmap :10
[ND]nand_info->bad_block_addr.Chip_NO :0
[ND]nand_info->bad_block_addr.Block_NO :13
[ND]nand_info->mbr_block_addr.Chip_NO :0
[ND]nand_info->mbr_block_addr.Block_NO :12
[ND]nand_info->no_used_block_addr.Chip_NO :0
[ND]nand_info->no_used_block_addr.Block_NO :16
[ND]nand_info->new_bad_block_addr.Chip_NO :0
[ND]nand_info->new_bad_block_addr.Block_NO :14
[ND]nand_info->new_bad_page_addr :65535
[ND]nand_info->partition_nums :1
[ND]sizeof partition:1192
[ND]nand_info->partition:0:
[ND]size:0x36400
[ND]cross_talk:0x0
[ND]attribute:0x0
[ND]start: chip:0 block:16
[ND]end : chip:0 block:511
NB1 : nftl num: 1
init nftl: 0
[ND]nand_partition0
[ND]nftl start:496,62
[ND]first
[ND]before second 496 434.
[NE]smart->version:aaaaaa01;
[NE]smart->total_recv_read_sectors:191736;
[NE]smart->total_recv_write_sectors:192706;
[NE]smart->total_real_read_pages:24563;
[NE]smart->total_real_write_pages:24617;
[NE]smart->total_recv_discard_sectors:0;
[NE]smart->total_real_discard_sectors:0;
[NE]smart->total_recv_read_claim_pages:0;
[NE]smart->total_gc_times:0;
[NE]smart->total_gc_pages:0;
[NE]smart->total_wl_times:0;
[NE]smart->total_real_read_error_pages:0;
[NE]smart->total_real_write_error_pages:0;
[NE]smart->total_normal_power_cycles:7;
[NE]smart->total_unusual_power_cycles:0;
[NE]smart->max_block_erase_times:0;
[NE]smart->min_block_erase_times:0;
[NE]smart->max_block_used_counter:0;
[NE]smart->min_block_used_counter:0;
[NE]smart->read_reclaim_utc:0;
[NE]recover_phy_page_mapping no used page 56!!
[ND]recover 108 56
[ND]A64 nand2.0 version:0009
[ND]zone->nand_chip->blk_per_chip: 496
[ND]zone->nand_chip->bytes_per_page: 4096
[ND]zone->nand_chip->pages_per_blk: 64
[ND]zone->nand_chip->max_erase_times: 3000
[ND]zone->nand_chip->support_read_reclaim: 0
[ND]zone->test: 0
[ND]zone->zone_no: 0
[ND]zone->zone_attr: 0
[ND]zone->blocks: 496
[ND]zone->bad_block: 0
[ND]zone->logic_cap_in_sects: 222208
[ND]zone->backup_cap_in_sects: 31744
[ND]zone->free_block_num: 112
[ND]zone->gc_strategy.start_gc_free_blocks: 12
[ND]zone->gc_strategy.stop_gc_free_blocks: 41
[ND]zone->gc_strategy.gc_page: 0
[ND]zone->gc_strategy.process: 1
[ND]zone->prio_gc.prio_type : 0
[ND]zone->zone_start_phy_block->phy_block.Block_NO: 0
[ND]zone->zone_end_phy_block->phy_block.Block_NO: 495
[ND]zone->zone_phy_page_map_for_gc: 4293dad0
[ND]zone->current_block.user_info: 4293d640
[ND]zone->current_block.block_info: 4291cd70
[ND]zone->current_block.block_info->phy_block.Block_NO: 108
[ND]zone->current_block.page_used: 56
[ND]zone->current_block.block_info->block_used_count: 387
[ND]zone->read_reclaim_complete: 0
[ND]zone->temp_page_buf: 42920428
[ND]zone->max_erase_num: 1
[ND]zone->cache.cache_totals: 0
[ND]zone->cfg->nftl_dont_use_cache: 1
[ND]zone->cfg->nftl_use_cache_sort: 1
[ND]zone->cfg->nftl_support_gc_read_reclaim: 1
[ND]zone->cfg->nftl_support_wear_leveling: 1
[ND]zone->cfg->nftl_need_erase: 0
[ND]zone->cfg->nftl_min_free_block_num: 32
[ND]zone->cfg->nftl_gc_threshold_free_block_num: a
[ND]zone->cfg->nftl_min_free_block: a
[ND]zone->cfg->nftl_gc_threshold_ratio_numerator: 2
[ND]zone->cfg->nftl_gc_threshold_ratio_denominator: 3
[ND]zone->cfg->nftl_max_cache_num: 20
[ND]zone->cfg->nftl_max_cache_write_num: 10
[ND]zone->cfg->nftl_cross_talk: 0
[ND]zone->cfg->nftl_read_claim_interval: 1296000
[NE]smart->total_real_read_pages:24620;
[ND]nftl ok!
[ND]max_erase_times = 65000
[ND]nftl_add ok
NB1 : NAND_LogicInit ok, result = 0x0
[ 1.646]sunxi flash init ok
In: serial
Out: serial
Err: serial
-total partitions:5-
-name- -start- -size-
bootloader : 100000 800000
env : 900000 80000
boot : 980000 800000
system : 1180000 5a00000
UDISK : 6b80000 0
base bootcmd=run bootcmd_nandd
bootcmd set setargs_nand
key 0
cant find rcvy value
cant find fstbt value
no misc partition is found
to be run cmd=run bootcmd_nandd
Net: eth0Warning: failed to set MAC address
WORK_MODE_BOOT
board_status_probe
adver not need show
sunxi_bmp_logo_display
** Unable to read "bootlogo.bmp" from sunxi_flash 0:1 **
sunxi bmp info error : unable to open logo file bootlogo.bmp
read bootlogo partition fail,start_block=0x0,rblock=0x0 ,ret=0
Not a JPG file ?
parse_header failed
Use decode 2x1 sampling
sunxi_read_bootlogo: jpg convert argb
[ 1.745]Hit any key to stop autoboot: 1 0
read boot or recovery all
boota: bad boot image magic, maybe not a boot.img?
try to read all
[ 3.184]sunxi flash read :offset 980000, 8388608 bytes OK
## Booting kernel from Legacy Image at 40007800 ...
Image Name: Linux-3.4.39
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 3671720 Bytes = 3.5 MiB
Load Address: 40008000
Entry Point: 40008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
para err in disp_ioctl, cmd = 0xa,screen id = 1
[ 3.377][mmc]: MMC Device 2 not found
[ 3.380][mmc]: mmc not find,so not exit
NAND_UbootExit
NB1 : NAND_LogicExit
nand release dma:43a31aa0
nand release dma:0
reload config to 0x43000000
[ 3.385]
[ 0.000000] Booting Linux on physical CPU 0
[ 0.000000] Linux version 3.4.39 (dev@dev-vm) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #2 Tue Nov 13 16:12:00 CST 2018
[ 0.000000] Kernel command line: console=ttyS2,115200 root=/dev/nandd
[ 0.000000] Memory: 64MB = 64MB total
[ 0.000000] Memory: 20384k/20384k available, 45152k reserved, 0K highmem
[ 0.000000] vmalloc : 0xc4800000 - 0xff000000 ( 936 MB)
[ 0.000000] .text : 0xc0008000 - 0xc068a000 (6664 kB)
[ 0.000000] .init : 0xc068a000 - 0xc06b3000 ( 164 kB)
[ 0.000000] .data : 0xc06b4000 - 0xc0738e20 ( 532 kB)
[ 0.000000] .bss : 0xc0738e44 - 0xc0774998 ( 239 kB)
[ 0.000000] NR_IRQS:544
[ 0.000000] Architected local timer running at 24.00MHz.
[ 0.000000] Switching to timer-based delay loop
[ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000271] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.00 BogoMIPS (lpj=24000000)
[ 0.000322] pid_max: default: 32768 minimum: 301
[ 0.000592] Mount-cache hash table entries: 512
[ 0.001462] CPU: Testing write buffer coherency: ok
[ 0.001823] Setting up static identity map for 0x404da660 - 0x404da6b8
[ 0.002892] devtmpfs: initialized
[ 0.005773] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.006139] pinctrl core: initialized pinctrl subsystem
[ 0.006991] NET: Registered protocol family 16
[ 0.007412] DMA: preallocated 128 KiB pool for atomic coherent allocations
[ 0.007503] script_sysfs_init success
[ 0.009125] gpiochip_add: registered GPIOs 0 to 223 on device: sunxi-pinctrl
[ 0.010984] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver
[ 0.012635] script config pll_isp to 360 Mhz
[ 0.012685] Not Found clk pll_video in script
[ 0.012715] script config pll_ve to 360 Mhz
[ 0.012753] Not Found clk pll_periph0 in script
[ 0.012773] Not Found clk pll_de in script
[ 0.026277] bio: create slab <bio-0> at 0
[ 0.026709] pwm module init!
[ 0.030753] SCSI subsystem initialized
[ 0.031196] usbcore: registered new interface driver usbfs
[ 0.031378] usbcore: registered new interface driver hub
[ 0.031611] usbcore: registered new device driver usb
[ 0.031869] twi_chan_cfg()341 - [twi0] has no twi_speed!
[ 0.031895] twi_chan_cfg()352 - [twi0] has no twi_regulator.
[ 0.031922] twi_chan_cfg()341 - [twi1] has no twi_speed!
[ 0.031945] twi_chan_cfg()352 - [twi1] has no twi_regulator.
[ 0.032866] Linux video capture interface: v2.00
[ 0.033298] Advanced Linux Sound Architecture Driver Version 1.0.25.
[ 0.034921] cfg80211: Calling CRDA to update world regulatory domain
[ 0.036739] Switching to clocksource arch_sys_counter
[ 0.048987] NET: Registered protocol family 2
[ 0.049485] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.050442] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.050554] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.050618] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.050643] TCP: reno registered
[ 0.050668] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.050715] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.051224] NET: Registered protocol family 1
[ 0.051803] RPC: Registered named UNIX socket transport module.
[ 0.051833] RPC: Registered udp transport module.
[ 0.051852] RPC: Registered tcp transport module.
[ 0.051871] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.052181] standby_mode = 1.
[ 0.052198] wakeup src cnt is : 3.
[ 0.052299] sunxi_reg_init enter
[ 0.054900] VFS: Disk quotas dquot_6.5.2
[ 0.055807] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.056435] NTFS driver 2.1.30 [Flags: R/W].
[ 0.056625] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.057069] msgmni has been set to 39
[ 0.059470] io scheduler noop registered
[ 0.059496] io scheduler deadline registered
[ 0.059656] io scheduler cfq registered (default)
[ 0.059682] [DISP]disp_module_init
[ 0.060552] cmdline,disp=
[ 0.063105] [DISP] Fb_map_kernel_logo,line:924:Fb_map_kernel_logo failed!
[ 0.067363] [DISP] disp_sys_gpio_set_value,line:374:OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[ 0.068315] [DISP]disp_module_init finish
[ 0.068785] sw_uart_get_devinfo()1503 - uart0 has no uart_regulator.
[ 0.068826] sw_uart_get_devinfo()1503 - uart2 has no uart_regulator.
[ 0.069612] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[ 0.070370] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[ 0.070406] sw_uart_pm()890 - uart2 clk is already enable
[ 0.070447] sw_console_setup()1233 - console setup baud 115200 parity n bits 8, flow n
[ 0.178187] console [ttyS2] enabled
[ 0.750100] [DISP] disp_sys_gpio_set_value,line:374:OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[ 0.759891] ili9341 sleep out
[ 0.916916] nanda:
[ 0.923190] nandb: unknown partition table
[ 0.932086] nandc: unknown partition table
[ 0.940785] nandd: unknown partition table
[ 0.947920] nande: unknown partition table
[ 0.953944] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator.
[ 0.961160] sunxi_spi_register_spidev()2009 - Get spi devices modalias failed
[ 0.969167] sunxi_spi_init()2073 - register spi devices board info failed
[ 0.978631] usbcore: registered new interface driver rtl8192cu
[ 0.985461] usbcore: registered new interface driver rt2500usb
[ 0.992296] usbcore: registered new interface driver rt73usb
[ 0.998765] usbcore: registered new interface driver rt2800usb
[ 1.005383] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.032959] sunxi-ehci sunxi-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.041991] [DISP] disp_lcd_pwm_enable,line:1023:pwm device hdl is NULL
[ 1.049789] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus number 1
[ 1.058514] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000
[ 1.080055] sunxi-ehci sunxi-ehci.1: USB 0.0 started, EHCI 1.00
[ 1.088020] hub 1-0:1.0: USB hub found
[ 1.092316] hub 1-0:1.0: 1 port detected
[ 1.097699] sunxi-ehci sunxi-ehci.1: remove, state 1
[ 1.103368] usb usb1: USB disconnect, device number 1
[ 1.110484] sunxi-ehci sunxi-ehci.1: USB bus 1 deregistered
[ 1.126890] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.154055] sunxi-ohci sunxi-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver
[ 1.162788] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus number 1
[ 1.171369] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400
[ 1.235237] hub 1-0:1.0: USB hub found
[ 1.239478] hub 1-0:1.0: 1 port detected
[ 1.244709] sunxi-ohci sunxi-ohci.1: remove, state 1
[ 1.250441] usb usb1: USB disconnect, device number 1
[ 1.257207] sunxi-ohci sunxi-ohci.1: USB bus 1 deregistered
[ 1.273744] Initializing USB Mass Storage driver...
[ 1.279377] usbcore: registered new interface driver usb-storage
[ 1.286226] USB Mass Storage support registered.
[ 1.291591] usbcore: registered new interface driver ums-cypress
[ 1.298510] usbcore: registered new interface driver ums_eneub6250
[ 1.305553] usbcore: registered new interface driver ums-freecom
[ 1.312451] usbcore: registered new interface driver ums-isd200
[ 1.319237] usbcore: registered new interface driver ums-jumpshot
[ 1.326214] usbcore: registered new interface driver ums-realtek
[ 1.333149] usbcore: registered new interface driver ums-sddr09
[ 1.339864] usbcore: registered new interface driver ums-sddr55
[ 1.346640] usbcore: registered new interface driver ums-usbat
[ 1.353959] file system registered
[ 1.360970] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 1.368783] android_usb gadget: Number of LUNs=1
[ 1.374039] lun0: LUN: removable file: (no medium)
[ 1.380414] android_usb gadget: android_usb ready
[ 1.386417] mousedev: PS/2 mouse device common for all mice
[ 1.392885] sunxikbd_script_init: key para not found, used default para.
[ 1.402163] sunxi-rtc sunxi-rtc: rtc core: registered sunxi-rtc as rtc0
[ 1.411093] usbcore: registered new interface driver uvcvideo
[ 1.417651] USB Video Class driver (v1.0.8_SONiX_v2.6.36.04)
[ 1.424918] sunxi_wdt_init_module: sunxi WatchDog Timer Driver v1.0
[ 1.432376] sunxi_wdt_probe: devm_ioremap return wdt_reg 0xf1c20ca0, res->start 0x01c20ca0, res->end 0x01c20cbf
[ 1.443918] sunxi_wdt_probe: initialized (g_timeout=16s, g_nowayout=0)
[ 1.451504] wdt_enable, write reg 0xf1c20cb8 val 0x00000000
[ 1.457764] wdt_set_tmout, write 0x000000b0 to mode reg 0xf1c20cb8, actual timeout 16 sec
[ 1.476439] sunxi_leds_fetch_sysconfig_para leds is not used in config
[ 1.483888] =========script_get_err============
[ 1.489415] usbcore: registered new interface driver usbhid
[ 1.495715] usbhid: USB HID core driver
[ 1.500802] usbcore: registered new interface driver snd-usb-audio
[ 1.507960] Netfilter messages via NETLINK v0.30.
[ 1.513328] nfnl_acct: registering with nfnetlink.
[ 1.518916] nf_conntrack version 0.5.0 (318 buckets, 1272 max)
[ 1.526238] ctnetlink v0.93: registering with nfnetlink.
[ 1.532374] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 1.540285] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 1.547372] xt_time: kernel timezone is -0000
[ 1.552448] ip_set: protocol 6
[ 1.556363] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.562709] arp_tables: (C) 2002 David S. Miller
[ 1.568012] TCP: cubic registered
[ 1.572210] NET: Registered protocol family 10
[ 1.578860] IPv6 over IPv4 tunneling driver
[ 1.584918] NET: Registered protocol family 17
[ 1.590310] ThumbEE CPU extension supported.
[ 1.595134] Registering SWP/SWPB emulation handler
[ 1.602998] sunxi-rtc sunxi-rtc: setting system clock to 1970-01-01 00:03:03 UTC (183)
[ 1.758105] *******************Try sdio*******************
[ 1.784826] mmc1: queuing unknown CIS tuple 0x01 (3 bytes)
[ 1.798429] mmc1: queuing unknown CIS tuple 0x1a (5 bytes)
[ 1.807822] mmc1: queuing unknown CIS tuple 0x1b (8 bytes)
[ 1.816873] mmc1: queuing unknown CIS tuple 0x80 (1 bytes)
[ 1.823185] mmc1: queuing unknown CIS tuple 0x81 (1 bytes)
[ 1.829399] mmc1: queuing unknown CIS tuple 0x82 (1 bytes)
[ 1.835627] mmc1: new high speed SDIO card at address 0001
[ 1.842724] *******************sdio init ok*******************
[ 2.507878] mmc1: card 0001 removed
[ 2.610153] ALSA device list:
[ 2.613486] No soundcards found.
[ 2.618912] EXT4-fs (nandd): couldn't mount as ext3 due to feature incompatibilities
[ 2.630393] EXT4-fs (nandd): couldn't mount as ext2 due to feature incompatibilities
[ 2.668404] *******************Try sdio*******************
[ 2.696844] mmc1: queuing unknown CIS tuple 0x01 (3 bytes)
[ 2.710916] EXT4-fs (nandd): recovery complete
[ 2.717911] EXT4-fs (nandd): mounted filesystem with ordered data mode. Opts: (null)
[ 2.726865] VFS: Mounted root (ext4 filesystem) on device 93:24.
[ 2.734621] devtmpfs: mounted
[ 2.738534] Freeing init memory: 164K
[ 2.743975] mmc1: queuing unknown CIS tuple 0x1a (5 bytes)
[ 2.756629] mmc1: queuing unknown CIS tuple 0x1b (8 bytes)
[ 2.774348] mmc1: queuing unknown CIS tuple 0x80 (1 bytes)
[ 2.780786] mmc1: queuing unknown CIS tuple 0x81 (1 bytes)
[ 2.787105] mmc1: queuing unknown CIS tuple 0x82 (1 bytes)
[ 2.793558] mmc1: new high speed SDIO card at address 0001
[ 3.219068] *******************sdio init ok*******************
[ 3.267767] *******************Try sdio*******************
[ 3.278808] *******************Try sd *******************
[ 3.313775] mmc0: new SDHC card at address 0001
[ 3.320736] mmcblk0: mmc0:0001 SD8GB 7.28 GiB
[ 3.331739] mmcblk0: p1
[ 3.338853] mmcblk mmc0:0001: Card claimed for testing.
[ 3.344833] mmc0:0001: SD8GB 7.28 GiB
[ 3.349303] *******************sd init ok*******************
[ 3.435226] EXT4-fs (nandd): re-mounted. Opts: data=ordered
Starting logging: OK
Starting mdev...
Starting sshd: OK
[ 4.800818] [VFE]cci probe start cci_sel = 0!
[ 4.805778] [VFE]cci probe end cci_sel = 0!
[ 4.831034] [VFE]cci_init end
[ 5.124288] [VFE]Welcome to Video Front End driver
[ 5.141378] [VFE]pdev->id = 0
[ 5.144722] [VFE]dev->mipi_sel = 0
[ 5.148637] [VFE]dev->vip_sel = 0
[ 5.152422] [VFE]dev->isp_sel = 0
[ 5.176353] [VFE_WARN]vfe vpu clock is null
[ 5.198079] [VFE]vfe_init end
[ 5.201960] [VFE]probe_work_handle start!
[ 5.206475] [VFE]..........................vfe clk open!.......................
[ 5.255617] [VFE]v4l2 subdev register input_num = 0
[ 5.261185] [VFE]vfe sensor detect start! input_num = 0
[ 5.267138] [VFE]Find sensor name is "ov2710_mipi", i2c address is 6c, type is "RAW" !
[ 5.276049] [VFE]Sub device register "ov2710_mipi" i2c_addr = 0x6c start!
[ 5.283819] [VFE]v4l2_device_register_subdev return 0
[ 5.289483] [VFE]registered sensor subdev is OK!
[ 5.294679] [VFE]Check sensor!
[ 5.298103] [VFE]Sub device register "ov2710_mipi" is OK!
[ 5.307469] [VFE]Check open /system/etc/hawkview/ov2710_mipi/isp_test_param.ini failed!
[ 5.307497] Match isp cfg start!
[ 5.320434] [VFE]Match isp cfg ok
[ 5.340554] [VFE]V4L2 device registered as video0
[ 5.356367] [VFE]..........................vfe clk close!.......................
[ 5.380331] [VFE]probe_work_handle end!
========= Run hwtest =========[ 5.632426] [VFE]vfe_open
LCD : Yes
ACM : No
NET : No[ 5.636619] [VFE]..........................vfe clk open!.......................
fb res 320x240 virtual 320x[ 5.650174] [VFE]vfe_open ok
480, line_len 1280, bpp 32
ptr [ 5.654213] [VFE]Set vfe core clk = 216000000, after Set vfe core clk = 180000000
= b6b1e000, bgptr = b6ad2008
[ 5.700490] [VFE]mclk on
[ 5.729117] [VFE]V4L2_MBUS_CSI2,1 lane,bus1 channel,rx 1 channel
[ 5.803951] [VFE]width_input = 1440, height_input = 1080, width = 640, height = 480
[ 5.812658] [VFE]dev->buf_byte_size = 462848, double_ch_flag = 0
[ 5.884709] [VFE]buffer_setup, buffer count=4, size=466944
* Rainbow Pi Allwinner V3S *
Welcome to Rainbow-Pi
Rainbow-Pi login: root
# ./ wifiap.sh start
-sh: ./: Permission denied
# ./wifiap.sh start
[ 37.696806] ADDRCONF(NETDEV_UP): wlan0: link is not ready
# random: Trying to read entropy from /dev/random
nl80211: Could not add multicast membership for vendor events: -2 (No such file or directory)
nl80211: Set mode ifind[ 38.302326] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
ex 4 iftype 3 (AP)
nl80211: Subscribe to mgmt frames with AP handle 0x1ce24f8
nl80211: Register frame type=0xb0 (WLAN_FC_STYPE_AUTH) nl_handle=0x1ce24f8 match=
nl80211: Register frame type=0x0 (WLAN_FC_STYPE_ASSOC_REQ) nl_handle=0x1ce24f8 match=
nl80211: Register frame type=0x20 (WLAN_FC_STYPE_REASSOC_REQ) nl_handle=0x1ce24f8 match=
nl80211: Register frame type=0xa0 (WLAN_FC_STYPE_DISASSOC) nl_handle=0x1ce24f8 match=
nl80211: Register frame type=0xc0 (WLAN_FC_STYPE_DEAUTH) nl_handle=0x1ce24f8 match=
nl80211: Register frame type=0x40 (WLAN_FC_STYPE_PROBE_REQ) nl_handle=0x1ce24f8 match=
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x1ce24f8 match=04
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x1ce24f8 match=0501
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x1ce24f8 match=0504
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x1ce24f8 match=06
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x1ce24f8 match=08
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x1ce24f8 match=09
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x1ce24f8 match=0a
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x1ce24f8 match=11
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x1ce24f8 match=7f
rfkill: Cannot open RFKILL control device
nl80211: RFKILL status not available
nl80211: Could not re-add multicast membership for vendor events: -2 (No such file or directory)
nl80211: Add own interface ifindex 4 (ifidx_reason -1)
nl80211: if_indices[16]: 4(-1)
phy: phy0
nl80211: 2457-2482 @ 40 MHz 20 mBm (no IR)
nl80211: 5170-5250 @ 40 MHz 20 mBm (no IR)
nl80211: 5735-5835 @ 40 MHz 20 mBm (no IR)
* freq=2412
* vht_enabled=0
* ht_enabled=0
* channel_type=0
hostapd_setup_bss(hapd=0x1ce0e40 (wlan0), first=1)
wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=(nil) key_idx=0 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=(nil) key_idx=1 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=(nil) key_idx=2 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=(nil) key_idx=3 set_tx=0 seq_len=0 key_len=0
Using interface wlan0 with hwaddr 68:c6:3a:00:f1:02 and ssid "RainbowPi-AP"
SSID - hexdump_ascii(len=12):
52 61 69 6e 62 6f 77 50 69 2d 41 50 RainbowPi-AP
PSK (ASCII passphrase) - hexdump_ascii(len=9): [REMOVED]
nl80211: Beacon head - hexdump(len=63): 80 00 00 00 ff ff ff ff ff ff 68 c6 3a 00 f1 02 68 c6 3a 00 f1 02 00 00 00 00 00 00 00 00 00 00 64 00 11 04 00 0c 52 61 69 6e 62 6f 77 50 69 2d 41 50 01 08 82 84 8b 96 0c 12 18 24 03 01 01
nl80211: Beacon tail - hexdump(len=59): 2a 01 04 32 04 30 48 60 6c dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02 dd 18 00 50 f2 02 01 01 00 00 03 a4 00 00 27 a4 00 00 42 43 5e 00 62 32 2f 00
nl80211: ifindex=4
nl80211: ssid - hexdump_ascii(len=12):
* beacon_int=100
* dtim_period=2
nl80211: privacy=1
nl80211: auth_algs=0x3
nl80211: wpa_version=0x1
nl80211: pairwise_ciphers=0x8
wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=2 addr=0xc55c8 key_idx=1 set_tx=1 seq_len=0 key_len=32
broadcast key
netlink: Operstate: ifindex=4 linkmode=-1 (no change), operstate=6 (IF_OPER_UP)
wlan0: AP-ENABLED
RTM_NEWLINK: ifi_index=4 ifname=wlan0 operstate=6 linkmode=0 ifi_family=0 ifi_flags=0x11043 ([UP][RUNNING][LOWER_UP])
nl80211: Drv Event 60 (NL80211_CMD_FRAME_TX_STATUS) received for wlan0
nl80211: Frame TX status event
wlan0: Event TX_STATUS (17) received
mgmt::deauth cb
nl80211: BSS Event 59 (NL80211_CMD_FRAME) received for wlan0
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=84:a1:34:57:58:fd bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-47 fc=0x40 seq_ctrl=0xc480 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=113
nl80211: send_mlme - da= 84:a1:34:57:58:fd noack=1 freq=0 no_cck=0 offchanok=0 wait_time=0 fc=0x50 (WLAN_FC_STYPE_PROBE_RESP) nlmode=3
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=84:a1:34:57:58:fd bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-46 fc=0x40 seq_ctrl=0xc490 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=113
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=84:a1:34:57:58:fd bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-49 fc=0x40 seq_ctrl=0xc4a0 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=113
Ignore Probe Request due to DS Params mismatch: chan=1 != ds.chan=2
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=84:a1:34:57:58:fd bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-49 fc=0x40 seq_ctrl=0xc4b0 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=113
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=00:03:ac:1f:8c:78 bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-82 fc=0x40 seq_ctrl=0x7080 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=224
nl80211: send_mlme - da= 00:03:ac:1f:8c:78 noack=1 freq=0 no_cck=0 offchanok=0 wait_time=0 fc=0x50 (WLAN_FC_STYPE_PROBE_RESP) nlmode=3
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=00:03:ac:1f:8c:78 bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-83 fc=0x40 seq_ctrl=0x7340 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=224
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=00:03:ac:1f:8c:78 bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-84 fc=0x40 seq_ctrl=0x7350 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=224
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=04:56:04:a7:45:d1 bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-82 fc=0x40 seq_ctrl=0x7840 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=48
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=04:56:04:a7:45:d1 bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-82 fc=0x40 seq_ctrl=0x7850 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=42
nl80211: send_mlme - da= 04:56:04:a7:45:d1 noack=1 freq=0 no_cck=0 offchanok=0 wait_time=0 fc=0x50 (WLAN_FC_STYPE_PROBE_RESP) nlmode=3
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=04:56:04:a7:45:d1 bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-85 fc=0x40 seq_ctrl=0x7870 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=42
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=da:a1:19:02:0f:8c bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-65 fc=0x40 seq_ctrl=0x2200 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=42
nl80211: send_mlme - da= da:a1:19:02:0f:8c noack=1 freq=0 no_cck=0 offchanok=0 wait_time=0 fc=0x50 (WLAN_FC_STYPE_PROBE_RESP) nlmode=3
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=da:a1:19:03:fd:b1 bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-65 fc=0x40 seq_ctrl=0x2210 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=42
nl80211: send_mlme - da= da:a1:19:03:fd:b1 noack=1 freq=0 no_cck=0 offchanok=0 wait_time=0 fc=0x50 (WLAN_FC_STYPE_PROBE_RESP) nlmode=3
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=00:03:ac:1f:8c:78 bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-82 fc=0x40 seq_ctrl=0x7600 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=224
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=84:a1:34:57:58:fd bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-48 fc=0x40 seq_ctrl=0xc8e0 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=113
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=84:a1:34:57:58:fd bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-47 fc=0x40 seq_ctrl=0xc8f0 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=113
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=84:a1:34:57:58:fd bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-50 fc=0x40 seq_ctrl=0xc900 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=113
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=84:a1:34:57:58:fd bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-49 fc=0x40 seq_ctrl=0xc910 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=113
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=00:03:ac:1f:8c:78 bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-87 fc=0x40 seq_ctrl=0x78d0 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=224
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=00:03:ac:1f:8c:78 bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-86 fc=0x40 seq_ctrl=0x7b90 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=224
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=da:a1:19:be:11:c5 bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-66 fc=0x40 seq_ctrl=0x2360 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=42
nl80211: send_mlme - da= da:a1:19:be:11:c5 noack=1 freq=0 no_cck=0 offchanok=0 wait_time=0 fc=0x50 (WLAN_FC_STYPE_PROBE_RESP) nlmode=3
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=da:a1:19:d6:d0:84 bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-64 fc=0x40 seq_ctrl=0x2370 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=42
nl80211: send_mlme - da= da:a1:19:d6:d0:84 noack=1 freq=0 no_cck=0 offchanok=0 wait_time=0 fc=0x50 (WLAN_FC_STYPE_PROBE_RESP) nlmode=3
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=c4:86:e9:ef:c7:8c bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-89 fc=0x40 seq_ctrl=0x6560 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=65
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=84:a1:34:57:58:fd bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-48 fc=0x40 seq_ctrl=0xccd0 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=113
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=84:a1:34:57:58:fd bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-48 fc=0x40 seq_ctrl=0xcce0 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=113
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=84:a1:34:57:58:fd bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-50 fc=0x40 seq_ctrl=0xccf0 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=113
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=84:a1:34:57:58:fd bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-50 fc=0x40 seq_ctrl=0xcd00 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=113
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=00:03:ac:1f:8c:78 bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-84 fc=0x40 seq_ctrl=0x7e40 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=224
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=00:03:ac:1f:8c:78 bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-86 fc=0x40 seq_ctrl=0x8100 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=224
nl80211: Drop oldest pending send action cookie 0xc17fd9c0
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=00:03:ac:1f:8c:78 bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-85 fc=0x40 seq_ctrl=0x8110 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=224
nl80211: Drop oldest pending send action cookie 0x0
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=4c:18:9a:7f:b6:31 bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-75 fc=0x40 seq_ctrl=0x190 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=46
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=4c:18:9a:7f:b6:31 bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-75 fc=0x40 seq_ctrl=0x1a0 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=42
nl80211: send_mlme - da= 4c:18:9a:7f:b6:31 noack=1 freq=0 no_cck=0 offchanok=0 wait_time=0 fc=0x50 (WLAN_FC_STYPE_PROBE_RESP) nlmode=3
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=4c:18:9a:7f:b6:31 bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-77 fc=0x40 seq_ctrl=0x570 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=42
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=4c:18:9a:7f:b6:31 bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-76 fc=0x40 seq_ctrl=0x580 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=42
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=4c:18:9a:7f:b6:31 bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-77 fc=0x40 seq_ctrl=0x590 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=42
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=00:03:ac:1f:8c:78 bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-85 fc=0x40 seq_ctrl=0x83c0 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=224
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=00:03:ac:1f:8c:78 bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-83 fc=0x40 seq_ctrl=0x83d0 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=224
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=04:56:04:a7:45:d1 bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-82 fc=0x40 seq_ctrl=0x7e40 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=55
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=04:56:04:a7:45:d1 bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-84 fc=0x40 seq_ctrl=0x7e50 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=42
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=c4:86:e9:ef:c7:8c bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-86 fc=0x40 seq_ctrl=0x6aa0 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=65
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=c4:86:e9:ef:c7:8c bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-86 fc=0x40 seq_ctrl=0x6ab0 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=42
nl80211: send_mlme - da= c4:86:e9:ef:c7:8c noack=1 freq=0 no_cck=0 offchanok=0 wait_time=0 fc=0x50 (WLAN_FC_STYPE_PROBE_RESP) nlmode=3
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=84:a1:34:57:58:fd bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-48 fc=0x40 seq_ctrl=0xd140 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=125
nl80211: send_mlme - da= 84:a1:34:57:58:fd noack=0 freq=0 no_cck=0 offchanok=0 wait_time=0 fc=0x50 (WLAN_FC_STYPE_PROBE_RESP) nlmode=3
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=da:a1:19:f6:b9:6d bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-63 fc=0x40 seq_ctrl=0x24c0 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=42
nl80211: send_mlme - da= da:a1:19:f6:b9:6d noack=1 freq=0 no_cck=0 offchanok=0 wait_time=0 fc=0x50 (WLAN_FC_STYPE_PROBE_RESP) nlmode=3
nl80211: RX frame da=68:c6:3a:00:f1:02 sa=84:a1:34:57:58:fd bssid=68:c6:3a:00:f1:02 freq=2412 ssi_signal=-49 fc=0xb0 seq_ctrl=0xd150 stype=11 (WLAN_FC_STYPE_AUTH) len=41
wlan0: Event RX_MGMT (19) received
mgmt::auth
authentication: STA=84:a1:34:57:58:fd auth_alg=0 auth_transaction=1 status_code=0 wep=0 seq_ctrl=0xd150
New STA
ap_sta_add: register ap_handle_timer timeout for 84:a1:34:57:58:fd (300 seconds - ap_max_inactivity)
wlan0: STA 84:a1:34:57:58:fd IEEE 802.11: authentication OK (open system)
wlan0: STA 84:a1:34:57:58:fd MLME: MLME-AUTHENTICATE.indication(84:a1:34:57:58:fd, OPEN_SYSTEM)
wlan0: STA 84:a1:34:57:58:fd MLME: MLME-DELETEKEYS.request(84:a1:34:57:58:fd)
authentication reply: STA=84:a1:34:57:58:fd auth_alg=0 auth_transaction=2 resp=0 (IE len=0)
nl80211: send_mlme - da= 84:a1:34:57:58:fd noack=0 freq=0 no_cck=0 offchanok=0 wait_time=0 fc=0xb0 (WLAN_FC_STYPE_AUTH) nlmode=3
mgmt::auth cb
wlan0: STA 84:a1:34:57:58:fd IEEE 802.11: authenticated
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=da:a1:19:c8:8b:3f bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-66 fc=0x40 seq_ctrl=0x24d0 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=42
nl80211: send_mlme - da= da:a1:19:c8:8b:3f noack=1 freq=0 no_cck=0 offchanok=0 wait_time=0 fc=0x50 (WLAN_FC_STYPE_PROBE_RESP) nlmode=3
nl80211: RX frame da=68:c6:3a:00:f1:02 sa=84:a1:34:57:58:fd bssid=68:c6:3a:00:f1:02 freq=2412 ssi_signal=-48 fc=0x0 seq_ctrl=0xd160 stype=0 (WLAN_FC_STYPE_ASSOC_REQ) len=112
mgmt::assoc_req
association request: STA=84:a1:34:57:58:fd capab_info=0x431 listen_interval=20 seq_ctrl=0xd160
Validating WMM IE: OUI 00:50:f2 OUI type 2 OUI sub-type 0 version 1 QoS info 0x0
new AID 1
wlan0: STA 84:a1:34:57:58:fd IEEE 802.11: association OK (aid 1)
nl80211: sta_remove -> DEL_STATION wlan0 84:a1:34:57:58:fd --> -2 (No such file or directory)
wlan0: STA 84:a1:34:57:58:fd WPA: event 7 notification
nl80211: Add STA 84:a1:34:57:58:fd
* supported rates - hexdump(len=12): 82 84 8b 96 24 30 48 6c 0c 12 18 60
* capability=0x431
* aid=1
* listen_interval=20
nl80211: Ignore ASSOC/AUTH flags since driver doesn't support full AP client state
* flags set=0xac mask=0xc
* qosinfo=0x0
nl80211: send_mlme - da= 84:a1:34:57:58:fd noack=0 freq=0 no_cck=0 offchanok=0 wait_time=0 fc=0x10 (WLAN_FC_STYPE_ASSOC_RESP) nlmode=3
nl80211: Drv Event 19 (NL80211_CMD_NEW_STATION) received for wlan0
nl80211: New station 84:a1:34:57:58:fd
mgmt::assoc_resp cb
wlan0: STA 84:a1:34:57:58:fd IEEE 802.11: associated (aid 1)
wlan0: STA 84:a1:34:57:58:fd MLME: MLME-ASSOCIATE.indication(84:a1:34:57:58:fd)
wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=0x1ce6098 key_idx=0 set_tx=1 seq_len=0 key_len=0
addr=84:a1:34:57:58:fd
nl80211: Set STA flags - ifname=wlan0 addr=84:a1:34:57:58:fd total_flags=0x66 flags_or=0x6 flags_and=0xfffffff7 authorized=0
wlan0: STA 84:a1:34:57:58:fd WPA: event 1 notification
IEEE 802.1X: Ignore STA - 802.1X not enabled or forced for WPS
wlan0: STA 84:a1:34:57:58:fd WPA: start authentication
WPA: 84:a1:34:57:58:fd WPA_PTK entering state INITIALIZE
nl80211: Set STA flags - ifname=wlan0 addr=84:a1:34:57:58:fd total_flags=0x66 flags_or=0x0 flags_and=0xfffffffe authorized=0
wlan0: STA 84:a1:34:57:58:fd IEEE 802.1X: unauthorizing port
WPA: 84:a1:34:57:58:fd WPA_PTK_GROUP entering state IDLE
WPA: 84:a1:34:57:58:fd WPA_PTK entering state AUTHENTICATION
WPA: 84:a1:34:57:58:fd WPA_PTK entering state AUTHENTICATION2
WPA: Re-initialize GMK/Counter on first station
broadcast key
WPA: Assign ANonce - hexdump(len=32): 56 6a 5a 53 47 93 53 c5 5b 40 56 9c 25 48 73 dd 08 93 48 5b 95 98 da 19 16 ad b8 1a 73 03 ba 40
WPA: 84:a1:34:57:58:fd WPA_PTK entering state INITPSK
Searching a PSK for 84:a1:34:57:58:fd prev_psk=(nil)
WPA: 84:a1:34:57:58:fd WPA_PTK entering state PTKSTART
wlan0: STA 84:a1:34:57:58:fd WPA: sending 1/4 msg of 4-Way Handshake
WPA: Send EAPOL(version=1 secure=0 mic=0 ack=1 install=0 pairwise=1 kde_len=0 keyidx=0 encr=0)
WPA: Replay Counter - hexdump(len=8): 00 00 00 00 00 00 00 01
WPA: Use EAPOL-Key timeout of 100 ms (retry counter 1)
wlan0: hostapd_new_assoc_sta: reschedule ap_handle_timer timeout for 84:a1:34:57:58:fd (300 seconds - ap_max_inactivity)
wlan0: Event EAPOL_TX_STATUS (38) received
IEEE 802.1X: 84:a1:34:57:58:fd TX status - version=2 type=3 length=95 - ack=1
WPA: EAPOL-Key TX status for STA 84:a1:34:57:58:fd ack=1
WPA: Increase initial EAPOL-Key 1/4 timeout by 1000 ms because of acknowledged frame
wlan0: Event EAPOL_RX (24) received
IEEE 802.1X: 125 bytes from 84:a1:34:57:58:fd
IEEE 802.1X: version=1 type=3 length=121
WPA: Received EAPOL-Key from 84:a1:34:57:58:fd key_info=0x109 type=254 key_data_length=26
WPA: Received Key Nonce - hexdump(len=32): 73 bf 31 03 88 1a df 97 03 40 f2 fc 97 e1 a0 7a 03 d7 0f 5f 85 02 14 0b 5f a4 81 6e f4 8c 2d cd
WPA: Received Replay Counter - hexdump(len=8): 00 00 00 00 00 00 00 01
wlan0: STA 84:a1:34:57:58:fd WPA: received EAPOL-Key frame (2/4 Pairwise)
WPA: 84:a1:34:57:58:fd WPA_PTK entering state PTKCALCNEGOTIATING
WPA: PTK derivation - A1=68:c6:3a:00:f1:02 A2=84:a1:34:57:58:fd
WPA: Nonce1 - hexdump(len=32): 56 6a 5a 53 47 93 53 c5 5b 40 56 9c 25 48 73 dd 08 93 48 5b 95 98 da 19 16 ad b8 1a 73 03 ba 40
WPA: Nonce2 - hexdump(len=32): 73 bf 31 03 88 1a df 97 03 40 f2 fc 97 e1 a0 7a 03 d7 0f 5f 85 02 14 0b 5f a4 81 6e f4 8c 2d cd
WPA: PMK - hexdump(len=32): [REMOVED]
WPA: PTK - hexdump(len=64): [REMOVED]
WPA: KCK - hexdump(len=16): [REMOVED]
WPA: KEK - hexdump(len=16): [REMOVED]
WPA: TK - hexdump(len=32): [REMOVED]
Searching a PSK for 84:a1:34:57:58:fd prev_psk=0x1ce1e00
wlan0: STA 84:a1:34:57:58:fd WPA: invalid MIC in msg 2/4 of 4-Way Handshake
wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 84:a1:34:57:58:fd
wlan0: STA 84:a1:34:57:58:fd WPA: EAPOL-Key timeout
WPA: Replay Counter - hexdump(len=8): 00 00 00 00 00 00 00 02
WPA: Use EAPOL-Key timeout of 1000 ms (retry counter 2)
WPA: Received Key Nonce - hexdump(len=32): 9d 08 17 ba 5e ea 08 a8 22 a1 15 0f ab c3 a1 e0 87 82 c3 ef 0f bd 82 14 f7 ad bd 6e f5 bb 52 20
WPA: Received Replay Counter - hexdump(len=8): 00 00 00 00 00 00 00 02
WPA: Nonce2 - hexdump(len=32): 9d 08 17 ba 5e ea 08 a8 22 a1 15 0f ab c3 a1 e0 87 82 c3 ef 0f bd 82 14 f7 ad bd 6e f5 bb 52 20
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=00:03:ac:1f:8c:78 bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-86 fc=0x40 seq_ctrl=0x8680 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=224
WPA: Replay Counter - hexdump(len=8): 00 00 00 00 00 00 00 03
WPA: Use EAPOL-Key timeout of 1000 ms (retry counter 3)
WPA: Received Key Nonce - hexdump(len=32): d8 06 9f e6 ff 34 fc d3 19 61 34 f1 d3 c7 61 c4 78 ec 38 9d e2 77 89 dc d8 8f 62 3d 88 f7 dc 23
WPA: Received Replay Counter - hexdump(len=8): 00 00 00 00 00 00 00 03
WPA: Nonce2 - hexdump(len=32): d8 06 9f e6 ff 34 fc d3 19 61 34 f1 d3 c7 61 c4 78 ec 38 9d e2 77 89 dc d8 8f 62 3d 88 f7 dc 23
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=04:56:04:a7:45:d1 bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-83 fc=0x40 seq_ctrl=0x8280 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=45
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=04:56:04:a7:45:d1 bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-82 fc=0x40 seq_ctrl=0x8290 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=42
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=04:56:04:a7:45:d1 bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-81 fc=0x40 seq_ctrl=0x82b0 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=42
WPA: Replay Counter - hexdump(len=8): 00 00 00 00 00 00 00 04
WPA: Use EAPOL-Key timeout of 1000 ms (retry counter 4)
WPA: Received Key Nonce - hexdump(len=32): b1 bf c6 fe 37 f5 20 2b 01 5c 05 73 2b 9c ae 72 73 90 31 bc 72 1a 37 94 43 58 0d 62 6b 13 53 b1
WPA: Received Replay Counter - hexdump(len=8): 00 00 00 00 00 00 00 04
WPA: Nonce2 - hexdump(len=32): b1 bf c6 fe 37 f5 20 2b 01 5c 05 73 2b 9c ae 72 73 90 31 bc 72 1a 37 94 43 58 0d 62 6b 13 53 b1
wlan0: STA 84:a1:34:57:58:fd WPA: PTKSTART: Retry limit 4 reached
WPA: 84:a1:34:57:58:fd WPA_PTK entering state DISCONNECT
wpa_sta_disconnect STA 84:a1:34:57:58:fd
hostapd_wpa_auth_disconnect: WPA authenticator requests disconnect: STA 84:a1:34:57:58:fd reason 2
wlan0: ap_sta_disconnect addr 84:a1:34:57:58:fd reason=2
nl80211: send_mlme - da= 84:a1:34:57:58:fd noack=0 freq=0 no_cck=0 offchanok=0 wait_time=0 fc=0xc0 (WLAN_FC_STYPE_DEAUTH) nlmode=3
wlan0: STA 84:a1:34:57:58:fd WPA: event 3 notification
wlan0: ap_sta_disconnect: reschedule ap_handle_timer timeout for 84:a1:34:57:58:fd (5 seconds - AP_MAX_INACTIVITY_AFTER_DEAUTH)
WPA: 84:a1:34:57:58:fd WPA_PTK entering state DISCONNECTED
nl80211: Set STA flags - ifname=wlan0 addr=84:a1:34:57:58:fd total_flags=0x6 flags_or=0x0 flags_and=0xfffffffe authorized=0
mgmt::deauth cb
STA 84:a1:34:57:58:fd acknowledged deauth
wlan0: Deauthentication callback for STA 84:a1:34:57:58:fd
wlan0: Removing STA 84:a1:34:57:58:fd from kernel driver
nl80211: sta_remove -> DEL_STATION wlan0 84:a1:34:57:58:fd --> 0 (Success)
wlan0: STA 84:a1:34:57:58:fd MLME: MLME-DEAUTHENTICATE.indication(84:a1:34:57:58:fd, 2)
nl80211: Drv Event 20 (NL80211_CMD_DEL_STATION) received for wlan0
nl80211: Delete station 84:a1:34:57:58:fd
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=00:03:ac:1f:8c:78 bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-84 fc=0x40 seq_ctrl=0x8940 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=224
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=f0:41:c8:75:b0:85 bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-81 fc=0x40 seq_ctrl=0x2420 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=135
nl80211: send_mlme - da= f0:41:c8:75:b0:85 noack=1 freq=0 no_cck=0 offchanok=0 wait_time=0 fc=0x50 (WLAN_FC_STYPE_PROBE_RESP) nlmode=3
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=f0:41:c8:75:b0:85 bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-83 fc=0x40 seq_ctrl=0x2440 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=135
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=84:a1:34:57:58:fd bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-50 fc=0x40 seq_ctrl=0xd2d0 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=117
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=84:a1:34:57:58:fd bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-50 fc=0x40 seq_ctrl=0xd2e0 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=117
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=84:a1:34:57:58:fd bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-52 fc=0x40 seq_ctrl=0xd2f0 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=117
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=84:a1:34:57:58:fd bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-51 fc=0x40 seq_ctrl=0xd300 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=117
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=84:a1:34:57:58:fd bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-49 fc=0x40 seq_ctrl=0xd680 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=113
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=84:a1:34:57:58:fd bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-48 fc=0x40 seq_ctrl=0xd690 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=113
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=84:a1:34:57:58:fd bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-52 fc=0x40 seq_ctrl=0xd6a0 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=113
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=84:a1:34:57:58:fd bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-52 fc=0x40 seq_ctrl=0xd6b0 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=113
wlan0: ap_handle_timer: 84:a1:34:57:58:fd flags=0x8280 timeout_next=3
wlan0: STA 84:a1:34:57:58:fd IEEE 802.11: deauthenticated due to local deauth request
ap_free_sta: cancel ap_handle_timer for 84:a1:34:57:58:fd
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=00:03:ac:1f:8c:78 bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-83 fc=0x40 seq_ctrl=0x8c00 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=224
nl80211: RX frame da=ff:ff:ff:ff:ff:ff sa=00:03:ac:1f:8c:78 bssid=ff:ff:ff:ff:ff:ff freq=2412 ssi_signal=-85 fc=0x40 seq_ctrl=0x8ec0 stype=4 (WLAN_FC_STYPE_PROBE_REQ) len=224
nl80211: Drop oldest pending send action cookie 0x0这是Rainbow Pi的原始固件, 手机能搜索到Rainbow Pi-AP
start() {
ifconfig wlan0 192.168.10.1 netmask 255.255.255.0 up
hostapd -d /etc/hostapd.conf &
udhcpd
源码:
芒果派的?
https://github.com/qq516333132/camdroid/tree/master/lichee/linux-3.4/drivers/net/wireless/esp8089
荔枝派的:
https://github.com/Lichee-Pi/esp8089
这个为什么没有init_data.conf文件
可能是全志的:
https://github.com/jwrdegoede/esp8089
出处:http://linux-sunxi.org/Wifi#Espressif
我还有彩虹派的,跟第一个一样。
楼主调试成功了,记得分享一下经验。
看了一下我和楼主编译的方法是一样的,但是我在连接到wifi一定时间后,会出现下面的Err:
err: to_host_seq reg 0x**, seq 0x00
楼主要不连着放久一点试试看看会不会出现这种问题?
太感谢了,我这几天调一下,调出来一定分享出来
playflash wrote:
源码:
芒果派的?
https://github.com/qq516333132/camdroid/tree/master/lichee/linux-3.4/drivers/net/wireless/esp8089荔枝派的:
这个为什么没有init_data.conf文件可能是全志的:
出处:http://linux-sunxi.org/Wifi#Espressif我还有彩虹派的,跟第一个一样。
楼主调试成功了,记得分享一下经验。
你大概多久会出现这个问题? 我测试一下
err: to_host_seq reg 0x**, seq 0x00楼主要不连着放久一点试试看看会不会出现这种问题?
我也出现崩溃的情况,一段时间就出现了崩溃的状况,我怀疑是我的SDIO 中没有上拉CMD引脚。你是在那个板子上弄的?
error_0 wrote:
你大概多久会出现这个问题? 我测试一下
找到一个帖子 看下 应该是这个的原因,还没有测试 https://whycan.cn/t_636.html
error_0 wrote:
你大概多久会出现这个问题? 我测试一下
你好 我根据你的笔记修改代码,遇到了代码没有编译的问题
楼主好,方便发个编译esp8089步奏的帖子吗?
你看下14楼我发的编译笔记
什么问题?
我也出现了这个问题不知道怎么回事
大神你的这个问题最后解决了吗?
现在的我的V3s + ESP8089 出现同样的问题,
一筹莫展, 期待支援.
感谢,用楼主的文档成功在F100上把驱动装好了。
大神你的这个问题最后解决了吗?
一筹莫展, 期待支援.
问题好像解决了
关闭 USB共享网络的那一项
│ -> Device Drivers │
│ -> USB support (USB_SUPPORT [=y]) │
│ (1) -> USB Gadget Support (USB_GADGET [=n])
现在还没有搞定AP模式,我在V3S上是可以使用AP模式,但是同样的驱动移植到F1C100S上就是不行,有没有大牛在F1C100S上成功使用AP模式的。
AP模式终于搞定了,可以正常使用了,但是WIFI 速度感觉不是很快,我PC 和 我的板子都连接同一个WIFI ,PING的延时有60ms,不知道是不是没有移植好,你们一般在下位机怎么测网速? 有没有大佬说一下 ESP8089-_20190420-2021.pdf
感谢分享这个重磅炸弹!
买了荔枝派esp8089一直不能用,这次可以用了,大神能把你的烧写文件上传一下吗?我想先试一下,内核编译一直没成功,只能慢慢学了
最近编辑记录 kekemuyu (2019-05-29 16:00:59)
楼主发给我了, 晚点我上传上来, 如果忘记了,跟帖提醒一下。
我测试了, 可以用。
我测试了, 可以用。
如果方便的话,帮我打包一个开启串口1的镜像吧,我用go写了个应用用到了串口和wifi,想在f1c100s上测试一下
楼主 @error_0 esp8089 固件下载: flashimg_f1c100s_esp8089.7z
使用方法:
开热点, 显示很全的 loghostapd -B /etc/hostapd.conf
不显示 log, 后台运行wpa_supplicant -i wlan0 -D wext -c /etc/wpa_supplicant.conf -d
连接 路由器, 显示很全的 logwpa_supplicant -i wlan0 -D wext -c /etc/wpa_supplicant.conf -B
不显示 log, 后台运行登陆账号: root
密码: 1
@kekemuyu 等有空我弄个 UART1 的固件 ^_^
/files/members/3/QQ20190529182553.jpg
使用方法:
密码: 1@kekemuyu 等有空我弄个 UART1 的固件 ^_^
ap模式可以用,但我的连不上路由
修改配置文件: /etc/wpa_supplicant.conf
修改过,连不上,是不是ip设置成静态的了,所以连不上,ifconfig查看一直是
你们的用过ap模式后,还能连路由吗?
最近编辑记录 kekemuyu (2019-05-29 22:46:56)
我也问过楼主,他说只能运行在一种模式。
我估计是驱动不支持同时运行在两种模式
我是关掉ap后试的,也不行,重启单独连路由也不行
我重新烧一遍固件直接连路由试试
最近编辑记录 kekemuyu (2019-05-30 07:32:25)
emmmm, 看下是不是加密方式和路由器设置不匹配。
看来下次我还是录个视频,有图有真相。
重新烧录了固件还是不行,难道是我的esp8089坏了?各种路由都试过了,连手机热点也没放过,就是连不上,ifconfig查看的ip如下图,ip一直不变,但rxbytes有数据:
最近编辑记录 kekemuyu (2019-05-30 09:05:13)
ping 路由器或者手机热点IP可以吗?
地址是不是你手动设置的?
ping了不行,ip都不是一个段的,esp8089一直是这个ip,我看/etc/dhcp/dhcp.conf下的配置如下:
手机热点一般是 192.168.43.1
你手动设置: ifconfig wlan0 192.168.43.99然后终端执行: ping 192.168.43.1
看下有没有反应。
ifconfig wlan0 192.168.43.99这条命令牛逼,可以了,谢晕哥
看下有没有反应。
那是因为你没有执行 dhcpc 命令, 执行这个命令可以从 手机热点/路由器 获取IP地址/DNS服务器/网关地址等,
这样就可以 ping 百毒了
看下有没有反应。
这样就可以 ping 百毒了
我执行了udhcpc -i wlan0,现在可以自动获取ip了。回想之前wifi应该是连上了,就是ip没有自动分配。又学到了,今天没白过
最近编辑记录 kekemuyu (2019-05-30 11:21:45)
有个不好的消息必须说出来打击你一下, 根据我的测试结果, 连续 ping 约一个小时, 驱动会奔溃。
我试下
果然是,不到20分就挂了,驱动模块自动卸载了
有点坑
主线Linux文档有 esp8089 相关资料,但是却没有源码:
https://github.com/torvalds/linux/tree/master/Documentation/devicetree/bindings/net/wireless
https://github.com/torvalds/linux/blob/master/Documentation/devicetree/bindings/net/wireless/esp%2Cesp8089.txt
如果想稳定跑, 估计还是得选 AP6212(模块)/BCM43438(芯片) 这种Linux内置驱动的芯片。
我烧录了楼主的固件,可以用WIFI。说明我自己的硬件没有问题。
但是自己按照https://whycan.cn/t_2232.html#p16338的编译方法编译出了esp8089.ko,也可以加载,问题是加载完了什么都log都没有出来。
不知道是不是还要设置什么设备树?
另外楼主的esp8089.ko 不知道咋能导出, ssh rz sz 都不行
不知道是不是还要设置什么设备树?另外楼主的esp8089.ko 不知道咋能导出, ssh rz sz 都不行
最终找到个tftp给传出来了
https://whycan.cn/t_2443.html#p19052
据说 binwalk 可以提取固件里面的文件
镜像的登录账户和密码是多少?
镜像的登录账户和密码是多少?
https://whycan.cn/t_2091.html#p19662
root
1
驱动奔溃问题有下文了吗
使用方法:
按照楼主的笔记PDF root文件夹下应该有esp8089.ko文件,但是我发现烧写进去的固件这个文件夹是空的,所以一直就会有找不到加载文件
这条指令报错。
最近编辑记录 郁郁葱葱 (2019-12-02 18:05:45)
这条指令报错。
找到了esp8089.ko的文件,在lib->modules文件夹里面,搞不懂为什么执行挂载就报错,找不到文件。
插入esp8089.ko失败了,请问是什么原因
这样就可以 ping 百毒了
请问,我执行wpa_supplicant -B -i wlan0 -c /etc/wpa_supplicant.conf后显示Successfully initialized wpa_supplicant。然后我执行udhcpc -i wlan0,就一直sending discover。这是什么问题,有啥解决方法。
不错 很好的参考
支持一下 不错
厉害 刚好需要 谢谢楼主
我也是一直打印sending discover,请问你的问题解决了吗
8089可以配置为STA模式吗?
这个好,8089终于可以拿出来试试了
驱动编译和安装都成功了,就是搜索只能搜索到一个信号,参考一下大神的步骤。
我也是这样啊,也没报错,但是获取IP一直显示sending discover,手动设置IP也无法ping通网关,请问这个问题解决了吗?
围观 终于看到可用的
连不上,呜呜呜
# ifconfig wlan0 up
# ifconfig
wlan0 Link encap:Ethernet HWaddr AC:D0:74:D3:F8:A8
# wpa_supplicant -B -i wlan0 -c /etc/wpa_supplicant.conf
rfkill: Cannot open RFKILL control device离线
Must load mac80211.ko first if not baked in.
sudo modprobe esp8089.ko
If you get a wlan interface, but scanning shows no networks try using:
sudo modprobe esp8089.ko config=crystal_26M_en=1
or:
sudo modprobe esp8089.ko config=crystal_26M_en=2
To load the module.
新手小白一个,这个BIN文件是能连接WiFi的吗?
