楼主 # 2024-07-26 14:34:47
dazb
T113-S3: 视频播放无缝切换 (Tina Linux Video Playback Seamless Switching)
如有错误,敬请原谅。我使用的是自动翻译器,因为我是英语使用者。
使用 Tina Linux,我一直在尝试修改 tplayer 库以实现以下功能:
我希望能够播放一个视频,并在播放该视频时预加载第二个视频,然后在两个视频之间无缝切换(没有黑框或暂停)。
我一直在尝试运行两个播放器并更改它们的 zorder,但似乎即使我可以更改 zorder,也不会对视频的分层产生影响。
有人有过这方面的经验吗?或者可以提供建议吗?
我也愿意付费请人来做这件事。
非常感谢,
Daz
Using Tina Linux, I've been trying to modify the tplayer library to achieve the following:
I want the ability to play a video, and while that video is playing, preload a 2nd video, and then switch between the 2 videos seamlessly (without a black frame or pause).
I've been trying to experiment with running 2 players and changing their zorder, however it seems that even though I can change the zorder, it has no effect to the layering of the video.
Has anybody had any experience in this before? Or can offer advice?
I am also willing to pay for the services of someone to do this.
Many thanks,
Daz
最近编辑记录 dazb (2024-07-26 15:47:22)
#1 2026-06-30 10:33:40
sy373466062
已发帖子: 135
Re: T113-S3: 视频播放无缝切换 (Tina Linux Video Playback Seamless Switching)
这个问题你解决了吗? 遇到同样的问题
#2 2026-06-30 10:45:16
播放完
-> 视频层保存
-> 复制到UI,同时把UI透明度设置为0(不透明)
->播放下一个视频重置UI
#3 2026-07-04 22:05:35
kendyChen
这个问题解了吗?
