楼主 # 2026-07-22 10:43:17
hegemony
X2000求助:使用cloner镜像导入后,卡在board_init_r步骤后不动了
串口打印如下内容所示:
[10:33:02.529]收←◆
U-Boot SPL 2013.07 (Jul 06 2024 - 22:06:07)
ERROR EPC b2403210
Current Version: V1
Timer init
CLK stop
PLL init
CPA_CPAPCR:0310086d
CPM_CPMPCR:07c0484d
CPM_CPEPCR:0310186d
CPM_CPCCR:9a094410
CLK init
SDRAM init
DDR: W63AH6NKB_BI type is : LPDDR3
ddr_readl(DDRP_INNOPHY_CL) 0000000c
ddr_readl(DDRP_INNOPHY_CWL) 00000006
ddr_readl(DDRP_INNOPHY_AL) 00000000
DDRP_INNOPHY_PLL_LOCK: 00000004
DDRP_INNOPHY_PLL_LOCK: 0000000c
DDRP_INNOPHY_CALIB_DELAY_AL:00000051
DDRP_INNOPHY_CALIB_DELAY_AH:00000051
-----ddr_readl(DDRP_INNOPHY_CALIB_DONE): 00000003
ddrp_auto_calibration success!
board_init_r
仅仅到这里之后就停住不动了,不知道该如何解决,有大神答疑解惑吗
最近编辑记录 hegemony (2026-07-22 10:46:18)
#1 2026-07-23 21:39:17
甘文崔
Re: X2000求助:使用cloner镜像导入后,卡在board_init_r步骤后不动了
U-Boot SPL 2013.07-00062-g08fc397fbc-dirty (Jul 23 2026 - 17:10:31)
ERROR EPC 80015ce8
CPM_CPAPCR:a9008520
CPM_CPMPCR:98000083
CPM_CPCCR:9a052210
GD25LQ128C 00c86018
spl: payload image: Linux-5.10.186-00057-g64a82f9bf load addr: 0x80efffc0 size: 2822208
Uncompressing Linux(zstd)...
Ok, booting the kernel.
[ 0.000000] Linux version 5.10.186-00057-g64a82f9bf98e-dirty (devvean@devvean-pc) (mips-linux-gnu-gcc (Ingenic 6
[ 0.000000] CPU0 RESET ERROR PC:80015CE8
[ 0.000000] [<80015ce8>] ingenic_wait_irqoff+0x5c/0x64
[ 0.000000] printk: bootconsole [early0] enabled
[ 0.000000] CPU0 revision is: 2ed1024f (Ingenic XBurst)
[ 0.000000] FPU revision is: 00330000
[ 0.000000] OF: fdt: No chosen node found, continuing without
[ 0.000000] MIPS: machine is x1000 module base
[ 0.000000] SOC: X1000E_NEW
[ 0.000000] User-defined physical RAM map overwrite
[ 0.000000] Primary instruction cache 16kB, VIVT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 16kB, 4-way, VIPT, no aliases, linesize 32 bytes
[ 0.000000] Unified secondary cache 320kB 5-way, linesize 128 bytes.
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000000000000-0x0000000003ffffff]
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000003ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000003ffffff]
[ 0.000000] On node 0 totalpages: 16384
[ 0.000000] Normal zone: 144 pages used for memmap
[ 0.000000] Normal zone: 16384 pages, LIFO batch:3
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
这个是x1000的正常打印,我遇到过高版本cloner写文件系统导致不开机的情况,你可以试一下低版本的clonercloner-2.5.19-ubuntu_alpha.tar.gz
最近编辑记录 甘文崔 (2026-07-23 21:41:39)
