楼主 # 2023-05-31 14:39:45
zhaoshaox
在闲鱼上捡了一个V3S的门禁控制器,带屏幕,摄像头,nfc等 ,目前不知道怎么驱动
正常开机,输入密码开门后有串口输出,不知道是什么系统。上面有两个flash芯片。正在研究鼓捣中,有谁见过这个主板吗?
#1 2023-05-31 18:32:17
binsys
Re: 在闲鱼上捡了一个V3S的门禁控制器,带屏幕,摄像头,nfc等 ,目前不知道怎么驱动
做一卡通的厂,去官网产品里找呗,比如:
https://www.newcapec.com.cn/mjkq/401.html
不知道是不是
楼主 #2 2026-08-02 16:02:46
zhaoshaox
这两个文件是用咱们网站的方法提取的原始固件,和sys_config.fex文件。原始系统是camdriod,可以开启adb,我自己编译了一个busybox上传上去可以使用。现在一直想要用主线liunx驱动屏幕,折腾了半年没有成功,一直是sunxi4-drm这个不成功。后来换的camdriod编译还是不显示。camdriod启动日志如下:
[    0.000000] Linux version 3.4.39 (zhao@zhao-desktop) (gcc version 4.9.4 (Linaro GCC 4.9-2017.01) ) #17 Sat Aug 1 16:29:46 CST6
[    0.000000] Initialized persistent memory from 41d20800-41d307ff
[    0.000000] Kernel command line: console=ttyS0,115200 panic=5 rootwait root=/dev/mmcblk0p2 earlyprintk rw
[    0.000000] Memory: 31348k/31348k available, 34188k reserved, 0K highmem
[    0.000000]       .text : 0xc0008000 - 0xc039e000   (3672 kB)
[    0.000000]       .init : 0xc039e000 - 0xc03c0000   ( 136 kB)
[    0.000000]       .data : 0xc03c0000 - 0xc03f75b0   ( 222 kB)
[    0.000000]        .bss : 0xc03f75d4 - 0xc048f594   ( 608 kB)
[    0.000000] NR_IRQS:544
[    0.000159] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.00 BogoMIPS (lpj=24000000)
[    0.000184] pid_max: default: 32768 minimum: 301
[    0.000328] Mount-cache hash table entries: 512
[    0.000868] CPU: Testing write buffer coherency: ok
[    0.001125] Setting up static identity map for 0x402b2da0 - 0x402b2df8
[    0.001754] devtmpfs: initialized
[    0.003328] pinctrl core: initialized pinctrl subsystem
[    0.003808] NET: Registered protocol family 16
[    0.004057] DMA: preallocated 128 KiB pool for atomic coherent allocations
[    0.004112] script_sysfs_init success
[    0.004860] gpiochip_add: registered GPIOs 0 to 223 on device: sunxi-pinctrl
[    0.005721] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver
[    0.006650] persistent_ram: uncorrectable error in header
[    0.006667] persistent_ram: no valid data in buffer (sig = 0x57524220)
[    0.011233] console [ram-1] enabled
[    0.011693] Not Found clk pll_isp in script
[    0.011945] Not Found clk pll_video in script
[    0.012079] Not Found clk pll_ve in script
[    0.012213] Not Found clk pll_periph0 in script
[    0.012345] Not Found clk pll_de in script
[    0.014509] bio: create slab <bio-0> at 0
[    0.015002] pwm module init!
[    0.017164] SCSI subsystem initialized
[    0.017397] twi_chan_cfg()340 - [twi0] has no twi_regulator.
[    0.017649] twi_chan_cfg()340 - [twi1] has no twi_regulator.
[    0.018899] Switching to clocksource arch_sys_counter
[    0.019997] NET: Registered protocol family 2
[    0.019997] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.019997] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[    0.019997] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[    0.019997] TCP: Hash tables configured (established 2048 bind 2048)
[    0.019997] TCP: reno registered
[    0.019997] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.020128] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.020634] NET: Registered protocol family 1
[    0.021055] standby_mode = 1.
[    0.021194] wakeup src cnt is : 3.
[    0.021487] sunxi_reg_init enter
[    0.023471] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.023665] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    0.024107] msgmni has been set to 61
[    0.025149] io scheduler noop registered
[    0.025407] io scheduler deadline registered
[    0.025624] io scheduler cfq registered (default)
[    0.026259] [DISP]disp_module_init
[    0.026747] cmdline,disp=
[    0.027418] [DISP] disp_get_rotation_sw,line:68:disp 0 out of range? g_rot_sw=0
[    0.028811] [DISP] Fb_map_kernel_logo,line:924:Fb_map_kernel_logo failed!
[    0.032100] [DISP]disp_module_init finish
[    0.032789] sw_uart_get_devinfo()1503 - uart0 has no uart_regulator.
[    0.033249] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[    0.033508] sw_uart_pm()890 - uart0 clk is already enable
[    0.033654] sw_console_setup()1233 - console setup baud 115200 parity n bits 8, flow n
[    0.147139] console [ttyS0] enabled
[    0.508075] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator.
[    0.515969] spi spi0: master is unqueued, this is deprecated
[    0.522710] m25p_probe()982 - Use the Dual Mode Read.
[    0.528544] m25p80 spi0.0: w25q128 (16384 Kbytes)
[    0.535515] partitions_register()869 - Invalid partitions count: 425295900
[    0.543747] Creating 4 MTD partitions on "spi0.0":
[    0.549346] 0x000000000000-0x000000080000 : "u-boot"
[    0.556076] 0x000000080000-0x000000100000 : "sys_config"
[    0.563197] 0x000000100000-0x000000400000 : "kernel"
[    0.569885] 0x000000400000-0x000001000000 : "rootfs"
[    0.576562] sunxikbd_script_init: key para not found, used default para.
[    0.590855] ashmem: initialized
[    0.594742] logger: created 256K log 'log_main'
[    0.600077] [DISP] disp_lcd_pwm_enable,line:1021:pwm device hdl is NULL
[    0.607882] logger: created 32K log 'log_events'
[    0.613608] logger: created 32K log 'log_radio'
[    0.618895] logger: created 32K log 'log_system'
[    0.624653] TCP: cubic registered
[    0.628474] NET: Registered protocol family 17
[    0.633680] VFP support v0.3: [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 0 err, cmd 52,  RTO !!
[    0.644079] ThumbEE CPU extension supported.
[    0.648978] Registering SWP/SWPB emulation handler
[    0.658764] *******************Try sdio*******************
[    0.666956] Waiting for root device /dev/mmcblk0p2...
[    0.675457] *******************Try sd *******************
[    0.749247] mmc0: new high speed SDHC card at address aaaa
[    0.756020] mmcblk0: mmc0:aaaa SS16G 14.8 GiB
[    0.766979]  mmcblk0: p1 p2
[    0.771050] mmcblk mmc0:aaaa: Card claimed for testing.
[    0.777108] mmc0:aaaa: SS16G 14.8 GiB
[    0.781507] *******************sd init ok*******************
[    0.836131] *******************Try sdio*******************
[    0.845659] *******************Try sd *******************
[    0.855194] *******************Try mmc*******************
[    0.893726] EXT4-fs (mmcblk0p2): mounting ext3 file system using the ext4 subsystem
[    0.909749] *******************Try sdio*******************
[    0.920402] *******************Try sd *******************
[    0.931391] *******************Try mmc*******************
[    0.968196] EXT4-fs (mmcblk0p2): recovery complete
[    0.980935] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    0.990179] VFS: Mounted root (ext3 filesystem) on device 179:2.
[    1.002882] *******************Try sdio*******************
[    1.015812] devtmpfs: mounted
[    1.019427] *******************Try sd *******************
[    1.025875] Freeing init memory: 136K
[    1.035499] *******************Try mmc*******************
[    1.087383] *******************Try sdio*******************
[    1.098781] *******************Try sd *******************
[    1.109454] *******************Try mmc*******************
[    1.243395] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
Starting logging: OK
Starting network: OK
Welcome to Buildroot
buildroot login: root
楼主 #3 2026-08-02 16:05:26
zhaoshaox
liunx6.1的启动日志:Starting kernel ...
[    0.000000] Linux version 6.1.177 (mac@mac-laptop) (arm-linux-gnueabihf-gcc (Ubuntu 11.4.0-1ubuntu1~22.04.3) 11.4.0, GNU ld (GNU Bin6
[    0.000000] OF: fdt: Machine model: Custom V3s Board with 320x240 RGB666 LCD
[    0.000000] cma: Reserved 16 MiB at 0x41c00000
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x0000000040000000-0x0000000043ffffff]
[    0.000000]   HighMem  empty
[    0.000000]   node   0: [mem 0x0000000040000000-0x0000000043ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x0000000043ffffff]
[    0.000000] percpu: Embedded 11 pages/cpu s16084 r8192 d20780 u45056
[    0.000000] Kernel command line: console=ttyS0,115200 root=/dev/mmcblk0p2 rootwait
[    0.000000] Memory: 34920K/65536K available (8192K kernel code, 928K rwdata, 2172K rodata, 1024K init, 273K bss, 14232K reserved, 16)
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000002] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000255] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000686] Console: colour dummy device 80x30
[    0.000760] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000785] CPU: Testing write buffer coherency: ok
[    0.000846] pid_max: default: 32768 minimum: 301
[    0.001077] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.001105] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.002432] /cpus/cpu@0 missing clock-frequency property
[    0.002482] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.004040] Setting up static identity map for 0x40100000 - 0x40100060
[    0.004374] rcu: Hierarchical SRCU implementation.
[    0.004386] rcu:     Max phase no-delay instances is 1000.
[    0.005232] smp: Bringing up secondary CPUs ...
[    0.005251] smp: Brought up 1 node, 1 CPU
[    0.005262] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[    0.005272] CPU: All CPU(s) started in HYP mode.
[    0.005275] CPU: Virtualization extensions available.
[    0.006395] devtmpfs: initialized
[    0.010284] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.010610] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.010646] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[    0.011559] pinctrl core: initialized pinctrl subsystem
[    0.013462] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.014793] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.016111] thermal_sys: Registered thermal governor 'step_wise'
[    0.016348] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.016369] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.018593] /soc/mixer@1100000: Fixed dependency cycle(s) with /soc/lcd-controller@1c0c000
[    0.018653] /soc/lcd-controller@1c0c000: Fixed dependency cycle(s) with /soc/mixer@1100000
[    0.018777] /soc/interrupt-controller@1c81000: Fixed dependency cycle(s) with /soc/interrupt-controller@1c81000
[    0.019171] /soc/mixer@1100000: Fixed dependency cycle(s) with /soc/lcd-controller@1c0c000
[    0.019812] /soc/mixer@1100000: Fixed dependency cycle(s) with /soc/lcd-controller@1c0c000
[    0.019916] /soc/lcd-controller@1c0c000: Fixed dependency cycle(s) with /soc/mixer@1100000
[    0.024011] /soc/lcd-controller@1c0c000: Fixed dependency cycle(s) with /panel
[    0.024134] /panel: Fixed dependency cycle(s) with /soc/lcd-controller@1c0c000
[    0.035025] SCSI subsystem initialized
[    0.035881] usbcore: registered new interface driver usbfs
[    0.035960] usbcore: registered new interface driver hub
[    0.036025] usbcore: registered new device driver usb
[    0.036284] mc: Linux media interface: v0.10
[    0.036375] videodev: Linux video capture interface: v2.00
[    0.036447] pps_core: LinuxPPS API ver. 1 registered
[    0.036455] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.036476] PTP clock support registered
[    0.037263] Advanced Linux Sound Architecture Driver Initialized.
[    0.038776] clocksource: Switched to clocksource arch_sys_counter
[    0.052980] NET: Registered PF_INET protocol family
[    0.053289] IP idents hash table entries: 2048 (order: 2, 16384 bytes, linear)
[    0.054135] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[    0.054185] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.054208] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.054235] TCP bind hash table entries: 1024 (order: 2, 16384 bytes, linear)
[    0.054300] TCP: Hash tables configured (established 1024 bind 1024)
[    0.054449] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.054505] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.054799] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.056067] RPC: Registered named UNIX socket transport module.
[    0.056093] RPC: Registered udp transport module.
[    0.056101] RPC: Registered tcp transport module.
[    0.056106] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.057916] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[    0.065230] NFS: Registering the id_resolver key type
[    0.065351] Key type id_resolver registered
[    0.065360] Key type id_legacy registered
[    0.065660] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    0.065676] io scheduler mq-deadline registered
[    0.065684] io scheduler kyber registered
[    0.156815] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.160408] sun4i-drm display-engine: === SUN4I DRM: probe called ===
[    0.163234] === PANEL-SIMPLE: probe called for panel ===
[    0.163264] panel-simple panel:  if (!panel)e: start
[    0.163303] panel-simple panel: supply power not found, using dummy regulator
[    0.163528] panel-simple panel:  IS_ERR(panel->supply: start
[    0.163576] panel-simple panel:  IS_ERR(panel->enable_gpio): start
[    0.163613] panel-simple panel:  panel_dpi_probe errr : start
[    0.167117] CAN device driver interface
[    0.170360] sun6i-rtc 1c20400.rtc: registered as rtc0
[    0.170448] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01T00:00:03 UTC (3)
[    0.170668] sun6i-rtc 1c20400.rtc: RTC enabled
[    0.171013] i2c_dev: i2c /dev entries driver
[    0.173054] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    0.174389] sun4i-ss 1c15000.crypto: Die ID 7
[    0.175726] usbcore: registered new interface driver usbhid
[    0.175745] usbhid: USB HID core driver
[    0.179396] NET: Registered PF_PACKET protocol family
[    0.179425] can: controller area network core
[    0.179562] NET: Registered PF_CAN protocol family
[    0.179578] can: raw protocol
[    0.179590] can: broadcast manager protocol
[    0.179636] can: netlink gateway - max_hops=1
[    0.179813] Key type dns_resolver registered
[    0.179916] Registering SWP/SWPB emulation handler
[    0.194376] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.197278] printk: console [ttyS0] disabled
[    0.217633] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 99, base_baud = 1500000) is a U6_16550A
[    1.026629] printk: console [ttyS0] enabled
[    1.032474] sun4i-tcon 1c0c000.lcd-controller: === SUN4I TCON: probe called ===
[    1.039941] sun4i-tcon 1c0c000.lcd-controller: Adding component...
[    1.046320] Stack Depot allocating hash table of 4096 entries with kvcalloc
[    1.053504] === SUN8I MIXER: bind called ===
[    1.060029] sun4i-drm display-engine: bound 1100000.mixer (ops 0xc0957ac4)
[    1.067719] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc0955e84)
[    1.076855] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[    1.121074] Console: switching to colour frame buffer device 40x30
[    1.143978] sun4i-drm display-engine: [drm] fb0: sun4i-drmdrmfb frame buffer device
[    1.156507] usb_phy_generic usb_phy_generic.1.auto: supply vcc not found, using dummy regulator
[    1.165631] usb_phy_generic usb_phy_generic.1.auto: dummy supplies not allowed for exclusive requests
[    1.175966] musb-hdrc musb-hdrc.2.auto: MUSB HDRC host driver
[    1.181872] musb-hdrc musb-hdrc.2.auto: new USB bus registered, assigned bus number 1
[    1.195311] hub 1-0:1.0: USB hub found
[    1.199318] hub 1-0:1.0: 1 port detected
[    1.205176] clk: Disabling unused clocks
[    1.209365] ALSA device list:
[    1.212348]   No soundcards found.
[    1.228831] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[    1.236078] Waiting for root device /dev/mmcblk0p2...
[    1.292655] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.306560] mmc0: new high speed SDHC card at address aaaa
[    1.313576] mmcblk0: mmc0:aaaa SS16G 14.8 GiB
[    1.325453]  mmcblk0: p1 p2
[    1.368430] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[    1.375923] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[    1.420376] EXT4-fs (mmcblk0p2): recovery complete
[    1.430469] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: disabled.
[    1.439565] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    1.452708] devtmpfs: mounted
[    1.457164] Freeing unused kernel image (initmem) memory: 1024K
[    1.463391] Run /sbin/init as init process
[    4.198742] random: crng init done
[    4.204248] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SE)
[    4.218347] systemd[1]: Detected architecture 'arm'.
Welcome to Debian GNU/Linux 8 (jessie)!
[    4.278621] systemd[1]: Failed to insert module 'autofs4'
[    4.284528] systemd[1]: Failed to insert module 'ipv6'
[    4.294777] systemd[1]: Set hostname to <LicheePi>.
[    4.777576] systemd[1]: Cannot add dependency job for unit dbus.socket, ignoring: Unit dbus.socket failed to load: No such file or d.
[    4.790851] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to.
[    4.808464] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[    4.816991] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    4.824964] systemd[1]: Expecting device dev-ttyS0.device...
[  OK  ] Reached target Remote File Systems (Pre).
[  OK  ] Reached target Paths.
[  OK  ] Reached target Encrypted Volumes.
[  OK  ] Reached target Swap.
         Expecting device dev-mmcblk0p1.device...
[  OK  ] Created slice Root Slice.
[  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
[  OK  ] Listening on Delayed Shutdown Socket.
[  OK  ] Listening on Journal Socket (/dev/log).
[  OK  ] Listening on udev Kernel Socket.
[  OK  ] Listening on udev Control Socket.
[  OK  ] Created slice User and Session Slice.
[  OK  ] Listening on Journal Socket.
[  OK  ] Reached target Sockets.
[  OK  ] Created slice System Slice.
         Mounting Debug File System...
         Starting Load Kernel Modules...
         Starting udev Coldplug all Devices...
         Starting Create Static Device Nodes in /dev...
[  OK  ] Created slice system-getty.slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
         Starting File System Check on Root Device...
         Starting Journal Service...
[  OK  ] Started Journal Service.
[  OK  ] Reached target Slices.
[  OK  ] Mounted Debug File System.
[  OK  ] Started Load Kernel Modules.
[  OK  ] Started Create Static Device Nodes in /dev.
[  OK  ] Started File System Check on Root Device.
[    6.014547] systemd-fsck[81]: /dev/mmcblk0p2 has unsupported feature(s): metadata_csum
[    6.030822] systemd-fsck[81]: e2fsck: Get a newer version of e2fsck!
         Starting Remount Root and Kernel File Systems...
         Starting udev Kernel Device Manager...
[    6.180772] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: disabled.
[  OK  ] Started udev Coldplug all Devices.
[    6.230360] systemd-udevd[92]: starting version 215
[  OK  ] Started Remount Root and Kernel File Systems.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Started udev Kernel Device Manager.
         Starting Copy rules generated while the root was ro...
[  OK  ] Reached target Local File Systems (Pre).
         Starting Load/Save Random Seed...
[  OK  ] Started Copy rules generated while the root was ro.
[  OK  ] Started Load/Save Random Seed.
[  OK  ] Created slice system-systemd\x2dbacklight.slice.
         Starting Load/Save Screen Backlight Brightness of ba...ht:backlight...
[  OK  ] Started Load/Save Screen Backlight Brightness of backlight:backlight.
[  OK  ] Found device /dev/ttyS0.
[  OK  ] Found device /dev/mmcblk0p1.
         Mounting /boot...
[    7.542782] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[  OK  ] Mounted /boot.
[  OK  ] Reached target Local File Systems.
[  OK  ] Reached target Remote File Systems.
         Starting Trigger Flushing of Journal to Persistent Storage...
         Starting LSB: Raise network interfaces....
[  OK  ] Started Create Volatile Files and Directories.
[    8.036999] systemd-journald[83]: Received request to flush runtime journal from PID 1
[  OK  ] Started Trigger Flushing of Journal to Persistent Storage.
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Started LSB: Raise network interfaces..
[  OK  ] Reached target Network.
[  OK  ] Reached target System Initialization.
[  OK  ] Reached target Timers.
[  OK  ] Reached target Basic System.
         Starting OpenBSD Secure Shell server...
[  OK  ] Started OpenBSD Secure Shell server.
         Starting /etc/rc.local Compatibility...
         Starting getty on tty2-tty6 if dbus and logind are not available...
[  OK  ] Started /etc/rc.local Compatibility.
[  OK  ] Started Permit User Sessions.
[  OK  ] Started getty on tty2-tty6 if dbus and logind are not available.
         Starting Getty on tty6...
[  OK  ] Started Getty on tty6.
         Starting Getty on tty5...
[  OK  ] Started Getty on tty5.
         Starting Getty on tty4...
[  OK  ] Started Getty on tty4.
         Starting Getty on tty3...
[  OK  ] Started Getty on tty3.
         Starting Getty on tty2...
[  OK  ] Started Getty on tty2.
         Starting Getty on tty1...
[  OK  ] Started Getty on tty1.
         Starting Serial Getty on ttyS0...
[  OK  ] Started Serial Getty on ttyS0.
[  OK  ] Reached target Login Prompts.
[  OK  ] Reached target Multi-User System.
[  OK  ] Reached target Graphical Interface.
         Starting Update UTMP about System Runlevel Changes...
[  OK  ] Started Update UTMP about System Runlevel Changes.
Debian GNU/Linux 8 LicheePi ttyS0
LicheePi login: root
Password:
Last login: Thu Jan  1 08:01:20 HKT 1970 on ttyS0
Linux LicheePi 6.1.177 #11 SMP Wed Jul 29 16:17:15 CST 2026 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
root@LicheePi:~# cd /boot/
root@LicheePi:/boot# ls
boot.scr  modetest  sun8i-v3s-custom.dtb  uboot.env  zImage
root@LicheePi:/boot# cp modetest ~/
root@LicheePi:/boot# cd
root@LicheePi:~# ls
modetest
root@LicheePi:~#
楼主 #4 2026-08-02 16:06:25
zhaoshaox
liunx6.1的设备树文件:
/dts-v1/;
#include "sun8i-v3s-licheepi-zero.dts"
#include "dt-bindings/gpio/gpio.h"
    model = "Custom V3s Board with 320x240 RGB666 LCD";
    compatible = "allwinner,sun8i-v3s";
    chosen {
        stdout-path = &uart0;
    // PB4 纯GPIO背光,无PWM
    lcd_backlight: backlight {
        compatible = "gpio-backlight";
        gpios = <&pio 1 4 GPIO_ACTIVE_HIGH>; // PB4
        default-on;
    // 全局3.3V固定电源,给PB/PE/PG引脚供电
    reg_vcc3v3: vcc3v3 {
        regulator-name = "vcc3v3";
        regulator-boot-on;
    rgb_panel: panel {
        compatible = "panel-dpi";
        backlight = <&lcd_backlight>;
        width-mm  = <49>;
        height-mm = <37>;
        panel-timing {
            clock-frequency = <9000000>;
            hactive = <320>;
            vactive = <240>;
            hfront-porch = <140>;
            hback-porch  = <30>;
            hsync-len    = <10>;
            vfront-porch = <46>;
            vback-porch  = <10>;
            vsync-len    = <4>;
            hsync-active = <0>;
            vsync-active = <0>;
            de-active    = <0>;
            pixelclk-active = <0>;
            bus-format = <0x1009>;
            bpc = <6>;
        port {
            panel_in: endpoint {
                remote-endpoint = <&tcon0_out_rgb>;
&de {
&tcon0 {
    pinctrl-names = "default";
    pinctrl-0 = <&pe_lcd_pins>;
&tcon0_out {
    tcon0_out_rgb: endpoint {
        remote-endpoint = <&rgb_panel>; // 修正:直接引用panel根标签,消除循环
&uart0 {
&pio {
    // 消除vcc-pb/vcc-pe/vcc-pf not found警告
    vcc-pb-supply = <&reg_vcc3v3>;
    vcc-pe-supply = <&reg_vcc3v3>;
    vcc-pf-supply = <&reg_vcc3v3>;
    vcc-pg-supply = <&reg_vcc3v3>;
    pe_lcd_pins: pe-lcd-pins {
        pins =
            "PE0", "PE1", "PE2", "PE3",
            "PE4", "PE5", "PE6", "PE7",
            "PE8", "PE9", "PE10","PE11",
            "PE12","PE13","PE14","PE15",
            "PE16","PE17","PE18","PE19",
            "PE23","PE24";
        function = "lcd";
        drive-strength = <30>;
        bias-disable;
