楼主 # 2026-08-08 20:52:41
QL2017
已发帖子: 84
F133 eMMC支持
我看数据手册明确写了
2.2.3 SMHC
• Three SD/MMC host controller (SMHC) interfaces
• The SMHC0 controls the devices that comply with the protocol Secure Digital Memory (SD mem-version
3.0)
• The SMHC1 controls the device that complies with the protocol Secure Digital I/O (SDIO-version 3.0)
• The SMHC2 controls the device that complies with the protocol Multimedia Card (eMMC-version 5.0)
• Maximum performance:
  • SDR mode 150 MHz@1.8 V IO pad
  • DDR mode 50 MHz@1.8 V IO pad
  • DDR mode 50 MHz@3.3 V IO pad
    • Supports 1-bit or 4-bit data width
    • Supports block size of 1 to 65535 bytes
    • Internal 1024-Bytes RX FIFO and 1024-Bytes TX FIFO
    • Supports card insertion and removal interrupt
    • Supports hardware CRC generation and error detection
    • Supports descriptor-based internal DMA controller
    是不是就要SDC2就行?但是SDC2的引脚只有D0-D3 CLK CMD,能直接接吗?好像还缺点什么吧
#1 2026-08-08 21:44:01
Re: F133 eMMC支持
SDC2 可以接 eMMC 用于启动。
#2 2026-08-10 09:51:40
506826164@qq.com
已发帖子: 69
Re: F133 eMMC支持
够用了,emmc 跑4bit模式
#3 2026-08-10 11:04:46
middle007
已发帖子: 21
Re: F133 eMMC支持
选对应要求的版本就能支持了
