楼主 # 昨天 23:59:12
CK52
RK3566卡死在---[ end Kernel panic - not syncing: Attempted to kill init!
DDR 03ea844c5d typ 24/09/03-10:42:57,fwver: v1.23
ln
wdqs_if: 0x1010100
LP4/4x derate en, other dram:1x trefi
SRX
ddrconfig:0
MID:0xff
LPDDR4, 324MHz
BW=32 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=2048MB
tdqss_lf: cs0 dqs0: -24ps, dqs1: -72ps, dqs2: -96ps, dqs3: -120ps,
tdqss_hf: cs0 dqs0: -24ps, dqs1: -72ps, dqs2: -96ps, dqs3: -120ps,
change to: 324MHz
PHY drv:clk:38,ca:38,DQ:30,odt:0
vrefinner:41%, vrefout:41%
dram drv:40,odt:0
clk skew:0x62
change to: 528MHz
dram drv:40,odt:0
clk skew:0x58
err: cs 0 wrtrn err
change to: 780MHz
PHY drv:clk:38,ca:38,DQ:30,odt:60
vrefinner:16%, vrefout:41%
dram drv:40,odt:0
clk skew:0x58
rx vref: 17.4%
err: cs 0 wrtrn err
tx vref: 42.0%
change to: 1056MHz(final freq)
vrefinner:16%, vrefout:29%
dram drv:40,odt:80
vref_ca:00000068
clk skew:0x36
rx vref: 16.4%
tx vref: 27.0%
cs 0:
rdtrn RS:
DQS0:0x39, DQS1:0x3b, DQS2:0x39, DQS3:0x36,
min  : 0x3  0x5  0x3  0x2  0x5  0x2  0x3  0x3 , 0x1  0x4  0x2  0x2  0x1  0x4  0x7  0x7 ,
       0x4  0x1  0x5  0x2  0x4  0x6  0x3  0x6 , 0x7  0x5  0x1  0x1  0x7  0x9  0x1  0x7 ,
mid  :0x1f 0x20 0x1f 0x1c 0x20 0x1e 0x1d 0x1f ,0x1c 0x1d 0x1d 0x1d 0x1d 0x21 0x23 0x23 ,
      0x1e 0x1c 0x21 0x1f 0x20 0x1f 0x1d 0x20 ,0x23 0x21 0x1c 0x1b 0x22 0x25 0x1f 0x23 ,
max  :0x3b 0x3c 0x3b 0x37 0x3b 0x3b 0x37 0x3c ,0x38 0x36 0x38 0x38 0x39 0x3e 0x3f 0x3f ,
      0x39 0x37 0x3d 0x3c 0x3c 0x38 0x37 0x3b ,0x3f 0x3d 0x38 0x35 0x3e 0x42 0x3d 0x3f ,
range:0x38 0x37 0x38 0x35 0x36 0x39 0x34 0x39 ,0x37 0x32 0x36 0x36 0x38 0x3a 0x38 0x38 ,
      0x35 0x36 0x38 0x3a 0x38 0x32 0x34 0x35 ,0x38 0x38 0x37 0x34 0x37 0x39 0x3c 0x38 ,
wrtrn RS:
DQS0:0x33, DQS1:0x2d, DQS2:0x2a, DQS3:0x26,
min  :0x57 0x59 0x59 0x57 0x59 0x57 0x58 0x59 0x59 ,0x4d 0x4e 0x4f 0x4f 0x4e 0x51 0x54 0x53 0x50 ,
      0x4d 0x4d 0x4e 0x4e 0x4e 0x50 0x4d 0x52 0x51 ,0x4e 0x4d 0x48 0x48 0x4f 0x4f 0x4b 0x50 0x4a ,
mid  :0x6f 0x72 0x71 0x70 0x70 0x6f 0x6f 0x72 0x73 ,0x64 0x67 0x66 0x66 0x64 0x69 0x6e 0x6d 0x68 ,
      0x67 0x66 0x68 0x68 0x68 0x66 0x64 0x68 0x67 ,0x67 0x65 0x60 0x60 0x66 0x67 0x66 0x68 0x62 ,
max  :0x88 0x8b 0x8a 0x89 0x87 0x87 0x87 0x8b 0x8d ,0x7c 0x81 0x7d 0x7d 0x7b 0x82 0x88 0x88 0x81 ,
      0x81 0x7f 0x82 0x83 0x82 0x7c 0x7b 0x7e 0x7e ,0x81 0x7d 0x79 0x78 0x7d 0x80 0x82 0x80 0x7a ,
range:0x31 0x32 0x31 0x32 0x2e 0x30 0x2f 0x32 0x34 ,0x2f 0x33 0x2e 0x2e 0x2d 0x31 0x34 0x35 0x31 ,
      0x34 0x32 0x34 0x35 0x34 0x2c 0x2e 0x2c 0x2d ,0x33 0x30 0x31 0x30 0x2e 0x31 0x37 0x30 0x30 ,
CBT RS:
cs:0 min  :0x40 0x3d 0x38 0x2f 0x35 0x2f 0x38 ,0x44 0x39 0x36 0x2c 0x35 0x2c 0x39 ,
cs:0 mid  :0x7d 0x7f 0x74 0x71 0x71 0x72 0x65 ,0x7e 0x7d 0x70 0x70 0x6f 0x70 0x65 ,
cs:0 max  :0xba 0xc2 0xb1 0xb4 0xae 0xb5 0x93 ,0xb9 0xc1 0xab 0xb5 0xaa 0xb4 0x91 ,
cs:0 range:0x7a 0x85 0x79 0x85 0x79 0x86 0x5b ,0x75 0x88 0x75 0x89 0x75 0x88 0x58 ,
out
U-Boot SPL board init
U-Boot SPL 2017.09-g606f72bd97a-240527 #lxh (May 30 2024 - 16:08:15), fwver: v1.14
unknown raw ID 0 0 0
unrecognized JEDEC id bytes: 00, 00, 00
Trying to boot from MMC2
MMC: no card present
mmc_init: -123, time 0
spl: mmc init failed with error: -123
Trying to boot from MMC1
No misc partition
Trying fit image at 0x4000 sector
## Verified-boot: 0
## Checking atf-1 0x00040000 (gzip @0x00240000) ... sha256(d5325ff715...) + sha256(b5946ac63d...) + OK
## Checking uboot 0x00a00000 (gzip @0x00c00000) ... sha256(982f04b1a1...) + sha256(dbe80f1ae0...) + OK
## Checking fdt 0x00b57f60 ... sha256(a474c6bb61...) + OK
## Checking atf-2 0xfdcc1000 ... sha256(b8dca786b4...) + OK
## Checking atf-3 0x0006b000 ... sha256(2f91089eb7...) + OK
## Checking atf-4 0xfdcce000 ... sha256(86ef885748...) + OK
## Checking atf-5 0xfdcd0000 ... sha256(0b2b146c60...) + OK
## Checking atf-6 0x00069000 ... sha256(a9a1e63bef...) + OK
## Checking optee 0x08400000 (gzip @0x08600000) ... sha256(34defb3dac...) + sha256(9ffc99f1a2...) + OK
Jumping to U-Boot(0x00a00000) via ARM Trusted Firmware(0x00040000)
Total: 168.157/235.617 ms
INFO:    Preloader serial: 2
NOTICE:  BL31: v2.3():v2.3-645-g8cea6ab0b:cl, fwver: v1.44
NOTICE:  BL31: Built : 16:36:43, Sep 19 2023
INFO:    GICv3 without legacy support detected.
INFO:    ARM GICv3 driver initialized in EL3
INFO:    pmu v1 is valid 220114
INFO:    l3 cache partition cfg-0
INFO:    dfs DDR fsp_param[0].freq_mhz= 1056MHz
INFO:    dfs DDR fsp_param[1].freq_mhz= 324MHz
INFO:    dfs DDR fsp_param[2].freq_mhz= 528MHz
INFO:    dfs DDR fsp_param[3].freq_mhz= 780MHz
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
INFO:    BL31: Initializing runtime services
INFO:    BL31: Initializing BL32
I/TC:
I/TC: OP-TEE version: 3.13.0-891-g9f2aca7d1 #hisping.lin (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16))) #2 Thu Oct 31 10:26:19 CST 2024 aarch64, fwver: v2.15
I/TC: OP-TEE memory: TEEOS 0x200000 TA 0xc00000 SHM 0x200000
I/TC: Primary CPU initializing
I/TC: CRYPTO_CRYPTO_VERSION_NEW no support. Skip all algo mode check.
I/TC: Primary CPU switching to normal world boot
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0xa00000
INFO:    SPSR = 0x3c9
usb dr_mode not found
U-Boot 2017.09-g8f53f800da-241224 #jiawen (Apr 22 2026 - 16:25:53 +0800)
Model: Rockchip RK3568 Evaluation Board
MPIDR: 0x0
PreSerial: 2, raw, 0xfe660000
DRAM:  2 GiB
Sysmem: init
Relocation Offset: 7d207000
Relocation fdt: 7b7f8c48 - 7b7fece8
CR: M/C/I
Using default environment
optee api revision: 2.0
dwmmc@fe2b0000: 1, dwmmc@fe2c0000: 2, sdhci@fe310000: 0
switch to partitions #0, OK
mmc0(part 0) is current device
Bootdev(scan): mmc 0
MMC0: HS200, 200Mhz
PartType: EFI
TEEC: Waring: Could not find security partition
E/TC:? 0 storage_check_security_level_flag:561 Not support security level!
DM: v1
164315 bytes read in 5 ms (31.3 MiB/s)
DTB(Distro): rk-kernel.dtb
No misc partition
boot mode: normal
I2c0 speed: 100000Hz
vsel-gpios- not found! Error: -2
vdd_cpu 900000 uV
can't find shutdown-sequence prop
can't find vb-shutdown-sequence prop
PMIC:  RK8090 (on=0x40, off=0x00)
vdd_logic init 900000 uV
vdd_gpu init 900000 uV
vdd_npu init 900000 uV
io-domain: OK
INFO:    ddr dmc_fsp already initialized in loader.
Could not find baseparameter partition
Model: Embedfire LubanCat-RK356x
No resource file: logo.bmp
63478 bytes read in 4 ms (15.1 MiB/s)
logo(Distro): logo.bmp
Rockchip UBOOT DRM driver version: v1.0.1
Assign plane mask automatically
VOP have 1 active VP
vp0 have layer nr:6[0 2 4 1 3 5 ], primary plane: 4
vp1 have layer nr:0[], primary plane: 0
vp2 have layer nr:0[], primary plane: 0
hdmi@fe0a0000 disconnected
CLK: (sync kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
  apll 1104000 KHz
  dpll 528000 KHz
  gpll 1188000 KHz
  cpll 1000000 KHz
  npll 1200000 KHz
  vpll 24000 KHz
  hpll 24000 KHz
  ppll 200000 KHz
  armclk 1104000 KHz
  aclk_bus 150000 KHz
  pclk_bus 100000 KHz
  aclk_top_high 500000 KHz
  aclk_top_low 400000 KHz
  hclk_top 150000 KHz
  pclk_top 100000 KHz
  aclk_perimid 300000 KHz
  hclk_perimid 150000 KHz
  pclk_pmu 100000 KHz
Net:   eth1: ethernet@fe010000
Hit key to stop autoboot('CTRL+C'):  0
Scanning mmc 0:2...
Found U-Boot script /boot.scr
4108 bytes read in 2 ms (2 MiB/s)
## Executing script at 00c00000
[boot.cmd] run boot.cmd scripts ...
[boot.cmd] load mmc 0:2 0x0a080000 /uEnv/uEnv.txt ...
329 bytes read in 4 ms (80.1 KiB/s)
[boot.cmd] Importing environment from mmc ...
bootargs=storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal root=/dev/mmcblk0p3 boot_part=2 earlyprintk console=ttyFIQ0 console=tty1 consoleblank=0 loglevel=7 rootwait rw rootfstype=ext4
[boot.cmd] try load mmc 0:2 0x0a200000 /initrd ...
** File not found /initrd **
[boot.cmd] try load mmc 0:2 0x0a200000 /initrd-6.1 ...
** File not found /initrd-6.1 **
[boot.cmd] try load mmc 0:2 0x00280000 /Image ...
42213888 bytes read in 229 ms (175.8 MiB/s)
[boot.cmd] loading default rk-kernel.dtb
[boot.cmd] check the I2C bus
Bus 0:  i2c@fdd40000  (active 0)
   1c: tcs4525@1c, offset len 1, flags 0
   20: pmic@20, offset len 1, flags 0
[boot.cmd] [mmc 0:2] ...
[boot.cmd] booti 0x00280000 - 0x0a100000 ...
Fdt Ramdisk skip relocation
No misc partition
## Flattened Device Tree blob at 0x0a100000
   Booting using the fdt blob at 0x0a100000
   Using Device Tree in place at 000000000a100000, end 000000000a12b1da
No resource file: logo_kernel.bmp
21434 bytes read in 3 ms (6.8 MiB/s)
logo(Distro): logo_kernel.bmp
vp0, plane_mask:0x3f, primary-id:4, curser-id:-1
vp1, plane_mask:0x0, primary-id:0, curser-id:-1
vp2, plane_mask:0x0, primary-id:0, curser-id:-1
## reserved-memory:
  drm-logo@0: addr=7df00000 size=318000
  drm-cubic-lut@0: addr=7ff00000 size=8000
  ramoops@110000: addr=110000 size=f0000
Adding bank: 0x00200000 - 0x08400000 (size: 0x08200000)
Adding bank: 0x09400000 - 0x80000000 (size: 0x76c00000)
Total: 778.141/826.478 ms
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
[    0.832683] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[    0.832719] Linux version 6.1.99-rk356x (jiawen@dev120.embedfire.local) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 10.3-2021.07 (arm-10.29)) 10.3.1 20210621, GNU ld (GNU Toolchain for the A-profile Architecture 10.3-2021.07 (arm-10.29)) 2.36.1.20210621) #8 SMP Wed Apr 22 16:26:16 CST 2026
[    0.834541] random: crng init done
[    0.837618] Machine model: Embedfire LubanCat-RK356x
[    0.849021] efi: UEFI not found.
[    0.890229] Zone ranges:
[    0.890242]   DMA      [mem 0x0000000000200000-0x000000007fffffff]
[    0.890257]   DMA32    empty
[    0.890262]   Normal   empty
[    0.890266] Movable zone start for each node
[    0.890268] Early memory node ranges
[    0.890270]   node   0: [mem 0x0000000000200000-0x00000000083fffff]
[    0.890278]   node   0: [mem 0x0000000009400000-0x000000007fffffff]
[    0.890283] Initmem setup node 0 [mem 0x0000000000200000-0x000000007fffffff]
[    0.891173] On node 0, zone DMA: 512 pages in unavailable ranges
[    0.906330] On node 0, zone DMA: 4096 pages in unavailable ranges
[    0.906354] cma: Reserved 16 MiB at 0x000000007ea00000
[    0.906461] psci: probing for conduit method from DT.
[    0.906474] psci: PSCIv1.1 detected in firmware.
[    0.906480] psci: Using standard PSCI v0.2 function IDs
[    0.906487] psci: Trusted OS migration not required
[    0.906500] psci: SMC Calling Convention v1.2
[    0.906906] percpu: Embedded 29 pages/cpu s78456 r8192 d32136 u118784
[    0.907048] Detected VIPT I-cache on CPU0
[    0.907103] CPU features: detected: GIC system register CPU interface
[    0.907107] CPU features: detected: Virtualization Host Extensions
[    0.907122] CPU features: detected: Qualcomm erratum 1009, or ARM erratum 1286807, 2441009
[    0.907126] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.907132] alternatives: applying boot alternatives
[    0.909862] Built 1 zonelists, mobility grouping on.  Total pages: 511496
[    0.909882] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal root=/dev/mmcblk0p3 boot_part=2 earlyprintk console=ttyFIQ0 console=tty1 consoleblank=0 loglevel=7 rootwait rw rootfstype=ext4 androidboot.fwver=ddr-v1.23-03ea844c5d,spl-v1.14,bl31-v1.44,bl32-v2.15,uboot-8f53f800da-04/22/2026
[    0.910261] Unknown kernel command line parameters "earlyprintk storagemedia=emmc boot_part=2", will be passed to user space.
[    0.910791] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.911047] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.911059] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.937428] Memory: 1975808K/2078720K available (21952K kernel code, 3976K rwdata, 7652K rodata, 7488K init, 709K bss, 86528K reserved, 16384K cma-reserved)
[    0.937589] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.937645] ftrace: allocating 67943 entries in 266 pages
[    1.054175] ftrace: allocated 266 pages with 3 groups
[    1.054386] trace event string verifier disabled
[    1.054624] rcu: Hierarchical RCU implementation.
[    1.054631] rcu:     RCU event tracing is enabled.
[    1.054633] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    1.054641]  Rude variant of Tasks RCU enabled.
[    1.054643]  Tracing variant of Tasks RCU enabled.
[    1.054646] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[    1.054652] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    1.065287] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    1.067205] GICv3: GIC: Using split EOI/Deactivate mode
[    1.067215] GICv3: 320 SPIs implemented
[    1.067222] GICv3: 0 Extended SPIs implemented
[    1.067267] Root IRQ handler: gic_handle_irq
[    1.067286] GICv3: GICv3 features: 16 PPIs
[    1.067735] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000
[    1.068323] ITS [mem 0xfd440000-0xfd45ffff]
[    1.068398] ITS@0x00000000fd440000: allocated 8192 Devices @3230000 (indirect, esz 8, psz 64K, shr 0)
[    1.068441] ITS@0x00000000fd440000: allocated 32768 Interrupt Collections @3240000 (flat, esz 2, psz 64K, shr 0)
[    1.068455] ITS: using cache flushing for cmd queue
[    1.068896] GICv3: using LPI property table @0x0000000003250000
[    1.069016] GIC: using cache flushing for LPI property table
[    1.069023] GICv3: CPU0: using allocated LPI pending table @0x0000000003260000
[    1.069107] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    1.100905] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    1.100931] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    1.100945] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    1.102249] Console: colour dummy device 80x25
[    1.102659] printk: console [tty1] enabled
[    1.102706] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[    1.102730] pid_max: default: 32768 minimum: 301
[    1.102899] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    1.102926] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    1.103939] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    1.104674] cblist_init_generic: Setting adjustable number of callback queues.
[    1.104694] cblist_init_generic: Setting shift to 2 and lim to 1.
[    1.104798] cblist_init_generic: Setting adjustable number of callback queues.
[    1.104815] cblist_init_generic: Setting shift to 2 and lim to 1.
[    1.105037] rcu: Hierarchical SRCU implementation.
[    1.105054] rcu:     Max phase no-delay instances is 1000.
[    1.105896] Platform MSI: interrupt-controller@fd440000 domain created
[    1.106483] PCI/MSI: /interrupt-controller@fd400000/interrupt-controller@fd440000 domain created
[    1.106941] EFI services will not be available.
[    1.107381] smp: Bringing up secondary CPUs ...
[    1.108705] Detected VIPT I-cache on CPU1
[    1.108802] cacheinfo: Unable to detect cache hierarchy for CPU 1
[    1.108818] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[    1.108842] GICv3: CPU1: using allocated LPI pending table @0x0000000003270000
[    1.108897] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[    1.110265] Detected VIPT I-cache on CPU2
[    1.110345] cacheinfo: Unable to detect cache hierarchy for CPU 2
[    1.110359] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[    1.110380] GICv3: CPU2: using allocated LPI pending table @0x0000000003280000
[    1.110419] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[    1.111744] Detected VIPT I-cache on CPU3
[    1.111820] cacheinfo: Unable to detect cache hierarchy for CPU 3
[    1.111834] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[    1.111853] GICv3: CPU3: using allocated LPI pending table @0x0000000003290000
[    1.111891] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[    1.111992] smp: Brought up 1 node, 4 CPUs
[    1.112111] SMP: Total of 4 processors activated.
[    1.112123] CPU features: detected: 32-bit EL0 Support
[    1.112134] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    1.112147] CPU features: detected: Common not Private translations
[    1.112156] CPU features: detected: CRC32 instructions
[    1.112169] CPU features: detected: RCpc load-acquire (LDAPR)
[    1.112178] CPU features: detected: LSE atomic instructions
[    1.112188] CPU features: detected: Privileged Access Never
[    1.112197] CPU features: detected: RAS Extension Support
[    1.112208] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    1.112287] CPU: All CPU(s) started at EL2
[    1.112300] alternatives: applying system-wide alternatives
[    1.117615] devtmpfs: initialized
[    1.139919] Registered cp15_barrier emulation handler
[    1.139963] Registered setend emulation handler
[    1.140169] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    1.140203] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    1.140693] pinctrl core: initialized pinctrl subsystem
[    1.141376] DMI not present or invalid.
[    1.141708] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    1.143146] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[    1.143470] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    1.143674] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    1.144389] Registered FIQ tty driver
[    1.144839] thermal_sys: Registered thermal governor 'fair_share'
[    1.144847] thermal_sys: Registered thermal governor 'step_wise'
[    1.144861] thermal_sys: Registered thermal governor 'user_space'
[    1.144872] thermal_sys: Registered thermal governor 'power_allocator'
[    1.144942] cpuidle: using governor menu
[    1.145382] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    1.145528] ASID allocator initialised with 65536 entries
[    1.148572] ramoops: dmesg-0 0x20000@0x0000000000110000
[    1.148627] ramoops: console 0x80000@0x0000000000130000
[    1.148654] ramoops: pmsg    0x50000@0x00000000001b0000
[    1.149124] printk: console [ramoops-1] enabled
[    1.149140] pstore: Registered ramoops as persistent store backend
[    1.149154] ramoops: using 0xf0000@0x110000, ecc: 0
[    1.166249] platform fe040000.vop: Fixed dependency cycle(s) with /hdmi@fe0a0000
[    1.166358] platform fe0a0000.hdmi: Fixed dependency cycle(s) with /vop@fe040000
[    1.186365] rockchip-gpio fdd60000.gpio: probed /pinctrl/gpio@fdd60000
[    1.186937] rockchip-gpio fe740000.gpio: probed /pinctrl/gpio@fe740000
[    1.187474] rockchip-gpio fe750000.gpio: probed /pinctrl/gpio@fe750000
[    1.187995] rockchip-gpio fe760000.gpio: probed /pinctrl/gpio@fe760000
[    1.188564] rockchip-gpio fe770000.gpio: probed /pinctrl/gpio@fe770000
[    1.188760] rockchip-pinctrl pinctrl: probed pinctrl
[    1.206818] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    1.206864] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    1.206881] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    1.206895] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    1.206910] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    1.206923] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    1.206938] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    1.206951] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    1.264323] raid6: neonx8   gen()  2055 MB/s
[    1.321096] raid6: neonx4   gen()  2091 MB/s
[    1.377856] raid6: neonx2   gen()  1941 MB/s
[    1.434642] raid6: neonx1   gen()  1593 MB/s
[    1.491417] raid6: int64x8  gen()  1381 MB/s
[    1.548185] raid6: int64x4  gen()  1524 MB/s
[    1.604950] raid6: int64x2  gen()  1351 MB/s
[    1.661716] raid6: int64x1  gen()   980 MB/s
[    1.661734] raid6: using algorithm neonx4 gen() 2091 MB/s
[    1.718484] raid6: .... xor() 1601 MB/s, rmw enabled
[    1.718505] raid6: using neon recovery algorithm
[    1.720263] fiq_debugger fiq_debugger.0: error -ENXIO: IRQ fiq not found
[    1.720307] fiq_debugger fiq_debugger.0: error -ENXIO: IRQ wakeup not found
[    1.720334] fiq_debugger_probe: could not install nmi irq handler
[    1.720868] printk: console [ttyFIQ0] enabled
[    1.721146] Registered fiq debugger ttyFIQ0
[    1.726179] iommu: Default domain type: Translated
[    1.726218] iommu: DMA domain TLB invalidation policy: strict mode
[    1.726593] SCSI subsystem initialized
[    1.726857] usbcore: registered new interface driver usbfs
[    1.726929] usbcore: registered new interface driver hub
[    1.726984] usbcore: registered new device driver usb
[    1.727422] mc: Linux media interface: v0.10
[    1.727515] videodev: Linux video capture interface: v2.00
[    1.727620] pps_core: LinuxPPS API ver. 1 registered
[    1.727641] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.727675] PTP clock support registered
[    1.727730] EDAC MC: Ver: 3.0.0
[    1.728570] arm-scmi firmware:scmi: Enabled polling mode TX channel - prot_id:16
[    1.728725] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled.
[    1.728803] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0
[    1.730534] Advanced Linux Sound Architecture Driver Initialized.
[    1.731671] rockchip-cpuinfo cpuinfo: SoC            : 35662000
[    1.731704] rockchip-cpuinfo cpuinfo: Serial         : 21e3895e05aa36a6
[    1.732947] clocksource: Switched to clocksource arch_sys_counter
[    1.743249] NET: Registered PF_INET protocol family
[    1.743471] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    1.745353] tcp_listen_portaddr_hash hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    1.745426] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    1.745510] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    1.745637] TCP bind hash table entries: 16384 (order: 8, 1048576 bytes, linear)
[    1.746597] TCP: Hash tables configured (established 16384 bind 16384)
[    1.746772] UDP hash table entries: 1024 (order: 4, 98304 bytes, linear)
[    1.746891] UDP-Lite hash table entries: 1024 (order: 4, 98304 bytes, linear)
[    1.747188] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    1.747671] RPC: Registered named UNIX socket transport module.
[    1.747697] RPC: Registered udp transport module.
[    1.747713] RPC: Registered tcp transport module.
[    1.747729] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.748747] PCI: CLS 0 bytes, default 64
[    1.751294] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[    1.751707] rockchip-thermal fe710000.tsadc: tsadc is probed successfully!
[    1.765773] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 counters available
[    2.132589] Initialise system trusted keyrings
[    2.132897] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[    2.139198] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    2.140165] NFS: Registering the id_resolver key type
[    2.140243] Key type id_resolver registered
[    2.140264] Key type id_legacy registered
[    2.140363] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    2.140406] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    2.142357] Key type cifs.idmap registered
[    2.142431] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    2.142706] fuse: init (API version 7.37)
[    2.143190] SGI XFS with security attributes, no debug enabled
[    2.181170] NET: Registered PF_ALG protocol family
[    2.181266] xor: measuring software checksum speed
[    2.185271]    8regs           :  2498 MB/sec
[    2.189683]    32regs          :  2288 MB/sec
[    2.193706]    arm64_neon      :  2499 MB/sec
[    2.193756] xor: using function: arm64_neon (2499 MB/sec)
[    2.193790] Key type asymmetric registered
[    2.193822] Asymmetric key parser 'x509' registered
[    2.193961] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[    2.194395] io scheduler mq-deadline registered
[    2.194435] io scheduler kyber registered
[    2.207865] pwm-backlight backlight: supply power not found, using dummy regulator
[    2.208350] iep: Module initialized.
[    2.208436] mpp_service mpp-srv: 53c0acb01bce6 author: Tao Huang 2024-12-09 video: rockchip: mpp: Fix typos in Rockchip copyright notices
[    2.208466] mpp_service mpp-srv: probe start
[    2.211740] mpp_service mpp-srv: probe success
[    2.216646] dma-pl330 fe530000.dma-controller: Loaded driver for PL330 DMAC-241330
[    2.216707] dma-pl330 fe530000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    2.218827] dma-pl330 fe550000.dma-controller: Loaded driver for PL330 DMAC-241330
[    2.218869] dma-pl330 fe550000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    2.219584] rockchip-pvtm fde00000.pvtm: pvtm@0 probed
[    2.219766] rockchip-pvtm fde80000.pvtm: pvtm@1 probed
[    2.219910] rockchip-pvtm fde90000.pvtm: pvtm@2 probed
[    2.220273] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[    2.220936] arm-scmi firmware:scmi: Failed. SCMI protocol 22 not active.
[    2.221221] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[    2.222186] rockchip-pinctrl pinctrl: pin gpio2-14 already requested by vcc5v0-usb20-lbc1-regulator; cannot claim for fe650000.serial
[    2.222224] rockchip-pinctrl pinctrl: pin-78 (fe650000.serial) status -22
[    2.222246] rockchip-pinctrl pinctrl: could not request pin 78 (gpio2-14) from group uart1m0-ctsn  on device rockchip-pinctrl
[    2.222270] dw-apb-uart fe650000.serial: Error applying setting, reverse things back
[    2.229758] rockchip-vop2 fe040000.vop: Adding to iommu group 7
[    2.237398] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: Cluster0 | Cluster1 | Esmart0 | Esmart1 | Smart0 | Smart1[0x3f], primary plane phy id: Smart0[4]
[    2.237485] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: [0x0], primary plane phy id: INVALID[-1]
[    2.237516] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: [0x0], primary plane phy id: INVALID[-1]
[    2.237761] [drm] failed to init overlay plane Cluster0-win1
[    2.237896] rockchip-vop2 fe040000.vop: bin=0
[    2.238021] rockchip-vop2 fe040000.vop: leakage=49
[    2.238050] rockchip-vop2 fe040000.vop: leakage-volt-sel=0
[    2.238122] rockchip-vop2 fe040000.vop: pvtm = 84080, from nvmem
[    2.238151] rockchip-vop2 fe040000.vop: pvtm-volt-sel=1
[    2.238278] rockchip-vop2 fe040000.vop: error -ENODEV: _opp_set_regulators: no regulator (vop) found
[    2.238342] rockchip-vop2 fe040000.vop: failed to set opp config
[    2.238365] rockchip-vop2 fe040000.vop: failed to init opp info
[    2.238383] rockchip-vop2 fe040000.vop: Unsupported VOP aclk dvfs
[    2.238405] rockchip-drm display-subsystem: bound fe040000.vop (ops 0xffffffc0096bbfe8)
[    2.238764] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[    2.239439] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver
[    2.239822] dwhdmi-rockchip fe0a0000.hdmi: error -ENXIO: IRQ index 1 not found
[    2.240268] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops 0xffffffc0096d0218)
[    2.241343] [drm] Initialized rockchip 4.0.0 20140818 for display-subsystem on minor 0
[    2.241479] rockchip-drm display-subsystem: route-hdmi: failed to get logo,offset
[    2.241509] rockchip-drm display-subsystem: can't not find any logo display
[    2.241533] rockchip-drm display-subsystem: failed to show kernel logo
[    2.241663] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[    2.241793] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[    2.242014] rockchip-drm display-subsystem: [drm] run display error_event monitor
[    2.245408] input: hdmi_cec_key as /devices/platform/fe0a0000.hdmi/dw-hdmi-cec.1.auto/input/input0
[    2.246398] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    2.247291] brd: module loaded
[    2.252602] loop: module loaded
[    2.253125] zram: Added device: zram0
[    2.253404] lkdtm: No crash points registered, enable through debugfs
[    2.259815] rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found
[    2.260136] rk_gmac-dwmac fe010000.ethernet: supply phy not found, using dummy regulator
[    2.260303] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input).
[    2.260330] rk_gmac-dwmac fe010000.ethernet: TX delay(0x16).
[    2.260351] rk_gmac-dwmac fe010000.ethernet: RX delay(0xa).
[    2.260378] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no).
[    2.260439] rk_gmac-dwmac fe010000.ethernet: clock input from PHY
[    2.260693] rk_gmac-dwmac fe010000.ethernet: init for RGMII
[    2.260947] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[    2.260978] rk_gmac-dwmac fe010000.ethernet:         DWMAC4/5
[    2.261000] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported
[    2.261021] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported
[    2.261041] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported
[    2.261059] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported
[    2.261132] rk_gmac-dwmac fe010000.ethernet: TSO supported
[    2.261153] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    2.261175] rk_gmac-dwmac fe010000.ethernet: Enabled RFS Flow TC (entries=10)
[    2.261195] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled
[    2.261215] rk_gmac-dwmac fe010000.ethernet: Using 32/32 bits DMA host/device width
[    2.473224] mdio_bus stmmac-1: MDIO device at address 0 is missing.
[    2.475226] PPP generic driver version 2.4.2
[    2.475468] PPP BSD Compression module registered
[    2.475495] PPP Deflate Compression module registered
[    2.475770] PPP MPPE Compression module registered
[    2.475797] NET: Registered PF_PPPOX protocol family
[    2.475911] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256).
[    2.475936] CSLIP: code copyright 1989 Regents of the University of California.
[    2.476290] usbcore: registered new interface driver rndis_wlan
[    2.476404] usbcore: registered new interface driver cdc_ether
[    2.476469] usbcore: registered new interface driver rndis_host
[    2.489458] phy phy-fe8b0000.usb2-phy.3: illegal mode
[    2.490085] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[    2.490358] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 1
[    2.490511] xhci-hcd xhci-hcd.4.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000808002010010
[    2.490600] xhci-hcd xhci-hcd.4.auto: irq 46, io mem 0xfd000000
[    2.490771] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[    2.490954] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 2
[    2.490990] xhci-hcd xhci-hcd.4.auto: Host supports USB 3.0 SuperSpeed
[    2.491144] ehci-platform fd800000.usb: EHCI Host Controller
[    2.491159] phy phy-fe8b0000.usb2-phy.3: illegal mode
[    2.491176] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[    2.491190] ohci-platform fd840000.usb: Generic Platform OHCI controller
[    2.491201] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.491243] usb usb1: Product: xHCI Host Controller
[    2.491261] usb usb1: Manufacturer: Linux 6.1.99-rk356x xhci-hcd
[    2.491279] usb usb1: SerialNumber: xhci-hcd.4.auto
[    2.491474] ehci-platform fd880000.usb: EHCI Host Controller
[    2.491488] ohci-platform fd8c0000.usb: Generic Platform OHCI controller
[    2.491759] hub 1-0:1.0: USB hub found
[    2.491819] hub 1-0:1.0: 1 port detected
[    2.492247] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.492393] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[    2.492423] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.492446] usb usb2: Product: xHCI Host Controller
[    2.492464] usb usb2: Manufacturer: Linux 6.1.99-rk356x xhci-hcd
[    2.492482] usb usb2: SerialNumber: xhci-hcd.4.auto
[    2.492910] hub 2-0:1.0: USB hub found
[    2.492997] hub 2-0:1.0: 1 port detected
[    2.493502] usbcore: registered new interface driver cdc_acm
[    2.493530] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    2.493600] usbcore: registered new interface driver cdc_wdm
[    2.493621] ohci-platform fd840000.usb: new USB bus registered, assigned bus number 4
[    2.493647] ehci-platform fd880000.usb: new USB bus registered, assigned bus number 5
[    2.493801] ohci-platform fd840000.usb: irq 49, io mem 0xfd840000
[    2.493819] ehci-platform fd880000.usb: irq 47, io mem 0xfd880000
[    2.493902] ehci-platform fd800000.usb: new USB bus registered, assigned bus number 3
[    2.493904] ohci-platform fd8c0000.usb: new USB bus registered, assigned bus number 6
[    2.493925] usbcore: registered new interface driver uas
[    2.494006] ohci-platform fd8c0000.usb: irq 50, io mem 0xfd8c0000
[    2.494032] usbcore: registered new interface driver usb-storage
[    2.494037] ehci-platform fd800000.usb: irq 48, io mem 0xfd800000
[    2.495230] usbcore: registered new interface driver usbtouchscreen
[    2.495716] i2c_dev: i2c /dev entries driver
[    2.498095] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected!
[    2.502694] i2c 0-0020: Fixed dependency cycle(s) with /i2c@fdd40000/pmic@20/pinctrl_rk8xx/rk817_slppin_rst
[    2.502744] i2c 0-0020: Fixed dependency cycle(s) with /i2c@fdd40000/pmic@20/pinctrl_rk8xx/rk817_slppin_pwrdn
[    2.502783] i2c 0-0020: Fixed dependency cycle(s) with /i2c@fdd40000/pmic@20/pinctrl_rk8xx/rk817_slppin_slp
[    2.504299] rk808 0-0020: chip id: 0x8090
[    2.504363] rk808 0-0020: No cache defaults, reading back from HW
[    2.506315] ehci-platform fd880000.usb: USB 2.0 started, EHCI 1.00
[    2.506726] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[    2.506758] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.506781] usb usb5: Product: EHCI Host Controller
[    2.506799] usb usb5: Manufacturer: Linux 6.1.99-rk356x ehci_hcd
[    2.506817] usb usb5: SerialNumber: fd880000.usb
[    2.507342] hub 5-0:1.0: USB hub found
[    2.507415] hub 5-0:1.0: 1 port detected
[    2.519624] ehci-platform fd800000.usb: USB 2.0 started, EHCI 1.00
[    2.519984] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[    2.520016] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.520039] usb usb3: Product: EHCI Host Controller
[    2.520057] usb usb3: Manufacturer: Linux 6.1.99-rk356x ehci_hcd
[    2.520075] usb usb3: SerialNumber: fd800000.usb
[    2.520538] hub 3-0:1.0: USB hub found
[    2.520610] hub 3-0:1.0: 1 port detected
[    2.528097] rk808 0-0020: source: on=0x40, off=0x00
[    2.528138] rk808 0-0020: support dcdc3 fb mode:-22, 1
[    2.528162] rk808 0-0020: support pmic reset mode:0,0
[    2.530947] rk808 0-0020: Fixed dependency cycle(s) with /i2c@fdd40000/pmic@20/pinctrl_rk8xx
[    2.535318] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    2.535386] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    2.553706] rk817-battery: Failed to locate of_node [id: -1]
[    2.553803] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01
[    2.553837] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.553861] usb usb4: Product: Generic Platform OHCI controller
[    2.553880] usb usb4: Manufacturer: Linux 6.1.99-rk356x ohci_hcd
[    2.553898] usb usb4: SerialNumber: fd840000.usb
[    2.553902] rk817-battery rk817-battery: Failed to find matching dt id
[    2.554064] rk817-charger: Failed to locate of_node [id: -1]
[    2.554203] rk817-charger rk817-charger: Failed to find matching dt id
[    2.554436] hub 4-0:1.0: USB hub found
[    2.554493] hub 4-0:1.0: 1 port detected
[    2.555026] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01
[    2.555059] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.555081] usb usb6: Product: Generic Platform OHCI controller
[    2.555100] usb usb6: Manufacturer: Linux 6.1.99-rk356x ohci_hcd
[    2.555118] usb usb6: SerialNumber: fd8c0000.usb
[    2.555602] hub 6-0:1.0: USB hub found
[    2.555655] hub 6-0:1.0: 1 port detected
[    2.557452] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input1
[    2.560905] rockchip-mipi-csi2-hw fdfb0000.mipi-csi2-hw: enter mipi csi2 hw probe!
[    2.561219] rockchip-mipi-csi2-hw fdfb0000.mipi-csi2-hw: probe success, v4l2_dev:mipi-csi2-hw!
[    2.563321] usbcore: registered new interface driver uvcvideo
[    2.565531] device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: dm-devel@redhat.com
[    2.566589] cpu cpu0: bin=0
[    2.566691] cpu cpu0: leakage=24
[    2.566749] cpu cpu0: pvtm = 84080, from nvmem
[    2.566778] cpu cpu0: pvtm-volt-sel=1
[    2.566803] cpu cpu0: soc version=0, speed=1
[    2.568776] cpu cpu0: avs=0
[    2.568992] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[    2.572618] cpu cpu0: EM: created perf domain
[    2.574933] sdhci: Secure Digital Host Controller Interface driver
[    2.574984] sdhci: Copyright(c) Pierre Ossman
[    2.575003] Synopsys Designware Multimedia Card Interface Driver
[    2.575496] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.576528] dwmmc_rockchip fe2b0000.mmc: No normal pinctrl state
[    2.576575] dwmmc_rockchip fe2b0000.mmc: No idle pinctrl state
[    2.577012] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
[    2.577060] dwmmc_rockchip fe2b0000.mmc: IDMAC supports 32-bit address mode.
[    2.577128] dwmmc_rockchip fe2b0000.mmc: Using internal DMA controller.
[    2.577138] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    2.577169] dwmmc_rockchip fe2b0000.mmc: Version ID is 270a
[    2.577247] dwmmc_rockchip fe2b0000.mmc: DW MMC controller at irq 80,32 bit host data width,256 deep fifo
[    2.577952] cryptodev: driver 1.12 loaded.
[    2.578048] hid: raw HID events driver (C) Jiri Kosina
[    2.578447] usbcore: registered new interface driver usbhid
[    2.578480] usbhid: USB HID core driver
[    2.579775] rockchip,bus bus-npu: bin=0
[    2.579835] rockchip,bus bus-npu: Failed to get leakage
[    2.579907] rockchip,bus bus-npu: pvtm = 84080, from nvmem
[    2.579940] rockchip,bus bus-npu: pvtm-volt-sel=1
[    2.581040] rockchip,bus bus-npu: avs=0
[    2.587139] usbcore: registered new interface driver snd-usb-audio
[    2.588912] rk817-codec rk817-codec: DMA mask not set
[    2.589018] clk: failed to reparent i2s1_mclkout_tx to clk_i2s1_8ch_tx: -22
[    2.590611] mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    2.594359] Initializing XFRM netlink socket
[    2.594827] NET: Registered PF_INET6 protocol family
[    2.596169] Segment Routing with IPv6
[    2.596240] In-situ OAM (IOAM) with IPv6
[    2.596373] NET: Registered PF_PACKET protocol family
[    2.596423] NET: Registered PF_KEY protocol family
[    2.596495] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    2.596566] 8021q: 802.1Q VLAN Support v1.8
[    2.596611] [BT_RFKILL]: Enter rfkill_rk_init
[    2.596632] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    2.597411] Key type dns_resolver registered
[    2.599511] Loading compiled-in X.509 certificates
[    2.603137] Btrfs loaded, crc32c=crc32c-generic, zoned=no, fsverity=no
[    2.603419] pstore: Using crash dump compression: deflate
[    2.608942] mmc0: SDHCI controller on fe310000.mmc [fe310000.mmc] using ADMA
[    2.611084] rga2 fdeb0000.rk_rga: probe successfully, irq = 83, hw_version:3.2.63318
[    2.611441] rga: IOMMU binding successfully, default mapping core[0x4]
[    2.611691] rga: Module initialized. v1.3.7
[    2.641016] rockchip-iodomain fdc20000.syscon:io-domains: pmuio1(3300000 uV) supplied by vcc3v3_pmu
[    2.641117] rockchip-iodomain fdc20000.syscon:io-domains: pmuio2(3300000 uV) supplied by vcc3v3_pmu
[    2.641261] rockchip-iodomain fdc20000.syscon:io-domains: vccio1(3300000 uV) supplied by vccio_acodec
[    2.641448] rockchip-iodomain fdc20000.syscon:io-domains: vccio3(3300000 uV) supplied by vccio_sd
[    2.641580] rockchip-iodomain fdc20000.syscon:io-domains: vccio4(3300000 uV) supplied by vcc_3v3
[    2.641651] rockchip-iodomain fdc20000.syscon:io-domains: vccio5(3300000 uV) supplied by vcc_3v3
[    2.641721] rockchip-iodomain fdc20000.syscon:io-domains: vccio6(3300000 uV) supplied by vcc_3v3
[    2.641796] rockchip-iodomain fdc20000.syscon:io-domains: vccio7(3300000 uV) supplied by vcc_3v3
[    2.642109] mpp_rkvenc fdf40000.rkvenc: Adding to iommu group 5
[    2.642301] mpp_rkvenc fdf40000.rkvenc: probing start
[    2.642705] mpp_rkvenc fdf40000.rkvenc: bin=0
[    2.642738] mpp_rkvenc fdf40000.rkvenc: Failed to get leakage
[    2.642789] mpp_rkvenc fdf40000.rkvenc: pvtm = 84080, from nvmem
[    2.642810] mpp_rkvenc fdf40000.rkvenc: pvtm-volt-sel=1
[    2.643090] mpp_rkvenc fdf40000.rkvenc: avs=0
[    2.643547] mpp_rkvenc fdf40000.rkvenc: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[    2.643922] mpp_rkvenc fdf40000.rkvenc: probing finish
[    2.644244] mpp_vdpu2 fdea0400.vdpu: Adding to iommu group 1
[    2.644409] mpp_vdpu2 fdea0400.vdpu: probe device
[    2.644680] mpp_vdpu2 fdea0400.vdpu: probing finish
[    2.644922] mpp_vepu2 fdee0000.vepu: Adding to iommu group 3
[    2.645058] mpp_vepu2 fdee0000.vepu: probing start
[    2.645289] mpp_vepu2 fdee0000.vepu: probing finish
[    2.645499] mpp-iep2 fdef0000.iep: Adding to iommu group 4
[    2.645598] mpp-iep2 fdef0000.iep: probe device
[    2.645822] mpp-iep2 fdef0000.iep: probing finish
[    2.646024] mpp_jpgdec fded0000.jpegd: Adding to iommu group 2
[    2.646120] mpp_jpgdec fded0000.jpegd: probe device
[    2.646422] mpp_jpgdec fded0000.jpegd: probing finish
[    2.646720] mpp_rkvdec2 fdf80200.rkvdec: Adding to iommu group 6
[    2.646904] mpp_rkvdec2 fdf80200.rkvdec: rkvdec, probing start
[    2.647166] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_a is not found!
[    2.647184] rkvdec2_init:1198: No niu aclk reset resource define
[    2.647200] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_h is not found!
[    2.647212] rkvdec2_init:1201: No niu hclk reset resource define
[    2.647435] mpp_rkvdec2 fdf80200.rkvdec: bin=0
[    2.647503] mpp_rkvdec2 fdf80200.rkvdec: leakage=49
[    2.647524] mpp_rkvdec2 fdf80200.rkvdec: leakage-volt-sel=0
[    2.647563] mpp_rkvdec2 fdf80200.rkvdec: pvtm = 84080, from nvmem
[    2.647582] mpp_rkvdec2 fdf80200.rkvdec: pvtm-volt-sel=1
[    2.647838] mpp_rkvdec2 fdf80200.rkvdec: avs=0
[    2.648273] mpp_rkvdec2 fdf80200.rkvdec: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[    2.648426] mpp_rkvdec2 fdf80200.rkvdec: sram_start 0x00000000fdcc0000
[    2.648445] mpp_rkvdec2 fdf80200.rkvdec: rcb_iova 0x0000000010000000
[    2.648459] mpp_rkvdec2 fdf80200.rkvdec: sram_size 45056
[    2.648471] mpp_rkvdec2 fdf80200.rkvdec: rcb_size 65536
[    2.648486] mpp_rkvdec2 fdf80200.rkvdec: min_width 512
[    2.648547] mpp_rkvdec2 fdf80200.rkvdec: link mode probe finish
[    2.648622] mpp_rkvdec2 fdf80200.rkvdec: probing finish
[    2.648637] mpp_rkvdec2 fdf80200.rkvdec: probing finish
[    2.649623] rockchip-dmc dmc: bin=0
[    2.649682] mali fde60000.gpu: Kernel DDK version g25p0-00eac0
[    2.649710] rockchip-dmc dmc: leakage=49
[    2.649735] rockchip-dmc dmc: leakage-volt-sel=0
[    2.649774] rockchip-dmc dmc: pvtm = 84080, from nvmem
[    2.649794] rockchip-dmc dmc: pvtm-volt-sel=1
[    2.649811] rockchip-dmc dmc: soc version=0, speed=1
[    2.649847] mali fde60000.gpu: GPU metrics tracepoint support enabled
[    2.650208] rockchip-dmc dmc: avs=0
[    2.650233] rockchip-dmc dmc: current ATF version 0x102
[    2.650246] mali fde60000.gpu: bin=0
[    2.650321] mali fde60000.gpu: leakage=7
[    2.650362] mali fde60000.gpu: pvtm = 84080, from nvmem
[    2.650384] mali fde60000.gpu: pvtm-volt-sel=1
[    2.650400] mali fde60000.gpu: soc version=0, speed=1
[    2.651029] mali fde60000.gpu: avs=0
[    2.651051] rockchip-dmc dmc: normal_rate = 780000000
[    2.651071] rockchip-dmc dmc: reboot_rate = 1056000000
[    2.651080] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 144; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available.
[    2.651086] rockchip-dmc dmc: suspend_rate = 324000000
[    2.651113] rockchip-dmc dmc: video_4k_rate = 780000000
[    2.651127] rockchip-dmc dmc: video_4k_10b_rate = 780000000
[    2.651140] rockchip-dmc dmc: boost_rate = 1056000000
[    2.651154] rockchip-dmc dmc: fixed_rate(isp|cif0|cif1|dualview) = 1056000000
[    2.651169] rockchip-dmc dmc: performance_rate = 1056000000
[    2.651199] rockchip-dmc dmc: failed to get vop pn to msch rl
[    2.651420] mali fde60000.gpu: Register LUT 00070200 initialized for GPU arch 0x00070400
[    2.651466] mali fde60000.gpu: GPU identified as 0x2 arch 7.4.0 r1p0 status 0
[    2.651753] mali fde60000.gpu: No priority control manager is configured
[    2.651772] mali fde60000.gpu: Large page allocation set to false after hardware feature check
[    2.651784] rockchip-dmc dmc: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[    2.652326] mali fde60000.gpu: No memory group manager is configured
[    2.654234] mali fde60000.gpu: l=0 h=2147483647 hyst=5000 l_limit=700000000 h_limit=0 h_table=0
[    2.655606] mali fde60000.gpu: Couldn't find power_model DT node matching 'arm,mali-simple-power-model'
[    2.655664] mali fde60000.gpu: Error -22, no DT entry: mali-simple-power-model.static-coefficient = 1*[0]
[    2.656061] mali fde60000.gpu: Error -22, no DT entry: mali-simple-power-model.dynamic-coefficient = 1*[0]
[    2.656550] mali fde60000.gpu: Error -22, no DT entry: mali-simple-power-model.ts = 4*[0]
[    2.657020] mali fde60000.gpu: Error -22, no DT entry: mali-simple-power-model.thermal-zone = ''
[    2.657465] mali fde60000.gpu: No thermal zone specified, will use the default temperature value of 55000
[    2.659866] mali fde60000.gpu: Clearing BASE_MEM_UNCACHED_GPU flag to avoid MMA violation
[    2.660062] mali fde60000.gpu: Using configured power model mali-g52_r1-power-model, and fallback mali-simple-power-model
[    2.661013] RKNPU fde40000.npu: Adding to iommu group 0
[    2.661663] RKNPU fde40000.npu: RKNPU: rknpu iommu is enabled, using iommu mode
[    2.661712] mali fde60000.gpu: * MALI kbase_mmap_min_addr compiled to CONFIG_DEFAULT_MMAP_MIN_ADDR, no runtime update possible! *
[    2.661737] mali fde60000.gpu: Probed as mali0
[    2.662054] RKNPU fde40000.npu: can't request region for resource [mem 0xfde40000-0xfde4ffff]
[    2.662132] RKNPU fde40000.npu: error -ENXIO: IRQ npu_irq not found
[    2.662519] [drm] Initialized rknpu 0.9.8 20240828 for fde40000.npu on minor 1
[    2.663180] RKNPU fde40000.npu: bin=0
[    2.663244] RKNPU fde40000.npu: leakage=4
[    2.663289] RKNPU fde40000.npu: pvtm = 84080, from nvmem
[    2.663313] RKNPU fde40000.npu: pvtm-volt-sel=1
[    2.663331] RKNPU fde40000.npu: soc version=0, speed=1
[    2.664167] RKNPU fde40000.npu: avs=0
[    2.664386] RKNPU fde40000.npu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[    2.666779] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    2.668458] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[    2.669064] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    2.669188] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    2.669215] cfg80211: failed to load regulatory.db
[    2.669469] clk: Disabling unused clocks
[    2.670997] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[    2.671665] rockchip-suspend not set sleep-mode-config for mem-lite
[    2.671682] rockchip-suspend not set wakeup-config for mem-lite
[    2.671696] rockchip-suspend not set sleep-mode-config for mem-ultra
[    2.671708] rockchip-suspend not set wakeup-config for mem-ultra
[    2.672732] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 407; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '07:49:09', on 'Apr 22 2026'.
[    2.673305] Mali:
[    2.673312] Mali device driver loaded
[    2.673528] ALSA device list:
[    2.673549]   No soundcards found.
[    2.673906] Waiting for root device /dev/mmcblk0p3...
[    2.679268] mmc0: Host Software Queue enabled
[    2.679333] mmc0: new HS200 MMC card at address 0001
[    2.680908] mmcblk0: mmc0:0001 8GTF4R 7.28 GiB
[    2.685135]  mmcblk0: p1 p2 p3
[    2.686240] mmcblk0boot0: mmc0:0001 8GTF4R 4.00 MiB
[    2.688200] mmcblk0boot1: mmc0:0001 8GTF4R 4.00 MiB
[    2.689969] mmcblk0rpmb: mmc0:0001 8GTF4R 512 KiB, chardev (235:0)
[    2.705253] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Quota mode: disabled.
[    2.706003] vendor storage:20190527 ret = 0
[    2.707994] VFS: Mounted root (ext4 filesystem) on device 179:3.
[    2.708872] devtmpfs: mounted
[    2.721515] Freeing unused kernel memory: 7488K
[    2.721785] Run /sbin/init as init process
[    2.785403] BUG: spinlock wrong CPU on CPU#1, init/1
[    2.785511]  lock: 0xffffff8006e1c768, .magic: dead4ead, .owner: init/1, .owner_cpu: 16777217
[    2.785573] CPU: 1 PID: 1 Comm: init Not tainted 6.1.99-rk356x #8
[    2.785613] Hardware name: Embedfire LubanCat-RK356x (DT)
[    2.785646] Call trace:
[    2.785673]  dump_backtrace+0xe4/0x140
[    2.785724]  show_stack+0x20/0x30
[    2.785764]  dump_stack_lvl+0x68/0x84
[    2.785805]  dump_stack+0x18/0x34
[    2.785839]  spin_dump+0x9c/0xb0
[    2.785877]  do_raw_spin_unlock+0xf4/0x100
[    2.785921]  _raw_spin_unlock_irq+0x18/0x40
[    2.785958]  __filemap_add_folio+0x1f4/0x44c
[    2.785998]  filemap_add_folio+0x4c/0xd0
[    2.786033]  page_cache_ra_unbounded+0x104/0x200
[    2.786070]  ondemand_readahead+0x1c4/0x340
[    2.786104]  page_cache_sync_ra+0x7c/0xb0
[    2.786138]  filemap_get_pages+0xbc/0x67c
[    2.786173]  filemap_read+0xc0/0x360
[    2.786207]  generic_file_read_iter+0x108/0x1a0
[    2.786244]  ext4_file_read_iter+0x58/0x180
[    2.786287]  vfs_read+0x1bc/0x280
[    2.786325]  ksys_read+0x70/0xfc
[    2.786359]  __arm64_sys_read+0x24/0x30
[    2.786394]  invoke_syscall+0x50/0x120
[    2.786433]  el0_svc_common.constprop.0+0x58/0x190
[    2.786472]  do_el0_svc+0x24/0x30
[    2.786508]  el0_svc+0x28/0xb0
[    2.786542]  el0t_64_sync_handler+0xb8/0xbc
[    2.786579]  el0t_64_sync+0x19c/0x1a0
[    2.790146] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[    2.796964] CPU: 1 PID: 1 Comm: init Not tainted 6.1.99-rk356x #8
[    2.797532] Hardware name: Embedfire LubanCat-RK356x (DT)
[    2.798030] Call trace:
[    2.798266]  dump_backtrace+0xe4/0x140
[    2.798646]  show_stack+0x20/0x30
[    2.798977]  dump_stack_lvl+0x68/0x84
[    2.799331]  dump_stack+0x18/0x34
[    2.799656]  panic+0x17c/0x354
[    2.799960]  make_task_dead+0x0/0x18c
[    2.800313]  do_group_exit+0x3c/0xa0
[    2.800661]  get_signal+0x848/0x880
[    2.801003]  do_notify_resume+0x344/0xdec
[    2.801392]  el0_da+0xf4/0xfc
[    2.801683]  el0t_64_sync_handler+0x68/0xbc
[    2.802081]  el0t_64_sync+0x19c/0x1a0
[    2.802431] SMP: stopping secondary CPUs
[    2.802803] CPU2: stopping
[    2.802817] CPU: 2 PID: 0 Comm: swapper/2 Not tainted 6.1.99-rk356x #8
[    2.802831] Hardware name: Embedfire LubanCat-RK356x (DT)
[    2.802837] Call trace:
[    2.802842]  dump_backtrace+0xe4/0x140
[    2.802865]  show_stack+0x20/0x30
[    2.802869] CPU0: stopping
[    2.802881]  dump_stack_lvl+0x68/0x84
[    2.802884] CPU3: stopping
[    2.802895]  dump_stack+0x18/0x34
[    2.802908]  local_cpu_stop+0x78/0x80
[    2.802922]  ipi_handler+0xe4/0x2c0
[    2.802935]  handle_percpu_devid_irq+0x90/0x1c4
[    2.802950]  generic_handle_domain_irq+0x34/0x4c
[    2.802968]  gic_handle_irq+0x12c/0x268
[    2.802977]  call_on_irq_stack+0x24/0x50
[    2.802991]  do_interrupt_handler+0x88/0x9c
[    2.803004]  el1_interrupt+0x48/0xb0
[    2.803017]  el1h_64_irq_handler+0x18/0x2c
[    2.803030]  el1h_64_irq+0x74/0x78
[    2.803039]  cpuidle_enter_state+0xbc/0x44c
[    2.803057]  cpuidle_enter+0x40/0x60
[    2.803072]  do_idle+0x234/0x2c0
[    2.803088]  cpu_startup_entry+0x40/0x44
[    2.803102]  secondary_start_kernel+0x138/0x19c
[    2.803116]  __secondary_switched+0xb0/0xb4
[    2.803133] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 6.1.99-rk356x #8
[    2.803147] Hardware name: Embedfire LubanCat-RK356x (DT)
[    2.803153] Call trace:
[    2.803157]  dump_backtrace+0xe4/0x140
[    2.803178]  show_stack+0x20/0x30
[    2.803193]  dump_stack_lvl+0x68/0x84
[    2.803206]  dump_stack+0x18/0x34
[    2.803217]  local_cpu_stop+0x78/0x80
[    2.803231]  ipi_handler+0xe4/0x2c0
[    2.803243]  handle_percpu_devid_irq+0x90/0x1c4
[    2.803256]  generic_handle_domain_irq+0x34/0x4c
[    2.803271]  gic_handle_irq+0x12c/0x268
[    2.803281]  call_on_irq_stack+0x24/0x50
[    2.803293]  do_interrupt_handler+0x88/0x9c
[    2.803306]  el1_interrupt+0x48/0xb0
[    2.803318]  el1h_64_irq_handler+0x18/0x2c
[    2.803331]  el1h_64_irq+0x74/0x78
[    2.803340]  cpuidle_enter_state+0xbc/0x44c
[    2.803357]  cpuidle_enter+0x40/0x60
[    2.803371]  do_idle+0x234/0x2c0
[    2.803385]  cpu_startup_entry+0x3c/0x44
[    2.803399]  secondary_start_kernel+0x138/0x19c
[    2.803413]  __secondary_switched+0xb0/0xb4
[    2.803429] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 6.1.99-rk356x #8
[    2.803443] Hardware name: Embedfire LubanCat-RK356x (DT)
[    2.803448] Call trace:
[    2.803452]  dump_backtrace+0xe4/0x140
[    2.803473]  show_stack+0x20/0x30
[    2.803488]  dump_stack_lvl+0x68/0x84
[    2.803501]  dump_stack+0x18/0x34
[    2.803512]  local_cpu_stop+0x78/0x80
[    2.803525]  ipi_handler+0xe4/0x2c0
[    2.803537]  handle_percpu_devid_irq+0x90/0x1c4
[    2.803549]  generic_handle_domain_irq+0x34/0x4c
[    2.803565]  gic_handle_irq+0x12c/0x268
[    2.803574]  call_on_irq_stack+0x24/0x50
[    2.803586]  do_interrupt_handler+0x88/0x9c
[    2.803599]  el1_interrupt+0x48/0xb0
[    2.803611]  el1h_64_irq_handler+0x18/0x2c
[    2.803624]  el1h_64_irq+0x74/0x78
[    2.803633]  cpuidle_enter_state+0xbc/0x44c
[    2.803649]  cpuidle_enter+0x40/0x60
[    2.803663]  do_idle+0x234/0x2c0
[    2.803677]  cpu_startup_entry+0x40/0x44
[    2.803691]  rest_init+0xd8/0xe0
[    2.803705]  arch_post_acpi_subsys_init+0x0/0x28
[    2.803720]  start_kernel+0x72c/0x76c
[    2.803733]  __primary_switched+0xb4/0xbc
[    2.803749] PMU CRU:
[    2.830420] 00000000: 00006064 00001481 00000000 00000007 00007f00 00000000 00000000 00000000
[    2.831208] 00000020: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    2.831995] 00000040: 00002063 00001481 00000000 00000007 00007f00 00000000 00000000 00000000
[    2.832781] 00000060: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    2.833565] 00000080: 00000001 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    2.834350] 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    2.835133] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    2.835918] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    2.836702] 00000100: 00000080 0040b71b 00000001 00000001 00000800 00000000 00000001 00000009
[    2.837487] 00000120: 0000050f 0000888b 00000000 00000000 00000000 00000000 00000000 00000000
[    2.838270] 00000140: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    2.839054] 00000160: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    2.839838] 00000180: 00000000 000039ff 0000fff9 00000000 00000000 00000000 00000000 00000000
[    2.840622] 000001a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    2.841405] 000001c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    2.842189] 000001e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    2.842973] 00000200: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    2.843756] 00000220: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    2.844531] 00000240: 00040020 00000000
[    2.844895] CRU:
[    2.845089] 00000000: 00004064 00001441 00000000 00000007 00007f00 00000000 00000000 00000000
[    2.845873] 00000020: 00004082 00001481 00000000 00000007 00007f00 00000000 00000000 00000000
[    2.846656] 00000040: 00002063 00001441 00000000 00000007 00007f00 00000000 00000000 00000000
[    2.847439] 00000060: 0000107d 00001443 00000000 00000007 00007f00 00000000 00000000 00000000
[    2.848223] 00000080: 00002064 00001441 00000000 00000000 00000000 00000000 00000000 00000000
[    2.849006] 000000a0: 0000307d 00001442 00000000 00000000 00000000 00000000 00000000 00000000
[    2.849790] 000000c0: 00004455 00000000 00000000 00000000 00640064 00000000 00000000 00000103
[    2.850573] 000000e0: 00000001 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    2.851357] 00000100: 000000c0 00000000 00000001 00000101 00000101 00000111 00004155 000000e5
[    2.852141] 00000120: 00000053 00000100 00000000 00008000 00040004 00008000 00040004 00000400
[    2.852924] 00000140: 00803057 00008000 00040004 00008000 00040004 00008000 00040004 00004000
[    2.853708] 00000160: 00040004 0000000b 00000000 00000010 00001031 00001c30 00000520 00000000
[    2.854492] 00000180: 00000020 00000004 00000310 0000c001 0000c0c0 00003100 00000001 00000000
[    2.855276] 000001a0: 00000401 00000003 00000103 00002100 00000203 00000003 00000000 00000103
[    2.856060] 000001c0: 00000003 00000303 00000001 00001725 0000200b 00000000 0000200b 00000000
[    2.856843] 000001e0: 0000200b 00000000 0000200b 00000000 0000200b 00000000 0000200b 00000000
[    2.857627] 00000200: 0000200b 00000000 0000200b 00000000 0000200b 00000000 00000303 00000203
[    2.858411] 00000220: 00001500 00000000 0000001f 00000302 00000705 00000f0b 0000013b 00000303
[    2.859195] 00000240: 00000f07 00002713 00001f09 00008000 00040004 00003b2f 00000101 00000302
[    2.859978] 00000260: 00000704 0000130f 00001f27 00000000 00000000 00000000 00000000 00000000
[    2.860762] 00000280: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    2.861544] 000002a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    2.862328] 000002c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    2.863110] 000002e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    2.863893] 00000300: 00000000 00000e00 000001c0 00000f9f 00000000 0000ff00 0000ffff 0000ffff
[    2.864676] 00000320: 0000f87f 00000c1f 00000010 00000777 00001f1f 0000005f 00000000 000011fc
[    2.865460] 00000340: 00000000 00000467 00002e07 00000717 00003d40 000003c7 0000d033 0000fff3
[    2.866243] 00000360: 000001c3 00000000 00000e00 0000f7e0 0000fff6 0000ffff 0000ffff 0000fc03
[    2.867026] 00000380: 000087e7 0000e100 00007870 00002000 00000000 00000000 00000000 00000000
[    2.867809] 000003a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    2.868592] 000003c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    2.869374] 000003e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    2.870158] 00000400: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    2.870941] 00000420: 00000000 00000000 00000002 00000002 00000002 00000000 00000000 00000000
[    2.871724] 00000440: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    2.872506] 00000460: 00000000 00000000 00000400 00000000 000002a0 00000000 00000000 00000000
[    2.873290] 00000480: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    2.874073] 000004a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    2.874856] 000004c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    2.875640] 000004e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    2.876423] 00000500: 00040020 00000000 00040020 00000000 00040020 00000000 00040020 00000000
[    2.877207] 00000520: 00040020 00000000 00040020 00000000 00040020 00000000 00040020 00000000
[    2.877990] 00000540: 00040020 00000000 00040020 00000000 00000000 00000000 00000000 00000000
[    2.878773] 00000560: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    2.879549] 00000580: 00000002 00000000
[    2.879916] CPU0 online:0
[    2.880177]  EL2(NS) PC: <0xffffffc008023508> local_cpu_stop+0x48/0x80
[    2.880907]
[    2.881057] CPU1 online:1
[    2.881316]  EL2(NS) PC: <0xffffffc008996f40> readl+0x0/0x20
[    2.881959]
[    2.882109] CPU2 online:0
[    2.882367]  EL2(NS) PC: <0xffffffc008023508> local_cpu_stop+0x48/0x80
[    2.883030]  EL2(NS) PC: <0xffffffc00802350c> local_cpu_stop+0x4c/0x80
[    2.883643]  EL2(NS) PC: <0xffffffc008023508> local_cpu_stop+0x48/0x80
[    2.884317]
[    2.884466] CPU3 online:0
[    2.884724]  EL2(NS) PC: <0xffffffc008023508> local_cpu_stop+0x48/0x80
[    2.885446]
[    2.885604]            CPU0       CPU1       CPU2       CPU3
[    2.886202]  13:        581        539        592        349     GICv3  26 Level     arch_timer
[    2.886997]  14:         10          6         22         21     GICv3 141 Level     rk_timer
[    2.887780]  15:          0          0          0          0     GICv3  65 Level     (null)
[    2.888548]  16:          0          0          0          0     GICv3  66 Level     (null)
[    2.889317]  17:          0          0          0          0     GICv3  67 Level     (null)
[    2.890084]  18:          0          0          0          0     GICv3  68 Level     (null)
[    2.890852]  19:          0          0          0          0     GICv3  69 Level     (null)
[    2.891621]  20:          0          0          0          0     GICv3 284 Edge      debug-signal
[    2.892437]  21:          0          0          0          0     GICv3 150 Level     debug
[    2.893196]  22:          0          0          0          0     GICv3 147 Level     rockchip_thermal
[    2.894036]  23:          0          0          0          0     GICv3 260 Level     arm-pmu
[    2.894806]  24:          0          0          0          0     GICv3 261 Level     arm-pmu
[    2.895575]  25:          0          0          0          0     GICv3 262 Level     arm-pmu
[    2.896343]  26:          0          0          0          0     GICv3 263 Level     arm-pmu
[    2.897125]  27:          1          0          0          0     GICv3 167 Level     rockchip_usb2phy
[    2.897966]  28:          0          0          0          0     GICv3 168 Level     rockchip_usb2phy
[    2.898807]  29:          0          0          0          0     GICv3  46 Level     fe530000.dma-controller
[    2.899707]  30:          0          0          0          0     GICv3  45 Level     fe530000.dma-controller
[    2.900608]  31:          0          0          0          0     GICv3  48 Level     fe550000.dma-controller
[    2.901509]  32:          0          0          0          0     GICv3  47 Level     fe550000.dma-controller
[    2.902412]  33:          0          0          0          0     GICv3 183 Level     fde4b000.iommu, fde40000.npu
[    2.903350]  34:          0          0          0          0     GICv3 170 Level     fdea0800.iommu
[    2.904178]  35:          0          0          0          0     GICv3  93 Level     fded0480.iommu
[    2.905006]  36:          0          0          0          0     GICv3  95 Level     fdee0800.iommu
[    2.905836]  37:          0          0          0          0     GICv3  88 Level     fdef0800.iommu, fdef0000.iep
[    2.906773]  38:          0          0          0          0     GICv3 173 Level     fdf40f00.iommu
[    2.907601]  39:          0          0          0          0     GICv3 174 Level     fdf40f00.iommu
[    2.908430]  40:          0          0          0          0     GICv3 124 Level     fdf80800.iommu
[    2.909261]  41:          0          0          0          0     GICv3 180 Level     fe043e00.iommu, fe040000.vop
[    2.910199]  42:          0          0          0          0     GICv3  77 Level     fe0a0000.hdmi, dw-hdmi-cec
[    2.911118]  46:          0          0          0          0     GICv3 202 Level     xhci-hcd:usb1
[    2.911936]  47:          0          0          0          0     GICv3 165 Level     ehci_hcd:usb5
[    2.912753]  48:          0          0          0          0     GICv3 162 Level     ehci_hcd:usb3
[    2.913571]  49:          0          0          0          0     GICv3 163 Level     ohci_hcd:usb4
[    2.914388]  50:          0          0          0          0     GICv3 166 Level     ohci_hcd:usb6
[    2.915207]  51:        213          0          0          0     GICv3  78 Level     fdd40000.i2c
[    2.916025]  52:          0          0          0          0  rockchip_gpio_irq   3 Level     rk817
[    2.916854]  53:          0          0          0          0     rk817   0 Edge      rk805_pwrkey_fall
[    2.917707]  54:          0          0          0          0     rk817   1 Edge      rk805_pwrkey_rise
[    2.918577]  77:          0          0          0          0     GICv3  40 Level     rockchip-mipi-csi2-hw
[    2.919454]  78:          0          0          0          0     GICv3  41 Level     rockchip-mipi-csi2-hw
[    2.920332]  79:          0          0          0          0     GICv3 181 Edge      fe600000.watchdog
[    2.921184]  80:          0          0          0          0     GICv3 130 Level     dw-mci
[    2.921954]  81:        387          0          0          0     GICv3  51 Level     mmc0
[    2.922709]  82:          0          0          0          0     GICv3 125 Level     fe720000.saradc
[    2.923550]  83:          0          0          0          0     GICv3 122 Level     rga2
[    2.924306]  84:          0          0          0          0     GICv3 172 Level     fdf40000.rkvenc
[    2.925147]  85:          0          0          0          0     GICv3 171 Level     fdea0400.vdpu
[    2.925965]  86:          0          0          0          0     GICv3  96 Level     fdee0000.vepu
[    2.926783]  87:          0          0          0          0     GICv3  94 Level     fded0000.jpegd
[    2.927611]  88:          0          0          0          0     GICv3 123 Level     fdf80200.rkvdec
[    2.928441]  89:          1          0          0          0     GICv3  72 Level     fde60000.gpu
[    2.929257]  90:          1          0          0          0     GICv3  73 Level     fde60000.gpu
[    2.930073]  91:          1          0          0          0     GICv3  71 Level     fde60000.gpu
[    2.930889]  92:          3          0          0          0     GICv3  42 Level     dmc
[    3.931753]            CPU0       CPU1       CPU2       CPU3
[    3.932343]  13:        581        539        592        349     GICv3  26 Level     arch_timer
[    3.933136]  14:         10          6         22         21     GICv3 141 Level     rk_timer
[    3.933916]  15:          0          0          0          0     GICv3  65 Level     (null)
[    3.934683]  16:          0          0          0          0     GICv3  66 Level     (null)
[    3.935450]  17:          0          0          0          0     GICv3  67 Level     (null)
[    3.936216]  18:          0          0          0          0     GICv3  68 Level     (null)
[    3.936983]  19:          0          0          0          0     GICv3  69 Level     (null)
[    3.937750]  20:          0          0          0          0     GICv3 284 Edge      debug-signal
[    3.938566]  21:          0          0          0          0     GICv3 150 Level     debug
[    3.939323]  22:          0          0          0          0     GICv3 147 Level     rockchip_thermal
[    3.940162]  23:          0          0          0          0     GICv3 260 Level     arm-pmu
[    3.940931]  24:          0          0          0          0     GICv3 261 Level     arm-pmu
[    3.941709]  25:          0          0          0          0     GICv3 262 Level     arm-pmu
[    3.942477]  26:          0          0          0          0     GICv3 263 Level     arm-pmu
[    3.943256]  27:          1          0          0          0     GICv3 167 Level     rockchip_usb2phy
[    3.944096]  28:          0          0          0          0     GICv3 168 Level     rockchip_usb2phy
[    3.944936]  29:          0          0          0          0     GICv3  46 Level     fe530000.dma-controller
[    3.945837]  30:          0          0          0          0     GICv3  45 Level     fe530000.dma-controller
[    3.946736]  31:          0          0          0          0     GICv3  48 Level     fe550000.dma-controller
[    3.947636]  32:          0          0          0          0     GICv3  47 Level     fe550000.dma-controller
[    3.948536]  33:          0          0          0          0     GICv3 183 Level     fde4b000.iommu, fde40000.npu
[    3.949473]  34:          0          0          0          0     GICv3 170 Level     fdea0800.iommu
[    3.950300]  35:          0          0          0          0     GICv3  93 Level     fded0480.iommu
[    3.951128]  36:          0          0          0          0     GICv3  95 Level     fdee0800.iommu
[    3.951956]  37:          0          0          0          0     GICv3  88 Level     fdef0800.iommu, fdef0000.iep
[    3.952892]  38:          0          0          0          0     GICv3 173 Level     fdf40f00.iommu
[    3.953719]  39:          0          0          0          0     GICv3 174 Level     fdf40f00.iommu
[    3.954547]  40:          0          0          0          0     GICv3 124 Level     fdf80800.iommu
[    3.955375]  41:          0          0          0          0     GICv3 180 Level     fe043e00.iommu, fe040000.vop
[    3.956313]  42:          0          0          0          0     GICv3  77 Level     fe0a0000.hdmi, dw-hdmi-cec
[    3.957228]  46:          0          0          0          0     GICv3 202 Level     xhci-hcd:usb1
[    3.958045]  47:          0          0          0          0     GICv3 165 Level     ehci_hcd:usb5
[    3.958861]  48:          0          0          0          0     GICv3 162 Level     ehci_hcd:usb3
[    3.959678]  49:          0          0          0          0     GICv3 163 Level     ohci_hcd:usb4
[    3.960493]  50:          0          0          0          0     GICv3 166 Level     ohci_hcd:usb6
[    3.961310]  51:        213          0          0          0     GICv3  78 Level     fdd40000.i2c
[    3.962124]  52:          0          0          0          0  rockchip_gpio_irq   3 Level     rk817
[    3.962952]  53:          0          0          0          0     rk817   0 Edge      rk805_pwrkey_fall
[    3.963803]  54:          0          0          0          0     rk817   1 Edge      rk805_pwrkey_rise
[    3.964666]  77:          0          0          0          0     GICv3  40 Level     rockchip-mipi-csi2-hw
[    3.965543]  78:          0          0          0          0     GICv3  41 Level     rockchip-mipi-csi2-hw
[    3.966421]  79:          0          0          0          0     GICv3 181 Edge      fe600000.watchdog
[    3.967272]  80:          0          0          0          0     GICv3 130 Level     dw-mci
[    3.968039]  81:        387          0          0          0     GICv3  51 Level     mmc0
[    3.968794]  82:          0          0          0          0     GICv3 125 Level     fe720000.saradc
[    3.969633]  83:          0          0          0          0     GICv3 122 Level     rga2
[    3.970387]  84:          0          0          0          0     GICv3 172 Level     fdf40000.rkvenc
[    3.971226]  85:          0          0          0          0     GICv3 171 Level     fdea0400.vdpu
[    3.972042]  86:          0          0          0          0     GICv3  96 Level     fdee0000.vepu
[    3.972857]  87:          0          0          0          0     GICv3  94 Level     fded0000.jpegd
[    3.973683]  88:          0          0          0          0     GICv3 123 Level     fdf80200.rkvdec
[    3.974512]  89:          1          0          0          0     GICv3  72 Level     fde60000.gpu
[    3.975327]  90:          1          0          0          0     GICv3  73 Level     fde60000.gpu
[    3.976142]  91:          1          0          0          0     GICv3  71 Level     fde60000.gpu
[    3.976956]  92:          3          0          0          0     GICv3  42 Level     dmc
[    3.977691] PMU:
[    3.977877] pwr       0x00a0: 00000046 00000000 00000003 00000000
[    3.978453] status    0x0098: 00000046 00000000 00000046 00000000
[    3.979023] req       0x0050: 0000004c 00000000 00000000 00000000
[    3.979593] idle      0x0068: 0000004c 00000000 0000ffff 0000000f
[    3.980162] ack       0x0060: 0000004c 00000000 0000004c 00000000
[    3.980738] rockchip-thermal fe710000.tsadc: channal 0: temperature(60 C)
[    3.981372] rockchip-thermal fe710000.tsadc: channal 1: temperature(53 C)
[    3.982000] THERMAL REGS:
[    3.982266] 00000000: 00000fc0 00010033 00000303 00000000 00000000 00000000 00000000 00000000
[    3.983052] 00000020: 000008cc 000008a4 00000000 00000000 00000940 00000a4c 00000000 00000000
[    3.983837] 00000040: 00000a70 00000a70 00000000 00000000 00000000 00000000 00000000 00000000
[    3.984622] 00000060: 00000004 00000004 00000656 00000656 00000000 00000000 00000000 00000000
[    3.985398] 00000080: 00000000 00000000
[    3.985764] Kernel Offset: disabled
[    3.986091] CPU features: 0x60000,000400a4,6600700b
[    3.986543] Memory Limit: none
[    3.986857] cpu cpu0: cur_freq: 600000000 Hz, volt: 850000 uV
[    3.987401] rockchip-dmc dmc: cur_freq: 780000000 Hz, volt: 875000 uV
[    4.021725] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b ]---
板子是自己画的RK3566。LPDDR4 2GB ,EMMC 16GB。大佬有遇到过这种情况吗?烧录了很多镜像但是最后卡死在这个地方,测过电源正常、重新焊接过几次。
#1 今天 08:22:25
yixiuge
已发帖子: 67
Re: RK3566卡死在---[ end Kernel panic - not syncing: Attempted to kill init!
根分区已挂载,panic是结果;先查spinlock wrong CPU,降DDR/关DMC变频并核对eMMC容量。
