楼主 # 昨天 14:27:54
QL2017
已发帖子: 84
全志A133启动失败
很离奇,就是无法开机,并且好像别的核心启动失败,不知道为啥,以下是完整Log:
[06.019]LCD open finish
[42]HELLO! BOOT0 is starting!
[45]BOOT0 commit : 7cc6792
[48]set pll start
[50]periph0 has been enabled
[53]set pll end
[55][pmu]: bus read error
[58]PMU: AXP803
[77]vaild para:1 select dram para0
[81]board init ok
[83]rtc[3] value = 0xb00f
[95]key pressed value=0x39
[108]DRAM BOOT DRIVE INFO: V0.40
[111]the chip id is 0x1400
[114]the chip id is 0x1400
[116]the chip id is 0x1400
[119]the chip id is 0x1400
[122]the chip id is 0x1400
[124]chip id check OK
[129]DRAM_VCC set to 1200 mv
[132]DRAM CLK =576 MHZ
[134]DRAM Type =7 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4)
[141]DRAM SIZE =2048 MBytes, para1 = 30fa, para2 = 8001000, dram_tpr13 = 6063
[148]dram_tpr11 = 10120c05,dram_tpr12 = 12121111
[158]DRAM simple test OK.
[160]dram size =2048
[162]chipid = 54401400
[165]nsi init ok 2020-4-7
[168]card no is 2
[170]sdcard 2 line count 8
[173][mmc]: mmc driver ver 2020-05-25 09:40-202007019516
[184][mmc]: Wrong media type 0x0
[187][mmc]: Try SD card 2
[191][mmc]: mmc 2 cmd 8 timeout, err 100
[195][mmc]: mmc 2 cmd 8 err 100
[198][mmc]: mmc 2 send if cond failed
[202][mmc]: mmc 2 cmd 55 timeout, err 100
[206][mmc]: mmc 2 cmd 55 err 100
[210][mmc]: mmc 2 send app cmd failed
[213][mmc]: Try MMC card 2
[246][mmc]: RMCA OK!
[248][mmc]: bias 4
[250][mmc]: mmc 2 bias 4
[253][mmc]: MMC 5.0
[255][mmc]: HSSDR52/SDR25 8 bit
[258][mmc]: 50000000 Hz
[260][mmc]: 3776 MB
[262][mmc]: SD/MMC 2 init OK!!!
[326]Loading boot-pkg Succeed(index=0).
[330]Entry_name = u-boot
[337]Entry_name = monitor
[341]Entry_name = scp
[349]set arisc reset to de-assert state
[353]Entry_name = dtb
[356]tunning data addr:0x4a0003e8
[360]Jump to second Boot.
NOTICE: BL3-1: v1.0(debug):5c8d955
NOTICE: BL3-1: Built : 14:47:18, 2020-08-14
NOTICE: BL3-1 commit: 8
ERROR: Error initializing runtime service tspd_fast
NOTICE: BL3-1: Preparing for EL3 exit to normal world
NOTICE: BL3-1: Next image address = 0x4a000000
NOTICE: BL3-1: Next image spsr = 0x1d3
U-Boot 2018.05-00002-gf806feb9ff (Sep 13 2020 - 05:36:41 +0000) Allwinner Technology
[00.446]CPU: Allwinner Family
[00.449]Model: sun50iw10
I2C: ready
[00.582]DRAM: 2 GiB
[00.585]Relocation Offset is: 75f14000
[00.618]secure enable bit: 0
[00.623][ARISC ERROR] :get [allwinner,sunxi-hwspinlock] device node error
CACHE: Misaligned operation at range [bffa70f8, bffa7410]
[SCP] :sunxi-arisc driver begin startup 2
[SCP] :0x1
[SCP] :arisc version: []
[SCP] :arisc startup ready
[SCP] :arisc startup notify message feedback
[SCP] :send hard sync feedback message: 0x900200
[SCP] :sunxi-arisc driver v1.10 is starting
[00.658]PMU: AXP803
[00.661]PMU: AXP803
bias_name:pc_bias bias_vol:1800
[00.681]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=400Mhz
[00.688]drv_disp_init
request pwm success, pwm0:pwm0:0x300a000.
[00.720]drv_disp_init finish
[00.725]gic: sec monitor mode
[00.727]flash init start
[00.730]workmode = 0,storage type = 2
[00.733][mmc]: mmc driver ver uboot2018:2020-5-25 9:26:00-202007011433
[00.740][mmc]: get sdc_type fail and use default host:tm4.
[00.752][mmc]: SUNXI SDMMC Controller Version:0x50300
[00.790][mmc]: Best spd md: 4-HS400, freq: 3-100000000, Bus width: 8
[00.796]sunxi flash init ok
[00.800]Loading Environment from SUNXI_FLASH... OK
[00.820]Item0 (Map) magic is bad
[00.823]the secure storage item0 copy0 magic is bad
[00.839]Item0 (Map) magic is bad
[00.842]the secure storage item0 copy1 magic is bad
[00.847]Item0 (Map) magic is bad
[00.850]usb burn from boot
delay time 0
weak:otg_phy_config
[00.860]usb prepare ok
[01.663]overtime
[01.668]do_burn_from_boot usb : no usb exist
[01.672]boot_gui_init:start
[01.677]set disp.dev2_output_type fail. using defval=0
[01.738]boot_gui_init:finish
4096056 bytes read in 24 ms (162.8 MiB/s)
[01.784]update dts
Unrecognized filesystem type
[01.793]load file(ULI/factory/snum.txt) error.
[01.804]load file(ULI/factory/mac.txt) error.
[01.815]load file(ULI/factory/wifi_mac.txt) error.
[01.827]load file(ULI/factory/bt_mac.txt) error.
[01.838]load file(ULI/factory/specialstr.txt) error.
[01.847]update part info
[01.900]update bootcmd
[02.007]soc ic_ver:0x6, qa_val:0x0, markid:0x54401400 dclk[0-9999]
[02.021]LCD open finish
[02.271]Starting kernel ...
[02.273][mmc]: mmc exit start
[02.311][mmc]: mmc 2 exit ok
[ 0.000000] Linux version 4.9.170 (nexa@nexa-desktop) (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05) ) #1 SMP PREEMPT Sat Sep 19 10:40:41 CST 2026
[ 0.000000] Boot CPU: AArch64 Processor [410fd034]
[ 0.000000] bootconsole [earlycon0] enabled
[ 0.107681] BOOTEVENT: 107.668915: ON
[ 1.147039] CPU1: failed to come online
[ 1.147079] CPU1: failed in unknown state : 0x0
[ 2.188735] CPU2: failed to come online
[ 2.188773] CPU2: failed in unknown state : 0x0
[ 3.230441] CPU3: failed to come online
[ 3.230479] CPU3: failed in unknown state : 0x0
[ 3.449448] axp2101-regulator axp2101-regulator.0: Setting DCDC frequency for unsupported AXP variant
[ 3.453269] axp2101-regulator axp2101-regulator.0: Error setting dcdc frequency: -22
[ 3.704000] disp soc@03000000:disp1@1: unable to map de registers
[ 郲 3.769040] uart uart1: get regulator failed
[ 3.923527] [NAND][NE] Not found valid nand node on dts
[ 3.935210] sunxi-wlan soc@03000000:wlan@0: get gpio chip_en failed
[ 3.942566] sunxi-wlan soc@03000000:wlan@0: get gpio power_en failed
[ 3.959495] sunxi-ehci 5200000.ehci1-controller: init_sunxi_hci is fail
[ 3.969933] sunxi-ohci 5200000.ohci1-controller: init_sunxi_hci is fail
[ 4.006010] twi_stop()514 - [i2c1] STOP can't sendout!
[ 4.011790] sunxi_i2c_core_process()1751 - [i2c1] STOP failed!
[ 4.018417] sunxi_i2c_do_xfer()1950 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x19)
[ 4.032713] VE: get debugfs_mpp_root is NULL, please check mpp
[ 4.032713]
[ 4.041659] VE: sunxi ve debug register driver failed!
[ 4.041659]
[ 4.115266] mmc:failed to get gpios
