楼主 #1 2018-10-28 11:56:08
asdf
已发帖子: 58
f1c100s官方bsp关于spi nand启动的问题
我拿到一个f1c100s能用的spi nand的lib库,同样的板子,同样的包之前烧录并且运行好几次都没问题,都成功起到文件系统的,啥没改说烧录不进去就不进去了,我跟踪了部分关键打印,初始化都成功但一到要下载写入就gg了,有大佬能帮忙分析下可能的原因不,硬件电路确认过,奇怪的是前后软硬都没变怎么就不行了,会有可能影响到了哪个关键寄存器值?
NAND_UbootInit
[1.443]NAND_UbootInit start
[1.445]NB1: enter NAND_LogicInit
[1.448]SpiNandHwInit: Start Nand Hardware initializing .....
[1.454]uboot: nand version: 3 6006 20180504 1300
int sunxi_dma_init---
irq enable
[1.473]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x83eb8b94
[1.480]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x83eb8bb4
_get_spic_clk_v1: sclk0=0x64
[1.510]not burn nand partition table!
[1.514][ND]not enough block:479,878!!
[1.517][NE]build phy partition 0 error!
[1.521][NE]build all phy partition fail!
[1.729][NE]not find mbr table!!!!
[1.732]NB1: nand_info_init fail
[1.735]NAND_UbootInit end: 0xfffffffb
NAND_UbootExit
[1.740]NB1: NAND_LogicExit
nand release dma:83eb8b94
nand release dma:0
sunxi dma exit
[1.748]erase_flag = 1
[1.750]NB1 : enter phy init
[1.753]SpiNandHwInit: Start Nand Hardware initializing .....
[1.758]uboot: nand version: 3 6006 20180504 1300
irq enable
[1.778]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x83eb8b94
[1.785]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x83eb8bb4
[1.815]NB1 : nand phy init ok
[1.818]erase by flag 1
[1.820]has cleared the boot blocks.
[1.917]erase block128
[2.086]erase block256
[2.256]erase block384
[2.425]erase block512
[2.595]erase block640
[2.765]erase block768
[2.934]erase block896
[3.102]NAND_Uboot_Erase
[3.104]NB1 : enter phy Exit
nand release dma:0
sunxi dma exit
[3.112]successed in erasing flash
NAND_UbootInit
[3.117]NAND_UbootInit start
[3.120]NB1: enter NAND_LogicInit
[3.123]SpiNandHwInit: Start Nand Hardware initializing .....
[3.128]uboot: nand version: 3 6006 20180504 1300
[3.144]request spi gpio ok!
irq enable
[3.150]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x83eb8b94
[3.157]request general tx dma channel ok!
[3.161]uboot nand_request_tx_dma: reqest genernal dma for nand success, 0x83eb8bb4
[3.169]request general rx dma channel ok!
[3.172]SPI nand ID: 12c212c2 12c212c2
[3.176][SCAN_DBG] NandTwoPlaneOp: 1, DriverTwoPlaneOPCfg: 1, 0xffcfffff
[3.182]nand : get id number_ctl from script:0x55aaaa55
[3.187]_UpdateExtAccessFreqPara: no para.
[3.191]PHY_Scan_DelayMode: right delay mode 0x0
[3.196]PHY_Scan_DelayMode: right delay mode 0x800
[3.203]PHY_Scan_DelayMode: right delay mode,clk 50 MHz, bit[13]=0,bit[11]=0
[3.209]physic_info_read start!!
[3.212]physic_info_read already!!
[3.215]
[3.216][SCAN_DBG] ==============Nand Architecture Parameter==============
[3.223][SCAN_DBG] Nand Chip ID: 0xffff12c2 0xffffffff
[3.229][SCAN_DBG] Nand Chip Count: 0x1
[3.233][SCAN_DBG] Nand Chip Connect: 0x1
[3.237][SCAN_DBG] Sector Count Of Page: 0x4
[3.241][SCAN_DBG] Page Count Of Block: 0x40
[3.246][SCAN_DBG] Block Count Of Die: 0x400
[3.250][SCAN_DBG] Plane Count Of Die: 0x1
[3.254][SCAN_DBG] Die Count Of Chip: 0x1
[3.259][SCAN_DBG] Bank Count Of Chip: 0x1
[3.263][SCAN_DBG] Optional Operation: 0x60
[3.267][SCAN_DBG] Access Frequence: 0x0
[3.271][SCAN_DBG] =======================================================
[3.298]secure storage updata ok!
[3.301]nand secure storage ok: 58,59
[3.304]nand: get CapacityLevel from script, 55aaaa55
[3.309]burn nand partition table! mbr tbl: 0x83eebcc4, part_count:9
[3.315]start block:60
[3.317][ND]factory FirstBuild 66
[3.320]PHY_PageReadSpare bad flag: bank 0x0 block 0x45 page 0x1
[3.326]PHY_PageReadSpare bad flag: bank 0x0 block 0x45 page 0x0
[3.332][PHY_DBG] Find a bad block (NO. 0x45) in the Die 0x0
[3.337]PHY_PageReadSpare bad flag: bank 0x0 block 0x46 page 0x1
[3.343]PHY_PageReadSpare bad flag: bank 0x0 block 0x46 page 0x0
[3.349][PHY_DBG] Find a bad block (NO. 0x46) in the Die 0x0
[3.355]PHY_PageReadSpare bad flag: bank 0x0 block 0x47 page 0x1
[3.361]PHY_PageReadSpare bad flag: bank 0x0 block 0x47 page 0x0
#2 2018-10-28 12:25:39
cityf
已发帖子: 195
Re: f1c100s官方bsp关于spi nand启动的问题
看不出来, 是不是坏块没处理好?
#3 2018-10-28 12:29:05
cityf
已发帖子: 195
这个 linux 是什么版本? 4.19 已经内置支持了 spi nand了.
楼主 #4 2018-10-28 13:19:44
asdf
已发帖子: 58
我这还是3.10的,不过这个出问题的还在uboot阶段,还没到kernel的
楼主 #5 2018-10-28 13:22:29
asdf
已发帖子: 58
kernel前的部分代码我得去看看有没有,还不确定是不是闭源的,话说你有成功稳定跑起过spi nand么,
#6 2018-10-28 15:28:09
v3s
已发帖子: 105
全志官方提供的 uboot spi nand lib?
最近编辑记录 v3s (2018-10-28 15:28:54)
此人很懒,没有签名!
#7 2018-10-28 16:00:41
这个是主线 u-boot, 支持 spi nand, 出自大神 @assert
就看你能不能用起来
https://whycan.cn/t_1594.html
#8 2018-10-28 16:11:52
可以用这个 sunxi-fel, 支持 GD5F1G spinand
楼主 #9 2018-10-28 22:27:16
asdf
已发帖子: 58
好的,多谢晕哥,板子不在手头明天我试下
就看你能不能用起来
楼主 #10 2018-10-28 22:28:46
asdf
已发帖子: 58
我还没去看有没代码,反正官方说的支持的
楼主 #11 2018-10-29 10:56:08
asdf
已发帖子: 58
我刚好有块gd的nand,查看info对得上,话说我能直接用这个烧.img不晕哥,如果不行的话要弄整个系统大概怎么操作的呢~~
/files/members/3/QQ20181028160937.png
#12 2018-10-29 11:06:38
assert说可以,你试一试,我没有用过
楼主 #13 2018-10-29 15:37:18
asdf
已发帖子: 58
这个sunxi-fel工具我烧了个0x6000长度的spl,然后有两个问题,第一烧录速度极慢,0.2k左右;第二烧录到spinand数据排列有问题,我的芯片是GD5F1G的,通过从spinand反读回来跟原spl.bin对比,spinand里面是跳着写入的,前1024一样,1024-2048全为ff,2049开始又跟源文件的1025一样了,现象就是跳1024个字节,但是只有sunxi-fel的bin文件~~
#14 2018-10-29 15:40:46
boot0部分只用1024字节,读回的时候按正常方式读取。
1024字节是brom决定的。
楼主 #15 2018-10-29 16:03:28
asdf
已发帖子: 58
嗯,从启动现象看已经初始化好了dram,正在尝试跳转,现在我在把整个uboot下进去,可是感人的速度
6% [== ] 0.2 kB/s, ETA 80:03
这个可能是硬件影响或者其它原因,一脸懵逼~
1024字节是brom决定的。
#16 2018-10-29 16:17:24
期待下一步更多进展...
1024字节是brom决定的。
楼主 #17 2018-10-29 16:46:54
asdf
已发帖子: 58
59% [============================ ] 0.3 kB/s, ETA 24:00 usb_bulk_send() ERROR -1: Input/Output Error
虽然龟速并且中途还报错了,但是好消息是连上串口上电居然能成功启动到uboot的命令行,也能操作!
那么问题来了:
一个是速度慢的问题,
二个是这种状态下的uboot我要怎么比较简便把dtb,kernel弄进来呢,还是直接用tftp
#18 2018-10-29 16:53:11
那么问题来了:
一个是速度慢的问题,
速度慢的问题我去请教原作者 @assert
kernel, dtb 的烧录可以用 u-boot的指令.
#19 2018-10-29 17:19:08
那么问题来了:
一个是速度慢的问题,
@assert 说 sunxi-fel 没有优化,是比较慢,有 4k-6k 左右的速度, 但是你的这么慢,就不知道是什么问题了。
只能自己重写 sunxi-fel 工具了.
#20 2018-10-29 17:19:58
那么问题来了:
一个是速度慢的问题,
出个歪主意, 从 TF 卡启动, 然后利用 linux 4.19 写 spi nand.
楼主 #21 2018-10-29 18:33:35
asdf
已发帖子: 58
好吧,多谢晕哥!我也搞不懂为啥到我这里又降了十多倍速度了,不知会不会是硬件原因啊?sd启动再烧录这个方法值得一试!
楼主 #22 2018-10-30 11:44:58
asdf
已发帖子: 58
这个问题目前找到一个解决方案,首先下载assert大神改的uboot到dram,然后对nand flash 进行全盘擦除;然后再用最新的全志phonixsuuit,注意要勾上格式化烧录就可以了,不擦只加格式化是不行的,除非新片子,应该是烧录时分区处理的完善性问题了
#23 2018-10-30 11:58:53
直接用 phonixsuit 烧录 spi nand 不可以吗?
楼主 #24 2018-10-30 12:34:51
asdf
已发帖子: 58
直接烧感觉不可控,新片子的话勾上格式化应该是没问题的,但我不确定更改类似分区或者多次烧录会不会再出什么意外咯~反正我是遇到了
#25 2018-10-30 13:55:58
lilo
已发帖子: 215
phonixsuit 烧 spi nand 的 img 要特别处理过才行吧?至少 u-boot 要包含 spi nand 的操作代码.
