楼主 #1 2018-11-14 22:25:06
k455619
已发帖子: 151
ESP32-dueros测试失败,
出错位置:\0x1b[0m
E (0,tid:3ffc99bc) lightduer_events.c( 131):[lightduer_socket] Alloc the events resource failed!
E (381,tid:3ffc99bc) lightduer_timers.c(  67):Memory Overflow!!!
弄了一晚上,主要是找不到 lightduer_timers.c ,请求支援
打印如下:
ets Jun  8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x3f (SPI_FAST_FLASH_BOOT)
flash read err, 1000
ets_main.c 371
rst:0x10 (RTCWDT_RTC_RESET),boot:0x3f (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:5740
load:0x40078000,len:7892
load:0x40080000,len:5808
entry 0x40080314
\0x1b[0;32mI (29) boot: ESP-IDF v3.1.1-6-g2aa9a21 2nd stage bootloader\0x1b[0m
\0x1b[0;32mI (29) boot: compile time 22:16:51\0x1b[0m
\0x1b[0;32mI (35) boot: Enabling RNG early entropy source...\0x1b[0m
\0x1b[0;32mI (35) boot: SPI Speed      : 80MHz\0x1b[0m
\0x1b[0;32mI (39) boot: SPI Mode       : DIO\0x1b[0m
\0x1b[0;32mI (43) boot: SPI Flash Size : 4MB\0x1b[0m
\0x1b[0;32mI (47) boot: Partition Table:\0x1b[0m
\0x1b[0;32mI (51) boot: ## Label            Usage          Type ST Offset   Length\0x1b[0m
\0x1b[0;32mI (58) boot:  0 nvs              WiFi data        01 02 00009000 00006000\0x1b[0m
\0x1b[0;32mI (66) boot:  1 phy_init         RF data          01 01 0000f000 00001000\0x1b[0m
\0x1b[0;32mI (73) boot:  2 factory          factory app      00 00 00010000 00200000\0x1b[0m
\0x1b[0;32mI (81) boot: End of partition table\0x1b[0m
\0x1b[0;32mI (85) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x8dfc0 (581568) map\0x1b[0m
\0x1b[0;32mI (261) esp_image: segment 1: paddr=0x0009dfe8 vaddr=0x3ffb0000 size=0x02028 (  8232) load\0x1b[0m
\0x1b[0;32mI (263) esp_image: segment 2: paddr=0x000a0018 vaddr=0x400d0018 size=0x1269c4 (1206724) map\0x1b[0m
\0x1b[0;32mI (614) esp_image: segment 3: paddr=0x001c69e4 vaddr=0x3ffb2028 size=0x01930 (  6448) load\0x1b[0m
\0x1b[0;32mI (616) esp_image: segment 4: paddr=0x001c831c vaddr=0x3ffb3958 size=0x00000 (     0) load\0x1b[0m
\0x1b[0;32mI (621) esp_image: segment 5: paddr=0x001c8324 vaddr=0x40080000 size=0x00400 (  1024) load\0x1b[0m
\0x1b[0;32mI (630) esp_image: segment 6: paddr=0x001c872c vaddr=0x40080400 size=0x11c28 ( 72744) load\0x1b[0m
\0x1b[0;32mI (663) esp_image: segment 7: paddr=0x001da35c vaddr=0x400c0000 size=0x00000 (     0) load\0x1b[0m
\0x1b[0;32mI (663) esp_image: segment 8: paddr=0x001da364 vaddr=0x50000000 size=0x00000 (     0) load\0x1b[0m
\0x1b[0;32mI (680) boot: Loaded app from partition at offset 0x10000\0x1b[0m
\0x1b[0;32mI (680) boot: Disabling RNG early entropy source...\0x1b[0m
\0x1b[0;32mI (681) cpu_start: Pro cpu up.\0x1b[0m
\0x1b[0;32mI (685) cpu_start: Starting app cpu, entry point is 0x40081334\0x1b[0m
\0x1b[0;32mI (0) cpu_start: App cpu up.\0x1b[0m
\0x1b[0;32mI (695) heap_init: Initializing. RAM available for dynamic allocation:\0x1b[0m
\0x1b[0;32mI (702) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM\0x1b[0m
\0x1b[0;32mI (708) heap_init: At 3FFBAF08 len 000250F8 (148 KiB): DRAM\0x1b[0m
\0x1b[0;32mI (714) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM\0x1b[0m
\0x1b[0;32mI (721) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM\0x1b[0m
\0x1b[0;32mI (727) heap_init: At 40092028 len 0000DFD8 (55 KiB): IRAM\0x1b[0m
\0x1b[0;32mI (733) cpu_start: Pro cpu start user code\0x1b[0m
\0x1b[0;32mI (80) cpu_start: Starting scheduler on PRO CPU.\0x1b[0m
\0x1b[0;32mI (0) cpu_start: Starting scheduler on APP CPU.\0x1b[0m
\0x1b[0;32mI (202) DUEROS: ADF version is v1.0-beta1-41-g35e686d-dirty\0x1b[0m
\0x1b[0;33mW (202) ESP_PERIPH: Peripherals have been initialized already\0x1b[0m
\0x1b[0;32mI (204) gpio: GPIO[36]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:3 \0x1b[0m
\0x1b[0;32mI (213) gpio: GPIO[39]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:3 \0x1b[0m
\0x1b[0;33mW (248) PERIPH_TOUCH: _touch_init\0x1b[0m
\0x1b[0;32mI (248) SDCARD: Trying to mount with base path=/sdcard\0x1b[0m
\0x1b[0;32mI (294) SDCARD: CID name SD8GB!
\0x1b[0m
E (384,tid:3ffc99bc) lightduer_statistics.c( 100):Start timer failed
E (390,tid:3ffc99bc) lightduer_ds_report.c(  55):memory overflow
E (396,tid:3ffc99bc) lightduer_system_info.c( 731):Sys Info: Register report system dynamic function failed ret: -17
I (541) wifi: wifi driver task: 3ffcb274, prio:23, stack:3584, core=0
E (407,tid:3ffc99bc) lightduer_ds_report.c(  55):memory overflow
I (557) wifi: wifi firmware version: b2c9a19
I (563) wifi: config NVS flash: enabled
I (567) wifi: config nano formating: disabled
\0x1b[0;32mI (571) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE\0x1b[0m
\0x1b[0;32mI (580) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE\0x1b[0m
I (608) wifi: Init dynamic tx buffer num: 32
I (608) wifi: Init data frame dynamic rx buffer num: 32
I (608) wifi: Init management frame dynamic rx buffer num: 32
I (612) wifi: Init static rx buffer size: 1600
I (616) wifi: Init static rx buffer num: 10
I (620) wifi: Init dynamic rx buffer num: 32
E (484,tid:3ffc99bc) lightduer_system_info.c( 736):Sys Info: Register report memory function failed ret: -17
\0x1b[0;33mW (629) phy_init: failed to load RF calibration data (0x1102), falling back to full calibration\0x1b[0m
\0x1b[0;32mI (793) phy: phy_version: 4000, b6198fa, Sep  3 2018, 15:11:06, 0, 2\0x1b[0m
I (802) wifi: mode : sta (24:0a:c4:9d:04:34)
E (664,tid:3ffc99bc) lightduer_ds_report.c(  55):memory overflow
E (664,tid:3ffc99bc) lightduer_system_info.c( 741):Sys Info: Register report network function failed ret: -17
E (670,tid:3ffc99bc) lightduer_ds_report.c(  55):memory overflow
E (676,tid:3ffc99bc) lightduer_system_info.c( 746):Sys Info: Register report disk function failed ret: -17
E (685,tid:3ffc99bc) lightduer_statistics.c( 315):Sys Info: Init system info failed ret: -17
E (693,tid:3ffc99bc) lightduer_events.c( 131):[lightduer_ca] Alloc the events resource failed!
E (701,tid:3ffc99bc) lightduer_connagent.c( 301):duer_initialize fail! res:-1
E (708,tid:3ffc99bc) lightduer_ds_report.c(  55):memory overflow
E (715,tid:3ffc99bc) lightduer_connagent.c( 306):report ca status register failed ret: -17
\0x1b[0;32mI (864) gpio: GPIO[19]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:3 \0x1b[0m
\0x1b[0;31mE (872) gpio: gpio_install_isr_service(394): GPIO isr service already installed\0x1b[0m
\0x1b[0;32mI (892) gpio: GPIO[21]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0 \0x1b[0m
\0x1b[0;32mI (892) ES8388_DRIVER: init,out:02, in:00\0x1b[0m
\0x1b[0;32mI (903) AUDIO_HAL: Codec mode is 1, Ctrl:1\0x1b[0m
\0x1b[0;32mI (907) I2S: DMA Malloc info, datalen=blocksize=1200, dma_buf_count=3\0x1b[0m
\0x1b[0;32mI (908) I2S: DMA Malloc info, datalen=blocksize=1200, dma_buf_count=3\0x1b[0m
\0x1b[0;32mI (918) I2S: APLL: Req RATE: 44100, real rate: 43945.238, BITS: 16, CLKM: 1, BCK_M: 8, MCLK: 11249981.000, SCLK: 1406247.625000, diva: 1, divb: 0\0x1b[0m
\0x1b[0;32mI (930) AUDIO_ELEMENT: [i2s] Element task created\0x1b[0m
\0x1b[0;32mI (935) AUDIO_ELEMENT: [filter] Element task created\0x1b[0m
\0x1b[0;32mI (940) AUDIO_ELEMENT: [raw] Element task created\0x1b[0m
\0x1b[0;32mI (946) AUDIO_PIPELINE: Func:audio_pipeline_run, Line:260, MEM Total:147680 Bytes
\0x1b[0m
\0x1b[0;32mI (954) AUDIO_PIPELINE: Pipeline started\0x1b[0m
\0x1b[0;32mI (954) AUDIO_ELEMENT: [i2s] AEL_MSG_CMD_RESUME,state:1\0x1b[0m
\0x1b[0;32mI (959) DUEROS: Recorder has been created\0x1b[0m
\0x1b[0;32mI (965) I2S_STREAM: AUDIO_STREAM_READER,Rate:48000,ch:2\0x1b[0m
\0x1b[0;33mW (970) REC_ENG: open rec_eng_2.wav failed,[293]\0x1b[0m
\0x1b[0;32mI (978) I2S: APLL: Req RATE: 48000, real rate: 47999.961, BITS: 16, CLKM: 1, BCK_M: 8, MCLK: 12287990.000, SCLK: 1535998.750000, diva: 1, divb: 0\0x1b[0m
\0x1b[0;32mI (981) REC_ENG: ESP SR Engine, chunksize is 480\0xef\0xbc\0x8c FRAME_SIZE:960, frequency:16000\0x1b[0m
\0x1b[0;32mI (954) AUDIO_ELEMENT: [filter] AEL_MSG_CMD_RESUME,state:1\0x1b[0m
\0x1b[0;31mE (1003) REC_ENG: Recorder Engine Running ..., vad_window=9, wakeup=10000 ms, vad_off=800 ms, threshold=90 ms, sensitivity=0\0x1b[0m
\0x1b[0;32mI (1009) RSP_FILTER: rsp_filter_open, encoder, src:48000,2,dest:16000,1,buf_sz:6200, in_pcm:6192\0x1b[0m
\0x1b[0;32mI (1021) REC_ENG: state idle\0x1b[0m
I (2133) wifi: n:11 2, o:1 0, ap:255 255, sta:11 2, prof:1
I (2977) wifi: state: init -> auth (b0)
I (2980) wifi: state: auth -> assoc (0)
I (2985) wifi: state: assoc -> run (10)
I (3233) wifi: connected with myserver, channel 11
I (3234) wifi: pm start, type: 1
\0x1b[0;32mI (4205) event: sta ip: 192.168.1.102, mask: 255.255.255.0, gw: 192.168.1.1\0x1b[0m
\0x1b[0;32mI (4205) DUEROS: PERIPH_WIFI_CONNECTED [452]\0x1b[0m
\0x1b[0;31mE (4207) DUEROS: Recv Que DUER_CMD_LOGIN\0x1b[0m
\0x1b[0;32mI (4211) DUEROS: duer_start, len:1470
{"configures":"{}","bindToken":"79dadeafe95dadcba84b53b2f6da0fd1","coapPort":443,"token":"JiG5ZzQRvybC7YmbdTpCAzNQP7007uP1","serverAddr":"device.iot.baidu.com","lwm2mPort":443,"uuid":"1909000000000d","rsaCaCrt":"-----BEGIN CERTIFICATE-----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\nOVSdXs1ttZxEaEBGUl7tgsBte556BIvufZX+BXGyycVJdBu3\n-----END CERTIFICATE-----\n","macId":"","version":11737}\0x1b[0m
E (4205,tid:3ffc99bc) lightduer_connagent.c( 331):memory alloc fail!
I (4208,tid:3ffc99bc) lightduer_ds_log_cache.c(  45):cached tracecode: 0x12010400
ets_main.c 371
entry 0x40080314
\0x1b[0;32mI (37) boot: Enabling RNG early entropy source...\0x1b[0m
\0x1b[0;32mI (37) boot: SPI Speed      : 80MHz\0x1b[0m
\0x1b[0;32mI (80) boot: End of partition table\0x1b[0m
\0x1b[0;32mI (177) DUEROS: ADF version is v1.0-beta1-41-g35e686d-dirty\0x1b[0m
\0x1b[0;33mW (177) ESP_PERIPH: Peripherals have been initialized already\0x1b[0m
\0x1b[0;32mI (179) gpio: GPIO[36]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:3 \0x1b[0m
\0x1b[0;32mI (188) gpio: GPIO[39]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:3 \0x1b[0m
\0x1b[0;33mW (224) PERIPH_TOUCH: _touch_init\0x1b[0m
\0x1b[0;32mI (224) SDCARD: Trying to mount with base path=/sdcard\0x1b[0m
\0x1b[0;32mI (270) SDCARD: CID name SD8GB!
\0x1b[0m
E (0,tid:3ffc9ba8) lightduer_events.c( 131):[lightduer_socket] Alloc the events resource failed!
E (369,tid:3ffc9ba8) lightduer_timers.c(  67):Memory Overflow!!!
E (372,tid:3ffc9ba8) lightduer_statistics.c( 100):Start timer failed
E (378,tid:3ffc9ba8) lightduer_ds_report.c(  55):memory overflow
I (509) wifi: wifi driver task: 3ffcb3bc, prio:23, stack:3584, core=0
E (385,tid:3ffc9ba8) lightduer_system_info.c( 731):Sys Info: Register report system dynamic function failed ret: -17
I (520) wifi: wifi firmware version: b2c9a19
I (534) wifi: config NVS flash: enabled
I (537) wifi: config nano formating: disabled
\0x1b[0;32mI (541) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE\0x1b[0m
\0x1b[0;32mI (551) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE\0x1b[0m
I (578) wifi: Init dynamic tx buffer num: 32
I (578) wifi: Init data frame dynamic rx buffer num: 32
I (578) wifi: Init management frame dynamic rx buffer num: 32
I (582) wifi: Init static rx buffer size: 1600
I (586) wifi: Init static rx buffer num: 10
I (589) wifi: Init dynamic rx buffer num: 32
E (465,tid:3ffc9ba8) lightduer_ds_report.c(  55):memory overflow
E (471,tid:3ffc\0x1b[0;32mI (657) phy: phy_version: 4000, b6198fa, Sep  3 2018, 15:11:06, 0, 0\0x1b[0m
9ba8) lightduer_system_info.c( 736)\0xfeets Jun  8 2016 00:22:57
ets_main.c 371
entry 0x40080314
\0x1b[0;33mW (178) ESP_PERIPH: Peripherals have been initialized already\0x1b[0m
\0x1b[0m
E (466,tid:3ffc9ba8) lightduer_ds_report.c(  55):memory overflow
E (470,tid:3ffc9ba8) lightduer_system_info.c( 736)ets Jun  8 2016 00:22:57
ets_main.c 371
entry 0x40080314
\0x1b[0;32mI (65) boot:  1 phy_init         RF data          01 01 0000f000 00001000\0x1b[0m
\0x1b[0;32mI (180) gpio: GPIO[36]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:3 \0x1b[0m
\0x1b[0;32mI (189) gpio: GPIO[39]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:3 \0x1b[0m
\0x1b[0m
ets_main.c 371
entry 0x40080314
\0x1b[0m
E (470,tid:3ffc9ba8) lightduer_system_info.c( 736)\0x1b[0;32mI (658) phy: phy_version: 4000, b6198fa, Sep  3 2018, 15:11:06, 0, 0\0x1b[0m
I (659) wifi: mode : sta (24:0a:c4:9d:04:34)
E (537,tid:3ffc9ba8) lightduer_ds_report.c(  55):memory overflow
E (541,tid:3ffc9ba8) lightduer_system_info.c( 741):Sys Info: Register report network function failed ret: -17
E (550,tid:3ffc9ba8) lightduer_ds_report.c(  55):memory overflow
E (555,tid:3ffc9ba8) lightduer_system_info.c( 746):Sys Info: Register report disk function failed ret: -17
E (565,tid:3ffc9ba8) lightduer_statistics.c( 315):Sys Info: Init system info failed ret: -17
E (573,tid:3ffc9ba8) lightduer_events.c( 131):[lightduer_ca] Alloc the events resource failed!
E (581,tid:3ffc9ba8) lightduer_connagent.c( 301):duer_initialize fail! res:-1
E (589,tid:3ffc9ba8) lightduer_ds_report.c(  55):memory overflow
E (594,tid:3ffc9ba8) lightduer_connagent.c( 306):report ca status register failed ret: -17
\0x1b[0;32mI (731) gpio: GPIO[19]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:3 \0x1b[0m
\0x1b[0;31mE (740) gpio: gpio_install_isr_service(394): GPIO isr service already installed\0x1b[0m
\0x1b[0;32mI (761) gpio: GPIO[21]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0 \0x1b[0m
\0x1b[0;32mI (761) ES8388_DRIVER: init,out:02, in:00\0x1b[0m
\0x1b[0;32mI (771) AUDIO_HAL: Codec mode is 1, Ctrl:1\0x1b[0m
\0x1b[0;32mI (774) I2S: DMA Malloc info, datalen=blocksize=1200, dma_buf_count=3\0x1b[0m
\0x1b[0;32mI (776) I2S: DMA Malloc info, datalen=blocksize=1200, dma_buf_count=3\0x1b[0m
\0x1b[0;32mI (786) I2S: APLL: Req RATE: 44100, real rate: 43945.238, BITS: 16, CLKM: 1, BCK_M: 8, MCLK: 11249981.000, SCLK: 1406247.625000, diva: 1, divb: 0\0x1b[0m
\0x1b[0;32mI (798) AUDIO_ELEMENT: [i2s] Element task created\0x1b[0m
\0x1b[0;32mI (804) AUDIO_ELEMENT: [filter] Element task created\0x1b[0m
\0x1b[0;32mI (808) AUDIO_ELEMENT: [raw] Element task created\0x1b[0m
\0x1b[0;32mI (813) AUDIO_PIPELINE: Func:audio_pipeline_run, Line:260, MEM Total:147692 Bytes
\0x1b[0m
\0x1b[0;32mI (822) AUDIO_PIPELINE: Pipeline started\0x1b[0m
\0x1b[0;32mI (822) AUDIO_ELEMENT: [i2s] AEL_MSG_CMD_RESUME,state:1\0x1b[0m
\0x1b[0;32mI (827) DUEROS: Recorder has been created\0x1b[0m
\0x1b[0;32mI (832) I2S_STREAM: AUDIO_STREAM_READER,Rate:48000,ch:2\0x1b[0m
\0x1b[0;33mW (838) REC_ENG: open rec_eng_2.wav failed,[293]\0x1b[0m
\0x1b[0;32mI (846) I2S: APLL: Req RATE: 48000, real rate: 47999.961, BITS: 16, CLKM: 1, BCK_M: 8, MCLK: 12287990.000, SCLK: 1535998.750000, diva: 1, divb: 0\0x1b[0m
\0x1b[0;32mI (849) REC_ENG: ESP SR Engine, chunksize is 480\0xef\0xbc\0x8c FRAME_SIZE:960, frequency:16000\0x1b[0m
\0x1b[0;31mE (870) REC_ENG: Recorder Engine Running ..., vad_window=9, wakeup=10000 ms, vad_off=800 ms, threshold=90 ms, sensitivity=0\0x1b[0m
\0x1b[0;32mI (822) AUDIO_ELEMENT: [filter] AEL_MSG_CMD_RESUME,state:1\0x1b[0m
\0x1b[0;32mI (882) REC_ENG: state idle\0x1b[0m
\0x1b[0;32mI (888) RSP_FILTER: rsp_filter_open, encoder, src:48000,2,dest:16000,1,buf_sz:6200, in_pcm:6192\0x1b[0m
I (1993) wifi: n:11 2, o:1 0, ap:255 255, sta:11 2, prof:1
I (2837) wifi: state: init -> auth (b0)
I (2841) wifi: state: auth -> assoc (0)
I (2845) wifi: state: assoc -> run (10)
I (3136) wifi: connected with myserver, channel 11
I (3137) wifi: pm start, type: 1
\0x1b[0;32mI (3679) event: sta ip: 192.168.1.102, mask: 255.255.255.0, gw: 192.168.1.1\0x1b[0m
\0x1b[0;32mI (3679) DUEROS: PERIPH_WIFI_CONNECTED [452]\0x1b[0m
\0x1b[0;31mE (3681) DUEROS: Recv Que DUER_CMD_LOGIN\0x1b[0m
\0x1b[0;32mI (3685) DUEROS: duer_start, len:1470
E (3689,tid:3ffc9ba8) lightduer_connagent.c( 331):memory alloc fail!
I (3694,tid:3ffc9ba8) lightduer_ds_log_cache.c(  45):cached tracecode: 0x12010400
#2 2018-11-14 22:30:42
所在地: 微信 whycan_cn
已发帖子: 9,234
Re: ESP32-dueros测试失败,
内存溢出?建议换一个串口终端,
试一试mobaxterm吧
楼主 #3 2018-11-14 22:40:44
k455619
已发帖子: 151
@晕哥 打印时间确实不对,用的cutecome 我才看到在打印信息第一句flash read err, 1000  在esp-adf里面config ESP32_DEEP_SLEEP_WAKEUP_DELAY
    int "Extra delay in deep sleep wake stub (in us)"
    default 2000
    range 0 5000
    help
        When ESP32 exits deep sleep, the CPU and the flash chip are powered on
        at the same time. CPU will run deep sleep stub first, and then
        proceed to load code from flash. Some flash chips need sufficient
        time to pass between power on and first read operation. By default,
        without any extra delay, this time is approximately 900us, although
        some flash chip types need more than that.
        By default extra delay is set to 2000us. When optimizing startup time
        for applications which require it, this value may be reduced.
        If you are seeing "flash read err, 1000" message printed to the
        console after deep sleep reset, try increasing this value.
就是不知道在哪里改 还在找。。。。
#4 2018-11-14 23:17:17
所在地: 微信 whycan_cn
已发帖子: 9,234
ESP32_DEEP_SLEEP_WAKEUP_DELAY 你的menuconfig 这个值是多少
楼主 #5 2018-11-15 19:39:00
k455619
已发帖子: 151
已经改到5000依然 read flash error 准备重新clone个Adf 再试试
楼主 #6 2018-11-15 19:40:13
k455619
已发帖子: 151
感觉并不是这个原因导致的问题,因为其他demo都能运行,
#7 2018-11-15 19:48:24
所在地: 微信 whycan_cn
已发帖子: 9,234
从log很难看出什么问题来, 要不你瞄下我以前发的这个帖子 https://whycan.cn/t_1098.html
看能不能对比出什么问题
楼主 #8 2018-11-15 20:24:47
k455619
已发帖子: 151
看了你的帖子了,,,但是这个东西在重启4次之后 读取到了flash了 最后打印如下:
----------------------------- ESP Audio Platform -----------------------------
|                              ESP_AUDIO v1.0-rc1                [0;32mI (9884) ESP_AUDIO_TASK: media_ctrl_task running...,0x3f8157a8[0m
|                     Compile date: Oct 15 2018-15:49:40                     |
[0;32mI (9916) ESP_AUDIO_CTRL: Func:media_ctrl_create, Line:144, MEM Total:4187836 Bytes, Inter:152540 Bytes, Dram:119656 Bytes
[0m
[0;33mW (9930) I2S: I2S driver already installed[0m
[0;33mW (9938) I2S: I2S driver already installed[0m
[0;32mI (9940) STAGEFRIGHTMP3_DECODER: MP3 init[0m
[0;32mI (9945) AUDIO_WRAPPER: Func:setup_player, Line:167, MEM Total:4176136 Bytes, Inter:144032 Bytes, Dram:111148 Bytes
[0m
[0;32mI (9953) AUDIO_WRAPPER: esp_audio instance is:0x3f8157a8[0m
I (9723,tid:3ffbd64c) lightduer_dcs_router.c( 283):namespace: ai.dueros.private.protocol
I (9725,tid:3ffbd64c) lightduer_dcs_router.c( 283):namespace: ai.dueros.device_interface.screen_extended_card
I (9740,tid:3ffbd64c) lightduer_dcs_router.c( 283):namespace: ai.dueros.device_interface.system
I (9744,tid:3ffbd64c) lightduer_dcs_router.c( 283):namespace: ai.dueros.device_interface.voice_input
I (9750,tid:3ffbd64c) lightduer_dcs_router.c( 283):namespace: ai.dueros.device_interface.voice_output
I (9763,tid:3ffbd64c) lightduer_dcs_router.c( 283):namespace: ai.dueros.device_interface.speaker_controller
I (9770,tid:3ffbd64c) lightduer_dcs_router.c( 283):namespace: ai.dueros.device_interface.audio_player
[0;32mI (10026) AUDIO_WRAPPER: duer_dcs_get_speaker_state[0m
[0;32mI (10055) DUEROS: Dueros DUER_CMD_CONNECTED, duer_state:1[0m
[0;31mE (10056) DUEROS: event: DUER_EVENT_STARTED[0m
W (9814,tid:3ffbd64c) lightduer_events.c(  80):[lightduer_ca] <== event end = 400F0DE0, timespent = 217
I (9820,tid:3ffbd64c) lightduer_connagent.c( 212):add resource successfully!!
I (9836,tid:3ffbd64c) lightduer_connagent.c( 212):add resource successfully!!
W (9837,tid:3ffbd64c) lightduer_engine.c( 634):data cache has not sent, pending..., dcache_len:1, qcache_len:4
W (9849,tid:3ffbd64c) lightduer_system_info.c( 306):Undefined memory type, 0
E (9857,tid:3ffbd64c) lightduer_system_info.c( 389):Sys Info: Get disk info failed
楼主 #9 2018-11-15 20:26:21
k455619
已发帖子: 151
按下rec键后又重启了。。。重启结束后又回到了上面的打印信息,
#10 2018-11-15 21:14:26
所在地: 微信 whycan_cn
已发帖子: 9,234
k455619 说:
[0m
[0m
插入一张格式化为FAT32的TF卡试一试
楼主 #11 2018-11-15 21:30:24
k455619
已发帖子: 151
文件系统就是FAT32 还在里面看见了REC.WAV,可能是我之前REC时候出来的,但是那个时候插上耳机,并么有声音,看电路应该是应该有声音的吧,已经clone好了新的ESP-ADF再试试,还有之前出现flash error 1000 就卡在内存错误那里,这次这make menuconfig 中设置了连接外部PSRAM,再不断复位的情况下,有几率读取到flash,
#12 2018-11-15 21:40:26
所在地: 微信 whycan_cn
已发帖子: 9,234
k455619 说:
这个esp32 dueros 完全只是一个demo, 不止功能不稳定,而且还没源码。
楼主 #13 2018-11-15 21:46:55
k455619
已发帖子: 151
感觉ESP8266够坑了 这个readflash都出错 是真的难受  再试试 不行就等几天再玩了
楼主 #14 2018-11-15 22:52:14
k455619
已发帖子: 151
重新clone,终于听见了 第一步:延时FLASH时间为5000us(和这步关系不大但是还是延时到5000)
              第二步:连接到外部PSRAM
但是及不稳定,要重启很多次才能连接到dueros,有时候对话发送不出去,还有换了个5V2A的电源
#15 2018-11-16 08:29:36
所在地: 微信 whycan_cn
已发帖子: 9,234
k455619 说:
              第二步:连接到外部PSRAM
对,官方demo就是酱紫,而且REC按键多按几次就炸了,就是这样还不开源
#16 2018-11-21 11:05:00
linweifu
碰到同样的问题了。等官方解决吧
