楼主 #1 2018-06-05 15:55:10
已发帖子: 9,342
写一个非常简单的 V3s@linux4.13-y 中断驱动
hello.c
#include <linux/kernel.h>
#include <linux/module.h>
#include <linux/input.h>
#include <linux/input-polldev.h>
#include <linux/i2c.h>
#include <linux/gpio.h>
#include <linux/interrupt.h>
#define GPIO 192    //PG0
#define GPIO_INT_NAME  "pg0_int"
#define GPIO_HIGH gpio_get_value(GPIO)
#define GPIO_LOW (gpio_get_value(GPIO) == 0)
short int irq_any_gpio    = 0;
int count =0;
enum { falling, rising } type;
static irqreturn_t r_irq_handler(int irq, void *dev_id)
    count++;
    printk(KERN_DEBUG "interrupt received (irq: %d)\n", irq);
	if (irq == gpio_to_irq(GPIO))
        type = GPIO_LOW ? falling : rising;
        if(type == falling)
            printk("gpio pin is low\n");
            printk("gpio pin is high\n");
    return IRQ_HANDLED;
void r_int_config(void) {
   if (gpio_request(GPIO, GPIO_INT_NAME ))
      printk("GPIO request failure: %s\n", GPIO_INT_NAME );
      return;
   if ( (irq_any_gpio = gpio_to_irq(GPIO)) < 0 ) {
      printk("GPIO to IRQ mapping failure %s\n",GPIO_INT_NAME );
      return;
   printk(KERN_NOTICE "Mapped int %d\n", irq_any_gpio);
   if (request_irq(irq_any_gpio,(irq_handler_t ) r_irq_handler, IRQF_TRIGGER_FALLING , GPIO_INT_NAME, NULL))
      printk("Irq Request failure\n");
      return;
   return;
void r_int_release(void) {
   free_irq(gpio_to_irq(GPIO), NULL);
    gpio_free(GPIO);;
   return;
int init_module1(void)
        printk("<1>Hello World\n");
    r_int_config();
module_init(init_module1);    // Do some better naming
module_exit(r_int_release);
MODULE_LICENSE("GPL");
MODULE_AUTHOR("whycan");
# dmesg
[   26.204637] interrupt received (irq: 71)
[   26.204660] gpio pin is low
[   26.919621] interrupt received (irq: 71)
[   26.919642] gpio pin is low
[   27.429350] interrupt received (irq: 71)
[   27.429359] gpio pin is low
[   27.694572] interrupt received (irq: 71)
[   27.694586] gpio pin is low
[   27.906767] interrupt received (irq: 71)
[   27.906779] gpio pin is low
把PG0 IO脚下拉就会进入中断, 输出上面的信息.
参考链接: https://stackoverflow.com/questions/25507750/detecting-interrupt-on-gpio-in-kernel-module
参考链接: 试一试 Ubuntu 下编译第一个 Hello World 驱动并运行
http://whycan.com/t_5233.html
以下由 @哇酷小二 2021-04-15 添加:
Makefile:
obj-m = hello.o
编译指令 (根据实际情况修改指令):
ARCH=arm CROSS_COMPILE=/opt/buildroot/output/host/bin/arm-linux-gnueabihf- make -C /opt/buildroot/output/build/linux-zero-5.2.y/ M=${PWD} modules
编译日志:
$ ARCH=arm CROSS_COMPILE=/opt/buildroot/output/host/bin/arm-linux-gnueabihf- make -C /opt/buildroot/output/build/linux-zero-5.2.y/ M=${PWD} modules
make: Entering directory '/opt/buildroot/output/build/linux-zero-5.2.y'
  CC [M]  /opt/buildroot/modules/test1/hello.o
  Building modules, stage 2.
  MODPOST 1 modules
WARNING: modpost: missing MODULE_LICENSE() in /opt/buildroot/modules/test1/hello.o
see include/linux/module.h for more information
  CC      /opt/buildroot/modules/test1/hello.mod.o
  LD [M]  /opt/buildroot/modules/test1/hello.ko
make: Leaving directory '/opt/buildroot/output/build/linux-zero-5.2.y'
楼主 #2 2018-06-05 16:05:51
已发帖子: 9,342
Re: 写一个非常简单的 V3s@linux4.13-y 中断驱动
#3 2018-06-14 14:44:25
beyondabcd
已发帖子: 44
现在成功了吗
楼主 #4 2018-06-14 14:47:26
已发帖子: 9,342
可以的,亲自试过。
#5 2018-08-08 23:35:43
include_h
@晕哥 ,能贴出将它编译成.ko文件的脚本吗?
友善的A9 4412是Makefile这样的,现在换到全志我转不过来,
FILE =  key_poll
INC =   key_poll.h
obj-m = $(FILE).o
KDIR = /works/linux/linux-3.5/
all:
	make -C $(KDIR)  M=$(PWD)  modules
楼主 #6 2018-08-09 08:47:34
已发帖子: 9,342
@include_h 一楼的代码我是修改 ns2009.c 里面的代码,直接编译到内核的.
你这个要做改一下 KDIR,改成你的内核源码试一试.
#7 2018-11-15 19:34:20
605364021
已发帖子: 251
晕哥 我将你的代码复制来进行测试,但是在insmod .ko文件时出现了
# insmod led.ko
[ 3287.239687] led: Unknown symbol gpiod_get_raw_value (err 0)
[ 3287.245282] led: Unknown symbol gpiod_to_irq (err 0)
[ 3287.250413] led: Unknown symbol gpio_free (err 0)
[ 3287.255131] led: Unknown symbol gpio_to_desc (err 0)
[ 3287.260126] led: Unknown symbol gpio_request (err 0)
[ 3287.266851] led: Unknown symbol gpiod_get_raw_value (err 0)
[ 3287.272447] led: Unknown symbol gpiod_to_irq (err 0)
[ 3287.277566] led: Unknown symbol gpio_free (err 0)
[ 3287.282282] led: Unknown symbol gpio_to_desc (err 0)
[ 3287.287271] led: Unknown symbol gpio_request (err 0)
insmod: can't insert 'led.ko': unknown symbol in module, or unknown parameter
楼主 #8 2018-11-15 19:50:58
已发帖子: 9,342
可能我一楼的代码是直接编译到 zImage 的,所以没有碰到你的这种情况.
楼主 #9 2018-11-15 19:59:55
已发帖子: 9,342
https://discuss.96boards.org/t/simple-irq-driver-issue/724/2
CONFIG_ARCH_WANT_OPTIONAL_GPIOLIB=y
CONFIG_ARCH_REQUIRE_GPIOLIB=y
CONFIG_GPIOLIB=y
#10 2018-11-15 20:02:33
605364021
已发帖子: 251
晕哥,我在4.13y内核分支已有相关驱动的情况下,想做个只控制PG0的.ko核模块通过insmod来实现控制led灯的闪烁,这样可以实现?
楼主 #11 2018-11-15 20:04:35
已发帖子: 9,342
605364021 说:
肯定可以的, 看9楼的解决方案, 先试一试
#12 2018-11-15 20:21:01
605364021
已发帖子: 251
CONFIG_GPIOLIB=y
前两个在内核.config文件下不存在,只有第三个有。是要将新建的内核加载到zimge上去运行?只移植.ko模块到板子上运行可以?
#13 2018-11-15 20:31:59
605364021
已发帖子: 251
605364021 说:
# insmod led.ko
这个问题解决了,.c文件缺失MODULE_LICENSE("GPL");,在.c文件加上,再编译就可以在v3上进行模块加载了
#14 2018-11-15 20:48:08
605364021
已发帖子: 251
怎么将PG0 IO脚下拉,赋值?
最近编辑记录 605364021 (2018-11-15 20:48:38)
楼主 #15 2018-11-15 21:13:19
已发帖子: 9,342
杜邦线,或者PG0飞一个轻触开关到GND。
楼主 #16 2018-11-15 21:25:11
已发帖子: 9,342
我也搜到这个答案,但是被我直接pass了,不过又get到新姿势了。
#17 2018-11-15 21:51:10
605364021
已发帖子: 251
605364021 说:
想用.ko内核模块实现led灯的闪烁,需要重新向内核注册设备吗?还是直接在.ko模块上实现相关功能就行?
楼主 #18 2018-11-15 21:54:35
已发帖子: 9,342
605364021 说:
605364021 说:
不用了,参考:
https://whycan.cn/t_1853.html#p11754
https://stackoverflow.com/questions/10812858/how-to-use-timers-in-linux-kernel-device-drivers
#include <linux/timer.h>
static struct timer_list my_timer;
void my_timer_callback( unsigned long data )
     /* do your timer stuff here */
int init_module(void)
  /* setup your timer to call my_timer_callback */
  setup_timer(&my_timer, my_timer_callback, 0);
  /* setup timer interval to 200 msecs */
  mod_timer(&my_timer, jiffies + msecs_to_jiffies(200));
void cleanup_module(void)
  /* remove kernel timer when unloading module */
  del_timer(&my_timer);
  return;
如果搞定了, 希望可以贴个完整的上来参考一下.
最好把这个中断也加上,按下GPIO 触发闪烁, 或者调整闪烁频率.
#19 2018-11-18 16:37:21
605364021
已发帖子: 251
#include <linux/init.h>
#include <linux/miscdevice.h>
#include <linux/types.h>
#include <linux/ioctl.h>
#include <linux/cdev.h>
#include <linux/delay.h>
#include <linux/errno.h>
#include <linux/fs.h>
#define PG0 192 //PG0 192=32*6+0
#define DEVICE "myled"
#define MAGIC_NUM 'k'			//定义幻数
#define LED_ON _IO(MAGIC_NUM, 0) //_IO    不带参数的ioctl
#define LED_OFF _IO(MAGIC_NUM, 1)
  函数名:      led_open
  参数:        struct inode *inode,struct file *filp
  返回值:      int
  描述:        open对应的驱动函数
int led_open(struct inode *inode, struct file *filp)
   int ret;
   ret = gpio_request_one(PG0,GPIOF_OUT_INIT_HIGH,"myled");//配置为输出,并初始化为高电平,gpio.txt
   if(ret)
		printk("error: cannot request gpio PG0 \n");
		printk("error ret = %d", ret);
	gpio_set_value(PG0,1); // GPIO 输出   void gpio_set_value(unsigned gpio, int value);
	函数名:		led_release
	返回值:	int
	描述:		release对应的驱动函数
int led_release(struct inode *inode, struct file *filp)
	gpio_free(PG0);// 释放之前声明的 GPIO  void gpio_free(unsigned gpio);
	printk("LED dev release");
	函数名:	led_ioctl
	参数:		struct inode *inode,struct file *filp,unsigned int cmd, unsigned long arg
	返回值:	int
	描述:		led_ioctl函数
long led_ioctl(struct file *filp, unsigned int cmd, unsigned long arg)
	switch(cmd)
		case LED_ON:
			printk("GPIO LED set low.\n");
			gpio_set_value(PG0, 0);
			break;
		case LED_OFF:
			printk("GPIO LED set high.\n");
			gpio_set_value(PG0, 1);
			break;
		default:
			printk("error cmd .\n");
			break;
	函数名:		file_opreations led_fops
	参数:		owner, open, release, ioctl
	返回值:		null
	描述:		file_opreations结构体
struct file_operations led_fops ={
		.owner		= THIS_MODULE,
		.open		= led_open,
		.release	= led_release,
		.unlocked_ioctl		= led_ioctl,
	函数名:		miscdevie led_dev
	参数:		minor, name, fops
	返回值:		null
	描述:		杂项设备
struct miscdevice led_dev ={
		.minor		= MISC_DYNAMIC_MINOR,//minor是这个混杂设备的次设备号,由系统自动配置,
		.name		= DEVICE,			//.name 设备名
		.fops		= &led_fops
	函数名:		led_init
	参数:		void
	返回值:		int
	描述:		模块初始化参数,安装模块时执行
static int __init led_init(void)
		int ret;
		ret = misc_register(&led_dev);//注册驱动程序时采用misc_register函数注册,此函数中会自动创建设备节点,即设备文件
		if(ret)
			printk("error: cannot register misc.\n");
			return ret;
		printk("misc-register %s\n", DEVICE);
		函数:		led_exit
		参数:		void
		返回值:		void
		描述:		模块卸载函数,卸载模块时执行
static void __exit led_exit(void)
		misc_deregister(&led_dev);//杂项设备的注销过程,其实就是注册过程的逆向过程
		printk("mise-deregister %s\n", DEVICE);
module_init(led_init);
module_exit(led_exit);
#include<stdio.h>
#include<stdlib.h>
#include<unistd.h>
#include<fcntl.h>
#include<errno.h>
#include<string.h>
#include<asm-generic/ioctl.h>
#define DEVICE          "/dev/myled"
       int fd;
        printf("Start led test.\n");
        fd = open(DEVICE, O_RDWR);//O_RDWR:可读可写
        if (fd < 2) {
                printf("Cannot open device %s\n", DEVICE);
                return -EFAULT;
        while (1) {
                ioctl(fd, LED_ON, 0);//ioctl(int fd,unsigned long cmd,...),fd:文件描述符,cmd 控制命令
                sleep(1);
                ioctl(fd, LED_OFF, 0);
                sleep(1);
上面是驱动程序和测试程序,能实现led灯的自动闪烁,我现在在弄按键产生中断来控制led灯的控制,但是原理图不会找按钮对应的引脚.....
#20 2019-01-02 13:11:37
aoaoao123mm
晕哥请问中断号是在哪里查到的,还有那个中断事件?
#21 2019-03-18 09:15:53
IoTer
已发帖子: 25
aoaoao123mm 说:
中断号在 V3s 手册的 "PB_EINT interrupt", "PG_EINT interrupt" 可以找到,
只有 PB, PG 两组口可以作为外部中断口。
#22 2019-03-22 10:25:59
Beta_vulgaris
已发帖子: 60
如果用Device tree配置,中断GPIO怎么表示?
#23 2019-03-22 10:46:45
和这个一样
只是要一个读 dts 的代码
https://whycan.cn/t_2251.html
#24 2019-04-17 13:04:28
zhenfanhei
已发帖子: 300
晕哥,S3上申请失败啊,点解? # insmod gpio-sun8i.ko
[   24.670723] <1>Hello World
[   24.678214] GPIO to IRQ mapping failure pb12_int
估计也是gpio_to_irq不行,我折腾触摸跟wifi也是中断申请不能通过,4.13.16,大概什么情况?
#25 2019-04-17 13:06:38
zhenfanhei
已发帖子: 300
加了一些跟踪,也是类似gpio到irq的映射那不行
# insmod brcmutil.ko
# insmod brcmfmac.ko
# [   61.265277] interrupt find name:wifi type:<NULL> full_name:/soc/mmc@01c10000/wifi@1
[   61.282371] irq gpio 42--zengfh
[   61.290215] irqgpio:42 request
[   61.297933] irq -22--zengfh
[   61.305348] of_irq_parse_one: dev=/soc/mmc@01c10000/wifi@1, index=0
[   61.321016] intspec:  intspec=1 intlen=3
[   61.329710]  intsize=3 intlen=3
[   61.337572] Checked index res:0
[   61.345384] irq_domain_translater /soc/pinctrl@01c20800 irq:-941213360 type:0 failed!
[   61.362553] brcmfmac: brcmf_of_probe: interrupt could not be mapped err:0
[   61.380772] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43430-sdio.bin failed with error -2
[   62.403759] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[   63.424179] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
#26 2019-04-17 13:08:07
zhenfanhei
已发帖子: 300
wifi在眼前了,[    5.009565] mmc1: new high speed SDIO card at address 0001
楼主 #27 2019-04-17 13:37:49
已发帖子: 9,342
zhenfanhei 说:
厉害厉害!
#28 2019-04-17 20:03:59
zhenfanhei
已发帖子: 300
不是啊,我是无法申请中断,gpio_to_irq系统里面是空的
#29 2019-04-18 08:57:14
zhenfanhei
已发帖子: 300
S3的一些脚在 pinctrl_V3s里面无定义,加上去即可,暂时我也没加全,就把PB10~PB13加了,其它还有好多,不加无法申请中断,不过比较坑的是全志只有PB PG才能做中断,其它不行,
#30 2020-04-06 17:38:38
ubuntu
已发帖子: 272
#31 2020-12-29 13:00:00
笨企鹅
已发帖子: 38
向大牛学习
#32 2021-01-22 12:16:41
LinuxGo
已发帖子: 88
晕哥 我这边编译 好多错误,怎么办呀,呼叫晕哥
程序复制了1楼的 ,Makefile复制了5楼并改了 路径
编译结果如下
jonsen@ubuntu:~/f1c100s/test_chrdevbase$ make
make -C /home/jonsen/f1c100s/linux/ M=/home/jonsen/f1c100s/test_chrdevbase modules
make[1]: Entering directory '/home/jonsen/f1c100s/linux'
  CC [M]  /home/jonsen/f1c100s/test_chrdevbase/chardevbase.o
In file included from ./arch/x86/include/asm/barrier.h:5,
                 from ./include/linux/compiler.h:242,
                 from ./include/linux/kernel.h:10,
                 from /home/jonsen/f1c100s/test_chrdevbase/chardevbase.c:1:
./arch/x86/include/asm/arch_hweight.h: In function ‘__arch_hweight64’:
./arch/x86/include/asm/arch_hweight.h:55:42: error: expected ‘:’ or ‘)’ before ‘POPCNT64’
   55 |  asm (ALTERNATIVE("call __sw_hweight64", POPCNT64, X86_FEATURE_POPCNT)
./arch/x86/include/asm/alternative.h:133:28: note: in definition of macro ‘ALTINSTR_REPLACEMENT’
  133 |  b_replacement(num)":\n\t" newinstr "\n" e_replacement(num) ":\n\t"
./arch/x86/include/asm/arch_hweight.h:55:7: note: in expansion of macro ‘ALTERNATIVE’
In file included from ./arch/x86/include/asm/atomic.h:276,
                 from ./include/linux/atomic.h:5,
                 from ./include/linux/jump_label.h:186,
                 from ./arch/x86/include/asm/string_64.h:6,
                 from ./arch/x86/include/asm/string.h:5,
                 from ./include/linux/string.h:19,
                 from ./arch/x86/include/asm/page_32.h:35,
                 from ./arch/x86/include/asm/page.h:14,
                 from ./arch/x86/include/asm/thread_info.h:12,
                 from ./include/linux/thread_info.h:38,
                 from ./arch/x86/include/asm/preempt.h:7,
                 from ./include/linux/preempt.h:81,
                 from ./include/linux/spinlock.h:51,
                 from ./include/linux/seqlock.h:36,
                 from ./include/linux/time.h:6,
                 from ./include/linux/stat.h:19,
                 from ./include/linux/module.h:10,
                 from /home/jonsen/f1c100s/test_chrdevbase/chardevbase.c:2:
./arch/x86/include/asm/atomic64_64.h: At top level:
./arch/x86/include/asm/atomic64_64.h:20:40: error: unknown type name ‘atomic64_t’
   20 | static inline long atomic64_read(const atomic64_t *v)
In file included from ./include/linux/kernel.h:10,
./arch/x86/include/asm/atomic64_64.h: In function ‘atomic64_read’:
./arch/x86/include/asm/atomic64_64.h:22:22: error: request for member ‘counter’ in something not a structure or union
   22 |  return READ_ONCE((v)->counter);
./include/linux/compiler.h:246:17: note: in definition of macro ‘__READ_ONCE’
  246 |  union { typeof(x) __val; char __c[1]; } __u;   \
./arch/x86/include/asm/atomic64_64.h:22:9: note: in expansion of macro ‘READ_ONCE’
./include/linux/compiler.h:248:22: note: in definition of macro ‘__READ_ONCE’
  248 |   __read_once_size(&(x), __u.__c, sizeof(x));  \
./include/linux/compiler.h:248:42: note: in definition of macro ‘__READ_ONCE’
./include/linux/compiler.h:250:30: note: in definition of macro ‘__READ_ONCE’
  250 |   __read_once_size_nocheck(&(x), __u.__c, sizeof(x)); \
./include/linux/compiler.h:250:50: note: in definition of macro ‘__READ_ONCE’
./arch/x86/include/asm/atomic64_64.h:32:33: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
   32 | static inline void atomic64_set(atomic64_t *v, long i)
      |                                 atomic_t
./arch/x86/include/asm/atomic64_64.h:44:50: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
   44 | static __always_inline void atomic64_add(long i, atomic64_t *v)
      |                                                  atomic_t
./arch/x86/include/asm/atomic64_64.h:58:41: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
   58 | static inline void atomic64_sub(long i, atomic64_t *v)
      |                                         atomic_t
./arch/x86/include/asm/atomic64_64.h:74:50: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
   74 | static inline bool atomic64_sub_and_test(long i, atomic64_t *v)
      |                                                  atomic_t
./arch/x86/include/asm/atomic64_64.h:85:42: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
   85 | static __always_inline void atomic64_inc(atomic64_t *v)
      |                                          atomic_t
./arch/x86/include/asm/atomic64_64.h:98:42: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
   98 | static __always_inline void atomic64_dec(atomic64_t *v)
      |                                          atomic_t
./arch/x86/include/asm/atomic64_64.h:113:42: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
  113 | static inline bool atomic64_dec_and_test(atomic64_t *v)
      |                                          atomic_t
./arch/x86/include/asm/atomic64_64.h:126:42: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
  126 | static inline bool atomic64_inc_and_test(atomic64_t *v)
      |                                          atomic_t
./arch/x86/include/asm/atomic64_64.h:140:50: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
  140 | static inline bool atomic64_add_negative(long i, atomic64_t *v)
      |                                                  atomic_t
./arch/x86/include/asm/atomic64_64.h:152:57: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
  152 | static __always_inline long atomic64_add_return(long i, atomic64_t *v)
      |                                                         atomic_t
./arch/x86/include/asm/atomic64_64.h:157:48: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
  157 | static inline long atomic64_sub_return(long i, atomic64_t *v)
      |                                                atomic_t
./arch/x86/include/asm/atomic64_64.h:162:47: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
  162 | static inline long atomic64_fetch_add(long i, atomic64_t *v)
      |                                               atomic_t
./arch/x86/include/asm/atomic64_64.h:167:47: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
  167 | static inline long atomic64_fetch_sub(long i, atomic64_t *v)
      |                                               atomic_t
./arch/x86/include/asm/atomic64_64.h:175:37: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
  175 | static inline long atomic64_cmpxchg(atomic64_t *v, long old, long new)
      |                                     atomic_t
./arch/x86/include/asm/atomic64_64.h:181:50: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
  181 | static __always_inline bool atomic64_try_cmpxchg(atomic64_t *v, s64 *old, long new)
      |                                                  atomic_t
./arch/x86/include/asm/atomic64_64.h:186:34: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
  186 | static inline long atomic64_xchg(atomic64_t *v, long new)
      |                                  atomic_t
./arch/x86/include/asm/atomic64_64.h:200:40: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
  200 | static inline bool atomic64_add_unless(atomic64_t *v, long a, long u)
      |                                        atomic_t
./arch/x86/include/asm/atomic64_64.h:219:45: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
  219 | static inline long atomic64_dec_if_positive(atomic64_t *v)
      |                                             atomic_t
./arch/x86/include/asm/atomic64_64.h:230:41: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
  230 | static inline void atomic64_and(long i, atomic64_t *v)
      |                                         atomic_t
./arch/x86/include/asm/atomic64_64.h:238:47: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
  238 | static inline long atomic64_fetch_and(long i, atomic64_t *v)
      |                                               atomic_t
./arch/x86/include/asm/atomic64_64.h:247:40: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
  247 | static inline void atomic64_or(long i, atomic64_t *v)
      |                                        atomic_t
./arch/x86/include/asm/atomic64_64.h:255:46: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
  255 | static inline long atomic64_fetch_or(long i, atomic64_t *v)
      |                                              atomic_t
./arch/x86/include/asm/atomic64_64.h:264:41: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
  264 | static inline void atomic64_xor(long i, atomic64_t *v)
      |                                         atomic_t
./arch/x86/include/asm/atomic64_64.h:272:47: error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
  272 | static inline long atomic64_fetch_xor(long i, atomic64_t *v)
      |                                               atomic_t
In file included from ./include/linux/atomic.h:660,
./include/asm-generic/atomic64.h:21:18: error: conflicting types for ‘atomic64_read’
   21 | extern long long atomic64_read(const atomic64_t *v);
./arch/x86/include/asm/atomic64_64.h:20:20: note: previous definition of ‘atomic64_read’ was here
./include/asm-generic/atomic64.h:59: warning: "atomic64_inc_return" redefined
   59 | #define atomic64_inc_return(v)  atomic64_add_return(1LL, (v))
./arch/x86/include/asm/atomic64_64.h:172: note: this is the location of the previous definition
  172 | #define atomic64_inc_return(v)  (atomic64_add_return(1, (v)))
./include/asm-generic/atomic64.h:63: warning: "atomic64_dec_return" redefined
   63 | #define atomic64_dec_return(v)  atomic64_sub_return(1LL, (v))
./arch/x86/include/asm/atomic64_64.h:173: note: this is the location of the previous definition
  173 | #define atomic64_dec_return(v)  (atomic64_sub_return(1, (v)))
./include/asm-generic/atomic64.h:65: warning: "atomic64_inc_not_zero" redefined
   65 | #define atomic64_inc_not_zero(v)  atomic64_add_unless((v), 1LL, 0LL)
./arch/x86/include/asm/atomic64_64.h:210: note: this is the location of the previous definition
  210 | #define atomic64_inc_not_zero(v) atomic64_add_unless((v), 1, 0)
In file included from ./arch/x86/include/asm/pgtable_types.h:324,
                 from ./arch/x86/include/asm/processor.h:19,
                 from ./arch/x86/include/asm/cpufeature.h:5,
                 from ./arch/x86/include/asm/thread_info.h:53,
./include/asm-generic/pgtable-nopud.h:21: warning: "PUD_SHIFT" redefined
   21 | #define PUD_SHIFT P4D_SHIFT
In file included from ./arch/x86/include/asm/pgtable_types.h:250,
./arch/x86/include/asm/pgtable_64_types.h:56: note: this is the location of the previous definition
   56 | #define PUD_SHIFT 30
./include/asm-generic/pgtable-nopud.h:22: warning: "PTRS_PER_PUD" redefined
   22 | #define PTRS_PER_PUD 1
./arch/x86/include/asm/pgtable_64_types.h:57: note: this is the location of the previous definition
   57 | #define PTRS_PER_PUD 512
./include/asm-generic/pgtable-nopud.h:23: warning: "PUD_SIZE" redefined
   23 | #define PUD_SIZE   (1UL << PUD_SHIFT)
./arch/x86/include/asm/pgtable_64_types.h:73: note: this is the location of the previous definition
   73 | #define PUD_SIZE (_AC(1, UL) << PUD_SHIFT)
./include/asm-generic/pgtable-nopud.h:24: warning: "PUD_MASK" redefined
   24 | #define PUD_MASK   (~(PUD_SIZE-1))
./arch/x86/include/asm/pgtable_64_types.h:74: note: this is the location of the previous definition
   74 | #define PUD_MASK (~(PUD_SIZE - 1))
In file included from ./arch/x86/include/asm/pgtable_types.h:345,
./include/asm-generic/pgtable-nopmd.h:20: warning: "PMD_SHIFT" redefined
   20 | #define PMD_SHIFT PUD_SHIFT
./arch/x86/include/asm/pgtable_64_types.h:63: note: this is the location of the previous definition
   63 | #define PMD_SHIFT 21
./include/asm-generic/pgtable-nopmd.h:21: warning: "PTRS_PER_PMD" redefined
   21 | #define PTRS_PER_PMD 1
./arch/x86/include/asm/pgtable_64_types.h:64: note: this is the location of the previous definition
   64 | #define PTRS_PER_PMD 512
./include/asm-generic/pgtable-nopmd.h:22: warning: "PMD_SIZE" redefined
   22 | #define PMD_SIZE   (1UL << PMD_SHIFT)
./arch/x86/include/asm/pgtable_64_types.h:71: note: this is the location of the previous definition
   71 | #define PMD_SIZE (_AC(1, UL) << PMD_SHIFT)
./include/asm-generic/pgtable-nopmd.h:23: warning: "PMD_MASK" redefined
   23 | #define PMD_MASK   (~(PMD_SIZE-1))
./arch/x86/include/asm/pgtable_64_types.h:72: note: this is the location of the previous definition
   72 | #define PMD_MASK (~(PMD_SIZE - 1))
In file included from ./arch/x86/include/asm/cpufeature.h:5,
./arch/x86/include/asm/processor.h:180: warning: "cache_line_size" redefined
  180 | #define cache_line_size() (boot_cpu_data.x86_cache_alignment)
In file included from ./include/linux/printk.h:9,
                 from ./include/linux/kernel.h:14,
./include/linux/cache.h:79: note: this is the location of the previous definition
   79 | #define cache_line_size() L1_CACHE_BYTES
./arch/x86/include/asm/processor.h: In function ‘load_cr3’:
./arch/x86/include/asm/processor.h:253:12: error: implicit declaration of function ‘__sme_pa’ [-Werror=implicit-function-declaration]
  253 |  write_cr3(__sme_pa(pgdir));
In file included from ./arch/x86/include/asm/preempt.h:7,
./include/linux/thread_info.h: At top level:
./include/linux/thread_info.h:96:19: error: redefinition of ‘arch_within_stack_frames’
   96 | static inline int arch_within_stack_frames(const void * const stack,
In file included from ./include/linux/thread_info.h:38,
./arch/x86/include/asm/thread_info.h:171:19: note: previous definition of ‘arch_within_stack_frames’ was here
  171 | static inline int arch_within_stack_frames(const void * const stack,
In file included from ./include/linux/elf.h:5,
                 from ./include/linux/module.h:15,
./arch/x86/include/asm/elf.h: In function ‘elf_common_init’:
./arch/x86/include/asm/elf.h:180:3: error: ‘struct thread_struct’ has no member named ‘fsbase’
  180 |  t->fsbase = t->gsbase = 0;
./arch/x86/include/asm/elf.h:180:15: error: ‘struct thread_struct’ has no member named ‘gsbase’
./arch/x86/include/asm/elf.h: In function ‘mmap_is_ia32’:
./include/linux/thread_info.h:91:22: error: implicit declaration of function ‘current_thread_info’ [-Werror=implicit-function-declaration]
   91 |  test_ti_thread_flag(current_thread_info(), flag)
./arch/x86/include/asm/elf.h:306:3: note: in expansion of macro ‘test_thread_flag’
  306 |   test_thread_flag(TIF_ADDR32));
./include/linux/thread_info.h:91:22: warning: passing argument 1 of ‘test_ti_thread_flag’ makes pointer from integer without a cast [-Wint-conversion]
      |                      int
./include/linux/thread_info.h:77:59: note: expected ‘struct thread_info *’ but argument is of type ‘int’
   77 | static inline int test_ti_thread_flag(struct thread_info *ti, int flag)
In file included from ./include/linux/cache.h:6,
./arch/x86/include/asm/elf.h: At top level:
./arch/x86/include/asm/cache.h:8:25: error: ‘CONFIG_X86_L1_CACHE_SHIFT’ undeclared here (not in a function); did you mean ‘CONFIG_ARM_L1_CACHE_SHIFT’?
    8 | #define L1_CACHE_SHIFT (CONFIG_X86_L1_CACHE_SHIFT)
./arch/x86/include/asm/cache.h:9:30: note: in expansion of macro ‘L1_CACHE_SHIFT’
    9 | #define L1_CACHE_BYTES (1 << L1_CACHE_SHIFT)
./include/linux/cache.h:13:25: note: in expansion of macro ‘L1_CACHE_BYTES’
   13 | #define SMP_CACHE_BYTES L1_CACHE_BYTES
./include/linux/cache.h:35:58: note: in expansion of macro ‘SMP_CACHE_BYTES’
   35 | #define ____cacheline_aligned __attribute__((__aligned__(SMP_CACHE_BYTES)))
./arch/x86/include/asm/elf.h:381:3: note: in expansion of macro ‘____cacheline_aligned’
  381 | } ____cacheline_aligned;
In file included from ./include/linux/module.h:24,
./arch/x86/include/asm/module.h:67:2: error: #error unknown processor family
   67 | #error unknown processor family
./include/linux/sched.h: In function ‘need_resched’:
      |                      int
./include/linux/compiler.h:77:42: note: in definition of macro ‘unlikely’
   77 | # define unlikely(x) __builtin_expect(!!(x), 0)
./include/linux/thread_info.h:93:28: note: in expansion of macro ‘test_thread_flag’
   93 | #define tif_need_resched() test_thread_flag(TIF_NEED_RESCHED)
./include/linux/sched.h:1613:18: note: in expansion of macro ‘tif_need_resched’
 1613 |  return unlikely(tif_need_resched());
In file included from /home/jonsen/f1c100s/test_chrdevbase/chardevbase.c:7:
./include/linux/gpio.h: At top level:
./include/linux/gpio.h:49:10: fatal error: asm/gpio.h: No such file or directory
   49 | #include <asm/gpio.h>
cc1: some warnings being treated as errors
compilation terminated.
make[2]: *** [scripts/Makefile.build:323: /home/jonsen/f1c100s/test_chrdevbase/chardevbase.o] Error 1
make[1]: *** [Makefile:1508: _module_/home/jonsen/f1c100s/test_chrdevbase] Error 2
make[1]: Leaving directory '/home/jonsen/f1c100s/linux'
make: *** [Makefile:9: all] Error 2
可以的,亲自试过。
#33 2021-04-15 14:44:09
cube
已发帖子: 288
感谢楼主, 测试了一下, 一楼的代码在 tiny200 tina3.5 linux 也可以跑.
#34 2021-04-15 21:58:32
mysteryli
已发帖子: 485
这种在应用层怎么调用?
#35 2021-04-15 22:33:42
raspberryman
已发帖子: 503
mysteryli 说:
这种在应用层怎么调用?
只是一个简单的演示代码,如果需要应用层调用,需要加 open/close/read/write/ioctl 等操作代码
#36 2021-05-07 22:30:04
microxp
已发帖子: 76
  • 不通过:与技术无关
#37 2022-04-01 15:38:20
uuid
已发帖子: 45
把楼主的 hello.c 和 Makefile 复制后,编译:
ARCH=arm64 CROSS_COMPILE=/opt/a100/longan/out/gcc-linaro-5.3.1-2016.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu- make -C /opt/a100/longan/kernel/linux-4.9/ M=${PWD} modules
A133 的板子, 一块能中断, 一块不能中断,一头雾水。
#38 2022-04-02 09:13:17
东哥
我之前是用内存映射直接写寄存器,这个比我的方便多了
