楼主 #1 2017-10-31 22:01:21
落雁
已发帖子: 62
我的openwrt opkg update 还是安装不了软件
root@Widora:~# opkg update
Downloading http://downloads.openwrt.org/chaos_calmer/15.05.1/ramips/mt7688/packages/base/Packages.gz.
Updated list of available packages in /var/opkg-lists/chaos_calmer_base.
Downloading http://downloads.openwrt.org/chaos_calmer/15.05.1/ramips/mt7688/packages/base/Packages.sig.
Signature check passed.
root@Widora:~# opkg install luci
Unknown package 'luci'.
Collected errors:
  • opkg_install_cmd: Cannot install package luci.
最近编辑记录 落雁 (2017-10-31 22:03:45)
#2 2017-10-31 22:04:29
Re: 我的openwrt opkg update 还是安装不了软件
#3 2017-11-01 09:42:23
daydayup
已发帖子: 343
碰到和楼主一样的问题,也是修改 /etc/opkg/distfeeds.conf 文件搞定了, 谢谢楼上的大侠
可是我的widora没有aplay, arecord, madplay应该怎么办呢?
#4 2017-11-01 09:44:03
试一试安装:
opkg install alsa-utils
opkg install madplay
#5 2017-11-01 09:45:04
daydayup
已发帖子: 343
搞定,谢谢!
root@Widora:/tmp/run/mountd/mmcblk0p1# aplay chimes.wav
Playing WAVE 'chimes.wav' : Signed 16 bit Little Endian, Rate 44100 Hz, Stereo
[ 1581.930000] wm8960_postinit
[ 1583.270000] playback free_dma_buffer
[ 1583.280000] ptri2s_config->mmap_index:8
#6 2017-11-01 09:52:12
daydayup
已发帖子: 343
root@Widora:/tmp/run/mountd/mmcblk0p1# madplay tkzc.mp3
MPEG Audio Decoder 0.15.2 (beta) - Copyright (C) 2000-2004 Robert Leslie et al.
Title: ▒▒▒֮▒▒
Artist: ▒▒▒ٰ▒
[ 1787.030000] wm8960_postinit
[ 1787.050000] mtk_dai: ASoC: unmatched rate symmetry: 8000 - 44100
[ 1787.060000] playback free_dma_buffer
[ 1787.060000] ptri2s_config->mmap_index:8
output: ioctl(SNDCTL_DSP_SPEED): Invalid argument
救命,madplay播放mp3不出声, 哭 ...
#7 2017-11-01 09:52:57
root@Widora:/tmp/run/mountd/mmcblk0p1# madplay -o wave:- tkzc.mp3 | aplay
试一试管道?
#8 2017-11-01 09:53:53
daydayup
已发帖子: 343
试一试管道?
总算可以,谢谢大神困扰我我几天的问题。
