楼主 #1 2017-11-01 10:24:12
daydayup
已发帖子: 343
/sbin/widora_mode 原来是用uci脚本实现的
root@Widora:/tmp/run/mountd/mmcblk0p1# cat /sbin/widora_mode
#!/bin/sh
if [ -n "$1" ];then
wifi down
sleep 1
case $1 in
repeater)       #repeater mode
        if [ -n "$2" ];then
        uci set wireless.sta.ssid="$2"
        if [ -n "$3" ];then
        uci set wireless.sta.key="$3"
        uci delete wireless.sta.key
        fi
        fi
        uci set wireless.sta.network=lan
        uci set wireless.sta.disabled=0
        uci set wireless.ap.hidden=0
        uci set dhcp.lan.ignore=1
        uci set network.lan.proto='dhcp'
        uci set network.lan.ifname='eth0'
        uci delete network.wan
        uci commit
        /etc/init.d/network restart
client) #client mode
        if [ -n "$2" ];then
        if [ -n "$3" ];then
        fi
        fi
        uci set wireless.sta.network=wan
        uci set wireless.ap.hidden=1
        uci set network.wan=interface
        uci set network.wan.ifname='apcli0'
        uci set network.wan.proto='dhcp'
        uci set dhcp.lan.ignore=0
        uci set network.lan.proto=static
        uci commit
router) #router mode
        uci set wireless.sta.disabled=1
        uci delete network.lan.ifname
        uci set network.wan.ifname='eth0'
        uci commit
pppoe)  #pppoe mode
        uci set network.wan.proto='pppoe'
        [ -n "$2" ] && uci set network.wan.username="$2"
        [ -n "$3" ] && uci set network.wan.password="$3"
        uci commit
esac
echo "---------------------------------------------------"
echo "widora_mode help"
echo "MODE |   REPEATER     |  CLIENT  | ROUTER PPPOE |"
echo "LAN  | eth0 ra0 apcli0|  eth0    | ra0          |"
echo "WAN  |                |  apcli0  | eth0         |"
echo "\"widora_mode repeater\""
echo "\"widora_mode repeater ssid key\""
echo "\"widora_mode client\""
echo "\"widora_mode client ssid key\""
echo "\"widora_mode router\""
echo "\"widora_mode pppoe\""
echo "\"widora_mode pppoe user_name password\""
fi
