U-Boot SPL 2017.01-rc2 (Nov 25 2018 - 14:49:54)
DRAM: 64 MiB
Trying to boot from sunxi SPI
U-Boot 2017.01-rc2 (Nov 25 2018 - 14:49:54 +0800) Allwinner Technology
Model: Lichee Pi Zero
DRAM: 64 MiB
MMC: SUNXI SD/MMC: 0
SF: Detected mx25l25635f with page size 256 Bytes, erase size 64 KiB, total 32 MiB
dotclock: 10000kHz = 10000kHz: (1 * 3MHz * 20) / 6
In: serial@01c28000
Out: serial@01c28000
Err: serial@01c28000
DRAM: 64 MiB
In: serial@01c28000
Net: No ethernet found.
No controllers found
=> boot
Loading Device Tree to 42dfa000, end 42dffed1 ... OK
[ 0.000000] Linux version 4.13.16-licheepi-zero (root@billnie) (gcc version 6.3.1 20170109 (Linaro GCC 6.3-2017.02)) #11 SMP Sun Nov 25 15:15:03 CST 2018
[ 0.000000] OF: fdt: Machine model: Lichee Pi Zero with Dock
[ 0.000000] percpu: Embedded 16 pages/cpu @c3edf000 s33868 r8192 d23476 u65536
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16129
[ 0.000000] Kernel command line: console=ttyS0,115200 earlyprintk panic=5 rootwait mtdparts=spi32766.0:1M(uboot)ro,64k(dtb)ro,4M(kernel)ro,-(rootfs) root=31:03 rw rootfstype=jffs2
[ 0.000000] Memory: 54568K/65024K available (6144K kernel code, 217K rwdata, 1456K rodata, 1024K init, 264K bss, 10456K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] vmalloc : 0xc4000000 - 0xff800000 ( 952 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc3f80000 ( 63 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0700000 (7136 kB)
[ 0.000000] .init : 0xc0900000 - 0xc0a00000 (1024 kB)
[ 0.000000] .data : 0xc0a00000 - 0xc0a367c0 ( 218 kB)
[ 0.000000] .bss : 0xc0a3daf0 - 0xc0a7fcac ( 265 kB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU event tracing is enabled.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
[ 0.000008] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000020] Switching to timer-based delay loop, resolution 41ns
[ 0.000180] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000402] Console: colour dummy device 80x30
[ 0.000438] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000453] pid_max: default: 32768 minimum: 301
[ 0.000579] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000592] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001186] CPU: Testing write buffer coherency: ok
[ 0.001556] /cpus/cpu@0 missing clock-frequency property
[ 0.001578] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.001997] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.002174] Hierarchical SRCU implementation.
[ 0.002673] smp: Bringing up secondary CPUs ...
[ 0.002688] smp: Brought up 1 node, 1 CPU
[ 0.002698] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.002705] CPU: All CPU(s) started in SVC mode.
[ 0.003459] devtmpfs: initialized
[ 0.006581] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.006870] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.006897] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.007055] pinctrl core: initialized pinctrl subsystem
[ 0.007906] random: get_random_u32 called from bucket_table_alloc+0xf4/0x244 with crng_init=0
[ 0.008037] NET: Registered protocol family 16
[ 0.008505] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.009632] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.009649] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.023048] SCSI subsystem initialized
[ 0.023348] usbcore: registered new interface driver usbfs
[ 0.023410] usbcore: registered new interface driver hub
[ 0.023507] usbcore: registered new device driver usb
[ 0.023754] pps_core: LinuxPPS API ver. 1 registered
[ 0.023764] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.023785] PTP clock support registered
[ 0.024022] Advanced Linux Sound Architecture Driver Initialized.
[ 0.025873] clocksource: Switched to clocksource arch_sys_counter
[ 0.036244] led_trigger_register 0 kbd-scrolllock
[ 0.036261] led_trigger_register 1 kbd-numlock
[ 0.036268] led_trigger_register 2 kbd-capslock
[ 0.036274] led_trigger_register 3 kbd-kanalock
[ 0.036279] led_trigger_register 4 kbd-shiftlock
[ 0.036285] led_trigger_register 5 kbd-altgrlock
[ 0.036291] led_trigger_register 6 kbd-ctrllock
[ 0.036297] led_trigger_register 7 kbd-altlock
[ 0.036303] led_trigger_register 8 kbd-shiftllock
[ 0.036310] led_trigger_register 9 kbd-shiftrlock
[ 0.036316] led_trigger_register 10 kbd-ctrlllock
[ 0.036322] led_trigger_register 11 kbd-ctrlrlock
[ 0.036768] NET: Registered protocol family 2
[ 0.037344] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.037377] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.037401] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.037527] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.037575] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.037788] NET: Registered protocol family 1
[ 0.038372] RPC: Registered named UNIX socket transport module.
[ 0.038390] RPC: Registered udp transport module.
[ 0.038397] RPC: Registered tcp transport module.
[ 0.038403] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.040493] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.049383] NFS: Registering the id_resolver key type
[ 0.049432] Key type id_resolver registered
[ 0.049439] Key type id_legacy registered
[ 0.049483] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.050999] random: fast init done
[ 0.053835] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.053855] io scheduler noop registered
[ 0.053862] io scheduler deadline registered
[ 0.054134] io scheduler cfq registered (default)
[ 0.054146] io scheduler mq-deadline registered
[ 0.054153] io scheduler kyber registered
[ 0.058491] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.128110] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.131331] console [ttyS0] disabled
[ 0.151602] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 36, base_baud = 1500000) is a U6_16550A
[ 0.795735] console [ttyS0] enabled
[ 0.803496] spi_nor_scan:(null)
[ 0.806939] m25p80 spi32766.0: unrecognized JEDEC id bytes: 00, 00, 00
[ 0.813472] m25p80 spi32766.0: unrecognized JEDEC id bytes: 00, 00, 00
[ 0.820067] m25p80: probe of spi32766.0 failed with error -2
[ 0.826158] libphy: Fixed MDIO Bus: probed
[ 0.830755] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[ 0.836633] dwmac-sun8i 1c30000.ethernet: No regulator found
[ 0.842343] dwmac-sun8i 1c30000.ethernet: Will use internal PHY
[ 0.848523] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[ 0.854185] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[ 0.861440] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[ 0.867111] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[ 0.874324] dwmac-sun8i 1c30000.ethernet: COE Type 2
[ 0.879297] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[ 0.886289] libphy: stmmac: probed
[ 0.891562] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.898220] ehci-platform: EHCI generic platform driver
[ 0.903740] ehci-platform 1c1a000.usb: EHCI Host Controller
[ 0.909428] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[ 0.917359] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000
[ 0.945895] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[ 0.953100] hub 1-0:1.0: USB hub found
[ 0.957044] hub 1-0:1.0: 1 port detected
[ 0.961538] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.967836] ohci-platform: OHCI generic platform driver
[ 0.973374] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[ 0.980097] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[ 0.988062] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400
[ 1.061013] hub 2-0:1.0: USB hub found
[ 1.064845] hub 2-0:1.0: 1 port detected
[ 1.072428] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[ 1.081998] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input0
[ 1.090968] sun6i-rtc 1c20400.rtc: rtc core: registered rtc-sun6i as rtc0
[ 1.097877] sun6i-rtc 1c20400.rtc: RTC enabled
[ 1.102419] i2c /dev entries driver
[ 1.107454] input: ns2009_ts as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0048/input/input1
[ 1.116960] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.126462] led_trigger_register_simple mmc0
[ 1.126482] led_trigger_register 12 mmc0
[ 1.185919] sunxi-mmc 1c0f000.mmc: base:0xc407b000 irq:23
[ 1.192386] led_trigger_register_simple mmc1
[ 1.192405] led_trigger_register 13 mmc1
[ 1.255905] sunxi-mmc 1c10000.mmc: base:0xc4144000 irq:24
[ 1.261626] led_trigger_register 14 heartbeat
[ 1.266044] led_trigger_register 15 default-on
[ 1.271147] usbcore: registered new interface driver usbhid
[ 1.276780] usbhid: USB HID core driver
[ 1.282179] sun4i-codec 1c22c00.codec: ASoC: /soc/codec-analog@01c23000 not registered
[ 1.290220] sun4i-codec 1c22c00.codec: Failed to register our card
[ 1.297689] NET: Registered protocol family 17
[ 1.302271] Key type dns_resolver registered
[ 1.306807] Registering SWP/SWPB emulation handler
[ 1.319307] simple-framebuffer 43f80000.framebuffer: framebuffer at 0x43f80000, 0x7f800 bytes, mapped to 0xc4300000
[ 1.329925] simple-framebuffer 43f80000.framebuffer: format=x8r8g8b8, mode=480x272x32, linelength=1920
[ 1.342206] Console: switching to colour frame buffer device 60x34
[ 1.350669] simple-framebuffer 43f80000.framebuffer: fb0: simplefb registered!
[ 1.359181] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 1.370550] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.376389] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[ 1.385435] hub 3-0:1.0: USB hub found
[ 1.389412] hub 3-0:1.0: 1 port detected
[ 1.394551] using random self ethernet address
[ 1.399124] using random host ethernet address
[ 1.404647] usb0: HOST MAC ea:26:5e:0b:a9:73
[ 1.409113] usb0: MAC 52:f9:25:c2:8a:3b
[ 1.412995] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[ 1.420522] g_cdc gadget: g_cdc ready
[ 1.426834] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
[ 1.436329] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01 00:00:23 UTC (23)
[ 1.444580] vcc3v3: disabling
[ 1.447621] vcc5v0: disabling
[ 1.450591] ALSA device list:
[ 1.453554] #0: V3s Audio Codec
[ 1.457723] VFS: Cannot open root device "31:03" or unknown-block(31,3): error -19
[ 1.465292] Please append a correct "root=" boot option; here are the available partitions:
[ 1.473737] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,3)
[ 1.482086] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.13.16-licheepi-zero #11
[ 1.489382] Hardware name: Allwinner sun8i Family
[ 1.494120] [<c010e5cc>] (unwind_backtrace) from [<c010b2b0>] (show_stack+0x10/0x14)
[ 1.501867] [<c010b2b0>] (show_stack) from [<c06788fc>] (dump_stack+0x84/0x98)
[ 1.509091] [<c06788fc>] (dump_stack) from [<c011b788>] (panic+0xdc/0x248)
[ 1.515968] [<c011b788>] (panic) from [<c09011d0>] (mount_block_root+0x188/0x25c)
[ 1.523446] [<c09011d0>] (mount_block_root) from [<c09013c4>] (mount_root+0x120/0x128)
[ 1.531358] [<c09013c4>] (mount_root) from [<c090151c>] (prepare_namespace+0x150/0x194)
[ 1.539355] [<c090151c>] (prepare_namespace) from [<c0900e20>] (kernel_init_freeable+0x1bc/0x1cc)
[ 1.548221] [<c0900e20>] (kernel_init_freeable) from [<c068b7d4>] (kernel_init+0x8/0x108)
[ 1.556393] [<c068b7d4>] (kernel_init) from [<c0107638>] (ret_from_fork+0x14/0x3c)
[ 1.563965] Rebooting in 5 seconds..
关键点,看起来linux驱动无法识别,
sunxi-fel 能识别
u-boot 也能识别
改成16MHZ了
&spi0 {
status ="okay";
mx25l25635e:mx25l25635e@0 {
compatible = "jedec,spi-nor";
reg = <0x0>;
spi-max-frequency = <16000000>;
#address-cells = <1>;
#size-cells = <1>;
现在可以识别flash,但是rootfs有问题
[ 0.000000] Linux version 4.13.16-licheepi-zero (root@billnie) (gcc version 6.3.1 20170109 (Linaro GCC 6.3-2017.02)) #17 SMP Sun Nov 25 23:23:00 CST 2018
[ 0.000019] Switching to timer-based delay loop, resolution 41ns
[ 0.000181] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000409] Console: colour dummy device 80x30
[ 0.000443] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000457] pid_max: default: 32768 minimum: 301
[ 0.000583] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000597] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001184] CPU: Testing write buffer coherency: ok
[ 0.001550] /cpus/cpu@0 missing clock-frequency property
[ 0.001573] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002169] Hierarchical SRCU implementation.
[ 0.002671] smp: Bringing up secondary CPUs ...
[ 0.002683] smp: Brought up 1 node, 1 CPU
[ 0.002691] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.002699] CPU: All CPU(s) started in SVC mode.
[ 0.003447] devtmpfs: initialized
[ 0.006567] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.006853] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.006878] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.007042] pinctrl core: initialized pinctrl subsystem
[ 0.007911] random: get_random_u32 called from bucket_table_alloc+0xf4/0x244 with crng_init=0
[ 0.008044] NET: Registered protocol family 16
[ 0.008513] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.009626] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.009644] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.023088] SCSI subsystem initialized
[ 0.023390] usbcore: registered new interface driver usbfs
[ 0.023457] usbcore: registered new interface driver hub
[ 0.023552] usbcore: registered new device driver usb
[ 0.023798] pps_core: LinuxPPS API ver. 1 registered
[ 0.023807] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.023828] PTP clock support registered
[ 0.024055] Advanced Linux Sound Architecture Driver Initialized.
[ 0.025899] clocksource: Switched to clocksource arch_sys_counter
[ 0.036306] led_trigger_register 0 kbd-scrolllock
[ 0.036324] led_trigger_register 1 kbd-numlock
[ 0.036330] led_trigger_register 2 kbd-capslock
[ 0.036336] led_trigger_register 3 kbd-kanalock
[ 0.036342] led_trigger_register 4 kbd-shiftlock
[ 0.036348] led_trigger_register 5 kbd-altgrlock
[ 0.036354] led_trigger_register 6 kbd-ctrllock
[ 0.036360] led_trigger_register 7 kbd-altlock
[ 0.036366] led_trigger_register 8 kbd-shiftllock
[ 0.036372] led_trigger_register 9 kbd-shiftrlock
[ 0.036378] led_trigger_register 10 kbd-ctrlllock
[ 0.036385] led_trigger_register 11 kbd-ctrlrlock
[ 0.036835] NET: Registered protocol family 2
[ 0.037405] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.037440] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.037465] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.037590] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.037638] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.037859] NET: Registered protocol family 1
[ 0.038441] RPC: Registered named UNIX socket transport module.
[ 0.038458] RPC: Registered udp transport module.
[ 0.038464] RPC: Registered tcp transport module.
[ 0.038470] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.040559] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.049490] NFS: Registering the id_resolver key type
[ 0.049539] Key type id_resolver registered
[ 0.049545] Key type id_legacy registered
[ 0.049590] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.051113] random: fast init done
[ 0.053969] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.053991] io scheduler noop registered
[ 0.053999] io scheduler deadline registered
[ 0.054271] io scheduler cfq registered (default)
[ 0.054282] io scheduler mq-deadline registered
[ 0.054288] io scheduler kyber registered
[ 0.058618] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.128112] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.131320] console [ttyS0] disabled
[ 0.151595] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 36, base_baud = 1500000) is a U6_16550A
[ 0.795739] console [ttyS0] enabled
[ 0.802530] sun6i_spi_probe
[ 0.806393] m25p_probe:
[ 0.809090] m25p80 spi32766.0: unrecognized JEDEC id bytes: c2, 20, 19
[ 0.815619] spi_nor_scan 2:(null)
[ 0.818990] spi_nor_init_params:
[ 0.822358] m25p80 spi32766.0: mx25l25635e (32768 Kbytes)
[ 0.827811] spi32766.0: parser cmdlinepart: 4
[ 0.832165] 4 cmdlinepart partitions found on MTD device spi32766.0
[ 0.838444] Creating 4 MTD partitions on "spi32766.0":
[ 0.843585] 0x000000000000-0x000000100000 : "uboot"
[ 0.849004] 0x000000100000-0x000000110000 : "dtb"
[ 0.854108] 0x000000110000-0x000000510000 : "kernel"
[ 0.859524] 0x000000510000-0x000002000000 : "rootfs"
[ 0.865275] libphy: Fixed MDIO Bus: probed
[ 0.869960] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[ 0.875755] dwmac-sun8i 1c30000.ethernet: No regulator found
[ 0.881531] dwmac-sun8i 1c30000.ethernet: Will use internal PHY
[ 0.887716] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[ 0.893377] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[ 0.900631] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[ 0.906300] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[ 0.913514] dwmac-sun8i 1c30000.ethernet: COE Type 2
[ 0.918486] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[ 0.925447] libphy: stmmac: probed
[ 0.930789] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.937446] ehci-platform: EHCI generic platform driver
[ 0.942960] ehci-platform 1c1a000.usb: EHCI Host Controller
[ 0.948645] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[ 0.956581] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000
[ 0.985917] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[ 0.993155] hub 1-0:1.0: USB hub found
[ 0.997108] hub 1-0:1.0: 1 port detected
[ 1.001624] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.007922] ohci-platform: OHCI generic platform driver
[ 1.013490] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[ 1.020234] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[ 1.028188] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400
[ 1.101025] hub 2-0:1.0: USB hub found
[ 1.104850] hub 2-0:1.0: 1 port detected
[ 1.112462] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[ 1.122041] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input0
[ 1.130977] sun6i-rtc 1c20400.rtc: rtc core: registered rtc-sun6i as rtc0
[ 1.137883] sun6i-rtc 1c20400.rtc: RTC enabled
[ 1.142422] i2c /dev entries driver
[ 1.147273] input: ns2009_ts as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0048/input/input1
[ 1.156766] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.166182] led_trigger_register_simple mmc0
[ 1.166200] led_trigger_register 12 mmc0
[ 1.225949] sunxi-mmc 1c0f000.mmc: base:0xc407b000 irq:23
[ 1.232404] led_trigger_register_simple mmc1
[ 1.232421] led_trigger_register 13 mmc1
[ 1.295928] sunxi-mmc 1c10000.mmc: base:0xc4144000 irq:24
[ 1.301673] led_trigger_register 14 heartbeat
[ 1.306101] led_trigger_register 15 default-on
[ 1.311220] usbcore: registered new interface driver usbhid
[ 1.316841] usbhid: USB HID core driver
[ 1.322297] sun4i-codec 1c22c00.codec: ASoC: /soc/codec-analog@01c23000 not registered
[ 1.330339] sun4i-codec 1c22c00.codec: Failed to register our card
[ 1.337794] NET: Registered protocol family 17
[ 1.342371] Key type dns_resolver registered
[ 1.346908] Registering SWP/SWPB emulation handler
[ 1.359402] simple-framebuffer 43f80000.framebuffer: framebuffer at 0x43f80000, 0x7f800 bytes, mapped to 0xc4300000
[ 1.370020] simple-framebuffer 43f80000.framebuffer: format=x8r8g8b8, mode=480x272x32, linelength=1920
[ 1.382296] Console: switching to colour frame buffer device 60x34
[ 1.390757] simple-framebuffer 43f80000.framebuffer: fb0: simplefb registered!
[ 1.399299] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 1.410649] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.416489] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[ 1.425626] hub 3-0:1.0: USB hub found
[ 1.429621] hub 3-0:1.0: 1 port detected
[ 1.434689] using random self ethernet address
[ 1.439241] using random host ethernet address
[ 1.444812] usb0: HOST MAC fa:2c:1b:ee:06:bc
[ 1.449235] usb0: MAC 62:22:20:4c:8f:06
[ 1.453116] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[ 1.460634] g_cdc gadget: g_cdc ready
[ 1.466985] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
[ 1.476595] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01 00:00:15 UTC (15)
[ 1.484847] vcc3v3: disabling
[ 1.487889] vcc5v0: disabling
[ 1.490858] ALSA device list:
[ 1.493822] #0: V3s Audio Codec
[ 1.505669] jffs2: jffs2_scan_inode_node(): CRC failed on node at 0x000020a8: Read 0x4594b5b8, calculated 0x798d4761
[ 1.518660] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000a0f8: 0xe666 instead
[ 1.528208] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000a0fc: 0x633f instead
[ 1.537898] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000a100: 0xc64f instead
[ 1.547406] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000a104: 0xa56f instead
[ 1.556888] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000a108: 0x81c9 instead
[ 1.566362] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000a10c: 0x84a3 instead
[ 1.575827] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000a110: 0x9eb6 instead
[ 1.585303] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000a114: 0x2e06 instead
[ 1.594830] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000a118: 0x0e2b instead
[ 1.604317] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000a11c: 0xa5f3 instead
[ 1.613794] jffs2: Further such events for this erase block will not be printed
[ 1.632729] random: crng init done
[ 1.636180] sun4i_lradc_irq voltage = 11 349206!
[ 1.927519] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0008d868: 0x8cc2 instead
[ 1.937086] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0008d86c: 0x0019 instead
[ 1.946579] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0008d870: 0x3735 instead
[ 1.956057] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0008d874: 0x808b instead
[ 1.965521] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0008d878: 0x0376 instead
[ 1.974997] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0008d87c: 0xc476 instead
[ 1.984474] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0008d884: 0x2676 instead
[ 1.993948] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0008d888: 0xb05d instead
[ 2.003424] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0008d88c: 0xb0dd instead
[ 2.012942] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0008d890: 0xb0dd instead
[ 2.022423] jffs2: Further such events for this erase block will not be printed
[ 2.043923] sun4i_lradc_irq voltage = 13 412698!
[ 2.201264] jffs2: jffs2_scan_inode_node(): CRC failed on node at 0x000d6064: Read 0x6b91f9a1, calculated 0x83c9f10a
[ 2.211889] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000d60dc: 0x265d instead
[ 2.221420] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000d60e0: 0x1467 instead
[ 2.230910] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000d60e4: 0x0501 instead
[ 2.240389] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000d60e8: 0x4c4d instead
[ 2.249865] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000d60ec: 0x911a instead
[ 2.259340] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000d60f0: 0xa11b instead
[ 2.268815] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000d60f4: 0xb44b instead
[ 2.278290] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000d60f8: 0x4e01 instead
[ 2.287765] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000d60fc: 0x2059 instead
[ 2.297240] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000d6100: 0xa9ff instead
[ 2.306712] jffs2: Further such events for this erase block will not be printed
[ 2.329067] sun4i_lradc_irq voltage = 11 349206!
[ 2.382457] jffs2: jffs2_scan_inode_node(): CRC failed on node at 0x000f10d4: Read 0x311c7253, calculated 0xf37a7290
[ 2.393108] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000f114c: 0x1dae instead
[ 2.402635] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000f1150: 0x3197 instead
[ 2.413181] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000f1154: 0x61e3 instead
[ 2.424719] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000f1158: 0x15d5 instead
[ 2.434257] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000f115c: 0x917a instead
[ 2.443767] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000f1160: 0x1283 instead
[ 2.453261] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000f1164: 0x1d8e instead
[ 2.462753] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000f1168: 0x0470 instead
[ 2.472251] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000f116c: 0x4bbd instead
[ 2.481746] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000f1170: 0x0d7e instead
[ 2.491241] jffs2: Further such events for this erase block will not be printed
[ 2.512655] sun4i_lradc_irq voltage = 11 349206!
[ 2.740209] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00154298: 0x8cc2 instead
[ 2.749784] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0015429c: 0x0022 instead
[ 2.759308] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001542a0: 0x4815 instead
[ 2.768792] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001542a4: 0x00cb instead
[ 2.778270] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001542a8: 0x8032 instead
[ 2.787746] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001542ac: 0xc076 instead
[ 2.797222] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001542b4: 0x703e instead
[ 2.806697] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001542b8: 0xb05d instead
[ 2.816170] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001542bc: 0xb0dd instead
[ 2.825634] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001542c0: 0xb0dd instead
[ 2.835107] jffs2: Further such events for this erase block will not be printed
[ 2.856384] sun4i_lradc_irq voltage = 11 349206!
[ 2.881320] jffs2: Empty flash at 0x0016225c ends at 0x0016227c
[ 2.887273] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0016227c: 0x61bb instead
[ 2.896807] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00162280: 0x61bb instead
[ 2.906289] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00162284: 0x61bb instead
[ 2.915754] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00162288: 0x1000 instead
[ 2.925234] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0016228c: 0x0100 instead
[ 2.934711] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00162290: 0x0100 instead
[ 2.944187] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00162298: 0xf429 instead
[ 2.953661] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0016229c: 0x8928 instead
[ 2.963136] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001622a0: 0xe92d instead
[ 2.972610] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001622a4: 0xf04f instead
[ 2.982084] jffs2: Further such events for this erase block will not be printed
[ 3.004814] sun4i_lradc_irq voltage = 11 349206!
[ 3.228563] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c92d8: 0x8cc2 instead
[ 3.238163] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c92dc: 0x0022 instead
[ 3.247663] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c92e0: 0x4815 instead
[ 3.257143] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c92e4: 0x00ce instead
[ 3.266662] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c92e8: 0x0246 instead
[ 3.276168] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c92ec: 0xc076 instead
[ 3.285634] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c92f4: 0x5350 instead
[ 3.295117] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c92f8: 0xb05d instead
[ 3.304594] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c92fc: 0xb0dd instead
[ 3.314069] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c9300: 0xb0dd instead
[ 3.323541] jffs2: Further such events for this erase block will not be printed
[ 3.344644] sun4i_lradc_irq voltage = 11 349206!
[ 3.364173] sun4i_lradc_irq voltage = 14 444444!
[ 3.390871] jffs2: Empty flash at 0x001de7c0 ends at 0x001de7e0
[ 3.396870] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001de7e0: 0x61bb instead
[ 3.406357] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001de7e4: 0x61bb instead
[ 3.415822] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001de7e8: 0x61bb instead
[ 3.425302] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001de7ec: 0x64fe instead
[ 3.434778] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001de7f0: 0x0002 instead
[ 3.444252] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001de7f4: 0x0002 instead
[ 3.453727] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001de7fc: 0x20c8 instead
[ 3.463201] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001de800: 0x6743 instead
[ 3.472675] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001de804: 0x2000 instead
[ 3.496979] sun4i_lradc_irq voltage = 11 349206!
[ 3.545011] jffs2: jffs2_scan_inode_node(): CRC failed on node at 0x001f89a8: Read 0x590164a2, calculated 0x8c8c1899
[ 3.555621] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001f8ae8: 0x8c42 instead
[ 3.565176] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001f8aec: 0x0023 instead
[ 3.574660] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001f8af0: 0x194b instead
[ 3.584138] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001f8af4: 0x004e instead
[ 3.593645] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001f8af8: 0x830d instead
[ 3.603151] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001f8afc: 0xc076 instead
[ 3.613738] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001f8b04: 0x5350 instead
[ 3.625277] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001f8b08: 0xb05d instead
[ 3.634780] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001f8b0c: 0xb0dd instead
[ 3.644316] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001f8b10: 0xb0dd instead
[ 3.653803] jffs2: Further such events for this erase block will not be printed
[ 3.676661] sun4i_lradc_irq voltage = 11 349206!
[ 3.714930] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0020c680: 0x8cc2 instead
[ 3.724509] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0020c684: 0x0022 instead
[ 3.734089] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0020c688: 0x4815 instead
[ 3.743603] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0020c68c: 0x00ce instead
[ 3.753102] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0020c690: 0x0413 instead
[ 3.762604] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0020c694: 0xc076 instead
[ 3.772101] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0020c69c: 0x5350 instead
[ 3.781597] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0020c6a0: 0xb05d instead
[ 3.791091] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0020c6a4: 0xb0dd instead
[ 3.800655] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0020c6a8: 0xb0dd instead
[ 3.810148] jffs2: Further such events for this erase block will not be printed
[ 3.832903] sun4i_lradc_irq voltage = 11 349206!
[ 4.220014] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002bb7a0: 0x8cc2 instead
[ 4.229590] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002bb7a4: 0x0022 instead
[ 4.239081] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002bb7a8: 0x4815 instead
[ 4.248562] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002bb7ac: 0x00d2 instead
[ 4.258037] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002bb7b0: 0x0117 instead
[ 4.267514] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002bb7b4: 0xc076 instead
[ 4.276989] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002bb7bc: 0x4a24 instead
[ 4.286462] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002bb7c0: 0xb05d instead
[ 4.295936] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002bb7c4: 0xb0dd instead
[ 4.305400] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002bb7c8: 0xb0dd instead
[ 4.314872] jffs2: Further such events for this erase block will not be printed
[ 4.336784] sun4i_lradc_irq voltage = 13 412698!
[ 4.470704] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002fb578: 0x8cc2 instead
[ 4.480264] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002fb57c: 0x000b instead
[ 4.489754] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002fb580: 0xab01 instead
[ 4.499232] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002fb584: 0x0052 instead
[ 4.508710] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002fb588: 0x0234 instead
[ 4.518185] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002fb58c: 0xc076 instead
[ 4.527703] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002fb594: 0x4a24 instead
[ 4.537185] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002fb598: 0xb05d instead
[ 4.546662] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002fb59c: 0xb0dd instead
[ 4.556136] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x002fb5a0: 0xb0dd instead
[ 4.565599] jffs2: Further such events for this erase block will not be printed
[ 4.586773] sun4i_lradc_irq voltage = 11 349206!
[ 4.978032] jffs2: Empty flash at 0x003a72a4 ends at 0x003a72c4
[ 4.985009] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003a72c4: 0x61bb instead
[ 4.994577] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003a72c8: 0x61bb instead
[ 5.004067] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003a72cc: 0x61bb instead
[ 5.013547] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003a72d0: 0x43fe instead
[ 5.023024] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003a72d4: 0x0002 instead
[ 5.032499] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003a72d8: 0x0002 instead
[ 5.041973] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003a72e0: 0x32ac instead
[ 5.051448] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003a72e4: 0xe3f0 instead
[ 5.060922] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003a72e8: 0x0908 instead
[ 5.082843] sun4i_lradc_irq voltage = 11 349206!
[ 5.116234] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003b91a0: 0x401b instead
[ 5.125763] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003b91a4: 0xed28 instead
[ 5.135289] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003b91a8: 0xa043 instead
[ 5.144772] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003b91ac: 0xce94 instead
[ 5.154248] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003b91b0: 0x5015 instead
[ 5.163762] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003b91b4: 0x4f4a instead
[ 5.173245] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003b91b8: 0xa073 instead
[ 5.182721] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003b91bc: 0xbd28 instead
[ 5.192196] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003b91c0: 0x0403 instead
[ 5.201671] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003b91c4: 0x7d28 instead
[ 5.211144] jffs2: Further such events for this erase block will not be printed
[ 5.231273] sun4i_lradc_irq voltage = 11 349206!
[ 5.465645] jffs2: ofs 0x00423104 has already been seen. Skipping
[ 5.474218] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004240fc: 0x0379 instead
[ 5.483777] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00424100: 0x81ed instead
[ 5.493266] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00424108: 0x7ddc instead
[ 5.502745] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0042410c: 0x61bb instead
[ 5.512221] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00424110: 0x61bb instead
[ 5.521695] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00424114: 0x61bb instead
[ 5.531170] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00424118: 0x7800 instead
[ 5.540645] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0042411c: 0x0098 instead
[ 5.550119] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00424120: 0x0100 instead
[ 5.559593] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00424124: 0x0006 instead
[ 5.569064] jffs2: Further such events for this erase block will not be printed
[ 5.590631] sun4i_lradc_irq voltage = 11 349206!
[ 6.067337] jffs2: ofs 0x004f830c has already been seen. Skipping
[ 6.076997] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004f9304: 0xe5e6 instead
[ 6.088644] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004f9308: 0xbb8b instead
[ 6.098167] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004f930c: 0x9c04 instead
[ 6.107664] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004f9310: 0xbbf7 instead
[ 6.117159] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004f9314: 0xc8a0 instead
[ 6.126652] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004f9318: 0x7b92 instead
[ 6.136167] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004f931c: 0xda4f instead
[ 6.145652] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004f9320: 0x818b instead
[ 6.155153] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004f9324: 0xba30 instead
[ 6.164649] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004f9328: 0x1e34 instead
[ 6.174131] jffs2: Further such events for this erase block will not be printed
[ 6.196073] sun4i_lradc_irq voltage = 12 380952!
[ 7.003915] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00660000: 0x8cc2 instead
[ 7.013508] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00660004: 0x0006 instead
[ 7.023003] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00660008: 0xd858 instead
[ 7.032519] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0066000c: 0x8c42 instead
[ 7.042031] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00660010: 0x005f instead
[ 7.052610] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00660014: 0x066f instead
[ 7.064157] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00660018: 0x00aa instead
[ 7.073660] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0066001c: 0x0003 instead
[ 7.083158] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00660020: 0xc076 instead
[ 7.092652] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00660028: 0x4302 instead
[ 7.102133] jffs2: Further such events for this erase block will not be printed
[ 7.121811] sun4i_lradc_irq voltage = 11 349206!
[ 7.400354] jffs2: jffs2_scan_inode_node(): CRC failed on node at 0x006da568: Read 0xffffffff, calculated 0xf09e7845
[ 7.410972] jffs2: ofs 0x006da568 has already been seen. Skipping
[ 7.419403] jffs2: Empty flash at 0x006da56c ends at 0x006da588
[ 7.425321] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006da588: 0x61bb instead
[ 7.434817] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006da58c: 0x61bb instead
[ 7.444328] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006da590: 0x61bb instead
[ 7.453811] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006da594: 0x0b00 instead
[ 7.463287] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006da598: 0x00fa instead
[ 7.472799] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006da59c: 0x00fd instead
[ 7.482282] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006da5a0: 0x0006 instead
[ 7.491758] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006da5a4: 0x0c44 instead
[ 7.501235] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006da5a8: 0xc124 instead
[ 7.510710] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x006da5ac: 0x5e78 instead
[ 7.520182] jffs2: Further such events for this erase block will not be printed
[ 7.539759] sun4i_lradc_irq voltage = 11 349206!
[ 7.761107] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00740000: 0x8cc2 instead
[ 7.770680] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00740004: 0x0006 instead
[ 7.780174] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00740008: 0xd858 instead
[ 7.789652] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0074000c: 0x8c42 instead
[ 7.799129] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00740010: 0x8016 instead
[ 7.808605] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00740014: 0x9451 instead
[ 7.818081] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00740018: 0x00ab instead
[ 7.827556] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0074001c: 0x8124 instead
[ 7.837030] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00740020: 0xc076 instead
[ 7.846504] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00740028: 0x132a instead
[ 7.855976] jffs2: Further such events for this erase block will not be printed
[ 7.875682] sun4i_lradc_irq voltage = 11 349206!
[ 8.018658] jffs2: ofs 0x00781150 has already been seen. Skipping
[ 8.027261] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00782148: 0x0072 instead
[ 8.036758] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0078214c: 0x0100 instead
[ 8.046237] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00782150: 0x0006 instead
[ 8.055702] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00782154: 0x19ad instead
[ 8.065179] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00782158: 0xed84 instead
[ 8.074655] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0078215c: 0x5e78 instead
[ 8.084130] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00782160: 0x8080 instead
[ 8.093636] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00782164: 0x0c0c instead
[ 8.103155] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00782168: 0x1ca1 instead
[ 8.112638] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0078216c: 0x8d9e instead
[ 8.122113] jffs2: Further such events for this erase block will not be printed
[ 8.145200] sun4i_lradc_irq voltage = 11 349206!
[ 8.189205] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0079a2c8: 0x8cc2 instead
[ 8.198827] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0079a2cc: 0x8063 instead
[ 8.208322] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0079a2d0: 0x7164 instead
[ 8.217833] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0079a2d4: 0x80bd instead
[ 8.227348] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0079a2d8: 0x807e instead
[ 8.236859] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0079a2dc: 0xc076 instead
[ 8.247392] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0079a2e4: 0x702a instead
[ 8.258926] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0079a2e8: 0xb05d instead
[ 8.268423] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0079a2ec: 0xb0dd instead
[ 8.277918] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0079a2f0: 0xb0dd instead
[ 8.287399] jffs2: Further such events for this erase block will not be printed
[ 8.308386] jffs2: jffs2_scan_inode_node(): CRC failed on node at 0x007a00e4: Read 0xe1ed246a, calculated 0x1e76b02b
[ 8.318925] sun4i_lradc_irq voltage = 11 349206!
[ 8.326087] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x007a8144: 0xe940 instead
[ 8.335631] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x007a8148: 0x100d instead
[ 8.345157] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x007a814c: 0x4c77 instead
[ 8.354661] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x007a8150: 0x0100 instead
[ 8.364243] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x007a8154: 0xc36e instead
[ 8.387378] sun4i_lradc_irq voltage = 11 349206!
[ 8.497972] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x007da2d4: 0x8cc2 instead
[ 8.507532] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x007da2d8: 0x0022 instead
[ 8.517064] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x007da2dc: 0x4815 instead
[ 8.526547] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x007da2e0: 0x80bd instead
[ 8.536026] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x007da2e4: 0x032b instead
[ 8.545490] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x007da2e8: 0xc076 instead
[ 8.554966] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x007da2f0: 0x702a instead
[ 8.564441] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x007da2f4: 0xb05d instead
[ 8.573916] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x007da2f8: 0xb0dd instead
[ 8.583391] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x007da2fc: 0xb0dd instead
[ 8.592864] jffs2: Further such events for this erase block will not be printed
[ 8.613931] sun4i_lradc_irq voltage = 11 349206!
[ 8.887862] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0085746c: 0x8cc2 instead
[ 8.897428] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00857470: 0x8022 instead
[ 8.906921] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00857474: 0x4e3c instead
[ 8.916395] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00857478: 0x803d instead
[ 8.925871] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0085747c: 0x0628 instead
[ 8.935336] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00857480: 0xc076 instead
[ 8.944852] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00857488: 0x702a instead
[ 8.954335] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0085748c: 0xb05d instead
[ 8.963813] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00857490: 0xb0dd instead
[ 8.973288] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00857494: 0xb0dd instead
[ 8.982762] jffs2: Further such events for this erase block will not be printed
[ 9.004536] sun4i_lradc_irq voltage = 11 349206!
[ 9.321599] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x008e7470: 0x6001 instead
[ 9.331171] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x008e7474: 0x7005 instead
[ 9.340659] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x008e7478: 0x0006 instead
[ 9.350137] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x008e747c: 0x81f0 instead
[ 9.359656] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x008e7480: 0x3028 instead
[ 9.369140] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x008e7484: 0x0105 instead
[ 9.378616] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x008e7488: 0xffe8 instead
[ 9.388090] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x008e748c: 0x3028 instead
[ 9.397565] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x008e7490: 0x7105 instead
[ 9.407040] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x008e7494: 0x5001 instead
[ 9.416510] jffs2: Further such events for this erase block will not be printed
[ 9.438111] sun4i_lradc_irq voltage = 11 349206!
[ 9.735107] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0096a58c: 0x8cc2 instead
[ 9.744687] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0096a590: 0x801d instead
[ 9.754180] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0096a594: 0x1070 instead
[ 9.763659] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0096a598: 0x8040 instead
[ 9.773134] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0096a59c: 0x0060 instead
[ 9.782662] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0096a5a0: 0xc076 instead
[ 9.792149] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0096a5a8: 0x444e instead
[ 9.801627] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0096a5ac: 0xb05d instead
[ 9.811102] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0096a5b0: 0xb0dd instead
[ 9.820577] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0096a5b4: 0xb0dd instead
[ 9.830050] jffs2: Further such events for this erase block will not be printed
[ 9.852153] sun4i_lradc_irq voltage = 12 380952!
[ 10.351966] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a4a4d0: 0x8cc2 instead
[ 10.361544] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a4a4d4: 0x800b instead
[ 10.371036] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a4a4d8: 0x1833 instead
[ 10.380515] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a4a4dc: 0x8047 instead
[ 10.389990] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a4a4e0: 0x806c instead
[ 10.399466] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a4a4e4: 0xc076 instead
[ 10.408984] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a4a4ec: 0x1826 instead
[ 10.418466] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a4a4f0: 0xb05d instead
[ 10.427943] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a4a4f4: 0xb0dd instead
[ 10.437418] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a4a4f8: 0xb0dd instead
[ 10.446891] jffs2: Further such events for this erase block will not be printed
[ 10.469312] sun4i_lradc_irq voltage = 11 349206!
[ 10.545353] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a7013c: 0x8cc2 instead
[ 10.554920] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a70140: 0x8005 instead
[ 10.564441] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a70144: 0xec20 instead
[ 10.574039] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a70148: 0x8048 instead
[ 10.583524] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a7014c: 0x005e instead
[ 10.593002] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a70150: 0xc064 instead
[ 10.602576] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a70158: 0x3326 instead
[ 10.612061] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a7015c: 0xb05d instead
[ 10.621584] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a70160: 0xb0dd instead
[ 10.631105] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00a70164: 0xb0dd instead
[ 10.640609] jffs2: Further such events for this erase block will not be printed
[ 10.660710] sun4i_lradc_irq voltage = 11 349206!
[ 10.891651] jffs2: ofs 0x00ad52e4 has already been seen. Skipping
[ 10.900218] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00ad62dc: 0x7389 instead
[ 10.909783] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00ad62e0: 0x9cfc instead
[ 10.919272] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00ad62e4: 0x355a instead
[ 10.928750] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00ad62e8: 0x3d98 instead
[ 10.938224] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00ad62ec: 0x29ab instead
[ 10.947699] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00ad62f0: 0xd2af instead
[ 10.957174] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00ad62f4: 0xa8fd instead
[ 10.966648] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00ad62f8: 0xd99d instead
[ 10.976120] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00ad62fc: 0x0cb4 instead
[ 10.985584] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00ad6300: 0x6ed4 instead
[ 10.995059] jffs2: Further such events for this erase block will not be printed
[ 11.016160] sun4i_lradc_irq voltage = 11 349206!
[ 11.084405] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00af8434: 0x8cc2 instead
[ 11.093973] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00af8438: 0x801e instead
[ 11.103465] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00af843c: 0x3f1e instead
[ 11.112943] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00af8440: 0x00c9 instead
[ 11.122417] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00af8444: 0x8150 instead
[ 11.131919] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00af8448: 0xc076 instead
[ 11.141400] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00af8450: 0x326c instead
[ 11.150875] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00af8454: 0xb05d instead
[ 11.160350] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00af8458: 0xb0dd instead
[ 11.169824] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00af845c: 0xb0dd instead
[ 11.179296] jffs2: Further such events for this erase block will not be printed
[ 11.199746] sun4i_lradc_irq voltage = 11 349206!
[ 11.448925] jffs2: Empty flash at 0x00b68490 ends at 0x00b684b0
[ 11.454903] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00b684b0: 0x61bb instead
[ 11.464441] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00b684b4: 0x61bb instead
[ 11.473931] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00b684b8: 0x61bb instead
[ 11.483410] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00b684bc: 0x5500 instead
[ 11.492886] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00b684c0: 0x00ec instead
[ 11.502363] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00b684c4: 0x0100 instead
[ 11.511840] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00b684c8: 0x0006 instead
[ 11.521315] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00b684cc: 0x06d2 instead
[ 11.530790] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00b684d0: 0x588c instead
[ 11.540265] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00b684d4: 0x5e78 instead
[ 11.549737] jffs2: Further such events for this erase block will not be printed
[ 11.570823] sun4i_lradc_irq voltage = 11 349206!
[ 21.166671] VFS: Mounted root (jffs2 filesystem) on device 31:3.
[ 21.174228] devtmpfs: mounted
[ 21.178493] Freeing unused kernel memory: 1024K
[ 21.198403] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x0c22b8. {8cc2,f080,00008017,79a2fc58}
[ 21.209223] sun4i_lradc_irq voltage = 63 2000000!
[ 21.237691] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x0bd924. {8cc2,7081,00808000,9aff9c12}
[ 21.252289] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x0bc87c. {8cc2,7081,00808006,bf14c34e}
[ 21.263944] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x0bc650. {8cc2,7081,00808015,7d38bb3f}
[ 21.279719] jffs2: notice: (1) jffs2_get_inode_nodes: Wrong magic bitmask 0x0000 in node header at 0x0baf08.
[ 21.296626] jffs2: notice: (1) jffs2_get_inode_nodes: Wrong magic bitmask 0x0000 in node header at 0x0b91ec.
[ 21.320378] sun4i_lradc_irq voltage = 18 571428!
[ 21.336448] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x0b1874. {8cc2,7081,00800009,bba9602a}
[ 21.349071] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x0b1570: read 0xffffffff, calculated 0xab8eb808
[ 21.367616] jffs2: notice: (1) jffs2_get_inode_nodes: Wrong magic bitmask 0x0000 in node header at 0x0af1a8.
[ 21.390688] sun4i_lradc_irq voltage = 19 603174!
[ 21.405915] jffs2: notice: (1) jffs2_get_inode_nodes: Wrong magic bitmask 0x0000 in node header at 0x0a7d38.
[ 21.424060] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x0a59d0: read 0xffffffff, calculated 0x130fc27d
[ 21.438588] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x0a4a24: read 0xcc2a58fd, calculated 0x15ff82a4
[ 21.464903] sun4i_lradc_irq voltage = 19 603174!
[ 21.480640] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x09cb44. {8cc2,7081,00800022,cc9a4815}
[ 21.496574] jffs2: notice: (1) jffs2_get_inode_nodes: Wrong magic bitmask 0x0000 in node header at 0x09b110.
[ 21.512135] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x0993e4: read 0x832f4800, calculated 0x3c499f22
[ 21.529915] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x097160: read 0xffffffff, calculated 0x546c62b3
[ 21.549617] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x093bb4: read 0x364fbc11, calculated 0x8eac1e0f
[ 21.560434] sun4i_lradc_irq voltage = 11 349206!
[ 21.571902] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x09167c: read 0xffffffff, calculated 0x458ca19a
[ 21.586778] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x090534. {8cc2,7081,00800013,040d5751}
[ 21.597730] jffs2: Node totlen on flash (0xffffffff) != totlen from node ref (0x00000128)
[ 21.613546] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x08c584. {ffff,ffff,ffffffff,ffffffff}
[ 21.624368] sun4i_lradc_irq voltage = 11 349206!
[ 21.639070] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x0889b8: read 0xe94d79a4, calculated 0xe384ba1c
[ 21.670470] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x08014c: read 0x8cb9a0ca, calculated 0x1b9ef8b3
[ 21.683541] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x07fbf8. {8cc2,7081,0080001e,1bdf8c2c}
[ 21.698842] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x07e900: read 0xffffffff, calculated 0x4aaafcd0
[ 21.709662] sun4i_lradc_irq voltage = 11 349206!
[ 21.716999] jffs2: notice: (1) jffs2_get_inode_nodes: Wrong magic bitmask 0x0000 in node header at 0x07e2a0.
[ 21.750331] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x074644. {8cc2,7081,0080001b,ac81fc1e}
[ 21.769320] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x0718a0: read 0xc2d01fcc, calculated 0xe02cc193
[ 21.797681] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x06a924. {8cc2,7081,0080800c,5029a32a}
[ 21.810189] jffs2: notice: (58) read_dnode: node CRC failed on dnode at 0x99000c: read 0xdc2680e2, calculated 0xe8254409
[ 21.835978] sun4i_lradc_irq voltage = 11 349206!
[ 21.870807] jffs2: notice: (1) jffs2_get_inode_nodes: Wrong magic bitmask 0x0000 in node header at 0x05abd4.
[ 21.882394] jffs2: notice: (58) read_dnode: node CRC failed on dnode at 0x98fd58: read 0x91ddcb3a, calculated 0xde2cd5b3
[ 21.897885] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x0589f8: read 0xffffffff, calculated 0xa0cf9bd0
[ 21.908695] sun4i_lradc_irq voltage = 11 349206!
[ 21.921175] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x055c20: read 0xf52dd8d2, calculated 0xf4b6f1b6
[ 21.936623] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x05450c. {8cc2,7081,0080001a,7985185b}
[ 21.951828] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x053018. {8cc2,7081,0080801c,00b0f435}
[ 21.966514] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x05202c: read 0x64bda6ee, calculated 0x32f0bdcd
[ 21.990448] jffs2: notice: (1) jffs2_get_inode_nodes: Wrong magic bitmask 0x0000 in node header at 0x04c9cc.
[ 22.003668] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x04be78: read 0x42d6f509, calculated 0xddee9636
[ 22.014645] jffs2: Node totlen on flash (0x0080001a) != totlen from node ref (0x00000134)
[ 22.027522] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x04a870. {8cc2,7081,00800022,cc9a4815}
[ 22.038329] sun4i_lradc_irq voltage = 11 349206!
[ 22.049394] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x048a20: read 0xffffffff, calculated 0x77d66a2a
[ 22.079147] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x040d30: read 0xffffffff, calculated 0x3dad47b3
[ 22.120023] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x033ee8: read 0xaaba1f6e, calculated 0x4cf48d18
[ 22.137956] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x03190c. {ffff,ffff,ffffffff,ffffffff}
[ 22.156859] jffs2: notice: (1) jffs2_get_inode_nodes: Wrong magic bitmask 0x0000 in node header at 0x02eb58.
[ 22.172579] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x02cd68. {8cc2,7081,00808013,58d3e463}
[ 22.186059] jffs2: notice: (1) jffs2_get_inode_nodes: Wrong magic bitmask 0x0000 in node header at 0x02c6e0.
[ 22.199396] jffs2: notice: (1) jffs2_get_inode_nodes: Wrong magic bitmask 0x0000 in node header at 0x02b970.
[ 22.216265] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x0292d8: read 0x9234705, calculated 0xa4361300
[ 22.244071] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x022100. {8cc2,7081,0080801f,9205db5b}
[ 22.263529] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x01ed8c. {8cc2,7081,0080801e,47013f1e}
[ 22.280973] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x01ca5c. {8cc2,7081,00000074,4fa52e50}
[ 22.298746] jffs2: notice: (1) jffs2_get_inode_nodes: Wrong magic bitmask 0x0000 in node header at 0x01a7f0.
[ 22.315543] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x017f8c: read 0xffffffff, calculated 0xb9b2a6f
[ 22.341021] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x011d98. {8cc2,7081,00800004,a47bbb57}
[ 22.353518] jffs2: notice: (58) read_dnode: node CRC failed on dnode at 0x98da0c: read 0xffffffff, calculated 0xf5adcc23
[ 22.374649] jffs2: notice: (1) jffs2_get_inode_nodes: Wrong magic bitmask 0x0000 in node header at 0x00cfb8.
[ 22.384509] sun4i_lradc_irq voltage = 11 349206!
[ 22.389855] jffs2: notice: (58) jffs2_get_inode_nodes: Node header CRC failed at 0x98d9a4. {8cc2,7081,00000034,b989f54d}
[ 22.410562] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x0014a0: read 0xb688f34b, calculated 0xb6a738b1
[ 22.421380] sun4i_lradc_irq voltage = 11 349206!
[ 22.428653] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x0010e8: read 0xffffffff, calculated 0x7ff83b64
[ 22.444865] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x000bf740: read 0xdb96ecb4, calculated 0x56ec5c97.
[ 22.467446] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x000bbda8: read 0x34f3fd34, calculated 0x4d70874c.
[ 22.481903] jffs2: notice: (58) jffs2_get_inode_nodes: Node header CRC failed at 0x98d340. {8cc2,7081,0000003f,83b0716c}
[ 22.501614] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x000b8200: read 0x53c1e86f, calculated 0xc1971dc5.
[ 22.513377] sun4i_lradc_irq voltage = 11 349206!
[ 22.524590] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x000b6560: read 0x74910c4e, calculated 0xe85e87ac.
[ 22.576844] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x000a77d8: read 0x28b2839c, calculated 0x4d70874c.
[ 22.605463] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x000a1b20: read 0x7fdacfd7, calculated 0xb6e18d66.
[ 22.668317] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x0008d384: read 0xda91a43b, calculated 0x1ac79bbe.
[ 22.682797] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x0008cc74: read 0xb1a8f672, calculated 0xda628297.
[ 22.707034] sun4i_lradc_irq voltage = 12 380952!
[ 22.724331] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x0008422c: read 0xec7d2b2e, calculated 0xa499524e.
[ 22.740679] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x00083194: read 0x867943db, calculated 0x625412b7.
[ 22.803521] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x0006feac: read 0x6c5de4f, calculated 0x12d14834.
[ 22.816698] jffs2: notice: (58) read_dnode: node CRC failed on dnode at 0x98c3e4: read 0x6f78613a, calculated 0xe94edb4
[ 22.836082] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x0006ca08: read 0x6eaa6145, calculated 0xd65d9a2.
[ 22.847751] sun4i_lradc_irq voltage = 11 349206!
[ 22.867687] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x00067550: read 0x59a41497, calculated 0xd437ce4.
[ 22.883457] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x00066744: read 0x877a125d, calculated 0xf2ae01c7.
[ 22.921356] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x0005d50c: read 0x97040f2b, calculated 0xa63a84b5.
[ 22.938232] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x0005c130: read 0xa9597bed, calculated 0xbe2612ff.
[ 22.996379] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x0004dd40: read 0xf0a687d8, calculated 0x1d4fc3eb.
[ 23.042928] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x00040f90: read 0xffa059d9, calculated 0x8c26d8be.
[ 23.060183] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x0003f608: read 0x9d07b33b, calculated 0x7510aefe.
[ 23.090987] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x00038c38: read 0xb45f0203, calculated 0xd526385c.
[ 23.107204] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x00037c54: read 0xbcba8ac9, calculated 0x52f7fe23.
[ 23.121408] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x00037670: read 0xe4202fa9, calculated 0xf0f0a300.
[ 23.147204] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x00032b48: read 0xbe32d3e2, calculated 0x93537575.
[ 23.158967] sun4i_lradc_irq voltage = 11 349206!
[ 23.236949] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x00016c38: read 0xdf64cb72, calculated 0xe16e94fe.
[ 23.258570] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x00013b20: read 0xf1550a82, calculated 0x57d49e3c.
[ 23.281627] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x0000ff00: read 0xa4fcc682, calculated 0xbe2612ff.
[ 23.300409] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x0000de24: read 0xda9799da, calculated 0x4de9cd9d.
[ 23.315847] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x0000d218: read 0x5fa6d049, calculated 0xfb10b256.
[ 23.352026] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x16cfdc: read 0x8064dd7f, calculated 0x88614930
[ 23.367019] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x16c110. {8cc2,7081,0000807e,fc46fd06}
[ 23.385397] jffs2: notice: (1) jffs2_get_inode_nodes: Wrong magic bitmask 0x0000 in node header at 0x16a060.
[ 23.403836] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x168200: read 0xffffffff, calculated 0x47d41ade
[ 23.418612] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x167300: read 0x5b92c6fc, calculated 0x275e1e
[ 23.443569] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x161c4c: read 0x51e468fc, calculated 0x85c3f6ce
[ 23.458563] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x160934: read 0xc6bd9075, calculated 0x8da3750e
[ 23.472386] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x15fed4: read 0xffffffff, calculated 0x4f8caa0f
[ 23.486863] jffs2: notice: (1) read_dnode: node CRC failed on dnode at 0x15ef68: read 0xdeb3560b, calculated 0x15ae7ec9
[ 23.501622] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x15dd44. {8cc2,7081,00800022,cc9a4815}
[ 23.529621] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x153d88. {8cc2,7081,00800022,cc9a4815}
[ 23.547065] jffs2: notice: (1) jffs2_get_inode_nodes: Node header CRC failed at 0x151454. {8cc2,7081,00800022,cc9a4815}
[ 23.558033] jffs2: Node totlen on flash (0x00800022) != totlen from node ref (0x00000144)
[ 23.581991] sun4i_lradc_irq voltage = 11 349206!
[ 23.600991] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x00166ce4: read 0xc534a724, calculated 0xccd25876.
[ 23.626422] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x001624e4: read 0xfb73bffb, calculated 0xf33e2d79.
[ 23.680072] jffs2: notice: (1) check_node_data: wrong data CRC in data node at 0x001501c4: read 0x83fcf0ef, calculated 0xf33e2d79.
[ 23.718497] jffs2: Data CRC b62e8215 != calculated CRC 00000000 for node at 001516dc
[ 23.727064] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000007
[ 23.727064]
[ 23.736201] CPU: 0 PID: 1 Comm: init Not tainted 4.13.16-licheepi-zero #17
[ 23.743065] Hardware name: Allwinner sun8i Family
[ 23.747804] [<c010e5cc>] (unwind_backtrace) from [<c010b2b0>] (show_stack+0x10/0x14)
[ 23.755551] [<c010b2b0>] (show_stack) from [<c067897c>] (dump_stack+0x84/0x98)
[ 23.762775] [<c067897c>] (dump_stack) from [<c011b788>] (panic+0xdc/0x248)
[ 23.769649] [<c011b788>] (panic) from [<c011e2f4>] (do_exit+0xa68/0xa98)
[ 23.776346] [<c011e2f4>] (do_exit) from [<c011f170>] (do_group_exit+0x3c/0xd0)
[ 23.783562] [<c011f170>] (do_group_exit) from [<c0128e7c>] (get_signal+0x284/0x5cc)
[ 23.791212] [<c0128e7c>] (get_signal) from [<c010a76c>] (do_signal+0xc4/0x420)
[ 23.798430] [<c010a76c>] (do_signal) from [<c010ac6c>] (do_work_pending+0x94/0xa4)
[ 23.805994] [<c010ac6c>] (do_work_pending) from [<c01075d4>] (slow_work_pending+0xc/0x20)
[ 23.814174] Rebooting in 5 seconds..
总空间是32M-1M-64K-4M=0x1AF0000
mkfs.jffs2 -s 0x100 -e 0x10000 -p 0x1AF0000 -d rootfs/ -o jffs2.img
mkfs.jffs2 我是系统带的,没有特别去指定,这个不对吗?晕哥
[ 1.493757] #0: V3s Audio Codec
[ 1.512589] sun4i_lradc_irq voltage = 11 349206!
[ 1.523048] random: crng init done
[ 1.532108] sun4i_lradc_irq voltage = 11 349206!
[ 1.594310] jffs2: jffs2_scan_inode_node(): CRC failed on node at 0x00023180: Read 0xa0124471, calculated 0x208cb662
[ 1.604896] jffs2: Dirty space 0x808020 larger then free_size 0xce80 (wasted 0x0)
[ 1.612419] ------------[ cut here ]------------
[ 1.617033] kernel BUG at fs/jffs2/nodelist.c:670!
[ 1.621816] Internal error: Oops - BUG: 0 [#1] SMP ARM
[ 1.626947] Modules linked in:
[ 1.630005] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.13.16-licheepi-zero #18
[ 1.637300] Hardware name: Allwinner sun8i Family
[ 1.641998] task: c382c000 task.stack: c3830000
[ 1.646535] PC is at jffs2_scan_dirty_space+0xc0/0xc4
[ 1.651582] LR is at jffs2_scan_dirty_space+0xc0/0xc4
[ 1.656625] pc : [<c02fd0e0>] lr : [<c02fd0e0>] psr: 60000013
[ 1.662881] sp : c3831cd8 ip : 00000000 fp : c381c000
[ 1.668097] r10: 00001000 r9 : c3bee400 r8 : 00023180
[ 1.673313] r7 : c381c000 r6 : 00020000 r5 : 0000008b r4 : c3bf8068
[ 1.679830] r3 : c0a0c418 r2 : c0a0c418 r1 : 03596000 r0 : 00000045
[ 1.686348] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none
[ 1.693472] Control: 10c5387d Table: 4000406a DAC: 00000051
[ 1.699208] Process swapper/0 (pid: 1, stack limit = 0xc3830210)
[ 1.705205] Stack: (0xc3831cd8 to 0xc3832000)
[ 1.709557] 1cc0: c381c000 c0302930
[ 1.717725] 1ce0: c07f27dc c3bf8068 0000008b c030289c 208cb662 c3831d48 c381c000 00000000
[ 1.725892] 1d00: c3eef040 00023180 00000068 00000002 00001000 0000000a 00000000 00000000
[ 1.734059] 1d20: 0000e002 00001985 c0a6f9b8 ffffc000 c07f29b4 c3bf6030 0000000d c381c000
[ 1.742226] 1d40: 00000000 00001000 00001000 e0021985 0000013f c3bee400 c3bee400 c3bee4cc
[ 1.750394] 1d60: c3bee400 00000000 00000001 01f00003 00008000 00000001 c3bf4000 c0304d1c
[ 1.758561] 1d80: c0704a70 00000000 c0a65e5c 014280c0 3b9aca00 00000000 c382b588 c3bee400
[ 1.766729] 1da0: 00010000 c3be4400 01af0000 01f00003 00008000 00000001 c3bf4000 c0307208
[ 1.774897] 1dc0: c3be4400 00008000 c3b79400 00000000 01f00003 00008000 00000001 c04592ec
[ 1.783064] 1de0: c3b79400 c04586a4 c3bec780 c3bec780 00008000 00000000 c0a106c4 c045942c
[ 1.791232] 1e00: c0307730 0000000d c0a6caa8 c0a6caa8 c03073c4 c3bec780 00008000 c0a106c4
[ 1.799399] 1e20: c0a106c4 c03073dc c0307730 c0214a60 00000000 c01f92f8 c3bec780 00008000
[ 1.807567] 1e40: c3bcf300 c3bec780 00008000 c0a106c4 00000000 c0214cec c0a106c4 00000000
[ 1.815734] 1e60: c3bec780 c3bec740 00000020 c0217af8 00000000 00000051 c3805d10 c340d4c8
[ 1.823901] 1e80: 0000000a 00000000 0000000a c01c4cd0 0000000a c3bec780 c3bec740 00000000
[ 1.832069] 1ea0: c07d40d8 00008000 00008000 c07d40d4 c3bf4000 c0218900 00000000 c0a3db64
[ 1.840236] 1ec0: c3bf4000 c3f71e80 c3bf4006 c07d40d8 c093785c c0901148 00000000 ffffff9c
[ 1.848404] 1ee0: c3481000 00006000 00006180 00000000 ffffff9c c0204e8c c3805d10 c340d2a8
[ 1.856571] 1f00: 00000000 01f00003 c0a0668c c0a3db64 c0937838 000000c4 00000008 c093783c
[ 1.864739] 1f20: c3ef12c0 c09013c4 000000c4 c093785c c093786c 00000008 c0a3db64 c093786c
[ 1.872906] 1f40: 00000008 c0937838 000000c4 00000008 c093783c c090151c c0937838 000000c4
[ 1.881074] 1f60: 00000008 c0a3db40 c0a3db40 c0900e20 00000007 00000007 00000000 c09005ac
[ 1.889240] 1f80: 00000000 00000000 c068ceac 00000000 00000000 00000000 00000000 00000000
[ 1.897407] 1fa0: 00000000 c068ceb4 00000000 c0107638 00000000 00000000 00000000 00000000
[ 1.905574] 1fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.913740] 1fe0: 00000000 00000000 00000000 00000000 00000013 00000000 2215a9e0 000000c9
[ 1.921930] [<c02fd0e0>] (jffs2_scan_dirty_space) from [<c030289c>] (jffs2_scan_medium+0xe30/0x100c)
[ 1.931059] [<c030289c>] (jffs2_scan_medium) from [<c0304d1c>] (jffs2_do_mount_fs+0x164/0x754)
[ 1.939665] [<c0304d1c>] (jffs2_do_mount_fs) from [<c0307208>] (jffs2_do_fill_super+0xc4/0x234)
[ 1.948360] [<c0307208>] (jffs2_do_fill_super) from [<c04592ec>] (mount_mtd_aux.constprop.0+0x80/0xc8)
[ 1.957660] [<c04592ec>] (mount_mtd_aux.constprop.0) from [<c045942c>] (mount_mtd+0xf8/0x158)
[ 1.966178] [<c045942c>] (mount_mtd) from [<c03073dc>] (jffs2_mount+0x18/0x20)
[ 1.973398] [<c03073dc>] (jffs2_mount) from [<c01f92f8>] (mount_fs+0x14/0xa4)
[ 1.980533] [<c01f92f8>] (mount_fs) from [<c0214cec>] (vfs_kern_mount+0x48/0x100)
[ 1.988013] [<c0214cec>] (vfs_kern_mount) from [<c0217af8>] (do_mount+0x154/0xbc4)
[ 1.995577] [<c0217af8>] (do_mount) from [<c0218900>] (SyS_mount+0x8c/0xb4)
[ 2.002539] [<c0218900>] (SyS_mount) from [<c0901148>] (mount_block_root+0x100/0x25c)
[ 2.010365] [<c0901148>] (mount_block_root) from [<c09013c4>] (mount_root+0x120/0x128)
[ 2.018276] [<c09013c4>] (mount_root) from [<c090151c>] (prepare_namespace+0x150/0x194)
[ 2.026272] [<c090151c>] (prepare_namespace) from [<c0900e20>] (kernel_init_freeable+0x1bc/0x1cc)
[ 2.035140] [<c0900e20>] (kernel_init_freeable) from [<c068ceb4>] (kernel_init+0x8/0x108)
[ 2.043316] [<c068ceb4>] (kernel_init) from [<c0107638>] (ret_from_fork+0x14/0x3c)
[ 2.050880] Code: e591301c e34c007f e1a0100c ebf98aff (e7f001f2)
[ 2.056968] ---[ end trace 97129af179694986 ]---
[ 2.061746] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 2.061746]
[ 2.070884] Rebooting in 5 seconds..
我使用tf卡启动 v3s,然后在v3s上挂载 mtdblock3 发现能挂载成功,文件也是对,就是spi中启动时不成功,不知道 为啥
# mount -t jffs2 /dev/mtdblock3 /mnt/c
# cd /mnt/cc
# ls
bin dev etc lib lib32 linuxrc media mnt opt proc root run sbin sys tmp usr var
卡在start kernel
U-Boot 2017.01-rc2-00073-gdd6e874-dirty (Jul 15 2018 - 23:15:30 +0800) Allwinner Technology
Model: Lichee Pi Zero
DRAM: 64 MiB
MMC: SUNXI SD/MMC: 0
SF: Detected mx25l25635f with page size 256 Bytes, erase size 64 KiB, total 32 MiB
In: serial@01c28000
Out: serial@01c28000
Err: serial@01c28000
Net: No ethernet found.
No controllers found
device 0 offset 0x110000, size 0x600000
SF: 6291456 bytes @ 0x110000 Read: OK
## Flattened Device Tree blob at 41000000
Booting using the fdt blob at 0x41000000
Loading Device Tree to 42dfa000, end 42dffd8e ... OK
